sp595 Posted December 24, 2022 Posted December 24, 2022 When starting orange pi, it happens that not all the RAM is available. That is, the orange pi has 2 GB of RAM and it is written that there is only 1 GB of RAM. This often happens when restarting using the reboot command. If you turn off the power and reconnect, this problem appears much less often. When 2 gb is available: https://paste.armbian.com/asatebupuw When 1 gb is available: https://paste.armbian.com/bohapeyahi Reveal hidden contents Reveal hidden contents 0 Quote
going Posted December 24, 2022 Posted December 24, 2022 On 12/24/2022 at 9:58 AM, sp595 said: This often happens when restarting using the reboot command. If you turn off the power and reconnect, this problem appears much less often. Expand Very strange behavior. But unfortunately this happens. This is similar to the fact that one memory chip soldered to the device cannot work at a frequency \ mode at which the other chip works normally. A possible solution to the problem is to experimentally select the operating modes on which both chips will function normally. Try to register this in the device tree overlay file. This will only be your personal file. But unfortunately I am not an assistant in this matter. 0 Quote
sp595 Posted December 24, 2022 Author Posted December 24, 2022 I'm unlikely to be able to do it. I'm not strong enough in linux to understand how it works. Is it a marriage? 0 Quote
going Posted December 25, 2022 Posted December 25, 2022 On 12/24/2022 at 5:23 PM, sp595 said: Is it a marriage? Expand It can't be called a marriage. The device board was tested before sale. The test image did not register an error and the device was sold. I have 4 RAM bars of different manufacturers on an x86 machine. All of them say that they work at 1800 Mhz, but one bar works stably only at 1600. I just set this frequency and enjoy stable operation. You can set the value of the variable "verbosity=7" in the file "/boot/armbianEnv.txt " and see what the UART output shows. When you can catch a stable value and the value of the frequency at which one memory chip fails, then write here and call me like this: @going 0 Quote
sp595 Posted December 26, 2022 Author Posted December 26, 2022 is it possible to somehow output the output to a file? 0 Quote
sp595 Posted December 26, 2022 Author Posted December 26, 2022 https://paste.armbian.com/qerihavapi This is a link to logs with verbosity=7. I didn't find any clue related to RAM. Maybe it will give you something 0 Quote
going Posted December 26, 2022 Posted December 26, 2022 @sp595 UART output shows? If this is not possible for you, then publish the inscriptions on the memory chips. 0 Quote
sp595 Posted December 26, 2022 Author Posted December 26, 2022 This is unlikely to work, the case + radiator is on memory. Only if tomorrow 0 Quote
going Posted December 26, 2022 Posted December 26, 2022 If the radiator is not glued, but screwed with a screw and thermal paste. If you glued it, then don't touch it. 0 Quote
going Posted December 27, 2022 Posted December 27, 2022 If this is your device, then there is only one RAM chip on it. I find it difficult to guess anything. 0 Quote
lissizza Posted February 21, 2023 Posted February 21, 2023 I have a very similar problem, I think, I bought Orange Pi 3 LTS with 2GB memory in the description, but only 1GB (984MB) is available. I don't know if is it a hardware or software problem. Could you help me? Was not able to upload a photo, there is the next text on it: SEC 122 K4E6E30 4EDEGCG JIEV599N 0 Quote
going Posted February 27, 2023 Posted February 27, 2023 On 2/21/2023 at 1:03 PM, lissizza said: SEC 122 K4E6E30 4EDEGCG JIEV599N Expand These inscriptions on this chip? Do I understand correctly? 0 Quote
ALIGMSTEN Posted February 27, 2023 Posted February 27, 2023 Hello, Interesting, have just got one, for my own research purposes and not yet seen this behavior. IMAGE: Armbian 22.11.4 Bullseye with Linux 5.15.80-sunxi64. CORRECT: @going except I have different inscriptions. SEC 113 K4E6E30 4EDEGCG JICVP59L INFO: f.y.i Reveal hidden contents login as: alistair alistair@10.0.0.9's password: ___ ____ _ _____ _ _____ ____ / _ \| _ \(_) |___ / | | |_ _/ ___| | | | | |_) | | |_ \ | | | | \___ \ | |_| | __/| | ___) | | |___| | ___) | \___/|_| |_| |____/ |_____|_| |____/ Welcome to Armbian 22.11.4 Bullseye with Linux 5.15.80-sunxi64 System load: 32% Up time: 0 min Memory usage: 7% of 1.94G IP: 10.0.0.9 CPU temp: 57°C Usage of /: 8% of 29G RX today: 1.1 MiB [ Kernel and firmware upgrades disabled: armbian-config ] Last check: 2023-02-27 10:33 Last login: Mon Feb 27 10:24:07 2023 from 10.0.0.7 alistair@orangepi3-lts:~$ free total used free shared buff/cache available Mem: 2037180 134800 1720432 3420 181948 1829920 Swap: 1018588 0 1018588 alistair@orangepi3-lts:~$ grep MemTotal /proc/meminfo MemTotal: 2037180 kB alistair@orangepi3-lts:~$ cat /proc/meminfo MemTotal: 2037180 kB MemFree: 1719172 kB MemAvailable: 1829680 kB Buffers: 14780 kB Cached: 153988 kB SwapCached: 0 kB Active: 111560 kB Inactive: 98536 kB Active(anon): 636 kB Inactive(anon): 44120 kB Active(file): 110924 kB Inactive(file): 54416 kB Unevictable: 0 kB Mlocked: 0 kB SwapTotal: 1018588 kB SwapFree: 1018588 kB Dirty: 0 kB Writeback: 0 kB AnonPages: 41348 kB Mapped: 41048 kB Shmem: 3416 kB KReclaimable: 14240 kB Slab: 48668 kB SReclaimable: 14240 kB SUnreclaim: 34428 kB KernelStack: 2672 kB PageTables: 1544 kB NFS_Unstable: 0 kB Bounce: 0 kB WritebackTmp: 0 kB CommitLimit: 2037176 kB Committed_AS: 167052 kB VmallocTotal: 133143592960 kB VmallocUsed: 24636 kB VmallocChunk: 0 kB Percpu: 1408 kB AnonHugePages: 0 kB ShmemHugePages: 0 kB ShmemPmdMapped: 0 kB FileHugePages: 0 kB FilePmdMapped: 0 kB CmaTotal: 131072 kB CmaFree: 128752 kB HugePages_Total: 0 HugePages_Free: 0 HugePages_Rsvd: 0 HugePages_Surp: 0 Hugepagesize: 2048 kB Hugetlb: 0 kB alistair@orangepi3-lts:~$ free -m; top; dmesg | grep Memory; grep MemTotal /proc/meminfo total used free shared buff/cache available Mem: 1989 131 1679 3 178 1787 Swap: 994 0 994 top - 10:39:31 up 6 min, 1 user, load average: 1.00, 0.82, 0.42 Tasks: 138 total, 1 running, 137 sleeping, 0 stopped, 0 zombie %Cpu(s): 0.1 us, 0.0 sy, 0.0 ni, 99.9 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 1989.4 total, 1678.4 free, 132.1 used, 179.0 buff/cache MiB Swap: 994.7 total, 994.7 free, 0.0 used. 1786.5 avail Mem PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 1 root 20 0 164992 9932 7216 S 0.0 0.5 0:02.97 systemd 2 root 20 0 0 0 0 S 0.0 0.0 0:00.01 kthreadd 3 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 rcu_gp 4 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 rcu_par+ 5 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 slub_fl+ 6 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 netns 10 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 mm_perc+ 11 root 20 0 0 0 0 S 0.0 0.0 0:00.00 rcu_tas+ 12 root 20 0 0 0 0 S 0.0 0.0 0:00.07 ksoftir+ 13 root 20 0 0 0 0 I 0.0 0.0 0:00.07 rcu_sch+ 14 root rt 0 0 0 0 S 0.0 0.0 0:00.00 migrati+ 15 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/0 16 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/1 17 root rt 0 0 0 0 S 0.0 0.0 0:00.00 migrati+ 18 root 20 0 0 0 0 S 0.0 0.0 0:00.02 ksoftir+ 21 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/2 22 root rt 0 0 0 0 S 0.0 0.0 0:00.00 migrati+ MemTotal: 2037180 kB alistair@orangepi3-lts:~$ 0 Quote
lissizza Posted February 27, 2023 Posted February 27, 2023 @going yes, from the top to the bottom 0 Quote
going Posted February 27, 2023 Posted February 27, 2023 Different series of the same chip. It is sad. I'll think about what can be done. 1 Quote
lissizza Posted February 27, 2023 Posted February 27, 2023 Quote orangepi@orangepi3-lts:~/robo$ free -m total used free shared buff/cache available Mem: 980 358 191 103 430 426 Swap: 490 331 159 orangepi@orangepi3-lts:~/robo$ grep MemTotal /proc/meminfo MemTotal: 1003912 kB orangepi@orangepi3-lts:~/robo$ cat /proc/meminfo MemTotal: 1003912 kB MemFree: 196156 kB MemAvailable: 436536 kB Buffers: 22976 kB Cached: 290224 kB SwapCached: 1272 kB Active: 149996 kB Inactive: 216188 kB Active(anon): 40600 kB Inactive(anon): 118288 kB Active(file): 109396 kB Inactive(file): 97900 kB Unevictable: 101656 kB Mlocked: 64 kB SwapTotal: 501952 kB SwapFree: 163008 kB Dirty: 0 kB Writeback: 0 kB AnonPages: 153532 kB Mapped: 64900 kB Shmem: 105876 kB KReclaimable: 127292 kB Slab: 173496 kB SReclaimable: 127292 kB SUnreclaim: 46204 kB KernelStack: 4592 kB PageTables: 7584 kB NFS_Unstable: 0 kB Bounce: 0 kB WritebackTmp: 0 kB CommitLimit: 1003908 kB Committed_AS: 2064648 kB VmallocTotal: 133143592960 kB VmallocUsed: 23012 kB VmallocChunk: 0 kB Percpu: 1696 kB AnonHugePages: 0 kB ShmemHugePages: 0 kB ShmemPmdMapped: 0 kB FileHugePages: 0 kB FilePmdMapped: 0 kB CmaTotal: 131072 kB CmaFree: 2860 kB HugePages_Total: 0 HugePages_Free: 0 HugePages_Rsvd: 0 HugePages_Surp: 0 Hugepagesize: 2048 kB Hugetlb: 0 kB Expand 0 Quote
going Posted February 27, 2023 Posted February 27, 2023 @lissizza Which image is currently running on your device. Why am I asking? Whether some other was downloaded, for example from the manufacturer's website or another Armbian edition. 0 Quote
lissizza Posted February 27, 2023 Posted February 27, 2023 (edited) @going there was Armbian_22.05.0-trunk_Orangepi3-lts_focal_edge_5.16.19_xfce_desktop.img first (because the image of 22.11.1 downloaded from the official Orange Pi 3 LTS page didn't start, both cli and desktop versions, and I hadn't USB-to-TTL interface). And then I tried Orangepi3-lts_3.0.8_debian_bullseye_desktop_xfce_linux5.16.17 image from the Orange Pi website n the hope that it will help to fix the memory problem, but it didn't, all the same. Edited February 27, 2023 by lissizza adding info 0 Quote
going Posted February 27, 2023 Posted February 27, 2023 Maybe the android version will work. I only need a dtb blob from the working version. These chips, according to the data that I found, can work with a voltage of a little more or less. The question is the exact figure. If we have any working image. I'll pull the information out of it and assemble a working kernel for you. 0 Quote
lissizza Posted February 27, 2023 Posted February 27, 2023 @going There was a working Android pre-installed on my Orange Oi on eMMS, but I didn't see how much memory it shows until I rewrote it with Linux The Orangepi3-lts_3.0.8_debian_bullseye_desktop_xfce_linux5.16.17 is working now. The official distro of the Orange Pi team is here https://drive.google.com/file/d/1A9-Y6O_1pJELM2GM2D7cJ110Z3wfh72L/view?usp=share_link I tried now to extract all the dtb and decompiled them into dts files, and now I don't know where I can find the memory section Is it in `36_dtbdump_,OrangePi_3_LTS.dts`? If it is hard to tell I leave it to you Thank you for helping! I have also some additional problems. 1. After rebooting, the computer won't boot immediately. I need to turn off the power for about 1 minute and only after that, I can boot. 2. I couldn't be able to start the graphics desktop with my 4K display. I added the string extraargs=video=HDMI-A-1:1920x1080@60 to my boot configuration file and after that, I can see the console boot log messages, but it seems I cannot switch to another graphic mode with xrandr orangepi@orangepi3-lts:/$ xrandr --output HDMI-1 --mode 2560x1440 --rate 60 xrandr: Configure crtc 0 failed The same with other resolutions. I tried also changing the string disp_mode in the boot config file, but it didn't help. 0 Quote
going Posted February 27, 2023 Posted February 27, 2023 On 2/27/2023 at 12:51 PM, lissizza said: The Orangepi3-lts_3.0.8_debian_bullseye_desktop_xfce_linux5.16.17 is working now Expand And can you see 2GB of memory? On 2/27/2023 at 12:51 PM, lissizza said: I tried now to extract all the dtb and decompiled them into dts files, Expand Just attach this file to your message 0 Quote
lissizza Posted February 27, 2023 Posted February 27, 2023 @going No, I see only 1 GB 136_dtbdump_,OrangePi_3_LTS.dtsFetching info... 0 Quote
going Posted February 27, 2023 Posted February 27, 2023 On 2/27/2023 at 1:29 PM, lissizza said: No, I see only 1 GB Expand I do not promise a quick result. Thanks for the dts file. Very timely, I am currently fixing it for the 6.2 kernel. Unfortunately, I am not an advisor on displays and their resolutions. I work with headless devices. Wait, someone will help. 0 Quote
going Posted March 2, 2023 Posted March 2, 2023 @lissizza It seems to me that I have reviewed all the links on the Internet, but I have not found any information about the chip with the letters that you published. Can we try to get information from the other side? For example, show what is written directly on the printed circuit board: the name of the device and its version. For example, I have: Orange PI PC v1.1 And please give me a link to download the schematic diagram for the version of this device. 0 Quote
lissizza Posted March 2, 2023 Posted March 2, 2023 (edited) @going There is printed Orange Pi 3 LTS v1.4. I attached the photo. And there is the TTL log below. Reveal hidden contents U-Boot SPL 2021.10-orangepi (Sep 06 2022 - 20:11:26 +0800) PMU: AXP806 DRAM: 1024 MiB Trying to boot from MMC1 NOTICE: BL31: v2.2(debug):a04808c1 NOTICE: BL31: Built : 19:40:26, Jul 13 2022 NOTICE: BL31: Detected Allwinner H6 SoC (1728) NOTICE: BL31: Found U-Boot DTB at 0xc07ea28, model: OrangePi 3 LTS INFO: ARM GICv2 driver initialized NOTICE: PMIC: Probing AXP805 NOTICE: PMIC: AXP805 detected INFO: BL31: Platform setup done INFO: BL31: Initializing runtime services INFO: BL31: cortex_a53: CPU workaround for 855873 was applied INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 U-Boot 2021.10-orangepi (Sep 06 2022 - 20:11:26 +0800) Allwinner Technology CPU: Allwinner H6 (SUN50I) Model: OrangePi 3 LTS I2C: ready DRAM: 1 GiB MMC: mmc@4020000: 0, mmc@4022000: 1 Loading Environment from FAT... Unable to use mmc 0:1... In: serial@5000000 Out: serial@5000000 Err: serial@5000000 Net: No ethernet found. Autoboot in 1 seconds, press <Space> to stop switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3206 bytes read in 2 ms (1.5 MiB/s) ## Executing script at 4fc00000 U-boot loaded from SD Boot script loaded from mmc 241 bytes read in 2 ms (117.2 KiB/s) 37593 bytes read in 5 ms (7.2 MiB/s) 3844 bytes read in 6 ms (625 KiB/s) Applying kernel provided DT fixup script (sun50i-h6-fixup.scr) ## Executing script at 45000000 10736930 bytes read in 532 ms (19.2 MiB/s) 25868296 bytes read in 1278 ms (19.3 MiB/s) Moving Image from 0x40080000 to 0x40200000, end=41c00000 ## Loading init Ramdisk from Legacy Image at 4ff00000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 10736866 Bytes = 10.2 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 4fa00000 Booting using the fdt blob at 0x4fa00000 Loading Ramdisk to 495c2000, end 49fff4e2 ... OK Loading Device Tree to 0000000049550000, end 00000000495c1fff ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 5.16.17-sun50iw6 (root@test) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #3.0.8 SMP Tue Sep 6 20:11:50 CST 2022 [ 0.000000] Machine model: OrangePi 3 LTS [ 0.000000] NUMA: No NUMA configuration found [ 0.000000] NUMA: Faking a node at [mem 0x0000000040000000-0x000000007fffffff] [ 0.000000] NUMA: NODE_DATA [mem 0x7fdcb040-0x7fdccfff] [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000040000000-0x000000007fffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal empty [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000040000000-0x000000007fffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000007fffffff] [ 0.000000] cma: Reserved 128 MiB at 0x0000000076c00000 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] psci: SMC Calling Convention v1.1 [ 0.000000] percpu: Embedded 19 pages/cpu s37016 r8192 d32616 u77824 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: ARM erratum 845719 [ 0.000000] Fallback order for Node 0: 0 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 258048 [ 0.000000] Policy zone: DMA [ 0.000000] Kernel command line: root=UUID=5ce619d5-0a9b-4295-8436-014d19a33fb6 rootwait rootfstype=ext4 console=tt yS0,115200 console=tty1 consoleblank=0 loglevel=7 ubootpart=85bf36e3-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x10 68:u video=HDMI-A-1:1920x1080@60 cgroup_enable=memory swapaccount=1 [ 0.000000] Unknown kernel command line parameters "ubootpart=85bf36e3-01 cgroup_enable=memory", will be passed to user space. [ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes, linear) [ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] Memory: 859860K/1048576K available (13760K kernel code, 4590K rwdata, 4272K rodata, 2496K init, 1338K b ss, 57644K reserved, 131072K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] rcu: Hierarchical RCU implementation. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] Root IRQ handler: gic_handle_irq [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] random: get_random_bytes called from start_kernel+0x4c4/0x6a4 with crng_init=0 [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 44079520259 2 ns [ 0.000001] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.000124] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns [ 0.000609] Console: colour dummy device 80x25 [ 0.000977] printk: console [tty1] enabled [ 0.001065] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) [ 0.001092] pid_max: default: 32768 minimum: 301 [ 0.001176] LSM: Security Framework initializing [ 0.001216] Yama: becoming mindful. [ 0.001307] AppArmor: AppArmor initialized [ 0.001364] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear) [ 0.001390] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear) [ 0.003031] rcu: Hierarchical SRCU implementation. [ 0.004097] smp: Bringing up secondary CPUs ... [ 0.004849] Detected VIPT I-cache on CPU1 [ 0.004919] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 0.005564] Detected VIPT I-cache on CPU2 [ 0.005604] CPU2: Booted secondary processor 0x0000000002 [0x410fd034] [ 5.092068] CPU3: failed to come online [ 5.092116] CPU3: failed in unknown state : 0x0 [ 5.092191] smp: Brought up 1 node, 3 CPUs [ 5.092207] SMP: Total of 3 processors activated. [ 5.092220] CPU features: detected: 32-bit EL0 Support [ 5.092233] CPU features: detected: CRC32 instructions [ 5.106089] CPU: All CPU(s) started at EL2 [ 5.106126] alternatives: patching kernel code [ 5.107562] devtmpfs: initialized [ 5.114276] Registered cp15_barrier emulation handler [ 5.114320] Registered setend emulation handler [ 5.114485] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 5.114519] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [ 5.119517] pinctrl core: initialized pinctrl subsystem [ 5.120754] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 5.122276] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations [ 5.122411] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 5.122547] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 5.122613] audit: initializing netlink subsys (disabled) [ 5.122764] audit: type=2000 audit(5.116:1): state=initialized audit_enabled=0 res=1 [ 5.123297] thermal_sys: Registered thermal governor 'fair_share' [ 5.123304] thermal_sys: Registered thermal governor 'bang_bang' [ 5.123319] thermal_sys: Registered thermal governor 'step_wise' [ 5.123331] thermal_sys: Registered thermal governor 'user_space' [ 5.123778] cpuidle: using governor menu [ 5.124033] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 5.124123] ASID allocator initialised with 65536 entries [ 5.124329] Serial: AMBA PL011 UART driver [ 5.137612] platform 6510000.tcon-top: Fixing up cyclic dependency with 6000000.hdmi [ 5.137981] platform 6515000.lcd-controller: Fixing up cyclic dependency with 6510000.tcon-top [ 5.140122] platform connector: Fixing up cyclic dependency with 6000000.hdmi [ 5.141356] platform vcc-wifi-io: Fixing up cyclic dependency with vcc33-wifi [ 5.148619] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages [ 5.148652] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages [ 5.148668] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 5.148683] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages [ 5.149304] cryptd: max_cpu_qlen set to 1000 [ 5.216409] raid6: neonx8 gen() 1590 MB/s [ 5.284477] raid6: neonx8 xor() 1187 MB/s [ 5.352553] raid6: neonx4 gen() 1623 MB/s [ 5.420628] raid6: neonx4 xor() 1176 MB/s [ 5.488695] raid6: neonx2 gen() 1541 MB/s [ 5.556772] raid6: neonx2 xor() 1096 MB/s [ 5.624850] raid6: neonx1 gen() 1341 MB/s [ 5.692921] raid6: neonx1 xor() 923 MB/s [ 5.760993] raid6: int64x8 gen() 1103 MB/s [ 5.829073] raid6: int64x8 xor() 580 MB/s [ 5.897147] raid6: int64x4 gen() 1230 MB/s [ 5.965206] raid6: int64x4 xor() 619 MB/s [ 6.033281] raid6: int64x2 gen() 1048 MB/s [ 6.101362] raid6: int64x2 xor() 540 MB/s [ 6.169430] raid6: int64x1 gen() 779 MB/s [ 6.237523] raid6: int64x1 xor() 414 MB/s [ 6.237536] raid6: using algorithm neonx4 gen() 1623 MB/s [ 6.237549] raid6: .... xor() 1176 MB/s, rmw enabled [ 6.237561] raid6: using neon recovery algorithm [ 6.238696] iommu: Default domain type: Translated [ 6.238715] iommu: DMA domain TLB invalidation policy: strict mode [ 6.239007] SCSI subsystem initialized [ 6.239200] usbcore: registered new interface driver usbfs [ 6.239247] usbcore: registered new interface driver hub [ 6.239289] usbcore: registered new device driver usb [ 6.239620] pps_core: LinuxPPS API ver. 1 registered [ 6.239635] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 6.239664] PTP clock support registered [ 6.240285] Advanced Linux Sound Architecture Driver Initialized. [ 6.240952] NetLabel: Initializing [ 6.240965] NetLabel: domain hash size = 128 [ 6.240976] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO [ 6.241053] NetLabel: unlabeled traffic allowed by default [ 6.241066] mctp: management component transport protocol core [ 6.241078] NET: Registered PF_MCTP protocol family [ 6.241566] clocksource: Switched to clocksource arch_sys_counter [ 6.241759] VFS: Disk quotas dquot_6.6.0 [ 6.241819] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 6.242411] AppArmor: AppArmor Filesystem Enabled [ 6.248913] NET: Registered PF_INET protocol family [ 6.249084] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 6.249929] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes, linear) [ 6.249971] TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 6.250062] TCP bind hash table entries: 8192 (order: 5, 131072 bytes, linear) [ 6.250222] TCP: Hash tables configured (established 8192 bind 8192) [ 6.250341] UDP hash table entries: 512 (order: 2, 16384 bytes, linear) [ 6.250387] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear) [ 6.250549] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 6.250817] Trying to unpack rootfs image as initramfs... [ 6.258672] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available [ 6.260347] Initialise system trusted keyrings [ 6.260419] Key type blacklist registered [ 6.260694] workingset: timestamp_bits=44 max_order=18 bucket_order=0 [ 6.266466] zbud: loaded [ 6.268014] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 6.270332] integrity: Platform Keyring initialized [ 6.318747] xor: automatically using best checksumming function 32regs [ 6.318789] async_tx: api initialized (async) [ 6.318805] Key type asymmetric registered [ 6.318818] Asymmetric key parser 'x509' registered [ 6.319013] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247) [ 6.319294] io scheduler mq-deadline registered [ 6.319312] io scheduler kyber registered [ 6.319511] io scheduler bfq registered [ 6.324811] sun50i-h6-r-pinctrl 7022000.pinctrl: initialized sunXi PIO driver [ 6.336210] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled [ 6.339016] misc dump reg init [ 6.343801] cacheinfo: Unable to detect cache hierarchy for CPU 0 [ 6.347885] loop: module loaded [ 6.350352] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 6.350400] ehci-platform: EHCI generic platform driver [ 6.350564] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 6.350586] ohci-platform: OHCI generic platform driver [ 6.351095] usbcore: registered new interface driver usb-storage [ 6.351660] mousedev: PS/2 mouse device common for all mice [ 6.352641] sun6i-rtc 7000000.rtc: registered as rtc0 [ 6.352768] sun6i-rtc 7000000.rtc: RTC enabled [ 6.352921] i2c_dev: i2c /dev entries driver [ 6.353811] sunxi-wdt 7020400.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0) [ 6.355386] sun50i-h6-r-pinctrl 7022000.pinctrl: supply vcc-pm not found, using dummy regulator [ 6.355836] sdhci: Secure Digital Host Controller Interface driver [ 6.355853] sdhci: Copyright(c) Pierre Ossman [ 6.355885] Synopsys Designware Multimedia Card Interface Driver [ 6.356668] sdhci-pltfm: SDHCI platform and OF driver helper [ 6.356840] sun50i-h6-r-pinctrl 7022000.pinctrl: supply vcc-pl not found, using dummy regulator [ 6.357664] ledtrig-cpu: registered to indicate activity on CPUs [ 6.358258] sun8i-ce 1904000.crypto: Set mod clock to 300000000 (300 Mhz) from 24000000 (24 Mhz) [ 6.358582] sun8i-ce 1904000.crypto: will run requests pump with realtime priority [ 6.358728] sun8i-ce 1904000.crypto: will run requests pump with realtime priority [ 6.358857] sun8i-ce 1904000.crypto: will run requests pump with realtime priority [ 6.358966] sun8i-ce 1904000.crypto: will run requests pump with realtime priority [ 6.359062] sun8i-ce 1904000.crypto: Register cbc(aes) [ 6.359140] sun8i-ce 1904000.crypto: Register ecb(aes) [ 6.359169] sun8i-ce 1904000.crypto: Register cbc(des3_ede) [ 6.359195] sun8i-ce 1904000.crypto: Register ecb(des3_ede) [ 6.359227] sun8i-ce 1904000.crypto: Register md5 [ 6.359254] sun8i-ce 1904000.crypto: Register sha1 [ 6.359280] sun8i-ce 1904000.crypto: Register sha224 [ 6.359307] sun8i-ce 1904000.crypto: Register sha256 [ 6.359335] sun8i-ce 1904000.crypto: Register sha384 [ 6.359362] sun8i-ce 1904000.crypto: Register sha512 [ 6.359389] sun8i-ce 1904000.crypto: Register stdrng [ 6.360030] sun8i-ce 1904000.crypto: CryptoEngine Die ID 0 [ 6.360632] hid: raw HID events driver (C) Jiri Kosina [ 6.360768] usbcore: registered new interface driver usbhid [ 6.360783] usbhid: USB HID core driver [ 6.361468] random: fast init done [ 6.362972] random: crng init done [ 6.363810] NET: Registered PF_INET6 protocol family [ 6.845464] Freeing initrd memory: 10484K [ 6.880278] Segment Routing with IPv6 [ 6.880367] In-situ OAM (IOAM) with IPv6 [ 6.880489] NET: Registered PF_PACKET protocol family [ 6.880595] 8021q: 802.1Q VLAN Support v1.8 [ 6.880753] 9pnet: Installing 9P2000 support [ 6.880830] Key type dns_resolver registered [ 6.881324] registered taskstats version 1 [ 6.881348] Loading compiled-in X.509 certificates [ 6.885316] Loaded X.509 cert 'Build time autogenerated kernel key: 6af1a27ae7a3ceaaa4ad504cae46c944e71bfd68' [ 6.887257] zswap: loaded using pool zstd/z3fold [ 6.887838] Key type ._fscrypt registered [ 6.887854] Key type .fscrypt registered [ 6.887866] Key type fscrypt-provisioning registered [ 6.888894] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=no [ 6.889173] Key type encrypted registered [ 6.889199] AppArmor: AppArmor sha1 policy hashing enabled [ 6.889237] ima: No TPM chip found, activating TPM-bypass! [ 6.889266] ima: Allocated hash algorithm: sha1 [ 6.889305] ima: No architecture policies found [ 6.889362] evm: Initialising EVM extended attributes: [ 6.889374] evm: security.selinux [ 6.889385] evm: security.SMACK64 [ 6.889395] evm: security.SMACK64EXEC [ 6.889405] evm: security.SMACK64TRANSMUTE [ 6.889415] evm: security.SMACK64MMAP [ 6.889425] evm: security.apparmor [ 6.889435] evm: security.ima [ 6.889444] evm: security.capability [ 6.889455] evm: HMAC attrs: 0x1 [ 6.909017] platform 1100000.mixer: Fixing up cyclic dependency with 6510000.tcon-top [ 6.911278] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller [ 6.911343] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1 [ 6.911516] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f064 hci version 0x100 quirks 0x0000000002010010 [ 6.911586] xhci-hcd xhci-hcd.1.auto: irq 43, io mem 0x05200000 [ 6.912041] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.16 [ 6.912067] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 6.912088] usb usb1: Product: xHCI Host Controller [ 6.912102] usb usb1: Manufacturer: Linux 5.16.17-sun50iw6 xhci-hcd [ 6.912118] usb usb1: SerialNumber: xhci-hcd.1.auto [ 6.912649] hub 1-0:1.0: USB hub found [ 6.912711] hub 1-0:1.0: 1 port detected [ 6.913064] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller [ 6.913092] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2 [ 6.913121] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed [ 6.913221] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 6.913391] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.16 [ 6.913416] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 6.913436] usb usb2: Product: xHCI Host Controller [ 6.913450] usb usb2: Manufacturer: Linux 5.16.17-sun50iw6 xhci-hcd [ 6.913465] usb usb2: SerialNumber: xhci-hcd.1.auto [ 6.913933] hub 2-0:1.0: USB hub found [ 6.913978] hub 2-0:1.0: 1 port detected [ 6.916587] sun50i_cpufreq_nvmem: Using CPU speed bin speed0 [ 6.918593] scpi_protocol scpi: SCP Protocol 0.0 Firmware 0.0.0 version [ 6.924556] WCN: marlin_init entry! [ 6.924849] WCN: wcn config bt wake host [ 6.925064] WCN_ERR: dts node for bt_wake not found [ 6.925068] WCN: marlin2 parse_dt some para not config [ 6.925099] sdiohal:sdiohal_parse_dt adma_tx:1, adma_rx:1, pwrseq:0, irq type:data, gpio_num:0, blksize:840 [ 6.929931] sdiohal:sdiohal_init ok [ 6.930561] WCN: marlin_probe ok! [ 6.931051] of_cfs_init [ 6.931174] of_cfs_init: OK [ 6.931657] ALSA device list: [ 6.931671] No soundcards found. [ 6.932944] Freeing unused kernel memory: 2496K [ 6.953685] Run /init as init process [ 7.165621] usb 1-1: new full-speed USB device number 2 using xhci-hcd [ 7.405281] axp20x-i2c 0-0036: AXP20x variant AXP806 found [ 7.435837] input: axp20x-pek as /devices/platform/soc/7081400.i2c/i2c-0/0-0036/axp221-pek/input/input0 [ 7.451157] vcc33-audio-tv-ephy-mac: Bringing 700000uV into 3300000-3300000uV [ 7.558342] vcc33-io-pd-emmc-sd-usb-uart-1: Bringing 700000uV into 3300000-3300000uV [ 7.561387] vcc-wifi-io-pm-pg: Bringing 700000uV into 1800000-1800000uV [ 7.565437] axp20x-i2c 0-0036: AXP20X driver loaded [ 7.572031] sun50i-h6-pinctrl 300b000.pinctrl: initialized sunXi PIO driver [ 7.572543] sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-pb not found, using dummy regulator [ 7.574228] sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-ph not found, using dummy regulator [ 7.574988] printk: console [ttyS0] disabled [ 7.575109] 5000000.serial: ttyS0 at MMIO 0x5000000 (irq = 35, base_baud = 1500000) is a 16550A [ 7.873647] usb 1-1: config 1 has an invalid interface number: 3 but max is 2 [ 7.881640] printk: console [ttyS0] enabled [ 7.890759] usb 1-1: config 1 has no interface number 1 [ 7.915931] sun4i-drm display-engine: bound 1100000.mixer (ops 0xffff800008e59a08) [ 7.933862] usb 1-1: New USB device found, idVendor=1b3f, idProduct=2008, bcdDevice= 1.00 [ 7.941927] sun4i-drm display-engine: bound 6510000.tcon-top (ops 0xffff800008e5df40) [ 7.946463] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 7.951316] sun4i-drm display-engine: bound 6515000.lcd-controller (ops 0xffff800008e54aa0) [ 7.955003] usb 1-1: Product: Usb Audio Device [ 7.955011] usb 1-1: Manufacturer: FamousAudio [ 7.961614] sun8i-dw-hdmi 6000000.hdmi: supply hvcc not found, using dummy regulator [ 8.017257] input: FamousAudio Usb Audio Device as /devices/platform/soc/5200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1:1 .3/0003:1B3F:2008.0001/input/input1 [ 8.021492] sun8i-dw-hdmi 6000000.hdmi: Detected HDMI TX controller v2.12a with HDCP (DWC HDMI 2.0 TX PHY) [ 8.093926] hid-generic 0003:1B3F:2008.0001: input,hidraw0: USB HID v2.01 Device [FamousAudio Usb Audio Device] on usb-xhci-hcd.1.auto-1/input3 [ 8.097395] sun8i-dw-hdmi 6000000.hdmi: registered DesignWare HDMI I2C bus driver [ 8.097500] sun8i-dw-hdmi 6000000.hdmi: EVENT=plugin [ 9.323644] sun4i-drm display-engine: bound 6000000.hdmi (ops 0xffff800008e58af0) [ 9.331912] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0 [ 9.339763] sun8i-dw-hdmi 6000000.hdmi: read_hpd result: 1 [ 9.546155] Console: switching to colour frame buffer device 240x67 [ 9.585862] sun4i-drm display-engine: [drm] fb0: sun4i-drmdrmfb frame buffer device [ 9.615583] sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-pf not found, using dummy regulator [ 9.618094] ehci-platform 5101000.usb: EHCI Host Controller [ 9.625394] sunxi-mmc 4020000.mmc: Got CD GPIO [ 9.630188] ehci-platform 5101000.usb: new USB bus registered, assigned bus number 3 [ 9.642895] ehci-platform 5101000.usb: irq 41, io mem 0x05101000 [ 9.649594] sunxi-mmc 4022000.mmc: initialized, max. request size: 2048 KB, uses new timings mode [ 9.651052] sunxi-mmc 4021000.mmc: allocated mmc-pwrseq [ 9.659317] sunxi-mmc 4020000.mmc: initialized, max. request size: 16384 KB, uses new timings mode [ 9.661611] ehci-platform 5101000.usb: USB 2.0 started, EHCI 1.00 [ 9.661879] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.16 [ 9.661891] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 9.661901] usb usb3: Product: EHCI Host Controller [ 9.661908] usb usb3: Manufacturer: Linux 5.16.17-sun50iw6 ehci_hcd [ 9.661915] usb usb3: SerialNumber: 5101000.usb [ 9.663766] hub 3-0:1.0: USB hub found [ 9.664031] hub 3-0:1.0: 1 port detected [ 9.665111] ehci-platform 5311000.usb: EHCI Host Controller [ 9.666055] acx00-codec acx00-codec: DMA mask not set [ 9.730600] ehci-platform 5311000.usb: new USB bus registered, assigned bus number 4 [ 9.738727] ehci-platform 5311000.usb: irq 44, io mem 0x05311000 [ 9.757588] ehci-platform 5311000.usb: USB 2.0 started, EHCI 1.00 [ 9.764141] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.16 [ 9.772627] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 9.780030] usb usb4: Product: EHCI Host Controller [ 9.785032] usb usb4: Manufacturer: Linux 5.16.17-sun50iw6 ehci_hcd [ 9.791453] usb usb4: SerialNumber: 5311000.usb [ 9.796704] hub 4-0:1.0: USB hub found [ 9.800664] hub 4-0:1.0: 1 port detected [ 9.811405] mmc0: host does not support reading read-only switch, assuming write-enable [ 9.822552] mmc0: new high speed SDHC card at address 5048 [ 9.829739] mmcblk0: mmc0:5048 SD32G 29.0 GiB [ 9.837326] mmcblk0: p1 [ 9.890162] sunxi-mmc 4021000.mmc: initialized, max. request size: 16384 KB, uses new timings mode [ 9.899750] mmc2: new HS200 MMC card at address 0001 [ 9.905988] mmcblk2: mmc2:0001 8GTF4R 7.28 GiB [ 9.912374] mmcblk2: p1 [ 9.915951] mmcblk2boot0: mmc2:0001 8GTF4R 4.00 MiB [ 9.922699] mmcblk2boot1: mmc2:0001 8GTF4R 4.00 MiB [ 9.943540] mmc1: new high speed SDIO card at address 8800 [ 9.949707] ohci-platform 5101400.usb: Generic Platform OHCI controller [ 9.956664] ohci-platform 5101400.usb: new USB bus registered, assigned bus number 5 [ 9.973080] ohci-platform 5101400.usb: irq 42, io mem 0x05101400 [ 10.049871] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.16 [ 10.066756] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 10.082480] usb usb5: Product: Generic Platform OHCI controller [ 10.096820] usb usb5: Manufacturer: Linux 5.16.17-sun50iw6 ohci_hcd [ 10.111457] usb usb5: SerialNumber: 5101400.usb [ 10.124883] hub 5-0:1.0: USB hub found [ 10.136937] hub 5-0:1.0: 1 port detected [ 10.150294] ohci-platform 5311400.usb: Generic Platform OHCI controller [ 10.165193] ohci-platform 5311400.usb: new USB bus registered, assigned bus number 6 [ 10.181228] ohci-platform 5311400.usb: irq 45, io mem 0x05311400 [ 10.257818] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.16 [ 10.274147] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 10.289402] usb usb6: Product: Generic Platform OHCI controller [ 10.303344] usb usb6: Manufacturer: Linux 5.16.17-sun50iw6 ohci_hcd [ 10.317592] usb usb6: SerialNumber: 5311400.usb [ 10.330609] hub 6-0:1.0: USB hub found [ 10.342282] hub 6-0:1.0: 1 port detected [ 10.355251] usb_phy_generic usb_phy_generic.4.auto: supply vcc not found, using dummy regulator [ 10.417996] musb-hdrc musb-hdrc.5.auto: MUSB HDRC host driver [ 10.431808] musb-hdrc musb-hdrc.5.auto: new USB bus registered, assigned bus number 7 [ 10.447864] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.16 [ 10.464165] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 10.479267] usb usb7: Product: MUSB HDRC host driver [ 10.479284] usb usb7: Manufacturer: Linux 5.16.17-sun50iw6 musb-hcd [ 10.479292] usb usb7: SerialNumber: musb-hdrc.5.auto [ 10.479965] hub 7-0:1.0: USB hub found [ 10.529812] hub 7-0:1.0: 1 port detected [ 10.551079] dwmac-sun8i 5020000.ethernet: IRQ eth_wake_irq not found [ 10.565074] dwmac-sun8i 5020000.ethernet: IRQ eth_lpi not found [ 10.565442] dwmac-sun8i 5020000.ethernet: supply phy-io not found, using dummy regulator [ 10.594759] dwmac-sun8i 5020000.ethernet: PTP uses main clock [ 10.608275] dwmac-sun8i 5020000.ethernet: Current syscon value is not the default 58000 (expect 50000) [ 10.765900] dwmac-sun8i 5020000.ethernet: No HW DMA feature register supported [ 10.781151] dwmac-sun8i 5020000.ethernet: RX Checksum Offload Engine supported [ 10.796320] dwmac-sun8i 5020000.ethernet: COE Type 2 [ 10.809214] dwmac-sun8i 5020000.ethernet: TX Checksum insertion supported [ 10.823923] dwmac-sun8i 5020000.ethernet: Normal descriptors [ 10.837476] dwmac-sun8i 5020000.ethernet: Chain mode enabled [ 11.044866] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null). Quota mode: none. [ 11.822063] systemd[1]: System time before build time, advancing clock. [ 11.872958] systemd[1]: systemd 247.3-7 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVIN IT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default- hierarchy=unified) [ 11.913050] systemd[1]: Detected architecture arm64. [ 11.967285] systemd[1]: Set hostname to <orangepi3-lts>. [ 12.874873] systemd[1]: Queued start job for default target Graphical Interface. [ 12.897829] systemd[1]: Created slice system-getty.slice. [ 12.923155] systemd[1]: Created slice system-modprobe.slice. [ 12.948832] systemd[1]: Created slice system-serial\x2dgetty.slice. [ 12.974916] systemd[1]: Created slice User and Session Slice. [ 12.999645] systemd[1]: Started Dispatch Password Requests to Console Directory Watch when bootsplash is active. [ 13.028994] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 13.056543] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point. [ 13.085744] systemd[1]: Reached target Local Encrypted Volumes. [ 13.111611] systemd[1]: Reached target Remote File Systems. [ 13.136949] systemd[1]: Reached target Slices. [ 13.161034] systemd[1]: Reached target Swap. [ 13.184773] systemd[1]: Reached target System Time Set. [ 13.217936] systemd[1]: Listening on Syslog Socket. [ 13.243299] systemd[1]: Listening on fsck to fsckd communication Socket. [ 13.270078] systemd[1]: Listening on initctl Compatibility Named Pipe. [ 13.297297] systemd[1]: Listening on Journal Audit Socket. [ 13.323128] systemd[1]: Listening on Journal Socket (/dev/log). [ 13.349547] systemd[1]: Listening on Journal Socket. [ 13.375397] systemd[1]: Listening on udev Control Socket. [ 13.401374] systemd[1]: Listening on udev Kernel Socket. [ 13.430471] systemd[1]: Mounting Huge Pages File System... [ 13.459784] systemd[1]: Mounting POSIX Message Queue File System... [ 13.489593] systemd[1]: Mounting Kernel Debug File System... [ 13.515199] systemd[1]: Condition check resulted in Kernel Trace File System being skipped. [ 13.539339] systemd[1]: Starting Restore / save the current clock... [ 13.570738] systemd[1]: Starting Set the console keyboard layout... [ 13.602404] systemd[1]: Starting Create list of static device nodes for the current kernel... [ 13.636973] systemd[1]: Starting Load Kernel Module configfs... [ 13.667670] systemd[1]: Starting Load Kernel Module drm... [ 13.698089] systemd[1]: Starting Load Kernel Module fuse... [ 13.728195] systemd[1]: Started Nameserver information manager. [ 13.744069] fuse: init (API version 7.35) [ 13.767138] systemd[1]: Reached target Network (Pre). [ 13.794759] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped. [ 13.813286] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 13.839446] systemd[1]: Starting Load Kernel Modules... [ 13.868368] systemd[1]: Starting Remount Root and Kernel File Systems... [ 13.899401] systemd[1]: Starting Coldplug All udev Devices... [ 13.929634] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro. Quota mode: none. [ 13.937191] systemd[1]: Mounted Huge Pages File System. [ 13.952270] mtty_probe init device addr: 0x00000000fa101a40 [ 13.977433] -->rfkill_bluetooth_init [ 13.977686] bluetooth_set_power: start_block=1 [ 13.977696] WCN: marlin power state:0, subsys: [MARLIN_BLUETOOTH] power 0 [ 13.977705] bluetooth_set_power: end_block=1 [ 13.977717] <--rfkill_bluetooth_init [ 14.060392] systemd[1]: Mounted POSIX Message Queue File System. [ 14.070817] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 14.092892] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 14.119345] systemd[1]: Mounted Kernel Debug File System. [ 14.138048] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid [ 14.162090] systemd[1]: Finished Restore / save the current clock. [ 14.189420] systemd[1]: Finished Set the console keyboard layout. [ 14.190717] WCN: start_marlin [MARLIN_WIFI] [ 14.217333] WCN: marlin power state:0, subsys: [MARLIN_WIFI] power 1 [ 14.232428] WCN: the first power on start [ 14.256701] systemd[1]: Finished Create list of static device nodes for the current kernel. [ 14.285238] systemd[1]: modprobe@configfs.service: Succeeded. [ 14.300957] systemd[1]: Finished Load Kernel Module configfs. [ 14.327304] systemd[1]: modprobe@drm.service: Succeeded. [ 14.337592] WCN: marlin chip en dummy pull up -- need manually set GPIO [ 14.342986] systemd[1]: Finished Load Kernel Module drm. [ 14.381592] sdiohal:sdiohal_scan_card [ 14.382702] systemd[1]: modprobe@fuse.service: Succeeded. [ 14.408190] sdiohal:sdiohal_probe: func->class=0, vendor=0x0000, device=0x0000, func_num=0x0001, clock=50000000 [ 14.410156] systemd[1]: Finished Load Kernel Module fuse. [ 14.427579] WCN: marlin_get_wcn_chipid: chipid: 0x2355b001 [ 14.455966] WCN: marlin_scan_finish! [ 14.468259] sdiohal:probe ok [ 14.468407] sdiohal:scan end! [ 14.491289] WCN: then marlin start to download [ 14.491317] WCN: marlin_request_firmware from /lib/firmware/wcnmodem.bin start! [ 14.533111] systemd[1]: Finished Remount Root and Kernel File Systems. [ 14.567645] systemd[1]: Mounting FUSE Control File System... [ 14.596101] systemd[1]: Mounting Kernel Configuration File System... [ 14.624459] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped. [ 14.642041] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped. [ 14.664467] systemd[1]: Starting Load/Save Random Seed... [ 14.693410] systemd[1]: Starting Create System Users... [ 14.721726] systemd[1]: Mounted FUSE Control File System. [ 14.746655] systemd[1]: Mounted Kernel Configuration File System. [ 14.773398] systemd[1]: Finished Load/Save Random Seed. [ 14.799049] systemd[1]: Finished Create System Users. [ 14.823403] systemd[1]: Condition check resulted in First Boot Complete being skipped. [ 14.844503] systemd[1]: Starting Create Static Device Nodes in /dev... [ 14.881282] systemd[1]: Finished Coldplug All udev Devices. [ 14.912646] systemd[1]: Starting Helper to synchronize boot up for ifupdown... [ 14.943260] systemd[1]: Starting Wait for udev To Complete Device Initialization... [ 14.972507] systemd[1]: Finished Create Static Device Nodes in /dev. [ 14.999827] systemd[1]: Finished Helper to synchronize boot up for ifupdown. [ 15.026523] systemd[1]: Reached target Local File Systems (Pre). [ 15.057746] systemd[1]: Mounting /tmp... [ 15.087275] systemd[1]: Starting Rule-based Manager for Device Events and Files... [ 15.118165] systemd[1]: Mounted /tmp. [ 15.141239] systemd[1]: Reached target Local File Systems. [ 15.169938] systemd[1]: Starting Set console font and keymap... [ 15.199066] systemd[1]: Starting Orange Pi ZRAM config... [ 15.223546] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped. [ 15.242503] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped. [ 15.262905] systemd[1]: Finished Set console font and keymap. [ 15.467376] systemd[1]: Started Rule-based Manager for Device Events and Files. [ 15.561191] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. [ 15.600677] WCN: combin_img 0 marlin_firmware_write finish and successful [ 15.600892] WCN: marlin_start_run read reset reg val:0x1 [ 15.600899] WCN: after do marlin_start_run reset reg val:0x0 [ 15.601116] WCN: s_marlin_bootup_time=15601116481 [ 15.605924] WCN: clock mode: TSX [ 15.606229] WCN: marlin_write_cali_data sync init_state:0xd4210000 [ 15.635083] WCN: marlin_write_cali_data sync init_state:0xd4210000 [ 15.674936] WCN: marlin_write_cali_data sync init_state:0xf0f0f0f1 [ 15.674962] WCN: sdio_config bt_wake_host trigger:[high] [ 15.674965] WCN: sdio_config irq:[inband] [ 15.674968] WCN: sdio_config wake_host_level_duration_time:[20ms] [ 15.674974] WCN: sdio_config wake_host_data_separation:[bt/wifi reuse] [ 15.674977] WCN: marlin_send_sdio_config_to_cp sdio_config:0x80f01 (enable config) [ 15.675444] WCN: marlin_write_cali_data finish [ 15.675665] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0 [ 15.728038] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0 [ 15.764394] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0 [ 15.811089] WCN: check_cp_ready sync val:0xf0f0f0f6, prj_type val:0x0 [ 15.811114] WCN: marlin_bind_verify confuse data: 0x7ea7044945022a17ab546caca88504d1 [ 15.811138] WCN: marlin_bind_verify verify data: 0x0005864a61d74fdcb0456eef82946a92 [ 15.811871] WCN: check_cp_ready sync val:0xf0f0f0f7, prj_type val:0x0 [ 15.837938] WCN: check_cp_ready sync val:0xf0f0f0ff, prj_type val:0x0 [ 15.837964] sdiohal:sdiohal_runtime_get entry [ 15.859949] WCN: get_cp2_version entry! [ 15.908578] WCN: WCND at cmd read:WCN_VER:Platform Version:MARLIN3_19B_W21.05.3~Project Version:sc2355_marlin3_lite _ott~12-15-2021 11:26:33~ [ 15.908617] WCN: switch_cp2_log - close entry! [ 15.909891] WCN: WCND at cmd read:OK [ 15.909949] WCN: then marlin download finished and run ok [ 15.909956] WCN: start_loopcheck [ 15.965471] WCN: get_board_ant_num [one_ant] [ 16.136080] wifi ini path = /lib/firmware/wifi_2355b001_1ant.ini [ 16.184078] panfrost 1800000.gpu: clock rate = 432000000 [ 16.193225] systemd[1]: Starting Load/Save RF Kill Switch Status... [ 16.193627] panfrost 1800000.gpu: bus_clock rate = 100000000 [ 16.214213] sprdwl:sprdwl_get_fw_info length mismatch: len_count=83, r_len=89 [ 16.214230] sprdwl:sprdwl_get_fw_info, drv_version=1, fw_version=2, compat_ver=0 [ 16.214233] sprdwl:chip_model:0x2355, chip_ver:0x0 [ 16.214236] sprdwl:fw_ver:0, fw_std:0x7f, fw_capa:0x120f7f [ 16.214239] sprdwl:mac_addr:3c:7a:aa:5f:61:b7 [ 16.214243] sprdwl:credit_capa:TX_WITH_CREDIT [ 16.214245] sprdwl:ott support:0 [ 16.217235] mc: Linux media interface: v0.10 [ 16.217884] panfrost 1800000.gpu: mali-t720 id 0x720 major 0x1 minor 0x1 status 0x0 [ 16.217905] panfrost 1800000.gpu: features: 00000000,10309e40, issues: 00000000,21054400 [ 16.217912] panfrost 1800000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002821 AS:0xf JS:0x7 [ 16.217918] panfrost 1800000.gpu: shader_present=0x3 l2_present=0x1 [ 16.245766] videodev: Linux video capture interface: v2.00 [ 16.338042] zram: Added device: zram0 [ 16.354424] [drm] Initialized panfrost 1.2.0 20180908 for 1800000.gpu on minor 1 [ 16.362955] zram: Added device: zram1 [ 16.368825] unisoc_wifi unisoc_wifi wlan0: mixed HW and IP checksum settings. [ 16.380733] zram: Added device: zram2 [ 16.407246] systemd[1]: Finished Load Kernel Modules. [ 16.440740] systemd[1]: Found device /dev/ttyS0. [ 16.461827] bluetooth_set_power: start_block=0 [ 16.470134] WCN: start_marlin [MARLIN_BLUETOOTH] [ 16.478477] WCN: marlin power state:4, subsys: [MARLIN_BLUETOOTH] power 1 [ 16.489037] WCN: marlin have open, GNSS is closed [ 16.497483] bluetooth_set_power: end_block=0 [ 16.604122] sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned. [ 16.610723] systemd[1]: Starting Apply Kernel Variables... [ 16.637949] cedrus 1c0e000.video-codec: Device registered as /dev/video0 Orange Pi 3.0.8 Bullseye ttyS0 orangepi3-lts login: Edited March 2, 2023 by lissizza 0 Quote
Redfern89 Posted June 9, 2023 Posted June 9, 2023 (edited) Exactly the same for me. One of 10 times when you turn it on, it says that 4GB DRAM is not loaded further. After a reboot everything is back to normal. There is only one memory chip. sorry for bad english, i use google translate Edited June 9, 2023 by Redfern89 0 Quote
