Posted (edited)
I was dumb enough to try and update uboot on this little box and then it got sort of bricked. When connected using serial I could see it loop trying to boot from EMMC so I tried the reset button recovery to no avail. Shorting the EMMC pins works putting the device in recovery mode but the usb burn tool is stuck on formatting at 7% after it seems to sucesfull removed (and maybe flashed) uboot but the serial connection still shows it looping on EMMC.
So I tried the next thing, shorting EMMC while connected using serial and I could the looping change to include sd and usb. So I made a sd recovery card using the burn card tool and it can boot from it, I can see uboot scroll by but it also gets stuck restoring (see log below). I've left it connected like this for an hour but it never progresses beyond whats shown in the log.
Is there a way to bring this back to live? I don't mind if the internal EMMC is fried as I was using sd cards with Arabian anyways. I build the latest Arabian from source for the s9xx target and it all worked perfectly fine. Until I messed with uboot. I really have no clue as to why this is so hard to recover. I messed up before and shorting EMMC always made the usb burn tool recover it back to Android so my guess is that the EMMC is really gone for some reason.
Is there a thing I can do to always make it both from sd card? I'm unable to boot Arabian when it cycling between EMMC/sd/usb, only the card made with the card burning tool will boot. I can't interrupt the booting process to get into a uboot shell, I've tried mashing the keyboard many times but it always continues to boot and tries to recover using the sd card as seen in the log.
I hope someone can help me bring this back to life as it would be a shame to throw it away. It's a nice little board with working wireless in Armbian and 2gb ram and 16gb internal storage.
Thanks for reading and I'll leave you with the log from the serial console (as you can see it only tried to boot from EMMC until I shorted the pins):
GXL:BL1:9ac50e:bb16dc;FEAT:ADFC318C:0;POC:3;RCY:0;EMMC:0;READ:0;0.0;CHK:0;GXL:BL1:9ac50e:bb16dc;FEAT:ADFC318C:0;POC:3;RCY:0;EMMC:0;READ:0;0.0;CHK:0;GXL:BL1:9ac50e:bb16dc;FEAT:ADFC318C:0;POC:3;RCY:0;EMMC:0;READ:0;0.0;CHK:0;GXL:BL1:9ac50e:bb16dc;FEAT:ADFC318C:0;POC:3;RCY:0;EMMC:0;READ:0;0.0;CHK:0;GXL:BL1:9ac50e:bb16dc;FEAT:ADFC318C:0;POC:3;RCY:0;EMMC:0;READ:0;0.0;CHK:0;GXL:BL1:9ac50e:bb16dc;FEAT:ADFC318C:0;POC:3;RCY:0;EMMC:0;READ:0;0.0;CHK:0;GXL:BL1:9ac50e:bb16dc;FEAT:ADFC318C:0;POC:3;RCY:0;EMMC:0;READ:0;0.0;CHK:0;GXL:BL1:9ac50e:bb16dc;FEAT:ADFC318C:0;POC:3;RCY:0;EMMC:0;READ:0;0.0;CHK:0;GXL:BL1:9ac50e:bb16dc;FEAT:ADFC318C:0;POC:3;RCY:0;EMMC:0;READ:0;0.0;CHK:0;GXL:BL1:9ac50e:bb16dc;FEAT:ADFC318C:0;POC:3;RCY:0;EMMC:400;NAND:81;SD:0;READ:0;0.0;CHK:0;
no sdio debug board detected
TE: 120589
BL2 Built : 20:32:17, Sep  8 2017.
gxl g6296b83 - xiaobo.gu@droid12
set vcck to 1120 mv
set vddee to 1000 mv
Board ID = 2
CPU clk: 1200MHz
DQS-corr enabled
DDR scramble enabled
DDR3 chl: Rank0 16bit @ 792MHz
Rank0: 2048MB(auto)-2T-11
DataBus test pass!
AddrBus test pass!
Load fip header from SD, src: 0x0000c200, des: 0x01400000, size: 0x00004000
New fip structure!
Load bl30 from SD, src: 0x00010200, des: 0x01100000, size: 0x0000d600
Load bl31 from SD, src: 0x00020200, des: 0x05100000, size: 0x0002c600
Load bl32 from SD, src: 0x00050200, des: 0x05300000, size: 0x00036600
Load bl33 from SD, src: 0x00088200, des: 0x01000000, size: 0x00066400
NOTICE:  BL3-1: v1.0(release):a625749
NOTICE:  BL3-1: Built : 11:25:15, Aug 25 2017
[BL31]: GXL CPU setup!
NOTICE:  BL31: BL33 decompress pass
mpu_config_enable:ok
[Image: gxl_v1.1.3243-377db0f 2017-09-07 11:28:58 qiufang.dai@droid07]
OPS=0xa4
38 66 40 cf a6 83 88 53 30 85 f5 8 [0.544834 Inits done]
secure task start!
high task start!
low task start!
INFO:    BL3-2: ATOS-V2.0.2-g4bffb3e #1 Wed Sep 27 19:06:53 CST 2017 arm
INFO:    BL3-2: Chip: GXL Rev: D (21:D - A0:2)
INFO:    BL3-2: crypto engine DMA
INFO:    BL3-2: secure time TEE
INFO:    BL3-2: CONFIG_DEVICE_SECURE 0xb200000e
U-Boot 2015.01 (Apr 21 2018 - 13:07:25)
DRAM:  2 GiB
Relocation Offset is: 76eb2000
board_init sm1628.
register usb cfg[0][1] = 0000000077f5a1b8
[CANVAS]canvas init
boot_device_flag : 1
Nand PHY Ver:1.01.001.0006 (c) 2013 Amlogic Inc.
init bus_cycle=6, bus_timing=7, system=5.0ns
reset failed
get_chip_type and ret:fffffffe
chip detect failed and ret:fffffffe
nandphy_init failed and ret=0xfffffff1
MMC:   aml_priv->desc_buf = 0x0000000073eb26b0
aml_priv->desc_buf = 0x0000000073eb49d0
SDIO Port B: 0, SDIO Port C: 1
emmc/sd response timeout, cmd8, status=0x1ff2800
emmc/sd response timeout, cmd55, status=0x1ff2800
[mmc_init] mmc init success
dtb magic 38315245
      Amlogic multi-dtb tool
      Cannot find legal dtb!
start dts,buffer=0000000073eb7200,dt_addr=0000000073eb7200
check_valid_dts: FDT_ERR_BADMAGIC
get_partition_from_dts: -9
get_ptbl_from_dtb()-259: get partition table from dts faild
mmc_device_init()-1081: get partition table from dtb failed
get_ptbl_rsv()-483: magic faild MPT, ER1
mmc_device_init()-1108: dtb&rsv are not exist, no LPT source
_find_partition_by_name()-188: do not find match in table env
get partition info failed !!
Using default environment
In:    serial
Out:   serial
Err:   serial
reboot_mode=cold_boot
[store]To run cmd[emmc dtb_read 0x1000000 0x40000]
_verify_dtb_checksum()-917: calc 62a48a00, store 0
dtb_read()-1034: cpy 1 is not valid
dtb_read()-1034: cpy 0 is not valid
dtb_read()-1039: total valid 0
[store]Err:do_store_dtb_ops,L330:Fail in fdt check header
board_late_init(): [store dtb read $dtb_mem_addr] fail
load dtb to 1000000
[store]To run cmd[emmc dtb_read 1000000 0x40000]
board_late_init(): store dtb read 1000000 fail
vpu: error: vpu: check dts: FDT_ERR_BADMAGIC, load default parameters
vpu: clk_level = 7
vpu: set clk: 666667000Hz, readback: 666660000Hz(0x300)
vpu: vpu_clk_gate_init_off
vpp: vpp_init
hpd_state=0
cvbs performance type = 6, table = 0
card in
init_part() 278: PART_TYPE_DOS
Device: SDIO Port B
Manufacturer ID: 74
OEM: 4a60
Tran Speed: 50000000
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 29.8 GiB
mmc clock: 40000000
Bus Width: 4-bit
[MSG]ini sz 0x256B
[fat]Filesize is 0x256B[0M]
[fat]0x:leftSz 256 < BPS 4000, gotSz 256
=========sdc_burn_paras=====>>>
[common]
erase_bootloader = 1
erase_flash      = 2
reboot           = 0x0
key_overwrite    = 0x0
[burn_ex]
package          = aml_upgrade_package.img
media            =
[burn_parts]
burn_num         = 0
<<<<=====sdc_burn_paras======
[fat]Filesize is 0x4737a458B[1139M]
[fat]0x:leftSz 2c40 < BPS 4000, gotSz 6c40
[MSG]image version [0x00000002]
[MSG]cfg10=0xADFC318C
[fat]Seek 0xf28c0 from 0x6c40
[MSG]itemSizeNotAligned 0x1740
[MSG]align 4 mmc read...        [fat]0x:leftSz c0 < BPS 4000, gotSz 15800
[MSG]Down(mem) part(dtb) sz(0x15800) fmt(normal)
[MSG]Burn Start...
[MSG]load dt.img to 0x0000000001000000, sz=0x15800
[MSG]Burn complete
Err imgread(L587):Logo header err.
_find_partition_by_name()-188: do not find match in table logo
Cannot find dev.
amlmmc cmd <NULL> failed
store - STORE sub-system
Usage:
store store init flag
store read name addr off|partition size
    read 'size' bytes starting at offset 'off'
    to/from memory address 'addr', skipping bad blocks.
store write name addr off|partition size
    write 'size' bytes starting at offset 'off'
store rom_write add off size.
        write uboot to the boot device
store erase boot/data:
        erase the area which is uboot or data
store erase partition <partition_name>:
        erase the area which partition in u-boot
store erase dtb
store erase key
store disprotect key
store rom_protect on/off
store scrub off|partition size
        scrub the area from offset and size
store dtb iread/read/write addr <size>
        read/write dtb, size is optional
store key read/write addr <size>
        read/write key, size is optional
store mbr addr
   update mbr/partition table by dtb
[burnup]Err:store_read_ops,L63:cmd failed, ret=1, [store  read logo 0xba20000  0x0  0x100000]
Err imgread(L361):Fail to read 0x100000B from part[logo] at offset 0
[MSG]Use upgrade res in pkg
[WRN]Can't find item [logo, aml_sdc_burn]
[MSG]logo for sdc UPGRADE[PARTITION]
[fat]Seek 0xb39dac from 0x1080c0
[MSG]itemSizeNotAligned 0x2254
[MSG]align 4 mmc read...        [fat]0x:leftSz adc < BPS 4000, gotSz 6cad30
[MSG]echo video prepare for upgrade
hpd_state=0
[OSD]check dts: FDT_ERR_BADMAGIC, load default fb_addr parameters
[OSD]fb_addr for logo: 0x3d800000
[CANVAS]addr=0x3d800000 width=5760, height=2160
[MSG]dw,dh[1920, 1080]
[MSG]w,h[4,14]
[MSG]Exit before re-init
command:        store  exit
dtb magic 5f4c4d41
      Multi dtb detected
      Multi dtb tool version: v2 .
      Support 2 dtbs.
        aml_dt soc: gxl platform: p212 variant: 2g
        dtb 0 soc: gxl   plat: p212   vari: 1g
        dtb 1 soc: gxl   plat: p212   vari: 2g
      Find match dtb: 1
start dts,buffer=0000000001000000,dt_addr=000000000100b000
      Multi dtb detected
      Support 2 dtbs.
      Find match dtb: 1
parts: 10
00:      logo   0000000002000000 1
01:  recovery   0000000002000000 1
02:       rsv   0000000000800000 1
03:       tee   0000000000800000 1
04:     crypt   0000000002000000 1
05:      misc   0000000002000000 1
06:      boot   0000000002000000 1
07:    system   0000000080000000 1
08:     cache   0000000020000000 2
09:      data   ffffffffffffffff 4
_calculate_offset()-349: too large partition table for current emmc, overflow!
switch to partitions #0, OK
mmc1(part 0) is current device
Device: SDIO Port C
Manufacturer ID: 65
OEM: 646f
Tran Speed: 52000000
Rd Block Len: 512
MMC version 4.41
High Capacity: No
Capacity: 128 MiB
mmc clock: 40000000
Bus Width: 8-bit
[store]amlmmc erase 1emmckey_is_protected : protect
 start = 0,end = 29359616
start = 113246208,end = 134216704
      Multi dtb detected
      Support 2 dtbs.
      Find match dtb: 1
[burn_parts]
burn_num         = 5
burn_part0       = _aml_dtb
burn_part1       = boot
burn_part2       = logo
burn_part3       = recovery
burn_part4       = system
[MSG]=====>To burn part [_aml_dtb]
[MSG]Down(store) part(_aml_dtb) sz(0x15800) fmt(normal)
[MSG]totalSlotNum = 0, nextWriteBackSlot 2
[fat]0x:leftSz c0 < BPS 4000, gotSz 40c0
[MSG]Burn Start...
[MSG]optimus_download_dtb_image:dataSzReceived=0x15800
start erase dtb......
start = 41943040,end = 42466816
dev # 1,  , several blocks erased OK
[store]To run cmd[emmc dtb_write 0x00000000076fe8c0 0x40000]
dtb_write()-1140: valid 0
dtb_write()-1160: new stamp 0, checksum 0x4487cea3, version 1, magic A~D
Edited by stut
If your emmc is not working, I don't think you can.  My understanding is that these amlogic boxes basically are hard coded to look for uboot on emmc.  That is why the aml-s9xx-box builds use the emmc uboot to then chain load the distribution from sd/usb/etc.  It is always using the emmc uboot initially.  If your emmc is working, you should use recovery to reinstall the android uboot and then you could move on from there.  But in your case you have already tried that, and it didn't work (likely indicating that your emmc is not working).  Based on your comments, it sounds like you have previously reinstalled the android firmware, so you know that process used to work (the reason I am stating this, is that sometimes different boards/firmware combinations require specific versions of the amlogic burning tool)
Posted (edited)
Yes, I've done recovery to Android many times on many of these little boxes. What I'm stumped by is that seemingly my nand is no longer functioning properly despite only using some software trying to update uboot. Usually software doesn't break hardware but it seems this box is unrecoverable now. When it's turned on there's no uboot showing, it just shows this one line where is loops trying to boot from EMMC. Only after shorting EMMC pins it tries to boot from usb or sd in the loop. Once I connect the sd card made with the card burning tool it boots. Nothing on other usb sticks boots (both Android recovery and Armbian) and only sd card booting works made with the card burning tool.
LOOP:18;EMMC:0;READ:0;CHK:A7;READ:0;CHK:A7;READ:0;CHK:A7;SD:800;USB:8;LOOP:19;EMMC:0;READ:0;CHK:A7;READ:0;CHK:A7;READ:0;CHK:A7;SD:800;USB:8;LOOP:1A;EMMC:0;READ:0;CHK:A7;READ:0;CHK:A7;READ:0;CHK:A7;SD:800;USB:8;LOOP:1B;EMMC:0;READ:0;CHK:A7;READ:0;CHK:A7;READ:0;CHK:A7;SD:0;READ:0;0.0;CHK:0;
There are entries in the log about the partition table and some kind of overflowing? I guess somehow when trying to update uboot the partition table got messed up and eight usb burning tool as sd card burning tool can fix it. Really amazing a software update can just convert this little box into a paperweight.
I think you're right about the booting but I'm still temped to desolder the nand chip and see what happens, can't get much worse than it is now right? Haha.
Edited by stut
Another factor is that at least as far as the armbian builds go, there is no uboot suitable for your box available.  It isn't feasible/possible to build uboots for the hundreds of different tv box hardware configurations out there (and the tv box manufacturers don't release their source for their android uboots), so the uboot on the armbian build sd card is basically just a place holder (generic uboot that 100% is guaranteed not to work for your box).  The whole armbian amlogic tv box strategy is to use the uboot that comes with the tv box on emmc.  So if you are trying to get something working from sd, it isn't going to be armbian unless you can get your emmc working again.
Posted (edited)
Alright, so in order to boot Armbian I need to be able to put the original uboot on the internal storage which is seemingly impossible as all recovery methods fail. I guess it goes into the bin and I'll order some Raspberry Zero W2 to replace it. Thanks for your time!
After desoldering the nand chip it now always tried to boot from all 3, EMMC, sd and usb. So if I manage to somehow compile a compatible uboot I should be able to boot it right? I might give it a go before throwing it out. It'll be educational if anything.
Obviously the restore sd card can't restore but it still boots, maybe the uboot can be taken from there and used on an Armbian sd card. I'll give that a go too. It's funny to see it try to restore to a non-existing chip, it even tries to unlock it haha.
GXL:BL1:9ac50e:bb16dc;FEAT:ADFC318C:0;POC:0;RCY:0;USB:0;SPI:0;CHK:A7;EMMC:400;NAND:81;SD:0;READ:0;0.0;CHK:0;
TE: 2445339
set vcck to 1120 mv
Board ID = 2
CPU clk: 1200MHz
DQS-corr enabled
DataBus test pass!
AddrBus test pass!
New fip structure!
OPS=0xa4
38 66 40 cf a6 83 88 53 30 85 f5 8 [2.869655 Inits done]
secure task start!
high task start!
low task start!
DRAM:  2 GiB
board_init sm1628.
[CANVAS]canvas init
reset failed
MMC init failed
In:    serial
Out:   serial
Err:   serial
reboot_mode=watchdog_reboot
_dtb_init()-956: mmc init failed
load dtb to 1000000
vpu: clk_level = 7
vpp: vpp_init
hpd_state=0
card in
Device: SDIO Port B
Manufacturer ID: 74
OEM: 4a60
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 29.8 GiB
mmc clock: 40000000
Bus Width: 4-bit
[MSG]ini sz 0x256B
[common]
erase_flash      = 4
reboot           = 0x1
key_overwrite    = 0x0
[burn_ex]
media            =
[burn_parts]
burn_num         = 0
[MSG]Burn Start...
[MSG]Burn complete
Cannot find dev.
Usage:
store erase dtb
store erase key
store mbr addr
hpd_state=0
[MSG]w,h[4,14]
command:        store  exit
dtb magic 5f4c4d41
      Multi dtb detected
      Support 2 dtbs.
      Find match dtb: 1
      Multi dtb detected
      Support 2 dtbs.
      Find match dtb: 1
parts: 10
[MSG]run cmd [store disprotect key; store disprotect hynix]
[store]disprotect key
disprotect hynix
Device: SDIO Port B
Manufacturer ID: 74
OEM: 4a60
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 29.8 GiB
mmc clock: 40000000
Bus Width: 4-bit
[store]amlmmc key
emmc disprotect key
[store]amlmmc erase 1emmckey_is_protected : disprotect
 blkcnt = 0
      Multi dtb detected
      Support 2 dtbs.
      Find match dtb: 1
[burn_parts]
burn_num         = 5
burn_part1       = boot
burn_part2       = logo
burn_part4       = system
[MSG]Burn Start...
dtb magic 5f4c4d41
      Multi dtb detected
      Support 2 dtbs.
      Find match dtb: 1
start dts,buffer=00000000076fe8c0,dt_addr=00000000077098c0
dtb magic 5f4c4d41
      Multi dtb detected
      Support 2 dtbs.
      Find match dtb: 1
      Multi dtb detected
      Support 2 dtbs.
      Find match dtb: 1
parts: 10
"Synchronous Abort" handler, esr 0x96000210
ELR:     77efda10
LR:      77efd9b0
x0 : 0000000000400000 x1 : 0000000077f618f8
x2 : 0000000000000001 x3 : 0000000000000004
x4 : 0000000004000000 x5 : 0000000077f618d0
x6 : 0000000077f618f8 x7 : 0000000000000020
x8 : 0000000000000034 x9 : 0000000000000000
x10: 000000000000000f x11: 0000000077f384d0
x12: 0000000000000000 x13: 0000000000004000
x14: 0000000000000000 x15: 0000000000000000
x16: 0000000000000000 x17: 0000000000000000
x18: 0000000073ea1e28 x19: 0000000077f618d0
x20: 0000000002400000 x21: 0000000073ea1250
x22: 0000000000000090 x23: 0000000077f42da1
x24: 0000000077fbb000 x25: 0000000000000000
x26: 0000000000000000 x27: 0000000073eac6e0
x28: 0000000000000090 x29: 0000000073ea11c0
Resetting CPU ...
resetting ...
Oh, I just noticed it is also trying to boot from SPI now, that wasn't in the list before!
Edited by stut
@stut - here i wrote down quite a bit of information about how to build mainline u-boot for amlogic s905x/w devices - see: https://github.com/hexdump0815/u-boot-misc/blob/master/readme.gxl - you might try the ones i built (see the july 18 2020 releases of that github repo) - gunzip all the files with boot-amlogic_gxl_*.gz and then dd them to an sd card and try to boot them one by one with serial console and a hdmi monitor connected (some have serial console and some hdmi) - if you are lucky one of them maybe gives you a working mainline u-boot you can boot from sd card :)
good luck and best wishes - hexdump
