Got the same box as @frikidelto -> RK3318_V1.4 (I am re-using his pictures)
Does anyone know the location of the pins to short to maskrom mode ?
Thanks in advance!
Edited by schultzz
15 hours ago, stroma said:
Thanks @jock I've seen this paragraph but I thought this nvram was already included in never images, according to this post and also the tutorial from @awawa (link on the first page)
They can't, because some boards like the "old" nvram and some others want the newer
Good evening everyone and thanks in advance for any help or advice you can give me.
I have two RK3318 TV Boxes, officially they are model A95X R5, which have a different motherboard, but apparently identical in terms of components and the exact same Android firmware loaded on them.
if can be useful here is the link to the original Android firmware loaded on these boards:
Looking at the components, the only ones that apparently seem grossly different to me are the eMMC and the LAN controller.
These are some pictures of the two boards:
On both I still have the same old version of Armbian installed and perfectly running, compiled and adapted in 2021 on Buster distro kernel 4 (everything working apart from wifi and some specific leds), sharing the same dtb and the same system configuration and loading using the old uboot.img and trust.img method.
Due to the need to start over with a more updated version of kernel and OS I tried to compile a more recent release based on current Bullseye kernel 5.15 and here the difficulties begin.
On the first board (the green one), which I've always used for preliminary tests, no problem and I was able to start everything strictly necessary right away with just a few modifications to the dtb rk3318-box.dtb.
On the second board (the blue one) I can't start any build I tried to compile. The box remains stucked with the screen off, without anything being loaded. If I re-flesh Android it works, if I try to boot from a SD / flash the old system works. I had no results neither trying booting from SD (with both eMMC erased and the old Armbian flashed) nor from the eMMC using the Multitool (I had to unbrick the memory at least a dozen of times till now). The biggest difficulty arises from the impossibility when it comes to check trough the serial port what is happening on the board during boot process, as the SMDs have not been set up on the blue model to make the port work.
I know that with so little information it is not easy to investigate and understand the source of these issues, but would you have any idea what could be the cause of this strange behavior of the board? There is something I'm missing?
Thanks in advance for any suggestions
@SpellKilleR Hello!
First of all, you should use one the included overlays suitable for your board to get better functionality using rk3318-config script. If I remember correctly, there should be an overlay for a95x board (but I can be wrong) with everything already in place.
About the missing boot from the second board and inability to do debugging via serial port, it looks to me the missing SMD components you are referring to are very near the serial pads. Usually those components are small resistors, you can get the serial functionality just shorting them in place of the resistor and you will ready to go.
I have half an idea about the bad behaviour of the rk3328_f2 board that can be related possibly to the ddrbin command rate or frequency rate: in some cases, the 667 mhz frequency at startup is not happily accepted by some boards. Since you're pretty able to compile your own images, you may try changing the ddrbin in this file with the 333 Mhz version (just swap 666 with 333) and try again.
PS: the big plastic package near the ethernet port is not a chip, it is a set of coils (a transformer, actually) to raise/reduce voltage to transmit and receive the signal over the wire. The real fast ethernet LAN controller is inside the SoC ;)
Hi @jock, thanks a lot for the reply, you are very quick and very kind in helping.
For the leds, I'll see as soon as I can start the blue card too. Both boards have a small display in front, which I was able to get working at the time by modifying the dtb, and a multicolor led bar above, which I never managed to get working. The two classic red and blue LEDs are present only on the green board and already worked with the original dtb on the old Armbian build.
I shorted the serial pins on the blue board and was able to get some boot messages. The boot sequence stops very quickly on the first few steps, with two different sequences of errors alternating.
The most frequent output:
DDR version 1.16 20190713
In
DDR3
666MHz
Bus Width=32 Col=11 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=4096MB
ddrconfig:3
OUT
U-Boot SPL 2022.07-armbian (Mar 17 2023 - 15:17:07 +0000)
Trying to boot from MMC1
NOTICE:  BL31: v2.6(release):armbian
NOTICE:  BL31: Built : 15:17:00, Mar 17 2023
NOTICE:  BL31:Rockchip release version: v1.2
INFO:    ARM GICv2 driver initialized
INFO:    plat_rockchip_pmu_init: pd status 0xe
INFO:    BL31: Initializing runtime services
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2022.07-armbian (Mar 17 2023 - 15:17:07 +0000)
Model: Rockchip RK3318 BOX
DRAM:  4 GiB
Core:  243 devices, 24 uclasses, devicetree: separate
MMC:   mmc@ff500000: 1, mmc@ff520000: 0, dwmmc@ff5f0000: 3
Loading Environment from MMC... *** Warning - bad CRC, using default environment
In:    serial@ff130000
Out:   serial@ff130000
Err:   serial@ff130000
Net:   No ethernet found.
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
3252 bytes read in 4 ms (793.9 KiB/s)
## Executing script at 00500000
Boot script loaded from mmc 1
149 bytes read in 3 ms (47.9 KiB/s)
mmc fail to send stop cmd
 ** fs_devread read error - block
Failed to load '/boot/uInitrd'
Failed to mount ext2 filesystem...
Can't set block device
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
No FDT memory address configured. Please configure
the FDT address via "fdt addr <address>" command.
Aborting!
Unknown command 'kaslrseed' - try 'help'
Bad Linux ARM64 Image magic!
SCRIPT FAILED: continuing...
** No partition table - mmc 1 **
Couldn't find partition mmc 1:1
No EFI system partition
BootOrder not defined
EFI boot manager: Cannot load any image
Card did not respond to voltage select! : -110
starting USB...
Bus usb@ff5c0000: ehci_generic usb@ff5c0000: Failed to get clocks (ret=-19)
Port not available.
Bus usb@ff5d0000: USB OHCI 1.0
Bus usb@ff580000: USB DWC2
scanning bus usb@ff5d0000 for devices... 1 USB Device(s) found
scanning bus usb@ff580000 for devices... 1 USB Device(s) found
Device 0: unknown device
mmc0(part 0) is current device
** No partition table - mmc 0 **
Couldn't find partition mmc 0:1
No ethernet found.
Retrieving file: pxelinux.cfg/00000000
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-rk3328-rk3318_box
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
No ethernet found.
No ethernet found.
"Synchronous Abort" handler, esr 0x96000004
elr: 000000000021fcc0 lr : 0000000000217f90 (reloc)
elr: 00000000fef5bcc0 lr : 00000000fef53f90
x0 : 0000000000000000 x1 : 00000000000000c0
x2 : 1600000002000030 x3 : 00000000fcf41650
x4 : 00000000fefce828 x5 : 00000000fcf41710
x6 : 16000000fef41740 x7 : 00000000fcf6e900
x8 : fffffffffffffff0 x9 : 0000000000000008
x10: 00000000fefc967c x11: 00000000fcf433a0
x12: 0000000000004d10 x13: 0000000000000004
x14: 00000000fcf26e30 x15: 0000000000000020
x16: 00000000fef712e0 x17: 0000000007d409cb
x18: 00000000fcf33db0 x19: 00000000fcf41540
x20: 00000000fcf416c0 x21: 00000000fcf416c0
x22: 0000000000000001 x23: 0000000000000001
x24: 0000000000000000 x25: 0000000000000028
x26: 00000000fefb84cf x27: 00000000fefc2669
x28: 00000000ffffffff x29: 00000000fcf26960
Code: f9000c06 f90008c0 52800000 8b0200a6 (f94004c6)
Resetting CPU ...
resetting ...
In
SRX
DDR3
666MHz
ddrconfig:3
OUT
mmc_load_image_raw_sector: mmc block read error
INFO:    SPSR = 0x3c9
DRAM:  4 GiB
In:    serial@ff130000
Scanning mmc 1:1...
Aborting!
starting USB...
Port not available.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
The least frequent, it only happened to me a couple of times:
In
DDR3
666MHz
ddrconfig:3
OUT
INFO:    SPSR = 0x3c9
DRAM:  4 GiB
In:    serial@ff130000
Scanning mmc 1:1...
124 bytes read in 3 ms (40 KiB/s)
20400650 bytes read in 887 ms (21.9 MiB/s)
30675456 bytes read in 1333 ms (21.9 MiB/s)
52147 bytes read in 8 ms (6.2 MiB/s)
2698 bytes read in 6 ms (438.5 KiB/s)
Applying kernel provided DT fixup script (rockchip-fixup.scr)
## Executing script at 09000000
Moving Image from 0x2080000 to 0x2200000, end=3fe0000
## Loading init Ramdisk from Legacy Image at 06000000 ...
   Image Name:   uInitrd
   Image Type:   AArch64 Linux RAMDisk Image (gzip compressed)
   Data Size:    20400586 Bytes = 19.5 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 01f00000
   Booting using the fdt blob at 0x1f00000
   Using Device Tree in place at 0000000001f00000, end 0000000001f75fff
Starting kernel ...
Both with the SD created yesterday with the standard compiler configuration resulting in a board freeze. The same memory always boots without any problem on the green board and also boots on another box I have which instead has a rk3328 (obviously without working peripherals there, only fot test).
Compiling by setting the ddr blob to 333Mhz shows the exact same result with the exact same output on the serial port.
In
DDR3
666MHz
ddrconfig:3
OUT
INFO:    SPSR = 0x3c9
DRAM:  4 GiB
In:    serial@ff130000
Scanning mmc 1:1...
Aborting!
starting USB...
Port not available.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Is it then normal that 666Mhz still appears written at start up in this case too or something is not working in the compiler / did I forget to change other settings?
Hey folks. I've been struggling a bit with an X88 Pro 10 I have. I'm able to install Armbian with the Multitool but only the 22.05.0 Jammy current 5.15.35 XFCE image because the file size is 4.3 GB. More recent versions the file size is 6.9GB or more and I can't fit the image on the Multitool partition.
I have tried to use the rkdeveloptool with the instructions given to install directly to eMMC and it succeeds but then the box doesn't boot unless I flash the specific version mentioned above, anything newer won't boot.
[Edit]
I had no idea Multitool could handle the compressed .xz files. The box is still not booting any XFCE image newer than Armbian 22.05.0 whether it's flashed with Multitool or rkdeveloptool.
Edited by Ethanol6
Hmmm, no, it's not norma, you should get 333Mhz there if you use the 333mhz ddrbin.
The blue board is IMHO having somehow unstable and the higher frequency of the DDR can indeed cause that.
If you are on the new "main" branch of armbian, perhaps there is an issue with the cache.
You may try rebuilding the images doing
./compile.sh ARTIFACT_IGNORE_CACHE=yes KERNEL_GIT=shallow EXPERT=yes
and try and see if it creates an image with the proper ddrbin.
It would take considerably longer times than usual cache-based compilation because it will rebuild the whole u-boot and kernel.
Perhaps you're having the same issue with ddr memory frequency mentioned in @SpellKilleR above. Perhaps it is time to go back to the slower but safer 333 mhz ddrbin 🤔
     1
     2    ### Activated 1 lzo-rle zram swap devices with 1987MB each.
     3    ### Activated Armbian ramlog partition with zstd compression
     4
     5    Sun Feb 12 05:58:46 PM UTC 2023 | RK3318 Box | 23.02.0-trunk | arm64 | aarch64 | 6.1.11-rockchip64
     6
     7    ### dmesg:
     8
     9    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
    10    [    0.000000] Linux version 6.1.11-rockchip64 (root@7284a09ced08) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #trunk.0248 SMP PREEMPT Fri Feb 10 05:25:40 UTC 2023
    11    [    0.000000] Machine model: Rockchip RK3318 BOX
    12    [    0.000000] efi: UEFI not found.
    13    [    0.000000] NUMA: No NUMA configuration found
    14    [    0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x00000000feffffff]
    15    [    0.000000] NUMA: NODE_DATA [mem 0xfe7b1a80-0xfe7b3fff]
    16    [    0.000000] Zone ranges:
    17    [    0.000000]   DMA      [mem 0x0000000000200000-0x00000000feffffff]
    18    [    0.000000]   DMA32    empty
    19    [    0.000000]   Normal   empty
    20    [    0.000000] Movable zone start for each node
    21    [    0.000000] Early memory node ranges
    22    [    0.000000]   node   0: [mem 0x0000000000200000-0x00000000feffffff]
    23    [    0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000000feffffff]
    24    [    0.000000] On node 0, zone DMA: 512 pages in unavailable ranges
    25    [    0.000000] On node 0, zone DMA: 4096 pages in unavailable ranges
    26    [    0.000000] cma: Reserved 128 MiB at 0x00000000f2600000
    27    [    0.000000] psci: probing for conduit method from DT.
    28    [    0.000000] psci: PSCIv1.1 detected in firmware.
    29    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    30    [    0.000000] psci: MIGRATE_INFO_TYPE not supported.
    31    [    0.000000] psci: SMC Calling Convention v1.2
    32    [    0.000000] percpu: Embedded 30 pages/cpu s82472 r8192 d32216 u122880
    33    [    0.000000] pcpu-alloc: s82472 r8192 d32216 u122880 alloc=30*4096
    34    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    35    [    0.000000] Detected VIPT I-cache on CPU0
    36    [    0.000000] CPU features: detected: ARM erratum 845719
    37    [    0.000000] alternatives: applying boot alternatives
    38    [    0.000000] Fallback order for Node 0: 0
    39    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1027656
    40    [    0.000000] Policy zone: DMA
    41    [    0.000000] Kernel command line: root=UUID=2eb1e931-b16f-46a3-8b3b-f0a92acc8ddb rootwait rootfstype=ext4 splash=verbose console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart=8635553d-01 usb-storage.quirks=   cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
    42    [    0.000000] The swapaccount= commandline option is deprecated. Please report your usecase to linux-mm@kvack.org if you depend on this functionality.
    43    [    0.000000] Unknown kernel command line parameters "splash=verbose ubootpart=8635553d-01 cgroup_enable=memory cgroup_memory=1", will be passed to user space.
    44    [    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
    45    [    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    46    [    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
    47    [    0.000000] Memory: 3913516K/4175872K available (16448K kernel code, 2240K rwdata, 5832K rodata, 3968K init, 585K bss, 131284K reserved, 131072K cma-reserved)
    48    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    49    [    0.000000] trace event string verifier disabled
    50    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    51    [    0.000000] rcu:     RCU event tracing is enabled.
    52    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
    53    [    0.000000]     Trampoline variant of Tasks RCU enabled.
    54    [    0.000000]     Tracing variant of Tasks RCU enabled.
    55    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    56    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
    57    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    58    [    0.000000] Root IRQ handler: gic_handle_irq
    59    [    0.000000] GIC: Using split EOI/Deactivate mode
    60    [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
    61    [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
    62    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
    63    [    0.000001] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
    64    [    0.001081] Console: colour dummy device 80x25
    65    [    0.001164] printk: console [tty1] enabled
    66    [    0.001282] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
    67    [    0.001311] pid_max: default: 32768 minimum: 301
    68    [    0.001458] LSM: Security Framework initializing
    69    [    0.001509] Yama: becoming mindful.
    70    [    0.001677] AppArmor: AppArmor initialized
    71    [    0.001727] Stack Depot allocating hash table of 262144 entries with kvcalloc
    72    [    0.002385] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    73    [    0.002426] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    74    [    0.005730] cblist_init_generic: Setting adjustable number of callback queues.
    75    [    0.005758] cblist_init_generic: Setting shift to 2 and lim to 1.
    76    [    0.005946] cblist_init_generic: Setting shift to 2 and lim to 1.
    77    [    0.006393] rcu: Hierarchical SRCU implementation.
    78    [    0.006404] rcu:     Max phase no-delay instances is 1000.
    79    [    0.010019] EFI services will not be available.
    80    [    0.010744] smp: Bringing up secondary CPUs ...
    81    [    0.012001] Detected VIPT I-cache on CPU1
    82    [    0.012191] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    83    [    0.013542] Detected VIPT I-cache on CPU2
    84    [    0.013729] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
    85    [    0.015076] Detected VIPT I-cache on CPU3
    86    [    0.015271] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
    87    [    0.015472] smp: Brought up 1 node, 4 CPUs
    88    [    0.015499] SMP: Total of 4 processors activated.
    89    [    0.015513] CPU features: detected: 32-bit EL0 Support
    90    [    0.015521] CPU features: detected: 32-bit EL1 Support
    91    [    0.015533] CPU features: detected: CRC32 instructions
    92    [    0.015662] CPU: All CPU(s) started at EL2
    93    [    0.015682] alternatives: applying system-wide alternatives
    94    [    0.019291] devtmpfs: initialized
    95    [    0.043140] Registered cp15_barrier emulation handler
    96    [    0.043173] Registered setend emulation handler
    97    [    0.043630] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    98    [    0.043678] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    99    [    0.049311] pinctrl core: initialized pinctrl subsystem
   100    [    0.050567] DMI not present or invalid.
   101    [    0.051794] NET: Registered PF_NETLINK/PF_ROUTE protocol family
   102    [    0.054856] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
   103    [    0.056296] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
   104    [    0.057549] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
   105    [    0.057671] audit: initializing netlink subsys (disabled)
   106    [    0.058056] audit: type=2000 audit(0.056:1): state=initialized audit_enabled=0 res=1
   107    [    0.059510] thermal_sys: Registered thermal governor 'fair_share'
   108    [    0.059524] thermal_sys: Registered thermal governor 'bang_bang'
   109    [    0.059538] thermal_sys: Registered thermal governor 'step_wise'
   110    [    0.059548] thermal_sys: Registered thermal governor 'user_space'
   111    [    0.059667] cpuidle: using governor menu
   112    [    0.060287] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
   113    [    0.060512] ASID allocator initialised with 65536 entries
   114    [    0.062503] Serial: AMBA PL011 UART driver
   115    [    0.081494] platform ff3c0000.hdmi: Fixing up cyclic dependency with ff370000.vop
   116    [    0.109747] rockchip-gpio ff210000.gpio: probed /pinctrl/gpio@ff210000
   117    [    0.111226] rockchip-gpio ff220000.gpio: probed /pinctrl/gpio@ff220000
   118    [    0.112494] rockchip-gpio ff230000.gpio: probed /pinctrl/gpio@ff230000
   119    [    0.113913] rockchip-gpio ff240000.gpio: probed /pinctrl/gpio@ff240000
   120    [    0.151063] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
   121    [    0.151149] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
   122    [    0.151167] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
   123    [    0.151177] HugeTLB: 508 KiB vmemmap can be freed for a 32.0 MiB page
   124    [    0.151189] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
   125    [    0.151199] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
   126    [    0.151214] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
   127    [    0.151225] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
   128    [    0.153046] cryptd: max_cpu_qlen set to 1000
   129    [    0.219345] raid6: neonx8   gen()  1037 MB/s
   130    [    0.287553] raid6: neonx4   gen()  1062 MB/s
   131    [    0.355808] raid6: neonx2   gen()   985 MB/s
   132    [    0.423896] raid6: neonx1   gen()   879 MB/s
   133    [    0.492063] raid6: int64x8  gen()   744 MB/s
   134    [    0.560205] raid6: int64x4  gen()   825 MB/s
   135    [    0.628366] raid6: int64x2  gen()   707 MB/s
   136    [    0.696529] raid6: int64x1  gen()   526 MB/s
   137    [    0.696545] raid6: using algorithm neonx4 gen() 1062 MB/s
   138    [    0.764650] raid6: .... xor() 770 MB/s, rmw enabled
   139    [    0.764663] raid6: using neon recovery algorithm
   140    [    0.771559] iommu: Default domain type: Translated
   141    [    0.771581] iommu: DMA domain TLB invalidation policy: strict mode
   142    [    0.772441] SCSI subsystem initialized
   143    [    0.772827] libata version 3.00 loaded.
   144    [    0.773433] usbcore: registered new interface driver usbfs
   145    [    0.773537] usbcore: registered new interface driver hub
   146    [    0.773628] usbcore: registered new device driver usb
   147    [    0.774692] pps_core: LinuxPPS API ver. 1 registered
   148    [    0.774704] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
   149    [    0.774740] PTP clock support registered
   150    [    0.775150] EDAC MC: Ver: 3.0.0
   151    [    0.778079] NetLabel: Initializing
   152    [    0.778098] NetLabel:  domain hash size = 128
   153    [    0.778112] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
   154    [    0.778238] NetLabel:  unlabeled traffic allowed by default
   155    [    0.778552] vgaarb: loaded
   156    [    0.779509] clocksource: Switched to clocksource arch_sys_counter
   157    [    0.780352] VFS: Disk quotas dquot_6.6.0
   158    [    0.780460] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
   159    [    0.782100] AppArmor: AppArmor Filesystem Enabled
   160    [    0.799534] NET: Registered PF_INET protocol family
   161    [    0.800002] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
   162    [    0.806349] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
   163    [    0.806610] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
   164    [    0.806714] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
   165    [    0.807400] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
   166    [    0.808840] TCP: Hash tables configured (established 32768 bind 32768)
   167    [    0.809102] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
   168    [    0.809281] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
   169    [    0.809773] NET: Registered PF_UNIX/PF_LOCAL protocol family
   170    [    0.809837] NET: Registered PF_XDP protocol family
   171    [    0.809860] PCI: CLS 0 bytes, default 64
   172    [    0.810719] Trying to unpack rootfs image as initramfs...
   173    [    0.821141] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
   174    [    0.822295] kvm [1]: IPA Size Limit: 40 bits
   175    [    0.824790] kvm [1]: vgic interrupt IRQ9
   176    [    0.825052] kvm [1]: Hyp mode initialized successfully
   177    [    0.829191] Initialise system trusted keyrings
   178    [    0.829312] Key type blacklist registered
   179    [    0.829768] workingset: timestamp_bits=44 max_order=20 bucket_order=0
   180    [    0.844186] zbud: loaded
   181    [    0.847780] squashfs: version 4.0 (2009/01/31) Phillip Lougher
   182    [    0.849352] fuse: init (API version 7.37)
   183    [    0.854316] integrity: Platform Keyring initialized
   184    [    0.926185] xor: measuring software checksum speed
   185    [    0.934387]    8regs           :  1220 MB/sec
   186    [    0.942285]    32regs          :  1261 MB/sec
   187    [    0.951592]    arm64_neon      :  1062 MB/sec
   188    [    0.951618] xor: using function: 32regs (1261 MB/sec)
   189    [    0.951640] Key type asymmetric registered
   190    [    0.951652] Asymmetric key parser 'x509' registered
   191    [    2.900853] Freeing initrd memory: 21288K
   192    [    2.945177] alg: self-tests for CTR-KDF (hmac(sha256)) passed
   193    [    2.945322] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
   194    [    2.945600] io scheduler mq-deadline registered
   195    [    2.945616] io scheduler kyber registered
   196    [    2.946069] io scheduler bfq registered
   197    [    2.965138] dma-pl330 ff1f0000.dma-controller: Loaded driver for PL330 DMAC-241330
   198    [    2.965168] dma-pl330 ff1f0000.dma-controller:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
   199    [    2.973894] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
   200    [    2.979967] ff110000.serial: ttyS0 at MMIO 0xff110000 (irq = 25, base_baud = 1500000) is a 16550A
   201    [    2.981904] ff130000.serial: ttyS2 at MMIO 0xff130000 (irq = 26, base_baud = 1500000) is a 16550A
   202    [    2.982368] printk: console [ttyS2] enabled
   203    [    2.984468] Serial: AMBA driver
   204    [    2.993293] rockchip-vop ff370000.vop: Adding to iommu group 4
   205    [    3.019580] loop: module loaded
   206    [    3.028384] tun: Universal TUN/TAP device driver, 1.6
   207    [    3.030214] thunder_xcv, ver 1.0
   208    [    3.030314] thunder_bgx, ver 1.0
   209    [    3.030402] nicpf, ver 1.0
   210    [    3.031858] e1000e: Intel(R) PRO/1000 Network Driver
   211    [    3.031871] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
   212    [    3.031981] igb: Intel(R) Gigabit Ethernet Network Driver
   213    [    3.031997] igb: Copyright (c) 2007-2014 Intel Corporation.
   214    [    3.032088] igbvf: Intel(R) Gigabit Virtual Function Network Driver
   215    [    3.032099] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
   216    [    3.032539] sky2: driver version 1.30
   217    [    3.033621] VFIO - User Level meta-driver version: 0.3
   218    [    3.037533] dwc2 ff580000.usb: supply vusb_d not found, using dummy regulator
   219    [    3.037865] dwc2 ff580000.usb: supply vusb_a not found, using dummy regulator
   220    [    3.050945] dwc2 ff580000.usb: DWC OTG Controller
   221    [    3.051002] dwc2 ff580000.usb: new USB bus registered, assigned bus number 1
   222    [    3.051064] dwc2 ff580000.usb: irq 34, io mem 0xff580000
   223    [    3.051439] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
   224    [    3.051465] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   225    [    3.051485] usb usb1: Product: DWC OTG Controller
   226    [    3.051540] usb usb1: Manufacturer: Linux 6.1.11-rockchip64 dwc2_hsotg
   227    [    3.051558] usb usb1: SerialNumber: ff580000.usb
   228    [    3.052732] hub 1-0:1.0: USB hub found
   229    [    3.052813] hub 1-0:1.0: 1 port detected
   230    [    3.057234] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
   231    [    3.057285] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
   232    [    3.057546] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
   233    [    3.057658] xhci-hcd xhci-hcd.0.auto: irq 33, io mem 0xff600000
   234    [    3.058157] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
   235    [    3.058187] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 3
   236    [    3.058215] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
   237    [    3.058232] ehci-platform ff5c0000.usb: EHCI Host Controller
   238    [    3.058265] ohci-platform ff5d0000.usb: Generic Platform OHCI controller
   239    [    3.058563] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
   240    [    3.058589] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   241    [    3.058610] usb usb2: Product: xHCI Host Controller
   242    [    3.058627] usb usb2: Manufacturer: Linux 6.1.11-rockchip64 xhci-hcd
   243    [    3.058644] usb usb2: SerialNumber: xhci-hcd.0.auto
   244    [    3.059916] hub 2-0:1.0: USB hub found
   245    [    3.059990] hub 2-0:1.0: 1 port detected
   246    [    3.060785] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
   247    [    3.061083] usb usb3: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
   248    [    3.061110] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   249    [    3.061130] usb usb3: Product: xHCI Host Controller
   250    [    3.061147] usb usb3: Manufacturer: Linux 6.1.11-rockchip64 xhci-hcd
   251    [    3.061165] usb usb3: SerialNumber: xhci-hcd.0.auto
   252    [    3.062234] hub 3-0:1.0: USB hub found
   253    [    3.062302] hub 3-0:1.0: 1 port detected
   254    [    3.063014] ehci-platform ff5c0000.usb: new USB bus registered, assigned bus number 4
   255    [    3.063040] ohci-platform ff5d0000.usb: new USB bus registered, assigned bus number 5
   256    [    3.063225] usbcore: registered new interface driver usb-storage
   257    [    3.063254] ehci-platform ff5c0000.usb: irq 35, io mem 0xff5c0000
   258    [    3.063298] ohci-platform ff5d0000.usb: irq 36, io mem 0xff5d0000
   259    [    3.066773] mousedev: PS/2 mouse device common for all mice
   260    [    3.068470] i2c_dev: i2c /dev entries driver
   261    [    3.073298] dw_wdt ff1a0000.watchdog: No valid TOPs array specified
   262    [    3.075577] ehci-platform ff5c0000.usb: USB 2.0 started, EHCI 1.00
   263    [    3.076027] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
   264    [    3.076055] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   265    [    3.076073] usb usb4: Product: EHCI Host Controller
   266    [    3.076088] usb usb4: Manufacturer: Linux 6.1.11-rockchip64 ehci_hcd
   267    [    3.076103] usb usb4: SerialNumber: ff5c0000.usb
   268    [    3.077122] sdhci: Secure Digital Host Controller Interface driver
   269    [    3.077142] sdhci: Copyright(c) Pierre Ossman
   270    [    3.077141] hub 4-0:1.0: USB hub found
   271    [    3.077190] Synopsys Designware Multimedia Card Interface Driver
   272    [    3.077208] hub 4-0:1.0: 1 port detected
   273    [    3.078938] sdhci-pltfm: SDHCI platform and OF driver helper
   274    [    3.079824] dwmmc_rockchip ff510000.mmc: IDMAC supports 32-bit address mode.
   275    [    3.079892] dwmmc_rockchip ff510000.mmc: Using internal DMA controller.
   276    [    3.079913] dwmmc_rockchip ff510000.mmc: Version ID is 270a
   277    [    3.079976] dwmmc_rockchip ff500000.mmc: IDMAC supports 32-bit address mode.
   278    [    3.080014] dwmmc_rockchip ff510000.mmc: DW MMC controller at irq 39,32 bit host data width,256 deep fifo
   279    [    3.080019] dwmmc_rockchip ff500000.mmc: Using internal DMA controller.
   280    [    3.080041] dwmmc_rockchip ff500000.mmc: Version ID is 270a
   281    [    3.080124] dwmmc_rockchip ff500000.mmc: DW MMC controller at irq 40,32 bit host data width,256 deep fifo
   282    [    3.080300] dwmmc_rockchip ff520000.mmc: IDMAC supports 32-bit address mode.
   283    [    3.080349] dwmmc_rockchip ff520000.mmc: Using internal DMA controller.
   284    [    3.080369] dwmmc_rockchip ff520000.mmc: Version ID is 270a
   285    [    3.080468] dwmmc_rockchip ff520000.mmc: DW MMC controller at irq 41,32 bit host data width,256 deep fifo
   286    [    3.080497] dwmmc_rockchip ff510000.mmc: allocated mmc-pwrseq
   287    [    3.080518] mmc_host mmc1: card is non-removable.
   288    [    3.080650] dwmmc_rockchip ff500000.mmc: Got CD GPIO
   289    [    3.081598] mmc_host mmc2: card is non-removable.
   290    [    3.082291] dwmmc_rockchip ff5f0000.dwmmc: IDMAC supports 32-bit address mode.
   291    [    3.082353] dwmmc_rockchip ff5f0000.dwmmc: Using internal DMA controller.
   292    [    3.082374] dwmmc_rockchip ff5f0000.dwmmc: Version ID is 270a
   293    [    3.082483] dwmmc_rockchip ff5f0000.dwmmc: DW MMC controller at irq 42,32 bit host data width,256 deep fifo
   294    [    3.083072] dwmmc_rockchip ff5f0000.dwmmc: Got CD GPIO
   295    [    3.083474] ledtrig-cpu: registered to indicate activity on CPUs
   296    [    3.084666] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
   297    [    3.085098] hid: raw HID events driver (C) Jiri Kosina
   298    [    3.085345] usbcore: registered new interface driver usbhid
   299    [    3.085361] usbhid: USB HID core driver
   300    [    3.091628] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
   301    [    3.093738] drop_monitor: Initializing network drop monitor service
   302    [    3.094032] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
   303    [    3.094463] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
   304    [    3.095105] NET: Registered PF_INET6 protocol family
   305    [    3.095636] mmc_host mmc3: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
   306    [    3.123937] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.01
   307    [    3.123975] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   308    [    3.123995] usb usb5: Product: Generic Platform OHCI controller
   309    [    3.124010] usb usb5: Manufacturer: Linux 6.1.11-rockchip64 ohci_hcd
   310    [    3.124025] usb usb5: SerialNumber: ff5d0000.usb
   311    [    3.125230] hub 5-0:1.0: USB hub found
   312    [    3.125329] hub 5-0:1.0: 1 port detected
   313    [    3.140189] Segment Routing with IPv6
   314    [    3.140301] In-situ OAM (IOAM) with IPv6
   315    [    3.140466] NET: Registered PF_PACKET protocol family
   316    [    3.140714] 8021q: 802.1Q VLAN Support v1.8
   317    [    3.140807] Key type dns_resolver registered
   318    [    3.143112] registered taskstats version 1
   319    [    3.143168] Loading compiled-in X.509 certificates
   320    [    3.143619] mmc_host mmc3: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
   321    [    3.143780] mmc_host mmc1: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
   322    [    3.149974] Loaded X.509 cert 'Build time autogenerated kernel key: e25f7f61aa13aedd90bace25454c8646dc5da469'
   323    [    3.153994] zswap: loaded using pool zstd/z3fold
   324    [    3.154140] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
   325    [    3.154333] mmc0: new high speed SDHC card at address 8dfc
   326    [    3.155982] mmcblk0: mmc0:8dfc SU16G 14.8 GiB
   327    [    3.156388] Key type .fscrypt registered
   328    [    3.156427] Key type fscrypt-provisioning registered
   329    [    3.160794] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=yes
   330    [    3.161501] Key type encrypted registered
   331    [    3.161547] AppArmor: AppArmor sha1 policy hashing enabled
   332    [    3.164265]  mmcblk0: p1
   333    [    3.191667] mmc_host mmc3: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
   334    [    3.199657] mmc_host mmc1: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
   335    [    3.243655] mmc_host mmc3: Bus speed (slot 0) = 100000Hz (slot req 100000Hz, actual 100000HZ div = 0)
   336    [    3.251110] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 52000000Hz, actual 50000000HZ div = 0)
   337    [    3.251780] mmc2: new high speed MMC card at address 0001
   338    [    3.253272] mmcblk2: mmc2:0001 CKTM4R 58.2 GiB
   339    [    3.256893] rockchip-drm display-subsystem: bound ff370000.vop (ops vop_component_ops)
   340    [    3.257222] dwhdmi-rockchip ff3c0000.hdmi: supply avdd-0v9 not found, using dummy regulator
   341    [    3.257683] dwhdmi-rockchip ff3c0000.hdmi: supply avdd-1v8 not found, using dummy regulator
   342    [    3.258457] mmcblk2boot0: mmc2:0001 CKTM4R 4.00 MiB
   343    [    3.258619] dwhdmi-rockchip ff3c0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (inno_dw_hdmi_phy2)
   344    [    3.259689] mmc_host mmc1: Bus speed (slot 0) = 100000Hz (slot req 100000Hz, actual 100000HZ div = 0)
   345    [    3.262845] mmcblk2boot1: mmc2:0001 CKTM4R 4.00 MiB
   346    [    3.264567] dwhdmi-rockchip ff3c0000.hdmi: registered DesignWare HDMI I2C bus driver
   347    [    3.265503] rockchip-drm display-subsystem: bound ff3c0000.hdmi (ops dw_hdmi_rockchip_ops)
   348    [    3.266460] mmcblk2rpmb: mmc2:0001 CKTM4R 4.00 MiB, chardev (242:0)
   349    [    3.266756] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 0
   350    [    3.355554] usb 1-1: new low-speed USB device number 2 using dwc2
   351    [    3.571416] usb 1-1: New USB device found, idVendor=045e, idProduct=00b0, bcdDevice= 1.10
   352    [    3.571445] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
   353    [    3.571460] usb 1-1: Product: Microsoft® Digital Media Pro Keyboard
   354    [    3.571475] usb 1-1: Manufacturer: Microsoft
   355    [    3.577267] input: Microsoft Microsoft® Digital Media Pro Keyboard as /devices/platform/ff580000.usb/usb1/1-1/1-1:1.0/0003:045E:00B0.0001/input/input0
   356    [    3.581899] Console: switching to colour frame buffer device 240x67
   357    [    3.632704] rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device
   358    [    3.633792] WCN: marlin_init entry!
   359    [    3.634644] of_cfs_init
   360    [    3.634703] of_cfs_init: OK
   361    [    3.637404] hid-generic 0003:045E:00B0.0001: input,hidraw0: USB HID v1.11 Keyboard [Microsoft Microsoft® Digital Media Pro Keyboard] on usb-ff580000.usb-1/input0
   362    [    3.638252] Freeing unused kernel memory: 3968K
   363    [    3.638515] Run /init as init process
   364    [    3.638526]   with arguments:
   365    [    3.638539]     /init
   366    [    3.638581]   with environment:
   367    [    3.638594]     HOME=/
   368    [    3.638604]     TERM=linux
   369    [    3.638616]     splash=verbose
   370    [    3.638626]     ubootpart=8635553d-01
   371    [    3.638637]     cgroup_enable=memory
   372    [    3.638648]     cgroup_memory=1
   373    [    3.646487] input: Microsoft Microsoft® Digital Media Pro Keyboard Consumer Control as /devices/platform/ff580000.usb/usb1/1-1/1-1:1.1/0003:045E:00B0.0002/input/input1
   374    [    3.649026] rockchip-pm-domain ff100000.syscon:power-controller: failed to get ack on domain 'hevc', val=0x88220
   375    [    3.704220] input: Microsoft Microsoft® Digital Media Pro Keyboard System Control as /devices/platform/ff580000.usb/usb1/1-1/1-1:1.1/0003:045E:00B0.0002/input/input2
   376    [    3.704797] hid-generic 0003:045E:00B0.0002: input,hidraw1: USB HID v1.11 Device [Microsoft Microsoft® Digital Media Pro Keyboard] on usb-ff580000.usb-1/input1
   377    [    4.696796] input: adc-keys as /devices/platform/adc-keys/input/input3
   378    [    4.713796] gpio-syscon ff100000.syscon:gpio: can't read the data register offset!
   379    [    4.763956] lima ff300000.gpu: gp - mali450 version major 0 minor 0
   380    [    4.764166] lima ff300000.gpu: pp0 - mali450 version major 0 minor 0
   381    [    4.764343] lima ff300000.gpu: pp1 - mali450 version major 0 minor 0
   382    [    4.764456] lima ff300000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
   383    [    4.764482] lima ff300000.gpu: l2 cache 64K, 4-way, 64byte cache line, 128bit external bus
   384    [    4.776012] lima ff300000.gpu: bus rate = 491520000
   385    [    4.776047] lima ff300000.gpu: mod rate = 491520000
   386    [    4.779025] [drm] Initialized lima 1.1.0 20191231 for ff300000.gpu on minor 1
   387    [    4.884875] rk_gmac-dwmac ff550000.ethernet: IRQ eth_wake_irq not found
   388    [    4.884910] rk_gmac-dwmac ff550000.ethernet: IRQ eth_lpi not found
   389    [    4.885141] rk_gmac-dwmac ff550000.ethernet: PTP uses main clock
   390    [    4.885726] rk_gmac-dwmac ff550000.ethernet: clock input or output? (output).
   391    [    4.885764] rk_gmac-dwmac ff550000.ethernet: TX delay(0x30).
   392    [    4.885784] rk_gmac-dwmac ff550000.ethernet: RX delay(0x10).
   393    [    4.885832] rk_gmac-dwmac ff550000.ethernet: integrated PHY? (yes).
   394    [    4.885987] rk_gmac-dwmac ff550000.ethernet: cannot get clock clk_mac_refout
   395    [    4.886009] rk_gmac-dwmac ff550000.ethernet: cannot get clock clk_mac_speed
   396    [    4.898852] rk_gmac-dwmac ff550000.ethernet: init for RMII
   397    [    4.943776] rk_gmac-dwmac ff550000.ethernet: User ID: 0x10, Synopsys ID: 0x35
   398    [    4.943822] rk_gmac-dwmac ff550000.ethernet:     DWMAC1000
   399    [    4.943838] rk_gmac-dwmac ff550000.ethernet: DMA HW capability register supported
   400    [    4.943852] rk_gmac-dwmac ff550000.ethernet: RX Checksum Offload Engine supported
   401    [    4.943865] rk_gmac-dwmac ff550000.ethernet: COE Type 2
   402    [    4.943880] rk_gmac-dwmac ff550000.ethernet: TX Checksum insertion supported
   403    [    4.943892] rk_gmac-dwmac ff550000.ethernet: Wake-Up On Lan supported
   404    [    4.944103] rk_gmac-dwmac ff550000.ethernet: Normal descriptors
   405    [    4.944128] rk_gmac-dwmac ff550000.ethernet: Ring mode enabled
   406    [    4.944141] rk_gmac-dwmac ff550000.ethernet: Enable RX Mitigation via HW Watchdog Timer
   407    [    5.106303] rk_gmac-dwmac ff550000.ethernet end1: renamed from eth0
   408    [    5.221261] dw-apb-uart ff130000.serial: forbid DMA for kernel console
   409    [    5.858999] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Quota mode: none.
   410    [    7.797066] systemd[1]: System time before build time, advancing clock.
   411    [    7.872139] systemd[1]: Inserted module 'autofs4'
   412    [    8.030402] systemd[1]: systemd 252.5-2 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
   413    [    8.030461] systemd[1]: Detected architecture arm64.
   414    [    8.034828] systemd[1]: Detected first boot.
   415    [    8.050775] systemd[1]: Hostname set to <rk3318-box>.
   416    [    8.065281] systemd[1]: Initializing machine ID from random generator.
   417    [    9.359789] systemd[330]: /usr/lib/systemd/system-generators/netplan failed with exit status 1.
   418    [   13.049943] systemd[1]: Failed to populate /etc with preset unit settings, ignoring: Read-only file system
   419    [   13.067563] random: crng init done
   420    [   13.771297] systemd[1]: Queued start job for default target graphical.target.
   421    [   13.797192] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
   422    [   13.801704] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
   423    [   13.804910] systemd[1]: Created slice user.slice - User and Session Slice.
   424    [   13.805992] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
   425    [   13.808103] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
   426    [   13.808881] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
   427    [   13.809644] systemd[1]: Reached target remote-fs.target - Remote File Systems.
   428    [   13.810022] systemd[1]: Reached target slices.target - Slice Units.
   429    [   13.810668] systemd[1]: Reached target swap.target - Swaps.
   430    [   13.811167] systemd[1]: Reached target time-set.target - System Time Set.
   431    [   13.811928] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
   432    [   13.821721] systemd[1]: Listening on syslog.socket - Syslog Socket.
   433    [   13.823415] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
   434    [   13.824519] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
   435    [   13.826487] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
   436    [   13.828102] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
   437    [   13.830157] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
   438    [   13.839424] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
   439    [   13.840993] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
   440    [   13.876215] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
   441    [   13.885810] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
   442    [   13.896125] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
   443    [   13.906685] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
   444    [   13.922019] systemd[1]: Starting fake-hwclock.service - Restore / save the current clock...
   445    [   13.932792] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
   446    [   13.944073] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
   447    [   13.955783] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
   448    [   13.969318] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
   449    [   13.981345] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
   450    [   13.993295] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
   451    [   13.995192] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
   452    [   14.021539] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
   453    [   14.032612] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
   454    [   14.033802] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
   455    [   14.043802] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
   456    [   14.063223] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
   457    [   14.066245] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
   458    [   14.069543] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
   459    [   14.072503] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
   460    [   14.077002] systemd[1]: Finished fake-hwclock.service - Restore / save the current clock.
   461    [   14.083307] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
   462    [   14.090658] systemd[1]: modprobe@configfs.service: Deactivated successfully.
   463    [   14.093098] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
   464    [   14.099305] systemd[1]: modprobe@drm.service: Deactivated successfully.
   465    [   14.101843] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
   466    [   14.106329] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
   467    [   14.108968] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
   468    [   14.113768] systemd[1]: modprobe@fuse.service: Deactivated successfully.
   469    [   14.116183] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
   470    [   14.121652] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
   471    [   14.156265] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
   472    [   14.157697] EXT4-fs (mmcblk0p1): re-mounted. Quota mode: none.
   473    [   14.170282] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
   474    [   14.181546] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables...
   475    [   14.209745] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
   476    [   14.213708] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
   477    [   14.217519] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
   478    [   14.221612] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
   479    [   14.232553] systemd[1]: Starting systemd-random-seed.service - Load/Save Random Seed...
   480    [   14.244948] systemd[1]: Starting systemd-sysusers.service - Create System Users...
   481    [   14.314533] systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables.
   482    [   14.380831] systemd[1]: Finished systemd-random-seed.service - Load/Save Random Seed.
   483    [   14.384030] systemd[1]: Reached target first-boot-complete.target - First Boot Complete.
   484    [   14.419222] systemd[1]: Finished systemd-sysusers.service - Create System Users.
   485    [   14.452803] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev...
   486    [   14.628139] systemd[1]: Finished systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev.
   487    [   14.662999] systemd[1]: Starting systemd-udevd.service - Rule-based Manager for Device Events and Files...
   488    [   14.694192] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout.
   489    [   14.696749] systemd[1]: Reached target local-fs-pre.target - Preparation for Local File Systems.
   490    [   15.096232] systemd[1]: Mounting tmp.mount - /tmp...
   491    [   15.120734] systemd[1]: Mounted tmp.mount - /tmp.
   492    [   15.132508] systemd[1]: Reached target local-fs.target - Local File Systems.
   493    [   15.152137] systemd[1]: Starting armbian-led-state.service - Armbian leds state...
   494    [   15.172574] systemd[1]: Starting armbian-zram-config.service - Armbian ZRAM config...
   495    [   15.192988] systemd[1]: Starting console-setup.service - Set console font and keymap...
   496    [   15.206757] systemd[1]: Starting plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data...
   497    [   15.285718] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
   498    [   15.299994] systemd[1]: Starting systemd-machine-id-commit.service - Commit a transient machine-id on disk...
   499    [   15.315336] systemd[1]: Finished console-setup.service - Set console font and keymap.
   500    [   15.338392] systemd[1]: Received SIGRTMIN+20 from PID 295 (plymouthd).
   501    [   15.370027] systemd[1]: Finished systemd-udev-trigger.service - Coldplug All udev Devices.
   502    [   15.376292] systemd[1]: Finished plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data.
   503    [   15.432850] systemd[1]: Starting ifupdown-pre.service - Helper to synchronize boot up for ifupdown...
   504    [   15.433791] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 391 (systemd-binfmt)
   505    [   15.445813] systemd[1]: Mounting proc-sys-fs-binfmt_misc.mount - Arbitrary Executable File Formats File System...
   506    [   15.473045] systemd[1]: Started systemd-udevd.service - Rule-based Manager for Device Events and Files.
   507    [   15.532376] systemd[1]: Starting plymouth-start.service - Show Plymouth Boot Screen...
   508    [   15.546707] systemd[1]: Finished armbian-led-state.service - Armbian leds state.
   509    [   15.551416] systemd[1]: Mounted proc-sys-fs-binfmt_misc.mount - Arbitrary Executable File Formats File System.
   510    [   15.576382] systemd[1]: Finished ifupdown-pre.service - Helper to synchronize boot up for ifupdown.
   511    [   15.614256] systemd[1]: Finished systemd-binfmt.service - Set Up Additional Binary Formats.
   512    [   15.824620] systemd[1]: Started plymouth-start.service - Show Plymouth Boot Screen.
   513    [   15.828096] systemd[1]: bootsplash-ask-password-console.path - Dispatch Password Requests to Console Directory Watch when bootsplash is active was skipped because of an unmet condition check (ConditionPathExists=/sys/devices/platform/bootsplash.0/enabled).
   514    [   15.830048] systemd[1]: Started systemd-ask-password-plymouth.path - Forward Password Requests to Plymouth Directory Watch.
   515    [   15.835300] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
   516    [   15.846712] systemd[1]: Reached target paths.target - Path Units.
   517    [   15.957277] systemd[1]: Found device dev-ttyS2.device - /dev/ttyS2.
   518    [   16.123430] systemd[1]: etc-machine\x2did.mount: Deactivated successfully.
   519    [   16.129764] systemd[1]: Finished systemd-machine-id-commit.service - Commit a transient machine-id on disk.
   520    [   16.656599] mc: Linux media interface: v0.10
   521    [   16.728663] zram: Added device: zram0
   522    [   16.729532] zram: Added device: zram1
   523    [   16.730359] zram: Added device: zram2
   524    [   16.748315] videodev: Linux video capture interface: v2.00
   525    [   16.962661] Registered IR keymap rc-empty
   526    [   16.963314] rc rc0: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc0
   527    [   16.974804] rc rc0: lirc_dev: driver gpio_ir_recv registered at minor = 0, raw IR receiver, no transmitter
   528    [   16.975110] input: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc0/input4
   529    [   17.084878] rockchip_vdec: module is from the staging directory, the quality is unknown, you have been warned.
   530    [   17.098483] zram0: detected capacity change from 0 to 4069848
   531    [   17.102751] rkvdec ff360000.video-codec: Adding to iommu group 3
   532    [   17.109646] hantro-vpu ff350000.video-codec: Adding to iommu group 2
   533    [   17.114522] rockchip-rga ff390000.rga: HW Version: 0x04.00
   534    [   17.115106] rockchip-rga ff390000.rga: Registered rockchip-rga as /dev/video1
   535    [   17.132163] hantro-vpu ff350000.video-codec: registered rockchip,rk3328-vpu-dec as /dev/video2
   536    [   17.170215] Adding 2034920k swap on /dev/zram0.  Priority:5 extents:1 across:2034920k SSFS
   537    [   17.357557] rk3328-codec ff410000.codec: spk_depop_time use default value.
   538    [   17.460547] systemd[1]: Reached target sound.target - Sound Card.
   539    [   17.591692] zram1: detected capacity change from 0 to 102400
   540    [   17.744459] systemd[1]: Finished armbian-zram-config.service - Armbian ZRAM config.
   541    [   17.780935] systemd[1]: Starting armbian-ramlog.service - Armbian memory supported logging...
   542    [   17.931610] EXT4-fs (zram1): mounted filesystem without journal. Quota mode: none.
   543    [   22.145437] systemd[1]: Finished armbian-ramlog.service - Armbian memory supported logging.
   544    [   22.177354] systemd[1]: Starting systemd-journald.service - Journal Service...
   545    [   22.528489] systemd[1]: Started systemd-journald.service - Journal Service.
   546    [   22.621369] systemd-journald[577]: Received client request to flush runtime journal.
   547
   548    ### armbian-release:
   549
   550    # PLEASE DO NOT EDIT THIS FILE
   551    BOARD=rk3318-box
   552    BOARD_NAME="RK3318 Box"
   553    BOARDFAMILY=rockchip64
   554    BUILD_REPOSITORY_URL=https://github.com/armbian/build
   555    BUILD_REPOSITORY_COMMIT=313c893
   556    VERSION=23.02.0-trunk
   557    LINUXFAMILY=rockchip64
   558    ARCH=arm64
   559    IMAGE_TYPE=nightly
   560    BOARD_TYPE=tvb
   561    INITRD_ARCH=arm64
   562    KERNEL_IMAGE_TYPE=Image
   563
   564    ### boot environment:
   565
   566    verbosity=1
   567    bootlogo=false
   568    overlay_prefix=rockchip
   569    fdtfile=rockchip/rk3318-box.dtb
   570    rootdev=UUID=2eb1e931-b16f-46a3-8b3b-f0a92acc8ddb
   571    rootfstype=ext4
   572
   573    ### lsusb:
   574
   575    Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
   576    Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
   577    Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
   578    Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
   579    Bus 001 Device 002: ID 045e:00b0 Microsoft Corp. Digital Media Pro Keyboard
   580    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
   581
   582    ### lscpu:
   583
   584    Architecture:                    aarch64
   585    CPU op-mode(s):                  32-bit, 64-bit
   586    Byte Order:                      Little Endian
   587    CPU(s):                          4
   588    On-line CPU(s) list:             0-3
   589    Vendor ID:                       ARM
   590    Model name:                      Cortex-A53
   591    Model:                           4
   592    Thread(s) per core:              1
   593    Core(s) per cluster:             4
   594    Socket(s):                       -
   595    Cluster(s):                      1
   596    Stepping:                        r0p4
   597    CPU(s) scaling MHz:              100%
   598    CPU max MHz:                     1008.0000
   599    CPU min MHz:                     600.0000
   600    BogoMIPS:                        48.00
   601    Flags:                           fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
   602    NUMA node(s):                    1
   603    NUMA node0 CPU(s):               0-3
   604    Vulnerability Itlb multihit:     Not affected
   605    Vulnerability L1tf:              Not affected
   606    Vulnerability Mds:               Not affected
   607    Vulnerability Meltdown:          Not affected
   608    Vulnerability Mmio stale data:   Not affected
   609    Vulnerability Retbleed:          Not affected
   610    Vulnerability Spec store bypass: Not affected
   611    Vulnerability Spectre v1:        Mitigation; __user pointer sanitization
   612    Vulnerability Spectre v2:        Not affected
   613    Vulnerability Srbds:             Not affected
   614    Vulnerability Tsx async abort:   Not affected
   615
   616    ### cpuinfo:
   617
   618    processor    : 0
   619    BogoMIPS    : 48.00
   620    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
   621    CPU implementer    : 0x41
   622    CPU architecture: 8
   623    CPU variant    : 0x0
   624    CPU part    : 0xd03
   625    CPU revision    : 4
   626
   627    processor    : 1
   628    BogoMIPS    : 48.00
   629    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
   630    CPU implementer    : 0x41
   631    CPU architecture: 8
   632    CPU variant    : 0x0
   633    CPU part    : 0xd03
   634    CPU revision    : 4
   635
   636    processor    : 2
   637    BogoMIPS    : 48.00
   638    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
   639    CPU implementer    : 0x41
   640    CPU architecture: 8
   641    CPU variant    : 0x0
   642    CPU part    : 0xd03
   643    CPU revision    : 4
   644
   645    processor    : 3
   646    BogoMIPS    : 48.00
   647    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
   648    CPU implementer    : 0x41
   649    CPU architecture: 8
   650    CPU variant    : 0x0
   651    CPU part    : 0xd03
   652    CPU revision    : 4
   653
   654
   655    ### meminfo:
   656
   657    MemTotal:        4069844 kB
   658    MemFree:         3883136 kB
   659    MemAvailable:    3883436 kB
   660    Buffers:            8188 kB
   661    Cached:            55368 kB
   662    SwapCached:            0 kB
   663    Active:            45132 kB
   664    Inactive:          18444 kB
   665    Active(anon):      11252 kB
   666    Inactive(anon):      768 kB
   667    Active(file):      33880 kB
   668    Inactive(file):    17676 kB
   669    Unevictable:       11088 kB
   670    Mlocked:               0 kB
   671    SwapTotal:       2034920 kB
   672    SwapFree:        2034920 kB
   673    Zswap:                 0 kB
   674    Zswapped:              0 kB
   675    Dirty:               356 kB
   676    Writeback:             0 kB
   677    AnonPages:         11344 kB
   678    Mapped:            15280 kB
   679    Shmem:              8828 kB
   680    KReclaimable:      16620 kB
   681    Slab:              46440 kB
   682    SReclaimable:      16620 kB
   683    SUnreclaim:        29820 kB
   684    KernelStack:        2072 kB
   685    PageTables:          760 kB
   686    SecPageTables:         0 kB
   687    NFS_Unstable:          0 kB
   688    Bounce:                0 kB
   689    WritebackTmp:          0 kB
   690    CommitLimit:     4069840 kB
   691    Committed_AS:      35292 kB
   692    VmallocTotal:   133143592960 kB
   693    VmallocUsed:       34788 kB
   694    VmallocChunk:          0 kB
   695    Percpu:             1008 kB
   696    AnonHugePages:         0 kB
   697    ShmemHugePages:        0 kB
   698    ShmemPmdMapped:        0 kB
   699    FileHugePages:         0 kB
   700    FilePmdMapped:         0 kB
   701    CmaTotal:         131072 kB
   702    CmaFree:          122368 kB
   703    HugePages_Total:       0
   704    HugePages_Free:        0
   705    HugePages_Rsvd:        0
   706    HugePages_Surp:        0
   707    Hugepagesize:       2048 kB
   708    Hugetlb:               0 kB
   709
   710    ### virtual memory:
   711
   712    vm.admin_reserve_kbytes = 8192
   713    vm.compaction_proactiveness = 20
   714    Sun Feb 12 05:58:46 PM UTC 2023 | RK3318 Box | 23.02.0-trunk | arm64 | aarch64 | 6.1.11-rockchip64
   715    vm.compact_unevictable_allowed = 1
   716    vm.dirty_background_bytes = 0
   717    vm.dirty_background_ratio = 10
   718    vm.dirty_bytes = 0
   719    vm.dirty_expire_centisecs = 3000
   720
   721    ### [resize2fs] Trying to resize partition /dev/mmcblk0p1:
   722
   723    vm.dirty_ratio = 20
   724    vm.dirtytime_expire_seconds = 43200
   725    diskdevname: mmcblk0
   726    diskdev: /dev/mmcblk0
   727    vm.dirty_writeback_centisecs = 500
   728    vm.extfrag_threshold = 500
   729    partindex: 1
   730    vm.hugetlb_optimize_vmemmap = 0
   731    vm.hugetlb_shm_group = 0
   732    vm.laptop_mode = 0
   733    vm.legacy_va_layout = 0
   734    vm.lowmem_reserve_ratio = 256    256    32    0
   735    vm.max_map_count = 65530
   736    vm.min_free_kbytes = 22528
   737    vm.min_slab_ratio = 5
   738    vm.min_unmapped_ratio = 1
   739    vm.mmap_min_addr = 4096
   740    vm.mmap_rnd_bits = 18
   741    vm.mmap_rnd_compat_bits = 11
   742    vm.nr_hugepages = 0
   743    vm.nr_hugepages_mempolicy = 0
   744    partstart: 32768s
   745    partend: 3907583s
   746    vm.nr_overcommit_hugepages = 0
   747    vm.numa_stat = 1
   748    vm.numa_zonelist_order = Node
   749    vm.oom_dump_tasks = 1
   750    vm.oom_kill_allocating_task = 0
   751    vm.overcommit_kbytes = 0
   752    vm.overcommit_memory = 0
   753    vm.overcommit_ratio = 50
   754    vm.page-cluster = 0
   755    vm.page_lock_unfairness = 5
   756    vm.panic_on_oom = 0
   757    vm.percpu_pagelist_high_fraction = 0
   758    vm.stat_interval = 1
   759    vm.swappiness = 100
   760    vm.user_reserve_kbytes = 125902
   761    vm.vfs_cache_pressure = 100
   762    capacity: 31116288s
   763    sectorsize: 512B
   764    Leaving 1% spare area
   765    Old partition table:
   766
   767    vm.watermark_boost_factor = 15000
   768    major minor  #blocks  name
   769
   770     179        0   15558144 mmcblk0
   771     179        1    1937408 mmcblk0p1
   772     179       32   61071360 mmcblk2
   773     179       64       4096 mmcblk2boot0
   774     179       96       4096 mmcblk2boot1
   775     252        0    2034924 zram0
   776     252        1      51200 zram1
   777
   778    Executing fdisk:
   779    vm.watermark_scale_factor = 10
   780    vm.zone_reclaim_mode = 0
   781
   782    ### ip addr:
   783
   784    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
   785        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
   786        inet XXX.XXX.0.1/8 scope host lo
   787           valid_lft forever preferred_lft forever
   788        inet6 ::1/128 scope host
   789           valid_lft forever preferred_lft forever
   790    2: end1: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
   791        link/ether 52:d1:50:3d:d5:78 brd ff:ff:ff:ff:ff:ff
   792
   793    ### partitions:
   794
   795    major minor  #blocks  name
   796
   797     179        0   15558144 mmcblk0
   798     179        1    1937408 mmcblk0p1
   799     179       32   61071360 mmcblk2
   800     179       64       4096 mmcblk2boot0
   801     179       96       4096 mmcblk2boot1
   802     252        0    2034924 zram0
   803     252        1      51200 zram1
   804
   805    ### df:
   806
   807    udev            1.9G     0  1.9G   0% /dev
   808    tmpfs           398M  724K  397M   1% /run
   809    /dev/mmcblk0p1  1.8G  1.5G  251M  86% /
   810    tmpfs           2.0G     0  2.0G   0% /dev/shm
   811    tmpfs           5.0M     0  5.0M   0% /run/lock
   812    tmpfs           2.0G     0  2.0G   0% /tmp
   813    /dev/zram1       47M  504K   43M   2% /var/log
   814
   815    ### lsblk:
   816
   817    NAME         FSTYPE  SIZE MOUNTPOINT UUID
   818    mmcblk0             14.8G
   819    └─mmcblk0p1  ext4    1.8G /          2eb1e931-b16f-46a3-8b3b-f0a92acc8ddb
   820    mmcblk2             58.2G
   821    mmcblk2boot0           4M
   822    mmcblk2boot1           4M
   823    zram1                 50M /var/log
   824    zram2                  0B
   825
   826    ### zramctl:
   827
   828    NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
   829    /dev/zram1 zstd           50M  544K   89K  380K       4 /var/log
   830    /dev/zram0 lzo-rle       1.9G    4K   74B   12K       4 [SWAP]
   831
   832    ### mtab:
   833
   834    /dev/mmcblk0p1 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0
   835    /dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0
   836    /dev/zram1 /var/log ext4 rw,relatime,discard 0 0
   837
   838    Welcome to fdisk (util-linux 2.38.1).
   839    Changes will remain in memory only, until you decide to write them.
   840    Be careful before using the write command.
   841
   842    This disk is currently in use - repartitioning is probably a bad idea.
   843    It's recommended to umount all file systems, and swapoff all swap
   844    partitions on this disk.
   845
   846
   847    Command (m for help):
   848    Selected partition 1
   849    Partition 1 has been deleted.
   850
   851    Command (m for help): Partition type
   852       p   primary (0 primary, 0 extended, 4 free)
   853       e   extended (container for logical partitions)
   854    Select (default p): Partition number (1-4, default 1): First sector (2048-31116287, default 2048): Last sector, +/-sectors or +/-size{K,M,G,T,P} (32768-31116287, default 31116287):
   855    Created a new partition 1 of type 'Linux' and of size 14.7 GiB.
   856    Partition #1 contains a ext4 signature.
   857
   858    Command (m for help):
   859    The partition table has been altered.
   860    Syncing disks.
   861
   862
   863    Executing partprobe:
   864    New partition table:
   865
   866    major minor  #blocks  name
   867
   868     179        0   15558144 mmcblk0
   869     179        1   15384576 mmcblk0p1
   870     179       32   61071360 mmcblk2
   871     179       64       4096 mmcblk2boot0
   872     179       96       4096 mmcblk2boot1
   873     252        0    2034924 zram0
   874     252        1      51200 zram1
   875
   876    ### [resize2fs] Trying to resize ext4 filesystem on /dev/mmcblk0p1:
   877
   878    Running 'resize2fs /dev/mmcblk0p1' now...
   879    resize2fs 1.47.0 (5-Feb-2023)
   880
   881    ### mmc0:8dfc info:
   882
   883                   fwrev: 0x0
   884                  uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SU16G MODALIAS=mmc:block
   885                     cid: 03534453553136478060b5bf4000a609
   886                     rca: 0x8dfc
   887                     csd: 400e00325b59000076b27f800a404013
   888                  manfid: 0x000003
   889                     ocr: 0x00300000
   890    preferred_erase_size: 4194304
   891                    type: SD
   892                   hwrev: 0x8
   893                    date: 06/2010
   894                     dsr: 0x404
   895              erase_size: 512
   896                   oemid: 0x5344
   897                  serial: 0x60b5bf40
   898                     ssr: 0000000004000000010190000b050000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
   899                     scr: 0235800000000000
   900                    name: SU16G
   901
   902    ### mmc2:0001 info:
   903
   904                   fwrev: 0x0500000000000000
   905                  uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=CKTM4R MODALIAS=mmc:block
   906                     cid: 150100434b544d345202a448f479c3a1
   907             rel_sectors: 0x1
   908    enhanced_rpmb_supported: 0x1
   909                     rca: 0x0001
   910            pre_eol_info: 0x01
   911                     csd: d02701320f5903fff6dbffef8e40400d
   912                  manfid: 0x000015
   913                     ocr: 0x00300000
   914    preferred_erase_size: 4194304
   915    enhanced_area_offset: 18446744073709551594
   916      raw_rpmb_size_mult: 0x20
   917                    type: MMC
   918                   hwrev: 0x0
   919                    date: 12/2016
   920                     prv: 0x2
   921             ffu_capable: 1
   922                     dsr: 0x404
   923              erase_size: 524288
   924               life_time: 0x01 0x01
   925      enhanced_area_size: 4294967274
   926                   oemid: 0x0100
   927                  serial: 0xa448f479
   928                 cmdq_en: 0
   929                     rev: 0x8
   930                    name: CKTM4R
   931
   932    ### Boot system health:
   933
   934    Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU  C.St.
   935    17:58:51:  816MHz  0.68  45%  22%  11%   0%  11%   0% 41.4 °C  0/3
   936    17:58:51:  816MHz  0.68  39%   3%   0%   0%  35%   0% 40.5 °C  0/3
   937    17:58:52:  816MHz  0.68  29%   5%   0%   0%  23%   0% 40.0 °C  0/3
   938    17:58:52:  816MHz  0.68  29%   5%   0%   0%  23%   0% 39.5 °C  0/3
   939    17:58:53:  816MHz  0.71  30%   5%   0%   0%  23%   0% 40.5 °C  0/3
   940    Filesystem at /dev/mmcblk0p1 is mounted on /; on-line resizing required
   941    old_desc_blocks = 1, new_desc_blocks = 1
   942    The filesystem on /dev/mmcblk0p1 is now 3846144 (4k) blocks long.
   943
   944    Removed "/etc/systemd/system/basic.target.wants/armbian-resize-filesystem.service".
   945
   946    ### quick iozone test: 4      124      378     4020     4058     3334      748
   947
   948    ### [firstrun] Recreated SSH keys (entropy: 256 256)
   949
   950    ### Activated 1 lzo-rle zram swap devices with 1987MB each.
   951    ### Activated Armbian ramlog partition with zstd compression
   952
   953    Sun Feb 12 09:03:05 PM MSK 2023 | RK3318 Box | 23.02.0-trunk | arm64 | aarch64 | 6.1.11-rockchip64
   954
   955    ### dmesg:
   956
   957    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
   958    [    0.000000] Linux version 6.1.11-rockchip64 (root@7284a09ced08) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #trunk.0248 SMP PREEMPT Fri Feb 10 05:25:40 UTC 2023
   959    [    0.000000] Machine model: Rockchip RK3318 BOX
   960    [    0.000000] efi: UEFI not found.
   961    [    0.000000] NUMA: No NUMA configuration found
   962    [    0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x00000000feffffff]
   963    [    0.000000] NUMA: NODE_DATA [mem 0xfe7b1a80-0xfe7b3fff]
   964    [    0.000000] Zone ranges:
   965    [    0.000000]   DMA      [mem 0x0000000000200000-0x00000000feffffff]
   966    [    0.000000]   DMA32    empty
   967    [    0.000000]   Normal   empty
   968    [    0.000000] Movable zone start for each node
   969    [    0.000000] Early memory node ranges
   970    [    0.000000]   node   0: [mem 0x0000000000200000-0x00000000feffffff]
   971    [    0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000000feffffff]
   972    [    0.000000] On node 0, zone DMA: 512 pages in unavailable ranges
   973    [    0.000000] On node 0, zone DMA: 4096 pages in unavailable ranges
   974    [    0.000000] cma: Reserved 128 MiB at 0x00000000f2600000
   975    [    0.000000] psci: probing for conduit method from DT.
   976    [    0.000000] psci: PSCIv1.1 detected in firmware.
   977    [    0.000000] psci: Using standard PSCI v0.2 function IDs
   978    [    0.000000] psci: MIGRATE_INFO_TYPE not supported.
   979    [    0.000000] psci: SMC Calling Convention v1.2
   980    [    0.000000] percpu: Embedded 30 pages/cpu s82472 r8192 d32216 u122880
   981    [    0.000000] pcpu-alloc: s82472 r8192 d32216 u122880 alloc=30*4096
   982    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
   983    [    0.000000] Detected VIPT I-cache on CPU0
   984    [    0.000000] CPU features: detected: ARM erratum 845719
   985    [    0.000000] alternatives: applying boot alternatives
   986    [    0.000000] Fallback order for Node 0: 0
   987    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1027656
   988    [    0.000000] Policy zone: DMA
   989    [    0.000000] Kernel command line: root=UUID=2eb1e931-b16f-46a3-8b3b-f0a92acc8ddb rootwait rootfstype=ext4 splash=verbose console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart=8635553d-01 usb-storage.quirks=   cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
   990    [    0.000000] The swapaccount= commandline option is deprecated. Please report your usecase to linux-mm@kvack.org if you depend on this functionality.
   991    [    0.000000] Unknown kernel command line parameters "splash=verbose ubootpart=8635553d-01 cgroup_enable=memory cgroup_memory=1", will be passed to user space.
   992    [    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
   993    [    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
   994    [    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
   995    [    0.000000] Memory: 3913516K/4175872K available (16448K kernel code, 2240K rwdata, 5832K rodata, 3968K init, 585K bss, 131284K reserved, 131072K cma-reserved)
   996    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
   997    [    0.000000] trace event string verifier disabled
   998    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
   999    [    0.000000] rcu:     RCU event tracing is enabled.
  1000    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
  1001    [    0.000000]     Trampoline variant of Tasks RCU enabled.
  1002    [    0.000000]     Tracing variant of Tasks RCU enabled.
  1003    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
  1004    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
  1005    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
  1006    [    0.000000] Root IRQ handler: gic_handle_irq
  1007    [    0.000000] GIC: Using split EOI/Deactivate mode
  1008    [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
  1009    [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
  1010    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  1011    [    0.000001] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  1012    [    0.001127] Console: colour dummy device 80x25
  1013    [    0.001214] printk: console [tty1] enabled
  1014    [    0.001330] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
  1015    [    0.001353] pid_max: default: 32768 minimum: 301
  1016    [    0.001504] LSM: Security Framework initializing
  1017    [    0.001556] Yama: becoming mindful.
  1018    [    0.001723] AppArmor: AppArmor initialized
  1019    [    0.001771] Stack Depot allocating hash table of 262144 entries with kvcalloc
  1020    [    0.002428] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
  1021    [    0.002468] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
  1022    [    0.005811] cblist_init_generic: Setting adjustable number of callback queues.
  1023    [    0.005838] cblist_init_generic: Setting shift to 2 and lim to 1.
  1024    [    0.006040] cblist_init_generic: Setting shift to 2 and lim to 1.
  1025    [    0.006481] rcu: Hierarchical SRCU implementation.
  1026    [    0.006494] rcu:     Max phase no-delay instances is 1000.
  1027    [    0.010196] EFI services will not be available.
  1028    [    0.010924] smp: Bringing up secondary CPUs ...
  1029    [    0.012185] Detected VIPT I-cache on CPU1
  1030    [    0.012374] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
  1031    [    0.013717] Detected VIPT I-cache on CPU2
  1032    [    0.013906] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
  1033    [    0.015260] Detected VIPT I-cache on CPU3
  1034    [    0.015451] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
  1035    [    0.015654] smp: Brought up 1 node, 4 CPUs
  1036    [    0.015680] SMP: Total of 4 processors activated.
  1037    [    0.015694] CPU features: detected: 32-bit EL0 Support
  1038    [    0.015703] CPU features: detected: 32-bit EL1 Support
  1039    [    0.015715] CPU features: detected: CRC32 instructions
  1040    [    0.015920] CPU: All CPU(s) started at EL2
  1041    [    0.015943] alternatives: applying system-wide alternatives
  1042    [    0.019514] devtmpfs: initialized
  1043    [    0.043457] Registered cp15_barrier emulation handler
  1044    [    0.043489] Registered setend emulation handler
  1045    [    0.044001] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  1046    [    0.044050] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
  1047    [    0.049667] pinctrl core: initialized pinctrl subsystem
  1048    [    0.050935] DMI not present or invalid.
  1049    [    0.052201] NET: Registered PF_NETLINK/PF_ROUTE protocol family
  1050    [    0.055228] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
  1051    [    0.056724] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
  1052    [    0.057931] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
  1053    [    0.058055] audit: initializing netlink subsys (disabled)
  1054    [    0.058438] audit: type=2000 audit(0.056:1): state=initialized audit_enabled=0 res=1
  1055    [    0.059907] thermal_sys: Registered thermal governor 'fair_share'
  1056    [    0.059922] thermal_sys: Registered thermal governor 'bang_bang'
  1057    [    0.059936] thermal_sys: Registered thermal governor 'step_wise'
  1058    [    0.059947] thermal_sys: Registered thermal governor 'user_space'
  1059    [    0.060064] cpuidle: using governor menu
  1060    [    0.060733] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  1061    [    0.060957] ASID allocator initialised with 65536 entries
  1062    [    0.062900] Serial: AMBA PL011 UART driver
  1063    [    0.082089] platform ff3c0000.hdmi: Fixing up cyclic dependency with ff370000.vop
  1064    [    0.108880] rockchip-gpio ff210000.gpio: probed /pinctrl/gpio@ff210000
  1065    [    0.110327] rockchip-gpio ff220000.gpio: probed /pinctrl/gpio@ff220000
  1066    [    0.111581] rockchip-gpio ff230000.gpio: probed /pinctrl/gpio@ff230000
  1067    [    0.112867] rockchip-gpio ff240000.gpio: probed /pinctrl/gpio@ff240000
  1068    [    0.152574] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
  1069    [    0.152599] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
  1070    [    0.152620] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
  1071    [    0.152630] HugeTLB: 508 KiB vmemmap can be freed for a 32.0 MiB page
  1072    [    0.152645] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
  1073    [    0.152655] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
  1074    [    0.152668] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
  1075    [    0.152679] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
  1076    [    0.154649] cryptd: max_cpu_qlen set to 1000
  1077    [    0.221133] raid6: neonx8   gen()  1037 MB/s
  1078    [    0.289338] raid6: neonx4   gen()  1062 MB/s
  1079    [    0.357585] raid6: neonx2   gen()   985 MB/s
  1080    [    0.425694] raid6: neonx1   gen()   879 MB/s
  1081    [    0.493846] raid6: int64x8  gen()   744 MB/s
  1082    [    0.561991] raid6: int64x4  gen()   823 MB/s
  1083    [    0.630158] raid6: int64x2  gen()   707 MB/s
  1084    [    0.698313] raid6: int64x1  gen()   526 MB/s
  1085    [    0.698327] raid6: using algorithm neonx4 gen() 1062 MB/s
  1086    [    0.766437] raid6: .... xor() 770 MB/s, rmw enabled
  1087    [    0.766450] raid6: using neon recovery algorithm
  1088    [    0.773350] iommu: Default domain type: Translated
  1089    [    0.773372] iommu: DMA domain TLB invalidation policy: strict mode
  1090    [    0.774276] SCSI subsystem initialized
  1091    [    0.774668] libata version 3.00 loaded.
  1092    [    0.775227] usbcore: registered new interface driver usbfs
  1093    [    0.775333] usbcore: registered new interface driver hub
  1094    [    0.775423] usbcore: registered new device driver usb
  1095    [    0.776495] pps_core: LinuxPPS API ver. 1 registered
  1096    [    0.776509] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  1097    [    0.776540] PTP clock support registered
  1098    [    0.776948] EDAC MC: Ver: 3.0.0
  1099    [    0.779927] NetLabel: Initializing
  1100    [    0.779946] NetLabel:  domain hash size = 128
  1101    [    0.779958] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
  1102    [    0.780089] NetLabel:  unlabeled traffic allowed by default
  1103    [    0.780404] vgaarb: loaded
  1104    [    0.781410] clocksource: Switched to clocksource arch_sys_counter
  1105    [    0.782242] VFS: Disk quotas dquot_6.6.0
  1106    [    0.782348] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  1107    [    0.783922] AppArmor: AppArmor Filesystem Enabled
  1108    [    0.801279] NET: Registered PF_INET protocol family
  1109    [    0.801777] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
  1110    [    0.808148] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
  1111    [    0.808399] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
  1112    [    0.808518] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
  1113    [    0.809184] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
  1114    [    0.810623] TCP: Hash tables configured (established 32768 bind 32768)
  1115    [    0.810873] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
  1116    [    0.811061] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
  1117    [    0.811558] NET: Registered PF_UNIX/PF_LOCAL protocol family
  1118    [    0.811630] NET: Registered PF_XDP protocol family
  1119    [    0.811652] PCI: CLS 0 bytes, default 64
  1120    [    0.812421] Trying to unpack rootfs image as initramfs...
  1121    [    0.823072] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
  1122    [    0.824302] kvm [1]: IPA Size Limit: 40 bits
  1123    [    0.826749] kvm [1]: vgic interrupt IRQ9
  1124    [    0.827003] kvm [1]: Hyp mode initialized successfully
  1125    [    0.831147] Initialise system trusted keyrings
  1126    [    0.831274] Key type blacklist registered
  1127    [    0.831707] workingset: timestamp_bits=44 max_order=20 bucket_order=0
  1128    [    0.846223] zbud: loaded
  1129    [    0.849812] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  1130    [    0.851372] fuse: init (API version 7.37)
  1131    [    0.856306] integrity: Platform Keyring initialized
  1132    [    0.927584] xor: measuring software checksum speed
  1133    [    0.935726]    8regs           :  1221 MB/sec
  1134    [    0.943618]    32regs          :  1261 MB/sec
  1135    [    0.952893]    arm64_neon      :  1070 MB/sec
  1136    [    0.952916] xor: using function: 32regs (1261 MB/sec)
  1137    [    0.952939] Key type asymmetric registered
  1138    [    0.952951] Asymmetric key parser 'x509' registered
  1139    [    2.902751] Freeing initrd memory: 21288K
  1140    [    2.946910] alg: self-tests for CTR-KDF (hmac(sha256)) passed
  1141    [    2.947066] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
  1142    [    2.947318] io scheduler mq-deadline registered
  1143    [    2.947334] io scheduler kyber registered
  1144    [    2.947777] io scheduler bfq registered
  1145    [    2.966804] dma-pl330 ff1f0000.dma-controller: Loaded driver for PL330 DMAC-241330
  1146    [    2.966837] dma-pl330 ff1f0000.dma-controller:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
  1147    [    2.975856] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
  1148    [    2.981801] ff110000.serial: ttyS0 at MMIO 0xff110000 (irq = 25, base_baud = 1500000) is a 16550A
  1149    [    2.983666] ff130000.serial: ttyS2 at MMIO 0xff130000 (irq = 26, base_baud = 1500000) is a 16550A
  1150    [    2.984104] printk: console [ttyS2] enabled
  1151    [    2.986259] Serial: AMBA driver
  1152    [    2.995160] rockchip-vop ff370000.vop: Adding to iommu group 4
  1153    [    3.021330] loop: module loaded
  1154    [    3.030269] tun: Universal TUN/TAP device driver, 1.6
  1155    [    3.032159] thunder_xcv, ver 1.0
  1156    [    3.032259] thunder_bgx, ver 1.0
  1157    [    3.032344] nicpf, ver 1.0
  1158    [    3.033821] e1000e: Intel(R) PRO/1000 Network Driver
  1159    [    3.033834] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
  1160    [    3.033957] igb: Intel(R) Gigabit Ethernet Network Driver
  1161    [    3.033970] igb: Copyright (c) 2007-2014 Intel Corporation.
  1162    [    3.034047] igbvf: Intel(R) Gigabit Virtual Function Network Driver
  1163    [    3.034059] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
  1164    [    3.034501] sky2: driver version 1.30
  1165    [    3.035608] VFIO - User Level meta-driver version: 0.3
  1166    [    3.039539] dwc2 ff580000.usb: supply vusb_d not found, using dummy regulator
  1167    [    3.039847] dwc2 ff580000.usb: supply vusb_a not found, using dummy regulator
  1168    [    3.052940] dwc2 ff580000.usb: DWC OTG Controller
  1169    [    3.052992] dwc2 ff580000.usb: new USB bus registered, assigned bus number 1
  1170    [    3.053057] dwc2 ff580000.usb: irq 34, io mem 0xff580000
  1171    [    3.053481] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
  1172    [    3.053509] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1173    [    3.053529] usb usb1: Product: DWC OTG Controller
  1174    [    3.053546] usb usb1: Manufacturer: Linux 6.1.11-rockchip64 dwc2_hsotg
  1175    [    3.053564] usb usb1: SerialNumber: ff580000.usb
  1176    [    3.054718] hub 1-0:1.0: USB hub found
  1177    [    3.054789] hub 1-0:1.0: 1 port detected
  1178    [    3.059394] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  1179    [    3.059449] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
  1180    [    3.059696] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
  1181    [    3.059817] xhci-hcd xhci-hcd.0.auto: irq 33, io mem 0xff600000
  1182    [    3.060294] ehci-platform ff5c0000.usb: EHCI Host Controller
  1183    [    3.060318] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  1184    [    3.060327] ohci-platform ff5d0000.usb: Generic Platform OHCI controller
  1185    [    3.060344] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 4
  1186    [    3.060344] ehci-platform ff5c0000.usb: new USB bus registered, assigned bus number 3
  1187    [    3.060376] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
  1188    [    3.060379] ohci-platform ff5d0000.usb: new USB bus registered, assigned bus number 5
  1189    [    3.060562] ehci-platform ff5c0000.usb: irq 35, io mem 0xff5c0000
  1190    [    3.060608] ohci-platform ff5d0000.usb: irq 36, io mem 0xff5d0000
  1191    [    3.060736] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
  1192    [    3.060761] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1193    [    3.060782] usb usb2: Product: xHCI Host Controller
  1194    [    3.060799] usb usb2: Manufacturer: Linux 6.1.11-rockchip64 xhci-hcd
  1195    [    3.060817] usb usb2: SerialNumber: xhci-hcd.0.auto
  1196    [    3.061942] hub 2-0:1.0: USB hub found
  1197    [    3.062017] hub 2-0:1.0: 1 port detected
  1198    [    3.062818] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
  1199    [    3.063086] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
  1200    [    3.063111] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1201    [    3.063129] usb usb4: Product: xHCI Host Controller
  1202    [    3.063148] usb usb4: Manufacturer: Linux 6.1.11-rockchip64 xhci-hcd
  1203    [    3.063166] usb usb4: SerialNumber: xhci-hcd.0.auto
  1204    [    3.064234] hub 4-0:1.0: USB hub found
  1205    [    3.064304] hub 4-0:1.0: 1 port detected
  1206    [    3.065233] usbcore: registered new interface driver usb-storage
  1207    [    3.068826] mousedev: PS/2 mouse device common for all mice
  1208    [    3.070515] i2c_dev: i2c /dev entries driver
  1209    [    3.073468] ehci-platform ff5c0000.usb: USB 2.0 started, EHCI 1.00
  1210    [    3.074114] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
  1211    [    3.074149] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1212    [    3.074166] usb usb3: Product: EHCI Host Controller
  1213    [    3.074182] usb usb3: Manufacturer: Linux 6.1.11-rockchip64 ehci_hcd
  1214    [    3.074196] usb usb3: SerialNumber: ff5c0000.usb
  1215    [    3.075268] hub 3-0:1.0: USB hub found
  1216    [    3.075336] dw_wdt ff1a0000.watchdog: No valid TOPs array specified
  1217    [    3.075398] hub 3-0:1.0: 1 port detected
  1218    [    3.079148] sdhci: Secure Digital Host Controller Interface driver
  1219    [    3.079168] sdhci: Copyright(c) Pierre Ossman
  1220    [    3.079247] Synopsys Designware Multimedia Card Interface Driver
  1221    [    3.080792] sdhci-pltfm: SDHCI platform and OF driver helper
  1222    [    3.081760] dwmmc_rockchip ff500000.mmc: IDMAC supports 32-bit address mode.
  1223    [    3.081827] dwmmc_rockchip ff500000.mmc: Using internal DMA controller.
  1224    [    3.081850] dwmmc_rockchip ff500000.mmc: Version ID is 270a
  1225    [    3.081951] dwmmc_rockchip ff500000.mmc: DW MMC controller at irq 39,32 bit host data width,256 deep fifo
  1226    [    3.082085] dwmmc_rockchip ff520000.mmc: IDMAC supports 32-bit address mode.
  1227    [    3.082131] dwmmc_rockchip ff520000.mmc: Using internal DMA controller.
  1228    [    3.082151] dwmmc_rockchip ff520000.mmc: Version ID is 270a
  1229    [    3.082235] dwmmc_rockchip ff5f0000.mmc: IDMAC supports 32-bit address mode.
  1230    [    3.082247] dwmmc_rockchip ff520000.mmc: DW MMC controller at irq 40,32 bit host data width,256 deep fifo
  1231    [    3.082279] dwmmc_rockchip ff5f0000.mmc: Using internal DMA controller.
  1232    [    3.082298] dwmmc_rockchip ff5f0000.mmc: Version ID is 270a
  1233    [    3.082379] dwmmc_rockchip ff5f0000.mmc: DW MMC controller at irq 41,32 bit host data width,256 deep fifo
  1234    [    3.082604] dwmmc_rockchip ff500000.mmc: Got CD GPIO
  1235    [    3.082808] dwmmc_rockchip ff5f0000.mmc: allocated mmc-pwrseq
  1236    [    3.082827] mmc_host mmc4: card is non-removable.
  1237    [    3.083149] mmc_host mmc2: card is non-removable.
  1238    [    3.085385] ledtrig-cpu: registered to indicate activity on CPUs
  1239    [    3.086381] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
  1240    [    3.086830] hid: raw HID events driver (C) Jiri Kosina
  1241    [    3.087094] usbcore: registered new interface driver usbhid
  1242    [    3.087109] usbhid: USB HID core driver
  1243    [    3.093538] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
  1244    [    3.095438] drop_monitor: Initializing network drop monitor service
  1245    [    3.095817] mmc_host mmc4: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
  1246    [    3.095965] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
  1247    [    3.096776] NET: Registered PF_INET6 protocol family
  1248    [    3.121855] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.01
  1249    [    3.121890] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1250    [    3.121908] usb usb5: Product: Generic Platform OHCI controller
  1251    [    3.121924] usb usb5: Manufacturer: Linux 6.1.11-rockchip64 ohci_hcd
  1252    [    3.121939] usb usb5: SerialNumber: ff5d0000.usb
  1253    [    3.123072] hub 5-0:1.0: USB hub found
  1254    [    3.123168] hub 5-0:1.0: 1 port detected
  1255    [    3.141783] Segment Routing with IPv6
  1256    [    3.141896] In-situ OAM (IOAM) with IPv6
  1257    [    3.142065] NET: Registered PF_PACKET protocol family
  1258    [    3.142315] 8021q: 802.1Q VLAN Support v1.8
  1259    [    3.142409] Key type dns_resolver registered
  1260    [    3.144734] registered taskstats version 1
  1261    [    3.144784] Loading compiled-in X.509 certificates
  1262    [    3.151454] Loaded X.509 cert 'Build time autogenerated kernel key: e25f7f61aa13aedd90bace25454c8646dc5da469'
  1263    [    3.151983] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
  1264    [    3.152155] mmc0: new high speed SDHC card at address 8dfc
  1265    [    3.156187] zswap: loaded using pool zstd/z3fold
  1266    [    3.156512] mmcblk0: mmc0:8dfc SU16G 14.8 GiB
  1267    [    3.157986] Key type .fscrypt registered
  1268    [    3.158010] Key type fscrypt-provisioning registered
  1269    [    3.162090] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=yes
  1270    [    3.162752] Key type encrypted registered
  1271    [    3.162797] AppArmor: AppArmor sha1 policy hashing enabled
  1272    [    3.165184]  mmcblk0: p1
  1273    [    3.196557] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 52000000Hz, actual 50000000HZ div = 0)
  1274    [    3.196885] mmc2: new high speed MMC card at address 0001
  1275    [    3.198606] mmcblk2: mmc2:0001 CKTM4R 58.2 GiB
  1276    [    3.204092] mmcblk2boot0: mmc2:0001 CKTM4R 4.00 MiB
  1277    [    3.208672] mmcblk2boot1: mmc2:0001 CKTM4R 4.00 MiB
  1278    [    3.212547] mmcblk2rpmb: mmc2:0001 CKTM4R 4.00 MiB, chardev (242:0)
  1279    [    3.243734] mmc_host mmc4: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
  1280    [    3.263591] rockchip-drm display-subsystem: bound ff370000.vop (ops vop_component_ops)
  1281    [    3.263773] dwhdmi-rockchip ff3c0000.hdmi: supply avdd-0v9 not found, using dummy regulator
  1282    [    3.264147] dwhdmi-rockchip ff3c0000.hdmi: supply avdd-1v8 not found, using dummy regulator
  1283    [    3.264719] dwhdmi-rockchip ff3c0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (inno_dw_hdmi_phy2)
  1284    [    3.266023] dwhdmi-rockchip ff3c0000.hdmi: registered DesignWare HDMI I2C bus driver
  1285    [    3.266935] rockchip-drm display-subsystem: bound ff3c0000.hdmi (ops dw_hdmi_rockchip_ops)
  1286    [    3.268173] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 0
  1287    [    3.353456] usb 1-1: new low-speed USB device number 2 using dwc2
  1288    [    3.569081] usb 1-1: New USB device found, idVendor=045e, idProduct=00b0, bcdDevice= 1.10
  1289    [    3.569110] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  1290    [    3.569126] usb 1-1: Product: Microsoft® Digital Media Pro Keyboard
  1291    [    3.569138] usb 1-1: Manufacturer: Microsoft
  1292    [    3.574812] input: Microsoft Microsoft® Digital Media Pro Keyboard as /devices/platform/ff580000.usb/usb1/1-1/1-1:1.0/0003:045E:00B0.0001/input/input0
  1293    [    3.580827] Console: switching to colour frame buffer device 240x67
  1294    [    3.631034] rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device
  1295    [    3.632133] WCN: marlin_init entry!
  1296    [    3.632960] of_cfs_init
  1297    [    3.633030] of_cfs_init: OK
  1298    [    3.635200] hid-generic 0003:045E:00B0.0001: input,hidraw0: USB HID v1.11 Keyboard [Microsoft Microsoft® Digital Media Pro Keyboard] on usb-ff580000.usb-1/input0
  1299    [    3.636432] Freeing unused kernel memory: 3968K
  1300    [    3.636692] Run /init as init process
  1301    [    3.636705]   with arguments:
  1302    [    3.636717]     /init
  1303    [    3.636727]   with environment:
  1304    [    3.636736]     HOME=/
  1305    [    3.636746]     TERM=linux
  1306    [    3.636756]     splash=verbose
  1307    [    3.636766]     ubootpart=8635553d-01
  1308    [    3.636776]     cgroup_enable=memory
  1309    [    3.636786]     cgroup_memory=1
  1310    [    3.643762] input: Microsoft Microsoft® Digital Media Pro Keyboard Consumer Control as /devices/platform/ff580000.usb/usb1/1-1/1-1:1.1/0003:045E:00B0.0002/input/input1
  1311    [    3.647104] rockchip-pm-domain ff100000.syscon:power-controller: failed to get ack on domain 'hevc', val=0x88220
  1312    [    3.702097] input: Microsoft Microsoft® Digital Media Pro Keyboard System Control as /devices/platform/ff580000.usb/usb1/1-1/1-1:1.1/0003:045E:00B0.0002/input/input2
  1313    [    3.702699] hid-generic 0003:045E:00B0.0002: input,hidraw1: USB HID v1.11 Device [Microsoft Microsoft® Digital Media Pro Keyboard] on usb-ff580000.usb-1/input1
  1314    [    4.685604] input: adc-keys as /devices/platform/adc-keys/input/input3
  1315    [    4.717336] gpio-syscon ff100000.syscon:gpio: can't read the data register offset!
  1316    [    4.775974] lima ff300000.gpu: gp - mali450 version major 0 minor 0
  1317    [    4.776179] lima ff300000.gpu: pp0 - mali450 version major 0 minor 0
  1318    [    4.776369] lima ff300000.gpu: pp1 - mali450 version major 0 minor 0
  1319    [    4.776519] lima ff300000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
  1320    [    4.776544] lima ff300000.gpu: l2 cache 64K, 4-way, 64byte cache line, 128bit external bus
  1321    [    4.780328] lima ff300000.gpu: bus rate = 491520000
  1322    [    4.780364] lima ff300000.gpu: mod rate = 491520000
  1323    [    4.860048] [drm] Initialized lima 1.1.0 20191231 for ff300000.gpu on minor 1
  1324    [    5.069195] rk_gmac-dwmac ff550000.ethernet: IRQ eth_wake_irq not found
  1325    [    5.069229] rk_gmac-dwmac ff550000.ethernet: IRQ eth_lpi not found
  1326    [    5.069523] rk_gmac-dwmac ff550000.ethernet: PTP uses main clock
  1327    [    5.069995] rk_gmac-dwmac ff550000.ethernet: clock input or output? (output).
  1328    [    5.070029] rk_gmac-dwmac ff550000.ethernet: TX delay(0x30).
  1329    [    5.070049] rk_gmac-dwmac ff550000.ethernet: RX delay(0x10).
  1330    [    5.070097] rk_gmac-dwmac ff550000.ethernet: integrated PHY? (yes).
  1331    [    5.070610] rk_gmac-dwmac ff550000.ethernet: cannot get clock clk_mac_refout
  1332    [    5.070647] rk_gmac-dwmac ff550000.ethernet: cannot get clock clk_mac_speed
  1333    [    5.075728] rk_gmac-dwmac ff550000.ethernet: init for RMII
  1334    [    5.113884] rk_gmac-dwmac ff550000.ethernet: User ID: 0x10, Synopsys ID: 0x35
  1335    [    5.113927] rk_gmac-dwmac ff550000.ethernet:     DWMAC1000
  1336    [    5.113944] rk_gmac-dwmac ff550000.ethernet: DMA HW capability register supported
  1337    [    5.113959] rk_gmac-dwmac ff550000.ethernet: RX Checksum Offload Engine supported
  1338    [    5.113973] rk_gmac-dwmac ff550000.ethernet: COE Type 2
  1339    [    5.113988] rk_gmac-dwmac ff550000.ethernet: TX Checksum insertion supported
  1340    [    5.114001] rk_gmac-dwmac ff550000.ethernet: Wake-Up On Lan supported
  1341    [    5.114181] rk_gmac-dwmac ff550000.ethernet: Normal descriptors
  1342    [    5.114197] rk_gmac-dwmac ff550000.ethernet: Ring mode enabled
  1343    [    5.114210] rk_gmac-dwmac ff550000.ethernet: Enable RX Mitigation via HW Watchdog Timer
  1344    [    5.150354] rk_gmac-dwmac ff550000.ethernet end1: renamed from eth0
  1345    [    5.312640] dw-apb-uart ff130000.serial: forbid DMA for kernel console
  1346    [    5.976172] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Quota mode: none.
  1347    [    6.096341] dwmmc_rockchip ff5f0000.mmc: All phases bad!
  1348    [    6.096387] mmc4: error -5 whilst initialising SDIO card
  1349    [    6.124167] mmc_host mmc4: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
  1350    [    6.279827] mmc_host mmc4: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
  1351    [    8.042612] systemd[1]: System time before build time, advancing clock.
  1352    [    8.119460] systemd[1]: Inserted module 'autofs4'
  1353    [    8.279861] systemd[1]: systemd 252.5-2 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
  1354    [    8.279920] systemd[1]: Detected architecture arm64.
  1355    [    8.302568] systemd[1]: Hostname set to <rk3318-box>.
  1356    [    9.132210] dwmmc_rockchip ff5f0000.mmc: All phases bad!
  1357    [    9.132250] mmc4: error -5 whilst initialising SDIO card
  1358    [    9.158994] mmc_host mmc4: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
  1359    [    9.370535] mmc_host mmc4: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
  1360    [    9.651602] systemd[327]: /usr/lib/systemd/system-generators/netplan failed with exit status 1.
  1361    [   10.915292] systemd[1]: Queued start job for default target graphical.target.
  1362    [   10.958938] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
  1363    [   10.963480] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
  1364    [   10.967603] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
  1365    [   10.970730] systemd[1]: Created slice user.slice - User and Session Slice.
  1366    [   10.971801] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
  1367    [   10.973904] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
  1368    [   10.974705] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
  1369    [   10.975327] systemd[1]: Reached target remote-fs.target - Remote File Systems.
  1370    [   10.975739] systemd[1]: Reached target slices.target - Slice Units.
  1371    [   10.976297] systemd[1]: Reached target swap.target - Swaps.
  1372    [   10.976740] systemd[1]: Reached target time-set.target - System Time Set.
  1373    [   10.977603] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
  1374    [   10.983241] systemd[1]: Listening on syslog.socket - Syslog Socket.
  1375    [   10.984726] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
  1376    [   10.985786] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
  1377    [   10.987789] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
  1378    [   10.989266] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
  1379    [   10.991420] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
  1380    [   11.003003] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
  1381    [   11.004488] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
  1382    [   11.038153] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
  1383    [   11.047616] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
  1384    [   11.057581] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
  1385    [   11.068061] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
  1386    [   11.083805] systemd[1]: Starting fake-hwclock.service - Restore / save the current clock...
  1387    [   11.094337] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
  1388    [   11.105285] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
  1389    [   11.116815] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
  1390    [   11.128261] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
  1391    [   11.140673] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
  1392    [   11.152267] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
  1393    [   11.154165] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
  1394    [   11.188568] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
  1395    [   11.199578] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
  1396    [   11.200947] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
  1397    [   11.211491] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
  1398    [   11.231840] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
  1399    [   11.235385] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
  1400    [   11.239701] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
  1401    [   11.244029] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
  1402    [   11.250335] systemd[1]: Finished fake-hwclock.service - Restore / save the current clock.
  1403    [   11.256924] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
  1404    [   11.263658] systemd[1]: modprobe@configfs.service: Deactivated successfully.
  1405    [   11.265889] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
  1406    [   11.270739] systemd[1]: modprobe@drm.service: Deactivated successfully.
  1407    [   11.272992] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
  1408    [   11.278996] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
  1409    [   11.280991] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
  1410    [   11.286640] systemd[1]: modprobe@fuse.service: Deactivated successfully.
  1411    [   11.288685] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
  1412    [   11.293104] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
  1413    [   11.316901] EXT4-fs (mmcblk0p1): re-mounted. Quota mode: none.
  1414    [   11.342057] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
  1415    [   11.352575] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
  1416    [   11.363560] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables...
  1417    [   11.393092] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
  1418    [   11.396342] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
  1419    [   11.399388] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
  1420    [   11.402668] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
  1421    [   11.444996] systemd[1]: Starting systemd-random-seed.service - Load/Save Random Seed...
  1422    [   11.455979] systemd[1]: Starting systemd-sysusers.service - Create System Users...
  1423    [   11.537246] systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables.
  1424    [   11.625184] systemd[1]: Finished systemd-sysusers.service - Create System Users.
  1425    [   11.682952] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev...
  1426    [   11.828112] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout.
  1427    [   11.867169] systemd[1]: Finished systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev.
  1428    [   11.869653] systemd[1]: Reached target local-fs-pre.target - Preparation for Local File Systems.
  1429    [   11.914607] systemd[1]: Starting systemd-udevd.service - Rule-based Manager for Device Events and Files...
  1430    [   11.941477] random: crng init done
  1431    [   11.959366] systemd[1]: Finished systemd-random-seed.service - Load/Save Random Seed.
  1432    [   11.971536] systemd[1]: first-boot-complete.target - First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes).
  1433    [   12.233978] dwmmc_rockchip ff5f0000.mmc: All phases bad!
  1434    [   12.234023] mmc4: error -5 whilst initialising SDIO card
  1435    [   12.257617] mmc_host mmc4: Bus speed (slot 0) = 100000Hz (slot req 100000Hz, actual 100000HZ div = 0)
  1436    [   12.274474] systemd[1]: Mounting tmp.mount - /tmp...
  1437    [   12.298874] systemd[1]: Mounted tmp.mount - /tmp.
  1438    [   12.301538] systemd[1]: Reached target local-fs.target - Local File Systems.
  1439    [   12.331168] systemd[1]: Starting armbian-led-state.service - Armbian leds state...
  1440    [   12.356058] systemd[1]: Starting armbian-zram-config.service - Armbian ZRAM config...
  1441    [   12.374246] systemd[1]: Starting console-setup.service - Set console font and keymap...
  1442    [   12.394459] systemd[1]: Starting plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data...
  1443    [   12.466681] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
  1444    [   12.469015] systemd[1]: systemd-machine-id-commit.service - Commit a transient machine-id on disk was skipped because of an unmet condition check (ConditionPathIsMountPoint=/etc/machine-id).
  1445    [   12.474767] systemd[1]: Finished console-setup.service - Set console font and keymap.
  1446    [   12.506892] systemd[1]: Received SIGRTMIN+20 from PID 293 (plymouthd).
  1447    [   12.559153] systemd[1]: Finished systemd-udev-trigger.service - Coldplug All udev Devices.
  1448    [   12.603114] systemd[1]: Starting ifupdown-pre.service - Helper to synchronize boot up for ifupdown...
  1449    [   12.608771] systemd[1]: Finished plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data.
  1450    [   12.616361] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 392 (systemd-binfmt)
  1451    [   12.627778] systemd[1]: Mounting proc-sys-fs-binfmt_misc.mount - Arbitrary Executable File Formats File System...
  1452    [   12.673196] mmc_host mmc4: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
  1453    [   12.704343] systemd[1]: Mounted proc-sys-fs-binfmt_misc.mount - Arbitrary Executable File Formats File System.
  1454    [   12.721130] systemd[1]: Finished ifupdown-pre.service - Helper to synchronize boot up for ifupdown.
  1455    [   12.729686] systemd[1]: Finished systemd-binfmt.service - Set Up Additional Binary Formats.
  1456    [   12.816790] systemd[1]: Finished armbian-led-state.service - Armbian leds state.
  1457    [   12.949129] systemd[1]: Started systemd-udevd.service - Rule-based Manager for Device Events and Files.
  1458    [   13.002267] systemd[1]: Starting plymouth-start.service - Show Plymouth Boot Screen...
  1459    [   13.141482] systemd[1]: Started plymouth-start.service - Show Plymouth Boot Screen.
  1460    [   13.170504] systemd[1]: bootsplash-ask-password-console.path - Dispatch Password Requests to Console Directory Watch when bootsplash is active was skipped because of an unmet condition check (ConditionPathExists=/sys/devices/platform/bootsplash.0/enabled).
  1461    [   13.172081] systemd[1]: Started systemd-ask-password-plymouth.path - Forward Password Requests to Plymouth Directory Watch.
  1462    [   13.172674] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
  1463    [   13.173166] systemd[1]: Reached target paths.target - Path Units.
  1464    [   13.306901] systemd[1]: Found device dev-ttyS2.device - /dev/ttyS2.
  1465    [   13.701570] zram: Added device: zram0
  1466    [   13.702954] zram: Added device: zram1
  1467    [   13.704597] zram: Added device: zram2
  1468    [   14.002386] zram0: detected capacity change from 0 to 4069848
  1469    [   14.087781] Adding 2034920k swap on /dev/zram0.  Priority:5 extents:1 across:2034920k SSFS
  1470    [   14.117216] mc: Linux media interface: v0.10
  1471    [   14.354671] videodev: Linux video capture interface: v2.00
  1472    [   14.379562] Registered IR keymap rc-empty
  1473    [   14.379791] rc rc0: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc0
  1474    [   14.381798] rc rc0: lirc_dev: driver gpio_ir_recv registered at minor = 0, raw IR receiver, no transmitter
  1475    [   14.399915] rk3328-codec ff410000.codec: spk_depop_time use default value.
  1476    [   14.404975] input: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc0/input4
  1477    [   14.651906] rockchip-rga ff390000.rga: HW Version: 0x04.00
  1478    [   14.652499] rockchip-rga ff390000.rga: Registered rockchip-rga as /dev/video0
  1479    [   14.659869] zram1: detected capacity change from 0 to 102400
  1480    [   14.696973] systemd[1]: Reached target sound.target - Sound Card.
  1481    [   14.711560] hantro-vpu ff350000.video-codec: Adding to iommu group 2
  1482    [   14.713612] hantro-vpu ff350000.video-codec: registered rockchip,rk3328-vpu-dec as /dev/video1
  1483    [   14.725785] rockchip_vdec: module is from the staging directory, the quality is unknown, you have been warned.
  1484    [   14.728744] rkvdec ff360000.video-codec: Adding to iommu group 3
  1485    [   14.849762] systemd[1]: Finished armbian-zram-config.service - Armbian ZRAM config.
  1486    [   14.954466] systemd[1]: Starting armbian-ramlog.service - Armbian memory supported logging...
  1487    [   15.073120] EXT4-fs (zram1): mounted filesystem without journal. Quota mode: none.
  1488    [   15.530195] dwmmc_rockchip ff5f0000.mmc: All phases bad!
  1489    [   15.530237] mmc4: error -5 whilst initialising SDIO card
  1490    [   19.337923] systemd[1]: Finished armbian-ramlog.service - Armbian memory supported logging.
  1491    [   19.366720] systemd[1]: Starting systemd-journald.service - Journal Service...
  1492    [   19.727768] systemd[1]: Started systemd-journald.service - Journal Service.
  1493    [   19.825467] systemd-journald[586]: Received client request to flush runtime journal.
  1494    [   19.999087] systemd-journald[586]: Data hash table of /var/log/journal/748f963f03bc4ff19142d0aa9df990a2/system.journal has a fill level at 85.5 (3889 of 4551 items, 2621440 file size, 674 bytes per hash table item), suggesting rotation.
  1495    [   19.999125] systemd-journald[586]: /var/log/journal/748f963f03bc4ff19142d0aa9df990a2/system.journal: Journal header limits reached or header out-of-date, rotating.
  1496
  1497    ### armbian-release:
  1498
  1499    # PLEASE DO NOT EDIT THIS FILE
  1500    BOARD=rk3318-box
  1501    BOARD_NAME="RK3318 Box"
  1502    BOARDFAMILY=rockchip64
  1503    BUILD_REPOSITORY_URL=https://github.com/armbian/build
  1504    BUILD_REPOSITORY_COMMIT=313c893
  1505    VERSION=23.02.0-trunk
  1506    LINUXFAMILY=rockchip64
  1507    ARCH=arm64
  1508    IMAGE_TYPE=nightly
  1509    BOARD_TYPE=tvb
  1510    INITRD_ARCH=arm64
  1511    KERNEL_IMAGE_TYPE=Image
  1512
  1513    ### boot environment:
  1514
  1515    verbosity=1
  1516    bootlogo=false
  1517    overlay_prefix=rockchip
  1518    fdtfile=rockchip/rk3318-box.dtb
  1519    rootdev=UUID=2eb1e931-b16f-46a3-8b3b-f0a92acc8ddb
  1520    rootfstype=ext4
  1521    overlays=rk3318-box-led-conf4
  1522
  1523    ### lsusb:
  1524
  1525    Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  1526    Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  1527    Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  1528    Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  1529    Bus 001 Device 002: ID 045e:00b0 Microsoft Corp. Digital Media Pro Keyboard
  1530    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  1531
  1532    ### lscpu:
  1533
  1534    Architecture:                    aarch64
  1535    CPU op-mode(s):                  32-bit, 64-bit
  1536    Byte Order:                      Little Endian
  1537    CPU(s):                          4
  1538    On-line CPU(s) list:             0-3
  1539    Vendor ID:                       ARM
  1540    Model name:                      Cortex-A53
  1541    Model:                           4
  1542    Thread(s) per core:              1
  1543    Core(s) per cluster:             4
  1544    Socket(s):                       -
  1545    Cluster(s):                      1
  1546    Stepping:                        r0p4
  1547    CPU(s) scaling MHz:              100%
  1548    CPU max MHz:                     1008.0000
  1549    CPU min MHz:                     600.0000
  1550    BogoMIPS:                        48.00
  1551    Flags:                           fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1552    NUMA node(s):                    1
  1553    NUMA node0 CPU(s):               0-3
  1554    Vulnerability Itlb multihit:     Not affected
  1555    Vulnerability L1tf:              Not affected
  1556    Vulnerability Mds:               Not affected
  1557    Vulnerability Meltdown:          Not affected
  1558    Vulnerability Mmio stale data:   Not affected
  1559    Vulnerability Retbleed:          Not affected
  1560    Vulnerability Spec store bypass: Not affected
  1561    Vulnerability Spectre v1:        Mitigation; __user pointer sanitization
  1562    Vulnerability Spectre v2:        Not affected
  1563    Vulnerability Srbds:             Not affected
  1564    Vulnerability Tsx async abort:   Not affected
  1565
  1566    ### cpuinfo:
  1567
  1568    processor    : 0
  1569    BogoMIPS    : 48.00
  1570    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1571    CPU implementer    : 0x41
  1572    CPU architecture: 8
  1573    CPU variant    : 0x0
  1574    CPU part    : 0xd03
  1575    CPU revision    : 4
  1576
  1577    processor    : 1
  1578    BogoMIPS    : 48.00
  1579    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1580    CPU implementer    : 0x41
  1581    CPU architecture: 8
  1582    CPU variant    : 0x0
  1583    CPU part    : 0xd03
  1584    CPU revision    : 4
  1585
  1586    processor    : 2
  1587    BogoMIPS    : 48.00
  1588    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1589    CPU implementer    : 0x41
  1590    CPU architecture: 8
  1591    CPU variant    : 0x0
  1592    CPU part    : 0xd03
  1593    CPU revision    : 4
  1594
  1595    processor    : 3
  1596    BogoMIPS    : 48.00
  1597    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1598    CPU implementer    : 0x41
  1599    CPU architecture: 8
  1600    CPU variant    : 0x0
  1601    CPU part    : 0xd03
  1602    CPU revision    : 4
  1603
  1604
  1605    ### meminfo:
  1606
  1607    MemTotal:        4069844 kB
  1608    MemFree:         3874820 kB
  1609    MemAvailable:    3877488 kB
  1610    Buffers:            8676 kB
  1611    Cached:            59260 kB
  1612    SwapCached:            0 kB
  1613    Active:            50184 kB
  1614    Inactive:          20196 kB
  1615    Active(anon):      13536 kB
  1616    Inactive(anon):      808 kB
  1617    Active(file):      36648 kB
  1618    Inactive(file):    19388 kB
  1619    Unevictable:       11088 kB
  1620    Mlocked:               0 kB
  1621    SwapTotal:       2034920 kB
  1622    SwapFree:        2034920 kB
  1623    Zswap:                 0 kB
  1624    Zswapped:              0 kB
  1625    Dirty:               264 kB
  1626    Writeback:             0 kB
  1627    AnonPages:         13644 kB
  1628    Mapped:            16400 kB
  1629    Shmem:              8848 kB
  1630    KReclaimable:      16876 kB
  1631    Slab:              47756 kB
  1632    SReclaimable:      16876 kB
  1633    SUnreclaim:        30880 kB
  1634    KernelStack:        2128 kB
  1635    PageTables:          964 kB
  1636    SecPageTables:         0 kB
  1637    NFS_Unstable:          0 kB
  1638    Bounce:                0 kB
  1639    WritebackTmp:          0 kB
  1640    CommitLimit:     4069840 kB
  1641    Committed_AS:      59132 kB
  1642    VmallocTotal:   133143592960 kB
  1643    VmallocUsed:       35120 kB
  1644    VmallocChunk:          0 kB
  1645    Percpu:             1056 kB
  1646    AnonHugePages:         0 kB
  1647    ShmemHugePages:        0 kB
  1648    ShmemPmdMapped:        0 kB
  1649    FileHugePages:         0 kB
  1650    FilePmdMapped:         0 kB
  1651    CmaTotal:         131072 kB
  1652    CmaFree:          122368 kB
  1653    HugePages_Total:       0
  1654    HugePages_Free:        0
  1655    HugePages_Rsvd:        0
  1656    HugePages_Surp:        0
  1657    Hugepagesize:       2048 kB
  1658    Hugetlb:               0 kB
  1659
  1660    ### virtual memory:
  1661
  1662    vm.admin_reserve_kbytes = 8192
  1663    vm.compaction_proactiveness = 20
  1664    vm.compact_unevictable_allowed = 1
  1665    vm.dirty_background_bytes = 0
  1666    vm.dirty_background_ratio = 10
  1667    vm.dirty_bytes = 0
  1668    vm.dirty_expire_centisecs = 3000
  1669    vm.dirty_ratio = 20
  1670    vm.dirtytime_expire_seconds = 43200
  1671    vm.dirty_writeback_centisecs = 500
  1672    vm.extfrag_threshold = 500
  1673    vm.hugetlb_optimize_vmemmap = 0
  1674    vm.hugetlb_shm_group = 0
  1675    vm.laptop_mode = 0
  1676    vm.legacy_va_layout = 0
  1677    vm.lowmem_reserve_ratio = 256    256    32    0
  1678    vm.max_map_count = 65530
  1679    vm.min_free_kbytes = 22528
  1680    vm.min_slab_ratio = 5
  1681    vm.min_unmapped_ratio = 1
  1682    vm.mmap_min_addr = 4096
  1683    vm.mmap_rnd_bits = 18
  1684    vm.mmap_rnd_compat_bits = 11
  1685    vm.nr_hugepages = 0
  1686    vm.nr_hugepages_mempolicy = 0
  1687    vm.nr_overcommit_hugepages = 0
  1688    vm.numa_stat = 1
  1689    vm.numa_zonelist_order = Node
  1690    vm.oom_dump_tasks = 1
  1691    vm.oom_kill_allocating_task = 0
  1692    vm.overcommit_kbytes = 0
  1693    vm.overcommit_memory = 0
  1694    vm.overcommit_ratio = 50
  1695    vm.page-cluster = 0
  1696    vm.page_lock_unfairness = 5
  1697    vm.panic_on_oom = 0
  1698    vm.percpu_pagelist_high_fraction = 0
  1699    vm.stat_interval = 1
  1700    vm.swappiness = 100
  1701    vm.user_reserve_kbytes = 125879
  1702    vm.vfs_cache_pressure = 100
  1703    vm.watermark_boost_factor = 15000
  1704    vm.watermark_scale_factor = 10
  1705    vm.zone_reclaim_mode = 0
  1706
  1707    ### ip addr:
  1708
  1709    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  1710        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  1711        inet XXX.XXX.0.1/8 scope host lo
  1712           valid_lft forever preferred_lft forever
  1713        inet6 ::1/128 scope host
  1714           valid_lft forever preferred_lft forever
  1715    2: end1: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  1716        link/ether 52:d1:50:3d:d5:78 brd ff:ff:ff:ff:ff:ff
  1717
  1718    ### partitions:
  1719
  1720    major minor  #blocks  name
  1721
  1722     179        0   15558144 mmcblk0
  1723     179        1   15384576 mmcblk0p1
  1724     179       32   61071360 mmcblk2
  1725     179       64       4096 mmcblk2boot0
  1726     179       96       4096 mmcblk2boot1
  1727     252        0    2034924 zram0
  1728     252        1      51200 zram1
  1729
  1730    ### df:
  1731
  1732    udev            1.9G     0  1.9G   0% /dev
  1733    tmpfs           398M  5.7M  392M   2% /run
  1734    /dev/mmcblk0p1   15G  1.5G   13G  11% /
  1735    tmpfs           2.0G     0  2.0G   0% /dev/shm
  1736    tmpfs           5.0M     0  5.0M   0% /run/lock
  1737    tmpfs           2.0G     0  2.0G   0% /tmp
  1738    /dev/zram1       47M  860K   43M   2% /var/log
  1739
  1740    ### lsblk:
  1741
  1742    NAME         FSTYPE  SIZE MOUNTPOINT UUID
  1743    mmcblk0             14.8G
  1744    └─mmcblk0p1  ext4   14.7G /          2eb1e931-b16f-46a3-8b3b-f0a92acc8ddb
  1745    mmcblk2             58.2G
  1746    mmcblk2boot0           4M
  1747    mmcblk2boot1           4M
  1748    zram1                 50M /var/log
  1749    zram2                  0B
  1750
  1751    ### zramctl:
  1752
  1753    NAME       ALGORITHM DISKSIZE  DATA  COMPR TOTAL STREAMS MOUNTPOINT
  1754    /dev/zram1 zstd           50M  748K 142.6K  460K       4 /var/log
  1755    /dev/zram0 lzo-rle       1.9G    4K    74B   12K       4 [SWAP]
  1756
  1757    ### mtab:
  1758
  1759    /dev/mmcblk0p1 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0
  1760    /dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0
  1761    /dev/zram1 /var/log ext4 rw,relatime,discard 0 0
  1762
  1763    ### mmc0:8dfc info:
  1764
  1765                   fwrev: 0x0
  1766                  uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SU16G MODALIAS=mmc:block
  1767                     cid: 03534453553136478060b5bf4000a609
  1768                     rca: 0x8dfc
  1769                     csd: 400e00325b59000076b27f800a404013
  1770                  manfid: 0x000003
  1771                     ocr: 0x00300000
  1772    preferred_erase_size: 4194304
  1773                    type: SD
  1774                   hwrev: 0x8
  1775                    date: 06/2010
  1776                     dsr: 0x404
  1777              erase_size: 512
  1778                   oemid: 0x5344
  1779                  serial: 0x60b5bf40
  1780                     ssr: 0000000004000000010190000b050000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  1781                     scr: 0235800000000000
  1782                    name: SU16G
  1783
  1784    ### mmc2:0001 info:
  1785
  1786                   fwrev: 0x0500000000000000
  1787                  uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=CKTM4R MODALIAS=mmc:block
  1788                     cid: 150100434b544d345202a448f479c3a1
  1789             rel_sectors: 0x1
  1790    enhanced_rpmb_supported: 0x1
  1791                     rca: 0x0001
  1792            pre_eol_info: 0x01
  1793                     csd: d02701320f5903fff6dbffef8e40400d
  1794                  manfid: 0x000015
  1795                     ocr: 0x00300000
  1796    preferred_erase_size: 4194304
  1797    enhanced_area_offset: 18446744073709551594
  1798      raw_rpmb_size_mult: 0x20
  1799                    type: MMC
  1800                   hwrev: 0x0
  1801                    date: 12/2016
  1802                     prv: 0x2
  1803             ffu_capable: 1
  1804                     dsr: 0x404
  1805              erase_size: 524288
  1806               life_time: 0x01 0x01
  1807      enhanced_area_size: 4294967274
  1808                   oemid: 0x0100
  1809                  serial: 0xa448f479
  1810                 cmdq_en: 0
  1811                     rev: 0x8
  1812                    name: CKTM4R
  1813
  1814    ### Boot system health:
  1815
  1816    Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU  C.St.
  1817    21:03:09:  816MHz  2.15  49%  24%  12%   0%  12%   0% 57.3 °C  0/3
  1818    21:03:10: 1008MHz  2.54  94%  34%  25%   1%  32%   0% 58.2 °C  0/3
  1819    21:03:10: 1008MHz  2.54  74%  14%  11%   1%  46%   0% 56.8 °C  0/3
  1820    21:03:10:  816MHz  2.54  55%  10%   8%   1%  34%   0% 54.6 °C  0/3
  1821    21:03:11:  816MHz  2.54  67%  15%   9%   1%  41%   0% 55.0 °C  0/3
  1822
  1823    ### Activated 1 lzo-rle zram swap devices with 1987MB each.
  1824    ### Activated Armbian ramlog partition with zstd compression
  1825
  1826    Sun Feb 12 09:08:30 PM MSK 2023 | RK3318 Box | 23.02.0-trunk | arm64 | aarch64 | 6.1.11-rockchip64
  1827
  1828    ### dmesg:
  1829
  1830    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
  1831    [    0.000000] Linux version 6.1.11-rockchip64 (root@7284a09ced08) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #trunk.0248 SMP PREEMPT Fri Feb 10 05:25:40 UTC 2023
  1832    [    0.000000] Machine model: Rockchip RK3318 BOX
  1833    [    0.000000] efi: UEFI not found.
  1834    [    0.000000] NUMA: No NUMA configuration found
  1835    [    0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x00000000feffffff]
  1836    [    0.000000] NUMA: NODE_DATA [mem 0xfe7b1a80-0xfe7b3fff]
  1837    [    0.000000] Zone ranges:
  1838    [    0.000000]   DMA      [mem 0x0000000000200000-0x00000000feffffff]
  1839    [    0.000000]   DMA32    empty
  1840    [    0.000000]   Normal   empty
  1841    [    0.000000] Movable zone start for each node
  1842    [    0.000000] Early memory node ranges
  1843    [    0.000000]   node   0: [mem 0x0000000000200000-0x00000000feffffff]
  1844    [    0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000000feffffff]
  1845    [    0.000000] On node 0, zone DMA: 512 pages in unavailable ranges
  1846    [    0.000000] On node 0, zone DMA: 4096 pages in unavailable ranges
  1847    [    0.000000] cma: Reserved 128 MiB at 0x00000000f2600000
  1848    [    0.000000] psci: probing for conduit method from DT.
  1849    [    0.000000] psci: PSCIv1.1 detected in firmware.
  1850    [    0.000000] psci: Using standard PSCI v0.2 function IDs
  1851    [    0.000000] psci: MIGRATE_INFO_TYPE not supported.
  1852    [    0.000000] psci: SMC Calling Convention v1.2
  1853    [    0.000000] percpu: Embedded 30 pages/cpu s82472 r8192 d32216 u122880
  1854    [    0.000000] pcpu-alloc: s82472 r8192 d32216 u122880 alloc=30*4096
  1855    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
  1856    [    0.000000] Detected VIPT I-cache on CPU0
  1857    [    0.000000] CPU features: detected: ARM erratum 845719
  1858    [    0.000000] alternatives: applying boot alternatives
  1859    [    0.000000] Fallback order for Node 0: 0
  1860    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1027656
  1861    [    0.000000] Policy zone: DMA
  1862    [    0.000000] Kernel command line: root=UUID=2eb1e931-b16f-46a3-8b3b-f0a92acc8ddb rootwait rootfstype=ext4 splash=verbose console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart=8635553d-01 usb-storage.quirks=   cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
  1863    [    0.000000] The swapaccount= commandline option is deprecated. Please report your usecase to linux-mm@kvack.org if you depend on this functionality.
  1864    [    0.000000] Unknown kernel command line parameters "splash=verbose ubootpart=8635553d-01 cgroup_enable=memory cgroup_memory=1", will be passed to user space.
  1865    [    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
  1866    [    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
  1867    [    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
  1868    [    0.000000] Memory: 3913516K/4175872K available (16448K kernel code, 2240K rwdata, 5832K rodata, 3968K init, 585K bss, 131284K reserved, 131072K cma-reserved)
  1869    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
  1870    [    0.000000] trace event string verifier disabled
  1871    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
  1872    [    0.000000] rcu:     RCU event tracing is enabled.
  1873    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
  1874    [    0.000000]     Trampoline variant of Tasks RCU enabled.
  1875    [    0.000000]     Tracing variant of Tasks RCU enabled.
  1876    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
  1877    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
  1878    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
  1879    [    0.000000] Root IRQ handler: gic_handle_irq
  1880    [    0.000000] GIC: Using split EOI/Deactivate mode
  1881    [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
  1882    [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
  1883    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  1884    [    0.000001] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  1885    [    0.001089] Console: colour dummy device 80x25
  1886    [    0.001174] printk: console [tty1] enabled
  1887    [    0.001291] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
  1888    [    0.001318] pid_max: default: 32768 minimum: 301
  1889    [    0.001466] LSM: Security Framework initializing
  1890    [    0.001516] Yama: becoming mindful.
  1891    [    0.001683] AppArmor: AppArmor initialized
  1892    [    0.001730] Stack Depot allocating hash table of 262144 entries with kvcalloc
  1893    [    0.002382] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
  1894    [    0.002421] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
  1895    [    0.005738] cblist_init_generic: Setting adjustable number of callback queues.
  1896    [    0.005765] cblist_init_generic: Setting shift to 2 and lim to 1.
  1897    [    0.005968] cblist_init_generic: Setting shift to 2 and lim to 1.
  1898    [    0.006407] rcu: Hierarchical SRCU implementation.
  1899    [    0.006419] rcu:     Max phase no-delay instances is 1000.
  1900    [    0.010030] EFI services will not be available.
  1901    [    0.010761] smp: Bringing up secondary CPUs ...
  1902    [    0.012012] Detected VIPT I-cache on CPU1
  1903    [    0.012204] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
  1904    [    0.013556] Detected VIPT I-cache on CPU2
  1905    [    0.013745] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
  1906    [    0.015093] Detected VIPT I-cache on CPU3
  1907    [    0.015286] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
  1908    [    0.015493] smp: Brought up 1 node, 4 CPUs
  1909    [    0.015518] SMP: Total of 4 processors activated.
  1910    [    0.015532] CPU features: detected: 32-bit EL0 Support
  1911    [    0.015541] CPU features: detected: 32-bit EL1 Support
  1912    [    0.015553] CPU features: detected: CRC32 instructions
  1913    [    0.015682] CPU: All CPU(s) started at EL2
  1914    [    0.015703] alternatives: applying system-wide alternatives
  1915    [    0.019329] devtmpfs: initialized
  1916    [    0.043287] Registered cp15_barrier emulation handler
  1917    [    0.043320] Registered setend emulation handler
  1918    [    0.043784] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  1919    [    0.043833] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
  1920    [    0.049464] pinctrl core: initialized pinctrl subsystem
  1921    [    0.050718] DMI not present or invalid.
  1922    [    0.051941] NET: Registered PF_NETLINK/PF_ROUTE protocol family
  1923    [    0.054998] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
  1924    [    0.056434] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
  1925    [    0.057710] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
  1926    [    0.057837] audit: initializing netlink subsys (disabled)
  1927    [    0.058227] audit: type=2000 audit(0.056:1): state=initialized audit_enabled=0 res=1
  1928    [    0.059687] thermal_sys: Registered thermal governor 'fair_share'
  1929    [    0.059701] thermal_sys: Registered thermal governor 'bang_bang'
  1930    [    0.059714] thermal_sys: Registered thermal governor 'step_wise'
  1931    [    0.059725] thermal_sys: Registered thermal governor 'user_space'
  1932    [    0.059846] cpuidle: using governor menu
  1933    [    0.060466] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  1934    [    0.060689] ASID allocator initialised with 65536 entries
  1935    [    0.062639] Serial: AMBA PL011 UART driver
  1936    [    0.081661] platform ff3c0000.hdmi: Fixing up cyclic dependency with ff370000.vop
  1937    [    0.109925] rockchip-gpio ff210000.gpio: probed /pinctrl/gpio@ff210000
  1938    [    0.111413] rockchip-gpio ff220000.gpio: probed /pinctrl/gpio@ff220000
  1939    [    0.112669] rockchip-gpio ff230000.gpio: probed /pinctrl/gpio@ff230000
  1940    [    0.114098] rockchip-gpio ff240000.gpio: probed /pinctrl/gpio@ff240000
  1941    [    0.151385] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
  1942    [    0.151409] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
  1943    [    0.151426] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
  1944    [    0.151436] HugeTLB: 508 KiB vmemmap can be freed for a 32.0 MiB page
  1945    [    0.151450] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
  1946    [    0.151460] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
  1947    [    0.151474] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
  1948    [    0.151485] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
  1949    [    0.153290] cryptd: max_cpu_qlen set to 1000
  1950    [    0.223505] raid6: neonx8   gen()  1037 MB/s
  1951    [    0.291695] raid6: neonx4   gen()  1062 MB/s
  1952    [    0.359891] raid6: neonx2   gen()  1003 MB/s
  1953    [    0.428071] raid6: neonx1   gen()   879 MB/s
  1954    [    0.496245] raid6: int64x8  gen()   744 MB/s
  1955    [    0.564420] raid6: int64x4  gen()   827 MB/s
  1956    [    0.632606] raid6: int64x2  gen()   707 MB/s
  1957    [    0.700811] raid6: int64x1  gen()   525 MB/s
  1958    [    0.700825] raid6: using algorithm neonx4 gen() 1062 MB/s
  1959    [    0.768956] raid6: .... xor() 769 MB/s, rmw enabled
  1960    [    0.768971] raid6: using neon recovery algorithm
  1961    [    0.775660] iommu: Default domain type: Translated
  1962    [    0.775682] iommu: DMA domain TLB invalidation policy: strict mode
  1963    [    0.776529] SCSI subsystem initialized
  1964    [    0.776916] libata version 3.00 loaded.
  1965    [    0.777488] usbcore: registered new interface driver usbfs
  1966    [    0.777592] usbcore: registered new interface driver hub
  1967    [    0.777674] usbcore: registered new device driver usb
  1968    [    0.778721] pps_core: LinuxPPS API ver. 1 registered
  1969    [    0.778735] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  1970    [    0.778769] PTP clock support registered
  1971    [    0.779186] EDAC MC: Ver: 3.0.0
  1972    [    0.782120] NetLabel: Initializing
  1973    [    0.782139] NetLabel:  domain hash size = 128
  1974    [    0.782153] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
  1975    [    0.782307] NetLabel:  unlabeled traffic allowed by default
  1976    [    0.782622] vgaarb: loaded
  1977    [    0.783623] clocksource: Switched to clocksource arch_sys_counter
  1978    [    0.894568] VFS: Disk quotas dquot_6.6.0
  1979    [    0.894677] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  1980    [    0.896447] AppArmor: AppArmor Filesystem Enabled
  1981    [    0.913682] NET: Registered PF_INET protocol family
  1982    [    0.914106] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
  1983    [    0.920372] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
  1984    [    0.920619] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
  1985    [    0.920723] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
  1986    [    0.921378] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
  1987    [    0.922741] TCP: Hash tables configured (established 32768 bind 32768)
  1988    [    0.922991] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
  1989    [    0.923177] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
  1990    [    0.923799] NET: Registered PF_UNIX/PF_LOCAL protocol family
  1991    [    0.923871] NET: Registered PF_XDP protocol family
  1992    [    0.923893] PCI: CLS 0 bytes, default 64
  1993    [    0.924323] Trying to unpack rootfs image as initramfs...
  1994    [    0.926135] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
  1995    [    0.927296] kvm [1]: IPA Size Limit: 40 bits
  1996    [    0.929821] kvm [1]: vgic interrupt IRQ9
  1997    [    0.930100] kvm [1]: Hyp mode initialized successfully
  1998    [    0.934338] Initialise system trusted keyrings
  1999    [    0.934475] Key type blacklist registered
  2000    [    0.934897] workingset: timestamp_bits=44 max_order=20 bucket_order=0
  2001    [    0.949404] zbud: loaded
  2002    [    0.952993] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  2003    [    0.954538] fuse: init (API version 7.37)
  2004    [    0.959547] integrity: Platform Keyring initialized
  2005    [    1.030076] xor: measuring software checksum speed
  2006    [    1.038213]    8regs           :  1221 MB/sec
  2007    [    1.046085]    32regs          :  1261 MB/sec
  2008    [    1.055350]    arm64_neon      :  1071 MB/sec
  2009    [    1.055373] xor: using function: 32regs (1261 MB/sec)
  2010    [    1.055394] Key type asymmetric registered
  2011    [    1.055406] Asymmetric key parser 'x509' registered
  2012    [    3.012595] Freeing initrd memory: 21288K
  2013    [    3.056698] alg: self-tests for CTR-KDF (hmac(sha256)) passed
  2014    [    3.056852] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
  2015    [    3.057124] io scheduler mq-deadline registered
  2016    [    3.057140] io scheduler kyber registered
  2017    [    3.057594] io scheduler bfq registered
  2018    [    3.076655] dma-pl330 ff1f0000.dma-controller: Loaded driver for PL330 DMAC-241330
  2019    [    3.076688] dma-pl330 ff1f0000.dma-controller:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
  2020    [    3.085337] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
  2021    [    3.091254] ff110000.serial: ttyS0 at MMIO 0xff110000 (irq = 25, base_baud = 1500000) is a 16550A
  2022    [    3.093175] ff130000.serial: ttyS2 at MMIO 0xff130000 (irq = 26, base_baud = 1500000) is a 16550A
  2023    [    3.093619] printk: console [ttyS2] enabled
  2024    [    3.095685] Serial: AMBA driver
  2025    [    3.104427] rockchip-vop ff370000.vop: Adding to iommu group 4
  2026    [    3.130642] loop: module loaded
  2027    [    3.139484] tun: Universal TUN/TAP device driver, 1.6
  2028    [    3.141363] thunder_xcv, ver 1.0
  2029    [    3.141460] thunder_bgx, ver 1.0
  2030    [    3.141548] nicpf, ver 1.0
  2031    [    3.142894] e1000e: Intel(R) PRO/1000 Network Driver
  2032    [    3.142908] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
  2033    [    3.143023] igb: Intel(R) Gigabit Ethernet Network Driver
  2034    [    3.143037] igb: Copyright (c) 2007-2014 Intel Corporation.
  2035    [    3.143125] igbvf: Intel(R) Gigabit Virtual Function Network Driver
  2036    [    3.143140] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
  2037    [    3.143528] sky2: driver version 1.30
  2038    [    3.144777] VFIO - User Level meta-driver version: 0.3
  2039    [    3.148767] dwc2 ff580000.usb: supply vusb_d not found, using dummy regulator
  2040    [    3.149075] dwc2 ff580000.usb: supply vusb_a not found, using dummy regulator
  2041    [    3.162158] dwc2 ff580000.usb: DWC OTG Controller
  2042    [    3.162236] dwc2 ff580000.usb: new USB bus registered, assigned bus number 1
  2043    [    3.162299] dwc2 ff580000.usb: irq 34, io mem 0xff580000
  2044    [    3.162667] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
  2045    [    3.162694] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  2046    [    3.162715] usb usb1: Product: DWC OTG Controller
  2047    [    3.162732] usb usb1: Manufacturer: Linux 6.1.11-rockchip64 dwc2_hsotg
  2048    [    3.162749] usb usb1: SerialNumber: ff580000.usb
  2049    [    3.163927] hub 1-0:1.0: USB hub found
  2050    [    3.164003] hub 1-0:1.0: 1 port detected
  2051    [    3.168433] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  2052    [    3.168484] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
  2053    [    3.168748] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
  2054    [    3.168860] xhci-hcd xhci-hcd.0.auto: irq 33, io mem 0xff600000
  2055    [    3.169373] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  2056    [    3.169401] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 3
  2057    [    3.169416] ehci-platform ff5c0000.usb: EHCI Host Controller
  2058    [    3.169431] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
  2059    [    3.169450] ohci-platform ff5d0000.usb: Generic Platform OHCI controller
  2060    [    3.169455] ehci-platform ff5c0000.usb: new USB bus registered, assigned bus number 4
  2061    [    3.169670] ehci-platform ff5c0000.usb: irq 35, io mem 0xff5c0000
  2062    [    3.169772] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
  2063    [    3.169796] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  2064    [    3.169816] usb usb2: Product: xHCI Host Controller
  2065    [    3.169833] usb usb2: Manufacturer: Linux 6.1.11-rockchip64 xhci-hcd
  2066    [    3.169850] usb usb2: SerialNumber: xhci-hcd.0.auto
  2067    [    3.170986] hub 2-0:1.0: USB hub found
  2068    [    3.171063] hub 2-0:1.0: 1 port detected
  2069    [    3.172071] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
  2070    [    3.172335] usb usb3: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
  2071    [    3.172361] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  2072    [    3.172381] usb usb3: Product: xHCI Host Controller
  2073    [    3.172398] usb usb3: Manufacturer: Linux 6.1.11-rockchip64 xhci-hcd
  2074    [    3.172413] usb usb3: SerialNumber: xhci-hcd.0.auto
  2075    [    3.173492] hub 3-0:1.0: USB hub found
  2076    [    3.173576] hub 3-0:1.0: 1 port detected
  2077    [    3.174287] ohci-platform ff5d0000.usb: new USB bus registered, assigned bus number 5
  2078    [    3.174503] usbcore: registered new interface driver usb-storage
  2079    [    3.174562] ohci-platform ff5d0000.usb: irq 36, io mem 0xff5d0000
  2080    [    3.178038] mousedev: PS/2 mouse device common for all mice
  2081    [    3.179709] i2c_dev: i2c /dev entries driver
  2082    [    3.183683] ehci-platform ff5c0000.usb: USB 2.0 started, EHCI 1.00
  2083    [    3.184357] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
  2084    [    3.184389] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  2085    [    3.184406] usb usb4: Product: EHCI Host Controller
  2086    [    3.184421] usb usb4: Manufacturer: Linux 6.1.11-rockchip64 ehci_hcd
  2087    [    3.184436] usb usb4: SerialNumber: ff5c0000.usb
  2088    [    3.184537] dw_wdt ff1a0000.watchdog: No valid TOPs array specified
  2089    [    3.185487] hub 4-0:1.0: USB hub found
  2090    [    3.185601] hub 4-0:1.0: 1 port detected
  2091    [    3.188275] sdhci: Secure Digital Host Controller Interface driver
  2092    [    3.188296] sdhci: Copyright(c) Pierre Ossman
  2093    [    3.188346] Synopsys Designware Multimedia Card Interface Driver
  2094    [    3.189932] sdhci-pltfm: SDHCI platform and OF driver helper
  2095    [    3.190764] dwmmc_rockchip ff510000.mmc: IDMAC supports 32-bit address mode.
  2096    [    3.190797] dwmmc_rockchip ff500000.mmc: IDMAC supports 32-bit address mode.
  2097    [    3.190826] dwmmc_rockchip ff510000.mmc: Using internal DMA controller.
  2098    [    3.190840] dwmmc_rockchip ff500000.mmc: Using internal DMA controller.
  2099    [    3.190846] dwmmc_rockchip ff510000.mmc: Version ID is 270a
  2100    [    3.190860] dwmmc_rockchip ff500000.mmc: Version ID is 270a
  2101    [    3.190949] dwmmc_rockchip ff510000.mmc: DW MMC controller at irq 39,32 bit host data width,256 deep fifo
  2102    [    3.190995] dwmmc_rockchip ff500000.mmc: DW MMC controller at irq 40,32 bit host data width,256 deep fifo
  2103    [    3.191218] dwmmc_rockchip ff520000.mmc: IDMAC supports 32-bit address mode.
  2104    [    3.191270] dwmmc_rockchip ff520000.mmc: Using internal DMA controller.
  2105    [    3.191290] dwmmc_rockchip ff520000.mmc: Version ID is 270a
  2106    [    3.191381] dwmmc_rockchip ff520000.mmc: DW MMC controller at irq 41,32 bit host data width,256 deep fifo
  2107    [    3.191438] dwmmc_rockchip ff510000.mmc: allocated mmc-pwrseq
  2108    [    3.191459] mmc_host mmc1: card is non-removable.
  2109    [    3.191560] dwmmc_rockchip ff500000.mmc: Got CD GPIO
  2110    [    3.192438] mmc_host mmc2: card is non-removable.
  2111    [    3.193288] dwmmc_rockchip ff5f0000.dwmmc: IDMAC supports 32-bit address mode.
  2112    [    3.193350] dwmmc_rockchip ff5f0000.dwmmc: Using internal DMA controller.
  2113    [    3.193372] dwmmc_rockchip ff5f0000.dwmmc: Version ID is 270a
  2114    [    3.193486] dwmmc_rockchip ff5f0000.dwmmc: DW MMC controller at irq 42,32 bit host data width,256 deep fifo
  2115    [    3.194095] dwmmc_rockchip ff5f0000.dwmmc: Got CD GPIO
  2116    [    3.194791] ledtrig-cpu: registered to indicate activity on CPUs
  2117    [    3.195750] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
  2118    [    3.196265] hid: raw HID events driver (C) Jiri Kosina
  2119    [    3.196533] usbcore: registered new interface driver usbhid
  2120    [    3.196548] usbhid: USB HID core driver
  2121    [    3.204416] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
  2122    [    3.204643] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
  2123    [    3.204966] drop_monitor: Initializing network drop monitor service
  2124    [    3.205310] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
  2125    [    3.206349] NET: Registered PF_INET6 protocol family
  2126    [    3.207098] mmc_host mmc3: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
  2127    [    3.236070] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.01
  2128    [    3.236112] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  2129    [    3.236133] usb usb5: Product: Generic Platform OHCI controller
  2130    [    3.236148] usb usb5: Manufacturer: Linux 6.1.11-rockchip64 ohci_hcd
  2131    [    3.236164] usb usb5: SerialNumber: ff5d0000.usb
  2132    [    3.237309] hub 5-0:1.0: USB hub found
  2133    [    3.237405] hub 5-0:1.0: 1 port detected
  2134    [    3.252059] Segment Routing with IPv6
  2135    [    3.252172] In-situ OAM (IOAM) with IPv6
  2136    [    3.252343] NET: Registered PF_PACKET protocol family
  2137    [    3.252647] 8021q: 802.1Q VLAN Support v1.8
  2138    [    3.252757] Key type dns_resolver registered
  2139    [    3.255263] registered taskstats version 1
  2140    [    3.255361] Loading compiled-in X.509 certificates
  2141    [    3.255903] mmc_host mmc3: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
  2142    [    3.256069] mmc_host mmc1: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
  2143    [    3.262114] Loaded X.509 cert 'Build time autogenerated kernel key: e25f7f61aa13aedd90bace25454c8646dc5da469'
  2144    [    3.263912] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
  2145    [    3.264139] mmc0: new high speed SDHC card at address 8dfc
  2146    [    3.266470] zswap: loaded using pool zstd/z3fold
  2147    [    3.266683] mmcblk0: mmc0:8dfc SU16G 14.8 GiB
  2148    [    3.268196] Key type .fscrypt registered
  2149    [    3.268222] Key type fscrypt-provisioning registered
  2150    [    3.272048] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=yes
  2151    [    3.272717] Key type encrypted registered
  2152    [    3.272760] AppArmor: AppArmor sha1 policy hashing enabled
  2153    [    3.274720]  mmcblk0: p1
  2154    [    3.302971] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 52000000Hz, actual 50000000HZ div = 0)
  2155    [    3.303363] mmc2: new high speed MMC card at address 0001
  2156    [    3.303717] mmc_host mmc3: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
  2157    [    3.305036] mmcblk2: mmc2:0001 CKTM4R 58.2 GiB
  2158    [    3.310539] mmcblk2boot0: mmc2:0001 CKTM4R 4.00 MiB
  2159    [    3.311870] mmc_host mmc1: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
  2160    [    3.314883] mmcblk2boot1: mmc2:0001 CKTM4R 4.00 MiB
  2161    [    3.318509] mmcblk2rpmb: mmc2:0001 CKTM4R 4.00 MiB, chardev (242:0)
  2162    [    3.355757] mmc_host mmc3: Bus speed (slot 0) = 100000Hz (slot req 100000Hz, actual 100000HZ div = 0)
  2163    [    3.366737] rockchip-drm display-subsystem: bound ff370000.vop (ops vop_component_ops)
  2164    [    3.366910] dwhdmi-rockchip ff3c0000.hdmi: supply avdd-0v9 not found, using dummy regulator
  2165    [    3.367293] dwhdmi-rockchip ff3c0000.hdmi: supply avdd-1v8 not found, using dummy regulator
  2166    [    3.367912] dwhdmi-rockchip ff3c0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (inno_dw_hdmi_phy2)
  2167    [    3.369190] dwhdmi-rockchip ff3c0000.hdmi: registered DesignWare HDMI I2C bus driver
  2168    [    3.370097] rockchip-drm display-subsystem: bound ff3c0000.hdmi (ops dw_hdmi_rockchip_ops)
  2169    [    3.371184] mmc_host mmc1: Bus speed (slot 0) = 100000Hz (slot req 100000Hz, actual 100000HZ div = 0)
  2170    [    3.371367] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 0
  2171    [    3.467664] usb 1-1: new low-speed USB device number 2 using dwc2
  2172    [    3.662711] Console: switching to colour frame buffer device 240x67
  2173    [    3.683334] usb 1-1: New USB device found, idVendor=045e, idProduct=00b0, bcdDevice= 1.10
  2174    [    3.683363] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  2175    [    3.683378] usb 1-1: Product: Microsoft® Digital Media Pro Keyboard
  2176    [    3.683389] usb 1-1: Manufacturer: Microsoft
  2177    [    3.688854] input: Microsoft Microsoft® Digital Media Pro Keyboard as /devices/platform/ff580000.usb/usb1/1-1/1-1:1.0/0003:045E:00B0.0001/input/input0
  2178    [    3.715130] rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device
  2179    [    3.716266] WCN: marlin_init entry!
  2180    [    3.717118] of_cfs_init
  2181    [    3.717175] of_cfs_init: OK
  2182    [    3.720555] Freeing unused kernel memory: 3968K
  2183    [    3.720847] Run /init as init process
  2184    [    3.720860]   with arguments:
  2185    [    3.720872]     /init
  2186    [    3.720883]   with environment:
  2187    [    3.720894]     HOME=/
  2188    [    3.720905]     TERM=linux
  2189    [    3.720914]     splash=verbose
  2190    [    3.720926]     ubootpart=8635553d-01
  2191    [    3.720938]     cgroup_enable=memory
  2192    [    3.720950]     cgroup_memory=1
  2193    [    3.731278] rockchip-pm-domain ff100000.syscon:power-controller: failed to get ack on domain 'hevc', val=0x88220
  2194    [    3.748876] hid-generic 0003:045E:00B0.0001: input,hidraw0: USB HID v1.11 Keyboard [Microsoft Microsoft® Digital Media Pro Keyboard] on usb-ff580000.usb-1/input0
  2195    [    3.756901] input: Microsoft Microsoft® Digital Media Pro Keyboard Consumer Control as /devices/platform/ff580000.usb/usb1/1-1/1-1:1.1/0003:045E:00B0.0002/input/input1
  2196    [    3.816339] input: Microsoft Microsoft® Digital Media Pro Keyboard System Control as /devices/platform/ff580000.usb/usb1/1-1/1-1:1.1/0003:045E:00B0.0002/input/input2
  2197    [    3.816847] hid-generic 0003:045E:00B0.0002: input,hidraw1: USB HID v1.11 Device [Microsoft Microsoft® Digital Media Pro Keyboard] on usb-ff580000.usb-1/input1
  2198    [    4.768428] input: adc-keys as /devices/platform/adc-keys/input/input3
  2199    [    4.831854] gpio-syscon ff100000.syscon:gpio: can't read the data register offset!
  2200    [    4.884318] lima ff300000.gpu: gp - mali450 version major 0 minor 0
  2201    [    4.884531] lima ff300000.gpu: pp0 - mali450 version major 0 minor 0
  2202    [    4.884770] lima ff300000.gpu: pp1 - mali450 version major 0 minor 0
  2203    [    4.884901] lima ff300000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
  2204    [    4.884927] lima ff300000.gpu: l2 cache 64K, 4-way, 64byte cache line, 128bit external bus
  2205    [    4.893684] lima ff300000.gpu: bus rate = 491520000
  2206    [    4.893723] lima ff300000.gpu: mod rate = 491520000
  2207    [    4.896715] [drm] Initialized lima 1.1.0 20191231 for ff300000.gpu on minor 1
  2208    [    5.021904] rk_gmac-dwmac ff550000.ethernet: IRQ eth_wake_irq not found
  2209    [    5.021935] rk_gmac-dwmac ff550000.ethernet: IRQ eth_lpi not found
  2210    [    5.022163] rk_gmac-dwmac ff550000.ethernet: PTP uses main clock
  2211    [    5.022524] rk_gmac-dwmac ff550000.ethernet: clock input or output? (output).
  2212    [    5.022551] rk_gmac-dwmac ff550000.ethernet: TX delay(0x30).
  2213    [    5.022569] rk_gmac-dwmac ff550000.ethernet: RX delay(0x10).
  2214    [    5.022610] rk_gmac-dwmac ff550000.ethernet: integrated PHY? (yes).
  2215    [    5.022743] rk_gmac-dwmac ff550000.ethernet: cannot get clock clk_mac_refout
  2216    [    5.022767] rk_gmac-dwmac ff550000.ethernet: cannot get clock clk_mac_speed
  2217    [    5.029625] rk_gmac-dwmac ff550000.ethernet: init for RMII
  2218    [    5.068606] rk_gmac-dwmac ff550000.ethernet: User ID: 0x10, Synopsys ID: 0x35
  2219    [    5.068653] rk_gmac-dwmac ff550000.ethernet:     DWMAC1000
  2220    [    5.068669] rk_gmac-dwmac ff550000.ethernet: DMA HW capability register supported
  2221    [    5.068683] rk_gmac-dwmac ff550000.ethernet: RX Checksum Offload Engine supported
  2222    [    5.068697] rk_gmac-dwmac ff550000.ethernet: COE Type 2
  2223    [    5.068711] rk_gmac-dwmac ff550000.ethernet: TX Checksum insertion supported
  2224    [    5.068724] rk_gmac-dwmac ff550000.ethernet: Wake-Up On Lan supported
  2225    [    5.068906] rk_gmac-dwmac ff550000.ethernet: Normal descriptors
  2226    [    5.068928] rk_gmac-dwmac ff550000.ethernet: Ring mode enabled
  2227    [    5.068941] rk_gmac-dwmac ff550000.ethernet: Enable RX Mitigation via HW Watchdog Timer
  2228    [    5.205905] rk_gmac-dwmac ff550000.ethernet end1: renamed from eth0
  2229    [    5.383998] dw-apb-uart ff130000.serial: forbid DMA for kernel console
  2230    [    6.041514] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Quota mode: none.
  2231    [    8.099330] systemd[1]: System time before build time, advancing clock.
  2232    [    8.178209] systemd[1]: Inserted module 'autofs4'
  2233    [    8.338766] systemd[1]: systemd 252.5-2 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
  2234    [    8.338824] systemd[1]: Detected architecture arm64.
  2235    [    8.362761] systemd[1]: Hostname set to <rk3318-box>.
  2236    [    9.734977] systemd[329]: /usr/lib/systemd/system-generators/netplan failed with exit status 1.
  2237    [   10.997162] systemd[1]: Queued start job for default target graphical.target.
  2238    [   11.040978] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
  2239    [   11.045580] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
  2240    [   11.049642] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
  2241    [   11.052848] systemd[1]: Created slice user.slice - User and Session Slice.
  2242    [   11.053897] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
  2243    [   11.055980] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
  2244    [   11.056730] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
  2245    [   11.057341] systemd[1]: Reached target remote-fs.target - Remote File Systems.
  2246    [   11.057735] systemd[1]: Reached target slices.target - Slice Units.
  2247    [   11.058300] systemd[1]: Reached target swap.target - Swaps.
  2248    [   11.058714] systemd[1]: Reached target time-set.target - System Time Set.
  2249    [   11.059474] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
  2250    [   11.065265] systemd[1]: Listening on syslog.socket - Syslog Socket.
  2251    [   11.066773] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
  2252    [   11.067832] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
  2253    [   11.069769] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
  2254    [   11.071251] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
  2255    [   11.073390] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
  2256    [   11.084667] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
  2257    [   11.086167] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
  2258    [   11.116399] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
  2259    [   11.125751] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
  2260    [   11.135488] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
  2261    [   11.145933] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
  2262    [   11.162670] systemd[1]: Starting fake-hwclock.service - Restore / save the current clock...
  2263    [   11.173019] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
  2264    [   11.184063] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
  2265    [   11.195335] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
  2266    [   11.207581] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
  2267    [   11.218878] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
  2268    [   11.231144] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
  2269    [   11.232978] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
  2270    [   11.266326] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
  2271    [   11.277801] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
  2272    [   11.278859] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
  2273    [   11.289346] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
  2274    [   11.310293] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
  2275    [   11.313323] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
  2276    [   11.316405] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
  2277    [   11.319915] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
  2278    [   11.325988] systemd[1]: Finished fake-hwclock.service - Restore / save the current clock.
  2279    [   11.333220] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
  2280    [   11.340171] systemd[1]: modprobe@configfs.service: Deactivated successfully.
  2281    [   11.342280] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
  2282    [   11.350035] systemd[1]: modprobe@drm.service: Deactivated successfully.
  2283    [   11.352450] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
  2284    [   11.356758] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
  2285    [   11.358699] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
  2286    [   11.363289] systemd[1]: modprobe@fuse.service: Deactivated successfully.
  2287    [   11.365353] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
  2288    [   11.369385] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
  2289    [   11.390965] EXT4-fs (mmcblk0p1): re-mounted. Quota mode: none.
  2290    [   11.404296] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
  2291    [   11.414117] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
  2292    [   11.425769] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables...
  2293    [   11.450555] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
  2294    [   11.454027] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
  2295    [   11.456890] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
  2296    [   11.460029] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
  2297    [   11.496921] systemd[1]: Starting systemd-random-seed.service - Load/Save Random Seed...
  2298    [   11.508566] systemd[1]: Starting systemd-sysusers.service - Create System Users...
  2299    [   11.582295] systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables.
  2300    [   11.671045] systemd[1]: Finished systemd-sysusers.service - Create System Users.
  2301    [   11.729156] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev...
  2302    [   11.928706] systemd[1]: Finished systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev.
  2303    [   11.980894] systemd[1]: Starting systemd-udevd.service - Rule-based Manager for Device Events and Files...
  2304    [   11.985504] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout.
  2305    [   11.992962] systemd[1]: Reached target local-fs-pre.target - Preparation for Local File Systems.
  2306    [   12.028304] systemd[1]: Mounting tmp.mount - /tmp...
  2307    [   12.065103] systemd[1]: Mounted tmp.mount - /tmp.
  2308    [   12.067551] systemd[1]: Reached target local-fs.target - Local File Systems.
  2309    [   12.115705] random: crng init done
  2310    [   12.120904] systemd[1]: Starting armbian-led-state.service - Armbian leds state...
  2311    [   12.153765] systemd[1]: Starting armbian-zram-config.service - Armbian ZRAM config...
  2312    [   12.170741] systemd[1]: Starting console-setup.service - Set console font and keymap...
  2313    [   12.191235] systemd[1]: Starting plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data...
  2314    [   12.289052] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
  2315    [   12.304755] systemd[1]: Finished systemd-random-seed.service - Load/Save Random Seed.
  2316    [   12.317034] systemd[1]: Finished console-setup.service - Set console font and keymap.
  2317    [   12.330846] systemd[1]: first-boot-complete.target - First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes).
  2318    [   12.331289] systemd[1]: systemd-machine-id-commit.service - Commit a transient machine-id on disk was skipped because of an unmet condition check (ConditionPathIsMountPoint=/etc/machine-id).
  2319    [   12.336903] systemd[1]: Received SIGRTMIN+20 from PID 294 (plymouthd).
  2320    [   12.357628] systemd[1]: Finished plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data.
  2321    [   12.376453] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 393 (systemd-binfmt)
  2322    [   12.413939] systemd[1]: Mounting proc-sys-fs-binfmt_misc.mount - Arbitrary Executable File Formats File System...
  2323    [   12.500224] systemd[1]: Mounted proc-sys-fs-binfmt_misc.mount - Arbitrary Executable File Formats File System.
  2324    [   12.524058] systemd[1]: Finished systemd-binfmt.service - Set Up Additional Binary Formats.
  2325    [   12.539389] systemd[1]: Finished armbian-led-state.service - Armbian leds state.
  2326    [   12.665287] systemd[1]: Finished systemd-udev-trigger.service - Coldplug All udev Devices.
  2327    [   12.716874] systemd[1]: Starting ifupdown-pre.service - Helper to synchronize boot up for ifupdown...
  2328    [   12.791693] systemd[1]: Finished ifupdown-pre.service - Helper to synchronize boot up for ifupdown.
  2329    [   13.108149] systemd[1]: Started systemd-udevd.service - Rule-based Manager for Device Events and Files.
  2330    [   13.148427] systemd[1]: Starting plymouth-start.service - Show Plymouth Boot Screen...
  2331    [   13.295201] zram: Added device: zram0
  2332    [   13.296564] zram: Added device: zram1
  2333    [   13.297892] zram: Added device: zram2
  2334    [   13.302246] systemd[1]: Started plymouth-start.service - Show Plymouth Boot Screen.
  2335    [   13.305221] systemd[1]: bootsplash-ask-password-console.path - Dispatch Password Requests to Console Directory Watch when bootsplash is active was skipped because of an unmet condition check (ConditionPathExists=/sys/devices/platform/bootsplash.0/enabled).
  2336    [   13.306981] systemd[1]: Started systemd-ask-password-plymouth.path - Forward Password Requests to Plymouth Directory Watch.
  2337    [   13.317557] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
  2338    [   13.322145] systemd[1]: Reached target paths.target - Path Units.
  2339    [   13.392142] systemd[1]: Found device dev-ttyS2.device - /dev/ttyS2.
  2340    [   13.762258] zram0: detected capacity change from 0 to 4069848
  2341    [   13.868052] Adding 2034920k swap on /dev/zram0.  Priority:5 extents:1 across:2034920k SSFS
  2342    [   14.309549] mc: Linux media interface: v0.10
  2343    [   14.338277] zram1: detected capacity change from 0 to 102400
  2344    [   14.349832] Registered IR keymap rc-empty
  2345    [   14.350015] rc rc0: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc0
  2346    [   14.350805] rc rc0: lirc_dev: driver gpio_ir_recv registered at minor = 0, raw IR receiver, no transmitter
  2347    [   14.351040] input: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc0/input4
  2348    [   14.412378] videodev: Linux video capture interface: v2.00
  2349    [   14.516253] systemd[1]: Finished armbian-zram-config.service - Armbian ZRAM config.
  2350    [   14.547999] systemd[1]: Starting armbian-ramlog.service - Armbian memory supported logging...
  2351    [   14.609736] rk3328-codec ff410000.codec: spk_depop_time use default value.
  2352    [   14.725425] EXT4-fs (zram1): mounted filesystem without journal. Quota mode: none.
  2353    [   14.751560] rockchip-rga ff390000.rga: HW Version: 0x04.00
  2354    [   14.752261] rockchip-rga ff390000.rga: Registered rockchip-rga as /dev/video0
  2355    [   14.844417] rockchip_vdec: module is from the staging directory, the quality is unknown, you have been warned.
  2356    [   14.847915] rkvdec ff360000.video-codec: Adding to iommu group 3
  2357    [   14.848869] systemd[1]: Reached target sound.target - Sound Card.
  2358    [   14.864578] hantro-vpu ff350000.video-codec: Adding to iommu group 2
  2359    [   14.866040] hantro-vpu ff350000.video-codec: registered rockchip,rk3328-vpu-dec as /dev/video1
  2360    [   19.079156] systemd[1]: Finished armbian-ramlog.service - Armbian memory supported logging.
  2361    [   19.105316] systemd[1]: Starting systemd-journald.service - Journal Service...
  2362    [   19.468572] systemd[1]: Started systemd-journald.service - Journal Service.
  2363    [   19.554099] systemd-journald[588]: Received client request to flush runtime journal.
  2364
  2365    ### armbian-release:
  2366
  2367    # PLEASE DO NOT EDIT THIS FILE
  2368    BOARD=rk3318-box
  2369    BOARD_NAME="RK3318 Box"
  2370    BOARDFAMILY=rockchip64
  2371    BUILD_REPOSITORY_URL=https://github.com/armbian/build
  2372    BUILD_REPOSITORY_COMMIT=313c893
  2373    VERSION=23.02.0-trunk
  2374    LINUXFAMILY=rockchip64
  2375    ARCH=arm64
  2376    IMAGE_TYPE=nightly
  2377    BOARD_TYPE=tvb
  2378    INITRD_ARCH=arm64
  2379    KERNEL_IMAGE_TYPE=Image
  2380
  2381    ### boot environment:
  2382
  2383    verbosity=1
  2384    bootlogo=false
  2385    overlay_prefix=rockchip
  2386    fdtfile=rockchip/rk3318-box.dtb
  2387    rootdev=UUID=2eb1e931-b16f-46a3-8b3b-f0a92acc8ddb
  2388    rootfstype=ext4
  2389    overlays=rk3318-box-led-conf1
  2390
  2391    ### lsusb:
  2392
  2393    Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  2394    Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  2395    Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  2396    Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  2397    Bus 001 Device 002: ID 045e:00b0 Microsoft Corp. Digital Media Pro Keyboard
  2398    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  2399
  2400    ### lscpu:
  2401
  2402    Architecture:                    aarch64
  2403    CPU op-mode(s):                  32-bit, 64-bit
  2404    Byte Order:                      Little Endian
  2405    CPU(s):                          4
  2406    On-line CPU(s) list:             0-3
  2407    Vendor ID:                       ARM
  2408    Model name:                      Cortex-A53
  2409    Model:                           4
  2410    Thread(s) per core:              1
  2411    Core(s) per cluster:             4
  2412    Socket(s):                       -
  2413    Cluster(s):                      1
  2414    Stepping:                        r0p4
  2415    CPU(s) scaling MHz:              100%
  2416    CPU max MHz:                     1008.0000
  2417    CPU min MHz:                     600.0000
  2418    BogoMIPS:                        48.00
  2419    Flags:                           fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  2420    NUMA node(s):                    1
  2421    NUMA node0 CPU(s):               0-3
  2422    Vulnerability Itlb multihit:     Not affected
  2423    Vulnerability L1tf:              Not affected
  2424    Vulnerability Mds:               Not affected
  2425    Vulnerability Meltdown:          Not affected
  2426    Vulnerability Mmio stale data:   Not affected
  2427    Vulnerability Retbleed:          Not affected
  2428    Vulnerability Spec store bypass: Not affected
  2429    Vulnerability Spectre v1:        Mitigation; __user pointer sanitization
  2430    Vulnerability Spectre v2:        Not affected
  2431    Vulnerability Srbds:             Not affected
  2432    Vulnerability Tsx async abort:   Not affected
  2433
  2434    ### cpuinfo:
  2435
  2436    processor    : 0
  2437    BogoMIPS    : 48.00
  2438    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  2439    CPU implementer    : 0x41
  2440    CPU architecture: 8
  2441    CPU variant    : 0x0
  2442    CPU part    : 0xd03
  2443    CPU revision    : 4
  2444
  2445    processor    : 1
  2446    BogoMIPS    : 48.00
  2447    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  2448    CPU implementer    : 0x41
  2449    CPU architecture: 8
  2450    CPU variant    : 0x0
  2451    CPU part    : 0xd03
  2452    CPU revision    : 4
  2453
  2454    processor    : 2
  2455    BogoMIPS    : 48.00
  2456    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  2457    CPU implementer    : 0x41
  2458    CPU architecture: 8
  2459    CPU variant    : 0x0
  2460    CPU part    : 0xd03
  2461    CPU revision    : 4
  2462
  2463    processor    : 3
  2464    BogoMIPS    : 48.00
  2465    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  2466    CPU implementer    : 0x41
  2467    CPU architecture: 8
  2468    CPU variant    : 0x0
  2469    CPU part    : 0xd03
  2470    CPU revision    : 4
  2471
  2472
  2473    ### meminfo:
  2474
  2475    MemTotal:        4069844 kB
  2476    MemFree:         3877944 kB
  2477    MemAvailable:    3880652 kB
  2478    Buffers:            8632 kB
  2479    Cached:            59732 kB
  2480    SwapCached:            0 kB
  2481    Active:            49992 kB
  2482    Inactive:          20676 kB
  2483    Active(anon):      13812 kB
  2484    Inactive(anon):      808 kB
  2485    Active(file):      36180 kB
  2486    Inactive(file):    19868 kB
  2487    Unevictable:       11088 kB
  2488    Mlocked:               0 kB
  2489    SwapTotal:       2034920 kB
  2490    SwapFree:        2034920 kB
  2491    Zswap:                 0 kB
  2492    Zswapped:              0 kB
  2493    Dirty:               596 kB
  2494    Writeback:             0 kB
  2495    AnonPages:         13704 kB
  2496    Mapped:            17084 kB
  2497    Shmem:              8848 kB
  2498    KReclaimable:      16952 kB
  2499    Slab:              47676 kB
  2500    SReclaimable:      16952 kB
  2501    SUnreclaim:        30724 kB
  2502    KernelStack:        2176 kB
  2503    PageTables:         1012 kB
  2504    SecPageTables:         0 kB
  2505    NFS_Unstable:          0 kB
  2506    Bounce:                0 kB
  2507    WritebackTmp:          0 kB
  2508    CommitLimit:     4069840 kB
  2509    Committed_AS:      59920 kB
  2510    VmallocTotal:   133143592960 kB
  2511    VmallocUsed:       35120 kB
  2512    VmallocChunk:          0 kB
  2513    Percpu:             1056 kB
  2514    AnonHugePages:         0 kB
  2515    ShmemHugePages:        0 kB
  2516    ShmemPmdMapped:        0 kB
  2517    FileHugePages:         0 kB
  2518    FilePmdMapped:         0 kB
  2519    CmaTotal:         131072 kB
  2520    CmaFree:          122368 kB
  2521    HugePages_Total:       0
  2522    HugePages_Free:        0
  2523    HugePages_Rsvd:        0
  2524    HugePages_Surp:        0
  2525    Hugepagesize:       2048 kB
  2526    Hugetlb:               0 kB
  2527
  2528    ### virtual memory:
  2529
  2530    vm.admin_reserve_kbytes = 8192
  2531    vm.compaction_proactiveness = 20
  2532    vm.compact_unevictable_allowed = 1
  2533    vm.dirty_background_bytes = 0
  2534    vm.dirty_background_ratio = 10
  2535    vm.dirty_bytes = 0
  2536    vm.dirty_expire_centisecs = 3000
  2537    vm.dirty_ratio = 20
  2538    vm.dirtytime_expire_seconds = 43200
  2539    vm.dirty_writeback_centisecs = 500
  2540    vm.extfrag_threshold = 500
  2541    vm.hugetlb_optimize_vmemmap = 0
  2542    vm.hugetlb_shm_group = 0
  2543    vm.laptop_mode = 0
  2544    vm.legacy_va_layout = 0
  2545    vm.lowmem_reserve_ratio = 256    256    32    0
  2546    vm.max_map_count = 65530
  2547    vm.min_free_kbytes = 22528
  2548    vm.min_slab_ratio = 5
  2549    vm.min_unmapped_ratio = 1
  2550    vm.mmap_min_addr = 4096
  2551    vm.mmap_rnd_bits = 18
  2552    vm.mmap_rnd_compat_bits = 11
  2553    vm.nr_hugepages = 0
  2554    vm.nr_hugepages_mempolicy = 0
  2555    vm.nr_overcommit_hugepages = 0
  2556    vm.numa_stat = 1
  2557    vm.numa_zonelist_order = Node
  2558    vm.oom_dump_tasks = 1
  2559    vm.oom_kill_allocating_task = 0
  2560    vm.overcommit_kbytes = 0
  2561    vm.overcommit_memory = 0
  2562    vm.overcommit_ratio = 50
  2563    vm.page-cluster = 0
  2564    vm.page_lock_unfairness = 5
  2565    vm.panic_on_oom = 0
  2566    vm.percpu_pagelist_high_fraction = 0
  2567    vm.stat_interval = 1
  2568    vm.swappiness = 100
  2569    vm.user_reserve_kbytes = 125902
  2570    vm.vfs_cache_pressure = 100
  2571    vm.watermark_boost_factor = 15000
  2572    vm.watermark_scale_factor = 10
  2573    vm.zone_reclaim_mode = 0
  2574
  2575    ### ip addr:
  2576
  2577    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  2578        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  2579        inet XXX.XXX.0.1/8 scope host lo
  2580           valid_lft forever preferred_lft forever
  2581        inet6 ::1/128 scope host
  2582           valid_lft forever preferred_lft forever
  2583    2: end1: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  2584        link/ether 52:d1:50:3d:d5:78 brd ff:ff:ff:ff:ff:ff
  2585
  2586    ### partitions:
  2587
  2588    major minor  #blocks  name
  2589
  2590     179        0   15558144 mmcblk0
  2591     179        1   15384576 mmcblk0p1
  2592     179       32   61071360 mmcblk2
  2593     179       64       4096 mmcblk2boot0
  2594     179       96       4096 mmcblk2boot1
  2595     252        0    2034924 zram0
  2596     252        1      51200 zram1
  2597
  2598    ### df:
  2599
  2600    udev            1.9G     0  1.9G   0% /dev
  2601    tmpfs           398M  5.7M  392M   2% /run
  2602    /dev/mmcblk0p1   15G  1.5G   13G  11% /
  2603    tmpfs           2.0G     0  2.0G   0% /dev/shm
  2604    tmpfs           5.0M     0  5.0M   0% /run/lock
  2605    tmpfs           2.0G     0  2.0G   0% /tmp
  2606    /dev/zram1       47M  1.4M   43M   4% /var/log
  2607
  2608    ### lsblk:
  2609
  2610    NAME         FSTYPE  SIZE MOUNTPOINT UUID
  2611    mmcblk0             14.8G
  2612    └─mmcblk0p1  ext4   14.7G /          2eb1e931-b16f-46a3-8b3b-f0a92acc8ddb
  2613    mmcblk2             58.2G
  2614    mmcblk2boot0           4M
  2615    mmcblk2boot1           4M
  2616    zram1                 50M /var/log
  2617    zram2                  0B
  2618
  2619    ### zramctl:
  2620
  2621    NAME       ALGORITHM DISKSIZE  DATA  COMPR TOTAL STREAMS MOUNTPOINT
  2622    /dev/zram1 zstd           50M  1.2M 204.4K  532K       4 /var/log
  2623    /dev/zram0 lzo-rle       1.9G    4K    74B   12K       4 [SWAP]
  2624
  2625    ### mtab:
  2626
  2627    /dev/mmcblk0p1 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0
  2628    /dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0
  2629    /dev/zram1 /var/log ext4 rw,relatime,discard 0 0
  2630
  2631    ### mmc0:8dfc info:
  2632
  2633                   fwrev: 0x0
  2634                  uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SU16G MODALIAS=mmc:block
  2635                     cid: 03534453553136478060b5bf4000a609
  2636                     rca: 0x8dfc
  2637                     csd: 400e00325b59000076b27f800a404013
  2638                  manfid: 0x000003
  2639                     ocr: 0x00300000
  2640    preferred_erase_size: 4194304
  2641                    type: SD
  2642                   hwrev: 0x8
  2643                    date: 06/2010
  2644                     dsr: 0x404
  2645              erase_size: 512
  2646                   oemid: 0x5344
  2647                  serial: 0x60b5bf40
  2648                     ssr: 0000000004000000010190000b050000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  2649                     scr: 0235800000000000
  2650                    name: SU16G
  2651
  2652    ### mmc2:0001 info:
  2653
  2654                   fwrev: 0x0500000000000000
  2655                  uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=CKTM4R MODALIAS=mmc:block
  2656                     cid: 150100434b544d345202a448f479c3a1
  2657             rel_sectors: 0x1
  2658    enhanced_rpmb_supported: 0x1
  2659                     rca: 0x0001
  2660            pre_eol_info: 0x01
  2661                     csd: d02701320f5903fff6dbffef8e40400d
  2662                  manfid: 0x000015
  2663                     ocr: 0x00300000
  2664    preferred_erase_size: 4194304
  2665    enhanced_area_offset: 18446744073709551594
  2666      raw_rpmb_size_mult: 0x20
  2667                    type: MMC
  2668                   hwrev: 0x0
  2669                    date: 12/2016
  2670                     prv: 0x2
  2671             ffu_capable: 1
  2672                     dsr: 0x404
  2673              erase_size: 524288
  2674               life_time: 0x01 0x01
  2675      enhanced_area_size: 4294967274
  2676                   oemid: 0x0100
  2677                  serial: 0xa448f479
  2678                 cmdq_en: 0
  2679                     rev: 0x8
  2680                    name: CKTM4R
  2681
  2682    ### Boot system health:
  2683
  2684    Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU  C.St.
  2685    21:08:34: 1008MHz  1.14  50%  24%  13%   0%  13%   0% 60.4 °C  0/3
  2686    21:08:34: 1008MHz  1.14  85%  32%  22%   0%  31%   0% 60.8 °C  0/3
  2687    21:08:35: 1008MHz  1.53  68%  15%   7%   1%  44%   0% 59.5 °C  0/3
  2688    21:08:35:  816MHz  1.53  59%   9%   5%   1%  43%   0% 59.1 °C  0/3
  2689    21:08:35:  816MHz  1.53  69%  15%   9%   1%  43%   0% 60.0 °C  0/3
  2690
  2691    ### Activated 1 lzo-rle zram swap devices with 1987MB each.
  2692    ### Activated Armbian ramlog partition with zstd compression
  2693
  2694    Sun Feb 12 09:11:45 PM MSK 2023 | RK3318 Box | 23.02.0-trunk | arm64 | aarch64 | 6.1.11-rockchip64
  2695
  2696    ### dmesg:
  2697
  2698    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
  2699    [    0.000000] Linux version 6.1.11-rockchip64 (root@7284a09ced08) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #trunk.0248 SMP PREEMPT Fri Feb 10 05:25:40 UTC 2023
  2700    [    0.000000] Machine model: Rockchip RK3318 BOX
  2701    [    0.000000] efi: UEFI not found.
  2702    [    0.000000] NUMA: No NUMA configuration found
  2703    [    0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x00000000feffffff]
  2704    [    0.000000] NUMA: NODE_DATA [mem 0xfe7b1a80-0xfe7b3fff]
  2705    [    0.000000] Zone ranges:
  2706    [    0.000000]   DMA      [mem 0x0000000000200000-0x00000000feffffff]
  2707    [    0.000000]   DMA32    empty
  2708    [    0.000000]   Normal   empty
  2709    [    0.000000] Movable zone start for each node
  2710    [    0.000000] Early memory node ranges
  2711    [    0.000000]   node   0: [mem 0x0000000000200000-0x00000000feffffff]
  2712    [    0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000000feffffff]
  2713    [    0.000000] On node 0, zone DMA: 512 pages in unavailable ranges
  2714    [    0.000000] On node 0, zone DMA: 4096 pages in unavailable ranges
  2715    [    0.000000] cma: Reserved 128 MiB at 0x00000000f2600000
  2716    [    0.000000] psci: probing for conduit method from DT.
  2717    [    0.000000] psci: PSCIv1.1 detected in firmware.
  2718    [    0.000000] psci: Using standard PSCI v0.2 function IDs
  2719    [    0.000000] psci: MIGRATE_INFO_TYPE not supported.
  2720    [    0.000000] psci: SMC Calling Convention v1.2
  2721    [    0.000000] percpu: Embedded 30 pages/cpu s82472 r8192 d32216 u122880
  2722    [    0.000000] pcpu-alloc: s82472 r8192 d32216 u122880 alloc=30*4096
  2723    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
  2724    [    0.000000] Detected VIPT I-cache on CPU0
  2725    [    0.000000] CPU features: detected: ARM erratum 845719
  2726    [    0.000000] alternatives: applying boot alternatives
  2727    [    0.000000] Fallback order for Node 0: 0
  2728    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1027656
  2729    [    0.000000] Policy zone: DMA
  2730    [    0.000000] Kernel command line: root=UUID=2eb1e931-b16f-46a3-8b3b-f0a92acc8ddb rootwait rootfstype=ext4 splash=verbose console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart=8635553d-01 usb-storage.quirks=   cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
  2731    [    0.000000] The swapaccount= commandline option is deprecated. Please report your usecase to linux-mm@kvack.org if you depend on this functionality.
  2732    [    0.000000] Unknown kernel command line parameters "splash=verbose ubootpart=8635553d-01 cgroup_enable=memory cgroup_memory=1", will be passed to user space.
  2733    [    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
  2734    [    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
  2735    [    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
  2736    [    0.000000] Memory: 3913516K/4175872K available (16448K kernel code, 2240K rwdata, 5832K rodata, 3968K init, 585K bss, 131284K reserved, 131072K cma-reserved)
  2737    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
  2738    [    0.000000] trace event string verifier disabled
  2739    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
  2740    [    0.000000] rcu:     RCU event tracing is enabled.
  2741    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
  2742    [    0.000000]     Trampoline variant of Tasks RCU enabled.
  2743    [    0.000000]     Tracing variant of Tasks RCU enabled.
  2744    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
  2745    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
  2746    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
  2747    [    0.000000] Root IRQ handler: gic_handle_irq
  2748    [    0.000000] GIC: Using split EOI/Deactivate mode
  2749    [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
  2750    [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
  2751    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  2752    [    0.000001] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  2753    [    0.001082] Console: colour dummy device 80x25
  2754    [    0.001166] printk: console [tty1] enabled
  2755    [    0.001285] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
  2756    [    0.001317] pid_max: default: 32768 minimum: 301
  2757    [    0.001467] LSM: Security Framework initializing
  2758    [    0.001517] Yama: becoming mindful.
  2759    [    0.001684] AppArmor: AppArmor initialized
  2760    [    0.001737] Stack Depot allocating hash table of 262144 entries with kvcalloc
  2761    [    0.002387] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
  2762    [    0.002428] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
  2763    [    0.005732] cblist_init_generic: Setting adjustable number of callback queues.
  2764    [    0.005760] cblist_init_generic: Setting shift to 2 and lim to 1.
  2765    [    0.005952] cblist_init_generic: Setting shift to 2 and lim to 1.
  2766    [    0.006387] rcu: Hierarchical SRCU implementation.
  2767    [    0.006398] rcu:     Max phase no-delay instances is 1000.
  2768    [    0.009993] EFI services will not be available.
  2769    [    0.010726] smp: Bringing up secondary CPUs ...
  2770    [    0.011975] Detected VIPT I-cache on CPU1
  2771    [    0.012165] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
  2772    [    0.013514] Detected VIPT I-cache on CPU2
  2773    [    0.013707] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
  2774    [    0.015052] Detected VIPT I-cache on CPU3
  2775    [    0.015243] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
  2776    [    0.015450] smp: Brought up 1 node, 4 CPUs
  2777    [    0.015476] SMP: Total of 4 processors activated.
  2778    [    0.015491] CPU features: detected: 32-bit EL0 Support
  2779    [    0.015500] CPU features: detected: 32-bit EL1 Support
  2780    [    0.015512] CPU features: detected: CRC32 instructions
  2781    [    0.015644] CPU: All CPU(s) started at EL2
  2782    [    0.015664] alternatives: applying system-wide alternatives
  2783    [    0.019288] devtmpfs: initialized
  2784    [    0.043194] Registered cp15_barrier emulation handler
  2785    [    0.043227] Registered setend emulation handler
  2786    [    0.043686] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  2787    [    0.043738] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
  2788    [    0.049656] pinctrl core: initialized pinctrl subsystem
  2789    [    0.050908] DMI not present or invalid.
  2790    [    0.052130] NET: Registered PF_NETLINK/PF_ROUTE protocol family
  2791    [    0.055184] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
  2792    [    0.056616] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
  2793    [    0.057876] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
  2794    [    0.058005] audit: initializing netlink subsys (disabled)
  2795    [    0.058390] audit: type=2000 audit(0.056:1): state=initialized audit_enabled=0 res=1
  2796    [    0.059847] thermal_sys: Registered thermal governor 'fair_share'
  2797    [    0.059862] thermal_sys: Registered thermal governor 'bang_bang'
  2798    [    0.059875] thermal_sys: Registered thermal governor 'step_wise'
  2799    [    0.059886] thermal_sys: Registered thermal governor 'user_space'
  2800    [    0.060008] cpuidle: using governor menu
  2801    [    0.060628] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  2802    [    0.060847] ASID allocator initialised with 65536 entries
  2803    [    0.062773] Serial: AMBA PL011 UART driver
  2804    [    0.081798] platform ff3c0000.hdmi: Fixing up cyclic dependency with ff370000.vop
  2805    [    0.108304] rockchip-gpio ff210000.gpio: probed /pinctrl/gpio@ff210000
  2806    [    0.109780] rockchip-gpio ff220000.gpio: probed /pinctrl/gpio@ff220000
  2807    [    0.111026] rockchip-gpio ff230000.gpio: probed /pinctrl/gpio@ff230000
  2808    [    0.112340] rockchip-gpio ff240000.gpio: probed /pinctrl/gpio@ff240000
  2809    [    0.151005] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
  2810    [    0.151030] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
  2811    [    0.151048] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
  2812    [    0.151059] HugeTLB: 508 KiB vmemmap can be freed for a 32.0 MiB page
  2813    [    0.151074] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
  2814    [    0.151084] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
  2815    [    0.151098] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
  2816    [    0.151109] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
  2817    [    0.152906] cryptd: max_cpu_qlen set to 1000
  2818    [    0.219608] raid6: neonx8   gen()  1038 MB/s
  2819    [    0.287788] raid6: neonx4   gen()  1063 MB/s
  2820    [    0.355971] raid6: neonx2   gen()  1004 MB/s
  2821    [    0.424121] raid6: neonx1   gen()   880 MB/s
  2822    [    0.492265] raid6: int64x8  gen()   744 MB/s
  2823    [    0.560414] raid6: int64x4  gen()   823 MB/s
  2824    [    0.628568] raid6: int64x2  gen()   707 MB/s
  2825    [    0.696751] raid6: int64x1  gen()   526 MB/s
  2826    [    0.696766] raid6: using algorithm neonx4 gen() 1063 MB/s
  2827    [    0.764859] raid6: .... xor() 770 MB/s, rmw enabled
  2828    [    0.764872] raid6: using neon recovery algorithm
  2829    [    0.771679] iommu: Default domain type: Translated
  2830    [    0.771701] iommu: DMA domain TLB invalidation policy: strict mode
  2831    [    0.772558] SCSI subsystem initialized
  2832    [    0.772943] libata version 3.00 loaded.
  2833    [    0.773493] usbcore: registered new interface driver usbfs
  2834    [    0.773588] usbcore: registered new interface driver hub
  2835    [    0.773667] usbcore: registered new device driver usb
  2836    [    0.774721] pps_core: LinuxPPS API ver. 1 registered
  2837    [    0.774733] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  2838    [    0.774768] PTP clock support registered
  2839    [    0.775217] EDAC MC: Ver: 3.0.0
  2840    [    0.778141] NetLabel: Initializing
  2841    [    0.778160] NetLabel:  domain hash size = 128
  2842    [    0.778172] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
  2843    [    0.778311] NetLabel:  unlabeled traffic allowed by default
  2844    [    0.778645] vgaarb: loaded
  2845    [    0.779655] clocksource: Switched to clocksource arch_sys_counter
  2846    [    0.780412] VFS: Disk quotas dquot_6.6.0
  2847    [    0.780523] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  2848    [    0.782096] AppArmor: AppArmor Filesystem Enabled
  2849    [    0.799888] NET: Registered PF_INET protocol family
  2850    [    0.800332] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
  2851    [    0.806626] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
  2852    [    0.806885] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
  2853    [    0.806991] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
  2854    [    0.807711] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
  2855    [    0.809104] TCP: Hash tables configured (established 32768 bind 32768)
  2856    [    0.809344] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
  2857    [    0.809539] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
  2858    [    0.810031] NET: Registered PF_UNIX/PF_LOCAL protocol family
  2859    [    0.810129] NET: Registered PF_XDP protocol family
  2860    [    0.810152] PCI: CLS 0 bytes, default 64
  2861    [    0.811131] Trying to unpack rootfs image as initramfs...
  2862    [    0.821153] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
  2863    [    0.822308] kvm [1]: IPA Size Limit: 40 bits
  2864    [    0.824764] kvm [1]: vgic interrupt IRQ9
  2865    [    0.825036] kvm [1]: Hyp mode initialized successfully
  2866    [    0.829187] Initialise system trusted keyrings
  2867    [    0.829320] Key type blacklist registered
  2868    [    0.829741] workingset: timestamp_bits=44 max_order=20 bucket_order=0
  2869    [    0.844213] zbud: loaded
  2870    [    0.847779] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  2871    [    0.849361] fuse: init (API version 7.37)
  2872    [    0.854176] integrity: Platform Keyring initialized
  2873    [    0.926343] xor: measuring software checksum speed
  2874    [    0.934481]    8regs           :  1221 MB/sec
  2875    [    0.942375]    32regs          :  1261 MB/sec
  2876    [    0.951673]    arm64_neon      :  1062 MB/sec
  2877    [    0.951698] xor: using function: 32regs (1261 MB/sec)
  2878    [    0.951720] Key type asymmetric registered
  2879    [    0.951730] Asymmetric key parser 'x509' registered
  2880    [    2.899892] Freeing initrd memory: 21288K
  2881    [    2.943854] alg: self-tests for CTR-KDF (hmac(sha256)) passed
  2882    [    2.944017] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
  2883    [    2.944292] io scheduler mq-deadline registered
  2884    [    2.944307] io scheduler kyber registered
  2885    [    2.944764] io scheduler bfq registered
  2886    [    2.963580] dma-pl330 ff1f0000.dma-controller: Loaded driver for PL330 DMAC-241330
  2887    [    2.963614] dma-pl330 ff1f0000.dma-controller:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
  2888    [    2.972276] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
  2889    [    2.978177] ff110000.serial: ttyS0 at MMIO 0xff110000 (irq = 25, base_baud = 1500000) is a 16550A
  2890    [    2.980094] ff130000.serial: ttyS2 at MMIO 0xff130000 (irq = 26, base_baud = 1500000) is a 16550A
  2891    [    2.980547] printk: console [ttyS2] enabled
  2892    [    2.982545] Serial: AMBA driver
  2893    [    2.991239] rockchip-vop ff370000.vop: Adding to iommu group 4
  2894    [    3.017293] loop: module loaded
  2895    [    3.026058] tun: Universal TUN/TAP device driver, 1.6
  2896    [    3.027922] thunder_xcv, ver 1.0
  2897    [    3.028019] thunder_bgx, ver 1.0
  2898    [    3.028108] nicpf, ver 1.0
  2899    [    3.029558] e1000e: Intel(R) PRO/1000 Network Driver
  2900    [    3.029569] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
  2901    [    3.029700] igb: Intel(R) Gigabit Ethernet Network Driver
  2902    [    3.029716] igb: Copyright (c) 2007-2014 Intel Corporation.
  2903    [    3.029792] igbvf: Intel(R) Gigabit Virtual Function Network Driver
  2904    [    3.029804] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
  2905    [    3.030201] sky2: driver version 1.30
  2906    [    3.031275] VFIO - User Level meta-driver version: 0.3
  2907    [    3.035094] dwc2 ff580000.usb: supply vusb_d not found, using dummy regulator
  2908    [    3.035413] dwc2 ff580000.usb: supply vusb_a not found, using dummy regulator
  2909    [    3.048524] dwc2 ff580000.usb: DWC OTG Controller
  2910    [    3.048582] dwc2 ff580000.usb: new USB bus registered, assigned bus number 1
  2911    [    3.048651] dwc2 ff580000.usb: irq 34, io mem 0xff580000
  2912    [    3.049044] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
  2913    [    3.049073] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  2914    [    3.049094] usb usb1: Product: DWC OTG Controller
  2915    [    3.049112] usb usb1: Manufacturer: Linux 6.1.11-rockchip64 dwc2_hsotg
  2916    [    3.049130] usb usb1: SerialNumber: ff580000.usb
  2917    [    3.050280] hub 1-0:1.0: USB hub found
  2918    [    3.050350] hub 1-0:1.0: 1 port detected
  2919    [    3.054765] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  2920    [    3.054818] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
  2921    [    3.055096] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
  2922    [    3.055222] xhci-hcd xhci-hcd.0.auto: irq 33, io mem 0xff600000
  2923    [    3.055784] ehci-platform ff5c0000.usb: EHCI Host Controller
  2924    [    3.055808] ohci-platform ff5d0000.usb: Generic Platform OHCI controller
  2925    [    3.055831] ehci-platform ff5c0000.usb: new USB bus registered, assigned bus number 3
  2926    [    3.055847] ohci-platform ff5d0000.usb: new USB bus registered, assigned bus number 4
  2927    [    3.055983] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  2928    [    3.056012] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 5
  2929    [    3.056041] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
  2930    [    3.056066] ehci-platform ff5c0000.usb: irq 35, io mem 0xff5c0000
  2931    [    3.056116] ohci-platform ff5d0000.usb: irq 36, io mem 0xff5d0000
  2932    [    3.056370] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
  2933    [    3.056396] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  2934    [    3.056416] usb usb2: Product: xHCI Host Controller
  2935    [    3.056434] usb usb2: Manufacturer: Linux 6.1.11-rockchip64 xhci-hcd
  2936    [    3.056451] usb usb2: SerialNumber: xhci-hcd.0.auto
  2937    [    3.057582] hub 2-0:1.0: USB hub found
  2938    [    3.057667] hub 2-0:1.0: 1 port detected
  2939    [    3.058447] usb usb5: We don't know the algorithms for LPM for this host, disabling LPM.
  2940    [    3.058702] usb usb5: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
  2941    [    3.058727] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  2942    [    3.058745] usb usb5: Product: xHCI Host Controller
  2943    [    3.058763] usb usb5: Manufacturer: Linux 6.1.11-rockchip64 xhci-hcd
  2944    [    3.058779] usb usb5: SerialNumber: xhci-hcd.0.auto
  2945    [    3.059871] hub 5-0:1.0: USB hub found
  2946    [    3.059961] hub 5-0:1.0: 1 port detected
  2947    [    3.060904] usbcore: registered new interface driver usb-storage
  2948    [    3.064295] mousedev: PS/2 mouse device common for all mice
  2949    [    3.065887] i2c_dev: i2c /dev entries driver
  2950    [    3.070650] dw_wdt ff1a0000.watchdog: No valid TOPs array specified
  2951    [    3.071702] ehci-platform ff5c0000.usb: USB 2.0 started, EHCI 1.00
  2952    [    3.072152] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
  2953    [    3.072183] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  2954    [    3.072202] usb usb3: Product: EHCI Host Controller
  2955    [    3.072218] usb usb3: Manufacturer: Linux 6.1.11-rockchip64 ehci_hcd
  2956    [    3.072233] usb usb3: SerialNumber: ff5c0000.usb
  2957    [    3.073230] hub 3-0:1.0: USB hub found
  2958    [    3.073305] hub 3-0:1.0: 1 port detected
  2959    [    3.074313] sdhci: Secure Digital Host Controller Interface driver
  2960    [    3.074332] sdhci: Copyright(c) Pierre Ossman
  2961    [    3.074388] Synopsys Designware Multimedia Card Interface Driver
  2962    [    3.076048] sdhci-pltfm: SDHCI platform and OF driver helper
  2963    [    3.076891] dwmmc_rockchip ff500000.mmc: IDMAC supports 32-bit address mode.
  2964    [    3.076947] dwmmc_rockchip ff500000.mmc: Using internal DMA controller.
  2965    [    3.076969] dwmmc_rockchip ff500000.mmc: Version ID is 270a
  2966    [    3.077071] dwmmc_rockchip ff500000.mmc: DW MMC controller at irq 39,32 bit host data width,256 deep fifo
  2967    [    3.077146] dwmmc_rockchip ff520000.mmc: IDMAC supports 32-bit address mode.
  2968    [    3.077190] dwmmc_rockchip ff520000.mmc: Using internal DMA controller.
  2969    [    3.077210] dwmmc_rockchip ff520000.mmc: Version ID is 270a
  2970    [    3.077304] dwmmc_rockchip ff520000.mmc: DW MMC controller at irq 40,32 bit host data width,256 deep fifo
  2971    [    3.077674] dwmmc_rockchip ff500000.mmc: Got CD GPIO
  2972    [    3.078156] mmc_host mmc2: card is non-removable.
  2973    [    3.078370] dwmmc_rockchip ff5f0000.mmc: IDMAC supports 32-bit address mode.
  2974    [    3.078429] dwmmc_rockchip ff5f0000.mmc: Using internal DMA controller.
  2975    [    3.078450] dwmmc_rockchip ff5f0000.mmc: Version ID is 270a
  2976    [    3.078562] dwmmc_rockchip ff5f0000.mmc: DW MMC controller at irq 41,32 bit host data width,256 deep fifo
  2977    [    3.079006] dwmmc_rockchip ff5f0000.mmc: allocated mmc-pwrseq
  2978    [    3.079028] mmc_host mmc4: card is non-removable.
  2979    [    3.080370] ledtrig-cpu: registered to indicate activity on CPUs
  2980    [    3.081274] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
  2981    [    3.081718] hid: raw HID events driver (C) Jiri Kosina
  2982    [    3.081974] usbcore: registered new interface driver usbhid
  2983    [    3.081990] usbhid: USB HID core driver
  2984    [    3.090267] drop_monitor: Initializing network drop monitor service
  2985    [    3.090785] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
  2986    [    3.091050] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
  2987    [    3.091614] NET: Registered PF_INET6 protocol family
  2988    [    3.091916] mmc_host mmc4: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
  2989    [    3.120090] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.01
  2990    [    3.120127] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  2991    [    3.120147] usb usb4: Product: Generic Platform OHCI controller
  2992    [    3.120162] usb usb4: Manufacturer: Linux 6.1.11-rockchip64 ohci_hcd
  2993    [    3.120179] usb usb4: SerialNumber: ff5d0000.usb
  2994    [    3.121387] hub 4-0:1.0: USB hub found
  2995    [    3.121465] hub 4-0:1.0: 1 port detected
  2996    [    3.136044] Segment Routing with IPv6
  2997    [    3.136156] In-situ OAM (IOAM) with IPv6
  2998    [    3.136347] NET: Registered PF_PACKET protocol family
  2999    [    3.136609] 8021q: 802.1Q VLAN Support v1.8
  3000    [    3.136705] Key type dns_resolver registered
  3001    [    3.138993] registered taskstats version 1
  3002    [    3.139040] Loading compiled-in X.509 certificates
  3003    [    3.145951] Loaded X.509 cert 'Build time autogenerated kernel key: e25f7f61aa13aedd90bace25454c8646dc5da469'
  3004    [    3.149972] zswap: loaded using pool zstd/z3fold
  3005    [    3.150292] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
  3006    [    3.150467] mmc0: new high speed SDHC card at address 8dfc
  3007    [    3.151285] Key type .fscrypt registered
  3008    [    3.151353] Key type fscrypt-provisioning registered
  3009    [    3.151991] mmcblk0: mmc0:8dfc SU16G 14.8 GiB
  3010    [    3.155797] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=yes
  3011    [    3.156568] Key type encrypted registered
  3012    [    3.156626] AppArmor: AppArmor sha1 policy hashing enabled
  3013    [    3.160870]  mmcblk0: p1
  3014    [    3.190822] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 52000000Hz, actual 50000000HZ div = 0)
  3015    [    3.191230] mmc2: new high speed MMC card at address 0001
  3016    [    3.193130] mmcblk2: mmc2:0001 CKTM4R 58.2 GiB
  3017    [    3.198304] mmcblk2boot0: mmc2:0001 CKTM4R 4.00 MiB
  3018    [    3.202456] mmcblk2boot1: mmc2:0001 CKTM4R 4.00 MiB
  3019    [    3.206165] mmcblk2rpmb: mmc2:0001 CKTM4R 4.00 MiB, chardev (242:0)
  3020    [    3.215556] mmc_host mmc4: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
  3021    [    3.217865] mmc4: new high speed SDIO card at address 0001
  3022    [    3.249633] rockchip-drm display-subsystem: bound ff370000.vop (ops vop_component_ops)
  3023    [    3.249815] dwhdmi-rockchip ff3c0000.hdmi: supply avdd-0v9 not found, using dummy regulator
  3024    [    3.250228] dwhdmi-rockchip ff3c0000.hdmi: supply avdd-1v8 not found, using dummy regulator
  3025    [    3.250795] dwhdmi-rockchip ff3c0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (inno_dw_hdmi_phy2)
  3026    [    3.252142] dwhdmi-rockchip ff3c0000.hdmi: registered DesignWare HDMI I2C bus driver
  3027    [    3.253074] rockchip-drm display-subsystem: bound ff3c0000.hdmi (ops dw_hdmi_rockchip_ops)
  3028    [    3.254351] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 0
  3029    [    3.347686] usb 1-1: new low-speed USB device number 2 using dwc2
  3030    [    3.563345] usb 1-1: New USB device found, idVendor=045e, idProduct=00b0, bcdDevice= 1.10
  3031    [    3.563375] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  3032    [    3.563390] usb 1-1: Product: Microsoft® Digital Media Pro Keyboard
  3033    [    3.563401] usb 1-1: Manufacturer: Microsoft
  3034    [    3.567151] Console: switching to colour frame buffer device 240x67
  3035    [    3.568813] input: Microsoft Microsoft® Digital Media Pro Keyboard as /devices/platform/ff580000.usb/usb1/1-1/1-1:1.0/0003:045E:00B0.0001/input/input0
  3036    [    3.617522] rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device
  3037    [    3.618658] WCN: marlin_init entry!
  3038    [    3.619466] of_cfs_init
  3039    [    3.619535] of_cfs_init: OK
  3040    [    3.622965] Freeing unused kernel memory: 3968K
  3041    [    3.629285] hid-generic 0003:045E:00B0.0001: input,hidraw0: USB HID v1.11 Keyboard [Microsoft Microsoft® Digital Media Pro Keyboard] on usb-ff580000.usb-1/input0
  3042    [    3.635849] Run /init as init process
  3043    [    3.635873]   with arguments:
  3044    [    3.635885]     /init
  3045    [    3.635896]   with environment:
  3046    [    3.635905]     HOME=/
  3047    [    3.635915]     TERM=linux
  3048    [    3.635924]     splash=verbose
  3049    [    3.635934]     ubootpart=8635553d-01
  3050    [    3.635945]     cgroup_enable=memory
  3051    [    3.635958]     cgroup_memory=1
  3052    [    3.637612] input: Microsoft Microsoft® Digital Media Pro Keyboard Consumer Control as /devices/platform/ff580000.usb/usb1/1-1/1-1:1.1/0003:045E:00B0.0002/input/input1
  3053    [    3.696430] input: Microsoft Microsoft® Digital Media Pro Keyboard System Control as /devices/platform/ff580000.usb/usb1/1-1/1-1:1.1/0003:045E:00B0.0002/input/input2
  3054    [    3.697073] hid-generic 0003:045E:00B0.0002: input,hidraw1: USB HID v1.11 Device [Microsoft Microsoft® Digital Media Pro Keyboard] on usb-ff580000.usb-1/input1
  3055    [    4.673302] input: adc-keys as /devices/platform/adc-keys/input/input3
  3056    [    4.719343] gpio-syscon ff100000.syscon:gpio: can't read the data register offset!
  3057    [    5.140107] lima ff300000.gpu: gp - mali450 version major 0 minor 0
  3058    [    5.141517] lima ff300000.gpu: pp0 - mali450 version major 0 minor 0
  3059    [    5.141866] lima ff300000.gpu: pp1 - mali450 version major 0 minor 0
  3060    [    5.141982] lima ff300000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
  3061    [    5.142006] lima ff300000.gpu: l2 cache 64K, 4-way, 64byte cache line, 128bit external bus
  3062    [    5.143136] lima ff300000.gpu: bus rate = 491520000
  3063    [    5.143170] lima ff300000.gpu: mod rate = 491520000
  3064    [    5.153521] rk_gmac-dwmac ff550000.ethernet: IRQ eth_wake_irq not found
  3065    [    5.153556] rk_gmac-dwmac ff550000.ethernet: IRQ eth_lpi not found
  3066    [    5.154290] rk_gmac-dwmac ff550000.ethernet: PTP uses main clock
  3067    [    5.155537] rk_gmac-dwmac ff550000.ethernet: clock input or output? (output).
  3068    [    5.155572] rk_gmac-dwmac ff550000.ethernet: TX delay(0x30).
  3069    [    5.155591] rk_gmac-dwmac ff550000.ethernet: RX delay(0x10).
  3070    [    5.155770] rk_gmac-dwmac ff550000.ethernet: integrated PHY? (yes).
  3071    [    5.155959] rk_gmac-dwmac ff550000.ethernet: cannot get clock clk_mac_refout
  3072    [    5.155989] rk_gmac-dwmac ff550000.ethernet: cannot get clock clk_mac_speed
  3073    [    5.161074] rk_gmac-dwmac ff550000.ethernet: init for RMII
  3074    [    5.164994] [drm] Initialized lima 1.1.0 20191231 for ff300000.gpu on minor 1
  3075    [    5.200074] rk_gmac-dwmac ff550000.ethernet: User ID: 0x10, Synopsys ID: 0x35
  3076    [    5.200117] rk_gmac-dwmac ff550000.ethernet:     DWMAC1000
  3077    [    5.200134] rk_gmac-dwmac ff550000.ethernet: DMA HW capability register supported
  3078    [    5.200150] rk_gmac-dwmac ff550000.ethernet: RX Checksum Offload Engine supported
  3079    [    5.200162] rk_gmac-dwmac ff550000.ethernet: COE Type 2
  3080    [    5.200177] rk_gmac-dwmac ff550000.ethernet: TX Checksum insertion supported
  3081    [    5.200190] rk_gmac-dwmac ff550000.ethernet: Wake-Up On Lan supported
  3082    [    5.200374] rk_gmac-dwmac ff550000.ethernet: Normal descriptors
  3083    [    5.200391] rk_gmac-dwmac ff550000.ethernet: Ring mode enabled
  3084    [    5.200404] rk_gmac-dwmac ff550000.ethernet: Enable RX Mitigation via HW Watchdog Timer
  3085    [    5.234759] rk_gmac-dwmac ff550000.ethernet end1: renamed from eth0
  3086    [    5.321424] dw-apb-uart ff130000.serial: forbid DMA for kernel console
  3087    [    5.989668] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Quota mode: none.
  3088    [    8.067544] systemd[1]: System time before build time, advancing clock.
  3089    [    8.146488] systemd[1]: Inserted module 'autofs4'
  3090    [    8.307920] systemd[1]: systemd 252.5-2 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
  3091    [    8.307977] systemd[1]: Detected architecture arm64.
  3092    [    8.332039] systemd[1]: Hostname set to <rk3318-box>.
  3093    [    9.702610] systemd[326]: /usr/lib/systemd/system-generators/netplan failed with exit status 1.
  3094    [   10.968035] systemd[1]: Queued start job for default target graphical.target.
  3095    [   11.001424] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
  3096    [   11.005883] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
  3097    [   11.010024] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
  3098    [   11.013249] systemd[1]: Created slice user.slice - User and Session Slice.
  3099    [   11.014336] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
  3100    [   11.016397] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
  3101    [   11.017132] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
  3102    [   11.017770] systemd[1]: Reached target remote-fs.target - Remote File Systems.
  3103    [   11.018164] systemd[1]: Reached target slices.target - Slice Units.
  3104    [   11.018757] systemd[1]: Reached target swap.target - Swaps.
  3105    [   11.019193] systemd[1]: Reached target time-set.target - System Time Set.
  3106    [   11.019974] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
  3107    [   11.025572] systemd[1]: Listening on syslog.socket - Syslog Socket.
  3108    [   11.027013] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
  3109    [   11.028395] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
  3110    [   11.030423] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
  3111    [   11.032005] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
  3112    [   11.034070] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
  3113    [   11.046670] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
  3114    [   11.048303] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
  3115    [   11.076411] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
  3116    [   11.085800] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
  3117    [   11.095896] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
  3118    [   11.106168] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
  3119    [   11.122958] systemd[1]: Starting fake-hwclock.service - Restore / save the current clock...
  3120    [   11.133410] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
  3121    [   11.144479] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
  3122    [   11.155897] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
  3123    [   11.167388] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
  3124    [   11.180056] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
  3125    [   11.192883] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
  3126    [   11.195417] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
  3127    [   11.227249] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
  3128    [   11.239026] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
  3129    [   11.242038] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
  3130    [   11.252870] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
  3131    [   11.273500] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
  3132    [   11.276624] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
  3133    [   11.279601] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
  3134    [   11.282572] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
  3135    [   11.286806] systemd[1]: Finished fake-hwclock.service - Restore / save the current clock.
  3136    [   11.292200] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
  3137    [   11.297847] systemd[1]: modprobe@configfs.service: Deactivated successfully.
  3138    [   11.300628] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
  3139    [   11.304745] systemd[1]: modprobe@drm.service: Deactivated successfully.
  3140    [   11.306534] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
  3141    [   11.313826] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
  3142    [   11.316209] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
  3143    [   11.320582] systemd[1]: modprobe@fuse.service: Deactivated successfully.
  3144    [   11.322862] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
  3145    [   11.328235] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
  3146    [   11.367503] EXT4-fs (mmcblk0p1): re-mounted. Quota mode: none.
  3147    [   11.372930] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
  3148    [   11.383286] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
  3149    [   11.394384] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables...
  3150    [   11.418858] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
  3151    [   11.422294] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
  3152    [   11.425144] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
  3153    [   11.428323] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
  3154    [   11.471527] systemd[1]: Starting systemd-random-seed.service - Load/Save Random Seed...
  3155    [   11.482957] systemd[1]: Starting systemd-sysusers.service - Create System Users...
  3156    [   11.535795] systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables.
  3157    [   11.652146] systemd[1]: Finished systemd-sysusers.service - Create System Users.
  3158    [   11.704908] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev...
  3159    [   11.894324] systemd[1]: Finished systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev.
  3160    [   11.943699] random: crng init done
  3161    [   11.953638] systemd[1]: Starting systemd-udevd.service - Rule-based Manager for Device Events and Files...
  3162    [   11.974628] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout.
  3163    [   11.984000] systemd[1]: Finished systemd-random-seed.service - Load/Save Random Seed.
  3164    [   11.991591] systemd[1]: first-boot-complete.target - First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes).
  3165    [   11.992096] systemd[1]: Reached target local-fs-pre.target - Preparation for Local File Systems.
  3166    [   12.015119] systemd[1]: Mounting tmp.mount - /tmp...
  3167    [   12.052097] systemd[1]: Mounted tmp.mount - /tmp.
  3168    [   12.057980] systemd[1]: Reached target local-fs.target - Local File Systems.
  3169    [   12.074377] systemd[1]: Starting armbian-led-state.service - Armbian leds state...
  3170    [   12.104988] systemd[1]: Starting armbian-zram-config.service - Armbian ZRAM config...
  3171    [   12.129568] systemd[1]: Starting console-setup.service - Set console font and keymap...
  3172    [   12.143244] systemd[1]: Starting plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data...
  3173    [   12.213271] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
  3174    [   12.214200] systemd[1]: systemd-machine-id-commit.service - Commit a transient machine-id on disk was skipped because of an unmet condition check (ConditionPathIsMountPoint=/etc/machine-id).
  3175    [   12.223416] systemd[1]: Finished console-setup.service - Set console font and keymap.
  3176    [   12.249869] systemd[1]: Received SIGRTMIN+20 from PID 292 (plymouthd).
  3177    [   12.293176] systemd[1]: Finished plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data.
  3178    [   12.310530] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 391 (systemd-binfmt)
  3179    [   12.336675] systemd[1]: Mounting proc-sys-fs-binfmt_misc.mount - Arbitrary Executable File Formats File System...
  3180    [   12.415070] systemd[1]: Mounted proc-sys-fs-binfmt_misc.mount - Arbitrary Executable File Formats File System.
  3181    [   12.460605] systemd[1]: Finished systemd-binfmt.service - Set Up Additional Binary Formats.
  3182    [   12.564445] systemd[1]: Finished armbian-led-state.service - Armbian leds state.
  3183    [   12.608491] systemd[1]: Finished systemd-udev-trigger.service - Coldplug All udev Devices.
  3184    [   12.664910] systemd[1]: Starting ifupdown-pre.service - Helper to synchronize boot up for ifupdown...
  3185    [   12.841678] systemd[1]: Finished ifupdown-pre.service - Helper to synchronize boot up for ifupdown.
  3186    [   12.989436] systemd[1]: Started systemd-udevd.service - Rule-based Manager for Device Events and Files.
  3187    [   13.036717] systemd[1]: Starting plymouth-start.service - Show Plymouth Boot Screen...
  3188    [   13.239396] systemd[1]: Started plymouth-start.service - Show Plymouth Boot Screen.
  3189    [   13.253867] systemd[1]: bootsplash-ask-password-console.path - Dispatch Password Requests to Console Directory Watch when bootsplash is active was skipped because of an unmet condition check (ConditionPathExists=/sys/devices/platform/bootsplash.0/enabled).
  3190    [   13.255527] systemd[1]: Started systemd-ask-password-plymouth.path - Forward Password Requests to Plymouth Directory Watch.
  3191    [   13.256308] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
  3192    [   13.256903] systemd[1]: Reached target paths.target - Path Units.
  3193    [   13.372479] zram: Added device: zram0
  3194    [   13.373898] zram: Added device: zram1
  3195    [   13.375483] zram: Added device: zram2
  3196    [   13.437339] systemd[1]: Found device dev-ttyS2.device - /dev/ttyS2.
  3197    [   13.791484] zram0: detected capacity change from 0 to 4069848
  3198    [   13.911079] Adding 2034920k swap on /dev/zram0.  Priority:5 extents:1 across:2034920k SSFS
  3199    [   14.201201] mc: Linux media interface: v0.10
  3200    [   14.353910] videodev: Linux video capture interface: v2.00
  3201    [   14.457325] Registered IR keymap rc-empty
  3202    [   14.457566] rc rc0: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc0
  3203    [   14.458259] rc rc0: lirc_dev: driver gpio_ir_recv registered at minor = 0, raw IR receiver, no transmitter
  3204    [   14.458642] input: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc0/input4
  3205    [   14.478505] rk3328-codec ff410000.codec: spk_depop_time use default value.
  3206    [   14.586578] zram1: detected capacity change from 0 to 102400
  3207    [   14.633572] cfg80211: Loading compiled-in X.509 certificates for regulatory database
  3208    [   14.636213] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
  3209    [   14.733808] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
  3210    [   14.833696] brcmfmac: F1 signature read @0x18000000=0x16034334
  3211    [   14.852245] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4334-sdio for chip BCM4334/3
  3212    [   14.853056] usbcore: registered new interface driver brcmfmac
  3213    [   14.857802] brcmfmac mmc4:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.rockchip,rk3318-box.bin failed with error -2
  3214    [   14.869954] systemd[1]: Finished armbian-zram-config.service - Armbian ZRAM config.
  3215    [   14.870155] rockchip-rga ff390000.rga: HW Version: 0x04.00
  3216    [   14.870694] rockchip-rga ff390000.rga: Registered rockchip-rga as /dev/video0
  3217    [   14.872276] systemd[1]: Listening on systemd-rfkill.socket - Load/Save RF Kill Switch Status /dev/rfkill Watch.
  3218    [   14.912910] systemd[1]: Starting armbian-ramlog.service - Armbian memory supported logging...
  3219    [   14.921744] brcmfmac mmc4:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.clm_blob failed with error -2
  3220    [   14.956223] hantro-vpu ff350000.video-codec: Adding to iommu group 2
  3221    [   14.957143] hantro-vpu ff350000.video-codec: registered rockchip,rk3328-vpu-dec as /dev/video1
  3222    [   14.973037] rockchip_vdec: module is from the staging directory, the quality is unknown, you have been warned.
  3223    [   14.978669] rkvdec ff360000.video-codec: Adding to iommu group 3
  3224    [   15.005900] systemd[1]: Reached target sound.target - Sound Card.
  3225    [   15.093573] EXT4-fs (zram1): mounted filesystem without journal. Quota mode: none.
  3226    [   15.158368] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
  3227    [   15.158967] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4334/3 wl0: Jul 24 2019 12:58:36 version 6.10.191 (TOB) (r) FWID 01-b049404e
  3228    [   15.200664] systemd[1]: Starting systemd-rfkill.service - Load/Save RF Kill Switch Status...
  3229    [   15.309570] systemd[1]: Started systemd-rfkill.service - Load/Save RF Kill Switch Status.
  3230    [   19.423031] systemd[1]: Finished armbian-ramlog.service - Armbian memory supported logging.
  3231    [   19.461536] systemd[1]: Starting systemd-journald.service - Journal Service...
  3232    [   19.804583] systemd[1]: Started systemd-journald.service - Journal Service.
  3233    [   19.902408] systemd-journald[601]: Received client request to flush runtime journal.
  3234
  3235    ### armbian-release:
  3236
  3237    # PLEASE DO NOT EDIT THIS FILE
  3238    BOARD=rk3318-box
  3239    BOARD_NAME="RK3318 Box"
  3240    BOARDFAMILY=rockchip64
  3241    BUILD_REPOSITORY_URL=https://github.com/armbian/build
  3242    BUILD_REPOSITORY_COMMIT=313c893
  3243    VERSION=23.02.0-trunk
  3244    LINUXFAMILY=rockchip64
  3245    ARCH=arm64
  3246    IMAGE_TYPE=nightly
  3247    BOARD_TYPE=tvb
  3248    INITRD_ARCH=arm64
  3249    KERNEL_IMAGE_TYPE=Image
  3250
  3251    ### boot environment:
  3252
  3253    verbosity=1
  3254    bootlogo=false
  3255    overlay_prefix=rockchip
  3256    fdtfile=rockchip/rk3318-box.dtb
  3257    rootdev=UUID=2eb1e931-b16f-46a3-8b3b-f0a92acc8ddb
  3258    rootfstype=ext4
  3259    overlays=rk3318-box-led-conf2
  3260
  3261    ### lsusb:
  3262
  3263    Bus 005 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  3264    Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  3265    Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  3266    Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  3267    Bus 001 Device 002: ID 045e:00b0 Microsoft Corp. Digital Media Pro Keyboard
  3268    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  3269
  3270    ### lscpu:
  3271
  3272    Architecture:                    aarch64
  3273    CPU op-mode(s):                  32-bit, 64-bit
  3274    Byte Order:                      Little Endian
  3275    CPU(s):                          4
  3276    On-line CPU(s) list:             0-3
  3277    Vendor ID:                       ARM
  3278    Model name:                      Cortex-A53
  3279    Model:                           4
  3280    Thread(s) per core:              1
  3281    Core(s) per cluster:             4
  3282    Socket(s):                       -
  3283    Cluster(s):                      1
  3284    Stepping:                        r0p4
  3285    CPU(s) scaling MHz:              100%
  3286    CPU max MHz:                     1008.0000
  3287    CPU min MHz:                     600.0000
  3288    BogoMIPS:                        48.00
  3289    Flags:                           fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  3290    NUMA node(s):                    1
  3291    NUMA node0 CPU(s):               0-3
  3292    Vulnerability Itlb multihit:     Not affected
  3293    Vulnerability L1tf:              Not affected
  3294    Vulnerability Mds:               Not affected
  3295    Vulnerability Meltdown:          Not affected
  3296    Vulnerability Mmio stale data:   Not affected
  3297    Vulnerability Retbleed:          Not affected
  3298    Vulnerability Spec store bypass: Not affected
  3299    Vulnerability Spectre v1:        Mitigation; __user pointer sanitization
  3300    Vulnerability Spectre v2:        Not affected
  3301    Vulnerability Srbds:             Not affected
  3302    Vulnerability Tsx async abort:   Not affected
  3303
  3304    ### cpuinfo:
  3305
  3306    processor    : 0
  3307    BogoMIPS    : 48.00
  3308    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  3309    CPU implementer    : 0x41
  3310    CPU architecture: 8
  3311    CPU variant    : 0x0
  3312    CPU part    : 0xd03
  3313    CPU revision    : 4
  3314
  3315    processor    : 1
  3316    BogoMIPS    : 48.00
  3317    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  3318    CPU implementer    : 0x41
  3319    CPU architecture: 8
  3320    CPU variant    : 0x0
  3321    CPU part    : 0xd03
  3322    CPU revision    : 4
  3323
  3324    processor    : 2
  3325    BogoMIPS    : 48.00
  3326    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  3327    CPU implementer    : 0x41
  3328    CPU architecture: 8
  3329    CPU variant    : 0x0
  3330    CPU part    : 0xd03
  3331    CPU revision    : 4
  3332
  3333    processor    : 3
  3334    BogoMIPS    : 48.00
  3335    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  3336    CPU implementer    : 0x41
  3337    CPU architecture: 8
  3338    CPU variant    : 0x0
  3339    CPU part    : 0xd03
  3340    CPU revision    : 4
  3341
  3342
  3343    ### meminfo:
  3344
  3345    MemTotal:        4069844 kB
  3346    MemFree:         3858596 kB
  3347    MemAvailable:    3864208 kB
  3348    Buffers:            9004 kB
  3349    Cached:            61384 kB
  3350    SwapCached:            0 kB
  3351    Active:            51300 kB
  3352    Inactive:          22388 kB
  3353    Active(anon):      14360 kB
  3354    Inactive(anon):      836 kB
  3355    Active(file):      36940 kB
  3356    Inactive(file):    21552 kB
  3357    Unevictable:       11088 kB
  3358    Mlocked:               0 kB
  3359    SwapTotal:       2034920 kB
  3360    SwapFree:        2034920 kB
  3361    Zswap:                 0 kB
  3362    Zswapped:              0 kB
  3363    Dirty:               452 kB
  3364    Writeback:             0 kB
  3365    AnonPages:         14196 kB
  3366    Mapped:            17132 kB
  3367    Shmem:              8872 kB
  3368    KReclaimable:      18140 kB
  3369    Slab:              49728 kB
  3370    SReclaimable:      18140 kB
  3371    SUnreclaim:        31588 kB
  3372    KernelStack:        2224 kB
  3373    PageTables:         1040 kB
  3374    SecPageTables:         0 kB
  3375    NFS_Unstable:          0 kB
  3376    Bounce:                0 kB
  3377    WritebackTmp:          0 kB
  3378    CommitLimit:     4069840 kB
  3379    Committed_AS:      61408 kB
  3380    VmallocTotal:   133143592960 kB
  3381    VmallocUsed:       36544 kB
  3382    VmallocChunk:          0 kB
  3383    Percpu:             1056 kB
  3384    AnonHugePages:         0 kB
  3385    ShmemHugePages:        0 kB
  3386    ShmemPmdMapped:        0 kB
  3387    FileHugePages:         0 kB
  3388    FilePmdMapped:         0 kB
  3389    CmaTotal:         131072 kB
  3390    CmaFree:          122368 kB
  3391    HugePages_Total:       0
  3392    HugePages_Free:        0
  3393    HugePages_Rsvd:        0
  3394    HugePages_Surp:        0
  3395    Hugepagesize:       2048 kB
  3396    Hugetlb:               0 kB
  3397
  3398    ### virtual memory:
  3399
  3400    vm.admin_reserve_kbytes = 8192
  3401    vm.compaction_proactiveness = 20
  3402    vm.compact_unevictable_allowed = 1
  3403    vm.dirty_background_bytes = 0
  3404    vm.dirty_background_ratio = 10
  3405    vm.dirty_bytes = 0
  3406    vm.dirty_expire_centisecs = 3000
  3407    vm.dirty_ratio = 20
  3408    vm.dirtytime_expire_seconds = 43200
  3409    vm.dirty_writeback_centisecs = 500
  3410    vm.extfrag_threshold = 500
  3411    vm.hugetlb_optimize_vmemmap = 0
  3412    vm.hugetlb_shm_group = 0
  3413    vm.laptop_mode = 0
  3414    vm.legacy_va_layout = 0
  3415    vm.lowmem_reserve_ratio = 256    256    32    0
  3416    vm.max_map_count = 65530
  3417    vm.min_free_kbytes = 22528
  3418    vm.min_slab_ratio = 5
  3419    vm.min_unmapped_ratio = 1
  3420    vm.mmap_min_addr = 4096
  3421    vm.mmap_rnd_bits = 18
  3422    vm.mmap_rnd_compat_bits = 11
  3423    vm.nr_hugepages = 0
  3424    vm.nr_hugepages_mempolicy = 0
  3425    vm.nr_overcommit_hugepages = 0
  3426    vm.numa_stat = 1
  3427    vm.numa_zonelist_order = Node
  3428    vm.oom_dump_tasks = 1
  3429    vm.oom_kill_allocating_task = 0
  3430    vm.overcommit_kbytes = 0
  3431    vm.overcommit_memory = 0
  3432    vm.overcommit_ratio = 50
  3433    vm.page-cluster = 0
  3434    vm.page_lock_unfairness = 5
  3435    vm.panic_on_oom = 0
  3436    vm.percpu_pagelist_high_fraction = 0
  3437    vm.stat_interval = 1
  3438    vm.swappiness = 100
  3439    vm.user_reserve_kbytes = 125902
  3440    vm.vfs_cache_pressure = 100
  3441    vm.watermark_boost_factor = 15000
  3442    vm.watermark_scale_factor = 10
  3443    vm.zone_reclaim_mode = 0
  3444
  3445    ### ip addr:
  3446
  3447    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  3448        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  3449        inet XXX.XXX.0.1/8 scope host lo
  3450           valid_lft forever preferred_lft forever
  3451        inet6 ::1/128 scope host
  3452           valid_lft forever preferred_lft forever
  3453    2: end1: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  3454        link/ether 52:d1:50:3d:d5:78 brd ff:ff:ff:ff:ff:ff
  3455    3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  3456        link/ether 20:02:af:49:e2:d5 brd ff:ff:ff:ff:ff:ff
  3457
  3458    ### partitions:
  3459
  3460    major minor  #blocks  name
  3461
  3462     179        0   15558144 mmcblk0
  3463     179        1   15384576 mmcblk0p1
  3464     179       32   61071360 mmcblk2
  3465     179       64       4096 mmcblk2boot0
  3466     179       96       4096 mmcblk2boot1
  3467     252        0    2034924 zram0
  3468     252        1      51200 zram1
  3469
  3470    ### df:
  3471
  3472    udev            1.9G     0  1.9G   0% /dev
  3473    tmpfs           398M  5.8M  392M   2% /run
  3474    /dev/mmcblk0p1   15G  1.5G   13G  11% /
  3475    tmpfs           2.0G     0  2.0G   0% /dev/shm
  3476    tmpfs           5.0M     0  5.0M   0% /run/lock
  3477    tmpfs           2.0G     0  2.0G   0% /tmp
  3478    /dev/zram1       47M  1.6M   42M   4% /var/log
  3479
  3480    ### lsblk:
  3481
  3482    NAME         FSTYPE  SIZE MOUNTPOINT UUID
  3483    mmcblk0             14.8G
  3484    └─mmcblk0p1  ext4   14.7G /          2eb1e931-b16f-46a3-8b3b-f0a92acc8ddb
  3485    mmcblk2             58.2G
  3486    mmcblk2boot0           4M
  3487    mmcblk2boot1           4M
  3488    zram1                 50M /var/log
  3489    zram2                  0B
  3490
  3491    ### zramctl:
  3492
  3493    NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
  3494    /dev/zram1 zstd           50M  1.4M  266K  624K       4 /var/log
  3495    /dev/zram0 lzo-rle       1.9G    4K   74B   12K       4 [SWAP]
  3496
  3497    ### mtab:
  3498
  3499    /dev/mmcblk0p1 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0
  3500    /dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0
  3501    /dev/zram1 /var/log ext4 rw,relatime,discard 0 0
  3502
  3503    ### mmc0:8dfc info:
  3504
  3505                   fwrev: 0x0
  3506                  uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SU16G MODALIAS=mmc:block
  3507                     cid: 03534453553136478060b5bf4000a609
  3508                     rca: 0x8dfc
  3509                     csd: 400e00325b59000076b27f800a404013
  3510                  manfid: 0x000003
  3511                     ocr: 0x00300000
  3512    preferred_erase_size: 4194304
  3513                    type: SD
  3514                   hwrev: 0x8
  3515                    date: 06/2010
  3516                     dsr: 0x404
  3517              erase_size: 512
  3518                   oemid: 0x5344
  3519                  serial: 0x60b5bf40
  3520                     ssr: 0000000004000000010190000b050000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  3521                     scr: 0235800000000000
  3522                    name: SU16G
  3523
  3524    ### mmc2:0001 info:
  3525
  3526                   fwrev: 0x0500000000000000
  3527                  uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=CKTM4R MODALIAS=mmc:block
  3528                     cid: 150100434b544d345202a448f479c3a1
  3529             rel_sectors: 0x1
  3530    enhanced_rpmb_supported: 0x1
  3531                     rca: 0x0001
  3532            pre_eol_info: 0x01
  3533                     csd: d02701320f5903fff6dbffef8e40400d
  3534                  manfid: 0x000015
  3535                     ocr: 0x00300000
  3536    preferred_erase_size: 4194304
  3537    enhanced_area_offset: 18446744073709551594
  3538      raw_rpmb_size_mult: 0x20
  3539                    type: MMC
  3540                   hwrev: 0x0
  3541                    date: 12/2016
  3542                     prv: 0x2
  3543             ffu_capable: 1
  3544                     dsr: 0x404
  3545              erase_size: 524288
  3546               life_time: 0x01 0x01
  3547      enhanced_area_size: 4294967274
  3548                   oemid: 0x0100
  3549                  serial: 0xa448f479
  3550                 cmdq_en: 0
  3551                     rev: 0x8
  3552                    name: CKTM4R
  3553
  3554    ### Boot system health:
  3555
  3556    Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU  C.St.
  3557    21:11:49: 1008MHz  2.39  51%  24%  13%   0%  13%   0% 63.3 °C  0/3
  3558    21:11:50:  816MHz  2.68  83%  22%  22%   0%  37%   0% 61.7 °C  0/3
  3559    21:11:50:  816MHz  2.68  67%  12%   9%   0%  44%   0% 60.8 °C  0/3
  3560    21:11:50: 1008MHz  2.68  55%  10%   4%   0%  40%   0% 60.8 °C  0/3
  3561    21:11:51:  816MHz  2.68  66%  14%   8%   1%  41%   0% 61.2 °C  0/3
  3562
  3563    ### Activated 1 lzo-rle zram swap devices with 1987MB each.
  3564    ### Activated Armbian ramlog partition with zstd compression
  3565
  3566    ### Activated 1 lzo-rle zram swap devices with 1987MB each.
  3567    ### Activated Armbian ramlog partition with zstd compression
  3568
  3569    Sun Feb 12 09:17:10 PM MSK 2023 | RK3318 Box | 23.02.0-trunk | arm64 | aarch64 | 6.1.11-rockchip64
  3570
  3571    ### dmesg:
  3572
  3573    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
  3574    [    0.000000] Linux version 6.1.11-rockchip64 (root@7284a09ced08) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #trunk.0248 SMP PREEMPT Fri Feb 10 05:25:40 UTC 2023
  3575    [    0.000000] Machine model: Rockchip RK3318 BOX
  3576    [    0.000000] efi: UEFI not found.
  3577    [    0.000000] NUMA: No NUMA configuration found
  3578    [    0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x00000000feffffff]
  3579    [    0.000000] NUMA: NODE_DATA [mem 0xfe7b1a80-0xfe7b3fff]
  3580    [    0.000000] Zone ranges:
  3581    [    0.000000]   DMA      [mem 0x0000000000200000-0x00000000feffffff]
  3582    [    0.000000]   DMA32    empty
  3583    [    0.000000]   Normal   empty
  3584    [    0.000000] Movable zone start for each node
  3585    [    0.000000] Early memory node ranges
  3586    [    0.000000]   node   0: [mem 0x0000000000200000-0x00000000feffffff]
  3587    [    0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000000feffffff]
  3588    [    0.000000] On node 0, zone DMA: 512 pages in unavailable ranges
  3589    [    0.000000] On node 0, zone DMA: 4096 pages in unavailable ranges
  3590    [    0.000000] cma: Reserved 128 MiB at 0x00000000f2600000
  3591    [    0.000000] psci: probing for conduit method from DT.
  3592    [    0.000000] psci: PSCIv1.1 detected in firmware.
  3593    [    0.000000] psci: Using standard PSCI v0.2 function IDs
  3594    [    0.000000] psci: MIGRATE_INFO_TYPE not supported.
  3595    [    0.000000] psci: SMC Calling Convention v1.2
  3596    [    0.000000] percpu: Embedded 30 pages/cpu s82472 r8192 d32216 u122880
  3597    [    0.000000] pcpu-alloc: s82472 r8192 d32216 u122880 alloc=30*4096
  3598    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
  3599    [    0.000000] Detected VIPT I-cache on CPU0
  3600    [    0.000000] CPU features: detected: ARM erratum 845719
  3601    [    0.000000] alternatives: applying boot alternatives
  3602    [    0.000000] Fallback order for Node 0: 0
  3603    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1027656
  3604    [    0.000000] Policy zone: DMA
  3605    [    0.000000] Kernel command line: root=UUID=2eb1e931-b16f-46a3-8b3b-f0a92acc8ddb rootwait rootfstype=ext4 splash=verbose console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart=8635553d-01 usb-storage.quirks=   cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
  3606    [    0.000000] The swapaccount= commandline option is deprecated. Please report your usecase to linux-mm@kvack.org if you depend on this functionality.
  3607    [    0.000000] Unknown kernel command line parameters "splash=verbose ubootpart=8635553d-01 cgroup_enable=memory cgroup_memory=1", will be passed to user space.
  3608    [    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
  3609    [    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
  3610    [    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
  3611    [    0.000000] Memory: 3913516K/4175872K available (16448K kernel code, 2240K rwdata, 5832K rodata, 3968K init, 585K bss, 131284K reserved, 131072K cma-reserved)
  3612    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
  3613    [    0.000000] trace event string verifier disabled
  3614    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
  3615    [    0.000000] rcu:     RCU event tracing is enabled.
  3616    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
  3617    [    0.000000]     Trampoline variant of Tasks RCU enabled.
  3618    [    0.000000]     Tracing variant of Tasks RCU enabled.
  3619    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
  3620    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
  3621    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
  3622    [    0.000000] Root IRQ handler: gic_handle_irq
  3623    [    0.000000] GIC: Using split EOI/Deactivate mode
  3624    [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
  3625    [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
  3626    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  3627    [    0.000001] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  3628    [    0.001091] Console: colour dummy device 80x25
  3629    [    0.001172] printk: console [tty1] enabled
  3630    [    0.001292] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
  3631    [    0.001319] pid_max: default: 32768 minimum: 301
  3632    [    0.001466] LSM: Security Framework initializing
  3633    [    0.001516] Yama: becoming mindful.
  3634    [    0.001689] AppArmor: AppArmor initialized
  3635    [    0.001738] Stack Depot allocating hash table of 262144 entries with kvcalloc
  3636    [    0.002392] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
  3637    [    0.002432] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
  3638    [    0.005751] cblist_init_generic: Setting adjustable number of callback queues.
  3639    [    0.005778] cblist_init_generic: Setting shift to 2 and lim to 1.
  3640    [    0.005977] cblist_init_generic: Setting shift to 2 and lim to 1.
  3641    [    0.006419] rcu: Hierarchical SRCU implementation.
  3642    [    0.006429] rcu:     Max phase no-delay instances is 1000.
  3643    [    0.010038] EFI services will not be available.
  3644    [    0.010762] smp: Bringing up secondary CPUs ...
  3645    [    0.012016] Detected VIPT I-cache on CPU1
  3646    [    0.012210] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
  3647    [    0.013554] Detected VIPT I-cache on CPU2
  3648    [    0.013744] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
  3649    [    0.015081] Detected VIPT I-cache on CPU3
  3650    [    0.015279] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
  3651    [    0.015486] smp: Brought up 1 node, 4 CPUs
  3652    [    0.015515] SMP: Total of 4 processors activated.
  3653    [    0.015530] CPU features: detected: 32-bit EL0 Support
  3654    [    0.015538] CPU features: detected: 32-bit EL1 Support
  3655    [    0.015550] CPU features: detected: CRC32 instructions
  3656    [    0.015680] CPU: All CPU(s) started at EL2
  3657    [    0.015701] alternatives: applying system-wide alternatives
  3658    [    0.019332] devtmpfs: initialized
  3659    [    0.043087] Registered cp15_barrier emulation handler
  3660    [    0.043120] Registered setend emulation handler
  3661    [    0.043590] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  3662    [    0.043641] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
  3663    [    0.049234] pinctrl core: initialized pinctrl subsystem
  3664    [    0.050551] DMI not present or invalid.
  3665    [    0.051782] NET: Registered PF_NETLINK/PF_ROUTE protocol family
  3666    [    0.054863] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
  3667    [    0.056304] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
  3668    [    0.057567] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
  3669    [    0.057693] audit: initializing netlink subsys (disabled)
  3670    [    0.058083] audit: type=2000 audit(0.056:1): state=initialized audit_enabled=0 res=1
  3671    [    0.059566] thermal_sys: Registered thermal governor 'fair_share'
  3672    [    0.059580] thermal_sys: Registered thermal governor 'bang_bang'
  3673    [    0.059591] thermal_sys: Registered thermal governor 'step_wise'
  3674    [    0.059600] thermal_sys: Registered thermal governor 'user_space'
  3675    [    0.059719] cpuidle: using governor menu
  3676    [    0.060338] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  3677    [    0.060559] ASID allocator initialised with 65536 entries
  3678    [    0.062525] Serial: AMBA PL011 UART driver
  3679    [    0.081459] platform ff3c0000.hdmi: Fixing up cyclic dependency with ff370000.vop
  3680    [    0.108002] rockchip-gpio ff210000.gpio: probed /pinctrl/gpio@ff210000
  3681    [    0.109436] rockchip-gpio ff220000.gpio: probed /pinctrl/gpio@ff220000
  3682    [    0.110689] rockchip-gpio ff230000.gpio: probed /pinctrl/gpio@ff230000
  3683    [    0.111996] rockchip-gpio ff240000.gpio: probed /pinctrl/gpio@ff240000
  3684    [    0.150677] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
  3685    [    0.150701] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
  3686    [    0.150717] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
  3687    [    0.150728] HugeTLB: 508 KiB vmemmap can be freed for a 32.0 MiB page
  3688    [    0.150741] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
  3689    [    0.150751] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
  3690    [    0.150764] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
  3691    [    0.150775] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
  3692    [    0.152633] cryptd: max_cpu_qlen set to 1000
  3693    [    0.219368] raid6: neonx8   gen()  1038 MB/s
  3694    [    0.287564] raid6: neonx4   gen()  1062 MB/s
  3695    [    0.355804] raid6: neonx2   gen()   985 MB/s
  3696    [    0.423924] raid6: neonx1   gen()   879 MB/s
  3697    [    0.492069] raid6: int64x8  gen()   744 MB/s
  3698    [    0.560231] raid6: int64x4  gen()   825 MB/s
  3699    [    0.628375] raid6: int64x2  gen()   707 MB/s
  3700    [    0.696550] raid6: int64x1  gen()   525 MB/s
  3701    [    0.696567] raid6: using algorithm neonx4 gen() 1062 MB/s
  3702    [    0.764666] raid6: .... xor() 769 MB/s, rmw enabled
  3703    [    0.764679] raid6: using neon recovery algorithm
  3704    [    0.771612] iommu: Default domain type: Translated
  3705    [    0.771632] iommu: DMA domain TLB invalidation policy: strict mode
  3706    [    0.772510] SCSI subsystem initialized
  3707    [    0.772883] libata version 3.00 loaded.
  3708    [    0.773469] usbcore: registered new interface driver usbfs
  3709    [    0.773576] usbcore: registered new interface driver hub
  3710    [    0.773669] usbcore: registered new device driver usb
  3711    [    0.774711] pps_core: LinuxPPS API ver. 1 registered
  3712    [    0.774723] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  3713    [    0.774755] PTP clock support registered
  3714    [    0.775149] EDAC MC: Ver: 3.0.0
  3715    [    0.778092] NetLabel: Initializing
  3716    [    0.778111] NetLabel:  domain hash size = 128
  3717    [    0.778122] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
  3718    [    0.778250] NetLabel:  unlabeled traffic allowed by default
  3719    [    0.778570] vgaarb: loaded
  3720    [    0.779529] clocksource: Switched to clocksource arch_sys_counter
  3721    [    0.780373] VFS: Disk quotas dquot_6.6.0
  3722    [    0.780487] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  3723    [    0.782103] AppArmor: AppArmor Filesystem Enabled
  3724    [    0.799481] NET: Registered PF_INET protocol family
  3725    [    0.800014] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
  3726    [    0.806402] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
  3727    [    0.806659] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
  3728    [    0.806764] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
  3729    [    0.807447] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
  3730    [    0.808875] TCP: Hash tables configured (established 32768 bind 32768)
  3731    [    0.809134] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
  3732    [    0.809318] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
  3733    [    0.809816] NET: Registered PF_UNIX/PF_LOCAL protocol family
  3734    [    0.809879] NET: Registered PF_XDP protocol family
  3735    [    0.809899] PCI: CLS 0 bytes, default 64
  3736    [    0.810788] Trying to unpack rootfs image as initramfs...
  3737    [    0.821155] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
  3738    [    0.822290] kvm [1]: IPA Size Limit: 40 bits
  3739    [    0.824759] kvm [1]: vgic interrupt IRQ9
  3740    [    0.825029] kvm [1]: Hyp mode initialized successfully
  3741    [    0.829165] Initialise system trusted keyrings
  3742    [    0.829264] Key type blacklist registered
  3743    [    0.829711] workingset: timestamp_bits=44 max_order=20 bucket_order=0
  3744    [    0.844181] zbud: loaded
  3745    [    0.847773] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  3746    [    0.849349] fuse: init (API version 7.37)
  3747    [    0.854213] integrity: Platform Keyring initialized
  3748    [    0.925577] xor: measuring software checksum speed
  3749    [    0.933716]    8regs           :  1221 MB/sec
  3750    [    0.941609]    32regs          :  1261 MB/sec
  3751    [    0.950888]    arm64_neon      :  1070 MB/sec
  3752    [    0.950911] xor: using function: 32regs (1261 MB/sec)
  3753    [    0.950933] Key type asymmetric registered
  3754    [    0.950946] Asymmetric key parser 'x509' registered
  3755    [    2.898095] Freeing initrd memory: 21288K
  3756    [    2.942146] alg: self-tests for CTR-KDF (hmac(sha256)) passed
  3757    [    2.942303] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
  3758    [    2.942575] io scheduler mq-deadline registered
  3759    [    2.942591] io scheduler kyber registered
  3760    [    2.943034] io scheduler bfq registered
  3761    [    2.961762] dma-pl330 ff1f0000.dma-controller: Loaded driver for PL330 DMAC-241330
  3762    [    2.961793] dma-pl330 ff1f0000.dma-controller:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
  3763    [    2.970443] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
  3764    [    2.976293] ff110000.serial: ttyS0 at MMIO 0xff110000 (irq = 25, base_baud = 1500000) is a 16550A
  3765    [    2.978230] ff130000.serial: ttyS2 at MMIO 0xff130000 (irq = 26, base_baud = 1500000) is a 16550A
  3766    [    2.978668] printk: console [ttyS2] enabled
  3767    [    2.980709] Serial: AMBA driver
  3768    [    2.989396] rockchip-vop ff370000.vop: Adding to iommu group 4
  3769    [    3.015315] loop: module loaded
  3770    [    3.024054] tun: Universal TUN/TAP device driver, 1.6
  3771    [    3.025874] thunder_xcv, ver 1.0
  3772    [    3.025969] thunder_bgx, ver 1.0
  3773    [    3.026054] nicpf, ver 1.0
  3774    [    3.027392] e1000e: Intel(R) PRO/1000 Network Driver
  3775    [    3.027403] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
  3776    [    3.027551] igb: Intel(R) Gigabit Ethernet Network Driver
  3777    [    3.027565] igb: Copyright (c) 2007-2014 Intel Corporation.
  3778    [    3.027655] igbvf: Intel(R) Gigabit Virtual Function Network Driver
  3779    [    3.027667] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
  3780    [    3.028139] sky2: driver version 1.30
  3781    [    3.029289] VFIO - User Level meta-driver version: 0.3
  3782    [    3.033153] dwc2 ff580000.usb: supply vusb_d not found, using dummy regulator
  3783    [    3.033489] dwc2 ff580000.usb: supply vusb_a not found, using dummy regulator
  3784    [    3.046568] dwc2 ff580000.usb: DWC OTG Controller
  3785    [    3.046624] dwc2 ff580000.usb: new USB bus registered, assigned bus number 1
  3786    [    3.046687] dwc2 ff580000.usb: irq 34, io mem 0xff580000
  3787    [    3.047055] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
  3788    [    3.047082] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  3789    [    3.047102] usb usb1: Product: DWC OTG Controller
  3790    [    3.047120] usb usb1: Manufacturer: Linux 6.1.11-rockchip64 dwc2_hsotg
  3791    [    3.047138] usb usb1: SerialNumber: ff580000.usb
  3792    [    3.048328] hub 1-0:1.0: USB hub found
  3793    [    3.048401] hub 1-0:1.0: 1 port detected
  3794    [    3.052787] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  3795    [    3.052838] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
  3796    [    3.053105] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
  3797    [    3.053231] xhci-hcd xhci-hcd.0.auto: irq 33, io mem 0xff600000
  3798    [    3.053737] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  3799    [    3.053769] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 3
  3800    [    3.053801] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
  3801    [    3.053859] ehci-platform ff5c0000.usb: EHCI Host Controller
  3802    [    3.053882] ohci-platform ff5d0000.usb: Generic Platform OHCI controller
  3803    [    3.054162] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
  3804    [    3.054186] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  3805    [    3.054206] usb usb2: Product: xHCI Host Controller
  3806    [    3.054224] usb usb2: Manufacturer: Linux 6.1.11-rockchip64 xhci-hcd
  3807    [    3.054242] usb usb2: SerialNumber: xhci-hcd.0.auto
  3808    [    3.055339] hub 2-0:1.0: USB hub found
  3809    [    3.055416] hub 2-0:1.0: 1 port detected
  3810    [    3.056442] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
  3811    [    3.056708] usb usb3: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
  3812    [    3.056735] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  3813    [    3.056755] usb usb3: Product: xHCI Host Controller
  3814    [    3.056773] usb usb3: Manufacturer: Linux 6.1.11-rockchip64 xhci-hcd
  3815    [    3.056790] usb usb3: SerialNumber: xhci-hcd.0.auto
  3816    [    3.057869] hub 3-0:1.0: USB hub found
  3817    [    3.057941] hub 3-0:1.0: 1 port detected
  3818    [    3.058652] ehci-platform ff5c0000.usb: new USB bus registered, assigned bus number 4
  3819    [    3.058675] ohci-platform ff5d0000.usb: new USB bus registered, assigned bus number 5
  3820    [    3.058861] usbcore: registered new interface driver usb-storage
  3821    [    3.058890] ehci-platform ff5c0000.usb: irq 35, io mem 0xff5c0000
  3822    [    3.058937] ohci-platform ff5d0000.usb: irq 36, io mem 0xff5d0000
  3823    [    3.062413] mousedev: PS/2 mouse device common for all mice
  3824    [    3.064093] i2c_dev: i2c /dev entries driver
  3825    [    3.068869] dw_wdt ff1a0000.watchdog: No valid TOPs array specified
  3826    [    3.071587] ehci-platform ff5c0000.usb: USB 2.0 started, EHCI 1.00
  3827    [    3.072223] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
  3828    [    3.072256] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  3829    [    3.072274] usb usb4: Product: EHCI Host Controller
  3830    [    3.072289] usb usb4: Manufacturer: Linux 6.1.11-rockchip64 ehci_hcd
  3831    [    3.072304] usb usb4: SerialNumber: ff5c0000.usb
  3832    [    3.072607] sdhci: Secure Digital Host Controller Interface driver
  3833    [    3.072621] sdhci: Copyright(c) Pierre Ossman
  3834    [    3.072679] Synopsys Designware Multimedia Card Interface Driver
  3835    [    3.073359] hub 4-0:1.0: USB hub found
  3836    [    3.073457] hub 4-0:1.0: 1 port detected
  3837    [    3.074382] sdhci-pltfm: SDHCI platform and OF driver helper
  3838    [    3.075607] dwmmc_rockchip ff500000.mmc: IDMAC supports 32-bit address mode.
  3839    [    3.075662] dwmmc_rockchip ff520000.mmc: IDMAC supports 32-bit address mode.
  3840    [    3.075670] dwmmc_rockchip ff500000.mmc: Using internal DMA controller.
  3841    [    3.075691] dwmmc_rockchip ff500000.mmc: Version ID is 270a
  3842    [    3.075716] dwmmc_rockchip ff520000.mmc: Using internal DMA controller.
  3843    [    3.075736] dwmmc_rockchip ff520000.mmc: Version ID is 270a
  3844    [    3.075797] dwmmc_rockchip ff5f0000.mmc: IDMAC supports 32-bit address mode.
  3845    [    3.075795] dwmmc_rockchip ff500000.mmc: DW MMC controller at irq 40,32 bit host data width,256 deep fifo
  3846    [    3.075839] dwmmc_rockchip ff5f0000.mmc: Using internal DMA controller.
  3847    [    3.075840] dwmmc_rockchip ff520000.mmc: DW MMC controller at irq 39,32 bit host data width,256 deep fifo
  3848    [    3.075859] dwmmc_rockchip ff5f0000.mmc: Version ID is 270a
  3849    [    3.075937] dwmmc_rockchip ff5f0000.mmc: DW MMC controller at irq 41,32 bit host data width,256 deep fifo
  3850    [    3.076396] dwmmc_rockchip ff5f0000.mmc: allocated mmc-pwrseq
  3851    [    3.076421] mmc_host mmc4: card is non-removable.
  3852    [    3.076493] dwmmc_rockchip ff500000.mmc: Got CD GPIO
  3853    [    3.076806] mmc_host mmc2: card is non-removable.
  3854    [    3.078704] ledtrig-cpu: registered to indicate activity on CPUs
  3855    [    3.079905] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
  3856    [    3.080392] hid: raw HID events driver (C) Jiri Kosina
  3857    [    3.080647] usbcore: registered new interface driver usbhid
  3858    [    3.080664] usbhid: USB HID core driver
  3859    [    3.087663] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
  3860    [    3.089031] drop_monitor: Initializing network drop monitor service
  3861    [    3.089298] mmc_host mmc4: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
  3862    [    3.089624] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
  3863    [    3.090396] NET: Registered PF_INET6 protocol family
  3864    [    3.119985] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.01
  3865    [    3.120024] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  3866    [    3.120042] usb usb5: Product: Generic Platform OHCI controller
  3867    [    3.120058] usb usb5: Manufacturer: Linux 6.1.11-rockchip64 ohci_hcd
  3868    [    3.120074] usb usb5: SerialNumber: ff5d0000.usb
  3869    [    3.121176] hub 5-0:1.0: USB hub found
  3870    [    3.121254] hub 5-0:1.0: 1 port detected
  3871    [    3.135283] Segment Routing with IPv6
  3872    [    3.135400] In-situ OAM (IOAM) with IPv6
  3873    [    3.135676] NET: Registered PF_PACKET protocol family
  3874    [    3.135981] 8021q: 802.1Q VLAN Support v1.8
  3875    [    3.136096] Key type dns_resolver registered
  3876    [    3.138425] registered taskstats version 1
  3877    [    3.138474] Loading compiled-in X.509 certificates
  3878    [    3.145097] Loaded X.509 cert 'Build time autogenerated kernel key: e25f7f61aa13aedd90bace25454c8646dc5da469'
  3879    [    3.146239] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
  3880    [    3.146403] mmc0: new high speed SDHC card at address 8dfc
  3881    [    3.149561] zswap: loaded using pool zstd/z3fold
  3882    [    3.149786] mmcblk0: mmc0:8dfc SU16G 14.8 GiB
  3883    [    3.151196] Key type .fscrypt registered
  3884    [    3.151217] Key type fscrypt-provisioning registered
  3885    [    3.154706] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=yes
  3886    [    3.155303] Key type encrypted registered
  3887    [    3.155344] AppArmor: AppArmor sha1 policy hashing enabled
  3888    [    3.158404]  mmcblk0: p1
  3889    [    3.186677] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 52000000Hz, actual 50000000HZ div = 0)
  3890    [    3.187117] mmc2: new high speed MMC card at address 0001
  3891    [    3.188828] mmcblk2: mmc2:0001 CKTM4R 58.2 GiB
  3892    [    3.194622] mmcblk2boot0: mmc2:0001 CKTM4R 4.00 MiB
  3893    [    3.198878] mmcblk2boot1: mmc2:0001 CKTM4R 4.00 MiB
  3894    [    3.202805] mmcblk2rpmb: mmc2:0001 CKTM4R 4.00 MiB, chardev (242:0)
  3895    [    3.210489] mmc_host mmc4: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
  3896    [    3.214496] mmc4: new high speed SDIO card at address 0001
  3897    [    3.249322] rockchip-drm display-subsystem: bound ff370000.vop (ops vop_component_ops)
  3898    [    3.249502] dwhdmi-rockchip ff3c0000.hdmi: supply avdd-0v9 not found, using dummy regulator
  3899    [    3.249885] dwhdmi-rockchip ff3c0000.hdmi: supply avdd-1v8 not found, using dummy regulator
  3900    [    3.250458] dwhdmi-rockchip ff3c0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (inno_dw_hdmi_phy2)
  3901    [    3.251775] dwhdmi-rockchip ff3c0000.hdmi: registered DesignWare HDMI I2C bus driver
  3902    [    3.252703] rockchip-drm display-subsystem: bound ff3c0000.hdmi (ops dw_hdmi_rockchip_ops)
  3903    [    3.254017] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 0
  3904    [    3.254144] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
  3905    [    3.254579] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
  3906    [    3.254623] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
  3907    [    3.255180] WCN: marlin_init entry!
  3908    [    3.256316] of_cfs_init
  3909    [    3.256395] of_cfs_init: OK
  3910    [    3.259658] Freeing unused kernel memory: 3968K
  3911    [    3.283718] Run /init as init process
  3912    [    3.283740]   with arguments:
  3913    [    3.283752]     /init
  3914    [    3.283765]   with environment:
  3915    [    3.283777]     HOME=/
  3916    [    3.283788]     TERM=linux
  3917    [    3.283800]     splash=verbose
  3918    [    3.283813]     ubootpart=8635553d-01
  3919    [    3.283824]     cgroup_enable=memory
  3920    [    3.283837]     cgroup_memory=1
  3921    [    4.340847] input: adc-keys as /devices/platform/adc-keys/input/input0
  3922    [    4.368299] gpio-syscon ff100000.syscon:gpio: can't read the data register offset!
  3923    [    4.492215] lima ff300000.gpu: gp - mali450 version major 0 minor 0
  3924    [    4.492502] lima ff300000.gpu: pp0 - mali450 version major 0 minor 0
  3925    [    4.492755] lima ff300000.gpu: pp1 - mali450 version major 0 minor 0
  3926    [    4.492888] lima ff300000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
  3927    [    4.492914] lima ff300000.gpu: l2 cache 64K, 4-way, 64byte cache line, 128bit external bus
  3928    [    4.733247] rk_gmac-dwmac ff550000.ethernet: IRQ eth_wake_irq not found
  3929    [    4.733280] rk_gmac-dwmac ff550000.ethernet: IRQ eth_lpi not found
  3930    [    4.733549] rk_gmac-dwmac ff550000.ethernet: PTP uses main clock
  3931    [    4.735206] lima ff300000.gpu: bus rate = 491520000
  3932    [    4.735242] lima ff300000.gpu: mod rate = 491520000
  3933    [    4.738345] rk_gmac-dwmac ff550000.ethernet: clock input or output? (output).
  3934    [    4.738387] rk_gmac-dwmac ff550000.ethernet: TX delay(0x30).
  3935    [    4.738407] rk_gmac-dwmac ff550000.ethernet: RX delay(0x10).
  3936    [    4.738780] rk_gmac-dwmac ff550000.ethernet: integrated PHY? (yes).
  3937    [    4.738939] rk_gmac-dwmac ff550000.ethernet: cannot get clock clk_mac_refout
  3938    [    4.738962] rk_gmac-dwmac ff550000.ethernet: cannot get clock clk_mac_speed
  3939    [    4.739736] [drm] Initialized lima 1.1.0 20191231 for ff300000.gpu on minor 1
  3940    [    4.744041] rk_gmac-dwmac ff550000.ethernet: init for RMII
  3941    [    4.783964] rk_gmac-dwmac ff550000.ethernet: User ID: 0x10, Synopsys ID: 0x35
  3942    [    4.784005] rk_gmac-dwmac ff550000.ethernet:     DWMAC1000
  3943    [    4.784024] rk_gmac-dwmac ff550000.ethernet: DMA HW capability register supported
  3944    [    4.784041] rk_gmac-dwmac ff550000.ethernet: RX Checksum Offload Engine supported
  3945    [    4.784055] rk_gmac-dwmac ff550000.ethernet: COE Type 2
  3946    [    4.784070] rk_gmac-dwmac ff550000.ethernet: TX Checksum insertion supported
  3947    [    4.784084] rk_gmac-dwmac ff550000.ethernet: Wake-Up On Lan supported
  3948    [    4.784272] rk_gmac-dwmac ff550000.ethernet: Normal descriptors
  3949    [    4.784290] rk_gmac-dwmac ff550000.ethernet: Ring mode enabled
  3950    [    4.784303] rk_gmac-dwmac ff550000.ethernet: Enable RX Mitigation via HW Watchdog Timer
  3951    [    4.820136] rk_gmac-dwmac ff550000.ethernet end1: renamed from eth0
  3952    [    4.961430] dw-apb-uart ff130000.serial: forbid DMA for kernel console
  3953    [    5.744239] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Quota mode: none.
  3954    [    7.837989] systemd[1]: System time before build time, advancing clock.
  3955    [    7.917596] systemd[1]: Inserted module 'autofs4'
  3956    [    8.079341] systemd[1]: systemd 252.5-2 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
  3957    [    8.079405] systemd[1]: Detected architecture arm64.
  3958    [    8.103435] systemd[1]: Hostname set to <rk3318-box>.
  3959    [    9.473747] systemd[325]: /usr/lib/systemd/system-generators/netplan failed with exit status 1.
  3960    [   10.797487] systemd[1]: Queued start job for default target graphical.target.
  3961    [   10.829502] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
  3962    [   10.834186] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
  3963    [   10.838605] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
  3964    [   10.841904] systemd[1]: Created slice user.slice - User and Session Slice.
  3965    [   10.843012] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
  3966    [   10.845239] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
  3967    [   10.845980] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
  3968    [   10.846611] systemd[1]: Reached target remote-fs.target - Remote File Systems.
  3969    [   10.846963] systemd[1]: Reached target slices.target - Slice Units.
  3970    [   10.847406] systemd[1]: Reached target swap.target - Swaps.
  3971    [   10.847926] systemd[1]: Reached target time-set.target - System Time Set.
  3972    [   10.848717] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
  3973    [   10.854356] systemd[1]: Listening on syslog.socket - Syslog Socket.
  3974    [   10.856069] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
  3975    [   10.857094] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
  3976    [   10.859085] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
  3977    [   10.860820] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
  3978    [   10.862974] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
  3979    [   10.874504] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
  3980    [   10.876263] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
  3981    [   10.908216] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
  3982    [   10.917769] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
  3983    [   10.927687] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
  3984    [   10.937931] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
  3985    [   10.954608] systemd[1]: Starting fake-hwclock.service - Restore / save the current clock...
  3986    [   10.965214] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
  3987    [   10.976345] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
  3988    [   10.987732] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
  3989    [   10.999128] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
  3990    [   11.012656] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
  3991    [   11.023902] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
  3992    [   11.025511] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
  3993    [   11.054400] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
  3994    [   11.065162] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
  3995    [   11.066378] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
  3996    [   11.076600] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
  3997    [   11.095726] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
  3998    [   11.098968] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
  3999    [   11.102870] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
  4000    [   11.106343] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
  4001    [   11.110580] systemd[1]: Finished fake-hwclock.service - Restore / save the current clock.
  4002    [   11.115429] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
  4003    [   11.121278] systemd[1]: modprobe@configfs.service: Deactivated successfully.
  4004    [   11.123218] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
  4005    [   11.128275] systemd[1]: modprobe@drm.service: Deactivated successfully.
  4006    [   11.130253] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
  4007    [   11.134552] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
  4008    [   11.136659] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
  4009    [   11.141103] systemd[1]: modprobe@fuse.service: Deactivated successfully.
  4010    [   11.143480] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
  4011    [   11.148239] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
  4012    [   11.180828] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
  4013    [   11.191743] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
  4014    [   11.201602] EXT4-fs (mmcblk0p1): re-mounted. Quota mode: none.
  4015    [   11.203229] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables...
  4016    [   11.234125] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
  4017    [   11.238375] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
  4018    [   11.241310] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
  4019    [   11.244967] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
  4020    [   11.280935] systemd[1]: Starting systemd-random-seed.service - Load/Save Random Seed...
  4021    [   11.292131] systemd[1]: Starting systemd-sysusers.service - Create System Users...
  4022    [   11.367058] systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables.
  4023    [   11.442473] systemd[1]: Finished systemd-sysusers.service - Create System Users.
  4024    [   11.477640] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev...
  4025    [   11.689113] systemd[1]: Finished systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev.
  4026    [   11.731822] systemd[1]: Starting systemd-udevd.service - Rule-based Manager for Device Events and Files...
  4027    [   11.735876] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout.
  4028    [   11.738464] systemd[1]: Reached target local-fs-pre.target - Preparation for Local File Systems.
  4029    [   12.128380] systemd[1]: Mounting tmp.mount - /tmp...
  4030    [   12.151065] systemd[1]: Mounted tmp.mount - /tmp.
  4031    [   12.154604] systemd[1]: Reached target local-fs.target - Local File Systems.
  4032    [   12.168766] systemd[1]: Starting armbian-led-state.service - Armbian leds state...
  4033    [   12.185423] systemd[1]: Starting armbian-zram-config.service - Armbian ZRAM config...
  4034    [   12.203097] systemd[1]: Starting console-setup.service - Set console font and keymap...
  4035    [   12.214799] systemd[1]: Starting plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data...
  4036    [   12.293400] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
  4037    [   12.298957] systemd[1]: Finished console-setup.service - Set console font and keymap.
  4038    [   12.320962] systemd[1]: Finished systemd-udev-trigger.service - Coldplug All udev Devices.
  4039    [   12.323418] systemd[1]: Received SIGRTMIN+20 from PID 291 (plymouthd).
  4040    [   12.374218] systemd[1]: Starting ifupdown-pre.service - Helper to synchronize boot up for ifupdown...
  4041    [   12.380370] systemd[1]: Finished plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data.
  4042    [   12.392854] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 389 (systemd-binfmt)
  4043    [   12.403360] systemd[1]: Mounting proc-sys-fs-binfmt_misc.mount - Arbitrary Executable File Formats File System...
  4044    [   12.474805] systemd[1]: Mounted proc-sys-fs-binfmt_misc.mount - Arbitrary Executable File Formats File System.
  4045    [   12.498024] systemd[1]: Finished systemd-binfmt.service - Set Up Additional Binary Formats.
  4046    [   12.502687] systemd[1]: Finished ifupdown-pre.service - Helper to synchronize boot up for ifupdown.
  4047    [   12.591663] systemd[1]: Finished armbian-led-state.service - Armbian leds state.
  4048    [   12.710581] systemd[1]: Started systemd-udevd.service - Rule-based Manager for Device Events and Files.
  4049    [   12.744342] systemd[1]: Starting plymouth-start.service - Show Plymouth Boot Screen...
  4050    [   12.910176] systemd[1]: Started plymouth-start.service - Show Plymouth Boot Screen.
  4051    [   12.912875] systemd[1]: bootsplash-ask-password-console.path - Dispatch Password Requests to Console Directory Watch when bootsplash is active was skipped because of an unmet condition check (ConditionPathExists=/sys/devices/platform/bootsplash.0/enabled).
  4052    [   12.914376] systemd[1]: Started systemd-ask-password-plymouth.path - Forward Password Requests to Plymouth Directory Watch.
  4053    [   12.914953] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
  4054    [   12.915452] systemd[1]: Reached target paths.target - Path Units.
  4055    [   13.035782] systemd[1]: Found device dev-ttyS2.device - /dev/ttyS2.
  4056    [   13.410889] zram: Added device: zram0
  4057    [   13.413520] zram: Added device: zram1
  4058    [   13.748423] zram: Added device: zram2
  4059    [   13.985968] mc: Linux media interface: v0.10
  4060    [   14.112330] zram0: detected capacity change from 0 to 4069848
  4061    [   14.194420] videodev: Linux video capture interface: v2.00
  4062    [   14.451236] rockchip_vdec: module is from the staging directory, the quality is unknown, you have been warned.
  4063    [   14.487496] Registered IR keymap rc-empty
  4064    [   14.488038] rc rc0: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc0
  4065    [   14.488764] rc rc0: lirc_dev: driver gpio_ir_recv registered at minor = 0, raw IR receiver, no transmitter
  4066    [   14.489437] input: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc0/input1
  4067    [   14.508176] rkvdec ff360000.video-codec: Adding to iommu group 3
  4068    [   14.548188] rockchip-rga ff390000.rga: HW Version: 0x04.00
  4069    [   14.556539] rockchip-rga ff390000.rga: Registered rockchip-rga as /dev/video1
  4070    [   14.576185] rk3328-codec ff410000.codec: spk_depop_time use default value.
  4071    [   14.656689] hantro-vpu ff350000.video-codec: Adding to iommu group 2
  4072    [   14.668462] hantro-vpu ff350000.video-codec: registered rockchip,rk3328-vpu-dec as /dev/video2
  4073    [   14.691268] cfg80211: Loading compiled-in X.509 certificates for regulatory database
  4074    [   14.692987] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
  4075    [   14.770172] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
  4076    [   14.818183] systemd[1]: Listening on systemd-rfkill.socket - Load/Save RF Kill Switch Status /dev/rfkill Watch.
  4077    [   14.846371] systemd[1]: Reached target sound.target - Sound Card.
  4078    [   14.875816] brcmfmac: F1 signature read @0x18000000=0x16034334
  4079    [   14.888990] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4334-sdio for chip BCM4334/3
  4080    [   14.889729] usbcore: registered new interface driver brcmfmac
  4081    [   14.892231] brcmfmac mmc4:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.rockchip,rk3318-box.bin failed with error -2
  4082    [   14.923229] brcmfmac mmc4:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.clm_blob failed with error -2
  4083    [   15.067547] random: crng init done
  4084    [   15.104391] systemd[1]: Finished systemd-random-seed.service - Load/Save Random Seed.
  4085    [   15.106081] systemd[1]: first-boot-complete.target - First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes).
  4086    [   15.106343] systemd[1]: systemd-machine-id-commit.service - Commit a transient machine-id on disk was skipped because of an unmet condition check (ConditionPathIsMountPoint=/etc/machine-id).
  4087    [   15.134739] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
  4088    [   15.135173] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4334/3 wl0: Jul 24 2019 12:58:36 version 6.10.191 (TOB) (r) FWID 01-b049404e
  4089    [   15.172608] systemd[1]: Starting systemd-rfkill.service - Load/Save RF Kill Switch Status...
  4090    [   15.241533] Adding 2034920k swap on /dev/zram0.  Priority:5 extents:1 across:2034920k SSFS
  4091    [   15.295240] systemd[1]: Started systemd-rfkill.service - Load/Save RF Kill Switch Status.
  4092    [   15.561633] zram1: detected capacity change from 0 to 102400
  4093    [   15.739756] systemd[1]: Finished armbian-zram-config.service - Armbian ZRAM config.
  4094    [   15.765002] systemd[1]: Starting armbian-ramlog.service - Armbian memory supported logging...
  4095    [   15.882533] EXT4-fs (zram1): mounted filesystem without journal. Quota mode: none.
  4096    [   20.304626] systemd[1]: systemd-rfkill.service: Deactivated successfully.
  4097    [   20.323500] systemd[1]: Finished armbian-ramlog.service - Armbian memory supported logging.
  4098    [   20.376875] systemd[1]: Starting systemd-journald.service - Journal Service...
  4099    [   20.727718] systemd[1]: Started systemd-journald.service - Journal Service.
  4100    [   20.813047] systemd-journald[555]: Received client request to flush runtime journal.
  4101    [   20.834019] systemd-journald[555]: File /var/log/journal/748f963f03bc4ff19142d0aa9df990a2/system.journal corrupted or uncleanly shut down, renaming and replacing.
  4102
  4103    ### armbian-release:
  4104
  4105    # PLEASE DO NOT EDIT THIS FILE
  4106    BOARD=rk3318-box
  4107    BOARD_NAME="RK3318 Box"
  4108    BOARDFAMILY=rockchip64
  4109    BUILD_REPOSITORY_URL=https://github.com/armbian/build
  4110    BUILD_REPOSITORY_COMMIT=313c893
  4111    VERSION=23.02.0-trunk
  4112    LINUXFAMILY=rockchip64
  4113    ARCH=arm64
  4114    IMAGE_TYPE=nightly
  4115    BOARD_TYPE=tvb
  4116    INITRD_ARCH=arm64
  4117    KERNEL_IMAGE_TYPE=Image
  4118
  4119    ### boot environment:
  4120
  4121    verbosity=1
  4122    bootlogo=false
  4123    overlay_prefix=rockchip
  4124    fdtfile=rockchip/rk3318-box.dtb
  4125    rootdev=UUID=2eb1e931-b16f-46a3-8b3b-f0a92acc8ddb
  4126    rootfstype=ext4
  4127    overlays=rk3318-box-led-conf2
  4128
  4129    ### lsusb:
  4130
  4131    Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  4132    Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  4133    Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  4134    Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  4135    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  4136
  4137    ### lscpu:
  4138
  4139    Architecture:                    aarch64
  4140    CPU op-mode(s):                  32-bit, 64-bit
  4141    Byte Order:                      Little Endian
  4142    CPU(s):                          4
  4143    On-line CPU(s) list:             0-3
  4144    Vendor ID:                       ARM
  4145    Model name:                      Cortex-A53
  4146    Model:                           4
  4147    Thread(s) per core:              1
  4148    Core(s) per cluster:             4
  4149    Socket(s):                       -
  4150    Cluster(s):                      1
  4151    Stepping:                        r0p4
  4152    CPU(s) scaling MHz:              100%
  4153    CPU max MHz:                     1008.0000
  4154    CPU min MHz:                     600.0000
  4155    BogoMIPS:                        48.00
  4156    Flags:                           fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4157    NUMA node(s):                    1
  4158    NUMA node0 CPU(s):               0-3
  4159    Vulnerability Itlb multihit:     Not affected
  4160    Vulnerability L1tf:              Not affected
  4161    Vulnerability Mds:               Not affected
  4162    Vulnerability Meltdown:          Not affected
  4163    Vulnerability Mmio stale data:   Not affected
  4164    Vulnerability Retbleed:          Not affected
  4165    Vulnerability Spec store bypass: Not affected
  4166    Vulnerability Spectre v1:        Mitigation; __user pointer sanitization
  4167    Vulnerability Spectre v2:        Not affected
  4168    Vulnerability Srbds:             Not affected
  4169    Vulnerability Tsx async abort:   Not affected
  4170
  4171    ### cpuinfo:
  4172
  4173    processor    : 0
  4174    BogoMIPS    : 48.00
  4175    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4176    CPU implementer    : 0x41
  4177    CPU architecture: 8
  4178    CPU variant    : 0x0
  4179    CPU part    : 0xd03
  4180    CPU revision    : 4
  4181
  4182    processor    : 1
  4183    BogoMIPS    : 48.00
  4184    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4185    CPU implementer    : 0x41
  4186    CPU architecture: 8
  4187    CPU variant    : 0x0
  4188    CPU part    : 0xd03
  4189    CPU revision    : 4
  4190
  4191    processor    : 2
  4192    BogoMIPS    : 48.00
  4193    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4194    CPU implementer    : 0x41
  4195    CPU architecture: 8
  4196    CPU variant    : 0x0
  4197    CPU part    : 0xd03
  4198    CPU revision    : 4
  4199
  4200    processor    : 3
  4201    BogoMIPS    : 48.00
  4202    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4203    CPU implementer    : 0x41
  4204    CPU architecture: 8
  4205    CPU variant    : 0x0
  4206    CPU part    : 0xd03
  4207    CPU revision    : 4
  4208
  4209
  4210    ### meminfo:
  4211
  4212    MemTotal:        4069844 kB
  4213    MemFree:         3882576 kB
  4214    MemAvailable:    3887452 kB
  4215    Buffers:            9028 kB
  4216    Cached:            52600 kB
  4217    SwapCached:            0 kB
  4218    Active:            50460 kB
  4219    Inactive:          22360 kB
  4220    Active(anon):      14160 kB
  4221    Inactive(anon):      784 kB
  4222    Active(file):      36300 kB
  4223    Inactive(file):    21576 kB
  4224    Unevictable:        2988 kB
  4225    Mlocked:               0 kB
  4226    SwapTotal:       2034920 kB
  4227    SwapFree:        2034920 kB
  4228    Zswap:                 0 kB
  4229    Zswapped:              0 kB
  4230    Dirty:               532 kB
  4231    Writeback:             0 kB
  4232    AnonPages:         14248 kB
  4233    Mapped:            16792 kB
  4234    Shmem:               716 kB
  4235    KReclaimable:      17904 kB
  4236    Slab:              48680 kB
  4237    SReclaimable:      17904 kB
  4238    SUnreclaim:        30776 kB
  4239    KernelStack:        2208 kB
  4240    PageTables:         1084 kB
  4241    SecPageTables:         0 kB
  4242    NFS_Unstable:          0 kB
  4243    Bounce:                0 kB
  4244    WritebackTmp:          0 kB
  4245    CommitLimit:     4069840 kB
  4246    Committed_AS:      53796 kB
  4247    VmallocTotal:   133143592960 kB
  4248    VmallocUsed:       28368 kB
  4249    VmallocChunk:          0 kB
  4250    Percpu:             1056 kB
  4251    AnonHugePages:         0 kB
  4252    ShmemHugePages:        0 kB
  4253    ShmemPmdMapped:        0 kB
  4254    FileHugePages:         0 kB
  4255    FilePmdMapped:         0 kB
  4256    CmaTotal:         131072 kB
  4257    CmaFree:          122368 kB
  4258    HugePages_Total:       0
  4259    HugePages_Free:        0
  4260    HugePages_Rsvd:        0
  4261    HugePages_Surp:        0
  4262    Hugepagesize:       2048 kB
  4263    Hugetlb:               0 kB
  4264
  4265    ### virtual memory:
  4266
  4267    vm.admin_reserve_kbytes = 8192
  4268    vm.compaction_proactiveness = 20
  4269    vm.compact_unevictable_allowed = 1
  4270    vm.dirty_background_bytes = 0
  4271    vm.dirty_background_ratio = 10
  4272    vm.dirty_bytes = 0
  4273    vm.dirty_expire_centisecs = 3000
  4274    vm.dirty_ratio = 20
  4275    vm.dirtytime_expire_seconds = 43200
  4276    vm.dirty_writeback_centisecs = 500
  4277    vm.extfrag_threshold = 500
  4278    vm.hugetlb_optimize_vmemmap = 0
  4279    vm.hugetlb_shm_group = 0
  4280    vm.laptop_mode = 0
  4281    vm.legacy_va_layout = 0
  4282    vm.lowmem_reserve_ratio = 256    256    32    0
  4283    vm.max_map_count = 65530
  4284    vm.min_free_kbytes = 22528
  4285    vm.min_slab_ratio = 5
  4286    vm.min_unmapped_ratio = 1
  4287    vm.mmap_min_addr = 4096
  4288    vm.mmap_rnd_bits = 18
  4289    vm.mmap_rnd_compat_bits = 11
  4290    vm.nr_hugepages = 0
  4291    vm.nr_hugepages_mempolicy = 0
  4292    vm.nr_overcommit_hugepages = 0
  4293    vm.numa_stat = 1
  4294    vm.numa_zonelist_order = Node
  4295    vm.oom_dump_tasks = 1
  4296    vm.oom_kill_allocating_task = 0
  4297    vm.overcommit_kbytes = 0
  4298    vm.overcommit_memory = 0
  4299    vm.overcommit_ratio = 50
  4300    vm.page-cluster = 0
  4301    vm.page_lock_unfairness = 5
  4302    vm.panic_on_oom = 0
  4303    vm.percpu_pagelist_high_fraction = 0
  4304    vm.stat_interval = 1
  4305    vm.swappiness = 100
  4306    vm.user_reserve_kbytes = 125902
  4307    vm.vfs_cache_pressure = 100
  4308    vm.watermark_boost_factor = 15000
  4309    vm.watermark_scale_factor = 10
  4310    vm.zone_reclaim_mode = 0
  4311
  4312    ### ip addr:
  4313
  4314    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  4315        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  4316        inet XXX.XXX.0.1/8 scope host lo
  4317           valid_lft forever preferred_lft forever
  4318        inet6 ::1/128 scope host
  4319           valid_lft forever preferred_lft forever
  4320    2: end1: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  4321        link/ether 52:d1:50:3d:d5:78 brd ff:ff:ff:ff:ff:ff
  4322    3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  4323        link/ether 20:02:af:49:e2:d5 brd ff:ff:ff:ff:ff:ff
  4324
  4325    ### partitions:
  4326
  4327    major minor  #blocks  name
  4328
  4329     179        0   15558144 mmcblk0
  4330     179        1   15384576 mmcblk0p1
  4331     179       32   61071360 mmcblk2
  4332     179       64       4096 mmcblk2boot0
  4333     179       96       4096 mmcblk2boot1
  4334     252        0    2034924 zram0
  4335     252        1      51200 zram1
  4336
  4337    ### df:
  4338
  4339    udev            1.9G     0  1.9G   0% /dev
  4340    tmpfs           398M  5.7M  392M   2% /run
  4341    /dev/mmcblk0p1   15G  1.5G   13G  11% /
  4342    tmpfs           2.0G     0  2.0G   0% /dev/shm
  4343    tmpfs           5.0M     0  5.0M   0% /run/lock
  4344    tmpfs           2.0G     0  2.0G   0% /tmp
  4345    /dev/zram1       47M  1.8M   42M   4% /var/log
  4346
  4347    ### lsblk:
  4348
  4349    NAME         FSTYPE  SIZE MOUNTPOINT UUID
  4350    mmcblk0             14.8G
  4351    └─mmcblk0p1  ext4   14.7G /          2eb1e931-b16f-46a3-8b3b-f0a92acc8ddb
  4352    mmcblk2             58.2G
  4353    mmcblk2boot0           4M
  4354    mmcblk2boot1           4M
  4355    zram1                 50M /var/log
  4356    zram2                  0B
  4357
  4358    ### zramctl:
  4359
  4360    NAME       ALGORITHM DISKSIZE  DATA  COMPR TOTAL STREAMS MOUNTPOINT
  4361    /dev/zram1 zstd           50M  1.5M 316.6K  640K       4 /var/log
  4362    /dev/zram0 lzo-rle       1.9G    4K    74B   12K       4 [SWAP]
  4363
  4364    ### mtab:
  4365
  4366    /dev/mmcblk0p1 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0
  4367    /dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0
  4368    /dev/zram1 /var/log ext4 rw,relatime,discard 0 0
  4369
  4370    ### mmc0:8dfc info:
  4371
  4372                   fwrev: 0x0
  4373                  uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SU16G MODALIAS=mmc:block
  4374                     cid: 03534453553136478060b5bf4000a609
  4375                     rca: 0x8dfc
  4376                     csd: 400e00325b59000076b27f800a404013
  4377                  manfid: 0x000003
  4378                     ocr: 0x00300000
  4379    preferred_erase_size: 4194304
  4380                    type: SD
  4381                   hwrev: 0x8
  4382                    date: 06/2010
  4383                     dsr: 0x404
  4384              erase_size: 512
  4385                   oemid: 0x5344
  4386                  serial: 0x60b5bf40
  4387                     ssr: 0000000004000000010190000b050000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  4388                     scr: 0235800000000000
  4389                    name: SU16G
  4390
  4391    ### mmc2:0001 info:
  4392
  4393                   fwrev: 0x0500000000000000
  4394                  uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=CKTM4R MODALIAS=mmc:block
  4395                     cid: 150100434b544d345202a448f479c3a1
  4396             rel_sectors: 0x1
  4397    enhanced_rpmb_supported: 0x1
  4398                     rca: 0x0001
  4399            pre_eol_info: 0x01
  4400                     csd: d02701320f5903fff6dbffef8e40400d
  4401                  manfid: 0x000015
  4402                     ocr: 0x00300000
  4403    preferred_erase_size: 4194304
  4404    enhanced_area_offset: 18446744073709551594
  4405      raw_rpmb_size_mult: 0x20
  4406                    type: MMC
  4407                   hwrev: 0x0
  4408                    date: 12/2016
  4409                     prv: 0x2
  4410             ffu_capable: 1
  4411                     dsr: 0x404
  4412              erase_size: 524288
  4413               life_time: 0x01 0x01
  4414      enhanced_area_size: 4294967274
  4415                   oemid: 0x0100
  4416                  serial: 0xa448f479
  4417                 cmdq_en: 0
  4418                     rev: 0x8
  4419                    name: CKTM4R
  4420
  4421    ### Boot system health:
  4422
  4423    Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU  C.St.
  4424    21:17:14: 1008MHz  0.71  50%  24%  12%   0%  13%   0% 60.4 °C  0/3
  4425    21:17:14: 1008MHz  0.71  83%  20%  18%   0%  43%   0% 59.5 °C  0/3
  4426    21:17:15:  816MHz  0.71  78%  11%   8%   0%  57%   0% 57.7 °C  0/3
  4427    21:17:15:  816MHz  0.71  58%  10%   8%   1%  38%   0% 58.2 °C  0/3
  4428    21:17:16: 1008MHz  0.71  63%   9%   5%   1%  46%   0% 58.2 °C  0/3
  4429
  4430    ### Activated 1 lzo-rle zram swap devices with 1987MB each.
  4431    ### Activated Armbian ramlog partition with zstd compression
  4432
  4433    Sun Feb 12 09:17:10 PM MSK 2023 | RK3318 Box | 23.02.0-trunk | arm64 | aarch64 | 6.1.11-rockchip64
  4434
  4435    ### dmesg:
  4436
  4437    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
  4438    [    0.000000] Linux version 6.1.11-rockchip64 (root@7284a09ced08) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #trunk.0248 SMP PREEMPT Fri Feb 10 05:25:40 UTC 2023
  4439    [    0.000000] Machine model: Rockchip RK3318 BOX
  4440    [    0.000000] efi: UEFI not found.
  4441    [    0.000000] NUMA: No NUMA configuration found
  4442    [    0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x00000000feffffff]
  4443    [    0.000000] NUMA: NODE_DATA [mem 0xfe7b1a80-0xfe7b3fff]
  4444    [    0.000000] Zone ranges:
  4445    [    0.000000]   DMA      [mem 0x0000000000200000-0x00000000feffffff]
  4446    [    0.000000]   DMA32    empty
  4447    [    0.000000]   Normal   empty
  4448    [    0.000000] Movable zone start for each node
  4449    [    0.000000] Early memory node ranges
  4450    [    0.000000]   node   0: [mem 0x0000000000200000-0x00000000feffffff]
  4451    [    0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000000feffffff]
  4452    [    0.000000] On node 0, zone DMA: 512 pages in unavailable ranges
  4453    [    0.000000] On node 0, zone DMA: 4096 pages in unavailable ranges
  4454    [    0.000000] cma: Reserved 128 MiB at 0x00000000f2600000
  4455    [    0.000000] psci: probing for conduit method from DT.
  4456    [    0.000000] psci: PSCIv1.1 detected in firmware.
  4457    [    0.000000] psci: Using standard PSCI v0.2 function IDs
  4458    [    0.000000] psci: MIGRATE_INFO_TYPE not supported.
  4459    [    0.000000] psci: SMC Calling Convention v1.2
  4460    [    0.000000] percpu: Embedded 30 pages/cpu s82472 r8192 d32216 u122880
  4461    [    0.000000] pcpu-alloc: s82472 r8192 d32216 u122880 alloc=30*4096
  4462    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
  4463    [    0.000000] Detected VIPT I-cache on CPU0
  4464    [    0.000000] CPU features: detected: ARM erratum 845719
  4465    [    0.000000] alternatives: applying boot alternatives
  4466    [    0.000000] Fallback order for Node 0: 0
  4467    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1027656
  4468    [    0.000000] Policy zone: DMA
  4469    [    0.000000] Kernel command line: root=UUID=2eb1e931-b16f-46a3-8b3b-f0a92acc8ddb rootwait rootfstype=ext4 splash=verbose console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart=8635553d-01 usb-storage.quirks=   cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
  4470    [    0.000000] The swapaccount= commandline option is deprecated. Please report your usecase to linux-mm@kvack.org if you depend on this functionality.
  4471    [    0.000000] Unknown kernel command line parameters "splash=verbose ubootpart=8635553d-01 cgroup_enable=memory cgroup_memory=1", will be passed to user space.
  4472    [    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
  4473    [    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
  4474    [    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
  4475    [    0.000000] Memory: 3913516K/4175872K available (16448K kernel code, 2240K rwdata, 5832K rodata, 3968K init, 585K bss, 131284K reserved, 131072K cma-reserved)
  4476    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
  4477    [    0.000000] trace event string verifier disabled
  4478    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
  4479    [    0.000000] rcu:     RCU event tracing is enabled.
  4480    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
  4481    [    0.000000]     Trampoline variant of Tasks RCU enabled.
  4482    [    0.000000]     Tracing variant of Tasks RCU enabled.
  4483    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
  4484    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
  4485    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
  4486    [    0.000000] Root IRQ handler: gic_handle_irq
  4487    [    0.000000] GIC: Using split EOI/Deactivate mode
  4488    [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
  4489    [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
  4490    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  4491    [    0.000002] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  4492    [    0.001074] Console: colour dummy device 80x25
  4493    [    0.001155] printk: console [tty1] enabled
  4494    [    0.001271] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
  4495    [    0.001300] pid_max: default: 32768 minimum: 301
  4496    [    0.001451] LSM: Security Framework initializing
  4497    [    0.001502] Yama: becoming mindful.
  4498    [    0.001670] AppArmor: AppArmor initialized
  4499    [    0.001717] Stack Depot allocating hash table of 262144 entries with kvcalloc
  4500    [    0.002372] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
  4501    [    0.002414] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
  4502    [    0.005723] cblist_init_generic: Setting adjustable number of callback queues.
  4503    [    0.005751] cblist_init_generic: Setting shift to 2 and lim to 1.
  4504    [    0.005935] cblist_init_generic: Setting shift to 2 and lim to 1.
  4505    [    0.006376] rcu: Hierarchical SRCU implementation.
  4506    [    0.006386] rcu:     Max phase no-delay instances is 1000.
  4507    [    0.010004] EFI services will not be available.
  4508    [    0.010735] smp: Bringing up secondary CPUs ...
  4509    [    0.011988] Detected VIPT I-cache on CPU1
  4510    [    0.012182] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
  4511    [    0.013540] Detected VIPT I-cache on CPU2
  4512    [    0.013729] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
  4513    [    0.015075] Detected VIPT I-cache on CPU3
  4514    [    0.015270] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
  4515    [    0.015472] smp: Brought up 1 node, 4 CPUs
  4516    [    0.015499] SMP: Total of 4 processors activated.
  4517    [    0.015513] CPU features: detected: 32-bit EL0 Support
  4518    [    0.015521] CPU features: detected: 32-bit EL1 Support
  4519    [    0.015533] CPU features: detected: CRC32 instructions
  4520    [    0.015666] CPU: All CPU(s) started at EL2
  4521    [    0.015689] alternatives: applying system-wide alternatives
  4522    [    0.019306] devtmpfs: initialized
  4523    [    0.043156] Registered cp15_barrier emulation handler
  4524    [    0.043188] Registered setend emulation handler
  4525    [    0.043641] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  4526    [    0.043689] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
  4527    [    0.049334] pinctrl core: initialized pinctrl subsystem
  4528    [    0.050599] DMI not present or invalid.
  4529    [    0.051828] NET: Registered PF_NETLINK/PF_ROUTE protocol family
  4530    [    0.054885] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
  4531    [    0.056318] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
  4532    [    0.057570] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
  4533    [    0.057699] audit: initializing netlink subsys (disabled)
  4534    [    0.058090] audit: type=2000 audit(0.056:1): state=initialized audit_enabled=0 res=1
  4535    [    0.059560] thermal_sys: Registered thermal governor 'fair_share'
  4536    [    0.059575] thermal_sys: Registered thermal governor 'bang_bang'
  4537    [    0.059588] thermal_sys: Registered thermal governor 'step_wise'
  4538    [    0.059599] thermal_sys: Registered thermal governor 'user_space'
  4539    [    0.059719] cpuidle: using governor menu
  4540    [    0.060344] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  4541    [    0.060570] ASID allocator initialised with 65536 entries
  4542    [    0.062550] Serial: AMBA PL011 UART driver
  4543    [    0.081522] platform ff3c0000.hdmi: Fixing up cyclic dependency with ff370000.vop
  4544    [    0.108028] rockchip-gpio ff210000.gpio: probed /pinctrl/gpio@ff210000
  4545    [    0.109475] rockchip-gpio ff220000.gpio: probed /pinctrl/gpio@ff220000
  4546    [    0.110737] rockchip-gpio ff230000.gpio: probed /pinctrl/gpio@ff230000
  4547    [    0.112045] rockchip-gpio ff240000.gpio: probed /pinctrl/gpio@ff240000
  4548    [    0.150887] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
  4549    [    0.150912] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
  4550    [    0.150929] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
  4551    [    0.150940] HugeTLB: 508 KiB vmemmap can be freed for a 32.0 MiB page
  4552    [    0.150954] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
  4553    [    0.150964] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
  4554    [    0.150978] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
  4555    [    0.150989] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
  4556    [    0.152898] cryptd: max_cpu_qlen set to 1000
  4557    [    0.219398] raid6: neonx8   gen()  1037 MB/s
  4558    [    0.287586] raid6: neonx4   gen()  1064 MB/s
  4559    [    0.355781] raid6: neonx2   gen()  1003 MB/s
  4560    [    0.423985] raid6: neonx1   gen()   879 MB/s
  4561    [    0.492142] raid6: int64x8  gen()   744 MB/s
  4562    [    0.560327] raid6: int64x4  gen()   827 MB/s
  4563    [    0.628519] raid6: int64x2  gen()   707 MB/s
  4564    [    0.696700] raid6: int64x1  gen()   525 MB/s
  4565    [    0.696716] raid6: using algorithm neonx4 gen() 1064 MB/s
  4566    [    0.764871] raid6: .... xor() 769 MB/s, rmw enabled
  4567    [    0.764885] raid6: using neon recovery algorithm
  4568    [    0.771602] iommu: Default domain type: Translated
  4569    [    0.771624] iommu: DMA domain TLB invalidation policy: strict mode
  4570    [    0.772459] SCSI subsystem initialized
  4571    [    0.772857] libata version 3.00 loaded.
  4572    [    0.773428] usbcore: registered new interface driver usbfs
  4573    [    0.773519] usbcore: registered new interface driver hub
  4574    [    0.773602] usbcore: registered new device driver usb
  4575    [    0.774661] pps_core: LinuxPPS API ver. 1 registered
  4576    [    0.774675] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  4577    [    0.774705] PTP clock support registered
  4578    [    0.775124] EDAC MC: Ver: 3.0.0
  4579    [    0.778073] NetLabel: Initializing
  4580    [    0.778093] NetLabel:  domain hash size = 128
  4581    [    0.778105] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
  4582    [    0.778252] NetLabel:  unlabeled traffic allowed by default
  4583    [    0.778556] vgaarb: loaded
  4584    [    0.779557] clocksource: Switched to clocksource arch_sys_counter
  4585    [    0.890429] VFS: Disk quotas dquot_6.6.0
  4586    [    0.890537] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  4587    [    0.892281] AppArmor: AppArmor Filesystem Enabled
  4588    [    0.909478] NET: Registered PF_INET protocol family
  4589    [    0.909892] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
  4590    [    0.916178] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
  4591    [    0.916423] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
  4592    [    0.916525] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
  4593    [    0.917179] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
  4594    [    0.918542] TCP: Hash tables configured (established 32768 bind 32768)
  4595    [    0.918791] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
  4596    [    0.918989] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
  4597    [    0.919480] NET: Registered PF_UNIX/PF_LOCAL protocol family
  4598    [    0.919650] NET: Registered PF_XDP protocol family
  4599    [    0.919677] PCI: CLS 0 bytes, default 64
  4600    [    0.920089] Trying to unpack rootfs image as initramfs...
  4601    [    0.921926] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
  4602    [    0.923079] kvm [1]: IPA Size Limit: 40 bits
  4603    [    0.925586] kvm [1]: vgic interrupt IRQ9
  4604    [    0.925864] kvm [1]: Hyp mode initialized successfully
  4605    [    0.930128] Initialise system trusted keyrings
  4606    [    0.930219] Key type blacklist registered
  4607    [    0.930622] workingset: timestamp_bits=44 max_order=20 bucket_order=0
  4608    [    0.945139] zbud: loaded
  4609    [    0.948772] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  4610    [    0.950337] fuse: init (API version 7.37)
  4611    [    0.955276] integrity: Platform Keyring initialized
  4612    [    1.027763] xor: measuring software checksum speed
  4613    [    1.035899]    8regs           :  1220 MB/sec
  4614    [    1.043779]    32regs          :  1261 MB/sec
  4615    [    1.053049]    arm64_neon      :  1069 MB/sec
  4616    [    1.053072] xor: using function: 32regs (1261 MB/sec)
  4617    [    1.053093] Key type asymmetric registered
  4618    [    1.053103] Asymmetric key parser 'x509' registered
  4619    [    3.008888] Freeing initrd memory: 21288K
  4620    [    3.053175] alg: self-tests for CTR-KDF (hmac(sha256)) passed
  4621    [    3.053344] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
  4622    [    3.053602] io scheduler mq-deadline registered
  4623    [    3.053617] io scheduler kyber registered
  4624    [    3.054068] io scheduler bfq registered
  4625    [    3.072951] dma-pl330 ff1f0000.dma-controller: Loaded driver for PL330 DMAC-241330
  4626    [    3.072982] dma-pl330 ff1f0000.dma-controller:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
  4627    [    3.081556] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
  4628    [    3.087445] ff110000.serial: ttyS0 at MMIO 0xff110000 (irq = 25, base_baud = 1500000) is a 16550A
  4629    [    3.089393] ff130000.serial: ttyS2 at MMIO 0xff130000 (irq = 26, base_baud = 1500000) is a 16550A
  4630    [    3.089839] printk: console [ttyS2] enabled
  4631    [    3.091890] Serial: AMBA driver
  4632    [    3.100681] rockchip-vop ff370000.vop: Adding to iommu group 4
  4633    [    3.126611] loop: module loaded
  4634    [    3.135345] tun: Universal TUN/TAP device driver, 1.6
  4635    [    3.137237] thunder_xcv, ver 1.0
  4636    [    3.137333] thunder_bgx, ver 1.0
  4637    [    3.137425] nicpf, ver 1.0
  4638    [    3.138761] e1000e: Intel(R) PRO/1000 Network Driver
  4639    [    3.138776] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
  4640    [    3.138869] igb: Intel(R) Gigabit Ethernet Network Driver
  4641    [    3.138881] igb: Copyright (c) 2007-2014 Intel Corporation.
  4642    [    3.138965] igbvf: Intel(R) Gigabit Virtual Function Network Driver
  4643    [    3.138977] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
  4644    [    3.139367] sky2: driver version 1.30
  4645    [    3.140551] VFIO - User Level meta-driver version: 0.3
  4646    [    3.144433] dwc2 ff580000.usb: supply vusb_d not found, using dummy regulator
  4647    [    3.144727] dwc2 ff580000.usb: supply vusb_a not found, using dummy regulator
  4648    [    3.157835] dwc2 ff580000.usb: DWC OTG Controller
  4649    [    3.157889] dwc2 ff580000.usb: new USB bus registered, assigned bus number 1
  4650    [    3.157952] dwc2 ff580000.usb: irq 34, io mem 0xff580000
  4651    [    3.158319] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
  4652    [    3.158346] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  4653    [    3.158367] usb usb1: Product: DWC OTG Controller
  4654    [    3.158384] usb usb1: Manufacturer: Linux 6.1.11-rockchip64 dwc2_hsotg
  4655    [    3.158402] usb usb1: SerialNumber: ff580000.usb
  4656    [    3.159586] hub 1-0:1.0: USB hub found
  4657    [    3.159658] hub 1-0:1.0: 1 port detected
  4658    [    3.164091] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  4659    [    3.164158] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
  4660    [    3.164408] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
  4661    [    3.164532] xhci-hcd xhci-hcd.0.auto: irq 33, io mem 0xff600000
  4662    [    3.165049] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  4663    [    3.165077] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 3
  4664    [    3.165106] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
  4665    [    3.165114] ehci-platform ff5c0000.usb: EHCI Host Controller
  4666    [    3.165138] ohci-platform ff5d0000.usb: Generic Platform OHCI controller
  4667    [    3.165459] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
  4668    [    3.165484] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  4669    [    3.165504] usb usb2: Product: xHCI Host Controller
  4670    [    3.165521] usb usb2: Manufacturer: Linux 6.1.11-rockchip64 xhci-hcd
  4671    [    3.165538] usb usb2: SerialNumber: xhci-hcd.0.auto
  4672    [    3.166666] hub 2-0:1.0: USB hub found
  4673    [    3.166742] hub 2-0:1.0: 1 port detected
  4674    [    3.167768] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
  4675    [    3.168056] usb usb3: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
  4676    [    3.168084] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  4677    [    3.168104] usb usb3: Product: xHCI Host Controller
  4678    [    3.168122] usb usb3: Manufacturer: Linux 6.1.11-rockchip64 xhci-hcd
  4679    [    3.168140] usb usb3: SerialNumber: xhci-hcd.0.auto
  4680    [    3.169229] hub 3-0:1.0: USB hub found
  4681    [    3.169303] hub 3-0:1.0: 1 port detected
  4682    [    3.170031] ehci-platform ff5c0000.usb: new USB bus registered, assigned bus number 4
  4683    [    3.170053] ohci-platform ff5d0000.usb: new USB bus registered, assigned bus number 5
  4684    [    3.170268] usbcore: registered new interface driver usb-storage
  4685    [    3.170281] ehci-platform ff5c0000.usb: irq 35, io mem 0xff5c0000
  4686    [    3.170340] ohci-platform ff5d0000.usb: irq 36, io mem 0xff5d0000
  4687    [    3.173750] mousedev: PS/2 mouse device common for all mice
  4688    [    3.175335] i2c_dev: i2c /dev entries driver
  4689    [    3.180202] dw_wdt ff1a0000.watchdog: No valid TOPs array specified
  4690    [    3.183624] ehci-platform ff5c0000.usb: USB 2.0 started, EHCI 1.00
  4691    [    3.183927] sdhci: Secure Digital Host Controller Interface driver
  4692    [    3.183942] sdhci: Copyright(c) Pierre Ossman
  4693    [    3.183992] Synopsys Designware Multimedia Card Interface Driver
  4694    [    3.184330] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
  4695    [    3.184357] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  4696    [    3.184376] usb usb4: Product: EHCI Host Controller
  4697    [    3.184390] usb usb4: Manufacturer: Linux 6.1.11-rockchip64 ehci_hcd
  4698    [    3.184406] usb usb4: SerialNumber: ff5c0000.usb
  4699    [    3.185454] hub 4-0:1.0: USB hub found
  4700    [    3.185557] hub 4-0:1.0: 1 port detected
  4701    [    3.185677] sdhci-pltfm: SDHCI platform and OF driver helper
  4702    [    3.186632] dwmmc_rockchip ff500000.mmc: IDMAC supports 32-bit address mode.
  4703    [    3.186695] dwmmc_rockchip ff500000.mmc: Using internal DMA controller.
  4704    [    3.186716] dwmmc_rockchip ff500000.mmc: Version ID is 270a
  4705    [    3.186819] dwmmc_rockchip ff500000.mmc: DW MMC controller at irq 39,32 bit host data width,256 deep fifo
  4706    [    3.187027] dwmmc_rockchip ff520000.mmc: IDMAC supports 32-bit address mode.
  4707    [    3.187078] dwmmc_rockchip ff520000.mmc: Using internal DMA controller.
  4708    [    3.187098] dwmmc_rockchip ff520000.mmc: Version ID is 270a
  4709    [    3.187194] dwmmc_rockchip ff520000.mmc: DW MMC controller at irq 40,32 bit host data width,256 deep fifo
  4710    [    3.187484] dwmmc_rockchip ff500000.mmc: Got CD GPIO
  4711    [    3.187484] dwmmc_rockchip ff5f0000.mmc: IDMAC supports 32-bit address mode.
  4712    [    3.187588] dwmmc_rockchip ff5f0000.mmc: Using internal DMA controller.
  4713    [    3.187611] dwmmc_rockchip ff5f0000.mmc: Version ID is 270a
  4714    [    3.187713] dwmmc_rockchip ff5f0000.mmc: DW MMC controller at irq 41,32 bit host data width,256 deep fifo
  4715    [    3.188161] dwmmc_rockchip ff5f0000.mmc: allocated mmc-pwrseq
  4716    [    3.188186] mmc_host mmc4: card is non-removable.
  4717    [    3.188224] mmc_host mmc2: card is non-removable.
  4718    [    3.190566] ledtrig-cpu: registered to indicate activity on CPUs
  4719    [    3.191439] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
  4720    [    3.191916] hid: raw HID events driver (C) Jiri Kosina
  4721    [    3.192179] usbcore: registered new interface driver usbhid
  4722    [    3.192193] usbhid: USB HID core driver
  4723    [    3.199734] mmc_host mmc4: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
  4724    [    3.199733] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
  4725    [    3.200439] drop_monitor: Initializing network drop monitor service
  4726    [    3.201122] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
  4727    [    3.201825] NET: Registered PF_INET6 protocol family
  4728    [    3.232048] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.01
  4729    [    3.232087] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  4730    [    3.232108] usb usb5: Product: Generic Platform OHCI controller
  4731    [    3.232123] usb usb5: Manufacturer: Linux 6.1.11-rockchip64 ohci_hcd
  4732    [    3.232138] usb usb5: SerialNumber: ff5d0000.usb
  4733    [    3.233286] hub 5-0:1.0: USB hub found
  4734    [    3.233414] hub 5-0:1.0: 1 port detected
  4735    [    3.248916] Segment Routing with IPv6
  4736    [    3.249033] In-situ OAM (IOAM) with IPv6
  4737    [    3.249238] NET: Registered PF_PACKET protocol family
  4738    [    3.249532] 8021q: 802.1Q VLAN Support v1.8
  4739    [    3.249647] Key type dns_resolver registered
  4740    [    3.251991] registered taskstats version 1
  4741    [    3.252040] Loading compiled-in X.509 certificates
  4742    [    3.258070] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
  4743    [    3.258208] mmc0: new high speed SDHC card at address 8dfc
  4744    [    3.258565] Loaded X.509 cert 'Build time autogenerated kernel key: e25f7f61aa13aedd90bace25454c8646dc5da469'
  4745    [    3.260107] mmcblk0: mmc0:8dfc SU16G 14.8 GiB
  4746    [    3.263764] zswap: loaded using pool zstd/z3fold
  4747    [    3.264832] Key type .fscrypt registered
  4748    [    3.264855] Key type fscrypt-provisioning registered
  4749    [    3.268304] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=yes
  4750    [    3.268460]  mmcblk0: p1
  4751    [    3.269029] Key type encrypted registered
  4752    [    3.269101] AppArmor: AppArmor sha1 policy hashing enabled
  4753    [    3.298696] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 52000000Hz, actual 50000000HZ div = 0)
  4754    [    3.299127] mmc2: new high speed MMC card at address 0001
  4755    [    3.301226] mmcblk2: mmc2:0001 CKTM4R 58.2 GiB
  4756    [    3.306693] mmcblk2boot0: mmc2:0001 CKTM4R 4.00 MiB
  4757    [    3.310915] mmcblk2boot1: mmc2:0001 CKTM4R 4.00 MiB
  4758    [    3.314525] mmcblk2rpmb: mmc2:0001 CKTM4R 4.00 MiB, chardev (242:0)
  4759    [    3.323676] mmc_host mmc4: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
  4760    [    3.327763] mmc4: new high speed SDIO card at address 0001
  4761    [    3.363652] rockchip-drm display-subsystem: bound ff370000.vop (ops vop_component_ops)
  4762    [    3.363824] dwhdmi-rockchip ff3c0000.hdmi: supply avdd-0v9 not found, using dummy regulator
  4763    [    3.364220] dwhdmi-rockchip ff3c0000.hdmi: supply avdd-1v8 not found, using dummy regulator
  4764    [    3.364813] dwhdmi-rockchip ff3c0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (inno_dw_hdmi_phy2)
  4765    [    3.366101] dwhdmi-rockchip ff3c0000.hdmi: registered DesignWare HDMI I2C bus driver
  4766    [    3.367031] rockchip-drm display-subsystem: bound ff3c0000.hdmi (ops dw_hdmi_rockchip_ops)
  4767    [    3.368340] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 0
  4768    [    3.368456] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
  4769    [    3.368900] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
  4770    [    3.368945] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
  4771    [    3.369490] WCN: marlin_init entry!
  4772    [    3.370331] of_cfs_init
  4773    [    3.370402] of_cfs_init: OK
  4774    [    3.374112] Freeing unused kernel memory: 3968K
  4775    [    3.383751] Run /init as init process
  4776    [    3.383770]   with arguments:
  4777    [    3.383783]     /init
  4778    [    3.383795]   with environment:
  4779    [    3.383806]     HOME=/
  4780    [    3.383817]     TERM=linux
  4781    [    3.383829]     splash=verbose
  4782    [    3.383841]     ubootpart=8635553d-01
  4783    [    3.383853]     cgroup_enable=memory
  4784    [    3.383866]     cgroup_memory=1
  4785    [    4.446009] input: adc-keys as /devices/platform/adc-keys/input/input0
  4786    [    4.470991] gpio-syscon ff100000.syscon:gpio: can't read the data register offset!
  4787    [    4.553249] lima ff300000.gpu: gp - mali450 version major 0 minor 0
  4788    [    4.553459] lima ff300000.gpu: pp0 - mali450 version major 0 minor 0
  4789    [    4.553674] lima ff300000.gpu: pp1 - mali450 version major 0 minor 0
  4790    [    4.553778] lima ff300000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
  4791    [    4.553802] lima ff300000.gpu: l2 cache 64K, 4-way, 64byte cache line, 128bit external bus
  4792    [    4.559968] lima ff300000.gpu: bus rate = 491520000
  4793    [    4.560003] lima ff300000.gpu: mod rate = 491520000
  4794    [    4.562842] [drm] Initialized lima 1.1.0 20191231 for ff300000.gpu on minor 1
  4795    [    4.757687] rk_gmac-dwmac ff550000.ethernet: IRQ eth_wake_irq not found
  4796    [    4.757721] rk_gmac-dwmac ff550000.ethernet: IRQ eth_lpi not found
  4797    [    4.757970] rk_gmac-dwmac ff550000.ethernet: PTP uses main clock
  4798    [    4.758648] rk_gmac-dwmac ff550000.ethernet: clock input or output? (output).
  4799    [    4.758683] rk_gmac-dwmac ff550000.ethernet: TX delay(0x30).
  4800    [    4.758703] rk_gmac-dwmac ff550000.ethernet: RX delay(0x10).
  4801    [    4.758749] rk_gmac-dwmac ff550000.ethernet: integrated PHY? (yes).
  4802    [    4.758889] rk_gmac-dwmac ff550000.ethernet: cannot get clock clk_mac_refout
  4803    [    4.758913] rk_gmac-dwmac ff550000.ethernet: cannot get clock clk_mac_speed
  4804    [    4.763997] rk_gmac-dwmac ff550000.ethernet: init for RMII
  4805    [    4.807966] rk_gmac-dwmac ff550000.ethernet: User ID: 0x10, Synopsys ID: 0x35
  4806    [    4.808008] rk_gmac-dwmac ff550000.ethernet:     DWMAC1000
  4807    [    4.808026] rk_gmac-dwmac ff550000.ethernet: DMA HW capability register supported
  4808    [    4.808043] rk_gmac-dwmac ff550000.ethernet: RX Checksum Offload Engine supported
  4809    [    4.808057] rk_gmac-dwmac ff550000.ethernet: COE Type 2
  4810    [    4.808071] rk_gmac-dwmac ff550000.ethernet: TX Checksum insertion supported
  4811    [    4.808085] rk_gmac-dwmac ff550000.ethernet: Wake-Up On Lan supported
  4812    [    4.808276] rk_gmac-dwmac ff550000.ethernet: Normal descriptors
  4813    [    4.808292] rk_gmac-dwmac ff550000.ethernet: Ring mode enabled
  4814    [    4.808306] rk_gmac-dwmac ff550000.ethernet: Enable RX Mitigation via HW Watchdog Timer
  4815    [    4.844168] rk_gmac-dwmac ff550000.ethernet end1: renamed from eth0
  4816    [    5.069101] dw-apb-uart ff130000.serial: forbid DMA for kernel console
  4817    [    5.955318] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Quota mode: none.
  4818    [    8.078859] systemd[1]: System time before build time, advancing clock.
  4819    [    8.158420] systemd[1]: Inserted module 'autofs4'
  4820    [    8.321551] systemd[1]: systemd 252.5-2 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
  4821    [    8.321612] systemd[1]: Detected architecture arm64.
  4822    [    8.345552] systemd[1]: Hostname set to <rk3318-box>.
  4823    [    9.724425] systemd[325]: /usr/lib/systemd/system-generators/netplan failed with exit status 1.
  4824    [   11.027496] systemd[1]: Queued start job for default target graphical.target.
  4825    [   11.057571] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
  4826    [   11.062222] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
  4827    [   11.066538] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
  4828    [   11.069831] systemd[1]: Created slice user.slice - User and Session Slice.
  4829    [   11.070905] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
  4830    [   11.073098] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
  4831    [   11.073898] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
  4832    [   11.074568] systemd[1]: Reached target remote-fs.target - Remote File Systems.
  4833    [   11.074936] systemd[1]: Reached target slices.target - Slice Units.
  4834    [   11.075425] systemd[1]: Reached target swap.target - Swaps.
  4835    [   11.075969] systemd[1]: Reached target time-set.target - System Time Set.
  4836    [   11.076705] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
  4837    [   11.082446] systemd[1]: Listening on syslog.socket - Syslog Socket.
  4838    [   11.084035] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
  4839    [   11.085097] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
  4840    [   11.087052] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
  4841    [   11.088724] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
  4842    [   11.090925] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
  4843    [   11.103352] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
  4844    [   11.104981] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
  4845    [   11.132342] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
  4846    [   11.141986] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
  4847    [   11.151846] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
  4848    [   11.162031] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
  4849    [   11.178797] systemd[1]: Starting fake-hwclock.service - Restore / save the current clock...
  4850    [   11.189405] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
  4851    [   11.200695] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
  4852    [   11.211897] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
  4853    [   11.223254] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
  4854    [   11.235524] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
  4855    [   11.246794] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
  4856    [   11.248598] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
  4857    [   11.277680] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
  4858    [   11.289056] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
  4859    [   11.290494] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
  4860    [   11.300884] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
  4861    [   11.319785] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
  4862    [   11.323506] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
  4863    [   11.327431] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
  4864    [   11.331456] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
  4865    [   11.336944] systemd[1]: Finished fake-hwclock.service - Restore / save the current clock.
  4866    [   11.342800] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
  4867    [   11.349188] systemd[1]: modprobe@configfs.service: Deactivated successfully.
  4868    [   11.351020] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
  4869    [   11.355083] systemd[1]: modprobe@drm.service: Deactivated successfully.
  4870    [   11.357554] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
  4871    [   11.361952] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
  4872    [   11.366400] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
  4873    [   11.370987] systemd[1]: modprobe@fuse.service: Deactivated successfully.
  4874    [   11.373034] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
  4875    [   11.378964] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
  4876    [   11.408072] EXT4-fs (mmcblk0p1): re-mounted. Quota mode: none.
  4877    [   11.432912] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
  4878    [   11.442885] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
  4879    [   11.454535] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables...
  4880    [   11.480041] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
  4881    [   11.483138] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
  4882    [   11.485974] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
  4883    [   11.489386] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
  4884    [   11.521290] systemd[1]: Starting systemd-random-seed.service - Load/Save Random Seed...
  4885    [   11.532575] systemd[1]: Starting systemd-sysusers.service - Create System Users...
  4886    [   11.602805] systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables.
  4887    [   11.684428] systemd[1]: Finished systemd-sysusers.service - Create System Users.
  4888    [   11.733233] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev...
  4889    [   11.910213] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout.
  4890    [   11.938975] systemd[1]: Finished systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev.
  4891    [   11.941419] systemd[1]: Reached target local-fs-pre.target - Preparation for Local File Systems.
  4892    [   11.968949] systemd[1]: Mounting tmp.mount - /tmp...
  4893    [   11.980069] systemd[1]: Starting systemd-udevd.service - Rule-based Manager for Device Events and Files...
  4894    [   12.004572] systemd[1]: Mounted tmp.mount - /tmp.
  4895    [   12.008169] systemd[1]: Reached target local-fs.target - Local File Systems.
  4896    [   12.018888] systemd[1]: Starting armbian-led-state.service - Armbian leds state...
  4897    [   12.043299] systemd[1]: Starting armbian-zram-config.service - Armbian ZRAM config...
  4898    [   12.070407] systemd[1]: Starting console-setup.service - Set console font and keymap...
  4899    [   12.086789] systemd[1]: Starting plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data...
  4900    [   12.168878] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
  4901    [   12.177302] systemd[1]: Finished console-setup.service - Set console font and keymap.
  4902    [   12.184941] systemd[1]: Received SIGRTMIN+20 from PID 291 (plymouthd).
  4903    [   12.250332] systemd[1]: Finished plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data.
  4904    [   12.279495] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 388 (systemd-binfmt)
  4905    [   12.347082] systemd[1]: Mounting proc-sys-fs-binfmt_misc.mount - Arbitrary Executable File Formats File System...
  4906    [   12.374209] systemd[1]: Finished armbian-led-state.service - Armbian leds state.
  4907    [   12.419450] systemd[1]: Mounted proc-sys-fs-binfmt_misc.mount - Arbitrary Executable File Formats File System.
  4908    [   12.434465] systemd[1]: Finished systemd-binfmt.service - Set Up Additional Binary Formats.
  4909    [   12.588157] systemd[1]: Finished systemd-udev-trigger.service - Coldplug All udev Devices.
  4910    [   12.633136] systemd[1]: Starting ifupdown-pre.service - Helper to synchronize boot up for ifupdown...
  4911    [   12.723807] systemd[1]: Finished ifupdown-pre.service - Helper to synchronize boot up for ifupdown.
  4912    [   12.992413] systemd[1]: Started systemd-udevd.service - Rule-based Manager for Device Events and Files.
  4913    [   13.044366] systemd[1]: Starting plymouth-start.service - Show Plymouth Boot Screen...
  4914    [   13.153070] zram: Added device: zram0
  4915    [   13.154445] zram: Added device: zram1
  4916    [   13.156710] zram: Added device: zram2
  4917    [   13.217777] systemd[1]: Started plymouth-start.service - Show Plymouth Boot Screen.
  4918    [   13.220284] systemd[1]: bootsplash-ask-password-console.path - Dispatch Password Requests to Console Directory Watch when bootsplash is active was skipped because of an unmet condition check (ConditionPathExists=/sys/devices/platform/bootsplash.0/enabled).
  4919    [   13.221697] systemd[1]: Started systemd-ask-password-plymouth.path - Forward Password Requests to Plymouth Directory Watch.
  4920    [   13.222236] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
  4921    [   13.222689] systemd[1]: Reached target paths.target - Path Units.
  4922    [   13.330688] systemd[1]: Found device dev-ttyS2.device - /dev/ttyS2.
  4923    [   13.557315] zram0: detected capacity change from 0 to 4069848
  4924    [   14.030343] mc: Linux media interface: v0.10
  4925    [   14.094770] videodev: Linux video capture interface: v2.00
  4926    [   14.277993] Registered IR keymap rc-empty
  4927    [   14.278121] rc rc0: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc0
  4928    [   14.279679] rc rc0: lirc_dev: driver gpio_ir_recv registered at minor = 0, raw IR receiver, no transmitter
  4929    [   14.279907] input: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc0/input1
  4930    [   14.496873] rockchip-rga ff390000.rga: HW Version: 0x04.00
  4931    [   14.498498] rockchip-rga ff390000.rga: Registered rockchip-rga as /dev/video0
  4932    [   14.518941] rockchip_vdec: module is from the staging directory, the quality is unknown, you have been warned.
  4933    [   14.565135] rkvdec ff360000.video-codec: Adding to iommu group 3
  4934    [   14.648012] hantro-vpu ff350000.video-codec: Adding to iommu group 2
  4935    [   14.648878] hantro-vpu ff350000.video-codec: registered rockchip,rk3328-vpu-dec as /dev/video2
  4936    [   14.681903] rk3328-codec ff410000.codec: spk_depop_time use default value.
  4937    [   14.725800] systemd[1]: Listening on systemd-rfkill.socket - Load/Save RF Kill Switch Status /dev/rfkill Watch.
  4938    [   14.737395] cfg80211: Loading compiled-in X.509 certificates for regulatory database
  4939    [   14.744714] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
  4940    [   14.808500] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
  4941    [   14.834379] systemd[1]: Reached target sound.target - Sound Card.
  4942    [   14.881690] brcmfmac: F1 signature read @0x18000000=0x16034334
  4943    [   14.885473] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4334-sdio for chip BCM4334/3
  4944    [   14.886108] usbcore: registered new interface driver brcmfmac
  4945    [   14.888906] brcmfmac mmc4:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.rockchip,rk3318-box.bin failed with error -2
  4946    [   14.919845] brcmfmac mmc4:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.clm_blob failed with error -2
  4947    [   15.023564] random: crng init done
  4948    [   15.064331] systemd[1]: Finished systemd-random-seed.service - Load/Save Random Seed.
  4949    [   15.066036] systemd[1]: first-boot-complete.target - First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes).
  4950    [   15.066311] systemd[1]: systemd-machine-id-commit.service - Commit a transient machine-id on disk was skipped because of an unmet condition check (ConditionPathIsMountPoint=/etc/machine-id).
  4951    [   15.130330] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
  4952    [   15.130789] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4334/3 wl0: Jul 24 2019 12:58:36 version 6.10.191 (TOB) (r) FWID 01-b049404e
  4953    [   15.164657] systemd[1]: Starting systemd-rfkill.service - Load/Save RF Kill Switch Status...
  4954    [   15.179680] Adding 2034920k swap on /dev/zram0.  Priority:5 extents:1 across:2034920k SSFS
  4955    [   15.294278] systemd[1]: Started systemd-rfkill.service - Load/Save RF Kill Switch Status.
  4956    [   15.514078] zram1: detected capacity change from 0 to 102400
  4957    [   15.688976] systemd[1]: Finished armbian-zram-config.service - Armbian ZRAM config.
  4958    [   15.721094] systemd[1]: Starting armbian-ramlog.service - Armbian memory supported logging...
  4959    [   15.858496] EXT4-fs (zram1): mounted filesystem without journal. Quota mode: none.
  4960    [   20.292667] systemd[1]: systemd-rfkill.service: Deactivated successfully.
  4961    [   20.298307] systemd[1]: Finished armbian-ramlog.service - Armbian memory supported logging.
  4962    [   20.344893] systemd[1]: Starting systemd-journald.service - Journal Service...
  4963    [   20.687832] systemd[1]: Started systemd-journald.service - Journal Service.
  4964    [   20.768499] systemd-journald[554]: Received client request to flush runtime journal.
  4965    [   20.773465] systemd-journald[554]: File /var/log/journal/748f963f03bc4ff19142d0aa9df990a2/system.journal corrupted or uncleanly shut down, renaming and replacing.
  4966
  4967    ### armbian-release:
  4968
  4969    # PLEASE DO NOT EDIT THIS FILE
  4970    BOARD=rk3318-box
  4971    BOARD_NAME="RK3318 Box"
  4972    BOARDFAMILY=rockchip64
  4973    BUILD_REPOSITORY_URL=https://github.com/armbian/build
  4974    BUILD_REPOSITORY_COMMIT=313c893
  4975    VERSION=23.02.0-trunk
  4976    LINUXFAMILY=rockchip64
  4977    ARCH=arm64
  4978    IMAGE_TYPE=nightly
  4979    BOARD_TYPE=tvb
  4980    INITRD_ARCH=arm64
  4981    KERNEL_IMAGE_TYPE=Image
  4982
  4983    ### boot environment:
  4984
  4985    verbosity=1
  4986    bootlogo=false
  4987    overlay_prefix=rockchip
  4988    fdtfile=rockchip/rk3318-box.dtb
  4989    rootdev=UUID=2eb1e931-b16f-46a3-8b3b-f0a92acc8ddb
  4990    rootfstype=ext4
  4991    overlays=rk3318-box-led-conf2
  4992
  4993    ### lsusb:
  4994
  4995    Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  4996    Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  4997    Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  4998    Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  4999    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  5000
  5001    ### lscpu:
  5002
  5003    Architecture:                    aarch64
  5004    CPU op-mode(s):                  32-bit, 64-bit
  5005    Byte Order:                      Little Endian
  5006    CPU(s):                          4
  5007    On-line CPU(s) list:             0-3
  5008    Vendor ID:                       ARM
  5009    Model name:                      Cortex-A53
  5010    Model:                           4
  5011    Thread(s) per core:              1
  5012    Core(s) per cluster:             4
  5013    Socket(s):                       -
  5014    Cluster(s):                      1
  5015    Stepping:                        r0p4
  5016    CPU(s) scaling MHz:              100%
  5017    CPU max MHz:                     1008.0000
  5018    CPU min MHz:                     600.0000
  5019    BogoMIPS:                        48.00
  5020    Flags:                           fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  5021    NUMA node(s):                    1
  5022    NUMA node0 CPU(s):               0-3
  5023    Vulnerability Itlb multihit:     Not affected
  5024    Vulnerability L1tf:              Not affected
  5025    Vulnerability Mds:               Not affected
  5026    Vulnerability Meltdown:          Not affected
  5027    Vulnerability Mmio stale data:   Not affected
  5028    Vulnerability Retbleed:          Not affected
  5029    Vulnerability Spec store bypass: Not affected
  5030    Vulnerability Spectre v1:        Mitigation; __user pointer sanitization
  5031    Vulnerability Spectre v2:        Not affected
  5032    Vulnerability Srbds:             Not affected
  5033    Vulnerability Tsx async abort:   Not affected
  5034
  5035    ### cpuinfo:
  5036
  5037    processor    : 0
  5038    BogoMIPS    : 48.00
  5039    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  5040    CPU implementer    : 0x41
  5041    CPU architecture: 8
  5042    CPU variant    : 0x0
  5043    CPU part    : 0xd03
  5044    CPU revision    : 4
  5045
  5046    processor    : 1
  5047    BogoMIPS    : 48.00
  5048    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  5049    CPU implementer    : 0x41
  5050    CPU architecture: 8
  5051    CPU variant    : 0x0
  5052    CPU part    : 0xd03
  5053    CPU revision    : 4
  5054
  5055    processor    : 2
  5056    BogoMIPS    : 48.00
  5057    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  5058    CPU implementer    : 0x41
  5059    CPU architecture: 8
  5060    CPU variant    : 0x0
  5061    CPU part    : 0xd03
  5062    CPU revision    : 4
  5063
  5064    processor    : 3
  5065    BogoMIPS    : 48.00
  5066    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  5067    CPU implementer    : 0x41
  5068    CPU architecture: 8
  5069    CPU variant    : 0x0
  5070    CPU part    : 0xd03
  5071    CPU revision    : 4
  5072
  5073
  5074    ### meminfo:
  5075
  5076    MemTotal:        4069844 kB
  5077    MemFree:         3880412 kB
  5078    MemAvailable:    3885296 kB
  5079    Buffers:            8992 kB
  5080    Cached:            52652 kB
  5081    SwapCached:            0 kB
  5082    Active:            50180 kB
  5083    Inactive:          22428 kB
  5084    Active(anon):      13944 kB
  5085    Inactive(anon):      788 kB
  5086    Active(file):      36236 kB
  5087    Inactive(file):    21640 kB
  5088    Unevictable:        2988 kB
  5089    Mlocked:               0 kB
  5090    SwapTotal:       2034920 kB
  5091    SwapFree:        2034920 kB
  5092    Zswap:                 0 kB
  5093    Zswapped:              0 kB
  5094    Dirty:               372 kB
  5095    Writeback:             0 kB
  5096    AnonPages:         14020 kB
  5097    Mapped:            16888 kB
  5098    Shmem:               720 kB
  5099    KReclaimable:      17916 kB
  5100    Slab:              48756 kB
  5101    SReclaimable:      17916 kB
  5102    SUnreclaim:        30840 kB
  5103    KernelStack:        2216 kB
  5104    PageTables:         1160 kB
  5105    SecPageTables:         0 kB
  5106    NFS_Unstable:          0 kB
  5107    Bounce:                0 kB
  5108    WritebackTmp:          0 kB
  5109    CommitLimit:     4069840 kB
  5110    Committed_AS:      52316 kB
  5111    VmallocTotal:   133143592960 kB
  5112    VmallocUsed:       28384 kB
  5113    VmallocChunk:          0 kB
  5114    Percpu:             1056 kB
  5115    AnonHugePages:         0 kB
  5116    ShmemHugePages:        0 kB
  5117    ShmemPmdMapped:        0 kB
  5118    FileHugePages:         0 kB
  5119    FilePmdMapped:         0 kB
  5120    CmaTotal:         131072 kB
  5121    CmaFree:          122368 kB
  5122    HugePages_Total:       0
  5123    HugePages_Free:        0
  5124    HugePages_Rsvd:        0
  5125    HugePages_Surp:        0
  5126    Hugepagesize:       2048 kB
  5127    Hugetlb:               0 kB
  5128
  5129    ### virtual memory:
  5130
  5131    vm.admin_reserve_kbytes = 8192
  5132    vm.compaction_proactiveness = 20
  5133    vm.compact_unevictable_allowed = 1
  5134    vm.dirty_background_bytes = 0
  5135    vm.dirty_background_ratio = 10
  5136    vm.dirty_bytes = 0
  5137    vm.dirty_expire_centisecs = 3000
  5138    vm.dirty_ratio = 20
  5139    vm.dirtytime_expire_seconds = 43200
  5140    vm.dirty_writeback_centisecs = 500
  5141    vm.extfrag_threshold = 500
  5142    vm.hugetlb_optimize_vmemmap = 0
  5143    vm.hugetlb_shm_group = 0
  5144    vm.laptop_mode = 0
  5145    vm.legacy_va_layout = 0
  5146    vm.lowmem_reserve_ratio = 256    256    32    0
  5147    vm.max_map_count = 65530
  5148    vm.min_free_kbytes = 22528
  5149    vm.min_slab_ratio = 5
  5150    vm.min_unmapped_ratio = 1
  5151    vm.mmap_min_addr = 4096
  5152    vm.mmap_rnd_bits = 18
  5153    vm.mmap_rnd_compat_bits = 11
  5154    vm.nr_hugepages = 0
  5155    vm.nr_hugepages_mempolicy = 0
  5156    vm.nr_overcommit_hugepages = 0
  5157    vm.numa_stat = 1
  5158    vm.numa_zonelist_order = Node
  5159    vm.oom_dump_tasks = 1
  5160    vm.oom_kill_allocating_task = 0
  5161    vm.overcommit_kbytes = 0
  5162    vm.overcommit_memory = 0
  5163    vm.overcommit_ratio = 50
  5164    vm.page-cluster = 0
  5165    vm.page_lock_unfairness = 5
  5166    vm.panic_on_oom = 0
  5167    vm.percpu_pagelist_high_fraction = 0
  5168    vm.stat_interval = 1
  5169    vm.swappiness = 100
  5170    vm.user_reserve_kbytes = 125902
  5171    vm.vfs_cache_pressure = 100
  5172    vm.watermark_boost_factor = 15000
  5173    vm.watermark_scale_factor = 10
  5174    vm.zone_reclaim_mode = 0
  5175
  5176    ### ip addr:
  5177
  5178    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  5179        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  5180        inet XXX.XXX.0.1/8 scope host lo
  5181           valid_lft forever preferred_lft forever
  5182        inet6 ::1/128 scope host
  5183           valid_lft forever preferred_lft forever
  5184    2: end1: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  5185        link/ether 52:d1:50:3d:d5:78 brd ff:ff:ff:ff:ff:ff
  5186    3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  5187        link/ether 20:02:af:49:e2:d5 brd ff:ff:ff:ff:ff:ff
  5188
  5189    ### partitions:
  5190
  5191    major minor  #blocks  name
  5192
  5193     179        0   15558144 mmcblk0
  5194     179        1   15384576 mmcblk0p1
  5195     179       32   61071360 mmcblk2
  5196     179       64       4096 mmcblk2boot0
  5197     179       96       4096 mmcblk2boot1
  5198     252        0    2034924 zram0
  5199     252        1      51200 zram1
  5200
  5201    ### df:
  5202
  5203    udev            1.9G     0  1.9G   0% /dev
  5204    tmpfs           398M  5.7M  392M   2% /run
  5205    /dev/mmcblk0p1   15G  1.5G   13G  11% /
  5206    tmpfs           2.0G     0  2.0G   0% /dev/shm
  5207    tmpfs           5.0M     0  5.0M   0% /run/lock
  5208    tmpfs           2.0G     0  2.0G   0% /tmp
  5209    /dev/zram1       47M  2.0M   42M   5% /var/log
  5210
  5211    ### lsblk:
  5212
  5213    NAME         FSTYPE  SIZE MOUNTPOINT UUID
  5214    mmcblk0             14.8G
  5215    └─mmcblk0p1  ext4   14.7G /          2eb1e931-b16f-46a3-8b3b-f0a92acc8ddb
  5216    mmcblk2             58.2G
  5217    mmcblk2boot0           4M
  5218    mmcblk2boot1           4M
  5219    zram1                 50M /var/log
  5220    zram2                  0B
  5221
  5222    ### zramctl:
  5223
  5224    NAME       ALGORITHM DISKSIZE  DATA  COMPR TOTAL STREAMS MOUNTPOINT
  5225    /dev/zram1 zstd           50M  1.8M 395.8K  716K       4 /var/log
  5226    /dev/zram0 lzo-rle       1.9G    4K    74B   12K       4 [SWAP]
  5227
  5228    ### mtab:
  5229
  5230    /dev/mmcblk0p1 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0
  5231    /dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0
  5232    /dev/zram1 /var/log ext4 rw,relatime,discard 0 0
  5233
  5234    ### mmc0:8dfc info:
  5235
  5236                   fwrev: 0x0
  5237                  uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SU16G MODALIAS=mmc:block
  5238                     cid: 03534453553136478060b5bf4000a609
  5239                     rca: 0x8dfc
  5240                     csd: 400e00325b59000076b27f800a404013
  5241                  manfid: 0x000003
  5242                     ocr: 0x00300000
  5243    preferred_erase_size: 4194304
  5244                    type: SD
  5245                   hwrev: 0x8
  5246                    date: 06/2010
  5247                     dsr: 0x404
  5248              erase_size: 512
  5249                   oemid: 0x5344
  5250                  serial: 0x60b5bf40
  5251                     ssr: 0000000004000000010190000b050000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  5252                     scr: 0235800000000000
  5253                    name: SU16G
  5254
  5255    ### mmc2:0001 info:
  5256
  5257                   fwrev: 0x0500000000000000
  5258                  uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=CKTM4R MODALIAS=mmc:block
  5259                     cid: 150100434b544d345202a448f479c3a1
  5260             rel_sectors: 0x1
  5261    enhanced_rpmb_supported: 0x1
  5262                     rca: 0x0001
  5263            pre_eol_info: 0x01
  5264                     csd: d02701320f5903fff6dbffef8e40400d
  5265                  manfid: 0x000015
  5266                     ocr: 0x00300000
  5267    preferred_erase_size: 4194304
  5268    enhanced_area_offset: 18446744073709551594
  5269      raw_rpmb_size_mult: 0x20
  5270                    type: MMC
  5271                   hwrev: 0x0
  5272                    date: 12/2016
  5273                     prv: 0x2
  5274             ffu_capable: 1
  5275                     dsr: 0x404
  5276              erase_size: 524288
  5277               life_time: 0x01 0x01
  5278      enhanced_area_size: 4294967274
  5279                   oemid: 0x0100
  5280                  serial: 0xa448f479
  5281                 cmdq_en: 0
  5282                     rev: 0x8
  5283                    name: CKTM4R
  5284
  5285    ### Boot system health:
  5286
  5287    Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU  C.St.
  5288    21:17:14: 1008MHz  0.71  49%  23%  12%   0%  13%   0% 60.4 °C  0/3
  5289    21:17:14: 1008MHz  0.71  90%  27%  21%   0%  41%   0% 60.8 °C  0/3
  5290    21:17:14:  816MHz  0.71  66%  11%   9%   1%  44%   0% 58.6 °C  0/3
  5291    21:17:15:  816MHz  0.71  63%   7%   6%   1%  47%   0% 57.7 °C  0/3
  5292    21:17:15:  816MHz  0.71  64%  14%  10%   0%  37%   0% 58.2 °C  0/3
  5293
  5294    ### Activated 1 lzo-rle zram swap devices with 1987MB each.
  5295    ### Activated Armbian ramlog partition with zstd compression
  5296
  5297    Thu Mar 30 02:30:51 PM MSK 2023 | RK3318 Box | 23.02.0-trunk | arm64 | aarch64 | 6.1.11-rockchip64
  5298
  5299    ### dmesg:
  5300
  5301    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
  5302    [    0.000000] Linux version 6.1.11-rockchip64 (root@7284a09ced08) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #trunk.0248 SMP PREEMPT Fri Feb 10 05:25:40 UTC 2023
  5303    [    0.000000] Machine model: Rockchip RK3318 BOX
  5304    [    0.000000] efi: UEFI not found.
  5305    [    0.000000] NUMA: No NUMA configuration found
  5306    [    0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x00000000feffffff]
  5307    [    0.000000] NUMA: NODE_DATA [mem 0xfe7b1a80-0xfe7b3fff]
  5308    [    0.000000] Zone ranges:
  5309    [    0.000000]   DMA      [mem 0x0000000000200000-0x00000000feffffff]
  5310    [    0.000000]   DMA32    empty
  5311    [    0.000000]   Normal   empty
  5312    [    0.000000] Movable zone start for each node
  5313    [    0.000000] Early memory node ranges
  5314    [    0.000000]   node   0: [mem 0x0000000000200000-0x00000000feffffff]
  5315    [    0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000000feffffff]
  5316    [    0.000000] On node 0, zone DMA: 512 pages in unavailable ranges
  5317    [    0.000000] On node 0, zone DMA: 4096 pages in unavailable ranges
  5318    [    0.000000] cma: Reserved 128 MiB at 0x00000000f2600000
  5319    [    0.000000] psci: probing for conduit method from DT.
  5320    [    0.000000] psci: PSCIv1.1 detected in firmware.
  5321    [    0.000000] psci: Using standard PSCI v0.2 function IDs
  5322    [    0.000000] psci: MIGRATE_INFO_TYPE not supported.
  5323    [    0.000000] psci: SMC Calling Convention v1.2
  5324    [    0.000000] percpu: Embedded 30 pages/cpu s82472 r8192 d32216 u122880
  5325    [    0.000000] pcpu-alloc: s82472 r8192 d32216 u122880 alloc=30*4096
  5326    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
  5327    [    0.000000] Detected VIPT I-cache on CPU0
  5328    [    0.000000] CPU features: detected: ARM erratum 845719
  5329    [    0.000000] alternatives: applying boot alternatives
  5330    [    0.000000] Fallback order for Node 0: 0
  5331    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1027656
  5332    [    0.000000] Policy zone: DMA
  5333    [    0.000000] Kernel command line: root=UUID=2eb1e931-b16f-46a3-8b3b-f0a92acc8ddb rootwait rootfstype=ext4 splash=verbose console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=7 ubootpart=8635553d-01 usb-storage.quirks=   cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
  5334    [    0.000000] The swapaccount= commandline option is deprecated. Please report your usecase to linux-mm@kvack.org if you depend on this functionality.
  5335    [    0.000000] Unknown kernel command line parameters "splash=verbose ubootpart=8635553d-01 cgroup_enable=memory cgroup_memory=1", will be passed to user space.
  5336    [    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
  5337    [    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
  5338    [    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
  5339    [    0.000000] Memory: 3913516K/4175872K available (16448K kernel code, 2240K rwdata, 5832K rodata, 3968K init, 585K bss, 131284K reserved, 131072K cma-reserved)
  5340    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
  5341    [    0.000000] trace event string verifier disabled
  5342    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
  5343    [    0.000000] rcu:     RCU event tracing is enabled.
  5344    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
  5345    [    0.000000]     Trampoline variant of Tasks RCU enabled.
  5346    [    0.000000]     Tracing variant of Tasks RCU enabled.
  5347    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
  5348    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
  5349    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
  5350    [    0.000000] Root IRQ handler: gic_handle_irq
  5351    [    0.000000] GIC: Using split EOI/Deactivate mode
  5352    [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
  5353    [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
  5354    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  5355    [    0.000002] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  5356    [    0.001070] Console: colour dummy device 80x25
  5357    [    0.002024] printk: console [tty1] enabled
  5358    [    0.002155] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
  5359    [    0.002207] pid_max: default: 32768 minimum: 301
  5360    [    0.002375] LSM: Security Framework initializing
  5361    [    0.002443] Yama: becoming mindful.
  5362    [    0.002622] AppArmor: AppArmor initialized
  5363    [    0.002686] Stack Depot allocating hash table of 262144 entries with kvcalloc
  5364    [    0.003361] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
  5365    [    0.003426] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
  5366    [    0.006777] cblist_init_generic: Setting adjustable number of callback queues.
  5367    [    0.006836] cblist_init_generic: Setting shift to 2 and lim to 1.
  5368    [    0.007048] cblist_init_generic: Setting shift to 2 and lim to 1.
  5369    [    0.007510] rcu: Hierarchical SRCU implementation.
  5370    [    0.007540] rcu:     Max phase no-delay instances is 1000.
  5371    [    0.011171] EFI services will not be available.
  5372    [    0.011981] smp: Bringing up secondary CPUs ...
  5373    [    0.013197] Detected VIPT I-cache on CPU1
  5374    [    0.013390] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
  5375    [    0.014743] Detected VIPT I-cache on CPU2
  5376    [    0.014935] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
  5377    [    0.016381] Detected VIPT I-cache on CPU3
  5378    [    0.016579] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
  5379    [    0.016788] smp: Brought up 1 node, 4 CPUs
  5380    [    0.016925] SMP: Total of 4 processors activated.
  5381    [    0.016953] CPU features: detected: 32-bit EL0 Support
  5382    [    0.016977] CPU features: detected: 32-bit EL1 Support
  5383    [    0.017005] CPU features: detected: CRC32 instructions
  5384    [    0.017150] CPU: All CPU(s) started at EL2
  5385    [    0.017192] alternatives: applying system-wide alternatives
  5386    [    0.020825] devtmpfs: initialized
  5387    [    0.044628] Registered cp15_barrier emulation handler
  5388    [    0.044688] Registered setend emulation handler
  5389    [    0.045160] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  5390    [    0.045240] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
  5391    [    0.050850] pinctrl core: initialized pinctrl subsystem
  5392    [    0.052201] DMI not present or invalid.
  5393    [    0.053453] NET: Registered PF_NETLINK/PF_ROUTE protocol family
  5394    [    0.056496] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
  5395    [    0.057971] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
  5396    [    0.059226] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
  5397    [    0.059381] audit: initializing netlink subsys (disabled)
  5398    [    0.059797] audit: type=2000 audit(0.056:1): state=initialized audit_enabled=0 res=1
  5399    [    0.061287] thermal_sys: Registered thermal governor 'fair_share'
  5400    [    0.061303] thermal_sys: Registered thermal governor 'bang_bang'
  5401    [    0.061340] thermal_sys: Registered thermal governor 'step_wise'
  5402    [    0.061367] thermal_sys: Registered thermal governor 'user_space'
  5403    [    0.061504] cpuidle: using governor menu
  5404    [    0.062150] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  5405    [    0.062397] ASID allocator initialised with 65536 entries
  5406    [    0.064318] Serial: AMBA PL011 UART driver
  5407    [    0.083325] platform ff3c0000.hdmi: Fixing up cyclic dependency with ff370000.vop
  5408    [    0.109923] rockchip-gpio ff210000.gpio: probed /pinctrl/gpio@ff210000
  5409    [    0.111398] rockchip-gpio ff220000.gpio: probed /pinctrl/gpio@ff220000
  5410    [    0.112744] rockchip-gpio ff230000.gpio: probed /pinctrl/gpio@ff230000
  5411    [    0.114047] rockchip-gpio ff240000.gpio: probed /pinctrl/gpio@ff240000
  5412    [    0.152751] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
  5413    [    0.152804] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
  5414    [    0.152839] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
  5415    [    0.152867] HugeTLB: 508 KiB vmemmap can be freed for a 32.0 MiB page
  5416    [    0.152941] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
  5417    [    0.152971] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
  5418    [    0.153000] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
  5419    [    0.153029] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
  5420    [    0.154877] cryptd: max_cpu_qlen set to 1000
  5421    [    0.221148] raid6: neonx8   gen()  1036 MB/s
  5422    [    0.289357] raid6: neonx4   gen()  1062 MB/s
  5423    [    0.357589] raid6: neonx2   gen()   984 MB/s
  5424    [    0.425708] raid6: neonx1   gen()   879 MB/s
  5425    [    0.493868] raid6: int64x8  gen()   744 MB/s
  5426    [    0.562020] raid6: int64x4  gen()   823 MB/s
  5427    [    0.630166] raid6: int64x2  gen()   707 MB/s
  5428    [    0.698333] raid6: int64x1  gen()   526 MB/s
  5429    [    0.698366] raid6: using algorithm neonx4 gen() 1062 MB/s
  5430    [    0.766455] raid6: .... xor() 770 MB/s, rmw enabled
  5431    [    0.766485] raid6: using neon recovery algorithm
  5432    [    0.773371] iommu: Default domain type: Translated
  5433    [    0.773420] iommu: DMA domain TLB invalidation policy: strict mode
  5434    [    0.774371] SCSI subsystem initialized
  5435    [    0.774755] libata version 3.00 loaded.
  5436    [    0.775320] usbcore: registered new interface driver usbfs
  5437    [    0.775446] usbcore: registered new interface driver hub
  5438    [    0.775555] usbcore: registered new device driver usb
  5439    [    0.776629] pps_core: LinuxPPS API ver. 1 registered
  5440    [    0.776664] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  5441    [    0.776723] PTP clock support registered
  5442    [    0.777170] EDAC MC: Ver: 3.0.0
  5443    [    0.780161] NetLabel: Initializing
  5444    [    0.780203] NetLabel:  domain hash size = 128
  5445    [    0.780228] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
  5446    [    0.780372] NetLabel:  unlabeled traffic allowed by default
  5447    [    0.780709] vgaarb: loaded
  5448    [    0.781680] clocksource: Switched to clocksource arch_sys_counter
  5449    [    0.782690] VFS: Disk quotas dquot_6.6.0
  5450    [    0.782937] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  5451    [    0.784535] AppArmor: AppArmor Filesystem Enabled
  5452    [    0.801990] NET: Registered PF_INET protocol family
  5453    [    0.802450] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
  5454    [    0.808773] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
  5455    [    0.809062] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
  5456    [    0.809195] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
  5457    [    0.809929] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
  5458    [    0.811347] TCP: Hash tables configured (established 32768 bind 32768)
  5459    [    0.811621] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
  5460    [    0.811831] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
  5461    [    0.812339] NET: Registered PF_UNIX/PF_LOCAL protocol family
  5462    [    0.812431] NET: Registered PF_XDP protocol family
  5463    [    0.812469] PCI: CLS 0 bytes, default 64
  5464    [    0.813357] Trying to unpack rootfs image as initramfs...
  5465    [    0.823524] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
  5466    [    0.824683] kvm [1]: IPA Size Limit: 40 bits
  5467    [    0.827186] kvm [1]: vgic interrupt IRQ9
  5468    [    0.827479] kvm [1]: Hyp mode initialized successfully
  5469    [    0.831606] Initialise system trusted keyrings
  5470    [    0.831755] Key type blacklist registered
  5471    [    0.832213] workingset: timestamp_bits=44 max_order=20 bucket_order=0
  5472    [    0.846967] zbud: loaded
  5473    [    0.850558] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  5474    [    0.852134] fuse: init (API version 7.37)
  5475    [    0.857040] integrity: Platform Keyring initialized
  5476    [    0.928646] xor: measuring software checksum speed
  5477    [    0.936848]    8regs           :  1221 MB/sec
  5478    [    0.944769]    32regs          :  1261 MB/sec
  5479    [    0.954099]    arm64_neon      :  1062 MB/sec
  5480    [    0.954144] xor: using function: 32regs (1261 MB/sec)
  5481    [    0.954183] Key type asymmetric registered
  5482    [    0.954211] Asymmetric key parser 'x509' registered
  5483    [    2.899901] Freeing initrd memory: 21288K
  5484    [    2.944029] alg: self-tests for CTR-KDF (hmac(sha256)) passed
  5485    [    2.944199] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
  5486    [    2.944482] io scheduler mq-deadline registered
  5487    [    2.944517] io scheduler kyber registered
  5488    [    2.944967] io scheduler bfq registered
  5489    [    2.963902] dma-pl330 ff1f0000.dma-controller: Loaded driver for PL330 DMAC-241330
  5490    [    2.963966] dma-pl330 ff1f0000.dma-controller:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
  5491    [    2.972678] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
  5492    [    2.978568] ff110000.serial: ttyS0 at MMIO 0xff110000 (irq = 25, base_baud = 1500000) is a 16550A
  5493    [    2.980504] ff130000.serial: ttyS2 at MMIO 0xff130000 (irq = 26, base_baud = 1500000) is a 16550A
  5494    [    3.079659] printk: console [ttyS2] enabled
  5495    [    3.082169] Serial: AMBA driver
  5496    [    3.090987] rockchip-vop ff370000.vop: Adding to iommu group 4
  5497    [    3.117500] loop: module loaded
  5498    [    3.126559] tun: Universal TUN/TAP device driver, 1.6
  5499    [    3.128884] thunder_xcv, ver 1.0
  5500    [    3.129292] thunder_bgx, ver 1.0
  5501    [    3.129740] nicpf, ver 1.0
  5502    [    3.131502] e1000e: Intel(R) PRO/1000 Network Driver
  5503    [    3.131972] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
  5504    [    3.132622] igb: Intel(R) Gigabit Ethernet Network Driver
  5505    [    3.133128] igb: Copyright (c) 2007-2014 Intel Corporation.
  5506    [    3.133742] igbvf: Intel(R) Gigabit Virtual Function Network Driver
  5507    [    3.134326] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
  5508    [    3.135335] sky2: driver version 1.30
  5509    [    3.136822] VFIO - User Level meta-driver version: 0.3
  5510    [    3.141109] dwc2 ff580000.usb: supply vusb_d not found, using dummy regulator
  5511    [    3.142122] dwc2 ff580000.usb: supply vusb_a not found, using dummy regulator
  5512    [    3.155930] dwc2 ff580000.usb: DWC OTG Controller
  5513    [    3.156430] dwc2 ff580000.usb: new USB bus registered, assigned bus number 1
  5514    [    3.157131] dwc2 ff580000.usb: irq 34, io mem 0xff580000
  5515    [    3.158035] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
  5516    [    3.158808] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  5517    [    3.159477] usb usb1: Product: DWC OTG Controller
  5518    [    3.159920] usb usb1: Manufacturer: Linux 6.1.11-rockchip64 dwc2_hsotg
  5519    [    3.160523] usb usb1: SerialNumber: ff580000.usb
  5520    [    3.162137] hub 1-0:1.0: USB hub found
  5521    [    3.162569] hub 1-0:1.0: 1 port detected
  5522    [    3.167322] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  5523    [    3.167885] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
  5524    [    3.168349] ehci-platform ff5c0000.usb: EHCI Host Controller
  5525    [    3.168376] ohci-platform ff5d0000.usb: Generic Platform OHCI controller
  5526    [    3.168412] ohci-platform ff5d0000.usb: new USB bus registered, assigned bus number 3
  5527    [    3.168661] ohci-platform ff5d0000.usb: irq 36, io mem 0xff5d0000
  5528    [    3.168827] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
  5529    [    3.168923] xhci-hcd xhci-hcd.0.auto: irq 33, io mem 0xff600000
  5530    [    3.169128] ehci-platform ff5c0000.usb: new USB bus registered, assigned bus number 4
  5531    [    3.169427] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  5532    [    3.169455] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 5
  5533    [    3.169479] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
  5534    [    3.170084] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
  5535    [    3.170674] ehci-platform ff5c0000.usb: irq 35, io mem 0xff5c0000
  5536    [    3.171007] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  5537    [    3.176835] usb usb2: Product: xHCI Host Controller
  5538    [    3.177294] usb usb2: Manufacturer: Linux 6.1.11-rockchip64 xhci-hcd
  5539    [    3.177908] usb usb2: SerialNumber: xhci-hcd.0.auto
  5540    [    3.179476] hub 2-0:1.0: USB hub found
  5541    [    3.179903] hub 2-0:1.0: 1 port detected
  5542    [    3.181059] usb usb5: We don't know the algorithms for LPM for this host, disabling LPM.
  5543    [    3.182095] usb usb5: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
  5544    [    3.182871] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  5545    [    3.183541] usb usb5: Product: xHCI Host Controller
  5546    [    3.183998] usb usb5: Manufacturer: Linux 6.1.11-rockchip64 xhci-hcd
  5547    [    3.184586] usb usb5: SerialNumber: xhci-hcd.0.auto
  5548    [    3.185722] ehci-platform ff5c0000.usb: USB 2.0 started, EHCI 1.00
  5549    [    3.186188] hub 5-0:1.0: USB hub found
  5550    [    3.186713] hub 5-0:1.0: 1 port detected
  5551    [    3.188058] usbcore: registered new interface driver usb-storage
  5552    [    3.188128] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
  5553    [    3.189379] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  5554    [    3.190092] usb usb4: Product: EHCI Host Controller
  5555    [    3.190558] usb usb4: Manufacturer: Linux 6.1.11-rockchip64 ehci_hcd
  5556    [    3.191151] usb usb4: SerialNumber: ff5c0000.usb
  5557    [    3.192228] mousedev: PS/2 mouse device common for all mice
  5558    [    3.192549] hub 4-0:1.0: USB hub found
  5559    [    3.193167] hub 4-0:1.0: 1 port detected
  5560    [    3.194465] i2c_dev: i2c /dev entries driver
  5561    [    3.199712] dw_wdt ff1a0000.watchdog: No valid TOPs array specified
  5562    [    3.204314] sdhci: Secure Digital Host Controller Interface driver
  5563    [    3.204905] sdhci: Copyright(c) Pierre Ossman
  5564    [    3.205359] Synopsys Designware Multimedia Card Interface Driver
  5565    [    3.207594] sdhci-pltfm: SDHCI platform and OF driver helper
  5566    [    3.208587] dwmmc_rockchip ff500000.mmc: IDMAC supports 32-bit address mode.
  5567    [    3.208600] dwmmc_rockchip ff520000.mmc: IDMAC supports 32-bit address mode.
  5568    [    3.208645] dwmmc_rockchip ff520000.mmc: Using internal DMA controller.
  5569    [    3.209292] dwmmc_rockchip ff500000.mmc: Using internal DMA controller.
  5570    [    3.209775] dwmmc_rockchip ff5f0000.mmc: IDMAC supports 32-bit address mode.
  5571    [    3.209824] dwmmc_rockchip ff5f0000.mmc: Using internal DMA controller.
  5572    [    3.209841] dwmmc_rockchip ff5f0000.mmc: Version ID is 270a
  5573    [    3.209936] dwmmc_rockchip ff5f0000.mmc: DW MMC controller at irq 41,32 bit host data width,256 deep fifo
  5574    [    3.209939] dwmmc_rockchip ff520000.mmc: Version ID is 270a
  5575    [    3.209970] dwmmc_rockchip ff500000.mmc: Version ID is 270a
  5576    [    3.210016] dwmmc_rockchip ff520000.mmc: DW MMC controller at irq 39,32 bit host data width,256 deep fifo
  5577    [    3.210413] dwmmc_rockchip ff5f0000.mmc: allocated mmc-pwrseq
  5578    [    3.210430] mmc_host mmc4: card is non-removable.
  5579    [    3.210680] dwmmc_rockchip ff500000.mmc: DW MMC controller at irq 40,32 bit host data width,256 deep fifo
  5580    [    3.212080] mmc_host mmc2: card is non-removable.
  5581    [    3.213043] dwmmc_rockchip ff500000.mmc: Got CD GPIO
  5582    [    3.218448] ledtrig-cpu: registered to indicate activity on CPUs
  5583    [    3.219918] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
  5584    [    3.220953] hid: raw HID events driver (C) Jiri Kosina
  5585    [    3.221969] usbcore: registered new interface driver usbhid
  5586    [    3.222502] usbhid: USB HID core driver
  5587    [    3.223317] mmc_host mmc4: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
  5588    [    3.226840] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
  5589    [    3.231295] drop_monitor: Initializing network drop monitor service
  5590    [    3.231449] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
  5591    [    3.233254] NET: Registered PF_INET6 protocol family
  5592    [    3.234115] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.01
  5593    [    3.234897] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  5594    [    3.235574] usb usb3: Product: Generic Platform OHCI controller
  5595    [    3.236131] usb usb3: Manufacturer: Linux 6.1.11-rockchip64 ohci_hcd
  5596    [    3.236723] usb usb3: SerialNumber: ff5d0000.usb
  5597    [    3.238311] hub 3-0:1.0: USB hub found
  5598    [    3.238778] hub 3-0:1.0: 1 port detected
  5599    [    3.277621] Segment Routing with IPv6
  5600    [    3.278156] In-situ OAM (IOAM) with IPv6
  5601    [    3.278757] NET: Registered PF_PACKET protocol family
  5602    [    3.279528] 8021q: 802.1Q VLAN Support v1.8
  5603    [    3.280021] Key type dns_resolver registered
  5604    [    3.282869] registered taskstats version 1
  5605    [    3.283305] Loading compiled-in X.509 certificates
  5606    [    3.291081] Loaded X.509 cert 'Build time autogenerated kernel key: e25f7f61aa13aedd90bace25454c8646dc5da469'
  5607    [    3.293527] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
  5608    [    3.294850] mmc0: new high speed SDHC card at address 8dfc
  5609    [    3.296188] zswap: loaded using pool zstd/z3fold
  5610    [    3.297316] mmcblk0: mmc0:8dfc SU16G 14.8 GiB
  5611    [    3.297902] Key type .fscrypt registered
  5612    [    3.298348] Key type fscrypt-provisioning registered
  5613    [    3.302977] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=yes
  5614    [    3.304272] Key type encrypted registered
  5615    [    3.304730] AppArmor: AppArmor sha1 policy hashing enabled
  5616    [    3.308244]  mmcblk0: p1
  5617    [    3.328831] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 52000000Hz, actual 50000000HZ div = 0)
  5618    [    3.330632] mmc2: new high speed MMC card at address 0001
  5619    [    3.332719] mmcblk2: mmc2:0001 CKTM4R 58.2 GiB
  5620    [    3.338433] mmcblk2boot0: mmc2:0001 CKTM4R 4.00 MiB
  5621    [    3.343217] mmcblk2boot1: mmc2:0001 CKTM4R 4.00 MiB
  5622    [    3.347381] mmcblk2rpmb: mmc2:0001 CKTM4R 4.00 MiB, chardev (242:0)
  5623    [    3.347595] mmc_host mmc4: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
  5624    [    3.352929] mmc4: new high speed SDIO card at address 0001
  5625    [    3.401566] rockchip-drm display-subsystem: bound ff370000.vop (ops vop_component_ops)
  5626    [    3.402533] dwhdmi-rockchip ff3c0000.hdmi: supply avdd-0v9 not found, using dummy regulator
  5627    [    3.403667] dwhdmi-rockchip ff3c0000.hdmi: supply avdd-1v8 not found, using dummy regulator
  5628    [    3.404994] dwhdmi-rockchip ff3c0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (inno_dw_hdmi_phy2)
  5629    [    3.407159] dwhdmi-rockchip ff3c0000.hdmi: registered DesignWare HDMI I2C bus driver
  5630    [    3.408773] rockchip-drm display-subsystem: bound ff3c0000.hdmi (ops dw_hdmi_rockchip_ops)
  5631    [    3.410867] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 0
  5632    [    3.411772] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
  5633    [    3.412591] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
  5634    [    3.414414] WCN: marlin_init entry!
  5635    [    3.415592] of_cfs_init
  5636    [    3.415902] of_cfs_init: OK
  5637    [    3.419679] Freeing unused kernel memory: 3968K
  5638    [    3.433863] Run /init as init process
  5639    [    3.434229]   with arguments:
  5640    [    3.434242]     /init
  5641    [    3.434257]   with environment:
  5642    [    3.434267]     HOME=/
  5643    [    3.434279]     TERM=linux
  5644    [    3.434290]     splash=verbose
  5645    [    3.434303]     ubootpart=8635553d-01
  5646    [    3.434314]     cgroup_enable=memory
  5647    [    3.434328]     cgroup_memory=1
  5648    [    4.477167] input: adc-keys as /devices/platform/adc-keys/input/input0
  5649    [    4.497795] gpio-syscon ff100000.syscon:gpio: can't read the data register offset!
  5650    [    4.551283] lima ff300000.gpu: gp - mali450 version major 0 minor 0
  5651    [    4.552085] lima ff300000.gpu: pp0 - mali450 version major 0 minor 0
  5652    [    4.552884] lima ff300000.gpu: pp1 - mali450 version major 0 minor 0
  5653    [    4.553565] lima ff300000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
  5654    [    4.554380] lima ff300000.gpu: l2 cache 64K, 4-way, 64byte cache line, 128bit external bus
  5655    [    4.556577] lima ff300000.gpu: bus rate = 491520000
  5656    [    4.557071] lima ff300000.gpu: mod rate = 491520000
  5657    [    4.564990] [drm] Initialized lima 1.1.0 20191231 for ff300000.gpu on minor 1
  5658    [    4.761100] rk_gmac-dwmac ff550000.ethernet: IRQ eth_wake_irq not found
  5659    [    4.761795] rk_gmac-dwmac ff550000.ethernet: IRQ eth_lpi not found
  5660    [    4.762602] rk_gmac-dwmac ff550000.ethernet: PTP uses main clock
  5661    [    4.763630] rk_gmac-dwmac ff550000.ethernet: clock input or output? (output).
  5662    [    4.764327] rk_gmac-dwmac ff550000.ethernet: TX delay(0x30).
  5663    [    4.764873] rk_gmac-dwmac ff550000.ethernet: RX delay(0x10).
  5664    [    4.765445] rk_gmac-dwmac ff550000.ethernet: integrated PHY? (yes).
  5665    [    4.766239] rk_gmac-dwmac ff550000.ethernet: cannot get clock clk_mac_refout
  5666    [    4.768660] rk_gmac-dwmac ff550000.ethernet: cannot get clock clk_mac_speed
  5667    [    4.780182] rk_gmac-dwmac ff550000.ethernet: init for RMII
  5668    [    4.830215] rk_gmac-dwmac ff550000.ethernet: User ID: 0x10, Synopsys ID: 0x35
  5669    [    4.830917] rk_gmac-dwmac ff550000.ethernet:     DWMAC1000
  5670    [    4.831417] rk_gmac-dwmac ff550000.ethernet: DMA HW capability register supported
  5671    [    4.832112] rk_gmac-dwmac ff550000.ethernet: RX Checksum Offload Engine supported
  5672    [    4.832806] rk_gmac-dwmac ff550000.ethernet: COE Type 2
  5673    [    4.833298] rk_gmac-dwmac ff550000.ethernet: TX Checksum insertion supported
  5674    [    4.834051] rk_gmac-dwmac ff550000.ethernet: Wake-Up On Lan supported
  5675    [    4.834827] rk_gmac-dwmac ff550000.ethernet: Normal descriptors
  5676    [    4.835402] rk_gmac-dwmac ff550000.ethernet: Ring mode enabled
  5677    [    4.835952] rk_gmac-dwmac ff550000.ethernet: Enable RX Mitigation via HW Watchdog Timer
  5678    [    4.875743] rk_gmac-dwmac ff550000.ethernet end1: renamed from eth0
  5679    [    4.973232] dw-apb-uart ff130000.serial: forbid DMA for kernel console
  5680    [    5.554968] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Quota mode: none.
  5681    [    7.648300] systemd[1]: System time before build time, advancing clock.
  5682    [    7.727839] systemd[1]: Inserted module 'autofs4'
  5683    [    7.892347] systemd[1]: systemd 252.5-2 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
  5684    [    7.895289] systemd[1]: Detected architecture arm64.
  5685    [    7.920275] systemd[1]: Hostname set to <rk3318-box>.
  5686    [    9.310514] systemd[326]: /usr/lib/systemd/system-generators/netplan failed with exit status 1.
  5687    [   10.610907] systemd[1]: Queued start job for default target graphical.target.
  5688    [   10.643724] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
  5689    [   10.649124] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
  5690    [   10.654307] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
  5691    [   10.658423] systemd[1]: Created slice user.slice - User and Session Slice.
  5692    [   10.660148] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
  5693    [   10.663247] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
  5694    [   10.665161] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
  5695    [   10.667055] systemd[1]: Reached target remote-fs.target - Remote File Systems.
  5696    [   10.668349] systemd[1]: Reached target slices.target - Slice Units.
  5697    [   10.669806] systemd[1]: Reached target swap.target - Swaps.
  5698    [   10.670893] systemd[1]: Reached target time-set.target - System Time Set.
  5699    [   10.672590] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
  5700    [   10.679100] systemd[1]: Listening on syslog.socket - Syslog Socket.
  5701    [   10.681224] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
  5702    [   10.683143] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
  5703    [   10.685990] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
  5704    [   10.688585] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
  5705    [   10.691498] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
  5706    [   10.705612] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
  5707    [   10.707990] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
  5708    [   10.742349] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
  5709    [   10.752671] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
  5710    [   10.763121] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
  5711    [   10.774433] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
  5712    [   10.791742] systemd[1]: Starting fake-hwclock.service - Restore / save the current clock...
  5713    [   10.803039] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
  5714    [   10.815074] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
  5715    [   10.827514] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
  5716    [   10.839911] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
  5717    [   10.852357] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
  5718    [   10.864810] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
  5719    [   10.867167] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
  5720    [   10.892442] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
  5721    [   10.904301] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
  5722    [   10.906611] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
  5723    [   10.917911] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
  5724    [   10.938110] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
  5725    [   10.942859] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
  5726    [   10.947672] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
  5727    [   10.952080] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
  5728    [   10.958013] systemd[1]: Finished fake-hwclock.service - Restore / save the current clock.
  5729    [   10.964801] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
  5730    [   10.971444] systemd[1]: modprobe@configfs.service: Deactivated successfully.
  5731    [   10.974326] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
  5732    [   10.979946] systemd[1]: modprobe@drm.service: Deactivated successfully.
  5733    [   10.984058] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
  5734    [   10.989435] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
  5735    [   10.992654] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
  5736    [   10.997587] systemd[1]: modprobe@fuse.service: Deactivated successfully.
  5737    [   11.001092] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
  5738    [   11.005260] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
  5739    [   11.017390] EXT4-fs (mmcblk0p1): re-mounted. Quota mode: none.
  5740    [   11.039115] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
  5741    [   11.049568] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
  5742    [   11.061054] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables...
  5743    [   11.086404] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
  5744    [   11.090701] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
  5745    [   11.094321] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
  5746    [   11.098289] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
  5747    [   11.123360] systemd[1]: Starting systemd-random-seed.service - Load/Save Random Seed...
  5748    [   11.135101] systemd[1]: Starting systemd-sysusers.service - Create System Users...
  5749    [   11.200550] systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables.
  5750    [   11.286141] systemd[1]: Finished systemd-sysusers.service - Create System Users.
  5751    [   11.335729] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev...
  5752    [   11.534999] systemd[1]: Finished systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev.
  5753    [   11.567346] systemd[1]: Starting systemd-udevd.service - Rule-based Manager for Device Events and Files...
  5754    [   11.572300] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout.
  5755    [   11.576770] systemd[1]: Reached target local-fs-pre.target - Preparation for Local File Systems.
  5756    [   11.646462] systemd[1]: Mounting tmp.mount - /tmp...
  5757    [   11.673438] systemd[1]: Mounted tmp.mount - /tmp.
  5758    [   11.677341] systemd[1]: Reached target local-fs.target - Local File Systems.
  5759    [   11.688816] systemd[1]: Starting armbian-led-state.service - Armbian leds state...
  5760    [   11.711411] systemd[1]: Starting armbian-zram-config.service - Armbian ZRAM config...
  5761    [   11.741813] systemd[1]: Starting console-setup.service - Set console font and keymap...
  5762    [   11.767362] systemd[1]: Starting plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data...
  5763    [   11.852272] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
  5764    [   11.861078] systemd[1]: Finished console-setup.service - Set console font and keymap.
  5765    [   11.867912] systemd[1]: Received SIGRTMIN+20 from PID 292 (plymouthd).
  5766    [   11.916783] systemd[1]: Finished plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data.
  5767    [   11.943182] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 390 (systemd-binfmt)
  5768    [   11.978646] systemd[1]: Mounting proc-sys-fs-binfmt_misc.mount - Arbitrary Executable File Formats File System...
  5769    [   12.045124] systemd[1]: Mounted proc-sys-fs-binfmt_misc.mount - Arbitrary Executable File Formats File System.
  5770    [   12.065603] systemd[1]: Finished systemd-binfmt.service - Set Up Additional Binary Formats.
  5771    [   12.077258] systemd[1]: Finished armbian-led-state.service - Armbian leds state.
  5772    [   12.204885] systemd[1]: Finished systemd-udev-trigger.service - Coldplug All udev Devices.
  5773    [   12.243288] systemd[1]: Starting ifupdown-pre.service - Helper to synchronize boot up for ifupdown...
  5774    [   12.345191] systemd[1]: Finished ifupdown-pre.service - Helper to synchronize boot up for ifupdown.
  5775    [   12.553280] systemd[1]: Started systemd-udevd.service - Rule-based Manager for Device Events and Files.
  5776    [   12.602426] systemd[1]: Starting plymouth-start.service - Show Plymouth Boot Screen...
  5777    [   12.812631] systemd[1]: Started plymouth-start.service - Show Plymouth Boot Screen.
  5778    [   12.816906] systemd[1]: bootsplash-ask-password-console.path - Dispatch Password Requests to Console Directory Watch when bootsplash is active was skipped because of an unmet condition check (ConditionPathExists=/sys/devices/platform/bootsplash.0/enabled).
  5779    [   12.820623] systemd[1]: Started systemd-ask-password-plymouth.path - Forward Password Requests to Plymouth Directory Watch.
  5780    [   12.826433] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
  5781    [   12.827908] systemd[1]: Reached target paths.target - Path Units.
  5782    [   12.870332] systemd[1]: Found device dev-ttyS2.device - /dev/ttyS2.
  5783    [   12.942890] zram: Added device: zram0
  5784    [   12.944457] zram: Added device: zram1
  5785    [   12.948122] zram: Added device: zram2
  5786    [   13.239422] zram0: detected capacity change from 0 to 4069848
  5787    [   13.615084] mc: Linux media interface: v0.10
  5788    [   13.688859] videodev: Linux video capture interface: v2.00
  5789    [   13.961749] rk3328-codec ff410000.codec: spk_depop_time use default value.
  5790    [   13.976618] Registered IR keymap rc-empty
  5791    [   13.977202] rc rc0: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc0
  5792    [   13.978145] rc rc0: lirc_dev: driver gpio_ir_recv registered at minor = 0, raw IR receiver, no transmitter
  5793    [   13.979318] input: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc0/input1
  5794    [   14.077965] rockchip-rga ff390000.rga: HW Version: 0x04.00
  5795    [   14.131547] rockchip_vdec: module is from the staging directory, the quality is unknown, you have been warned.
  5796    [   14.133835] rockchip-rga ff390000.rga: Registered rockchip-rga as /dev/video0
  5797    [   14.168011] hantro-vpu ff350000.video-codec: Adding to iommu group 2
  5798    [   14.174954] hantro-vpu ff350000.video-codec: registered rockchip,rk3328-vpu-dec as /dev/video1
  5799    [   14.201477] rkvdec ff360000.video-codec: Adding to iommu group 3
  5800    [   14.346050] cfg80211: Loading compiled-in X.509 certificates for regulatory database
  5801    [   14.348492] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
  5802    [   14.403771] systemd[1]: Reached target sound.target - Sound Card.
  5803    [   14.405095] systemd[1]: Listening on systemd-rfkill.socket - Load/Save RF Kill Switch Status /dev/rfkill Watch.
  5804    [   14.424198] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
  5805    [   14.494902] brcmfmac: F1 signature read @0x18000000=0x16034334
  5806    [   14.500335] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4334-sdio for chip BCM4334/3
  5807    [   14.501777] usbcore: registered new interface driver brcmfmac
  5808    [   14.504471] brcmfmac mmc4:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.rockchip,rk3318-box.bin failed with error -2
  5809    [   14.536441] brcmfmac mmc4:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.clm_blob failed with error -2
  5810    [   14.677692] random: crng init done
  5811    [   14.716995] systemd[1]: Finished systemd-random-seed.service - Load/Save Random Seed.
  5812    [   14.720553] systemd[1]: first-boot-complete.target - First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes).
  5813    [   14.722345] systemd[1]: systemd-machine-id-commit.service - Commit a transient machine-id on disk was skipped because of an unmet condition check (ConditionPathIsMountPoint=/etc/machine-id).
  5814    [   14.749334] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
  5815    [   14.750802] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4334/3 wl0: Jul 24 2019 12:58:36 version 6.10.191 (TOB) (r) FWID 01-b049404e
  5816    [   14.790666] systemd[1]: Starting systemd-rfkill.service - Load/Save RF Kill Switch Status...
  5817    [   14.853759] Adding 2034920k swap on /dev/zram0.  Priority:5 extents:1 across:2034920k SSFS
  5818    [   14.898782] systemd[1]: Started systemd-rfkill.service - Load/Save RF Kill Switch Status.
  5819    [   15.184537] zram1: detected capacity change from 0 to 102400
  5820    [   15.338829] systemd[1]: Finished armbian-zram-config.service - Armbian ZRAM config.
  5821    [   15.391046] systemd[1]: Starting armbian-ramlog.service - Armbian memory supported logging...
  5822    [   15.512211] EXT4-fs (zram1): mounted filesystem without journal. Quota mode: none.
  5823    [   19.906899] systemd[1]: systemd-rfkill.service: Deactivated successfully.
  5824    [   20.008532] systemd[1]: Finished armbian-ramlog.service - Armbian memory supported logging.
  5825    [   20.043262] systemd[1]: Starting systemd-journald.service - Journal Service...
  5826    [   20.390419] systemd[1]: Started systemd-journald.service - Journal Service.
  5827    [   20.482584] systemd-journald[555]: Received client request to flush runtime journal.
  5828
  5829    ### armbian-release:
  5830
  5831    # PLEASE DO NOT EDIT THIS FILE
  5832    BOARD=rk3318-box
  5833    BOARD_NAME="RK3318 Box"
  5834    BOARDFAMILY=rockchip64
  5835    BUILD_REPOSITORY_URL=https://github.com/armbian/build
  5836    BUILD_REPOSITORY_COMMIT=313c893
  5837    VERSION=23.02.0-trunk
  5838    LINUXFAMILY=rockchip64
  5839    ARCH=arm64
  5840    IMAGE_TYPE=nightly
  5841    BOARD_TYPE=tvb
  5842    INITRD_ARCH=arm64
  5843    KERNEL_IMAGE_TYPE=Image
  5844
  5845    ### boot environment:
  5846
  5847    verbosity=7
  5848    bootlogo=false
  5849    overlay_prefix=rockchip
  5850    fdtfile=rockchip/rk3318-box.dtb
  5851    rootdev=UUID=2eb1e931-b16f-46a3-8b3b-f0a92acc8ddb
  5852    rootfstype=ext4
  5853    overlays=rk3318-box-led-conf2
  5854
  5855    ### lsusb:
  5856
  5857    Bus 005 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  5858    Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  5859    Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  5860    Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  5861    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  5862
  5863    ### lscpu:
  5864
  5865    Architecture:                    aarch64
  5866    CPU op-mode(s):                  32-bit, 64-bit
  5867    Byte Order:                      Little Endian
  5868    CPU(s):                          4
  5869    On-line CPU(s) list:             0-3
  5870    Vendor ID:                       ARM
  5871    Model name:                      Cortex-A53
  5872    Model:                           4
  5873    Thread(s) per core:              1
  5874    Core(s) per cluster:             4
  5875    Socket(s):                       -
  5876    Cluster(s):                      1
  5877    Stepping:                        r0p4
  5878    CPU(s) scaling MHz:              100%
  5879    CPU max MHz:                     1008.0000
  5880    CPU min MHz:                     600.0000
  5881    BogoMIPS:                        48.00
  5882    Flags:                           fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  5883    NUMA node(s):                    1
  5884    NUMA node0 CPU(s):               0-3
  5885    Vulnerability Itlb multihit:     Not affected
  5886    Vulnerability L1tf:              Not affected
  5887    Vulnerability Mds:               Not affected
  5888    Vulnerability Meltdown:          Not affected
  5889    Vulnerability Mmio stale data:   Not affected
  5890    Vulnerability Retbleed:          Not affected
  5891    Vulnerability Spec store bypass: Not affected
  5892    Vulnerability Spectre v1:        Mitigation; __user pointer sanitization
  5893    Vulnerability Spectre v2:        Not affected
  5894    Vulnerability Srbds:             Not affected
  5895    Vulnerability Tsx async abort:   Not affected
  5896
  5897    ### cpuinfo:
  5898
  5899    processor    : 0
  5900    BogoMIPS    : 48.00
  5901    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  5902    CPU implementer    : 0x41
  5903    CPU architecture: 8
  5904    CPU variant    : 0x0
  5905    CPU part    : 0xd03
  5906    CPU revision    : 4
  5907
  5908    processor    : 1
  5909    BogoMIPS    : 48.00
  5910    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  5911    CPU implementer    : 0x41
  5912    CPU architecture: 8
  5913    CPU variant    : 0x0
  5914    CPU part    : 0xd03
  5915    CPU revision    : 4
  5916
  5917    processor    : 2
  5918    BogoMIPS    : 48.00
  5919    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  5920    CPU implementer    : 0x41
  5921    CPU architecture: 8
  5922    CPU variant    : 0x0
  5923    CPU part    : 0xd03
  5924    CPU revision    : 4
  5925
  5926    processor    : 3
  5927    BogoMIPS    : 48.00
  5928    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  5929    CPU implementer    : 0x41
  5930    CPU architecture: 8
  5931    CPU variant    : 0x0
  5932    CPU part    : 0xd03
  5933    CPU revision    : 4
  5934
  5935
  5936    ### meminfo:
  5937
  5938    MemTotal:        4069844 kB
  5939    MemFree:         3883636 kB
  5940    MemAvailable:    3888988 kB
  5941    Buffers:            8976 kB
  5942    Cached:            53148 kB
  5943    SwapCached:            0 kB
  5944    Active:            50880 kB
  5945    Inactive:          22548 kB
  5946    Active(anon):      14280 kB
  5947    Inactive(anon):      780 kB
  5948    Active(file):      36600 kB
  5949    Inactive(file):    21768 kB
  5950    Unevictable:        2988 kB
  5951    Mlocked:               0 kB
  5952    SwapTotal:       2034920 kB
  5953    SwapFree:        2034920 kB
  5954    Zswap:                 0 kB
  5955    Zswapped:              0 kB
  5956    Dirty:               520 kB
  5957    Writeback:             0 kB
  5958    AnonPages:         14348 kB
  5959    Mapped:            17064 kB
  5960    Shmem:               720 kB
  5961    KReclaimable:      17872 kB
  5962    Slab:              48644 kB
  5963    SReclaimable:      17872 kB
  5964    SUnreclaim:        30772 kB
  5965    KernelStack:        2176 kB
  5966    PageTables:         1020 kB
  5967    SecPageTables:         0 kB
  5968    NFS_Unstable:          0 kB
  5969    Bounce:                0 kB
  5970    WritebackTmp:          0 kB
  5971    CommitLimit:     4069840 kB
  5972    Committed_AS:      53344 kB
  5973    VmallocTotal:   133143592960 kB
  5974    VmallocUsed:       28400 kB
  5975    VmallocChunk:          0 kB
  5976    Percpu:             1056 kB
  5977    AnonHugePages:         0 kB
  5978    ShmemHugePages:        0 kB
  5979    ShmemPmdMapped:        0 kB
  5980    FileHugePages:         0 kB
  5981    FilePmdMapped:         0 kB
  5982    CmaTotal:         131072 kB
  5983    CmaFree:          122368 kB
  5984    HugePages_Total:       0
  5985    HugePages_Free:        0
  5986    HugePages_Rsvd:        0
  5987    HugePages_Surp:        0
  5988    Hugepagesize:       2048 kB
  5989    Hugetlb:               0 kB
  5990
  5991    ### virtual memory:
  5992
  5993    vm.admin_reserve_kbytes = 8192
  5994    vm.compaction_proactiveness = 20
  5995    vm.compact_unevictable_allowed = 1
  5996    vm.dirty_background_bytes = 0
  5997    vm.dirty_background_ratio = 10
  5998    vm.dirty_bytes = 0
  5999    vm.dirty_expire_centisecs = 3000
  6000    vm.dirty_ratio = 20
  6001    vm.dirtytime_expire_seconds = 43200
  6002    vm.dirty_writeback_centisecs = 500
  6003    vm.extfrag_threshold = 500
  6004    vm.hugetlb_optimize_vmemmap = 0
  6005    vm.hugetlb_shm_group = 0
  6006    vm.laptop_mode = 0
  6007    vm.legacy_va_layout = 0
  6008    vm.lowmem_reserve_ratio = 256    256    32    0
  6009    vm.max_map_count = 65530
  6010    vm.min_free_kbytes = 22528
  6011    vm.min_slab_ratio = 5
  6012    vm.min_unmapped_ratio = 1
  6013    vm.mmap_min_addr = 4096
  6014    vm.mmap_rnd_bits = 18
  6015    vm.mmap_rnd_compat_bits = 11
  6016    vm.nr_hugepages = 0
  6017    vm.nr_hugepages_mempolicy = 0
  6018    vm.nr_overcommit_hugepages = 0
  6019    vm.numa_stat = 1
  6020    vm.numa_zonelist_order = Node
  6021    vm.oom_dump_tasks = 1
  6022    vm.oom_kill_allocating_task = 0
  6023    vm.overcommit_kbytes = 0
  6024    vm.overcommit_memory = 0
  6025    vm.overcommit_ratio = 50
  6026    vm.page-cluster = 0
  6027    vm.page_lock_unfairness = 5
  6028    vm.panic_on_oom = 0
  6029    vm.percpu_pagelist_high_fraction = 0
  6030    vm.stat_interval = 1
  6031    vm.swappiness = 100
  6032    vm.user_reserve_kbytes = 125902
  6033    vm.vfs_cache_pressure = 100
  6034    vm.watermark_boost_factor = 15000
  6035    vm.watermark_scale_factor = 10
  6036    vm.zone_reclaim_mode = 0
  6037
  6038    ### ip addr:
  6039
  6040    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  6041        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  6042        inet XXX.XXX.0.1/8 scope host lo
  6043           valid_lft forever preferred_lft forever
  6044        inet6 ::1/128 scope host
  6045           valid_lft forever preferred_lft forever
  6046    2: end1: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  6047        link/ether 52:d1:50:3d:d5:78 brd ff:ff:ff:ff:ff:ff
  6048    3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  6049        link/ether 20:02:af:49:e2:d5 brd ff:ff:ff:ff:ff:ff
  6050
  6051    ### partitions:
  6052
  6053    major minor  #blocks  name
  6054
  6055     179        0   15558144 mmcblk0
  6056     179        1   15384576 mmcblk0p1
  6057     179       32   61071360 mmcblk2
  6058     179       64       4096 mmcblk2boot0
  6059     179       96       4096 mmcblk2boot1
  6060     252        0    2034924 zram0
  6061     252        1      51200 zram1
  6062
  6063    ### df:
  6064
  6065    udev            1.9G     0  1.9G   0% /dev
  6066    tmpfs           398M  5.7M  392M   2% /run
  6067    /dev/mmcblk0p1   15G  1.5G   13G  11% /
  6068    tmpfs           2.0G     0  2.0G   0% /dev/shm
  6069    tmpfs           5.0M     0  5.0M   0% /run/lock
  6070    tmpfs           2.0G     0  2.0G   0% /tmp
  6071    /dev/zram1       47M  2.2M   42M   5% /var/log
  6072
  6073    ### lsblk:
  6074
  6075    NAME         FSTYPE  SIZE MOUNTPOINT UUID
  6076    mmcblk0             14.8G
  6077    └─mmcblk0p1  ext4   14.7G /          2eb1e931-b16f-46a3-8b3b-f0a92acc8ddb
  6078    mmcblk2             58.2G
  6079    mmcblk2boot0           4M
  6080    mmcblk2boot1           4M
  6081    zram1                 50M /var/log
  6082    zram2                  0B
  6083
  6084    ### zramctl:
  6085
  6086    NAME       ALGORITHM DISKSIZE DATA  COMPR TOTAL STREAMS MOUNTPOINT
  6087    /dev/zram1 zstd           50M   2M 456.1K  764K       4 /var/log
  6088    /dev/zram0 lzo-rle       1.9G   4K    74B   12K       4 [SWAP]
  6089
  6090    ### mtab:
  6091
  6092    /dev/mmcblk0p1 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0
  6093    /dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0
  6094    /dev/zram1 /var/log ext4 rw,relatime,discard 0 0
  6095
  6096    ### mmc0:8dfc info:
  6097
  6098                   fwrev: 0x0
  6099                  uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SU16G MODALIAS=mmc:block
  6100                     cid: 03534453553136478060b5bf4000a609
  6101                     rca: 0x8dfc
  6102                     csd: 400e00325b59000076b27f800a404013
  6103                  manfid: 0x000003
  6104                     ocr: 0x00300000
  6105    preferred_erase_size: 4194304
  6106                    type: SD
  6107                   hwrev: 0x8
  6108                    date: 06/2010
  6109                     dsr: 0x404
  6110              erase_size: 512
  6111                   oemid: 0x5344
  6112                  serial: 0x60b5bf40
  6113                     ssr: 0000000004000000010190000b050000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  6114                     scr: 0235800000000000
  6115                    name: SU16G
  6116
  6117    ### mmc2:0001 info:
  6118
  6119                   fwrev: 0x0500000000000000
  6120                  uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=CKTM4R MODALIAS=mmc:block
  6121                     cid: 150100434b544d345202a448f479c3a1
  6122             rel_sectors: 0x1
  6123    enhanced_rpmb_supported: 0x1
  6124                     rca: 0x0001
  6125            pre_eol_info: 0x01
  6126                     csd: d02701320f5903fff6dbffef8e40400d
  6127                  manfid: 0x000015
  6128                     ocr: 0x00300000
  6129    preferred_erase_size: 4194304
  6130    enhanced_area_offset: 18446744073709551594
  6131      raw_rpmb_size_mult: 0x20
  6132                    type: MMC
  6133                   hwrev: 0x0
  6134                    date: 12/2016
  6135                     prv: 0x2
  6136             ffu_capable: 1
  6137                     dsr: 0x404
  6138              erase_size: 524288
  6139               life_time: 0x01 0x01
  6140      enhanced_area_size: 4294967274
  6141                   oemid: 0x0100
  6142                  serial: 0xa448f479
  6143                 cmdq_en: 0
  6144                     rev: 0x8
  6145                    name: CKTM4R
  6146
  6147    ### Boot system health:
  6148
  6149    Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU  C.St.
  6150    14:30:55: 1008MHz  0.72  50%  24%  12%   0%  13%   0% 61.2 °C  0/3
  6151    14:30:55: 1008MHz  0.72  85%  27%  22%   0%  34%   0% 62.1 °C  0/3
  6152    14:30:56:  816MHz  0.72  84%  14%  12%   0%  56%   0% 60.0 °C  0/3
  6153    14:30:56:  816MHz  0.72  58%  10%   4%   1%  42%   0% 59.5 °C  0/3
  6154    14:30:56:  816MHz  0.72  64%  14%  10%   1%  39%   0% 60.4 °C  0/3
  6155
  6156    ### lsusb:
  6157
  6158
  6159    Bus 005 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  6160    Device Descriptor:
  6161      bLength                18
  6162      bDescriptorType         1
  6163      bcdUSB               3.00
  6164      bDeviceClass            9 Hub
  6165      bDeviceSubClass         0
  6166      bDeviceProtocol         3
  6167      bMaxPacketSize0         9
  6168      idVendor           0x1d6b Linux Foundation
  6169      idProduct          0x0003 3.0 root hub
  6170      bcdDevice            6.01
  6171      iManufacturer           3 Linux 6.1.11-rockchip64 xhci-hcd
  6172      iProduct                2 xHCI Host Controller
  6173      iSerial                 1 xhci-hcd.0.auto
  6174      bNumConfigurations      1
  6175      Configuration Descriptor:
  6176        bLength                 9
  6177        bDescriptorType         2
  6178        wTotalLength       0x001f
  6179        bNumInterfaces          1
  6180        bConfigurationValue     1
  6181        iConfiguration          0
  6182        bmAttributes         0xe0
  6183          Self Powered
  6184          Remote Wakeup
  6185        MaxPower                0mA
  6186        Interface Descriptor:
  6187          bLength                 9
  6188          bDescriptorType         4
  6189          bInterfaceNumber        0
  6190          bAlternateSetting       0
  6191          bNumEndpoints           1
  6192          bInterfaceClass         9 Hub
  6193          bInterfaceSubClass      0
  6194          bInterfaceProtocol      0 Full speed (or root) hub
  6195          iInterface              0
  6196          Endpoint Descriptor:
  6197            bLength                 7
  6198            bDescriptorType         5
  6199            bEndpointAddress     0x81  EP 1 IN
  6200            bmAttributes            3
  6201              Transfer Type            Interrupt
  6202              Synch Type               None
  6203              Usage Type               Data
  6204            wMaxPacketSize     0x0004  1x 4 bytes
  6205            bInterval              12
  6206            bMaxBurst               0
  6207    Hub Descriptor:
  6208      bLength              12
  6209      bDescriptorType      42
  6210      nNbrPorts             1
  6211      wHubCharacteristic 0x000a
  6212        No power switching (usb 1.0)
  6213        Per-port overcurrent protection
  6214      bPwrOn2PwrGood       50 * 2 milli seconds
  6215      bHubContrCurrent      0 milli Ampere
  6216      bHubDecLat          0.0 micro seconds
  6217      wHubDelay             0 nano seconds
  6218      DeviceRemovable    0x00
  6219     Hub Port Status:
  6220       Port 1: 0000.02a0 5Gbps power Rx.Detect
  6221    Binary Object Store Descriptor:
  6222      bLength                 5
  6223      bDescriptorType        15
  6224      wTotalLength       0x000f
  6225      bNumDeviceCaps          1
  6226      SuperSpeed USB Device Capability:
  6227        bLength                10
  6228        bDescriptorType        16
  6229        bDevCapabilityType      3
  6230        bmAttributes         0x02
  6231          Latency Tolerance Messages (LTM) Supported
  6232        wSpeedsSupported   0x0008
  6233          Device can operate at SuperSpeed (5Gbps)
  6234        bFunctionalitySupport   1
  6235          Lowest fully-functional device speed is Full Speed (12Mbps)
  6236        bU1DevExitLat           0 micro seconds
  6237        bU2DevExitLat           0 micro seconds
  6238    Device Status:     0x0001
  6239      Self Powered
  6240
  6241    Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  6242    Device Descriptor:
  6243      bLength                18
  6244      bDescriptorType         1
  6245      bcdUSB               2.00
  6246      bDeviceClass            9 Hub
  6247      bDeviceSubClass         0
  6248      bDeviceProtocol         1 Single TT
  6249      bMaxPacketSize0        64
  6250      idVendor           0x1d6b Linux Foundation
  6251      idProduct          0x0002 2.0 root hub
  6252      bcdDevice            6.01
  6253      iManufacturer           3 Linux 6.1.11-rockchip64 xhci-hcd
  6254      iProduct                2 xHCI Host Controller
  6255      iSerial                 1 xhci-hcd.0.auto
  6256      bNumConfigurations      1
  6257      Configuration Descriptor:
  6258        bLength                 9
  6259        bDescriptorType         2
  6260        wTotalLength       0x0019
  6261        bNumInterfaces          1
  6262        bConfigurationValue     1
  6263        iConfiguration          0
  6264        bmAttributes         0xe0
  6265          Self Powered
  6266          Remote Wakeup
  6267        MaxPower                0mA
  6268        Interface Descriptor:
  6269          bLength                 9
  6270          bDescriptorType         4
  6271          bInterfaceNumber        0
  6272          bAlternateSetting       0
  6273          bNumEndpoints           1
  6274          bInterfaceClass         9 Hub
  6275          bInterfaceSubClass      0
  6276          bInterfaceProtocol      0 Full speed (or root) hub
  6277          iInterface              0
  6278          Endpoint Descriptor:
  6279            bLength                 7
  6280            bDescriptorType         5
  6281            bEndpointAddress     0x81  EP 1 IN
  6282            bmAttributes            3
  6283              Transfer Type            Interrupt
  6284              Synch Type               None
  6285              Usage Type               Data
  6286            wMaxPacketSize     0x0004  1x 4 bytes
  6287            bInterval              12
  6288    Hub Descriptor:
  6289      bLength               9
  6290      bDescriptorType      41
  6291      nNbrPorts             1
  6292      wHubCharacteristic 0x000a
  6293        No power switching (usb 1.0)
  6294        Per-port overcurrent protection
  6295        TT think time 8 FS bits
  6296      bPwrOn2PwrGood       10 * 2 milli seconds
  6297      bHubContrCurrent      0 milli Ampere
  6298      DeviceRemovable    0x00
  6299      PortPwrCtrlMask    0xff
  6300     Hub Port Status:
  6301       Port 1: 0000.0100 power
  6302    Device Status:     0x0001
  6303      Self Powered
  6304
  6305    Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  6306    Device Descriptor:
  6307      bLength                18
  6308      bDescriptorType         1
  6309      bcdUSB               1.10
  6310      bDeviceClass            9 Hub
  6311      bDeviceSubClass         0
  6312      bDeviceProtocol         0 Full speed (or root) hub
  6313      bMaxPacketSize0        64
  6314      idVendor           0x1d6b Linux Foundation
  6315      idProduct          0x0001 1.1 root hub
  6316      bcdDevice            6.01
  6317      iManufacturer           3 Linux 6.1.11-rockchip64 ohci_hcd
  6318      iProduct                2 Generic Platform OHCI controller
  6319      iSerial                 1 ff5d0000.usb
  6320      bNumConfigurations      1
  6321      Configuration Descriptor:
  6322        bLength                 9
  6323        bDescriptorType         2
  6324        wTotalLength       0x0019
  6325        bNumInterfaces          1
  6326        bConfigurationValue     1
  6327        iConfiguration          0
  6328        bmAttributes         0xe0
  6329          Self Powered
  6330          Remote Wakeup
  6331        MaxPower                0mA
  6332        Interface Descriptor:
  6333          bLength                 9
  6334          bDescriptorType         4
  6335          bInterfaceNumber        0
  6336          bAlternateSetting       0
  6337          bNumEndpoints           1
  6338          bInterfaceClass         9 Hub
  6339          bInterfaceSubClass      0
  6340          bInterfaceProtocol      0 Full speed (or root) hub
  6341          iInterface              0
  6342          Endpoint Descriptor:
  6343            bLength                 7
  6344            bDescriptorType         5
  6345            bEndpointAddress     0x81  EP 1 IN
  6346            bmAttributes            3
  6347              Transfer Type            Interrupt
  6348              Synch Type               None
  6349              Usage Type               Data
  6350            wMaxPacketSize     0x0002  1x 2 bytes
  6351            bInterval             255
  6352    Hub Descriptor:
  6353      bLength               9
  6354      bDescriptorType      41
  6355      nNbrPorts             1
  6356      wHubCharacteristic 0x000a
  6357        No power switching (usb 1.0)
  6358        Per-port overcurrent protection
  6359      bPwrOn2PwrGood        2 * 2 milli seconds
  6360      bHubContrCurrent      0 milli Ampere
  6361      DeviceRemovable    0x00
  6362      PortPwrCtrlMask    0xff
  6363     Hub Port Status:
  6364       Port 1: 0000.0100 power
  6365    Device Status:     0x0001
  6366      Self Powered
  6367
  6368    Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  6369    Device Descriptor:
  6370      bLength                18
  6371      bDescriptorType         1
  6372      bcdUSB               2.00
  6373      bDeviceClass            9 Hub
  6374      bDeviceSubClass         0
  6375      bDeviceProtocol         0 Full speed (or root) hub
  6376      bMaxPacketSize0        64
  6377      idVendor           0x1d6b Linux Foundation
  6378      idProduct          0x0002 2.0 root hub
  6379      bcdDevice            6.01
  6380      iManufacturer           3 Linux 6.1.11-rockchip64 ehci_hcd
  6381      iProduct                2 EHCI Host Controller
  6382      iSerial                 1 ff5c0000.usb
  6383      bNumConfigurations      1
  6384      Configuration Descriptor:
  6385        bLength                 9
  6386        bDescriptorType         2
  6387        wTotalLength       0x0019
  6388        bNumInterfaces          1
  6389        bConfigurationValue     1
  6390        iConfiguration          0
  6391        bmAttributes         0xe0
  6392          Self Powered
  6393          Remote Wakeup
  6394        MaxPower                0mA
  6395        Interface Descriptor:
  6396          bLength                 9
  6397          bDescriptorType         4
  6398          bInterfaceNumber        0
  6399          bAlternateSetting       0
  6400          bNumEndpoints           1
  6401          bInterfaceClass         9 Hub
  6402          bInterfaceSubClass      0
  6403          bInterfaceProtocol      0 Full speed (or root) hub
  6404          iInterface              0
  6405          Endpoint Descriptor:
  6406            bLength                 7
  6407            bDescriptorType         5
  6408            bEndpointAddress     0x81  EP 1 IN
  6409            bmAttributes            3
  6410              Transfer Type            Interrupt
  6411              Synch Type               None
  6412              Usage Type               Data
  6413            wMaxPacketSize     0x0004  1x 4 bytes
  6414            bInterval              12
  6415    Hub Descriptor:
  6416      bLength               9
  6417      bDescriptorType      41
  6418      nNbrPorts             1
  6419      wHubCharacteristic 0x0009
  6420        Per-port power switching
  6421        Per-port overcurrent protection
  6422      bPwrOn2PwrGood       10 * 2 milli seconds
  6423      bHubContrCurrent      0 milli Ampere
  6424      DeviceRemovable    0x00
  6425      PortPwrCtrlMask    0xff
  6426     Hub Port Status:
  6427       Port 1: 0000.0100 power
  6428    Device Status:     0x0001
  6429      Self Powered
  6430
  6431    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  6432    Device Descriptor:
  6433      bLength                18
  6434      bDescriptorType         1
  6435      bcdUSB               2.00
  6436      bDeviceClass            9 Hub
  6437      bDeviceSubClass         0
  6438      bDeviceProtocol         1 Single TT
  6439      bMaxPacketSize0        64
  6440      idVendor           0x1d6b Linux Foundation
  6441      idProduct          0x0002 2.0 root hub
  6442      bcdDevice            6.01
  6443      iManufacturer           3 Linux 6.1.11-rockchip64 dwc2_hsotg
  6444      iProduct                2 DWC OTG Controller
  6445      iSerial                 1 ff580000.usb
  6446      bNumConfigurations      1
  6447      Configuration Descriptor:
  6448        bLength                 9
  6449        bDescriptorType         2
  6450        wTotalLength       0x0019
  6451        bNumInterfaces          1
  6452        bConfigurationValue     1
  6453        iConfiguration          0
  6454        bmAttributes         0xe0
  6455          Self Powered
  6456          Remote Wakeup
  6457        MaxPower                0mA
  6458        Interface Descriptor:
  6459          bLength                 9
  6460          bDescriptorType         4
  6461          bInterfaceNumber        0
  6462          bAlternateSetting       0
  6463          bNumEndpoints           1
  6464          bInterfaceClass         9 Hub
  6465          bInterfaceSubClass      0
  6466          bInterfaceProtocol      0 Full speed (or root) hub
  6467          iInterface              0
  6468          Endpoint Descriptor:
  6469            bLength                 7
  6470            bDescriptorType         5
  6471            bEndpointAddress     0x81  EP 1 IN
  6472            bmAttributes            3
  6473              Transfer Type            Interrupt
  6474              Synch Type               None
  6475              Usage Type               Data
  6476            wMaxPacketSize     0x0004  1x 4 bytes
  6477            bInterval              12
  6478    Hub Descriptor:
  6479      bLength               9
  6480      bDescriptorType      41
  6481      nNbrPorts             1
  6482      wHubCharacteristic 0x0008
  6483        Ganged power switching
  6484        Per-port overcurrent protection
  6485        TT think time 8 FS bits
  6486      bPwrOn2PwrGood        1 * 2 milli seconds
  6487      bHubContrCurrent      0 milli Ampere
  6488      DeviceRemovable    0x00
  6489      PortPwrCtrlMask    0xff
  6490     Hub Port Status:
  6491       Port 1: 0000.0000
  6492    Device Status:     0x0001
  6493      Self Powered
  6494
  6495    /:  Bus 05.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M
  6496    /:  Bus 04.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M
  6497    /:  Bus 03.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M
  6498    /:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M
  6499    /:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=dwc2/1p, 480M
  6500
  6501    ### Group membership of root : root
  6502
  6503    ### Userland:
  6504
  6505    PRETTY_NAME="Armbian 23.02.0-trunk Sid"
  6506
  6507    ### Installed packages:
  6508
  6509    ii  armbian-bsp-cli-rk3318-box    23.02.0-trunk                  arm64        Armbian board support files for rk3318-box
  6510    ii  armbian-firmware              23.02.0-trunk.0252             all          Linux firmware
  6511    ii  armbian-plymouth-theme        23.02.0-trunk                  all          boot animation, logger and I/O multiplexer - armbian theme
  6512    ii  linux-base                    4.9                            all          Linux image base package
  6513    ii  linux-dtb-edge-rockchip64     23.02.0-trunk.0248             arm64        Armbian Linux DTB, version 6.1.11-rockchip64 edge
  6514    ii  linux-headers-edge-rockchip64 23.02.0-trunk.0248             arm64        Linux kernel headers for 6.1.11-rockchip64 on arm64 edge
  6515    ii  linux-image-edge-rockchip64   23.02.0-trunk.0248             arm64        Linux kernel, armbian version 6.1.11-rockchip64 edge
  6516    ii  linux-libc-dev:arm64          23.02.0-trunk.0252             arm64        Armbian Linux support headers for userspace development
  6517    ii  linux-u-boot-rk3318-box-edge  23.02.0-trunk                  arm64        Uboot loader 2022.07
  6518
  6519    ### Loaded modules:
  6520
  6521    Module                  Size  Used by
  6522    lz4hc                  16384  0
  6523    lz4                    16384  0
  6524    brcmfmac              393216  0
  6525    brcmutil               24576  1 brcmfmac
  6526    cfg80211              925696  1 brcmfmac
  6527    hantro_vpu            135168  0
  6528    rockchip_vdec          45056  0
  6529    rfkill                 32768  2 cfg80211
  6530    v4l2_vp9               24576  2 rockchip_vdec,hantro_vpu
  6531    videobuf2_dma_contig    24576  2 rockchip_vdec,hantro_vpu
  6532    rockchip_rga           20480  0
  6533    v4l2_h264              20480  2 rockchip_vdec,hantro_vpu
  6534    snd_soc_spdif_tx       16384  1
  6535    snd_soc_hdmi_codec     24576  1
  6536    snd_soc_simple_card    24576  0
  6537    v4l2_mem2mem           36864  3 rockchip_vdec,hantro_vpu,rockchip_rga
  6538    gpio_ir_recv           16384  0
  6539    videobuf2_dma_sg       16384  1 rockchip_rga
  6540    snd_soc_rk3328         16384  1
  6541    snd_soc_simple_card_utils    28672  1 snd_soc_simple_card
  6542    snd_soc_rockchip_spdif    16384  2
  6543    snd_soc_rockchip_i2s    28672  4
  6544    videobuf2_memops       20480  2 videobuf2_dma_contig,videobuf2_dma_sg
  6545    videobuf2_v4l2         32768  4 rockchip_vdec,hantro_vpu,rockchip_rga,v4l2_mem2mem
  6546    rc_core                57344  2 gpio_ir_recv
  6547    snd_soc_core          270336  7 snd_soc_spdif_tx,snd_soc_hdmi_codec,snd_soc_rockchip_spdif,snd_soc_rk3328,snd_soc_simple_card_utils,snd_soc_rockchip_i2s,snd_soc_simple_card
  6548    videobuf2_common       65536  8 rockchip_vdec,videobuf2_dma_contig,videobuf2_v4l2,hantro_vpu,rockchip_rga,videobuf2_dma_sg,v4l2_mem2mem,videobuf2_memops
  6549    videodev              262144  6 rockchip_vdec,videobuf2_v4l2,hantro_vpu,rockchip_rga,videobuf2_common,v4l2_mem2mem
  6550    snd_compress           24576  1 snd_soc_core
  6551    snd_pcm_dmaengine      16384  1 snd_soc_core
  6552    mc                     65536  6 rockchip_vdec,videodev,videobuf2_v4l2,hantro_vpu,videobuf2_common,v4l2_mem2mem
  6553    snd_pcm               131072  5 snd_soc_hdmi_codec,snd_compress,snd_soc_simple_card_utils,snd_soc_core,snd_pcm_dmaengine
  6554    snd_timer              40960  1 snd_pcm
  6555    snd                    94208  5 snd_soc_hdmi_codec,snd_timer,snd_compress,snd_soc_core,snd_pcm
  6556    soundcore              16384  1 snd
  6557    cpufreq_dt             20480  0
  6558    zram                   36864  3
  6559    binfmt_misc            24576  1
  6560    ip_tables              32768  0
  6561    x_tables               45056  1 ip_tables
  6562    autofs4                45056  2
  6563    dwmac_rk               32768  0
  6564    stmmac_platform        24576  1 dwmac_rk
  6565    stmmac                237568  2 stmmac_platform,dwmac_rk
  6566    pcs_xpcs               20480  1 stmmac
  6567    dw_hdmi_i2s_audio      16384  0
  6568    dw_hdmi_cec            16384  0
  6569    lima                   61440  0
  6570    gpu_sched              45056  1 lima
  6571    drm_shmem_helper       20480  1 lima
  6572    gpio_syscon            20480  1
  6573    adc_keys               16384  0
  6574
  6575    ### Current system health:
  6576
  6577    Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU  C.St.
  6578    14:33:31: 1008MHz  1.71  31%   5%  22%   0%   3%   0% 62.1 °C  0/3
  6579    14:33:32: 1008MHz  1.71  30%   3%  25%   2%   0%   0% 62.1 °C  0/3
  6580    14:33:32: 1008MHz  1.71  30%   4%  25%   1%   0%   0% 61.7 °C  0/3
  6581    14:33:32: 1008MHz  1.71  29%   4%  25%   0%   0%   0% 61.7 °C  0/3
  6582    14:33:33: 1008MHz  1.71  30%   4%  25%   1%   0%   0% 61.7 °C  0/3
  6583    14:33:33: 1008MHz  1.71  31%   5%  22%   0%   3%   0% 62.1 °C  0/3
  6584    14:33:34: 1008MHz  1.71  30%   3%  25%   2%   0%   0% 62.5 °C  0/3
  6585    14:33:34: 1008MHz  1.65  29%   4%  25%   0%   0%   0% 62.1 °C  0/3
  6586    14:33:34: 1008MHz  1.65  29%   4%  25%   0%   0%   0% 61.2 °C  0/3
  6587    14:33:35: 1008MHz  1.65  30%   4%  25%   0%   0%   0% 61.7 °C  0/3
  6588
  6589    ### resolv.conf
  6590
  6591    -rw-r--r-- 1 root root 53 Mar 30 14:30 /etc/resolv.conf
  6592    # Generated by NetworkManager
  6593    nameserver XXX.XXX.1.1
  6594
  6595    ### Current sysinfo:
  6596
  6597    Linux 6.1.11-rockchip64 (rk3318-box)     03/30/2023     _aarch64_    (4 CPU)
  6598
  6599    avg-cpu:  %user   %nice %system %iowait  %steal   %idle
  6600              22.68    0.08    5.34    3.50    0.00   68.40
  6601
  6602    Device             tps    kB_read/s    kB_wrtn/s    kB_dscd/s    kB_read    kB_wrtn    kB_dscd
  6603    mmcblk0          19.19      1024.67        11.52         0.00     165823       1864          0
  6604    mmcblk0p1        18.58      1011.67        11.52         0.00     163719       1864          0
  6605    mmcblk2           0.90        19.38         0.00         0.00       3136          0          0
  6606    mmcblk2boot0      0.18         0.72         0.00         0.00        116          0          0
  6607    mmcblk2boot1      0.18         0.72         0.00         0.00        116          0          0
  6608    zram0             2.06         8.23         0.02         0.00       1332          4          0
  6609    zram1             1.38         2.87        15.50         0.00        464       2508          0
  6610    zram2             0.00         0.00         0.00         0.00          0          0          0
  6611
  6612    --procs-- -----------------------memory---------------------- ---swap-- -----io---- -system-- ----------cpu----------
  6613       r    b         swpd         free         buff        cache   si   so    bi    bo   in   cs  us  sy  id  wa  st  gu
  6614       2    0            0      3737436         9740       180688    0    0   263     7  219  262  23   5  68   4   0   0
  6615
  6616                   total        used        free      shared  buff/cache   available
  6617    Mem:           3.9Gi       215Mi       3.6Gi       6.1Mi       185Mi       3.7Gi
  6618    Swap:          1.9Gi          0B       1.9Gi
  6619
  6620    NAME       ALGORITHM DISKSIZE  DATA  COMPR TOTAL STREAMS MOUNTPOINT
  6621    /dev/zram1 zstd           50M  2.2M 534.1K  928K       4 /var/log
  6622    /dev/zram0 lzo-rle       1.9G    4K    74B   12K       4 [SWAP]
  6623
  6624     14:33:35 up 2 min,  2 users,  load average: 1.65, 0.71, 0.27
  6625
  6626    [    3.222502] usbhid: USB HID core driver
  6627    [    3.223317] mmc_host mmc4: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
  6628    [    3.226840] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
  6629    [    3.231295] drop_monitor: Initializing network drop monitor service
  6630    [    3.231449] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
  6631    [    3.233254] NET: Registered PF_INET6 protocol family
  6632    [    3.234115] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.01
  6633    [    3.234897] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  6634    [    3.235574] usb usb3: Product: Generic Platform OHCI controller
  6635    [    3.236131] usb usb3: Manufacturer: Linux 6.1.11-rockchip64 ohci_hcd
  6636    [    3.236723] usb usb3: SerialNumber: ff5d0000.usb
  6637    [    3.238311] hub 3-0:1.0: USB hub found
  6638    [    3.238778] hub 3-0:1.0: 1 port detected
  6639    [    3.277621] Segment Routing with IPv6
  6640    [    3.278156] In-situ OAM (IOAM) with IPv6
  6641    [    3.278757] NET: Registered PF_PACKET protocol family
  6642    [    3.279528] 8021q: 802.1Q VLAN Support v1.8
  6643    [    3.280021] Key type dns_resolver registered
  6644    [    3.282869] registered taskstats version 1
  6645    [    3.283305] Loading compiled-in X.509 certificates
  6646    [    3.291081] Loaded X.509 cert 'Build time autogenerated kernel key: e25f7f61aa13aedd90bace25454c8646dc5da469'
  6647    [    3.293527] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
  6648    [    3.294850] mmc0: new high speed SDHC card at address 8dfc
  6649    [    3.296188] zswap: loaded using pool zstd/z3fold
  6650    [    3.297316] mmcblk0: mmc0:8dfc SU16G 14.8 GiB
  6651    [    3.297902] Key type .fscrypt registered
  6652    [    3.298348] Key type fscrypt-provisioning registered
  6653    [    3.302977] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=yes
  6654    [    3.304272] Key type encrypted registered
  6655    [    3.304730] AppArmor: AppArmor sha1 policy hashing enabled
  6656    [    3.308244]  mmcblk0: p1
  6657    [    3.328831] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 52000000Hz, actual 50000000HZ div = 0)
  6658    [    3.330632] mmc2: new high speed MMC card at address 0001
  6659    [    3.332719] mmcblk2: mmc2:0001 CKTM4R 58.2 GiB
  6660    [    3.338433] mmcblk2boot0: mmc2:0001 CKTM4R 4.00 MiB
  6661    [    3.343217] mmcblk2boot1: mmc2:0001 CKTM4R 4.00 MiB
  6662    [    3.347381] mmcblk2rpmb: mmc2:0001 CKTM4R 4.00 MiB, chardev (242:0)
  6663    [    3.347595] mmc_host mmc4: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
  6664    [    3.352929] mmc4: new high speed SDIO card at address 0001
  6665    [    3.401566] rockchip-drm display-subsystem: bound ff370000.vop (ops vop_component_ops)
  6666    [    3.402533] dwhdmi-rockchip ff3c0000.hdmi: supply avdd-0v9 not found, using dummy regulator
  6667    [    3.403667] dwhdmi-rockchip ff3c0000.hdmi: supply avdd-1v8 not found, using dummy regulator
  6668    [    3.404994] dwhdmi-rockchip ff3c0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (inno_dw_hdmi_phy2)
  6669    [    3.407159] dwhdmi-rockchip ff3c0000.hdmi: registered DesignWare HDMI I2C bus driver
  6670    [    3.408773] rockchip-drm display-subsystem: bound ff3c0000.hdmi (ops dw_hdmi_rockchip_ops)
  6671    [    3.410867] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 0
  6672    [    3.411772] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
  6673    [    3.412591] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
  6674    [    3.414414] WCN: marlin_init entry!
  6675    [    3.415592] of_cfs_init
  6676    [    3.415902] of_cfs_init: OK
  6677    [    3.419679] Freeing unused kernel memory: 3968K
  6678    [    3.433863] Run /init as init process
  6679    [    3.434229]   with arguments:
  6680    [    3.434242]     /init
  6681    [    3.434257]   with environment:
  6682    [    3.434267]     HOME=/
  6683    [    3.434279]     TERM=linux
  6684    [    3.434290]     splash=verbose
  6685    [    3.434303]     ubootpart=8635553d-01
  6686    [    3.434314]     cgroup_enable=memory
  6687    [    3.434328]     cgroup_memory=1
  6688    [    4.477167] input: adc-keys as /devices/platform/adc-keys/input/input0
  6689    [    4.497795] gpio-syscon ff100000.syscon:gpio: can't read the data register offset!
  6690    [    4.551283] lima ff300000.gpu: gp - mali450 version major 0 minor 0
  6691    [    4.552085] lima ff300000.gpu: pp0 - mali450 version major 0 minor 0
  6692    [    4.552884] lima ff300000.gpu: pp1 - mali450 version major 0 minor 0
  6693    [    4.553565] lima ff300000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
  6694    [    4.554380] lima ff300000.gpu: l2 cache 64K, 4-way, 64byte cache line, 128bit external bus
  6695    [    4.556577] lima ff300000.gpu: bus rate = 491520000
  6696    [    4.557071] lima ff300000.gpu: mod rate = 491520000
  6697    [    4.564990] [drm] Initialized lima 1.1.0 20191231 for ff300000.gpu on minor 1
  6698    [    4.761100] rk_gmac-dwmac ff550000.ethernet: IRQ eth_wake_irq not found
  6699    [    4.761795] rk_gmac-dwmac ff550000.ethernet: IRQ eth_lpi not found
  6700    [    4.762602] rk_gmac-dwmac ff550000.ethernet: PTP uses main clock
  6701    [    4.763630] rk_gmac-dwmac ff550000.ethernet: clock input or output? (output).
  6702    [    4.764327] rk_gmac-dwmac ff550000.ethernet: TX delay(0x30).
  6703    [    4.764873] rk_gmac-dwmac ff550000.ethernet: RX delay(0x10).
  6704    [    4.765445] rk_gmac-dwmac ff550000.ethernet: integrated PHY? (yes).
  6705    [    4.766239] rk_gmac-dwmac ff550000.ethernet: cannot get clock clk_mac_refout
  6706    [    4.768660] rk_gmac-dwmac ff550000.ethernet: cannot get clock clk_mac_speed
  6707    [    4.780182] rk_gmac-dwmac ff550000.ethernet: init for RMII
  6708    [    4.830215] rk_gmac-dwmac ff550000.ethernet: User ID: 0x10, Synopsys ID: 0x35
  6709    [    4.830917] rk_gmac-dwmac ff550000.ethernet:     DWMAC1000
  6710    [    4.831417] rk_gmac-dwmac ff550000.ethernet: DMA HW capability register supported
  6711    [    4.832112] rk_gmac-dwmac ff550000.ethernet: RX Checksum Offload Engine supported
  6712    [    4.832806] rk_gmac-dwmac ff550000.ethernet: COE Type 2
  6713    [    4.833298] rk_gmac-dwmac ff550000.ethernet: TX Checksum insertion supported
  6714    [    4.834051] rk_gmac-dwmac ff550000.ethernet: Wake-Up On Lan supported
  6715    [    4.834827] rk_gmac-dwmac ff550000.ethernet: Normal descriptors
  6716    [    4.835402] rk_gmac-dwmac ff550000.ethernet: Ring mode enabled
  6717    [    4.835952] rk_gmac-dwmac ff550000.ethernet: Enable RX Mitigation via HW Watchdog Timer
  6718    [    4.875743] rk_gmac-dwmac ff550000.ethernet end1: renamed from eth0
  6719    [    4.973232] dw-apb-uart ff130000.serial: forbid DMA for kernel console
  6720    [    5.554968] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Quota mode: none.
  6721    [    7.648300] systemd[1]: System time before build time, advancing clock.
  6722    [    7.727839] systemd[1]: Inserted module 'autofs4'
  6723    [    7.892347] systemd[1]: systemd 252.5-2 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
  6724    [    7.895289] systemd[1]: Detected architecture arm64.
  6725    [    7.920275] systemd[1]: Hostname set to <rk3318-box>.
  6726    [    9.310514] systemd[326]: /usr/lib/systemd/system-generators/netplan failed with exit status 1.
  6727    [   10.610907] systemd[1]: Queued start job for default target graphical.target.
  6728    [   10.643724] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
  6729    [   10.649124] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
  6730    [   10.654307] systemd[1]: Created slice system-serial-getty.slice - Slice /system/serial-getty.
  6731    [   10.658423] systemd[1]: Created slice user.slice - User and Session Slice.
  6732    [   10.660148] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
  6733    [   10.663247] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
  6734    [   10.665161] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
  6735    [   10.667055] systemd[1]: Reached target remote-fs.target - Remote File Systems.
  6736    [   10.668349] systemd[1]: Reached target slices.target - Slice Units.
  6737    [   10.669806] systemd[1]: Reached target swap.target - Swaps.
  6738    [   10.670893] systemd[1]: Reached target time-set.target - System Time Set.
  6739    [   10.672590] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
  6740    [   10.679100] systemd[1]: Listening on syslog.socket - Syslog Socket.
  6741    [   10.681224] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
  6742    [   10.683143] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
  6743    [   10.685990] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
  6744    [   10.688585] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
  6745    [   10.691498] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
  6746    [   10.705612] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
  6747    [   10.707990] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
  6748    [   10.742349] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
  6749    [   10.752671] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
  6750    [   10.763121] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
  6751    [   10.774433] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
  6752    [   10.791742] systemd[1]: Starting fake-hwclock.service - Restore / save the current clock...
  6753    [   10.803039] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
  6754    [   10.815074] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
  6755    [   10.827514] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
  6756    [   10.839911] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
  6757    [   10.852357] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
  6758    [   10.864810] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
  6759    [   10.867167] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
  6760    [   10.892442] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
  6761    [   10.904301] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
  6762    [   10.906611] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
  6763    [   10.917911] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
  6764    [   10.938110] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
  6765    [   10.942859] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
  6766    [   10.947672] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
  6767    [   10.952080] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
  6768    [   10.958013] systemd[1]: Finished fake-hwclock.service - Restore / save the current clock.
  6769    [   10.964801] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
  6770    [   10.971444] systemd[1]: modprobe@configfs.service: Deactivated successfully.
  6771    [   10.974326] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
  6772    [   10.979946] systemd[1]: modprobe@drm.service: Deactivated successfully.
  6773    [   10.984058] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
  6774    [   10.989435] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
  6775    [   10.992654] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
  6776    [   10.997587] systemd[1]: modprobe@fuse.service: Deactivated successfully.
  6777    [   11.001092] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
  6778    [   11.005260] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
  6779    [   11.017390] EXT4-fs (mmcblk0p1): re-mounted. Quota mode: none.
  6780    [   11.039115] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
  6781    [   11.049568] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
  6782    [   11.061054] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables...
  6783    [   11.086404] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
  6784    [   11.090701] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
  6785    [   11.094321] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
  6786    [   11.098289] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
  6787    [   11.123360] systemd[1]: Starting systemd-random-seed.service - Load/Save Random Seed...
  6788    [   11.135101] systemd[1]: Starting systemd-sysusers.service - Create System Users...
  6789    [   11.200550] systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables.
  6790    [   11.286141] systemd[1]: Finished systemd-sysusers.service - Create System Users.
  6791    [   11.335729] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev...
  6792    [   11.534999] systemd[1]: Finished systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev.
  6793    [   11.567346] systemd[1]: Starting systemd-udevd.service - Rule-based Manager for Device Events and Files...
  6794    [   11.572300] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout.
  6795    [   11.576770] systemd[1]: Reached target local-fs-pre.target - Preparation for Local File Systems.
  6796    [   11.646462] systemd[1]: Mounting tmp.mount - /tmp...
  6797    [   11.673438] systemd[1]: Mounted tmp.mount - /tmp.
  6798    [   11.677341] systemd[1]: Reached target local-fs.target - Local File Systems.
  6799    [   11.688816] systemd[1]: Starting armbian-led-state.service - Armbian leds state...
  6800    [   11.711411] systemd[1]: Starting armbian-zram-config.service - Armbian ZRAM config...
  6801    [   11.741813] systemd[1]: Starting console-setup.service - Set console font and keymap...
  6802    [   11.767362] systemd[1]: Starting plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data...
  6803    [   11.852272] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
  6804    [   11.861078] systemd[1]: Finished console-setup.service - Set console font and keymap.
  6805    [   11.867912] systemd[1]: Received SIGRTMIN+20 from PID 292 (plymouthd).
  6806    [   11.916783] systemd[1]: Finished plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data.
  6807    [   11.943182] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 390 (systemd-binfmt)
  6808    [   11.978646] systemd[1]: Mounting proc-sys-fs-binfmt_misc.mount - Arbitrary Executable File Formats File System...
  6809    [   12.045124] systemd[1]: Mounted proc-sys-fs-binfmt_misc.mount - Arbitrary Executable File Formats File System.
  6810    [   12.065603] systemd[1]: Finished systemd-binfmt.service - Set Up Additional Binary Formats.
  6811    [   12.077258] systemd[1]: Finished armbian-led-state.service - Armbian leds state.
  6812    [   12.204885] systemd[1]: Finished systemd-udev-trigger.service - Coldplug All udev Devices.
  6813    [   12.243288] systemd[1]: Starting ifupdown-pre.service - Helper to synchronize boot up for ifupdown...
  6814    [   12.345191] systemd[1]: Finished ifupdown-pre.service - Helper to synchronize boot up for ifupdown.
  6815    [   12.553280] systemd[1]: Started systemd-udevd.service - Rule-based Manager for Device Events and Files.
  6816    [   12.602426] systemd[1]: Starting plymouth-start.service - Show Plymouth Boot Screen...
  6817    [   12.812631] systemd[1]: Started plymouth-start.service - Show Plymouth Boot Screen.
  6818    [   12.816906] systemd[1]: bootsplash-ask-password-console.path - Dispatch Password Requests to Console Directory Watch when bootsplash is active was skipped because of an unmet condition check (ConditionPathExists=/sys/devices/platform/bootsplash.0/enabled).
  6819    [   12.820623] systemd[1]: Started systemd-ask-password-plymouth.path - Forward Password Requests to Plymouth Directory Watch.
  6820    [   12.826433] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
  6821    [   12.827908] systemd[1]: Reached target paths.target - Path Units.
  6822    [   12.870332] systemd[1]: Found device dev-ttyS2.device - /dev/ttyS2.
  6823    [   12.942890] zram: Added device: zram0
  6824    [   12.944457] zram: Added device: zram1
  6825    [   12.948122] zram: Added device: zram2
  6826    [   13.239422] zram0: detected capacity change from 0 to 4069848
  6827    [   13.615084] mc: Linux media interface: v0.10
  6828    [   13.688859] videodev: Linux video capture interface: v2.00
  6829    [   13.961749] rk3328-codec ff410000.codec: spk_depop_time use default value.
  6830    [   13.976618] Registered IR keymap rc-empty
  6831    [   13.977202] rc rc0: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc0
  6832    [   13.978145] rc rc0: lirc_dev: driver gpio_ir_recv registered at minor = 0, raw IR receiver, no transmitter
  6833    [   13.979318] input: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc0/input1
  6834    [   14.077965] rockchip-rga ff390000.rga: HW Version: 0x04.00
  6835    [   14.131547] rockchip_vdec: module is from the staging directory, the quality is unknown, you have been warned.
  6836    [   14.133835] rockchip-rga ff390000.rga: Registered rockchip-rga as /dev/video0
  6837    [   14.168011] hantro-vpu ff350000.video-codec: Adding to iommu group 2
  6838    [   14.174954] hantro-vpu ff350000.video-codec: registered rockchip,rk3328-vpu-dec as /dev/video1
  6839    [   14.201477] rkvdec ff360000.video-codec: Adding to iommu group 3
  6840    [   14.346050] cfg80211: Loading compiled-in X.509 certificates for regulatory database
  6841    [   14.348492] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
  6842    [   14.403771] systemd[1]: Reached target sound.target - Sound Card.
  6843    [   14.405095] systemd[1]: Listening on systemd-rfkill.socket - Load/Save RF Kill Switch Status /dev/rfkill Watch.
  6844    [   14.424198] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
  6845    [   14.494902] brcmfmac: F1 signature read @0x18000000=0x16034334
  6846    [   14.500335] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4334-sdio for chip BCM4334/3
  6847    [   14.501777] usbcore: registered new interface driver brcmfmac
  6848    [   14.504471] brcmfmac mmc4:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.rockchip,rk3318-box.bin failed with error -2
  6849    [   14.536441] brcmfmac mmc4:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.clm_blob failed with error -2
  6850    [   14.677692] random: crng init done
  6851    [   14.716995] systemd[1]: Finished systemd-random-seed.service - Load/Save Random Seed.
  6852    [   14.720553] systemd[1]: first-boot-complete.target - First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes).
  6853    [   14.722345] systemd[1]: systemd-machine-id-commit.service - Commit a transient machine-id on disk was skipped because of an unmet condition check (ConditionPathIsMountPoint=/etc/machine-id).
  6854    [   14.749334] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
  6855    [   14.750802] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4334/3 wl0: Jul 24 2019 12:58:36 version 6.10.191 (TOB) (r) FWID 01-b049404e
  6856    [   14.790666] systemd[1]: Starting systemd-rfkill.service - Load/Save RF Kill Switch Status...
  6857    [   14.853759] Adding 2034920k swap on /dev/zram0.  Priority:5 extents:1 across:2034920k SSFS
  6858    [   14.898782] systemd[1]: Started systemd-rfkill.service - Load/Save RF Kill Switch Status.
  6859    [   15.184537] zram1: detected capacity change from 0 to 102400
  6860    [   15.338829] systemd[1]: Finished armbian-zram-config.service - Armbian ZRAM config.
  6861    [   15.391046] systemd[1]: Starting armbian-ramlog.service - Armbian memory supported logging...
  6862    [   15.512211] EXT4-fs (zram1): mounted filesystem without journal. Quota mode: none.
  6863    [   19.906899] systemd[1]: systemd-rfkill.service: Deactivated successfully.
  6864    [   20.008532] systemd[1]: Finished armbian-ramlog.service - Armbian memory supported logging.
  6865    [   20.043262] systemd[1]: Starting systemd-journald.service - Journal Service...
  6866    [   20.390419] systemd[1]: Started systemd-journald.service - Journal Service.
  6867    [   20.482584] systemd-journald[555]: Received client request to flush runtime journal.
  6868    [   22.466903] systemd-journald[555]: Received client request to relinquish /var/log/journal/748f963f03bc4ff19142d0aa9df990a2 access.
  6869    [   27.367744] rk_gmac-dwmac ff550000.ethernet end1: Register MEM_TYPE_PAGE_POOL RxQ-0
  6870    [   27.432019] rk_gmac-dwmac ff550000.ethernet end1: PHY [stmmac-1:00] driver [Rockchip integrated EPHY] (irq=POLL)
  6871    [   27.443041] rk_gmac-dwmac ff550000.ethernet end1: No Safety Features support found
  6872    [   27.443768] rk_gmac-dwmac ff550000.ethernet end1: PTP not supported by HW
  6873    [   27.445090] rk_gmac-dwmac ff550000.ethernet end1: configuring for phy/rmii link mode
  6874    [   29.474219] rk_gmac-dwmac ff550000.ethernet end1: Link is Up - 100Mbps/Full - flow control rx/tx
  6875    [   29.475113] IPv6: ADDRCONF(NETDEV_CHANGE): end1: link becomes ready
  6876
  6877
  6878    vm.admin_reserve_kbytes = 8192
  6879    vm.compaction_proactiveness = 20
  6880    vm.compact_unevictable_allowed = 1
  6881    vm.dirty_background_bytes = 0
  6882    vm.dirty_background_ratio = 10
  6883    vm.dirty_bytes = 0
  6884    vm.dirty_expire_centisecs = 3000
  6885    vm.dirty_ratio = 20
  6886    vm.dirtytime_expire_seconds = 43200
  6887    vm.dirty_writeback_centisecs = 500
  6888    vm.extfrag_threshold = 500
  6889    vm.hugetlb_optimize_vmemmap = 0
  6890    vm.hugetlb_shm_group = 0
  6891    vm.laptop_mode = 0
  6892    vm.legacy_va_layout = 0
  6893    vm.lowmem_reserve_ratio = 256    256    32    0
  6894    vm.max_map_count = 65530
  6895    vm.min_free_kbytes = 22528
  6896    vm.min_slab_ratio = 5
  6897    vm.min_unmapped_ratio = 1
  6898    vm.mmap_min_addr = 4096
  6899    vm.mmap_rnd_bits = 18
  6900    vm.mmap_rnd_compat_bits = 11
  6901    vm.nr_hugepages = 0
  6902    vm.nr_hugepages_mempolicy = 0
  6903    vm.nr_overcommit_hugepages = 0
  6904    vm.numa_stat = 1
  6905    vm.numa_zonelist_order = Node
  6906    vm.oom_dump_tasks = 1
  6907    vm.oom_kill_allocating_task = 0
  6908    vm.overcommit_kbytes = 0
  6909    vm.overcommit_memory = 0
  6910    vm.overcommit_ratio = 50
  6911    vm.page-cluster = 0
  6912    vm.page_lock_unfairness = 5
  6913    vm.panic_on_oom = 0
  6914    vm.percpu_pagelist_high_fraction = 0
  6915    vm.stat_interval = 1
  6916    vm.swappiness = 100
  6917    vm.user_reserve_kbytes = 125902
  6918    vm.vfs_cache_pressure = 100
  6919    vm.watermark_boost_factor = 15000
  6920    vm.watermark_scale_factor = 10
  6921    vm.zone_reclaim_mode = 0
  6922
  6923    ### interrupts:
  6924               CPU0       CPU1       CPU2       CPU3
  6925      9:          0          0          0          0     GICv2  25 Level     vgic
  6926     11:      14229      36219      12477       7221     GICv2  30 Level     arch_timer
  6927     12:          0          0          0          0     GICv2  27 Level     kvm guest vtimer
  6928     18:          0          0          0          0     GICv2 132 Level     arm-pmu
  6929     19:          0          0          0          0     GICv2 133 Level     arm-pmu
  6930     20:          0          0          0          0     GICv2 134 Level     arm-pmu
  6931     21:          0          0          0          0     GICv2 135 Level     arm-pmu
  6932     22:          0          0          0          0     GICv2  94 Level     rockchip_usb2phy
  6933     23:          0          0          0          0     GICv2  32 Level     ff1f0000.dma-controller
  6934     24:          0          0          0          0     GICv2  33 Level     ff1f0000.dma-controller
  6935     26:        329          0          0          0     GICv2  89 Level     ttyS2
  6936     27:          0          0          0          0     GICv2 128 Level     ff330200.iommu
  6937     28:          0          0          0          0     GICv2 130 Level     ff340800.iommu
  6938     29:          0          0          0          0     GICv2  43 Level     ff350800.iommu
  6939     30:          0          0          0          0     GICv2 106 Level     ff360480.iommu
  6940     31:          0          0          0          0     GICv2  64 Level     ff373f00.iommu, ff370000.vop
  6941     32:          0          0          0          0     GICv2  63 Level     ff3a0800.iommu
  6942     33:          0          0          0          0     GICv2  99 Level     xhci-hcd:usb2
  6943     34:          0          0          0          0     GICv2  55 Level     ff580000.usb, dwc2_hsotg:usb1
  6944     35:          0          0          0          0     GICv2  48 Level     ehci_hcd:usb4
  6945     36:          0          0          0          0     GICv2  49 Level     ohci_hcd:usb3
  6946     37:          0          0          0          0     GICv2  90 Level     rockchip_thermal
  6947     38:          0          0          0          0     GICv2  72 Edge      ff1a0000.watchdog
  6948     39:        644          0          0          0     GICv2  46 Level     dw-mci
  6949     40:      10064          0          0          0     GICv2  44 Level     dw-mci
  6950     41:       7072          0          0          0     GICv2  36 Level     dw-mci
  6951     42:          9          0          0          0     GICv2 112 Level     ff280000.adc
  6952     43:          0          0          0          0  rockchip_gpio_irq   5 Edge      ff500000.mmc cd
  6953     44:          0          0          0          0     GICv2 115 Level     ff430000.phy
  6954     45:          0          0          0          0     GICv2  67 Level     ff3c0000.hdmi, dw-hdmi-cec
  6955     46:          0          0          0          0     GICv2 119 Level     gpmmu
  6956     47:          0          0          0          0     GICv2 121 Level     ppmmu0
  6957     48:          0          0          0          0     GICv2 124 Level     ppmmu1
  6958     49:          0          0          0          0     GICv2 122 Level     gp
  6959     50:          0          0          0          0     GICv2 120 Level     pp0
  6960     51:          0          0          0          0     GICv2 123 Level     pp1
  6961     52:          0          0          0          0     GICv2 125 Level     pp_bcast
  6962     53:        474          0          0          0     GICv2  53 Level     end1
  6963     54:          0          0          0          0  rockchip_gpio_irq   2 Edge      gpio-ir-recv-irq
  6964     55:          0          0          0          0     GICv2  65 Level     ff390000.rga
  6965     56:          0          0          0          0     GICv2  41 Level     ff350000.video-codec
  6966     57:          0          0          0          0     GICv2  39 Level     ff360000.video-codec
  6967    IPI0:      8818        953       3830       2383       Rescheduling interrupts
  6968    IPI1:      6930       3192       5595       9656       Function call interrupts
  6969    IPI2:         0          0          0          0       CPU stop interrupts
  6970    IPI3:         0          0          0          0       CPU stop (for crash dump) interrupts
  6971    IPI4:         0          0          0          0       Timer broadcast interrupts
  6972    IPI5:      2086       8607       1325        590       IRQ work interrupts
  6973    IPI6:         0          0          0          0       CPU wake-up interrupts
  6974    Err:          0
Please upload the whole output above to an online pasteboard service
and provide the URL in the forum where you have been asked for this.
@mikes123 Hello, first of all you need to choose led-conf2 from rk3318-config to enable the proper led/gpio configuration for you X88 Pro board, then reboot. This is an essential, one-time only configuration that you should not change later for any reason.
Try to connect with this setup. If you still have problems with wifi, consult the first page in the paragraph "special hardware" and follow the instructions there
I did a reset and the settings that you wrote, wifi did not work.
verbosity=1
bootlogo=false
rootfstype=ext4
# original nvram found in Android sources for HS2734C SP
manfid=0x2d0
prodid=0x05c1
vendid=0x14e4
devid=0x4380
boardtype=0x05de
boardrev=0x1200
boardnum=22
macaddr=00:90:4c:c5:12:38
sromrev=3# brcm4334 nvram for AP6334/HK6334/SP6334
boardflags=0x10081a01
xtalfreq=37400
nocrc=1
ag0=252
aa2g=1
ccode=ALL
regrev=1
pa0itssit=0x20
#PA parameters for 2.4GHz_QM_4p2_120517
pa0b0=0x2AFD
pa0b1=0xFB41
pa0b2=0x6C
tssifloor2g=12
extpagain2g=2
extpagain5g=2
cckPwrOffset=12
# rssi params for 2.4GHz
rssismf2g=0x2
rssismc2g=0xC
rssisav2g=0x1
# rssi params for 5GHz
rssismf5g=0x8
rssismc5g=0x8
rssisav5g=0x1
#PA parameters for lower band_QM_4p2_120214
pa1lob0=0x1672
pa1lob1=0xFD53
pa1lob2=0xFF69
tssifloor5gl=18
#PA parameters for midband
pa1b0=0x1712
pa1b1=0xFD5D
pa1b2=0xFF82
tssifloor5gm=18
#PA parameters for high band
pa1hib0=0x1696
pa1hib1=0xFD64
pa1hib2=0xFF7A
tssifloor5gh=18
PwrOffset40mhz5g=-10
rxpo5g=0
maxp2ga0=78
ofdm2gpo=0x44444444
mcs2gpo0=0xaaaa
mcs2gpo1=0xaaaa
cckdigfilttype=24
ofdmdigfilttype2g=9
ofdmdigfilttype5g=3
ofdm40digfilttype=8
maxp5gla0=64
ofdm5glpo=0x33333333
mcs5glpo0=0x5555
mcs5glpo1=0x5555
mcs5glpo2=0x7777
mcs5glpo3=0x7777
maxp5ga0=66
ofdm5gpo=0x33333333
mcs5gpo0=0x5555
mcs5gpo1=0x5555
mcs5gpo2=0x7777
mcs5gpo3=0x7777
maxp5gha0=65
ofdm5ghpo=0x33333333
mcs5ghpo0=0x5555
mcs5ghpo1=0x5555
mcs5ghpo2=0x7777
mcs5ghpo3=0x7777
#il0macaddr=00:90:4c:c5:12:38
wl0id=0x431b
pagc2g=0x10
#For HS2734C Module
swctrlmap_2g=0x0c0c0c0c,0x12120202,0x02020202,0x11202,0x1ff
swctrlmap_5g=0x40404040,0xa0a0a0a0,0x80808080,0x11202,0x2f8
elna_off_gain_idx_2g=30
triso2g=6
triso5g=3
muxenab=0x10
#sd_gpout=0
#sd_oobonly=1
dacrate2xen=1
txalpfbyp=1
# In RC58.29, adding to keep the txALPF powered up , even when the txALPF is bypassed.
txalpfpu=1
# 11b ACR Performance
aci_detect_en_2g=1
dacpu.fab.4=1
gain_settle_dly_2g=4
gain_settle_dly_5g=4
#For TSMC rx sensitivity in low rate
noise_cal_po_2g=-1
#For UMC rx sensitivity in low rate
noise_cal_po_2g.fab.4=6
noise_cal_po_40_2g=-1
noise_cal_high_gain_2g=73
noise_cal_nf_substract_val_2g=346
noise_cal_po_5g=-1
noise_cal_po_40_5g=-1
noise_cal_high_gain_5g=73
# Adding in RC58.29
noise_cal_nf_substract_val_5g=346
iqlocalidx5g=55
# In RC58.35/38. Added on For LOFT
dlocalidx5g=75
# In RC58.33, change EPA_or_PAD_lpbck5g=1 to lpbckmode5g=1
#EPA_or_PAD_lpbck5g=1
lpbckmode5g=1
txiqlopapu5g=0
iqcalidx5g=50
txiqlopapu2g=0
#In RC58.35, Change Value to 5
dlorange_lowlimit=5
loflag=1
# In RC58.29, for RSSI return with pkteng_stats
#rssicorrnorm=3
#rssicorratten=3
#rssicorrnorm5g=5,3,3
#rssicorratten5g=5,3,3
#for BT-coexistence
btc_params80=0
btc_params6=10
btc_params95=53
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 6.1.11-rockchip64 (root@7284a09ced08) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 2.32.0.20190321) #trunk.0248 SMP PREEMPT Fri Feb 10 05:25:40 UTC 2023
[    0.000000] Machine model: Rockchip RK3318 BOX
[    0.000000] efi: UEFI not found.
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x00000000feffffff]
[    0.000000] NUMA: NODE_DATA [mem 0xfe7b1a80-0xfe7b3fff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000200000-0x00000000feffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000200000-0x00000000feffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000000feffffff]
[    0.000000] On node 0, zone DMA: 512 pages in unavailable ranges
[    0.000000] On node 0, zone DMA: 4096 pages in unavailable ranges
[    0.000000] cma: Reserved 128 MiB at 0x00000000f2600000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 30 pages/cpu s82472 r8192 d32216 u122880
[    0.000000] pcpu-alloc: s82472 r8192 d32216 u122880 alloc=30*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Fallback order for Node 0: 0
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1027656
[    0.000000] Policy zone: DMA
[    0.000000] Kernel command line: root=UUID=2eb1e931-b16f-46a3-8b3b-f0a92acc8ddb rootwait rootfstype=ext4 splash=verbose console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart=8635553d-01 usb-storage.quirks=   cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
[    0.000000] The swapaccount= commandline option is deprecated. Please report your usecase to linux-mm@kvack.org if you depend on this functionality.
[    0.000000] Unknown kernel command line parameters "splash=verbose ubootpart=8635553d-01 cgroup_enable=memory cgroup_memory=1", will be passed to user space.
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
[    0.000000] Memory: 3913516K/4175872K available (16448K kernel code, 2240K rwdata, 5832K rodata, 3968K init, 585K bss, 131284K reserved, 131072K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] trace event string verifier disabled
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[    0.000000]     Trampoline variant of Tasks RCU enabled.
[    0.000000]     Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000001] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.001077] Console: colour dummy device 80x25
[    0.001159] printk: console [tty1] enabled
[    0.001277] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.001307] pid_max: default: 32768 minimum: 301
[    0.001460] LSM: Security Framework initializing
[    0.001511] Yama: becoming mindful.
[    0.001684] AppArmor: AppArmor initialized
[    0.001732] Stack Depot allocating hash table of 262144 entries with kvcalloc
[    0.002381] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.002421] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.005744] cblist_init_generic: Setting adjustable number of callback queues.
[    0.005772] cblist_init_generic: Setting shift to 2 and lim to 1.
[    0.005962] cblist_init_generic: Setting shift to 2 and lim to 1.
[    0.006408] rcu: Hierarchical SRCU implementation.
[    0.006421] rcu:     Max phase no-delay instances is 1000.
[    0.010047] EFI services will not be available.
[    0.010772] smp: Bringing up secondary CPUs ...
[    0.012023] Detected VIPT I-cache on CPU1
[    0.012214] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.013561] Detected VIPT I-cache on CPU2
[    0.013755] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.015105] Detected VIPT I-cache on CPU3
[    0.015301] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.015507] smp: Brought up 1 node, 4 CPUs
[    0.015536] SMP: Total of 4 processors activated.
[    0.015550] CPU features: detected: 32-bit EL0 Support
[    0.015558] CPU features: detected: 32-bit EL1 Support
[    0.015571] CPU features: detected: CRC32 instructions
[    0.015702] CPU: All CPU(s) started at EL2
[    0.015724] alternatives: applying system-wide alternatives
[    0.019336] devtmpfs: initialized
[    0.043247] Registered cp15_barrier emulation handler
[    0.043279] Registered setend emulation handler
[    0.043727] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.043778] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.049424] pinctrl core: initialized pinctrl subsystem
[    0.050687] DMI not present or invalid.
[    0.051916] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.054984] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.056411] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.057682] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.057811] audit: initializing netlink subsys (disabled)
[    0.058197] audit: type=2000 audit(0.056:1): state=initialized audit_enabled=0 res=1
[    0.059665] thermal_sys: Registered thermal governor 'fair_share'
[    0.059678] thermal_sys: Registered thermal governor 'bang_bang'
[    0.059692] thermal_sys: Registered thermal governor 'step_wise'
[    0.059704] thermal_sys: Registered thermal governor 'user_space'
[    0.059828] cpuidle: using governor menu
[    0.060450] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.060668] ASID allocator initialised with 65536 entries
[    0.062605] Serial: AMBA PL011 UART driver
[    0.081648] platform ff3c0000.hdmi: Fixing up cyclic dependency with ff370000.vop
[    0.108141] rockchip-gpio ff210000.gpio: probed /pinctrl/gpio@ff210000
[    0.109584] rockchip-gpio ff220000.gpio: probed /pinctrl/gpio@ff220000
[    0.110839] rockchip-gpio ff230000.gpio: probed /pinctrl/gpio@ff230000
[    0.112154] rockchip-gpio ff240000.gpio: probed /pinctrl/gpio@ff240000
[    0.150848] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.150872] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
[    0.150889] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.150900] HugeTLB: 508 KiB vmemmap can be freed for a 32.0 MiB page
[    0.150913] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.150923] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[    0.150935] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.150946] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.153323] cryptd: max_cpu_qlen set to 1000
[    0.223505] raid6: neonx8   gen()  1020 MB/s
[    0.291602] raid6: neonx4   gen()  1060 MB/s
[    0.359756] raid6: neonx2   gen()  1004 MB/s
[    0.427906] raid6: neonx1   gen()   879 MB/s
[    0.496065] raid6: int64x8  gen()   744 MB/s
[    0.564232] raid6: int64x4  gen()   821 MB/s
[    0.632366] raid6: int64x2  gen()   707 MB/s
[    0.700521] raid6: int64x1  gen()   526 MB/s
[    0.700538] raid6: using algorithm neonx4 gen() 1060 MB/s
[    0.768670] raid6: .... xor() 769 MB/s, rmw enabled
[    0.768684] raid6: using neon recovery algorithm
[    0.775496] iommu: Default domain type: Translated
[    0.775518] iommu: DMA domain TLB invalidation policy: strict mode
[    0.776405] SCSI subsystem initialized
[    0.776824] libata version 3.00 loaded.
[    0.777431] usbcore: registered new interface driver usbfs
[    0.777526] usbcore: registered new interface driver hub
[    0.777616] usbcore: registered new device driver usb
[    0.778669] pps_core: LinuxPPS API ver. 1 registered
[    0.778682] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.778717] PTP clock support registered
[    0.779103] EDAC MC: Ver: 3.0.0
[    0.782056] NetLabel: Initializing
[    0.782074] NetLabel:  domain hash size = 128
[    0.782087] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.782219] NetLabel:  unlabeled traffic allowed by default
[    0.782530] vgaarb: loaded
[    0.783507] clocksource: Switched to clocksource arch_sys_counter
[    0.784328] VFS: Disk quotas dquot_6.6.0
[    0.784431] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.786068] AppArmor: AppArmor Filesystem Enabled
[    0.803631] NET: Registered PF_INET protocol family
[    0.804088] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.810478] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.810730] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.810841] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.811541] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[    0.812926] TCP: Hash tables configured (established 32768 bind 32768)
[    0.813157] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.813346] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.813851] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.813919] NET: Registered PF_XDP protocol family
[    0.813943] PCI: CLS 0 bytes, default 64
[    0.814743] Trying to unpack rootfs image as initramfs...
[    0.825077] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    0.826210] kvm [1]: IPA Size Limit: 40 bits
[    0.828692] kvm [1]: vgic interrupt IRQ9
[    0.828942] kvm [1]: Hyp mode initialized successfully
[    0.833067] Initialise system trusted keyrings
[    0.833171] Key type blacklist registered
[    0.833614] workingset: timestamp_bits=44 max_order=20 bucket_order=0
[    0.848108] zbud: loaded
[    0.851741] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.853332] fuse: init (API version 7.37)
[    0.858184] integrity: Platform Keyring initialized
[    0.930641] xor: measuring software checksum speed
[    0.938784]    8regs           :  1221 MB/sec
[    0.946675]    32regs          :  1261 MB/sec
[    0.955983]    arm64_neon      :  1062 MB/sec
[    0.956006] xor: using function: 32regs (1261 MB/sec)
[    0.956028] Key type asymmetric registered
[    0.956042] Asymmetric key parser 'x509' registered
[    2.901845] Freeing initrd memory: 21288K
[    2.946017] alg: self-tests for CTR-KDF (hmac(sha256)) passed
[    2.946185] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    2.946446] io scheduler mq-deadline registered
[    2.946464] io scheduler kyber registered
[    2.946908] io scheduler bfq registered
[    2.965736] dma-pl330 ff1f0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    2.965768] dma-pl330 ff1f0000.dma-controller:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    2.974454] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    2.980388] ff110000.serial: ttyS0 at MMIO 0xff110000 (irq = 25, base_baud = 1500000) is a 16550A
[    2.982314] ff130000.serial: ttyS2 at MMIO 0xff130000 (irq = 26, base_baud = 1500000) is a 16550A
[    2.982763] printk: console [ttyS2] enabled
[    2.984791] Serial: AMBA driver
[    2.993449] rockchip-vop ff370000.vop: Adding to iommu group 4
[    3.019398] loop: module loaded
[    3.028186] tun: Universal TUN/TAP device driver, 1.6
[    3.030026] thunder_xcv, ver 1.0
[    3.030121] thunder_bgx, ver 1.0
[    3.030226] nicpf, ver 1.0
[    3.031599] e1000e: Intel(R) PRO/1000 Network Driver
[    3.031612] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    3.031769] igb: Intel(R) Gigabit Ethernet Network Driver
[    3.031783] igb: Copyright (c) 2007-2014 Intel Corporation.
[    3.031858] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    3.031871] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    3.032338] sky2: driver version 1.30
[    3.033445] VFIO - User Level meta-driver version: 0.3
[    3.037277] dwc2 ff580000.usb: supply vusb_d not found, using dummy regulator
[    3.037593] dwc2 ff580000.usb: supply vusb_a not found, using dummy regulator
[    3.051938] dwc2 ff580000.usb: DWC OTG Controller
[    3.052017] dwc2 ff580000.usb: new USB bus registered, assigned bus number 1
[    3.052086] dwc2 ff580000.usb: irq 34, io mem 0xff580000
[    3.052462] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[    3.052488] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.052510] usb usb1: Product: DWC OTG Controller
[    3.052527] usb usb1: Manufacturer: Linux 6.1.11-rockchip64 dwc2_hsotg
[    3.052545] usb usb1: SerialNumber: ff580000.usb
[    3.053688] hub 1-0:1.0: USB hub found
[    3.053759] hub 1-0:1.0: 1 port detected
[    3.058132] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    3.058187] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[    3.058444] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
[    3.058557] xhci-hcd xhci-hcd.0.auto: irq 33, io mem 0xff600000
[    3.059066] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    3.059100] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 3
[    3.059127] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[    3.059169] ehci-platform ff5c0000.usb: EHCI Host Controller
[    3.059200] ohci-platform ff5d0000.usb: Generic Platform OHCI controller
[    3.059482] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[    3.059745] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.059771] usb usb2: Product: xHCI Host Controller
[    3.059788] usb usb2: Manufacturer: Linux 6.1.11-rockchip64 xhci-hcd
[    3.059805] usb usb2: SerialNumber: xhci-hcd.0.auto
[    3.060918] hub 2-0:1.0: USB hub found
[    3.060997] hub 2-0:1.0: 1 port detected
[    3.061769] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
[    3.062032] usb usb3: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[    3.062059] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.062080] usb usb3: Product: xHCI Host Controller
[    3.062097] usb usb3: Manufacturer: Linux 6.1.11-rockchip64 xhci-hcd
[    3.062113] usb usb3: SerialNumber: xhci-hcd.0.auto
[    3.063160] hub 3-0:1.0: USB hub found
[    3.063245] hub 3-0:1.0: 1 port detected
[    3.064017] ehci-platform ff5c0000.usb: new USB bus registered, assigned bus number 4
[    3.064041] ohci-platform ff5d0000.usb: new USB bus registered, assigned bus number 5
[    3.064234] usbcore: registered new interface driver usb-storage
[    3.064259] ehci-platform ff5c0000.usb: irq 35, io mem 0xff5c0000
[    3.064303] ohci-platform ff5d0000.usb: irq 36, io mem 0xff5d0000
[    3.067677] mousedev: PS/2 mouse device common for all mice
[    3.069295] i2c_dev: i2c /dev entries driver
[    3.074026] dw_wdt ff1a0000.watchdog: No valid TOPs array specified
[    3.077859] sdhci: Secure Digital Host Controller Interface driver
[    3.077881] sdhci: Copyright(c) Pierre Ossman
[    3.077938] Synopsys Designware Multimedia Card Interface Driver
[    3.079446] sdhci-pltfm: SDHCI platform and OF driver helper
[    3.079596] ehci-platform ff5c0000.usb: USB 2.0 started, EHCI 1.00
[    3.080158] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[    3.080190] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.080209] usb usb4: Product: EHCI Host Controller
[    3.080223] usb usb4: Manufacturer: Linux 6.1.11-rockchip64 ehci_hcd
[    3.080238] usb usb4: SerialNumber: ff5c0000.usb
[    3.080365] dwmmc_rockchip ff500000.mmc: IDMAC supports 32-bit address mode.
[    3.080415] dwmmc_rockchip ff500000.mmc: Using internal DMA controller.
[    3.080436] dwmmc_rockchip ff500000.mmc: Version ID is 270a
[    3.080534] dwmmc_rockchip ff500000.mmc: DW MMC controller at irq 39,32 bit host data width,256 deep fifo
[    3.080834] dwmmc_rockchip ff520000.mmc: IDMAC supports 32-bit address mode.
[    3.080888] dwmmc_rockchip ff520000.mmc: Using internal DMA controller.
[    3.080908] dwmmc_rockchip ff520000.mmc: Version ID is 270a
[    3.081006] dwmmc_rockchip ff520000.mmc: DW MMC controller at irq 40,32 bit host data width,256 deep fifo
[    3.081136] dwmmc_rockchip ff500000.mmc: Got CD GPIO
[    3.081934] mmc_host mmc2: card is non-removable.
[    3.082117] dwmmc_rockchip ff5f0000.mmc: IDMAC supports 32-bit address mode.
[    3.082175] dwmmc_rockchip ff5f0000.mmc: Using internal DMA controller.
[    3.082195] dwmmc_rockchip ff5f0000.mmc: Version ID is 270a
[    3.082301] dwmmc_rockchip ff5f0000.mmc: DW MMC controller at irq 41,32 bit host data width,256 deep fifo
[    3.082454] hub 4-0:1.0: USB hub found
[    3.082594] hub 4-0:1.0: 1 port detected
[    3.082746] dwmmc_rockchip ff5f0000.mmc: allocated mmc-pwrseq
[    3.082768] mmc_host mmc4: card is non-removable.
[    3.083954] ledtrig-cpu: registered to indicate activity on CPUs
[    3.084878] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    3.085314] hid: raw HID events driver (C) Jiri Kosina
[    3.085575] usbcore: registered new interface driver usbhid
[    3.085591] usbhid: USB HID core driver
[    3.094073] drop_monitor: Initializing network drop monitor service
[    3.094300] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    3.094812] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    3.095431] NET: Registered PF_INET6 protocol family
[    3.095635] mmc_host mmc4: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    3.131941] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.01
[    3.131977] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.131995] usb usb5: Product: Generic Platform OHCI controller
[    3.132010] usb usb5: Manufacturer: Linux 6.1.11-rockchip64 ohci_hcd
[    3.132025] usb usb5: SerialNumber: ff5d0000.usb
[    3.133059] hub 5-0:1.0: USB hub found
[    3.133158] hub 5-0:1.0: 1 port detected
[    3.139755] Segment Routing with IPv6
[    3.139872] In-situ OAM (IOAM) with IPv6
[    3.140079] NET: Registered PF_PACKET protocol family
[    3.140364] 8021q: 802.1Q VLAN Support v1.8
[    3.140467] Key type dns_resolver registered
[    3.142782] registered taskstats version 1
[    3.142841] Loading compiled-in X.509 certificates
[    3.149442] Loaded X.509 cert 'Build time autogenerated kernel key: e25f7f61aa13aedd90bace25454c8646dc5da469'
[    3.153458] zswap: loaded using pool zstd/z3fold
[    3.154032] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[    3.154175] mmc0: new high speed SDHC card at address 8dfc
[    3.154667] Key type .fscrypt registered
[    3.154689] Key type fscrypt-provisioning registered
[    3.155868] mmcblk0: mmc0:8dfc SU16G 14.8 GiB
[    3.159820] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=yes
[    3.160705] Key type encrypted registered
[    3.160765] AppArmor: AppArmor sha1 policy hashing enabled
[    3.162039]  mmcblk0: p1
[    3.190676] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 52000000Hz, actual 50000000HZ div = 0)
[    3.191104] mmc2: new high speed MMC card at address 0001
[    3.192870] mmcblk2: mmc2:0001 CKTM4R 58.2 GiB
[    3.198000] mmcblk2boot0: mmc2:0001 CKTM4R 4.00 MiB
[    3.202214] mmcblk2boot1: mmc2:0001 CKTM4R 4.00 MiB
[    3.206165] mmcblk2rpmb: mmc2:0001 CKTM4R 4.00 MiB, chardev (242:0)
[    3.220373] mmc_host mmc4: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[    3.224827] mmc4: new high speed SDIO card at address 0001
[    3.255583] rockchip-drm display-subsystem: bound ff370000.vop (ops vop_component_ops)
[    3.255752] dwhdmi-rockchip ff3c0000.hdmi: supply avdd-0v9 not found, using dummy regulator
[    3.256140] dwhdmi-rockchip ff3c0000.hdmi: supply avdd-1v8 not found, using dummy regulator
[    3.256716] dwhdmi-rockchip ff3c0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (inno_dw_hdmi_phy2)
[    3.258037] dwhdmi-rockchip ff3c0000.hdmi: registered DesignWare HDMI I2C bus driver
[    3.258947] rockchip-drm display-subsystem: bound ff3c0000.hdmi (ops dw_hdmi_rockchip_ops)
[    3.260288] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 0
[    3.260402] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[    3.260831] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[    3.260874] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[    3.261473] WCN: marlin_init entry!
[    3.262324] of_cfs_init
[    3.262382] of_cfs_init: OK
[    3.265646] Freeing unused kernel memory: 3968K
[    3.275699] Run /init as init process
[    3.275723]   with arguments:
[    3.275735]     /init
[    3.275748]   with environment:
[    3.275759]     HOME=/
[    3.275770]     TERM=linux
[    3.275781]     splash=verbose
[    3.275793]     ubootpart=8635553d-01
[    3.275804]     cgroup_enable=memory
[    3.275817]     cgroup_memory=1
[    4.290950] input: adc-keys as /devices/platform/adc-keys/input/input0
[    4.334308] gpio-syscon ff100000.syscon:gpio: can't read the data register offset!
[    4.406577] lima ff300000.gpu: gp - mali450 version major 0 minor 0
[    4.407747] lima ff300000.gpu: pp0 - mali450 version major 0 minor 0
[    4.408018] lima ff300000.gpu: pp1 - mali450 version major 0 minor 0
[    4.408139] lima ff300000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
[    4.408164] lima ff300000.gpu: l2 cache 64K, 4-way, 64byte cache line, 128bit external bus
[    4.420639] lima ff300000.gpu: bus rate = 491520000
[    4.420676] lima ff300000.gpu: mod rate = 491520000
[    4.437605] [drm] Initialized lima 1.1.0 20191231 for ff300000.gpu on minor 1
[    4.498673] rk_gmac-dwmac ff550000.ethernet: IRQ eth_wake_irq not found
[    4.498705] rk_gmac-dwmac ff550000.ethernet: IRQ eth_lpi not found
[    4.498918] rk_gmac-dwmac ff550000.ethernet: PTP uses main clock
[    4.521373] rk_gmac-dwmac ff550000.ethernet: clock input or output? (output).
[    4.521409] rk_gmac-dwmac ff550000.ethernet: TX delay(0x30).
[    4.521429] rk_gmac-dwmac ff550000.ethernet: RX delay(0x10).
[    4.521478] rk_gmac-dwmac ff550000.ethernet: integrated PHY? (yes).
[    4.521623] rk_gmac-dwmac ff550000.ethernet: cannot get clock clk_mac_refout
[    4.521647] rk_gmac-dwmac ff550000.ethernet: cannot get clock clk_mac_speed
[    4.526731] rk_gmac-dwmac ff550000.ethernet: init for RMII
[    4.574223] rk_gmac-dwmac ff550000.ethernet: User ID: 0x10, Synopsys ID: 0x35
[    4.574270] rk_gmac-dwmac ff550000.ethernet:     DWMAC1000
[    4.574286] rk_gmac-dwmac ff550000.ethernet: DMA HW capability register supported
[    4.574300] rk_gmac-dwmac ff550000.ethernet: RX Checksum Offload Engine supported
[    4.574313] rk_gmac-dwmac ff550000.ethernet: COE Type 2
[    4.574327] rk_gmac-dwmac ff550000.ethernet: TX Checksum insertion supported
[    4.574340] rk_gmac-dwmac ff550000.ethernet: Wake-Up On Lan supported
[    4.574524] rk_gmac-dwmac ff550000.ethernet: Normal descriptors
[    4.574552] rk_gmac-dwmac ff550000.ethernet: Ring mode enabled
[    4.574565] rk_gmac-dwmac ff550000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    4.697418] rk_gmac-dwmac ff550000.ethernet end1: renamed from eth0
[    4.901328] dw-apb-uart ff130000.serial: forbid DMA for kernel console
[    5.700862] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Quota mode: none.
[    7.814874] systemd[1]: System time before build time, advancing clock.
[    7.896649] systemd[1]: Inserted module 'autofs4'
[    8.064648] systemd[1]: systemd 252.5-2 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[    8.064709] systemd[1]: Detected architecture arm64.
[    8.085448] systemd[1]: Hostname set to <rk3318-box>.
[    9.449804] systemd[324]: /usr/lib/systemd/system-generators/netplan failed with exit status 1.
[   10.755016] systemd[1]: Queued start job for default target graphical.target.
[   10.785529] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
[   10.790212] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
[   10.794528] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
[   10.797877] systemd[1]: Created slice user.slice - User and Session Slice.
[   10.798944] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
[   10.801118] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
[   10.801886] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
[   10.802505] systemd[1]: Reached target remote-fs.target - Remote File Systems.
[   10.802886] systemd[1]: Reached target slices.target - Slice Units.
[   10.803360] systemd[1]: Reached target swap.target - Swaps.
[   10.803832] systemd[1]: Reached target time-set.target - System Time Set.
[   10.804594] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
[   10.810400] systemd[1]: Listening on syslog.socket - Syslog Socket.
[   10.811996] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
[   10.813009] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
[   10.815007] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
[   10.816775] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
[   10.818940] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
[   10.833839] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
[   10.835384] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[   10.864109] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
[   10.873729] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
[   10.883315] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
[   10.893622] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
[   10.908228] systemd[1]: Starting fake-hwclock.service - Restore / save the current clock...
[   10.918622] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
[   10.929795] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
[   10.941042] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
[   10.953403] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
[   10.965798] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
[   10.977861] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
[   10.979928] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
[   11.013202] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
[   11.023960] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
[   11.025055] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
[   11.035443] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
[   11.054063] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
[   11.056989] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
[   11.059960] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
[   11.062877] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
[   11.067313] systemd[1]: Finished fake-hwclock.service - Restore / save the current clock.
[   11.073034] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
[   11.079049] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[   11.081478] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
[   11.085890] systemd[1]: modprobe@drm.service: Deactivated successfully.
[   11.088185] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
[   11.092697] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[   11.095110] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
[   11.101755] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[   11.104286] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
[   11.108336] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
[   11.144963] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
[   11.151690] EXT4-fs (mmcblk0p1): re-mounted. Quota mode: none.
[   11.156781] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
[   11.167735] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables...
[   11.192568] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
[   11.196289] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
[   11.199046] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
[   11.202346] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
[   11.241521] systemd[1]: Starting systemd-random-seed.service - Load/Save Random Seed...
[   11.252797] systemd[1]: Starting systemd-sysusers.service - Create System Users...
[   11.318748] systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables.
[   11.411839] systemd[1]: Finished systemd-sysusers.service - Create System Users.
[   11.448679] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev...
[   11.630246] systemd[1]: Finished systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev.
[   11.657177] systemd[1]: Starting systemd-udevd.service - Rule-based Manager for Device Events and Files...
[   11.661791] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout.
[   11.665387] systemd[1]: Reached target local-fs-pre.target - Preparation for Local File Systems.
[   11.680204] systemd[1]: Mounting tmp.mount - /tmp...
[   11.708745] systemd[1]: Mounted tmp.mount - /tmp.
[   11.712121] systemd[1]: Reached target local-fs.target - Local File Systems.
[   11.758169] systemd[1]: Starting armbian-led-state.service - Armbian leds state...
[   11.779932] systemd[1]: Starting armbian-zram-config.service - Armbian ZRAM config...
[   11.802001] systemd[1]: Starting console-setup.service - Set console font and keymap...
[   11.813965] systemd[1]: Starting plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data...
[   11.884803] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
[   11.889977] systemd[1]: Finished console-setup.service - Set console font and keymap.
[   11.921169] systemd[1]: Received SIGRTMIN+20 from PID 289 (plymouthd).
[   11.966672] systemd[1]: Finished plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data.
[   12.009539] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 389 (systemd-binfmt)
[   12.076286] systemd[1]: Mounting proc-sys-fs-binfmt_misc.mount - Arbitrary Executable File Formats File System...
[   12.110974] systemd[1]: Finished armbian-led-state.service - Armbian leds state.
[   12.160632] systemd[1]: Mounted proc-sys-fs-binfmt_misc.mount - Arbitrary Executable File Formats File System.
[   12.179049] systemd[1]: Finished systemd-binfmt.service - Set Up Additional Binary Formats.
[   12.315380] systemd[1]: Finished systemd-udev-trigger.service - Coldplug All udev Devices.
[   12.348973] systemd[1]: Starting ifupdown-pre.service - Helper to synchronize boot up for ifupdown...
[   12.453974] systemd[1]: Finished ifupdown-pre.service - Helper to synchronize boot up for ifupdown.
[   12.606500] systemd[1]: Started systemd-udevd.service - Rule-based Manager for Device Events and Files.
[   12.640307] systemd[1]: Starting plymouth-start.service - Show Plymouth Boot Screen...
[   12.843976] systemd[1]: Started plymouth-start.service - Show Plymouth Boot Screen.
[   12.846523] systemd[1]: bootsplash-ask-password-console.path - Dispatch Password Requests to Console Directory Watch when bootsplash is active was skipped because of an unmet condition check (ConditionPathExists=/sys/devices/platform/bootsplash.0/enabled).
[   12.848073] systemd[1]: Started systemd-ask-password-plymouth.path - Forward Password Requests to Plymouth Directory Watch.
[   12.848671] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
[   12.849192] systemd[1]: Reached target paths.target - Path Units.
[   12.915572] systemd[1]: Found device dev-ttyS2.device - /dev/ttyS2.
[   13.083966] zram: Added device: zram0
[   13.085619] zram: Added device: zram1
[   13.087259] zram: Added device: zram2
[   13.364883] zram0: detected capacity change from 0 to 4069848
[   13.673661] mc: Linux media interface: v0.10
[   13.759289] videodev: Linux video capture interface: v2.00
[   13.954942] rockchip-rga ff390000.rga: HW Version: 0x04.00
[   13.958242] rockchip-rga ff390000.rga: Registered rockchip-rga as /dev/video0
[   14.118238] Registered IR keymap rc-empty
[   14.118415] rc rc0: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc0
[   14.135955] rc rc0: lirc_dev: driver gpio_ir_recv registered at minor = 0, raw IR receiver, no transmitter
[   14.136205] input: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc0/input1
[   14.186435] rockchip_vdec: module is from the staging directory, the quality is unknown, you have been warned.
[   14.195391] rkvdec ff360000.video-codec: Adding to iommu group 3
[   14.250903] hantro-vpu ff350000.video-codec: Adding to iommu group 2
[   14.254055] hantro-vpu ff350000.video-codec: registered rockchip,rk3328-vpu-dec as /dev/video2
[   14.291749] rk3328-codec ff410000.codec: spk_depop_time use default value.
[   14.369454] systemd[1]: Listening on systemd-rfkill.socket - Load/Save RF Kill Switch Status /dev/rfkill Watch.
[   14.434882] systemd[1]: Reached target sound.target - Sound Card.
[   14.509734] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   14.511226] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   14.575441] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[   14.642081] brcmfmac: F1 signature read @0x18000000=0x16034334
[   14.647632] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4334-sdio for chip BCM4334/3
[   14.648264] usbcore: registered new interface driver brcmfmac
[   14.659553] brcmfmac mmc4:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.rockchip,rk3318-box.bin failed with error -2
[   14.691891] brcmfmac mmc4:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.clm_blob failed with error -2
[   14.831530] random: crng init done
[   14.850455] systemd[1]: Finished systemd-random-seed.service - Load/Save Random Seed.
[   14.852214] systemd[1]: first-boot-complete.target - First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes).
[   14.852488] systemd[1]: systemd-machine-id-commit.service - Commit a transient machine-id on disk was skipped because of an unmet condition check (ConditionPathIsMountPoint=/etc/machine-id).
[   14.904182] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
[   14.904722] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4334/3 wl0: Jul 24 2019 12:58:36 version 6.10.191 (TOB) (r) FWID 01-b049404e
[   14.938634] Adding 2034920k swap on /dev/zram0.  Priority:5 extents:1 across:2034920k SSFS
[   14.944519] systemd[1]: Starting systemd-rfkill.service - Load/Save RF Kill Switch Status...
[   15.044673] systemd[1]: Started systemd-rfkill.service - Load/Save RF Kill Switch Status.
[   15.265587] zram1: detected capacity change from 0 to 102400
[   15.419481] systemd[1]: Finished armbian-zram-config.service - Armbian ZRAM config.
[   15.453068] systemd[1]: Starting armbian-ramlog.service - Armbian memory supported logging...
[   15.568070] EXT4-fs (zram1): mounted filesystem without journal. Quota mode: none.
[   20.053606] systemd[1]: systemd-rfkill.service: Deactivated successfully.
[   20.086979] systemd[1]: Finished armbian-ramlog.service - Armbian memory supported logging.
[   20.125218] systemd[1]: Starting systemd-journald.service - Journal Service...
[   20.469756] systemd[1]: Started systemd-journald.service - Journal Service.
[   20.552992] systemd-journald[555]: Received client request to flush runtime journal.
[   20.577479] systemd-journald[555]: File /var/log/journal/8f80d697a24e4be4bff1724efb455156/system.journal corrupted or uncleanly shut down, renaming and replacing.
[   22.632184] systemd-journald[555]: Received client request to relinquish /var/log/journal/8f80d697a24e4be4bff1724efb455156 access.
[   27.275715] rk_gmac-dwmac ff550000.ethernet end1: Register MEM_TYPE_PAGE_POOL RxQ-0
[   27.341828] rk_gmac-dwmac ff550000.ethernet end1: PHY [stmmac-1:00] driver [Rockchip integrated EPHY] (irq=POLL)
[   27.351949] rk_gmac-dwmac ff550000.ethernet end1: No Safety Features support found
[   27.351994] rk_gmac-dwmac ff550000.ethernet end1: PTP not supported by HW
[   27.353006] rk_gmac-dwmac ff550000.ethernet end1: configuring for phy/rmii link mode
[   29.415991] rk_gmac-dwmac ff550000.ethernet end1: Link is Up - 100Mbps/Full - flow control rx/tx
[   29.416077] IPv6: ADDRCONF(NETDEV_CHANGE): end1: link becomes ready
@mikes123 run again rk3318-config, select again led-conf2 and then reboot again. It should appear wlan-ap6334 in overlays line in armbianEnv.txt
Without changes.
android tv firmware works.
verbosity=1
bootlogo=false
overlay_prefix=rockchip
fdtfile=rockchip/rk3318-box.dtb
rootdev=UUID=2eb1e931-b16f-46a3-8b3b-f0a92acc8ddb
rootfstype=ext4
overlays=rk3318-box-led-conf2 rk3318-box-wlan-ap6334
[    0.000000] NUMA: NODE_DATA [mem 0xfe7afa80-0xfe7b1fff]
[    0.000000] Memory: 3913508K/4175872K available (16448K kernel code, 2240K rwdata, 5832K rodata, 3968K init, 585K bss, 131292K reserved, 131072K cma-reserved)
[    0.001108] Console: colour dummy device 80x25
[    0.001191] printk: console [tty1] enabled
[    0.001312] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.001340] pid_max: default: 32768 minimum: 301
[    0.001491] LSM: Security Framework initializing
[    0.001544] Yama: becoming mindful.
[    0.001708] AppArmor: AppArmor initialized
[    0.001756] Stack Depot allocating hash table of 262144 entries with kvcalloc
[    0.002407] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.002447] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.005774] cblist_init_generic: Setting adjustable number of callback queues.
[    0.005802] cblist_init_generic: Setting shift to 2 and lim to 1.
[    0.005991] cblist_init_generic: Setting shift to 2 and lim to 1.
[    0.006439] rcu: Hierarchical SRCU implementation.
[    0.006450] rcu:     Max phase no-delay instances is 1000.
[    0.010124] EFI services will not be available.
[    0.010854] smp: Bringing up secondary CPUs ...
[    0.012099] Detected VIPT I-cache on CPU1
[    0.012290] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.013625] Detected VIPT I-cache on CPU2
[    0.013816] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.015156] Detected VIPT I-cache on CPU3
[    0.015352] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.015560] smp: Brought up 1 node, 4 CPUs
[    0.015585] SMP: Total of 4 processors activated.
[    0.015599] CPU features: detected: 32-bit EL0 Support
[    0.015607] CPU features: detected: 32-bit EL1 Support
[    0.015619] CPU features: detected: CRC32 instructions
[    0.015834] CPU: All CPU(s) started at EL2
[    0.015863] alternatives: applying system-wide alternatives
[    0.019449] devtmpfs: initialized
[    0.043837] Registered cp15_barrier emulation handler
[    0.043870] Registered setend emulation handler
[    0.044367] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.044418] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.050014] pinctrl core: initialized pinctrl subsystem
[    0.051282] DMI not present or invalid.
[    0.052545] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.055567] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.057036] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.058249] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.058369] audit: initializing netlink subsys (disabled)
[    0.058762] audit: type=2000 audit(0.056:1): state=initialized audit_enabled=0 res=1
[    0.060300] thermal_sys: Registered thermal governor 'fair_share'
[    0.060314] thermal_sys: Registered thermal governor 'bang_bang'
[    0.060327] thermal_sys: Registered thermal governor 'step_wise'
[    0.060339] thermal_sys: Registered thermal governor 'user_space'
[    0.060455] cpuidle: using governor menu
[    0.061082] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.061305] ASID allocator initialised with 65536 entries
[    0.063284] Serial: AMBA PL011 UART driver
[    0.082578] platform ff3c0000.hdmi: Fixing up cyclic dependency with ff370000.vop
[    0.109345] rockchip-gpio ff210000.gpio: probed /pinctrl/gpio@ff210000
[    0.110897] rockchip-gpio ff220000.gpio: probed /pinctrl/gpio@ff220000
[    0.112142] rockchip-gpio ff230000.gpio: probed /pinctrl/gpio@ff230000
[    0.113439] rockchip-gpio ff240000.gpio: probed /pinctrl/gpio@ff240000
[    0.153097] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.153121] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
[    0.153138] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.153149] HugeTLB: 508 KiB vmemmap can be freed for a 32.0 MiB page
[    0.153164] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.153174] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[    0.153187] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.153199] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.155362] cryptd: max_cpu_qlen set to 1000
[    0.225544] raid6: neonx8   gen()  1038 MB/s
[    0.293752] raid6: neonx4   gen()  1064 MB/s
[    0.361914] raid6: neonx2   gen()  1004 MB/s
[    0.430060] raid6: neonx1   gen()   879 MB/s
[    0.498212] raid6: int64x8  gen()   744 MB/s
[    0.566360] raid6: int64x4  gen()   825 MB/s
[    0.634503] raid6: int64x2  gen()   707 MB/s
[    0.702673] raid6: int64x1  gen()   525 MB/s
[    0.702691] raid6: using algorithm neonx4 gen() 1064 MB/s
[    0.770809] raid6: .... xor() 769 MB/s, rmw enabled
[    0.770825] raid6: using neon recovery algorithm
[    0.777541] iommu: Default domain type: Translated
[    0.777563] iommu: DMA domain TLB invalidation policy: strict mode
[    0.778425] SCSI subsystem initialized
[    0.778812] libata version 3.00 loaded.
[    0.779415] usbcore: registered new interface driver usbfs
[    0.779507] usbcore: registered new interface driver hub
[    0.779584] usbcore: registered new device driver usb
[    0.780646] pps_core: LinuxPPS API ver. 1 registered
[    0.780660] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.780705] PTP clock support registered
[    0.781103] EDAC MC: Ver: 3.0.0
[    0.784056] NetLabel: Initializing
[    0.784076] NetLabel:  domain hash size = 128
[    0.784088] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.784218] NetLabel:  unlabeled traffic allowed by default
[    0.784567] vgaarb: loaded
[    0.785575] clocksource: Switched to clocksource arch_sys_counter
[    0.786315] VFS: Disk quotas dquot_6.6.0
[    0.786427] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.788062] AppArmor: AppArmor Filesystem Enabled
[    0.806012] NET: Registered PF_INET protocol family
[    0.806440] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.812741] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.813016] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.813121] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.813829] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[    0.815221] TCP: Hash tables configured (established 32768 bind 32768)
[    0.815469] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.815656] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.816151] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.816226] NET: Registered PF_XDP protocol family
[    0.816248] PCI: CLS 0 bytes, default 64
[    0.817242] Trying to unpack rootfs image as initramfs...
[    0.827125] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    0.828288] kvm [1]: IPA Size Limit: 40 bits
[    0.830757] kvm [1]: vgic interrupt IRQ9
[    0.831005] kvm [1]: Hyp mode initialized successfully
[    0.835134] Initialise system trusted keyrings
[    0.835250] Key type blacklist registered
[    0.835777] workingset: timestamp_bits=44 max_order=20 bucket_order=0
[    0.850164] zbud: loaded
[    0.853796] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.855389] fuse: init (API version 7.37)
[    0.860214] integrity: Platform Keyring initialized
[    0.933251] xor: measuring software checksum speed
[    0.941390]    8regs           :  1221 MB/sec
[    0.949283]    32regs          :  1261 MB/sec
[    0.958603]    arm64_neon      :  1061 MB/sec
[    0.958628] xor: using function: 32regs (1261 MB/sec)
[    0.958650] Key type asymmetric registered
[    0.958662] Asymmetric key parser 'x509' registered
[    2.906794] Freeing initrd memory: 21288K
[    2.950833] alg: self-tests for CTR-KDF (hmac(sha256)) passed
[    2.950999] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    2.951268] io scheduler mq-deadline registered
[    2.951283] io scheduler kyber registered
[    2.951734] io scheduler bfq registered
[    2.970700] dma-pl330 ff1f0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    2.970733] dma-pl330 ff1f0000.dma-controller:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    2.979370] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    2.985293] ff110000.serial: ttyS0 at MMIO 0xff110000 (irq = 25, base_baud = 1500000) is a 16550A
[    2.985706] serial serial0: tty port ttyS0 registered
[    2.987681] ff130000.serial: ttyS2 at MMIO 0xff130000 (irq = 26, base_baud = 1500000) is a 16550A
[    2.988125] printk: console [ttyS2] enabled
[    2.990177] Serial: AMBA driver
[    2.998905] rockchip-vop ff370000.vop: Adding to iommu group 4
[    3.024966] loop: module loaded
[    3.033940] tun: Universal TUN/TAP device driver, 1.6
[    3.035751] thunder_xcv, ver 1.0
[    3.035845] thunder_bgx, ver 1.0
[    3.035943] nicpf, ver 1.0
[    3.037325] e1000e: Intel(R) PRO/1000 Network Driver
[    3.037337] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    3.037442] igb: Intel(R) Gigabit Ethernet Network Driver
[    3.037455] igb: Copyright (c) 2007-2014 Intel Corporation.
[    3.037527] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    3.037542] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    3.038059] sky2: driver version 1.30
[    3.039215] VFIO - User Level meta-driver version: 0.3
[    3.043101] dwc2 ff580000.usb: supply vusb_d not found, using dummy regulator
[    3.043417] dwc2 ff580000.usb: supply vusb_a not found, using dummy regulator
[    3.056519] dwc2 ff580000.usb: DWC OTG Controller
[    3.056577] dwc2 ff580000.usb: new USB bus registered, assigned bus number 1
[    3.056639] dwc2 ff580000.usb: irq 34, io mem 0xff580000
[    3.057016] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[    3.057043] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.057062] usb usb1: Product: DWC OTG Controller
[    3.057079] usb usb1: Manufacturer: Linux 6.1.11-rockchip64 dwc2_hsotg
[    3.057095] usb usb1: SerialNumber: ff580000.usb
[    3.058293] hub 1-0:1.0: USB hub found
[    3.058367] hub 1-0:1.0: 1 port detected
[    3.062770] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    3.062825] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[    3.063104] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
[    3.063228] xhci-hcd xhci-hcd.0.auto: irq 33, io mem 0xff600000
[    3.063731] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    3.063759] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 3
[    3.063770] ehci-platform ff5c0000.usb: EHCI Host Controller
[    3.063789] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[    3.063801] ohci-platform ff5d0000.usb: Generic Platform OHCI controller
[    3.063809] ehci-platform ff5c0000.usb: new USB bus registered, assigned bus number 4
[    3.064011] ehci-platform ff5c0000.usb: irq 35, io mem 0xff5c0000
[    3.064158] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[    3.064184] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.064202] usb usb2: Product: xHCI Host Controller
[    3.064219] usb usb2: Manufacturer: Linux 6.1.11-rockchip64 xhci-hcd
[    3.064237] usb usb2: SerialNumber: xhci-hcd.0.auto
[    3.065299] hub 2-0:1.0: USB hub found
[    3.065383] hub 2-0:1.0: 1 port detected
[    3.066451] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
[    3.066716] usb usb3: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[    3.066741] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.066759] usb usb3: Product: xHCI Host Controller
[    3.066776] usb usb3: Manufacturer: Linux 6.1.11-rockchip64 xhci-hcd
[    3.066794] usb usb3: SerialNumber: xhci-hcd.0.auto
[    3.067865] hub 3-0:1.0: USB hub found
[    3.067936] hub 3-0:1.0: 1 port detected
[    3.068670] ohci-platform ff5d0000.usb: new USB bus registered, assigned bus number 5
[    3.068886] usbcore: registered new interface driver usb-storage
[    3.068920] ohci-platform ff5d0000.usb: irq 36, io mem 0xff5d0000
[    3.072452] mousedev: PS/2 mouse device common for all mice
[    3.074219] i2c_dev: i2c /dev entries driver
[    3.077609] ehci-platform ff5c0000.usb: USB 2.0 started, EHCI 1.00
[    3.078247] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[    3.078280] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.078297] usb usb4: Product: EHCI Host Controller
[    3.078313] usb usb4: Manufacturer: Linux 6.1.11-rockchip64 ehci_hcd
[    3.078328] usb usb4: SerialNumber: ff5c0000.usb
[    3.078973] dw_wdt ff1a0000.watchdog: No valid TOPs array specified
[    3.079406] hub 4-0:1.0: USB hub found
[    3.079512] hub 4-0:1.0: 1 port detected
[    3.082558] sdhci: Secure Digital Host Controller Interface driver
[    3.082579] sdhci: Copyright(c) Pierre Ossman
[    3.082654] Synopsys Designware Multimedia Card Interface Driver
[    3.084295] sdhci-pltfm: SDHCI platform and OF driver helper
[    3.085252] dwmmc_rockchip ff520000.mmc: IDMAC supports 32-bit address mode.
[    3.085310] dwmmc_rockchip ff520000.mmc: Using internal DMA controller.
[    3.085331] dwmmc_rockchip ff520000.mmc: Version ID is 270a
[    3.085430] dwmmc_rockchip ff520000.mmc: DW MMC controller at irq 39,32 bit host data width,256 deep fifo
[    3.085442] dwmmc_rockchip ff5f0000.mmc: IDMAC supports 32-bit address mode.
[    3.085482] dwmmc_rockchip ff5f0000.mmc: Using internal DMA controller.
[    3.085502] dwmmc_rockchip ff5f0000.mmc: Version ID is 270a
[    3.085646] dwmmc_rockchip ff5f0000.mmc: DW MMC controller at irq 41,32 bit host data width,256 deep fifo
[    3.086174] dwmmc_rockchip ff5f0000.mmc: allocated mmc-pwrseq
[    3.086199] mmc_host mmc4: card is non-removable.
[    3.086399] mmc_host mmc2: card is non-removable.
[    3.086735] dwmmc_rockchip ff500000.mmc: IDMAC supports 32-bit address mode.
[    3.086793] dwmmc_rockchip ff500000.mmc: Using internal DMA controller.
[    3.086812] dwmmc_rockchip ff500000.mmc: Version ID is 270a
[    3.086922] dwmmc_rockchip ff500000.mmc: DW MMC controller at irq 40,32 bit host data width,256 deep fifo
[    3.087494] dwmmc_rockchip ff500000.mmc: Got CD GPIO
[    3.089489] ledtrig-cpu: registered to indicate activity on CPUs
[    3.090484] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    3.090960] hid: raw HID events driver (C) Jiri Kosina
[    3.091221] usbcore: registered new interface driver usbhid
[    3.091236] usbhid: USB HID core driver
[    3.097699] mmc_host mmc4: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    3.099317] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    3.099320] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    3.099674] drop_monitor: Initializing network drop monitor service
[    3.101024] NET: Registered PF_INET6 protocol family
[    3.130012] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.01
[    3.130049] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.130066] usb usb5: Product: Generic Platform OHCI controller
[    3.130082] usb usb5: Manufacturer: Linux 6.1.11-rockchip64 ohci_hcd
[    3.130099] usb usb5: SerialNumber: ff5d0000.usb
[    3.131224] hub 5-0:1.0: USB hub found
[    3.131303] hub 5-0:1.0: 1 port detected
[    3.147132] Segment Routing with IPv6
[    3.147265] In-situ OAM (IOAM) with IPv6
[    3.147448] NET: Registered PF_PACKET protocol family
[    3.147707] 8021q: 802.1Q VLAN Support v1.8
[    3.147815] Key type dns_resolver registered
[    3.150157] registered taskstats version 1
[    3.150208] Loading compiled-in X.509 certificates
[    3.156145] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[    3.156275] mmc0: new high speed SDHC card at address 8dfc
[    3.156765] Loaded X.509 cert 'Build time autogenerated kernel key: e25f7f61aa13aedd90bace25454c8646dc5da469'
[    3.157975] mmcblk0: mmc0:8dfc SU16G 14.8 GiB
[    3.161921] zswap: loaded using pool zstd/z3fold
[    3.163056] Key type .fscrypt registered
[    3.163080] Key type fscrypt-provisioning registered
[    3.166417]  mmcblk0: p1
[    3.166552] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=yes
[    3.167197] Key type encrypted registered
[    3.167245] AppArmor: AppArmor sha1 policy hashing enabled
[    3.196783] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 52000000Hz, actual 50000000HZ div = 0)
[    3.197107] mmc2: new high speed MMC card at address 0001
[    3.198844] mmcblk2: mmc2:0001 CKTM4R 58.2 GiB
[    3.204216] mmcblk2boot0: mmc2:0001 CKTM4R 4.00 MiB
[    3.208982] mmcblk2boot1: mmc2:0001 CKTM4R 4.00 MiB
[    3.212834] mmcblk2rpmb: mmc2:0001 CKTM4R 4.00 MiB, chardev (242:0)
[    3.228780] mmc_host mmc4: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[    3.261295] rockchip-drm display-subsystem: bound ff370000.vop (ops vop_component_ops)
[    3.261468] dwhdmi-rockchip ff3c0000.hdmi: supply avdd-0v9 not found, using dummy regulator
[    3.261894] dwhdmi-rockchip ff3c0000.hdmi: supply avdd-1v8 not found, using dummy regulator
[    3.262464] dwhdmi-rockchip ff3c0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (inno_dw_hdmi_phy2)
[    3.263777] dwhdmi-rockchip ff3c0000.hdmi: registered DesignWare HDMI I2C bus driver
[    3.264676] rockchip-drm display-subsystem: bound ff3c0000.hdmi (ops dw_hdmi_rockchip_ops)
[    3.265981] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 0
[    3.266094] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[    3.266528] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[    3.266571] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[    3.267150] WCN: marlin_init entry!
[    3.268003] of_cfs_init
[    3.268085] of_cfs_init: OK
[    3.271487] Freeing unused kernel memory: 3968K
[    3.301756] Run /init as init process
[    3.301778]   with arguments:
[    3.301790]     /init
[    3.301801]   with environment:
[    3.301812]     HOME=/
[    3.301824]     TERM=linux
[    3.301836]     splash=verbose
[    3.301848]     ubootpart=8635553d-01
[    3.301860]     cgroup_enable=memory
[    3.301873]     cgroup_memory=1
[    3.566338] dwmmc_rockchip ff5f0000.mmc: Successfully tuned phase to 162
[    3.570885] mmc4: new ultra high speed SDR50 SDIO card at address 0001
[    4.334438] input: adc-keys as /devices/platform/adc-keys/input/input0
[    4.362994] gpio-syscon ff100000.syscon:gpio: can't read the data register offset!
[    4.495903] lima ff300000.gpu: gp - mali450 version major 0 minor 0
[    4.496122] lima ff300000.gpu: pp0 - mali450 version major 0 minor 0
[    4.496326] lima ff300000.gpu: pp1 - mali450 version major 0 minor 0
[    4.496459] lima ff300000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
[    4.496514] lima ff300000.gpu: l2 cache 64K, 4-way, 64byte cache line, 128bit external bus
[    4.499977] lima ff300000.gpu: bus rate = 491520000
[    4.500012] lima ff300000.gpu: mod rate = 491520000
[    4.503298] [drm] Initialized lima 1.1.0 20191231 for ff300000.gpu on minor 1
[    4.519196] rk_gmac-dwmac ff550000.ethernet: IRQ eth_wake_irq not found
[    4.519231] rk_gmac-dwmac ff550000.ethernet: IRQ eth_lpi not found
[    4.519466] rk_gmac-dwmac ff550000.ethernet: PTP uses main clock
[    4.519858] rk_gmac-dwmac ff550000.ethernet: clock input or output? (output).
[    4.519885] rk_gmac-dwmac ff550000.ethernet: TX delay(0x30).
[    4.519906] rk_gmac-dwmac ff550000.ethernet: RX delay(0x10).
[    4.519948] rk_gmac-dwmac ff550000.ethernet: integrated PHY? (yes).
[    4.520084] rk_gmac-dwmac ff550000.ethernet: cannot get clock clk_mac_refout
[    4.520107] rk_gmac-dwmac ff550000.ethernet: cannot get clock clk_mac_speed
[    4.525208] rk_gmac-dwmac ff550000.ethernet: init for RMII
[    4.570270] rk_gmac-dwmac ff550000.ethernet: User ID: 0x10, Synopsys ID: 0x35
[    4.570316] rk_gmac-dwmac ff550000.ethernet:     DWMAC1000
[    4.570332] rk_gmac-dwmac ff550000.ethernet: DMA HW capability register supported
[    4.570346] rk_gmac-dwmac ff550000.ethernet: RX Checksum Offload Engine supported
[    4.570360] rk_gmac-dwmac ff550000.ethernet: COE Type 2
[    4.570374] rk_gmac-dwmac ff550000.ethernet: TX Checksum insertion supported
[    4.570388] rk_gmac-dwmac ff550000.ethernet: Wake-Up On Lan supported
[    4.570551] rk_gmac-dwmac ff550000.ethernet: Normal descriptors
[    4.570572] rk_gmac-dwmac ff550000.ethernet: Ring mode enabled
[    4.570586] rk_gmac-dwmac ff550000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    4.722728] rk_gmac-dwmac ff550000.ethernet end1: renamed from eth0
[    4.919276] dw-apb-uart ff130000.serial: forbid DMA for kernel console
[    5.510390] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Quota mode: none.
[    7.619961] systemd[1]: System time before build time, advancing clock.
[    7.699532] systemd[1]: Inserted module 'autofs4'
[    7.864113] systemd[1]: systemd 252.5-2 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[    7.864173] systemd[1]: Detected architecture arm64.
[    7.886531] systemd[1]: Hostname set to <rk3318-box>.
[    9.264166] systemd[327]: /usr/lib/systemd/system-generators/netplan failed with exit status 1.
[   10.567615] systemd[1]: Queued start job for default target graphical.target.
[   10.599700] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
[   10.604464] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
[   10.608827] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
[   10.612232] systemd[1]: Created slice user.slice - User and Session Slice.
[   10.613308] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
[   10.615437] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
[   10.616177] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
[   10.616826] systemd[1]: Reached target remote-fs.target - Remote File Systems.
[   10.617198] systemd[1]: Reached target slices.target - Slice Units.
[   10.617743] systemd[1]: Reached target swap.target - Swaps.
[   10.618158] systemd[1]: Reached target time-set.target - System Time Set.
[   10.618902] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
[   10.624551] systemd[1]: Listening on syslog.socket - Syslog Socket.
[   10.626154] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
[   10.627216] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
[   10.629197] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
[   10.630886] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
[   10.633025] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
[   10.646874] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
[   10.648390] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[   10.686234] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
[   10.695964] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
[   10.706034] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
[   10.716451] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
[   10.732686] systemd[1]: Starting fake-hwclock.service - Restore / save the current clock...
[   10.743345] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
[   10.754528] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
[   10.765718] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
[   10.777547] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
[   10.794007] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
[   10.805547] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
[   10.807277] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
[   10.837149] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
[   10.848258] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
[   10.849608] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
[   10.860435] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
[   10.879619] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
[   10.882455] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
[   10.885363] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
[   10.888389] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
[   10.893255] systemd[1]: Finished fake-hwclock.service - Restore / save the current clock.
[   10.899898] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
[   10.910462] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[   10.912617] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
[   10.917176] systemd[1]: modprobe@drm.service: Deactivated successfully.
[   10.919674] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
[   10.924717] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[   10.927073] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
[   10.931781] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[   10.933933] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
[   10.938814] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
[   10.978074] EXT4-fs (mmcblk0p1): re-mounted. Quota mode: none.
[   10.982429] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
[   10.993847] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
[   11.004340] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables...
[   11.028829] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
[   11.032295] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
[   11.035301] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
[   11.038454] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
[   11.067333] systemd[1]: Starting systemd-random-seed.service - Load/Save Random Seed...
[   11.079311] systemd[1]: Starting systemd-sysusers.service - Create System Users...
[   11.156331] systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables.
[   11.239803] systemd[1]: Finished systemd-sysusers.service - Create System Users.
[   11.275448] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev...
[   11.465026] systemd[1]: Finished systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev.
[   11.513866] systemd[1]: Starting systemd-udevd.service - Rule-based Manager for Device Events and Files...
[   11.531219] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout.
[   11.534523] systemd[1]: Reached target local-fs-pre.target - Preparation for Local File Systems.
[   11.562436] systemd[1]: Mounting tmp.mount - /tmp...
[   11.588841] systemd[1]: Mounted tmp.mount - /tmp.
[   11.592254] systemd[1]: Reached target local-fs.target - Local File Systems.
[   11.603348] systemd[1]: Starting armbian-led-state.service - Armbian leds state...
[   11.625926] systemd[1]: Starting armbian-zram-config.service - Armbian ZRAM config...
[   11.656458] systemd[1]: Starting console-setup.service - Set console font and keymap...
[   11.676003] systemd[1]: Starting plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data...
[   11.731624] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
[   11.738739] systemd[1]: Finished console-setup.service - Set console font and keymap.
[   11.780935] systemd[1]: Received SIGRTMIN+20 from PID 293 (plymouthd).
[   11.813685] systemd[1]: Finished plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data.
[   11.848371] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 391 (systemd-binfmt)
[   11.894397] systemd[1]: Mounting proc-sys-fs-binfmt_misc.mount - Arbitrary Executable File Formats File System...
[   11.960685] systemd[1]: Finished armbian-led-state.service - Armbian leds state.
[   11.967143] systemd[1]: Mounted proc-sys-fs-binfmt_misc.mount - Arbitrary Executable File Formats File System.
[   11.999601] systemd[1]: Finished systemd-binfmt.service - Set Up Additional Binary Formats.
[   12.147621] systemd[1]: Finished systemd-udev-trigger.service - Coldplug All udev Devices.
[   12.206788] systemd[1]: Starting ifupdown-pre.service - Helper to synchronize boot up for ifupdown...
[   12.313405] systemd[1]: Finished ifupdown-pre.service - Helper to synchronize boot up for ifupdown.
[   12.543217] systemd[1]: Started systemd-udevd.service - Rule-based Manager for Device Events and Files.
[   12.590389] systemd[1]: Starting plymouth-start.service - Show Plymouth Boot Screen...
[   12.779632] systemd[1]: Started plymouth-start.service - Show Plymouth Boot Screen.
[   12.783308] systemd[1]: bootsplash-ask-password-console.path - Dispatch Password Requests to Console Directory Watch when bootsplash is active was skipped because of an unmet condition check (ConditionPathExists=/sys/devices/platform/bootsplash.0/enabled).
[   12.784758] systemd[1]: Started systemd-ask-password-plymouth.path - Forward Password Requests to Plymouth Directory Watch.
[   12.785829] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
[   12.786736] systemd[1]: Reached target paths.target - Path Units.
[   12.931842] zram: Added device: zram0
[   12.933127] zram: Added device: zram1
[   12.934597] zram: Added device: zram2
[   12.936400] systemd[1]: Found device dev-ttyS2.device - /dev/ttyS2.
[   13.215033] zram0: detected capacity change from 0 to 4069840
[   13.600625] mc: Linux media interface: v0.10
[   13.780808] videodev: Linux video capture interface: v2.00
[   13.903108] rk3328-codec ff410000.codec: spk_depop_time use default value.
[   13.912962] Bluetooth: Core ver 2.22
[   13.913108] NET: Registered PF_BLUETOOTH protocol family
[   13.913121] Bluetooth: HCI device and connection manager initialized
[   13.913143] Bluetooth: HCI socket layer initialized
[   13.913155] Bluetooth: L2CAP socket layer initialized
[   13.913187] Bluetooth: SCO socket layer initialized
[   14.011105] Registered IR keymap rc-empty
[   14.011310] rc rc0: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc0
[   14.048332] rc rc0: lirc_dev: driver gpio_ir_recv registered at minor = 0, raw IR receiver, no transmitter
[   14.048551] input: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc0/input1
[   14.156540] rockchip_vdec: module is from the staging directory, the quality is unknown, you have been warned.
[   14.180854] rkvdec ff360000.video-codec: Adding to iommu group 3
[   14.229704] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   14.243271] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   14.254871] rockchip-rga ff390000.rga: HW Version: 0x04.00
[   14.255277] rockchip-rga ff390000.rga: Registered rockchip-rga as /dev/video1
[   14.285144] systemd[1]: Listening on systemd-rfkill.socket - Load/Save RF Kill Switch Status /dev/rfkill Watch.
[   14.287501] hantro-vpu ff350000.video-codec: Adding to iommu group 2
[   14.290263] hantro-vpu ff350000.video-codec: registered rockchip,rk3328-vpu-dec as /dev/video2
[   14.364970] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[   14.375694] Bluetooth: HCI UART driver ver 2.3
[   14.375719] Bluetooth: HCI UART protocol H4 registered
[   14.375726] Bluetooth: HCI UART protocol BCSP registered
[   14.375883] Bluetooth: HCI UART protocol LL registered
[   14.375892] Bluetooth: HCI UART protocol ATH3K registered
[   14.375990] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   14.376245] Bluetooth: HCI UART protocol Intel registered
[   14.380871] Bluetooth: HCI UART protocol Broadcom registered
[   14.380981] Bluetooth: HCI UART protocol QCA registered
[   14.380989] Bluetooth: HCI UART protocol AG6XX registered
[   14.381067] Bluetooth: HCI UART protocol Marvell registered
[   14.388447] systemd[1]: Reached target sound.target - Sound Card.
[   14.449772] brcmfmac: F1 signature read @0x18000000=0x16034334
[   14.454979] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4334-sdio for chip BCM4334/3
[   14.455658] usbcore: registered new interface driver brcmfmac
[   14.461499] brcmfmac mmc4:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.rockchip,rk3318-box.bin failed with error -2
[   14.493053] brcmfmac mmc4:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.clm_blob failed with error -2
[   14.613588] random: crng init done
[   14.658472] systemd[1]: Starting systemd-rfkill.service - Load/Save RF Kill Switch Status...
[   14.661273] systemd[1]: Finished systemd-random-seed.service - Load/Save Random Seed.
[   14.674402] Adding 2034916k swap on /dev/zram0.  Priority:5 extents:1 across:2034916k SSFS
[   14.684336] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
[   14.684717] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4334/3 wl0: Jul 24 2019 12:58:36 version 6.10.191 (TOB) (r) FWID 01-b049404e
[   14.704502] systemd[1]: Reached target bluetooth.target - Bluetooth Support.
[   14.705404] systemd[1]: first-boot-complete.target - First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes).
[   14.705957] systemd[1]: systemd-machine-id-commit.service - Commit a transient machine-id on disk was skipped because of an unmet condition check (ConditionPathIsMountPoint=/etc/machine-id).
[   14.762943] Bluetooth: hci0: BCM: chip id 68
[   14.763515] Bluetooth: hci0: BCM: features 0x0f
[   14.764374] Bluetooth: hci0: BCM4334B0
[   14.764393] Bluetooth: hci0: BCM4334B0 (002.001.013) build 0000
[   14.783199] systemd[1]: Started systemd-rfkill.service - Load/Save RF Kill Switch Status.
[   14.783733] Bluetooth: hci0: BCM4334B0 'brcm/BCM4334B0.hcd' Patch
[   15.022183] zram1: detected capacity change from 0 to 102400
[   15.172552] systemd[1]: Finished armbian-zram-config.service - Armbian ZRAM config.
[   15.210781] systemd[1]: Starting armbian-ramlog.service - Armbian memory supported logging...
[   15.323878] EXT4-fs (zram1): mounted filesystem without journal. Quota mode: none.
[   15.899110] Bluetooth: hci0: BCM: features 0x0f
[   15.899847] Bluetooth: hci0: Frame reassembly failed (-84)
[   15.900036] Bluetooth: hci0: BCM4334B1
[   15.900065] Bluetooth: hci0: BCM4334B0 (002.001.013) build 1852
[   15.914266] Bluetooth: hci0: Frame reassembly failed (-84)
[   15.964195] Bluetooth: hci0: Frame reassembly failed (-84)
[   15.981172] Bluetooth: hci0: Frame reassembly failed (-84)
[   17.989636] Bluetooth: hci0: command 0x0c52 tx timeout
[   17.989625] Bluetooth: hci0: Opcode 0x c52 failed: -110
[   19.790686] systemd[1]: systemd-rfkill.service: Deactivated successfully.
[   20.044702] systemd[1]: Finished armbian-ramlog.service - Armbian memory supported logging.
[   20.075175] systemd[1]: Starting systemd-journald.service - Journal Service...
[   20.426419] systemd[1]: Started systemd-journald.service - Journal Service.
[   20.516029] systemd-journald[557]: Received client request to flush runtime journal.
[   22.711040] systemd-journald[557]: Received client request to relinquish /var/log/journal/8f80d697a24e4be4bff1724efb455156 access.
[   27.422367] rk_gmac-dwmac ff550000.ethernet end1: Register MEM_TYPE_PAGE_POOL RxQ-0
[   27.487957] rk_gmac-dwmac ff550000.ethernet end1: PHY [stmmac-1:00] driver [Rockchip integrated EPHY] (irq=POLL)
[   27.497602] rk_gmac-dwmac ff550000.ethernet end1: No Safety Features support found
[   27.497649] rk_gmac-dwmac ff550000.ethernet end1: PTP not supported by HW
[   27.498628] rk_gmac-dwmac ff550000.ethernet end1: configuring for phy/rmii link mode
[   29.542058] rk_gmac-dwmac ff550000.ethernet end1: Link is Up - 100Mbps/Full - flow control rx/tx
[   29.542141] IPv6: ADDRCONF(NETDEV_CHANGE): end1: link becomes ready
On 3/31/2023 at 2:16 AM, jock said:
Perhaps you're having the same issue with ddr memory frequency mentioned in @SpellKilleR above. Perhaps it is time to go back to the slower but safer 333 mhz ddrbin 🤔
@jock The Armbian_23.02.0-trunk_Rk3318-box_lunar_edge_6.1.11_xfce_desktop.img from the Armbian community github page does boot from SD card though. It boots, runs well, wifi works. It just won't boot if I install it to eMMc with either Multitool or rkdeveloptool.
Edited by Ethanol6
@Ethanol6 Then I need the detailed UART serial output to help you with diagnostics, if the image boots from sdcard but not from emmc there is something going on.
@mikes123 Actually I don't know what is going on with your wifi: the chip is detected regularly and the firmware is correctly uploaded. If you tried swapping the nvram as suggested and still does not work, honestly I don't know what else can be. Perhaps you could extract the firmware and nvram from your original firmware and try them.
5 minutes ago, Energokom said:
@jock  It is possible to add the cpu range min 408 - max 1400 in the rk3188 config?
This is not for rk3188, but for rk3318.
And no, you have to handcraft yourself the device tree for that or use the existing overlays to overclock the thing
I have Rk3318 - H96MAX 4/32
Yes, I've already done that. It turned out to change the frequency range from 408 to 1392 Mhz. Before that, I cooled it well. I added a 40x50x2mm copper plate, and glued a radiator with a cooler on it.
Everything works, except the LED display. I'm reading how to transfer to emmc
OMG, you are the best!!!
I managed to install armbian on my HK1R BOX. With android it was nearly useless. I installed the
"Armbian_22.05.0-trunk_Rk3318-box_bullseye_current_5.15.35_minimal.img.xz" image. Is there a way to update to the newest release (23.xx) without reinstalling the system?
One issue to report here: after a while, the box gets disconnected from the network and I cannot access it via SSH anymore, unitl I unplug and plug it back.
When it's connected everything works fine
RK3318
64gb eMMC
4gb ram
dual wifi
Latest stable version installed
@xlordxcheater
You can try to debug such issues by connecting eth after the wifi has stopped working and checking if there is anything interesting in dmesg output.
I found a bunch of errors suggesting the wifi chip had crashed. I am testing again with the original power supply but I think I get another Comfast CF-812AC(RTL8812BU) usb wifi adapter or 1000Mbps usb ethernet adapter. You should consider getting a more proper raspberry pi power supply with 3A or 4A rating if you want connect things to the usb ports. The original on these is only 2A and pictures show input capacitor is like 100uF which is kind of ridiculously small. You could solder 2200uF 16V capacitor to the input. I originally had SSD on it that was consuming some mere 200mA current but it caused the whole tv-box to become unstable so I had to tear it down. I have also had issues with the eth link going down and not recovering after a week of uptime.
Edited by Aapo Tahkola
Is it a really stupid idea to buy one of these boxes, install armbian+raspap (or  openwrt) and use it as a travel router/access point (I need both 2.4 and 5GHz)?
Most cheap routers (i.e. at the same price point of a tv-box) with openwrt support have no usb port (I need one for tethering with an android phone).
OTOH tv-boxes have flaky wifi, but I have several usb wifi sticks that I could use (though I'd prefer to use the integrated wifi if at all possible, at least for one of the bands).
If it's really stupid (and the first message of the threads seems to imply so) I'll go back to my cave, but if it isn't, what's the most suitable box?
@olivluca well, it is not totally a stupid idea, but consider that tv boxes are mostly just-for-fun kind of product; I would rather go with a properly supported SBC, or at least a community supported SBC. For example, today I test a Radxa Pi-e board (very small, one gigabit eth, one fast eth, 802.11ac/b/g/n wifi) that turned out being a very impressive throughput of > 100mbps on a 300mbps 802.11n 2.4ghz link, and the access point was one floor above! SImilar results came from an Orange Pi 4 LTS; the tv boxes I tried couldn't reach such bitrate and one of them which had the ssv6051 wifi on board was not even working right.
I never tried RaspAp, but looks very good if it does what it promises.
But if you want something reliable, go with an SBC + armbian, otherwise find an access point that supports openwrt.
Thank you @jock the Radxa Pi-e board is interesting, but if you add a case and shipping it would at least double or triple the price of a tv-box shipped.
Of course it is better to spend more money once instead of buying something cheap that you have to throw in the trash, but I really like cheap things (provided they work well enough 😅).
I'll keep thinking about it.
