KernelPanic Posted October 26, 2016 Posted October 26, 2016 (edited) Dear Sirs and Madams! I am trying to reconfigure https://github.com/friendlyarm/h3_lichee BSP's kernel via make menuconfig which is producing following .config file: # # Automatically generated file; DO NOT EDIT. # Linux/arm 3.4.39 Kernel Configuration # CONFIG_ARM=y CONFIG_ARM_HAS_SG_CHAIN=y CONFIG_SYS_SUPPORTS_APM_EMULATION=y CONFIG_GENERIC_GPIO=y # CONFIG_ARCH_USES_GETTIMEOFFSET is not set CONFIG_GENERIC_CLOCKEVENTS=y CONFIG_GENERIC_CLOCKEVENTS_BROADCAST=y CONFIG_KTIME_SCALAR=y CONFIG_HAVE_PROC_CPU=y CONFIG_STACKTRACE_SUPPORT=y CONFIG_LOCKDEP_SUPPORT=y CONFIG_TRACE_IRQFLAGS_SUPPORT=y CONFIG_HARDIRQS_SW_RESEND=y CONFIG_GENERIC_IRQ_PROBE=y CONFIG_GENERIC_LOCKBREAK=y CONFIG_RWSEM_GENERIC_SPINLOCK=y CONFIG_ARCH_HAS_CPUFREQ=y CONFIG_ARCH_HAS_CPU_IDLE_WAIT=y CONFIG_GENERIC_HWEIGHT=y CONFIG_GENERIC_CALIBRATE_DELAY=y CONFIG_NEED_DMA_MAP_STATE=y CONFIG_VECTORS_BASE=0xffff0000 CONFIG_ARM_PATCH_PHYS_VIRT=y CONFIG_NEED_MACH_IO_H=y CONFIG_NEED_MACH_MEMORY_H=y CONFIG_DEFCONFIG_LIST="/lib/modules/$UNAME_RELEASE/.config" CONFIG_HAVE_IRQ_WORK=y CONFIG_IRQ_WORK=y # # General setup # CONFIG_EXPERIMENTAL=y CONFIG_INIT_ENV_ARG_LIMIT=32 CONFIG_CROSS_COMPILE="arm-linux-gnueabi-" CONFIG_LOCALVERSION="-h3" # CONFIG_LOCALVERSION_AUTO is not set CONFIG_HAVE_KERNEL_GZIP=y CONFIG_HAVE_KERNEL_LZMA=y CONFIG_HAVE_KERNEL_XZ=y CONFIG_HAVE_KERNEL_LZO=y CONFIG_KERNEL_GZIP=y # CONFIG_KERNEL_LZMA is not set # CONFIG_KERNEL_XZ is not set # CONFIG_KERNEL_LZO is not set CONFIG_DEFAULT_HOSTNAME="soundengine" CONFIG_SYSVIPC=y CONFIG_SYSVIPC_SYSCTL=y # CONFIG_POSIX_MQUEUE is not set # CONFIG_BSD_PROCESS_ACCT is not set # CONFIG_FHANDLE is not set # CONFIG_TASKSTATS is not set # CONFIG_AUDIT is not set CONFIG_HAVE_GENERIC_HARDIRQS=y # # IRQ subsystem # CONFIG_GENERIC_HARDIRQS=y CONFIG_GENERIC_IRQ_SHOW=y CONFIG_IRQ_DOMAIN=y # CONFIG_IRQ_DOMAIN_DEBUG is not set # # RCU Subsystem # CONFIG_TREE_PREEMPT_RCU=y CONFIG_PREEMPT_RCU=y CONFIG_RCU_FANOUT=32 # CONFIG_RCU_FANOUT_EXACT is not set # CONFIG_RCU_FAST_NO_HZ is not set # CONFIG_TREE_RCU_TRACE is not set # CONFIG_RCU_BOOST is not set CONFIG_IKCONFIG=y CONFIG_IKCONFIG_PROC=y CONFIG_LOG_BUF_SHIFT=16 CONFIG_HAVE_UNSTABLE_SCHED_CLOCK=y # CONFIG_CHECKPOINT_RESTORE is not set # CONFIG_NAMESPACES is not set # CONFIG_SCHED_AUTOGROUP is not set # CONFIG_SYSFS_DEPRECATED is not set CONFIG_RELAY=y CONFIG_BLK_DEV_INITRD=y CONFIG_INITRAMFS_SOURCE="" CONFIG_RD_GZIP=y # CONFIG_RD_BZIP2 is not set # CONFIG_RD_LZMA is not set # CONFIG_RD_XZ is not set # CONFIG_RD_LZO is not set CONFIG_CC_OPTIMIZE_FOR_SIZE=y CONFIG_SYSCTL=y CONFIG_ANON_INODES=y CONFIG_PANIC_TIMEOUT=0 CONFIG_EXPERT=y # CONFIG_UID16 is not set # CONFIG_SYSCTL_SYSCALL is not set CONFIG_KALLSYMS=y # CONFIG_KALLSYMS_ALL is not set CONFIG_HOTPLUG=y # CONFIG_PRINTK is not set # CONFIG_BUG is not set # CONFIG_ELF_CORE is not set # CONFIG_BASE_FULL is not set # CONFIG_FUTEX is not set # CONFIG_EPOLL is not set # CONFIG_SIGNALFD is not set # CONFIG_TIMERFD is not set # CONFIG_EVENTFD is not set # CONFIG_SHMEM is not set CONFIG_AIO=y CONFIG_EMBEDDED=y CONFIG_HAVE_PERF_EVENTS=y CONFIG_PERF_USE_VMALLOC=y # # Kernel Performance Events And Counters # CONFIG_PERF_EVENTS=y # CONFIG_PERF_COUNTERS is not set # CONFIG_DEBUG_PERF_USE_VMALLOC is not set # CONFIG_VM_EVENT_COUNTERS is not set CONFIG_COMPAT_BRK=y CONFIG_SLAB=y # CONFIG_SLUB is not set # CONFIG_SLOB is not set # CONFIG_PROFILING is not set CONFIG_HAVE_OPROFILE=y # CONFIG_KPROBES is not set # CONFIG_JUMP_LABEL is not set CONFIG_HAVE_KPROBES=y CONFIG_HAVE_KRETPROBES=y CONFIG_HAVE_DMA_ATTRS=y CONFIG_HAVE_DMA_CONTIGUOUS=y CONFIG_USE_GENERIC_SMP_HELPERS=y CONFIG_HAVE_REGS_AND_STACK_ACCESS_API=y CONFIG_HAVE_CLK=y CONFIG_HAVE_DMA_API_DEBUG=y CONFIG_HAVE_HW_BREAKPOINT=y CONFIG_HAVE_ARCH_JUMP_LABEL=y # # GCOV-based kernel profiling # # CONFIG_GCOV_KERNEL is not set CONFIG_HAVE_GENERIC_DMA_COHERENT=y CONFIG_SLABINFO=y CONFIG_RT_MUTEXES=y CONFIG_BASE_SMALL=1 CONFIG_MODULES=y # CONFIG_MODULE_FORCE_LOAD is not set CONFIG_MODULE_UNLOAD=y CONFIG_MODULE_FORCE_UNLOAD=y # CONFIG_MODVERSIONS is not set # CONFIG_MODULE_SRCVERSION_ALL is not set CONFIG_STOP_MACHINE=y # CONFIG_BLOCK is not set # CONFIG_INLINE_SPIN_TRYLOCK is not set # CONFIG_INLINE_SPIN_TRYLOCK_BH is not set # CONFIG_INLINE_SPIN_LOCK is not set # CONFIG_INLINE_SPIN_LOCK_BH is not set # CONFIG_INLINE_SPIN_LOCK_IRQ is not set # CONFIG_INLINE_SPIN_LOCK_IRQSAVE is not set CONFIG_UNINLINE_SPIN_UNLOCK=y # CONFIG_INLINE_SPIN_UNLOCK_BH is not set # CONFIG_INLINE_SPIN_UNLOCK_IRQ is not set # CONFIG_INLINE_SPIN_UNLOCK_IRQRESTORE is not set # CONFIG_INLINE_READ_TRYLOCK is not set # CONFIG_INLINE_READ_LOCK is not set # CONFIG_INLINE_READ_LOCK_BH is not set # CONFIG_INLINE_READ_LOCK_IRQ is not set # CONFIG_INLINE_READ_LOCK_IRQSAVE is not set # CONFIG_INLINE_READ_UNLOCK is not set # CONFIG_INLINE_READ_UNLOCK_BH is not set # CONFIG_INLINE_READ_UNLOCK_IRQ is not set # CONFIG_INLINE_READ_UNLOCK_IRQRESTORE is not set # CONFIG_INLINE_WRITE_TRYLOCK is not set # CONFIG_INLINE_WRITE_LOCK is not set # CONFIG_INLINE_WRITE_LOCK_BH is not set # CONFIG_INLINE_WRITE_LOCK_IRQ is not set # CONFIG_INLINE_WRITE_LOCK_IRQSAVE is not set # CONFIG_INLINE_WRITE_UNLOCK is not set # CONFIG_INLINE_WRITE_UNLOCK_BH is not set # CONFIG_INLINE_WRITE_UNLOCK_IRQ is not set # CONFIG_INLINE_WRITE_UNLOCK_IRQRESTORE is not set CONFIG_MUTEX_SPIN_ON_OWNER=y # CONFIG_FREEZER is not set # # System Type # CONFIG_MMU=y # CONFIG_ARCH_INTEGRATOR is not set # CONFIG_ARCH_REALVIEW is not set # CONFIG_ARCH_VERSATILE is not set # CONFIG_ARCH_VEXPRESS is not set CONFIG_ARCH_SUNXI=y # CONFIG_ARCH_AT91 is not set # CONFIG_ARCH_BCMRING is not set # CONFIG_ARCH_HIGHBANK is not set # CONFIG_ARCH_CLPS711X is not set # CONFIG_ARCH_CNS3XXX is not set # CONFIG_ARCH_GEMINI is not set # CONFIG_ARCH_PRIMA2 is not set # CONFIG_ARCH_EBSA110 is not set # CONFIG_ARCH_EP93XX is not set # CONFIG_ARCH_FOOTBRIDGE is not set # CONFIG_ARCH_MXC is not set # CONFIG_ARCH_MXS is not set # CONFIG_ARCH_NETX is not set # CONFIG_ARCH_H720X is not set # CONFIG_ARCH_IOP13XX is not set # CONFIG_ARCH_IOP32X is not set # CONFIG_ARCH_IOP33X is not set # CONFIG_ARCH_IXP23XX is not set # CONFIG_ARCH_IXP2000 is not set # CONFIG_ARCH_IXP4XX is not set # CONFIG_ARCH_DOVE is not set # CONFIG_ARCH_KIRKWOOD is not set # CONFIG_ARCH_LPC32XX is not set # CONFIG_ARCH_MV78XX0 is not set # CONFIG_ARCH_ORION5X is not set # CONFIG_ARCH_MMP is not set # CONFIG_ARCH_KS8695 is not set # CONFIG_ARCH_W90X900 is not set # CONFIG_ARCH_TEGRA is not set # CONFIG_ARCH_PICOXCELL is not set # CONFIG_ARCH_PNX4008 is not set # CONFIG_ARCH_PXA is not set # CONFIG_ARCH_MSM is not set # CONFIG_ARCH_SHMOBILE is not set # CONFIG_ARCH_RPC is not set # CONFIG_ARCH_SA1100 is not set # CONFIG_ARCH_S3C24XX is not set # CONFIG_ARCH_S3C64XX is not set # CONFIG_ARCH_S5P64X0 is not set # CONFIG_ARCH_S5PC100 is not set # CONFIG_ARCH_S5PV210 is not set # CONFIG_ARCH_EXYNOS is not set # CONFIG_ARCH_SHARK is not set # CONFIG_ARCH_U300 is not set # CONFIG_ARCH_U8500 is not set # CONFIG_ARCH_NOMADIK is not set # CONFIG_ARCH_DAVINCI is not set # CONFIG_ARCH_OMAP is not set # CONFIG_PLAT_SPEAR is not set # CONFIG_ARCH_VT8500 is not set # CONFIG_ARCH_ZYNQ is not set # CONFIG_GPIO_PCA953X is not set # # System MMU # CONFIG_SUNXI_CONSISTENT_DMA_SIZE=12 CONFIG_ARCH_SUN8I=y # CONFIG_ARCH_SUN9I is not set # CONFIG_ARCH_SUN8IW1 is not set # CONFIG_ARCH_SUN8IW3 is not set # CONFIG_ARCH_SUN8IW5 is not set # CONFIG_ARCH_SUN8IW6 is not set CONFIG_ARCH_SUN8IW7=y # CONFIG_ARCH_SUN8IW8 is not set # CONFIG_ARCH_SUN8IW9 is not set # CONFIG_SUN8I_ROOT_DEVICE is not set CONFIG_ARCH_SUN8IW7P1=y # CONFIG_FPGA_V4_PLATFORM is not set # CONFIG_FPGA_V7_PLATFORM is not set CONFIG_EVB_PLATFORM=y # # Power management # # # Common Features Selection # # # Boot Options # # CONFIG_SUNXI_TRUSTZONE is not set CONFIG_HOMLET_PLATFORM=y # CONFIG_SUNXI_BOOTUP_EXTEND is not set # CONFIG_SUNXI_OOPS_HOOK is not set # CONFIG_MEM_512M_DEBUG is not set # # Processor Type # CONFIG_CPU_V7=y CONFIG_CPU_32v6K=y CONFIG_CPU_32v7=y CONFIG_CPU_ABRT_EV7=y CONFIG_CPU_PABRT_V7=y CONFIG_CPU_CACHE_V7=y CONFIG_CPU_CACHE_VIPT=y CONFIG_CPU_COPY_V6=y CONFIG_CPU_TLB_V7=y CONFIG_CPU_HAS_ASID=y CONFIG_CPU_CP15=y CONFIG_CPU_CP15_MMU=y # # Processor Features # # CONFIG_ARM_LPAE is not set # CONFIG_ARCH_PHYS_ADDR_T_64BIT is not set CONFIG_ARM_THUMB=y CONFIG_ARM_THUMBEE=y CONFIG_SWP_EMULATE=y # CONFIG_CPU_ICACHE_DISABLE is not set # CONFIG_CPU_DCACHE_DISABLE is not set # CONFIG_CPU_BPREDICT_DISABLE is not set CONFIG_MIGHT_HAVE_CACHE_L2X0=y # CONFIG_CACHE_L2X0 is not set CONFIG_ARM_L1_CACHE_SHIFT_6=y CONFIG_ARM_L1_CACHE_SHIFT=6 CONFIG_ARM_DMA_MEM_BUFFERABLE=y CONFIG_ARM_NR_BANKS=8 CONFIG_CPU_HAS_PMU=y CONFIG_MULTI_IRQ_HANDLER=y # CONFIG_ARM_ERRATA_430973 is not set # CONFIG_ARM_ERRATA_458693 is not set # CONFIG_ARM_ERRATA_460075 is not set # CONFIG_ARM_ERRATA_742230 is not set # CONFIG_ARM_ERRATA_742231 is not set # CONFIG_ARM_ERRATA_720789 is not set # CONFIG_ARM_ERRATA_743622 is not set # CONFIG_ARM_ERRATA_751472 is not set # CONFIG_ARM_ERRATA_754322 is not set # CONFIG_ARM_ERRATA_754327 is not set # CONFIG_ARM_ERRATA_764369 is not set # CONFIG_ARM_ERRATA_775420 is not set CONFIG_ARM_GIC=y # CONFIG_FIQ_DEBUGGER is not set # # Bus support # # CONFIG_PCI_SYSCALL is not set # CONFIG_ARCH_SUPPORTS_MSI is not set # CONFIG_PCCARD is not set # # Kernel Features # CONFIG_TICK_ONESHOT=y CONFIG_NO_HZ=y CONFIG_HIGH_RES_TIMERS=y CONFIG_GENERIC_CLOCKEVENTS_BUILD=y CONFIG_HAVE_SMP=y CONFIG_SMP=y CONFIG_SMP_ON_UP=y CONFIG_ARM_CPU_TOPOLOGY=y # CONFIG_SCHED_MC is not set # CONFIG_SCHED_SMT is not set # CONFIG_DISABLE_CPU_SCHED_DOMAIN_BALANCE is not set CONFIG_HAVE_ARM_SCU=y CONFIG_ARM_ARCH_TIMER=y # CONFIG_MCPM is not set # CONFIG_BIG_LITTLE is not set CONFIG_VMSPLIT_3G=y # CONFIG_VMSPLIT_2G is not set # CONFIG_VMSPLIT_1G is not set CONFIG_PAGE_OFFSET=0xC0000000 CONFIG_NR_CPUS=4 CONFIG_HOTPLUG_CPU=y CONFIG_ARCH_NR_GPIO=2048 # CONFIG_PREEMPT_NONE is not set # CONFIG_PREEMPT_VOLUNTARY is not set CONFIG_PREEMPT=y CONFIG_PREEMPT_COUNT=y CONFIG_HZ=100 # CONFIG_THUMB2_KERNEL is not set CONFIG_AEABI=y CONFIG_OABI_COMPAT=y # CONFIG_ARCH_SPARSEMEM_DEFAULT is not set # CONFIG_ARCH_SELECT_MEMORY_MODEL is not set CONFIG_HAVE_ARCH_PFN_VALID=y # CONFIG_HIGHMEM is not set # CONFIG_HW_PERF_EVENTS is not set CONFIG_SELECT_MEMORY_MODEL=y CONFIG_FLATMEM_MANUAL=y CONFIG_FLATMEM=y CONFIG_FLAT_NODE_MEM_MAP=y CONFIG_HAVE_MEMBLOCK=y CONFIG_MEMORY_ISOLATION=y CONFIG_PAGEFLAGS_EXTENDED=y CONFIG_SPLIT_PTLOCK_CPUS=4 CONFIG_COMPACTION=y CONFIG_MIGRATION=y # CONFIG_PHYS_ADDR_T_64BIT is not set CONFIG_ZONE_DMA_FLAG=0 CONFIG_VIRT_TO_BUS=y # CONFIG_KSM is not set CONFIG_DEFAULT_MMAP_MIN_ADDR=4096 # CONFIG_CLEANCACHE is not set CONFIG_FORCE_MAX_ZONEORDER=11 CONFIG_ALIGNMENT_TRAP=y # CONFIG_UACCESS_WITH_MEMCPY is not set # CONFIG_SECCOMP is not set # CONFIG_CC_STACKPROTECTOR is not set # CONFIG_DEPRECATED_PARAM_STRUCT is not set CONFIG_ARM_FLUSH_CONSOLE_ON_RESTART=y # # Boot options # CONFIG_USE_OF=y # CONFIG_BUILD_ARM_APPENDED_DTB_IMAGE is not set CONFIG_ZBOOT_ROM_TEXT=0 CONFIG_ZBOOT_ROM_BSS=0 # CONFIG_ARM_APPENDED_DTB is not set CONFIG_CMDLINE="earlyprintk=ttyS0,115200 loglevel=8 initcall_debug=0 console=ttyS0,115200 console=tty0 init=/init" CONFIG_CMDLINE_FROM_BOOTLOADER=y # CONFIG_CMDLINE_EXTEND is not set # CONFIG_CMDLINE_FORCE is not set # CONFIG_XIP_KERNEL is not set # CONFIG_KEXEC is not set # CONFIG_CRASH_DUMP is not set # CONFIG_AUTO_ZRELADDR is not set # # CPU Power Management # # # CPU Frequency scaling # # CONFIG_CPU_FREQ is not set # # CPU Idle # # CONFIG_CPU_IDLE is not set # CONFIG_ARCH_NEEDS_CPU_IDLE_COUPLED is not set # # Floating point emulation # # # At least one emulation must be selected # # CONFIG_FPE_NWFPE is not set # CONFIG_FPE_FASTFPE is not set CONFIG_VFP=y CONFIG_VFPv3=y CONFIG_NEON=y # # Userspace binary formats # CONFIG_BINFMT_ELF=y CONFIG_ARCH_BINFMT_ELF_RANDOMIZE_PIE=y CONFIG_HAVE_AOUT=y # CONFIG_BINFMT_AOUT is not set # CONFIG_BINFMT_MISC is not set # # Power management options # # CONFIG_SUSPEND is not set # CONFIG_PM_RUNTIME is not set # CONFIG_SUSPEND_TIME is not set CONFIG_ARCH_SUSPEND_POSSIBLE=y # CONFIG_ARM_CPU_SUSPEND is not set CONFIG_ARCH_HIBERNATION_POSSIBLE=y CONFIG_NET=y # # Networking options # CONFIG_PACKET=y CONFIG_UNIX=y # CONFIG_UNIX_DIAG is not set # CONFIG_NET_KEY is not set CONFIG_INET=y CONFIG_IP_MULTICAST=y # CONFIG_IP_ADVANCED_ROUTER is not set # CONFIG_IP_PNP is not set # CONFIG_NET_IPIP is not set # CONFIG_NET_IPGRE_DEMUX is not set # CONFIG_IP_MROUTE is not set # CONFIG_ARPD is not set # CONFIG_SYN_COOKIES is not set # CONFIG_INET_AH is not set # CONFIG_INET_ESP is not set # CONFIG_INET_IPCOMP is not set # CONFIG_INET_XFRM_TUNNEL is not set # CONFIG_INET_TUNNEL is not set # CONFIG_INET_XFRM_MODE_TRANSPORT is not set # CONFIG_INET_XFRM_MODE_TUNNEL is not set # CONFIG_INET_XFRM_MODE_BEET is not set # CONFIG_INET_LRO is not set # CONFIG_INET_DIAG is not set # CONFIG_TCP_CONG_ADVANCED is not set CONFIG_TCP_CONG_CUBIC=y CONFIG_DEFAULT_TCP_CONG="cubic" # CONFIG_TCP_MD5SIG is not set # CONFIG_IPV6 is not set # CONFIG_ANDROID_PARANOID_NETWORK is not set # CONFIG_NET_ACTIVITY_STATS is not set # CONFIG_NETWORK_SECMARK is not set # CONFIG_NETWORK_PHY_TIMESTAMPING is not set # CONFIG_NETFILTER is not set # CONFIG_IP_DCCP is not set # CONFIG_IP_SCTP is not set # CONFIG_RDS is not set # CONFIG_TIPC is not set # CONFIG_ATM is not set # CONFIG_L2TP is not set # CONFIG_BRIDGE is not set # CONFIG_NET_DSA is not set # CONFIG_VLAN_8021Q is not set # CONFIG_DECNET is not set # CONFIG_LLC2 is not set # CONFIG_IPX is not set # CONFIG_ATALK is not set # CONFIG_X25 is not set # CONFIG_LAPB is not set # CONFIG_ECONET is not set # CONFIG_WAN_ROUTER is not set # CONFIG_PHONET is not set # CONFIG_IEEE802154 is not set # CONFIG_NET_SCHED is not set # CONFIG_DCB is not set # CONFIG_DNS_RESOLVER is not set # CONFIG_BATMAN_ADV is not set # CONFIG_OPENVSWITCH is not set CONFIG_RPS=y CONFIG_RFS_ACCEL=y CONFIG_XPS=y CONFIG_BQL=y CONFIG_HAVE_BPF_JIT=y # CONFIG_BPF_JIT is not set # # Network testing # # CONFIG_NET_PKTGEN is not set # CONFIG_HAMRADIO is not set # CONFIG_CAN is not set # CONFIG_IRDA is not set # CONFIG_BT is not set # CONFIG_AF_RXRPC is not set CONFIG_WIRELESS=y # CONFIG_LINUX_BACKPORTS is not set # CONFIG_CFG80211 is not set # CONFIG_LIB80211 is not set # # CFG80211 needs to be enabled for MAC80211 # # CONFIG_WIMAX is not set # CONFIG_RFKILL is not set # CONFIG_NET_9P is not set # CONFIG_CAIF is not set # CONFIG_CEPH_LIB is not set # CONFIG_NFC is not set # # Device Drivers # CONFIG_SUNXI_ARISC=y # # Generic Driver Options # CONFIG_UEVENT_HELPER_PATH="" CONFIG_DEVTMPFS=y # CONFIG_DEVTMPFS_MOUNT is not set CONFIG_STANDALONE=y CONFIG_PREVENT_FIRMWARE_BUILD=y CONFIG_FW_LOADER=y CONFIG_FIRMWARE_IN_KERNEL=y CONFIG_EXTRA_FIRMWARE="" CONFIG_FW_LOADER_USER_HELPER=y # CONFIG_DEBUG_DRIVER is not set # CONFIG_DEBUG_DEVRES is not set # CONFIG_SYS_HYPERVISOR is not set # CONFIG_GENERIC_CPU_DEVICES is not set CONFIG_REGMAP=y CONFIG_REGMAP_I2C=y CONFIG_REGMAP_SPI=y # CONFIG_DMA_SHARED_BUFFER is not set CONFIG_CMA=y # CONFIG_CMA_DEBUG is not set # # Default contiguous memory area size: # CONFIG_CMA_SIZE_MBYTES=16 CONFIG_CMA_RESERVE_BASE=0x43400000 CONFIG_CMA_SIZE_SEL_MBYTES=y # CONFIG_CMA_SIZE_SEL_PERCENTAGE is not set # CONFIG_CMA_SIZE_SEL_MIN is not set # CONFIG_CMA_SIZE_SEL_MAX is not set CONFIG_CMA_ALIGNMENT=0 CONFIG_CMA_AREAS=7 CONFIG_SYNC=y CONFIG_SW_SYNC=y # CONFIG_SW_SYNC_USER is not set # # Bus devices # # CONFIG_CONNECTOR is not set # CONFIG_MTD is not set CONFIG_DTC=y CONFIG_OF=y # # Device Tree and Open Firmware support # # CONFIG_PROC_DEVICETREE is not set # CONFIG_OF_SELFTEST is not set CONFIG_OF_FLATTREE=y CONFIG_OF_EARLY_FLATTREE=y CONFIG_OF_ADDRESS=y CONFIG_OF_IRQ=y CONFIG_OF_DEVICE=y CONFIG_OF_GPIO=y CONFIG_OF_I2C=y CONFIG_OF_NET=y CONFIG_OF_SPI=y CONFIG_OF_MDIO=y # CONFIG_PARPORT is not set # # Misc devices # # CONFIG_SUNXI_VIBRATOR is not set # CONFIG_SUN8I_VIBRATOR is not set # CONFIG_SENSORS_LIS3LV02D is not set # CONFIG_AD525X_DPOT is not set # CONFIG_ATMEL_PWM is not set # CONFIG_ICS932S401 is not set # CONFIG_ENCLOSURE_SERVICES is not set # CONFIG_APDS9802ALS is not set # CONFIG_ISL29003 is not set # CONFIG_ISL29020 is not set # CONFIG_SENSORS_TSL2550 is not set # CONFIG_SENSORS_BH1780 is not set # CONFIG_SENSORS_BH1770 is not set # CONFIG_SENSORS_APDS990X is not set # CONFIG_HMC6352 is not set # CONFIG_SENSORS_AK8975 is not set # CONFIG_DS1682 is not set # CONFIG_TI_DAC7512 is not set CONFIG_UID_STAT=y CONFIG_BMP085=m # CONFIG_USB_SWITCH_FSA9480 is not set # CONFIG_SUNXI_BROM_READ is not set # CONFIG_C2PORT is not set # # EEPROM support # # CONFIG_EEPROM_AT24 is not set # CONFIG_EEPROM_AT25 is not set # CONFIG_EEPROM_LEGACY is not set # CONFIG_EEPROM_MAX6875 is not set CONFIG_EEPROM_93CX6=m # CONFIG_EEPROM_93XX46 is not set # CONFIG_IWMC3200TOP is not set # # Texas Instruments shared transport line discipline # # CONFIG_TI_ST is not set # CONFIG_SENSORS_LIS3_SPI is not set # CONFIG_SENSORS_LIS3_I2C is not set # # Altera FPGA firmware download module # # CONFIG_ALTERA_STAPL is not set # CONFIG_SW_3G_MODULE is not set # # SCSI device support # CONFIG_SCSI_MOD=y # CONFIG_SCSI_DMA is not set # CONFIG_SCSI_NETLINK is not set CONFIG_NETDEVICES=y CONFIG_NET_CORE=y # CONFIG_BONDING is not set # CONFIG_DUMMY is not set # CONFIG_EQUALIZER is not set # CONFIG_MII is not set # CONFIG_NET_TEAM is not set # CONFIG_MACVLAN is not set # CONFIG_NETCONSOLE is not set # CONFIG_NETPOLL is not set # CONFIG_NET_POLL_CONTROLLER is not set # CONFIG_TUN is not set # CONFIG_VETH is not set # # CAIF transport drivers # CONFIG_ETHERNET=y # CONFIG_NET_VENDOR_BROADCOM is not set # CONFIG_NET_CALXEDA_XGMAC is not set # CONFIG_NET_VENDOR_CHELSIO is not set # CONFIG_NET_VENDOR_CIRRUS is not set # CONFIG_DM9000 is not set # CONFIG_DNET is not set # CONFIG_NET_VENDOR_FARADAY is not set # CONFIG_NET_VENDOR_INTEL is not set # CONFIG_NET_VENDOR_MARVELL is not set # CONFIG_NET_VENDOR_MICREL is not set # CONFIG_NET_VENDOR_MICROCHIP is not set # CONFIG_NET_VENDOR_NATSEMI is not set # CONFIG_ETHOC is not set # CONFIG_NET_VENDOR_SEEQ is not set # CONFIG_NET_VENDOR_SMSC is not set # CONFIG_NET_VENDOR_STMICRO is not set CONFIG_NET_VENDOR_SUNXI=y CONFIG_SUNXI_GETH=y CONFIG_GETH_SCRIPT_SYS=y CONFIG_GETH_CLK_SYS=y CONFIG_PHYLIB=y # # MII PHY device drivers # # CONFIG_AMD_PHY is not set # CONFIG_MARVELL_PHY is not set # CONFIG_DAVICOM_PHY is not set # CONFIG_QSEMI_PHY is not set # CONFIG_LXT_PHY is not set # CONFIG_CICADA_PHY is not set # CONFIG_VITESSE_PHY is not set # CONFIG_SMSC_PHY is not set # CONFIG_BROADCOM_PHY is not set # CONFIG_ICPLUS_PHY is not set # CONFIG_REALTEK_PHY is not set # CONFIG_NATIONAL_PHY is not set # CONFIG_STE10XP is not set # CONFIG_LSI_ET1011C_PHY is not set # CONFIG_MICREL_PHY is not set # CONFIG_FIXED_PHY is not set # CONFIG_MDIO_BITBANG is not set # CONFIG_MICREL_KS8995MA is not set # CONFIG_PPP is not set # CONFIG_SLIP is not set # # USB Network Adapters # # CONFIG_USB_CATC is not set # CONFIG_USB_KAWETH is not set # CONFIG_USB_PEGASUS is not set # CONFIG_USB_RTL8150 is not set # CONFIG_USB_USBNET is not set # CONFIG_USB_IPHETH is not set # CONFIG_WLAN is not set # # Enable WiMAX (Networking options) to see the WiMAX drivers # # CONFIG_WAN is not set # CONFIG_ISDN is not set # # Input device support # CONFIG_INPUT=y CONFIG_INPUT_FF_MEMLESS=y # CONFIG_INPUT_POLLDEV is not set # CONFIG_INPUT_SPARSEKMAP is not set # # Userland interfaces # # CONFIG_INPUT_MOUSEDEV is not set # CONFIG_INPUT_JOYDEV is not set # CONFIG_INPUT_EVDEV is not set # CONFIG_INPUT_EVBUG is not set # CONFIG_INPUT_KEYRESET is not set CONFIG_INPUT_SW_DEVICE=y # # Input Device Drivers # # CONFIG_INPUT_KEYBOARD is not set # CONFIG_INPUT_MOUSE is not set # CONFIG_INPUT_JOYSTICK is not set # CONFIG_INPUT_TABLET is not set # CONFIG_INPUT_TOUCHSCREEN is not set # CONFIG_INPUT_MISC is not set # # Hardware I/O ports # # CONFIG_SERIO is not set # CONFIG_GAMEPORT is not set # # Character devices # # CONFIG_VT is not set # CONFIG_UNIX98_PTYS is not set # CONFIG_LEGACY_PTYS is not set # CONFIG_SERIAL_NONSTANDARD is not set # CONFIG_N_GSM is not set # CONFIG_TRACE_SINK is not set # CONFIG_DEVMEM is not set # CONFIG_DEVKMEM is not set # # Serial drivers # # CONFIG_SERIAL_8250 is not set # # Non-8250 serial port support # # CONFIG_SERIAL_MAX3100 is not set # CONFIG_SERIAL_MAX3107 is not set CONFIG_SERIAL_CORE=y CONFIG_SERIAL_CORE_CONSOLE=y # CONFIG_SERIAL_TIMBERDALE is not set # CONFIG_SERIAL_ALTERA_JTAGUART is not set # CONFIG_SERIAL_ALTERA_UART is not set # CONFIG_SERIAL_IFX6X60 is not set # CONFIG_SERIAL_XILINX_PS_UART is not set CONFIG_SERIAL_SUNXI=y CONFIG_SERIAL_SUNXI_CONSOLE=y # CONFIG_SERIAL_DEBUG is not set # CONFIG_TTY_PRINTK is not set # CONFIG_HVC_DCC is not set # CONFIG_IPMI_HANDLER is not set # CONFIG_HW_RANDOM is not set # CONFIG_R3964 is not set # CONFIG_TCG_TPM is not set # CONFIG_DCC_TTY is not set # CONFIG_RAMOOPS is not set # CONFIG_SUNXI_D7S is not set # CONFIG_MATRIX_GPIO_INT is not set # CONFIG_MATRIX_PWM is not set # CONFIG_MATRIX_ROTARY_ENCODER is not set # CONFIG_MATRIX_HCSR04 is not set # CONFIG_MATRIX_IR_RECV is not set # CONFIG_IR_CUT is not set CONFIG_SUNXI_CMATESET=y # CONFIG_SUNXI_ARISC_TEST is not set # CONFIG_SUNXI_MODULE is not set # CONFIG_SUNXI_TIMER_TEST is not set # CONFIG_SUNXI_DMA_TEST is not set # CONFIG_SUNXI_SCR is not set # CONFIG_SUNXI_DI is not set CONFIG_SUNXI_SOC_INFO=y # CONFIG_ID is not set # CONFIG_RESET_KEY is not set CONFIG_I2C=y CONFIG_I2C_BOARDINFO=y CONFIG_I2C_COMPAT=y CONFIG_I2C_CHARDEV=y # CONFIG_I2C_MUX is not set CONFIG_I2C_HELPER_AUTO=y # # I2C Hardware Bus support # # # I2C system bus drivers (mostly embedded / system-on-chip) # # CONFIG_I2C_DESIGNWARE_PLATFORM is not set # CONFIG_I2C_GPIO is not set # CONFIG_I2C_OCORES is not set # CONFIG_I2C_PCA_PLATFORM is not set # CONFIG_I2C_PXA_PCI is not set # CONFIG_I2C_SIMTEC is not set CONFIG_I2C_SUNXI=y # CONFIG_I2C_XILINX is not set # # External I2C/SMBus adapter drivers # # CONFIG_I2C_DIOLAN_U2C is not set # CONFIG_I2C_PARPORT_LIGHT is not set # CONFIG_I2C_TAOS_EVM is not set # CONFIG_I2C_TINY_USB is not set # # Other I2C/SMBus bus drivers # # CONFIG_I2C_STUB is not set # CONFIG_I2C_DEBUG_CORE is not set # CONFIG_I2C_DEBUG_ALGO is not set # CONFIG_I2C_DEBUG_BUS is not set CONFIG_SPI=y # CONFIG_SPI_DEBUG is not set CONFIG_SPI_MASTER=y # # SPI Master Controller Drivers # # CONFIG_SPI_ALTERA is not set # CONFIG_SPI_BITBANG is not set # CONFIG_SPI_GPIO is not set # CONFIG_SPI_OC_TINY is not set # CONFIG_SPI_PXA2XX_PCI is not set CONFIG_SPI_SUNXI=y # CONFIG_SPI_XILINX is not set # CONFIG_SPI_DESIGNWARE is not set # # SPI Protocol Masters # CONFIG_SPI_SPIDEV=y # CONFIG_SPI_TLE62X0 is not set # CONFIG_HSI is not set # # PPS support # # CONFIG_PPS is not set # # PPS generators support # # # PTP clock support # # # Enable Device Drivers -> PPS to see the PTP clock options. # CONFIG_PINCTRL=y # # Pin controllers # CONFIG_PINMUX=y CONFIG_PINCONF=y CONFIG_GENERIC_PINCONF=y # CONFIG_DEBUG_PINCTRL is not set CONFIG_PINCTRL_SUNXI=y # CONFIG_PINCTRL_SUNXI_DEBUG is not set # CONFIG_SUNXI_PINCTRL_TEST is not set CONFIG_ARCH_HAVE_CUSTOM_GPIO_H=y CONFIG_ARCH_REQUIRE_GPIOLIB=y CONFIG_GPIOLIB=y # CONFIG_DEBUG_GPIO is not set CONFIG_GPIO_SYSFS=y # # Memory mapped GPIO drivers: # # CONFIG_GPIO_GENERIC_PLATFORM is not set # # I2C GPIO expanders: # # CONFIG_GPIO_MAX7300 is not set # CONFIG_GPIO_MAX732X is not set # CONFIG_GPIO_PCF857X is not set # CONFIG_GPIO_SX150X is not set # CONFIG_GPIO_ADP5588 is not set # # PCI GPIO expanders: # # # SPI GPIO expanders: # # CONFIG_GPIO_MAX7301 is not set # CONFIG_GPIO_MCP23S08 is not set # CONFIG_GPIO_MC33880 is not set # CONFIG_GPIO_74X164 is not set # # AC97 GPIO expanders: # # # MODULbus GPIO expanders: # CONFIG_GPIO_SUNXI=y # CONFIG_W1 is not set # CONFIG_POWER_SUPPLY is not set # CONFIG_HWMON is not set CONFIG_THERMAL=y CONFIG_THERMAL_DEFAULT_GOV_STEP_WISE=y # CONFIG_THERMAL_DEFAULT_GOV_FAIR_SHARE is not set # CONFIG_THERMAL_DEFAULT_GOV_USER_SPACE is not set # CONFIG_FAIR_SHARE is not set CONFIG_STEP_WISE=y # CONFIG_USER_SPACE is not set # CONFIG_SUNXI_THERMAL_DYNAMIC is not set CONFIG_SUNXI_THERMAL=y CONFIG_WATCHDOG=y # CONFIG_WATCHDOG_CORE is not set # CONFIG_WATCHDOG_NOWAYOUT is not set # # Watchdog Device Drivers # # CONFIG_SOFT_WATCHDOG is not set # CONFIG_DW_WATCHDOG is not set # CONFIG_MAX63XX_WATCHDOG is not set CONFIG_SUNXI_WDT=y # # USB-based Watchdog Cards # # CONFIG_USBPCWATCHDOG is not set CONFIG_SSB_POSSIBLE=y # # Sonics Silicon Backplane # # CONFIG_SSB is not set CONFIG_BCMA_POSSIBLE=y # # Broadcom specific AMBA # # CONFIG_BCMA is not set # # Multifunction device drivers # # CONFIG_MFD_CORE is not set # CONFIG_MFD_88PM860X is not set # CONFIG_MFD_SM501 is not set # CONFIG_MFD_ASIC3 is not set # CONFIG_HTC_EGPIO is not set # CONFIG_HTC_PASIC3 is not set # CONFIG_HTC_I2CPLD is not set # CONFIG_TPS6105X is not set # CONFIG_TPS65010 is not set # CONFIG_TPS6507X is not set # CONFIG_MFD_TPS65217 is not set # CONFIG_MFD_TPS6586X is not set # CONFIG_MFD_TPS65910 is not set # CONFIG_MFD_TPS65912_I2C is not set # CONFIG_MFD_TPS65912_SPI is not set # CONFIG_TWL4030_CORE is not set # CONFIG_TWL6040_CORE is not set # CONFIG_MFD_STMPE is not set # CONFIG_MFD_TC3589X is not set # CONFIG_MFD_TMIO is not set # CONFIG_MFD_T7L66XB is not set # CONFIG_MFD_TC6387XB is not set # CONFIG_MFD_TC6393XB is not set # CONFIG_PMIC_DA903X is not set # CONFIG_MFD_DA9052_SPI is not set # CONFIG_MFD_DA9052_I2C is not set # CONFIG_PMIC_ADP5520 is not set # CONFIG_MFD_MAX8925 is not set # CONFIG_MFD_MAX8997 is not set # CONFIG_MFD_MAX8998 is not set # CONFIG_MFD_S5M_CORE is not set # CONFIG_MFD_WM8400 is not set # CONFIG_MFD_WM831X_I2C is not set # CONFIG_MFD_WM831X_SPI is not set # CONFIG_MFD_WM8350_I2C is not set # CONFIG_MFD_WM8994 is not set # CONFIG_MFD_ACX00 is not set # CONFIG_MFD_PCF50633 is not set # CONFIG_MFD_MC13XXX is not set # CONFIG_ABX500_CORE is not set # CONFIG_EZX_PCAP is not set # CONFIG_MFD_WL1273_CORE is not set # CONFIG_MFD_TPS65090 is not set # CONFIG_MFD_AAT2870_CORE is not set # CONFIG_MFD_RC5T583 is not set # CONFIG_REGULATOR is not set CONFIG_PWM=y CONFIG_PWM_SUNXI=y CONFIG_MEDIA_SUPPORT=y # # Multimedia core support # # CONFIG_MEDIA_CONTROLLER is not set # CONFIG_VIDEO_DEV is not set # CONFIG_DVB_CORE is not set # CONFIG_VIDEO_MEDIA is not set # # Multimedia drivers # # CONFIG_RC_CORE is not set # CONFIG_AW_TSC is not set # CONFIG_VIDEO_ENCODER_DECODER_SUNXI is not set # # Graphics support # # CONFIG_DRM is not set # CONFIG_ION is not set # CONFIG_VGASTATE is not set # CONFIG_VIDEO_OUTPUT_CONTROL is not set # CONFIG_FB is not set # CONFIG_EXYNOS_VIDEO is not set # CONFIG_BACKLIGHT_LCD_SUPPORT is not set CONFIG_SOUND=y CONFIG_SOUND_OSS_CORE=y CONFIG_SOUND_OSS_CORE_PRECLAIM=y CONFIG_SND=y CONFIG_SND_TIMER=y CONFIG_SND_PCM=y CONFIG_SND_RAWMIDI=y CONFIG_SND_JACK=y CONFIG_SND_SEQUENCER=m CONFIG_SND_SEQ_DUMMY=m CONFIG_SND_OSSEMUL=y CONFIG_SND_MIXER_OSS=m CONFIG_SND_PCM_OSS=m CONFIG_SND_PCM_OSS_PLUGINS=y CONFIG_SND_SEQUENCER_OSS=y # CONFIG_SND_HRTIMER is not set # CONFIG_SND_DYNAMIC_MINORS is not set CONFIG_SND_SUPPORT_OLD_API=y # CONFIG_SND_VERBOSE_PROCFS is not set # CONFIG_SND_VERBOSE_PRINTK is not set # CONFIG_SND_DEBUG is not set CONFIG_SND_RAWMIDI_SEQ=m # CONFIG_SND_OPL3_LIB_SEQ is not set # CONFIG_SND_OPL4_LIB_SEQ is not set # CONFIG_SND_SBAWE_SEQ is not set # CONFIG_SND_EMU10K1_SEQ is not set CONFIG_SND_DRIVERS=y CONFIG_SND_DUMMY=m CONFIG_SND_ALOOP=m CONFIG_SND_VIRMIDI=m # CONFIG_SND_MTPAV is not set # CONFIG_SND_SERIAL_U16550 is not set # CONFIG_SND_MPU401 is not set CONFIG_SND_ARM=y CONFIG_SND_SPI=y CONFIG_SND_USB=y # CONFIG_SND_USB_AUDIO is not set # CONFIG_SND_USB_UA101 is not set # CONFIG_SND_USB_CAIAQ is not set # CONFIG_SND_USB_6FIRE is not set CONFIG_SND_SOC=y CONFIG_SND_SOC_DMAENGINE_PCM=y CONFIG_SND_SUNXI_SOC_AUDIOCODEC=y CONFIG_SND_SUNXI_SOC_PUBLUC_MACHINE=y CONFIG_SND_SUN8IW7_SNDCODEC=y CONFIG_SND_SUNXI_SOC_DAUDIO0_INTERFACE=y CONFIG_SND_SUNXI_SOC_DAUDIO0_PUBLIC_MACHINE=y CONFIG_SND_SUNXI_SOC_DAUDIO1_INTERFACE=y CONFIG_SND_SUNXI_SOC_DAUDIO1_PUBLIC_MACHINE=y CONFIG_SND_SUNXI_SOC_HDMIAUDIO=y CONFIG_SND_SUN8IW7_HDMIPCM=y CONFIG_SND_SUNXI_SOC_SPDIF=y CONFIG_SND_SUNXI_SOC_AUDIOHUB_INTERFACE=y CONFIG_SND_SUN8IW7_AUDIOHUB=y CONFIG_SND_SUNXI_SOC_SUPPORT_AUDIO_RAW=y CONFIG_SND_SOC_I2C_AND_SPI=y # CONFIG_SND_SOC_RT3261 is not set # CONFIG_SND_RT_EFFECT is not set # CONFIG_SOUND_PRIME is not set # CONFIG_HID_SUPPORT is not set CONFIG_USB_ARCH_HAS_OHCI=y CONFIG_USB_ARCH_HAS_EHCI=y CONFIG_USB_ARCH_HAS_XHCI=y CONFIG_USB_SUPPORT=y CONFIG_USB_COMMON=y CONFIG_USB_ARCH_HAS_HCD=y CONFIG_USB=y # CONFIG_USB_DEBUG is not set CONFIG_USB_ANNOUNCE_NEW_DEVICES=y # # Miscellaneous USB options # # CONFIG_USB_DEVICEFS is not set # CONFIG_USB_DEVICE_CLASS is not set # CONFIG_USB_DYNAMIC_MINORS is not set # CONFIG_USB_OTG_WHITELIST is not set # CONFIG_USB_OTG_BLACKLIST_HUB is not set # CONFIG_USB_DWC3 is not set CONFIG_USB_SUNXI=y # CONFIG_USB_SUNXI_DEBUG is not set # CONFIG_USB_MON is not set # CONFIG_USB_WUSB_CBAF is not set # # USB Host Controller Drivers # # CONFIG_USB_C67X00_HCD is not set # CONFIG_USB_XHCI_HCD is not set CONFIG_USB_XHCI_PLATFORM=y CONFIG_USB_EHCI_HCD=y # CONFIG_USB_EHCI_ROOT_HUB_TT is not set # CONFIG_USB_EHCI_TT_NEWSCHED is not set # CONFIG_USB_OXU210HP_HCD is not set # CONFIG_USB_ISP116X_HCD is not set # CONFIG_USB_ISP1760_HCD is not set # CONFIG_USB_ISP1362_HCD is not set CONFIG_USB_OHCI_HCD=y # CONFIG_USB_OHCI_HCD_PLATFORM is not set CONFIG_USB_EHCI_HCD_PLATFORM=y # CONFIG_USB_OHCI_BIG_ENDIAN_DESC is not set # CONFIG_USB_OHCI_BIG_ENDIAN_MMIO is not set CONFIG_USB_OHCI_LITTLE_ENDIAN=y # CONFIG_USB_SL811_HCD is not set # CONFIG_USB_R8A66597_HCD is not set CONFIG_USB_SUNXI_HCD=y CONFIG_USB_SUNXI_HCD0=y CONFIG_USB_SUNXI_HCI=y CONFIG_USB_SUNXI_EHCI0=y CONFIG_USB_SUNXI_EHCI1=y CONFIG_USB_SUNXI_OHCI0=y CONFIG_USB_SUNXI_OHCI1=y CONFIG_USB_SUNXI_EHCI2=y CONFIG_USB_SUNXI_OHCI2=y CONFIG_USB_SUNXI_EHCI3=y CONFIG_USB_SUNXI_OHCI3=y CONFIG_USB_SUNXI_HSIC=y # CONFIG_SW_USB_3G is not set # CONFIG_USB_MUSB_HDRC is not set # CONFIG_USB_RENESAS_USBHS is not set # # USB Device Class drivers # # CONFIG_USB_ACM is not set # CONFIG_USB_PRINTER is not set # CONFIG_USB_WDM is not set # CONFIG_USB_TMC is not set # # NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may # # # also be needed; see USB_STORAGE Help for more info # # CONFIG_USB_LIBUSUAL is not set # # USB Imaging devices # # CONFIG_USB_MDC800 is not set # # USB port drivers # CONFIG_USB_SERIAL=y CONFIG_USB_SERIAL_CONSOLE=y # CONFIG_USB_EZUSB is not set CONFIG_USB_SERIAL_GENERIC=y # CONFIG_USB_SERIAL_AIRCABLE is not set # CONFIG_USB_SERIAL_ARK3116 is not set # CONFIG_USB_SERIAL_BELKIN is not set # CONFIG_USB_SERIAL_CH341 is not set # CONFIG_USB_SERIAL_WHITEHEAT is not set # CONFIG_USB_SERIAL_DIGI_ACCELEPORT is not set # CONFIG_USB_SERIAL_CP210X is not set # CONFIG_USB_SERIAL_CYPRESS_M8 is not set # CONFIG_USB_SERIAL_EMPEG is not set # CONFIG_USB_SERIAL_FTDI_SIO is not set # CONFIG_USB_SERIAL_FUNSOFT is not set # CONFIG_USB_SERIAL_VISOR is not set # CONFIG_USB_SERIAL_IPAQ is not set # CONFIG_USB_SERIAL_IR is not set # CONFIG_USB_SERIAL_EDGEPORT is not set # CONFIG_USB_SERIAL_EDGEPORT_TI is not set # CONFIG_USB_SERIAL_F81232 is not set # CONFIG_USB_SERIAL_GARMIN is not set # CONFIG_USB_SERIAL_IPW is not set # CONFIG_USB_SERIAL_IUU is not set # CONFIG_USB_SERIAL_KEYSPAN_PDA is not set # CONFIG_USB_SERIAL_KEYSPAN is not set # CONFIG_USB_SERIAL_KLSI is not set # CONFIG_USB_SERIAL_KOBIL_SCT is not set # CONFIG_USB_SERIAL_MCT_U232 is not set # CONFIG_USB_SERIAL_METRO is not set # CONFIG_USB_SERIAL_MOS7720 is not set # CONFIG_USB_SERIAL_MOS7840 is not set # CONFIG_USB_SERIAL_MOTOROLA is not set # CONFIG_USB_SERIAL_NAVMAN is not set # CONFIG_USB_SERIAL_PL2303 is not set # CONFIG_USB_SERIAL_OTI6858 is not set # CONFIG_USB_SERIAL_QCAUX is not set # CONFIG_USB_SERIAL_QUALCOMM is not set # CONFIG_USB_SERIAL_SPCP8X5 is not set # CONFIG_USB_SERIAL_HP4X is not set # CONFIG_USB_SERIAL_SAFE is not set # CONFIG_USB_SERIAL_SIEMENS_MPI is not set # CONFIG_USB_SERIAL_SIERRAWIRELESS is not set # CONFIG_USB_SERIAL_SYMBOL is not set # CONFIG_USB_SERIAL_TI is not set # CONFIG_USB_SERIAL_CYBERJACK is not set # CONFIG_USB_SERIAL_XIRCOM is not set # CONFIG_USB_SERIAL_OPTION is not set # CONFIG_USB_SERIAL_OMNINET is not set # CONFIG_USB_SERIAL_OPTICON is not set # CONFIG_USB_SERIAL_VIVOPAY_SERIAL is not set # CONFIG_USB_SERIAL_ZIO is not set # CONFIG_USB_SERIAL_SSU100 is not set # CONFIG_USB_SERIAL_DEBUG is not set # # USB Miscellaneous drivers # # CONFIG_USB_EMI62 is not set # CONFIG_USB_EMI26 is not set # CONFIG_USB_ADUTUX is not set # CONFIG_USB_SEVSEG is not set # CONFIG_USB_RIO500 is not set # CONFIG_USB_LEGOTOWER is not set # CONFIG_USB_LCD is not set # CONFIG_USB_LED is not set # CONFIG_USB_CYPRESS_CY7C63 is not set # CONFIG_USB_CYTHERM is not set # CONFIG_USB_IDMOUSE is not set # CONFIG_USB_FTDI_ELAN is not set # CONFIG_USB_APPLEDISPLAY is not set # CONFIG_USB_SISUSBVGA is not set # CONFIG_USB_LD is not set # CONFIG_USB_TRANCEVIBRATOR is not set # CONFIG_USB_IOWARRIOR is not set # CONFIG_USB_TEST is not set # CONFIG_USB_ISIGHTFW is not set # CONFIG_USB_YUREX is not set CONFIG_USB_GADGET=y # CONFIG_USB_GADGET_DEBUG is not set # CONFIG_USB_GADGET_DEBUG_FILES is not set # CONFIG_USB_GADGET_DEBUG_FS is not set CONFIG_USB_GADGET_VBUS_DRAW=500 CONFIG_USB_GADGET_STORAGE_NUM_BUFFERS=2 # CONFIG_USB_FUSB300 is not set # CONFIG_USB_R8A66597 is not set # CONFIG_USB_MV_UDC is not set # CONFIG_USB_M66592 is not set # CONFIG_USB_NET2272 is not set # CONFIG_USB_DUMMY_HCD is not set CONFIG_USB_SUNXI_UDC0=y CONFIG_USB_GADGET_DUALSPEED=y CONFIG_USB_GADGET_SUPERSPEED=y # CONFIG_USB_ZERO is not set # CONFIG_USB_AUDIO is not set # CONFIG_USB_ETH is not set # CONFIG_USB_G_NCM is not set # CONFIG_USB_GADGETFS is not set # CONFIG_USB_FUNCTIONFS is not set # CONFIG_USB_G_SERIAL is not set CONFIG_USB_MIDI_GADGET=y # CONFIG_USB_G_PRINTER is not set # CONFIG_USB_G_ANDROID is not set # CONFIG_USB_CDC_COMPOSITE is not set # CONFIG_USB_G_HID is not set # CONFIG_USB_G_DBGP is not set # # OTG and related infrastructure # CONFIG_USB_OTG_UTILS=y # CONFIG_USB_GPIO_VBUS is not set # CONFIG_USB_ULPI is not set # CONFIG_NOP_USB_XCEIV is not set CONFIG_USB_SUNXI_USB=y CONFIG_USB_SUNXI_USB_MANAGER=y # CONFIG_USB_SUNXI_USB0_NULL is not set # CONFIG_USB_SUNXI_USB0_DEVICE_ONLY is not set # CONFIG_USB_SUNXI_USB0_HOST_ONLY is not set CONFIG_USB_SUNXI_USB0_OTG=y CONFIG_USB_SUNXI_USB_DEBUG=y CONFIG_USB_SUNXI_HOST=y CONFIG_MMC=y # CONFIG_MMC_DEBUG is not set # CONFIG_MMC_UNSAFE_RESUME is not set # CONFIG_MMC_CLKGATE is not set # CONFIG_MMC_EMBEDDED_SDIO is not set # CONFIG_MMC_PARANOID_SD_INIT is not set # # MMC/SD/SDIO Card Drivers # # CONFIG_SDIO_UART is not set # CONFIG_MMC_TEST is not set CONFIG_FATFS_FS_SUPPORT=y # # MMC/SD/SDIO Host Controller Drivers # # CONFIG_MMC_SDHCI is not set # CONFIG_MMC_SDHCI_PXAV3 is not set # CONFIG_MMC_SDHCI_PXAV2 is not set # CONFIG_MMC_SPI is not set # CONFIG_MMC_DW is not set CONFIG_MMC_SUNXI=y # CONFIG_MMC_DEBUG_SUNXI is not set CONFIG_MMC_PRE_DBGLVL_SUNXI=0 # CONFIG_MMC_VUB300 is not set # CONFIG_MMC_USHC is not set # CONFIG_MEMSTICK is not set CONFIG_NEW_LEDS=y CONFIG_LEDS_CLASS=y # # LED drivers # # CONFIG_LEDS_LM3530 is not set # CONFIG_LEDS_PCA9532 is not set CONFIG_LEDS_GPIO=y CONFIG_SUNXI_LEDS=y CONFIG_SUNXI_LEDS_COM=y # CONFIG_LEDS_LP3944 is not set # CONFIG_LEDS_LP5521 is not set # CONFIG_LEDS_LP5523 is not set # CONFIG_LEDS_PCA955X is not set # CONFIG_LEDS_PCA9633 is not set # CONFIG_LEDS_DAC124S085 is not set # CONFIG_LEDS_BD2802 is not set # CONFIG_LEDS_LT3593 is not set # CONFIG_LEDS_RENESAS_TPU is not set # CONFIG_LEDS_TCA6507 is not set # CONFIG_LEDS_OT200 is not set CONFIG_LEDS_TRIGGERS=y # # LED Triggers # CONFIG_LEDS_TRIGGER_TIMER=y # CONFIG_LEDS_TRIGGER_HEARTBEAT is not set # CONFIG_LEDS_TRIGGER_BACKLIGHT is not set # CONFIG_LEDS_TRIGGER_GPIO is not set CONFIG_LEDS_TRIGGER_DEFAULT_ON=y # # iptables trigger is under Netfilter config (LED target) # # CONFIG_SWITCH is not set # CONFIG_ACCESSIBILITY is not set CONFIG_RTC_LIB=y CONFIG_RTC_CLASS=y CONFIG_RTC_HCTOSYS=y CONFIG_RTC_HCTOSYS_DEVICE="rtc0" # CONFIG_RTC_DEBUG is not set # # RTC interfaces # CONFIG_RTC_INTF_SYSFS=y CONFIG_RTC_INTF_PROC=y CONFIG_RTC_INTF_DEV=y # CONFIG_RTC_INTF_DEV_UIE_EMUL is not set # CONFIG_RTC_DRV_TEST is not set # # I2C RTC drivers # # CONFIG_RTC_DRV_DS1307 is not set # CONFIG_RTC_DRV_DS1374 is not set # CONFIG_RTC_DRV_DS1672 is not set # CONFIG_RTC_DRV_DS3232 is not set # CONFIG_RTC_DRV_MAX6900 is not set # CONFIG_RTC_DRV_RS5C372 is not set # CONFIG_RTC_DRV_ISL1208 is not set # CONFIG_RTC_DRV_ISL12022 is not set # CONFIG_RTC_DRV_X1205 is not set # CONFIG_RTC_DRV_PCF8563 is not set # CONFIG_RTC_DRV_PCF8583 is not set # CONFIG_RTC_DRV_M41T80 is not set # CONFIG_RTC_DRV_BQ32K is not set # CONFIG_RTC_DRV_S35390A is not set # CONFIG_RTC_DRV_FM3130 is not set # CONFIG_RTC_DRV_RX8581 is not set # CONFIG_RTC_DRV_RX8025 is not set # CONFIG_RTC_DRV_EM3027 is not set # CONFIG_RTC_DRV_RV3029C2 is not set # # SPI RTC drivers # # CONFIG_RTC_DRV_M41T93 is not set # CONFIG_RTC_DRV_M41T94 is not set # CONFIG_RTC_DRV_DS1305 is not set # CONFIG_RTC_DRV_DS1390 is not set # CONFIG_RTC_DRV_MAX6902 is not set # CONFIG_RTC_DRV_R9701 is not set # CONFIG_RTC_DRV_RS5C348 is not set # CONFIG_RTC_DRV_DS3234 is not set # CONFIG_RTC_DRV_PCF2123 is not set # # Platform RTC drivers # # CONFIG_RTC_DRV_CMOS is not set # CONFIG_RTC_DRV_DS1286 is not set # CONFIG_RTC_DRV_DS1511 is not set # CONFIG_RTC_DRV_DS1553 is not set # CONFIG_RTC_DRV_DS1742 is not set # CONFIG_RTC_DRV_STK17TA8 is not set # CONFIG_RTC_DRV_M48T86 is not set # CONFIG_RTC_DRV_M48T35 is not set # CONFIG_RTC_DRV_M48T59 is not set # CONFIG_RTC_DRV_MSM6242 is not set # CONFIG_RTC_DRV_BQ4802 is not set # CONFIG_RTC_DRV_RP5C01 is not set # CONFIG_RTC_DRV_V3020 is not set # # on-CPU RTC drivers # CONFIG_RTC_DRV_SUNXI=y CONFIG_DMADEVICES=y # CONFIG_DMADEVICES_DEBUG is not set # # DMA Devices # # CONFIG_DW_DMAC is not set # CONFIG_TIMB_DMA is not set CONFIG_DMA_ENGINE=y CONFIG_DMA_VIRTUAL_CHANNELS=y # # DMA Clients # # CONFIG_NET_DMA is not set # CONFIG_ASYNC_TX_DMA is not set CONFIG_SUNXI_DMA=y # CONFIG_DMATEST is not set # CONFIG_AUXDISPLAY is not set # CONFIG_UIO is not set # # Virtio drivers # # CONFIG_VIRTIO_BALLOON is not set # CONFIG_VIRTIO_MMIO is not set # # Microsoft Hyper-V guest support # CONFIG_STAGING=y # CONFIG_USBIP_CORE is not set # CONFIG_ECHO is not set # CONFIG_ASUS_OLED is not set # CONFIG_TRANZPORT is not set # CONFIG_LINE6_USB is not set # CONFIG_USB_SERIAL_QUATECH2 is not set # CONFIG_USB_SERIAL_QUATECH_USB2 is not set # CONFIG_IIO is not set # CONFIG_ZSMALLOC is not set # CONFIG_BCM_WIMAX is not set # CONFIG_FT1000 is not set # # Speakup console speech # # CONFIG_TOUCHSCREEN_CLEARPAD_TM1217 is not set # CONFIG_TOUCHSCREEN_SYNAPTICS_I2C_RMI4 is not set # CONFIG_STAGING_MEDIA is not set # # Android # # CONFIG_ANDROID is not set # CONFIG_PHONE is not set # CONFIG_USB_WPAN_HCD is not set # CONFIG_SUNXIOOPS is not set CONFIG_CLKDEV_LOOKUP=y CONFIG_HAVE_CLK_PREPARE=y CONFIG_COMMON_CLK=y # # Common Clock Framework # # CONFIG_COMMON_CLK_DISABLE_UNUSED is not set # CONFIG_COMMON_CLK_ENABLE_SYNCBOOT is not set # CONFIG_COMMON_CLK_DEBUG is not set # # SUNXI Clock Configuration # # CONFIG_SUNXI_CLK_DEFAULT_INIT is not set # CONFIG_SUNXI_CLK_AHB_FROM_PLL6 is not set CONFIG_PLL6AHB1_CLK_DFT_VALUE=200000000 CONFIG_AHB1_CLK_DFT_VALUE=200000000 CONFIG_APB1_CLK_DFT_VALUE=100000000 # # Hardware Spinlock drivers # CONFIG_CLKSRC_MMIO=y CONFIG_SUNXI_TIMER=y # CONFIG_IOMMU_SUPPORT is not set # # Remoteproc drivers (EXPERIMENTAL) # # # Rpmsg drivers (EXPERIMENTAL) # # CONFIG_VIRT_DRIVERS is not set # CONFIG_PM_DEVFREQ is not set # CONFIG_GATOR_PERF is not set # # File systems # # CONFIG_FS_POSIX_ACL is not set # CONFIG_FILE_LOCKING is not set CONFIG_FSNOTIFY=y CONFIG_DNOTIFY=y CONFIG_INOTIFY_USER=y CONFIG_FANOTIFY=y # CONFIG_QUOTA is not set # CONFIG_QUOTACTL is not set # CONFIG_AUTOFS4_FS is not set # CONFIG_FUSE_FS is not set # # Caches # # CONFIG_FSCACHE is not set # # Pseudo filesystems # CONFIG_PROC_FS=y CONFIG_PROC_SYSCTL=y CONFIG_PROC_PAGE_MONITOR=y CONFIG_SYSFS=y # CONFIG_HUGETLB_PAGE is not set # CONFIG_CONFIGFS_FS is not set CONFIG_MISC_FILESYSTEMS=y # CONFIG_PSTORE is not set # CONFIG_NETWORK_FILESYSTEMS is not set CONFIG_NLS=y CONFIG_NLS_DEFAULT="iso8859-1" CONFIG_NLS_CODEPAGE_437=y # CONFIG_NLS_CODEPAGE_737 is not set # CONFIG_NLS_CODEPAGE_775 is not set # CONFIG_NLS_CODEPAGE_850 is not set # CONFIG_NLS_CODEPAGE_852 is not set # CONFIG_NLS_CODEPAGE_855 is not set # CONFIG_NLS_CODEPAGE_857 is not set # CONFIG_NLS_CODEPAGE_860 is not set # CONFIG_NLS_CODEPAGE_861 is not set # CONFIG_NLS_CODEPAGE_862 is not set # CONFIG_NLS_CODEPAGE_863 is not set # CONFIG_NLS_CODEPAGE_864 is not set # CONFIG_NLS_CODEPAGE_865 is not set # CONFIG_NLS_CODEPAGE_866 is not set # CONFIG_NLS_CODEPAGE_869 is not set # CONFIG_NLS_CODEPAGE_936 is not set # CONFIG_NLS_CODEPAGE_950 is not set # CONFIG_NLS_CODEPAGE_932 is not set # CONFIG_NLS_CODEPAGE_949 is not set # CONFIG_NLS_CODEPAGE_874 is not set # CONFIG_NLS_ISO8859_8 is not set # CONFIG_NLS_CODEPAGE_1250 is not set # CONFIG_NLS_CODEPAGE_1251 is not set CONFIG_NLS_ASCII=y CONFIG_NLS_ISO8859_1=y # CONFIG_NLS_ISO8859_2 is not set # CONFIG_NLS_ISO8859_3 is not set # CONFIG_NLS_ISO8859_4 is not set # CONFIG_NLS_ISO8859_5 is not set # CONFIG_NLS_ISO8859_6 is not set # CONFIG_NLS_ISO8859_7 is not set # CONFIG_NLS_ISO8859_9 is not set # CONFIG_NLS_ISO8859_13 is not set # CONFIG_NLS_ISO8859_14 is not set # CONFIG_NLS_ISO8859_15 is not set # CONFIG_NLS_KOI8_R is not set # CONFIG_NLS_KOI8_U is not set CONFIG_NLS_UTF8=y # CONFIG_FS_BLOCK_COMPAT is not set # # Kernel hacking # CONFIG_DEFAULT_MESSAGE_LOGLEVEL=7 # CONFIG_ENABLE_WARN_DEPRECATED is not set # CONFIG_ENABLE_MUST_CHECK is not set CONFIG_FRAME_WARN=1024 CONFIG_MAGIC_SYSRQ=y # CONFIG_STRIP_ASM_SYMS is not set # CONFIG_UNUSED_SYMBOLS is not set CONFIG_DEBUG_FS=y # CONFIG_HEADERS_CHECK is not set # CONFIG_DEBUG_SECTION_MISMATCH is not set CONFIG_DEBUG_KERNEL=y # CONFIG_DEBUG_SHIRQ is not set CONFIG_LOCKUP_DETECTOR=y # CONFIG_HARDLOCKUP_DETECTOR_NMI is not set CONFIG_HARDLOCKUP_DETECTOR_OTHER_CPU=y CONFIG_HARDLOCKUP_DETECTOR=y # CONFIG_BOOTPARAM_HARDLOCKUP_PANIC is not set CONFIG_BOOTPARAM_HARDLOCKUP_PANIC_VALUE=0 # CONFIG_BOOTPARAM_SOFTLOCKUP_PANIC is not set CONFIG_BOOTPARAM_SOFTLOCKUP_PANIC_VALUE=0 # CONFIG_DETECT_HUNG_TASK is not set # CONFIG_SCHED_DEBUG is not set # CONFIG_SCHEDSTATS is not set # CONFIG_TIMER_STATS is not set # CONFIG_DEBUG_OBJECTS is not set # CONFIG_DEBUG_SLAB is not set # CONFIG_DEBUG_KMEMLEAK is not set # CONFIG_DEBUG_PREEMPT is not set # CONFIG_DEBUG_RT_MUTEXES is not set # CONFIG_RT_MUTEX_TESTER is not set # CONFIG_DEBUG_SPINLOCK is not set # CONFIG_DEBUG_MUTEXES is not set # CONFIG_DEBUG_LOCK_ALLOC is not set # CONFIG_PROVE_LOCKING is not set # CONFIG_SPARSE_RCU_POINTER is not set # CONFIG_LOCK_STAT is not set # CONFIG_DEBUG_ATOMIC_SLEEP is not set # CONFIG_DEBUG_LOCKING_API_SELFTESTS is not set CONFIG_STACKTRACE=y # CONFIG_DEBUG_STACK_USAGE is not set # CONFIG_DEBUG_KOBJECT is not set # CONFIG_DEBUG_INFO is not set # CONFIG_DEBUG_VM is not set # CONFIG_DEBUG_WRITECOUNT is not set # CONFIG_DEBUG_MEMORY_INIT is not set # CONFIG_DEBUG_LIST is not set # CONFIG_TEST_LIST_SORT is not set # CONFIG_DEBUG_SG is not set # CONFIG_DEBUG_NOTIFIERS is not set # CONFIG_DEBUG_CREDENTIALS is not set # CONFIG_RCU_TORTURE_TEST is not set CONFIG_RCU_CPU_STALL_TIMEOUT=20 # CONFIG_RCU_CPU_STALL_VERBOSE is not set # CONFIG_RCU_CPU_STALL_INFO is not set # CONFIG_RCU_TRACE is not set # CONFIG_BACKTRACE_SELF_TEST is not set # CONFIG_DEBUG_FORCE_WEAK_PER_CPU is not set # CONFIG_DEBUG_PER_CPU_MAPS is not set # CONFIG_CPU_NOTIFIER_ERROR_INJECT is not set # CONFIG_FAULT_INJECTION is not set # CONFIG_DEBUG_PAGEALLOC is not set CONFIG_HAVE_FUNCTION_TRACER=y CONFIG_HAVE_FUNCTION_GRAPH_TRACER=y CONFIG_HAVE_DYNAMIC_FTRACE=y CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y CONFIG_HAVE_C_RECORDMCOUNT=y CONFIG_TRACING_SUPPORT=y # CONFIG_FTRACE is not set # CONFIG_DMA_API_DEBUG is not set # CONFIG_ATOMIC64_SELFTEST is not set # CONFIG_SAMPLES is not set CONFIG_HAVE_ARCH_KGDB=y # CONFIG_KGDB is not set # CONFIG_TEST_KSTRTOX is not set CONFIG_STRICT_DEVMEM=y CONFIG_ARM_UNWIND=y # CONFIG_DEBUG_USER is not set # CONFIG_DEBUG_RODATA is not set # CONFIG_DEBUG_LL is not set # # Security options # CONFIG_KEYS=y # CONFIG_ENCRYPTED_KEYS is not set # CONFIG_KEYS_DEBUG_PROC_KEYS is not set # CONFIG_SECURITY_DMESG_RESTRICT is not set # CONFIG_SECURITY is not set # CONFIG_SECURITYFS is not set # CONFIG_TRUSTED_LITTLE_KERNEL is not set CONFIG_DEFAULT_SECURITY_DAC=y CONFIG_DEFAULT_SECURITY="" # CONFIG_CRYPTO is not set # CONFIG_BINARY_PRINTF is not set # # Library routines # CONFIG_BITREVERSE=y CONFIG_GENERIC_PCI_IOMAP=y CONFIG_GENERIC_IO=y # CONFIG_CRC_CCITT is not set # CONFIG_CRC16 is not set # CONFIG_CRC_T10DIF is not set # CONFIG_CRC_ITU_T is not set CONFIG_CRC32=y # CONFIG_CRC32_SELFTEST is not set CONFIG_CRC32_SLICEBY8=y # CONFIG_CRC32_SLICEBY4 is not set # CONFIG_CRC32_SARWATE is not set # CONFIG_CRC32_BIT is not set # CONFIG_CRC7 is not set # CONFIG_LIBCRC32C is not set # CONFIG_CRC8 is not set CONFIG_ZLIB_INFLATE=y CONFIG_LZO_COMPRESS=y CONFIG_LZO_DECOMPRESS=y # CONFIG_XZ_DEC is not set # CONFIG_XZ_DEC_BCJ is not set CONFIG_DECOMPRESS_GZIP=y CONFIG_GENERIC_ALLOCATOR=y CONFIG_HAS_IOMEM=y CONFIG_HAS_IOPORT=y CONFIG_HAS_DMA=y CONFIG_CPU_RMAP=y CONFIG_DQL=y CONFIG_NLATTR=y # CONFIG_AVERAGE is not set # CONFIG_CORDIC is not set However, If I try to rebuild kernel with instructions taken from wiki.friendlyarm.com/wiki/index.php/NanoPi_NEO#Get_Image_Files, I get following error(s): fs/sync.c: In function ‘vfs_fsync_range’: fs/sync.c:206:3: error: implicit declaration of function ‘__blkdev_driver_ioctl’ [-Werror=implicit-function-declaration] cc1: some warnings being treated as errors scripts/Makefile.build:307: recipe for target 'fs/sync.o' failed make[1]: *** [fs/sync.o] Error 1 make[1]: *** Waiting for unfinished jobs.... CC [M] sound/core/seq/seq.o CC net/ipv4/tcp_output.o CC net/core/netevent.o CC kernel/srcu.o CC kernel/semaphore.o LD drivers/clk/sunxi/built-in.o CC [M] sound/core/seq/seq_lock.o LD drivers/clk/built-in.o CC drivers/clocksource/mmio.o CC net/core/neighbour.o CC kernel/notifier.o CC kernel/ksysfs.o CC [M] sound/core/seq/seq_clientmgr.o CC drivers/clocksource/sunxi_timer.o CC net/core/rtnetlink.o drivers/clocksource/sunxi_timer.c: In function ‘sunxi_timer_init’: drivers/clocksource/sunxi_timer.c:174:2: error: implicit declaration of function ‘of_clk_get’ [-Werror=implicit-function-declaration] drivers/clocksource/sunxi_timer.c:174:6: warning: assignment makes pointer from integer without a cast [enabled by default] cc1: some warnings being treated as errors scripts/Makefile.build:307: recipe for target 'drivers/clocksource/sunxi_timer.o' failed make[2]: *** [drivers/clocksource/sunxi_timer.o] Error 1 scripts/Makefile.build:443: recipe for target 'drivers/clocksource' failed make[1]: *** [drivers/clocksource] Error 2 Makefile:946: recipe for target 'drivers' failed make: *** [drivers] Error 2 make: *** Waiting for unfinished jobs.... CC net/core/utils.o CC kernel/cred.o Makefile:946: recipe for target 'fs' failed make: *** [fs] Error 2 What did I forgot to include in kernel configuration process? Sincerely, Marko Edited October 27, 2016 by zador.blood.stained Added spoiler tags
Igor Posted October 27, 2016 Posted October 27, 2016 Such problems are one of the main reasons that Armbian project started to exists. Script: https://github.com/igorpecovnik/lib Manual: http://docs.armbian.com/Developer-Guide_Build-Preparation/ It will move you to the user level and save a lot of time. Result will be way better.
KernelPanic Posted October 27, 2016 Author Posted October 27, 2016 Such problems are one of the main reasons that Armbian project started to exists. Script: https://github.com/igorpecovnik/lib Manual: http://docs.armbian.com/Developer-Guide_Build-Preparation/ It will move you to the user level and save a lot of time. Result will be way better. This is all ok, I've created new image, however it is too big and full of things which I do not need. I need minimal low latency (realtime) kernel with full ALSA support and (for testing purposes) ssh so I can test image via LAN. Otherwise, superb script you have written!
