Fresh Install on AML-S905X-CC (Le Potato) with Armbian Jammy Minimal CLI - No armbian-config - Solved
Go to solution Solved by SteeMan,
So, as the title describes, I flashed Armbian Jammy Minimal CLI to a micro SD card and booted my lepotato, and was able to setup a user and update it via apt, set a static IP, but armbian-config is not an available command.
I have a armbianmonitor log uploaded here: https://paste.armbian.com/berejipusu
When I try to run armbian-config, well, which doesn't work, and autocomplete for "armbain" gives me these options:
armbian-add-overlay  armbian-install      armbianmonitor
Any help would be appreciated.  Thank you.
  • Solution
*minimal* is the key there, it really is minimal, you need to install armbianconfig if you want to use it: sudo apt install armbian-config
(Note: since you have installed 23.05, the apt repositories don't yet have the 23.05 packages available (some issues still being addressed) so the apt install may not currently work until that is resolved)
  • TheSmashy changed the title to Fresh Install on AML-S905X-CC (Le Potato) with Armbian Jammy Minimal CLI - No armbian-config - Solved
