Im stubmeld accros armbian while search for a ARM distribution for my RockPi S.
I started successful with writing it to a SD Card and run it from there.
Now i want to write it to the internal storage and start it from there.
So far so got, everything "worked".
But it stucks in a boot loop.
I attached a Serial/TTL to USB converter and noticed the same output over and over again.
Willkommen zu minicom 2.7.1
Optionen: I18n
Übersetzt am Aug 13 2017, 15:25:34.
Port /dev/ttyUSB0, 15:37:49
Drücken Sie CTRL-A  Z für Hilfe zu speziellen Tasten
DDR Version V2.06 20211109
CHIP ID = 0x00003308
REG2C: 0x00000033, 0x00000034
In
589MHz
DDR3
Col=10 Bank=3 Row=15 Size=512MB
OUT: sdram_init finish.
Boot1 Release Time: Mar 24 2022 08:28:57, version: 1.36
ROM VER:0x56323030, 19
chip_id:330800,0
ChipType = 0x13, 511
DPLL = 1300 MHz
...nandc_flash_init enter...
No.1 FLASH ID:ff ff ff ff ff ff
DPLL = 1300 MHz
sfc nor id: ff ff ff
DPLL = 1300 MHz
sfc_nand id: ff ff ff
NeedKHz=200KHz,clock=12000KHz
mmc2:cmd5,20
DPLL = 1300 MHz
NeedKHz=24000KHz,clock=650000KHz
DPLL = 1300 MHz
NeedKHz=40000KHz,clock=650000KHz
SdmmcInit=2 0
BootCapSize=0
UserCapSize=3696MB
FwPartOffset=2000 , 0
SdmmcInit=0 NOT PRESENT
StorageInit ok = 19304
SecureMode = 0
Secure read PBA: 0x4
Secure read PBA: 0x404
Secure read PBA: 0x804
Secure read PBA: 0xc04
Secure read PBA: 0x1004
SecureInit ret = 0, SecureMode = 0
atags_set_bootdev: ret:(0)
GPT 0x3306530 signature is wrong
recovery gpt...
recovery gpt fail!
LoadTrust Addr:0x4000
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x600000, size=0x994c8
RunBL31 0x40000 @ 96576 us
INFO:    Preloader serial: 0
NOTICE:  BL31: v1.3(release):30f1405
NOTICE:  BL31: Built : 17:08:28, Sep 23 2019
INFO:    Lastlog: last=0x100000, realtime=0x102000, size=0x2000
INFO:    ARM GICv2 driver initialized
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 1
INFO:    plat_rockchip_pmu_init: pd status 0xe b
INFO:    BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x600000
INFO:    SPSR = 0x3c9
U-Boot 2022.04-armbian (May 27 2023 - 19:27:05 +0000)
Model: Radxa ROCK Pi S
DRAM:  510 MiB
Core:  276 devices, 20 uclasses, devicetree: separate
MMC:   dwmmc@ff480000: 1, dwmmc@ff490000: 0
Loading Environment from nowhere... OK
In:    serial
Out:   serial
Err:   serial
rockchip_dnl_key_pressed read board id failed
Net:   eth0: ethernet@ff4e0000
Card did not respond to voltage select! : -110
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
3045 bytes read in 5 ms (594.7 KiB/s)
## Executing script at 00500000
Boot script loaded from mmc 0
176 bytes read in 4 ms (43 KiB/s)
14086333 bytes read in 597 ms (22.5 MiB/s)
29331968 bytes read in 1238 ms (22.6 MiB/s)
54770 bytes read in 10 ms (5.2 MiB/s)
Failed to load '/boot/dtb/rockchip/overlay/rk3308-fixup.scr'
Moving Image from 0x680000 to 0x800000, end=2490000
## Loading init Ramdisk from Legacy Image at 04000000 ...
   Image Name:   uInitrd
   Data Size:    14086269 Bytes = 13.4 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 02800000
   Booting using the fdt blob at 0x2800000
   Loading Ramdisk to 1d1b7000, end 1df2607d ... OK
ERROR: reserving fdt memory region failed (addr=0 size=0 flags=0)
   Loading Device Tree to 000000001d141000, end 000000001d1b6fff ... OK
Starting kernel ...
Loading, please wait...
Starting systemd-udevd version 252.6-1
Begin: Running /scripts/local-premount ... done.
Begin: Will now check root file system ... fsck from util-linux 2.38.1
[/sbin/fsck.ext4 (1) -- /dev/mmcblk0p1] fsck.ext4 -a -C0 /dev/mmcblk0p1
armbi_root: clean, 29764/73296 files, 263864/292864 blocks
done.
done.
Welcome to Armbian 23.05.1 bookworm!
[  OK  ] Created slice system-modpr��…lice - Slice /system/modprobe.
[  OK  ] Created slice system-seria��… - Slice /system/serial-getty.
[  OK  ] Created slice user.slice - User and Session Slice.
[  OK  ] Started systemd-ask-passwo��…quests to Console Directory Watch.
[  OK  ] Started systemd-ask-passwo��… Requests to Wall Directory Watch.
[  OK  ] Set up automount proc-sys-��…rmats File System Automount Point.
[  OK  ] Reached target cryptsetup.��…get - Local Encrypted Volumes.
In
589MHz
DDR3
chip_id:330800,0
ChipType = 0x13, 512
DPLL = 1300 MHz
DPLL = 1300 MHz
DPLL = 1300 MHz
mmc2:cmd5,20
DPLL = 1300 MHz
DPLL = 1300 MHz
SdmmcInit=2 0
BootCapSize=0
UserCapSize=3696MB
StorageInit ok = 19297
SecureMode = 0
recovery gpt...
recovery gpt fail!
No find bl30.bin
No find bl32.bin
RunBL31 0x40000 @ 96630 us
INFO:    SPSR = 0x3c9
DRAM:  510 MiB
In:    serial
Out:   serial
Err:   serial
Scanning mmc 0:1...
176 bytes read in 5 ms (34.2 KiB/s)
   Image Name:   uInitrd
Starting kernel ...
done.
done.
In
589MHz
DDR3
chip_id:330800,0
DPLL = 1300 MHz
DPLL = 1300 MHz
DPLL = 1300 MHz
mmc2:cmd5,20
DPLL = 1300 MHz
DPLL = 1300 MHz
SdmmcInit=2 0
BootCapSize=0
UserCapSize=3696MB
StorageInit ok = 19338
SecureMode = 0
recovery gpt...
recovery gpt fail!
No find bl30.bin
No find bl32.bin
RunBL31 0x40000 @ 96666 us
INFO:    SPSR = 0x3c9
DRAM:  510 MiB
In:    serial
Out:   serial
Err:   serial
Scanning mmc 0:1...
   Image Name:   uInitrd
Starting kernel ...
done.
done.
I followed this tutorials:
- https://www.armbian.com/rockpi-s
- https://wiki.radxa.com/RockpiS/dev/sdnand-install
- https://wiki.radxa.com/RockpiS/dev/serial-console
Unfotunatly some of the links are broken and i need to find the file (rk3308_loader_uart0_m0_emmc_port_support_sd_20190717.bin) via google: https://forum.radxa.com/t/where-can-i-find-the-rk3308-loader-binary/2769
As i found it, i extracted the armbian image (Armbian_23.5.1_Rockpi-s_bookworm_current_6.1.30_minimal.img) and proceeded with the flasing progress.
It worked, but as said, its stucks in a boot loop.
Can any one help me and point out where to start debugging?
Im not very familiar with embedded linux/hardware.
Thanks in advance and for the awesome work!
My recommendation is to use SD card, or stick to smelly factory OS, which supports this.
https://docs.armbian.com/User-Guide_FAQ/#why-does-hardware-feature-xy-work-in-old-kernel-but-not-in-more-recent-one
It is nothing unusual that different internal NAND chips never came to modern software especially also because
50 minutes ago, node.js said:
awesome work
we are trying to maintain this cheap hardware with absolutely no budget. If boot scenarios for this chip is closed source (possible), than things are hard also for those that are very familiar with embedded Linux.
If you are new, it will be hard and will take time. Nobody can do the homework instead ...
https://opensource.rock-chips.com/wiki_Main_Page
https://github.com/armbian/build/blob/main/config/sources/families/include/rockchip64_common.inc
