thwast Posted January 21, 2023 Posted January 21, 2023 I have a Rock64, purchased in 2019, that has been running happily for 4 years. I was recently experimenting with hooking it up to a relay board and now I am unable to connect to the internet. I am unsure whether something is fried on the board itself or if this is a software problem I can fix, and unsure how to figure that out. Details I have learned more about relay boards now, so I'll do a few things differently and more carefully next attempt, but I had the 5v pin powering the relay board and the 3v pin, GPIO3_A4, and GPIO3_A5 connected to the control side to control two of the board's relays. When connected the Rock's power leds were still on, but either the OS or the internet was down, not sure which. When I then disconnected the relay board, everything worked as normal for a few iterations, but then it remained down even with the relay board disconnected. At this point I logged in over a serial console and found the OS working just fine, but no sign of the ethernet port. This is the current state and I'd like to figure out if it's a fixable one! I have ordered a wifi dongle, but I'd also like to get back ethernet if possible. I believe the only thing I've done intentionally that may have changed the state of the filesystem was that I ran `dpkg-reconfigure network-manager`. Not sure if that changed anything. The orange light on the ethernet port is lit constantly when the board is on. The green light is always off (now). `lspci` produces no output. `ip a` lists only the `lo` interface: 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet 127.0.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host valid_lft forever preferred_lft forever `/etc/network/interfaces`: #source /etc/network/interfaces.d/* # Network is managed by Network manager auto eth0 iface eth0 inet dhcp # address 192.168.70.70 # netmask 255.255.255.0 # gateway 192.168.1.1 # dns-nameservers 8.8.8.8 8.8.4.4 USB, emmc, and sd still work Boot output The only thing I note here is the line `Net: No ethernet found.` and, at the bottom, several `EXT4-fs error`s. The first makes sense, that's what I'm seeing after bootup. Not sure what to do about the second, if anything. Spoiler DDR version 1.13 20180428 ID:0x805 N In LPDDR3 786MHz Bus Width=32 Col=11 Bank=8 Row=15/15 CS=2 Die Bus-Width=32 Size=4096MB ddrconfig:7 OUT Boot1 Release Time: Feb 2 2018 15:41:39, version: 2.46 ChipType = 0x11, 143 SdmmcInit=2 0 BootCapSize=2000 UserCapSize=15028MB FwPartOffset=2000 , 2000 SdmmcInit=0 0 BootCapSize=0 UserCapSize=121942MB FwPartOffset=0 , 0 StorageInit ok = 281382 Raw SecureMode = 0 SecureInit read PBA: 0x4 SecureInit read PBA: 0x404 SecureInit read PBA: 0x804 SecureInit read PBA: 0xc04 SecureInit read PBA: 0x1004 SecureInit ret = 0, SecureMode = 0 LoadTrustBL No find bl30.bin No find bl32.bin Load uboot, ReadLba = 2000 Load OK, addr=0x200000, size=0xa4e00 RunBL31 0x10000 NOTICE: BL31: v1.3(debug):f947c7e NOTICE: BL31: Built : 20:41:40, Nov 26 2018 NOTICE: BL31:Rockchip release version: v1.3 INFO: ARM GICv2 driver initialized INFO: Using rkfiq sec cpu_context! INFO: boot cpu mask: 1 INFO: plat_rockchip_pmu_init: pd status 0xe INFO: BL31: Initializing runtime services INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2017.09-armbian (Feb 08 2019 - 11:49:32 +0100) Model: Pine64 Rock64 DRAM: 4 GiB MMC: rksdmmc@ff520000: 0, rksdmmc@ff500000: 1 SF: unrecognized JEDEC id bytes: ff, ff, ff *** Warning - spi_flash_probe_bus_cs() failed, using default environment In: serial@ff130000 Out: serial@ff130000 Err: serial@ff130000 Model: Pine64 Rock64 misc_init_r cpuid=55524b50303930323100000000120521 serial=d37825d1f8dfc00 Net: No ethernet found. Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0(part 0) is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 2958 bytes read in 17 ms (169.9 KiB/s) ## Executing script at 00500000 Boot script loaded from mmc 0 251 bytes read in 14 ms (16.6 KiB/s) 7808508 bytes read in 211 ms (35.3 MiB/s) 18978824 bytes read in 485 ms (37.3 MiB/s) 73680 bytes read in 54 ms (1.3 MiB/s) ** File not found /boot/dtb/rockchip/overlay/-fixup.scr ** ## Loading init Ramdisk from Legacy Image at 04000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 7808444 Bytes = 7.4 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 01f00000 Booting using the fdt blob at 0x1f00000 Loading Ramdisk to fc78e000, end fcf005bc ... OK reserving fdt memory region: addr=1f00000 size=78000 Loading Device Tree to 00000000fc713000, end 00000000fc78dfff ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 4.4.178-rockchip64 (root@armbian.com) (gcc version 7.4.1 20181213 [linaro-7.4-2019.02 revision 56ec6f6b99cc167ff0c2f8e1a2eed33b1edc85d4] (Linaro GCC 7.4-2019.02) ) #4 SMP Wed May 8 19:34:01 CEST 2019 [ 0.000000] Boot CPU: AArch64 Processor [410fd034] [ 0.000000] earlycon: Early serial console at MMIO32 0xff130000 (options '') [ 0.000000] bootconsole [uart0] enabled ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) [ 9.468579] EXT4-fs error (device zram0): ext4_readdir:189: inode #11: comm rsync: path /var/log/lost+found: directory fails checksum at offset 4096 [ 9.476883] EXT4-fs error (device zram0): ext4_readdir:189: inode #11: comm rsync: path /var/log/lost+found: directory fails checksum at offset 8192 [ 9.485098] EXT4-fs error (device zram0): ext4_readdir:189: inode #11: comm rsync: path /var/log/lost+found: directory fails checksum at offset 12288 [ 9.493685] EXT4-fs error (device zram0): ext4_empty_dir:2731: inode #11: block 1: comm rsync: Directory block failed checksum Ubuntu 18.04.6 LTS katie ttyS2 katie login: trygve Password: Last login: Tue Jan 17 19:17:17 CST 2023 on ttyS2 ____ ___ ____ _ ____ _ _ | _ \ / _ \ / ___| |/ / /_ | || | | |_) | | | | | | ' / '_ \| || |_ | _ <| |_| | |___| . \ (_) |__ _| |_| \_\\___/ \____|_|\_\___/ |_| Welcome to ARMBIAN 5.75 stable Ubuntu 18.04.6 LTS 4.4.178-rockchip64 System load: 0.88 0.21 0.07 Up time: 0 min Memory usage: 2 % of 3988MB IP: CPU temp: 30°C Usage of /: 42% of 15G 0 Quote
Solution xsider Posted March 18, 2023 Solution Posted March 18, 2023 (edited) Ethernet missing happened to me too at a Rockpi4A, Armbian 23.02.02, after enabling rk3328-uart1 overlay in armbian-config. You need to disable overlay for UART1, then ethernet is back again. UART1 and Ethernet seems to share a common pin. Edited March 18, 2023 by xsider 0 Quote
