Tanix TX3 Mini (Amlogic S905W) Broadcom WiFi issue
Clonazepunk
Hello guys!
First of all, i couldn't find a topic about the same problem im having, so, if this is a duplicate, just let me know and i'll delete it
So, i just installed Armbian Lunar Edge (Kernel 6.2.9) on my box. The WiFi chip is properly recognized, but the firmware for it won't load
This is the dmesg output
[    8.897269] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    8.898654] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    8.899871] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    8.899910] cfg80211: failed to load regulatory.db
[    8.912366] Adding 988264k swap on /dev/zram0.  Priority:5 extents:1 across:988264k SSFS
[    8.993849] systemd[1]: Listening on systemd-rfkill.socket - Load/Save RF Kill Switch Status /dev/rfkill Watch.
[    9.000207] brcmfmac: F1 signature read @0x18000000=0x16044330
[    9.017810] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4330-sdio for chip BCM4330/4
[    9.019051] usbcore: registered new interface driver brcmfmac
[    9.020401] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4330-sdio.amlogic,p281.bin failed with error -2
[    9.035609] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4330-sdio.clm_blob failed with error -2
Given that the board is recognized, i dont think its a big deal. Still investigating the problem, but until that, can someone give me some tips on how to solve it?
Thanks in advance!
EDIT: I am an advanced user, and intend to give official support for this hardware. A lot of people own similar boxes
Edited by Clonazepunk
Support propose
Link to comment
Share on other sites
Armbian & Khadas are rewarding contributors
Ok, i'm stupid
The firmware for this board is missing.
the file brcmfmac4330-sdio.amlogic,p281.bin simply doesn't exist
Wonder if it works if i borrow it from Android...
EDIT: Found a workaround! I'll leave this thread for other user's further research
cp /usr/lib/firmware/brcm/brcmfmac4330-sdio.bin /usr/lib/firmware/brcm/brcmfmac4330-sdio.amlogic,p281.bin
For some reason, the kernel won't  use the default firmware, and want the specific board version. It works now!
Solution
Link to comment
hi mr.Clonazepunk I want to install arch on my device (rk322x) but I don't able to do. When I was researching for my problem I found your post (
) after that I want guide for how I can do it for my device. so please help me and sorry for my bad english.
Edited by basodo
Link to comment
This forum is for Armbian not arch.  This sub-forum is for amlogic based devices (not rockchip).  Everything about your post is not appropriate.  Please post arch questions in an arch forum.  Don't hijack a post that is completely unrelated to your question.
Link to comment
