hello, I have mqxpro s905 tx box.
armbian 23.05.0. I installed ffmpeg.
If I try to play a video with ffplay I always get "segmentation fault" .
I never tried any other sw that use graphic.
Maybe I need to setup video?
thanks in advance
@Alcide You are not using Armbian. The location you are downloading from is a fork of armbian. They use the Armbian name without permission. We can't help you in these forums because we don't know what code you are using, you need to direct your questions to the location you downloaded your code from. Those developers do not participate in these forums, nor support armbian development.
I've downloaded image Armbian_23.02.2_Aml-s9xx-box_bullseye_current_6.1.11.img..gz
select dtb and uboot, apt update, apt upgrade, apt install ffmpeg
and ffplay always same issue "segmentatiom fault" when image shoul appear
Tested
Armbian_23.02.2_Aml-s9xx-box_jammy_current_6.1.11.img.gz
and the error is different:
"Failed to create window or renderer: Can't load EGL/GL library on window creation."
Edited by Alcide
