djdiegodj Posted May 19, 2023 Posted May 19, 2023 I'm using the ps2 emulator and when I try to run a game I get an error message "OpenGL is not supported. Only OpenGL 3.0 was found" I'm using the version "Armbian 23.02 Jammy Gnome" 0 Quote
Doozethe Posted May 26, 2023 Posted May 26, 2023 (edited) I've made a little progress - if you run export PAN_MESA_DEBUG=gl3 prior to launching and switch to the software renderer you can at least launch games, but it'll run poorly. Edited May 26, 2023 by Doozethe 0 Quote
royk Posted May 27, 2023 Posted May 27, 2023 https://github.com/ptitSeb/gl4es/tree/master Should be in the repo of amazingfate sudo apt install libgl4es 0 Quote
Hqnicolas Posted June 29, 2024 Posted June 29, 2024 On 5/27/2023 at 7:49 AM, royk said: Should be in the repo of amazingfate sudo add-apt-repository ppa:liujianfeng1994/panfork-mesa sudo apt update sudo apt install libgl4es 0 Quote
