I try to install chromium and get this:
root@tinkerboard:~# sudo apt install chromium-browser
Reading package lists... Done
Building dependency tree... Done
The following NEW packages will be installed:
  chromium-browser
0 upgraded, 1 newly installed, 0 to remove and 1 not upgraded.
Need to get 0 B/49.2 kB of archives.
After this operation, 165 kB of additional disk space will be used.
Preconfiguring packages ...
(Reading database ... 41567 files and directories currently installed.)
Preparing to unpack .../chromium-browser_1%3a85.0.4183.83-0ubuntu2.22.04.1_armhf.deb ...
=> Installing the chromium snap
==> Checking connectivity with the snap store
==> Installing the chromium snap
error: system does not fully support snapd: cannot mount squashfs image using "squashfs": mount:
       /tmp/syscheck-mountpoint-3456514169: unknown filesystem type 'squashfs'.
dpkg: error processing archive /var/cache/apt/archives/chromium-browser_1%3a85.0.4183.83-0ubuntu2.22.04.1_armhf.deb (--unpack):
 new chromium-browser package pre-installation script subprocess returned error exit status 1
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
This only happens in Armbian 23, in Armbian 22 both Ubuntu/Debian images everything worked well.
Any way to solve without rebuilding image?
