spirake Posted December 19, 2022 Posted December 19, 2022 I installed the latest version on an armbian sd and after the update and upgrade it doesn't start anymore. At the end, the terminal shows the following:ln: failed to create hard link '/boot/initrd.img-6.1.0-meson64.dpkg-bak' => '/boot/initrd.img-6.1.0-meson64': Operation not permitted update-initramfs: Generating /boot/initrd.img-6.1.0-meson64 The version used is from here:https://github.com/armbian/community-aml-s9xx-box📁📁kinetic-edge-xfce-1319M-6.1.0. I am also attaching a picture. Can someone help me what I need to do to be able to update && upgrade?
SteeMan Posted December 19, 2022 Posted December 19, 2022 You have provided very little basic information about your situation. Lets start with the basics: What box do you have, what dtb are you using, what u-boot.ext are you using. Did the box originally work from the sdcard? What exact steps did you do between when it was working and when you get the error above?
spirake Posted December 19, 2022 Author Posted December 19, 2022 R-TV BOX S10 CPU:Amlogic S912 Octa core ARM Cortex-A53 CPU 64 biti GPU:ARM Mali-T820MP3 GPU up to 750MHz (DVFS) RAM: 3GB DDR4 ROM: 64GB eMMC DTB :meson-gxm-q200 The box started, it works, but it asked for an update. I performed the upgrade and after the restart it remained as in the attached image. The installation was done on the sd card. I wrote one more time and after the update and upgrade the same thing happened. This is the image used: Armbian_23.02.0-trunk_Aml-s9xx-box_kinetic_edge_6.1.0_xfce_desktop.img On another sd card I installed the older image which works without problems after the upgrade with the same dtb Armbian_20.10_Arm-64_bullseye_current_5.9.0_desktop I write the images with balenaEtcher to check them
SteeMan Posted December 19, 2022 Posted December 19, 2022 How are you doing the update/upgrade? command line or gui? The error screen you show above is interesting as it is saying it can't find the mmcblk1p1 (which should be the root partition on the sd card). Can you provide a directory listing of the contents of /boot after the upgrade, but before rebooting. Also could you show the contents of your extlinux.conf file (again after upgrade but before rebooting). Then it would also be helpful to have the full contents of the uboot display during the reboot (not just the end of the output you have screenshot above).
SteeMan Posted December 20, 2022 Posted December 20, 2022 moved thread to the correct forum and modified title to include the box name
spirake Posted December 30, 2022 Author Posted December 30, 2022 I identified the reason why the box didn't start after the upgrade. At first when I wrote the image on the card, I used (meson-gxm-q200-mod.dtb) and it detected bluetooth with this dtb. After the upgrade the dtb was changed - the one without mode, respectively (meson-gxm-q200.dtb) and it no longer corresponded to the one written in extlinux.conf and the bluetooth was no longer connected either.
SteeMan Posted December 30, 2022 Posted December 30, 2022 If you are going to use a custom dtb you need to put it in the /boot directory and make the extlinux.conf point to it there. The contents of /boot/dtb are kernel version specific and when the kernel is upgraded they are replaced with newer versions. The whole directory is replaced so any customizations you place in there will be lost.
spirake Posted December 31, 2022 Author Posted December 31, 2022 Thanks for the reply. What should I do to use the same custom dtb all the time?
spirake Posted December 31, 2022 Author Posted December 31, 2022 I saw that there are no ath10k drivers in the lib/firmware, can they be included in the kernel?
SteeMan Posted December 31, 2022 Posted December 31, 2022 48 minutes ago, spirake said: What should I do to use the same custom dtb all the time? I tried to already answer that question, but perhaps I wasn't specific enough: 16 hours ago, SteeMan said: If you are going to use a custom dtb you need to put it in the /boot directory and make the extlinux.conf point to it there. You need to place the custom dtb outside the /boot/dtb directory in /boot directly. Then you extlinux.conf reference would look like: FDT /<custom file>.dtb
SteeMan Posted December 31, 2022 Posted December 31, 2022 23 minutes ago, spirake said: I saw that there are no ath10k drivers in the lib/firmware, can they be included in the kernel? Try installing the armbian-firmware-full package
spirake Posted December 31, 2022 Author Posted December 31, 2022 Thanks, I did that and it works, but it doesn't change after the upgrade?
SteeMan Posted December 31, 2022 Posted December 31, 2022 1 minute ago, spirake said: Thanks, I did that and it works, but it doesn't change after the upgrade? Correct
spirake Posted January 12, 2023 Author Posted January 12, 2023 Hello Please help me with an advice how I can fix the system errors. I have 3 errors that are degraded: sorin@aml-s9xx-box:~$ systemctl --failed UNIT LOAD ACTIVE SUB DESCRIPTION ● motd-news.service loaded failed failed Message of the Day ● smartmontools.service loaded failed failed Self Monitoring and Reporting Technology (SMART) Daemon ● speech-dispatcherd.service loaded failed failed Speech-Dispatcher, common interface to speech synthesizers LOAD = Reflects whether the unit definition was properly loaded. ACTIVE = The high-level unit activation state, i.e. generalization of SUB. SUB = The low-level unit activation state, values depend on unit type. 3 loaded units listed.
SteeMan Posted January 15, 2023 Posted January 15, 2023 I would suggest looking at log files and trying to figure out why these services are failing.
