X96 Max Plus with S905x3 4Gb RAM and 64Gb ROM
JaimeDB
Hello @SteeMan,
I install armbian on X96 Max Plus with S905x3 4Gb RAM and 64Gb ROM, thanks a lot for your work, the ethernet and emmc install is ok, but NO audio?
I use meson-sm1-a95xf3-air.dtb and Armbian_23.02.2_Aml-s9xx-box_jammy_current_6.1.11_xfce_desktop.img
What dtb file I must use or where I can learn how to compile new dtb file?
Can I use emuelec dtb files?
Regards
That is pretty good.  Better than many tv boxes.
Have you read:
https://forum.armbian.com/topic/16976-status-of-armbian-on-tv-boxes-please-read-first
Have you tried all the meson-sm1-* dtb files?  The idea is to find the one that is the best fit for your hardware where there isn't an exact match in the linux kernel.
Maybe.  dtb files are kernel version specific (but not alot changes between linux versions) so if the dtb is from a recent linux kernel it may be compatible.  There would be no harm in trying.
