garz Posted April 4, 2023 Posted April 4, 2023 Hello everyone, I recently purchased an ili9488 touch screen for use with my Orange Pi 5, but I'm having trouble getting it to work. I've tried several solutions that I found online, but so far nothing has worked. Specifically, the screen isn't displaying any output when I connect it to my Orange Pi 5, and I'm not sure what steps to take next. https://a.aliexpress.com/_EQaN4gj - That is the screen I bought. For context,I have the latest version of the Armbian operating system installed. I've followed the instructions that came with the touch screen, and I've also tried several different solutions that I found online (including using the fbset command to adjust the display resolution, and updating the device tree overlay file). If anyone has any suggestions or advice for how I can troubleshoot this issue, I would be extremely grateful. I'm open to any possible solutions, and I'm willing to try anything to get this screen up and running. Thank you in advance for your help! 0 Quote
Fruchtzerg Posted June 9, 2023 Posted June 9, 2023 Hi just had a similar problem with my bananapi and the ili9341 and might have some helpful tips. 1. thing I did was to check if there's a driver for your chip honestly I am not sure if this is the case for the ili9488 locate ili9488 2. Load your overlay and check dmesg dmesg | grep -E ili9488 There you should see if the panel gets loaded during spartup or if there are any problems with the spi bus for example. 3. Post your overlay and wiring, I had a lot of trouble too understand the syntax fot the <&pio x y z > and got them wrong all the time. the orange pi cs(chipselect) for the spi4 is the gpio1_c4 so it should look like this <&pio 2 4 0> With 2 = (letter C)-1 4(comes from the pin) and 0 is low. at least that's how it works with the bananapi. Hope this can help a little bit 0 Quote
robertoj Posted December 11 Posted December 11 I am currently in the middle of getting ili9488 working. check this thread https://forum.armbian.com/topic/47971-driving-the-ili9488-lcd-40-inch-cheap-chinese-clone/ and if possible, collaborate with the experiments I am trying The ili9341 is already solved: search "orange pi zero 3 ili9341" ... I used the driver with DRM, which has more efficient GPU and video acceleration 0 Quote
