Hankpt Posted May 3, 2023 Share Posted May 3, 2023 Hi peoples, updating my old NAS (odroidH1 OMV) 1TB SSD New set-up: BPiM5 armbian bullseye - OMV samsung 2TB SSD installation up and running but... OMV or sudo fdisk -l cannot see new Samsung 2TB SSD (I have 2 of these, one will be back-up) I have connected ssd's via sata usb3.1 cable 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted May 3, 2023 Share Posted May 3, 2023 Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. 0 Quote Link to comment Share on other sites More sharing options...
Hankpt Posted May 4, 2023 Author Share Posted May 4, 2023 Hi Werner Thanks for taking the time to reply. I spent many hrs lastnight trying to get these ssd's to show up with no success..... upon waking this morning i had an idea to test.... I plugged in a standard usb thumb drive next to 1 SSD and rebooted.... In the terminal i could see the usb drive and to my surprise i could also see the SSD I then opened OMV6 web interface and could also see both usb drive & SSD.. so! long story short, i ended up setting up both the SSD's for OMV6..... all good!.... BUT!! I found the problem: when i take the usb drive out it continues to work until I restart BPiM5 without it in place, the SSD's no longer show up. If i plug the usb drive back in and restart BPiM5 then the SSD's show up. So I'm now in the situation for this to work, i have to have a usb stick in place, not really ideal considering if i want to mount more drive's in near future. It seems that the BPi had no trouble seeing the usb stick and allocated a label for it which then lets it see the 2 SSD's and label them accordingly, all still runs fine when i remove usb stick.... until I restart without it. It's like it's messing with it's (a)(b)(c) allocations. I'm a noob, I have no idea what's causing this.... maybe the sata cables i bought (USB3.1 usap)?? I really wanted to get the 3.2 gen2 cables but the costs were mounting up. maybe i should have stuck with the standard USB3.0 cables? Or it's the ssd's themselves, I thought being samsung 2TB-870QVO's it should be less chance of issues? Kind Regards. 0 Quote Link to comment Share on other sites More sharing options...
