Banani Pi M5, Armbian_23.02.2_Bananapim5_bullseye_current_6.1.11_xfce_desktop into SD card, USB drive connected and auto mounted in fstab.
Boot loop looking for system into USB.
I have to disconnect USB then it boots up from SD.
Any help?
Hello, I managed to boot recently on external usb sata. here is the HOW-TO I would have seen somewhere..
I - Install armbian x86 UEFI
        I really recommend it !  You will be able to compile arm from it faster.
        just before going on, it possible to put it side by side with LMDE5 and share /home using garted copy and paste of partitions!
II - Install armbian arm64 aside and outside 😎
1)      I used gparted to make free space  and create a new partition of size 14749 Mb (size of emmc) /dev/sdaX
2) then decompress  the image you downloaded from (redirect).armbian.com big KISS to @Werner for the mirror !
 here <foo> is for example jammy,bullseye,bookworm etc..
unxz -T0 Armbian_<version>_<foo>_arm64.img.tz
3) copy it to the partition (and SD)
   a) then you mount armbian_<version>_<foo>_arm64.img with gnome-disks utility or other way
  b) inside gnome-disk locate THE ARMBIAN_ROOT PARTITION and mount it. click on the link /media/$USER/armbian_root
 c) The fastest way to transfer I found is with partclone (see ubuntu manual that indicates partiitons should be umounted!):
partclone.extfs -b -d -s /media/$USER/armbian_root  -o /dev/sdaX
4) Fix the UUID if it does not match
you can access to the /boot directory , in this directory you see the UUID in the boot/armbianEnv.txt  like "SoSIe-Love-Armbian-It-R0cks" or in etc/fstab
you use tune2fs to set the partition /dev/sdaX to it with:
tune2fs /dev/sdaX -U <UUID>
5) then you copy it to a sdcard > 16Go to boot on it
dd if=/dev/sdaX of=/dev/<sdcard> bs=10M
6) Put the sdcard on the sbc bananapiM5 and boot it
   recommend to install to emmc with armbian-install or dd way like i discribed before ,
  then shutdown the sbc, remove the sdcard, light on to make all actions in the emmc because it is faster and safer
7 ) Now inside as root you can copy boot as boot-emmc
mkdir /boot-emmc
rsync -aPz /boot /boot-emmc
8 ) then you rename boot
mv boot boot-usb-sata-<foo>
9) Adapt  armbianEnv.txt and boot.cmd tfor usb sata target
cd /boot-usb-sata-<foo>
Check the armbianEnv.txt and boot.cmd to match target usb sata partition drive
    a) the UUID must match those of /dev/sdaX  (or other armbian_root)
    b) rootdevfs is no more /dev/mmcblk1p1 but /dev/sdaX   (or other armbian_root)
10) then you do symlink to usb sata boot, the one you want to boot
rm boot # erase previous link, ln -sf does nothing
ln -s boot-usb-sata-<foo> boot
11) Ensure your usb sata drive is connected to BPI M5 usb3 port.. I have a powered usb sata case. I notice the power is not enougth on USB3 to handle usb sata drive
11) Reboot the baby.. now you should boot on usb sata /dev/sdaX !
of course  ONE WILL SAY, HEY DUDE, THERE IS THE ARMBIAN-INSTALL SCRIPT...yes but no it can not handle side by side boot without erasing all drive.
Edited by SoSie
fix
