Odroid HC2 suddenly keeps crashing/isn't reachable via ssh etc.. after a while
Go to solution Solved by trohn_javolta,
Hello, my Odroid HC2 was working flawlessly for years but since 1-2 weeks it keeps crashing/freezing and I don't know why.
If I cut power and repower it, it works fine for a while but then trying to reach it via ssh, or accessing the harddrive via smb share, or opening a webinterface fails.
I checked the microsd card with
armbianmonitor -c "$HOME"
and it showed it's fine. I can only provide the logs: https://paste.armbian.com/cibowaquyi and hope someone can check them and reply 🙏.
I don't know what to look for in the logs that could be wrong...
One last thing I noticed, after I ssh to it amongst other things I'm greeted with this: RX today: Error: Unable to read database "/var/lib/vnstat/veth1251466": No such file or directory. I never noticed that all the time before.
Thanks! The issue on my side with the "new" C4.
- Disabled swap, enabled selinux, using Luks.
- Strange enough 2 other "almost identical" board are running for months without a hitch.
- The seller used their stress tests and found no hardware malfunction.
Edited by wow64
