I just tried 4. or 5. versions for kvim3l. On start is always same message.
"Gave up waiting for root file system device. Common problems: Boot args (cat /proc/cndline)
Check rootdelay= (did the system wait long enough?) Missing modules (cat /proc/modules: ls /deu)
ALERT! UUID=fb208f7b-bf5e-4f42-a9c1-3c0111c20c?? does not exist. Dropping to a shell! (initramfs)_"
It was supported 23.5 desktop and server. And some old archived versions. Maybe is something with my power source or something. Then i use whoohoho or rescue to go back and install coreelec. When Armbian get in whohoho and automatic instalation..
that will be nice.
  • Solution
@jaffac
Works for me, logs: https://paste.armbian.com/feyuxegepo
 _  ___               _            __     _____ __  __ _____ _
| |/ / |__   __ _  __| | __ _ ___  \ \   / /_ _|  \/  |___ /| |
| ' /| '_ \ / _` |/ _` |/ _` / __|  \ \ / / | || |\/| | |_ \| |
| . \| | | | (_| | (_| | (_| \__ \   \ V /  | || |  | |___) | |___
|_|\_\_| |_|\__,_|\__,_|\__,_|___/    \_/  |___|_|  |_|____/|_____|
Welcome to Armbian 23.05.1 Jammy with Linux 6.1.30-meson64
System load:   40%           	Up time:       2 min	Local users:   2
Memory usage:  31% of 1.90G  	IP:	       10.0.10.236
CPU temp:      59°C           	Usage of /:    38% of 15G
RX today:      35.6 KiB
Installation:
  • Download Khadas Rescue system (flash to SD card, insert, power on, hold FUNCTION and short press RESET button)
  • Download Armbian image and place it to the USB drive (copy .xz or .img file, do not flash with Etcher)
  • Boot into Khadas OOWOW and install to eMMC by selecting image from USB drive
This will soon be simplified as we are going to get into OOWOW.
