Howdy,
I am in desperate need of help getting this dang usb wifi dongle working on my orange pi 5. I am new to sbc and fiarly new to linux. I have tried multiple github drivers with freash OS installs, all to no avail. Time spent trying to get it to work is reaching close 20 hours, across multiple forums, github searches, videos, linux how to site, and armbian site itself. I'm either missing something or an idiot cause i can't figure out this "make" or "dkms" command stuff out for compiling the driver and installing it. My last resort is asking for y'all for help before i feed this thing to my dog... "joke".
My most recent attempt is from the git https://github.com/quickreflex/rtl8188eus/tree/v5.2.2.4  with a terminal out put stating
_______________________________________________________________________________________________
root@orangepi5:/opt/rtl8188eus# dkms build 8188eu/1.0
Kernel preparation unnecessary for this kernel. Skipping...
Building module:
cleaning build area...
'make' all KVER=5.10.110-rockchip-rk3588...(bad exit status: 2)
Error! Bad return status for module build on kernel: 5.10.110-rockchip-rk3588 (aarch64)
Consult /var/lib/dkms/8188eu/1.0/build/make.log for more information.
-___________________________________________________________________________________________________
i understand that this attempt this build is probably not compatible with my specific platform, because there is no config for the RK3588 chip in the Makefile, but i have tried countless other drivers with similar results.
I feel it should be way easier than I am making it.
_________________________________________________________________________________________________________________________________________________________________
root@orangepi5:/opt/rtl8188eus# make all
make ARCH=aarch64 CROSS_COMPILE= -C /lib/modules/5.10.110-rockchip-rk3588/build M=/opt/rtl8188eus  modules
make[1]: Entering directory '/usr/src/linux-headers-5.10.110-rockchip-rk3588'
/usr/bin/env: ‘python’: No such file or directory
Makefile:708: arch/aarch64/Makefile: No such file or directory
make[1]: *** No rule to make target 'arch/aarch64/Makefile'.  Stop.
make[1]: Leaving directory '/usr/src/linux-headers-5.10.110-rockchip-rk3588'
make: *** [Makefile:1911: modules] Error 2
root@orangepi5:/opt/rtl8188eus# make all ARCH=arm64 KSRC=/usr/src/linux-headers-5.10.110-rockchip-rk3588 KVER=5.10.110-rockchip-rk3588
make ARCH=arm64 CROSS_COMPILE= -C /usr/src/linux-headers-5.10.110-rockchip-rk3588 M=/opt/rtl8188eus  modules
arch/arm64/Makefile:44: Detected assembler with broken .inst; disassembly will be unreliable
(standard_in) 1: syntax error
  CC [M]  /opt/rtl8188eus/core/rtw_cmd.o
make[2]: *** [scripts/Makefile.build:273: /opt/rtl8188eus/core/rtw_cmd.o] Error 127
make[1]: *** [Makefile:1920: /opt/rtl8188eus] Error 2
______________________________________________________________________________________________________________________________________________________________________
If anyone has instight to what I am doing wrong, other options, or a different driver I should try please reach out. In the mean time i Search further for answers on the internet
To anyone that has made it through my long winded discourse I thank you for your time.
p.s. sorry for not having screen shot
That should help:
alias python=python3
But this is only small step. I spent many hours trying to compile drivers and make kernel module for MT7610U without success. I was able to do that for different usb wifi dongles on x86-64 platform but not on orange pi 5.
Kernel recompile with proper config is maybe better aproach. You should also reconsider different wifi dongles which just works.
