Posted (edited)
  On 6/21/2024 at 8:09 PM, Vincenzoernst1 said:
question: i see the red EMMC(? its not ethernet.) led blinking all the time. Iotop doesnt show any writes. Is  it a write (access) led?
Expand
The RED LED is set on DTS to be HeartBeat: This is the code
@Vincenzoernst1 if you wanna change it:
sudo apt update
sudo apt install armbian-config
sudo armbian-config
Edit Device tree with armbian config.
		led_status: led-status {
			label = "led-status";
			gpios = <&gpio0 RK_PD4 GPIO_ACTIVE_HIGH>;
			linux,default-trigger = "heartbeat";
			pinctrl-names = "default";
			pinctrl-0 = <&led_status_enable_h>;
@Vincenzoernst1 I noticed that you care a lot about the look of the box
I invite you to participate in the development of This project with @pocosparc
The objective is here
Edited by Hqnicolas
Posted (edited)
Today I Test the DXVK Wine against wined3d wrapper
wined3d wrapper by default translate directx calls to the openGL api
and it got Slower on Vulkan
WTF!
winetricks renderer=vulkan
Edited by Hqnicolas
Testing "AetherSX2-v1.5-3606.AppImage"
Playstation 2 emulation Isn't compatible at all
it requires OpenGL 3.3 but RK3566 only got 3.1:
glxinfo | grep "OpenGL version"
OpenGL version string: 3.1 Mesa 23.2.1-1ubuntu3.1~22.04.2
AetherSX2 works with Vulkan at 15fps on Guitar Hero II "unplayable"
PS1 emulation works fine with 3x resolution on Retroarch from Snap Store.
all olders emulators works fine
aarch64-retroarch-cores.tar.xzFetching info...
Posted (edited)
################# FULL DESKTOP EXAMPLE ################
For the users who bought the device hoping to create a cheap desktop,
here is an image that exemplifies this experience:
32gb: Example Desktop Image
64gb: Example Desktop Image
Unzip Method
About:
Status: Unsafe (test only)
User: user
Passwd: user
Version: 22.04 (pop)
Language: PT-BR
Device: H96-MAX RK3566
Flash Method: v1.1
After Install:
Resize disc
Change Language
Edited by Hqnicolas
Hqnicolas,
Please help me,
I just bought android TV box X96 X6 (rk3566 8/64G) to use as a server for Home Assistant, but can't install armbian/debian, can you help me? I haven't found a suitable ".img" file to install. Actually I don't know much about armbian.
Thank you very much!
Expand
hello @loi xin
unfortunately the laws in my country have changed for international shopping, we are now living in the North Korea format.
I no longer have access to international products like last year,
I believe you can perform all the methods that were exemplified in this topic
Just create another topic to find people that have the same board as you
Name it "Efforts to develop firmware for X96 X6 k3566 8/64G"
Posted (edited)
oh. sorry didnt notice that it was a X6 version he was asking for.
@loi xin
this thing is 135€ in germany and imho not worth it. the v56 is much cheaper with the same functionallity (but "only" having single WIFI). so imho if u have the chance to send it back, replace it with the v56 unit if u can. then u have a ready to go unit.
@Hqnicolas opened a topic for the H96 MAX M9 RK3576 TV Box 8G/128G which i find the much more interesting unit, with much more power. but the pricing of this unit (top notch) is holding me back right now.
Edited by Vincenzoernst1
  On 7/15/2024 at 3:51 PM, Vincenzoernst1 said:
[mention=211404]pessimism[/mention]
have u something else connected to get the sdcard reader running? i only get "cant read partiontion table" errors.
No, just soldered the socket. There are seven unpopulated passive components behind it but it didn’t matter for me…
Sent from my iPad using Tapatalk
In Canada law didn’t change but AliExpress decided to be much more expensive, I paid $43 CAD (170 Real) in April, same box now $87/340Real
@pessimism  hmm....i got i beautuifull soldert on there but sill get the error. maybe there is a modul missing?
[   60.390814] mmc0: error -110 whilst initialising SD card
[   60.422082] mmc_host mmc0: Bus speed (slot 0) = 375000Hz (slot req 375000Hz, actual 375000HZ div = 0)
[   60.487693] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[   60.487855] mmc0: new high speed SDHC card at address b368
[   60.491174] mmcblk0: mmc0:b368 USD00 29.5 GiB
[   60.530849] mmc_host mmc0: Bus speed (slot 0) = 375000Hz (slot req 375000Hz, actual 375000HZ div = 0)
[   60.580493] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[   60.581278] I/O error, dev mmcblk0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[   60.581666] I/O error, dev mmcblk0, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[   60.582044] I/O error, dev mmcblk0, sector 2 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[   60.582424] I/O error, dev mmcblk0, sector 3 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[   60.582816] I/O error, dev mmcblk0, sector 4 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[   60.583207] I/O error, dev mmcblk0, sector 5 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[   60.583591] I/O error, dev mmcblk0, sector 6 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[   60.583970] I/O error, dev mmcblk0, sector 7 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[   60.584019] Buffer I/O error on dev mmcblk0, logical block 0, async page read
[   60.586020] I/O error, dev mmcblk0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[   60.586412] I/O error, dev mmcblk0, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[   60.588580] Buffer I/O error on dev mmcblk0, logical block 0, async page read
[   60.588714]  mmcblk0: unable to read partition table
[   60.615997] Buffer I/O error on dev mmcblk0, logical block 7743984, async page read
[   72.535157] blk_print_req_error: 22 callbacks suppressed
[   72.535169] I/O error, dev mmcblk0, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
[   72.535403] I/O error, dev mmcblk0, sector 1 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
[   72.535634] I/O error, dev mmcblk0, sector 2 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
[   72.535865] I/O error, dev mmcblk0, sector 3 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
[   72.536096] I/O error, dev mmcblk0, sector 4 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
[   72.536328] I/O error, dev mmcblk0, sector 5 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
[   72.536559] I/O error, dev mmcblk0, sector 6 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
[   72.536791] I/O error, dev mmcblk0, sector 7 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
[   72.537900] I/O error, dev mmcblk0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[   72.538133] I/O error, dev mmcblk0, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[   72.539579] Buffer I/O error on dev mmcblk0, logical block 0, async page read
[   72.542910] Buffer I/O error on dev mmcblk0, logical block 0, async page read
[   72.547094] Buffer I/O error on dev mmcblk0, logical block 0, async page read
[   72.665033] Buffer I/O error on dev mmcblk0, logical block 0, async page read
[   72.665085]  mmcblk0: unable to read partition table
[   72.680752] Buffer I/O error on dev mmcblk0, logical block 7743984, async page read
SD is esxt4 formated. fat also didnt work.
any thoughts?
Posted (edited)
Expand
I/O error = missing pad or bad connection
it's plug and play,
the only thing that you need is the socket.
when I do it I discard 4 units before it works....
be carefull with board cooper pads when change sockets
Expand
Just flash the armbian image with balena etcher......
you dont need to format the sdcard after flash armbian image....
Edited by Hqnicolas
i alread have armian running. just want to ad the reader for fun.
Expand
hmmm....the soldering was very good, so i guess its maybe the cheap chinese sdcard socket. i have still 9 left to try 😡  now i go with the hot gun....
Posted (edited)
@Hqnicolas I tried flas to eMMc your POP OS images, but to the 4/32 don't able because too big the image for that eMMC, on 8/64 don't boot after flash.
I tried with the v1.1 mode.
Edited by paradigman
Posted (edited)
Expand
will test it here,
edit: downloaded and Tested with 7zip, it boot's on 8/64gb clear android ROM
 make sure you Unzip it With 7zip
Expand
the system Uses 24gb (android emulator) + (kodi Games) +(debian Linux)+(wine Desktop)
Next Week I will rebuild it for 4/32gb
Edited by Hqnicolas
