Hi!
I'm trying to build a cluster of a few Odroid N2+, with Microk8s.
I installed and tested it on the first board that I'm designating as the primary node.
Now I'd like to setup the others, how do I configure the primary board as a gateway for the others?
The primary board has a WiFi connection with internet access, the ethernet connection is then shared with the other boards with a different subnet.
I'm very rusty with linux/ubuntu as I haven't used it in years now.
I followed this guide (https://linuxhint.com/enable_ip_forwarding_ipv4_debian_linux/) and enable the routing on the main board.
Then in the first node I set the gateway and dns to the IP of the primary node, but it is not working.
As example `apt-get update` gives me a few errors like "Could not resolve 'apt.armbian.com'"
