Igor Posted June 11, 2023 Posted June 11, 2023 2 hours ago, jaffac said: May i ask about support for Khadas vim3l? We support VIM3L, just download page was disabled by mistake. Enabled now https://www.armbian.com/khadas-vim3l/ 1 Quote
jaffac Posted June 11, 2023 Author Posted June 11, 2023 I just tried 4. or 5. versions for kvim3l. On start is always same message. "Gave up waiting for root file system device. Common problems: Boot args (cat /proc/cndline) Check rootdelay= (did the system wait long enough?) Missing modules (cat /proc/modules: ls /deu) ALERT! UUID=fb208f7b-bf5e-4f42-a9c1-3c0111c20c?? does not exist. Dropping to a shell! (initramfs)_" 0 Quote
jaffac Posted June 11, 2023 Author Posted June 11, 2023 But on 23.5.1 is almost the same. Goes to shell (initramfs)_ 0 Quote
Igor Posted June 14, 2023 Posted June 14, 2023 On 6/11/2023 at 2:56 PM, jaffac said: But on 23.5.1 is almost the same. Goes to shell That is strange. Can you tell which image exactly you are trying? 0 Quote
jaffac Posted June 14, 2023 Author Posted June 14, 2023 It was supported 23.5 desktop and server. And some old archived versions. Maybe is something with my power source or something. Then i use whoohoho or rescue to go back and install coreelec. When Armbian get in whohoho and automatic instalation.. that will be nice. 0 Quote
Solution Igor Posted June 14, 2023 Solution Posted June 14, 2023 @jaffac Works for me, logs: https://paste.armbian.com/feyuxegepo _ ___ _ __ _____ __ __ _____ _ | |/ / |__ __ _ __| | __ _ ___ \ \ / /_ _| \/ |___ /| | | ' /| '_ \ / _` |/ _` |/ _` / __| \ \ / / | || |\/| | |_ \| | | . \| | | | (_| | (_| | (_| \__ \ \ V / | || | | |___) | |___ |_|\_\_| |_|\__,_|\__,_|\__,_|___/ \_/ |___|_| |_|____/|_____| Welcome to Armbian 23.05.1 Jammy with Linux 6.1.30-meson64 System load: 40% Up time: 2 min Local users: 2 Memory usage: 31% of 1.90G IP: 10.0.10.236 CPU temp: 59°C Usage of /: 38% of 15G RX today: 35.6 KiB Installation: Download Khadas Rescue system (flash to SD card, insert, power on, hold FUNCTION and short press RESET button) Download Armbian image and place it to the USB drive (copy .xz or .img file, do not flash with Etcher) Boot into Khadas OOWOW and install to eMMC by selecting image from USB drive This will soon be simplified as we are going to get into OOWOW. 0 Quote
