Marc059 Posted December 14, 2022 Posted December 14, 2022 Hello, I have a problem compiling the TBS driver. mkdir tbsdriver cd tbsdriver git clone https://github.com/tbsdtv/media_build.git git clone --depth=1 https://github.com/tbsdtv/linux_media.git -b latest ./media cd media_build make dir DIR=../media make alliesconfig make -j4 sudo make install" Indeed under Armbian (Linux rock-5b 5.10.72-rockchip-rk3588), warnings during compilation are blocking, unlike the Ubuntu system (where everything passes). /home/marc/Prog/tbsdriver/media_build/v4l/av201x.c:232:22: warning: unused variable 'priv' [-Wunused-variable] error, forbidden warning:av201x.c:232 232 | struct av201x_priv *priv = fe->tuner_priv; | ^~~~ make[3]: *** [scripts/Makefile.build:273: /home/marc/Prog/tbsdriver/media_build/v4l/av201x.o] Error 1 I tried several options ex: -Wno-errors but none worked. When I try to edit the file by commenting out the line, the system puts back the original file. I've had this problem for two days. Thanks for your help. Sincerely Marc. 0 Quote
Igor Posted December 14, 2022 Posted December 14, 2022 13 minutes ago, Marc059 said: Indeed under Armbian (Linux rock-5b 5.10.72-rockchip-rk3588), warnings during compilation are blocking, unlike the Ubuntu system (where everything passes). You are saying Armbian is a problem ? https://docs.armbian.com/#what-is-armbian All those things are clear? https://docs.armbian.com/User-Guide_FAQ/ 0 Quote
