_Rygelius_ Posted March 19, 2023 Posted March 19, 2023 Hey there, first of all: THANKS for the armbian project! My issue is with an M1, fresh jammy xfce install on an sd-card. NVME is installed (can be accessed after mounting it manually, no issues there) Wishing to move system to this /dev/nvme0n1, keeping boot on the sdcard, as I understand this being the only viable option, currently. When using armbian-install, selectin option 1 "Boot from SD - system on SATA, USB or NVMe" and confiming, next is an error message: --- There is not enough free capacity on /dev/nvme0n1. Please check your device. --- Did so, tried creating an empty (linux) file system, fat etc, accessible using mount, still the same error. I am pretty sure I am doing something wrong and I'm missing something completely, could someone please help me out? Thanks so much 🙂 0 Quote
Werner Posted March 19, 2023 Posted March 19, 2023 Can you show us the output of fdisk -l of the nvme you are trying to use? 0 Quote
_Rygelius_ Posted March 19, 2023 Author Posted March 19, 2023 fdisk -l /dev/nvme0n1 Disk /dev/nvme0n1: 238,47 GiB, 256060514304 bytes, 500118192 sectors Disk model: SK hynix BC501 HFM256GDJTNG-8310A Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes It's a Gen 3 device, throughputs using iozone3 (or simply dd for a sequential write test) are normal (on wintendo levels) I tried mounted and not mounted, with a 100% percent partion in default "linux file system" (ext4) and (v)fat(32), to no avail, it's always coming up with its complaint about no free space on the device 0 Quote
