Build fails on "could not resolve 'ports.ubuntu.com'" on machine that has built successfully in the past
Hello,
I have been building images for the NanoPC-T4 with armbian successfully in the past.
However I now get the error "could not resolve 'ports.ubuntu.com'" when the build tries to install ping_5.1-1_arm64.deb
(full log below).
Do you have any idea what this comes from and how I could solve/debug this ? Thank you
Additional info :
I added 8.8.8.8 as an alternative DNS server on my machine, I can ping ports.ubuntu.com successfully.
I have cloned the armbian build and head points to this commit https://github.com/armbian/build/commit/5b8d86ae5f6f34cf6cc13edf6b1def2773f66f0a
Best regards,
Rick
  Reveal hidden contents
Cannot reproduce. Just built with your parameters successfully.
BOARD=nanopct4 BRANCH=edge RELEASE=jammy BUILD_MINIMAL=no BUILD_DESKTOP=yes KERNEL_ONLY=no KERNEL_CONFIGURE=yes DESKTOP_ENVIRONMENT=xfce DESKTOP_ENVIRONMENT_CONFIG_NAME=config_base DESKTOP_APPGROUPS_SELECTED="3dsupport browsers desktop_tools editors internet programming remote_desktop" COMPRESS_OUTPUTIMAGE=sha,img
Thanks for trying this out, it is probably a network issue, if you have any pointers on how to debug this it would be great.
I have issues with apt from within the build but not from outside the build. I wonder if the chroot may cause this.
Running on Ubuntu 22.04.2 LTS
It happens every-time, even when I delete / reclone.
Posted (edited)
I have run the build on another machine, the build gives the same error.
Edit : From the machine I can download the file in the error message without any issues when I use e.g., wget
   E: Failed to fetch http://ports.ubuntu.com/pool/universe/f/fping/fping_5.1-1_arm64.deb  Could not resolve 'ports.ubuntu.com'
   E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
wget http://ports.ubuntu.com/pool/universe/f/fping/fping_5.1-1_arm64.deb
 Downloads the file no problem...
Edited by rwk
I had the same problem, running on an Ubuntu host with Docker, and adding
  Quote
cp /etc/resolv.conf ${SDCARD}/etc/resolv.conf
Expand
indeed solved the problem. I'll be happy to provide more information if needed.
