Having read through the thread, it seems I may have fallen prey to the issues with new eMMCs...? There was a recent hardware BOM change and the new part is https://www.samsung.com/semiconductor/estorage/emmc/KLM8G1GETF-B041/. This is not getting detected.
Output is as follows:
U-Boot 2016.09-armbian-fel-mass-storage-dirty (Sep 28 2016 - 12:21:11 +0300) Allwinner Technology
CPU:   Allwinner H3 (SUN8I 1680)
Model: Xunlong Orange Pi One
DRAM:  1 GiB
Using default environment
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
Hit any key to stop autoboot:  0
(FEL boot)
## Loading init Ramdisk from Legacy Image at 43300000 ...
   Image Name:   uInitrd
   Image Type:   ARM Linux RAMDisk Image (gzip compressed)
   Data Size:    2229486 Bytes = 2.1 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
Using machid 0x1029 from environment
Starting kernel ...
[sun8i_fixup]: From boot, get meminfo:
        Start:  0x40000000
ion_carveout reserve: 160m@0 256m@0 130m@1 200m@1
ion_reserve_select: ion chipid  [0x2004620!
ion_reserve_common: ion reserve: [0x50000000, 0x60000000]!
Loading, please wait...
Begin: Running /scripts/init-premount ...
Starting g_mass_storage script
https://github.com/zador-blood-stained/fel-mass-storage
No SD/eMMC device found
done.
Begin: Running /scripts/local-premount ... done.
Begin: Will now check  file system ... fsck from util-linux 2.25.2
Checking all file systems.
done.
Usage: mount [-r] [-w] [-o options] [-t type] [-f] [-i] [-n] device directory
done.
Target filesystem doesn't have requested /sbin/init.
Begin: Running /scripts/init-bottom ... mount: No such file or directory
done.
Could not copy file: No such file or directory
No init found. Try passing init= bootarg.
Rebooting automatically due to panic= boot argument
Am I understanding the issue correctly? And if so, this means the kernel and uInit will have to be re-done?
If its at all material, the previous part was Hynix H26M31003GMR which was being shown as an SD card...
Edited by Tido
added spoiler
More likely u-boot needs to have support for this chip.
yes, I read that thread from your git but am not 100% clear.
This means I clone the git and cross compile the kernel, then make that adjustment and retrieve the resultant uImage? And that goes in place of zImage in the current tool package?
Assuming that I understand this correctly and this allows me to get the MMC on USB to clone my old image, does it also mean that the image should be fine at that point?
As I wrote in the issue, you need zImage and matching uInitrd with a custom premount script from the repository. There are no guides on how exactly to create them.
The only thing that makes it easier is that mentioned eMMC CSD revision patch is already included in the Armbian patchset, but this assumes that CSD revision 8 is the problem which is impossible to confirm without kernel logs.
