Hi to all, I'm new to this thread, even if it's a little off-topic, somebody can tell me if I can update acestream arm v7 from here https://github.com/sshmanko/acestream-armv7 with shared object files (.so) taken from apk on google play (armeabi v7a)? I have already tried to install apk for android tv and it's work, but now I want switch to armbian.
Yes, but the core files has changed.... so to be sure that all works fine isn't better make an update (or try to make an update)?
You have checked that acestream start and working, but what does it happen if there are circustances or issues that are fixed in the last build of apk play store? the current build of github have that issues.
Hope that I'm clear about want tell.
On 2/19/2023 at 5:07 PM, WarHawk_AVG said:
From your initial link...installed and working on my Orange Pi PC just fine
Just follow the howto
just git clone https://github.com/sshmanko/acestream-armv7
Then cd into the directory it created
modify the .conf file with username/password
then run the .start file and it comes right up
can You make a test to check if work? I'm rooting a rk3229 and I will choose if install a firmware with androidtv or a firmware with armbian
11 hours ago, WarHawk_AVG said:
Have no clue how to use it...I just know it starts and I get the webgui
please, make a backup of acestream arm-v7l, overwrite the original files with .so library getted from apk (not all, only the core libraries necessary), and test if work
Edited by n3o
