Hi,
I'm testing a visionfive2 board with 8GB ram and I can only see 4GB in the armbian installed system.
As far as I understand, the official image by StarFive has a extra u-boot partition on SD that tricks something to make the ram fully visible to the system.
In fact I can see 8GB when using the official debian image but only 4 under armbian.
Is there any way to fix this? I'd like to use the armbian environment while using the full ram available. I'm trying to mashup the two partition schemas but I'm probably doing someting wrong... :D
Thank you in advance for any (very appreciated) help!
-psi
