Non - Booting of Armbian_4.3_Cubietruck_Debian_jessie_3.4.108
First Boot is Ok and then at second Booting of the above image, I receive the usual Out of Sync messaage (67.5kHz / 60 Hz) message and no display!
regards, hitam4450
I have no idea what kind of monitor do you have?  :o  :D
Images are tested and they are working. I did a test on exact (just to make sure) this one and it boots like charm.
On HDMI and VGA.
You own me a beer ;)
If you have some old monitor, than you will need to force lower resolution. Check Documentation.
Hi Igor!
Thanks for your answer & advice!
Well, I use a LG 22" Monitor with a native 1600 x 1050 resolution. All your *old* images worked and displayed without any problems.
I always use a HDMI - VGA adapter, because the HDMI - DVI creates some problems displaying contents.It is strange, since the display problems onyl show up lately!
regads, hitam4450
PS:
Output from dmesg:
 4.540306] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
Any Clou??
Strange. I guess it must be related to this a little bit unusual resolution.
So, do you see this picture after the Tux?
and some text from U-boot or not?
.. and exactly which image is working?
This is what we need to check up first.
On cold boot i see armbian and a few lines...that's it!
I triple checked all cabling..... i always use the same adapter........
 I use the other image, mentioned in my other post!
regards, hitam4450
PS: i just tried the HDM - DVI adapter without any pro blems, all content is ddisplayed clearly!
Advice??
