I had some troubles with the latest build (Armbian_23.05.0-trunk_Orangepi5_lunar_legacy_5.10.110).
First I had to restore the 5b specific device tree (rk3588s-orangepi-5b.dts) because with the modified rk3588s-orangepi-5.dts the Wi-Fi and the eMMC doesn't work.
So far everything works fine with the exception of the bluetooth.
After each boot I have to manually attach it:
hciattach /dev/ttyS9 any
...otherwise the hci_uart module is not loaded and no hci device is available.
Once attached the bluetooth works fine and I can pair my mouse with it, but not my bluetooth keyboard?!?
Seems like the adapter doesn't even detect the keyboard. When I run bluetoothctl scan on - the device (with a strange address: 00:00:00:00:0E:3E) doesn't show up.
I can easily connect the same keyboard to my macbook with no problems and it works just fine.
Is there anything that I'm missing?
