Hello I just installed armbian (Gnome) on my NVME and all seems to work great (without SD card).
So, the first issue I have is the resolution of the screen.
I add 2560x1440 (1920x1080 was the maximum before) but the test in this mode not working.
I think the cause is than I copy/paste the mode from a post on internet.
In fact, cvt is not installed and impossible to calculate mysel the vesa CVT modline.
How can I install CVT ?
bash: cvt: command not found
Thanks a lot
Anakin
9 часов назад, Anakin сказал:
sudo apt install apt-file
sudo apt-file update
apt-file search /usr/bin/cvt
gnustep-base-runtime: /usr/bin/cvtenc
sudo: /usr/bin/cvtsudoers
sudo-ldap: /usr/bin/cvtsudoers
xcvt: /usr/bin/cvt
apt search xcvt
Sorting... Done
Full Text Search... Done
libxcvt-dev/jammy 0.1.1-3 amd64
  VESA CVT standard timing modelines generator -- development files
libxcvt0/jammy 0.1.1-3 amd64
  VESA CVT standard timing modelines generator -- shared library
wcslib-tools/jammy 7.7+ds-1 amd64
  Command line tools utilizing wcslib
xcvt/jammy 0.1.1-3 amd64
All working but impossible to start cvt
anakin@rock-5b:~$ /usr/bin/cvt
bash: /usr/bin/cvt: No such file or directory
anakin@rock-5b:~$ sudo cvt
sudo: cvt: command not found
Edit : it's good
sudo apt-get install xcvt.
But Impossible to stay in this mode. Just 0,1 seconde and the board switch to the older 1920x1080
Thanks for all !
Edited by Anakin
