voltagex Posted November 27, 2022 Posted November 27, 2022 https://gist.github.com/voltagex/1dae7c0bf153c76a49bea407f932be69 if anyone's interested. 0 Quote
Butch Driver Posted March 1 Posted March 1 I made some progress with booting Armbian from USB on my Mochabin. I've been teaching myself U-boot cli. I downloaded Armbian_community_24.5.0-trunk.93_Espressobin_jammy_current_5.15.149.img.xz and used dd to write it to a USB stick. Marvell>> usb start starting USB... USB0: Register 2000120 NbrPorts 2 Starting the controller USB XHCI 1.00 USB1: Register 2000120 NbrPorts 2 Starting the controller USB XHCI 1.00 scanning bus 0 for devices... 4 USB Device(s) found scanning bus 1 for devices... 1 USB Device(s) found scanning usb for storage devices... 1 Storage Device(s) found Marvell>> usb dev IDE device 0: Vendor: Rev: PMAP Prod: USB DISK 3.0 Type: Removable Hard Disk Capacity: 29604.0 MB = 28.9 GB (60628992 x 512) Marvell>> usb part Partition Map for USB device 0 -- Partition Type: DOS Part Start Sector Num Sectors UUID Type 1 8192 4644864 1806f7be-01 83 Then to boot from the USB I use: setenv bootargs 'console=ttyS0,115200' 'earlycon=uart8250,mmio32,0xf0512000' 'root=/dev/sdb1' 'rootfstype=ext2' rootwait setenv bootcmd 'true; usb start; ext2load usb 0:1 $kernel_addr_r $image_name; ext2load usb 0:1 $fdt_addr_r boot/dtb/marvell/armada-7040-db.dtb; booti $kernel_addr_r - $fdt_addr_r' boot The image boots but the kernel reports that it is waiting for /dev/sdb1 What should: root= be set to, please? Thanks, Butch xx 0 Quote
Butch Driver Posted March 1 Posted March 1 I put all the console output in this gist: https://gist.github.com/kennethstailey/7087c6105d5f2d3b5e1726e07e0a34c8 0 Quote
SteeMan Posted March 1 Posted March 1 In general I would expect the root parameter to look like: root=UUID=997635c3-00f2-4eca-aa3d-1bf187651ea3 or root=LABEL=armbi_root (obviously with the correct LABEL or UUID for your root partition) 0 Quote
Butch Driver Posted March 2 Posted March 2 I put all the console output in this gist: https://gist.github.com/kennethstailey/7087c6105d5f2d3b5e1726e07e0a34c8 0 Quote
SteeMan Posted March 2 Posted March 2 Why did you repost the log? Have you changed your root= parameter as was suggested? 0 Quote
Butch Driver Posted March 2 Posted March 2 Yes, I said that I used a number of different root= I reposted what I think is the most important part of the log. 0 Quote
Butch Driver Posted March 2 Posted March 2 My next step is to get Kevin's and Lynix's kernel config files off of Github and compare it to what's in the build system. 0 Quote
