Hqnicolas
Quote
What about "Ubuntu 24.04 LTS with Rockchip Linux 6.1" anyone try to launch ubuntu-24.04-preinstalled-desktop-arm64-orangepi-3b.img.xz
I have run this on my box but I'm dissapointed because I get better 1080P youtube with mainline kernel. I think the problem is that this repo is focused in rk3588 with uses mali driver with GBM, and seems that panfrost has not it. I can run 4K video with poor results and that means MPP is enabled (checked with dmesg). I have better video with vendor android.
Don't waste your time, I will do it for you O:)
Posted (edited)
@maka too late I already wasted my time too hahaha :D
Kernel 610:
sudo nano /var/log/dmesg
Quote
[    1.511048] kernel: Booting Linux on physical CPU 0x0000000000 [0x412fd050]
[    1.511094] kernel: Linux version 6.1.43-vendor-rk35xx (armbian@next) (aarch64-linux-gnu-gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1 SMP Wed May 15 03:04:01 UTC 2024
[    1.521423] kernel: Machine model: Rockchip RK3566 H96 MAX Board
[    1.521646] kernel: earlycon: uart8250 at MMIO32 0x00000000fe660000 (options '')
[    1.521673] kernel: printk: bootconsole [uart8250] enabled
[    1.524644] kernel: efi: UEFI not found.
[    1.524912] kernel: OF: fdt: Reserved memory: failed to reserve memory for node 'drm-logo@0': base 0x0000000000000000, size 0 MiB
[    1.524941] kernel: OF: fdt: Reserved memory: failed to reserve memory for node 'drm-cubic-lut@0': base 0x0000000000000000, size 0 MiB
[    1.525099] kernel: Reserved memory: created CMA memory pool at 0x00000001e0000000, size 512 MiB
[    1.525109] kernel: OF: reserved mem: initialized node rknpu, compatible id shared-dma-pool
[    1.738213] kernel: Zone ranges:
[    1.738235] kernel:   DMA      [mem 0x0000000000200000-0x00000000ffffffff]
[    1.738256] kernel:   DMA32    empty
[    1.738266] kernel:   Normal   [mem 0x0000000100000000-0x00000001ffffffff]
[    1.738280] kernel: Movable zone start for each node
[    1.738286] kernel: Early memory node ranges
[    1.738291] kernel:   node   0: [mem 0x0000000000200000-0x00000000efffffff]
[    1.738306] kernel:   node   0: [mem 0x0000000100000000-0x00000001ffffffff]
[    1.738319] kernel: Initmem setup node 0 [mem 0x0000000000200000-0x00000001ffffffff]
[    1.767234] kernel: On node 0, zone DMA: 512 pages in unavailable ranges
[    1.798099] kernel: cma: Reserved 16 MiB at 0x00000000ef000000
[    1.798255] kernel: psci: probing for conduit method from DT.
[    1.798274] kernel: psci: PSCIv1.1 detected in firmware.
[    1.798285] kernel: psci: Using standard PSCI v0.2 function IDs
[    1.798295] kernel: psci: MIGRATE_INFO_TYPE not supported.
[    1.798312] kernel: psci: SMC Calling Convention v1.2
[    1.798776] kernel: percpu: Embedded 29 pages/cpu s79592 r8192 d31000 u118784
[    1.798835] kernel: pcpu-alloc: s79592 r8192 d31000 u118784 alloc=29*4096
[    1.798857] kernel: pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    1.799006] kernel: Detected VIPT I-cache on CPU0
[    1.799090] kernel: CPU features: detected: GIC system register CPU interface
[    1.799100] kernel: CPU features: detected: Virtualization Host Extensions
[    1.799124] kernel: CPU features: detected: Qualcomm erratum 1009, or ARM erratum 1286807, 2441009
[    1.799134] kernel: CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    1.799144] kernel: alternatives: applying boot alternatives
[    1.799748] kernel: Built 1 zonelists, mobility grouping on.  Total pages: 1999368
[    1.799775] kernel: Kernel command line: root=UUID=5da23228-6b5c-446c-8a6f-1510cb7b6787 rootwait rootfstype=ext4 splash plymouth.ignore-serial-consoles console=ttyFIQ0 console=tty1 consoleblank=0 loglevel=1 ubootpart=9b25914f-58db-1647-84b9-7f8229e30d13 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 earlycon=uart8250,mmio32,0xfe660000
[    1.800604] kernel: The swapaccount= commandline option is deprecated. Please report your usecase to linux-mm@kvack.org if you depend on this functionality.
[    1.800689] kernel: Unknown kernel command line parameters "splash ubootpart=9b25914f-58db-1647-84b9-7f8229e30d13 cgroup_enable=memory cgroup_memory=1", will be passed to user space.
[    1.803350] kernel: Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    1.804679] kernel: Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    1.804696] kernel: mem auto-init: stack:off, heap alloc:off, heap free:off
[    1.804708] kernel: software IO TLB: area num 4.
[    1.847408] kernel: software IO TLB: mapped [mem 0x00000000eb000000-0x00000000ef000000] (64MB)
[    1.974415] kernel: Memory: 7307240K/8124416K available (17920K kernel code, 3758K rwdata, 7268K rodata, 7488K init, 697K bss, 276504K reserved, 540672K cma-reserved)
[    1.974672] kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    1.974737] kernel: ftrace: allocating 68397 entries in 268 pages
[    2.158886] kernel: ftrace: allocated 268 pages with 3 groups
[    2.158947] kernel:
[    2.158953] kernel: **********************************************************
[    2.158959] kernel: **   NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE   **
[    2.158965] kernel: **                                                      **
[    2.158970] kernel: ** trace_printk() being used. Allocating extra memory.  **
[    2.158975] kernel: **                                                      **
[    2.158980] kernel: ** This means that this is a DEBUG kernel and it is     **
[    2.158985] kernel: ** unsafe for production use.                           **
[    2.158990] kernel: **                                                      **
[    2.158995] kernel: ** If you see this message and you are not debugging    **
[    2.159000] kernel: ** the kernel, report this immediately to your vendor!  **
[    2.159005] kernel: **                                                      **
[    2.159011] kernel: **   NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE   **
[    2.159016] kernel: **********************************************************
[    2.159877] kernel: trace event string verifier disabled
[    2.160239] kernel: rcu: Hierarchical RCU implementation.
[    2.160250] kernel: rcu:         RCU event tracing is enabled.
[    2.160257] kernel: rcu:         RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    2.160268] kernel:         Rude variant of Tasks RCU enabled.
[    2.160273] kernel:         Tracing variant of Tasks RCU enabled.
[    2.160279] kernel: rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[    2.160288] kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    2.174486] kernel: NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    2.177843] kernel: GICv3: GIC: Using split EOI/Deactivate mode
[    2.177863] kernel: GICv3: 320 SPIs implemented
[    2.177873] kernel: GICv3: 0 Extended SPIs implemented
[    2.177939] kernel: Root IRQ handler: gic_handle_irq
[    2.177968] kernel: GICv3: GICv3 features: 16 PPIs
[    2.178017] kernel: GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000
[    2.178922] kernel: ITS [mem 0xfd440000-0xfd45ffff]
[    2.179048] kernel: ITS@0x00000000fd440000: allocated 8192 Devices @2c10000 (indirect, esz 8, psz 64K, shr 0)
[    2.179119] kernel: ITS@0x00000000fd440000: allocated 32768 Interrupt Collections @2c20000 (flat, esz 2, psz 64K, shr 0)
[    2.179148] kernel: ITS: using cache flushing for cmd queue
[    2.179836] kernel: GICv3: using LPI property table @0x0000000002c30000
[    2.180020] kernel: GIC: using cache flushing for LPI property table
[    2.180036] kernel: GICv3: CPU0: using allocated LPI pending table @0x0000000002c40000
[    2.180146] kernel: rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    2.229144] kernel: arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    2.229185] kernel: clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    2.229205] kernel: sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    2.231463] kernel: Console: colour dummy device 80x25
[    2.231494] kernel: printk: console [tty1] enabled
[    2.231505] kernel: printk: bootconsole [uart8250] disabled
[    2.231562] kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[    2.231583] kernel: pid_max: default: 32768 minimum: 301
[    2.231809] kernel: LSM: Security Framework initializing
[    2.232009] kernel: Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    2.232068] kernel: Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    2.233722] kernel: cacheinfo: Unable to detect cache hierarchy for CPU 0
[    2.235382] kernel: cblist_init_generic: Setting adjustable number of callback queues.
[    2.235396] kernel: cblist_init_generic: Setting shift to 2 and lim to 1.
[    2.235608] kernel: cblist_init_generic: Setting adjustable number of callback queues.
[    2.235620] kernel: cblist_init_generic: Setting shift to 2 and lim to 1.
[    2.236093] kernel: rcu: Hierarchical SRCU implementation.
[    2.236104] kernel: rcu:         Max phase no-delay instances is 1000.
[    2.237557] kernel: Platform MSI: interrupt-controller@fd440000 domain created
[    2.238523] kernel: PCI/MSI: /interrupt-controller@fd400000/interrupt-controller@fd440000 domain created
[    2.239204] kernel: EFI services will not be available.
[    2.239948] kernel: smp: Bringing up secondary CPUs ...
[    2.241855] kernel: Detected VIPT I-cache on CPU1
[    2.242001] kernel: cacheinfo: Unable to detect cache hierarchy for CPU 1
[    2.242023] kernel: GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[    2.242061] kernel: GICv3: CPU1: using allocated LPI pending table @0x0000000002c50000
[    2.242133] kernel: CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[    2.244233] kernel: Detected VIPT I-cache on CPU2
[    2.244368] kernel: cacheinfo: Unable to detect cache hierarchy for CPU 2
[    2.244389] kernel: GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[    2.244426] kernel: GICv3: CPU2: using allocated LPI pending table @0x0000000002c60000
[    2.244483] kernel: CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[    2.246570] kernel: Detected VIPT I-cache on CPU3
[    2.246707] kernel: cacheinfo: Unable to detect cache hierarchy for CPU 3
[    2.246729] kernel: GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000
[    2.246765] kernel: GICv3: CPU3: using allocated LPI pending table @0x0000000002c70000
[    2.246822] kernel: CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[    2.247017] kernel: smp: Brought up 1 node, 4 CPUs
[    2.247051] kernel: SMP: Total of 4 processors activated.
[    2.247062] kernel: CPU features: detected: 32-bit EL0 Support
[    2.247068] kernel: CPU features: detected: 32-bit EL1 Support
[    2.247078] kernel: CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    2.247085] kernel: CPU features: detected: Common not Private translations
[    2.247092] kernel: CPU features: detected: CRC32 instructions
[    2.247102] kernel: CPU features: detected: RCpc load-acquire (LDAPR)
[    2.247110] kernel: CPU features: detected: Privileged Access Never
[    2.247116] kernel: CPU features: detected: RAS Extension Support
[    2.247127] kernel: CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    2.247262] kernel: CPU: All CPU(s) started at EL2
[    2.247272] kernel: alternatives: applying system-wide alternatives
[    2.251633] kernel: devtmpfs: initialized
[    2.304656] kernel: Registered cp15_barrier emulation handler
[    2.304691] kernel: Registered setend emulation handler
[    2.305021] kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    2.305060] kernel: futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    2.322182] kernel: pinctrl core: initialized pinctrl subsystem
[    2.322791] kernel: regulator-dummy: no parameters, enabled
[    2.323304] kernel: DMI not present or invalid.
[    2.324323] kernel: NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    2.326819] kernel: DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[    2.327463] kernel: DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    2.328057] kernel: DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    2.328198] kernel: audit: initializing netlink subsys (disabled)
[    2.328524] kernel: audit: type=2000 audit(0.096:1): state=initialized audit_enabled=0 res=1
[    2.333762] kernel: Registered FIQ tty driver
[    2.334544] kernel: thermal_sys: Registered thermal governor 'fair_share'
[    2.334558] kernel: thermal_sys: Registered thermal governor 'step_wise'
[    2.334567] kernel: thermal_sys: Registered thermal governor 'user_space'
[    2.334575] kernel: thermal_sys: Registered thermal governor 'power_allocator'
[    2.334712] kernel: cpuidle: using governor menu
[    2.335631] kernel: hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    2.335918] kernel: ASID allocator initialised with 65536 entries
[    2.340023] kernel: ramoops: dmesg-0        0x20000@0x0000000000110000
[    2.340097] kernel: ramoops: console        0x80000@0x0000000000130000
[    2.340133] kernel: ramoops: pmsg        0x50000@0x00000000001b0000
[    2.340386] kernel: printk: console [ramoops-1] enabled
[    2.340400] kernel: pstore: Registered ramoops as persistent store backend
[    2.340410] kernel: ramoops: using 0xf0000@0x110000, ecc: 0
[    2.371046] kernel: platform fe040000.vop: Fixed dependency cycle(s) with /hdmi@fe0a0000
[    2.410953] kernel: rockchip-gpio fdd60000.gpio: probed /pinctrl/gpio@fdd60000
[    2.411946] kernel: rockchip-gpio fe740000.gpio: probed /pinctrl/gpio@fe740000
[    2.412891] kernel: rockchip-gpio fe750000.gpio: probed /pinctrl/gpio@fe750000
[    2.413821] kernel: rockchip-gpio fe760000.gpio: probed /pinctrl/gpio@fe760000
[    2.414727] kernel: rockchip-gpio fe770000.gpio: probed /pinctrl/gpio@fe770000
[    2.414963] kernel: rockchip-pinctrl pinctrl: probed pinctrl
[    2.427618] kernel: KASLR disabled due to lack of seed
[    2.451236] kernel: HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    2.451262] kernel: HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    2.451275] kernel: HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    2.451283] kernel: HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    2.451293] kernel: HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    2.451302] kernel: HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    2.451313] kernel: HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    2.451321] kernel: HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    2.507398] kernel: raid6: neonx8   gen()  1363 MB/s
[    2.564301] kernel: raid6: neonx4   gen()  1407 MB/s
[    2.621170] kernel: raid6: neonx2   gen()  1287 MB/s
[    2.678033] kernel: raid6: neonx1   gen()  1052 MB/s
[    2.734974] kernel: raid6: int64x8  gen()   350 MB/s
[    2.791815] kernel: raid6: int64x4  gen()   440 MB/s
[    2.848675] kernel: raid6: int64x2  gen()   909 MB/s
[    2.905550] kernel: raid6: int64x1  gen()   633 MB/s
[    2.905565] kernel: raid6: using algorithm neonx4 gen() 1407 MB/s
[    2.962414] kernel: raid6: .... xor() 1055 MB/s, rmw enabled
[    2.962429] kernel: raid6: using neon recovery algorithm
[    2.964653] kernel: fiq_debugger fiq_debugger.0: error -ENXIO: IRQ fiq not found
[    2.964698] kernel: fiq_debugger fiq_debugger.0: error -ENXIO: IRQ wakeup not found
[    2.964721] kernel: fiq_debugger_probe: could not install nmi irq handler
[    2.965160] kernel: printk: console [ttyFIQ0] enabled
[    2.965608] kernel: Registered fiq debugger ttyFIQ0
[    2.966460] kernel: dc_12v: 12000 mV, enabled
[    2.966765] kernel: reg-fixed-voltage dc-12v: dc_12v supplying 12000000uV
[    2.966997] kernel: reg-fixed-voltage vcc3v3-sys: Looking up vin-supply from device tree
[    2.967026] kernel: vcc3v3_sys: supplied by dc_12v
[    2.967046] kernel: dc_12v: could not add device link regulator.2: -ENOENT
[    2.967130] kernel: vcc3v3_sys: 3300 mV, enabled
[    2.967422] kernel: reg-fixed-voltage vcc3v3-sys: vcc3v3_sys supplying 3300000uV
[    2.967671] kernel: reg-fixed-voltage vcc5v0-sys: Looking up vin-supply from device tree
[    2.967725] kernel: vcc5v0_sys: supplied by dc_12v
[    2.967744] kernel: dc_12v: could not add device link regulator.3: -ENOENT
[    2.967813] kernel: vcc5v0_sys: 5000 mV, enabled
[    2.968094] kernel: reg-fixed-voltage vcc5v0-sys: vcc5v0_sys supplying 5000000uV
[    2.968606] kernel: vcc5v0_host: no parameters, enabled
[    2.968907] kernel: reg-fixed-voltage vcc5v0-host-regulator: vcc5v0_host supplying 0uV
[    2.969159] kernel: vcc3v3_lcd0_n: no parameters, enabled
[    2.969435] kernel: reg-fixed-voltage vcc3v3-lcd0-n: vcc3v3_lcd0_n supplying 0uV
[    2.969665] kernel: vcc3v3_lcd1_n: no parameters, enabled
[    2.969948] kernel: reg-fixed-voltage vcc3v3-lcd1-n: vcc3v3_lcd1_n supplying 0uV
[    2.970173] kernel: reg-fixed-voltage vcc2v5-ddr: Looking up vin-supply from device tree
[    2.970201] kernel: vcc2v5-sys: supplied by vcc3v3_sys
[    2.970227] kernel: vcc3v3_sys: could not add device link regulator.7: -ENOENT
[    2.970307] kernel: vcc2v5-sys: 2500 mV, enabled
[    2.970559] kernel: reg-fixed-voltage vcc2v5-ddr: vcc2v5-sys supplying 2500000uV
[    2.970814] kernel: reg-fixed-voltage vcc3v3-vga: Looking up vin-supply from device tree
[    2.970842] kernel: vcc3v3_vga: supplied by vcc3v3_sys
[    2.970860] kernel: vcc3v3_sys: could not add device link regulator.8: -ENOENT
[    2.970934] kernel: vcc3v3_vga: at 3300 mV, enabled
[    2.971282] kernel: reg-fixed-voltage vcc3v3-vga: vcc3v3_vga supplying 0uV
[    2.971502] kernel: reg-fixed-voltage pcie30-avdd0v9: Looking up vin-supply from device tree
[    2.971530] kernel: pcie30_avdd0v9: supplied by vcc3v3_sys
[    2.971556] kernel: vcc3v3_sys: could not add device link regulator.9: -ENOENT
[    2.971625] kernel: pcie30_avdd0v9: 900 mV, enabled
[    2.971905] kernel: reg-fixed-voltage pcie30-avdd0v9: pcie30_avdd0v9 supplying 900000uV
[    2.972124] kernel: reg-fixed-voltage pcie30-avdd1v8: Looking up vin-supply from device tree
[    2.972150] kernel: pcie30_avdd1v8: supplied by vcc3v3_sys
[    2.972168] kernel: vcc3v3_sys: could not add device link regulator.10: -ENOENT
[    2.972262] kernel: pcie30_avdd1v8: 1800 mV, enabled
[    2.972540] kernel: reg-fixed-voltage pcie30-avdd1v8: pcie30_avdd1v8 supplying 1800000uV
[    2.972764] kernel: reg-fixed-voltage vcc3v3-bu: Looking up vin-supply from device tree
[    2.972792] kernel: vcc3v3_bu: supplied by vcc5v0_sys
[    2.972818] kernel: vcc5v0_sys: could not add device link regulator.11: -ENOENT
[    2.972889] kernel: vcc3v3_bu: 3300 mV, enabled
[    2.973186] kernel: reg-fixed-voltage vcc3v3-bu: vcc3v3_bu supplying 3300000uV
[    2.973946] kernel: pcie30_3v3: 100 <--> 3300 mV at 3300 mV, enabled
[    2.975047] kernel: iommu: Default domain type: Translated
[    2.975065] kernel: iommu: DMA domain TLB invalidation policy: strict mode
[    2.975699] kernel: SCSI subsystem initialized
[    2.975776] kernel: libata version 3.00 loaded.
[    2.976093] kernel: usbcore: registered new interface driver usbfs
[    2.976185] kernel: usbcore: registered new interface driver hub
[    2.976250] kernel: usbcore: registered new device driver usb
[    2.976511] kernel: mc: Linux media interface: v0.10
[    2.976596] kernel: videodev: Linux video capture interface: v2.00
[    2.976743] kernel: pps_core: LinuxPPS API ver. 1 registered
[    2.976757] kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    2.976795] kernel: PTP clock support registered
[    2.977845] kernel: arm-scmi firmware:scmi: Enabled polling mode TX channel - prot_id:16
[    2.978094] kernel: arm-scmi firmware:scmi: SCMI Notifications - Core Enabled.
[    2.978181] kernel: arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0
[    2.979508] kernel: Advanced Linux Sound Architecture Driver Initialized.
[    2.980613] kernel: Bluetooth: Core ver 2.22
[    2.980699] kernel: NET: Registered PF_BLUETOOTH protocol family
[    2.980713] kernel: Bluetooth: HCI device and connection manager initialized
[    2.980732] kernel: Bluetooth: HCI socket layer initialized
[    2.980747] kernel: Bluetooth: L2CAP socket layer initialized
[    2.980787] kernel: Bluetooth: SCO socket layer initialized
[    2.980929] kernel: NetLabel: Initializing
[    2.980940] kernel: NetLabel:  domain hash size = 128
[    2.980951] kernel: NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    2.981062] kernel: NetLabel:  unlabeled traffic allowed by default
[    2.981737] kernel: vgaarb: loaded
[    3.616195] kernel: clocksource: Switched to clocksource arch_sys_counter
[    3.616864] kernel: VFS: Disk quotas dquot_6.6.0
[    3.616943] kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    3.635346] kernel: NET: Registered PF_INET protocol family
[    3.635918] kernel: IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    3.645871] kernel: tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[    3.645984] kernel: Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    3.646125] kernel: TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    3.646704] kernel: TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[    3.648865] kernel: TCP: Hash tables configured (established 65536 bind 65536)
[    3.649365] kernel: MPTCP token hash table entries: 8192 (order: 5, 196608 bytes, linear)
[    3.649762] kernel: UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    3.649931] kernel: UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    3.650378] kernel: NET: Registered PF_UNIX/PF_LOCAL protocol family
[    3.651363] kernel: RPC: Registered named UNIX socket transport module.
[    3.651383] kernel: RPC: Registered udp transport module.
[    3.651391] kernel: RPC: Registered tcp transport module.
[    3.651400] kernel: RPC: Registered tcp NFSv4.1 backchannel transport module.
[    3.653243] kernel: PCI: CLS 0 bytes, default 64
[    3.654254] kernel: Trying to unpack rootfs image as initramfs...
[    3.661272] kernel: hw perfevents: enabled with armv8_cortex_a55 PMU driver, 7 counters available
[    3.663026] kernel: kvm [1]: IPA Size Limit: 40 bits
[    3.663086] kernel: kvm [1]: GICv3: no GICV resource entry
[    3.663099] kernel: kvm [1]: disabling GICv2 emulation
[    3.663110] kernel: kvm [1]: GIC system register CPU interface enabled
[    3.664102] kernel: kvm [1]: vgic interrupt IRQ9
[    3.664464] kernel: kvm [1]: VHE mode initialized successfully
[    3.715154] kernel: Initialise system trusted keyrings
[    3.715641] kernel: workingset: timestamp_bits=46 max_order=21 bucket_order=0
[    3.728883] kernel: NFS: Registering the id_resolver key type
[    3.728964] kernel: Key type id_resolver registered
[    3.728978] kernel: Key type id_legacy registered
[    3.729130] kernel: nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    3.729147] kernel: nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    3.783304] kernel: NET: Registered PF_ALG protocol family
[    3.783349] kernel: xor: measuring software checksum speed
[    3.789707] kernel:    8regs           :  1554 MB/sec
[    3.794904] kernel:    32regs          :  1911 MB/sec
[    3.801042] kernel:    arm64_neon      :  1619 MB/sec
[    3.801066] kernel: xor: using function: 32regs (1911 MB/sec)
[    3.801105] kernel: Key type asymmetric registered
[    3.801120] kernel: Asymmetric key parser 'x509' registered
[    3.801270] kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[    3.801657] kernel: io scheduler mq-deadline registered
[    3.801675] kernel: io scheduler kyber registered
[    3.805051] kernel: rockchip-csi2-dphy-hw fe870000.csi2-dphy-hw: csi2 dphy hw probe successfully!
[    3.809554] kernel: phy phy-fe8a0000.usb2-phy.0: Looking up phy-supply from device tree
[    3.809948] kernel: vcc5v0_host: could not add device link phy-fe8a0000.usb2-phy.0: -ENOENT
[    3.810312] kernel: phy phy-fe8a0000.usb2-phy.1: Looking up phy-supply from device tree
[    3.810346] kernel: vcc5v0_host: could not add device link phy-fe8a0000.usb2-phy.1: -ENOENT
[    3.810627] kernel: phy phy-fe8a0000.usb2-phy.1: Looking up vbus-supply from device tree
[    3.810650] kernel: phy phy-fe8a0000.usb2-phy.1: Looking up vbus-supply property in node /usb2-phy@fe8a0000/otg-port failed
[    3.815043] kernel: phy phy-fe830000.phy.2: Looking up phy-supply from device tree
[    3.815080] kernel: phy phy-fe830000.phy.2: Looking up phy-supply property in node /phy@fe830000 failed
[    3.815857] kernel: phy phy-fe840000.phy.3: Looking up phy-supply from device tree
[    3.815883] kernel: phy phy-fe840000.phy.3: Looking up phy-supply property in node /phy@fe840000 failed
[    3.823847] kernel: iep: Module initialized.
[    3.824004] kernel: mpp_service mpp-srv: 6849c1e28b7b author: Ding Wei 2023-12-28 video: rockchip: mpp: px30: fix issue combo_init when device probe
[    3.824026] kernel: mpp_service mpp-srv: probe start
[    3.830908] kernel: mpp_service mpp-srv: probe success
[    3.839870] kernel: dma-pl330 fe530000.dma-controller: Loaded driver for PL330 DMAC-241330
[    3.839907] kernel: dma-pl330 fe530000.dma-controller:         DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    3.844012] kernel: dma-pl330 fe550000.dma-controller: Loaded driver for PL330 DMAC-241330
[    3.844045] kernel: dma-pl330 fe550000.dma-controller:         DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    3.844763] kernel: rockchip-pvtm fde00000.pvtm: failed to retrieve pvtm_tz
[    3.844843] kernel: rockchip-pvtm fde00000.pvtm: pvtm@0 probed
[    3.845060] kernel: rockchip-pvtm fde80000.pvtm: failed to retrieve pvtm_tz
[    3.845123] kernel: rockchip-pvtm fde80000.pvtm: pvtm@1 probed
[    3.845288] kernel: rockchip-pvtm fde90000.pvtm: failed to retrieve pvtm_tz
[    3.845357] kernel: rockchip-pvtm fde90000.pvtm: pvtm@2 probed
[    3.847033] kernel: rockchip-system-monitor rockchip-system-monitor: system monitor probe
[    3.848299] kernel: arm-scmi firmware:scmi: Failed. SCMI protocol 22 not active.
[    3.848802] kernel: Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[    3.850438] kernel: fe650000.serial: ttyS1 at MMIO 0xfe650000 (irq = 31, base_baud = 1500000) is a 16550A
[    3.854870] kernel: led_vk2c21_init
[    3.855041] kernel: random: crng init done
[    3.856739] kernel: rockchip-pm-domain fdd90000.power-management:power-controller: Looking up vpu-supply from device tree
[    3.856789] kernel: rockchip-pm-domain fdd90000.power-management:power-controller: Looking up vpu-supply property in node /power-management@fdd90000/power-controller failed
[    3.857853] kernel: rockchip-pm-domain fdd90000.power-management:power-controller: Looking up rga-supply from device tree
[    3.857895] kernel: rockchip-pm-domain fdd90000.power-management:power-controller: Looking up rga-supply property in node /power-management@fdd90000/power-controller failed
[    3.861122] kernel: rockchip-pm-domain fdd90000.power-management:power-controller: Looking up rkvenc-supply from device tree
[    3.861177] kernel: rockchip-pm-domain fdd90000.power-management:power-controller: Looking up rkvenc-supply property in node /power-management@fdd90000/power-controller failed
[    3.862236] kernel: rockchip-pm-domain fdd90000.power-management:power-controller: Looking up rkvdec-supply from device tree
[    3.862280] kernel: rockchip-pm-domain fdd90000.power-management:power-controller: Looking up rkvdec-supply property in node /power-management@fdd90000/power-controller failed
[    3.863368] kernel: rockchip-pm-domain fdd90000.power-management:power-controller: Looking up vi-supply from device tree
[    3.863415] kernel: rockchip-pm-domain fdd90000.power-management:power-controller: Looking up vi-supply property in node /power-management@fdd90000/power-controller failed
[    3.882091] kernel: cacheinfo: Unable to detect cache hierarchy for CPU 0
[    3.883780] kernel: brd: module loaded
[    3.893709] kernel: loop: module loaded
[    3.894412] kernel: rbd: loaded (major 254)
[    3.894912] kernel: lkdtm: No crash points registered, enable through debugfs
[    3.898472] kernel: SPI driver spidev has no spi_device_id for rockchip,spidev
[    3.902526] kernel: spi-nor spi4.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff
[    3.907329] kernel: rk_gmac-dwmac fe010000.ethernet: IRQ eth_lpi not found
[    3.907742] kernel: rk_gmac-dwmac fe010000.ethernet: Looking up phy-supply from device tree
[    3.907775] kernel: rk_gmac-dwmac fe010000.ethernet: Looking up phy-supply property in node /ethernet@fe010000 failed
[    3.907828] kernel: rk_gmac-dwmac fe010000.ethernet: supply phy not found, using dummy regulator
[    3.908065] kernel: rk_gmac-dwmac fe010000.ethernet: clock input or output? (input).
[    3.908086] kernel: rk_gmac-dwmac fe010000.ethernet: TX delay(0x30).
[    3.908102] kernel: rk_gmac-dwmac fe010000.ethernet: RX delay(0x10).
[    3.908138] kernel: rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no).
[    3.908217] kernel: rk_gmac-dwmac fe010000.ethernet: clock input from PHY
[    3.908507] kernel: rk_gmac-dwmac fe010000.ethernet: init for RGMII
[    3.908899] kernel: rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[    3.908928] kernel: rk_gmac-dwmac fe010000.ethernet:         DWMAC4/5
[    3.908944] kernel: rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported
[    3.908956] kernel: rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported
[    3.908967] kernel: rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported
[    3.908978] kernel: rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported
[    3.909102] kernel: rk_gmac-dwmac fe010000.ethernet: TSO supported
[    3.909118] kernel: rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    3.909134] kernel: rk_gmac-dwmac fe010000.ethernet: Enabled RFS Flow TC (entries=10)
[    3.909150] kernel: rk_gmac-dwmac fe010000.ethernet: TSO feature enabled
[    3.909163] kernel: rk_gmac-dwmac fe010000.ethernet: Using 32/32 bits DMA host/device width
[    4.634336] kernel: Freeing initrd memory: 16156K
[    4.655718] kernel: usbcore: registered new interface driver rndis_wlan
[    4.655809] kernel: usbcore: registered new interface driver asix
[    4.655881] kernel: usbcore: registered new interface driver cdc_ether
[    4.655951] kernel: usbcore: registered new interface driver rndis_host
[    4.656055] kernel: usbcore: registered new interface driver cdc_ncm
[    4.656482] kernel: VFIO - User Level meta-driver version: 0.3
[    4.671661] kernel: xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    4.671718] kernel: xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    4.671928] kernel: xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000022010010
[    4.672026] kernel: xhci-hcd xhci-hcd.0.auto: irq 44, io mem 0xfcc00000
[    4.672266] kernel: xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    4.672296] kernel: xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[    4.672327] kernel: xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[    4.672744] kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[    4.672769] kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.672786] kernel: usb usb1: Product: xHCI Host Controller
[    4.672799] kernel: usb usb1: Manufacturer: Linux 6.1.43-vendor-rk35xx xhci-hcd
[    4.672812] kernel: usb usb1: SerialNumber: xhci-hcd.0.auto
[    4.673775] kernel: hub 1-0:1.0: USB hub found
[    4.673857] kernel: hub 1-0:1.0: 1 port detected
[    4.674671] kernel: usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    4.674968] kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[    4.674993] kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.675012] kernel: usb usb2: Product: xHCI Host Controller
[    4.675025] kernel: usb usb2: Manufacturer: Linux 6.1.43-vendor-rk35xx xhci-hcd
[    4.675038] kernel: usb usb2: SerialNumber: xhci-hcd.0.auto
[    4.675853] kernel: hub 2-0:1.0: USB hub found
[    4.675941] kernel: hub 2-0:1.0: 1 port detected
[    4.676939] kernel: xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    4.676981] kernel: xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 3
[    4.677183] kernel: xhci-hcd xhci-hcd.1.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000800002010010
[    4.677290] kernel: xhci-hcd xhci-hcd.1.auto: irq 45, io mem 0xfd000000
[    4.677537] kernel: xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    4.677566] kernel: xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 4
[    4.677594] kernel: xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[    4.677969] kernel: usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[    4.677992] kernel: usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.678009] kernel: usb usb3: Product: xHCI Host Controller
[    4.678022] kernel: usb usb3: Manufacturer: Linux 6.1.43-vendor-rk35xx xhci-hcd
[    4.678035] kernel: usb usb3: SerialNumber: xhci-hcd.1.auto
[    4.678847] kernel: hub 3-0:1.0: USB hub found
[    4.678930] kernel: hub 3-0:1.0: 1 port detected
[    4.679753] kernel: usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    4.680048] kernel: usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[    4.680073] kernel: usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.680089] kernel: usb usb4: Product: xHCI Host Controller
[    4.680101] kernel: usb usb4: Manufacturer: Linux 6.1.43-vendor-rk35xx xhci-hcd
[    4.680114] kernel: usb usb4: SerialNumber: xhci-hcd.1.auto
[    4.680949] kernel: hub 4-0:1.0: USB hub found
[    4.681027] kernel: hub 4-0:1.0: 1 port detected
[    4.681896] kernel: usbcore: registered new interface driver cdc_acm
[    4.681913] kernel: cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    4.682378] kernel: usbcore: registered new interface driver uas
[    4.682555] kernel: usbcore: registered new interface driver usb-storage
[    4.683557] kernel: mousedev: PS/2 mouse device common for all mice
[    4.684310] kernel: .. rk pwm remotectl v2.0 init
[    4.684761] kernel: input: fe6e0030.pwm as /devices/platform/fe6e0030.pwm/input/input0
[    4.685316] kernel: remotectl-pwm fe6e0030.pwm: pwm version is 0x2130000
[    4.685347] kernel: remotectl-pwm fe6e0030.pwm: error -ENXIO: IRQ index 1 not found
[    4.685365] kernel: remotectl-pwm fe6e0030.pwm: cannot find PWR IRQ
[    4.685378] kernel: remotectl-pwm fe6e0030.pwm: pwm sip wakeup config error!!
[    4.685390] kernel: remotectl-pwm fe6e0030.pwm: Donot support ATF Wakeup
[    4.685704] kernel: .. rk pwm remotectl v2.0 init
[    4.686110] kernel: input: fe700030.pwm as /devices/platform/fe700030.pwm/input/input1
[    4.686692] kernel: remotectl-pwm fe700030.pwm: pwm version is 0x2130000
[    4.686835] kernel: remotectl-pwm fe700030.pwm: Controller support pwrkey capture
[    4.687824] kernel: i2c_dev: i2c /dev entries driver
[    4.690945] kernel: fan53555-regulator 0-001c: FAN53555 Option[12] Rev[15] Detected!
[    4.690997] kernel: fan53555-regulator 0-001c: Looking up vin-supply from device tree
[    4.691031] kernel: vdd_cpu: supplied by vcc5v0_sys
[    4.691050] kernel: vcc5v0_sys: could not add device link regulator.13: -ENOENT
[    4.691619] kernel: vdd_cpu: override max_uV, 1390000 -> 1387500
[    4.694450] kernel: vdd_cpu: 712 <--> 1387 mV at 900 mV, enabled
[    4.699324] kernel: rk808 0-0020: chip id: 0x8090
[    4.699406] kernel: rk808 0-0020: No cache defaults, reading back from HW
[    4.723219] kernel: rk808 0-0020: source: on=0x40, off=0x00
[    4.723247] kernel: rk808 0-0020: support dcdc3 fb mode:-22, 1
[    4.723266] kernel: rk808 0-0020: support pmic reset mode:0,0
[    4.736122] kernel: rk808-regulator rk808-regulator: there is no dvs0 gpio
[    4.736262] kernel: rk808-regulator rk808-regulator: there is no dvs1 gpio
[    4.736367] kernel: rk808 0-0020: Looking up vcc1-supply from device tree
[    4.736402] kernel: vdd_logic: supplied by vcc3v3_sys
[    4.736421] kernel: vcc3v3_sys: could not add device link regulator.14: -ENOENT
[    4.736982] kernel: vdd_logic: 500 <--> 1350 mV at 900 mV, enabled
[    4.737462] kernel: rk808 0-0020: Looking up vcc2-supply from device tree
[    4.737492] kernel: vdd_gpu: supplied by vcc3v3_sys
[    4.737511] kernel: vcc3v3_sys: could not add device link regulator.15: -ENOENT
[    4.737978] kernel: vdd_gpu: 500 <--> 1350 mV at 900 mV, enabled
[    4.738425] kernel: rk808 0-0020: Looking up vcc3-supply from device tree
[    4.738453] kernel: vcc_ddr: supplied by vcc3v3_sys
[    4.738472] kernel: vcc3v3_sys: could not add device link regulator.16: -ENOENT
[    4.738922] kernel: vcc_ddr: at 500 mV, enabled
[    4.739373] kernel: rk808 0-0020: Looking up vcc4-supply from device tree
[    4.739401] kernel: vdd_npu: supplied by vcc3v3_sys
[    4.739418] kernel: vcc3v3_sys: could not add device link regulator.17: -ENOENT
[    4.739934] kernel: vdd_npu: 500 <--> 1350 mV at 900 mV, enabled
[    4.740380] kernel: rk808 0-0020: Looking up vcc9-supply from device tree
[    4.740409] kernel: vcc_1v8: supplied by vcc3v3_sys
[    4.740435] kernel: vcc3v3_sys: could not add device link regulator.18: -ENOENT
[    4.740890] kernel: vcc_1v8: 1800 mV, enabled
[    4.741287] kernel: rk808 0-0020: Looking up vcc5-supply from device tree
[    4.741314] kernel: vdda0v9_image: supplied by vcc3v3_sys
[    4.741332] kernel: vcc3v3_sys: could not add device link regulator.19: -ENOENT
[    4.742326] kernel: vdda0v9_image: 900 mV, enabled
[    4.742743] kernel: rk808 0-0020: Looking up vcc5-supply from device tree
[    4.742771] kernel: vdda_0v9: supplied by vcc3v3_sys
[    4.742789] kernel: vcc3v3_sys: could not add device link regulator.20: -ENOENT
[    4.743841] kernel: vdda_0v9: 900 mV, enabled
[    4.744258] kernel: rk808 0-0020: Looking up vcc5-supply from device tree
[    4.744287] kernel: vdda0v9_pmu: supplied by vcc3v3_sys
[    4.744304] kernel: vcc3v3_sys: could not add device link regulator.21: -ENOENT
[    4.745304] kernel: vdda0v9_pmu: 900 mV, enabled
[    4.745694] kernel: rk808 0-0020: Looking up vcc6-supply from device tree
[    4.745721] kernel: vccio_acodec: supplied by vcc3v3_sys
[    4.745739] kernel: vcc3v3_sys: could not add device link regulator.22: -ENOENT
[    4.746764] kernel: vccio_acodec: 3300 mV, enabled
[    4.747206] kernel: rk808 0-0020: Looking up vcc6-supply from device tree
[    4.747234] kernel: vccio_sd: supplied by vcc3v3_sys
[    4.747260] kernel: vcc3v3_sys: could not add device link regulator.23: -ENOENT
[    4.748254] kernel: vccio_sd: 1800 <--> 3300 mV at 3300 mV, enabled
[    4.748707] kernel: rk808 0-0020: Looking up vcc6-supply from device tree
[    4.748735] kernel: vcc3v3_pmu: supplied by vcc3v3_sys
[    4.748755] kernel: vcc3v3_sys: could not add device link regulator.24: -ENOENT
[    4.749752] kernel: vcc3v3_pmu: 3300 mV, enabled
[    4.750167] kernel: rk808 0-0020: Looking up vcc7-supply from device tree
[    4.750196] kernel: vcca_1v8: supplied by vcc3v3_sys
[    4.750214] kernel: vcc3v3_sys: could not add device link regulator.25: -ENOENT
[    4.751224] kernel: vcca_1v8: 1800 mV, enabled
[    4.751641] kernel: rk808 0-0020: Looking up vcc7-supply from device tree
[    4.751669] kernel: vcca1v8_pmu: supplied by vcc3v3_sys
[    4.751689] kernel: vcc3v3_sys: could not add device link regulator.26: -ENOENT
[    4.752677] kernel: vcca1v8_pmu: 1800 mV, enabled
[    4.753158] kernel: rk808 0-0020: Looking up vcc7-supply from device tree
[    4.753186] kernel: vcca1v8_image: supplied by vcc3v3_sys
[    4.753206] kernel: vcc3v3_sys: could not add device link regulator.27: -ENOENT
[    4.754201] kernel: vcca1v8_image: 1800 mV, enabled
[    4.754609] kernel: rk808 0-0020: Looking up vcc9-supply from device tree
[    4.754637] kernel: vcc_3v3: supplied by vcc3v3_sys
[    4.754655] kernel: vcc3v3_sys: could not add device link regulator.28: -ENOENT
[    4.755137] kernel: vcc_3v3: at 3300 mV, enabled
[    4.755514] kernel: rk808 0-0020: Looking up vcc8-supply from device tree
[    4.755543] kernel: vcc3v3_sd: supplied by vcc3v3_sys
[    4.755560] kernel: vcc3v3_sys: could not add device link regulator.29: -ENOENT
[    4.756008] kernel: vcc3v3_sd: at 3300 mV, enabled
[    4.756451] kernel: rk817-battery: Failed to locate of_node [id: -1]
[    4.756676] kernel: rk817-battery rk817-battery: Failed to find matching dt id
[    4.756859] kernel: rk817-charger: Failed to locate of_node [id: -1]
[    4.757044] kernel: rk817-charger rk817-charger: Failed to find matching dt id
[    4.760658] kernel: input: rk805 pwrkey as /devices/platform/fdd40000.i2c/i2c-0/0-0020/rk805-pwrkey/input/input2
[    4.768001] kernel: rk808-rtc rk808-rtc: registered as rtc0
[    4.769828] kernel: rk808-rtc rk808-rtc: setting system clock to 2024-05-16T17:20:25 UTC (1715880025)
[    4.776284] kernel: rockchip-mipi-csi2-hw fdfb0000.mipi-csi2-hw: enter mipi csi2 hw probe!
[    4.776686] kernel: rockchip-mipi-csi2-hw fdfb0000.mipi-csi2-hw: probe success, v4l2_dev:mipi-csi2-hw!
[    4.779477] kernel: rkisp_hw fdff0000.rkisp: Adding to iommu group 6
[    4.779913] kernel: rkisp_hw fdff0000.rkisp: is_thunderboot: 0
[    4.779963] kernel: rkisp_hw fdff0000.rkisp: can't request region for resource [mem 0xfdff0000-0xfdffffff]
[    4.780017] kernel: rkisp_hw fdff0000.rkisp: max input:0x0@0fps
[    4.780498] kernel: rkisp_hw fdff0000.rkisp: no find phandle sram
[    4.781449] kernel: rkisp rkisp-vir0: rkisp driver version: v02.04.00
[    4.781695] kernel: rkisp rkisp-vir0: No memory-region-thunderboot specified
[    4.782064] kernel: rkisp rkisp-vir0: Entity type for entity rkisp-isp-subdev was not initialized!
[    4.782099] kernel: rkisp rkisp-vir0: Entity type for entity rkisp-csi-subdev was not initialized!
[    4.787614] kernel: usbcore: registered new interface driver uvcvideo
[    4.791034] kernel: cpu cpu0: Failed to get specification_serial_number
[    4.791100] kernel: cpu cpu0: Failed to get leakage
[    4.791138] kernel: cpu cpu0: Looking up cpu-supply from device tree
[    4.792210] kernel: cpu cpu0: soc version=0, speed=0
[    4.792322] kernel: cpu cpu0: Looking up cpu-supply from device tree
[    4.794975] kernel: cpu cpu0: avs=0
[    4.795266] kernel: cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=1416000000 h_limit=0 h_table=0
[    4.798884] kernel: cpu cpu0: EM: OPP:600000 is inefficient
[    4.799220] kernel: cpu cpu0: EM: created perf domain
[    4.803384] kernel: sdhci: Secure Digital Host Controller Interface driver
[    4.803400] kernel: sdhci: Copyright(c) Pierre Ossman
[    4.803404] kernel: Synopsys Designware Multimedia Card Interface Driver
[    4.804568] kernel: sdhci-pltfm: SDHCI platform and OF driver helper
[    4.804969] kernel: dwmmc_rockchip fe000000.mmc: No normal pinctrl state
[    4.804983] kernel: dwmmc_rockchip fe000000.mmc: No idle pinctrl state
[    4.804983] kernel: dwmmc_rockchip fe2b0000.mmc: No normal pinctrl state
[    4.804988] kernel: dwmmc_rockchip fe2b0000.mmc: No idle pinctrl state
[    4.805063] kernel: dwmmc_rockchip fe2c0000.mmc: No normal pinctrl state
[    4.805071] kernel: dwmmc_rockchip fe2c0000.mmc: No idle pinctrl state
[    4.805472] kernel: dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.
[    4.805472] kernel: dwmmc_rockchip fe000000.mmc: IDMAC supports 32-bit address mode.
[    4.805476] kernel: dwmmc_rockchip fe2b0000.mmc: IDMAC supports 32-bit address mode.
[    4.805501] kernel: dwmmc_rockchip fe000000.mmc: Using internal DMA controller.
[    4.805513] kernel: dwmmc_rockchip fe2b0000.mmc: Using internal DMA controller.
[    4.805513] kernel: dwmmc_rockchip fe000000.mmc: Version ID is 270a
[    4.805525] kernel: dwmmc_rockchip fe2b0000.mmc: Version ID is 270a
[    4.805529] kernel: dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.
[    4.805539] kernel: dwmmc_rockchip fe2c0000.mmc: Version ID is 270a
[    4.805572] kernel: dwmmc_rockchip fe000000.mmc: DW MMC controller at irq 83,32 bit host data width,256 deep fifo
[    4.805588] kernel: dwmmc_rockchip fe2b0000.mmc: DW MMC controller at irq 84,32 bit host data width,256 deep fifo
[    4.805600] kernel: dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 85,32 bit host data width,256 deep fifo
[    4.805687] kernel: dwmmc_rockchip fe000000.mmc: Looking up vmmc-supply from device tree
[    4.805687] kernel: dwmmc_rockchip fe2b0000.mmc: Looking up vmmc-supply from device tree
[    4.805688] kernel: dwmmc_rockchip fe2c0000.mmc: Looking up vmmc-supply from device tree
[    4.805698] kernel: dwmmc_rockchip fe2c0000.mmc: Looking up vmmc-supply property in node /mmc@fe2c0000 failed
[    4.805701] kernel: dwmmc_rockchip fe000000.mmc: Looking up vmmc-supply property in node /mmc@fe000000 failed
[    4.805751] kernel: dwmmc_rockchip fe2c0000.mmc: Looking up vqmmc-supply from device tree
[    4.805751] kernel: dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply from device tree
[    4.805758] kernel: dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply property in node /mmc@fe000000 failed
[    4.805760] kernel: dwmmc_rockchip fe2c0000.mmc: Looking up vqmmc-supply property in node /mmc@fe2c0000 failed
[    4.805830] kernel: dwmmc_rockchip fe2b0000.mmc: Looking up vqmmc-supply from device tree
[    4.806110] kernel: dwmmc_rockchip fe000000.mmc: allocated mmc-pwrseq
[    4.806110] kernel: dwmmc_rockchip fe2c0000.mmc: allocated mmc-pwrseq
[    4.806118] kernel: mmc_host mmc2: card is non-removable.
[    4.806120] kernel: mmc_host mmc3: card is non-removable.
[    4.807247] kernel: sdhci-dwcmshc fe310000.mmc: Looking up vmmc-supply from device tree
[    4.807268] kernel: sdhci-dwcmshc fe310000.mmc: Looking up vmmc-supply property in node /mmc@fe310000 failed
[    4.807310] kernel: sdhci-dwcmshc fe310000.mmc: Looking up vqmmc-supply from device tree
[    4.807317] kernel: sdhci-dwcmshc fe310000.mmc: Looking up vqmmc-supply property in node /mmc@fe310000 failed
[    4.807469] kernel: ledtrig-cpu: registered to indicate activity on CPUs
[    4.807539] kernel: arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
[    4.807616] kernel: SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    4.808530] kernel: cryptodev: driver 1.12 loaded.
[    4.808587] kernel: hid: raw HID events driver (C) Jiri Kosina
[    4.808855] kernel: usbcore: registered new interface driver usbhid
[    4.808863] kernel: usbhid: USB HID core driver
[    4.809128] kernel: rockchip,bus bus-npu: Looking up bus-supply from device tree
[    4.809259] kernel: rockchip,bus bus-npu: bin=0
[    4.809280] kernel: rockchip,bus bus-npu: Failed to get leakage
[    4.809297] kernel: rockchip,bus bus-npu: Looking up pvtm-supply from device tree
[    4.812962] kernel: rockchip,bus bus-npu: Looking up pvtm-supply from device tree
[    4.813871] kernel: rockchip,bus bus-npu: avs=0
[    4.817586] kernel: rockchip-saradc fe720000.saradc: Looking up vref-supply from device tree
[    4.818622] kernel: SPI driver inv-icm42600-spi has no spi_device_id for invensense,icm42600
[    4.818634] kernel: SPI driver inv-icm42600-spi has no spi_device_id for invensense,icm42602
[    4.818639] kernel: SPI driver inv-icm42600-spi has no spi_device_id for invensense,icm42605
[    4.818644] kernel: SPI driver inv-icm42600-spi has no spi_device_id for invensense,icm42622
[    4.818884] kernel: mmc_host mmc2: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[    4.818898] kernel: mmc_host mmc1: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[    4.818957] kernel: mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[    4.820137] kernel: usbcore: registered new interface driver snd-usb-audio
[    4.822200] kernel: rk817-codec rk817-codec: DMA mask not set
[    4.824211] kernel: [Awinic] aw87xxx_pa_init:driver version: v2.2.0
[    4.829650] kernel: Initializing XFRM netlink socket
[    4.829722] kernel: NET: Registered PF_PACKET protocol family
[    4.830116] kernel: [BT_RFKILL]: Enter rfkill_rk_init
[    4.830130] kernel: [WLAN_RFKILL]: Enter rfkill_wlan_init
[    4.830774] kernel: [WLAN_RFKILL]: Enter rfkill_wlan_probe
[    4.830838] kernel: [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6398s
[    4.830846] kernel: [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[    4.830852] kernel: [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[    4.830893] kernel: [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,host_wake_irq = 74, flags = 0.
[    4.830907] kernel: [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[    4.830913] kernel: [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[    4.830921] kernel: [WLAN_RFKILL]: rfkill_set_wifi_bt_power: 1
[    4.830929] kernel: [WLAN_RFKILL]: Exit rfkill_wlan_probe
[    4.832022] kernel: [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 77.
[    4.832065] kernel: [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 79.
[    4.832081] kernel: [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 81.
[    4.832097] kernel: [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 80.
[    4.832168] kernel: [BT_RFKILL]: Request irq for bt wakeup host
[    4.832293] kernel: [BT_RFKILL]: ** disable irq
[    4.832461] kernel: [BT_RFKILL]: bt shut off power
[    4.832506] kernel: [BT_RFKILL]: bt_default device registered.
[    4.832664] kernel: Key type dns_resolver registered
[    4.832705] kernel: Key type ceph registered
[    4.833223] kernel: libceph: loaded (mon/osd proto 15/24)
[    4.835066] kernel: registered taskstats version 1
[    4.835101] kernel: Loading compiled-in X.509 certificates
[    4.836089] kernel: Btrfs loaded, crc32c=crc32c-generic, zoned=no, fsverity=no
[    4.836561] kernel: pstore: Using crash dump compression: deflate
[    4.838937] kernel: mmc0: SDHCI controller on fe310000.mmc [fe310000.mmc] using ADMA
[    4.846818] kernel: rga: rga2, irq = 91, match scheduler
[    4.847359] kernel: rga: rga2 hardware loaded successfully, hw_version:3.2.63318.
[    4.847425] kernel: rga: rga2 probe successfully
[    4.847817] kernel: rga_iommu: IOMMU binding successfully, default mapping core[0x4]
[    4.848085] kernel: rga: Module initialized. v1.3.1
[    4.852758] kernel: mmc2: error -110 whilst initialising SDIO card
[    4.855733] kernel: mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 375000Hz, actual 375000HZ div = 0)
[    4.866327] kernel: mmc_host mmc2: Bus speed (slot 0) = 375000Hz (slot req 375000Hz, actual 375000HZ div = 0)
[    4.875339] kernel: rockchip-iodomain fdc20000.syscon:io-domains: Looking up pmuio1-supply from device tree
[    4.875591] kernel: rockchip-iodomain fdc20000.syscon:io-domains: pmuio1(3300000 uV) supplied by vcc3v3_pmu
[    4.875605] kernel: rockchip-iodomain fdc20000.syscon:io-domains: Looking up pmuio2-supply from device tree
[    4.875661] kernel: rockchip-iodomain fdc20000.syscon:io-domains: pmuio2(3300000 uV) supplied by vcc3v3_pmu
[    4.875673] kernel: rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio1-supply from device tree
[    4.875785] kernel: rockchip-iodomain fdc20000.syscon:io-domains: vccio1(3300000 uV) supplied by vccio_acodec
[    4.875797] kernel: rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio2-supply from device tree
[    4.875804] kernel: rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio2-supply property in node /syscon@fdc20000/io-domains failed
[    4.875844] kernel: rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio3-supply from device tree
[    4.875944] kernel: rockchip-iodomain fdc20000.syscon:io-domains: vccio3(3300000 uV) supplied by vccio_sd
[    4.875960] kernel: rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio4-supply from device tree
[    4.876107] kernel: rockchip-iodomain fdc20000.syscon:io-domains: vccio4(1800000 uV) supplied by vcc_1v8
[    4.876119] kernel: rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio5-supply from device tree
[    4.876273] kernel: rockchip-iodomain fdc20000.syscon:io-domains: vccio5(3300000 uV) supplied by vcc_3v3
[    4.876286] kernel: rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio6-supply from device tree
[    4.876336] kernel: rockchip-iodomain fdc20000.syscon:io-domains: vccio6(1800000 uV) supplied by vcc_1v8
[    4.876347] kernel: rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio7-supply from device tree
[    4.876403] kernel: rockchip-iodomain fdc20000.syscon:io-domains: vccio7(3300000 uV) supplied by vcc_3v3
[    4.876792] kernel: mpp_rkvenc fdf40000.rkvenc: Adding to iommu group 4
[    4.876992] kernel: mpp_rkvenc fdf40000.rkvenc: probing start
[    4.877260] kernel: mpp_rkvenc fdf40000.rkvenc: Looking up venc-supply from device tree
[    4.877400] kernel: mpp_rkvenc fdf40000.rkvenc: bin=0
[    4.877424] kernel: mpp_rkvenc fdf40000.rkvenc: Failed to get leakage
[    4.877441] kernel: mpp_rkvenc fdf40000.rkvenc: Looking up venc-supply from device tree
[    4.877461] kernel: vdd_logic: could not add device link fdf40000.rkvenc: -EEXIST
[    4.877544] kernel: mpp_rkvenc fdf40000.rkvenc: Looking up venc-supply from device tree
[    4.877564] kernel: debugfs: Directory 'fdf40000.rkvenc-venc' with parent 'vdd_logic' already present!
[    4.877574] kernel: vdd_logic: Failed to create debugfs directory
[    4.877769] kernel: mpp_rkvenc fdf40000.rkvenc: avs=0
[    4.877953] kernel: mpp_rkvenc fdf40000.rkvenc: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[    4.878544] kernel: mpp_rkvenc fdf40000.rkvenc: probing finish
[    4.878896] kernel: mpp_vdpu2 fdea0400.vdpu: Adding to iommu group 0
[    4.879059] kernel: mpp_vdpu2 fdea0400.vdpu: probe device
[    4.879541] kernel: mpp_vdpu2 fdea0400.vdpu: probing finish
[    4.879971] kernel: mpp_vepu2 fdee0000.vepu: Adding to iommu group 2
[    4.880145] kernel: mpp_vepu2 fdee0000.vepu: probing start
[    4.880815] kernel: mpp_vepu2 fdee0000.vepu: probing finish
[    4.881195] kernel: mpp-iep2 fdef0000.iep: Adding to iommu group 3
[    4.881368] kernel: mpp-iep2 fdef0000.iep: probe device
[    4.881633] kernel: mpp-iep2 fdef0000.iep: allocate roi buffer failed
[    4.881959] kernel: mpp-iep2 fdef0000.iep: probing finish
[    4.882418] kernel: mpp_jpgdec fded0000.jpegd: Adding to iommu group 1
[    4.882624] kernel: mpp_jpgdec fded0000.jpegd: probe device
[    4.883387] kernel: mpp_jpgdec fded0000.jpegd: probing finish
[    4.883887] kernel: mpp_rkvdec2 fdf80200.rkvdec: Adding to iommu group 5
[    4.884120] kernel: mpp_rkvdec2 fdf80200.rkvdec: rkvdec, probing start
[    4.884469] kernel: mpp_rkvdec2 fdf80200.rkvdec: shared_niu_a is not found!
[    4.884478] kernel: rkvdec2_init:982: No niu aclk reset resource define
[    4.884487] kernel: mpp_rkvdec2 fdf80200.rkvdec: shared_niu_h is not found!
[    4.884493] kernel: rkvdec2_init:985: No niu hclk reset resource define
[    4.884526] kernel: mpp_rkvdec2 fdf80200.rkvdec: Looking up vdec-supply from device tree
[    4.884783] kernel: mpp_rkvdec2 fdf80200.rkvdec: bin=0
[    4.884879] kernel: mpp_rkvdec2 fdf80200.rkvdec: Failed to get leakage
[    4.884901] kernel: mpp_rkvdec2 fdf80200.rkvdec: Looking up vdec-supply from device tree
[    4.884933] kernel: vdd_logic: could not add device link fdf80200.rkvdec: -EEXIST
[    4.884948] kernel: debugfs: File 'uA_load' in directory '/' already present!
[    4.884961] kernel: debugfs: File 'min_uV' in directory '/' already present!
[    4.884969] kernel: debugfs: File 'max_uV' in directory '/' already present!
[    4.884976] kernel: debugfs: File 'constraint_flags' in directory '/' already present!
[    4.885042] kernel: mpp_rkvdec2 fdf80200.rkvdec: Looking up vdec-supply from device tree
[    4.885068] kernel: debugfs: Directory 'fdf80200.rkvdec-vdec' with parent 'vdd_logic' already present!
[    4.885077] kernel: vdd_logic: Failed to create debugfs directory
[    4.885330] kernel: mpp_rkvdec2 fdf80200.rkvdec: avs=0
[    4.885554] kernel: mpp_rkvdec2 fdf80200.rkvdec: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[    4.885745] kernel: mpp_rkvdec2 fdf80200.rkvdec: sram_start 0x00000000fdcc0000
[    4.885757] kernel: mpp_rkvdec2 fdf80200.rkvdec: rcb_iova 0x0000000010000000
[    4.885764] kernel: mpp_rkvdec2 fdf80200.rkvdec: sram_size 45056
[    4.885771] kernel: mpp_rkvdec2 fdf80200.rkvdec: rcb_size 65536
[    4.885780] kernel: mpp_rkvdec2 fdf80200.rkvdec: min_width 512
[    4.885844] kernel: mpp_rkvdec2 fdf80200.rkvdec: link mode probe finish
[    4.885923] kernel: mpp_rkvdec2 fdf80200.rkvdec: probing finish
[    4.886561] kernel: rockchip-vop2 fe040000.vop: Adding to iommu group 7
[    4.888072] kernel: [drm] all windows should be assigned, full plane mask: 0x3f, current plane mask: 0x15
[    4.888092] kernel: [drm] use default plane mask
[    4.888327] kernel: [drm] RK3566 only support 2 vps
[    4.888354] kernel: rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x15, primary plane phy id: 4
[    4.888377] kernel: rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp1 assign plane mask: 0x22, primary plane phy id: 5
[    4.888388] kernel: rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x8, primary plane phy id: 3
[    4.888750] kernel: [drm] failed to init overlay plane Cluster0-win1
[    4.888821] kernel: [drm] failed to init overlay plane Cluster1-win1
[    4.889030] kernel: rockchip-vop2 fe040000.vop: bin=0
[    4.889064] kernel: rockchip-vop2 fe040000.vop: Failed to get leakage
[    4.889120] kernel: rockchip-vop2 fe040000.vop: Looking up vop-supply from device tree
[    4.889612] kernel: rockchip-vop2 fe040000.vop: Looking up vop-supply from device tree
[    4.889982] kernel: rockchip-vop2 fe040000.vop: avs=0
[    4.890148] kernel: rockchip-vop2 fe040000.vop: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[    4.890629] kernel: rockchip-vop2 fe040000.vop: Supported VOP aclk dvfs, normal mode:396000000, advanced mode:500000000
[    4.890650] kernel: rockchip-drm display-subsystem: bound fe040000.vop (ops 0xffff8000092d7c18)
[    4.890763] kernel: dwhdmi-rockchip fe0a0000.hdmi: Looking up avdd-0v9-supply from device tree
[    4.890946] kernel: dwhdmi-rockchip fe0a0000.hdmi: Looking up avdd-1v8-supply from device tree
[    4.891240] kernel: dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[    4.892466] kernel: dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver
[    4.893185] kernel: dwhdmi-rockchip fe0a0000.hdmi: error -ENXIO: IRQ index 1 not found
[    4.894415] kernel: input: hdmi_cec_key as /devices/platform/fe0a0000.hdmi/dw-hdmi-cec.5.auto/input/input3
[    4.895283] kernel: rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops 0xffff8000092e9ff0)
[    4.895858] kernel: rockchip-drm display-subsystem: failed to parse loader memory
[    4.896628] kernel: [drm] Initialized rockchip 3.0.0 20140818 for display-subsystem on minor 0
[    4.898984] kernel: mmc0: Host Software Queue enabled
[    4.899005] kernel: mmc0: new HS200 MMC card at address 0001
[    4.899717] kernel: mmcblk0: mmc0:0001 CJNB4R 58.2 GiB
[    4.903709] kernel:  mmcblk0: p1 p2
[    4.904755] kernel: mmcblk0boot0: mmc0:0001 CJNB4R 4.00 MiB
[    4.906425] kernel: mmcblk0boot1: mmc0:0001 CJNB4R 4.00 MiB
[    4.907861] kernel: mmcblk0rpmb: mmc0:0001 CJNB4R 4.00 MiB, chardev (235:0)
[    4.922973] kernel: usb 1-1: new full-speed USB device number 2 using xhci-hcd
[    4.948639] kernel: vendor storage:20190527 ret = 0
[    5.026666] kernel: rockchip-vop2 fe040000.vop: [drm:vop2_crtc_atomic_enable] Update mode to 3840x2160p60, type: 11(if:800, flag:0x0) for vp0 dclk: 594000000
[    5.066995] kernel: usb 1-1: New USB device found, idVendor=0a05, idProduct=7211, bcdDevice= 1.00
[    5.067042] kernel: usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    5.067064] kernel: usb 1-1: Product: USB2.0 HUB
[    5.313735] kernel: hub 1-1:1.0: USB hub found
[    5.314232] kernel: hub 1-1:1.0: 4 ports detected
[    5.377537] kernel: Console: switching to colour frame buffer device 480x135
[    5.579331] kernel: rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device
[    5.583776] kernel: rockchip-dmc dmc: Failed to get specification_serial_number
[    5.583882] kernel: rockchip-dmc dmc: Failed to get leakage
[    5.583904] kernel: rockchip-dmc dmc: Looking up center-supply from device tree
[    5.583921] kernel: rockchip-pm-domain fdd90000.power-management:power-controller: Looking up gpu-supply from device tree
[    5.583942] kernel: rockchip-pm-domain fdd90000.power-management:power-controller: Looking up gpu-supply property in node /power-management@fdd90000/power-controller failed
[    5.584038] kernel: mali fde60000.gpu: Kernel DDK version g18p0-01eac0
[    5.584051] kernel: mali fde60000.gpu: error -ENXIO: IRQ JOB not found
[    5.584163] kernel: mali fde60000.gpu: error -ENXIO: IRQ MMU not found
[    5.584205] kernel: mali fde60000.gpu: error -ENXIO: IRQ GPU not found
[    5.584244] kernel: mali fde60000.gpu: Insufficient register space, will override to the required size
[    5.584258] kernel: mali fde60000.gpu: Register window unavailable
[    5.584264] kernel: mali fde60000.gpu: Failed to map registers
[    5.584269] kernel: mali fde60000.gpu: Register map failed error = -5
[    5.584275] kernel: mali fde60000.gpu: Device initialization failed
[    5.584288] kernel: rockchip-dmc dmc: soc version=0, speed=0
[    5.584306] kernel: mali: probe of fde60000.gpu failed with error -5
[    5.584364] kernel: rockchip-dmc dmc: Looking up center-supply from device tree
[    5.584735] kernel: rockchip-dmc dmc: avs=0
[    5.584756] kernel: rockchip-dmc dmc: current ATF version 0x102
[    5.585473] kernel: rockchip-dmc dmc: normal_rate = 780000000
[    5.585483] kernel: rockchip-dmc dmc: reboot_rate = 1056000000
[    5.585489] kernel: rockchip-dmc dmc: suspend_rate = 324000000
[    5.585496] kernel: rockchip-dmc dmc: video_4k_rate = 780000000
[    5.585503] kernel: rockchip-dmc dmc: video_4k_10b_rate = 780000000
[    5.585509] kernel: rockchip-dmc dmc: boost_rate = 1056000000
[    5.585515] kernel: rockchip-dmc dmc: fixed_rate(isp|cif0|cif1|dualview) = 1056000000
[    5.585521] kernel: rockchip-dmc dmc: performance_rate = 1056000000
[    5.585540] kernel: rockchip-dmc dmc: failed to get vop pn to msch rl
[    5.585785] kernel: rockchip-dmc dmc: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[    5.590323] kernel: rk817-codec rk817-codec: rk817_probe: chip_name:0x80, chip_ver:0x94
[    5.597881] kernel: WCN: marlin_init entry!
[    5.599689] kernel: rockchip-pm-domain fdd90000.power-management:power-controller: Looking up npu-supply from device tree
[    5.599725] kernel: rockchip-pm-domain fdd90000.power-management:power-controller: Looking up npu-supply property in node /power-management@fdd90000/power-controller failed
[    5.599845] kernel: RKNPU fde40000.npu: RKNPU: rknpu iommu is disabled, using non-iommu mode
[    5.599887] kernel: RKNPU fde40000.npu: assigned reserved memory node rknpu
[    5.599899] kernel: RKNPU fde40000.npu: RKNPU: initialize reserved memory for rknpu device!
[    5.599959] kernel: RKNPU fde40000.npu: Looking up rknpu-supply from device tree
[    5.600174] kernel: RKNPU fde40000.npu: Looking up mem-supply from device tree
[    5.600190] kernel: RKNPU fde40000.npu: Looking up mem-supply property in node /npu@fde40000 failed
[    5.600289] kernel: RKNPU fde40000.npu: error -ENXIO: IRQ npu_irq not found
[    5.601162] kernel: [drm] Initialized rknpu 0.9.6 20240322 for fde40000.npu on minor 1
[    5.601788] kernel: RKNPU fde40000.npu: Failed to get specification_serial_number
[    5.601995] kernel: RKNPU fde40000.npu: Failed to get leakage
[    5.602026] kernel: RKNPU fde40000.npu: Looking up rknpu-supply from device tree
[    5.602073] kernel: vdd_npu: could not add device link fde40000.npu: -EEXIST
[    5.602091] kernel: debugfs: File 'uA_load' in directory '/' already present!
[    5.602105] kernel: debugfs: File 'min_uV' in directory '/' already present!
[    5.602115] kernel: debugfs: File 'max_uV' in directory '/' already present!
[    5.602124] kernel: debugfs: File 'constraint_flags' in directory '/' already present!
[    5.602170] kernel: RKNPU fde40000.npu: soc version=0, speed=0
[    5.602249] kernel: RKNPU fde40000.npu: Looking up rknpu-supply from device tree
[    5.602284] kernel: debugfs: Directory 'fde40000.npu-rknpu' with parent 'vdd_npu' already present!
[    5.602295] kernel: vdd_npu: Failed to create debugfs directory
[    5.603314] kernel: RKNPU fde40000.npu: avs=0
[    5.603577] kernel: RKNPU fde40000.npu: l=0 h=2147483647 hyst=5000 l_limit=800000000 h_limit=0 h_table=0
[    5.605851] kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    5.625658] kernel: cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    5.626719] kernel: rockchip-pm rockchip-suspend: not set pwm-regulator-config
[    5.627283] kernel: rockchip-suspend not set sleep-mode-config for mem-lite
[    5.627292] kernel: rockchip-suspend not set wakeup-config for mem-lite
[    5.627301] kernel: rockchip-suspend not set sleep-mode-config for mem-ultra
[    5.627306] kernel: rockchip-suspend not set wakeup-config for mem-ultra
[    5.628603] kernel: rkisp rkisp-vir0: clear unready subdev num: 1
[    5.629080] kernel: rkisp-vir0: Async subdev notifier completed
[    5.629100] kernel: ALSA device list:
[    5.629106] kernel:   #0: hdmi-sound
[    5.629112] kernel:   #1: rockchip,rk809-codec
[    5.635627] kernel: Freeing unused kernel memory: 7488K
[    5.656797] kernel: Run /init as init process
[    5.656845] kernel:   with arguments:
[    5.656868] kernel:     /init
[    5.656888] kernel:     splash
[    5.656906] kernel:   with environment:
[    5.656923] kernel:     HOME=/
[    5.656940] kernel:     TERM=linux
[    5.656958] kernel:     ubootpart=9b25914f-58db-1647-84b9-7f8229e30d13
[    5.656978] kernel:     cgroup_enable=memory
[    5.656996] kernel:     cgroup_memory=1
[    5.679890] kernel: usb 4-1: new SuperSpeed USB device number 2 using xhci-hcd
[    5.698267] kernel: usb 4-1: New USB device found, idVendor=0951, idProduct=1666, bcdDevice= 1.10
[    5.698309] kernel: usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    5.698325] kernel: usb 4-1: Product: DataTraveler 3.0
[    5.698338] kernel: usb 4-1: Manufacturer: Kingston
[    5.698350] kernel: usb 4-1: SerialNumber: 08606E6D4139B1409831D890
[    5.700430] kernel: usb-storage 4-1:1.0: USB Mass Storage device detected
[    5.701512] kernel: scsi host0: usb-storage 4-1:1.0
[    5.966318] kernel: usb 1-1.1: new low-speed USB device number 3 using xhci-hcd
[    6.067692] kernel: usb 1-1.1: New USB device found, idVendor=17ef, idProduct=6099, bcdDevice= 1.00
[    6.067717] kernel: usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    6.067724] kernel: usb 1-1.1: Product: Lenovo Traditional USB Keyboard
[    6.067730] kernel: usb 1-1.1: Manufacturer: Lenovo
[    6.149688] kernel: input: adc-keys as /devices/platform/adc-keys/input/input4
[    6.191010] kernel: panfrost fde60000.gpu: clock rate = 594000000
[    6.191073] kernel: panfrost fde60000.gpu: bus_clock rate = 500000000
[    6.191179] kernel: panfrost fde60000.gpu: Looking up mali-supply from device tree
[    6.192630] kernel: panfrost fde60000.gpu: mali-g52 id 0x7402 major 0x1 minor 0x0 status 0x0
[    6.192656] kernel: panfrost fde60000.gpu: features: 00000000,00000cf7, issues: 00000000,00000400
[    6.192664] kernel: panfrost fde60000.gpu: Features: L2:0x07110206 Shader:0x00000002 Tiler:0x00000209 Mem:0x1 MMU:0x00002823 AS:0xff JS:0x7
[    6.192673] kernel: panfrost fde60000.gpu: shader_present=0x1 l2_present=0x1
[    6.194757] kernel: [drm] Initialized panfrost 1.2.0 20180908 for fde60000.gpu on minor 2
[    6.226668] kernel: input: Lenovo Lenovo Traditional USB Keyboard as /devices/platform/usbdrd/fcc00000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.1/1-1.1:1.0/0003:17EF:6099.0001/input/input5
[    6.283898] kernel: hid-generic 0003:17EF:6099.0001: input,hidraw0: USB HID v1.11 Keyboard [Lenovo Lenovo Traditional USB Keyboard] on usb-xhci-hcd.0.auto-1.1/input0
[    6.356246] kernel: usb 1-1.3: new low-speed USB device number 4 using xhci-hcd
[    6.454835] kernel: usb 1-1.3: New USB device found, idVendor=17ef, idProduct=608d, bcdDevice= 1.00
[    6.454905] kernel: usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    6.454938] kernel: usb 1-1.3: Product: Lenovo USB Optical Mouse
[    6.454963] kernel: usb 1-1.3: Manufacturer: PixArt
[    6.598299] kernel: input: PixArt Lenovo USB Optical Mouse as /devices/platform/usbdrd/fcc00000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.3/1-1.3:1.0/0003:17EF:608D.0002/input/input6
[    6.600739] kernel: hid-generic 0003:17EF:608D.0002: input,hidraw1: USB HID v1.11 Mouse [PixArt Lenovo USB Optical Mouse] on usb-xhci-hcd.0.auto-1.3/input0
[    6.720686] kernel: scsi 0:0:0:0: Direct-Access     Kingston DataTraveler 3.0 PMAP PQ: 0 ANSI: 6
[    6.721705] kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
[    6.722724] kernel: sd 0:0:0:0: [sda] 60567552 512-byte logical blocks: (31.0 GB/28.9 GiB)
[    6.723534] kernel: sd 0:0:0:0: [sda] Write Protect is off
[    6.723553] kernel: sd 0:0:0:0: [sda] Mode Sense: 45 00 00 00
[    6.724362] kernel: sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[    6.793156] kernel:  sda: sda1
[    6.793678] kernel: sd 0:0:0:0: [sda] Attached SCSI removable disk
[    7.569731] kernel: EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Quota mode: none.
[    7.954517] kernel: NET: Registered PF_INET6 protocol family
[    7.955889] kernel: Segment Routing with IPv6
[    7.955927] kernel: In-situ OAM (IOAM) with IPv6
[    7.980450] systemd[1]: systemd 249.11-0ubuntu3.12 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[    7.981615] systemd[1]: Detected architecture arm64.
[    7.985112] systemd[1]: Hostname set to <h96-tvbox-3566-vendor>.
[    8.588042] systemd[1]: Queued start job for default target Graphical Interface.
[    8.617924] systemd[1]: Created slice Slice /system/modprobe.
[    8.621974] systemd[1]: Created slice Slice /system/serial-getty.
[    8.625501] systemd[1]: Created slice Slice /system/systemd-fsck.
[    8.628265] systemd[1]: Created slice User and Session Slice.
[    8.629233] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    8.630381] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    8.630862] systemd[1]: Reached target User and Group Name Lookups.
[    8.631071] systemd[1]: Reached target Slice Units.
[    8.631203] systemd[1]: Reached target Mounting snaps.
[    8.631346] systemd[1]: Reached target Swaps.
[    8.631474] systemd[1]: Reached target System Time Set.
[    8.631726] systemd[1]: Reached target Local Verity Protected Volumes.
[    8.650639] systemd[1]: Listening on RPCbind Server Activation Socket.
[    8.651778] systemd[1]: Listening on Syslog Socket.
[    8.652636] systemd[1]: Listening on fsck to fsckd communication Socket.
[    8.653272] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    8.654582] systemd[1]: Listening on Journal Audit Socket.
[    8.655366] systemd[1]: Listening on Journal Socket (/dev/log).
[    8.656389] systemd[1]: Listening on Journal Socket.
[    8.660098] systemd[1]: Listening on udev Control Socket.
[    8.660952] systemd[1]: Listening on udev Kernel Socket.
[    8.665178] systemd[1]: Mounting Huge Pages File System...
[    8.670186] systemd[1]: Mounting POSIX Message Queue File System...
[    8.675671] systemd[1]: Mounting Kernel Debug File System...
[    8.680720] systemd[1]: Mounting Kernel Trace File System...
[    8.681739] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[    8.687702] systemd[1]: Starting Restore / save the current clock...
[    8.693796] systemd[1]: Starting Set the console keyboard layout...
[    8.700528] systemd[1]: Starting Create List of Static Device Nodes...
[    8.708055] systemd[1]: Starting Load Kernel Module configfs...
[    8.715171] systemd[1]: Starting Load Kernel Module drm...
[    8.725058] systemd[1]: Starting Load Kernel Module efi_pstore...
[    8.731456] systemd[1]: Starting Load Kernel Module fuse...
[    8.732985] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    8.741519] systemd[1]: Starting Load Kernel Modules...
[    8.749160] systemd[1]: Starting Remount Root and Kernel File Systems...
[    8.749160] kernel: fuse: init (API version 7.37)
[    8.756833] systemd[1]: Starting Coldplug All udev Devices...
[    8.766490] systemd[1]: Mounted Huge Pages File System.
[    8.768133] systemd[1]: Mounted POSIX Message Queue File System.
[    8.769733] systemd[1]: Mounted Kernel Debug File System.
[    8.771079] systemd[1]: Mounted Kernel Trace File System.
[    8.773941] systemd[1]: Finished Restore / save the current clock.
[    8.777155] systemd[1]: Finished Create List of Static Device Nodes.
[    8.779418] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[    8.781204] systemd[1]: Finished Load Kernel Module configfs.
[    8.783303] systemd[1]: modprobe@drm.service: Deactivated successfully.
[    8.784779] systemd[1]: Finished Load Kernel Module drm.
[    8.785834] kernel: EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
[    8.787417] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[    8.788709] systemd[1]: Finished Load Kernel Module efi_pstore.
[    8.794104] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[    8.795340] systemd[1]: Finished Load Kernel Module fuse.
[    8.797453] systemd[1]: Finished Load Kernel Modules.
[    8.799559] systemd[1]: Finished Remount Root and Kernel File Systems.
[    8.854223] systemd[1]: Mounting FUSE Control File System...
[    8.858698] systemd[1]: Mounting Kernel Configuration File System...
[    8.864628] systemd[1]: Starting Platform Persistent Storage Archival...
[    8.870412] systemd[1]: Starting Load/Save Random Seed...
[    8.876417] systemd[1]: Starting Apply Kernel Variables...
[    8.902535] systemd[1]: Starting Create System Users...
[    8.917338] systemd[1]: Mounted FUSE Control File System.
[    8.919236] systemd[1]: Mounted Kernel Configuration File System.
[    8.932256] systemd[1]: Finished Set the console keyboard layout.
[    8.935089] systemd[1]: Finished Platform Persistent Storage Archival.
[    8.938083] systemd[1]: Finished Load/Save Random Seed.
[    8.939363] systemd[1]: Condition check resulted in First Boot Complete being skipped.
[    8.946939] systemd[1]: Finished Apply Kernel Variables.
[    8.948997] systemd[1]: Finished Create System Users.
[    8.983925] systemd[1]: Starting Create Static Device Nodes in /dev...
[    9.020812] systemd[1]: Finished Create Static Device Nodes in /dev.
[    9.021729] systemd[1]: Reached target Preparation for Local File Systems.
[    9.027903] systemd[1]: Mounting Mount unit for bare, revision 5...
[    9.033904] systemd[1]: Mounting Mount unit for chromium, revision 2856...
[    9.037399] kernel: loop0: detected capacity change from 0 to 8
[    9.040727] systemd[1]: Mounting Mount unit for core22, revision 1383...
[    9.046485] kernel: loop1: detected capacity change from 0 to 331048
[    9.047896] systemd[1]: Mounting Mount unit for cups, revision 1049...
[    9.048467] kernel: squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    9.056578] systemd[1]: Mounting Mount unit for gnome-42-2204, revision 178...
[    9.063087] kernel: loop2: detected capacity change from 0 to 134056
[    9.067486] kernel: loop3: detected capacity change from 0 to 141760
[    9.071120] systemd[1]: Mounting Mount unit for gtk-common-themes, revision 1535...
[    9.074894] kernel: loop4: detected capacity change from 0 to 989864
[    9.079742] systemd[1]: Mounting Mount unit for snapd, revision 21467...
[    9.083548] kernel: loop5: detected capacity change from 0 to 187776
[    9.087502] systemd[1]: Mounting /tmp...
[    9.090756] kernel: loop6: detected capacity change from 0 to 68920
[    9.097242] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[    9.117646] systemd[1]: Mounted Mount unit for bare, revision 5.
[    9.118704] systemd[1]: Mounted Mount unit for chromium, revision 2856.
[    9.119778] systemd[1]: Mounted Mount unit for core22, revision 1383.
[    9.120769] systemd[1]: Mounted Mount unit for cups, revision 1049.
[    9.121723] systemd[1]: Mounted Mount unit for gnome-42-2204, revision 178.
[    9.122719] systemd[1]: Mounted Mount unit for gtk-common-themes, revision 1535.
[    9.123751] systemd[1]: Mounted Mount unit for snapd, revision 21467.
[    9.124702] systemd[1]: Mounted /tmp.
[    9.125545] systemd[1]: Reached target Mounted snaps.
[    9.277622] systemd[1]: Started Rule-based Manager for Device Events and Files.
[    9.303822] systemd[1]: Finished Coldplug All udev Devices.
[    9.340514] systemd[1]: Starting Helper to synchronize boot up for ifupdown...
[    9.346811] systemd[1]: Starting Show Plymouth Boot Screen...
[    9.358200] systemd[1]: Finished Helper to synchronize boot up for ifupdown.
[    9.397627] systemd[1]: Started Show Plymouth Boot Screen.
[    9.398512] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch being skipped.
[    9.399263] systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
[    9.399545] systemd[1]: Reached target Local Encrypted Volumes.
[   10.071310] systemd[1]: Found device /dev/disk/by-uuid/9449-A321.
[   10.110283] systemd[1]: Starting File System Check on /dev/disk/by-uuid/9449-A321...
[   10.113341] systemd[1]: Found device /dev/ttyFIQ0.
[   10.142003] systemd[1]: Started File System Check Daemon to report status.
[   10.241928] systemd[1]: Finished File System Check on /dev/disk/by-uuid/9449-A321.
[   10.274068] systemd[1]: Mounting /boot...
[   10.311714] systemd[1]: Mounted /boot.
[   10.313193] systemd[1]: Reached target Local File Systems.
[   10.313666] systemd[1]: Condition check resulted in Load AppArmor profiles being skipped.
[   10.330741] systemd[1]: Starting Armbian ZRAM config...
[   10.337825] systemd[1]: Starting Set console font and keymap...
[   10.357566] systemd[1]: Starting Raise network interfaces...
[   10.372874] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[   10.374133] systemd[1]: Condition check resulted in RPC security service for NFS server being skipped.
[   10.374324] systemd[1]: Condition check resulted in Load AppArmor profiles managed internally by snapd being skipped.
[   10.384933] systemd[1]: Starting Set Up Additional Binary Formats...
[   10.385504] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[   10.386005] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[   10.391353] systemd[1]: Finished Set console font and keymap.
[   10.392704] systemd[1]: Received SIGRTMIN+20 from PID 242 (plymouthd).
[   10.419141] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[   10.441541] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 488 (systemd-binfmt)
[   10.460431] systemd[1]: Mounting Arbitrary Executable File Formats File System...
[   10.515147] systemd[1]: Mounted Arbitrary Executable File Formats File System.
[   10.533779] systemd[1]: Finished Set Up Additional Binary Formats.
[   10.548138] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch being skipped.
[   10.548371] systemd[1]: Condition check resulted in Load AppArmor profiles being skipped.
[   10.548528] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[   10.548685] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[   10.641568] kernel: zram: Added device: zram0
[   10.642351] kernel: zram: Added device: zram1
[   10.643244] kernel: zram: Added device: zram2
[   10.772771] kernel: zram0: detected capacity change from 0 to 7871560
[   10.810594] kernel: Adding 3935776k swap on /dev/zram0.  Priority:5 extents:1 across:3935776k SS
[   10.954831] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[   10.980510] systemd[1]: Starting Load/Save RF Kill Switch Status...
[   10.983472] systemd[1]: Finished Raise network interfaces.
[   11.011720] kernel: [BT_RFKILL]: rfkill_rk_set_power: set bt wake_host high!
[   11.062964] kernel: [BT_RFKILL]: rfkill_rk_set_power: set bt wake_host input!
[   11.063018] kernel: [BT_RFKILL]: ENABLE UART_RTS
[   11.081927] kernel: zram1: detected capacity change from 0 to 102400
[   11.138578] systemd[1]: Finished Armbian ZRAM config.
[   11.167173] systemd[1]: Starting Armbian memory supported logging...
[   11.169601] kernel: [BT_RFKILL]: DISABLE UART_RTS
[   11.169678] kernel: [BT_RFKILL]: bt turn on power
[   11.169713] kernel: [BT_RFKILL]: Request irq for bt wakeup host
[   11.169762] kernel: [BT_RFKILL]: ** disable irq
[   11.172613] systemd[1]: Started Load/Save RF Kill Switch Status.
[   11.237564] kernel: EXT4-fs (zram1): mounted filesystem without journal. Quota mode: none.
[   13.287993] systemd[1]: Finished Armbian memory supported logging.
[   13.319453] systemd[1]: Starting Journal Service...
[   13.643750] systemd[1]: Started Journal Service.
[   16.376861] kernel: rockchip-thermal fe710000.tsadc: ch0 Missing trim_l property
[   16.376918] kernel: rockchip-thermal fe710000.tsadc: ch1 Missing trim_l property
[   16.396758] kernel: rockchip-thermal fe710000.tsadc: tsadc is probed successfully!
[   16.397416] kernel: platform mtd_vendor_storage: deferred probe pending
[   16.487747] kernel: loop7: detected capacity change from 0 to 8
[   17.113556] kernel: rk_gmac-dwmac fe010000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0
[   17.114396] kernel: phy_rtl8211f_led_fixup in
[   17.114561] kernel: phy_rtl8211f_led_fixup in  val=0x0000
[   17.216339] kernel: rk_gmac-dwmac fe010000.ethernet eth0: PHY [stmmac-1:00] driver [RTL8211F Gigabit Ethernet] (irq=POLL)
[   17.216987] kernel: dwmac4: Master AXI performs any burst length
[   17.217032] kernel: rk_gmac-dwmac fe010000.ethernet eth0: No Safety Features support found
[   17.217065] kernel: rk_gmac-dwmac fe010000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported
[   17.217471] kernel: rk_gmac-dwmac fe010000.ethernet eth0: registered PTP clock
[   17.231211] kernel: rk_gmac-dwmac fe010000.ethernet eth0: configuring for phy/rgmii link mode
Edited by Hqnicolas
Posted (edited)
- Update: Rockchip Kernel 5.1 Legacy
HDMI Audio
✔️ WIFI 2.4 + 5ghz
✔️ Ethernet
 ✔️Bluetooth
✔️ NPU
VPU
✔️ GPU
Wifi-K510:
https://drive.google.com/file/d/1B1LmAylalETcnBEWiPiJHL0MjK5xlIV4/view
sudo apt-mark hold linux-image-5.10.160-rockchip linux-headers-5.10.160-rockchip
cd /lib/firmware/brcm/
sudo wget https://github.com/CoreELEC/brcmfmac_sdio-firmware-aml/raw/master/firmware/brcm/fw_bcm4335b0_ag.bin
sudo ln -s fw_bcm4335b0_ag.bin brcmfmac4335-sdio.bin
Quote
sudo cat > /lib/firmware/brcm/brcmfmac4335-sdio.txt << "EOF"
# bcm94335wlcspMS_ES50_RC171p24p23_04052013_AM_mdfy_PAparam.txt -- 4/5/2013 by Murata, based on bcm94335wlcspMS_ES50_RC171p24p20_04022013_AM.txt, changed PA parameters and txidxcap parameters and ccode.
# bcm94335wlcspMS_ES50_RC171p24p20_04022013_AM.txt -- 4/2/2013 by Broadcom Corporation
# Use with AARDVARK_REL_6_30_171_24_23 -- Murata BCM4335 WLCSP 11AC Module
# Sample variables file for Murata Type-XJ ES5.0 (0x00 0x11) -- bcm94335wlcspMS_AM_P400.txt as original
sromrev=11
boardrev=0x1500
boardtype=0x064b
boardflags=0x10401001
boardflags2=0x0
#updated boardflags3 for forcing to enable external LPO
boardflags3=0x0800c08b
macaddr=00:90:4c:c5:12:38
#ccode modified by Murata
#ccode=0
ccode=XS
regrev=0
antswitch=0
pdgain5g=1
pdgain2g=1
tworangetssi2g=0
tworangetssi5g=0
femctrl=4
vendid=0x14e4
devid=0x43ae
manfid=0x2d0
#prodid=0x052e
nocrc=1
#otpimagesize=502
xtalfreq=37400
extpagain2g=1
extpagain5g=1
rxgains2gelnagaina0=2
rxgains2gtrisoa0=6
rxgains2gtrelnabypa0=1
rxgains5gelnagaina0=3
rxgains5gtrisoa0=5
rxgains5gtrelnabypa0=1
rxchain=1
txchain=1
aa2g=1
aa5g=1
ag0=0
ag1=0
tssipos5g=1
tssipos2g=1
#PA parameters (2G20M/2G40M/5G20M/5G40M/5G80M)
#PA parameters modified by Murata
#pa2ga0=-208,6208,-764
#pa2ga1=-203,6429,-793
#pa5ga0=-167,5736,-685,-157,5669,-670,-157,5548,-665,-141,5621,-664
#pa5ga1=-101,6543,-735,-99,6452,-731,-147,5743,-695,-75,6468,-723
#pa5ga2=-172,5903,-708,-160,5868,-698,-113,6264,-722,-125,5915,-684
pa2ga0=0xff31,0x1759,0xFD1D
pa2ga1=0xff35,0x18BB,0xFCEC
pa5ga0=0xff78,0x1715,0xFD49,0xff89,0x1714,0xFD57,0xff86,0x1652,0xFD62,0xffa9,0x1760,0xFD5E
pa5ga1=0xff56,0x1596,0xFD5F,0xff88,0x1764,0xFD45,0xff89,0x1632,0xFD65,0xff69,0x160E,0xFD49
pa5ga2=0xff5a,0x1667,0xFD4E,0xff5f,0x15F7,0xFD5E,0xff5a,0x1531,0xFD68,0xff6e,0x1587,0xFD6A
# Default Target Power for 2G -- 17dBm(11)/14dBm(54)/13dBm(MCS7,MCS8)/16dBm(6,MCS0)
maxp2ga0=74
cckbw202gpo=0
cckbw20ul2gpo=0
dot11agofdmhrbw202gpo=0x6666
ofdmlrbw202gpo=0x0022
mcsbw202gpo=0x88866662
# Default Target Power for 5G -- 14dBm(54)/13dBm(HT20-MCS7,VHT20-MCS8)/12dBm(HT40-MCS7,VHT40-MCS9)/11dBm(VHT80-MCS8/MCS9)/16dBm(6,20HT-MCS0)
maxp5ga0=74,74,74,74
# Low
mcslr5glpo=0
mcsbw205glpo=0x88866662
mcsbw405glpo=0xAAA88884
mcsbw805glpo=0xCCCAAAA6
# Mid
mcslr5gmpo=0
mcsbw205gmpo=0x88866662
mcsbw405gmpo=0xAAA88884
mcsbw805gmpo=0xCCCAAAA6
# High
mcslr5ghpo=0
mcsbw205ghpo=0x88866662
mcsbw405ghpo=0xAAA88884
mcsbw805ghpo=0xCCCAAAA6
#20MHz High Rate
sb20in40hrpo=0x0
sb20in80and160hr5glpo=0x0
sb20in80and160hr5gmpo=0x0
sb20in80and160hr5ghpo=0x0
#40MHz High Rate
sb40and80hr5glpo=0x0
sb40and80hr5gmpo=0x0
sb40and80hr5ghpo=0x0
#20MHz Low Rate
sb20in40lrpo=0x0
sb20in80and160lr5glpo=0x0
sb20in80and160lr5gmpo=0x0
sb20in80and160lr5ghpo=0x0
#40MHz Low Rate
sb40and80lr5glpo=0x0
sb40and80lr5gmpo=0x0
sb40and80lr5ghpo=0x0
dot11agduphrpo=0x0
dot11agduplrpo=0x0
tssifloor2g=80
tssifloor5g=160,190,240,260
#rpcal:use with 171.17 or later, compensates filter ripple
rpcal2g=0x0
rpcal5gb0=0x0
#cckdigfilttype[0-7] 0:default
cckdigfilttype=2
phycal_tempdelta=25
#GPIO 0 for SDIO HW OOB interruption
muxenab=0x10
#sd_gpout=0
#sd_oobonly=1
rssicorrnorm_c0=-3,-2
rssicorrnorm5g_c0=-1,0,-3,-1,0,-3,-3,-2,-4,-3,-2,-4
#txidxcap2g and txidxcap5g modified by Murata
#txidxcap2g=32
#txidxcap5g=44
txidxcap2g=36
txidxcap5g=36
paparambwver=1
EOF
sudo reboot now
nmcli dev wifi
sudo rmmod brcmfmac_wcc brcmfmac brcmutil
modprobe brcmfmac
- Image:
Updated K510 test image: https://drive.google.com/file/d/18nsBoAjroMBSnNM0mr7qoVI_rKsReufM/view?usp=sharing
- BaseFiles:
RK3566-H96-MAX-LEGACY-51-V7: https://drive.google.com/file/d/1C6xce8CTsIaI8znwRjhg_KcskKtTXJR_/view?usp=sharing
edit Rockchip U-boot Legacy 4.19 DTShttps://github.com/hqnicolas/u-boot/blob/next-dev-v2024.03/arch/arm/dts/rk3566-h96.dts
edit Rockchip U-boot Legacy 4.19 DEFCONFIGhttps://github.com/hqnicolas/u-boot/blob/next-dev-v2024.03/configs/h96-rk3566_defconfig
dmesg after wifi install:
Quote
[    1.459119] kernel: Booting Linux on physical CPU 0x0000000000 [0x412fd050]
[    1.459154] kernel: Linux version 5.10.160-legacy-rk35xx (armbian@next) (aarch64-linux-gnu-gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1 SMP Wed May 15 03:04:45 UTC 2024
[    1.473647] kernel: Machine model: h96 TVbox 3566
[    1.473911] kernel: earlycon: uart8250 at MMIO32 0x00000000fe660000 (options '')
[    1.473928] kernel: printk: bootconsole [uart8250] enabled
[    1.476767] kernel: efi: UEFI not found.
[    1.480579] kernel: OF: fdt: Reserved memory: failed to reserve memory for node 'drm-logo@00000000': base 0x0000000000000000, size 0 MiB
[    1.480606] kernel: OF: fdt: Reserved memory: failed to reserve memory for node 'drm-cubic-lut@00000000': base 0x0000000000000000, size 0 MiB
[    1.480772] kernel: Reserved memory: created CMA memory pool at 0x00000001fe000000, size 32 MiB
[    1.480779] kernel: OF: reserved mem: initialized node cma, compatible id shared-dma-pool
[    1.480857] kernel: Reserved memory: created CMA memory pool at 0x00000001de000000, size 512 MiB
[    1.480864] kernel: OF: reserved mem: initialized node rknpu, compatible id shared-dma-pool
[    1.692982] kernel: Zone ranges:
[    1.692996] kernel:   DMA      [mem 0x0000000000200000-0x00000000ffffffff]
[    1.693013] kernel:   DMA32    empty
[    1.693021] kernel:   Normal   [mem 0x0000000100000000-0x00000001ffffffff]
[    1.693031] kernel: Movable zone start for each node
[    1.693035] kernel: Early memory node ranges
[    1.693042] kernel:   node   0: [mem 0x0000000000200000-0x00000000efffffff]
[    1.693054] kernel:   node   0: [mem 0x0000000100000000-0x00000001ffffffff]
[    1.693065] kernel: Initmem setup node 0 [mem 0x0000000000200000-0x00000001ffffffff]
[    1.693074] kernel: On node 0 totalpages: 2031104
[    1.693082] kernel:   DMA zone: 15352 pages used for memmap
[    1.693087] kernel:   DMA zone: 0 pages reserved
[    1.693094] kernel:   DMA zone: 982528 pages, LIFO batch:63
[    1.693101] kernel:   Normal zone: 16384 pages used for memmap
[    1.693107] kernel:   Normal zone: 1048576 pages, LIFO batch:63
[    1.760261] kernel: psci: probing for conduit method from DT.
[    1.760285] kernel: psci: PSCIv1.1 detected in firmware.
[    1.760291] kernel: psci: Using standard PSCI v0.2 function IDs
[    1.760301] kernel: psci: MIGRATE_INFO_TYPE not supported.
[    1.760310] kernel: psci: SMC Calling Convention v1.2
[    1.760838] kernel: percpu: Embedded 32 pages/cpu s92504 r8192 d30376 u131072
[    1.760892] kernel: pcpu-alloc: s92504 r8192 d30376 u131072 alloc=32*4096
[    1.760904] kernel: pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    1.761055] kernel: Detected VIPT I-cache on CPU0
[    1.761131] kernel: CPU features: detected: GIC system register CPU interface
[    1.761139] kernel: CPU features: detected: Virtualization Host Extensions
[    1.761155] kernel: CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    1.761176] kernel: alternatives: patching kernel code
[    1.761786] kernel: Built 1 zonelists, mobility grouping on.  Total pages: 1999368
[    1.761803] kernel: Kernel command line: root=UUID=99afbffd-df32-4603-bd9a-5bc5ef2c2148 rootwait rootfstype=ext4 splash plymouth.ignore-serial-consoles console=ttyFIQ0 console=tty1 consoleblank=0 loglevel=1 ubootpart=e4caba4b-ae0a-b440-b218-45acb356bc04 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 earlycon=uart8250,mmio32,0xfe660000
[    1.765386] kernel: Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    1.766711] kernel: Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    1.766723] kernel: mem auto-init: stack:off, heap alloc:off, heap free:off
[    1.788029] kernel: software IO TLB: mapped [mem 0x00000000ec000000-0x00000000f0000000] (64MB)
[    1.925397] kernel: Memory: 7294596K/8124416K available (16960K kernel code, 3576K rwdata, 6516K rodata, 7040K init, 630K bss, 272764K reserved, 557056K cma-reserved)
[    1.925616] kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    1.925669] kernel: ftrace: allocating 64426 entries in 252 pages
[    2.076281] kernel: ftrace: allocated 252 pages with 6 groups
[    2.076747] kernel: rcu: Hierarchical RCU implementation.
[    2.076757] kernel: rcu:         RCU event tracing is enabled.
[    2.076764] kernel: rcu:         RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    2.076771] kernel:         Rude variant of Tasks RCU enabled.
[    2.076776] kernel:         Tracing variant of Tasks RCU enabled.
[    2.076783] kernel: rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[    2.076789] kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    2.085514] kernel: NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    2.088427] kernel: GICv3: GIC: Using split EOI/Deactivate mode
[    2.088444] kernel: GICv3: 320 SPIs implemented
[    2.088450] kernel: GICv3: 0 Extended SPIs implemented
[    2.088508] kernel: GICv3: Distributor has no Range Selector support
[    2.088524] kernel: GICv3: 16 PPIs implemented
[    2.088572] kernel: GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000
[    2.088782] kernel: ITS [mem 0xfd440000-0xfd45ffff]
[    2.088899] kernel: ITS@0x00000000fd440000: allocated 8192 Devices @2810000 (indirect, esz 8, psz 64K, shr 0)
[    2.088959] kernel: ITS@0x00000000fd440000: allocated 32768 Interrupt Collections @2820000 (flat, esz 2, psz 64K, shr 0)
[    2.088974] kernel: ITS: using cache flushing for cmd queue
[    2.089547] kernel: GICv3: using LPI property table @0x0000000002830000
[    2.089718] kernel: GIC: using cache flushing for LPI property table
[    2.089733] kernel: GICv3: CPU0: using allocated LPI pending table @0x0000000002840000
[    2.138237] kernel: arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    2.138257] kernel: clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    2.138274] kernel: sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    2.140161] kernel: Console: colour dummy device 80x25
[    2.140178] kernel: printk: console [tty1] enabled
[    2.140186] kernel: printk: bootconsole [uart8250] disabled
[    2.140233] kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[    2.140250] kernel: pid_max: default: 32768 minimum: 301
[    2.140417] kernel: LSM: Security Framework initializing
[    2.140543] kernel: Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    2.140594] kernel: Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    2.143865] kernel: rcu: Hierarchical SRCU implementation.
[    2.145266] kernel: Platform MSI: interrupt-controller@fd440000 domain created
[    2.145933] kernel: PCI/MSI: /interrupt-controller@fd400000/interrupt-controller@fd440000 domain created
[    2.146462] kernel: EFI services will not be available.
[    2.147124] kernel: smp: Bringing up secondary CPUs ...
[    2.148407] kernel: Detected VIPT I-cache on CPU1
[    2.148468] kernel: GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[    2.148501] kernel: GICv3: CPU1: using allocated LPI pending table @0x0000000002850000
[    2.148575] kernel: CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[    2.149903] kernel: Detected VIPT I-cache on CPU2
[    2.149952] kernel: GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[    2.149979] kernel: GICv3: CPU2: using allocated LPI pending table @0x0000000002860000
[    2.150033] kernel: CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[    2.151410] kernel: Detected VIPT I-cache on CPU3
[    2.151457] kernel: GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000
[    2.151485] kernel: GICv3: CPU3: using allocated LPI pending table @0x0000000002870000
[    2.151537] kernel: CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[    2.151734] kernel: smp: Brought up 1 node, 4 CPUs
[    2.151754] kernel: SMP: Total of 4 processors activated.
[    2.151762] kernel: CPU features: detected: Privileged Access Never
[    2.151769] kernel: CPU features: detected: User Access Override
[    2.151776] kernel: CPU features: detected: 32-bit EL0 Support
[    2.151782] kernel: CPU features: detected: Common not Private translations
[    2.151788] kernel: CPU features: detected: RAS Extension Support
[    2.151794] kernel: CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    2.151801] kernel: CPU features: detected: CRC32 instructions
[    2.151806] kernel: CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    2.151815] kernel: CPU features: detected: 32-bit EL1 Support
[    2.151821] kernel: CPU features: detected: RCpc load-acquire (LDAPR)
[    2.151948] kernel: CPU: All CPU(s) started at EL2
[    2.156803] kernel: devtmpfs: initialized
[    2.199081] kernel: Registered cp15_barrier emulation handler
[    2.199106] kernel: Registered setend emulation handler
[    2.199122] kernel: KASLR disabled due to lack of seed
[    2.199413] kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    2.199439] kernel: futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    2.224993] kernel: pinctrl core: initialized pinctrl subsystem
[    2.225587] kernel: regulator-dummy: no parameters, enabled
[    2.226056] kernel: DMI not present or invalid.
[    2.227062] kernel: NET: Registered protocol family 16
[    2.230644] kernel: DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[    2.230844] kernel: DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    2.231011] kernel: audit: initializing netlink subsys (disabled)
[    2.231378] kernel: audit: type=2000 audit(0.089:1): state=initialized audit_enabled=0 res=1
[    2.235679] kernel: Registered FIQ tty driver
[    2.236365] kernel: thermal_sys: Registered thermal governor 'fair_share'
[    2.236375] kernel: thermal_sys: Registered thermal governor 'step_wise'
[    2.236382] kernel: thermal_sys: Registered thermal governor 'user_space'
[    2.236388] kernel: thermal_sys: Registered thermal governor 'power_allocator'
[    2.237052] kernel: cpuidle: using governor menu
[    2.237948] kernel: hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    2.238189] kernel: ASID allocator initialised with 65536 entries
[    2.241905] kernel: ramoops: dmesg-0        0x20000@0x0000000000110000
[    2.241963] kernel: ramoops: console        0x80000@0x0000000000130000
[    2.241999] kernel: ramoops: pmsg        0x50000@0x00000000001b0000
[    2.242149] kernel: printk: console [ramoops-1] enabled
[    2.242157] kernel: pstore: Registered ramoops as persistent store backend
[    2.242165] kernel: ramoops: using 0xf0000@0x110000, ecc: 0
[    2.310437] kernel: rockchip-gpio fdd60000.gpio0: probed /pinctrl/gpio0@fdd60000
[    2.311409] kernel: rockchip-gpio fe740000.gpio1: probed /pinctrl/gpio1@fe740000
[    2.312378] kernel: rockchip-gpio fe750000.gpio2: probed /pinctrl/gpio2@fe750000
[    2.313352] kernel: rockchip-gpio fe760000.gpio3: probed /pinctrl/gpio3@fe760000
[    2.314256] kernel: rockchip-gpio fe770000.gpio4: probed /pinctrl/gpio4@fe770000
[    2.314470] kernel: rockchip-pinctrl pinctrl: probed pinctrl
[    2.345506] kernel: HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    2.345523] kernel: HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    2.345532] kernel: HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    2.345541] kernel: HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    2.412601] kernel: raid6: neonx8   gen()  1364 MB/s
[    2.469447] kernel: raid6: neonx8   xor()  1087 MB/s
[    2.526304] kernel: raid6: neonx4   gen()  1406 MB/s
[    2.583164] kernel: raid6: neonx4   xor()  1071 MB/s
[    2.640039] kernel: raid6: neonx2   gen()  1272 MB/s
[    2.696888] kernel: raid6: neonx2   xor()   973 MB/s
[    2.753764] kernel: raid6: neonx1   gen()  1036 MB/s
[    2.810617] kernel: raid6: neonx1   xor()   805 MB/s
[    2.867489] kernel: raid6: int64x8  gen()   352 MB/s
[    2.924347] kernel: raid6: int64x8  xor()   234 MB/s
[    2.981204] kernel: raid6: int64x4  gen()   439 MB/s
[    3.038069] kernel: raid6: int64x4  xor()   243 MB/s
[    3.094936] kernel: raid6: int64x2  gen()   886 MB/s
[    3.151782] kernel: raid6: int64x2  xor()   481 MB/s
[    3.208676] kernel: raid6: int64x1  gen()   633 MB/s
[    3.265527] kernel: raid6: int64x1  xor()   342 MB/s
[    3.265535] kernel: raid6: using algorithm neonx4 gen() 1406 MB/s
[    3.265541] kernel: raid6: .... xor() 1071 MB/s, rmw enabled
[    3.265548] kernel: raid6: using neon recovery algorithm
[    3.267448] kernel: fiq_debugger fiq_debugger.0: IRQ fiq not found
[    3.267478] kernel: fiq_debugger fiq_debugger.0: IRQ wakeup not found
[    3.267494] kernel: fiq_debugger_probe: could not install nmi irq handler
[    3.267736] kernel: printk: console [ttyFIQ0] enabled
[    3.268057] kernel: Registered fiq debugger ttyFIQ0
[    3.268776] kernel: dc_5v: 5000 mV, enabled
[    3.269062] kernel: reg-fixed-voltage dc-5v: dc_5v supplying 5000000uV
[    3.269287] kernel: reg-fixed-voltage vcc3v3-sys: Looking up vin-supply from device tree
[    3.269306] kernel: vcc3v3_sys: supplied by dc_5v
[    3.269323] kernel: dc_5v: could not add device link regulator.2: -ENOENT
[    3.269419] kernel: vcc3v3_sys: 3300 mV, enabled
[    3.269661] kernel: reg-fixed-voltage vcc3v3-sys: vcc3v3_sys supplying 3300000uV
[    3.269858] kernel: reg-fixed-voltage vcc5v0-sys: Looking up vin-supply from device tree
[    3.269876] kernel: vcc5v0_sys: supplied by dc_5v
[    3.269891] kernel: dc_5v: could not add device link regulator.3: -ENOENT
[    3.269952] kernel: vcc5v0_sys: 5000 mV, enabled
[    3.270232] kernel: reg-fixed-voltage vcc5v0-sys: vcc5v0_sys supplying 5000000uV
[    3.270725] kernel: vcc5v0_host: no parameters, enabled
[    3.270978] kernel: reg-fixed-voltage vcc5v0-host-regulator: vcc5v0_host supplying 0uV
[    3.271172] kernel: reg-fixed-voltage vcc2v5-ddr: Looking up vin-supply from device tree
[    3.271190] kernel: vcc2v5_sys: supplied by vcc3v3_sys
[    3.271205] kernel: vcc3v3_sys: could not add device link regulator.5: -ENOENT
[    3.271278] kernel: vcc2v5_sys: 2500 mV, enabled
[    3.271549] kernel: reg-fixed-voltage vcc2v5-ddr: vcc2v5_sys supplying 2500000uV
[    3.271770] kernel: reg-fixed-voltage vcc3v3-vga: Looking up vin-supply from device tree
[    3.271788] kernel: vcc3v3_vga: supplied by vcc3v3_sys
[    3.271803] kernel: vcc3v3_sys: could not add device link regulator.6: -ENOENT
[    3.271870] kernel: vcc3v3_vga: at 3300 mV, enabled
[    3.272127] kernel: reg-fixed-voltage vcc3v3-vga: vcc3v3_vga supplying 0uV
[    3.273206] kernel: iommu: Default domain type: Translated
[    3.273560] kernel: rockchip-pm-domain fdd90000.power-management:power-controller: Looking up npu-supply from device tree
[    3.273596] kernel: rockchip-pm-domain fdd90000.power-management:power-controller: Looking up npu-supply property in node /power-management@fdd90000/power-controller failed
[    3.274864] kernel: rockchip-pm-domain fdd90000.power-management:power-controller: Looking up vpu-supply from device tree
[    3.274903] kernel: rockchip-pm-domain fdd90000.power-management:power-controller: Looking up vpu-supply property in node /power-management@fdd90000/power-controller failed
[    3.275442] kernel: rockchip-pm-domain fdd90000.power-management:power-controller: Looking up rga-supply from device tree
[    3.275477] kernel: rockchip-pm-domain fdd90000.power-management:power-controller: Looking up rga-supply property in node /power-management@fdd90000/power-controller failed
[    3.277226] kernel: rockchip-pm-domain fdd90000.power-management:power-controller: Looking up rkvenc-supply from device tree
[    3.277261] kernel: rockchip-pm-domain fdd90000.power-management:power-controller: Looking up rkvenc-supply property in node /power-management@fdd90000/power-controller failed
[    3.277819] kernel: rockchip-pm-domain fdd90000.power-management:power-controller: Looking up rkvdec-supply from device tree
[    3.277854] kernel: rockchip-pm-domain fdd90000.power-management:power-controller: Looking up rkvdec-supply property in node /power-management@fdd90000/power-controller failed
[    3.278926] kernel: vgaarb: loaded
[    3.279588] kernel: SCSI subsystem initialized
[    3.279653] kernel: libata version 3.00 loaded.
[    3.279947] kernel: usbcore: registered new interface driver usbfs
[    3.280020] kernel: usbcore: registered new interface driver hub
[    3.280083] kernel: usbcore: registered new device driver usb
[    3.280268] kernel: mc: Linux media interface: v0.10
[    3.280327] kernel: videodev: Linux video capture interface: v2.00
[    3.280468] kernel: pps_core: LinuxPPS API ver. 1 registered
[    3.280477] kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    3.280504] kernel: PTP clock support registered
[    3.281596] kernel: arm-scmi firmware:scmi: SCMI Notifications - Core Enabled.
[    3.281685] kernel: arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0
[    3.285094] kernel: Advanced Linux Sound Architecture Driver Initialized.
[    3.286046] kernel: Bluetooth: Core ver 2.22
[    3.286131] kernel: NET: Registered protocol family 31
[    3.286140] kernel: Bluetooth: HCI device and connection manager initialized
[    3.286158] kernel: Bluetooth: HCI socket layer initialized
[    3.286171] kernel: Bluetooth: L2CAP socket layer initialized
[    3.286200] kernel: Bluetooth: SCO socket layer initialized
[    3.286240] kernel: NetLabel: Initializing
[    3.286248] kernel: NetLabel:  domain hash size = 128
[    3.286252] kernel: NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    3.286354] kernel: NetLabel:  unlabeled traffic allowed by default
[    3.287178] kernel: rockchip-cpuinfo cpuinfo: SoC                : 35662000
[    3.287192] kernel: rockchip-cpuinfo cpuinfo: Serial                : 676aa02a4ca6d232
[    3.288885] kernel: clocksource: Switched to clocksource arch_sys_counter
[    4.393897] kernel: VFS: Disk quotas dquot_6.6.0
[    4.393990] kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    4.411225] kernel: NET: Registered protocol family 2
[    4.411769] kernel: IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    4.418778] kernel: tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[    4.418991] kernel: TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    4.419519] kernel: TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    4.420447] kernel: TCP: Hash tables configured (established 65536 bind 65536)
[    4.420835] kernel: MPTCP token hash table entries: 8192 (order: 5, 196608 bytes, linear)
[    4.421052] kernel: UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    4.421207] kernel: UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    4.421593] kernel: NET: Registered protocol family 1
[    4.422571] kernel: RPC: Registered named UNIX socket transport module.
[    4.422581] kernel: RPC: Registered udp transport module.
[    4.422588] kernel: RPC: Registered tcp transport module.
[    4.422593] kernel: RPC: Registered tcp NFSv4.1 backchannel transport module.
[    4.424163] kernel: PCI: CLS 0 bytes, default 64
[    4.425101] kernel: Trying to unpack rootfs image as initramfs...
[    5.294655] kernel: Freeing initrd memory: 15184K
[    5.298069] kernel: rockchip-thermal fe710000.tsadc: tsadc is probed successfully!
[    5.300364] kernel: hw perfevents: enabled with armv8_cortex_a55 PMU driver, 7 counters available
[    5.301740] kernel: kvm [1]: IPA Size Limit: 40 bits
[    5.301769] kernel: kvm [1]: GICv3: no GICV resource entry
[    5.301777] kernel: kvm [1]: disabling GICv2 emulation
[    5.301783] kernel: kvm [1]: GIC system register CPU interface enabled
[    5.302029] kernel: kvm [1]: vgic interrupt IRQ9
[    5.302395] kernel: kvm [1]: VHE mode initialized successfully
[    5.309677] kernel: Initialise system trusted keyrings
[    5.309986] kernel: workingset: timestamp_bits=46 max_order=21 bucket_order=0
[    5.320107] kernel: NFS: Registering the id_resolver key type
[    5.320163] kernel: Key type id_resolver registered
[    5.320171] kernel: Key type id_legacy registered
[    5.320311] kernel: nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    5.320322] kernel: nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    5.320370] kernel: ntfs: driver 2.1.32 [Flags: R/W].
[    5.376312] kernel: NET: Registered protocol family 38
[    5.376335] kernel: xor: measuring software checksum speed
[    5.382714] kernel:    8regs           :  1554 MB/sec
[    5.387700] kernel:    32regs          :  1984 MB/sec
[    5.393798] kernel:    arm64_neon      :  1624 MB/sec
[    5.393807] kernel: xor: using function: 32regs (1984 MB/sec)
[    5.393825] kernel: Key type asymmetric registered
[    5.393833] kernel: Asymmetric key parser 'x509' registered
[    5.393898] kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[    5.394168] kernel: io scheduler mq-deadline registered
[    5.394189] kernel: io scheduler kyber registered
[    5.395325] kernel: rockchip-csi2-dphy-hw fe870000.csi2-dphy-hw: csi2 dphy hw probe successfully!
[    5.399066] kernel: phy phy-fe8a0000.usb2-phy.0: Looking up phy-supply from device tree
[    5.399106] kernel: vcc5v0_host: could not add device link phy-fe8a0000.usb2-phy.0: -ENOENT
[    5.399405] kernel: phy phy-fe8a0000.usb2-phy.1: Looking up phy-supply from device tree
[    5.399432] kernel: vcc5v0_host: could not add device link phy-fe8a0000.usb2-phy.1: -ENOENT
[    5.399715] kernel: phy phy-fe8a0000.usb2-phy.1: Looking up vbus-supply from device tree
[    5.399738] kernel: phy phy-fe8a0000.usb2-phy.1: Looking up vbus-supply property in node /usb2-phy@fe8a0000/otg-port failed
[    5.403768] kernel: phy phy-fe830000.phy.2: Looking up phy-supply from device tree
[    5.403795] kernel: phy phy-fe830000.phy.2: Looking up phy-supply property in node /phy@fe830000 failed
[    5.404444] kernel: phy phy-fe840000.phy.3: Looking up phy-supply from device tree
[    5.404466] kernel: phy phy-fe840000.phy.3: Looking up phy-supply property in node /phy@fe840000 failed
[    5.411002] kernel: iep: Module initialized.
[    5.411106] kernel: mpp_service mpp-srv: f421f8a9774d author: Yandong Lin 2023-09-21 video: rockchip: mpp: rkvenc2: fix slice mode poll failed
[    5.411116] kernel: mpp_service mpp-srv: probe start
[    5.414841] kernel: mpp_vepu2 fdee0000.vepu: Adding to iommu group 3
[    5.415268] kernel: mpp_vepu2 fdee0000.vepu: probing start
[    5.416168] kernel: mpp_vepu2 fdee0000.vepu: probing finish
[    5.416987] kernel: mpp-iep2 fdef0000.iep: Adding to iommu group 4
[    5.417304] kernel: mpp-iep2 fdef0000.iep: probe device
[    5.417736] kernel: mpp-iep2 fdef0000.iep: allocate roi buffer failed
[    5.418116] kernel: mpp-iep2 fdef0000.iep: probing finish
[    5.418791] kernel: mpp_jpgdec fded0000.jpegd: Adding to iommu group 2
[    5.419150] kernel: mpp_jpgdec fded0000.jpegd: probe device
[    5.419929] kernel: mpp_jpgdec fded0000.jpegd: probing finish
[    5.422318] kernel: mpp_service mpp-srv: probe success
[    5.429858] kernel: dma-pl330 fe530000.dmac: Loaded driver for PL330 DMAC-241330
[    5.429877] kernel: dma-pl330 fe530000.dmac:         DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    5.433464] kernel: dma-pl330 fe550000.dmac: Loaded driver for PL330 DMAC-241330
[    5.433479] kernel: dma-pl330 fe550000.dmac:         DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    5.434240] kernel: rockchip-pvtm fde00000.pvtm: pvtm@0 probed
[    5.434504] kernel: rockchip-pvtm fde80000.pvtm: pvtm@1 probed
[    5.434720] kernel: rockchip-pvtm fde90000.pvtm: pvtm@2 probed
[    5.435981] kernel: rockchip-system-monitor rockchip-system-monitor: system monitor probe
[    5.436959] kernel: arm-scmi firmware:scmi: Failed. SCMI protocol 22 not active.
[    5.437377] kernel: Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[    5.438759] kernel: fe650000.serial: ttyS1 at MMIO 0xfe650000 (irq = 56, base_baud = 1500000) is a 16550A
[    5.442536] kernel: led_vk2c21_init
[    5.442778] kernel: random: crng init done
[    5.444246] kernel: rockchip-vop2 fe040000.vop: Adding to iommu group 7
[    5.456445] kernel: [drm] all windows should be assigned, full plane mask: 0x3f, current plane mask: 0x0
[    5.456456] kernel: [drm] use default plane mask
[    5.456794] kernel: [drm] RK3566 only support 2 vps
[    5.456853] kernel: rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x15, primary plane phy id: 4
[    5.456868] kernel: rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp1 assign plane mask: 0x22, primary plane phy id: 5
[    5.456881] kernel: rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x8, primary plane phy id: 3
[    5.457509] kernel: [drm] failed to init overlay plane Cluster0-win1
[    5.457600] kernel: [drm] failed to init overlay plane Cluster1-win1
[    5.457920] kernel: rockchip-drm display-subsystem: bound fe040000.vop (ops 0xffff8000091d3a70)
[    5.458321] kernel: dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[    5.459337] kernel: dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver
[    5.459662] kernel: dwhdmi-rockchip fe0a0000.hdmi: IRQ index 1 not found
[    5.460358] kernel: rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops 0xffff8000091e1cf8)
[    5.461290] kernel: rockchip-drm display-subsystem: failed to parse loader memory
[    5.661454] kernel: rockchip-vop2 fe040000.vop: [drm:vop2_crtc_atomic_enable] Update mode to 3840x2160p60, type: 11(if:800, flag:0x0) for vp0 dclk: 594000000
[    5.995276] kernel: Console: switching to colour frame buffer device 480x135
[    6.162514] kernel: rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device
[    6.164163] kernel: [drm] Initialized rockchip 3.0.0 20140818 for display-subsystem on minor 0
[    6.173174] kernel: input: hdmi_cec_key as /devices/platform/fe0a0000.hdmi/dw-hdmi-cec.1.auto/input/input0
[    6.174639] kernel: cacheinfo: Unable to detect cache hierarchy for CPU 0
[    6.175901] kernel: brd: module loaded
[    6.185519] kernel: loop: module loaded
[    6.186322] kernel: zram: Added device: zram0
[    6.186770] kernel: lkdtm: No crash points registered, enable through debugfs
[    6.187206] kernel: system_heap: orders[0] = 6
[    6.187215] kernel: system_heap: orders[1] = 4
[    6.187220] kernel: system_heap: orders[2] = 0
[    6.195809] kernel: rk_gmac-dwmac fe010000.ethernet: IRQ eth_lpi not found
[    6.196150] kernel: rk_gmac-dwmac fe010000.ethernet: Looking up phy-supply from device tree
[    6.196185] kernel: rk_gmac-dwmac fe010000.ethernet: Looking up phy-supply property in node /ethernet@fe010000 failed
[    6.196211] kernel: rk_gmac-dwmac fe010000.ethernet: no regulator found
[    6.196222] kernel: rk_gmac-dwmac fe010000.ethernet: clock input or output? (input).
[    6.196233] kernel: rk_gmac-dwmac fe010000.ethernet: TX delay(0x4e).
[    6.196243] kernel: rk_gmac-dwmac fe010000.ethernet: RX delay(0x2c).
[    6.196273] kernel: rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no).
[    6.196334] kernel: rk_gmac-dwmac fe010000.ethernet: clock input from PHY
[    6.196607] kernel: rk_gmac-dwmac fe010000.ethernet: init for RGMII
[    6.196992] kernel: rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[    6.197009] kernel: rk_gmac-dwmac fe010000.ethernet:         DWMAC4/5
[    6.197021] kernel: rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported
[    6.197030] kernel: rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported
[    6.197037] kernel: rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported
[    6.197044] kernel: rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported
[    6.197159] kernel: rk_gmac-dwmac fe010000.ethernet: TSO supported
[    6.197170] kernel: rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    6.197180] kernel: rk_gmac-dwmac fe010000.ethernet: TSO feature enabled
[    6.197189] kernel: rk_gmac-dwmac fe010000.ethernet: Using 32 bits DMA width
[    6.346186] kernel: usbcore: registered new interface driver rndis_wlan
[    6.346276] kernel: usbcore: registered new interface driver asix
[    6.346342] kernel: usbcore: registered new interface driver cdc_ether
[    6.346400] kernel: usbcore: registered new interface driver rndis_host
[    6.346478] kernel: usbcore: registered new interface driver cdc_ncm
[    6.358769] kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    6.358816] kernel: ehci-pci: EHCI PCI platform driver
[    6.358988] kernel: ehci-platform: EHCI generic platform driver
[    6.359378] kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    6.359410] kernel: ohci-platform: OHCI generic platform driver
[    6.360329] kernel: xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
[    6.360368] kernel: xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 1
[    6.360608] kernel: xhci-hcd xhci-hcd.4.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000002022010010
[    6.360699] kernel: xhci-hcd xhci-hcd.4.auto: irq 69, io mem 0xfcc00000
[    6.361640] kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    6.361655] kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.361664] kernel: usb usb1: Product: xHCI Host Controller
[    6.361673] kernel: usb usb1: Manufacturer: Linux 5.10.160-legacy-rk35xx xhci-hcd
[    6.361682] kernel: usb usb1: SerialNumber: xhci-hcd.4.auto
[    6.362589] kernel: hub 1-0:1.0: USB hub found
[    6.362666] kernel: hub 1-0:1.0: 1 port detected
[    6.363239] kernel: xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
[    6.363267] kernel: xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 2
[    6.363294] kernel: xhci-hcd xhci-hcd.4.auto: Host supports USB 3.0 SuperSpeed
[    6.363446] kernel: usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    6.363731] kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[    6.363745] kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.363755] kernel: usb usb2: Product: xHCI Host Controller
[    6.363763] kernel: usb usb2: Manufacturer: Linux 5.10.160-legacy-rk35xx xhci-hcd
[    6.363771] kernel: usb usb2: SerialNumber: xhci-hcd.4.auto
[    6.364520] kernel: hub 2-0:1.0: USB hub found
[    6.364588] kernel: hub 2-0:1.0: 1 port detected
[    6.365496] kernel: xhci-hcd xhci-hcd.5.auto: xHCI Host Controller
[    6.365584] kernel: xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 3
[    6.365802] kernel: xhci-hcd xhci-hcd.5.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000200002010010
[    6.365893] kernel: xhci-hcd xhci-hcd.5.auto: irq 70, io mem 0xfd000000
[    6.366481] kernel: usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    6.366494] kernel: usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.366503] kernel: usb usb3: Product: xHCI Host Controller
[    6.366511] kernel: usb usb3: Manufacturer: Linux 5.10.160-legacy-rk35xx xhci-hcd
[    6.366520] kernel: usb usb3: SerialNumber: xhci-hcd.5.auto
[    6.367259] kernel: hub 3-0:1.0: USB hub found
[    6.367347] kernel: hub 3-0:1.0: 1 port detected
[    6.367919] kernel: xhci-hcd xhci-hcd.5.auto: xHCI Host Controller
[    6.367946] kernel: xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 4
[    6.367970] kernel: xhci-hcd xhci-hcd.5.auto: Host supports USB 3.0 SuperSpeed
[    6.368117] kernel: usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    6.368395] kernel: usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[    6.368409] kernel: usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.368418] kernel: usb usb4: Product: xHCI Host Controller
[    6.368426] kernel: usb usb4: Manufacturer: Linux 5.10.160-legacy-rk35xx xhci-hcd
[    6.368434] kernel: usb usb4: SerialNumber: xhci-hcd.5.auto
[    6.369209] kernel: hub 4-0:1.0: USB hub found
[    6.369279] kernel: hub 4-0:1.0: 1 port detected
[    6.370059] kernel: usbcore: registered new interface driver cdc_acm
[    6.370068] kernel: cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    6.370497] kernel: usbcore: registered new interface driver uas
[    6.370661] kernel: usbcore: registered new interface driver usb-storage
[    6.373081] kernel: Error: Driver 'Goodix-TS' is already registered, aborting...
[    6.373215] kernel: usbcore: registered new interface driver usbtouchscreen
[    6.374253] kernel: i2c /dev entries driver
[    6.377570] kernel: fan53555-regulator 0-001c: FAN53555 Option[12] Rev[15] Detected!
[    6.379076] kernel: fan53555-regulator 0-001c: Looking up vin-supply from device tree
[    6.379431] kernel: vdd_cpu: supplied by vcc5v0_sys
[    6.379452] kernel: vcc5v0_sys: could not add device link regulator.7: -ENOENT
[    6.382456] kernel: vdd_cpu: 800 <--> 1200 mV at 900 mV, enabled
[    6.388121] kernel: rk808 0-0020: chip id: 0x8090
[    6.388190] kernel: rk808 0-0020: No cache defaults, reading back from HW
[    6.412023] kernel: rk808 0-0020: source: on=0x40, off=0x00
[    6.412044] kernel: rk808 0-0020: support dcdc3 fb mode:-22, 1
[    6.412057] kernel: rk808 0-0020: support pmic reset mode:0,0
[    6.418815] kernel: rk808-regulator rk808-regulator: there is no dvs0 gpio
[    6.418933] kernel: rk808-regulator rk808-regulator: there is no dvs1 gpio
[    6.419058] kernel: rk808 0-0020: Looking up vcc1-supply from device tree
[    6.419085] kernel: vdd_logic: supplied by vcc3v3_sys
[    6.419110] kernel: vcc3v3_sys: could not add device link regulator.8: -ENOENT
[    6.419639] kernel: vdd_logic: 800 <--> 1100 mV at 900 mV, enabled
[    6.420061] kernel: rk808 0-0020: Looking up vcc2-supply from device tree
[    6.420080] kernel: vdd_gpu: supplied by vcc3v3_sys
[    6.420095] kernel: vcc3v3_sys: could not add device link regulator.9: -ENOENT
[    6.420578] kernel: vdd_gpu: 800 <--> 1350 mV at 900 mV, enabled
[    6.420952] kernel: rk808 0-0020: Looking up vcc3-supply from device tree
[    6.420971] kernel: vcc_ddr: supplied by vcc3v3_sys
[    6.420986] kernel: vcc3v3_sys: could not add device link regulator.10: -ENOENT
[    6.421430] kernel: vcc_ddr: at 500 mV, enabled
[    6.421842] kernel: rk808 0-0020: Looking up vcc4-supply from device tree
[    6.421860] kernel: vdd_npu: supplied by vcc3v3_sys
[    6.421875] kernel: vcc3v3_sys: could not add device link regulator.11: -ENOENT
[    6.422333] kernel: vdd_npu: 800 <--> 1350 mV at 900 mV, enabled
[    6.422746] kernel: rk808 0-0020: Looking up vcc9-supply from device tree
[    6.422764] kernel: vcc_1v8: supplied by vcc3v3_sys
[    6.422780] kernel: vcc3v3_sys: could not add device link regulator.12: -ENOENT
[    6.423214] kernel: vcc_1v8: 1800 mV, enabled
[    6.423575] kernel: rk808 0-0020: Looking up vcc5-supply from device tree
[    6.423593] kernel: vdda0v9_image: supplied by vcc3v3_sys
[    6.423608] kernel: vcc3v3_sys: could not add device link regulator.13: -ENOENT
[    6.424611] kernel: vdda0v9_image: 900 mV, enabled
[    6.425004] kernel: rk808 0-0020: Looking up vcc5-supply from device tree
[    6.425024] kernel: vdda_0v9: supplied by vcc3v3_sys
[    6.425039] kernel: vcc3v3_sys: could not add device link regulator.14: -ENOENT
[    6.426016] kernel: vdda_0v9: 900 mV, enabled
[    6.426404] kernel: rk808 0-0020: Looking up vcc5-supply from device tree
[    6.426423] kernel: vdda0v9_pmu: supplied by vcc3v3_sys
[    6.426438] kernel: vcc3v3_sys: could not add device link regulator.15: -ENOENT
[    6.427416] kernel: vdda0v9_pmu: 900 mV, enabled
[    6.427782] kernel: vccio_acodec: No configuration
[    6.427799] kernel: rk808 0-0020: Looking up vcc6-supply from device tree
[    6.427815] kernel: vccio_acodec: supplied by vcc3v3_sys
[    6.427829] kernel: vcc3v3_sys: could not add device link regulator.16: -ENOENT
[    6.427910] kernel: vccio_acodec: No configuration
[    6.428837] kernel: vccio_acodec: 3300 mV, enabled
[    6.429236] kernel: rk808 0-0020: Looking up vcc6-supply from device tree
[    6.429255] kernel: vccio_sd: supplied by vcc3v3_sys
[    6.429270] kernel: vcc3v3_sys: could not add device link regulator.17: -ENOENT
[    6.430263] kernel: vccio_sd: 1800 <--> 3300 mV at 3300 mV, enabled
[    6.430656] kernel: rk808 0-0020: Looking up vcc6-supply from device tree
[    6.430674] kernel: vcc3v3_pmu: supplied by vcc3v3_sys
[    6.430690] kernel: vcc3v3_sys: could not add device link regulator.18: -ENOENT
[    6.431676] kernel: vcc3v3_pmu: 3300 mV, enabled
[    6.432038] kernel: rk808 0-0020: Looking up vcc7-supply from device tree
[    6.432057] kernel: vcca_1v8: supplied by vcc3v3_sys
[    6.432072] kernel: vcc3v3_sys: could not add device link regulator.19: -ENOENT
[    6.433070] kernel: vcca_1v8: 1800 mV, enabled
[    6.433448] kernel: rk808 0-0020: Looking up vcc7-supply from device tree
[    6.433467] kernel: vcca1v8_pmu: supplied by vcc3v3_sys
[    6.433490] kernel: vcc3v3_sys: could not add device link regulator.20: -ENOENT
[    6.434467] kernel: vcca1v8_pmu: 1800 mV, enabled
[    6.434872] kernel: rk808 0-0020: Looking up vcc7-supply from device tree
[    6.434892] kernel: vcca1v8_image: supplied by vcc3v3_sys
[    6.434907] kernel: vcc3v3_sys: could not add device link regulator.21: -ENOENT
[    6.435887] kernel: vcca1v8_image: 1800 mV, enabled
[    6.436255] kernel: rk808 0-0020: Looking up vcc9-supply from device tree
[    6.436273] kernel: vcc_3v3: supplied by vcc3v3_sys
[    6.436288] kernel: vcc3v3_sys: could not add device link regulator.22: -ENOENT
[    6.436748] kernel: vcc_3v3: at 3300 mV, enabled
[    6.437093] kernel: rk808 0-0020: Looking up vcc8-supply from device tree
[    6.437111] kernel: vcc3v3_sd: supplied by vcc3v3_sys
[    6.437126] kernel: vcc3v3_sys: could not add device link regulator.23: -ENOENT
[    6.437563] kernel: vcc3v3_sd: at 3300 mV, enabled
[    6.437927] kernel: rk817-battery: Failed to locate of_node [id: -1]
[    6.438154] kernel: rk817-battery rk817-battery: Failed to find matching dt id
[    6.438339] kernel: rk817-charger: Failed to locate of_node [id: -1]
[    6.438524] kernel: rk817-charger rk817-charger: Failed to find matching dt id
[    6.442102] kernel: input: rk805 pwrkey as /devices/platform/fdd40000.i2c/i2c-0/0-0020/rk805-pwrkey/input/input1
[    6.449426] kernel: rk808-rtc rk808-rtc: registered as rtc0
[    6.451253] kernel: rk808-rtc rk808-rtc: setting system clock to 2024-05-25T19:53:38 UTC (1716666818)
[    6.457837] kernel: rockchip-mipi-csi2-hw fdfb0000.mipi-csi2-hw: enter mipi csi2 hw probe!
[    6.458117] kernel: rockchip-mipi-csi2-hw fdfb0000.mipi-csi2-hw: probe success, v4l2_dev:mipi-csi2-hw!
[    6.461192] kernel: usbcore: registered new interface driver uvcvideo
[    6.461201] kernel: USB Video Class driver (1.1.1)
[    6.464607] kernel: cpu cpu0: bin=0
[    6.464673] kernel: cpu cpu0: leakage=22
[    6.464730] kernel: cpu cpu0: pvtm = 85240, from nvmem
[    6.464756] kernel: cpu cpu0: pvtm-volt-sel=1
[    6.464833] kernel: cpu cpu0: soc version=0, speed=1
[    6.465214] kernel: cpu cpu0: Looking up cpu-supply from device tree
[    6.467391] kernel: cpu cpu0: avs=0
[    6.467607] kernel: cpu cpu0: EM: OPP:600000 is inefficient
[    6.467618] kernel: cpu cpu0: EM: OPP:408000 is inefficient
[    6.467888] kernel: cpu cpu0: EM: created perf domain
[    6.467984] kernel: cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=1608000000 h_limit=0 h_table=0
[    6.476029] kernel: sdhci: Secure Digital Host Controller Interface driver
[    6.476036] kernel: sdhci: Copyright(c) Pierre Ossman
[    6.476040] kernel: Synopsys Designware Multimedia Card Interface Driver
[    6.476524] kernel: sdhci-pltfm: SDHCI platform and OF driver helper
[    6.477264] kernel: dwmmc_rockchip fe2b0000.dwmmc: No normal pinctrl state
[    6.477273] kernel: dwmmc_rockchip fe2b0000.dwmmc: No idle pinctrl state
[    6.477399] kernel: dwmmc_rockchip fe2b0000.dwmmc: IDMAC supports 32-bit address mode.
[    6.477447] kernel: dwmmc_rockchip fe2b0000.dwmmc: Using internal DMA controller.
[    6.477451] kernel: dwmmc_rockchip fe2c0000.dwmmc: No normal pinctrl state
[    6.477457] kernel: dwmmc_rockchip fe2c0000.dwmmc: No idle pinctrl state
[    6.477461] kernel: dwmmc_rockchip fe2b0000.dwmmc: Version ID is 270a
[    6.477518] kernel: dwmmc_rockchip fe2b0000.dwmmc: DW MMC controller at irq 44,32 bit host data width,256 deep fifo
[    6.477562] kernel: dwmmc_rockchip fe2c0000.dwmmc: IDMAC supports 32-bit address mode.
[    6.477584] kernel: dwmmc_rockchip fe2c0000.dwmmc: Using internal DMA controller.
[    6.477595] kernel: dwmmc_rockchip fe2c0000.dwmmc: Version ID is 270a
[    6.477632] kernel: dwmmc_rockchip fe2b0000.dwmmc: Looking up vmmc-supply from device tree
[    6.477638] kernel: dwmmc_rockchip fe2c0000.dwmmc: DW MMC controller at irq 45,32 bit host data width,256 deep fifo
[    6.477651] kernel: dwmmc_rockchip fe2b0000.dwmmc: Looking up vmmc-supply property in node /dwmmc@fe2b0000 failed
[    6.477691] kernel: dwmmc_rockchip fe2b0000.dwmmc: Looking up vqmmc-supply from device tree
[    6.477717] kernel: dwmmc_rockchip fe2c0000.dwmmc: Looking up vmmc-supply from device tree
[    6.477884] kernel: dwmmc_rockchip fe2c0000.dwmmc: Looking up vqmmc-supply from device tree
[    6.478282] kernel: dwmmc_rockchip fe2c0000.dwmmc: allocated mmc-pwrseq
[    6.478290] kernel: mmc_host mmc2: card is non-removable.
[    6.478555] kernel: sdhci-dwcmshc fe310000.sdhci: Looking up vmmc-supply from device tree
[    6.478568] kernel: sdhci-dwcmshc fe310000.sdhci: Looking up vmmc-supply property in node /sdhci@fe310000 failed
[    6.478594] kernel: sdhci-dwcmshc fe310000.sdhci: Looking up vqmmc-supply from device tree
[    6.478602] kernel: sdhci-dwcmshc fe310000.sdhci: Looking up vqmmc-supply property in node /sdhci@fe310000 failed
[    6.479013] kernel: ledtrig-cpu: registered to indicate activity on CPUs
[    6.479062] kernel: arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
[    6.479131] kernel: SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    6.480024] kernel: cryptodev: driver 1.12 loaded.
[    6.480079] kernel: hid: raw HID events driver (C) Jiri Kosina
[    6.480341] kernel: usbcore: registered new interface driver usbhid
[    6.480345] kernel: usbhid: USB HID core driver
[    6.480612] kernel: ashmem: initialized
[    6.480906] kernel: rockchip,bus bus-npu: Looking up bus-supply from device tree
[    6.481088] kernel: rockchip,bus bus-npu: bin=0
[    6.481098] kernel: rockchip,bus bus-npu: Failed to get leakage
[    6.481153] kernel: rockchip,bus bus-npu: pvtm = 85240, from nvmem
[    6.481164] kernel: rockchip,bus bus-npu: pvtm-volt-sel=1
[    6.481390] kernel: rockchip,bus bus-npu: avs=0
[    6.484916] kernel: rockchip-saradc fe720000.saradc: Looking up vref-supply from device tree
[    6.486122] kernel: optee: probing for conduit method.
[    6.486133] kernel: optee: api uid mismatch
[    6.486146] kernel: optee: probe of firmware:optee failed with error -22
[    6.486907] kernel: usbcore: registered new interface driver snd-usb-audio
[    6.488721] kernel: rk817-codec rk817-codec: DMA mask not set
[    6.489378] kernel: mmc_host mmc1: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[    6.494180] kernel: rk-multicodecs rk809-sound: Failed to get ADC channel
[    6.494325] kernel: rk-multicodecs rk809-sound: ASoC: Property 'rockchip,audio-routing' does not exist or its length is not even
[    6.494330] kernel: rk-multicodecs rk809-sound: Audio routing invalid/unspecified
[    6.495483] kernel: rk817-codec rk817-codec: rk817_probe: chip_name:0x80, chip_ver:0x94
[    6.499754] kernel: rk-multicodecs rk809-sound: Don't need to map headset detect gpio to irq
[    6.502270] kernel: Initializing XFRM netlink socket
[    6.502293] kernel: NET: Registered protocol family 17
[    6.502615] kernel: [BT_RFKILL]: Enter rfkill_rk_init
[    6.502619] kernel: [WLAN_RFKILL]: Enter rfkill_wlan_init
[    6.502991] kernel: [WLAN_RFKILL]: Enter rfkill_wlan_probe
[    6.503026] kernel: [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6356s
[    6.503030] kernel: [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[    6.503033] kernel: [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[    6.503060] kernel: [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[    6.503063] kernel: [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[    6.503070] kernel: [WLAN_RFKILL]: rfkill_set_wifi_bt_power: 1
[    6.503074] kernel: [WLAN_RFKILL]: Exit rfkill_wlan_probe
[    6.503425] kernel: Key type dns_resolver registered
[    6.504879] kernel: registered taskstats version 1
[    6.504892] kernel: Loading compiled-in X.509 certificates
[    6.505841] kernel: Btrfs loaded, crc32c=crc32c-generic
[    6.506087] kernel: pstore: Using crash dump compression: deflate
[    6.507175] kernel: rga: rga2, irq = 26, match scheduler
[    6.507793] kernel: rga: rga2 hardware loaded successfully, hw_version:3.2.63318.
[    6.507820] kernel: rga: rga2 probe successfully
[    6.508150] kernel: rga_iommu: IOMMU binding successfully, default mapping core[0x4]
[    6.508471] kernel: rga: Module initialized. v1.3.0
[    6.508945] kernel: mmc0: SDHCI controller on fe310000.sdhci [fe310000.sdhci] using ADMA
[    6.543939] kernel: mmc0: Host Software Queue enabled
[    6.543971] kernel: mmc0: new HS200 MMC card at address 0001
[    6.545093] kernel: mmcblk0: mmc0:0001 CJNB4R 58.2 GiB
[    6.545410] kernel: mmcblk0boot0: mmc0:0001 CJNB4R partition 1 4.00 MiB
[    6.545805] kernel: mmcblk0boot1: mmc0:0001 CJNB4R partition 2 4.00 MiB
[    6.546118] kernel: mmcblk0rpmb: mmc0:0001 CJNB4R partition 3 4.00 MiB, chardev (237:0)
[    6.550451] kernel:  mmcblk0: p1 p2
[    6.612477] kernel: usb 1-1: new full-speed USB device number 2 using xhci-hcd
[    6.615018] kernel: vendor storage:20190527 ret = 0
[    6.696538] kernel: mmc_host mmc2: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[    6.712357] kernel: mpp_vdpu2 fdea0400.vdpu: Adding to iommu group 1
[    6.712913] kernel: mpp_vdpu2 fdea0400.vdpu: probe device
[    6.715084] kernel: mpp_vdpu2 fdea0400.vdpu: probing finish
[    6.716194] kernel: mpp_rkvenc fdf40000.rkvenc: Adding to iommu group 5
[    6.716784] kernel: mpp_rkvenc fdf40000.rkvenc: probing start
[    6.717564] kernel: mpp_rkvenc fdf40000.rkvenc: Looking up venc-supply from device tree
[    6.718151] kernel: mpp_rkvenc fdf40000.rkvenc: bin=0
[    6.718189] kernel: mpp_rkvenc fdf40000.rkvenc: Failed to get leakage
[    6.718334] kernel: mpp_rkvenc fdf40000.rkvenc: pvtm = 85240, from nvmem
[    6.718378] kernel: mpp_rkvenc fdf40000.rkvenc: pvtm-volt-sel=1
[    6.719145] kernel: mpp_rkvenc fdf40000.rkvenc: avs=0
[    6.719571] kernel: mpp_rkvenc fdf40000.rkvenc: failed to find power_model node
[    6.719597] kernel: mpp_rkvenc fdf40000.rkvenc: failed to initialize power model
[    6.719614] kernel: mpp_rkvenc fdf40000.rkvenc: failed to get dynamic-coefficient
[    6.722149] kernel: mpp_rkvenc fdf40000.rkvenc: probing finish
[    6.723457] kernel: mpp_rkvdec2 fdf80200.rkvdec: Adding to iommu group 6
[    6.724031] kernel: mpp_rkvdec2 fdf80200.rkvdec: rkvdec, probing start
[    6.724370] kernel: mpp_rkvdec2 fdf80200.rkvdec: shared_niu_a is not found!
[    6.724376] kernel: rkvdec2_init:1022: No niu aclk reset resource define
[    6.724383] kernel: mpp_rkvdec2 fdf80200.rkvdec: shared_niu_h is not found!
[    6.724386] kernel: rkvdec2_init:1025: No niu hclk reset resource define
[    6.724410] kernel: mpp_rkvdec2 fdf80200.rkvdec: Looking up vdec-supply from device tree
[    6.724590] kernel: mpp_rkvdec2 fdf80200.rkvdec: bin=0
[    6.724691] kernel: mpp_rkvdec2 fdf80200.rkvdec: leakage=49
[    6.724701] kernel: mpp_rkvdec2 fdf80200.rkvdec: leakage-volt-sel=0
[    6.724734] kernel: mpp_rkvdec2 fdf80200.rkvdec: pvtm = 85240, from nvmem
[    6.724743] kernel: mpp_rkvdec2 fdf80200.rkvdec: pvtm-volt-sel=1
[    6.724918] kernel: mpp_rkvdec2 fdf80200.rkvdec: avs=0
[    6.725036] kernel: mpp_rkvdec2 fdf80200.rkvdec: failed to find power_model node
[    6.725041] kernel: mpp_rkvdec2 fdf80200.rkvdec: failed to initialize power model
[    6.725045] kernel: mpp_rkvdec2 fdf80200.rkvdec: failed to get dynamic-coefficient
[    6.725161] kernel: mpp_rkvdec2 fdf80200.rkvdec: sram_start 0x00000000fdcc0000
[    6.725166] kernel: mpp_rkvdec2 fdf80200.rkvdec: rcb_iova 0x0000000010000000
[    6.725170] kernel: mpp_rkvdec2 fdf80200.rkvdec: sram_size 45056
[    6.725174] kernel: mpp_rkvdec2 fdf80200.rkvdec: rcb_size 65536
[    6.725179] kernel: mpp_rkvdec2 fdf80200.rkvdec: min_width 512
[    6.725229] kernel: mpp_rkvdec2 fdf80200.rkvdec: link mode probe finish
[    6.725301] kernel: mpp_rkvdec2 fdf80200.rkvdec: probing finish
[    6.726349] kernel: rockchip-pm-domain fdd90000.power-management:power-controller: Looking up gpu-supply from device tree
[    6.726432] kernel: rockchip-pm-domain fdd90000.power-management:power-controller: Looking up gpu-supply property in node /power-management@fdd90000/power-controller failed
[    6.726464] kernel: rockchip-dmc dmc: Looking up center-supply from device tree
[    6.726509] kernel: mali fde60000.gpu: Kernel DDK version g18p0-01eac0
[    6.726520] kernel: mali fde60000.gpu: IRQ JOB not found
[    6.726549] kernel: mali fde60000.gpu: IRQ MMU not found
[    6.726561] kernel: mali fde60000.gpu: IRQ GPU not found
[    6.726572] kernel: mali fde60000.gpu: Insufficient register space, will override to the required size
[    6.726583] kernel: mali fde60000.gpu: Register window unavailable
[    6.726587] kernel: mali fde60000.gpu: Failed to map registers
[    6.726591] kernel: mali fde60000.gpu: Register map failed error = -5
[    6.726595] kernel: mali fde60000.gpu: Device initialization failed
[    6.726610] kernel: rockchip-dmc dmc: Looking up center-supply from device tree
[    6.726629] kernel: vdd_logic: could not add device link dmc: -EEXIST
[    6.726633] kernel: vdd_logic: Failed to create debugfs directory
[    6.726673] kernel: mali: probe of fde60000.gpu failed with error -5
[    6.726811] kernel: rockchip-dmc dmc: bin=0
[    6.726846] kernel: rockchip-dmc dmc: leakage=49
[    6.726860] kernel: rockchip-dmc dmc: leakage-volt-sel=0
[    6.726892] kernel: rockchip-dmc dmc: pvtm = 85240, from nvmem
[    6.726903] kernel: rockchip-dmc dmc: pvtm-volt-sel=1
[    6.726915] kernel: rockchip-dmc dmc: soc version=0, speed=1
[    6.727088] kernel: rockchip-dmc dmc: avs=0
[    6.727104] kernel: rockchip-dmc dmc: current ATF version 0x102
[    6.727719] kernel: rockchip-dmc dmc: normal_rate = 780000000
[    6.727725] kernel: rockchip-dmc dmc: reboot_rate = 1056000000
[    6.727730] kernel: rockchip-dmc dmc: suspend_rate = 324000000
[    6.727735] kernel: rockchip-dmc dmc: video_4k_rate = 780000000
[    6.727739] kernel: rockchip-dmc dmc: video_4k_10b_rate = 780000000
[    6.727743] kernel: rockchip-dmc dmc: boost_rate = 1056000000
[    6.727748] kernel: rockchip-dmc dmc: fixed_rate(isp|cif0|cif1|dualview) = 1056000000
[    6.727753] kernel: rockchip-dmc dmc: performance_rate = 1056000000
[    6.727772] kernel: rockchip-dmc dmc: failed to get vop pn to msch rl
[    6.727937] kernel: rockchip-dmc dmc: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[    6.728004] kernel: rockchip-dmc dmc: could not find power_model node
[    6.729075] kernel: rockchip-iodomain fdc20000.syscon:io-domains: Looking up pmuio1-supply from device tree
[    6.729352] kernel: rockchip-iodomain fdc20000.syscon:io-domains: pmuio1(3300000 uV) supplied by vcc3v3_pmu
[    6.729360] kernel: rockchip-iodomain fdc20000.syscon:io-domains: Looking up pmuio2-supply from device tree
[    6.729416] kernel: rockchip-iodomain fdc20000.syscon:io-domains: pmuio2(3300000 uV) supplied by vcc3v3_pmu
[    6.729422] kernel: rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio1-supply from device tree
[    6.729537] kernel: rockchip-iodomain fdc20000.syscon:io-domains: vccio1(3300000 uV) supplied by vccio_acodec
[    6.729544] kernel: rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio2-supply from device tree
[    6.729670] kernel: rockchip-iodomain fdc20000.syscon:io-domains: vccio2(1800000 uV) supplied by vcc_1v8
[    6.729681] kernel: rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio3-supply from device tree
[    6.729799] kernel: rockchip-iodomain fdc20000.syscon:io-domains: vccio3(3300000 uV) supplied by vccio_sd
[    6.729807] kernel: rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio4-supply from device tree
[    6.729855] kernel: rockchip-iodomain fdc20000.syscon:io-domains: vccio4(1800000 uV) supplied by vcc_1v8
[    6.729861] kernel: rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio5-supply from device tree
[    6.729976] kernel: rockchip-iodomain fdc20000.syscon:io-domains: vccio5(3300000 uV) supplied by vcc_3v3
[    6.729982] kernel: rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio6-supply from device tree
[    6.730035] kernel: rockchip-iodomain fdc20000.syscon:io-domains: vccio6(1800000 uV) supplied by vcc_1v8
[    6.730042] kernel: rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio7-supply from device tree
[    6.730090] kernel: rockchip-iodomain fdc20000.syscon:io-domains: vccio7(3300000 uV) supplied by vcc_3v3
[    6.730650] kernel: input: adc-keys as /devices/platform/adc-keys/input/input2
[    6.735943] kernel: rockchip-pm-domain fdd90000.power-management:power-controller: Looking up vi-supply from device tree
[    6.735983] kernel: rockchip-pm-domain fdd90000.power-management:power-controller: Looking up vi-supply property in node /power-management@fdd90000/power-controller failed
[    6.737844] kernel: RKNPU fde40000.npu: Adding to iommu group 0
[    6.738453] kernel: RKNPU fde40000.npu: RKNPU: rknpu iommu is enabled, using iommu mode
[    6.738513] kernel: RKNPU fde40000.npu: Looking up rknpu-supply from device tree
[    6.738787] kernel: RKNPU fde40000.npu: Looking up mem-supply from device tree
[    6.738853] kernel: RKNPU fde40000.npu: can't request region for resource [mem 0xfde40000-0xfde4ffff]
[    6.739484] kernel: [drm] Initialized rknpu 0.9.2 20231018 for fde40000.npu on minor 1
[    6.739997] kernel: RKNPU fde40000.npu: Looking up rknpu-supply from device tree
[    6.740028] kernel: vdd_npu: could not add device link fde40000.npu: -EEXIST
[    6.740032] kernel: vdd_npu: Failed to create debugfs directory
[    6.740046] kernel: RKNPU fde40000.npu: Looking up mem-supply from device tree
[    6.740062] kernel: vdd_npu: could not add device link fde40000.npu: -EEXIST
[    6.740065] kernel: vdd_npu: Failed to create debugfs directory
[    6.740311] kernel: RKNPU fde40000.npu: bin=0
[    6.740364] kernel: RKNPU fde40000.npu: leakage=3
[    6.740399] kernel: RKNPU fde40000.npu: pvtm = 85240, from nvmem
[    6.740414] kernel: RKNPU fde40000.npu: pvtm-volt-sel=1
[    6.740426] kernel: RKNPU fde40000.npu: soc version=0, speed=1
[    6.740444] kernel: RKNPU fde40000.npu: opp_parse_supplies: Invalid number of elements in opp-microvolt property (3) with supplies (2)
[    6.740451] kernel: RKNPU fde40000.npu: _of_add_opp_table_v2: Failed to add OPP, -22
[    6.740456] kernel: RKNPU fde40000.npu: Invalid operating-points in device tree.
[    6.740460] kernel: RKNPU fde40000.npu: RKNPU: failed to init_opp_table
[    6.741827] kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    6.748562] kernel: mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[    6.751728] kernel: mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[    6.753485] kernel: mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[    6.753574] kernel: usb 1-1: New USB device found, idVendor=0a05, idProduct=7211, bcdDevice= 1.00
[    6.753582] kernel: usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    6.753587] kernel: usb 1-1: Product: USB2.0 HUB
[    6.758715] kernel: cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    6.759950] kernel: rockchip-pm rockchip-suspend: not set pwm-regulator-config
[    6.760627] kernel: rockchip-suspend not set sleep-mode-config for mem-lite
[    6.760633] kernel: rockchip-suspend not set wakeup-config for mem-lite
[    6.760639] kernel: rockchip-suspend not set sleep-mode-config for mem-ultra
[    6.760643] kernel: rockchip-suspend not set wakeup-config for mem-ultra
[    6.762125] kernel: I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 406; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '03:04:45', on 'May 15 2024'.
[    6.762628] kernel: Mali:
[    6.762634] kernel: Mali device driver loaded
[    6.762645] kernel: ALSA device list:
[    6.762651] kernel:   #0: rockchip-rk809
[    6.762655] kernel:   #1: rockchip,hdmi
[    6.771405] kernel: Freeing unused kernel memory: 7040K
[    6.809165] kernel: Run /init as init process
[    6.809187] kernel:   with arguments:
[    6.809198] kernel:     /init
[    6.809205] kernel:     splash
[    6.809214] kernel:   with environment:
[    6.809221] kernel:     HOME=/
[    6.809228] kernel:     TERM=linux
[    6.809235] kernel:     ubootpart=e4caba4b-ae0a-b440-b218-45acb356bc04
[    6.809243] kernel:     cgroup_enable=memory
[    6.809250] kernel:     cgroup_memory=1
[    6.820323] kernel: mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 100000000Hz, actual 50000000HZ div = 0)
[    6.832531] kernel: dwmmc_rockchip fe2c0000.dwmmc: Successfully tuned phase to 360
[    6.837255] kernel: mmc2: new ultra high speed SDR50 SDIO card at address 0001
[    7.003907] kernel: hub 1-1:1.0: USB hub found
[    7.004086] kernel: hub 1-1:1.0: 4 ports detected
[    7.323405] kernel: panfrost fde60000.gpu: clock rate = 594000000
[    7.323433] kernel: panfrost fde60000.gpu: bus_clock rate = 500000000
[    7.323645] kernel: panfrost fde60000.gpu: Looking up mali-supply from device tree
[    7.326132] kernel: panfrost fde60000.gpu: mali-g52 id 0x7402 major 0x1 minor 0x0 status 0x0
[    7.326148] kernel: panfrost fde60000.gpu: features: 00000000,13de77ff, issues: 00000000,00000400
[    7.326155] kernel: panfrost fde60000.gpu: Features: L2:0x07110206 Shader:0x00000002 Tiler:0x00000209 Mem:0x1 MMU:0x00002823 AS:0xff JS:0x7
[    7.326160] kernel: panfrost fde60000.gpu: shader_present=0x1 l2_present=0x1
[    7.340164] kernel: [drm] Initialized panfrost 1.1.0 20180908 for fde60000.gpu on minor 2
[    7.385644] kernel: usb 1-1.2: new low-speed USB device number 3 using xhci-hcd
[    7.479683] kernel: usb 1-1.2: New USB device found, idVendor=17ef, idProduct=608d, bcdDevice= 1.00
[    7.479699] kernel: usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    7.479704] kernel: usb 1-1.2: Product: Lenovo USB Optical Mouse
[    7.479708] kernel: usb 1-1.2: Manufacturer: PixArt
[    7.648718] kernel: input: PixArt Lenovo USB Optical Mouse as /devices/platform/usbdrd/fcc00000.dwc3/xhci-hcd.4.auto/usb1/1-1/1-1.2/1-1.2:1.0/0003:17EF:608D.0001/input/input3
[    7.649962] kernel: hid-generic 0003:17EF:608D.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt Lenovo USB Optical Mouse] on usb-xhci-hcd.4.auto-1.2/input0
[    7.729012] kernel: usb 1-1.3: new low-speed USB device number 4 using xhci-hcd
[    7.830944] kernel: usb 1-1.3: New USB device found, idVendor=17ef, idProduct=6099, bcdDevice= 1.00
[    7.830965] kernel: usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    7.830977] kernel: usb 1-1.3: Product: Lenovo Traditional USB Keyboard
[    7.830988] kernel: usb 1-1.3: Manufacturer: Lenovo
[    8.049833] kernel: input: Lenovo Lenovo Traditional USB Keyboard as /devices/platform/usbdrd/fcc00000.dwc3/xhci-hcd.4.auto/usb1/1-1/1-1.3/1-1.3:1.0/0003:17EF:6099.0002/input/input4
[    8.107711] kernel: hid-generic 0003:17EF:6099.0002: input,hidraw1: USB HID v1.11 Keyboard [Lenovo Lenovo Traditional USB Keyboard] on usb-xhci-hcd.4.auto-1.3/input0
[    9.137975] kernel: EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Opts: (null)
[    9.503732] kernel: NET: Registered protocol family 10
[    9.505060] kernel: Segment Routing with IPv6
[    9.530490] systemd[1]: systemd 249.11-0ubuntu3.12 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[    9.531784] systemd[1]: Detected architecture arm64.
[    9.534487] systemd[1]: Hostname set to <h96-tvbox-3566-legacy>.
[   10.083469] systemd[1]: Queued start job for default target Graphical Interface.
[   10.088395] systemd[1]: Created slice Slice /system/modprobe.
[   10.091135] systemd[1]: Created slice Slice /system/serial-getty.
[   10.093613] systemd[1]: Created slice Slice /system/systemd-fsck.
[   10.094955] systemd[1]: Created slice User and Session Slice.
[   10.095483] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   10.096564] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   10.097090] systemd[1]: Reached target User and Group Name Lookups.
[   10.097296] systemd[1]: Reached target Slice Units.
[   10.097444] systemd[1]: Reached target Swaps.
[   10.097573] systemd[1]: Reached target System Time Set.
[   10.097836] systemd[1]: Reached target Local Verity Protected Volumes.
[   10.118155] systemd[1]: Listening on RPCbind Server Activation Socket.
[   10.119804] systemd[1]: Listening on Syslog Socket.
[   10.120783] systemd[1]: Listening on fsck to fsckd communication Socket.
[   10.121363] systemd[1]: Listening on initctl Compatibility Named Pipe.
[   10.122823] systemd[1]: Listening on Journal Audit Socket.
[   10.123715] systemd[1]: Listening on Journal Socket (/dev/log).
[   10.124703] systemd[1]: Listening on Journal Socket.
[   10.128016] systemd[1]: Listening on udev Control Socket.
[   10.129085] systemd[1]: Listening on udev Kernel Socket.
[   10.134719] systemd[1]: Mounting Huge Pages File System...
[   10.140190] systemd[1]: Mounting POSIX Message Queue File System...
[   10.145988] systemd[1]: Mounting Kernel Debug File System...
[   10.151895] systemd[1]: Mounting Kernel Trace File System...
[   10.153062] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[   10.159604] systemd[1]: Starting Restore / save the current clock...
[   10.166357] systemd[1]: Starting Set the console keyboard layout...
[   10.173289] systemd[1]: Starting Create List of Static Device Nodes...
[   10.181041] systemd[1]: Starting Load Kernel Module configfs...
[   10.189178] systemd[1]: Starting Load Kernel Module drm...
[   10.198147] systemd[1]: Starting Load Kernel Module efi_pstore...
[   10.205091] systemd[1]: Starting Load Kernel Module fuse...
[   10.206193] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[   10.215175] systemd[1]: Starting Load Kernel Modules...
[   10.224355] kernel: fuse: init (API version 7.32)
[   10.224973] systemd[1]: Starting Remount Root and Kernel File Systems...
[   10.234013] systemd[1]: Starting Coldplug All udev Devices...
[   10.248552] systemd[1]: Mounted Huge Pages File System.
[   10.250715] systemd[1]: Mounted POSIX Message Queue File System.
[   10.252880] systemd[1]: Mounted Kernel Debug File System.
[   10.254582] systemd[1]: Mounted Kernel Trace File System.
[   10.257724] systemd[1]: Finished Restore / save the current clock.
[   10.260696] kernel: EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600,errors=remount-ro
[   10.261970] systemd[1]: Finished Create List of Static Device Nodes.
[   10.268345] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[   10.269593] systemd[1]: Finished Load Kernel Module configfs.
[   10.271506] systemd[1]: modprobe@drm.service: Deactivated successfully.
[   10.272728] systemd[1]: Finished Load Kernel Module drm.
[   10.274548] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[   10.275786] systemd[1]: Finished Load Kernel Module efi_pstore.
[   10.277497] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[   10.278588] systemd[1]: Finished Load Kernel Module fuse.
[   10.280657] systemd[1]: Finished Load Kernel Modules.
[   10.283745] systemd[1]: Finished Remount Root and Kernel File Systems.
[   10.290383] systemd[1]: Mounting FUSE Control File System...
[   10.298830] systemd[1]: Mounting Kernel Configuration File System...
[   10.305379] systemd[1]: Starting Platform Persistent Storage Archival...
[   10.314517] systemd[1]: Starting Load/Save Random Seed...
[   10.321048] systemd[1]: Starting Apply Kernel Variables...
[   10.328645] systemd[1]: Starting Create System Users...
[   10.334635] systemd[1]: Mounted FUSE Control File System.
[   10.337029] systemd[1]: Mounted Kernel Configuration File System.
[   10.366400] systemd[1]: Finished Platform Persistent Storage Archival.
[   10.379518] systemd[1]: Finished Load/Save Random Seed.
[   10.381579] systemd[1]: Condition check resulted in First Boot Complete being skipped.
[   10.389928] systemd[1]: Finished Create System Users.
[   10.396711] systemd[1]: Starting Create Static Device Nodes in /dev...
[   10.415977] systemd[1]: Finished Apply Kernel Variables.
[   10.420136] systemd[1]: Finished Set the console keyboard layout.
[   10.441813] systemd[1]: Finished Create Static Device Nodes in /dev.
[   10.443256] systemd[1]: Reached target Preparation for Local File Systems.
[   10.449753] systemd[1]: Mounting /tmp...
[   10.458295] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[   10.462739] systemd[1]: Mounted /tmp.
[   10.618767] systemd[1]: Started Rule-based Manager for Device Events and Files.
[   10.818116] systemd[1]: Finished Coldplug All udev Devices.
[   10.826517] systemd[1]: Starting Helper to synchronize boot up for ifupdown...
[   10.832744] systemd[1]: Starting Show Plymouth Boot Screen...
[   10.848056] systemd[1]: Finished Helper to synchronize boot up for ifupdown.
[   10.884859] systemd[1]: Started Show Plymouth Boot Screen.
[   10.886443] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch being skipped.
[   10.887288] systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
[   10.887818] systemd[1]: Reached target Local Encrypted Volumes.
[   11.430387] systemd[1]: Found device /dev/disk/by-uuid/332B-61E4.
[   11.452456] systemd[1]: Starting File System Check on /dev/disk/by-uuid/332B-61E4...
[   11.456182] systemd[1]: Found device /dev/ttyFIQ0.
[   11.479060] kernel: brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4335-sdio for chip BCM4335/1
[   11.481394] systemd[1]: Started File System Check Daemon to report status.
[   11.483086] kernel: usbcore: registered new interface driver brcmfmac
[   11.492078] kernel: brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4335-sdio.h96-TVbox,rk3566.txt failed with error -2
[   11.584576] systemd[1]: Finished File System Check on /dev/disk/by-uuid/332B-61E4.
[   11.596715] systemd[1]: Mounting /boot...
[   11.608657] kernel: FAT-fs (mmcblk0p1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[   11.632336] systemd[1]: Mounted /boot.
[   11.633772] systemd[1]: Reached target Local File Systems.
[   11.639741] systemd[1]: Starting Armbian ZRAM config...
[   11.656297] systemd[1]: Starting Set console font and keymap...
[   11.664709] systemd[1]: Starting Raise network interfaces...
[   11.677432] kernel: brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4335-sdio for chip BCM4335/1
[   11.677597] kernel: brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
[   11.679681] kernel: brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4335/1 wl0: May 18 2014 16:56:54 version 6.34.171.58.2
[   11.683991] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[   11.684672] systemd[1]: Condition check resulted in RPC security service for NFS server being skipped.
[   11.695745] systemd[1]: Starting Set Up Additional Binary Formats...
[   11.696297] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[   11.696539] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[   11.707226] systemd[1]: Finished Set console font and keymap.
[   11.708776] systemd[1]: Received SIGRTMIN+20 from PID 227 (plymouthd).
[   11.714637] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[   11.719366] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 405 (systemd-binfmt)
[   11.726654] systemd[1]: Mounting Arbitrary Executable File Formats File System...
[   11.784040] systemd[1]: Mounted Arbitrary Executable File Formats File System.
[   11.793450] systemd[1]: Finished Set Up Additional Binary Formats.
[   11.944762] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[   11.951597] systemd[1]: Starting Load/Save RF Kill Switch Status...
[   12.261300] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch being skipped.
[   12.262043] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[   12.262665] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[   12.301241] kernel: zram0: detected capacity change from 0 to 4031426560
[   12.355714] kernel: Adding 3936936k swap on /dev/zram0.  Priority:5 extents:1 across:3936936k SS
[   12.383100] kernel: zram: Added device: zram1
[   12.415201] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch being skipped.
[   12.415498] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[   12.415880] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[   12.427224] systemd[1]: Started Load/Save RF Kill Switch Status.
[   12.559395] systemd[1]: Finished Raise network interfaces.
[   12.588256] kernel: zram1: detected capacity change from 0 to 52428800
[   12.634317] systemd[1]: Finished Armbian ZRAM config.
[   12.642890] systemd[1]: Starting Armbian memory supported logging...
[   12.719600] kernel: EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
[   14.672903] systemd[1]: Finished Armbian memory supported logging.
[   14.680768] systemd[1]: Starting Journal Service...
[   14.952935] systemd[1]: Started Journal Service.
[   16.497819] kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   16.497836] kernel: Bluetooth: BNEP filters: protocol multicast
[   16.497867] kernel: Bluetooth: BNEP socket layer initialized
[   17.852035] kernel: phy_rtl8211f_led_fixup in
[   17.858154] kernel: phy_rtl8211f_led_fixup in  val=0x0000
[   17.895705] kernel: rk_gmac-dwmac fe010000.ethernet eth0: PHY [stmmac-1:00] driver [RTL8211F Gigabit Ethernet] (irq=POLL)
[   17.903607] kernel: dwmac4: Master AXI performs any burst length
[   17.903651] kernel: rk_gmac-dwmac fe010000.ethernet eth0: No Safety Features support found
[   17.903693] kernel: rk_gmac-dwmac fe010000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported
[   17.904292] kernel: rk_gmac-dwmac fe010000.ethernet eth0: registered PTP clock
[   17.913056] kernel: rk_gmac-dwmac fe010000.ethernet eth0: configuring for phy/rgmii link mode
[   17.943348] kernel: rk_gmac-dwmac fe010000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[   17.943449] kernel: IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
glmark2-es2-wayland
Quote
    glmark2 2021.02
    OpenGL Information
    GL_VENDOR:     Mesa
    GL_RENDERER:   Mali-G52 r1 (Panfrost)
    GL_VERSION:    OpenGL ES 3.1 Mesa 23.2.1-1ubuntu3.1~22.04.2
[build] use-vbo=false: FPS: 349 FrameTime: 2.865 ms
[build] use-vbo=true: FPS: 457 FrameTime: 2.188 ms
[texture] texture-filter=nearest: FPS: 726 FrameTime: 1.377 ms
[texture] texture-filter=linear: FPS: 698 FrameTime: 1.433 ms
[texture] texture-filter=mipmap: FPS: 681 FrameTime: 1.468 ms
[shading] shading=gouraud: FPS: 288 FrameTime: 3.472 ms
[shading] shading=blinn-phong-inf: FPS: 290 FrameTime: 3.448 ms
[shading] shading=phong: FPS: 278 FrameTime: 3.597 ms
[shading] shading=cel: FPS: 287 FrameTime: 3.484 ms
[bump] bump-render=high-poly: FPS: 99 FrameTime: 10.101 ms
[bump] bump-render=normals: FPS: 754 FrameTime: 1.326 ms
[bump] bump-render=height: FPS: 733 FrameTime: 1.364 ms
[effect2d] kernel=0,1,0;1,-4,1;0,1,0;: FPS: 531 FrameTime: 1.883 ms
[effect2d] kernel=1,1,1,1,1;1,1,1,1,1;1,1,1,1,1;: FPS: 188 FrameTime: 5.319 ms
[pulsar] light=false:quads=5:texture=false: FPS: 699 FrameTime: 1.431 ms
[desktop] blur-radius=5:effect=blur:passes=1:separable=true:windows=4: FPS: 188 FrameTime: 5.319 ms
[desktop] effect=shadow:windows=4: FPS: 429 FrameTime: 2.331 ms
[buffer] columns=200:interleave=false:update-dispersion=0.9:update-fraction=0.5:update-method=map: FPS: 44 FrameTime: 22.727 ms
[buffer] columns=200:interleave=false:update-dispersion=0.9:update-fraction=0.5:update-method=subdata: FPS: 45 FrameTime: 22.222 ms
[buffer] columns=200:interleave=true:update-dispersion=0.9:update-fraction=0.5:update-method=map: FPS: 51 FrameTime: 19.608 ms
[ideas] speed=duration: FPS: 267 FrameTime: 3.745 ms
[jellyfish] <default>: FPS: 357 FrameTime: 2.801 ms
[terrain] <default>: FPS: 23 FrameTime: 43.478 ms
[shadow] <default>: FPS: 192 FrameTime: 5.208 ms
[refract] <default>: FPS: 24 FrameTime: 41.667 ms
[conditionals] fragment-steps=0:vertex-steps=0: FPS: 679 FrameTime: 1.473 ms
[conditionals] fragment-steps=5:vertex-steps=0: FPS: 689 FrameTime: 1.451 ms
[conditionals] fragment-steps=0:vertex-steps=5: FPS: 669 FrameTime: 1.495 ms
[function] fragment-complexity=low:fragment-steps=5: FPS: 687 FrameTime: 1.456 ms
[function] fragment-complexity=medium:fragment-steps=5: FPS: 460 FrameTime: 2.174 ms
[loop] fragment-loop=false:fragment-steps=5:vertex-steps=5: FPS: 654 FrameTime: 1.529 ms
[loop] fragment-steps=5:fragment-uniform=false:vertex-steps=5: FPS: 656 FrameTime: 1.524 ms
[loop] fragment-steps=5:fragment-uniform=true:vertex-steps=5: FPS: 636 FrameTime: 1.572 ms
                                  glmark2 Score: 418
RK3566-H96-MAX-LEGACY-51-V6.zip
Edited by Hqnicolas
Posted (edited)
- Update: Rockchip Kernel 6.1 Vendor
✔️ HDMI Audio
✔️ WIFI 2.4 + 5ghz
✔️ Ethernet
Bluetooth
✔️ NPU
VPU
✔️ GPU
Wifi-K610:
https://drive.google.com/file/d/1B1LmAylalETcnBEWiPiJHL0MjK5xlIV4/view
Wifi-Fix:
https://drive.google.com/file/d/1agxdBh8gruXn8It_pa_DDyJnzVxbDK8g/view?usp=drive_link
cd /lib/firmware/brcm/
sudo wget https://github.com/CoreELEC/brcmfmac_sdio-firmware-aml/raw/master/firmware/brcm/fw_bcm4335b0_ag.bin
sudo ln -s fw_bcm4335b0_ag.bin brcmfmac4335-sdio.h96-TVbox,rk3566.bin
Quote
sudo cat > /lib/firmware/brcm/brcmfmac4335-sdio.txt << "EOF"
# bcm94335wlcspMS_ES50_RC171p24p23_04052013_AM_mdfy_PAparam.txt -- 4/5/2013 by Murata, based on bcm94335wlcspMS_ES50_RC171p24p20_04022013_AM.txt, changed PA parameters and txidxcap parameters and ccode.
# bcm94335wlcspMS_ES50_RC171p24p20_04022013_AM.txt -- 4/2/2013 by Broadcom Corporation
# Use with AARDVARK_REL_6_30_171_24_23 -- Murata BCM4335 WLCSP 11AC Module
# Sample variables file for Murata Type-XJ ES5.0 (0x00 0x11) -- bcm94335wlcspMS_AM_P400.txt as original
sromrev=11
boardrev=0x1500
boardtype=0x064b
boardflags=0x10401001
boardflags2=0x0
#updated boardflags3 for forcing to enable external LPO
boardflags3=0x0800c08b
macaddr=00:90:4c:c5:12:38
#ccode modified by Murata
#ccode=0
ccode=XS
regrev=0
antswitch=0
pdgain5g=1
pdgain2g=1
tworangetssi2g=0
tworangetssi5g=0
femctrl=4
vendid=0x14e4
devid=0x43ae
manfid=0x2d0
#prodid=0x052e
nocrc=1
#otpimagesize=502
xtalfreq=37400
extpagain2g=1
extpagain5g=1
rxgains2gelnagaina0=2
rxgains2gtrisoa0=6
rxgains2gtrelnabypa0=1
rxgains5gelnagaina0=3
rxgains5gtrisoa0=5
rxgains5gtrelnabypa0=1
rxchain=1
txchain=1
aa2g=1
aa5g=1
ag0=0
ag1=0
tssipos5g=1
tssipos2g=1
#PA parameters (2G20M/2G40M/5G20M/5G40M/5G80M)
#PA parameters modified by Murata
#pa2ga0=-208,6208,-764
#pa2ga1=-203,6429,-793
#pa5ga0=-167,5736,-685,-157,5669,-670,-157,5548,-665,-141,5621,-664
#pa5ga1=-101,6543,-735,-99,6452,-731,-147,5743,-695,-75,6468,-723
#pa5ga2=-172,5903,-708,-160,5868,-698,-113,6264,-722,-125,5915,-684
pa2ga0=0xff31,0x1759,0xFD1D
pa2ga1=0xff35,0x18BB,0xFCEC
pa5ga0=0xff78,0x1715,0xFD49,0xff89,0x1714,0xFD57,0xff86,0x1652,0xFD62,0xffa9,0x1760,0xFD5E
pa5ga1=0xff56,0x1596,0xFD5F,0xff88,0x1764,0xFD45,0xff89,0x1632,0xFD65,0xff69,0x160E,0xFD49
pa5ga2=0xff5a,0x1667,0xFD4E,0xff5f,0x15F7,0xFD5E,0xff5a,0x1531,0xFD68,0xff6e,0x1587,0xFD6A
# Default Target Power for 2G -- 17dBm(11)/14dBm(54)/13dBm(MCS7,MCS8)/16dBm(6,MCS0)
maxp2ga0=74
cckbw202gpo=0
cckbw20ul2gpo=0
dot11agofdmhrbw202gpo=0x6666
ofdmlrbw202gpo=0x0022
mcsbw202gpo=0x88866662
# Default Target Power for 5G -- 14dBm(54)/13dBm(HT20-MCS7,VHT20-MCS8)/12dBm(HT40-MCS7,VHT40-MCS9)/11dBm(VHT80-MCS8/MCS9)/16dBm(6,20HT-MCS0)
maxp5ga0=74,74,74,74
# Low
mcslr5glpo=0
mcsbw205glpo=0x88866662
mcsbw405glpo=0xAAA88884
mcsbw805glpo=0xCCCAAAA6
# Mid
mcslr5gmpo=0
mcsbw205gmpo=0x88866662
mcsbw405gmpo=0xAAA88884
mcsbw805gmpo=0xCCCAAAA6
# High
mcslr5ghpo=0
mcsbw205ghpo=0x88866662
mcsbw405ghpo=0xAAA88884
mcsbw805ghpo=0xCCCAAAA6
#20MHz High Rate
sb20in40hrpo=0x0
sb20in80and160hr5glpo=0x0
sb20in80and160hr5gmpo=0x0
sb20in80and160hr5ghpo=0x0
#40MHz High Rate
sb40and80hr5glpo=0x0
sb40and80hr5gmpo=0x0
sb40and80hr5ghpo=0x0
#20MHz Low Rate
sb20in40lrpo=0x0
sb20in80and160lr5glpo=0x0
sb20in80and160lr5gmpo=0x0
sb20in80and160lr5ghpo=0x0
#40MHz Low Rate
sb40and80lr5glpo=0x0
sb40and80lr5gmpo=0x0
sb40and80lr5ghpo=0x0
dot11agduphrpo=0x0
dot11agduplrpo=0x0
tssifloor2g=80
tssifloor5g=160,190,240,260
#rpcal:use with 171.17 or later, compensates filter ripple
rpcal2g=0x0
rpcal5gb0=0x0
#cckdigfilttype[0-7] 0:default
cckdigfilttype=2
phycal_tempdelta=25
#GPIO 0 for SDIO HW OOB interruption
muxenab=0x10
#sd_gpout=0
#sd_oobonly=1
rssicorrnorm_c0=-3,-2
rssicorrnorm5g_c0=-1,0,-3,-1,0,-3,-3,-2,-4,-3,-2,-4
#txidxcap2g and txidxcap5g modified by Murata
#txidxcap2g=32
#txidxcap5g=44
txidxcap2g=36
txidxcap5g=36
paparambwver=1
EOF
sudo reboot now
nmcli dev wifi
sudo rmmod brcmfmac_wcc brcmfmac brcmutil
modprobe brcmfmac
- Image:
Updated K610 test image: https://drive.google.com/file/d/1rKzJ2RbxEBgSdqUy2O0-qhIipBakyt9t/view?usp=drive_link
- BaseFiles:
RK3566-H96-MAX-VENDOR-61-V12: https://drive.google.com/file/d/1E0GBU3vog_6Y72V3EUMjgQhwi6WX3v6w/view?usp=sharing
edit Rockchip U-boot Legacy 4.19 DTShttps://github.com/hqnicolas/u-boot/blob/next-dev-v2024.03/arch/arm/dts/rk3566-h96.dts
edit Rockchip U-boot Legacy 4.19 DEFCONFIGhttps://github.com/hqnicolas/u-boot/blob/next-dev-v2024.03/configs/h96-rk3566_defconfig
Quote
nicolas@h96-tvbox-3566-vendor:~$ glmark2-es2-wayland
    glmark2 2021.02
    OpenGL Information
    GL_VENDOR:     Mesa
[build] use-vbo=false: FPS: 362 FrameTime: 2.762 ms
[build] use-vbo=true: FPS: 403 FrameTime: 2.481 ms
[texture] texture-filter=nearest: FPS: 681 FrameTime: 1.468 ms
[texture] texture-filter=linear: FPS: 686 FrameTime: 1.458 ms
[texture] texture-filter=mipmap: FPS: 708 FrameTime: 1.412 ms
[shading] shading=gouraud: FPS: 273 FrameTime: 3.663 ms
[shading] shading=blinn-phong-inf: FPS: 275 FrameTime: 3.636 ms
[shading] shading=phong: FPS: 260 FrameTime: 3.846 ms
[shading] shading=cel: FPS: 268 FrameTime: 3.731 ms
[bump] bump-render=high-poly: FPS: 94 FrameTime: 10.638 ms
[bump] bump-render=normals: FPS: 710 FrameTime: 1.408 ms
[bump] bump-render=height: FPS: 718 FrameTime: 1.393 ms
[effect2d] kernel=0,1,0;1,-4,1;0,1,0;: FPS: 479 FrameTime: 2.088 ms
[effect2d] kernel=1,1,1,1,1;1,1,1,1,1;1,1,1,1,1;: FPS: 175 FrameTime: 5.714 ms
[pulsar] light=false:quads=5:texture=false: FPS: 697 FrameTime: 1.435 ms
[desktop] blur-radius=5:effect=blur:passes=1:separable=true:windows=4: FPS: 175 FrameTime: 5.714 ms
[desktop] effect=shadow:windows=4: FPS: 425 FrameTime: 2.353 ms
[buffer] columns=200:interleave=false:update-dispersion=0.9:update-fraction=0.5:update-method=map: FPS: 46 FrameTime: 21.739 ms
[buffer] columns=200:interleave=false:update-dispersion=0.9:update-fraction=0.5:update-method=subdata: FPS: 46 FrameTime: 21.739 ms
[buffer] columns=200:interleave=true:update-dispersion=0.9:update-fraction=0.5:update-method=map: FPS: 53 FrameTime: 18.868 ms
[ideas] speed=duration: FPS: 255 FrameTime: 3.922 ms
[jellyfish] <default>: FPS: 335 FrameTime: 2.985 ms
[terrain] <default>: FPS: 22 FrameTime: 45.455 ms
[shadow] <default>: FPS: 182 FrameTime: 5.495 ms
[refract] <default>: FPS: 23 FrameTime: 43.478 ms
[conditionals] fragment-steps=0:vertex-steps=0: FPS: 651 FrameTime: 1.536 ms
[conditionals] fragment-steps=5:vertex-steps=0: FPS: 646 FrameTime: 1.548 ms
[conditionals] fragment-steps=0:vertex-steps=5: FPS: 656 FrameTime: 1.524 ms
[function] fragment-complexity=low:fragment-steps=5: FPS: 646 FrameTime: 1.548 ms
[function] fragment-complexity=medium:fragment-steps=5: FPS: 488 FrameTime: 2.049 ms
[loop] fragment-loop=false:fragment-steps=5:vertex-steps=5: FPS: 629 FrameTime: 1.590 ms
[loop] fragment-steps=5:fragment-uniform=false:vertex-steps=5: FPS: 637 FrameTime: 1.570 ms
[loop] fragment-steps=5:fragment-uniform=true:vertex-steps=5: FPS: 625 FrameTime: 1.600 ms
                                  glmark2 Score: 403
Edited by Hqnicolas
Posted (edited)
Truncate 2 partitions image
sudo losetup --partscan /dev/loop13 disk_image.img
sudo e2fsck -f /dev/loop13p1
sudo e2fsck -f /dev/loop13p2
sudo resize2fs /dev/loop13p1 -M
sudo resize2fs /dev/loop13p2 -M
### RUN THE "DISC" software and resize partition using the gui
fdisk -l disk_image.img
sudo losetup --detach /dev/loop13
truncate -s $(INSERT THE (END*BLOCKSIZE) OF PARTITION2 HERE) disk_image.img
mkdir /tmp/disk_image
sudo mount /dev/loop13p1 /tmp/disk_image
sudo fstrim -v /tmp/disk_image
sudo umount /tmp/disk_image
sudo mount /dev/loop13p2 /tmp/disk_image
Edited by Hqnicolas
Hello. Are these files and information also valid for the same box but with the RK3588 chip? I have one of those boxes, and there are issues with it being identified by the APPs as a mobile phone, so some apps like Disney+ work like on a smartphone instead of a TV, thus i wanted to try some other firmware and see if things get better.
Thank you!
Posted (edited)
Joshua Riek VPU on Armbian Kernel 6.1 Vendor
img File, Desktop Kernel 6.1 Joshua Riek: https://github.com/hqnicolas/ubuntu-rockchip/actions/runs/9321238931
This Github actions Workflow was edited by me to compile a Trans LGTV Orangepi-3b
that works on H96 MAX https://github.com/hqnicolas/ubuntu-rockchip/releases/tag/v2.1.1-v56
✔️ HDMI Audio
✔️ WIFI 2.4 + 5ghz
✔️ Ethernet
 Bluetooth
✔️ NPU
✔️ VPU  1080P 60FPS  ZERO DROP FRAMES
✔️ GPU
Wifi fix: https://drive.google.com/file/d/1agxdBh8gruXn8It_pa_DDyJnzVxbDK8g/view?usp=sharing
DTS + DTBhttps://drive.google.com/file/d/1E0GBU3vog_6Y72V3EUMjgQhwi6WX3v6w/view?usp=sharing
Freeze Kernel:
sudo apt-mark hold linux-image-6.1.0-1014-rockchip  linux-headers-6.1.0-1014-rockchip
RK3566-H96-MAX-VENDOR-61-V12.zip
fix_610_h96_Wifi_Bluetooth.zip
@maka
Today I take the U-Boot from test image Kernel Vendor 6.1: https://drive.google.com/file/d/1rKzJ2RbxEBgSdqUy2O0-qhIipBakyt9t/view?usp=drive_link
and unpack it inside Joshua Riek OrangePi-3b 24.04 image https://github.com/Joshua-Riek/ubuntu-rockchip/releases
Change the UUID on armbian boot file
Using this method:
sudo losetup --partscan /dev/loop14 disk_image.img
sudo mount /dev/loop14p1 /tmp/disk_image
####### DROP the new File to /tmp/disk_image/u-Boot ##########
sudo losetup --detach /dev/loop14
Same Experience as Armbian with VPU enabled
dmesg?
Quote
[    5.321272] Booting Linux on physical CPU 0x0000000000 [0x412fd050]
[    5.321319] Linux version 6.1.43-vendor-rk35xx (armbian@next) (aarch64-linux-gnu-gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1 SMP Fri May 24 03:14:47 UTC 2024
[    5.331307] Machine model: h96 TVbox 3566
[    5.334393] efi: UEFI not found.
[    5.334655] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-logo@0': base 0x0000000000000000, size 0 MiB
[    5.334683] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-cubic-lut@0': base 0x0000000000000000, size 0 MiB
[    5.334837] Reserved memory: created CMA memory pool at 0x00000001ff800000, size 8 MiB
[    5.334846] OF: reserved mem: initialized node cma, compatible id shared-dma-pool
[    5.334918] Reserved memory: created CMA memory pool at 0x00000001df800000, size 512 MiB
[    5.334927] OF: reserved mem: initialized node rknpu, compatible id shared-dma-pool
[    5.547130] Zone ranges:
[    5.547144]   DMA      [mem 0x0000000000200000-0x00000000ffffffff]
[    5.547163]   DMA32    empty
[    5.547169]   Normal   [mem 0x0000000100000000-0x00000001ffffffff]
[    5.547179] Movable zone start for each node
[    5.547182] Early memory node ranges
[    5.547185]   node   0: [mem 0x0000000000200000-0x00000000efffffff]
[    5.547198]   node   0: [mem 0x0000000100000000-0x00000001ffffffff]
[    5.547209] Initmem setup node 0 [mem 0x0000000000200000-0x00000001ffffffff]
[    5.576124] On node 0, zone DMA: 512 pages in unavailable ranges
[    5.607120] psci: probing for conduit method from DT.
[    5.607139] psci: PSCIv1.1 detected in firmware.
[    5.607146] psci: Using standard PSCI v0.2 function IDs
[    5.607153] psci: MIGRATE_INFO_TYPE not supported.
[    5.607170] psci: SMC Calling Convention v1.2
[    5.607634] percpu: Embedded 29 pages/cpu s79592 r8192 d31000 u118784
[    5.607690] pcpu-alloc: s79592 r8192 d31000 u118784 alloc=29*4096
[    5.607709] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    5.607844] Detected VIPT I-cache on CPU0
[    5.607930] CPU features: detected: GIC system register CPU interface
[    5.607937] CPU features: detected: Virtualization Host Extensions
[    5.607961] CPU features: detected: Qualcomm erratum 1009, or ARM erratum 1286807, 2441009
[    5.607968] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    5.607976] alternatives: applying boot alternatives
[    5.608586] Built 1 zonelists, mobility grouping on.  Total pages: 1999368
[    5.608610] Kernel command line: root=UUID=3353bae0-7677-496b-85b1-7f9920020fe3 rootwait rootfstype=ext4 splash plymouth.ignore-serial-consoles console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart=6dcd74a8-9459-4861-aaa1-2e5e37833167 usb-storage.quirks=   cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
[    5.609443] The swapaccount= commandline option is deprecated. Please report your usecase to linux-mm@kvack.org if you depend on this functionality.
[    5.609468] Unknown kernel command line parameters "splash ubootpart=6dcd74a8-9459-4861-aaa1-2e5e37833167 cgroup_enable=memory cgroup_memory=1", will be passed to user space.
[    5.612127] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    5.613452] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    5.613466] mem auto-init: stack:off, heap alloc:off, heap free:off
[    5.613476] software IO TLB: area num 4.
[    5.656201] software IO TLB: mapped [mem 0x00000000e7e7e000-0x00000000ebe7e000] (64MB)
[    5.784874] Memory: 7315484K/8124416K available (17920K kernel code, 3758K rwdata, 7268K rodata, 7488K init, 697K bss, 276452K reserved, 532480K cma-reserved)
[    5.785131] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    5.785190] ftrace: allocating 68397 entries in 268 pages
[    5.969821] ftrace: allocated 268 pages with 3 groups
[    5.969879] **********************************************************
[    5.969883] **   NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE   **
[    5.969887] **                                                      **
[    5.969891] ** trace_printk() being used. Allocating extra memory.  **
[    5.969894] **                                                      **
[    5.969898] ** This means that this is a DEBUG kernel and it is     **
[    5.969901] ** unsafe for production use.                           **
[    5.969904] **                                                      **
[    5.969909] ** If you see this message and you are not debugging    **
[    5.969912] ** the kernel, report this immediately to your vendor!  **
[    5.969915] **                                                      **
[    5.969919] **   NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE   **
[    5.969922] **********************************************************
[    5.970794] trace event string verifier disabled
[    5.971154] rcu: Hierarchical RCU implementation.
[    5.971163] rcu:     RCU event tracing is enabled.
[    5.971168] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    5.971178]     Rude variant of Tasks RCU enabled.
[    5.971182]     Tracing variant of Tasks RCU enabled.
[    5.971186] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[    5.971193] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    5.985480] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    5.988747] GICv3: GIC: Using split EOI/Deactivate mode
[    5.988762] GICv3: 320 SPIs implemented
[    5.988771] GICv3: 0 Extended SPIs implemented
[    5.988837] Root IRQ handler: gic_handle_irq
[    5.988864] GICv3: GICv3 features: 16 PPIs
[    5.988909] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000
[    5.989789] ITS [mem 0xfd440000-0xfd45ffff]
[    5.989911] ITS@0x00000000fd440000: allocated 8192 Devices @410000 (indirect, esz 8, psz 64K, shr 0)
[    5.989974] ITS@0x00000000fd440000: allocated 32768 Interrupt Collections @420000 (flat, esz 2, psz 64K, shr 0)
[    5.990000] ITS: using cache flushing for cmd queue
[    5.990668] GICv3: using LPI property table @0x0000000000430000
[    5.990844] GIC: using cache flushing for LPI property table
[    5.990856] GICv3: CPU0: using allocated LPI pending table @0x0000000000440000
[    5.990968] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    6.040423] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    6.040458] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    6.040475] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    6.042648] Console: colour dummy device 80x25
[    6.042746] printk: console [tty1] enabled
[    6.042805] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[    6.042826] pid_max: default: 32768 minimum: 301
[    6.042987] LSM: Security Framework initializing
[    6.043260] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    6.043321] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    6.044996] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    6.046645] cblist_init_generic: Setting adjustable number of callback queues.
[    6.046659] cblist_init_generic: Setting shift to 2 and lim to 1.
[    6.046869] cblist_init_generic: Setting adjustable number of callback queues.
[    6.046882] cblist_init_generic: Setting shift to 2 and lim to 1.
[    6.047353] rcu: Hierarchical SRCU implementation.
[    6.047365] rcu:     Max phase no-delay instances is 1000.
[    6.048837] Platform MSI: interrupt-controller@fd440000 domain created
[    6.049621] PCI/MSI: /interrupt-controller@fd400000/interrupt-controller@fd440000 domain created
[    6.050360] EFI services will not be available.
[    6.051092] smp: Bringing up secondary CPUs ...
[    6.053014] Detected VIPT I-cache on CPU1
[    6.053161] cacheinfo: Unable to detect cache hierarchy for CPU 1
[    6.053184] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[    6.053222] GICv3: CPU1: using allocated LPI pending table @0x0000000000450000
[    6.053294] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[    6.055510] Detected VIPT I-cache on CPU2
[    6.055644] cacheinfo: Unable to detect cache hierarchy for CPU 2
[    6.055666] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[    6.055700] GICv3: CPU2: using allocated LPI pending table @0x0000000000460000
[    6.055758] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[    6.057812] Detected VIPT I-cache on CPU3
[    6.057950] cacheinfo: Unable to detect cache hierarchy for CPU 3
[    6.057972] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000
[    6.058007] GICv3: CPU3: using allocated LPI pending table @0x0000000000470000
[    6.058064] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[    6.058259] smp: Brought up 1 node, 4 CPUs
[    6.058292] SMP: Total of 4 processors activated.
[    6.058303] CPU features: detected: 32-bit EL0 Support
[    6.058309] CPU features: detected: 32-bit EL1 Support
[    6.058318] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    6.058326] CPU features: detected: Common not Private translations
[    6.058332] CPU features: detected: CRC32 instructions
[    6.058343] CPU features: detected: RCpc load-acquire (LDAPR)
[    6.058350] CPU features: detected: Privileged Access Never
[    6.058356] CPU features: detected: RAS Extension Support
[    6.058367] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    6.058505] CPU: All CPU(s) started at EL2
[    6.058515] alternatives: applying system-wide alternatives
[    6.062914] devtmpfs: initialized
[    6.113573] Registered cp15_barrier emulation handler
[    6.113608] Registered setend emulation handler
[    6.113926] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    6.113965] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    6.131062] pinctrl core: initialized pinctrl subsystem
[    6.131588] regulator-dummy: no parameters, enabled
[    6.132118] DMI not present or invalid.
[    6.133136] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    6.135818] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[    6.136034] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    6.136228] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    6.136414] audit: initializing netlink subsys (disabled)
[    6.136818] audit: type=2000 audit(0.093:1): state=initialized audit_enabled=0 res=1
[    6.142074] Registered FIQ tty driver
[    6.142879] thermal_sys: Registered thermal governor 'fair_share'
[    6.142893] thermal_sys: Registered thermal governor 'step_wise'
[    6.142902] thermal_sys: Registered thermal governor 'user_space'
[    6.142910] thermal_sys: Registered thermal governor 'power_allocator'
[    6.143392] cpuidle: using governor menu
[    6.144291] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    6.144595] ASID allocator initialised with 65536 entries
[    6.148817] ramoops: dmesg-0    0x20000@0x0000000000110000
[    6.148872] ramoops: console    0x80000@0x0000000000130000
[    6.148906] ramoops: pmsg    0x50000@0x00000000001b0000
[    6.149162] printk: console [ramoops-1] enabled
[    6.149175] pstore: Registered ramoops as persistent store backend
[    6.149184] ramoops: using 0xf0000@0x110000, ecc: 0
[    6.178561] platform fe040000.vop: Fixed dependency cycle(s) with /hdmi@fe0a0000
[    6.217415] rockchip-gpio fdd60000.gpio: probed /pinctrl/gpio@fdd60000
[    6.218399] rockchip-gpio fe740000.gpio: probed /pinctrl/gpio@fe740000
[    6.219484] rockchip-gpio fe750000.gpio: probed /pinctrl/gpio@fe750000
[    6.220477] rockchip-gpio fe760000.gpio: probed /pinctrl/gpio@fe760000
[    6.221386] rockchip-gpio fe770000.gpio: probed /pinctrl/gpio@fe770000
[    6.221627] rockchip-pinctrl pinctrl: probed pinctrl
[    6.231198] KASLR disabled due to lack of seed
[    6.254782] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    6.254808] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    6.254821] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    6.254830] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    6.254840] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    6.254849] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    6.254859] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    6.254867] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    6.312619] raid6: neonx8   gen()  1370 MB/s
[    6.369509] raid6: neonx4   gen()  1408 MB/s
[    6.426408] raid6: neonx2   gen()  1289 MB/s
[    6.483288] raid6: neonx1   gen()  1052 MB/s
[    6.540223] raid6: int64x8  gen()   349 MB/s
[    6.597090] raid6: int64x4  gen()   440 MB/s
[    6.653947] raid6: int64x2  gen()   910 MB/s
[    6.710870] raid6: int64x1  gen()   635 MB/s
[    6.710884] raid6: using algorithm neonx4 gen() 1408 MB/s
[    6.767655] raid6: .... xor() 1067 MB/s, rmw enabled
[    6.767670] raid6: using neon recovery algorithm
[    6.769074] dc_5v: 5000 mV, enabled
[    6.769401] reg-fixed-voltage dc-5v: dc_5v supplying 5000000uV
[    6.769647] reg-fixed-voltage vcc3v3-sys: Looking up vin-supply from device tree
[    6.769675] vcc3v3_sys: supplied by dc_5v
[    6.769694] dc_5v: could not add device link regulator.2: -ENOENT
[    6.769764] vcc3v3_sys: 3300 mV, enabled
[    6.770075] reg-fixed-voltage vcc3v3-sys: vcc3v3_sys supplying 3300000uV
[    6.770315] reg-fixed-voltage vcc5v0-sys: Looking up vin-supply from device tree
[    6.770341] vcc5v0_sys: supplied by dc_5v
[    6.770359] dc_5v: could not add device link regulator.3: -ENOENT
[    6.770428] vcc5v0_sys: 5000 mV, enabled
[    6.770706] reg-fixed-voltage vcc5v0-sys: vcc5v0_sys supplying 5000000uV
[    6.771258] vcc5v0_host: no parameters, enabled
[    6.771543] reg-fixed-voltage vcc5v0-host-regulator: vcc5v0_host supplying 0uV
[    6.771778] reg-fixed-voltage vcc2v5-ddr: Looking up vin-supply from device tree
[    6.771804] vcc2v5_sys: supplied by vcc3v3_sys
[    6.771821] vcc3v3_sys: could not add device link regulator.5: -ENOENT
[    6.771891] vcc2v5_sys: 2500 mV, enabled
[    6.772166] reg-fixed-voltage vcc2v5-ddr: vcc2v5_sys supplying 2500000uV
[    6.772431] reg-fixed-voltage vcc3v3-vga: Looking up vin-supply from device tree
[    6.772458] vcc3v3_vga: supplied by vcc3v3_sys
[    6.772474] vcc3v3_sys: could not add device link regulator.6: -ENOENT
[    6.772547] vcc3v3_vga: at 3300 mV, enabled
[    6.772842] reg-fixed-voltage vcc3v3-vga: vcc3v3_vga supplying 0uV
[    6.773895] iommu: Default domain type: Translated
[    6.773912] iommu: DMA domain TLB invalidation policy: strict mode
[    6.774607] SCSI subsystem initialized
[    6.774684] libata version 3.00 loaded.
[    6.775006] usbcore: registered new interface driver usbfs
[    6.775088] usbcore: registered new interface driver hub
[    6.775150] usbcore: registered new device driver usb
[    6.775409] mc: Linux media interface: v0.10
[    6.775491] videodev: Linux video capture interface: v2.00
[    6.775653] pps_core: LinuxPPS API ver. 1 registered
[    6.775666] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    6.775703] PTP clock support registered
[    6.776653] arm-scmi firmware:scmi: Enabled polling mode TX channel - prot_id:16
[    6.776884] arm-scmi firmware:scmi: SCMI Notifications - Core Enabled.
[    6.776969] arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0
[    6.778256] Advanced Linux Sound Architecture Driver Initialized.
[    6.779339] Bluetooth: Core ver 2.22
[    6.779403] NET: Registered PF_BLUETOOTH protocol family
[    6.779414] Bluetooth: HCI device and connection manager initialized
[    6.779433] Bluetooth: HCI socket layer initialized
[    6.779448] Bluetooth: L2CAP socket layer initialized
[    6.779478] Bluetooth: SCO socket layer initialized
[    6.779610] NetLabel: Initializing
[    6.779619] NetLabel:  domain hash size = 128
[    6.779629] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    6.779740] NetLabel:  unlabeled traffic allowed by default
[    6.780393] vgaarb: loaded
[    7.418168] clocksource: Switched to clocksource arch_sys_counter
[    7.419084] VFS: Disk quotas dquot_6.6.0
[    7.419172] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    7.439195] NET: Registered PF_INET protocol family
[    7.439768] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    7.449754] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[    7.449868] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    7.450010] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    7.450550] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[    7.452818] TCP: Hash tables configured (established 65536 bind 65536)
[    7.453330] MPTCP token hash table entries: 8192 (order: 5, 196608 bytes, linear)
[    7.453585] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    7.453758] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    7.454219] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    7.455297] RPC: Registered named UNIX socket transport module.
[    7.455316] RPC: Registered udp transport module.
[    7.455324] RPC: Registered tcp transport module.
[    7.455332] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    7.457130] PCI: CLS 0 bytes, default 64
[    7.458157] Trying to unpack rootfs image as initramfs...
[    7.466579] hw perfevents: enabled with armv8_cortex_a55 PMU driver, 7 counters available
[    7.468276] kvm [1]: IPA Size Limit: 40 bits
[    7.468349] kvm [1]: GICv3: no GICV resource entry
[    7.468363] kvm [1]: disabling GICv2 emulation
[    7.468372] kvm [1]: GIC system register CPU interface enabled
[    7.469088] kvm [1]: vgic interrupt IRQ9
[    7.469637] kvm [1]: VHE mode initialized successfully
[    7.518367] Initialise system trusted keyrings
[    7.518800] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[    7.532058] NFS: Registering the id_resolver key type
[    7.532131] Key type id_resolver registered
[    7.532143] Key type id_legacy registered
[    7.532295] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    7.532312] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    7.586031] NET: Registered PF_ALG protocol family
[    7.586077] xor: measuring software checksum speed
[    7.592428]    8regs           :  1565 MB/sec
[    7.597613]    32regs          :  1911 MB/sec
[    7.603747]    arm64_neon      :  1619 MB/sec
[    7.603765] xor: using function: 32regs (1911 MB/sec)
[    7.603802] Key type asymmetric registered
[    7.603817] Asymmetric key parser 'x509' registered
[    7.603974] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[    7.604373] io scheduler mq-deadline registered
[    7.604389] io scheduler kyber registered
[    7.607861] rockchip-csi2-dphy-hw fe870000.csi2-dphy-hw: csi2 dphy hw probe successfully!
[    7.612453] phy phy-fe8a0000.usb2-phy.0: Looking up phy-supply from device tree
[    7.612506] vcc5v0_host: could not add device link phy-fe8a0000.usb2-phy.0: -ENOENT
[    7.612821] phy phy-fe8a0000.usb2-phy.1: Looking up phy-supply from device tree
[    7.612861] vcc5v0_host: could not add device link phy-fe8a0000.usb2-phy.1: -ENOENT
[    7.613148] phy phy-fe8a0000.usb2-phy.1: Looking up vbus-supply from device tree
[    7.613169] phy phy-fe8a0000.usb2-phy.1: Looking up vbus-supply property in node /usb2-phy@fe8a0000/otg-port failed
[    7.617918] phy phy-fe830000.phy.2: Looking up phy-supply from device tree
[    7.617955] phy phy-fe830000.phy.2: Looking up phy-supply property in node /phy@fe830000 failed
[    7.618798] phy phy-fe840000.phy.3: Looking up phy-supply from device tree
[    7.618826] phy phy-fe840000.phy.3: Looking up phy-supply property in node /phy@fe840000 failed
[    7.626432] iep: Module initialized.
[    7.626576] mpp_service mpp-srv: 6849c1e28b7b author: Ding Wei 2023-12-28 video: rockchip: mpp: px30: fix issue combo_init when device probe
[    7.626595] mpp_service mpp-srv: probe start
[    7.633274] mpp_service mpp-srv: probe success
[    7.642008] dma-pl330 fe530000.dma-controller: Loaded driver for PL330 DMAC-241330
[    7.642044] dma-pl330 fe530000.dma-controller:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    7.646157] dma-pl330 fe550000.dma-controller: Loaded driver for PL330 DMAC-241330
[    7.646190] dma-pl330 fe550000.dma-controller:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    7.646922] rockchip-pvtm fde00000.pvtm: failed to retrieve pvtm_tz
[    7.647002] rockchip-pvtm fde00000.pvtm: pvtm@0 probed
[    7.647213] rockchip-pvtm fde80000.pvtm: failed to retrieve pvtm_tz
[    7.647275] rockchip-pvtm fde80000.pvtm: pvtm@1 probed
[    7.647449] rockchip-pvtm fde90000.pvtm: failed to retrieve pvtm_tz
[    7.647516] rockchip-pvtm fde90000.pvtm: pvtm@2 probed
[    7.649083] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[    7.650242] arm-scmi firmware:scmi: Failed. SCMI protocol 22 not active.
[    7.650753] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[    7.652774] fe650000.serial: ttyS1 at MMIO 0xfe650000 (irq = 29, base_baud = 1500000) is a 16550A
[    7.653105] serial serial0: tty port ttyS1 registered
[    7.657318] led_vk2c21_init
[    7.657549] random: crng init done
[    7.658379] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up vpu-supply from device tree
[    7.658420] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up vpu-supply property in node /power-management@fdd90000/power-controller failed
[    7.659560] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up rga-supply from device tree
[    7.659598] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up rga-supply property in node /power-management@fdd90000/power-controller failed
[    7.662568] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up rkvenc-supply from device tree
[    7.662613] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up rkvenc-supply property in node /power-management@fdd90000/power-controller failed
[    7.663735] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up rkvdec-supply from device tree
[    7.663772] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up rkvdec-supply property in node /power-management@fdd90000/power-controller failed
[    7.683593] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    7.685362] brd: module loaded
[    7.695167] loop: module loaded
[    7.695859] rbd: loaded (major 254)
[    7.696350] lkdtm: No crash points registered, enable through debugfs
[    7.699886] SPI driver spidev has no spi_device_id for rockchip,spidev
[    7.706127] usbcore: registered new interface driver rndis_wlan
[    7.706219] usbcore: registered new interface driver asix
[    7.706290] usbcore: registered new interface driver cdc_ether
[    7.706360] usbcore: registered new interface driver rndis_host
[    7.706447] usbcore: registered new interface driver cdc_ncm
[    7.706832] VFIO - User Level meta-driver version: 0.3
[    7.722372] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    7.722433] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    7.722651] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000022010010
[    7.722751] xhci-hcd xhci-hcd.0.auto: irq 38, io mem 0xfcc00000
[    7.723010] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    7.723041] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[    7.723072] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[    7.723531] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[    7.723554] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    7.723569] usb usb1: Product: xHCI Host Controller
[    7.723580] usb usb1: Manufacturer: Linux 6.1.43-vendor-rk35xx xhci-hcd
[    7.723592] usb usb1: SerialNumber: xhci-hcd.0.auto
[    7.724534] hub 1-0:1.0: USB hub found
[    7.724619] hub 1-0:1.0: 1 port detected
[    7.725484] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    7.725808] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[    7.725832] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    7.725847] usb usb2: Product: xHCI Host Controller
[    7.725859] usb usb2: Manufacturer: Linux 6.1.43-vendor-rk35xx xhci-hcd
[    7.725870] usb usb2: SerialNumber: xhci-hcd.0.auto
[    7.726704] hub 2-0:1.0: USB hub found
[    7.726784] hub 2-0:1.0: 1 port detected
[    7.727765] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    7.727805] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 3
[    7.728006] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000800002010010
[    7.728177] xhci-hcd xhci-hcd.1.auto: irq 39, io mem 0xfd000000
[    7.728443] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    7.728480] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 4
[    7.728510] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[    7.728900] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[    7.728924] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    7.728939] usb usb3: Product: xHCI Host Controller
[    7.728951] usb usb3: Manufacturer: Linux 6.1.43-vendor-rk35xx xhci-hcd
[    7.728963] usb usb3: SerialNumber: xhci-hcd.1.auto
[    7.729827] hub 3-0:1.0: USB hub found
[    7.729913] hub 3-0:1.0: 1 port detected
[    7.730755] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    7.731060] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[    7.731083] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    7.731099] usb usb4: Product: xHCI Host Controller
[    7.731111] usb usb4: Manufacturer: Linux 6.1.43-vendor-rk35xx xhci-hcd
[    7.731122] usb usb4: SerialNumber: xhci-hcd.1.auto
[    7.732105] hub 4-0:1.0: USB hub found
[    7.732188] hub 4-0:1.0: 1 port detected
[    7.733109] usbcore: registered new interface driver cdc_acm
[    7.733125] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    7.733590] usbcore: registered new interface driver uas
[    7.733787] usbcore: registered new interface driver usb-storage
[    7.734736] mousedev: PS/2 mouse device common for all mice
[    7.736099] i2c_dev: i2c /dev entries driver
[    7.739022] fan53555-regulator 0-001c: FAN53555 Option[12] Rev[15] Detected!
[    7.739081] fan53555-regulator 0-001c: Looking up vin-supply from device tree
[    7.739117] vdd_cpu: supplied by vcc5v0_sys
[    7.739146] vcc5v0_sys: could not add device link regulator.7: -ENOENT
[    7.742192] vdd_cpu: 900 <--> 1200 mV at 1150 mV, enabled
[    7.744149] dw-apb-uart fe650000.serial: Failed to create device link (0x180) with 0-0020
[    7.747528] rk808 0-0020: chip id: 0x8090
[    7.747609] rk808 0-0020: No cache defaults, reading back from HW
[    7.771548] rk808 0-0020: source: on=0x40, off=0x00
[    7.771597] rk808 0-0020: support dcdc3 fb mode:-22, 1
[    7.771616] rk808 0-0020: support pmic reset mode:0,0
[    7.783309] rk808-regulator rk808-regulator: there is no dvs0 gpio
[    7.783371] rk808-regulator rk808-regulator: there is no dvs1 gpio
[    7.783472] rk808 0-0020: Looking up vcc1-supply from device tree
[    7.783507] vdd_logic: supplied by vcc3v3_sys
[    7.783523] vcc3v3_sys: could not add device link regulator.8: -ENOENT
[    7.784453] vdd_logic: 900 <--> 1100 mV at 900 mV, enabled
[    7.785048] rk808 0-0020: Looking up vcc2-supply from device tree
[    7.785079] vdd_gpu: supplied by vcc3v3_sys
[    7.785095] vcc3v3_sys: could not add device link regulator.9: -ENOENT
[    7.785940] vdd_gpu: 900 <--> 1350 mV at 900 mV, enabled
[    7.786406] rk808 0-0020: Looking up vcc3-supply from device tree
[    7.786436] vcc_ddr: supplied by vcc3v3_sys
[    7.786452] vcc3v3_sys: could not add device link regulator.10: -ENOENT
[    7.786911] vcc_ddr: at 500 mV, enabled
[    7.787354] rk808 0-0020: Looking up vcc4-supply from device tree
[    7.787382] vdd_npu: supplied by vcc3v3_sys
[    7.787398] vcc3v3_sys: could not add device link regulator.11: -ENOENT
[    7.788265] vdd_npu: 900 <--> 1350 mV at 900 mV, enabled
[    7.788739] rk808 0-0020: Looking up vcc9-supply from device tree
[    7.788770] vcc_1v8: supplied by vcc3v3_sys
[    7.788787] vcc3v3_sys: could not add device link regulator.12: -ENOENT
[    7.789620] vcc_1v8: 1800 mV, enabled
[    7.790060] rk808 0-0020: Looking up vcc5-supply from device tree
[    7.790089] vdda0v9_image: supplied by vcc3v3_sys
[    7.790105] vcc3v3_sys: could not add device link regulator.13: -ENOENT
[    7.791476] vdda0v9_image: 900 mV, enabled
[    7.791910] rk808 0-0020: Looking up vcc5-supply from device tree
[    7.791938] vdda_0v9: supplied by vcc3v3_sys
[    7.791954] vcc3v3_sys: could not add device link regulator.14: -ENOENT
[    7.793335] vdda_0v9: 900 mV, enabled
[    7.793796] rk808 0-0020: Looking up vcc5-supply from device tree
[    7.793824] vdda0v9_pmu: supplied by vcc3v3_sys
[    7.793848] vcc3v3_sys: could not add device link regulator.15: -ENOENT
[    7.794877] vdda0v9_pmu: 900 mV, enabled
[    7.795296] rk808 0-0020: Looking up vcc6-supply from device tree
[    7.795325] vccio_acodec: supplied by vcc3v3_sys
[    7.795342] vcc3v3_sys: could not add device link regulator.16: -ENOENT
[    7.795401] vccio_acodec: Bringing 3000000uV into 3300000-3300000uV
[    7.795816] vccio_acodec: No configuration
[    7.796753] vccio_acodec: 3300 mV, enabled
[    7.797208] rk808 0-0020: Looking up vcc6-supply from device tree
[    7.797236] vccio_sd: supplied by vcc3v3_sys
[    7.797253] vcc3v3_sys: could not add device link regulator.17: -ENOENT
[    7.798620] vccio_sd: 1800 <--> 3300 mV at 3300 mV, enabled
[    7.799074] rk808 0-0020: Looking up vcc6-supply from device tree
[    7.799104] vcc3v3_pmu: supplied by vcc3v3_sys
[    7.799120] vcc3v3_sys: could not add device link regulator.18: -ENOENT
[    7.800149] vcc3v3_pmu: 3300 mV, enabled
[    7.800595] rk808 0-0020: Looking up vcc7-supply from device tree
[    7.800624] vcca_1v8: supplied by vcc3v3_sys
[    7.800640] vcc3v3_sys: could not add device link regulator.19: -ENOENT
[    7.802043] vcca_1v8: 1800 mV, enabled
[    7.802554] rk808 0-0020: Looking up vcc7-supply from device tree
[    7.802585] vcca1v8_pmu: supplied by vcc3v3_sys
[    7.802602] vcc3v3_sys: could not add device link regulator.20: -ENOENT
[    7.803606] vcca1v8_pmu: 1800 mV, enabled
[    7.804028] rk808 0-0020: Looking up vcc7-supply from device tree
[    7.804057] vcca1v8_image: supplied by vcc3v3_sys
[    7.804073] vcc3v3_sys: could not add device link regulator.21: -ENOENT
[    7.805477] vcca1v8_image: 1800 mV, enabled
[    7.805963] rk808 0-0020: Looking up vcc9-supply from device tree
[    7.805993] vcc_3v3: supplied by vcc3v3_sys
[    7.806011] vcc3v3_sys: could not add device link regulator.22: -ENOENT
[    7.806844] vcc_3v3: at 3300 mV, enabled
[    7.807272] rk808 0-0020: Looking up vcc8-supply from device tree
[    7.807300] vcc3v3_sd: supplied by vcc3v3_sys
[    7.807317] vcc3v3_sys: could not add device link regulator.23: -ENOENT
[    7.808196] vcc3v3_sd: at 3300 mV, enabled
[    7.808592] rk817-battery: Failed to locate of_node [id: -1]
[    7.808826] rk817-battery rk817-battery: Failed to find matching dt id
[    7.809004] rk817-charger: Failed to locate of_node [id: -1]
[    7.809193] rk817-charger rk817-charger: Failed to find matching dt id
[    7.812917] input: rk805 pwrkey as /devices/platform/fdd40000.i2c/i2c-0/0-0020/rk805-pwrkey/input/input0
[    7.820541] rk808-rtc rk808-rtc: registered as rtc0
[    7.822386] rk808-rtc rk808-rtc: setting system clock to 2017-08-04T09:00:10 UTC (1501837210)
[    7.823547] dw-apb-uart fe650000.serial: Failed to create device link (0x180) with 0-0020
[    7.828340] rockchip-mipi-csi2-hw fdfb0000.mipi-csi2-hw: enter mipi csi2 hw probe!
[    7.828762] rockchip-mipi-csi2-hw fdfb0000.mipi-csi2-hw: probe success, v4l2_dev:mipi-csi2-hw!
[    7.834182] usbcore: registered new interface driver uvcvideo
[    7.837860] cpu cpu0: Failed to get specification_serial_number
[    7.837930] cpu cpu0: Failed to get leakage
[    7.837970] cpu cpu0: Looking up cpu-supply from device tree
[    7.839157] cpu cpu0: soc version=0, speed=0
[    7.839239] cpu cpu0: Looking up cpu-supply from device tree
[    7.842081] cpu cpu0: avs=0
[    7.842431] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=1416000000 h_limit=0 h_table=0
[    7.846182] cpu cpu0: EM: OPP:600000 is inefficient
[    7.846543] cpu cpu0: EM: created perf domain
[    7.850871] sdhci: Secure Digital Host Controller Interface driver
[    7.850886] sdhci: Copyright(c) Pierre Ossman
[    7.850890] Synopsys Designware Multimedia Card Interface Driver
[    7.851350] sdhci-pltfm: SDHCI platform and OF driver helper
[    7.851967] dwmmc_rockchip fe2b0000.mmc: No normal pinctrl state
[    7.851983] dwmmc_rockchip fe2b0000.mmc: No idle pinctrl state
[    7.852909] dwmmc_rockchip fe2c0000.mmc: No normal pinctrl state
[    7.852931] dwmmc_rockchip fe2c0000.mmc: No idle pinctrl state
[    7.853177] dwmmc_rockchip fe2b0000.mmc: IDMAC supports 32-bit address mode.
[    7.853240] dwmmc_rockchip fe2b0000.mmc: Using internal DMA controller.
[    7.853251] dwmmc_rockchip fe2b0000.mmc: Version ID is 270a
[    7.853256] sdhci-dwcmshc fe310000.mmc: Looking up vmmc-supply from device tree
[    7.853268] sdhci-dwcmshc fe310000.mmc: Looking up vmmc-supply property in node /mmc@fe310000 failed
[    7.853308] dwmmc_rockchip fe2b0000.mmc: DW MMC controller at irq 70,32 bit host data width,256 deep fifo
[    7.853312] sdhci-dwcmshc fe310000.mmc: Looking up vqmmc-supply from device tree
[    7.853321] sdhci-dwcmshc fe310000.mmc: Looking up vqmmc-supply property in node /mmc@fe310000 failed
[    7.853402] dwmmc_rockchip fe2b0000.mmc: Looking up vmmc-supply from device tree
[    7.853415] dwmmc_rockchip fe2b0000.mmc: Looking up vmmc-supply property in node /mmc@fe2b0000 failed
[    7.853438] dwmmc_rockchip fe2b0000.mmc: Looking up vqmmc-supply from device tree
[    7.853911] ledtrig-cpu: registered to indicate activity on CPUs
[    7.853979] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
[    7.854065] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    7.854153] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.
[    7.854187] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.
[    7.854198] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a
[    7.854260] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 71,32 bit host data width,256 deep fifo
[    7.854344] dwmmc_rockchip fe2c0000.mmc: Looking up vmmc-supply from device tree
[    7.854461] dwmmc_rockchip fe2c0000.mmc: Looking up vqmmc-supply from device tree
[    7.854957] dwmmc_rockchip fe2c0000.mmc: allocated mmc-pwrseq
[    7.854983] mmc_host mmc2: card is non-removable.
[    7.855280] cryptodev: driver 1.12 loaded.
[    7.855341] hid: raw HID events driver (C) Jiri Kosina
[    7.855712] usbcore: registered new interface driver usbhid
[    7.855727] usbhid: USB HID core driver
[    7.856030] rockchip,bus bus-npu: Looking up bus-supply from device tree
[    7.856244] rockchip,bus bus-npu: bin=0
[    7.856268] rockchip,bus bus-npu: Failed to get leakage
[    7.856286] rockchip,bus bus-npu: Looking up pvtm-supply from device tree
[    7.857136] rockchip,bus bus-npu: Looking up pvtm-supply from device tree
[    7.857991] rockchip,bus bus-npu: avs=0
[    7.861883] rockchip-saradc fe720000.saradc: Looking up vref-supply from device tree
[    7.862988] SPI driver inv-icm42600-spi has no spi_device_id for invensense,icm42600
[    7.863004] SPI driver inv-icm42600-spi has no spi_device_id for invensense,icm42602
[    7.863009] SPI driver inv-icm42600-spi has no spi_device_id for invensense,icm42605
[    7.863013] SPI driver inv-icm42600-spi has no spi_device_id for invensense,icm42622
[    7.863682] optee: probing for conduit method.
[    7.863697] optee: api uid mismatch
[    7.863701] optee: probe of firmware:optee failed with error -22
[    7.864432] usbcore: registered new interface driver snd-usb-audio
[    7.864860] mmc_host mmc1: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[    7.866488] rk817-codec rk817-codec: DMA mask not set
[    7.868392] [Awinic] aw87xxx_pa_init:driver version: v2.2.0
[    7.873144] rk-multicodecs rk809-sound: Failed to get ADC channel
[    7.873303] rk-multicodecs rk809-sound: ASoC: Property 'rockchip,audio-routing' does not exist or its length is not even
[    7.874530] rk817-codec rk817-codec: rk817_probe: chip_name:0x80, chip_ver:0x94
[    7.878784] rk-multicodecs rk809-sound: Don't need to map headset detect gpio to irq
[    7.881356] Initializing XFRM netlink socket
[    7.881433] NET: Registered PF_PACKET protocol family
[    7.881610] [BT_RFKILL]: Enter rfkill_rk_init
[    7.881617] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    7.882067] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[    7.882136] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6356s
[    7.882143] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[    7.882147] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[    7.882176] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[    7.882180] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[    7.882186] [WLAN_RFKILL]: rfkill_set_wifi_bt_power: 1
[    7.882192] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[    7.882630] Key type dns_resolver registered
[    7.882668] Key type ceph registered
[    7.883182] libceph: loaded (mon/osd proto 15/24)
[    7.884915] mmc0: SDHCI controller on fe310000.mmc [fe310000.mmc] using ADMA
[    7.885092] registered taskstats version 1
[    7.885120] Loading compiled-in X.509 certificates
[    7.886258] Btrfs loaded, crc32c=crc32c-generic, zoned=no, fsverity=no
[    7.886703] pstore: Using crash dump compression: deflate
[    7.894951] rga: rga2, irq = 76, match scheduler
[    7.895373] rga: rga2 hardware loaded successfully, hw_version:3.2.63318.
[    7.895435] rga: rga2 probe successfully
[    7.895785] rga_iommu: IOMMU binding successfully, default mapping core[0x4]
[    7.896029] rga: Module initialized. v1.3.1
[    7.919148] rockchip-iodomain fdc20000.syscon:io-domains: Looking up pmuio1-supply from device tree
[    7.919389] rockchip-iodomain fdc20000.syscon:io-domains: pmuio1(3300000 uV) supplied by vcc3v3_pmu
[    7.919402] rockchip-iodomain fdc20000.syscon:io-domains: Looking up pmuio2-supply from device tree
[    7.919492] rockchip-iodomain fdc20000.syscon:io-domains: pmuio2(3300000 uV) supplied by vcc3v3_pmu
[    7.919503] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio1-supply from device tree
[    7.919641] rockchip-iodomain fdc20000.syscon:io-domains: vccio1(3300000 uV) supplied by vccio_acodec
[    7.919652] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio2-supply from device tree
[    7.919749] rockchip-iodomain fdc20000.syscon:io-domains: vccio2(1800000 uV) supplied by vcc_1v8
[    7.919761] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio3-supply from device tree
[    7.919858] rockchip-iodomain fdc20000.syscon:io-domains: vccio3(3300000 uV) supplied by vccio_sd
[    7.919870] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio4-supply from device tree
[    7.919923] rockchip-iodomain fdc20000.syscon:io-domains: vccio4(1800000 uV) supplied by vcc_1v8
[    7.919934] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio5-supply from device tree
[    7.920067] rockchip-iodomain fdc20000.syscon:io-domains: vccio5(3300000 uV) supplied by vcc_3v3
[    7.920079] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio6-supply from device tree
[    7.920127] rockchip-iodomain fdc20000.syscon:io-domains: vccio6(1800000 uV) supplied by vcc_1v8
[    7.920138] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio7-supply from device tree
[    7.920192] rockchip-iodomain fdc20000.syscon:io-domains: vccio7(3300000 uV) supplied by vcc_3v3
[    7.920631] mpp_rkvenc fdf40000.rkvenc: Adding to iommu group 4
[    7.920844] mpp_rkvenc fdf40000.rkvenc: probing start
[    7.921130] mpp_rkvenc fdf40000.rkvenc: Looking up venc-supply from device tree
[    7.921315] mpp_rkvenc fdf40000.rkvenc: bin=0
[    7.921340] mpp_rkvenc fdf40000.rkvenc: Failed to get leakage
[    7.921358] mpp_rkvenc fdf40000.rkvenc: Looking up venc-supply from device tree
[    7.921377] vdd_logic: could not add device link fdf40000.rkvenc: -EEXIST
[    7.921511] mpp_rkvenc fdf40000.rkvenc: Looking up venc-supply from device tree
[    7.921531] debugfs: Directory 'fdf40000.rkvenc-venc' with parent 'vdd_logic' already present!
[    7.921540] vdd_logic: Failed to create debugfs directory
[    7.921756] mpp_rkvenc fdf40000.rkvenc: avs=0
[    7.921958] mpp_rkvenc fdf40000.rkvenc: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[    7.922656] mpp_rkvenc fdf40000.rkvenc: probing finish
[    7.923164] mpp_vdpu2 fdea0400.vdpu: Adding to iommu group 0
[    7.923350] mpp_vdpu2 fdea0400.vdpu: probe device
[    7.923923] mpp_vdpu2 fdea0400.vdpu: probing finish
[    7.924374] mpp_vepu2 fdee0000.vepu: Adding to iommu group 2
[    7.924571] mpp_vepu2 fdee0000.vepu: probing start
[    7.926013] mpp_vepu2 fdee0000.vepu: probing finish
[    7.926482] mpp-iep2 fdef0000.iep: Adding to iommu group 3
[    7.926670] mpp-iep2 fdef0000.iep: probe device
[    7.926954] mpp-iep2 fdef0000.iep: allocate roi buffer failed
[    7.927300] mpp-iep2 fdef0000.iep: probing finish
[    7.927794] mpp_jpgdec fded0000.jpegd: Adding to iommu group 1
[    7.927979] mpp_jpgdec fded0000.jpegd: probe device
[    7.928794] mpp_jpgdec fded0000.jpegd: probing finish
[    7.929300] mpp_rkvdec2 fdf80200.rkvdec: Adding to iommu group 5
[    7.929526] mpp_rkvdec2 fdf80200.rkvdec: rkvdec, probing start
[    7.929868] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_a is not found!
[    7.929876] rkvdec2_init:982: No niu aclk reset resource define
[    7.929883] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_h is not found!
[    7.929888] rkvdec2_init:985: No niu hclk reset resource define
[    7.929911] mpp_rkvdec2 fdf80200.rkvdec: Looking up vdec-supply from device tree
[    7.930119] mpp_rkvdec2 fdf80200.rkvdec: bin=0
[    7.930193] mpp_rkvdec2 fdf80200.rkvdec: Failed to get leakage
[    7.930209] mpp_rkvdec2 fdf80200.rkvdec: Looking up vdec-supply from device tree
[    7.930230] vdd_logic: could not add device link fdf80200.rkvdec: -EEXIST
[    7.930242] debugfs: File 'uA_load' in directory '/' already present!
[    7.930252] debugfs: File 'min_uV' in directory '/' already present!
[    7.930258] debugfs: File 'max_uV' in directory '/' already present!
[    7.930264] debugfs: File 'constraint_flags' in directory '/' already present!
[    7.930320] mpp_rkvdec2 fdf80200.rkvdec: Looking up vdec-supply from device tree
[    7.930338] debugfs: Directory 'fdf80200.rkvdec-vdec' with parent 'vdd_logic' already present!
[    7.930344] vdd_logic: Failed to create debugfs directory
[    7.930542] mpp_rkvdec2 fdf80200.rkvdec: avs=0
[    7.930732] mpp_rkvdec2 fdf80200.rkvdec: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[    7.930907] mpp_rkvdec2 fdf80200.rkvdec: sram_start 0x00000000fdcc0000
[    7.930916] mpp_rkvdec2 fdf80200.rkvdec: rcb_iova 0x0000000010000000
[    7.930921] mpp_rkvdec2 fdf80200.rkvdec: sram_size 45056
[    7.930927] mpp_rkvdec2 fdf80200.rkvdec: rcb_size 65536
[    7.930933] mpp_rkvdec2 fdf80200.rkvdec: min_width 512
[    7.930993] mpp_rkvdec2 fdf80200.rkvdec: link mode probe finish
[    7.931061] mpp_rkvdec2 fdf80200.rkvdec: probing finish
[    7.931704] rockchip-vop2 fe040000.vop: Adding to iommu group 6
[    7.932243] [drm] all windows should be assigned, full plane mask: 0x3f, current plane mask: 0x0
[    7.932255] [drm] use default plane mask
[    7.932407] [drm] RK3566 only support 2 vps
[    7.932425] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x15, primary plane phy id: 4
[    7.932444] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp1 assign plane mask: 0x22, primary plane phy id: 5
[    7.932453] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x8, primary plane phy id: 3
[    7.932742] [drm] failed to init overlay plane Cluster0-win1
[    7.932784] [drm] failed to init overlay plane Cluster1-win1
[    7.932950] rockchip-vop2 fe040000.vop: bin=0
[    7.932978] rockchip-vop2 fe040000.vop: Failed to get leakage
[    7.933023] rockchip-vop2 fe040000.vop: Looking up vop-supply from device tree
[    7.933444] rockchip-vop2 fe040000.vop: Looking up vop-supply from device tree
[    7.933872] rockchip-vop2 fe040000.vop: avs=0
[    7.934023] rockchip-vop2 fe040000.vop: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[    7.934451] rockchip-vop2 fe040000.vop: Supported VOP aclk dvfs, normal mode:396000000, advanced mode:500000000
[    7.934469] rockchip-drm display-subsystem: bound fe040000.vop (ops 0xffff8000092d7c18)
[    7.934612] dwhdmi-rockchip fe0a0000.hdmi: Looking up avdd-0v9-supply from device tree
[    7.934624] dwhdmi-rockchip fe0a0000.hdmi: Looking up avdd-0v9-supply property in node /hdmi@fe0a0000 failed
[    7.934665] dwhdmi-rockchip fe0a0000.hdmi: Looking up avdd-1v8-supply from device tree
[    7.934675] dwhdmi-rockchip fe0a0000.hdmi: Looking up avdd-1v8-supply property in node /hdmi@fe0a0000 failed
[    7.934871] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[    7.935772] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver
[    7.936325] dwhdmi-rockchip fe0a0000.hdmi: error -ENXIO: IRQ index 1 not found
[    7.937259] input: hdmi_cec_key as /devices/platform/fe0a0000.hdmi/dw-hdmi-cec.5.auto/input/input1
[    7.938219] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops 0xffff8000092e9ff0)
[    7.938993] rockchip-drm display-subsystem: failed to parse loader memory
[    7.939890] [drm] Initialized rockchip 3.0.0 20140818 for display-subsystem on minor 0
[    7.941581] mmc0: Host Software Queue enabled
[    7.941610] mmc0: new HS200 MMC card at address 0001
[    7.942264] mmcblk0: mmc0:0001 CJNB4R 58.2 GiB
[    7.946375] GPT:Primary header thinks Alt. header is not at the end of the disk.
[    7.946394] GPT:14280703 != 122142719
[    7.946402] GPT:Alternate GPT header not at the end of the disk.
[    7.946405] GPT:14280703 != 122142719
[    7.946409] GPT: Use GNU Parted to correct GPT errors.
[    7.946437]  mmcblk0: p1
[    7.947111] mmcblk0boot0: mmc0:0001 CJNB4R 4.00 MiB
[    7.948433] mmcblk0boot1: mmc0:0001 CJNB4R 4.00 MiB
[    7.949616] mmcblk0rpmb: mmc0:0001 CJNB4R 4.00 MiB, chardev (235:0)
[    7.978207] usb 3-1: new full-speed USB device number 2 using xhci-hcd
[    7.991119] vendor storage:20190527 ret = 0
[    8.054313] rockchip-vop2 fe040000.vop: [drm:vop2_crtc_atomic_enable] Update mode to 3840x2160p60, type: 11(if:800, flag:0x0) for vp0 dclk: 594000000
[    8.074964] mmc_host mmc2: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[    8.124275] usb 3-1: New USB device found, idVendor=0a05, idProduct=7211, bcdDevice= 1.00
[    8.124295] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    8.124300] usb 3-1: Product: USB2.0 HUB
[    8.141110] Freeing initrd memory: 16160K
[    8.224146] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 100000000Hz, actual 50000000HZ div = 0)
[    8.250660] dwmmc_rockchip fe2c0000.mmc: Successfully tuned phase to 360
[    8.258601] mmc2: new ultra high speed SDR50 SDIO card at address 0001
[    8.370200] hub 3-1:1.0: USB hub found
[    8.370688] hub 3-1:1.0: 4 ports detected
[    8.404923] Console: switching to colour frame buffer device 480x135
[    8.606822] rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device
[    8.611147] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up gpu-supply from device tree
[    8.611230] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up gpu-supply property in node /power-management@fdd90000/power-controller failed
[    8.611578] mali fde60000.gpu: Kernel DDK version g18p0-01eac0
[    8.611598] mali fde60000.gpu: error -ENXIO: IRQ JOB not found
[    8.611823] mali fde60000.gpu: error -ENXIO: IRQ MMU not found
[    8.611921] mali fde60000.gpu: error -ENXIO: IRQ GPU not found
[    8.611966] mali fde60000.gpu: Insufficient register space, will override to the required size
[    8.611979] mali fde60000.gpu: Register window unavailable
[    8.611985] mali fde60000.gpu: Failed to map registers
[    8.611989] mali fde60000.gpu: Register map failed error = -5
[    8.612020] mali fde60000.gpu: Device initialization failed
[    8.612067] mali: probe of fde60000.gpu failed with error -5
[    8.612459] rk_gmac-dwmac fe010000.ethernet: IRQ eth_lpi not found
[    8.612668] rk_gmac-dwmac fe010000.ethernet: Looking up phy-supply from device tree
[    8.612839] rk_gmac-dwmac fe010000.ethernet: clock input or output? (input).
[    8.612848] rk_gmac-dwmac fe010000.ethernet: TX delay(0x4f).
[    8.612855] rk_gmac-dwmac fe010000.ethernet: RX delay(0x24).
[    8.612867] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no).
[    8.612898] rk_gmac-dwmac fe010000.ethernet: clock input from PHY
[    8.613143] rk_gmac-dwmac fe010000.ethernet: init for RGMII
[    8.613520] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[    8.613535] rk_gmac-dwmac fe010000.ethernet:     DWMAC4/5
[    8.613543] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported
[    8.613548] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported
[    8.613553] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported
[    8.613557] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported
[    8.613621] rk_gmac-dwmac fe010000.ethernet: TSO supported
[    8.613628] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    8.613636] rk_gmac-dwmac fe010000.ethernet: Enabled RFS Flow TC (entries=10)
[    8.613648] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled
[    8.613655] rk_gmac-dwmac fe010000.ethernet: Using 32/32 bits DMA host/device width
[    8.769872] rockchip-dmc dmc: Failed to get specification_serial_number
[    8.769910] rockchip-dmc dmc: Failed to get leakage
[    8.769933] rockchip-dmc dmc: Looking up center-supply from device tree
[    8.770413] rockchip-dmc dmc: soc version=0, speed=0
[    8.770554] rockchip-dmc dmc: Looking up center-supply from device tree
[    8.770801] rockchip-dmc dmc: avs=0
[    8.770823] rockchip-dmc dmc: current ATF version 0x102
[    8.771890] rockchip-dmc dmc: normal_rate = 780000000
[    8.771906] rockchip-dmc dmc: reboot_rate = 1056000000
[    8.771913] rockchip-dmc dmc: suspend_rate = 324000000
[    8.771921] rockchip-dmc dmc: video_4k_rate = 780000000
[    8.771927] rockchip-dmc dmc: video_4k_10b_rate = 780000000
[    8.771934] rockchip-dmc dmc: boost_rate = 1056000000
[    8.771940] rockchip-dmc dmc: fixed_rate(isp|cif0|cif1|dualview) = 1056000000
[    8.771947] rockchip-dmc dmc: performance_rate = 1056000000
[    8.771970] rockchip-dmc dmc: failed to get vop pn to msch rl
[    8.772297] rockchip-dmc dmc: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[    8.797270] WCN: marlin_init entry!
[    8.799294] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up npu-supply from device tree
[    8.799336] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up npu-supply property in node /power-management@fdd90000/power-controller failed
[    8.799458] RKNPU fde40000.npu: RKNPU: rknpu iommu is disabled, using non-iommu mode
[    8.799478] RKNPU fde40000.npu: assigned reserved memory node rknpu
[    8.799488] RKNPU fde40000.npu: RKNPU: initialize reserved memory for rknpu device!
[    8.799551] RKNPU fde40000.npu: Looking up rknpu-supply from device tree
[    8.799842] RKNPU fde40000.npu: Looking up mem-supply from device tree
[    8.800063] RKNPU fde40000.npu: error -ENXIO: IRQ npu_irq not found
[    8.801011] [drm] Initialized rknpu 0.9.6 20240322 for fde40000.npu on minor 1
[    8.801768] RKNPU fde40000.npu: Failed to get specification_serial_number
[    8.801806] RKNPU fde40000.npu: Failed to get leakage
[    8.801836] RKNPU fde40000.npu: Looking up rknpu-supply from device tree
[    8.801885] vdd_npu: could not add device link fde40000.npu: -EEXIST
[    8.801907] debugfs: File 'uA_load' in directory '/' already present!
[    8.801921] debugfs: File 'min_uV' in directory '/' already present!
[    8.801930] debugfs: File 'max_uV' in directory '/' already present!
[    8.801939] debugfs: File 'constraint_flags' in directory '/' already present!
[    8.801989] RKNPU fde40000.npu: soc version=0, speed=0
[    8.802085] RKNPU fde40000.npu: Looking up rknpu-supply from device tree
[    8.802117] debugfs: Directory 'fde40000.npu-rknpu' with parent 'vdd_npu' already present!
[    8.802127] vdd_npu: Failed to create debugfs directory
[    8.802141] RKNPU fde40000.npu: Looking up mem-supply from device tree
[    8.802179] vdd_logic: could not add device link fde40000.npu: -EEXIST
[    8.802192] debugfs: File 'uA_load' in directory '/' already present!
[    8.802201] debugfs: File 'min_uV' in directory '/' already present!
[    8.802209] debugfs: File 'max_uV' in directory '/' already present!
[    8.802217] debugfs: File 'constraint_flags' in directory '/' already present!
[    8.802258] RKNPU fde40000.npu: opp_parse_supplies: Invalid number of elements in opp-microvolt property (3) with supplies (2)
[    8.802275] RKNPU fde40000.npu: _of_add_opp_table_v2: Failed to add OPP, -22
[    8.802289] RKNPU fde40000.npu: failed to add opp table
[    8.802361] RKNPU fde40000.npu: RKNPU: failed to init_opp_table
[    8.804001] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    8.826555] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    8.827820] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[    8.828646] rockchip-suspend not set sleep-mode-config for mem-lite
[    8.828662] rockchip-suspend not set wakeup-config for mem-lite
[    8.828671] rockchip-suspend not set sleep-mode-config for mem-ultra
[    8.828678] rockchip-suspend not set wakeup-config for mem-ultra
[    8.830458] ALSA device list:
[    8.830473]   #0: rockchip-rk809
[    8.830481]   #1: rockchip,hdmi
[    8.840255] Freeing unused kernel memory: 7488K
[    8.865490] Run /init as init process
[    8.865544]   with arguments:
[    8.865566]     /init
[    8.865583]     splash
[    8.865600]   with environment:
[    8.865614]     HOME=/
[    8.865630]     TERM=linux
[    8.865645]     ubootpart=6dcd74a8-9459-4861-aaa1-2e5e37833167
[    8.865663]     cgroup_enable=memory
[    8.865679]     cgroup_memory=1
[    9.001590] usb 3-1.2: new low-speed USB device number 3 using xhci-hcd
[    9.095752] usb 3-1.2: New USB device found, idVendor=17ef, idProduct=608d, bcdDevice= 1.00
[    9.095791] usb 3-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    9.095798] usb 3-1.2: Product: Lenovo USB Optical Mouse
[    9.095804] usb 3-1.2: Manufacturer: PixArt
[    9.290937] input: PixArt Lenovo USB Optical Mouse as /devices/platform/usbhost/fd000000.usb/xhci-hcd.1.auto/usb3/3-1/3-1.2/3-1.2:1.0/0003:17EF:608D.0001/input/input2
[    9.292710] hid-generic 0003:17EF:608D.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt Lenovo USB Optical Mouse] on usb-xhci-hcd.1.auto-1.2/input0
[    9.364890] usb 3-1.3: new low-speed USB device number 4 using xhci-hcd
[    9.368278] input: adc-keys as /devices/platform/adc-keys/input/input3
[    9.435436] panfrost fde60000.gpu: clock rate = 594000000
[    9.435487] panfrost fde60000.gpu: bus_clock rate = 500000000
[    9.435555] panfrost fde60000.gpu: Looking up mali-supply from device tree
[    9.438022] panfrost fde60000.gpu: mali-g52 id 0x7402 major 0x1 minor 0x0 status 0x0
[    9.438050] panfrost fde60000.gpu: features: 00000000,00000cf7, issues: 00000000,00000400
[    9.438058] panfrost fde60000.gpu: Features: L2:0x07110206 Shader:0x00000002 Tiler:0x00000209 Mem:0x1 MMU:0x00002823 AS:0xff JS:0x7
[    9.438066] panfrost fde60000.gpu: shader_present=0x1 l2_present=0x1
[    9.445809] [drm] Initialized panfrost 1.2.0 20180908 for fde60000.gpu on minor 2
[    9.466423] usb 3-1.3: New USB device found, idVendor=17ef, idProduct=6099, bcdDevice= 1.00
[    9.466457] usb 3-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    9.466465] usb 3-1.3: Product: Lenovo Traditional USB Keyboard
[    9.466471] usb 3-1.3: Manufacturer: Lenovo
[    9.688774] input: Lenovo Lenovo Traditional USB Keyboard as /devices/platform/usbhost/fd000000.usb/xhci-hcd.1.auto/usb3/3-1/3-1.3/3-1.3:1.0/0003:17EF:6099.0002/input/input4
[    9.745977] hid-generic 0003:17EF:6099.0002: input,hidraw1: USB HID v1.11 Keyboard [Lenovo Lenovo Traditional USB Keyboard] on usb-xhci-hcd.1.auto-1.3/input0
[   10.940710] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Quota mode: none.
[   11.313621] systemd[1]: System time before build time, advancing clock.
[   11.366009] systemd[1]: systemd 255.4-1ubuntu8 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[   11.366053] systemd[1]: Detected architecture arm64.
[   11.374008] systemd[1]: Hostname set to <nicolas-pc>.
[   12.259264] systemd[1]: Queued start job for default target graphical.target.
[   12.337014] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
[   12.339216] systemd[1]: Created slice user.slice - User and Session Slice.
[   12.339862] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
[   12.341149] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
[   12.341557] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
[   12.341894] systemd[1]: Reached target remote-fs.target - Remote File Systems.
[   12.342042] systemd[1]: Reached target slices.target - Slice Units.
[   12.342185] systemd[1]: Reached target snapd.mounts-pre.target - Mounting snaps.
[   12.342304] systemd[1]: Reached target snapd.mounts.target - Mounted snaps.
[   12.342512] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
[   12.343704] systemd[1]: Listening on syslog.socket - Syslog Socket.
[   12.344511] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
[   12.345071] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
[   12.345908] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
[   12.346846] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
[   12.348329] systemd[1]: Listening on systemd-oomd.socket - Userspace Out-Of-Memory (OOM) Killer Socket.
[   12.348645] systemd[1]: systemd-pcrextend.socket - TPM2 PCR Extension (Varlink) was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[   12.350151] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
[   12.351070] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[   12.356550] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
[   12.361755] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
[   12.368268] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
[   12.375897] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
[   12.403488] systemd[1]: Starting fake-hwclock-load.service - Restore the current clock...
[   12.411683] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
[   12.412897] systemd[1]: kmod-static-nodes.service - Create List of Static Device Nodes was skipped because of an unmet condition check (ConditionFileNotEmpty=/lib/modules/6.1.43-vendor-rk35xx/modules.devname).
[   12.423718] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
[   12.430198] (-hwclock)[307]: fake-hwclock-load.service: Referenced but unset environment variable evaluates to an empty string: FORCE
[   12.432562] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
[   12.445707] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
[   12.469969] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
[   12.486364] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
[   12.504026] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
[   12.505107] systemd[1]: snapd.apparmor.service - Load AppArmor profiles managed internally by snapd was skipped because of an unmet condition check (ConditionSecurity=apparmor).
[   12.505645] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
[   12.517069] systemd[1]: Starting systemd-journald.service - Journal Service...
[   12.530655] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
[   12.531381] systemd[1]: systemd-pcrmachine.service - TPM2 PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[   12.538793] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
[   12.547182] systemd[1]: Starting systemd-tmpfiles-setup-dev-early.service - Create Static Device Nodes in /dev gracefully...
[   12.548052] systemd[1]: systemd-tpm2-setup-early.service - TPM2 SRK Setup (Early) was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[   12.572979] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
[   12.593481] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
[   12.600427] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
[   12.602727] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
[   12.613079] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
[   12.615514] systemd[1]: fake-hwclock-load.service: Deactivated successfully.
[   12.616760] systemd[1]: Finished fake-hwclock-load.service - Restore the current clock.
[   12.632580] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[   12.633658] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
[   12.649347] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
[   12.650511] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
[   12.653740] systemd[1]: modprobe@drm.service: Deactivated successfully.
[   12.654521] systemd-journald[326]: Collecting audit messages is disabled.
[   12.654968] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
[   12.657164] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[   12.658997] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
[   12.662921] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[   12.664059] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
[   12.679441] systemd[1]: modprobe@loop.service: Deactivated successfully.
[   12.680526] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
[   12.683601] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
[   12.688288] systemd[1]: sys-fs-fuse-connections.mount - FUSE Control File System was skipped because of an unmet condition check (ConditionPathExists=/sys/fs/fuse/connections).
[   12.705101] EXT4-fs (mmcblk0p1): re-mounted. Quota mode: none.
[   12.762225] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
[   12.762796] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
[   12.769743] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables...
[   12.775854] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout.
[   12.778488] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
[   12.787390] systemd[1]: Finished systemd-tmpfiles-setup-dev-early.service - Create Static Device Nodes in /dev gracefully.
[   12.790912] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
[   12.799371] systemd[1]: Starting systemd-growfs-root.service - Grow Root File System...
[   12.802224] systemd[1]: systemd-hwdb-update.service - Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
[   12.802538] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
[   12.810173] systemd[1]: Starting systemd-random-seed.service - Load/Save OS Random Seed...
[   12.810987] systemd[1]: systemd-sysusers.service - Create System Users was skipped because no trigger condition checks were met.
[   12.829669] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev...
[   12.830253] systemd[1]: systemd-tpm2-setup.service - TPM2 SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[   12.909846] systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables.
[   12.964013] systemd[1]: Finished systemd-random-seed.service - Load/Save OS Random Seed.
[   12.980787] EXT4-fs (mmcblk0p1): resizing filesystem from 1780736 to 1780736 blocks
[   12.986510] systemd[1]: Finished systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev.
[   12.987570] systemd[1]: Reached target local-fs-pre.target - Preparation for Local File Systems.
[   13.006356] systemd[1]: Starting systemd-udevd.service - Rule-based Manager for Device Events and Files...
[   13.008179] systemd[1]: Finished systemd-growfs-root.service - Grow Root File System.
[   13.009248] systemd[1]: Reached target local-fs.target - Local File Systems.
[   13.015251] systemd[1]: Listening on systemd-sysext.socket - System Extension Image Management (Varlink).
[   13.022272] systemd[1]: Starting console-setup.service - Set console font and keymap...
[   13.050181] systemd[1]: Starting finalrd.service - Create final runtime dir for shutdown pivot root...
[   13.051238] systemd[1]: ldconfig.service - Rebuild Dynamic Linker Cache was skipped because no trigger condition checks were met.
[   13.052046] systemd[1]: mkswap.service - Create the default swapfile was skipped because of an unmet condition check (ConditionPathExists=!/swapfile).
[   13.063306] systemd[1]: Activating swap swapfile.swap - The default swapfile...
[   13.135653] systemd[1]: Starting plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data...
[   13.161206] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
[   13.182612] Adding 1048572k swap on /swapfile.  Priority:-2 extents:2 across:1081340k SS
[   13.183574] systemd[1]: Starting ufw.service - Uncomplicated firewall...
[   13.186565] systemd[1]: Activated swap swapfile.swap - The default swapfile.
[   13.190181] systemd[1]: Started systemd-journald.service - Journal Service.
[   13.407135] systemd-journald[326]: Received client request to flush runtime journal.
[   13.439989] systemd-journald[326]: /var/log/journal/69935652028348009f2319f39d9e18ec/system.journal: Realtime clock jumped backwards relative to last journal entry, rotating.
[   13.440043] systemd-journald[326]: Rotating system journal.
[   13.806775] rk_gmac-dwmac fe010000.ethernet end1: renamed from eth0
[   17.764828] loop0: detected capacity change from 0 to 8
[   19.542417] rockchip-thermal fe710000.tsadc: ch0 Missing trim_l property
[   19.542476] rockchip-thermal fe710000.tsadc: ch1 Missing trim_l property
[   19.559348] rockchip-thermal fe710000.tsadc: tsadc is probed successfully!
[   19.561296] platform spdif-sound: deferred probe pending
[   19.561329] platform mtd_vendor_storage: deferred probe pending
[   21.929329] rk_gmac-dwmac fe010000.ethernet end1: Register MEM_TYPE_PAGE_POOL RxQ-0
[   21.930046] phy_rtl8211f_led_fixup in
[   21.930190] phy_rtl8211f_led_fixup in  val=0x0a42
[   22.021512] rk_gmac-dwmac fe010000.ethernet end1: PHY [stmmac-1:00] driver [RTL8211F Gigabit Ethernet] (irq=POLL)
[   22.022074] dwmac4: Master AXI performs any burst length
[   22.022099] rk_gmac-dwmac fe010000.ethernet end1: No Safety Features support found
[   22.022132] rk_gmac-dwmac fe010000.ethernet end1: IEEE 1588-2008 Advanced Timestamp supported
[   22.022585] rk_gmac-dwmac fe010000.ethernet end1: registered PTP clock
[   22.023071] rk_gmac-dwmac fe010000.ethernet end1: configuring for phy/rgmii link mode
[   25.624329] hdmi-audio-codec hdmi-audio-codec.4.auto: Not able to map channels to speakers (-22)
[   25.624385] hdmi-audio-codec hdmi-audio-codec.4.auto: ASoC: error at snd_soc_dai_hw_params on i2s-hifi: -22
[   25.624407]  fe400000.i2s-i2s-hifi: ASoC: error at __soc_pcm_hw_params on fe400000.i2s-i2s-hifi: -22
[   25.624473] hdmi-audio-codec hdmi-audio-codec.4.auto: Not able to map channels to speakers (-22)
[   25.624487] hdmi-audio-codec hdmi-audio-codec.4.auto: ASoC: error at snd_soc_dai_hw_params on i2s-hifi: -22
[   25.624499]  fe400000.i2s-i2s-hifi: ASoC: error at __soc_pcm_hw_params on fe400000.i2s-i2s-hifi: -22
[   25.624559] hdmi-audio-codec hdmi-audio-codec.4.auto: Not able to map channels to speakers (-22)
[   25.624571] hdmi-audio-codec hdmi-audio-codec.4.auto: ASoC: error at snd_soc_dai_hw_params on i2s-hifi: -22
[   25.624582]  fe400000.i2s-i2s-hifi: ASoC: error at __soc_pcm_hw_params on fe400000.i2s-i2s-hifi: -22
[   25.624634] hdmi-audio-codec hdmi-audio-codec.4.auto: Not able to map channels to speakers (-22)
[   25.624647] hdmi-audio-codec hdmi-audio-codec.4.auto: ASoC: error at snd_soc_dai_hw_params on i2s-hifi: -22
[   25.624657]  fe400000.i2s-i2s-hifi: ASoC: error at __soc_pcm_hw_params on fe400000.i2s-i2s-hifi: -22
[   25.624714] hdmi-audio-codec hdmi-audio-codec.4.auto: Not able to map channels to speakers (-22)
[   25.624727] hdmi-audio-codec hdmi-audio-codec.4.auto: ASoC: error at snd_soc_dai_hw_params on i2s-hifi: -22
[   25.624930]  fe400000.i2s-i2s-hifi: ASoC: error at __soc_pcm_hw_params on fe400000.i2s-i2s-hifi: -22
[   25.629959] hdmi-audio-codec hdmi-audio-codec.4.auto: Not able to map channels to speakers (-22)
[   25.630012] hdmi-audio-codec hdmi-audio-codec.4.auto: ASoC: error at snd_soc_dai_hw_params on i2s-hifi: -22
[   25.630034]  fe400000.i2s-i2s-hifi: ASoC: error at __soc_pcm_hw_params on fe400000.i2s-i2s-hifi: -22
[   25.630100] hdmi-audio-codec hdmi-audio-codec.4.auto: Not able to map channels to speakers (-22)
[   25.630114] hdmi-audio-codec hdmi-audio-codec.4.auto: ASoC: error at snd_soc_dai_hw_params on i2s-hifi: -22
[   25.630125]  fe400000.i2s-i2s-hifi: ASoC: error at __soc_pcm_hw_params on fe400000.i2s-i2s-hifi: -22
[   25.630184] hdmi-audio-codec hdmi-audio-codec.4.auto: Not able to map channels to speakers (-22)
[   25.630198] hdmi-audio-codec hdmi-audio-codec.4.auto: ASoC: error at snd_soc_dai_hw_params on i2s-hifi: -22
[   25.630208]  fe400000.i2s-i2s-hifi: ASoC: error at __soc_pcm_hw_params on fe400000.i2s-i2s-hifi: -22
[   25.630261] hdmi-audio-codec hdmi-audio-codec.4.auto: Not able to map channels to speakers (-22)
[   25.630277] hdmi-audio-codec hdmi-audio-codec.4.auto: ASoC: error at snd_soc_dai_hw_params on i2s-hifi: -22
[   25.630288]  fe400000.i2s-i2s-hifi: ASoC: error at __soc_pcm_hw_params on fe400000.i2s-i2s-hifi: -22
[   25.630345] hdmi-audio-codec hdmi-audio-codec.4.auto: Not able to map channels to speakers (-22)
[   25.630358] hdmi-audio-codec hdmi-audio-codec.4.auto: ASoC: error at snd_soc_dai_hw_params on i2s-hifi: -22
[   25.630369]  fe400000.i2s-i2s-hifi: ASoC: error at __soc_pcm_hw_params on fe400000.i2s-i2s-hifi: -22
[   25.632692] hdmi-audio-codec hdmi-audio-codec.4.auto: Not able to map channels to speakers (-22)
[   25.632746] hdmi-audio-codec hdmi-audio-codec.4.auto: ASoC: error at snd_soc_dai_hw_params on i2s-hifi: -22
[   25.632769]  fe400000.i2s-i2s-hifi: ASoC: error at __soc_pcm_hw_params on fe400000.i2s-i2s-hifi: -22
[   25.633015] hdmi-audio-codec hdmi-audio-codec.4.auto: Not able to map channels to speakers (-22)
[   25.633032] hdmi-audio-codec hdmi-audio-codec.4.auto: ASoC: error at snd_soc_dai_hw_params on i2s-hifi: -22
[   25.633047]  fe400000.i2s-i2s-hifi: ASoC: error at __soc_pcm_hw_params on fe400000.i2s-i2s-hifi: -22
[   25.633281] hdmi-audio-codec hdmi-audio-codec.4.auto: Not able to map channels to speakers (-22)
[   25.633296] hdmi-audio-codec hdmi-audio-codec.4.auto: ASoC: error at snd_soc_dai_hw_params on i2s-hifi: -22
[   25.633308]  fe400000.i2s-i2s-hifi: ASoC: error at __soc_pcm_hw_params on fe400000.i2s-i2s-hifi: -22
[   25.633530] hdmi-audio-codec hdmi-audio-codec.4.auto: Not able to map channels to speakers (-22)
[   25.633545] hdmi-audio-codec hdmi-audio-codec.4.auto: ASoC: error at snd_soc_dai_hw_params on i2s-hifi: -22
[   25.633557]  fe400000.i2s-i2s-hifi: ASoC: error at __soc_pcm_hw_params on fe400000.i2s-i2s-hifi: -22
[   25.633787] hdmi-audio-codec hdmi-audio-codec.4.auto: Not able to map channels to speakers (-22)
[   25.633808] hdmi-audio-codec hdmi-audio-codec.4.auto: ASoC: error at snd_soc_dai_hw_params on i2s-hifi: -22
[   25.633820]  fe400000.i2s-i2s-hifi: ASoC: error at __soc_pcm_hw_params on fe400000.i2s-i2s-hifi: -22
[   25.635757] hdmi-audio-codec hdmi-audio-codec.4.auto: Not able to map channels to speakers (-22)
[   25.635816] hdmi-audio-codec hdmi-audio-codec.4.auto: ASoC: error at snd_soc_dai_hw_params on i2s-hifi: -22
[   25.635839]  fe400000.i2s-i2s-hifi: ASoC: error at __soc_pcm_hw_params on fe400000.i2s-i2s-hifi: -22
[   25.636144] hdmi-audio-codec hdmi-audio-codec.4.auto: Not able to map channels to speakers (-22)
[   25.636163] hdmi-audio-codec hdmi-audio-codec.4.auto: ASoC: error at snd_soc_dai_hw_params on i2s-hifi: -22
[   25.636176]  fe400000.i2s-i2s-hifi: ASoC: error at __soc_pcm_hw_params on fe400000.i2s-i2s-hifi: -22
[   25.636465] hdmi-audio-codec hdmi-audio-codec.4.auto: Not able to map channels to speakers (-22)
[   25.636487] hdmi-audio-codec hdmi-audio-codec.4.auto: ASoC: error at snd_soc_dai_hw_params on i2s-hifi: -22
[   25.636500]  fe400000.i2s-i2s-hifi: ASoC: error at __soc_pcm_hw_params on fe400000.i2s-i2s-hifi: -22
[   25.636782] hdmi-audio-codec hdmi-audio-codec.4.auto: Not able to map channels to speakers (-22)
[   25.636797] hdmi-audio-codec hdmi-audio-codec.4.auto: ASoC: error at snd_soc_dai_hw_params on i2s-hifi: -22
[   25.636810]  fe400000.i2s-i2s-hifi: ASoC: error at __soc_pcm_hw_params on fe400000.i2s-i2s-hifi: -22
[   25.637091] hdmi-audio-codec hdmi-audio-codec.4.auto: Not able to map channels to speakers (-22)
[   25.637112] hdmi-audio-codec hdmi-audio-codec.4.auto: ASoC: error at snd_soc_dai_hw_params on i2s-hifi: -22
[   25.637126]  fe400000.i2s-i2s-hifi: ASoC: error at __soc_pcm_hw_params on fe400000.i2s-i2s-hifi: -22
[   26.102244] rk_gmac-dwmac fe010000.ethernet end1: Link is Up - 1Gbps/Full - flow control rx/tx
[   30.725239] loop0: detected capacity change from 0 to 68920
[   38.673807] rfkill: input handler disabled
[  133.737352] EXT4-fs (mmcblk0p1): resizing filesystem from 1780736 to 15263488 blocks
[  134.103379] EXT4-fs (mmcblk0p1): resized filesystem to 15263488
glmark2:
Quote
nicolas@nicolas-pc:~$ glmark2-es2-wayland
    glmark2 2023.01
    OpenGL Information
    GL_VENDOR:      Mesa
    GL_RENDERER:    Mali-G52 r1 (Panfrost)
    GL_VERSION:     OpenGL ES 3.1 Mesa 24.0.5-1ubuntu1
    Surface Config: buf=32 r=8 g=8 b=8 a=8 depth=24 stencil=0 samples=0
    Surface Size:   800x600 windowed
[build] use-vbo=false: FPS: 323 FrameTime: 3.096 ms
[build] use-vbo=true: FPS: 424 FrameTime: 2.362 ms
[texture] texture-filter=nearest: FPS: 594 FrameTime: 1.685 ms
[texture] texture-filter=linear: FPS: 596 FrameTime: 1.680 ms
[texture] texture-filter=mipmap: FPS: 604 FrameTime: 1.658 ms
[shading] shading=gouraud: FPS: 278 FrameTime: 3.600 ms
[shading] shading=blinn-phong-inf: FPS: 279 FrameTime: 3.588 ms
[shading] shading=phong: FPS: 271 FrameTime: 3.691 ms
[shading] shading=cel: FPS: 271 FrameTime: 3.698 ms
[bump] bump-render=high-poly: FPS: 95 FrameTime: 10.548 ms
[bump] bump-render=normals: FPS: 611 FrameTime: 1.638 ms
[bump] bump-render=height: FPS: 638 FrameTime: 1.568 ms
[effect2d] kernel=0,1,0;1,-4,1;0,1,0;: FPS: 483 FrameTime: 2.073 ms
[effect2d] kernel=1,1,1,1,1;1,1,1,1,1;1,1,1,1,1;: FPS: 180 FrameTime: 5.578 ms
[pulsar] light=false:quads=5:texture=false: FPS: 606 FrameTime: 1.651 ms
[desktop] blur-radius=5:effect=blur:passes=1:separable=true:windows=4: FPS: 157 FrameTime: 6.404 ms
[desktop] effect=shadow:windows=4: FPS: 358 FrameTime: 2.797 ms
[buffer] columns=200:interleave=false:update-dispersion=0.9:update-fraction=0.5:update-method=map: FPS: 55 FrameTime: 18.459 ms
[buffer] columns=200:interleave=false:update-dispersion=0.9:update-fraction=0.5:update-method=subdata: FPS: 54 FrameTime: 18.673 ms
[buffer] columns=200:interleave=true:update-dispersion=0.9:update-fraction=0.5:update-method=map: FPS: 60 FrameTime: 16.697 ms
[ideas] speed=duration: FPS: 255 FrameTime: 3.935 ms
[jellyfish] <default>: FPS: 335 FrameTime: 2.990 ms
[terrain] <default>: FPS: 23 FrameTime: 45.032 ms
[shadow] <default>: FPS: 183 FrameTime: 5.470 ms
[refract] <default>: FPS: 23 FrameTime: 44.876 ms
[conditionals] fragment-steps=0:vertex-steps=0: FPS: 583 FrameTime: 1.718 ms
[conditionals] fragment-steps=5:vertex-steps=0: FPS: 579 FrameTime: 1.728 ms
[conditionals] fragment-steps=0:vertex-steps=5: FPS: 579 FrameTime: 1.728 ms
[function] fragment-complexity=low:fragment-steps=5: FPS: 581 FrameTime: 1.724 ms
[function] fragment-complexity=medium:fragment-steps=5: FPS: 567 FrameTime: 1.765 ms
[loop] fragment-loop=false:fragment-steps=5:vertex-steps=5: FPS: 577 FrameTime: 1.734 ms
[loop] fragment-steps=5:fragment-uniform=false:vertex-steps=5: FPS: 569 FrameTime: 1.760 ms
[loop] fragment-steps=5:fragment-uniform=true:vertex-steps=5: FPS: 568 FrameTime: 1.761 ms
                                  glmark2 Score: 373
Next Step: Fix Bluetooth, Freeze kernel and drop wine + box86 +box64
to add DTB to 6.1 kernel image:
sudo losetup --partscan /dev/loop13 disk_image.img
mkdir /tmp/disk_image
sudo mount /dev/loop13p1 /tmp/disk_image
####### DROP the new DTB File to /tmp/disk_image/boot/dtb/rockchip ##########
sudo fstrim -v /tmp/disk_image
sudo umount /tmp/disk_image
sudo losetup --detach /dev/loop13
You could also add the wifi fix to the image:
sudo mkdir -p /tmp/disk_image/usr/lib/scripts
sudo cp ap6335-bluetooth.service /tmp/disk_image/usr/lib/systemd/system/
sudo cp ap6335-bluetooth.sh /tmp/disk_image/usr/lib/scripts/
sudo cp brcm_patchram_plus /tmp/disk_image/usr/bin/
sudo cp fw_bcm4335b0_ag.bin /tmp/disk_image/lib/firmware/brcm/
sudo cp BCM4335A0.hcd /tmp/disk_image/lib/firmware/brcm/
sudo cp brcmfmac4335-sdio.txt /tmp/disk_image/lib/firmware/brcm/
sudo mkdir -p /tmp/disk_image/data/cfg/
sudo cp device_info.txt /tmp/disk_image/data/cfg/
sudo ln -s fw_bcm4335b0_ag.bin brcmfmac4335-sdio.h96-TVbox,rk3566.bin
sudo ln -s fw_bcm4335b0_ag.bin brcmfmac4335-sdio.bin
sudo chmod 775 /tmp/disk_image/usr/lib/scripts/ap6335-bluetooth.sh
sudo chmod 775 /tmp/disk_image/usr/lib/systemd/system/ap6335-bluetooth.service
sudo chmod 775 /tmp/disk_image/data/cfg/device_info.txt
sudo chmod 775 /tmp/disk_image/usr/bin/brcm_patchram_plus
Fix CPU clock
sudo -i
# See policy to see how CPUs are grouped.
echo conservative > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
echo conservative > /sys/devices/system/cpu/cpu4/cpufreq/scaling_governor
echo conservative > /sys/devices/system/cpu/cpu6/cpufreq/scaling_governor
exit
cat /sys/devices/system/cpu/cpu*/cpufreq/scaling_governor
Check GPU Frequency
ls /sys/devices/platform/fde60000.gpu/devfreq/fde60000.gpu/
cat /sys/devices/platform/fde60000.gpu/devfreq/fde60000.gpu/cur_freq
cat /sys/devices/platform/fde60000.gpu/devfreq/fde60000.gpu/min_freq
cat /sys/devices/platform/fde60000.gpu/devfreq/fde60000.gpu/max_freq
Check CPU frequency
ls /sys/devices/system/cpu/cpu0/cpufreq
cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_max_freq
cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq
cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_min_freq
Edited by Hqnicolas
Posted (edited)
@maka
The main advantage for Joshua against Armbian is this vpu support
can we bring this VPU to armbian?
Some Kernel Config need to be changed on Joshua riek to enable wifi
and it turn 100% true since I use this kernel config to build this file:
https://github.com/hqnicolas/ubuntu-rockchip/blob/main/packages/u-boot-turing-rk3588/debian/patches/0005-board-rockchip-Add-Xunlong-Orange-Pi-3B.patch
Quote
CONFIG_ARM64_WORKAROUND_CLEAN_CACHE=y
CONFIG_ARM64_ERRATUM_826319=y
CONFIG_ARM64_ERRATUM_827319=y
CONFIG_ARM64_ERRATUM_824069=y
CONFIG_ARM64_ERRATUM_819472=y
CONFIG_ARM64_ERRATUM_832075=y
CONFIG_ARM64_ERRATUM_2051678=y
CONFIG_CAVIUM_ERRATUM_23154=y
CONFIG_CAVIUM_ERRATUM_22375=y
CONFIG_ROCKCHIP_ERRATUM_3588001=y
CONFIG_NUMA=y
CONFIG_NODES_SHIFT=2
CONFIG_PARAVIRT=y
CONFIG_CPUFREQ_DT=m
CONFIG_CPUFREQ_DT_PLATDEV=y
CONFIG_ARM_SCPI_CPUFREQ=y
CONFIG_BT_MTKUART=m
CONFIG_BT_VIRTIO=m
CONFIG_BT_HCIUART_LL=y
CONFIG_BT_HCIUART_MRVL=y
CONFIG_CFG80211=m
# CONFIG_NL80211_TESTMODE is not set
CONFIG_NET_9P=m
CONFIG_RFKILL_INPUT=y
CONFIG_RFKILL_GPIO=m
CONFIG_BRCMSTB_GISB_ARB=y
CONFIG_VEXPRESS_CONFIG=y
CONFIG_MHI_BUS_PCI_GENERIC=m
CONFIG_MHI_BUS_EP=m
CONFIG_BRCM_TRACING=y
CONFIG_BRCMDBG=y
CONFIG_B43LEGACY=m
CONFIG_B43LEGACY_PCI_AUTOSELECT=y
CONFIG_B43LEGACY_PCICORE_AUTOSELECT=y
CONFIG_B43LEGACY_LEDS=y
CONFIG_B43LEGACY_HWRNG=y
CONFIG_B43LEGACY_DEBUG=y
CONFIG_B43LEGACY_DMA=y
CONFIG_B43LEGACY_PIO=y
CONFIG_B43LEGACY_DMA_AND_PIO_MODE=y
# CONFIG_B43LEGACY_DMA_MODE is not set
# CONFIG_B43LEGACY_PIO_MODE is not set
CONFIG_VIRT_WIFI=m
Edited by Hqnicolas
Maybe the panfork  was present in my system and slowing down? I dont know, but i think that not. Panfrost was active and the problem must be drm is better in mainline.
I use Desktop gnome on mainline and works very good. Video and web and just want to pull fireworks from the chip and so making trials with kernels. The best for me now is mainline with 1080p in web video without skipped frames. This is the top but can't stop trying 🤕🤒🤮
rk3566 with kernel 6.6 and chromium-browser
It's not mainline because is not the last from kernel.org? But it is the last in community builds and not a BSP kernel. I am not using the new RGA node but will update with 6.9
I am using the 1506 ddr blob without issues but kids should not use this at home.
Posted (edited)
i think this will be the next step here to...
I didn't have that luck in the silicon lottery. My board stops at 1056mhz DDR
1080P without drop frames, how about CPU usage? 80% all cores? while video Player?
Rockchip BSP kernel is a mess :(
Edited by Hqnicolas
Posted (edited)
On 5/30/2024 at 5:45 PM, paradigman said:
which method should be used to flash either these special editions or the mainline images to the emmc?
@paradigman
everything I have here is to collaborate with development.
The image you can use for fun is the Rockchip Kernel 6.1:
on the first boot you will need to resize the partition to full EMMC using the "disc" GUI
if it doesn't work you can try switch partition type to linux filesystem, resize, and go back to EFI system
it wont have Wifi and Bluetooth enabled but you can try to search for a fix.
if you're prefer Cable network this image is perfect for parsec and other things
If you want a Official Mainline Kernel 6.6 Without VPU Video Player
You wiil find the H96 on Armbian 24.8.0-trunk.6
https://github.com/armbian/community/releases/tag/24.8.0-trunk.6
you can drop the wifi drivers normally.
https://drive.google.com/file/d/1B1LmAylalETcnBEWiPiJHL0MjK5xlIV4/view?usp=sharing
cd /lib/firmware/brcm/
sudo reboot now
the method to flash this images on H96-MAX is the same as v1.1
https://forum.armbian.com/topic/28895-efforts-to-develop-firmware-for-h96-max-v56-rk3566-8g64g/?do=findComment&comment=186851
Edited by Hqnicolas
Posted (edited)
Can Somebody help?
Wifi works, but, bluetooth dont...
$ rfkill
ID TYPE      DEVICE      SOFT      HARD
 0 bluetooth hci0     blocked unblocked
 1 wlan      phy0   unblocked unblocked
 2 bluetooth hci1     blocked unblocked
dmesg
Quote
[    4.022903] Initializing XFRM netlink socket
[    4.022946] NET: Registered PF_PACKET protocol family
[    4.023268] [BT_RFKILL]: Enter rfkill_rk_init
[    4.023275] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    4.023611] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[    4.023650] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6398s
[    4.023656] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[    4.023660] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[    4.023802] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,poweren_gpio = 74 flags = 0.
[    4.023829] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[    4.023833] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[    4.023839] [WLAN_RFKILL]: rfkill_set_wifi_bt_power: 1
[    4.023846] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[    4.024358] Key type dns_resolver registered
[   11.850882] Bluetooth: hci1: command 0xfc4c tx timeout
[   12.753638] systemd[1]: Finished Armbian memory supported logging.
[ 19.545010] platform mtd_vendor_storage: deferred probe pending
[   19.743891] Bluetooth: hci1: BCM: Patch command fc4c failed (-110)
[   19.743940] Bluetooth: hci1: BCM: Patch failed (-110)
[   20.467558] rk_gmac-dwmac fe010000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[   20.467662] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   21.877218] Bluetooth: hci1: command 0xfc18 tx timeout
[   28.798502] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[   29.527972] rfkill: input handler disabled
[   29.994719] Bluetooth: hci1: BCM: failed to write update baudrate (-110)
[   32.321905] Bluetooth: hci1: command 0x0c03 tx timeout
[   35.602943] rockchip-vop2 fe040000.vop: [drm:vop2_crtc_atomic_disable] Crtc atomic disable vp0
[   35.626558] rockchip-vop2 fe040000.vop: [drm:vop2_crtc_atomic_enable] Update mode to 1920x1080p60, type: 11(if:800, flag:0x0) for vp0 dclk: 148500000
[   40.322974] Bluetooth: hci1: BCM: Reset failed (-110)
[  330.506787] usb 1-1: USB disconnect, device number 2
[  330.506814] usb 1-1.2: USB disconnect, device number 3
[  330.657274] usb 1-1.3: USB disconnect, device number 4
[  334.550788] usb 4-1: USB disconnect, device number 2
Edited by Hqnicolas
Posted (edited)
Can Somebody help?
This is the Kernel 6.1 image V11
On 5/16/2024 at 11:49 AM, Hqnicolas said:
Edited by Hqnicolas
Posted (edited)
Updating here some bluetooth fix K610 V11,
doesn't work, but it was there....
gpioinfo
Quote
gpiochip0 - 32 lines:
    line   0:      unnamed       unused   input  active-high
    line   1:      unnamed       unused   input  active-high
    line   2:      unnamed       unused   input  active-high
    line   3:      unnamed  "interrupt"   input  active-high [used]
    line   4:      unnamed         "cd"   input   active-low [used]
    line   5:      unnamed       unused   input  active-high
    line   6:      unnamed "vcc5v0-host-regulator" output active-high [used]
    line   7:      unnamed       unused   input  active-high
    line   8:      unnamed       unused   input  active-high
    line   9:      unnamed       unused   input  active-high
    line  10:      unnamed       unused   input  active-high
    line  11:      unnamed       unused   input  active-high
    line  12:      unnamed       unused   input  active-high
    line  13:      unnamed       unused   input  active-high
    line  14:      unnamed       unused   input  active-high
    line  15:      unnamed "snps,reset"  output   active-low [used]
    line  16:      unnamed       unused   input  active-high
    line  17:      unnamed       unused   input  active-high
    line  18:      unnamed       unused   input  active-high
    line  19:      unnamed       unused   input  active-high
    line  20:      unnamed "vcc3v3-vga"  output  active-high [used]
    line  21:      unnamed       unused   input  active-high
    line  22:      unnamed       unused   input  active-high
    line  23:      unnamed       unused   input  active-high
    line  24:      unnamed       unused   input  active-high
    line  25:      unnamed       unused   input  active-high
    line  26:      unnamed       unused   input  active-high
    line  27:      unnamed  "led-power"  output  active-high [used]
    line  28:      unnamed "led-status"  output  active-high [used]
    line  29:      unnamed       unused   input  active-high
    line  30:      unnamed       unused   input  active-high
    line  31:      unnamed       unused   input  active-high
gpiochip1 - 32 lines:
    line   3:      unnamed       unused   input  active-high
    line   4:      unnamed       unused   input  active-high
    line   6:      unnamed       unused   input  active-high
    line  15:      unnamed       unused   input  active-high
    line  20:      unnamed       unused   input  active-high
    line  27:      unnamed       unused   input  active-high
    line  28:      unnamed       unused   input  active-high
gpiochip2 - 32 lines:
    line   9:      unnamed      "reset"  output   active-low [used]
    line  13:      unnamed "bt_default_rts" output active-high [used]
    line  15:      unnamed "bt_default_reset" output active-high [used]
    line  16:      unnamed "bt_default_wake_host" input active-high [used]
    line  17:      unnamed "bt_default_wake" output active-high [used]
gpiochip3 - 32 lines:
gpiochip4 - 32 lines:
Full dmesg
Quote
[    3.964557] input: rk805 pwrkey as /devices/platform/fdd40000.i2c/i2c-0/0-0020/rk805-pwrkey/input/input0
[    3.972227] rk808-rtc rk808-rtc: registered as rtc0
[    3.974082] rk808-rtc rk808-rtc: setting system clock to 2024-06-08T16:14:15 UTC (1717863255)
[    3.979642] rockchip-mipi-csi2-hw fdfb0000.mipi-csi2-hw: enter mipi csi2 hw probe!
[    3.980066] rockchip-mipi-csi2-hw fdfb0000.mipi-csi2-hw: probe success, v4l2_dev:mipi-csi2-hw!
[    3.985053] usbcore: registered new interface driver uvcvideo
[    3.988724] cpu cpu0: Failed to get specification_serial_number
[    3.988792] cpu cpu0: Failed to get leakage
[    3.988834] cpu cpu0: Looking up cpu-supply from device tree
[    3.989934] cpu cpu0: soc version=0, speed=0
[    3.990017] cpu cpu0: Looking up cpu-supply from device tree
[    3.991771] cpu cpu0: avs=0
[    3.992041] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[    3.995835] cpu cpu0: EM: created perf domain
[    3.997740] sdhci: Secure Digital Host Controller Interface driver
[    3.997755] sdhci: Copyright(c) Pierre Ossman
[    3.997766] Synopsys Designware Multimedia Card Interface Driver
[    3.998219] sdhci-pltfm: SDHCI platform and OF driver helper
[    3.999281] dwmmc_rockchip fe2b0000.mmc: No normal pinctrl state
[    3.999281] dwmmc_rockchip fe2c0000.mmc: No normal pinctrl state
[    3.999294] dwmmc_rockchip fe2b0000.mmc: No idle pinctrl state
[    3.999301] dwmmc_rockchip fe2c0000.mmc: No idle pinctrl state
[    3.999642] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.
[    3.999681] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.
[    3.999693] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a
[    3.999760] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 68,32 bit host data width,256 deep fifo
[    3.999858] dwmmc_rockchip fe2c0000.mmc: Looking up vmmc-supply from device tree
[    3.999999] dwmmc_rockchip fe2c0000.mmc: Looking up vqmmc-supply from device tree
[    4.000414] dwmmc_rockchip fe2c0000.mmc: allocated mmc-pwrseq
[    4.000430] mmc_host mmc2: card is non-removable.
[    4.000775] dwmmc_rockchip fe2b0000.mmc: IDMAC supports 32-bit address mode.
[    4.000814] dwmmc_rockchip fe2b0000.mmc: Using internal DMA controller.
[    4.000825] dwmmc_rockchip fe2b0000.mmc: Version ID is 270a
[    4.000862] sdhci-dwcmshc fe310000.mmc: Looking up vmmc-supply from device tree
[    4.000875] dwmmc_rockchip fe2b0000.mmc: DW MMC controller at irq 69,32 bit host data width,256 deep fifo
[    4.000872] sdhci-dwcmshc fe310000.mmc: Looking up vmmc-supply property in node /mmc@fe310000 failed
[    4.000915] sdhci-dwcmshc fe310000.mmc: Looking up vqmmc-supply from device tree
[    4.000923] sdhci-dwcmshc fe310000.mmc: Looking up vqmmc-supply property in node /mmc@fe310000 failed
[    4.000933] dwmmc_rockchip fe2b0000.mmc: Looking up vmmc-supply from device tree
[    4.000943] dwmmc_rockchip fe2b0000.mmc: Looking up vmmc-supply property in node /mmc@fe2b0000 failed
[    4.000964] dwmmc_rockchip fe2b0000.mmc: Looking up vqmmc-supply from device tree
[    4.001170] dwmmc_rockchip fe2b0000.mmc: Got CD GPIO
[    4.002324] ledtrig-cpu: registered to indicate activity on CPUs
[    4.002386] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
[    4.002455] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    4.003417] cryptodev: driver 1.12 loaded.
[    4.003471] hid: raw HID events driver (C) Jiri Kosina
[    4.003703] usbcore: registered new interface driver usbhid
[    4.003711] usbhid: USB HID core driver
[    4.003982] rockchip,bus bus-npu: Looking up bus-supply from device tree
[    4.004175] rockchip,bus bus-npu: bin=0
[    4.004199] rockchip,bus bus-npu: Failed to get leakage
[    4.004216] rockchip,bus bus-npu: Looking up pvtm-supply from device tree
[    4.005092] rockchip,bus bus-npu: Looking up pvtm-supply from device tree
[    4.006072] rockchip,bus bus-npu: avs=0
[    4.010131] rockchip-saradc fe720000.saradc: Looking up vref-supply from device tree
[    4.011184] SPI driver inv-icm42600-spi has no spi_device_id for invensense,icm42600
[    4.011200] SPI driver inv-icm42600-spi has no spi_device_id for invensense,icm42602
[    4.011204] SPI driver inv-icm42600-spi has no spi_device_id for invensense,icm42605
[    4.011208] SPI driver inv-icm42600-spi has no spi_device_id for invensense,icm42622
[    4.011786] mmc_host mmc1: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[    4.011963] optee: probing for conduit method.
[    4.011973] optee: api uid mismatch
[    4.011978] optee: probe of firmware:optee failed with error -22
[    4.012837] usbcore: registered new interface driver snd-usb-audio
[    4.014689] rk817-codec rk817-codec: DMA mask not set
[    4.016521] [Awinic] aw87xxx_pa_init:driver version: v2.2.0
[    4.021101] rk-multicodecs rk809-sound: Failed to get ADC channel
[    4.021253] rk-multicodecs rk809-sound: ASoC: Property 'rockchip,audio-routing' does not exist or its length is not even
[    4.022603] rk817-codec rk817-codec: rk817_probe: chip_name:0x80, chip_ver:0x94
[    4.026766] rk-multicodecs rk809-sound: Don't need to map headset detect gpio to irq
[    4.029439] Initializing XFRM netlink socket
[    4.029482] NET: Registered PF_PACKET protocol family
[    4.029801] [BT_RFKILL]: Enter rfkill_rk_init
[    4.029809] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    4.030148] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[    4.030187] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6398s
[    4.030193] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[    4.030197] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[    4.030218] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,poweren_gpio = 74 flags = 0.
[    4.030242] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[    4.030247] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[    4.030254] [WLAN_RFKILL]: rfkill_set_wifi_bt_power: 1
[    4.030260] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[    4.031007] mmc0: SDHCI controller on fe310000.mmc [fe310000.mmc] using ADMA
[    4.031422] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 77.
[    4.031453] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 79.
[    4.031466] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 81.
[    4.031478] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 80.
[    4.031548] [BT_RFKILL]: Request irq for bt wakeup host
[    4.031698] [BT_RFKILL]: ** disable irq
[    4.031849] [BT_RFKILL]: bt shut off power
[    4.031886] [BT_RFKILL]: bt_default device registered.
[    4.032051] Key type dns_resolver registered
[    4.032094] Key type ceph registered
[    4.032586] libceph: loaded (mon/osd proto 15/24)
[    4.034469] registered taskstats version 1
[    4.034504] Loading compiled-in X.509 certificates
[    4.035671] Btrfs loaded, crc32c=crc32c-generic, zoned=no, fsverity=no
[    4.036162] pstore: Using crash dump compression: deflate
[    4.044164] rga: rga2, irq = 76, match scheduler
[    4.044591] rga: rga2 hardware loaded successfully, hw_version:3.2.63318.
[    4.044653] rga: rga2 probe successfully
[    4.045017] rga_iommu: IOMMU binding successfully, default mapping core[0x4]
[    4.045268] rga: Module initialized. v1.3.1
[    4.068619] rockchip-iodomain fdc20000.syscon:io-domains: Looking up pmuio1-supply from device tree
[    4.068838] rockchip-iodomain fdc20000.syscon:io-domains: pmuio1(3300000 uV) supplied by vcc3v3_pmu
[    4.068852] rockchip-iodomain fdc20000.syscon:io-domains: Looking up pmuio2-supply from device tree
[    4.068925] rockchip-iodomain fdc20000.syscon:io-domains: pmuio2(3300000 uV) supplied by vcc3v3_pmu
[    4.068937] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio1-supply from device tree
[    4.069084] rockchip-iodomain fdc20000.syscon:io-domains: vccio1(3300000 uV) supplied by vccio_acodec
[    4.069096] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio2-supply from device tree
[    4.069201] rockchip-iodomain fdc20000.syscon:io-domains: vccio2(1800000 uV) supplied by vcc_1v8
[    4.069212] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio3-supply from device tree
[    4.069320] rockchip-iodomain fdc20000.syscon:io-domains: vccio3(3300000 uV) supplied by vccio_sd
[    4.069332] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio4-supply from device tree
[    4.069395] rockchip-iodomain fdc20000.syscon:io-domains: vccio4(1800000 uV) supplied by vcc_1v8
[    4.069410] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio5-supply from device tree
[    4.069507] rockchip-iodomain fdc20000.syscon:io-domains: vccio5(3300000 uV) supplied by vcc_3v3
[    4.069519] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio6-supply from device tree
[    4.069571] rockchip-iodomain fdc20000.syscon:io-domains: vccio6(1800000 uV) supplied by vcc_1v8
[    4.069583] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio7-supply from device tree
[    4.069632] rockchip-iodomain fdc20000.syscon:io-domains: vccio7(3300000 uV) supplied by vcc_3v3
[    4.070039] mpp_rkvenc fdf40000.rkvenc: probing start
[    4.070286] mpp_iommu_probe:487: failed to get device node
[    4.070294] mpp_rkvenc fdf40000.rkvenc: failed to attach iommu
[    4.070345] mpp_rkvenc fdf40000.rkvenc: Looking up venc-supply from device tree
[    4.070516] mpp_rkvenc fdf40000.rkvenc: bin=0
[    4.070540] mpp_rkvenc fdf40000.rkvenc: Failed to get leakage
[    4.070556] mpp_rkvenc fdf40000.rkvenc: Looking up venc-supply from device tree
[    4.070575] vdd_logic: could not add device link fdf40000.rkvenc: -EEXIST
[    4.070656] mpp_rkvenc fdf40000.rkvenc: Looking up venc-supply from device tree
[    4.070674] debugfs: Directory 'fdf40000.rkvenc-venc' with parent 'vdd_logic' already present!
[    4.070683] vdd_logic: Failed to create debugfs directory
[    4.070872] mpp_rkvenc fdf40000.rkvenc: avs=0
[    4.071053] mpp_rkvenc fdf40000.rkvenc: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[    4.071585] mpp_rkvenc fdf40000.rkvenc: probing finish
[    4.072134] mpp_vdpu2 fdea0400.vdpu: Adding to iommu group 0
[    4.072321] mpp_vdpu2 fdea0400.vdpu: probe device
[    4.072990] mpp_vdpu2 fdea0400.vdpu: probing finish
[    4.073413] mpp_vepu2 fdee0000.vepu: Adding to iommu group 2
[    4.073620] mpp_vepu2 fdee0000.vepu: probing start
[    4.074162] mpp_vepu2 fdee0000.vepu: probing finish
[    4.074587] mpp-iep2 fdef0000.iep: Adding to iommu group 3
[    4.074768] mpp-iep2 fdef0000.iep: probe device
[    4.075127] mpp-iep2 fdef0000.iep: allocate roi buffer failed
[    4.075494] mpp-iep2 fdef0000.iep: probing finish
[    4.075992] mpp_jpgdec fded0000.jpegd: Adding to iommu group 1
[    4.076173] mpp_jpgdec fded0000.jpegd: probe device
[    4.076790] mpp_jpgdec fded0000.jpegd: probing finish
[    4.077279] mpp_rkvdec2 fdf80200.rkvdec: Adding to iommu group 4
[    4.077567] mpp_rkvdec2 fdf80200.rkvdec: rkvdec, probing start
[    4.077919] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_a is not found!
[    4.077927] rkvdec2_init:982: No niu aclk reset resource define
[    4.077934] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_h is not found!
[    4.077939] rkvdec2_init:985: No niu hclk reset resource define
[    4.077962] mpp_rkvdec2 fdf80200.rkvdec: Looking up vdec-supply from device tree
[    4.078154] mpp_rkvdec2 fdf80200.rkvdec: bin=0
[    4.078228] mpp_rkvdec2 fdf80200.rkvdec: Failed to get leakage
[    4.078243] mpp_rkvdec2 fdf80200.rkvdec: Looking up vdec-supply from device tree
[    4.078329] vdd_logic: could not add device link fdf80200.rkvdec: -EEXIST
[    4.078344] debugfs: File 'uA_load' in directory '/' already present!
[    4.078353] debugfs: File 'min_uV' in directory '/' already present!
[    4.078359] debugfs: File 'max_uV' in directory '/' already present!
[    4.078366] debugfs: File 'constraint_flags' in directory '/' already present!
[    4.078434] mpp_rkvdec2 fdf80200.rkvdec: Looking up vdec-supply from device tree
[    4.078455] debugfs: Directory 'fdf80200.rkvdec-vdec' with parent 'vdd_logic' already present!
[    4.078462] vdd_logic: Failed to create debugfs directory
[    4.078680] mpp_rkvdec2 fdf80200.rkvdec: avs=0
[    4.078908] mpp_rkvdec2 fdf80200.rkvdec: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[    4.079061] mpp_rkvdec2 fdf80200.rkvdec: sram_start 0x00000000fdcc0000
[    4.079070] mpp_rkvdec2 fdf80200.rkvdec: rcb_iova 0x0000000010000000
[    4.079075] mpp_rkvdec2 fdf80200.rkvdec: sram_size 65536
[    4.079081] mpp_rkvdec2 fdf80200.rkvdec: rcb_size 65536
[    4.079087] mpp_rkvdec2 fdf80200.rkvdec: min_width 512
[    4.079149] mpp_rkvdec2 fdf80200.rkvdec: link mode probe finish
[    4.079219] mpp_rkvdec2 fdf80200.rkvdec: probing finish
[    4.079683] rockchip-vop2 fe040000.vop: Adding to iommu group 5
[    4.080210] [drm] all windows should be assigned, full plane mask: 0x3f, current plane mask: 0x0
[    4.080221] [drm] use default plane mask
[    4.080371] [drm] RK3566 only support 2 vps
[    4.080390] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x15, primary plane phy id: 4
[    4.080410] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp1 assign plane mask: 0x22, primary plane phy id: 5
[    4.080419] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x8, primary plane phy id: 3
[    4.080710] [drm] failed to init overlay plane Cluster0-win1
[    4.080749] [drm] failed to init overlay plane Cluster1-win1
[    4.080921] rockchip-vop2 fe040000.vop: bin=0
[    4.080950] rockchip-vop2 fe040000.vop: Failed to get leakage
[    4.080995] rockchip-vop2 fe040000.vop: Looking up vop-supply from device tree
[    4.081403] rockchip-vop2 fe040000.vop: Looking up vop-supply from device tree
[    4.081768] rockchip-vop2 fe040000.vop: avs=0
[    4.081916] rockchip-vop2 fe040000.vop: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[    4.082391] rockchip-vop2 fe040000.vop: Supported VOP aclk dvfs, normal mode:396000000, advanced mode:500000000
[    4.082409] rockchip-drm display-subsystem: bound fe040000.vop (ops 0xffff8000092d7c18)
[    4.082602] dwhdmi-rockchip fe0a0000.hdmi: Looking up avdd-0v9-supply from device tree
[    4.082614] dwhdmi-rockchip fe0a0000.hdmi: Looking up avdd-0v9-supply property in node /hdmi@fe0a0000 failed
[    4.082654] dwhdmi-rockchip fe0a0000.hdmi: Looking up avdd-1v8-supply from device tree
[    4.082663] dwhdmi-rockchip fe0a0000.hdmi: Looking up avdd-1v8-supply property in node /hdmi@fe0a0000 failed
[    4.082831] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[    4.083852] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver
[    4.084349] dwhdmi-rockchip fe0a0000.hdmi: error -ENXIO: IRQ index 1 not found
[    4.085144] input: hdmi_cec_key as /devices/platform/fe0a0000.hdmi/dw-hdmi-cec.5.auto/input/input1
[    4.086079] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops 0xffff8000092e9ff0)
[    4.086799] rockchip-drm display-subsystem: failed to parse loader memory
[    4.087592] [drm] Initialized rockchip 3.0.0 20140818 for display-subsystem on minor 0
[    4.091709] mmc0: Host Software Queue enabled
[    4.091747] mmc0: new HS200 MMC card at address 0001
[    4.092498] mmcblk0: mmc0:0001 CJNB4R 58.2 GiB
[    4.096225]  mmcblk0: p1 p2
[    4.097006] mmcblk0boot0: mmc0:0001 CJNB4R 4.00 MiB
[    4.098240] mmcblk0boot1: mmc0:0001 CJNB4R 4.00 MiB
[    4.099312] mmcblk0rpmb: mmc0:0001 CJNB4R 4.00 MiB, chardev (235:0)
[    4.128374] usb 1-1: new full-speed USB device number 2 using xhci-hcd
[    4.140924] vendor storage:20190527 ret = 0
[    4.200129] rockchip-vop2 fe040000.vop: [drm:vop2_crtc_atomic_enable] Update mode to 3840x2160p60, type: 11(if:800, flag:0x0) for vp0 dclk: 594000000
[    4.221806] mmc_host mmc2: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[    4.273214] Freeing initrd memory: 16156K
[    4.273663] usb 1-1: New USB device found, idVendor=0a05, idProduct=7211, bcdDevice= 1.00
[    4.273674] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    4.273679] usb 1-1: Product: USB2.0 HUB
[    4.344306] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 100000000Hz, actual 50000000HZ div = 0)
[    4.353011] dwmmc_rockchip fe2c0000.mmc: Successfully tuned phase to 360
[    4.356904] mmc2: new ultra high speed SDR50 SDIO card at address 0001
[    4.519774] hub 1-1:1.0: USB hub found
[    4.519884] hub 1-1:1.0: 4 ports detected
[    4.533927] Console: switching to colour frame buffer device 480x135
[    4.591500] rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device
[    4.592887] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up gpu-supply from device tree
[    4.592928] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up gpu-supply property in node /power-management@fdd90000/power-controller failed
[    4.593177] mali fde60000.gpu: Kernel DDK version g18p0-01eac0
[    4.593227] mali fde60000.gpu: error -ENXIO: IRQ JOB not found
[    4.593352] mali fde60000.gpu: error -ENXIO: IRQ MMU not found
[    4.593398] mali fde60000.gpu: error -ENXIO: IRQ GPU not found
[    4.593435] mali fde60000.gpu: Insufficient register space, will override to the required size
[    4.593448] mali fde60000.gpu: Register window unavailable
[    4.593453] mali fde60000.gpu: Failed to map registers
[    4.593458] mali fde60000.gpu: Register map failed error = -5
[    4.593464] mali fde60000.gpu: Device initialization failed
[    4.593519] mali: probe of fde60000.gpu failed with error -5
[    4.593851] rk_gmac-dwmac fe010000.ethernet: IRQ eth_lpi not found
[    4.594037] rk_gmac-dwmac fe010000.ethernet: Looking up phy-supply from device tree
[    4.594200] rk_gmac-dwmac fe010000.ethernet: clock input or output? (input).
[    4.594209] rk_gmac-dwmac fe010000.ethernet: TX delay(0x4f).
[    4.594216] rk_gmac-dwmac fe010000.ethernet: RX delay(0x24).
[    4.594228] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no).
[    4.594267] rk_gmac-dwmac fe010000.ethernet: clock input from PHY
[    4.594508] rk_gmac-dwmac fe010000.ethernet: init for RGMII
[    4.594913] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[    4.594956] rk_gmac-dwmac fe010000.ethernet:     DWMAC4/5
[    4.594966] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported
[    4.594971] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported
[    4.594975] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported
[    4.594980] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported
[    4.595045] rk_gmac-dwmac fe010000.ethernet: TSO supported
[    4.595051] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    4.595058] rk_gmac-dwmac fe010000.ethernet: Enabled RFS Flow TC (entries=10)
[    4.595065] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled
[    4.595071] rk_gmac-dwmac fe010000.ethernet: Using 32/32 bits DMA host/device width
[    4.738981] rockchip-dmc dmc: Failed to get specification_serial_number
[    4.739017] rockchip-dmc dmc: Failed to get leakage
[    4.739038] rockchip-dmc dmc: Looking up center-supply from device tree
[    4.739378] rockchip-dmc dmc: soc version=0, speed=0
[    4.739428] rockchip-dmc dmc: Looking up center-supply from device tree
[    4.739646] rockchip-dmc dmc: avs=0
[    4.739664] rockchip-dmc dmc: current ATF version 0x102
[    4.740383] rockchip-dmc dmc: normal_rate = 780000000
[    4.740392] rockchip-dmc dmc: reboot_rate = 1056000000
[    4.740398] rockchip-dmc dmc: suspend_rate = 324000000
[    4.740405] rockchip-dmc dmc: video_4k_rate = 780000000
[    4.740411] rockchip-dmc dmc: video_4k_10b_rate = 780000000
[    4.740417] rockchip-dmc dmc: boost_rate = 1056000000
[    4.740422] rockchip-dmc dmc: fixed_rate(isp|cif0|cif1|dualview) = 1056000000
[    4.740428] rockchip-dmc dmc: performance_rate = 1056000000
[    4.740446] rockchip-dmc dmc: failed to get vop pn to msch rl
[    4.740692] rockchip-dmc dmc: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[    4.756344] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up vi-supply from device tree
[    4.756381] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up vi-supply property in node /power-management@fdd90000/power-controller failed
[    4.756548] WCN: marlin_init entry!
[    4.757959] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up npu-supply from device tree
[    4.757984] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up npu-supply property in node /power-management@fdd90000/power-controller failed
[    4.758066] RKNPU fde40000.npu: RKNPU: rknpu iommu is disabled, using non-iommu mode
[    4.758079] RKNPU fde40000.npu: assigned reserved memory node rknpu
[    4.758085] RKNPU fde40000.npu: RKNPU: initialize reserved memory for rknpu device!
[    4.758135] RKNPU fde40000.npu: Looking up rknpu-supply from device tree
[    4.758390] RKNPU fde40000.npu: Looking up mem-supply from device tree
[    4.758550] RKNPU fde40000.npu: error -ENXIO: IRQ npu_irq not found
[    4.759194] [drm] Initialized rknpu 0.9.6 20240322 for fde40000.npu on minor 1
[    4.759755] RKNPU fde40000.npu: Failed to get specification_serial_number
[    4.759788] RKNPU fde40000.npu: Failed to get leakage
[    4.759808] RKNPU fde40000.npu: Looking up rknpu-supply from device tree
[    4.759836] vdd_npu: could not add device link fde40000.npu: -EEXIST
[    4.759849] debugfs: File 'uA_load' in directory '/' already present!
[    4.759860] debugfs: File 'min_uV' in directory '/' already present!
[    4.759866] debugfs: File 'max_uV' in directory '/' already present!
[    4.759872] debugfs: File 'constraint_flags' in directory '/' already present!
[    4.759907] RKNPU fde40000.npu: soc version=0, speed=0
[    4.759964] RKNPU fde40000.npu: Looking up rknpu-supply from device tree
[    4.759984] debugfs: Directory 'fde40000.npu-rknpu' with parent 'vdd_npu' already present!
[    4.759991] vdd_npu: Failed to create debugfs directory
[    4.760000] RKNPU fde40000.npu: Looking up mem-supply from device tree
[    4.760017] vdd_logic: could not add device link fde40000.npu: -EEXIST
[    4.760025] debugfs: File 'uA_load' in directory '/' already present!
[    4.760031] debugfs: File 'min_uV' in directory '/' already present!
[    4.760035] debugfs: File 'max_uV' in directory '/' already present!
[    4.760040] debugfs: File 'constraint_flags' in directory '/' already present!
[    4.760068] RKNPU fde40000.npu: opp_parse_supplies: Invalid number of elements in opp-microvolt property (3) with supplies (2)
[    4.760078] RKNPU fde40000.npu: _of_add_opp_table_v2: Failed to add OPP, -22
[    4.760088] RKNPU fde40000.npu: failed to add opp table
[    4.760137] RKNPU fde40000.npu: RKNPU: failed to init_opp_table
[    4.761481] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    4.776763] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    4.777744] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[    4.778401] rockchip-suspend not set sleep-mode-config for mem-lite
[    4.778409] rockchip-suspend not set wakeup-config for mem-lite
[    4.778415] rockchip-suspend not set sleep-mode-config for mem-ultra
[    4.778419] rockchip-suspend not set wakeup-config for mem-ultra
[    4.779759] ALSA device list:
[    4.779771]   #0: rockchip-rk809
[    4.779776]   #1: rockchip,hdmi
[    4.790940] Freeing unused kernel memory: 7488K
[    4.805093] Run /init as init process
[    4.805107]   with arguments:
[    4.805113]     /init
[    4.805118]     splash
[    4.805122]   with environment:
[    4.805125]     HOME=/
[    4.805129]     TERM=linux
[    4.805133]     ubootpart=09aa643e-0128-0449-ac24-f65ab04b7198
[    4.805137]     cgroup_enable=memory
[    4.805141]     cgroup_memory=1
[    4.891854] usb 4-1: new SuperSpeed USB device number 2 using xhci-hcd
[    4.913023] usb 4-1: New USB device found, idVendor=0951, idProduct=1666, bcdDevice= 1.10
[    4.913053] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    4.913061] usb 4-1: Product: DataTraveler 3.0
[    4.913066] usb 4-1: Manufacturer: Kingston
[    4.913072] usb 4-1: SerialNumber: 08606E6D4139B1409831D890
[    4.914669] usb-storage 4-1:1.0: USB Mass Storage device detected
[    4.916708] scsi host0: usb-storage 4-1:1.0
[    4.985125] usb 1-1.2: new low-speed USB device number 3 using xhci-hcd
[    5.079414] usb 1-1.2: New USB device found, idVendor=17ef, idProduct=608d, bcdDevice= 1.00
[    5.079457] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    5.079466] usb 1-1.2: Product: Lenovo USB Optical Mouse
[    5.079471] usb 1-1.2: Manufacturer: PixArt
[    5.280305] input: adc-keys as /devices/platform/adc-keys/input/input2
[    5.304113] input: PixArt Lenovo USB Optical Mouse as /devices/platform/usbdrd/fcc00000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.2/1-1.2:1.0/0003:17EF:608D.0001/input/input3
[    5.305158] hid-generic 0003:17EF:608D.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt Lenovo USB Optical Mouse] on usb-xhci-hcd.0.auto-1.2/input0
[    5.358646] panfrost fde60000.gpu: clock rate = 594000000
[    5.358694] panfrost fde60000.gpu: bus_clock rate = 500000000
[    5.358782] panfrost fde60000.gpu: Looking up mali-supply from device tree
[    5.360030] panfrost fde60000.gpu: mali-g52 id 0x7402 major 0x1 minor 0x0 status 0x0
[    5.360061] panfrost fde60000.gpu: features: 00000000,00000cf7, issues: 00000000,00000400
[    5.360070] panfrost fde60000.gpu: Features: L2:0x07110206 Shader:0x00000002 Tiler:0x00000209 Mem:0x1 MMU:0x00002823 AS:0xff JS:0x7
[    5.360078] panfrost fde60000.gpu: shader_present=0x1 l2_present=0x1
[    5.361575] [drm] Initialized panfrost 1.2.0 20180908 for fde60000.gpu on minor 2
[    5.378385] usb 1-1.3: new low-speed USB device number 4 using xhci-hcd
[    5.484832] usb 1-1.3: New USB device found, idVendor=17ef, idProduct=6099, bcdDevice= 1.00
[    5.484868] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    5.484876] usb 1-1.3: Product: Lenovo Traditional USB Keyboard
[    5.484881] usb 1-1.3: Manufacturer: Lenovo
[    5.688717] input: Lenovo Lenovo Traditional USB Keyboard as /devices/platform/usbdrd/fcc00000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.3/1-1.3:1.0/0003:17EF:6099.0002/input/input4
[    5.745557] hid-generic 0003:17EF:6099.0002: input,hidraw1: USB HID v1.11 Keyboard [Lenovo Lenovo Traditional USB Keyboard] on usb-xhci-hcd.0.auto-1.3/input0
[    5.939415] scsi 0:0:0:0: Direct-Access     Kingston DataTraveler 3.0 PMAP PQ: 0 ANSI: 6
[    5.940835] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    5.941226] sd 0:0:0:0: [sda] 60567552 512-byte logical blocks: (31.0 GB/28.9 GiB)
[    5.941498] sd 0:0:0:0: [sda] Write Protect is off
[    5.941511] sd 0:0:0:0: [sda] Mode Sense: 45 00 00 00
[    5.941759] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[    6.047299]  sda: sda1
[    6.048119] sd 0:0:0:0: [sda] Attached SCSI removable disk
[    6.258507] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up rkvenc-supply from device tree
[    6.258552] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up rkvenc-supply property in node /power-management@fdd90000/power-controller failed
[    6.731658] EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Quota mode: none.
[    7.070089] NET: Registered PF_INET6 protocol family
[    7.071368] Segment Routing with IPv6
[    7.071404] In-situ OAM (IOAM) with IPv6
[    7.094691] systemd[1]: systemd 249.11-0ubuntu3.12 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[    7.095654] systemd[1]: Detected architecture arm64.
[    7.098608] systemd[1]: Hostname set to <h96-tvbox-3566-vendor>.
[    7.639133] systemd[1]: Configuration file /lib/systemd/system/ap6335-bluetooth.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[    7.656335] systemd[1]: Queued start job for default target Graphical Interface.
[    7.680664] systemd[1]: Created slice Slice /system/modprobe.
[    7.683106] systemd[1]: Created slice Slice /system/serial-getty.
[    7.685128] systemd[1]: Created slice Slice /system/systemd-fsck.
[    7.686500] systemd[1]: Created slice User and Session Slice.
[    7.687112] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    7.688173] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    7.688740] systemd[1]: Reached target User and Group Name Lookups.
[    7.688977] systemd[1]: Reached target Slice Units.
[    7.689139] systemd[1]: Reached target Swaps.
[    7.689270] systemd[1]: Reached target System Time Set.
[    7.689515] systemd[1]: Reached target Local Verity Protected Volumes.
[    7.709663] systemd[1]: Listening on RPCbind Server Activation Socket.
[    7.710798] systemd[1]: Listening on Syslog Socket.
[    7.711571] systemd[1]: Listening on fsck to fsckd communication Socket.
[    7.712236] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    7.713379] systemd[1]: Listening on Journal Audit Socket.
[    7.714072] systemd[1]: Listening on Journal Socket (/dev/log).
[    7.714910] systemd[1]: Listening on Journal Socket.
[    7.717913] systemd[1]: Listening on udev Control Socket.
[    7.719009] systemd[1]: Listening on udev Kernel Socket.
[    7.723606] systemd[1]: Mounting Huge Pages File System...
[    7.729407] systemd[1]: Mounting POSIX Message Queue File System...
[    7.735371] systemd[1]: Mounting Kernel Debug File System...
[    7.740954] systemd[1]: Mounting Kernel Trace File System...
[    7.742152] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[    7.749199] systemd[1]: Starting Restore / save the current clock...
[    7.755662] systemd[1]: Starting Set the console keyboard layout...
[    7.763913] systemd[1]: Starting Create List of Static Device Nodes...
[    7.773572] systemd[1]: Starting Load Kernel Module configfs...
[    7.783868] systemd[1]: Starting Load Kernel Module drm...
[    7.790989] systemd[1]: Starting Load Kernel Module efi_pstore...
[    7.798184] systemd[1]: Starting Load Kernel Module fuse...
[    7.799334] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    7.809046] systemd[1]: Starting Load Kernel Modules...
[    7.816409] systemd[1]: Starting Remount Root and Kernel File Systems...
[    7.818624] fuse: init (API version 7.37)
[    7.823439] systemd[1]: Starting Coldplug All udev Devices...
[    7.837508] systemd[1]: Mounted Huge Pages File System.
[    7.839505] systemd[1]: Mounted POSIX Message Queue File System.
[    7.842325] systemd[1]: Mounted Kernel Debug File System.
[    7.844671] systemd[1]: Mounted Kernel Trace File System.
[    7.848682] systemd[1]: Finished Restore / save the current clock.
[    7.853742] systemd[1]: Finished Create List of Static Device Nodes.
[    7.857028] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[    7.857788] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
[    7.860199] systemd[1]: Finished Load Kernel Module configfs.
[    7.866940] systemd[1]: modprobe@drm.service: Deactivated successfully.
[    7.869180] systemd[1]: Finished Load Kernel Module drm.
[    7.871175] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[    7.873624] systemd[1]: Finished Load Kernel Module efi_pstore.
[    7.875687] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[    7.876874] systemd[1]: Finished Load Kernel Module fuse.
[    7.879245] systemd[1]: Finished Load Kernel Modules.
[    7.883017] systemd[1]: Finished Remount Root and Kernel File Systems.
[    7.903316] systemd[1]: Mounting FUSE Control File System...
[    7.909160] systemd[1]: Mounting Kernel Configuration File System...
[    7.915721] systemd[1]: Starting Platform Persistent Storage Archival...
[    7.921996] systemd[1]: Starting Load/Save Random Seed...
[    7.933156] systemd[1]: Starting Apply Kernel Variables...
[    7.940125] systemd[1]: Starting Create System Users...
[    7.953437] systemd[1]: Mounted FUSE Control File System.
[    7.974198] systemd[1]: Mounted Kernel Configuration File System.
[    7.982631] systemd[1]: Finished Platform Persistent Storage Archival.
[    7.996913] systemd[1]: Finished Load/Save Random Seed.
[    8.004663] systemd[1]: Finished Create System Users.
[    8.006103] systemd[1]: Condition check resulted in First Boot Complete being skipped.
[    8.039705] systemd[1]: Starting Create Static Device Nodes in /dev...
[    8.042868] systemd[1]: Finished Set the console keyboard layout.
[    8.050224] systemd[1]: Finished Apply Kernel Variables.
[    8.083120] systemd[1]: Finished Create Static Device Nodes in /dev.
[    8.084148] systemd[1]: Reached target Preparation for Local File Systems.
[    8.109380] systemd[1]: Mounting /tmp...
[    8.118456] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[    8.122915] systemd[1]: Mounted /tmp.
[    8.290162] systemd[1]: Started Rule-based Manager for Device Events and Files.
[    8.423090] systemd[1]: Finished Coldplug All udev Devices.
[    8.445901] systemd[1]: Starting Helper to synchronize boot up for ifupdown...
[    8.452654] systemd[1]: Starting Show Plymouth Boot Screen...
[    8.467603] systemd[1]: Finished Helper to synchronize boot up for ifupdown.
[    8.503516] systemd[1]: Started Show Plymouth Boot Screen.
[    8.504619] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch being skipped.
[    8.505505] systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
[    8.505815] systemd[1]: Reached target Local Encrypted Volumes.
[    9.199652] systemd[1]: Found device /dev/disk/by-uuid/E472-B054.
[    9.242720] systemd[1]: Starting File System Check on /dev/disk/by-uuid/E472-B054...
[    9.309545] systemd[1]: Started File System Check Daemon to report status.
[    9.346581] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4335-sdio for chip BCM4335/1
[    9.349950] usbcore: registered new interface driver brcmfmac
[    9.362260] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4335-sdio.clm_blob failed with error -2
[    9.436238] systemd[1]: Finished File System Check on /dev/disk/by-uuid/E472-B054.
[    9.445322] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch being skipped.
[    9.468920] systemd[1]: Mounting /boot...
[    9.469671] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    9.517280] systemd[1]: Mounted /boot.
[    9.518130] systemd[1]: Reached target Local File Systems.
[    9.549713] systemd[1]: Starting Armbian ZRAM config...
[    9.556050] systemd[1]: Starting Set console font and keymap...
[    9.565978] systemd[1]: Starting Raise network interfaces...
[    9.576273] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[    9.576883] systemd[1]: Condition check resulted in RPC security service for NFS server being skipped.
[    9.584919] systemd[1]: Starting Set Up Additional Binary Formats...
[    9.585494] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[    9.585798] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[    9.603198] systemd[1]: Finished Set console font and keymap.
[    9.643426] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[    9.664540] systemd[1]: Received SIGRTMIN+20 from PID 245 (plymouthd).
[    9.664817] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 431 (systemd-binfmt)
[    9.666257] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[    9.705572] systemd[1]: Mounting Arbitrary Executable File Formats File System...
[    9.722769] systemd[1]: Starting Load/Save RF Kill Switch Status...
[    9.892990] systemd[1]: Mounted Arbitrary Executable File Formats File System.
[    9.894770] [BT_RFKILL]: rfkill_rk_set_power: set bt wake_host high!
[    9.901684] systemd[1]: Finished Set Up Additional Binary Formats.
[    9.948376] [BT_RFKILL]: rfkill_rk_set_power: set bt wake_host input!
[    9.948440] [BT_RFKILL]: ENABLE UART_RTS
[   10.055014] [BT_RFKILL]: DISABLE UART_RTS
[   10.055123] [BT_RFKILL]: bt turn on power
[   10.055160] [BT_RFKILL]: Request irq for bt wakeup host
[   10.055176] zram: Added device: zram0
[   10.055208] [BT_RFKILL]: ** disable irq
[   10.057272] zram: Added device: zram1
[   10.057962] zram: Added device: zram2
[   10.104431] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch being skipped.
[   10.106268] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[   10.107500] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[   10.149798] systemd[1]: Started Load/Save RF Kill Switch Status.
[   10.196756] zram0: detected capacity change from 0 to 7871616
[   10.234172] Adding 3935804k swap on /dev/zram0.  Priority:5 extents:1 across:3935804k SS
[   10.324007] systemd[1]: Finished Raise network interfaces.
[   10.457094] zram1: detected capacity change from 0 to 102400
[   10.509942] systemd[1]: Finished Armbian ZRAM config.
[   10.532744] systemd[1]: Starting Armbian memory supported logging...
[   10.607689] EXT4-fs (zram1): mounted filesystem without journal. Quota mode: none.
[   11.542971] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
[   11.543490] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4335/1 wl0: May 18 2014 16:56:54 version 6.34.171.58.2
[   12.733993] systemd[1]: Finished Armbian memory supported logging.
[   12.772887] systemd[1]: Starting Journal Service...
[   13.065374] systemd[1]: Started Journal Service.
[   13.121439] systemd-journald[683]: Received client request to flush runtime journal.
[   14.755266] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   14.755319] Bluetooth: BNEP filters: protocol multicast
[   14.755354] Bluetooth: BNEP socket layer initialized
[   14.870726] [BT_RFKILL]: rfkill_rk_set_power: set bt wake_host high!
[   14.895126] [BT_RFKILL]: rfkill_rk_set_power: set bt wake_host input!
[   14.895228] [BT_RFKILL]: ENABLE UART_RTS
[   15.001779] [BT_RFKILL]: DISABLE UART_RTS
[   15.001907] [BT_RFKILL]: bt turn on power
[   15.001955] [BT_RFKILL]: Request irq for bt wakeup host
[   15.002018] [BT_RFKILL]: ** disable irq
[   15.085674] dw-apb-uart fe650000.serial: got rx and tx dma channels
[   16.162543] rk_gmac-dwmac fe010000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0
[   16.164294] phy_rtl8211f_led_fixup in
[   16.164748] phy_rtl8211f_led_fixup in  val=0x0000
[   16.268392] rk_gmac-dwmac fe010000.ethernet eth0: PHY [stmmac-1:00] driver [RTL8211F Gigabit Ethernet] (irq=POLL)
[   16.269079] dwmac4: Master AXI performs any burst length
[   16.269138] rk_gmac-dwmac fe010000.ethernet eth0: No Safety Features support found
[   16.269181] rk_gmac-dwmac fe010000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported
[   16.269876] rk_gmac-dwmac fe010000.ethernet eth0: registered PTP clock
[   16.283033] rk_gmac-dwmac fe010000.ethernet eth0: configuring for phy/rgmii link mode
[   19.755284] rockchip-thermal fe710000.tsadc: ch0 Missing trim_l property
[   19.755459] rockchip-thermal fe710000.tsadc: ch1 Missing trim_l property
[   19.764325] rockchip-thermal fe710000.tsadc: tsadc is probed successfully!
[   19.766169] platform spdif-sound: deferred probe pending
[   19.766204] platform mtd_vendor_storage: deferred probe pending
[   20.372343] rk_gmac-dwmac fe010000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[   20.372455] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   28.938252] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[   29.749088] rfkill: input handler disabled
[   35.697953] rockchip-vop2 fe040000.vop: [drm:vop2_crtc_atomic_disable] Crtc atomic disable vp0
[   35.717455] rockchip-vop2 fe040000.vop: [drm:vop2_crtc_atomic_enable] Update mode to 1920x1080p60, type: 11(if:800, flag:0x0) for vp0 dclk: 148500000
rfkill
Quote
 0 bluetooth bt_default unblocked unblocked
 1 bluetooth hci0       unblocked unblocked
 2 wlan      phy0       unblocked unblocked
journalctl -b | grep Bluetooth
Quote
jun 08 13:14:24 h96-tvbox-3566-vendor kernel: Bluetooth: Core ver 2.22
jun 08 13:14:24 h96-tvbox-3566-vendor kernel: Bluetooth: HCI device and connection manager initialized
jun 08 13:14:24 h96-tvbox-3566-vendor kernel: Bluetooth: HCI socket layer initialized
jun 08 13:14:24 h96-tvbox-3566-vendor kernel: Bluetooth: L2CAP socket layer initialized
jun 08 13:14:24 h96-tvbox-3566-vendor kernel: Bluetooth: SCO socket layer initialized
jun 08 13:14:25 h96-tvbox-3566-vendor systemd[1]: Starting Bluetooth service...
jun 08 13:14:26 h96-tvbox-3566-vendor bluetoothd[752]: Bluetooth daemon 5.64
jun 08 13:14:26 h96-tvbox-3566-vendor kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
jun 08 13:14:26 h96-tvbox-3566-vendor kernel: Bluetooth: BNEP filters: protocol multicast
jun 08 13:14:26 h96-tvbox-3566-vendor kernel: Bluetooth: BNEP socket layer initialized
jun 08 13:14:26 h96-tvbox-3566-vendor bluetoothd[752]: Bluetooth management interface 1.22 initialized
jun 08 13:14:26 h96-tvbox-3566-vendor systemd[1]: Started Bluetooth service.
jun 08 13:14:26 h96-tvbox-3566-vendor systemd[1]: Reached target Bluetooth Support.
jun 08 13:14:26 h96-tvbox-3566-vendor systemd[1]: Starting Bluetooth AP6335...
sudo systemctl status ap6335-bluetooth
Quote
● ap6335-bluetooth.service - Bluetooth AP6335
     Loaded: loaded (/lib/systemd/system/ap6335-bluetooth.service; enabled; vendor preset: enabled)
     Active: activating (start) since Sat 2024-06-08 13:14:26 -03; 8min ago
    Process: 944 ExecStartPre=rfkill unblock all (code=exited, status=0/SUCCESS)
Cntrl PID: 977 (brcm_patchram_p)
      Tasks: 1 (limit: 8572)
     Memory: 284.0K
        CPU: 30ms
     CGroup: /system.slice/ap6335-bluetooth.service
             └─977 brcm_patchram_plus --bd_addr_rand --enable_hci --no2bytes --use_baudrate_for_download --tosleep 200000 --baudrate 1500000 --patchram /lib/firmware/brcm BCM4335A0.hcd /dev/ttyS1 "&"
jun 08 13:14:26 h96-tvbox-3566-vendor rfkill[944]: unblock set for all
jun 08 13:14:26 h96-tvbox-3566-vendor brcm_patchram_plus[977]: ###AMPAK FW Auto detection patch version = [v1.1 20161117]###
jun 08 13:14:26 h96-tvbox-3566-vendor brcm_patchram_plus[977]: FW folder path = /lib/firmware/brcm
jun 08 13:14:26 h96-tvbox-3566-vendor brcm_patchram_plus[977]: proc_resetchip id = BCM4335A0
jun 08 13:14:26 h96-tvbox-3566-vendor brcm_patchram_plus[977]: FW path = /lib/firmware/brcm/BCM4335A0.hcd
Found some answer in other forums: Could be Pull down or Pull Up pins on UART
Edited by Hqnicolas
Posted (edited)
Updating some bluetooth fix K610 V12,
doesn't work, but it was there on HCi Line talking....
Quote
     Active: activating (start) since Sun 2024-06-09 15:28:55 -03; 7min ago
    Process: 989 ExecStartPre=rfkill unblock all (code=exited, status=0/SUCCESS)
Cntrl PID: 1002 (brcm_patchram_p)
     Memory: 240.0K
        CPU: 39ms
             └─1002 brcm_patchram_plus --bd_addr_rand --enable_hci --no2bytes --use_baudrate_for_download --tosleep 200000 --baudrate 1500000 --patchram /lib/firmware/brcm BCM4335A0.hcd /dev/ttyS1 "&"
jun 09 15:28:55 h96-tvbox-3566-vendor systemd[1]: Starting Bluetooth AP6335...
jun 09 15:28:55 h96-tvbox-3566-vendor rfkill[989]: unblock set for all
jun 09 15:28:55 h96-tvbox-3566-vendor brcm_patchram_plus[1002]: ###AMPAK FW Auto detection patch version = [v1.1 20161117]###
jun 09 15:28:55 h96-tvbox-3566-vendor brcm_patchram_plus[1002]: FW folder path = /lib/firmware/brcm
gpioinfo
Quote
rfkill
Quote
rfkill
 0 wlan      phy0   unblocked unblocked
Full dmesg
Quote
dmesg
[    1.486030] Booting Linux on physical CPU 0x0000000000 [0x412fd050]
[    1.486077] Linux version 6.1.43-vendor-rk35xx (armbian@next) (aarch64-linux-gnu-gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1 SMP Wed May 29 01:45:25 UTC 2024
[    1.495960] Machine model: h96 TVbox 3566
[    1.496183] earlycon: uart8250 at MMIO32 0x00000000fe660000 (options '')
[    1.496210] printk: bootconsole [uart8250] enabled
[    1.499045] efi: UEFI not found.
[    1.499272] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-logo@0': base 0x0000000000000000, size 0 MiB
[    1.499302] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-cubic-lut@0': base 0x0000000000000000, size 0 MiB
[    1.499458] Reserved memory: created CMA memory pool at 0x00000001ff800000, size 8 MiB
[    1.499469] OF: reserved mem: initialized node cma, compatible id shared-dma-pool
[    1.499542] Reserved memory: created CMA memory pool at 0x00000001df800000, size 512 MiB
[    1.499552] OF: reserved mem: initialized node rknpu, compatible id shared-dma-pool
[    1.711368] Zone ranges:
[    1.711390]   DMA      [mem 0x0000000000200000-0x00000000ffffffff]
[    1.711413]   DMA32    empty
[    1.711424]   Normal   [mem 0x0000000100000000-0x00000001ffffffff]
[    1.711436] Movable zone start for each node
[    1.711441] Early memory node ranges
[    1.711446]   node   0: [mem 0x0000000000200000-0x00000000efffffff]
[    1.711462]   node   0: [mem 0x0000000100000000-0x00000001ffffffff]
[    1.711476] Initmem setup node 0 [mem 0x0000000000200000-0x00000001ffffffff]
[    1.740386] On node 0, zone DMA: 512 pages in unavailable ranges
[    1.771333] psci: probing for conduit method from DT.
[    1.771358] psci: PSCIv1.1 detected in firmware.
[    1.771370] psci: Using standard PSCI v0.2 function IDs
[    1.771379] psci: MIGRATE_INFO_TYPE not supported.
[    1.771397] psci: SMC Calling Convention v1.2
[    1.771863] percpu: Embedded 29 pages/cpu s79592 r8192 d31000 u118784
[    1.771922] pcpu-alloc: s79592 r8192 d31000 u118784 alloc=29*4096
[    1.771944] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    1.772091] Detected VIPT I-cache on CPU0
[    1.772179] CPU features: detected: GIC system register CPU interface
[    1.772189] CPU features: detected: Virtualization Host Extensions
[    1.772214] CPU features: detected: Qualcomm erratum 1009, or ARM erratum 1286807, 2441009
[    1.772223] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    1.772234] alternatives: applying boot alternatives
[    1.772849] Built 1 zonelists, mobility grouping on.  Total pages: 1999368
[    1.772874] Kernel command line: root=UUID=560b5e0c-649e-4c39-8e80-a3e1cc8432e2 rootwait rootfstype=ext4 splash plymouth.ignore-serial-consoles console=ttyFIQ0 console=tty1 consoleblank=0 loglevel=1 ubootpart=c37ef71b-9684-d942-a097-a2d95dc143eb usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 earlycon=uart8250,mmio32,0xfe660000
[    1.773714] The swapaccount= commandline option is deprecated. Please report your usecase to linux-mm@kvack.org if you depend on this functionality.
[    1.773799] Unknown kernel command line parameters "splash ubootpart=c37ef71b-9684-d942-a097-a2d95dc143eb cgroup_enable=memory cgroup_memory=1", will be passed to user space.
[    1.776463] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    1.777790] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    1.777807] mem auto-init: stack:off, heap alloc:off, heap free:off
[    1.777820] software IO TLB: area num 4.
[    1.820550] software IO TLB: mapped [mem 0x00000000ec000000-0x00000000f0000000] (64MB)
[    1.949095] Memory: 7315492K/8124416K available (17920K kernel code, 3758K rwdata, 7268K rodata, 7488K init, 697K bss, 276444K reserved, 532480K cma-reserved)
[    1.949358] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    1.949424] ftrace: allocating 68397 entries in 268 pages
[    2.134090] ftrace: allocated 268 pages with 3 groups
[    2.134159] **********************************************************
[    2.134165] **   NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE   **
[    2.134171] **                                                      **
[    2.134176] ** trace_printk() being used. Allocating extra memory.  **
[    2.134182] **                                                      **
[    2.134187] ** This means that this is a DEBUG kernel and it is     **
[    2.134192] ** unsafe for production use.                           **
[    2.134197] **                                                      **
[    2.134202] ** If you see this message and you are not debugging    **
[    2.134207] ** the kernel, report this immediately to your vendor!  **
[    2.134212] **                                                      **
[    2.134217] **   NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE   **
[    2.134222] **********************************************************
[    2.135103] trace event string verifier disabled
[    2.135464] rcu: Hierarchical RCU implementation.
[    2.135478] rcu:     RCU event tracing is enabled.
[    2.135484] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    2.135496]     Rude variant of Tasks RCU enabled.
[    2.135501]     Tracing variant of Tasks RCU enabled.
[    2.135507] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[    2.135516] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    2.149802] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    2.153084] GICv3: GIC: Using split EOI/Deactivate mode
[    2.153104] GICv3: 320 SPIs implemented
[    2.153115] GICv3: 0 Extended SPIs implemented
[    2.153178] Root IRQ handler: gic_handle_irq
[    2.153209] GICv3: GICv3 features: 16 PPIs
[    2.153257] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000
[    2.154163] ITS [mem 0xfd440000-0xfd45ffff]
[    2.154288] ITS@0x00000000fd440000: allocated 8192 Devices @2c10000 (indirect, esz 8, psz 64K, shr 0)
[    2.154357] ITS@0x00000000fd440000: allocated 32768 Interrupt Collections @2c20000 (flat, esz 2, psz 64K, shr 0)
[    2.154385] ITS: using cache flushing for cmd queue
[    2.155016] GICv3: using LPI property table @0x0000000002c30000
[    2.155207] GIC: using cache flushing for LPI property table
[    2.155221] GICv3: CPU0: using allocated LPI pending table @0x0000000002c40000
[    2.155339] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    2.204139] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    2.204180] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    2.204201] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    2.206331] Console: colour dummy device 80x25
[    2.206364] printk: console [tty1] enabled
[    2.206376] printk: bootconsole [uart8250] disabled
[    2.206435] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[    2.206457] pid_max: default: 32768 minimum: 301
[    2.206616] LSM: Security Framework initializing
[    2.206886] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    2.206946] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    2.208622] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    2.210279] cblist_init_generic: Setting adjustable number of callback queues.
[    2.210293] cblist_init_generic: Setting shift to 2 and lim to 1.
[    2.210505] cblist_init_generic: Setting adjustable number of callback queues.
[    2.210518] cblist_init_generic: Setting shift to 2 and lim to 1.
[    2.210988] rcu: Hierarchical SRCU implementation.
[    2.211000] rcu:     Max phase no-delay instances is 1000.
[    2.212476] Platform MSI: interrupt-controller@fd440000 domain created
[    2.213227] PCI/MSI: /interrupt-controller@fd400000/interrupt-controller@fd440000 domain created
[    2.213986] EFI services will not be available.
[    2.214729] smp: Bringing up secondary CPUs ...
[    2.216651] Detected VIPT I-cache on CPU1
[    2.216798] cacheinfo: Unable to detect cache hierarchy for CPU 1
[    2.216819] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[    2.216857] GICv3: CPU1: using allocated LPI pending table @0x0000000002c50000
[    2.216929] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[    2.219139] Detected VIPT I-cache on CPU2
[    2.219276] cacheinfo: Unable to detect cache hierarchy for CPU 2
[    2.219297] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[    2.219331] GICv3: CPU2: using allocated LPI pending table @0x0000000002c60000
[    2.219388] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[    2.221447] Detected VIPT I-cache on CPU3
[    2.221583] cacheinfo: Unable to detect cache hierarchy for CPU 3
[    2.221605] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000
[    2.221639] GICv3: CPU3: using allocated LPI pending table @0x0000000002c70000
[    2.221696] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[    2.221894] smp: Brought up 1 node, 4 CPUs
[    2.221929] SMP: Total of 4 processors activated.
[    2.221940] CPU features: detected: 32-bit EL0 Support
[    2.221947] CPU features: detected: 32-bit EL1 Support
[    2.221956] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    2.221965] CPU features: detected: Common not Private translations
[    2.221971] CPU features: detected: CRC32 instructions
[    2.221982] CPU features: detected: RCpc load-acquire (LDAPR)
[    2.221989] CPU features: detected: Privileged Access Never
[    2.221996] CPU features: detected: RAS Extension Support
[    2.222006] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    2.222142] CPU: All CPU(s) started at EL2
[    2.222153] alternatives: applying system-wide alternatives
[    2.226550] devtmpfs: initialized
[    2.276752] Registered cp15_barrier emulation handler
[    2.276786] Registered setend emulation handler
[    2.277117] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    2.277156] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    2.294165] pinctrl core: initialized pinctrl subsystem
[    2.294763] regulator-dummy: no parameters, enabled
[    2.295297] DMI not present or invalid.
[    2.296321] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    2.299093] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[    2.299309] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    2.299506] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    2.299650] audit: initializing netlink subsys (disabled)
[    2.299983] audit: type=2000 audit(0.093:1): state=initialized audit_enabled=0 res=1
[    2.305094] Registered FIQ tty driver
[    2.305906] thermal_sys: Registered thermal governor 'fair_share'
[    2.305920] thermal_sys: Registered thermal governor 'step_wise'
[    2.305929] thermal_sys: Registered thermal governor 'user_space'
[    2.305937] thermal_sys: Registered thermal governor 'power_allocator'
[    2.306068] cpuidle: using governor menu
[    2.307002] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    2.307286] ASID allocator initialised with 65536 entries
[    2.311338] ramoops: dmesg-0    0x20000@0x0000000000110000
[    2.311435] ramoops: console    0x80000@0x0000000000130000
[    2.311472] ramoops: pmsg    0x50000@0x00000000001b0000
[    2.311731] printk: console [ramoops-1] enabled
[    2.311745] pstore: Registered ramoops as persistent store backend
[    2.311755] ramoops: using 0xf0000@0x110000, ecc: 0
[    2.340166] platform fe040000.vop: Fixed dependency cycle(s) with /hdmi@fe0a0000
[    2.378213] rockchip-gpio fdd60000.gpio: probed /pinctrl/gpio@fdd60000
[    2.379217] rockchip-gpio fe740000.gpio: probed /pinctrl/gpio@fe740000
[    2.380127] rockchip-gpio fe750000.gpio: probed /pinctrl/gpio@fe750000
[    2.381038] rockchip-gpio fe760000.gpio: probed /pinctrl/gpio@fe760000
[    2.381986] rockchip-gpio fe770000.gpio: probed /pinctrl/gpio@fe770000
[    2.382218] rockchip-pinctrl pinctrl: probed pinctrl
[    2.393357] KASLR disabled due to lack of seed
[    2.416922] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    2.416949] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    2.416962] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    2.416970] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    2.416980] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    2.416989] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    2.416999] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    2.417007] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    2.475290] raid6: neonx8   gen()  1370 MB/s
[    2.532176] raid6: neonx4   gen()  1408 MB/s
[    2.589057] raid6: neonx2   gen()  1288 MB/s
[    2.645952] raid6: neonx1   gen()  1053 MB/s
[    2.702859] raid6: int64x8  gen()   349 MB/s
[    2.759778] raid6: int64x4  gen()   440 MB/s
[    2.816633] raid6: int64x2  gen()   909 MB/s
[    2.873536] raid6: int64x1  gen()   638 MB/s
[    2.873551] raid6: using algorithm neonx4 gen() 1408 MB/s
[    2.930352] raid6: .... xor() 1067 MB/s, rmw enabled
[    2.930368] raid6: using neon recovery algorithm
[    2.931778] dc_5v: 5000 mV, enabled
[    2.932137] reg-fixed-voltage dc-5v: dc_5v supplying 5000000uV
[    2.932400] reg-fixed-voltage vcc3v3-sys: Looking up vin-supply from device tree
[    2.932429] vcc3v3_sys: supplied by dc_5v
[    2.932448] dc_5v: could not add device link regulator.2: -ENOENT
[    2.932515] vcc3v3_sys: 3300 mV, enabled
[    2.932791] reg-fixed-voltage vcc3v3-sys: vcc3v3_sys supplying 3300000uV
[    2.933028] reg-fixed-voltage vcc5v0-sys: Looking up vin-supply from device tree
[    2.933053] vcc5v0_sys: supplied by dc_5v
[    2.933070] dc_5v: could not add device link regulator.3: -ENOENT
[    2.933139] vcc5v0_sys: 5000 mV, enabled
[    2.933434] reg-fixed-voltage vcc5v0-sys: vcc5v0_sys supplying 5000000uV
[    2.933980] vcc5v0_host: no parameters, enabled
[    2.934272] reg-fixed-voltage vcc5v0-host-regulator: vcc5v0_host supplying 0uV
[    2.934525] reg-fixed-voltage vcc2v5-ddr: Looking up vin-supply from device tree
[    2.934551] vcc2v5_sys: supplied by vcc3v3_sys
[    2.934568] vcc3v3_sys: could not add device link regulator.5: -ENOENT
[    2.934660] vcc2v5_sys: 2500 mV, enabled
[    2.934928] reg-fixed-voltage vcc2v5-ddr: vcc2v5_sys supplying 2500000uV
[    2.935186] reg-fixed-voltage vcc3v3-vga: Looking up vin-supply from device tree
[    2.935211] vcc3v3_vga: supplied by vcc3v3_sys
[    2.935229] vcc3v3_sys: could not add device link regulator.6: -ENOENT
[    2.935303] vcc3v3_vga: at 3300 mV, enabled
[    2.935582] reg-fixed-voltage vcc3v3-vga: vcc3v3_vga supplying 0uV
[    2.936676] iommu: Default domain type: Translated
[    2.936695] iommu: DMA domain TLB invalidation policy: strict mode
[    2.937377] SCSI subsystem initialized
[    2.937453] libata version 3.00 loaded.
[    2.937784] usbcore: registered new interface driver usbfs
[    2.937874] usbcore: registered new interface driver hub
[    2.937939] usbcore: registered new device driver usb
[    2.938175] mc: Linux media interface: v0.10
[    2.938267] videodev: Linux video capture interface: v2.00
[    2.938441] pps_core: LinuxPPS API ver. 1 registered
[    2.938454] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    2.938492] PTP clock support registered
[    2.939438] arm-scmi firmware:scmi: Enabled polling mode TX channel - prot_id:16
[    2.939681] arm-scmi firmware:scmi: SCMI Notifications - Core Enabled.
[    2.939767] arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0
[    2.941098] Advanced Linux Sound Architecture Driver Initialized.
[    2.942166] Bluetooth: Core ver 2.22
[    2.942241] NET: Registered PF_BLUETOOTH protocol family
[    2.942254] Bluetooth: HCI device and connection manager initialized
[    2.942272] Bluetooth: HCI socket layer initialized
[    2.942287] Bluetooth: L2CAP socket layer initialized
[    2.942318] Bluetooth: SCO socket layer initialized
[    2.942447] NetLabel: Initializing
[    2.942457] NetLabel:  domain hash size = 128
[    2.942467] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    2.942575] NetLabel:  unlabeled traffic allowed by default
[    2.943282] vgaarb: loaded
[    3.580236] clocksource: Switched to clocksource arch_sys_counter
[    3.581105] VFS: Disk quotas dquot_6.6.0
[    3.581193] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    3.601774] NET: Registered PF_INET protocol family
[    3.602350] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    3.612320] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[    3.612433] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    3.612582] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    3.613129] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[    3.615378] TCP: Hash tables configured (established 65536 bind 65536)
[    3.615894] MPTCP token hash table entries: 8192 (order: 5, 196608 bytes, linear)
[    3.616151] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    3.616314] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    3.616773] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    3.617885] RPC: Registered named UNIX socket transport module.
[    3.617905] RPC: Registered udp transport module.
[    3.617914] RPC: Registered tcp transport module.
[    3.617922] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    3.619681] PCI: CLS 0 bytes, default 64
[    3.620736] Trying to unpack rootfs image as initramfs...
[    3.628864] hw perfevents: enabled with armv8_cortex_a55 PMU driver, 7 counters available
[    3.630711] kvm [1]: IPA Size Limit: 40 bits
[    3.630780] kvm [1]: GICv3: no GICV resource entry
[    3.630794] kvm [1]: disabling GICv2 emulation
[    3.630803] kvm [1]: GIC system register CPU interface enabled
[    3.631159] kvm [1]: vgic interrupt IRQ9
[    3.631907] kvm [1]: VHE mode initialized successfully
[    3.680906] Initialise system trusted keyrings
[    3.681325] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[    3.694601] NFS: Registering the id_resolver key type
[    3.694662] Key type id_resolver registered
[    3.694674] Key type id_legacy registered
[    3.694824] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    3.694841] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    3.748636] NET: Registered PF_ALG protocol family
[    3.748681] xor: measuring software checksum speed
[    3.755032]    8regs           :  1565 MB/sec
[    3.760236]    32regs          :  1910 MB/sec
[    3.766387]    arm64_neon      :  1619 MB/sec
[    3.766411] xor: using function: 32regs (1910 MB/sec)
[    3.766448] Key type asymmetric registered
[    3.766463] Asymmetric key parser 'x509' registered
[    3.766616] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[    3.767059] io scheduler mq-deadline registered
[    3.767076] io scheduler kyber registered
[    3.770390] rockchip-csi2-dphy-hw fe870000.csi2-dphy-hw: csi2 dphy hw probe successfully!
[    3.774622] phy phy-fe8a0000.usb2-phy.0: Looking up phy-supply from device tree
[    3.774967] vcc5v0_host: could not add device link phy-fe8a0000.usb2-phy.0: -ENOENT
[    3.775318] phy phy-fe8a0000.usb2-phy.1: Looking up phy-supply from device tree
[    3.775350] vcc5v0_host: could not add device link phy-fe8a0000.usb2-phy.1: -ENOENT
[    3.775619] phy phy-fe8a0000.usb2-phy.1: Looking up vbus-supply from device tree
[    3.775642] phy phy-fe8a0000.usb2-phy.1: Looking up vbus-supply property in node /usb2-phy@fe8a0000/otg-port failed
[    3.780141] phy phy-fe830000.phy.2: Looking up phy-supply from device tree
[    3.780250] phy phy-fe830000.phy.2: Looking up phy-supply property in node /phy@fe830000 failed
[    3.781081] phy phy-fe840000.phy.3: Looking up phy-supply from device tree
[    3.781107] phy phy-fe840000.phy.3: Looking up phy-supply property in node /phy@fe840000 failed
[    3.788769] iep: Module initialized.
[    3.788907] mpp_service mpp-srv: 6849c1e28b7b author: Ding Wei 2023-12-28 video: rockchip: mpp: px30: fix issue combo_init when device probe
[    3.788928] mpp_service mpp-srv: probe start
[    3.795588] mpp_service mpp-srv: probe success
[    3.804402] dma-pl330 fe530000.dma-controller: Loaded driver for PL330 DMAC-241330
[    3.804438] dma-pl330 fe530000.dma-controller:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    3.808543] dma-pl330 fe550000.dma-controller: Loaded driver for PL330 DMAC-241330
[    3.808578] dma-pl330 fe550000.dma-controller:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    3.809307] rockchip-pvtm fde00000.pvtm: failed to retrieve pvtm_tz
[    3.809386] rockchip-pvtm fde00000.pvtm: pvtm@0 probed
[    3.809600] rockchip-pvtm fde80000.pvtm: failed to retrieve pvtm_tz
[    3.809665] rockchip-pvtm fde80000.pvtm: pvtm@1 probed
[    3.809832] rockchip-pvtm fde90000.pvtm: failed to retrieve pvtm_tz
[    3.809900] rockchip-pvtm fde90000.pvtm: pvtm@2 probed
[    3.811487] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[    3.812659] arm-scmi firmware:scmi: Failed. SCMI protocol 22 not active.
[    3.813172] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[    3.814763] fe650000.serial: ttyS1 at MMIO 0xfe650000 (irq = 29, base_baud = 1500000) is a 16550A
[    3.819150] led_vk2c21_init
[    3.819348] random: crng init done
[    3.821021] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up vpu-supply from device tree
[    3.821071] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up vpu-supply property in node /power-management@fdd90000/power-controller failed
[    3.822075] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up rga-supply from device tree
[    3.822116] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up rga-supply property in node /power-management@fdd90000/power-controller failed
[    3.825098] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up rkvdec-supply from device tree
[    3.825147] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up rkvdec-supply property in node /power-management@fdd90000/power-controller failed
[    3.844326] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    3.845976] brd: module loaded
[    3.855923] loop: module loaded
[    3.856614] rbd: loaded (major 254)
[    3.857193] lkdtm: No crash points registered, enable through debugfs
[    3.860845] SPI driver spidev has no spi_device_id for rockchip,spidev
[    3.867125] usbcore: registered new interface driver rndis_wlan
[    3.867237] usbcore: registered new interface driver asix
[    3.867311] usbcore: registered new interface driver cdc_ether
[    3.867379] usbcore: registered new interface driver rndis_host
[    3.867467] usbcore: registered new interface driver cdc_ncm
[    3.867862] VFIO - User Level meta-driver version: 0.3
[    3.883570] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    3.883632] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    3.883853] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000022010010
[    3.883961] xhci-hcd xhci-hcd.0.auto: irq 36, io mem 0xfcc00000
[    3.884216] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    3.884245] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[    3.884273] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[    3.884707] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[    3.884731] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.884747] usb usb1: Product: xHCI Host Controller
[    3.884759] usb usb1: Manufacturer: Linux 6.1.43-vendor-rk35xx xhci-hcd
[    3.884771] usb usb1: SerialNumber: xhci-hcd.0.auto
[    3.885701] hub 1-0:1.0: USB hub found
[    3.885786] hub 1-0:1.0: 1 port detected
[    3.886618] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    3.886968] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[    3.886991] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.887006] usb usb2: Product: xHCI Host Controller
[    3.887018] usb usb2: Manufacturer: Linux 6.1.43-vendor-rk35xx xhci-hcd
[    3.887030] usb usb2: SerialNumber: xhci-hcd.0.auto
[    3.887892] hub 2-0:1.0: USB hub found
[    3.887974] hub 2-0:1.0: 1 port detected
[    3.888974] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    3.889018] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 3
[    3.889226] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000800002010010
[    3.889321] xhci-hcd xhci-hcd.1.auto: irq 37, io mem 0xfd000000
[    3.889580] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    3.889609] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 4
[    3.889637] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[    3.890040] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[    3.890063] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.890078] usb usb3: Product: xHCI Host Controller
[    3.890090] usb usb3: Manufacturer: Linux 6.1.43-vendor-rk35xx xhci-hcd
[    3.890102] usb usb3: SerialNumber: xhci-hcd.1.auto
[    3.891116] hub 3-0:1.0: USB hub found
[    3.891208] hub 3-0:1.0: 1 port detected
[    3.892024] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    3.892351] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[    3.892375] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.892390] usb usb4: Product: xHCI Host Controller
[    3.892402] usb usb4: Manufacturer: Linux 6.1.43-vendor-rk35xx xhci-hcd
[    3.892414] usb usb4: SerialNumber: xhci-hcd.1.auto
[    3.893301] hub 4-0:1.0: USB hub found
[    3.893391] hub 4-0:1.0: 1 port detected
[    3.894346] usbcore: registered new interface driver cdc_acm
[    3.894364] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    3.894813] usbcore: registered new interface driver uas
[    3.894993] usbcore: registered new interface driver usb-storage
[    3.895928] mousedev: PS/2 mouse device common for all mice
[    3.897299] i2c_dev: i2c /dev entries driver
[    3.900445] fan53555-regulator 0-001c: FAN53555 Option[12] Rev[15] Detected!
[    3.900514] fan53555-regulator 0-001c: Looking up vin-supply from device tree
[    3.900550] vdd_cpu: supplied by vcc5v0_sys
[    3.900569] vcc5v0_sys: could not add device link regulator.7: -ENOENT
[    3.903583] vdd_cpu: 700 <--> 1200 mV at 900 mV, enabled
[    3.909320] rk808 0-0020: chip id: 0x8090
[    3.909405] rk808 0-0020: No cache defaults, reading back from HW
[    3.933301] rk808 0-0020: source: on=0x40, off=0x00
[    3.933346] rk808 0-0020: support dcdc3 fb mode:-22, 1
[    3.933364] rk808 0-0020: support pmic reset mode:-22,0
[    3.940604] rk808 0-0020: had get a pinctrl!
[    3.945184] rk808-regulator rk808-regulator: there is no dvs0 gpio
[    3.945245] rk808-regulator rk808-regulator: there is no dvs1 gpio
[    3.945346] rk808 0-0020: Looking up vcc1-supply from device tree
[    3.945380] vdd_logic: supplied by vcc3v3_sys
[    3.945398] vcc3v3_sys: could not add device link regulator.8: -ENOENT
[    3.945955] vdd_logic: 700 <--> 1100 mV at 900 mV, enabled
[    3.946463] rk808 0-0020: Looking up vcc2-supply from device tree
[    3.946493] vdd_gpu: supplied by vcc3v3_sys
[    3.946510] vcc3v3_sys: could not add device link regulator.9: -ENOENT
[    3.946983] vdd_gpu: 700 <--> 1350 mV at 1000 mV, enabled
[    3.947394] DCDC_REG3: at 500 mV, enabled
[    3.947641] rk808 0-0020: Looking up vcc3-supply from device tree
[    3.947669] DCDC_REG3: supplied by vcc3v3_sys
[    3.947908] rk808 0-0020: Looking up vcc4-supply from device tree
[    3.947934] vdd_npu: supplied by vcc3v3_sys
[    3.947951] vcc3v3_sys: could not add device link regulator.11: -ENOENT
[    3.948422] vdd_npu: 700 <--> 1350 mV at 900 mV, enabled
[    3.948884] rk808 0-0020: Looking up vcc9-supply from device tree
[    3.948912] vcc_1v8: supplied by vcc3v3_sys
[    3.948936] vcc3v3_sys: could not add device link regulator.12: -ENOENT
[    3.949391] vcc_1v8: 1800 mV, enabled
[    3.949827] rk808 0-0020: Looking up vcc5-supply from device tree
[    3.949855] vdda0v9_image: supplied by vcc3v3_sys
[    3.949871] vcc3v3_sys: could not add device link regulator.13: -ENOENT
[    3.950861] vdda0v9_image: 900 mV, enabled
[    3.951291] rk808 0-0020: Looking up vcc5-supply from device tree
[    3.951319] vdda_0v9: supplied by vcc3v3_sys
[    3.951336] vcc3v3_sys: could not add device link regulator.14: -ENOENT
[    3.952319] vdda_0v9: 900 mV, enabled
[    3.952747] rk808 0-0020: Looking up vcc5-supply from device tree
[    3.952774] vdda0v9_pmu: supplied by vcc3v3_sys
[    3.952798] vcc3v3_sys: could not add device link regulator.15: -ENOENT
[    3.953796] vdda0v9_pmu: 900 mV, enabled
[    3.954268] rk808 0-0020: Looking up vcc6-supply from device tree
[    3.954298] vccio_acodec: supplied by vcc3v3_sys
[    3.954315] vcc3v3_sys: could not add device link regulator.16: -ENOENT
[    3.954379] vccio_acodec: No configuration
[    3.955321] vccio_acodec: 3300 mV, enabled
[    3.955756] rk808 0-0020: Looking up vcc6-supply from device tree
[    3.955785] vccio_sd: supplied by vcc3v3_sys
[    3.955801] vcc3v3_sys: could not add device link regulator.17: -ENOENT
[    3.956816] vccio_sd: 1800 <--> 3300 mV at 3300 mV, enabled
[    3.957279] rk808 0-0020: Looking up vcc6-supply from device tree
[    3.957310] vcc3v3_pmu: supplied by vcc3v3_sys
[    3.957327] vcc3v3_sys: could not add device link regulator.18: -ENOENT
[    3.958317] vcc3v3_pmu: 3300 mV, enabled
[    3.958781] rk808 0-0020: Looking up vcc7-supply from device tree
[    3.958810] vcca_1v8: supplied by vcc3v3_sys
[    3.958826] vcc3v3_sys: could not add device link regulator.19: -ENOENT
[    3.959814] vcca_1v8: 1800 mV, enabled
[    3.960283] rk808 0-0020: Looking up vcc7-supply from device tree
[    3.960312] vcca1v8_pmu: supplied by vcc3v3_sys
[    3.960329] vcc3v3_sys: could not add device link regulator.20: -ENOENT
[    3.961348] vcca1v8_pmu: 1800 mV, enabled
[    3.961791] rk808 0-0020: Looking up vcc7-supply from device tree
[    3.961820] vcca1v8_image: supplied by vcc3v3_sys
[    3.961838] vcc3v3_sys: could not add device link regulator.21: -ENOENT
[    3.962827] vcca1v8_image: 1800 mV, enabled
[    3.963290] rk808 0-0020: Looking up vcc9-supply from device tree
[    3.963320] vcc_3v3: supplied by vcc3v3_sys
[    3.963336] vcc3v3_sys: could not add device link regulator.22: -ENOENT
[    3.963807] vcc_3v3: at 3300 mV, enabled
[    3.964208] rk808 0-0020: Looking up vcc8-supply from device tree
[    3.964237] vcc3v3_sd: supplied by vcc3v3_sys
[    3.964253] vcc3v3_sys: could not add device link regulator.23: -ENOENT
[    3.964728] vcc3v3_sd: at 3300 mV, enabled
[    3.965114] rk817-battery: Failed to locate of_node [id: -1]
[    3.965319] rk817-battery rk817-battery: Failed to find matching dt id
[    3.965502] rk817-charger: Failed to locate of_node [id: -1]
[    3.965693] rk817-charger rk817-charger: Failed to find matching dt id
[    3.969295] input: rk805 pwrkey as /devices/platform/fdd40000.i2c/i2c-0/0-0020/rk805-pwrkey/input/input0
[    3.976795] rk808-rtc rk808-rtc: registered as rtc0
[    3.978610] rk808-rtc rk808-rtc: setting system clock to 2024-06-09T18:28:43 UTC (1717957723)
[    3.984259] rockchip-mipi-csi2-hw fdfb0000.mipi-csi2-hw: enter mipi csi2 hw probe!
[    3.984683] rockchip-mipi-csi2-hw fdfb0000.mipi-csi2-hw: probe success, v4l2_dev:mipi-csi2-hw!
[    3.989602] usbcore: registered new interface driver uvcvideo
[    3.993300] cpu cpu0: Failed to get specification_serial_number
[    3.993368] cpu cpu0: Failed to get leakage
[    3.993407] cpu cpu0: Looking up cpu-supply from device tree
[    3.994576] cpu cpu0: soc version=0, speed=0
[    3.994699] cpu cpu0: Looking up cpu-supply from device tree
[    3.996341] cpu cpu0: avs=0
[    3.996624] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[    4.000410] cpu cpu0: EM: created perf domain
[    4.002349] sdhci: Secure Digital Host Controller Interface driver
[    4.002366] sdhci: Copyright(c) Pierre Ossman
[    4.002370] Synopsys Designware Multimedia Card Interface Driver
[    4.002835] sdhci-pltfm: SDHCI platform and OF driver helper
[    4.003775] dwmmc_rockchip fe2c0000.mmc: No normal pinctrl state
[    4.003795] dwmmc_rockchip fe2c0000.mmc: No idle pinctrl state
[    4.003842] dwmmc_rockchip fe2b0000.mmc: No normal pinctrl state
[    4.003851] dwmmc_rockchip fe2b0000.mmc: No idle pinctrl state
[    4.004198] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.
[    4.004208] dwmmc_rockchip fe2b0000.mmc: IDMAC supports 32-bit address mode.
[    4.004254] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.
[    4.004261] dwmmc_rockchip fe2b0000.mmc: Using internal DMA controller.
[    4.004265] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a
[    4.004272] dwmmc_rockchip fe2b0000.mmc: Version ID is 270a
[    4.004324] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 68,32 bit host data width,256 deep fifo
[    4.004344] dwmmc_rockchip fe2b0000.mmc: DW MMC controller at irq 69,32 bit host data width,256 deep fifo
[    4.004425] dwmmc_rockchip fe2c0000.mmc: Looking up vmmc-supply from device tree
[    4.004426] dwmmc_rockchip fe2b0000.mmc: Looking up vmmc-supply from device tree
[    4.004438] dwmmc_rockchip fe2b0000.mmc: Looking up vmmc-supply property in node /mmc@fe2b0000 failed
[    4.004484] dwmmc_rockchip fe2b0000.mmc: Looking up vqmmc-supply from device tree
[    4.004570] dwmmc_rockchip fe2c0000.mmc: Looking up vqmmc-supply from device tree
[    4.004706] dwmmc_rockchip fe2b0000.mmc: Got CD GPIO
[    4.004988] dwmmc_rockchip fe2c0000.mmc: allocated mmc-pwrseq
[    4.005001] mmc_host mmc2: card is non-removable.
[    4.006062] sdhci-dwcmshc fe310000.mmc: Looking up vmmc-supply from device tree
[    4.006084] sdhci-dwcmshc fe310000.mmc: Looking up vmmc-supply property in node /mmc@fe310000 failed
[    4.006127] sdhci-dwcmshc fe310000.mmc: Looking up vqmmc-supply from device tree
[    4.006134] sdhci-dwcmshc fe310000.mmc: Looking up vqmmc-supply property in node /mmc@fe310000 failed
[    4.006332] ledtrig-cpu: registered to indicate activity on CPUs
[    4.006413] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
[    4.006505] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    4.007480] cryptodev: driver 1.12 loaded.
[    4.007549] hid: raw HID events driver (C) Jiri Kosina
[    4.007873] usbcore: registered new interface driver usbhid
[    4.007882] usbhid: USB HID core driver
[    4.008185] rockchip,bus bus-npu: Looking up bus-supply from device tree
[    4.008401] rockchip,bus bus-npu: bin=0
[    4.008426] rockchip,bus bus-npu: Failed to get leakage
[    4.008444] rockchip,bus bus-npu: Looking up pvtm-supply from device tree
[    4.009312] rockchip,bus bus-npu: Looking up pvtm-supply from device tree
[    4.010225] rockchip,bus bus-npu: avs=0
[    4.014398] rockchip-saradc fe720000.saradc: Looking up vref-supply from device tree
[    4.015393] SPI driver inv-icm42600-spi has no spi_device_id for invensense,icm42600
[    4.015408] SPI driver inv-icm42600-spi has no spi_device_id for invensense,icm42602
[    4.015413] SPI driver inv-icm42600-spi has no spi_device_id for invensense,icm42605
[    4.015416] SPI driver inv-icm42600-spi has no spi_device_id for invensense,icm42622
[    4.016062] optee: probing for conduit method.
[    4.016075] optee: api uid mismatch
[    4.016078] optee: probe of firmware:optee failed with error -22
[    4.016813] usbcore: registered new interface driver snd-usb-audio
[    4.016961] mmc_host mmc1: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[    4.018800] rk817-codec rk817-codec: DMA mask not set
[    4.020759] [Awinic] aw87xxx_pa_init:driver version: v2.2.0
[    4.025707] rk-multicodecs rk809-sound: Failed to get ADC channel
[    4.025870] rk-multicodecs rk809-sound: ASoC: Property 'rockchip,audio-routing' does not exist or its length is not even
[    4.027267] rk817-codec rk817-codec: rk817_probe: chip_name:0x80, chip_ver:0x94
[    4.031604] rk-multicodecs rk809-sound: Don't need to map headset detect gpio to irq
[    4.034172] Initializing XFRM netlink socket
[    4.034234] NET: Registered PF_PACKET protocol family
[    4.034545] [BT_RFKILL]: Enter rfkill_rk_init
[    4.034553] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    4.034903] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[    4.034944] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6398s
[    4.034949] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[    4.034954] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[    4.034976] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,poweren_gpio = 74 flags = 0.
[    4.035002] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[    4.035007] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[    4.035013] [WLAN_RFKILL]: rfkill_set_wifi_bt_power: 1
[    4.035018] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[    4.035450] Key type dns_resolver registered
[    4.035486] Key type ceph registered
[    4.035947] libceph: loaded (mon/osd proto 15/24)
[    4.036254] mmc0: SDHCI controller on fe310000.mmc [fe310000.mmc] using ADMA
[    4.037861] registered taskstats version 1
[    4.037898] Loading compiled-in X.509 certificates
[    4.038984] Btrfs loaded, crc32c=crc32c-generic, zoned=no, fsverity=no
[    4.039577] pstore: Using crash dump compression: deflate
[    4.048003] rga: rga2, irq = 75, match scheduler
[    4.048426] rga: rga2 hardware loaded successfully, hw_version:3.2.63318.
[    4.048487] rga: rga2 probe successfully
[    4.048822] rga_iommu: IOMMU binding successfully, default mapping core[0x4]
[    4.049085] rga: Module initialized. v1.3.1
[    4.072972] rockchip-iodomain fdc20000.syscon:io-domains: Looking up pmuio1-supply from device tree
[    4.073203] rockchip-iodomain fdc20000.syscon:io-domains: pmuio1(3300000 uV) supplied by vcc3v3_pmu
[    4.073219] rockchip-iodomain fdc20000.syscon:io-domains: Looking up pmuio2-supply from device tree
[    4.073292] rockchip-iodomain fdc20000.syscon:io-domains: pmuio2(3300000 uV) supplied by vcc3v3_pmu
[    4.073304] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio1-supply from device tree
[    4.073450] rockchip-iodomain fdc20000.syscon:io-domains: vccio1(3300000 uV) supplied by vccio_acodec
[    4.073463] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio2-supply from device tree
[    4.073658] rockchip-iodomain fdc20000.syscon:io-domains: vccio2(1800000 uV) supplied by vcc_1v8
[    4.073673] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio3-supply from device tree
[    4.073793] rockchip-iodomain fdc20000.syscon:io-domains: vccio3(3300000 uV) supplied by vccio_sd
[    4.073805] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio4-supply from device tree
[    4.073856] rockchip-iodomain fdc20000.syscon:io-domains: vccio4(1800000 uV) supplied by vcc_1v8
[    4.073867] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio5-supply from device tree
[    4.073995] rockchip-iodomain fdc20000.syscon:io-domains: vccio5(3300000 uV) supplied by vcc_3v3
[    4.074007] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio6-supply from device tree
[    4.074062] rockchip-iodomain fdc20000.syscon:io-domains: vccio6(1800000 uV) supplied by vcc_1v8
[    4.074073] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio7-supply from device tree
[    4.074129] rockchip-iodomain fdc20000.syscon:io-domains: vccio7(3300000 uV) supplied by vcc_3v3
[    4.074551] mpp_rkvenc fdf40000.rkvenc: probing start
[    4.074783] mpp_iommu_probe:487: failed to get device node
[    4.074793] mpp_rkvenc fdf40000.rkvenc: failed to attach iommu
[    4.074847] mpp_rkvenc fdf40000.rkvenc: Looking up venc-supply from device tree
[    4.075008] mpp_rkvenc fdf40000.rkvenc: bin=0
[    4.075033] mpp_rkvenc fdf40000.rkvenc: Failed to get leakage
[    4.075049] mpp_rkvenc fdf40000.rkvenc: Looking up venc-supply from device tree
[    4.075070] vdd_logic: could not add device link fdf40000.rkvenc: -EEXIST
[    4.075143] mpp_rkvenc fdf40000.rkvenc: Looking up venc-supply from device tree
[    4.075161] debugfs: Directory 'fdf40000.rkvenc-venc' with parent 'vdd_logic' already present!
[    4.075170] vdd_logic: Failed to create debugfs directory
[    4.075382] mpp_rkvenc fdf40000.rkvenc: avs=0
[    4.075580] mpp_rkvenc fdf40000.rkvenc: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[    4.076176] mpp_rkvenc fdf40000.rkvenc: probing finish
[    4.076619] mpp_vdpu2 fdea0400.vdpu: Adding to iommu group 0
[    4.076799] mpp_vdpu2 fdea0400.vdpu: probe device
[    4.077757] mpp_vdpu2 fdea0400.vdpu: probing finish
[    4.078201] mpp_vepu2 fdee0000.vepu: Adding to iommu group 2
[    4.078396] mpp_vepu2 fdee0000.vepu: probing start
[    4.079034] mpp_vepu2 fdee0000.vepu: probing finish
[    4.079461] mpp-iep2 fdef0000.iep: Adding to iommu group 3
[    4.079654] mpp-iep2 fdef0000.iep: probe device
[    4.079928] mpp-iep2 fdef0000.iep: allocate roi buffer failed
[    4.080150] mpp-iep2 fdef0000.iep: probing finish
[    4.080680] mpp_jpgdec fded0000.jpegd: Adding to iommu group 1
[    4.080864] mpp_jpgdec fded0000.jpegd: probe device
[    4.081549] mpp_jpgdec fded0000.jpegd: probing finish
[    4.082023] mpp_rkvdec2 fdf80200.rkvdec: Adding to iommu group 4
[    4.082317] mpp_rkvdec2 fdf80200.rkvdec: rkvdec, probing start
[    4.082662] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_a is not found!
[    4.082670] rkvdec2_init:982: No niu aclk reset resource define
[    4.082678] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_h is not found!
[    4.082682] rkvdec2_init:985: No niu hclk reset resource define
[    4.082706] mpp_rkvdec2 fdf80200.rkvdec: Looking up vdec-supply from device tree
[    4.082924] mpp_rkvdec2 fdf80200.rkvdec: bin=0
[    4.083005] mpp_rkvdec2 fdf80200.rkvdec: Failed to get leakage
[    4.083023] mpp_rkvdec2 fdf80200.rkvdec: Looking up vdec-supply from device tree
[    4.083046] vdd_logic: could not add device link fdf80200.rkvdec: -EEXIST
[    4.083059] debugfs: File 'uA_load' in directory '/' already present!
[    4.083067] debugfs: File 'min_uV' in directory '/' already present!
[    4.083073] debugfs: File 'max_uV' in directory '/' already present!
[    4.083079] debugfs: File 'constraint_flags' in directory '/' already present!
[    4.083136] mpp_rkvdec2 fdf80200.rkvdec: Looking up vdec-supply from device tree
[    4.083155] debugfs: Directory 'fdf80200.rkvdec-vdec' with parent 'vdd_logic' already present!
[    4.083162] vdd_logic: Failed to create debugfs directory
[    4.083369] mpp_rkvdec2 fdf80200.rkvdec: avs=0
[    4.083697] mpp_rkvdec2 fdf80200.rkvdec: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[    4.083860] mpp_rkvdec2 fdf80200.rkvdec: sram_start 0x00000000fdcc0000
[    4.083869] mpp_rkvdec2 fdf80200.rkvdec: rcb_iova 0x0000000010000000
[    4.083875] mpp_rkvdec2 fdf80200.rkvdec: sram_size 65536
[    4.083880] mpp_rkvdec2 fdf80200.rkvdec: rcb_size 65536
[    4.083887] mpp_rkvdec2 fdf80200.rkvdec: min_width 512
[    4.083953] mpp_rkvdec2 fdf80200.rkvdec: link mode probe finish
[    4.084023] mpp_rkvdec2 fdf80200.rkvdec: probing finish
[    4.084494] rockchip-vop2 fe040000.vop: Adding to iommu group 5
[    4.085013] [drm] all windows should be assigned, full plane mask: 0x3f, current plane mask: 0x0
[    4.085025] [drm] use default plane mask
[    4.085212] [drm] RK3566 only support 2 vps
[    4.085236] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x15, primary plane phy id: 4
[    4.085255] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp1 assign plane mask: 0x22, primary plane phy id: 5
[    4.085265] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x8, primary plane phy id: 3
[    4.085568] [drm] failed to init overlay plane Cluster0-win1
[    4.085609] [drm] failed to init overlay plane Cluster1-win1
[    4.085787] rockchip-vop2 fe040000.vop: bin=0
[    4.085815] rockchip-vop2 fe040000.vop: Failed to get leakage
[    4.085862] rockchip-vop2 fe040000.vop: Looking up vop-supply from device tree
[    4.086268] rockchip-vop2 fe040000.vop: Looking up vop-supply from device tree
[    4.086664] rockchip-vop2 fe040000.vop: avs=0
[    4.086880] rockchip-vop2 fe040000.vop: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[    4.087308] rockchip-vop2 fe040000.vop: Supported VOP aclk dvfs, normal mode:396000000, advanced mode:500000000
[    4.087328] rockchip-drm display-subsystem: bound fe040000.vop (ops 0xffff8000092d7c18)
[    4.087530] dwhdmi-rockchip fe0a0000.hdmi: Looking up avdd-0v9-supply from device tree
[    4.087544] dwhdmi-rockchip fe0a0000.hdmi: Looking up avdd-0v9-supply property in node /hdmi@fe0a0000 failed
[    4.087584] dwhdmi-rockchip fe0a0000.hdmi: Looking up avdd-1v8-supply from device tree
[    4.087594] dwhdmi-rockchip fe0a0000.hdmi: Looking up avdd-1v8-supply property in node /hdmi@fe0a0000 failed
[    4.087758] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[    4.088622] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver
[    4.089189] dwhdmi-rockchip fe0a0000.hdmi: error -ENXIO: IRQ index 1 not found
[    4.089639] mmc0: Host Software Queue enabled
[    4.089659] mmc0: new HS200 MMC card at address 0001
[    4.090376] mmcblk0: mmc0:0001 CJNB4R 58.2 GiB
[    4.091370] input: hdmi_cec_key as /devices/platform/fe0a0000.hdmi/dw-hdmi-cec.5.auto/input/input1
[    4.092154] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops 0xffff8000092e9ff0)
[    4.093017] rockchip-drm display-subsystem: failed to parse loader memory
[    4.093909] [drm] Initialized rockchip 3.0.0 20140818 for display-subsystem on minor 0
[    4.094156]  mmcblk0: p1 p2
[    4.094899] mmcblk0boot0: mmc0:0001 CJNB4R 4.00 MiB
[    4.096073] mmcblk0boot1: mmc0:0001 CJNB4R 4.00 MiB
[    4.097171] mmcblk0rpmb: mmc0:0001 CJNB4R 4.00 MiB, chardev (235:0)
[    4.133590] usb 1-1: new full-speed USB device number 2 using xhci-hcd
[    4.142755] vendor storage:20190527 ret = 0
[    4.207395] rockchip-vop2 fe040000.vop: [drm:vop2_crtc_atomic_enable] Update mode to 3840x2160p60, type: 11(if:800, flag:0x0) for vp0 dclk: 594000000
[    4.223743] mmc_host mmc2: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[    4.278840] usb 1-1: New USB device found, idVendor=0a05, idProduct=7211, bcdDevice= 1.00
[    4.278881] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    4.278887] usb 1-1: Product: USB2.0 HUB
[    4.280058] Freeing initrd memory: 16156K
[    4.350976] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 100000000Hz, actual 50000000HZ div = 0)
[    4.364062] dwmmc_rockchip fe2c0000.mmc: Successfully tuned phase to 360
[    4.368000] mmc2: new ultra high speed SDR50 SDIO card at address 0001
[    4.524661] hub 1-1:1.0: USB hub found
[    4.524838] hub 1-1:1.0: 4 ports detected
[    4.541198] Console: switching to colour frame buffer device 480x135
[    4.598904] rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device
[    4.600486] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up gpu-supply from device tree
[    4.600523] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up gpu-supply property in node /power-management@fdd90000/power-controller failed
[    4.600622] mali fde60000.gpu: Kernel DDK version g18p0-01eac0
[    4.600637] mali fde60000.gpu: error -ENXIO: IRQ JOB not found
[    4.600724] mali fde60000.gpu: error -ENXIO: IRQ MMU not found
[    4.600773] mali fde60000.gpu: error -ENXIO: IRQ GPU not found
[    4.600813] mali fde60000.gpu: Insufficient register space, will override to the required size
[    4.600826] mali fde60000.gpu: Register window unavailable
[    4.600831] mali fde60000.gpu: Failed to map registers
[    4.600836] mali fde60000.gpu: Register map failed error = -5
[    4.600870] mali fde60000.gpu: Device initialization failed
[    4.600921] mali: probe of fde60000.gpu failed with error -5
[    4.600987] rk_gmac-dwmac fe010000.ethernet: IRQ eth_lpi not found
[    4.601245] rk_gmac-dwmac fe010000.ethernet: Looking up phy-supply from device tree
[    4.601421] rk_gmac-dwmac fe010000.ethernet: clock input or output? (input).
[    4.601429] rk_gmac-dwmac fe010000.ethernet: TX delay(0x4f).
[    4.601436] rk_gmac-dwmac fe010000.ethernet: RX delay(0x24).
[    4.601448] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no).
[    4.601483] rk_gmac-dwmac fe010000.ethernet: clock input from PHY
[    4.601725] rk_gmac-dwmac fe010000.ethernet: init for RGMII
[    4.602124] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[    4.602155] rk_gmac-dwmac fe010000.ethernet:     DWMAC4/5
[    4.602164] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported
[    4.602169] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported
[    4.602174] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported
[    4.602179] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported
[    4.602242] rk_gmac-dwmac fe010000.ethernet: TSO supported
[    4.602248] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    4.602256] rk_gmac-dwmac fe010000.ethernet: Enabled RFS Flow TC (entries=10)
[    4.602263] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled
[    4.602269] rk_gmac-dwmac fe010000.ethernet: Using 32/32 bits DMA host/device width
[    4.744537] rockchip-dmc dmc: Failed to get specification_serial_number
[    4.744572] rockchip-dmc dmc: Failed to get leakage
[    4.744594] rockchip-dmc dmc: Looking up center-supply from device tree
[    4.744935] rockchip-dmc dmc: soc version=0, speed=0
[    4.744986] rockchip-dmc dmc: Looking up center-supply from device tree
[    4.745218] rockchip-dmc dmc: avs=0
[    4.745237] rockchip-dmc dmc: current ATF version 0x102
[    4.745962] rockchip-dmc dmc: normal_rate = 780000000
[    4.745971] rockchip-dmc dmc: reboot_rate = 1056000000
[    4.745978] rockchip-dmc dmc: suspend_rate = 324000000
[    4.745984] rockchip-dmc dmc: video_4k_rate = 780000000
[    4.745990] rockchip-dmc dmc: video_4k_10b_rate = 780000000
[    4.745995] rockchip-dmc dmc: boost_rate = 1056000000
[    4.746001] rockchip-dmc dmc: fixed_rate(isp|cif0|cif1|dualview) = 1056000000
[    4.746007] rockchip-dmc dmc: performance_rate = 1056000000
[    4.746024] rockchip-dmc dmc: failed to get vop pn to msch rl
[    4.746254] rockchip-dmc dmc: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[    4.763862] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up vi-supply from device tree
[    4.763905] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up vi-supply property in node /power-management@fdd90000/power-controller failed
[    4.764083] WCN: marlin_init entry!
[    4.765573] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up npu-supply from device tree
[    4.765603] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up npu-supply property in node /power-management@fdd90000/power-controller failed
[    4.765697] RKNPU fde40000.npu: RKNPU: rknpu iommu is disabled, using non-iommu mode
[    4.765711] RKNPU fde40000.npu: assigned reserved memory node rknpu
[    4.765716] RKNPU fde40000.npu: RKNPU: initialize reserved memory for rknpu device!
[    4.765769] RKNPU fde40000.npu: Looking up rknpu-supply from device tree
[    4.765949] RKNPU fde40000.npu: Looking up mem-supply from device tree
[    4.766117] RKNPU fde40000.npu: error -ENXIO: IRQ npu_irq not found
[    4.766994] [drm] Initialized rknpu 0.9.6 20240322 for fde40000.npu on minor 1
[    4.767578] RKNPU fde40000.npu: Failed to get specification_serial_number
[    4.767612] RKNPU fde40000.npu: Failed to get leakage
[    4.767634] RKNPU fde40000.npu: Looking up rknpu-supply from device tree
[    4.767667] vdd_npu: could not add device link fde40000.npu: -EEXIST
[    4.767682] debugfs: File 'uA_load' in directory '/' already present!
[    4.767692] debugfs: File 'min_uV' in directory '/' already present!
[    4.767699] debugfs: File 'max_uV' in directory '/' already present!
[    4.767704] debugfs: File 'constraint_flags' in directory '/' already present!
[    4.767742] RKNPU fde40000.npu: soc version=0, speed=0
[    4.767807] RKNPU fde40000.npu: Looking up rknpu-supply from device tree
[    4.767827] debugfs: Directory 'fde40000.npu-rknpu' with parent 'vdd_npu' already present!
[    4.767834] vdd_npu: Failed to create debugfs directory
[    4.767842] RKNPU fde40000.npu: Looking up mem-supply from device tree
[    4.767860] vdd_logic: could not add device link fde40000.npu: -EEXIST
[    4.767868] debugfs: File 'uA_load' in directory '/' already present!
[    4.767874] debugfs: File 'min_uV' in directory '/' already present!
[    4.767878] debugfs: File 'max_uV' in directory '/' already present!
[    4.767884] debugfs: File 'constraint_flags' in directory '/' already present!
[    4.767913] RKNPU fde40000.npu: opp_parse_supplies: Invalid number of elements in opp-microvolt property (3) with supplies (2)
[    4.767923] RKNPU fde40000.npu: _of_add_opp_table_v2: Failed to add OPP, -22
[    4.767932] RKNPU fde40000.npu: failed to add opp table
[    4.767987] RKNPU fde40000.npu: RKNPU: failed to init_opp_table
[    4.769400] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    4.785072] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    4.786083] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[    4.786690] rockchip-suspend not set sleep-mode-config for mem-lite
[    4.786696] rockchip-suspend not set wakeup-config for mem-lite
[    4.786702] rockchip-suspend not set sleep-mode-config for mem-ultra
[    4.786706] rockchip-suspend not set wakeup-config for mem-ultra
[    4.788178] ALSA device list:
[    4.788199]   #0: rockchip-rk809
[    4.788204]   #1: rockchip,hdmi
[    4.796701] Freeing unused kernel memory: 7488K
[    4.826997] Run /init as init process
[    4.827020]   with arguments:
[    4.827026]     /init
[    4.827030]     splash
[    4.827034]   with environment:
[    4.827037]     HOME=/
[    4.827041]     TERM=linux
[    4.827045]     ubootpart=c37ef71b-9684-d942-a097-a2d95dc143eb
[    4.827049]     cgroup_enable=memory
[    4.827053]     cgroup_memory=1
[    4.900618] usb 4-1: new SuperSpeed USB device number 2 using xhci-hcd
[    4.918387] usb 4-1: New USB device found, idVendor=0951, idProduct=1666, bcdDevice= 1.10
[    4.918420] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    4.918427] usb 4-1: Product: DataTraveler 3.0
[    4.918433] usb 4-1: Manufacturer: Kingston
[    4.918438] usb 4-1: SerialNumber: 08606E6D4139B1409831D890
[    4.919964] usb-storage 4-1:1.0: USB Mass Storage device detected
[    4.922346] scsi host0: usb-storage 4-1:1.0
[    4.990307] usb 1-1.2: new low-speed USB device number 3 using xhci-hcd
[    5.084794] usb 1-1.2: New USB device found, idVendor=17ef, idProduct=608d, bcdDevice= 1.00
[    5.084828] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    5.084836] usb 1-1.2: Product: Lenovo USB Optical Mouse
[    5.084842] usb 1-1.2: Manufacturer: PixArt
[    5.295965] input: PixArt Lenovo USB Optical Mouse as /devices/platform/usbdrd/fcc00000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.2/1-1.2:1.0/0003:17EF:608D.0001/input/input2
[    5.296728] hid-generic 0003:17EF:608D.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt Lenovo USB Optical Mouse] on usb-xhci-hcd.0.auto-1.2/input0
[    5.317355] input: adc-keys as /devices/platform/adc-keys/input/input3
[    5.370333] usb 1-1.3: new low-speed USB device number 4 using xhci-hcd
[    5.372622] panfrost fde60000.gpu: clock rate = 594000000
[    5.372681] panfrost fde60000.gpu: bus_clock rate = 500000000
[    5.372788] panfrost fde60000.gpu: Looking up mali-supply from device tree
[    5.373962] panfrost fde60000.gpu: mali-g52 id 0x7402 major 0x1 minor 0x0 status 0x0
[    5.373998] panfrost fde60000.gpu: features: 00000000,00000cf7, issues: 00000000,00000400
[    5.374006] panfrost fde60000.gpu: Features: L2:0x07110206 Shader:0x00000002 Tiler:0x00000209 Mem:0x1 MMU:0x00002823 AS:0xff JS:0x7
[    5.374014] panfrost fde60000.gpu: shader_present=0x1 l2_present=0x1
[    5.379338] [drm] Initialized panfrost 1.2.0 20180908 for fde60000.gpu on minor 2
[    5.471871] usb 1-1.3: New USB device found, idVendor=17ef, idProduct=6099, bcdDevice= 1.00
[    5.471911] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    5.471918] usb 1-1.3: Product: Lenovo Traditional USB Keyboard
[    5.471924] usb 1-1.3: Manufacturer: Lenovo
[    5.697289] input: Lenovo Lenovo Traditional USB Keyboard as /devices/platform/usbdrd/fcc00000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.3/1-1.3:1.0/0003:17EF:6099.0002/input/input4
[    5.754196] hid-generic 0003:17EF:6099.0002: input,hidraw1: USB HID v1.11 Keyboard [Lenovo Lenovo Traditional USB Keyboard] on usb-xhci-hcd.0.auto-1.3/input0
[    5.947969] scsi 0:0:0:0: Direct-Access     Kingston DataTraveler 3.0 PMAP PQ: 0 ANSI: 6
[    5.949090] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    5.950013] sd 0:0:0:0: [sda] 60567552 512-byte logical blocks: (31.0 GB/28.9 GiB)
[    5.950352] sd 0:0:0:0: [sda] Write Protect is off
[    5.950376] sd 0:0:0:0: [sda] Mode Sense: 45 00 00 00
[    5.950772] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[    6.037016]  sda: sda1
[    6.037872] sd 0:0:0:0: [sda] Attached SCSI removable disk
[    6.564481] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up rkvenc-supply from device tree
[    6.564668] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up rkvenc-supply property in node /power-management@fdd90000/power-controller failed
[    6.746546] EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Quota mode: none.
[    7.089248] NET: Registered PF_INET6 protocol family
[    7.090780] Segment Routing with IPv6
[    7.090818] In-situ OAM (IOAM) with IPv6
[    7.114865] systemd[1]: systemd 249.11-0ubuntu3.12 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[    7.115747] systemd[1]: Detected architecture arm64.
[    7.117835] systemd[1]: Hostname set to <h96-tvbox-3566-vendor>.
[    7.685820] systemd[1]: Configuration file /lib/systemd/system/ap6335-bluetooth.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[    7.705322] systemd[1]: Queued start job for default target Graphical Interface.
[    7.742872] systemd[1]: Created slice Slice /system/modprobe.
[    7.745313] systemd[1]: Created slice Slice /system/serial-getty.
[    7.747364] systemd[1]: Created slice Slice /system/systemd-fsck.
[    7.748703] systemd[1]: Created slice User and Session Slice.
[    7.749279] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    7.750406] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    7.750917] systemd[1]: Reached target User and Group Name Lookups.
[    7.751140] systemd[1]: Reached target Slice Units.
[    7.751274] systemd[1]: Reached target Mounting snaps.
[    7.751388] systemd[1]: Reached target Mounted snaps.
[    7.751525] systemd[1]: Reached target Swaps.
[    7.751671] systemd[1]: Reached target System Time Set.
[    7.751946] systemd[1]: Reached target Local Verity Protected Volumes.
[    7.774076] systemd[1]: Listening on RPCbind Server Activation Socket.
[    7.775218] systemd[1]: Listening on Syslog Socket.
[    7.776047] systemd[1]: Listening on fsck to fsckd communication Socket.
[    7.776532] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    7.777792] systemd[1]: Listening on Journal Audit Socket.
[    7.778559] systemd[1]: Listening on Journal Socket (/dev/log).
[    7.779458] systemd[1]: Listening on Journal Socket.
[    7.782482] systemd[1]: Listening on udev Control Socket.
[    7.783498] systemd[1]: Listening on udev Kernel Socket.
[    7.788458] systemd[1]: Mounting Huge Pages File System...
[    7.794003] systemd[1]: Mounting POSIX Message Queue File System...
[    7.800531] systemd[1]: Mounting Kernel Debug File System...
[    7.806185] systemd[1]: Mounting Kernel Trace File System...
[    7.807395] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[    7.814177] systemd[1]: Starting Restore / save the current clock...
[    7.820763] systemd[1]: Starting Set the console keyboard layout...
[    7.828105] systemd[1]: Starting Create List of Static Device Nodes...
[    7.838230] systemd[1]: Starting Load Kernel Module configfs...
[    7.846732] systemd[1]: Starting Load Kernel Module drm...
[    7.857860] systemd[1]: Starting Load Kernel Module efi_pstore...
[    7.864986] systemd[1]: Starting Load Kernel Module fuse...
[    7.866362] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    7.875618] systemd[1]: Starting Load Kernel Modules...
[    7.885723] systemd[1]: Starting Remount Root and Kernel File Systems...
[    7.886688] fuse: init (API version 7.37)
[    7.897893] systemd[1]: Starting Coldplug All udev Devices...
[    7.912258] systemd[1]: Mounted Huge Pages File System.
[    7.915365] systemd[1]: Mounted POSIX Message Queue File System.
[    7.919099] systemd[1]: Mounted Kernel Debug File System.
[    7.921069] systemd[1]: Mounted Kernel Trace File System.
[    7.926146] systemd[1]: Finished Restore / save the current clock.
[    7.931183] systemd[1]: Finished Create List of Static Device Nodes.
[    7.933911] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
[    7.934670] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[    7.936145] systemd[1]: Finished Load Kernel Module configfs.
[    7.941582] systemd[1]: modprobe@drm.service: Deactivated successfully.
[    7.942980] systemd[1]: Finished Load Kernel Module drm.
[    7.945361] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[    7.946739] systemd[1]: Finished Load Kernel Module efi_pstore.
[    7.949169] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[    7.952111] systemd[1]: Finished Load Kernel Module fuse.
[    7.954533] systemd[1]: Finished Load Kernel Modules.
[    7.957641] systemd[1]: Finished Remount Root and Kernel File Systems.
[    7.988205] systemd[1]: Mounting FUSE Control File System...
[    7.993868] systemd[1]: Mounting Kernel Configuration File System...
[    8.000659] systemd[1]: Starting Platform Persistent Storage Archival...
[    8.007164] systemd[1]: Starting Load/Save Random Seed...
[    8.014059] systemd[1]: Starting Apply Kernel Variables...
[    8.024437] systemd[1]: Starting Create System Users...
[    8.041704] systemd[1]: Mounted FUSE Control File System.
[    8.044053] systemd[1]: Mounted Kernel Configuration File System.
[    8.063303] systemd[1]: Finished Platform Persistent Storage Archival.
[    8.074899] systemd[1]: Finished Load/Save Random Seed.
[    8.076197] systemd[1]: Condition check resulted in First Boot Complete being skipped.
[    8.086638] systemd[1]: Finished Create System Users.
[    8.118221] systemd[1]: Starting Create Static Device Nodes in /dev...
[    8.121778] systemd[1]: Finished Set the console keyboard layout.
[    8.129374] systemd[1]: Finished Apply Kernel Variables.
[    8.162806] systemd[1]: Finished Create Static Device Nodes in /dev.
[    8.164052] systemd[1]: Reached target Preparation for Local File Systems.
[    8.170296] systemd[1]: Mounting /tmp...
[    8.179612] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[    8.185014] systemd[1]: Mounted /tmp.
[    8.353469] systemd[1]: Started Rule-based Manager for Device Events and Files.
[    8.565243] systemd[1]: Finished Coldplug All udev Devices.
[    8.604652] systemd[1]: Starting Helper to synchronize boot up for ifupdown...
[    8.612361] systemd[1]: Starting Show Plymouth Boot Screen...
[    8.624418] systemd[1]: Finished Helper to synchronize boot up for ifupdown.
[    8.691502] systemd[1]: Started Show Plymouth Boot Screen.
[    8.692668] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch being skipped.
[    8.693604] systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
[    8.694038] systemd[1]: Reached target Local Encrypted Volumes.
[    9.203491] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4335-sdio for chip BCM4335/1
[    9.217200] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4335-sdio.clm_blob failed with error -2
[    9.242569] usbcore: registered new interface driver brcmfmac
[    9.253772] systemd[1]: Found device /dev/disk/by-uuid/139F-3D21.
[    9.277969] systemd[1]: Starting File System Check on /dev/disk/by-uuid/139F-3D21...
[    9.313761] systemd[1]: Started File System Check Daemon to report status.
[    9.398753] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
[    9.399439] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4335/1 wl0: May 18 2014 16:56:54 version 6.34.171.58.2
[    9.405510] Bluetooth: HCI UART driver ver 2.3
[    9.405553] Bluetooth: HCI UART protocol H4 registered
[    9.405559] Bluetooth: HCI UART protocol BCSP registered
[    9.405564] Bluetooth: HCI UART protocol ATH3K registered
[    9.405670] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    9.406111] Bluetooth: HCI UART protocol Intel registered
[    9.406479] Bluetooth: HCI UART protocol Broadcom registered
[    9.406529] Bluetooth: HCI UART protocol QCA registered
[    9.406535] Bluetooth: HCI UART protocol AG6XX registered
[    9.444136] systemd[1]: Finished File System Check on /dev/disk/by-uuid/139F-3D21.
[    9.467587] systemd[1]: Mounting /boot...
[    9.571158] systemd[1]: Mounted /boot.
[    9.682296] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch being skipped.
[    9.682973] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    9.683138] systemd[1]: Reached target Local File Systems.
[    9.683664] systemd[1]: Condition check resulted in Load AppArmor profiles being skipped.
[    9.704567] systemd[1]: Starting Armbian ZRAM config...
[    9.714108] systemd[1]: Starting Set console font and keymap...
[    9.724841] systemd[1]: Starting Raise network interfaces...
[    9.734047] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[    9.735140] systemd[1]: Condition check resulted in RPC security service for NFS server being skipped.
[    9.735520] systemd[1]: Condition check resulted in Load AppArmor profiles managed internally by snapd being skipped.
[    9.747835] systemd[1]: Starting Set Up Additional Binary Formats...
[    9.748755] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[    9.749304] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[    9.770646] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[    9.774614] systemd[1]: Received SIGRTMIN+20 from PID 240 (plymouthd).
[    9.775116] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[    9.798192] systemd[1]: Starting Load/Save RF Kill Switch Status...
[    9.814569] systemd[1]: Finished Set console font and keymap.
[    9.833965] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 424 (systemd-binfmt)
[    9.861158] systemd[1]: Mounting Arbitrary Executable File Formats File System...
[    9.913048] systemd[1]: Mounted Arbitrary Executable File Formats File System.
[    9.923156] systemd[1]: Finished Set Up Additional Binary Formats.
[   10.048555] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch being skipped.
[   10.048951] systemd[1]: Condition check resulted in Load AppArmor profiles being skipped.
[   10.049144] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[   10.049315] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[   10.079161] systemd[1]: Started Load/Save RF Kill Switch Status.
[   10.289946] zram: Added device: zram0
[   10.291250] zram: Added device: zram1
[   10.293981] zram: Added device: zram2
[   10.384941] zram0: detected capacity change from 0 to 7871616
[   10.417312] Adding 3935804k swap on /dev/zram0.  Priority:5 extents:1 across:3935804k SS
[   10.604744] zram1: detected capacity change from 0 to 102400
[   10.651145] systemd[1]: Finished Armbian ZRAM config.
[   10.678529] systemd[1]: Starting Armbian memory supported logging...
[   10.747014] EXT4-fs (zram1): mounted filesystem without journal. Quota mode: none.
[   11.977799] systemd[1]: Finished Raise network interfaces.
[   12.914406] systemd[1]: Finished Armbian memory supported logging.
[   12.951542] systemd[1]: Starting Journal Service...
[   13.247139] systemd[1]: Started Journal Service.
[   13.306586] systemd-journald[687]: Received client request to flush runtime journal.
[   15.725835] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   15.725882] Bluetooth: BNEP filters: protocol multicast
[   15.725918] Bluetooth: BNEP socket layer initialized
[   15.837241] dw-apb-uart fe650000.serial: got rx and tx dma channels
[   16.216484] loop0: detected capacity change from 0 to 8
[   16.337169] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[   17.448389] rk_gmac-dwmac fe010000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0
[   17.450586] phy_rtl8211f_led_fixup in
[   17.453933] phy_rtl8211f_led_fixup in  val=0x0000
[   17.543730] rk_gmac-dwmac fe010000.ethernet eth0: PHY [stmmac-1:00] driver [RTL8211F Gigabit Ethernet] (irq=POLL)
[   17.544399] dwmac4: Master AXI performs any burst length
[   17.544454] rk_gmac-dwmac fe010000.ethernet eth0: No Safety Features support found
[   17.544496] rk_gmac-dwmac fe010000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported
[   17.545050] rk_gmac-dwmac fe010000.ethernet eth0: registered PTP clock
[   17.550539] rk_gmac-dwmac fe010000.ethernet eth0: configuring for phy/rgmii link mode
[   19.763567] rockchip-thermal fe710000.tsadc: ch0 Missing trim_l property
[   19.763628] rockchip-thermal fe710000.tsadc: ch1 Missing trim_l property
[   19.779235] rockchip-thermal fe710000.tsadc: tsadc is probed successfully!
[   19.782208] platform spdif-sound: deferred probe pending
[   19.782246] platform mtd_vendor_storage: deferred probe pending
[   21.630844] rk_gmac-dwmac fe010000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[   21.630963] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[  128.529476] rockchip-vop2 fe040000.vop: [drm:vop2_crtc_atomic_disable] Crtc atomic disable vp0
[  128.605276] rockchip-vop2 fe040000.vop: [drm:vop2_crtc_atomic_enable] Update mode to 1920x1080p60, type: 11(if:800, flag:0x0) for vp0 dclk: 148500000
[  132.300720] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[  241.438879] usb 1-1: USB disconnect, device number 2
[  241.438908] usb 1-1.2: USB disconnect, device number 3
[  241.581267] usb 1-1.3: USB disconnect, device number 4
journalctl -b | grep Bluetooth
Quote
jun 09 15:28:52 h96-tvbox-3566-vendor kernel: Bluetooth: Core ver 2.22
jun 09 15:28:52 h96-tvbox-3566-vendor kernel: Bluetooth: HCI device and connection manager initialized
jun 09 15:28:52 h96-tvbox-3566-vendor kernel: Bluetooth: HCI socket layer initialized
jun 09 15:28:52 h96-tvbox-3566-vendor kernel: Bluetooth: L2CAP socket layer initialized
jun 09 15:28:52 h96-tvbox-3566-vendor kernel: Bluetooth: SCO socket layer initialized
jun 09 15:28:52 h96-tvbox-3566-vendor kernel: Bluetooth: HCI UART driver ver 2.3
jun 09 15:28:52 h96-tvbox-3566-vendor kernel: Bluetooth: HCI UART protocol H4 registered
jun 09 15:28:52 h96-tvbox-3566-vendor kernel: Bluetooth: HCI UART protocol BCSP registered
jun 09 15:28:52 h96-tvbox-3566-vendor kernel: Bluetooth: HCI UART protocol ATH3K registered
jun 09 15:28:52 h96-tvbox-3566-vendor kernel: Bluetooth: HCI UART protocol Three-wire (H5) registered
jun 09 15:28:52 h96-tvbox-3566-vendor kernel: Bluetooth: HCI UART protocol Intel registered
jun 09 15:28:52 h96-tvbox-3566-vendor kernel: Bluetooth: HCI UART protocol Broadcom registered
jun 09 15:28:52 h96-tvbox-3566-vendor kernel: Bluetooth: HCI UART protocol QCA registered
jun 09 15:28:52 h96-tvbox-3566-vendor kernel: Bluetooth: HCI UART protocol AG6XX registered
jun 09 15:28:53 h96-tvbox-3566-vendor systemd[1]: Starting Bluetooth management mechanism...
jun 09 15:28:53 h96-tvbox-3566-vendor systemd[1]: Starting Bluetooth service...
jun 09 15:28:55 h96-tvbox-3566-vendor bluetoothd[767]: Bluetooth daemon 5.64
jun 09 15:28:55 h96-tvbox-3566-vendor systemd[1]: Started Bluetooth service.
jun 09 15:28:55 h96-tvbox-3566-vendor systemd[1]: Reached target Bluetooth Support.
jun 09 15:28:55 h96-tvbox-3566-vendor systemd[1]: Starting Bluetooth AP6335...
jun 09 15:28:55 h96-tvbox-3566-vendor kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
jun 09 15:28:55 h96-tvbox-3566-vendor kernel: Bluetooth: BNEP filters: protocol multicast
jun 09 15:28:55 h96-tvbox-3566-vendor kernel: Bluetooth: BNEP socket layer initialized
jun 09 15:28:55 h96-tvbox-3566-vendor bluetoothd[767]: Bluetooth management interface 1.22 initialized
jun 09 15:28:58 h96-tvbox-3566-vendor systemd[1]: Started Bluetooth management mechanism.
jun 09 15:30:58 h96-tvbox-3566-vendor systemd[1]: Starting Bluetooth management mechanism...
jun 09 15:30:59 h96-tvbox-3566-vendor systemd[1]: Started Bluetooth management mechanism.
jun 09 15:30:59 h96-tvbox-3566-vendor systemd[1594]: Starting Bluetooth OBEX service...
jun 09 15:30:59 h96-tvbox-3566-vendor systemd[1594]: Started Bluetooth OBEX service.
jun 09 15:31:15 h96-tvbox-3566-vendor systemd[1594]: Starting Bluetooth Manager...
jun 09 15:31:17 h96-tvbox-3566-vendor systemd[1594]: Started Bluetooth Manager.
Edited by Hqnicolas
Posted (edited)
Updating some HDMi Audio fix K510 V7,
no HDMi audio until now
Found this HDMI fix
sudo systemctl status ap6335-bluetooth
Quote
● ap6335-bluetooth.service - Bluetooth AP6335
     Loaded: loaded (/lib/systemd/system/ap6335-bluetooth.service; enabled; vendor preset: enabled)
     Active: activating (start) since Sun 2024-06-09 14:30:40 -03; 18min ago
    Process: 1117 ExecStartPre=rfkill unblock all (code=exited, status=0/SUCCESS)
Cntrl PID: 1124 (brcm_patchram_p)
      Tasks: 1 (limit: 8577)
     Memory: 236.0K
        CPU: 71ms
     CGroup: /system.slice/ap6335-bluetooth.service
             └─1124 brcm_patchram_plus --bd_addr_rand --enable_hci --no2bytes --use_baudrate_for_download --tosleep 200000 --baudrate 1500000 --patchram /lib/firmware/brcm BCM4335A0.hcd /dev/ttyS1 "&"
jun 09 14:30:40 h96-tvbox-3566-legacy systemd[1]: Starting Bluetooth AP6335...
jun 09 14:30:40 h96-tvbox-3566-legacy brcm_patchram_plus[1124]: ###AMPAK FW Auto detection patch version = [v1.1 20161117]###
jun 09 14:30:40 h96-tvbox-3566-legacy brcm_patchram_plus[1124]: FW folder path = /lib/firmware/brcm
gpioinfo
Quote
sudo gpioinfo
gpiochip0 - 32 lines:
    line   0:      unnamed       unused   input  active-high
    line   1:      unnamed       unused   input  active-high
    line   2:      unnamed       unused   input  active-high
    line   3:      unnamed       unused   input  active-high
    line   4:      unnamed       unused   input  active-high
    line   5:      unnamed "vcc5v0-otg-regulator" output active-high [used]
    line   6:      unnamed "vcc5v0-host-regulator" output active-high [used]
    line   7:      unnamed       unused   input  active-high
    line   8:      unnamed       unused   input  active-high
    line   9:      unnamed       unused   input  active-high
    line  10:      unnamed       unused   input  active-high
    line  11:      unnamed       unused   input  active-high
    line  12:      unnamed       unused   input  active-high
    line  13:      unnamed       unused   input  active-high
    line  14:      unnamed       unused   input  active-high
    line  15:      unnamed "snps,reset"  output   active-low [used]
    line  16:      unnamed       unused   input  active-high
    line  17:      unnamed       unused   input  active-high
    line  18:      unnamed       unused   input  active-high
    line  19:      unnamed       unused   input  active-high
    line  20:      unnamed       unused   input  active-high
    line  21:      unnamed       unused   input  active-high
    line  22:      unnamed       unused   input  active-high
    line  23:      unnamed       unused   input  active-high
    line  24:      unnamed       unused   input  active-high
    line  25:      unnamed       unused   input  active-high
    line  26:      unnamed       unused   input  active-high
    line  27:      unnamed  "led-power"  output  active-high [used]
    line  28:      unnamed "led-status"  output  active-high [used]
    line  29:      unnamed "vcc3v3-vga"  output  active-high [used]
    line  30:      unnamed       unused   input  active-high
    line  31:      unnamed       unused   input  active-high
gpiochip1 - 32 lines:
    line   5:      unnamed       unused   input  active-high
    line   6:      unnamed       unused   input  active-high
    line  15:      unnamed       unused   input  active-high
    line  27:      unnamed       unused   input  active-high
    line  28:      unnamed       unused   input  active-high
    line  29:      unnamed       unused   input  active-high
gpiochip2 - 32 lines:
    line   9:      unnamed      "reset"  output   active-low [used]
gpiochip3 - 32 lines:
    line   1:      unnamed     "hp-det"   input   active-low [used]
gpiochip4 - 32 lines:
rfkill
Quote
rfkill
ID TYPE      DEVICE      SOFT      HARD
 0 bluetooth hci0   unblocked unblocked
 1 wlan      phy0   unblocked unblocked
Full dmesg
Quote
[    1.469812] Booting Linux on physical CPU 0x0000000000 [0x412fd050]
[    1.469848] Linux version 5.10.160-legacy-rk35xx (armbian@next) (aarch64-linux-gnu-gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1 SMP Wed May 15 03:04:45 UTC 2024
[    1.484322] Machine model: h96 TVbox 3566
[    1.484589] earlycon: uart8250 at MMIO32 0x00000000fe660000 (options '')
[    1.484605] printk: bootconsole [uart8250] enabled
[    1.487426] efi: UEFI not found.
[    1.491195] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-logo@00000000': base 0x0000000000000000, size 0 MiB
[    1.491222] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-cubic-lut@00000000': base 0x0000000000000000, size 0 MiB
[    1.491388] Reserved memory: created CMA memory pool at 0x00000001ff800000, size 8 MiB
[    1.491396] OF: reserved mem: initialized node cma, compatible id shared-dma-pool
[    1.491473] Reserved memory: created CMA memory pool at 0x00000001df800000, size 512 MiB
[    1.491481] OF: reserved mem: initialized node rknpu, compatible id shared-dma-pool
[    1.703699] Zone ranges:
[    1.703715]   DMA      [mem 0x0000000000200000-0x00000000ffffffff]
[    1.703732]   DMA32    empty
[    1.703740]   Normal   [mem 0x0000000100000000-0x00000001ffffffff]
[    1.703749] Movable zone start for each node
[    1.703753] Early memory node ranges
[    1.703760]   node   0: [mem 0x0000000000200000-0x00000000efffffff]
[    1.703772]   node   0: [mem 0x0000000100000000-0x00000001ffffffff]
[    1.703783] Initmem setup node 0 [mem 0x0000000000200000-0x00000001ffffffff]
[    1.703793] On node 0 totalpages: 2031104
[    1.703801]   DMA zone: 15352 pages used for memmap
[    1.703806]   DMA zone: 0 pages reserved
[    1.703813]   DMA zone: 982528 pages, LIFO batch:63
[    1.703821]   Normal zone: 16384 pages used for memmap
[    1.703827]   Normal zone: 1048576 pages, LIFO batch:63
[    1.770941] psci: probing for conduit method from DT.
[    1.770964] psci: PSCIv1.1 detected in firmware.
[    1.770971] psci: Using standard PSCI v0.2 function IDs
[    1.770981] psci: MIGRATE_INFO_TYPE not supported.
[    1.770990] psci: SMC Calling Convention v1.2
[    1.771529] percpu: Embedded 32 pages/cpu s92504 r8192 d30376 u131072
[    1.771584] pcpu-alloc: s92504 r8192 d30376 u131072 alloc=32*4096
[    1.771596] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    1.771744] Detected VIPT I-cache on CPU0
[    1.771818] CPU features: detected: GIC system register CPU interface
[    1.771828] CPU features: detected: Virtualization Host Extensions
[    1.771844] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    1.771865] alternatives: patching kernel code
[    1.772487] Built 1 zonelists, mobility grouping on.  Total pages: 1999368
[    1.772505] Kernel command line: root=UUID=99afbffd-df32-4603-bd9a-5bc5ef2c2148 rootwait rootfstype=ext4 splash plymouth.ignore-serial-consoles console=ttyFIQ0 console=tty1 consoleblank=0 loglevel=1 ubootpart=e4caba4b-ae0a-b440-b218-45acb356bc04 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 earlycon=uart8250,mmio32,0xfe660000
[    1.776091] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    1.777416] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    1.777427] mem auto-init: stack:off, heap alloc:off, heap free:off
[    1.798737] software IO TLB: mapped [mem 0x00000000ec000000-0x00000000f0000000] (64MB)
[    1.937586] Memory: 7319168K/8124416K available (16960K kernel code, 3576K rwdata, 6516K rodata, 7040K init, 630K bss, 272768K reserved, 532480K cma-reserved)
[    1.937807] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    1.937859] ftrace: allocating 64426 entries in 252 pages
[    2.088773] ftrace: allocated 252 pages with 6 groups
[    2.089251] rcu: Hierarchical RCU implementation.
[    2.089261] rcu:     RCU event tracing is enabled.
[    2.089270] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    2.089276]     Rude variant of Tasks RCU enabled.
[    2.089281]     Tracing variant of Tasks RCU enabled.
[    2.089288] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[    2.089294] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    2.098047] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    2.101071] GICv3: GIC: Using split EOI/Deactivate mode
[    2.101089] GICv3: 320 SPIs implemented
[    2.101096] GICv3: 0 Extended SPIs implemented
[    2.101154] GICv3: Distributor has no Range Selector support
[    2.101169] GICv3: 16 PPIs implemented
[    2.101217] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000
[    2.101427] ITS [mem 0xfd440000-0xfd45ffff]
[    2.101546] ITS@0x00000000fd440000: allocated 8192 Devices @2810000 (indirect, esz 8, psz 64K, shr 0)
[    2.101607] ITS@0x00000000fd440000: allocated 32768 Interrupt Collections @2820000 (flat, esz 2, psz 64K, shr 0)
[    2.101622] ITS: using cache flushing for cmd queue
[    2.102229] GICv3: using LPI property table @0x0000000002830000
[    2.102403] GIC: using cache flushing for LPI property table
[    2.102419] GICv3: CPU0: using allocated LPI pending table @0x0000000002840000
[    2.151106] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    2.151127] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    2.151142] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    2.153077] Console: colour dummy device 80x25
[    2.153096] printk: console [tty1] enabled
[    2.153104] printk: bootconsole [uart8250] disabled
[    2.153152] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[    2.153169] pid_max: default: 32768 minimum: 301
[    2.153339] LSM: Security Framework initializing
[    2.153469] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    2.153520] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    2.156820] rcu: Hierarchical SRCU implementation.
[    2.158254] Platform MSI: interrupt-controller@fd440000 domain created
[    2.158946] PCI/MSI: /interrupt-controller@fd400000/interrupt-controller@fd440000 domain created
[    2.159463] EFI services will not be available.
[    2.160135] smp: Bringing up secondary CPUs ...
[    2.161417] Detected VIPT I-cache on CPU1
[    2.161479] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[    2.161515] GICv3: CPU1: using allocated LPI pending table @0x0000000002850000
[    2.161592] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[    2.162921] Detected VIPT I-cache on CPU2
[    2.162970] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[    2.163000] GICv3: CPU2: using allocated LPI pending table @0x0000000002860000
[    2.163054] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[    2.164451] Detected VIPT I-cache on CPU3
[    2.164499] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000
[    2.164528] GICv3: CPU3: using allocated LPI pending table @0x0000000002870000
[    2.164581] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[    2.164777] smp: Brought up 1 node, 4 CPUs
[    2.164796] SMP: Total of 4 processors activated.
[    2.164805] CPU features: detected: Privileged Access Never
[    2.164812] CPU features: detected: User Access Override
[    2.164819] CPU features: detected: 32-bit EL0 Support
[    2.164825] CPU features: detected: Common not Private translations
[    2.164831] CPU features: detected: RAS Extension Support
[    2.164838] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    2.164844] CPU features: detected: CRC32 instructions
[    2.164850] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    2.164858] CPU features: detected: 32-bit EL1 Support
[    2.164864] CPU features: detected: RCpc load-acquire (LDAPR)
[    2.164988] CPU: All CPU(s) started at EL2
[    2.169906] devtmpfs: initialized
[    2.212342] Registered cp15_barrier emulation handler
[    2.212369] Registered setend emulation handler
[    2.212385] KASLR disabled due to lack of seed
[    2.212674] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    2.212699] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    2.237463] pinctrl core: initialized pinctrl subsystem
[    2.237988] regulator-dummy: no parameters, enabled
[    2.238539] DMI not present or invalid.
[    2.239570] NET: Registered protocol family 16
[    2.243143] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[    2.243343] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    2.243515] audit: initializing netlink subsys (disabled)
[    2.243873] audit: type=2000 audit(0.089:1): state=initialized audit_enabled=0 res=1
[    2.248381] Registered FIQ tty driver
[    2.249069] thermal_sys: Registered thermal governor 'fair_share'
[    2.249079] thermal_sys: Registered thermal governor 'step_wise'
[    2.249086] thermal_sys: Registered thermal governor 'user_space'
[    2.249092] thermal_sys: Registered thermal governor 'power_allocator'
[    2.249650] cpuidle: using governor menu
[    2.250543] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    2.250800] ASID allocator initialised with 65536 entries
[    2.254566] ramoops: dmesg-0    0x20000@0x0000000000110000
[    2.254614] ramoops: console    0x80000@0x0000000000130000
[    2.254660] ramoops: pmsg    0x50000@0x00000000001b0000
[    2.254808] printk: console [ramoops-1] enabled
[    2.254817] pstore: Registered ramoops as persistent store backend
[    2.254825] ramoops: using 0xf0000@0x110000, ecc: 0
[    2.322915] rockchip-gpio fdd60000.gpio0: probed /pinctrl/gpio0@fdd60000
[    2.323904] rockchip-gpio fe740000.gpio1: probed /pinctrl/gpio1@fe740000
[    2.324788] rockchip-gpio fe750000.gpio2: probed /pinctrl/gpio2@fe750000
[    2.325642] rockchip-gpio fe760000.gpio3: probed /pinctrl/gpio3@fe760000
[    2.326495] rockchip-gpio fe770000.gpio4: probed /pinctrl/gpio4@fe770000
[    2.326742] rockchip-pinctrl pinctrl: probed pinctrl
[    2.363473] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    2.363490] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    2.363498] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    2.363507] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    2.428807] raid6: neonx8   gen()  1364 MB/s
[    2.485659] raid6: neonx8   xor()  1087 MB/s
[    2.542521] raid6: neonx4   gen()  1407 MB/s
[    2.599383] raid6: neonx4   xor()  1071 MB/s
[    2.656240] raid6: neonx2   gen()  1272 MB/s
[    2.713100] raid6: neonx2   xor()   973 MB/s
[    2.769969] raid6: neonx1   gen()  1036 MB/s
[    2.826833] raid6: neonx1   xor()   805 MB/s
[    2.883698] raid6: int64x8  gen()   352 MB/s
[    2.940557] raid6: int64x8  xor()   234 MB/s
[    2.997418] raid6: int64x4  gen()   439 MB/s
[    3.054305] raid6: int64x4  xor()   243 MB/s
[    3.111136] raid6: int64x2  gen()   883 MB/s
[    3.168002] raid6: int64x2  xor()   481 MB/s
[    3.224881] raid6: int64x1  gen()   644 MB/s
[    3.281719] raid6: int64x1  xor()   343 MB/s
[    3.281728] raid6: using algorithm neonx4 gen() 1407 MB/s
[    3.281734] raid6: .... xor() 1071 MB/s, rmw enabled
[    3.281740] raid6: using neon recovery algorithm
[    3.283669] fiq_debugger fiq_debugger.0: IRQ fiq not found
[    3.283688] fiq_debugger fiq_debugger.0: IRQ wakeup not found
[    3.283704] fiq_debugger_probe: could not install nmi irq handler
[    3.283951] printk: console [ttyFIQ0] enabled
[    3.284279] Registered fiq debugger ttyFIQ0
[    3.285042] dc_5v: 5000 mV, enabled
[    3.285319] reg-fixed-voltage dc-5v: dc_5v supplying 5000000uV
[    3.285545] reg-fixed-voltage vcc3v3-sys: Looking up vin-supply from device tree
[    3.285564] vcc3v3_sys: supplied by dc_5v
[    3.285580] dc_5v: could not add device link regulator.2: -ENOENT
[    3.285677] vcc3v3_sys: 3300 mV, enabled
[    3.285918] reg-fixed-voltage vcc3v3-sys: vcc3v3_sys supplying 3300000uV
[    3.286121] reg-fixed-voltage vcc5v0-sys: Looking up vin-supply from device tree
[    3.286139] vcc5v0_sys: supplied by dc_5v
[    3.286154] dc_5v: could not add device link regulator.3: -ENOENT
[    3.286217] vcc5v0_sys: 5000 mV, enabled
[    3.286502] reg-fixed-voltage vcc5v0-sys: vcc5v0_sys supplying 5000000uV
[    3.286983] vcc5v0_host: no parameters, enabled
[    3.287233] reg-fixed-voltage vcc5v0-host-regulator: vcc5v0_host supplying 0uV
[    3.287614] vcc5v0_otg: no parameters, disabled
[    3.287876] reg-fixed-voltage vcc5v0-otg-regulator: vcc5v0_otg supplying 0uV
[    3.288073] reg-fixed-voltage vcc2v5-ddr: Looking up vin-supply from device tree
[    3.288091] vcc2v5_sys: supplied by vcc3v3_sys
[    3.288107] vcc3v3_sys: could not add device link regulator.6: -ENOENT
[    3.288199] vcc2v5_sys: 2500 mV, enabled
[    3.288459] reg-fixed-voltage vcc2v5-ddr: vcc2v5_sys supplying 2500000uV
[    3.288678] reg-fixed-voltage vcc3v3-vga: Looking up vin-supply from device tree
[    3.288695] vcc3v3_vga: supplied by vcc3v3_sys
[    3.288710] vcc3v3_sys: could not add device link regulator.7: -ENOENT
[    3.288778] vcc3v3_vga: at 3300 mV, enabled
[    3.289050] reg-fixed-voltage vcc3v3-vga: vcc3v3_vga supplying 0uV
[    3.290219] iommu: Default domain type: Translated
[    3.290529] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up npu-supply from device tree
[    3.290566] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up npu-supply property in node /power-management@fdd90000/power-controller failed
[    3.291817] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up vpu-supply from device tree
[    3.291851] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up vpu-supply property in node /power-management@fdd90000/power-controller failed
[    3.292401] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up rga-supply from device tree
[    3.292435] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up rga-supply property in node /power-management@fdd90000/power-controller failed
[    3.294167] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up rkvenc-supply from device tree
[    3.294200] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up rkvenc-supply property in node /power-management@fdd90000/power-controller failed
[    3.294779] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up rkvdec-supply from device tree
[    3.294814] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up rkvdec-supply property in node /power-management@fdd90000/power-controller failed
[    3.295914] vgaarb: loaded
[    3.296555] SCSI subsystem initialized
[    3.296619] libata version 3.00 loaded.
[    3.296966] usbcore: registered new interface driver usbfs
[    3.297045] usbcore: registered new interface driver hub
[    3.297120] usbcore: registered new device driver usb
[    3.297278] mc: Linux media interface: v0.10
[    3.297344] videodev: Linux video capture interface: v2.00
[    3.297486] pps_core: LinuxPPS API ver. 1 registered
[    3.297495] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    3.297521] PTP clock support registered
[    3.298629] arm-scmi firmware:scmi: SCMI Notifications - Core Enabled.
[    3.298720] arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0
[    3.302317] Advanced Linux Sound Architecture Driver Initialized.
[    3.303262] Bluetooth: Core ver 2.22
[    3.303328] NET: Registered protocol family 31
[    3.303337] Bluetooth: HCI device and connection manager initialized
[    3.303353] Bluetooth: HCI socket layer initialized
[    3.303365] Bluetooth: L2CAP socket layer initialized
[    3.303395] Bluetooth: SCO socket layer initialized
[    3.303435] NetLabel: Initializing
[    3.303443] NetLabel:  domain hash size = 128
[    3.303448] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    3.303550] NetLabel:  unlabeled traffic allowed by default
[    3.304405] rockchip-cpuinfo cpuinfo: SoC        : 35662000
[    3.304420] rockchip-cpuinfo cpuinfo: Serial        : 676aa02a4ca6d232
[    3.306103] clocksource: Switched to clocksource arch_sys_counter
[    4.411470] VFS: Disk quotas dquot_6.6.0
[    4.411564] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    4.428872] NET: Registered protocol family 2
[    4.429416] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    4.436464] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[    4.436654] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    4.437173] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    4.438122] TCP: Hash tables configured (established 65536 bind 65536)
[    4.438466] MPTCP token hash table entries: 8192 (order: 5, 196608 bytes, linear)
[    4.438687] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    4.438842] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    4.439218] NET: Registered protocol family 1
[    4.440200] RPC: Registered named UNIX socket transport module.
[    4.440209] RPC: Registered udp transport module.
[    4.440215] RPC: Registered tcp transport module.
[    4.440221] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    4.441820] PCI: CLS 0 bytes, default 64
[    4.442898] Trying to unpack rootfs image as initramfs...
[    5.312678] Freeing initrd memory: 15184K
[    5.316567] rockchip-thermal fe710000.tsadc: tsadc is probed successfully!
[    5.318790] hw perfevents: enabled with armv8_cortex_a55 PMU driver, 7 counters available
[    5.320415] kvm [1]: IPA Size Limit: 40 bits
[    5.320445] kvm [1]: GICv3: no GICV resource entry
[    5.320453] kvm [1]: disabling GICv2 emulation
[    5.320460] kvm [1]: GIC system register CPU interface enabled
[    5.320704] kvm [1]: vgic interrupt IRQ9
[    5.321024] kvm [1]: VHE mode initialized successfully
[    5.328227] Initialise system trusted keyrings
[    5.328517] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[    5.338724] NFS: Registering the id_resolver key type
[    5.338780] Key type id_resolver registered
[    5.338788] Key type id_legacy registered
[    5.338929] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    5.338941] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    5.338990] ntfs: driver 2.1.32 [Flags: R/W].
[    5.394139] NET: Registered protocol family 38
[    5.394165] xor: measuring software checksum speed
[    5.400540]    8regs           :  1565 MB/sec
[    5.405530]    32regs          :  1984 MB/sec
[    5.411634]    arm64_neon      :  1624 MB/sec
[    5.411643] xor: using function: 32regs (1984 MB/sec)
[    5.411663] Key type asymmetric registered
[    5.411672] Asymmetric key parser 'x509' registered
[    5.411739] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[    5.412019] io scheduler mq-deadline registered
[    5.412040] io scheduler kyber registered
[    5.413262] rockchip-csi2-dphy-hw fe870000.csi2-dphy-hw: csi2 dphy hw probe successfully!
[    5.417400] phy phy-fe8a0000.usb2-phy.0: Looking up phy-supply from device tree
[    5.417436] vcc5v0_host: could not add device link phy-fe8a0000.usb2-phy.0: -ENOENT
[    5.417749] phy phy-fe8a0000.usb2-phy.1: Looking up phy-supply from device tree
[    5.417775] vcc5v0_host: could not add device link phy-fe8a0000.usb2-phy.1: -ENOENT
[    5.418033] phy phy-fe8a0000.usb2-phy.1: Looking up vbus-supply from device tree
[    5.418055] phy phy-fe8a0000.usb2-phy.1: Looking up vbus-supply property in node /usb2-phy@fe8a0000/otg-port failed
[    5.422509] phy phy-fe830000.phy.2: Looking up phy-supply from device tree
[    5.422536] phy phy-fe830000.phy.2: Looking up phy-supply property in node /phy@fe830000 failed
[    5.423276] phy phy-fe840000.phy.3: Looking up phy-supply from device tree
[    5.423298] phy phy-fe840000.phy.3: Looking up phy-supply property in node /phy@fe840000 failed
[    5.431042] iep: Module initialized.
[    5.431152] mpp_service mpp-srv: f421f8a9774d author: Yandong Lin 2023-09-21 video: rockchip: mpp: rkvenc2: fix slice mode poll failed
[    5.431164] mpp_service mpp-srv: probe start
[    5.435002] mpp_vepu2 fdee0000.vepu: Adding to iommu group 3
[    5.435355] mpp_vepu2 fdee0000.vepu: probing start
[    5.436290] mpp_vepu2 fdee0000.vepu: probing finish
[    5.437149] mpp-iep2 fdef0000.iep: Adding to iommu group 4
[    5.437448] mpp-iep2 fdef0000.iep: probe device
[    5.437898] mpp-iep2 fdef0000.iep: allocate roi buffer failed
[    5.438315] mpp-iep2 fdef0000.iep: probing finish
[    5.439101] mpp_jpgdec fded0000.jpegd: Adding to iommu group 2
[    5.439382] mpp_jpgdec fded0000.jpegd: probe device
[    5.440273] mpp_jpgdec fded0000.jpegd: probing finish
[    5.442571] mpp_service mpp-srv: probe success
[    5.450282] dma-pl330 fe530000.dmac: Loaded driver for PL330 DMAC-241330
[    5.450301] dma-pl330 fe530000.dmac:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    5.453912] dma-pl330 fe550000.dmac: Loaded driver for PL330 DMAC-241330
[    5.453929] dma-pl330 fe550000.dmac:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    5.454703] rockchip-pvtm fde00000.pvtm: pvtm@0 probed
[    5.454980] rockchip-pvtm fde80000.pvtm: pvtm@1 probed
[    5.455200] rockchip-pvtm fde90000.pvtm: pvtm@2 probed
[    5.456583] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[    5.457600] arm-scmi firmware:scmi: Failed. SCMI protocol 22 not active.
[    5.458016] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[    5.459323] fe650000.serial: ttyS1 at MMIO 0xfe650000 (irq = 56, base_baud = 1500000) is a 16550A
[    5.462908] led_vk2c21_init
[    5.463131] random: crng init done
[    5.464773] rockchip-vop2 fe040000.vop: Adding to iommu group 7
[    5.478004] [drm] all windows should be assigned, full plane mask: 0x3f, current plane mask: 0x0
[    5.478017] [drm] use default plane mask
[    5.478332] [drm] RK3566 only support 2 vps
[    5.478390] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x15, primary plane phy id: 4
[    5.478405] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp1 assign plane mask: 0x22, primary plane phy id: 5
[    5.478419] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x8, primary plane phy id: 3
[    5.479051] [drm] failed to init overlay plane Cluster0-win1
[    5.479141] [drm] failed to init overlay plane Cluster1-win1
[    5.479512] rockchip-drm display-subsystem: bound fe040000.vop (ops 0xffff8000091d3a70)
[    5.479957] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[    5.480926] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver
[    5.481264] dwhdmi-rockchip fe0a0000.hdmi: IRQ index 1 not found
[    5.481917] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops 0xffff8000091e1cf8)
[    5.482871] rockchip-drm display-subsystem: failed to parse loader memory
[    5.680165] rockchip-vop2 fe040000.vop: [drm:vop2_crtc_atomic_enable] Update mode to 3840x2160p60, type: 11(if:800, flag:0x0) for vp0 dclk: 594000000
[    6.013986] Console: switching to colour frame buffer device 480x135
[    6.181205] rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device
[    6.182999] [drm] Initialized rockchip 3.0.0 20140818 for display-subsystem on minor 0
[    6.193367] input: hdmi_cec_key as /devices/platform/fe0a0000.hdmi/dw-hdmi-cec.1.auto/input/input0
[    6.195013] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    6.196278] brd: module loaded
[    6.205941] loop: module loaded
[    6.206726] zram: Added device: zram0
[    6.207183] lkdtm: No crash points registered, enable through debugfs
[    6.207638] system_heap: orders[0] = 6
[    6.207647] system_heap: orders[1] = 4
[    6.207652] system_heap: orders[2] = 0
[    6.216318] rk_gmac-dwmac fe010000.ethernet: IRQ eth_lpi not found
[    6.216659] rk_gmac-dwmac fe010000.ethernet: Looking up phy-supply from device tree
[    6.216695] rk_gmac-dwmac fe010000.ethernet: Looking up phy-supply property in node /ethernet@fe010000 failed
[    6.216723] rk_gmac-dwmac fe010000.ethernet: no regulator found
[    6.216735] rk_gmac-dwmac fe010000.ethernet: clock input or output? (input).
[    6.216747] rk_gmac-dwmac fe010000.ethernet: TX delay(0x4e).
[    6.216757] rk_gmac-dwmac fe010000.ethernet: RX delay(0x2c).
[    6.216775] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no).
[    6.216836] rk_gmac-dwmac fe010000.ethernet: clock input from PHY
[    6.217115] rk_gmac-dwmac fe010000.ethernet: init for RGMII
[    6.217508] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[    6.217525] rk_gmac-dwmac fe010000.ethernet:     DWMAC4/5
[    6.217537] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported
[    6.217545] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported
[    6.217553] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported
[    6.217559] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported
[    6.217670] rk_gmac-dwmac fe010000.ethernet: TSO supported
[    6.217680] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    6.217690] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled
[    6.217700] rk_gmac-dwmac fe010000.ethernet: Using 32 bits DMA width
[    6.366998] usbcore: registered new interface driver rndis_wlan
[    6.367085] usbcore: registered new interface driver asix
[    6.367151] usbcore: registered new interface driver cdc_ether
[    6.367211] usbcore: registered new interface driver rndis_host
[    6.367290] usbcore: registered new interface driver cdc_ncm
[    6.380063] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    6.380127] ehci-pci: EHCI PCI platform driver
[    6.380237] ehci-platform: EHCI generic platform driver
[    6.380657] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    6.380686] ohci-platform: OHCI generic platform driver
[    6.381684] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
[    6.381726] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 1
[    6.381964] xhci-hcd xhci-hcd.4.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000002022010010
[    6.382057] xhci-hcd xhci-hcd.4.auto: irq 69, io mem 0xfcc00000
[    6.383020] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    6.383035] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.383044] usb usb1: Product: xHCI Host Controller
[    6.383053] usb usb1: Manufacturer: Linux 5.10.160-legacy-rk35xx xhci-hcd
[    6.383061] usb usb1: SerialNumber: xhci-hcd.4.auto
[    6.383973] hub 1-0:1.0: USB hub found
[    6.384048] hub 1-0:1.0: 1 port detected
[    6.384648] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
[    6.384676] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 2
[    6.384715] xhci-hcd xhci-hcd.4.auto: Host supports USB 3.0 SuperSpeed
[    6.384869] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    6.385154] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[    6.385168] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.385178] usb usb2: Product: xHCI Host Controller
[    6.385186] usb usb2: Manufacturer: Linux 5.10.160-legacy-rk35xx xhci-hcd
[    6.385194] usb usb2: SerialNumber: xhci-hcd.4.auto
[    6.385946] hub 2-0:1.0: USB hub found
[    6.386016] hub 2-0:1.0: 1 port detected
[    6.386997] xhci-hcd xhci-hcd.5.auto: xHCI Host Controller
[    6.387035] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 3
[    6.387281] xhci-hcd xhci-hcd.5.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000200002010010
[    6.387380] xhci-hcd xhci-hcd.5.auto: irq 70, io mem 0xfd000000
[    6.387946] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    6.387960] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.387969] usb usb3: Product: xHCI Host Controller
[    6.387978] usb usb3: Manufacturer: Linux 5.10.160-legacy-rk35xx xhci-hcd
[    6.387986] usb usb3: SerialNumber: xhci-hcd.5.auto
[    6.388760] hub 3-0:1.0: USB hub found
[    6.388832] hub 3-0:1.0: 1 port detected
[    6.389450] xhci-hcd xhci-hcd.5.auto: xHCI Host Controller
[    6.389487] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 4
[    6.389513] xhci-hcd xhci-hcd.5.auto: Host supports USB 3.0 SuperSpeed
[    6.389666] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    6.389949] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[    6.389963] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.389972] usb usb4: Product: xHCI Host Controller
[    6.389981] usb usb4: Manufacturer: Linux 5.10.160-legacy-rk35xx xhci-hcd
[    6.389989] usb usb4: SerialNumber: xhci-hcd.5.auto
[    6.390760] hub 4-0:1.0: USB hub found
[    6.390829] hub 4-0:1.0: 1 port detected
[    6.391624] usbcore: registered new interface driver cdc_acm
[    6.391633] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    6.392052] usbcore: registered new interface driver uas
[    6.392228] usbcore: registered new interface driver usb-storage
[    6.394789] Error: Driver 'Goodix-TS' is already registered, aborting...
[    6.394927] usbcore: registered new interface driver usbtouchscreen
[    6.396192] i2c /dev entries driver
[    6.399469] fan53555-regulator 0-001c: FAN53555 Option[12] Rev[15] Detected!
[    6.400001] vdd_cpu: override max_uV, 1390000 -> 1387500
[    6.402146] fan53555-regulator 0-001c: Looking up vin-supply from device tree
[    6.402524] vdd_cpu: supplied by vcc5v0_sys
[    6.402545] vcc5v0_sys: could not add device link regulator.8: -ENOENT
[    6.405958] vdd_cpu: 712 <--> 1387 mV at 900 mV, enabled
[    6.411757] rk808 0-0020: chip id: 0x8090
[    6.411836] rk808 0-0020: No cache defaults, reading back from HW
[    6.435693] rk808 0-0020: source: on=0x40, off=0x00
[    6.435713] rk808 0-0020: support dcdc3 fb mode:-22, 1
[    6.435726] rk808 0-0020: support pmic reset mode:0,0
[    6.442741] rk808-regulator rk808-regulator: there is no dvs0 gpio
[    6.442857] rk808-regulator rk808-regulator: there is no dvs1 gpio
[    6.442962] rk808 0-0020: Looking up vcc1-supply from device tree
[    6.442986] vdd_logic: supplied by vcc3v3_sys
[    6.443005] vcc3v3_sys: could not add device link regulator.9: -ENOENT
[    6.443513] vdd_logic: 500 <--> 1350 mV at 900 mV, enabled
[    6.443977] rk808 0-0020: Looking up vcc2-supply from device tree
[    6.443998] vdd_gpu: supplied by vcc3v3_sys
[    6.444022] vcc3v3_sys: could not add device link regulator.10: -ENOENT
[    6.444480] vdd_gpu: 500 <--> 1350 mV at 900 mV, enabled
[    6.444872] rk808 0-0020: Looking up vcc3-supply from device tree
[    6.444890] vcc_ddr: supplied by vcc3v3_sys
[    6.444906] vcc3v3_sys: could not add device link regulator.11: -ENOENT
[    6.445373] vcc_ddr: at 500 mV, enabled
[    6.445775] rk808 0-0020: Looking up vcc4-supply from device tree
[    6.445793] vdd_npu: supplied by vcc3v3_sys
[    6.445811] vcc3v3_sys: could not add device link regulator.12: -ENOENT
[    6.446297] vdd_npu: 500 <--> 1350 mV at 900 mV, enabled
[    6.446730] rk808 0-0020: Looking up vcc9-supply from device tree
[    6.446748] vcc_1v8: supplied by vcc3v3_sys
[    6.446764] vcc3v3_sys: could not add device link regulator.13: -ENOENT
[    6.447209] vcc_1v8: 1800 mV, enabled
[    6.447603] rk808 0-0020: Looking up vcc5-supply from device tree
[    6.447621] vdda0v9_image: supplied by vcc3v3_sys
[    6.447637] vcc3v3_sys: could not add device link regulator.14: -ENOENT
[    6.448619] vdda0v9_image: 900 mV, enabled
[    6.448994] rk808 0-0020: Looking up vcc5-supply from device tree
[    6.449012] vdda_0v9: supplied by vcc3v3_sys
[    6.449027] vcc3v3_sys: could not add device link regulator.15: -ENOENT
[    6.450010] vdda_0v9: 900 mV, enabled
[    6.450396] rk808 0-0020: Looking up vcc5-supply from device tree
[    6.450414] vdda0v9_pmu: supplied by vcc3v3_sys
[    6.450430] vcc3v3_sys: could not add device link regulator.16: -ENOENT
[    6.451415] vdda0v9_pmu: 900 mV, enabled
[    6.451795] vccio_acodec: Bringing 3300000uV into 3000000-3000000uV
[    6.452182] vccio_acodec: ramp_delay not set
[    6.452205] rk808 0-0020: Looking up vcc6-supply from device tree
[    6.452221] vccio_acodec: supplied by vcc3v3_sys
[    6.452237] vcc3v3_sys: could not add device link regulator.17: -ENOENT
[    6.453221] vccio_acodec: 3000 mV, enabled
[    6.453591] rk808 0-0020: Looking up vcc6-supply from device tree
[    6.453609] vccio_sd: supplied by vcc3v3_sys
[    6.453624] vcc3v3_sys: could not add device link regulator.18: -ENOENT
[    6.454605] vccio_sd: 1800 <--> 3300 mV at 3300 mV, enabled
[    6.455009] rk808 0-0020: Looking up vcc6-supply from device tree
[    6.455027] vcc3v3_pmu: supplied by vcc3v3_sys
[    6.455043] vcc3v3_sys: could not add device link regulator.19: -ENOENT
[    6.456021] vcc3v3_pmu: 3300 mV, enabled
[    6.456485] rk808 0-0020: Looking up vcc7-supply from device tree
[    6.456504] vcca_1v8: supplied by vcc3v3_sys
[    6.456519] vcc3v3_sys: could not add device link regulator.20: -ENOENT
[    6.457495] vcca_1v8: 1800 mV, enabled
[    6.457873] rk808 0-0020: Looking up vcc7-supply from device tree
[    6.457891] vcca1v8_pmu: supplied by vcc3v3_sys
[    6.457906] vcc3v3_sys: could not add device link regulator.21: -ENOENT
[    6.458881] vcca1v8_pmu: 1800 mV, enabled
[    6.459285] rk808 0-0020: Looking up vcc7-supply from device tree
[    6.459304] vcca1v8_image: supplied by vcc3v3_sys
[    6.459319] vcc3v3_sys: could not add device link regulator.22: -ENOENT
[    6.460291] vcca1v8_image: 1800 mV, enabled
[    6.460688] rk808 0-0020: Looking up vcc9-supply from device tree
[    6.460708] vcc_3v3: supplied by vcc3v3_sys
[    6.460723] vcc3v3_sys: could not add device link regulator.23: -ENOENT
[    6.461171] vcc_3v3: at 3300 mV, enabled
[    6.461521] rk808 0-0020: Looking up vcc8-supply from device tree
[    6.461540] vcc3v3_sd: supplied by vcc3v3_sys
[    6.461555] vcc3v3_sys: could not add device link regulator.24: -ENOENT
[    6.461993] vcc3v3_sd: at 3300 mV, enabled
[    6.462354] rk817-battery: Failed to locate of_node [id: -1]
[    6.462580] rk817-battery rk817-battery: Failed to find matching dt id
[    6.462810] rk817-charger: Failed to locate of_node [id: -1]
[    6.462976] rk817-charger rk817-charger: Failed to find matching dt id
[    6.466541] input: rk805 pwrkey as /devices/platform/fdd40000.i2c/i2c-0/0-0020/rk805-pwrkey/input/input1
[    6.473739] rk808-rtc rk808-rtc: registered as rtc0
[    6.475568] rk808-rtc rk808-rtc: setting system clock to 2024-06-09T17:30:27 UTC (1717954227)
[    6.480772] rockchip-mipi-csi2-hw fdfb0000.mipi-csi2-hw: enter mipi csi2 hw probe!
[    6.481059] rockchip-mipi-csi2-hw fdfb0000.mipi-csi2-hw: probe success, v4l2_dev:mipi-csi2-hw!
[    6.484330] usbcore: registered new interface driver uvcvideo
[    6.484339] USB Video Class driver (1.1.1)
[    6.488012] cpu cpu0: bin=0
[    6.488080] cpu cpu0: leakage=22
[    6.488137] cpu cpu0: pvtm = 85240, from nvmem
[    6.488163] cpu cpu0: pvtm-volt-sel=1
[    6.488247] cpu cpu0: soc version=0, speed=1
[    6.488651] cpu cpu0: Looking up cpu-supply from device tree
[    6.490228] cpu cpu0: avs=0
[    6.490556] cpu cpu0: EM: created perf domain
[    6.490654] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=1608000000 h_limit=0 h_table=0
[    6.496703] sdhci: Secure Digital Host Controller Interface driver
[    6.496711] sdhci: Copyright(c) Pierre Ossman
[    6.496714] Synopsys Designware Multimedia Card Interface Driver
[    6.497460] sdhci-pltfm: SDHCI platform and OF driver helper
[    6.497922] dwmmc_rockchip fe2b0000.dwmmc: No normal pinctrl state
[    6.497930] dwmmc_rockchip fe2b0000.dwmmc: No idle pinctrl state
[    6.497975] dwmmc_rockchip fe2c0000.dwmmc: No normal pinctrl state
[    6.497980] dwmmc_rockchip fe2c0000.dwmmc: No idle pinctrl state
[    6.498073] dwmmc_rockchip fe2b0000.dwmmc: IDMAC supports 32-bit address mode.
[    6.498083] dwmmc_rockchip fe2c0000.dwmmc: IDMAC supports 32-bit address mode.
[    6.498106] dwmmc_rockchip fe2c0000.dwmmc: Using internal DMA controller.
[    6.498109] dwmmc_rockchip fe2b0000.dwmmc: Using internal DMA controller.
[    6.498121] dwmmc_rockchip fe2b0000.dwmmc: Version ID is 270a
[    6.498124] dwmmc_rockchip fe2c0000.dwmmc: Version ID is 270a
[    6.498185] dwmmc_rockchip fe2b0000.dwmmc: DW MMC controller at irq 44,32 bit host data width,256 deep fifo
[    6.498203] dwmmc_rockchip fe2c0000.dwmmc: DW MMC controller at irq 45,32 bit host data width,256 deep fifo
[    6.498288] dwmmc_rockchip fe2b0000.dwmmc: Looking up vmmc-supply from device tree
[    6.498291] dwmmc_rockchip fe2c0000.dwmmc: Looking up vmmc-supply from device tree
[    6.498314] dwmmc_rockchip fe2b0000.dwmmc: Looking up vmmc-supply property in node /dwmmc@fe2b0000 failed
[    6.498351] dwmmc_rockchip fe2b0000.dwmmc: Looking up vqmmc-supply from device tree
[    6.498440] dwmmc_rockchip fe2c0000.dwmmc: Looking up vqmmc-supply from device tree
[    6.498887] dwmmc_rockchip fe2c0000.dwmmc: allocated mmc-pwrseq
[    6.498898] mmc_host mmc2: card is non-removable.
[    6.499572] sdhci-dwcmshc fe310000.sdhci: Looking up vmmc-supply from device tree
[    6.499590] sdhci-dwcmshc fe310000.sdhci: Looking up vmmc-supply property in node /sdhci@fe310000 failed
[    6.500097] sdhci-dwcmshc fe310000.sdhci: Looking up vqmmc-supply from device tree
[    6.500111] sdhci-dwcmshc fe310000.sdhci: Looking up vqmmc-supply property in node /sdhci@fe310000 failed
[    6.500493] ledtrig-cpu: registered to indicate activity on CPUs
[    6.500552] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
[    6.500623] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    6.501549] cryptodev: driver 1.12 loaded.
[    6.501600] hid: raw HID events driver (C) Jiri Kosina
[    6.501917] usbcore: registered new interface driver usbhid
[    6.501921] usbhid: USB HID core driver
[    6.502186] ashmem: initialized
[    6.502489] rockchip,bus bus-npu: Looking up bus-supply from device tree
[    6.502665] rockchip,bus bus-npu: bin=0
[    6.502675] rockchip,bus bus-npu: Failed to get leakage
[    6.502730] rockchip,bus bus-npu: pvtm = 85240, from nvmem
[    6.502779] rockchip,bus bus-npu: pvtm-volt-sel=1
[    6.503025] rockchip,bus bus-npu: avs=0
[    6.506925] rockchip-saradc fe720000.saradc: Looking up vref-supply from device tree
[    6.508058] optee: probing for conduit method.
[    6.508069] optee: api uid mismatch
[    6.508081] optee: probe of firmware:optee failed with error -22
[    6.508806] usbcore: registered new interface driver snd-usb-audio
[    6.511024] rk817-codec rk817-codec: DMA mask not set
[    6.512920] mmc_host mmc1: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[    6.517616] rk-multicodecs rk809-sound: Failed to get ADC channel
[    6.517820] rk-multicodecs rk809-sound: ASoC: Property 'rockchip,audio-routing' does not exist or its length is not even
[    6.517825] rk-multicodecs rk809-sound: Audio routing invalid/unspecified
[    6.519079] rk817-codec rk817-codec: rk817_probe: chip_name:0x80, chip_ver:0x94
[    6.525779] input: rockchip-rk809 Headset as /devices/platform/rk809-sound/sound/card0/input2
[    6.526741] Initializing XFRM netlink socket
[    6.526761] NET: Registered protocol family 17
[    6.527117] [BT_RFKILL]: Enter rfkill_rk_init
[    6.527121] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    6.527481] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[    6.527519] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6398s
[    6.527523] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[    6.527526] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[    6.527548] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,poweren_gpio = 74 flags = 0.
[    6.527571] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[    6.527574] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[    6.527579] [WLAN_RFKILL]: rfkill_set_wifi_bt_power: 1
[    6.527583] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[    6.527989] Key type dns_resolver registered
[    6.529487] mmc0: SDHCI controller on fe310000.sdhci [fe310000.sdhci] using ADMA
[    6.529666] registered taskstats version 1
[    6.529676] Loading compiled-in X.509 certificates
[    6.530676] Btrfs loaded, crc32c=crc32c-generic
[    6.530860] pstore: Using crash dump compression: deflate
[    6.531914] rga: rga2, irq = 26, match scheduler
[    6.532437] rga: rga2 hardware loaded successfully, hw_version:3.2.63318.
[    6.532461] rga: rga2 probe successfully
[    6.532847] rga_iommu: IOMMU binding successfully, default mapping core[0x4]
[    6.533184] rga: Module initialized. v1.3.0
[    6.564998] mmc0: Host Software Queue enabled
[    6.565023] mmc0: new HS200 MMC card at address 0001
[    6.565820] mmcblk0: mmc0:0001 CJNB4R 58.2 GiB
[    6.566074] mmcblk0boot0: mmc0:0001 CJNB4R partition 1 4.00 MiB
[    6.566455] mmcblk0boot1: mmc0:0001 CJNB4R partition 2 4.00 MiB
[    6.566793] mmcblk0rpmb: mmc0:0001 CJNB4R partition 3 4.00 MiB, chardev (237:0)
[    6.569963]  mmcblk0: p1 p2
[    6.632876] usb 1-1: new full-speed USB device number 2 using xhci-hcd
[    6.635491] vendor storage:20190527 ret = 0
[    6.716498] mmc_host mmc2: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[    6.730303] mpp_vdpu2 fdea0400.vdpu: Adding to iommu group 1
[    6.730501] mpp_vdpu2 fdea0400.vdpu: probe device
[    6.731237] mpp_vdpu2 fdea0400.vdpu: probing finish
[    6.731551] mpp_rkvenc fdf40000.rkvenc: Adding to iommu group 5
[    6.731757] mpp_rkvenc fdf40000.rkvenc: probing start
[    6.732004] mpp_rkvenc fdf40000.rkvenc: Looking up venc-supply from device tree
[    6.732227] mpp_rkvenc fdf40000.rkvenc: bin=0
[    6.732239] mpp_rkvenc fdf40000.rkvenc: Failed to get leakage
[    6.732291] mpp_rkvenc fdf40000.rkvenc: pvtm = 85240, from nvmem
[    6.732303] mpp_rkvenc fdf40000.rkvenc: pvtm-volt-sel=1
[    6.732489] mpp_rkvenc fdf40000.rkvenc: avs=0
[    6.732610] mpp_rkvenc fdf40000.rkvenc: failed to find power_model node
[    6.732616] mpp_rkvenc fdf40000.rkvenc: failed to initialize power model
[    6.732621] mpp_rkvenc fdf40000.rkvenc: failed to get dynamic-coefficient
[    6.733385] mpp_rkvenc fdf40000.rkvenc: probing finish
[    6.733856] mpp_rkvdec2 fdf80200.rkvdec: Adding to iommu group 6
[    6.734153] mpp_rkvdec2 fdf80200.rkvdec: rkvdec, probing start
[    6.734499] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_a is not found!
[    6.734504] rkvdec2_init:1022: No niu aclk reset resource define
[    6.734511] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_h is not found!
[    6.734515] rkvdec2_init:1025: No niu hclk reset resource define
[    6.734541] mpp_rkvdec2 fdf80200.rkvdec: Looking up vdec-supply from device tree
[    6.734765] mpp_rkvdec2 fdf80200.rkvdec: bin=0
[    6.734871] mpp_rkvdec2 fdf80200.rkvdec: leakage=49
[    6.734880] mpp_rkvdec2 fdf80200.rkvdec: leakage-volt-sel=0
[    6.734914] mpp_rkvdec2 fdf80200.rkvdec: pvtm = 85240, from nvmem
[    6.734925] mpp_rkvdec2 fdf80200.rkvdec: pvtm-volt-sel=1
[    6.735110] mpp_rkvdec2 fdf80200.rkvdec: avs=0
[    6.735234] mpp_rkvdec2 fdf80200.rkvdec: failed to find power_model node
[    6.735241] mpp_rkvdec2 fdf80200.rkvdec: failed to initialize power model
[    6.735245] mpp_rkvdec2 fdf80200.rkvdec: failed to get dynamic-coefficient
[    6.735349] mpp_rkvdec2 fdf80200.rkvdec: sram_start 0x00000000fdcc0000
[    6.735355] mpp_rkvdec2 fdf80200.rkvdec: rcb_iova 0x0000000010000000
[    6.735359] mpp_rkvdec2 fdf80200.rkvdec: sram_size 65536
[    6.735364] mpp_rkvdec2 fdf80200.rkvdec: rcb_size 65536
[    6.735369] mpp_rkvdec2 fdf80200.rkvdec: min_width 512
[    6.735423] mpp_rkvdec2 fdf80200.rkvdec: link mode probe finish
[    6.735497] mpp_rkvdec2 fdf80200.rkvdec: probing finish
[    6.736679] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up gpu-supply from device tree
[    6.736748] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up gpu-supply property in node /power-management@fdd90000/power-controller failed
[    6.736806] rockchip-dmc dmc: Looking up center-supply from device tree
[    6.736830] mali fde60000.gpu: Kernel DDK version g18p0-01eac0
[    6.736843] mali fde60000.gpu: IRQ JOB not found
[    6.736874] mali fde60000.gpu: IRQ MMU not found
[    6.736887] mali fde60000.gpu: IRQ GPU not found
[    6.736899] mali fde60000.gpu: Insufficient register space, will override to the required size
[    6.736913] mali fde60000.gpu: Register window unavailable
[    6.736918] mali fde60000.gpu: Failed to map registers
[    6.736922] mali fde60000.gpu: Register map failed error = -5
[    6.736927] mali fde60000.gpu: Device initialization failed
[    6.736967] rockchip-dmc dmc: Looking up center-supply from device tree
[    6.736989] vdd_logic: could not add device link dmc: -EEXIST
[    6.736993] vdd_logic: Failed to create debugfs directory
[    6.737002] mali: probe of fde60000.gpu failed with error -5
[    6.737185] rockchip-dmc dmc: bin=0
[    6.737224] rockchip-dmc dmc: leakage=49
[    6.737237] rockchip-dmc dmc: leakage-volt-sel=0
[    6.737269] rockchip-dmc dmc: pvtm = 85240, from nvmem
[    6.737281] rockchip-dmc dmc: pvtm-volt-sel=1
[    6.737292] rockchip-dmc dmc: soc version=0, speed=1
[    6.737464] rockchip-dmc dmc: avs=0
[    6.737482] rockchip-dmc dmc: current ATF version 0x102
[    6.738138] rockchip-dmc dmc: normal_rate = 780000000
[    6.738145] rockchip-dmc dmc: reboot_rate = 1056000000
[    6.738150] rockchip-dmc dmc: suspend_rate = 324000000
[    6.738156] rockchip-dmc dmc: video_4k_rate = 780000000
[    6.738161] rockchip-dmc dmc: video_4k_10b_rate = 780000000
[    6.738166] rockchip-dmc dmc: boost_rate = 1056000000
[    6.738171] rockchip-dmc dmc: fixed_rate(isp|cif0|cif1|dualview) = 1056000000
[    6.738176] rockchip-dmc dmc: performance_rate = 1056000000
[    6.738195] rockchip-dmc dmc: failed to get vop pn to msch rl
[    6.738391] rockchip-dmc dmc: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[    6.738473] rockchip-dmc dmc: could not find power_model node
[    6.747680] rockchip-iodomain fdc20000.syscon:io-domains: Looking up pmuio1-supply from device tree
[    6.747914] rockchip-iodomain fdc20000.syscon:io-domains: pmuio1(3300000 uV) supplied by vcc3v3_pmu
[    6.747922] rockchip-iodomain fdc20000.syscon:io-domains: Looking up pmuio2-supply from device tree
[    6.748011] rockchip-iodomain fdc20000.syscon:io-domains: pmuio2(3300000 uV) supplied by vcc3v3_pmu
[    6.748018] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio1-supply from device tree
[    6.748149] rockchip-iodomain fdc20000.syscon:io-domains: vccio1(3000000 uV) supplied by vccio_acodec
[    6.748160] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio2-supply from device tree
[    6.748275] rockchip-iodomain fdc20000.syscon:io-domains: vccio2(1800000 uV) supplied by vcc_1v8
[    6.748282] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio3-supply from device tree
[    6.748382] rockchip-iodomain fdc20000.syscon:io-domains: vccio3(3300000 uV) supplied by vccio_sd
[    6.748389] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio4-supply from device tree
[    6.748438] rockchip-iodomain fdc20000.syscon:io-domains: vccio4(1800000 uV) supplied by vcc_1v8
[    6.748444] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio5-supply from device tree
[    6.748562] rockchip-iodomain fdc20000.syscon:io-domains: vccio5(3300000 uV) supplied by vcc_3v3
[    6.748569] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio6-supply from device tree
[    6.748634] rockchip-iodomain fdc20000.syscon:io-domains: vccio6(1800000 uV) supplied by vcc_1v8
[    6.748641] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio7-supply from device tree
[    6.748691] rockchip-iodomain fdc20000.syscon:io-domains: vccio7(3300000 uV) supplied by vcc_3v3
[    6.749304] input: adc-keys as /devices/platform/adc-keys/input/input3
[    6.757253] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up vi-supply from device tree
[    6.757296] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up vi-supply property in node /power-management@fdd90000/power-controller failed
[    6.759049] RKNPU fde40000.npu: Adding to iommu group 0
[    6.759751] RKNPU fde40000.npu: RKNPU: rknpu iommu is enabled, using iommu mode
[    6.759818] RKNPU fde40000.npu: Looking up rknpu-supply from device tree
[    6.760087] RKNPU fde40000.npu: Looking up mem-supply from device tree
[    6.760168] RKNPU fde40000.npu: can't request region for resource [mem 0xfde40000-0xfde4ffff]
[    6.760825] [drm] Initialized rknpu 0.9.2 20231018 for fde40000.npu on minor 1
[    6.761340] RKNPU fde40000.npu: Looking up rknpu-supply from device tree
[    6.761374] vdd_npu: could not add device link fde40000.npu: -EEXIST
[    6.761378] vdd_npu: Failed to create debugfs directory
[    6.761394] RKNPU fde40000.npu: Looking up mem-supply from device tree
[    6.761409] vdd_npu: could not add device link fde40000.npu: -EEXIST
[    6.761413] vdd_npu: Failed to create debugfs directory
[    6.761628] RKNPU fde40000.npu: bin=0
[    6.761681] RKNPU fde40000.npu: leakage=3
[    6.761714] RKNPU fde40000.npu: pvtm = 85240, from nvmem
[    6.761729] RKNPU fde40000.npu: pvtm-volt-sel=1
[    6.761740] RKNPU fde40000.npu: soc version=0, speed=1
[    6.761760] RKNPU fde40000.npu: opp_parse_supplies: Invalid number of elements in opp-microvolt property (3) with supplies (2)
[    6.761766] RKNPU fde40000.npu: _of_add_opp_table_v2: Failed to add OPP, -22
[    6.761771] RKNPU fde40000.npu: Invalid operating-points in device tree.
[    6.761775] RKNPU fde40000.npu: RKNPU: failed to init_opp_table
[    6.765275] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    6.768459] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[    6.771503] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[    6.773263] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[    6.773980] usb 1-1: New USB device found, idVendor=0a05, idProduct=7211, bcdDevice= 1.00
[    6.773988] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    6.773994] usb 1-1: Product: USB2.0 HUB
[    6.781049] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    6.783046] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[    6.783673] rockchip-suspend not set sleep-mode-config for mem-lite
[    6.783678] rockchip-suspend not set wakeup-config for mem-lite
[    6.783684] rockchip-suspend not set sleep-mode-config for mem-ultra
[    6.783687] rockchip-suspend not set wakeup-config for mem-ultra
[    6.784937] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 406; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '03:04:45', on 'May 15 2024'.
[    6.785380] Mali:
[    6.785383] Mali device driver loaded
[    6.785392] ALSA device list:
[    6.785397]   #0: rockchip-rk809
[    6.785400]   #1: rockchip,hdmi
[    6.785404]   #2: ROCKCHIP,SPDIF
[    6.794146] Freeing unused kernel memory: 7040K
[    6.819552] Run /init as init process
[    6.819560]   with arguments:
[    6.819563]     /init
[    6.819566]     splash
[    6.819570]   with environment:
[    6.819573]     HOME=/
[    6.819575]     TERM=linux
[    6.819578]     ubootpart=e4caba4b-ae0a-b440-b218-45acb356bc04
[    6.819581]     cgroup_enable=memory
[    6.819584]     cgroup_memory=1
[    6.840326] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 100000000Hz, actual 50000000HZ div = 0)
[    6.853769] dwmmc_rockchip fe2c0000.dwmmc: Successfully tuned phase to 360
[    6.857489] mmc2: new ultra high speed SDR50 SDIO card at address 0001
[    7.025377] hub 1-1:1.0: USB hub found
[    7.025573] hub 1-1:1.0: 4 ports detected
[    7.322251] panfrost fde60000.gpu: clock rate = 594000000
[    7.323256] panfrost fde60000.gpu: bus_clock rate = 500000000
[    7.323515] panfrost fde60000.gpu: Looking up mali-supply from device tree
[    7.324388] panfrost fde60000.gpu: mali-g52 id 0x7402 major 0x1 minor 0x0 status 0x0
[    7.324405] panfrost fde60000.gpu: features: 00000000,13de77ff, issues: 00000000,00000400
[    7.324412] panfrost fde60000.gpu: Features: L2:0x07110206 Shader:0x00000002 Tiler:0x00000209 Mem:0x1 MMU:0x00002823 AS:0xff JS:0x7
[    7.324416] panfrost fde60000.gpu: shader_present=0x1 l2_present=0x1
[    7.327954] [drm] Initialized panfrost 1.1.0 20180908 for fde60000.gpu on minor 2
[    7.392989] usb 4-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
[    7.406242] usb 1-1.2: new low-speed USB device number 3 using xhci-hcd
[    7.410721] usb 4-1: New USB device found, idVendor=0951, idProduct=1666, bcdDevice= 1.10
[    7.410735] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    7.410740] usb 4-1: Product: DataTraveler 3.0
[    7.410744] usb 4-1: Manufacturer: Kingston
[    7.410748] usb 4-1: SerialNumber: 08606E6D4139B1409831D890
[    7.412358] usb-storage 4-1:1.0: USB Mass Storage device detected
[    7.414415] scsi host0: usb-storage 4-1:1.0
[    7.500578] usb 1-1.2: New USB device found, idVendor=17ef, idProduct=608d, bcdDevice= 1.00
[    7.500595] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    7.500599] usb 1-1.2: Product: Lenovo USB Optical Mouse
[    7.500604] usb 1-1.2: Manufacturer: PixArt
[    7.668397] input: PixArt Lenovo USB Optical Mouse as /devices/platform/usbdrd/fcc00000.dwc3/xhci-hcd.4.auto/usb1/1-1/1-1.2/1-1.2:1.0/0003:17EF:608D.0001/input/input4
[    7.668754] hid-generic 0003:17EF:608D.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt Lenovo USB Optical Mouse] on usb-xhci-hcd.4.auto-1.2/input0
[    7.742845] usb 1-1.3: new low-speed USB device number 4 using xhci-hcd
[    7.844098] usb 1-1.3: New USB device found, idVendor=17ef, idProduct=6099, bcdDevice= 1.00
[    7.844107] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    7.844112] usb 1-1.3: Product: Lenovo Traditional USB Keyboard
[    7.844116] usb 1-1.3: Manufacturer: Lenovo
[    8.066552] input: Lenovo Lenovo Traditional USB Keyboard as /devices/platform/usbdrd/fcc00000.dwc3/xhci-hcd.4.auto/usb1/1-1/1-1.3/1-1.3:1.0/0003:17EF:6099.0002/input/input5
[    8.123519] hid-generic 0003:17EF:6099.0002: input,hidraw1: USB HID v1.11 Keyboard [Lenovo Lenovo Traditional USB Keyboard] on usb-xhci-hcd.4.auto-1.3/input0
[    8.421018] scsi 0:0:0:0: Direct-Access     Kingston DataTraveler 3.0 PMAP PQ: 0 ANSI: 6
[    8.424461] sd 0:0:0:0: [sda] 60567552 512-byte logical blocks: (31.0 GB/28.9 GiB)
[    8.424852] sd 0:0:0:0: [sda] Write Protect is off
[    8.424867] sd 0:0:0:0: [sda] Mode Sense: 45 00 00 00
[    8.426000] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[    8.539847]  sda: sda1
[    8.543195] sd 0:0:0:0: [sda] Attached SCSI removable disk
[    9.178797] EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Opts: (null)
[    9.504266] NET: Registered protocol family 10
[    9.505461] Segment Routing with IPv6
[    9.528240] systemd[1]: systemd 249.11-0ubuntu3.12 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[    9.529176] systemd[1]: Detected architecture arm64.
[    9.531330] systemd[1]: Hostname set to <h96-tvbox-3566-legacy>.
[   10.097964] systemd[1]: Configuration file /lib/systemd/system/ap6335-bluetooth.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[   10.116368] systemd[1]: Queued start job for default target Graphical Interface.
[   10.121978] systemd[1]: Created slice Slice /system/modprobe.
[   10.124487] systemd[1]: Created slice Slice /system/serial-getty.
[   10.126856] systemd[1]: Created slice Slice /system/systemd-fsck.
[   10.128190] systemd[1]: Created slice User and Session Slice.
[   10.128773] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   10.129882] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   10.130420] systemd[1]: Reached target User and Group Name Lookups.
[   10.130634] systemd[1]: Reached target Slice Units.
[   10.130786] systemd[1]: Reached target Mounting snaps.
[   10.130933] systemd[1]: Reached target Swaps.
[   10.131071] systemd[1]: Reached target System Time Set.
[   10.131365] systemd[1]: Reached target Local Verity Protected Volumes.
[   10.151857] systemd[1]: Listening on RPCbind Server Activation Socket.
[   10.153112] systemd[1]: Listening on Syslog Socket.
[   10.153964] systemd[1]: Listening on fsck to fsckd communication Socket.
[   10.154465] systemd[1]: Listening on initctl Compatibility Named Pipe.
[   10.155632] systemd[1]: Listening on Journal Audit Socket.
[   10.156838] systemd[1]: Listening on Journal Socket (/dev/log).
[   10.157795] systemd[1]: Listening on Journal Socket.
[   10.160822] systemd[1]: Listening on udev Control Socket.
[   10.161777] systemd[1]: Listening on udev Kernel Socket.
[   10.166430] systemd[1]: Mounting Huge Pages File System...
[   10.172476] systemd[1]: Mounting POSIX Message Queue File System...
[   10.178942] systemd[1]: Mounting Kernel Debug File System...
[   10.184914] systemd[1]: Mounting Kernel Trace File System...
[   10.186066] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[   10.193334] systemd[1]: Starting Restore / save the current clock...
[   10.200229] systemd[1]: Starting Set the console keyboard layout...
[   10.207715] systemd[1]: Starting Create List of Static Device Nodes...
[   10.216199] systemd[1]: Starting Load Kernel Module configfs...
[   10.224830] systemd[1]: Starting Load Kernel Module drm...
[   10.234499] systemd[1]: Starting Load Kernel Module efi_pstore...
[   10.242325] systemd[1]: Starting Load Kernel Module fuse...
[   10.243603] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[   10.253229] systemd[1]: Starting Load Kernel Modules...
[   10.260773] systemd[1]: Starting Remount Root and Kernel File Systems...
[   10.262453] fuse: init (API version 7.32)
[   10.268530] systemd[1]: Starting Coldplug All udev Devices...
[   10.280998] systemd[1]: Mounted Huge Pages File System.
[   10.283392] systemd[1]: Mounted POSIX Message Queue File System.
[   10.285895] systemd[1]: Mounted Kernel Debug File System.
[   10.288839] systemd[1]: Mounted Kernel Trace File System.
[   10.293491] systemd[1]: Finished Restore / save the current clock.
[   10.298623] systemd[1]: Finished Create List of Static Device Nodes.
[   10.301650] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[   10.302074] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600,errors=remount-ro
[   10.303900] systemd[1]: Finished Load Kernel Module configfs.
[   10.310082] systemd[1]: modprobe@drm.service: Deactivated successfully.
[   10.311222] systemd[1]: Finished Load Kernel Module drm.
[   10.313959] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[   10.315100] systemd[1]: Finished Load Kernel Module efi_pstore.
[   10.317198] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[   10.318403] systemd[1]: Finished Load Kernel Module fuse.
[   10.320703] systemd[1]: Finished Load Kernel Modules.
[   10.323883] systemd[1]: Finished Remount Root and Kernel File Systems.
[   10.330700] systemd[1]: Mounting FUSE Control File System...
[   10.337658] systemd[1]: Mounting Kernel Configuration File System...
[   10.344994] systemd[1]: Starting Platform Persistent Storage Archival...
[   10.352125] systemd[1]: Starting Load/Save Random Seed...
[   10.358725] systemd[1]: Starting Apply Kernel Variables...
[   10.366089] systemd[1]: Starting Create System Users...
[   10.371889] systemd[1]: Mounted FUSE Control File System.
[   10.374402] systemd[1]: Mounted Kernel Configuration File System.
[   10.415012] systemd[1]: Finished Load/Save Random Seed.
[   10.416832] systemd[1]: Condition check resulted in First Boot Complete being skipped.
[   10.420007] systemd[1]: Finished Platform Persistent Storage Archival.
[   10.441971] systemd[1]: Finished Create System Users.
[   10.451607] systemd[1]: Starting Create Static Device Nodes in /dev...
[   10.458702] systemd[1]: Finished Apply Kernel Variables.
[   10.470344] systemd[1]: Finished Set the console keyboard layout.
[   10.496466] systemd[1]: Finished Create Static Device Nodes in /dev.
[   10.497571] systemd[1]: Reached target Preparation for Local File Systems.
[   10.504715] systemd[1]: Mounting Mount unit for bare, revision 5...
[   10.512716] systemd[1]: Mounting Mount unit for chromium, revision 2875...
[   10.522357] systemd[1]: Mounting Mount unit for core22, revision 1383...
[   10.531522] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[   10.532302] systemd[1]: Mounting Mount unit for cups, revision 1049...
[   10.542970] systemd[1]: Mounting Mount unit for gnome-42-2204, revision 178...
[   10.552179] systemd[1]: Mounting Mount unit for gtk-common-themes, revision 1535...
[   10.564004] systemd[1]: Mounting Mount unit for snapd, revision 21761...
[   10.576821] systemd[1]: Mounting /tmp...
[   10.587362] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[   10.616243] systemd[1]: Mounted Mount unit for bare, revision 5.
[   10.617997] systemd[1]: Mounted Mount unit for chromium, revision 2875.
[   10.619318] systemd[1]: Mounted Mount unit for core22, revision 1383.
[   10.620922] systemd[1]: Mounted Mount unit for cups, revision 1049.
[   10.622197] systemd[1]: Mounted Mount unit for gnome-42-2204, revision 178.
[   10.623561] systemd[1]: Mounted Mount unit for gtk-common-themes, revision 1535.
[   10.624837] systemd[1]: Mounted Mount unit for snapd, revision 21761.
[   10.626074] systemd[1]: Mounted /tmp.
[   10.627428] systemd[1]: Reached target Mounted snaps.
[   10.777940] systemd[1]: Started Rule-based Manager for Device Events and Files.
[   10.857326] systemd[1]: Finished Coldplug All udev Devices.
[   10.867629] systemd[1]: Starting Helper to synchronize boot up for ifupdown...
[   10.874441] systemd[1]: Starting Show Plymouth Boot Screen...
[   10.889222] systemd[1]: Finished Helper to synchronize boot up for ifupdown.
[   10.925275] systemd[1]: Started Show Plymouth Boot Screen.
[   10.927003] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch being skipped.
[   10.927890] systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
[   10.928409] systemd[1]: Reached target Local Encrypted Volumes.
[   11.703118] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4335-sdio for chip BCM4335/1
[   11.705481] usbcore: registered new interface driver brcmfmac
[   11.715168] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4335-sdio.h96-TVbox,rk3566.txt failed with error -2
[   11.729902] systemd[1]: Found device /dev/ttyFIQ0.
[   11.800450] systemd[1]: Found device /dev/disk/by-uuid/332B-61E4.
[   11.808770] systemd[1]: Starting File System Check on /dev/disk/by-uuid/332B-61E4...
[   11.897688] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4335-sdio for chip BCM4335/1
[   11.897797] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
[   11.898462] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4335/1 wl0: May 18 2014 16:56:54 version 6.34.171.58.2
[   11.905952] systemd[1]: Started File System Check Daemon to report status.
[   12.067057] systemd[1]: Finished File System Check on /dev/disk/by-uuid/332B-61E4.
[   12.075199] systemd[1]: Mounting /boot...
[   12.083661] FAT-fs (mmcblk0p1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[   12.125922] systemd[1]: Mounted /boot.
[   12.130273] systemd[1]: Reached target Local File Systems.
[   12.130743] systemd[1]: Condition check resulted in Load AppArmor profiles being skipped.
[   12.142422] systemd[1]: Starting Armbian ZRAM config...
[   12.155629] systemd[1]: Starting Set console font and keymap...
[   12.165060] systemd[1]: Starting Raise network interfaces...
[   12.181536] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[   12.182126] systemd[1]: Condition check resulted in RPC security service for NFS server being skipped.
[   12.182331] systemd[1]: Condition check resulted in Load AppArmor profiles managed internally by snapd being skipped.
[   12.197628] systemd[1]: Starting Set Up Additional Binary Formats...
[   12.198136] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[   12.198444] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[   12.206282] systemd[1]: Finished Set console font and keymap.
[   12.223222] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[   12.225697] systemd[1]: Received SIGRTMIN+20 from PID 240 (plymouthd).
[   12.277756] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 480 (systemd-binfmt)
[   12.287721] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch being skipped.
[   12.296336] systemd[1]: Mounting Arbitrary Executable File Formats File System...
[   12.297366] systemd[1]: Condition check resulted in Load AppArmor profiles being skipped.
[   12.297725] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[   12.297960] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[   12.397018] systemd[1]: Mounted Arbitrary Executable File Formats File System.
[   12.404489] systemd[1]: Finished Set Up Additional Binary Formats.
[   12.655548] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[   12.669082] systemd[1]: Starting Load/Save RF Kill Switch Status...
[   12.756232] zram0: detected capacity change from 0 to 4031422464
[   12.836651] Adding 3936932k swap on /dev/zram0.  Priority:5 extents:1 across:3936932k SS
[   12.865198] zram: Added device: zram1
[   13.051871] systemd[1]: Finished Raise network interfaces.
[   13.123457] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch being skipped.
[   13.123815] systemd[1]: Condition check resulted in Load AppArmor profiles being skipped.
[   13.124081] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[   13.124429] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[   13.135746] systemd[1]: Started Load/Save RF Kill Switch Status.
[   13.221851] zram1: detected capacity change from 0 to 52428800
[   13.270622] systemd[1]: Finished Armbian ZRAM config.
[   13.276554] systemd[1]: Starting Armbian memory supported logging...
[   13.396990] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
[   16.540941] systemd[1]: Finished Armbian memory supported logging.
[   16.550189] systemd[1]: Starting Journal Service...
[   16.836153] systemd[1]: Started Journal Service.
[   16.861824] systemd-journald[758]: Received client request to flush runtime journal.
[   19.324243] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   19.324260] Bluetooth: BNEP filters: protocol multicast
[   19.324288] Bluetooth: BNEP socket layer initialized
[   19.611256] dw-apb-uart fe650000.serial: got rx and tx dma channels
[   20.712991] phy_rtl8211f_led_fixup in
[   20.713194] phy_rtl8211f_led_fixup in  val=0x0000
[   20.772896] rk_gmac-dwmac fe010000.ethernet eth0: PHY [stmmac-1:00] driver [RTL8211F Gigabit Ethernet] (irq=POLL)
[   20.794741] alloc_contig_range: [1ff900, 1ff902) PFNs busy
[   20.796456] dwmac4: Master AXI performs any burst length
[   20.796494] rk_gmac-dwmac fe010000.ethernet eth0: No Safety Features support found
[   20.796534] rk_gmac-dwmac fe010000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported
[   20.799082] rk_gmac-dwmac fe010000.ethernet eth0: registered PTP clock
[   20.807474] rk_gmac-dwmac fe010000.ethernet eth0: configuring for phy/rgmii link mode
[   20.840751] rk_gmac-dwmac fe010000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[   20.840843] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   36.117318] FAT-fs (sda1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[   36.122144] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[   37.267920] rfkill: input handler disabled
[   44.479350] audit: type=1326 audit(1717954264.379:2): auid=4294967295 uid=0 gid=0 ses=4294967295 pid=2547 comm="cupsd" exe="/snap/cups/1049/sbin/cupsd" sig=0 arch=c00000b7 syscall=55 compat=0 ip=0xffffa822910c code=0x50000
[   44.696108] rockchip-vop2 fe040000.vop: [drm:vop2_crtc_atomic_disable] Crtc atomic disable vp0
[   44.697601] rockchip-vop2 fe040000.vop: [drm:vop2_crtc_atomic_enable] Update mode to 1920x1080p60, type: 11(if:800, flag:0x0) for vp0 dclk: 148500000
[   45.454238] audit: type=1326 audit(1717954265.356:3): auid=4294967295 uid=0 gid=0 ses=4294967295 pid=2548 comm="cups-proxyd" exe="/snap/cups/1049/sbin/cups-proxyd" sig=0 arch=c00000b7 syscall=274 compat=0 ip=0xffffa11e1c28 code=0x50000
[   48.233578] ttyFIQ ttyFIQ0: tty_port_close_start: tty->count = 1 port count = 2
[   64.174422] audit: type=1326 audit(1717954284.073:4): auid=1000 uid=1000 gid=1000 ses=4 pid=2767 comm="chrome" exe="/snap/chromium/2875/usr/lib/chromium-browser/chrome" sig=0 arch=c00000b7 syscall=444 compat=0 ip=0xffff9f7b1c28 code=0x50000
[  255.203346] usb 1-1: USB disconnect, device number 2
[  255.203361] usb 1-1.2: USB disconnect, device number 3
[  255.345911] usb 1-1.3: USB disconnect, device number 4
[ 1034.959809] usb 1-1: new full-speed USB device number 5 using xhci-hcd
[ 1035.104347] usb 1-1: New USB device found, idVendor=0a05, idProduct=7211, bcdDevice= 1.00
[ 1035.104360] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1035.104365] usb 1-1: Product: USB2.0 HUB
[ 1035.249330] hub 1-1:1.0: USB hub found
[ 1035.249462] hub 1-1:1.0: 4 ports detected
[ 1035.633125] usb 1-1.2: new low-speed USB device number 6 using xhci-hcd
[ 1035.727256] usb 1-1.2: New USB device found, idVendor=17ef, idProduct=608d, bcdDevice= 1.00
[ 1035.727268] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1035.727273] usb 1-1.2: Product: Lenovo USB Optical Mouse
[ 1035.727277] usb 1-1.2: Manufacturer: PixArt
[ 1035.892538] input: PixArt Lenovo USB Optical Mouse as /devices/platform/usbdrd/fcc00000.dwc3/xhci-hcd.4.auto/usb1/1-1/1-1.2/1-1.2:1.0/0003:17EF:608D.0003/input/input6
[ 1035.892992] hid-generic 0003:17EF:608D.0003: input,hidraw0: USB HID v1.11 Mouse [PixArt Lenovo USB Optical Mouse] on usb-xhci-hcd.4.auto-1.2/input0
[ 1035.979833] usb 1-1.3: new low-speed USB device number 7 using xhci-hcd
[ 1036.088336] usb 1-1.3: New USB device found, idVendor=17ef, idProduct=6099, bcdDevice= 1.00
[ 1036.088351] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1036.088357] usb 1-1.3: Product: Lenovo Traditional USB Keyboard
[ 1036.088361] usb 1-1.3: Manufacturer: Lenovo
[ 1036.283982] input: Lenovo Lenovo Traditional USB Keyboard as /devices/platform/usbdrd/fcc00000.dwc3/xhci-hcd.4.auto/usb1/1-1/1-1.3/1-1.3:1.0/0003:17EF:6099.0004/input/input7
[ 1036.344318] hid-generic 0003:17EF:6099.0004: input,hidraw1: USB HID v1.11 Keyboard [Lenovo Lenovo Traditional USB Keyboard] on usb-xhci-hcd.4.auto-1.3/input0
[ 1066.411089] usb 1-1: USB disconnect, device number 5
[ 1066.411106] usb 1-1.2: USB disconnect, device number 6
[ 1066.481875] usb 1-1.3: USB disconnect, device number 7
journalctl -b | grep Bluetooth
Quote
jun 09 14:30:37 h96-tvbox-3566-legacy kernel: Bluetooth: Core ver 2.22
jun 09 14:30:37 h96-tvbox-3566-legacy kernel: Bluetooth: HCI device and connection manager initialized
jun 09 14:30:37 h96-tvbox-3566-legacy kernel: Bluetooth: HCI socket layer initialized
jun 09 14:30:37 h96-tvbox-3566-legacy kernel: Bluetooth: L2CAP socket layer initialized
jun 09 14:30:37 h96-tvbox-3566-legacy kernel: Bluetooth: SCO socket layer initialized
jun 09 14:30:38 h96-tvbox-3566-legacy systemd[1]: Starting Bluetooth service...
jun 09 14:30:40 h96-tvbox-3566-legacy bluetoothd[833]: Bluetooth daemon 5.64
jun 09 14:30:40 h96-tvbox-3566-legacy kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
jun 09 14:30:40 h96-tvbox-3566-legacy kernel: Bluetooth: BNEP filters: protocol multicast
jun 09 14:30:40 h96-tvbox-3566-legacy kernel: Bluetooth: BNEP socket layer initialized
jun 09 14:30:40 h96-tvbox-3566-legacy bluetoothd[833]: Bluetooth management interface 1.18 initialized
jun 09 14:30:40 h96-tvbox-3566-legacy systemd[1]: Started Bluetooth service.
jun 09 14:30:40 h96-tvbox-3566-legacy systemd[1]: Reached target Bluetooth Support.
jun 09 14:30:40 h96-tvbox-3566-legacy systemd[1]: Starting Bluetooth AP6335...
Quote
journalctl -b | grep sound
jun 09 14:30:37 h96-tvbox-3566-legacy kernel: rk-multicodecs rk809-sound: Failed to get ADC channel
jun 09 14:30:37 h96-tvbox-3566-legacy kernel: rk-multicodecs rk809-sound: ASoC: Property 'rockchip,audio-routing' does not exist or its length is not even
jun 09 14:30:37 h96-tvbox-3566-legacy kernel: rk-multicodecs rk809-sound: Audio routing invalid/unspecified
jun 09 14:30:37 h96-tvbox-3566-legacy kernel: input: rockchip-rk809 Headset as /devices/platform/rk809-sound/sound/card0/input2
jun 09 14:30:56 h96-tvbox-3566-legacy systemd[1221]: Starting GNOME sound sample caching service...
jun 09 14:30:57 h96-tvbox-3566-legacy systemd[1221]: Started GNOME sound sample caching service.
jun 09 14:30:57 h96-tvbox-3566-legacy systemd[1221]: Reached target GNOME sound sample caching target.
Edited by Hqnicolas
what we need to find?
~taken from a working kernel 6.6 mainline~
dmesg:
Quote
[   18.693599] Bluetooth: hci1: BCM: chip id 82
[   18.694223] Bluetooth: hci1: BCM: features 0x2f
[   18.696413] Bluetooth: hci1: BCM4335A0
[   18.696495] Bluetooth: hci1: BCM4335A0 (002.001.006) build 0000
[   18.702527] Bluetooth: hci1: BCM4335A0 'brcm/BCM4335A0.hcd' Patch
[   18.222782] Bluetooth: Core ver 2.22
[   18.223139] NET: Registered PF_BLUETOOTH protocol family
[   18.223176] Bluetooth: HCI device and connection manager initialized
[   18.223225] Bluetooth: HCI socket layer initialized
[   18.223239] Bluetooth: L2CAP socket layer initialized
[   18.223330] Bluetooth: SCO socket layer initialized
[   18.276186] Bluetooth: HCI UART driver ver 2.3
[   18.276215] Bluetooth: HCI UART protocol H4 registered
[   18.276220] Bluetooth: HCI UART protocol BCSP registered
[   18.276327] Bluetooth: HCI UART protocol LL registered
[   18.276333] Bluetooth: HCI UART protocol ATH3K registered
[   18.276377] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   18.276610] Bluetooth: HCI UART protocol Intel registered
[   18.294457] Bluetooth: HCI UART protocol Broadcom registered
[   18.294523] Bluetooth: HCI UART protocol QCA registered
[   18.294529] Bluetooth: HCI UART protocol AG6XX registered
[   18.294565] Bluetooth: HCI UART protocol Marvell registered
rfkill:
Quote
ID TYPE      DEVICE      SOFT      HARD
 0 bluetooth hci0   unblocked unblocked
 1 bluetooth hci1   unblocked unblocked
 2 wlan      phy0   unblocked unblocked
Quote
jun 12 13:38:35 h96-tvbox-3566 kernel: Bluetooth: Core ver 2.22
jun 12 13:38:35 h96-tvbox-3566 kernel: Bluetooth: HCI device and connection manager initialized
jun 12 13:38:35 h96-tvbox-3566 kernel: Bluetooth: HCI socket layer initialized
jun 12 13:38:35 h96-tvbox-3566 kernel: Bluetooth: L2CAP socket layer initialized
jun 12 13:38:35 h96-tvbox-3566 kernel: Bluetooth: SCO socket layer initialized
jun 12 13:38:35 h96-tvbox-3566 kernel: Bluetooth: HCI UART driver ver 2.3
jun 12 13:38:35 h96-tvbox-3566 kernel: Bluetooth: HCI UART protocol H4 registered
jun 12 13:38:35 h96-tvbox-3566 kernel: Bluetooth: HCI UART protocol BCSP registered
jun 12 13:38:35 h96-tvbox-3566 kernel: Bluetooth: HCI UART protocol LL registered
jun 12 13:38:35 h96-tvbox-3566 kernel: Bluetooth: HCI UART protocol ATH3K registered
jun 12 13:38:35 h96-tvbox-3566 kernel: Bluetooth: HCI UART protocol Three-wire (H5) registered
jun 12 13:38:35 h96-tvbox-3566 kernel: Bluetooth: HCI UART protocol Intel registered
jun 12 13:38:35 h96-tvbox-3566 kernel: Bluetooth: HCI UART protocol Broadcom registered
jun 12 13:38:35 h96-tvbox-3566 kernel: Bluetooth: HCI UART protocol QCA registered
jun 12 13:38:35 h96-tvbox-3566 kernel: Bluetooth: HCI UART protocol AG6XX registered
jun 12 13:38:35 h96-tvbox-3566 kernel: Bluetooth: HCI UART protocol Marvell registered
jun 12 13:38:35 h96-tvbox-3566 kernel: Bluetooth: hci1: BCM: chip id 82
jun 12 13:38:35 h96-tvbox-3566 kernel: Bluetooth: hci1: BCM: features 0x2f
jun 12 13:38:35 h96-tvbox-3566 kernel: Bluetooth: hci1: BCM4335A0
jun 12 13:38:35 h96-tvbox-3566 kernel: Bluetooth: hci1: BCM4335A0 (002.001.006) build 0000
jun 12 13:38:35 h96-tvbox-3566 kernel: Bluetooth: hci1: BCM4335A0 'brcm/BCM4335A0.hcd' Patch
jun 12 13:38:35 h96-tvbox-3566 kernel: Bluetooth: hci1: BCM4335B0 JF-LTE MurataXJ AFH_LimitPwr_EDR 2STOPBIT-0343
jun 12 13:38:35 h96-tvbox-3566 kernel: Bluetooth: hci1: BCM4335A0 (002.001.006) build 0353
jun 12 13:38:35 h96-tvbox-3566 systemd[1]: Starting Bluetooth service...
jun 12 13:38:37 h96-tvbox-3566 bluetoothd[965]: Bluetooth daemon 5.64
jun 12 13:38:37 h96-tvbox-3566 systemd[1]: Started Bluetooth service.
jun 12 13:38:37 h96-tvbox-3566 systemd[1]: Reached target Bluetooth Support.
jun 12 13:38:37 h96-tvbox-3566 kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
jun 12 13:38:37 h96-tvbox-3566 kernel: Bluetooth: BNEP filters: protocol multicast
jun 12 13:38:37 h96-tvbox-3566 kernel: Bluetooth: BNEP socket layer initialized
jun 12 13:38:37 h96-tvbox-3566 bluetoothd[965]: Bluetooth management interface 1.22 initialized
jun 12 13:38:37 h96-tvbox-3566 kernel: Bluetooth: MGMT ver 1.22
jun 12 13:38:43 h96-tvbox-3566 kernel: Bluetooth: RFCOMM TTY layer initialized
jun 12 13:38:43 h96-tvbox-3566 kernel: Bluetooth: RFCOMM socket layer initialized
jun 12 13:38:43 h96-tvbox-3566 kernel: Bluetooth: RFCOMM ver 1.11
jun 12 13:39:27 h96-tvbox-3566 systemd[1576]: Starting Bluetooth OBEX service...
jun 12 13:39:27 h96-tvbox-3566 systemd[1576]: Started Bluetooth OBEX service.
jun 12 13:41:35 h96-tvbox-3566 kernel: Bluetooth: hci1: Frame reassembly failed (-84)
gpioinfo
Quote
gpiochip0 - 32 lines:
    line   0:      unnamed       unused   input  active-high
    line   1:      unnamed       unused   input  active-high
    line   2:      unnamed       unused   input  active-high
    line   3:      unnamed  "interrupt"   input  active-high [used]
    line   4:      unnamed         "cd"   input   active-low [used]
    line   5:      unnamed "vcc5v0-otg-regulator" output active-high [used]
    line   6:      unnamed "vcc5v0-host-regulator" output active-high [used]
    line   7:      unnamed       unused   input  active-high
    line   8:      unnamed       unused   input  active-high
    line   9:      unnamed       unused   input  active-high
    line  10:      unnamed       unused   input  active-high
    line  11:      unnamed       unused   input  active-high
    line  12:      unnamed       unused   input  active-high
    line  13:      unnamed       unused   input  active-high
    line  14:      unnamed       unused   input  active-high
    line  15:      unnamed "snps,reset"  output   active-low [used]
    line  16:      unnamed       unused   input  active-high
    line  17:      unnamed       unused   input  active-high
    line  18:      unnamed "ir-receiver" input active-low [used]
    line  19:      unnamed       unused   input  active-high
    line  20:      unnamed "vcc3v3-pcie-p-regulator" output active-high [used]
    line  21:      unnamed       unused   input  active-high
    line  22:      unnamed       unused   input  active-high
    line  23:      unnamed       unused   input  active-high
    line  24:      unnamed       unused   input  active-high
    line  25:      unnamed       unused   input  active-high
    line  26:      unnamed       unused   input  active-high
    line  27:      unnamed  "led-power"  output  active-high [used]
    line  28:      unnamed "led-status"  output  active-high [used]
    line  29:      unnamed       unused   input  active-high
    line  30:      unnamed       unused   input  active-high
    line  31:      unnamed       unused   input  active-high
gpiochip1 - 32 lines:
    line   3:      unnamed       unused   input  active-high
    line   4:      unnamed       unused   input  active-high
    line   5:      unnamed       unused   input  active-high
    line   6:      unnamed       unused   input  active-high
    line  15:      unnamed       unused   input  active-high
    line  18:      unnamed       unused   input  active-high
    line  20:      unnamed       unused   input  active-high
    line  27:      unnamed       unused   input  active-high
    line  28:      unnamed       unused   input  active-high
gpiochip2 - 32 lines:
    line   9:      unnamed      "reset"  output   active-low [used]
    line  10:      unnamed  "interrupt"   input  active-high [used]
    line  15:      unnamed   "shutdown"  output  active-high [used]
    line  16:      unnamed "host-wakeup" input active-high [used]
    line  17:      unnamed "device-wakeup" output active-high [used]
gpiochip3 - 32 lines:
gpiochip4 - 32 lines:
Posted (edited)
Marking all packages on hold to prevent update after add arch armhf and i386
Marking Packages with letter X on hold
install dependency
sudo apt-get install parallel
nano mark_hold_all.sh
#!/bin/bash
while IFS= read -r line; do
    package=$(echo "$line" | awk '{print $1}')
    echo "Marking $package as hold..."
    sudo apt-mark hold "$package"
done < <(sudo apt list)
parallel -a 12 :::: ::: <<< $(printf "%s\n" "${packages[@]}") |
while read package; do
done
nano mark_hold_letter_X_.sh
#!/bin/bash
packages=$(sudo apt list | awk '/^x/{print $1}')
for package in $packages; do
done
 nano mark_hold_all_linux_.sh
#!/bin/bash
packages=$(sudo apt list | awk '/^linux/{print $1}')
done
Edited by Hqnicolas
Posted (edited)
@pocosparc @maka
Since Armbian_community_24.8.0-trunk.6_H96-tvbox-3566_noble_current_6.6.32_gnome_desktop
The VPU Acceleration from Joshua Riek  Vendor Kernel start to become less important
The Vendor 6.1 Kernel was slower then mainline.
in full environment experience Kernel Mainline was faster with video player on NPU hantro
and The hantro Video Acceleration Run 1080P 30hz 10% drop frames.
I think this RK35xx will start to shine on kernel 6.8
Edited by Hqnicolas
