Greetings,
As the subject says...
CEC not detected in kernel, cec-client throws errors, nothing I tried worked.
root@odroidxu4:~# uname -a
Linux odroidxu4 5.4.239-odroidxu4 #1 SMP PREEMPT Thu Mar 16 15:52:54 UTC 2023 armv7l GNU/Linux
root@odroidxu4:~# cec-client -l
libCEC version: 6.0.2, compiled on Linux-4.19.0-14-armmp-lpae ... , features: P8_USB, DRM, P8_detect, randr, Exynos, Linux, AOCEC
Found devices: 1
device:              1
com port:            Linux
vendor id:           0000
product id:          0000
firmware version:    0
type:                Linux
No device type given. Using 'recording device'
CEC Parser created - libCEC version 6.0.2
no serial port given. trying autodetect:
 path:     /dev/cec0
 com port: Linux
opening a connection to the CEC adapter...
DEBUG:   [             468]     Broadcast (F): osd name set to 'Broadcast'
DEBUG:   [             468]     CLinuxCECAdapterCommunication::Open - m_fd=3 bStartListening=1
DEBUG:   [             468]     CLinuxCECAdapterCommunication::Open - ioctl CEC_ADAP_G_PHYS_ADDR - addr=ffff
WARNING: [             468]     CLinuxCECAdapterCommunication::Open - physical address is invalid
DEBUG:   [             468]     CLinuxCECAdapterCommunication::Open - ioctl CEC_ADAP_S_LOG_ADDRS - log_addr_mask=0000 num_log_addrs=0
DEBUG:   [             468]     CLinuxCECAdapterCommunication::Open - ioctl CEC_ADAP_S_LOG_ADDRS - log_addr_mask=0000 num_log_addrs=1
NOTICE:  [             469]     connection opened
DEBUG:   [             469]     << Broadcast (F) -> TV (0): POLL
TRAFFIC: [             469]     << f0
ERROR:   [             469]     CLinuxCECAdapterCommunication::Write - ioctl CEC_TRANSMIT failed - tx_status=00 errno=64
DEBUG:   [             469]     >> POLL not sent
DEBUG:   [             469]     TV (0): device status changed into 'not present'
DEBUG:   [             469]     registering new CEC client - v6.0.2
DEBUG:   [             469]     SetClientVersion - using client version '6.0.2'
NOTICE:  [             469]     setting HDMI port to 1 on device TV (0)
DEBUG:   [             469]     SetConfiguration: double tap timeout = 200ms, repeat rate = 0ms, release delay = 500ms
DEBUG:   [             469]     detecting logical address for type 'recording device'
DEBUG:   [             469]     trying logical address 'Recorder 1'
DEBUG:   [             469]     << Recorder 1 (1) -> Recorder 1 (1): POLL
DEBUG:   [             469]     CLinuxCECAdapterCommunication::Process - CEC_DQEVENT - CEC_EVENT_STATE_CHANGE - log_addr_mask=0000 phys_addr=ffff
TRAFFIC: [             469]     << 11
ERROR:   [             470]     CLinuxCECAdapterCommunication::Write - ioctl CEC_TRANSMIT failed - tx_status=00 errno=64
TRAFFIC: [             470]     << 11
DEBUG:   [             470]     >> POLL not sent
DEBUG:   [             470]     using logical address 'Recorder 1'
DEBUG:   [             470]     Recorder 1 (1): device status changed into 'handled by libCEC'
DEBUG:   [             470]     Recorder 1 (1): power status changed from 'unknown' to 'on'
DEBUG:   [             470]     Recorder 1 (1): vendor = Pulse Eight (001582)
DEBUG:   [             470]     Recorder 1 (1): CEC version 1.4
DEBUG:   [             470]     AllocateLogicalAddresses - device '0', type 'recording device', LA '1'
DEBUG:   [             470]     CLinuxCECAdapterCommunication::SetLogicalAddresses - ioctl CEC_ADAP_S_LOG_ADDRS - log_addr_mask=0000 num_log_addrs=0
DEBUG:   [             470]     CLinuxCECAdapterCommunication::SetLogicalAddresses - ioctl CEC_ADAP_S_LOG_ADDRS - log_addr_mask=0000 num_log_addrs=1
DEBUG:   [             470]     Recorder 1 (1): osd name set to 'CECTester'
DEBUG:   [             470]     Recorder 1 (1): menu language set to 'eng'
NOTICE:  [             470]     setting HDMI port to 1 on device TV (0)
DEBUG:   [             470]     << Recorder 1 (1) -> TV (0): POLL
TRAFFIC: [             470]     << 10
DEBUG:   [             470]     Recorder 1 (1): physical address changed from ffff to 1000
DEBUG:   [             470]     << Recorder 1 (1) -> broadcast (F): physical address 1000
TRAFFIC: [             470]     << 1f:84:10:00:01
root@odroidxu4:~# lsmod
Module                  Size  Used by
rfkill                 24576  1
cpufreq_powersave      16384  0
cpufreq_userspace      16384  0
cpufreq_conservative    16384  0
zstd                   16384  8
joydev                 20480  0
input_leds             16384  0
exynos_gsc             32768  0
s5p_mfc               135168  0
s5p_jpeg               45056  0
v4l2_mem2mem           20480  2 s5p_jpeg,exynos_gsc
videobuf2_dma_contig    20480  3 s5p_jpeg,s5p_mfc,exynos_gsc
mali_kbase            364544  0
videobuf2_memops       16384  1 videobuf2_dma_contig
videobuf2_v4l2         24576  4 s5p_jpeg,s5p_mfc,exynos_gsc,v4l2_mem2mem
videobuf2_common       40960  5 s5p_jpeg,s5p_mfc,exynos_gsc,v4l2_mem2mem,videobuf2_v4l2
s5p_cec                16384  0
evdev                  24576  4
exynos_gpiomem         16384  0
zram                   28672  2
sunrpc                315392  1
ip_tables              24576  0
ipv6                  462848  42
autofs4                36864  2
usbhid                 49152  0
gpio_keys              20480  0
root@odroidxu4:~# zgrep CEC /proc/config.gz
CONFIG_TABLET_USB_ACECAD=m
CONFIG_CEC_CORE=y
CONFIG_CEC_NOTIFIER=y
CONFIG_MEDIA_CEC_SUPPORT=y
# CONFIG_MEDIA_CEC_RC is not set
# USB HDMI CEC adapters
# CONFIG_USB_PULSE8_CEC is not set
# CONFIG_USB_RAINSHADOW_CEC is not set
# CONFIG_VIDEO_VIVID_CEC is not set
CONFIG_CEC_PLATFORM_DRIVERS=y
# CONFIG_VIDEO_CROS_EC_CEC is not set
# CONFIG_CEC_GPIO is not set
CONFIG_VIDEO_SAMSUNG_S5P_CEC=m
# CONFIG_DRM_DP_CEC is not set
Please help!
Thanks in advance.
Ok, responding to myself lol.
After many days (and nights) of testing, reflashing, up/downgrading, switching kernels/branches, even rolling my own...
....it turns out that whatever I do, kernel 5.4.x just doesn't want to give me CEC.
BUT.
If I run 6.1.y, CEC just works.
It doesn't matter how I get to 6.1 (switching kernels, compiling my own, building from git, any branch, any userspace), it just works.
It doesn't even matter what I have in boot.ini (you know, that option to supposedly turn off CEC, or that pesky HPD).
So I'm at a loss.
If anyone could please find out what's going on here.
What could be the difference between 5.4 and 6.1 with regards to HDMI CEC? I can't figure it out. It bugs me to no end.
Maybe what I described rings a bell for someone.
I'm gonna stop for now and wait for the stable 23.05 with Bookworm, 6.1 and (hopefully!) still working CEC.
tl;dr; difference between generations is usually huge, between private old and mainline new, only bigger.
https://github.com/armbian/build/blob/main/config/sources/families/odroidxu4.conf#L19-L32
5.4.y is private vendor kernel that is getting generic bug-fix patches from mainline
6.1.y is pure mainline
Without code analysis and understanding of related (CEC) mechanisms it is usually hard to tell anything. Its a complex question that could require extensive study on top of general kernel know-how. Theoretical / I didn't look into the code or commits ... it could be more simple answer too.
Probably features names changed. boot.ini is Harkernel proprietary way of setting kernel / hw parameters, tailored for their kernel.
Bookworm "current" will still come with 5.4 so you need to switch to edge 6.1 kernel manually or via armbian-config. We will keep 5.4 at least for next release as dropping it ain't a simple binary decision.
