I just tried 4. or 5. versions for kvim3l. On start is always same message.
"Gave up waiting for root file system device. Common problems: Boot args (cat /proc/cndline)
Check rootdelay= (did the system wait long enough?) Missing modules (cat /proc/modules: ls /deu)
ALERT! UUID=fb208f7b-bf5e-4f42-a9c1-3c0111c20c?? does not exist. Dropping to a shell! (initramfs)_"
On 6/11/2023 at 2:56 PM, jaffac said:
But on 23.5.1 is almost the same. Goes to shell
That is strange. Can you tell which image exactly you are trying?
It was supported 23.5 desktop and server. And some old archived versions. Maybe is something with my power source or something. Then i use whoohoho or rescue to go back and install coreelec. When Armbian get in whohoho and automatic instalation..
that will be nice.
  • Solution
@jaffac
Works for me, logs: https://paste.armbian.com/feyuxegepo
 _  ___               _            __     _____ __  __ _____ _
| |/ / |__   __ _  __| | __ _ ___  \ \   / /_ _|  \/  |___ /| |
| ' /| '_ \ / _` |/ _` |/ _` / __|  \ \ / / | || |\/| | |_ \| |
| . \| | | | (_| | (_| | (_| \__ \   \ V /  | || |  | |___) | |___
|_|\_\_| |_|\__,_|\__,_|\__,_|___/    \_/  |___|_|  |_|____/|_____|
Welcome to Armbian 23.05.1 Jammy with Linux 6.1.30-meson64
System load:   40%           	Up time:       2 min	Local users:   2
Memory usage:  31% of 1.90G  	IP:	       10.0.10.236
CPU temp:      59°C           	Usage of /:    38% of 15G
RX today:      35.6 KiB
Installation:
  • Download Khadas Rescue system (flash to SD card, insert, power on, hold FUNCTION and short press RESET button)
  • Download Armbian image and place it to the USB drive (copy .xz or .img file, do not flash with Etcher)
  • Boot into Khadas OOWOW and install to eMMC by selecting image from USB drive
This will soon be simplified as we are going to get into OOWOW.
