h0ly0ne 0 Posted May 26, 2015 Share Posted May 26, 2015 Hi all, I've one minor issue with my Lamobo R1. I've to set the coherent_pool to > 256KiB to get my USB DVB device working. But every time I set the coherent_pool to e.g. 2M and regenerate the boot.scr the device gets in an endless boot loop (starting uboot - starting kernel - changes resolution and starts to load drivers - but then crashes with graphic errors and starts all over again). Is there something I can do against this? I've compiled the v3.0 with Jessie 3.4.107 with following kernel paramters configured (and sunxi uboot v2015.04): MEDIA_SUPPORT=mVIDEO_DEV=mSOUND=mGMAC_FOR_BANANAPI=yCMA=yCMA_SIZE_MBYTES=16 Greetings, Oliver Link to post Share on other sites More sharing options...
h0ly0ne 0 Posted May 31, 2015 Author Share Posted May 31, 2015 Finally solved - for all other people facing the same issues: Change /boot/boot.cmd from: setenv bootargs console=tty1 root=/dev/mmcblk0p1 rootwait .... loglevel=1 to: setenv bootargs "coherent_pool=6M console=tty1 root=/dev/mmcblk0p1 rootwait .... loglevel=1" then make a backup of /boot/boot.scr (e.g. boot.old) and regenerate boot.scr: mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr And for all other users that want to get v4l devices, not supported in kernel by default, working - you have to recompile the image yourselves - as Igor seems not to change MEDIA_SUPPORT=Y to MEDIA_SUPPORT=m (and VIDEO_DEV=Y to VIDEO_DEV=m) in his builds. This could be an oversight - so take this just as a reminder - to save some people compile and troubleshooting time. Greetings, h0ly0ne Link to post Share on other sites More sharing options...
h0ly0ne 0 Posted May 31, 2015 Author Share Posted May 31, 2015 A few driver panics later the perfect additional module composition for kernel compilation seems to be following configuration (at the moment running stable - more tests to come): CONFIG_MEDIA_SUPPORT=mCONFIG_VIDEO_DEV=mCONFIG_SOUND=mCONFIG_GMAC_FOR_BANANAPI=yCONFIG_CMA=yCONFIG_CMA_DEBUG=nCONFIG_CMA_MBYTES=16CONFIG_CMA_SIZE_SEL_MBYTES=yCONFIG_CMA_ALIGNMENT=8CONFIG_CMA_AREAS=7 Greetings, h0ly0ne Link to post Share on other sites More sharing options...
