Namexx Posted April 21, 2023 Share Posted April 21, 2023 Hello guys, you know that armbian has a problem that sometimes when the system boots, the ethernet interfaces fail. The led turns on indicating that it detected the interface but it is totally blocked. It does not work, no method of restarting the interface. The only solution is to restart the computer... 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted April 21, 2023 Share Posted April 21, 2023 Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. 0 Quote Link to comment Share on other sites More sharing options...
