problem with Enable 3D Acceleration, mount Exfat external drive, blank screen on VNC
Problem 1
i just installed Operating system, and then used coding command
sudo add-apt-repository ppa:liujianfeng1994/panfork-mesa
sudo add-apt-repository ppa:liujianfeng1994/rockchip-multimedia
sudo apt update
sudo apt dist-upgrade
sudo apt install mali-g610-firmware rockchip-multimedia-config
to activate 3d accelerator.
but it failed and an error appeared
Errors were encountered while processing:
 /var/cache/apt/archives/mali-g610-firmware_1.0.0-1_all.deb
E: Sub-process /usr/bin/dpkg returned an error code (1)
https://ibb.co/0BhLJzm
Problem 2
operating system can't mount exfat partition format so I used the following command
sudo apt-get install exfat-fuse
sudo apt-get install exfat-utils
but an error appears
orangepi@orangepi5:~$ sudo apt-get install exfat-utils
Reading package lists... Done
Building dependency tree... Done
Package exfat-utils is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'exfat-utils' has no installation candidate
https://ibb.co/JRQ4jF5
Problem 3
I'm trying to install vnc server using tightvncserver, when it connects successfully but there is no desktop display
https://ibb.co/m9bXY9j
1- Update armbian-firmware package and try again.
2- Install `exfatprogs`
done install exfatprogs but still cant mount exfat partition.
also any fix for vnc no desktop display?
Edited by Tarakula
Are you trying to run it with Wayland? You could try Remote Desktop.
Yes it try install xrdp, but same error black screen only
Edited:
Remote desktop solve. work fine using nomachine.
any problem solve for exfat partition cant be mounted?
exfat-fuse, exfat-utils, exfatprogs none of this work
Edited by Tarakula
Recompile the kernel with exfat support
git clone https://github.com/armbian/build.git && cd build
 ./compile.sh BUILD_ONLY=kernel KERNEL_CONFIGURE=yes BOARD=orangepi5 BRANCH=legacy
Then search for Filesystems and then I thought another submenu enable exfat and compile
In the output/debs folder it places the packages.
You could also try to compile/install the exfat kernel module from: https://github.com/arter97/exfat-linux
git clone https://github.com/arter97/exfat-linux && cd exfat-linux
make
sudo make install
sudo modprobe exfat
Edited by royk
Adding another option
