trohn_javolta Posted June 11, 2023 Posted June 11, 2023 Hello, my Odroid HC2 was working flawlessly for years but since 1-2 weeks it keeps crashing/freezing and I don't know why. If I cut power and repower it, it works fine for a while but then trying to reach it via ssh, or accessing the harddrive via smb share, or opening a webinterface fails. I checked the microsd card with armbianmonitor -c "$HOME" and it showed it's fine. I can only provide the logs: https://paste.armbian.com/cibowaquyi and hope someone can check them and reply 🙏. I don't know what to look for in the logs that could be wrong... One last thing I noticed, after I ssh to it amongst other things I'm greeted with this: RX today: Error: Unable to read database "/var/lib/vnstat/veth1251466": No such file or directory. I never noticed that all the time before. 0 Quote
Solution trohn_javolta Posted June 27, 2023 Author Solution Posted June 27, 2023 Found the issue: It was one single docker container that caused the crashes. This can be closed. 0 Quote
wow64 Posted August 14, 2023 Posted August 14, 2023 Hey, you mind sharing which container it was? Experiencing same behavior, but only have stock k8s containers with wireguard. 0 Quote
trohn_javolta Posted August 15, 2023 Author Posted August 15, 2023 On 8/14/2023 at 11:05 PM, wow64 said: Hey, you mind sharing which container it was? Expand I think it was jackett container but in the meantime I ditched my hc2 because armhf support is being ceased. 0 Quote
wow64 Posted August 15, 2023 Posted August 15, 2023 (edited) Thanks! The issue on my side with the "new" C4. - Disabled swap, enabled selinux, using Luks. - Strange enough 2 other "almost identical" board are running for months without a hitch. - The seller used their stress tests and found no hardware malfunction. Edited August 15, 2023 by wow64 0 Quote
