I have Armbian 23.05.0-trunk Bullseye with Linux 5.4.239-odroidxu4 on my XU4. I recently bought a USB Bluetooth adapter using RTL8761A. But the firmware is not present in rtl_bt.
I want the Bluetooth adapter to work for Home Assistant.
I am quite new to this stuff, so if you need any additional information i will provide.
Thanks in Advance.
Possible quick fix is:
sudo apt install armbian-firmware-full
+ reboot
If that doesn't help, its more complicated.
It gives this error.
Reading package lists... Done
Building dependency tree... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 armbian-firmware : Conflicts: armbian-firmware-full
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
