Hi, I decided to switch from Ubuntu 20.04 to 22.04 on my MVR9 (Rockchip 3328).
The previous version (Armbian_20.10_Arm-64_focal_current_5.9.0.img.xz) that I had used, had been realized by Balbes150.
Today, I installed the image for the Station M1 by Balbes150 (Armbian_23.02.0-trunk_Station-m1_jammy_edge_6.2.0.img.xz) on my MVR9, and everything works except the blue front led that no longer automatically turns on when I agree the PC.
I wanted to know if you can tell me which files it is necessary to modify so that the blue LED turns on when the PC is on and that turns off when the PC is turned off. MVR9 has only one LED (Blue).
It seems that only the LEDs for the M1 station are defined, I tried to trigger them but as had to be expected, the LED does not turn on.
If it becomes necessary to edit source files, it is not a problem for me to compile armbian myself.
@balbes150, please, can you help me?
With Ubuntu 22.04:
  Quote
# ls /sys/devices/platform/leds/leds/
firefly:blue:power
firefly:yellow:user
Expand
  Quote
# sudo ls /sys/class/leds/
firefly:blue:power
firefly:yellow:user
input0::capslock
input0::compose
input0::kana
input0::numlock
input0::scrolllock
Expand
With Ubuntu 20.04:
DTB used: rk3328-box-trn9.dtb
  Quote
power
Expand
  Quote
input1::capslock
input1::compose
input1::kana
input1::numlock
input1::scrolllock
power
Expand
Posted (edited)
  On 4/3/2023 at 7:40 AM, balbes150 said:
look for the difference and create your own DTB.
Expand
Thanks for the reply.
I compared the files, there is a considerable number of differences.
1) Should I just copy only the led section from the rk3328-box-trn9.dtb to the rk3328-roc-pc.dtb?
From rk3328-box-trn9.dts:
  Quote
    leds {
        compatible = "gpio-leds";
        power {
            gpios = <0x6e 0x00 0x01>;
            linux,default-trigger = "default-on";
            default-state = "on";
Expand
Here I uploaded the two dtb and the two dts.
2) Do you have the sources of the dtb file: rk3328-box-trn9.dtb?
I searched among the story of your Github "Build" repo, but I couldn't find it.
Edited by Tod
