PatrikO Posted February 22, 2023 Share Posted February 22, 2023 Hello, I'm having issues with my Orange Pi 4 LTS. I cannot get any HDMI output at the moment. Neither with the Debian flashed on the eMMC, or with Armbian running of the SD card. In both cases I can SSH into the Orange and run commands normally. The HDMI worked just a day before, but in the meantime I was flashing different systems and it stopped working. I tried different monitors and cables. Any ideas what can I do? 0 Quote Link to comment Share on other sites More sharing options...
PatrikO Posted February 22, 2023 Author Share Posted February 22, 2023 `cat /sys/class/drm/card0-HDMI-A-1/status` says "disconnected." `/sys/class/drm/card0-HDMI-A-1/mode` doesn't exist. 0 Quote Link to comment Share on other sites More sharing options...
jock Posted February 23, 2023 Share Posted February 23, 2023 Hello, what do you mean exactly with: Quote The HDMI worked just a day before, but in the meantime I was flashing different systems and it stopped working. Also post the link given by armbianmonitor -u 0 Quote Link to comment Share on other sites More sharing options...
JDoll Posted March 15, 2023 Share Posted March 15, 2023 Have the same problem on Orange Pi 4 LTS. Last working version was Armbian_22.08.1_Orangepi4-lts_jammy_current_5.15.63. After system update monitor was black but system was still up and connectable trough SSH. Installing Armbian_23.02.2_Orangepi4-lts_jammy_current_5.15.93 shows the same result. Any suggestion will appreciated. I can reinstall Armbian_22.08.1 for analysis. Thanks in advance. edit: Please forget what I've said about Armbian_23.02.2_Orangepi4-lts. Meanwhile I've got 23.02.2_Orangepi4-lts running flawlessly. My last testing environment had a broken HDMI-cable. Thus it has no urgency anymore for me. Sorry & thanks. 0 Quote Link to comment Share on other sites More sharing options...
jock Posted July 31, 2023 Share Posted July 31, 2023 I resume this thread to see if anyone is still interested in this issue: I can provide a minimal testing image to see if some patches may reduce or eliminate the HDMI problem. Please answer here if there is still interest in this topic 0 Quote Link to comment Share on other sites More sharing options...
jock Posted August 1, 2023 Share Posted August 1, 2023 I prepared an experimental minimal build for Orange Pi 4 LTS with some extra patches that may fix the HDMI issues: https://users.armbian.com/jock/misc/Armbian_23.08.0-trunk_Orangepi4-lts_bookworm_edge_6.3.13_minimal.img.xz Please try it and report if possible, thanks! 0 Quote Link to comment Share on other sites More sharing options...
cgutman Posted August 2, 2023 Share Posted August 2, 2023 Wow perfect timing. I just got an Orange Pi 4 LTS today and experienced the same HDMI issues reported by OP when trying to use the Armbian_23.5.1_Orangepi4-lts_bookworm_current_6.1.30_xfce_desktop image. Your experimental image works perfectly. 1 Quote Link to comment Share on other sites More sharing options...
jock Posted August 2, 2023 Share Posted August 2, 2023 @cgutman thank you for reporting! 😉 0 Quote Link to comment Share on other sites More sharing options...
going Posted August 4, 2023 Share Posted August 4, 2023 01.08.2023 в 15:31, jock сказал: I prepared an experimental minimal build for Orange Pi 4 LTS with some extra patches that may fix the HDMI issues: https://users.armbian.com/jock/misc/Armbian_23.08.0-trunk_Orangepi4-lts_bookworm_edge_6.3.13_minimal.img.xz Please describe briefly the problem that you managed to solve in order to make HDMI work P.S. @jock Or just let me take a look at the changes in the git repository. 0 Quote Link to comment Share on other sites More sharing options...
jock Posted August 4, 2023 Share Posted August 4, 2023 1 hour ago, going said: Please describe briefly the problem that you managed to solve in order to make HDMI work Eh, I had to apply the famous libreelec patches (most of them are work from @Kwiboo, btw) that change and fix the various HDMI timings and the subsystem in general. I cut out those patches which seems to be non applicable to the case, but still there are plenty of them (I actually count 48 of them) that, in a way or another, touch the rockchip HDMI subsystem; some of them are difficult to remove because there depend from each other, but I will try to refine to get a small group of patches. Those changes seem to solve problems both with rk3399 and with rk3318/rk3328 and also provide new features, but I don't want to encounter the wall of the last time I did the refactor of the rockchip64 patches into series. BTW this is the commit on my private branch were the work is in progress (based upon 6.3, but I will rebase upon 6.4 soon) 0 Quote Link to comment Share on other sites More sharing options...
going Posted August 4, 2023 Share Posted August 4, 2023 28 минут назад, jock сказал: BTW this is the commit on my private branch were the work is in progress (based upon 6.3, but I will rebase upon 6.4 soon) Thanks, I saw it. 30 минут назад, jock сказал: I cut out those patches which seems to be non applicable to the case, but still there are plenty of them (I actually count 48 of them) that, in a way or another, touch the rockchip HDMI subsystem; some of them are difficult to remove because there depend from each other, but I will try to refine to get a small group of patches. Those changes seem to solve problems both with rk3399 and with rk3318/rk3328 and also provide new features, but I don't want to encounter the wall of the last time I did the refactor of the rockchip64 patches into series. 48 fixes or 148 is a small difference. The main thing in switching to the series is the ease of maintenance, there are a large number of small patches (several thousand) of the code. I think people are used to something different. They are used to experiencing the torment of processing several dozen patches, and we say that there will be 1000 patches and it will be easier to maintain, they just don't believe it. 0 Quote Link to comment Share on other sites More sharing options...
its.not.working Posted September 22, 2023 Share Posted September 22, 2023 I'm having the same problem with no HDMI output. @jock Do I understand correctly then that fixes are in the works? That patched image works so far. (Thanks!) 0 Quote Link to comment Share on other sites More sharing options...
jock Posted April 6 Share Posted April 6 Hello; for anyone is still having issues with HDMI output, I have arranged a minimal set of patches that could go into mainline armbian. The .deb packages for an experimental 6.6.25 kernel and dtbs are here. Just install them with dpkg -i I can't test if they are effective by myself because I have no setup where HDMI fails, nonetheless they seem not to harm my current setup. If you can afford to try that experimental kernel, please report your experience, thanks! 0 Quote Link to comment Share on other sites More sharing options...
wilsonh Posted May 4 Share Posted May 4 Quote Hello; for anyone is still having issues with HDMI output, I have arranged a minimal set of patches that could go into mainline armbian. Thanks!! The patch works perfectly! I have the similar but not exactly issue (no options above 1080p) on RockPro64 here: After applying the patch, immediately the system picks 2K automatically after robot. By the way, am I supposed to do so since I just realized the patch is made for OPi 4 LTS. 0 Quote Link to comment Share on other sites More sharing options...
