Posted (edited)
56 minutes ago, WINEDS said:
The compatible = part was only to make the driver module load automatically.  The driver module itself had to be first compiled into the kernel using source code from the chip vendor.  I suggest you try my DTB (it might be close to what you need) and then post your dmesg as a file (sudo dmesg > dmesg.txt).
can it be compiled in currently running armbian ? my computer specs and internet speed is not decend enough to compile armbian from scratch, compile using github action may be a choice but i don't know how to do that yet.
i attached the dmesg.txt with your dtb, my bluetooth seems incompatible with your dtb, and ethernet still not working
dmesg.txt
also added dmesg with default dtb (rk3566-h96-tvbox.dtb), bluetooth is working
dmesg-hqnic.txt
Edited by Andre B
17 hours ago, Andre B said:
would you mind assist me to assign those values to rk3566-h96-tvbox.dtb ?
I think the main way to go is to create a .dtsi that will patch the base "old" board with this new features,
+&gmac1 {
+ phy-mode = "rgmii";
+ clock_in_out = "output";
+ snps,reset-gpio = <&gpio4 RK_PC2 GPIO_ACTIVE_LOW>;
+ snps,reset-active-low;
+ /* Reset time is 20ms, 100ms for rtl8211f */
+ snps,reset-delays-us = <0 100000 200000>;
+ assigned-clocks = <&cru SCLK_GMAC1_RX_TX>, <&cru SCLK_GMAC1>;
+ assigned-clock-parents = <&cru SCLK_GMAC1_RGMII_SPEED>;
+ assigned-clock-rates = <0>, <125000000>;
+ pinctrl-names = "default";
+ pinctrl-0 = <&gmac1m1_miim
+ &gmac1m1_tx_bus2
+ &gmac1m1_rx_bus2
+ &gmac1m1_rgmii_clk
+ &gmac1m1_rgmii_bus>;
+ tx_delay = <0x4b>;
+ rx_delay = <0x26>;
+ phy-handle = <&rgmii_phy1>;
+ status = "okay";
On 5/18/2025 at 12:57 AM, mvpwar said:
how to flash this official community image?
Hello @mvpwar
Download image
Unzip
On 4/3/2024 at 10:26 PM, Hqnicolas said:
1 - Follow the Build Armbian instructions
if it doesnt Build your image as espected
rm -rf build
git clone --depth 1 --branch v24.02 https://github.com/armbian/build
try again and again and again and again
2 -  Download H96MAX Armbian Build Config  (Original Source)
3 - Copy the h96-max-v56 directory to build/packages/blobs/  directory
4 - Copy the h96-max-v56.conf file to the build/config/boards/ directory
5 - Run the image build
./compile.sh
On Windows:
6 - Download the Armbian.cfg file to RKDevTool (Original Source)
7 - Drop it on RKDevTool
Boot, MiniLoaderAll:
H96-MAX-8gb-MiniLoaderAll.bin
H96-MAX-4gb-MiniLoaderAll.bin
8 - Shutting down H96 MAX.
9 - Press the Reset button.
10 - Turn on the H96 MAX.
11 - Wait until The message "Found One MASKROM Device" or "Found One LOADER Device" should appear. (1)
12 - Mark all 2 sections with check marks (2)
13 - Open 2 files for each section (3)
14 - Check "Write by Address" (4).
15 - Press the "Run" button (5). The download will start.
When the message "Download image OK" appears, the download is finished (6).
16 - H96 MAX will automatically reboot.
Done.
Alternative: On Linux OS
rkdeveloptool db MiniLoaderAll.bin   # If this is not your first time flashing with this firmware, an error may appear here\. It\'s not a big deal
rkdeveloptool wl 0x0 Your_Armbian_Image-trunk_H96-max-v56_jammy_current_6.1.62.img
rkdeveloptool rd
And because a malware was discovered in the XZ library from Edge trixie and Edge sid
I came here again to remove and ReBuild all afected images.
Ubuntu: One of the most popular Linux distributions is not affected as its xz version is the older 5.4 version. No updates are required.
Debian Linux: No stable versions of the distribution were affected.
but compromised packages were part of test, unstable and experimental versions. Users must update xz-utils.
Read more: CVE-2024-3094
On 11/17/2023 at 1:50 PM, hzdm said:
How to install this Armbian:
On Windows OS:
1. Download, unzip and install the software: RKDevTool_Release_v3.15_and_DriverAssitant_v5.12
https://drive.google.com/file/d/14HWcHYHDrgUBFWholrDCKUWDPHw1r4F1/view?usp=drive_link
2. Run RKDevTool. Right-click in the partition list window (1). Select "Load Config". Open armbian.cfg file (2)
https://drive.google.com/file/d/1MhmUJ8DaikZzwjBliY-PrOrvSrcBPwSA/view?usp=drive_link
4. Shutting down H96 MAX. Press the Reset button. Turn on the H96 MAX. The message "Found One MASKROM Device" or "Found One LOADER Device" should appear. (1)
Done.
On Linux OS
rkdeveloptool wl 0x0 Armbian_23.11.0-trunk_H96-max-v56_jammy_current_6.1.62.img
rkdeveloptool rd
PS: This image is functionally the same as the previous ones. It is still the same Station M2 image, only it already has all the past improvements built in and is easier to install!
@paradigman
not to be unfair against OVPN but its very slow (high cpu load) and hard to configure/maintain ( i developed the opvn plugin in ddwrt for some years).  you will be better off with Wireguard on this box (i bet it can push linespeed of the gig port).
Posted (edited)
15 hours ago, Hqnicolas said:
I think you will need to fork and rebuild it, the files got expired
@Hqnicolas Thanks for your reply, but i found the workflow run failed, could you please help to re-run the workflow which run successfully before?  https://github.com/hqnicolas/ubuntu-rockchip-joshua/actions/runs/13094582628
success now after i fixed some branch missing errors, let me try to test the image
Edited by mvpwar
Posted (edited)
U-Boot 2025.01-dirty (Jun 06 2025 - 16:36:43 +0000)
Model: h96 TVbox 3566
DRAM:  8 GiB (effective 7.7 GiB)
PMIC:  RK809 (on=0x40, off=0x00)
Core:  323 devices, 31 uclasses, devicetree: separate
MMC:   mmc@fe2b0000: 1, mmc@fe2c0000: 2, mmc@fe310000: 0
Loading Environment from nowhere... OK
In:    serial@fe660000
Out:   serial@fe660000
Err:   serial@fe660000
ADC channel 2 value read: 1021
setup_boot_mode: Boot mode 0x5242c300
Net:   eth0: ethernet@fe010000
Scanning for bootflows in all bootdevs
Seq  Method       State   Uclass    Part  Name                      Filename
Scanning global bootmeth 'efi_mgr':
Card did not respond to voltage select! : -110
** File not found ubootefi.var **
Failed to load EFI variables
** Unable to write file ubootefi.var **
Failed to persist EFI variables
  0  efi_mgr      ready   (none)       0  <NULL>
** Booting bootflow '<NULL>' with efi_mgr
Loading Boot0000 'mmc 0' failed
EFI boot manager: Cannot load any image
Boot failed (err=-14)
Scanning bootdev 'mmc@fe2b0000.bootdev':
Scanning bootdev 'mmc@fe310000.bootdev':
  1  extlinux     ready   mmc          2  mmc@fe310000.bootdev.part /boot/extlinux/extlinux.conf
** Booting bootflow 'mmc@fe310000.bootdev.part_2' with extlinux
U-Boot menu
1:	Ubuntu 24.04.2 LTS 6.1.0-1027-rockchip
2:	Ubuntu 24.04.2 LTS 6.1.0-1027-rockchip (rescue target)
Enter choice: 1:	Ubuntu 24.04.2 LTS 6.1.0-1027-rockchip
Retrieving file: /boot/vmlinuz-6.1.0-1027-rockchip
Retrieving file: /boot/initrd.img-6.1.0-1027-rockchip
append: root=UUID=8bce15ff-99cf-482b-981d-3b732fcb0650 rootwait rw console=ttyS2,1500000 console=tty1 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory
Retrieving file: /lib/firmware/6.1.0-1027-rockchip/device-tree/rockchip/rk3566-h96max-v56.dtb
Skipping fdtdir /lib/firmware/6.1.0-1027-rockchip/device-tree/ for failure retrieving dts
## Flattened Device Tree blob at edecb210
   Booting using the fdt blob at 0xedecb210
Working FDT set to edecb210
   Loading Ramdisk to ebf24000, end ece9955c ... OK
   Loading Device Tree to 00000000ebf0d000, end 00000000ebf23bc7 ... OK
Working FDT set to ebf0d000
Starting kernel ...
[    6.483775] Booting Linux on physical CPU 0x0000000000 [0x412fd050]
[    6.483821] Linux version 6.1.0-1027-rockchip (root@fv-az975-670) (aarch64-linux-gnu-gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #27 SMP Fri Jun  6 15:35:04 UTC 2025
[    6.488694] Machine model: h96 TVbox 3566
[    6.490148] efi: UEFI not found.
[    6.684612] Zone ranges:
[    6.684627]   DMA      [mem 0x0000000000200000-0x00000000ffffffff]
[    6.684648]   DMA32    empty
[    6.684656]   Normal   [mem 0x0000000100000000-0x00000001ffffffff]
[    6.684667] Movable zone start for each node
[    6.684671] Early memory node ranges
[    6.684675]   node   0: [mem 0x0000000000200000-0x00000000efffffff]
[    6.684689]   node   0: [mem 0x0000000100000000-0x00000001ffffffff]
[    6.684700] Initmem setup node 0 [mem 0x0000000000200000-0x00000001ffffffff]
[    6.714813] On node 0, zone DMA: 512 pages in unavailable ranges
[    6.746933] cma: Reserved 16 MiB at 0x00000000ef000000
[    6.747041] psci: probing for conduit method from DT.
[    6.747057] psci: PSCIv1.1 detected in firmware.
[    6.747067] psci: Using standard PSCI v0.2 function IDs
[    6.747075] psci: MIGRATE_INFO_TYPE not supported.
[    6.747093] psci: SMC Calling Convention v1.2
[    6.747578] percpu: Embedded 29 pages/cpu s80504 r8192 d30088 u118784
[    6.747786] Detected VIPT I-cache on CPU0
[    6.747881] CPU features: detected: GIC system register CPU interface
[    6.747889] CPU features: detected: Virtualization Host Extensions
[    6.747908] CPU features: kernel page table isolation forced ON by KASLR
[    6.747917] CPU features: detected: Kernel page table isolation (KPTI)
[    6.747927] CPU features: detected: Qualcomm erratum 1009, or ARM erratum 1286807, 2441009
[    6.747933] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    6.747941] alternatives: applying boot alternatives
[    6.748466] Built 1 zonelists, mobility grouping on.  Total pages: 1999368
[    6.748486] Kernel command line: root=UUID=8bce15ff-99cf-482b-981d-3b732fcb0650 rootwait rw console=ttyS2,1500000 console=tty1 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory
[    6.748977] Unknown kernel command line parameters "cgroup_enable=memory cgroup_memory=1", will be passed to user space.
[    6.751628] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    6.752949] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    6.752965] mem auto-init: stack:off, heap alloc:off, heap free:off
[    6.752975] software IO TLB: area num 4.
[    6.795614] software IO TLB: mapped [mem 0x00000000e7f0d000-0x00000000ebf0d000] (64MB)
[    6.957563] Memory: 7826628K/8124416K available (17984K kernel code, 3690K rwdata, 12860K rodata, 7616K init, 783K bss, 281404K reserved, 16384K cma-reserved)
[    6.957848] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    6.957940] ftrace: allocating 73550 entries in 288 pages
[    7.175507] ftrace: allocated 288 pages with 2 groups
[    7.175725] trace event string verifier disabled
[    7.176088] rcu: Hierarchical RCU implementation.
[    7.176097] rcu: 	RCU event tracing is enabled.
[    7.176102] rcu: 	RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    7.176112] 	Rude variant of Tasks RCU enabled.
[    7.176116] 	Tracing variant of Tasks RCU enabled.
[    7.176121] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[    7.176128] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    7.187430] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    7.189226] GICv3: GIC: Using split EOI/Deactivate mode
[    7.189238] GICv3: 320 SPIs implemented
[    7.189247] GICv3: 0 Extended SPIs implemented
[    7.189315] GICv3: MBI range [296:319]
[    7.189333] GICv3: Using MBI frame 0x00000000fd410000
[    7.189389] Root IRQ handler: gic_handle_irq
[    7.189413] GICv3: GICv3 features: 16 PPIs
[    7.189460] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000
[    7.190098] ITS: No ITS available, not enabling LPIs
[    7.190183] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    7.193391] rockchip_clk_register_muxgrf: regmap not available
[    7.193405] rockchip_clk_register_branches: failed to register clock clk_32k_ioe: -524
[    7.299472] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    7.299504] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    7.299521] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    7.300681] Console: colour dummy device 80x25
[    7.301585] printk: console [tty1] enabled
[    7.301658] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[    7.301703] pid_max: default: 32768 minimum: 301
[    7.301901] LSM: Security Framework initializing
[    7.302098] AppArmor: AppArmor initialized
[    7.302368] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    7.302517] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    7.306124] cblist_init_generic: Setting adjustable number of callback queues.
[    7.306172] cblist_init_generic: Setting shift to 2 and lim to 1.
[    7.306425] cblist_init_generic: Setting adjustable number of callback queues.
[    7.306462] cblist_init_generic: Setting shift to 2 and lim to 1.
[    7.306992] rcu: Hierarchical SRCU implementation.
[    7.307022] rcu: 	Max phase no-delay instances is 1000.
[    7.309992] EFI services will not be available.
[    7.310799] smp: Bringing up secondary CPUs ...
[    7.312169] Detected VIPT I-cache on CPU1
[    7.312352] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[    7.312425] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[    7.313938] Detected VIPT I-cache on CPU2
[    7.314109] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[    7.314167] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[    7.315644] Detected VIPT I-cache on CPU3
[    7.315812] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000
[    7.315867] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[    7.316122] smp: Brought up 1 node, 4 CPUs
[    7.316285] SMP: Total of 4 processors activated.
[    7.316309] CPU features: detected: 32-bit EL0 Support
[    7.316329] CPU features: detected: 32-bit EL1 Support
[    7.316353] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    7.316381] CPU features: detected: Common not Private translations
[    7.316402] CPU features: detected: CRC32 instructions
[    7.316425] CPU features: detected: RCpc load-acquire (LDAPR)
[    7.316446] CPU features: detected: Privileged Access Never
[    7.316467] CPU features: detected: RAS Extension Support
[    7.316491] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    7.316641] CPU: All CPU(s) started at EL2
[    7.316668] alternatives: applying system-wide alternatives
[    7.320933] devtmpfs: initialized
[    7.343895] Registered cp15_barrier emulation handler
[    7.343966] Registered setend emulation handler
[    7.344315] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    7.344383] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    7.345291] pinctrl core: initialized pinctrl subsystem
[    7.346546] DMI not present or invalid.
[    7.347699] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    7.349900] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[    7.350579] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    7.351250] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    7.351369] audit: initializing netlink subsys (disabled)
[    7.351731] audit: type=2000 audit(0.049:1): state=initialized audit_enabled=0 res=1
[    7.352604] Registered FIQ tty driver
[    7.353476] thermal_sys: Registered thermal governor 'fair_share'
[    7.353489] thermal_sys: Registered thermal governor 'step_wise'
[    7.353517] thermal_sys: Registered thermal governor 'user_space'
[    7.353542] thermal_sys: Registered thermal governor 'power_allocator'
[    7.353668] cpuidle: using governor menu
[    7.354303] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    7.354612] ASID allocator initialised with 32768 entries
[    7.375912] platform fe0a0000.hdmi: Fixed dependency cycle(s) with /vop@fe040000/ports/port@0/endpoint@2
[    7.398644] rockchip-gpio fdd60000.gpio: probed /pinctrl/gpio@fdd60000
[    7.399761] rockchip-gpio fe740000.gpio: probed /pinctrl/gpio@fe740000
[    7.400862] rockchip-gpio fe750000.gpio: probed /pinctrl/gpio@fe750000
[    7.402019] rockchip-gpio fe760000.gpio: probed /pinctrl/gpio@fe760000
[    7.403043] rockchip-gpio fe770000.gpio: probed /pinctrl/gpio@fe770000
[    7.403287] rockchip-pinctrl pinctrl: probed pinctrl
[    7.405189] platform hdmi-con: Fixed dependency cycle(s) with /hdmi@fe0a0000/ports/port@1/endpoint
[    7.414022] KASLR enabled
[    7.439086] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    7.439136] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    7.439164] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    7.439187] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    7.439211] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    7.439234] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    7.439259] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    7.439280] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    7.497382] raid6: neonx8   gen()  1373 MB/s
[    7.554282] raid6: neonx4   gen()  1412 MB/s
[    7.611216] raid6: neonx2   gen()  1279 MB/s
[    7.668140] raid6: neonx1   gen()  1041 MB/s
[    7.725024] raid6: int64x8  gen()   352 MB/s
[    7.781962] raid6: int64x4  gen()   439 MB/s
[    7.838907] raid6: int64x2  gen()   354 MB/s
[    7.895823] raid6: int64x1  gen()   308 MB/s
[    7.895854] raid6: using algorithm neonx4 gen() 1412 MB/s
[    7.952635] raid6: .... xor() 1068 MB/s, rmw enabled
[    7.952666] raid6: using neon recovery algorithm
[    7.961680] iommu: Default domain type: Translated
[    7.961721] iommu: DMA domain TLB invalidation policy: strict mode
[    7.962368] SCSI subsystem initialized
[    7.962878] usbcore: registered new interface driver usbfs
[    7.962985] usbcore: registered new interface driver hub
[    7.963074] usbcore: registered new device driver usb
[    7.963370] mc: Linux media interface: v0.10
[    7.963474] videodev: Linux video capture interface: v2.00
[    7.963665] pps_core: LinuxPPS API ver. 1 registered
[    7.963693] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    7.963754] PTP clock support registered
[    7.964693] arm-scmi firmware:scmi: Enabled polling mode TX channel - prot_id:16
[    7.964983] arm-scmi firmware:scmi: SCMI Notifications - Core Enabled.
[    7.965090] arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0
[    7.967955] rockchip-otp fe38c000.nvmem: Failed to get clk 'usr': -2
[    7.968000] rockchip-otp: probe of fe38c000.nvmem failed with error -2
[    7.968240] Advanced Linux Sound Architecture Driver Initialized.
[    7.969406] Bluetooth: Core ver 2.22
[    7.969530] NET: Registered PF_BLUETOOTH protocol family
[    7.969559] Bluetooth: HCI device and connection manager initialized
[    7.969596] Bluetooth: HCI socket layer initialized
[    7.969627] Bluetooth: L2CAP socket layer initialized
[    7.969675] Bluetooth: SCO socket layer initialized
[    7.969734] NetLabel: Initializing
[    7.969757] NetLabel:  domain hash size = 128
[    7.969777] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    7.969913] NetLabel:  unlabeled traffic allowed by default
[    7.972752] clocksource: Switched to clocksource arch_sys_counter
[    7.973564] VFS: Disk quotas dquot_6.6.0
[    7.973674] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    7.974764] AppArmor: AppArmor Filesystem Enabled
[    7.995841] NET: Registered PF_INET protocol family
[    7.996490] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    8.006419] tcp_listen_portaddr_hash hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    8.006601] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    8.006770] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    8.007361] TCP bind hash table entries: 65536 (order: 10, 4194304 bytes, linear)
[    8.011210] TCP: Hash tables configured (established 65536 bind 65536)
[    8.011875] MPTCP token hash table entries: 8192 (order: 6, 393216 bytes, linear)
[    8.012342] UDP hash table entries: 4096 (order: 6, 393216 bytes, linear)
[    8.012820] UDP-Lite hash table entries: 4096 (order: 6, 393216 bytes, linear)
[    8.013530] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    8.014503] RPC: Registered named UNIX socket transport module.
[    8.014540] RPC: Registered udp transport module.
[    8.014563] RPC: Registered tcp transport module.
[    8.014583] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    8.014964] PCI: CLS 0 bytes, default 64
[    8.015963] Trying to unpack rootfs image as initramfs...
[    8.017002] rockchip-thermal fe710000.tsadc: Missing tshut mode property, using default (gpio)
[    8.017052] rockchip-thermal fe710000.tsadc: Missing tshut-polarity property, using default (low)
[    8.017383] rockchip-thermal fe710000.tsadc: failed to find thermal gpio state
[    8.017422] rockchip-thermal fe710000.tsadc: failed to find thermal otpout state
[    8.019189] rockchip-thermal fe710000.tsadc: tsadc is probed successfully!
[    8.030617] hw perfevents: enabled with armv8_cortex_a55 PMU driver, 7 counters available
[    8.031845] kvm [1]: IPA Size Limit: 40 bits
[    8.031917] kvm [1]: GICv3: no GICV resource entry
[    8.031943] kvm [1]: disabling GICv2 emulation
[    8.031963] kvm [1]: GIC system register CPU interface enabled
[    8.039919] kvm [1]: vgic interrupt IRQ9
[    8.049211] kvm [1]: VHE mode initialized successfully
[    8.711850] Initialise system trusted keyrings
[    8.712335] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[    8.727163] NFS: Registering the id_resolver key type
[    8.727283] Key type id_resolver registered
[    8.727311] Key type id_legacy registered
[    8.727493] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    8.727531] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    8.782861] NET: Registered PF_ALG protocol family
[    8.782942] xor: measuring software checksum speed
[    8.789300]    8regs           :  1565 MB/sec
[    8.794527]    32regs          :  1911 MB/sec
[    8.800680]    arm64_neon      :  1621 MB/sec
[    8.800722] xor: using function: 32regs (1911 MB/sec)
[    8.800762] Key type asymmetric registered
[    8.800787] Asymmetric key parser 'x509' registered
[    8.800966] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[    8.801442] io scheduler mq-deadline registered
[    8.801480] io scheduler kyber registered
[    8.816489] naneng-combphy fe830000.phy: Failed to get clk 'refclk': -2
[    8.817418] naneng-combphy fe840000.phy: Failed to get clk 'refclk': -2
[    8.822697] iep: Module initialized.
[    8.833170] dma-pl330 fe530000.dma-controller: Loaded driver for PL330 DMAC-241330
[    8.833232] dma-pl330 fe530000.dma-controller: 	DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    8.837769] dma-pl330 fe550000.dma-controller: Loaded driver for PL330 DMAC-241330
[    8.837832] dma-pl330 fe550000.dma-controller: 	DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    8.840875] arm-scmi firmware:scmi: Failed. SCMI protocol 22 not active.
[    8.841404] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[    8.842902] fe650000.serial: ttyS1 at MMIO 0xfe650000 (irq = 30, base_baud = 1500000) is a 16550A
[    8.844403] fe660000.serial: ttyS2 at MMIO 0xfe660000 (irq = 31, base_baud = 1500000) is a 16550A
[    8.971461] printk: console [ttyS2] enabled
[    8.976196] led_vk2c21_init
[    8.976196] =============================================
[    8.976565] random: crng init done
[    8.998753] brd: module loaded
[    9.010299] loop: module loaded
[    9.011348] rbd: loaded (major 254)
[    9.012246] lkdtm: No crash points registered, enable through debugfs
[    9.019567] spi-nor spi4.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff
[    9.025108] rk_gmac-dwmac fe010000.ethernet: IRQ eth_lpi not found
[    9.026201] rk_gmac-dwmac fe010000.ethernet: supply phy not found, using dummy regulator
[    9.027179] rk_gmac-dwmac fe010000.ethernet: clock input or output? (input).
[    9.027839] rk_gmac-dwmac fe010000.ethernet: TX delay(0x30).
[    9.028364] rk_gmac-dwmac fe010000.ethernet: RX delay(0x10).
[    9.028908] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no).
[    9.029657] rk_gmac-dwmac fe010000.ethernet: clock input from PHY
[    9.030572] rk_gmac-dwmac fe010000.ethernet: init for RGMII
[    9.031784] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[    9.032512] rk_gmac-dwmac fe010000.ethernet: 	DWMAC4/5
[    9.033088] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported
[    9.033809] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported
[    9.034513] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported
[    9.035165] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported
[    9.035993] rk_gmac-dwmac fe010000.ethernet: TSO supported
[    9.036602] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    9.037375] rk_gmac-dwmac fe010000.ethernet: Enabled RFS Flow TC (entries=10)
[    9.038060] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled
[    9.038626] rk_gmac-dwmac fe010000.ethernet: Using 32/32 bits DMA host/device width
[    9.038888] Freeing initrd memory: 15828K
[    9.326991] usbcore: registered new interface driver asix
[    9.327593] usbcore: registered new interface driver cdc_ether
[    9.328219] usbcore: registered new interface driver rndis_host
[    9.328855] usbcore: registered new interface driver cdc_ncm
[    9.329829] VFIO - User Level meta-driver version: 0.3
[    9.335165] naneng-combphy fe830000.phy: No refclk found
[    9.335686] naneng-combphy fe830000.phy: failed to init phy for usb3
[    9.342658] phy phy-fe8a0000.usb2phy.1: illegal mode
[    9.343196] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    9.343737] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    9.344653] xhci-hcd xhci-hcd.0.auto: USB3 root hub has no ports
[    9.345219] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
[    9.346198] xhci-hcd xhci-hcd.0.auto: irq 38, io mem 0xfcc00000
[    9.347495] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[    9.348264] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    9.348931] usb usb1: Product: xHCI Host Controller
[    9.349384] usb usb1: Manufacturer: Linux 6.1.0-1027-rockchip xhci-hcd
[    9.350016] usb usb1: SerialNumber: xhci-hcd.0.auto
[    9.351382] hub 1-0:1.0: USB hub found
[    9.351820] hub 1-0:1.0: 1 port detected
[    9.353274] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    9.353819] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2
[    9.354726] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
[    9.355675] xhci-hcd xhci-hcd.1.auto: irq 39, io mem 0xfd000000
[    9.356582] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    9.357113] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 3
[    9.357833] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[    9.358857] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[    9.359669] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    9.360339] usb usb2: Product: xHCI Host Controller
[    9.360794] usb usb2: Manufacturer: Linux 6.1.0-1027-rockchip xhci-hcd
[    9.361392] usb usb2: SerialNumber: xhci-hcd.1.auto
[    9.362692] hub 2-0:1.0: USB hub found
[    9.363168] hub 2-0:1.0: 1 port detected
[    9.364413] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
[    9.365489] usb usb3: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[    9.366298] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    9.366969] usb usb3: Product: xHCI Host Controller
[    9.367425] usb usb3: Manufacturer: Linux 6.1.0-1027-rockchip xhci-hcd
[    9.368024] usb usb3: SerialNumber: xhci-hcd.1.auto
[    9.369322] hub 3-0:1.0: USB hub found
[    9.369796] hub 3-0:1.0: 1 port detected
[    9.371065] usbcore: registered new interface driver cdc_acm
[    9.371596] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    9.372854] usbcore: registered new interface driver uas
[    9.373501] usbcore: registered new interface driver usb-storage
[    9.375030] mousedev: PS/2 mouse device common for all mice
[    9.377185] i2c_dev: i2c /dev entries driver
[    9.380375] fan53555-regulator 0-001c: FAN53555 Option[12] Rev[15] Detected!
[    9.388748] rk808 0-0020: chip id: 0x8090
[    9.389209] rk808 0-0020: No cache defaults, reading back from HW
[    9.413749] rk808 0-0020: source: on=0x40, off=0x00
[    9.414223] rk808 0-0020: support dcdc3 fb mode:-22, 63
[    9.415099] rk808 0-0020: support pmic reset mode:-22,0
[    9.419325] rk808 0-0020: had get a pinctrl!
[    9.425456] rk808-regulator rk808-regulator: there is no dvs0 gpio
[    9.426146] rk808-regulator rk808-regulator: there is no dvs1 gpio
[    9.449620] rk817-battery: Failed to locate of_node [id: -1]
[    9.450385] rk817-battery rk817-battery: Failed to find matching dt id
[    9.451160] rk817-charger: Failed to locate of_node [id: -1]
[    9.451869] rk817-charger rk817-charger: Failed to find matching dt id
[    9.456870] input: rk805 pwrkey as /devices/platform/fdd40000.i2c/i2c-0/0-0020/rk805-pwrkey/input/input0
[    9.465352] rk808-rtc rk808-rtc: registered as rtc0
[    9.468292] rk808-rtc rk808-rtc: setting system clock to 2017-08-04T09:02:42 UTC (1501837362)
[    9.469159] rk817-codec: Failed to locate of_node [id: -1]
[    9.478300] rockchip-rga fdeb0000.rga: HW Version: 0x03.02
[    9.479441] rockchip-rga fdeb0000.rga: Registered rockchip-rga as /dev/video0
[    9.481339] usbcore: registered new interface driver uvcvideo
[    9.484804] cpu cpu0: bin=0
[    9.485145] cpu cpu0: Failed to get leakage
[    9.489015] cpu cpu0: avs=0
[    9.489616] cpu cpu0: failed to register system monitor
[    9.495187] sdhci: Secure Digital Host Controller Interface driver
[    9.495756] sdhci: Copyright(c) Pierre Ossman
[    9.496176] Synopsys Designware Multimedia Card Interface Driver
[    9.497056] sdhci-pltfm: SDHCI platform and OF driver helper
[    9.497686] dwmmc_rockchip fe2c0000.mmc: No normal pinctrl state
[    9.497695] dwmmc_rockchip fe2b0000.mmc: No normal pinctrl state
[    9.497707] dwmmc_rockchip fe2c0000.mmc: No idle pinctrl state
[    9.497716] dwmmc_rockchip fe2b0000.mmc: No idle pinctrl state
[    9.498107] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.
[    9.498498] dwmmc_rockchip fe2b0000.mmc: IDMAC supports 32-bit address mode.
[    9.498906] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.
[    9.499355] dwmmc_rockchip fe2b0000.mmc: Using internal DMA controller.
[    9.499868] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a
[    9.500480] dwmmc_rockchip fe2b0000.mmc: Version ID is 270a
[    9.501188] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 68,32 bit host data width,256 deep fifo
[    9.501732] ledtrig-cpu: registered to indicate activity on CPUs
[    9.501759] dwmmc_rockchip fe2b0000.mmc: DW MMC controller at irq 69,32 bit host data width,256 deep fifo
[    9.502136] dwmmc_rockchip fe2b0000.mmc: Got CD GPIO
[    9.502872] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
[    9.504215] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    9.506903] cryptodev: driver 1.12 loaded.
[    9.507799] hid: raw HID events driver (C) Jiri Kosina
[    9.508305] dwmmc_rockchip fe2c0000.mmc: allocated mmc-pwrseq
[    9.508826] usbcore: registered new interface driver usbhid
[    9.509096] mmc_host mmc2: card is non-removable.
[    9.510039] usbhid: USB HID core driver
[    9.511429] rockchip-dmc dmc: failed to get the count of devfreq-event in /dmc node
[    9.512131] rockchip-dmc dmc: failed to init opp info
[    9.512586] rockchip-dmc: probe of dmc failed with error -2
[    9.513163] mmc_host mmc1: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[    9.514910] Unable to handle kernel NULL pointer dereference at virtual address 0000000000000254
[    9.515692] Mem abort info:
[    9.515945]   ESR = 0x0000000096000004
[    9.516300]   EC = 0x25: DABT (current EL), IL = 32 bits
[    9.516776]   SET = 0, FnV = 0
[    9.517051]   EA = 0, S1PTW = 0
[    9.517335]   FSC = 0x04: level 0 translation fault
[    9.517769] Data abort info:
[    9.518029]   ISV = 0, ISS = 0x00000004
[    9.518371]   CM = 0, WnR = 0
[    9.518640] user pgtable: 4k pages, 48-bit VAs, pgdp=000000010546a000
[    9.519211] [0000000000000254] pgd=0000000000000000, p4d=0000000000000000
[    9.520476] Internal error: Oops: 0000000096000004 [#1] SMP
[    9.520980] Modules linked in:
[    9.521261] CPU: 3 PID: 1 Comm: swapper/0 Not tainted 6.1.0-1027-rockchip #27
[    9.521897] Hardware name: h96 TVbox 3566 (DT)
[    9.522295] pstate: 60400009 (nZCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[    9.522914] pc : regmap_read+0x20/0x80
[    9.523260] lr : px30_dfi_init+0x90/0x110
[    9.523626] sp : ffff80000803bb00
[    9.523925] x29: ffff80000803bb00 x28: 0000000000000000 x27: ffffb65f6a840104
[    9.524565] x26: ffffb65f6a8b6970 x25: ffff1d360553e278 x24: ffffb65f6a9b800c
[    9.525204] x23: ffff1d36ff037830 x22: ffff1d36ff037830 x21: ffff1d360036c400
[    9.525844] x20: ffff1d360553e380 x19: 0000000000000000 x18: 0000000000000000
[    9.526483] x17: 0000000000000000 x16: 0000000000000000 x15: 000000000000000a
[    9.527120] x14: 0000000000000000 x13: ffffffffffffffff x12: ffffffffffffffff
[    9.527758] x11: 0000000000000001 x10: 00000000000487b1 x9 : ffffb65f6a886670
[    9.528399] x8 : 0101010101010101 x7 : 203a732500667267 x6 : 0000000000000003
[    9.529037] x5 : 0873131067000000 x4 : 0000000080000000 x3 : 0000000000000000
[    9.529674] x2 : ffff80000803bb60 x1 : 0000000000000208 x0 : 0000000000000000
[    9.530315] Call trace:
[    9.530538]  regmap_read+0x20/0x80
[    9.530853]  px30_dfi_init+0x90/0x110
[    9.531189]  rockchip_dfi_probe+0xac/0x110
[    9.531564]  platform_probe+0x70/0xc0
[    9.531898]  really_probe+0x1cc/0x390
[    9.532148] mmc0: SDHCI controller on fe310000.mmc [fe310000.mmc] using ADMA
[    9.532230]  __driver_probe_device+0x13c/0x154
[    9.533250]  driver_probe_device+0x48/0xd0
[    9.533618]  __driver_attach+0x168/0x178
[    9.533974]  bus_for_each_dev+0x78/0xc4
[    9.534320]  driver_attach+0x2c/0x38
[    9.534644]  bus_add_driver+0xf8/0x20c
[    9.534982]  driver_register+0xbc/0xf8
[    9.535326]  __platform_driver_register+0x30/0x3c
[    9.535750]  rockchip_dfi_driver_init+0x24/0x30
[    9.536797]  do_one_initcall+0x84/0x1c4
[    9.537145]  kernel_init_freeable+0x298/0x2a0
[    9.537544]  kernel_init+0x30/0x140
[    9.537863]  ret_from_fork+0x10/0x20
[    9.538190]
[    9.538190] PC: 0xffffb65f693a8aa4:
[    9.538633] 88a4  1a9f17e0 d5384101 f94017e3 f9429c22 eb020063 d2800002 54000080 941f5464
[    9.539379] 88c4  52800000 17fffff8 a94153f3 a8c37bfd d50323bf d65f03c0 aa1e03e9 d503201f
[    9.540122] 88e4  f9410802 b40002c2 b941a802 34000062 6b01005f 54000243 f9404802 b5000202
[    9.540865] 8904  d503233f a9bf7bfd 910003fd f940dc02 b40000e2 f9402c00 d63f0040 12001c00
[    9.541608] 8924  a8c17bfd d50323bf d65f03c0 f940f402 b40000a2 97fff661 17fffff9 52800000
[    9.542351] 8944  d65f03c0 52800020 17fffff6 aa1e03e9 d503201f d503233f a9bc7bfd 910003fd
[    9.543094] 8964  a90153f3 aa0003f3 a9025bf5 2a0103f5 aa0203f6 a90363f7 f9405c00 b5000140
[    9.543836] 8984  f9411660 b5000100 f9406274 3949f660 340000e0 3949f260 34000240 128001f4
[    9.544578] 89a4  14000009 aa1303f4 17fffff9 aa1603e2 2a1503e1 aa1303e0 94000a91 35fffec0
[    9.545324] 89c4  52800014 2a1403e0 a94153f3 a9425bf5 a94363f7 a8c47bfd d50323bf d65f03c0
[    9.546065] 89e4  2a1503e1 aa1303e0 97ffffbc 72001c1f 54000440 f9410a63 aa1403e0 aa1603e2
[    9.546807] 8a04  2a1503e1 d63f0060 2a0003f4 35fffdc0 d000f920 91068000 91010000 b94002d8
[    9.547550] 8a24  b9400800 7100001f 540001ad 97ffef2a b000b097 910022f7 b8606ae0 97ffef2a
[    9.548291] 8a44  72001c1f 540000c0 d2800000 2a1803e3 2a1503e2 aa1303e1 97ffef53 3949f660
[    9.549033] 8a64  35fffb00 b94002c2 2a1503e1 aa1303e0 94000a9b 17ffffd4 12800094 17ffffd2
[    9.550417] 8a84  aa1e03e9 d503201f d503233f a9bd7bfd 910003fd a90153f3 aa0003f3 f90013f5
[    9.551159] 8aa4* b9425400 51000400 6a01001f 54000261 2a0103f4 aa0203f5 f9401e61 f9402660
[    9.551901] 8ac4  d63f0020 2a1403e1 aa1503e2 aa1303e0 97ffff9f 2a0003f4 a9440261 d63f0020
[    9.552643] 8ae4  2a1403e0 a94153f3 f94013f5 a8c37bfd d50323bf d65f03c0 128002b4 17fffff9
[    9.553383] 8b04  aa1e03e9 d503201f d503233f a9bd7bfd 910003fd a90153f3 aa0003f3 d5384100
[    9.554126] 8b24  aa0103f4 f9429c01 f90017e1 d2800001 b9401261 910093e2 f9400260 97ffffd1
[    9.554868] 8b44  350000e0 b9400a62 b94027e1 0a010042 b9400e61 1ac12442 b9000282 d5384101
[    9.555610] 8b64  f94017e3 f9429c22 eb020063 d2800002 54000040 941f53b6 a94153f3 a8c37bfd
[    9.556351] 8b84  d50323bf d65f03c0 aa1e03e9 d503201f d503233f a9bd7bfd 910003fd f9000bf3
[    9.557093] 8ba4  2a0103f3 d5384101 f9429c22 f90017e2 d2800002 910093e1 97ffffd2 35000080
[    9.557837] 8bc4  b94027e0 6a20027f 1a9f17e0 d5384101 f94017e3 f9429c22 eb020063 d2800002
[    9.558579] 8be4  54000040 941f539a f9400bf3 a8c37bfd d50323bf d65f03c0 aa1e03e9 d503201f
[    9.559320] 8c04  d503233f a9bd7bfd 910003fd a90153f3 aa0003f3 d5384100 aa0203f4 f9429c02
[    9.560062] 8c24  f90017e2 d2800002 b9401660 6b01001f 540002a9 b9401260 910093e2 b9401a63
[    9.560803] 8c44  1b030021 f9400260 97ffff8e 350000e0 b9400a61 b94027e2 0a020021 b9400e62
[    9.561545] 8c64  1ac22421 b9000281 d5384101 f94017e3 f9429c22 eb020063 d2800002 54000080
[    9.562286] 8c84  941f5373 128002a0 17fffff8 a94153f3 a8c37bfd d50323bf d65f03c0 aa1e03e9
[    9.563028]
[    9.563028] LR: 0xffffb65f6a886670:
[    9.563472] 6470  a8c57bfd d50323bf d65f03c0 aa1e03e9 d503201f d503233f a9be7bfd 910003fd
[    9.564216] 6490  f9000bf3 aa0103f3 97ffffa7 35000060 52a00021 b9008a61 f9400bf3 a8c27bfd
[    9.564957] 64b0  d50323bf d65f03c0 aa1e03e9 d503201f d503233f a9bc7bfd 910003fd a90153f3
[    9.565699] 64d0  aa0103f3 d5384101 a9025bf5 aa0203f5 91004016 f9429c22 f9001fe2 d2800002
[    9.567085] 64f0  52800001 f9417814 97ac067e f9002e60 b140041f 540001a8 aa1603e0 f0ffee81
[    9.567827] 6510  911dd821 97a3902d f9003e60 aa0003e1 b140041f 54000189 f0fff662 91283c42
[    9.568569] 6530  aa1603e0 97abe3ff d5384101 f9401fe3 f9429c22 eb020063 d2800002 54000400
[    9.569311] 6550  97cbdd40 aa1403e0 f0ffedc1 9129c821 97cbb727 aa0003f4 b50000a0 f0fff662
[    9.570055] 6570  12800241 9128c042 17ffffee 97ad1acf f9003260 aa1403e0 97bcffe8 f9403260
[    9.570797] 6590  b140041f 54fffd28 52806101 9100d3e2 97ac8939 b94037e0 d34d3c01 d35c7400
[    9.571538] 65b0  b9008261 b900b260 d0ffc9c0 913ca000 f9000ea0 52800000 17ffffdc a94153f3
[    9.572280] 65d0  a9425bf5 a8c47bfd d50323bf d65f03c0 aa1e03e9 d503201f d503233f a9bc7bfd
[    9.573022] 65f0  910003fd a90153f3 aa0103f3 d5384101 a9025bf5 aa0203f4 aa0003f5 f9429c22
[    9.573765] 6610  f9001fe2 d2800002 52804001 f9417816 97ac05bb aa0003e1 910042a0 979f4803
[    9.574507] 6630  f9002e60 b140041f 54000448 90ffee81 aa1603e0 913e9021 97cbb6ed b40000a0
[    9.575248] 6650  97ad1a9a f9003a60 b140041f 54000328 f9403a60 9100c3e2 52804101 97ac8906
[    9.575991] 6670* 9100d3e2 f9403a60 52804181 97ac8902 f9003e7f 294603e1 531c7c02 530c7c00
[    9.576733] 6690  d34d3c21 71000c5f 531d0400 2a000020 1a803021 52800020 b9008261 b900b260
[    9.577476] 66b0  d0ffc9c0 913ca000 f9000e80 52800000 d5384101 f9401fe3 f9429c22 eb020063
[    9.578219] 66d0  d2800002 54000040 97cbdcde a94153f3 a9425bf5 a8c47bfd d50323bf d65f03c0
[    9.578961] 66f0  aa1e03e9 d503201f d503233f a9bc7bfd 910003fd a90153f3 aa0103f3 d5384101
[    9.579703] 6710  a9025bf5 aa0203f5 aa0003f4 f9429c22 f9001fe2 d2800002 52804001 f9417816
[    9.580445] 6730  97ac0577 aa0003e1 91004280 979f47bf f9002e60 b140041f 54000308 d0ffeda1
[    9.581186] 6750  aa1603e0 912eb021 97cbb6a9 b40000a0 97ad1a56 f9003660 b140041f 540001e8
[    9.581928] 6770  f9403660 9100d3e2 5280ba01 97ac88c2 b94037e0 f9003e7f d34d3c00 b9008260
[    9.582670] 6790  52800020 b900b260 d0ffc9c0 913ca000 f9000ea0 52800000 d5384101 f9401fe3
[    9.583411] 67b0  f9429c22 eb020063 d2800002 54000040 97cbdca4 a94153f3 a9425bf5 a8c47bfd
[    9.584153] 67d0  d50323bf d65f03c0 aa1e03e9 d503201f d503233f a9bc7bfd 910003fd a90153f3
[    9.584894] 67f0  aa0103f3 d5384101 a9025bf5 aa0203f4 aa0003f5 f9429c22 f9001fe2 d2800002
[    9.585636] 6810  52804001 f9417816 97ac053d aa0003e1 910042a0 979f4785 f9002e60 b140041f
[    9.586378] 6830  540004c8 d0ffeda1 aa1603e0 912eb021 97cbb66f b40000a0 97ad1a1c f9003660
[    9.587120] 6850  b140041f 540003a8 f9403660 52804901 9100c3e2 72a000e1 97ac8887 9100d3e2
[    9.587863]
[    9.587863] SP: 0xffff80000803bb00:
[    9.588305] b900  6a840104 ffffb65f 002d0000 ffff1d36 0803b940 ffff8000 68a32cc4 ffffb65f
[    9.589048] b920  0803b9b0 ffff8000 96000004 00000000 00000254 00000000 69bab070 ffffb65f
[    9.590433] b940  0803b970 ffff8000 69b7c288 ffffb65f 0803b9b0 ffff8000 96000004 00000000
[    9.591176] b960  00000254 00000000 693a8aa4 ffffb65f 0803b9a0 ffff8000 69b7cfdc ffffb65f
[    9.591918] b980  00000000 00000000 0553e380 ffff1d36 0803bb00 ffff8000 ff037830 ffff1d36
[    9.592660] b9a0  0803bae0 ffff8000 68a112e0 ffffb65f 00000000 00000000 00000208 00000000
[    9.593401] b9c0  0803bb60 ffff8000 00000000 00000000 80000000 00000000 67000000 08731310
[    9.594144] b9e0  00000003 00000000 00667267 203a7325 01010101 01010101 6a886670 ffffb65f
[    9.594885] ba00  000487b1 00000000 00000001 00000000 ffffffff ffffffff ffffffff ffffffff
[    9.595628] ba20  00000000 00000000 0000000a 00000000 00000000 00000000 00000000 00000000
[    9.596369] ba40  00000000 00000000 00000000 00000000 0553e380 ffff1d36 0036c400 ffff1d36
[    9.597110] ba60  ff037830 ffff1d36 ff037830 ffff1d36 6a9b800c ffffb65f 0553e278 ffff1d36
[    9.597852] ba80  6a8b6970 ffffb65f 6a840104 ffffb65f 00000000 00000000 0803bb00 ffff8000
[    9.598556] mmc0: Host Software Queue enabled
[    9.598593] baa0  6a886670 ffffb65f
[    9.598614] mmc0: new HS200 MMC card at address 0001
[    9.598985]  0803bb00 ffff8000 693a8aa4 ffffb65f 60400009 00000000
[    9.600312] bac0  0803bb30 ffff8000 6a88664c ffffb65f 6afdcf88 ffffb65f 6a9b800c ffffb65f
[    9.601091] bae0  0803bb00 ffff8000 693a8aa4 ffffb65f 04880a80 ffff1d36 00000000 00000000
[    9.601790] mmcblk0: mmc0:0001 DD4064 58.2 GiB
[    9.601853] bb00* 0803bb30 ffff8000 6a886670 ffffb65f 04880a80 ffff1d36 0553e380 ffff1d36
[    9.603016] bb20  0036c400 ffff1d36 2a33cb00 ed5202de 0803bb70 ffff8000 697da744 ffffb65f
[    9.603781] bb40  04880a80 ffff1d36 0036c400 ffff1d36 0553e380 ffff1d36 0036c410 ffff1d36
[    9.604540] bb60  0553e380 ffff1d36 2a33cb00 ed5202de 0803bbb0 ffff8000 69388a14 ffffb65f
[    9.605317] bb80  00000000 00000000 0036c410 ffff1d36 6b26f690 ffffb65f 6b2e9ad8 ffffb65f
[    9.606092] bba0  00000000 00000000 693889fc ffffb65f 0803bbe0 ffff8000 69385b54 ffffb65f
[    9.606846] bbc0  0036c410 ffff1d36 00000000 00000000 6b26f690 ffffb65f 6b2e9ad8 ffffb65f
[    9.607592] bbe0  0803bc20 ffff8000 69385e54 ffffb65f 0036c410 ffff1d36 6b26f690 ffffb65f
[    9.608335] bc00  6b3f03a8 ffffb65f 0036c410 ffff1d36 00000000 00000000 69385dbc ffffb65f
[    9.609081] bc20  0803bc50 ffff8000 69385eb4 ffffb65f 6b3f0000 ffffb65f 6b26f690 ffffb65f
[    9.610468] bc40  6b3f03a8 ffffb65f 69386294 ffffb65f 0803bc90 ffff8000 69386554 ffffb65f
[    9.611212] bc60  0036c410 ffff1d36 6b26f690 ffffb65f 00000000 00000000 00000000 00000000
[    9.611593] GPT:Primary header thinks Alt. header is not at the end of the disk.
[    9.611953] bc80  6b2048d0 ffffb65f 6b26f690
[    9.611972] GPT:9400319 != 122142719
[    9.612614]  ffffb65f
[    9.612621] GPT:Alternate GPT header not at the end of the disk.
[    9.612626]  0803bcc0
[    9.612631] GPT:9400319 != 122142719
[    9.612639]  ffff8000
[    9.612644] GPT: Use GNU Parted to correct GPT errors.
[    9.612650]  69383410
[    9.612678]  mmcblk0: p1 p2
[    9.613035]  ffffb65f
[    9.613039] bca0  00000000 00000000 6b26f690 ffffb65f 693863ec ffffb65f 00000000 00000000
[    9.613055] bcc0  0803bd10 ffff8000
[    9.615526] mmcblk0boot0: mmc0:0001 DD4064 4.00 MiB
[    9.615724]  6938501c ffffb65f 6b26f690 ffffb65f 0553e200 ffff1d36
[    9.617958] bce0  6b204bc8 ffffb65f 0553e278 ffff1d36 0803bd00 ffff8000 003448c8 ffff1d36
[    9.618707]
[    9.618707] X2: 0xffff80000803bb60:
[    9.619155] b960  00000254 00000000 693a8aa4 ffffb65f 0803b9a0 ffff8000 69b7cfdc ffffb65f
[    9.619907] b980  00000000 00000000 0553e380 ffff1d36 0803bb00 ffff8000 ff037830 ffff1d36
[    9.620649] b9a0  0803bae0 ffff8000 68a112e0 ffffb65f 00000000 00000000 00000208 00000000
[    9.621396] b9c0  0803bb60 ffff8000 00000000 00000000 80000000 00000000 67000000 08731310
[    9.622141] b9e0  00000003 00000000 00667267 203a7325 01010101 01010101 6a886670 ffffb65f
[    9.622267] mmcblk0boot1: mmc0:0001 DD4064 4.00 MiB
[    9.622884] ba00  000487b1 00000000 00000001 00000000 ffffffff ffffffff ffffffff ffffffff
[    9.622902] ba20  00000000 00000000 0000000a 00000000 00000000 00000000 00000000 00000000
[    9.622918] ba40  00000000 00000000 00000000 00000000 0553e380 ffff1d36 0036c400 ffff1d36
[    9.622935] ba60  ff037830 ffff1d36 ff037830 ffff1d36 6a9b800c ffffb65f 0553e278 ffff1d36
[    9.626922] ba80  6a8b6970 ffffb65f 6a840104 ffffb65f 00000000 00000000 0803bb00 ffff8000
[    9.627668] baa0  6a886670 ffffb65f 0803bb00 ffff8000 693a8aa4 ffffb65f 60400009 00000000
[    9.628410] bac0  0803bb30 ffff8000 6a88664c ffffb65f 6afdcf88 ffffb65f 6a9b800c ffffb65f
[    9.629025] mmcblk0rpmb: mmc0:0001 DD4064 16.0 MiB, chardev (236:0)
[    9.629151] bae0  0803bb00 ffff8000 693a8aa4 ffffb65f 04880a80 ffff1d36 00000000 00000000
[    9.630447] bb00  0803bb30 ffff8000 6a886670 ffffb65f 04880a80 ffff1d36 0553e380 ffff1d36
[    9.631191] bb20  0036c400 ffff1d36 2a33cb00 ed5202de 0803bb70 ffff8000 697da744 ffffb65f
[    9.631933] bb40  04880a80 ffff1d36 0036c400 ffff1d36 0553e380 ffff1d36 0036c410 ffff1d36
[    9.632676] bb60* 0553e380 ffff1d36 2a33cb00 ed5202de 0803bbb0 ffff8000 69388a14 ffffb65f
[    9.633419] bb80  00000000 00000000 0036c410 ffff1d36 6b26f690 ffffb65f 6b2e9ad8 ffffb65f
[    9.634162] bba0  00000000 00000000 693889fc ffffb65f 0803bbe0 ffff8000 69385b54 ffffb65f
[    9.634905] bbc0  0036c410 ffff1d36 00000000 00000000 6b26f690 ffffb65f 6b2e9ad8 ffffb65f
[    9.635647] bbe0  0803bc20 ffff8000 69385e54 ffffb65f 0036c410 ffff1d36 6b26f690 ffffb65f
[    9.636389] bc00  6b3f03a8 ffffb65f 0036c410 ffff1d36 00000000 00000000 69385dbc ffffb65f
[    9.637130] bc20  0803bc50 ffff8000 69385eb4 ffffb65f 6b3f0000 ffffb65f 6b26f690 ffffb65f
[    9.637873] bc40  6b3f03a8 ffffb65f 69386294 ffffb65f 0803bc90 ffff8000 69386554 ffffb65f
[    9.638614] bc60  0036c410 ffff1d36 6b26f690 ffffb65f 00000000 00000000 00000000 00000000
[    9.639357] bc80  6b2048d0 ffffb65f 6b26f690 ffffb65f 0803bcc0 ffff8000 69383410 ffffb65f
[    9.640099] bca0  00000000 00000000 6b26f690 ffffb65f 693863ec ffffb65f 00000000 00000000
[    9.640843] bcc0  0803bd10 ffff8000 6938501c ffffb65f 6b26f690 ffffb65f 0553e200 ffff1d36
[    9.641584] bce0  6b204bc8 ffffb65f 0553e278 ffff1d36 0803bd00 ffff8000 003448c8 ffff1d36
[    9.642326] bd00  00b71378 ffff1d36 2a33cb00 ed5202de 0803bd20 ffff8000 693848cc ffffb65f
[    9.643068] bd20  0803bd70 ffff8000 69387100 ffffb65f 6b26f690 ffffb65f 6b2bca60 ffffb65f
[    9.643810] bd40  6b351000 ffffb65f 00000000 00000000 008ff400 ffff1d36 6a9b800c ffffb65f
[    9.644555]
[    9.644555] X9: 0xffffb65f6a886670:
[    9.644998] 6470  a8c57bfd d50323bf d65f03c0 aa1e03e9 d503201f d503233f a9be7bfd 910003fd
[    9.645740] 6490  f9000bf3 aa0103f3 97ffffa7 35000060 52a00021 b9008a61 f9400bf3 a8c27bfd
[    9.647125] 64b0  d50323bf d65f03c0 aa1e03e9 d503201f d503233f a9bc7bfd 910003fd a90153f3
[    9.647867] 64d0  aa0103f3 d5384101 a9025bf5 aa0203f5 91004016 f9429c22 f9001fe2 d2800002
[    9.648609] 64f0  52800001 f9417814 97ac067e f9002e60 b140041f 540001a8 aa1603e0 f0ffee81
[    9.649351] 6510  911dd821 97a3902d f9003e60 aa0003e1 b140041f 54000189 f0fff662 91283c42
[    9.650093] 6530  aa1603e0 97abe3ff d5384101 f9401fe3 f9429c22 eb020063 d2800002 54000400
[    9.650834] 6550  97cbdd40 aa1403e0 f0ffedc1 9129c821 97cbb727 aa0003f4 b50000a0 f0fff662
[    9.651577] 6570  12800241 9128c042 17ffffee 97ad1acf f9003260 aa1403e0 97bcffe8 f9403260
[    9.652319] 6590  b140041f 54fffd28 52806101 9100d3e2 97ac8939 b94037e0 d34d3c01 d35c7400
[    9.653062] 65b0  b9008261 b900b260 d0ffc9c0 913ca000 f9000ea0 52800000 17ffffdc a94153f3
[    9.653804] 65d0  a9425bf5 a8c47bfd d50323bf d65f03c0 aa1e03e9 d503201f d503233f a9bc7bfd
[    9.654546] 65f0  910003fd a90153f3 aa0103f3 d5384101 a9025bf5 aa0203f4 aa0003f5 f9429c22
[    9.655288] 6610  f9001fe2 d2800002 52804001 f9417816 97ac05bb aa0003e1 910042a0 979f4803
[    9.656029] 6630  f9002e60 b140041f 54000448 90ffee81 aa1603e0 913e9021 97cbb6ed b40000a0
[    9.656772] 6650  97ad1a9a f9003a60 b140041f 54000328 f9403a60 9100c3e2 52804101 97ac8906
[    9.657513] 6670* 9100d3e2 f9403a60 52804181 97ac8902 f9003e7f 294603e1 531c7c02 530c7c00
[    9.658255] 6690  d34d3c21 71000c5f 531d0400 2a000020 1a803021 52800020 b9008261 b900b260
[    9.658997] 66b0  d0ffc9c0 913ca000 f9000e80 52800000 d5384101 f9401fe3 f9429c22 eb020063
[    9.659739] 66d0  d2800002 54000040 97cbdcde a94153f3 a9425bf5 a8c47bfd d50323bf d65f03c0
[    9.660480] 66f0  aa1e03e9 d503201f d503233f a9bc7bfd 910003fd a90153f3 aa0103f3 d5384101
[    9.661223] 6710  a9025bf5 aa0203f5 aa0003f4 f9429c22 f9001fe2 d2800002 52804001 f9417816
[    9.661965] 6730  97ac0577 aa0003e1 91004280 979f47bf f9002e60 b140041f 54000308 d0ffeda1
[    9.662707] 6750  aa1603e0 912eb021 97cbb6a9 b40000a0 97ad1a56 f9003660 b140041f 540001e8
[    9.663449] 6770  f9403660 9100d3e2 5280ba01 97ac88c2 b94037e0 f9003e7f d34d3c00 b9008260
[    9.664193] 6790  52800020 b900b260 d0ffc9c0 913ca000 f9000ea0 52800000 d5384101 f9401fe3
[    9.664935] 67b0  f9429c22 eb020063 d2800002 54000040 97cbdca4 a94153f3 a9425bf5 a8c47bfd
[    9.665678] 67d0  d50323bf d65f03c0 aa1e03e9 d503201f d503233f a9bc7bfd 910003fd a90153f3
[    9.667061] 67f0  aa0103f3 d5384101 a9025bf5 aa0203f4 aa0003f5 f9429c22 f9001fe2 d2800002
[    9.667802] 6810  52804001 f9417816 97ac053d aa0003e1 910042a0 979f4785 f9002e60 b140041f
[    9.668544] 6830  540004c8 d0ffeda1 aa1603e0 912eb021 97cbb66f b40000a0 97ad1a1c f9003660
[    9.669286] 6850  b140041f 540003a8 f9403660 52804901 9100c3e2 72a000e1 97ac8887 9100d3e2
[    9.670033]
[    9.670033] X20: 0xffff1d360553e380:
[    9.670485] e180  0553e280 ffff1d36 0553e080 ffff1d36 00000001 00000000 00000000 00000000
[    9.671228] e1a0  6b26f428 ffffb65f 00000000 00000000 00000000 00000000 00000000 00000000
[    9.671969] e1c0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.672712] e1e0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.673453] e200  6a755a6c ffffb65f 00afec00 ffff1d36 0553e108 ffff1d36 00afec28 ffff1d36
[    9.674196] e220  00afec00 ffff1d36 6b204960 ffffb65f 05539980 ffff1d36 00000001 00000003
[    9.674937] e240  00000000 dead4ead ffffffff 00000000 ffffffff ffffffff 0553e258 ffff1d36
[    9.675679] e260  0553e258 ffff1d36 00000000 00000000 00000000 00000000 00344900 ffff1d36
[    9.676421] e280  00344918 ffff1d36 0553e180 ffff1d36 00000001 00000000 00000000 00000000
[    9.677164] e2a0  6b26f690 ffffb65f 00000000 00000000 00000000 00000000 00000000 00000000
[    9.677904] e2c0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.678647] e2e0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.679389] e300  0553e400 ffff1d36 04880a00 ffff1d36 6938b0d0 ffffb65f 6a6b4aa6 ffffb65f
[    9.680130] e320  00000020 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.680871] e340  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.681612] e360  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.682353] e380* 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.683095] e3a0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.683836] e3c0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.684577] e3e0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.685319] e400  0553e500 ffff1d36 0553e300 ffff1d36 6938b0d0 ffffb65f 6a6b4aa6 ffffb65f
[    9.686060] e420  0000001a 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.687453] e440  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.688194] e460  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.688935] e480  33326566 30303030 6966642e 69666420 32656640 30303033 00000030 00000000
[    9.689678] e4a0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.690420] e4c0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.691162] e4e0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.691905] e500  0553e600 ffff1d36 0553e400 ffff1d36 68a8dbe8 ffffb65f 6a5deb68 ffffb65f
[    9.692647] e520  00000018 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.693388] e540  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.694129] e560  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.694871]
[    9.694871] X21: 0xffff1d360036c400:
[    9.695322] c200  0036c1f8 ffff1d36 00000000 00000000 00000000 00000000 00000081 00000000
[    9.696065] c220  00000000 00000002 ffffffff 00000000 00000000 00000000 00000000 00000000
[    9.696807] c240  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.697549] c260  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.698290] c280  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.699034] c2a0  0036c368 ffff1d36 ffffffff 00000000 00000000 00000000 00000000 00000000
[    9.699777] c2c0  0036c370 ffff1d36 0036c2c8 ffff1d36 0036c2c8 ffff1d36 00000000 00000000
[    9.700519] c2e0  00000000 00000000 6b399408 ffffb65f ff0375a8 ffff1d36 ff0375c0 ffff1d36
[    9.701264] c300  00000000 00000000 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff
[    9.702005] c320  0036c320 ffff1d36 0036c320 ffff1d36 00000000 00000000 00000000 00000000
[    9.702747] c340  693884cc ffffb65f 00000000 00000000 00000000 00000000 00000000 00000000
[    9.703489] c360  00000000 00000000 ffffffff 00000000 00000000 00000000 00000000 00000000
[    9.704230] c380  00000001 00000000 00b6e900 ffff1d36 00000000 00000000 00000000 00000000
[    9.704972] c3a0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.705715] c3c0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.707097] c3e0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.707842] c400* 00b6eb80 ffff1d36 ffffffff 00000000 00b6eb80 ffff1d36 0036d418 ffff1d36
[    9.708585] c420  0036c018 ffff1d36 6b204ca8 ffffb65f 008fa980 ffff1d36 6b2044b0 ffffb65f
[    9.709326] c440  00b72b80 ffff1d36 00000003 00000007 6b204ca8 ffffb65f 00b71300 ffff1d36
[    9.710068] c460  00000000 00000000 00000000 00000000 6b204bc8 ffffb65f 6b26f690 ffffb65f
[    9.710809] c480  00000000 00000000 00000000 00000000 002d0000 ffff1d36 00000000 dead4ead
[    9.711550] c4a0  ffffffff 00000000 ffffffff ffffffff 00000000 00000000 0036c4b8 ffff1d36
[    9.712292] c4c0  0036c4b8 ffff1d36 0036c4c8 ffff1d36 0036c4c8 ffff1d36 0036c4d8 ffff1d36
[    9.713034] c4e0  0036c4d8 ffff1d36 0036c4e8 ffff1d36 0036c4e8 ffff1d36 00000001 00000000
[    9.713776] c500  00000000 00000104 00000000 00000000 00000000 dead4ead ffffffff 00000000
[    9.714518] c520  ffffffff ffffffff 0036d528 ffff1d36 0036c128 ffff1d36 ffffffff 00000000
[    9.715259] c540  00000000 dead4ead ffffffff 00000000 ffffffff ffffffff 0036c558 ffff1d36
[    9.716001] c560  0036c558 ffff1d36 00000000 00000000 00000000 00000000 0036c578 ffff1d36
[    9.716743] c580  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.717484] c5a0  69395fb8 ffffb65f fef8b480 ffff1d36 00000000 00000000 00000000 00000000
[    9.718226] c5c0  ffffffe0 0000000f 0036c5c8 ffff1d36 0036c5c8 ffff1d36 693965f0 ffffb65f
[    9.718968] c5e0  00000000 dead4ead ffffffff 00000000 ffffffff ffffffff 0036c5f8 ffff1d36
[    9.719712]
[    9.719712] X22: 0xffff1d36ff037830:
[    9.720162] 7630  ff0378b8 ffff1d36 ff0373a8 ffff1d36 ff010e58 ffff1d36 008fa080 ffff1d36
[    9.720905] 7650  6b26e708 ffffb65f 00a2d080 ffff1d36 00000003 00000003 00000008 00000000
[    9.721648] 7670  00000000 00000000 40736f71 61316566 30303138 00000000 fdd1e7f0 fffffbff
[    9.722391] 7690  0000001b 00000000 fdd12fcc fffffbff ff0376f0 ffff1d36 00000000 00000000
[    9.723133] 76b0  00a2e080 ffff1d36 00000124 00000000 0000001b 00000000 00000000 00000000
[    9.723875] 76d0  00000000 00000000 697c6038 ffffb65f 00000000 00000000 00000000 00000000
[    9.724617] 76f0  fdd1e8cb fffffbff 00000010 00000000 fdd12ff4 fffffbff ff037758 ffff1d36
[    9.725359] 7710  00000000 00000000 00a2e180 ffff1d36 00000124 00000000 00000010 00000000
[    9.726744] 7730  00000000 00000000 00000000 00000000 697c6038 ffffb65f 00000000 00000000
[    9.726781] mmc_host mmc2: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[    9.727485] 7750  00000000 00000000 fdd1e97b fffffbff 00000004 00000000 fdd13010 fffffbff
[    9.729035] 7770  ff0377c0 ffff1d36 00000000 00000000 00a2e280 ffff1d36 00000124 00000000
[    9.729777] 7790  00000004 00000000 00000000 00000000 00000000 00000000 697c6038 ffffb65f
[    9.730519] 77b0  00000000 00000000 00000000 00000000 6a60e7f3 ffffb65f 00000004 00000000
[    9.731260] 77d0  ff037828 ffff1d36 00000000 00000000 00000000 00000000 00a2e380 ffff1d36
[    9.732006] 77f0  00000124 00000000 00000004 00000000 00000000 00000000 00000000 00000000
[    9.732748] 7810  697c6038 ffffb65f 00000000 00000000 00000000 00000000 00736f71 00000000
[    9.733490] 7830* ff037b80 ffff1d36 000000fb 00000000 ff037900 ffff1d36 00000000 00000000
[    9.734232] 7850  6a1bda80 ffffb65f 0036c410 ffff1d36 ff037860 ffff1d36 ff037860 ffff1d36
[    9.734974] 7870  ff037870 ffff1d36 ff037870 ffff1d36 00000001 00000000 ff037910 ffff1d36
[    9.735716] 7890  00000000 00000000 ff010dd8 ffff1d36 00000000 00000000 ff037b88 ffff1d36
[    9.736457] 78b0  00a2e500 ffff1d36 ff037c10 ffff1d36 ff037630 ffff1d36 ff010e58 ffff1d36
[    9.737199] 78d0  008fa080 ffff1d36 6b26e708 ffffb65f 00a2d300 ffff1d36 00000003 00000003
[    9.737942] 78f0  00000008 00000000 00000000 00000000 40696664 33326566 30303030 00000000
[    9.738684] 7910  fdd1e7f0 fffffbff 00000014 00000000 fdd13038 fffffbff ff037978 ffff1d36
[    9.739426] 7930  00000000 00000000 00a2e480 ffff1d36 00000124 00000000 00000014 00000000
[    9.740168] 7950  00000000 00000000 00000000 00000000 697c6038 ffffb65f 00000000 00000000
[    9.740909] 7970  00000000 00000000 fdd1e8cb fffffbff 00000010 00000000 fdd13058 fffffbff
[    9.741652] 7990  ff0379e0 ffff1d36 00000000 00000000 00a2e680 ffff1d36 00000124 00000000
[    9.742393] 79b0  00000010 00000000 00000000 00000000 00000000 00000000 697c6038 ffffb65f
[    9.743774] 79d0  00000000 00000000 00000000 00000000 fdd1ea59 fffffbff 0000000c 00000000
[    9.744516] 79f0  fdd13074 fffffbff ff037a48 ffff1d36 00000000 00000000 00a2e780 ffff1d36
[    9.745259] 7a10  00000124 00000000 0000000c 00000000 00000000 00000000 00000000 00000000
[    9.746002]
[    9.746002] X23: 0xffff1d36ff037830:
[    9.746452] 7630  ff0378b8 ffff1d36 ff0373a8 ffff1d36 ff010e58 ffff1d36 008fa080 ffff1d36
[    9.747194] 7650  6b26e708 ffffb65f 00a2d080 ffff1d36 00000003 00000003 00000008 00000000
[    9.747936] 7670  00000000 00000000 40736f71 61316566 30303138 00000000 fdd1e7f0 fffffbff
[    9.748677] 7690  0000001b 00000000 fdd12fcc fffffbff ff0376f0 ffff1d36 00000000 00000000
[    9.749419] 76b0  00a2e080 ffff1d36 00000124 00000000 0000001b 00000000 00000000 00000000
[    9.750161] 76d0  00000000 00000000 697c6038 ffffb65f 00000000 00000000 00000000 00000000
[    9.750903] 76f0  fdd1e8cb fffffbff 00000010 00000000 fdd12ff4 fffffbff ff037758 ffff1d36
[    9.751644] 7710  00000000 00000000 00a2e180 ffff1d36 00000124 00000000 00000010 00000000
[    9.752386] 7730  00000000 00000000 00000000 00000000 697c6038 ffffb65f 00000000 00000000
[    9.753127] 7750  00000000 00000000 fdd1e97b fffffbff 00000004 00000000 fdd13010 fffffbff
[    9.753868] 7770  ff0377c0 ffff1d36 00000000 00000000 00a2e280 ffff1d36 00000124 00000000
[    9.754610] 7790  00000004 00000000 00000000 00000000 00000000 00000000 697c6038 ffffb65f
[    9.755351] 77b0  00000000 00000000 00000000 00000000 6a60e7f3 ffffb65f 00000004 00000000
[    9.756738] 77d0  ff037828 ffff1d36 00000000 00000000 00000000 00000000 00a2e380 ffff1d36
[    9.757479] 77f0  00000124 00000000 00000004 00000000 00000000 00000000 00000000 00000000
[    9.758219] 7810  697c6038 ffffb65f 00000000 00000000 00000000 00000000 00736f71 00000000
[    9.758961] 7830* ff037b80 ffff1d36 000000fb 00000000 ff037900 ffff1d36 00000000 00000000
[    9.759703] 7850  6a1bda80 ffffb65f 0036c410 ffff1d36 ff037860 ffff1d36 ff037860 ffff1d36
[    9.760446] 7870  ff037870 ffff1d36 ff037870 ffff1d36 00000001 00000000 ff037910 ffff1d36
[    9.761188] 7890  00000000 00000000 ff010dd8 ffff1d36 00000000 00000000 ff037b88 ffff1d36
[    9.761930] 78b0  00a2e500 ffff1d36 ff037c10 ffff1d36 ff037630 ffff1d36 ff010e58 ffff1d36
[    9.762672] 78d0  008fa080 ffff1d36 6b26e708 ffffb65f 00a2d300 ffff1d36 00000003 00000003
[    9.763413] 78f0  00000008 00000000 00000000 00000000 40696664 33326566 30303030 00000000
[    9.764155] 7910  fdd1e7f0 fffffbff 00000014 00000000 fdd13038 fffffbff ff037978 ffff1d36
[    9.764898] 7930  00000000 00000000 00a2e480 ffff1d36 00000124 00000000 00000014 00000000
[    9.765640] 7950  00000000 00000000 00000000 00000000 697c6038 ffffb65f 00000000 00000000
[    9.766381] 7970  00000000 00000000 fdd1e8cb fffffbff 00000010 00000000 fdd13058 fffffbff
[    9.767123] 7990  ff0379e0 ffff1d36 00000000 00000000 00a2e680 ffff1d36 00000124 00000000
[    9.767865] 79b0  00000010 00000000 00000000 00000000 00000000 00000000 697c6038 ffffb65f
[    9.768610] 79d0  00000000 00000000 00000000 00000000 fdd1ea59 fffffbff 0000000c 00000000
[    9.769351] 79f0  fdd13074 fffffbff ff037a48 ffff1d36 00000000 00000000 00a2e780 ffff1d36
[    9.770093] 7a10  00000124 00000000 0000000c 00000000 00000000 00000000 00000000 00000000
[    9.770835]
[    9.770835] X24: 0xffffb65f6a9b800c:
[    9.771284] 7e0c  ffec1214 ffec1248 ffec127c ffec12c4 ffec1418 ffec15a8 ffec15f8 ffec1620
[    9.772026] 7e2c  ffec1ba0 ffec1c18 ffec1f00 ffec1f2c ffec1f60 ffec1f8c ffec1fb8 ffec1fe4
[    9.773406] 7e4c  ffec2104 ffec2180 ffec21d0 ffec2274 ffec22c4 ffec2340 ffec23b8 ffec23f8
[    9.774147] 7e6c  ffec2508 ffec2574 ffec25c4 ffec26c0 ffec26e8 ffec2848 ffec2870 ffec2898
[    9.774891] 7e8c  ffec28c0 ffec28e8 ffec2910 ffec2938 ffec2960 ffec298c ffec29b8 ffec2a0c
[    9.775632] 7eac  ffec2a38 ffec2a60 ffec2a8c ffec2ab4 ffec2adc ffec2b04 ffec2c44 ffec2c70
[    9.776375] 7ecc  ffec2c9c ffec2cc8 ffec2e6c ffec2f28 ffec2f50 ffec2f9c ffec2fc8 fec2f278
[    9.777117] 7eec  ffec2ff0 ffec3024 ffec3050 ffec3138 ffec3164 ffec3288 ffec3368 ffec33c4
[    9.777859] 7f0c  ffec35d0 ffec365c ffec3688 ffec36b4 fece25d4 ffec3a80 ffec3b18 ffec3c84
[    9.778600] 7f2c  ffec3cb0 ffec3ce0 ffec3edc ffec3f08 ffec3f34 ffec3fcc ffec3ff8 ffec4024
[    9.779343] 7f4c  ffec4050 ffec407c ffec40a8 ffec4494 ffec4688 ffec46b8 ffec493c ffec4a80
[    9.780085] 7f6c  ffec4aac ffec4ad8 ffec4bec ffec4c18 ffec4c50 ffec4c7c ffec4ca8 ffec4cd4
[    9.780827] 7f8c  ffec4d00 ffec4d2c ffec4dc4 ffec4df0 ffec4e1c ffec4e44 ffec4e6c ffec4edc
[    9.781569] 7fac  ffec4f2c ffec4f84 ffec4fac ffec4fd4 ffec50f8 ffec5150 ffec5178 ffec51a0
[    9.782311] 7fcc  ffec51f0 ffec5248 ffec6988 ffec8698 ffec8b80 ffec9920 ffec9cf4 ffec9e54
[    9.783052] 7fec  ffec9e80 ffecb4c8 ffecb660 ffecb688 ffecb6bc ffece2a4 ffece2d0 ffece2fc
[    9.783793] 800c* ffece8ec ffece918 ffece94c ffecea2c ffecea58 ffecea84 ffeceab0 ffeceadc
[    9.784535] 802c  ffeceb08 ffeceb34 ffecec50 ffecedec fee4e750 ffecf1e8 ffecf26c ffecf474
[    9.785277] 804c  ffecf5a8 ffecf6c4 ffecf704 ffecfc8c ffecfd6c ffecfd98 ffecfdcc ffecff40
[    9.786019] 806c  ffecffc0 ffed0014 ffed0040 ffed006c ffed0098 ffed00c4 ffed00f0 ffed011c
[    9.787399] 808c  ffed0148 ffed0174 ffed01a0 ffed01cc ffed01f8 ffed0224 ffed0250 ffed027c
[    9.788141] 80ac  ffed02a8 ffed02d4 ffed0300 ffed032c ffed03b0 ffed03dc ffed0408 ffed0434
[    9.788882] 80cc  ffed0460 ffed048c ffed04b8 ffed04e4 ffed0510 ffed053c ffed0f80 ffed1488
[    9.789624] 80ec  ffed19f0 ffed1b44 ffed3374 ffed34fc ffed3550 ffed5948 ffed5e1c ffed6178
[    9.790366] 810c  ffed6844 ffed68cc ffed6ef0 ffed6f3c ffed7024 ffed7138 ffeb9900 ffeb9950
[    9.791108] 812c  ffec3170 ffec31cc ffec31f8 ffec3224 ffec3250 ffec327c ffec32a8 ffec32d4
[    9.791849] 814c  ffec3300 ffec332c ffec3358 ffec33b4 ffec33e0 ffec349c ffe8a954 ffe931dc
[    9.792591] 816c  ffe93218 ffe937ac ffe937e8 ffe94ad0 ffe94efc ffe95738 ffe958ac ffe958ec
[    9.793333] 818c  ffe9612c ffe95af0 ffe963fc ffe9647c ffe969f4 ffe977f8 ffe98a14 ffe99ffc
[    9.794075] 81ac  ffe9a3bc ffe9a440 ffe9acf8 ffe9b78c ffe9bca0 ffe9bcdc ffe9bfd0 ffe9dd3c
[    9.794817] 81cc  ffe9e034 ffe9e184 ffe9e238 ffe9e264 ffe9e2d0 ffe9e400 ffe9e444 ffe9e488
[    9.795559] 81ec  ffe9e5fc ffe9ed04 ffea0cf4 ffea395c ffea5fbc ffea6cd8 ffea6e78 ffea8bc8
[    9.796301]
[    9.796301] X25: 0xffff1d360553e278:
[    9.796752] e078  00344900 ffff1d36 0553e180 ffff1d36 0568b480 ffff1d36 00000001 00000000
[    9.797495] e098  00000000 00000000 6b26f298 ffffb65f 00000000 00000000 00000000 00000000
[    9.798237] e0b8  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.798979] e0d8  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.799720] e0f8  00000000 00000000 6a7543c1 ffffb65f 0553e208 ffff1d36 0553e008 ffff1d36
[    9.800462] e118  00afec28 ffff1d36 00afec00 ffff1d36 6b204960 ffffb65f 05539780 ffff1d36
[    9.801204] e138  00000001 00000007 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff
[    9.801946] e158  0553e158 ffff1d36 0553e158 ffff1d36 00000000 00000000 00000000 00000000
[    9.802688] e178  00344900 ffff1d36 0553e280 ffff1d36 0553e080 ffff1d36 00000001 00000000
[    9.804074] e198  00000000 00000000 6b26f428 ffffb65f 00000000 00000000 00000000 00000000
[    9.804816] e1b8  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.805558] e1d8  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.806299] e1f8  00000000 00000000 6a755a6c ffffb65f 00afec00 ffff1d36 0553e108 ffff1d36
[    9.807041] e218  00afec28 ffff1d36 00afec00 ffff1d36 6b204960 ffffb65f 05539980 ffff1d36
[    9.807784] e238  00000001 00000003 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff
[    9.808526] e258  0553e258 ffff1d36 0553e258 ffff1d36 00000000 00000000 00000000 00000000
[    9.809269] e278* 00344900 ffff1d36 00344918 ffff1d36 0553e180 ffff1d36 00000001 00000000
[    9.810013] e298  00000000 00000000 6b26f690 ffffb65f 00000000 00000000 00000000 00000000
[    9.810758] e2b8  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.811501] e2d8  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.812243] e2f8  00000000 00000000 0553e400 ffff1d36 04880a00 ffff1d36 6938b0d0 ffffb65f
[    9.812985] e318  6a6b4aa6 ffffb65f 00000020 00000000 00000000 00000000 00000000 00000000
[    9.813729] e338  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.814471] e358  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.815213] e378  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.815955] e398  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.817337] e3b8  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.818079] e3d8  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.818820] e3f8  00000000 00000000 0553e500 ffff1d36 0553e300 ffff1d36 6938b0d0 ffffb65f
[    9.819561] e418  6a6b4aa6 ffffb65f 0000001a 00000000 00000000 00000000 00000000 00000000
[    9.820302] e438  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.821044] e458  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.821786]
[    9.821786] X26: 0xffffb65f6a8b6970:
[    9.822234] 6770  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.822977] 6790  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.823718] 67b0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.824461] 67d0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.825202] 67f0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.825944] 6810  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.826689] 6830  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.827431] 6850  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.828174] 6870  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.828915] 6890  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.829657] 68b0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.830398] 68d0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.831139] 68f0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.831881] 6910  00000000 dead4ead ffffffff 00000000 ffffffff ffffffff 6a8b6928 ffffb65f
[    9.832624] 6930  6a8b6928 ffffb65f 00000000 00000000 6a5d22c2 ffffb65f 6a5e6c2f ffffb65f
[    9.834007] 6950  6a5d22c7 ffffb65f 6a74dfcb ffffb65f 6a5d22d0 ffffb65f 6a62ad45 ffffb65f
[    9.834749] 6970* 6a6e853b ffffb65f 6a6b57ac ffffb65f 6a9b74dc ffffb65f 6a9b74f4 ffffb65f
[    9.835491] 6990  6a9b75e0 ffffb65f 6a9b7678 ffffb65f 6a9b76bc ffffb65f 6a9b7924 ffffb65f
[    9.836233] 69b0  6a9b7a24 ffffb65f 6a9b8164 ffffb65f 6a9b82d8 ffffb65f 00000000 00000000
[    9.836975] 69d0  00000000 00000000 00000000 44495555 6362383d 66353165 39392d66 342d6663
[    9.837716] 69f0  2d623238 64313839 3762332d 63663233 35363062 00000030 00000000 00000000
[    9.838460] 6a10  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.839201] 6a30  00000001 00000000 ebf24000 00000000 00f7555c 00000000 00000000 00000000
[    9.839944] 6a50  009d6e00 ffff1d36 00f7555c 00000000 00000000 00000000 009d6d12 ffff1d36
[    9.840686] 6a70  00c30065 ffff1d36 00000000 00000000 00000007 00000007 0086a880 ffff1d36
[    9.841427] 6a90  02e56d20 00000000 0000000b 00000000 00000000 00000000 00000000 00000000
[    9.842168] 6ab0  00000000 00000000 6a842f70 ffffb65f 6a843790 ffffb65f 6a84363c ffffb65f
[    9.842910] 6ad0  6a842fa8 ffffb65f 6a843bf4 ffffb65f 6a8433f0 ffffb65f 6a843110 ffffb65f
[    9.843195] mmc_host mmc2: Bus speed (slot 0) = 150000000Hz (slot req 150000000Hz, actual 150000000HZ div = 0)
[    9.843651] 6af0  6a84300c ffffb65f 00000000 00000000 00000000 00000000 00963e00 ffff1d36
[    9.845271] 6b10  000000d1 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.846012] 6b30  00000001 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.847392] 6b50  00c30000 ffff1d36 009c8000 ffff1d36 00f5a15c 00000000 00000000 00000000
[    9.848134]
[    9.848134] X27: 0xffffb65f6a840104:
[    9.848584] ff04  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.849327] ff24  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.850069] ff44  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.850812] ff64  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.851553] ff84  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.852295] ffa4  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.853037] ffc4  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.853778] ffe4  00000000 00000000 00000000 00000000 00000000 00000000 00000000 aa1e03e9
[    9.854477] dwmmc_rockchip fe2c0000.mmc: Successfully tuned phase to 145
[    9.854518] 0004  d503201f b0005881 52800020 d503233f d50323bf b9000020 d65f03c0 aa1e03e9
[    9.855850] 0024  d503201f b0003d20 52800141 d503233f d50323bf b90c9c01 52800000 d65f03c0
[    9.856593] 0044  aa1e03e9 d503201f b0003d20 52800081 d503233f d50323bf b90c9c01 52800000
[    9.857335] 0064  d65f03c0 aa1e03e9 d503201f 52800000 d503233f d50323bf d65f03c0 aa1e03e9
[    9.857796] mmc2: new ultra high speed SDR104 SDIO card at address 0001
[    9.858077] 0084  d503201f d503233f a9bf7bfd b0005881 910003fd f9000420 f0003c40 91200000
[    9.859401] 00a4  d2801f02 52800001 91002000 97cb2704 52800020 a8c17bfd d50323bf d65f03c0
[    9.860144] 00c4  aa1e03e9 d503201f d503233f f0003c43 a9bf7bfd 91200063 d2801f02 910003fd
[    9.860886] 00e4  52800001 f9008860 91002060 97cb26f4 52800020 a8c17bfd d50323bf d65f03c0
[    9.861633] 0104* aa1e03e9 d503201f 52800000 d503233f d50323bf d65f03c0 aa1e03e9 d503201f
[    9.862375] 0124  d503233f a9bf7bfd b0ffec81 910003fd 912da021 97cb274e 35000080 b0005880
[    9.863119] 0144  52800021 39004001 a8c17bfd d50323bf 52800000 d65f03c0 aa1e03e9 d503201f
[    9.863863] 0164  d503233f a9bc7bfd 910003fd a90153f3 d0000bb3 aa0003f4 91048273 a9025bf5
[    9.864607] 0184  f0000bb5 aa0103f6 9111c2b5 a90363f7 b0ffec97 b0fff158 912dcef7 91126f18
[    9.865349] 01a4  eb15027f 54000103 52800000 a94153f3 a9425bf5 a94363f7 a8c47bfd d50323bf
[    9.866737] 01c4  d65f03c0 b9401260 350000e0 aa1803e1 aa1403e0 97cb2726 34000200 91006273
[    9.867478] 01e4  17fffff0 f9400261 aa1403e0 97899f97 72001c1f 54fffec0 f9400661 aa1603e0
[    9.868220] 0204  d63f0020 34fffec0 aa1403e1 aa1703e0 97cbadd6 17fffff2 f9400260 b0fff141
[    9.868961] 0224  91336021 97cb2712 34fffe80 17ffffec aa1e03e9 d503201f d503233f a9be7bfd
[    9.869704] 0244  910003fd f9000bf3 aa0003f3 b4000480 b0ffed61 9116c821 97cb2705 35000160
[    9.870446] 0264  90fffaa1 52800020 390b6020 f0fffa81 39336020 52800000 f9400bf3 a8c27bfd
[    9.871189] 0284  d50323bf d65f03c0 d0fff621 aa1303e0 913b7821 97cb26f6 350000c0 90fffaa0
[    9.871931] 02a4  390b601f f0fffa80 3933601f 17fffff2 d0fff621 aa1303e0 913a2c21 97cb26ec
[    9.872673] 02c4  350000e0 f0fffa80 52800021 39336001 90fffaa0 390b601f 17ffffe7 aa1303e1
[    9.873414] 02e4  b0ffec80 912e4800 97cbada0 17ffffe2 aa1e03e9 d503201f b4000401 d503233f
[    9.874157]
[    9.874157] X29: 0xffff80000803bb00:
[    9.874608] b900  6a840104 ffffb65f 002d0000 ffff1d36 0803b940 ffff8000 68a32cc4 ffffb65f
[    9.875350] b920  0803b9b0 ffff8000 96000004 00000000 00000254 00000000 69bab070 ffffb65f
[    9.876092] b940  0803b970 ffff8000 69b7c288 ffffb65f 0803b9b0 ffff8000 96000004 00000000
[    9.876835] b960  00000254 00000000 693a8aa4 ffffb65f 0803b9a0 ffff8000 69b7cfdc ffffb65f
[    9.877577] b980  00000000 00000000 0553e380 ffff1d36 0803bb00 ffff8000 ff037830 ffff1d36
[    9.878321] b9a0  0803bae0 ffff8000 68a112e0 ffffb65f 00000000 00000000 00000208 00000000
[    9.879063] b9c0  0803bb60 ffff8000 00000000 00000000 80000000 00000000 67000000 08731310
[    9.879805] b9e0  00000003 00000000 00667267 203a7325 01010101 01010101 6a886670 ffffb65f
[    9.880548] ba00  000487b1 00000000 00000001 00000000 ffffffff ffffffff ffffffff ffffffff
[    9.881291] ba20  00000000 00000000 0000000a 00000000 00000000 00000000 00000000 00000000
[    9.882032] ba40  00000000 00000000 00000000 00000000 0553e380 ffff1d36 0036c400 ffff1d36
[    9.882773] ba60  ff037830 ffff1d36 ff037830 ffff1d36 6a9b800c ffffb65f 0553e278 ffff1d36
[    9.883515] ba80  6a8b6970 ffffb65f 6a840104 ffffb65f 00000000 00000000 0803bb00 ffff8000
[    9.884257] baa0  6a886670 ffffb65f 0803bb00 ffff8000 693a8aa4 ffffb65f 60400009 00000000
[    9.884999] bac0  0803bb30 ffff8000 6a88664c ffffb65f 6afdcf88 ffffb65f 6a9b800c ffffb65f
[    9.885741] bae0  0803bb00 ffff8000 693a8aa4 ffffb65f 04880a80 ffff1d36 00000000 00000000
[    9.886482] bb00* 0803bb30 ffff8000 6a886670 ffffb65f 04880a80 ffff1d36 0553e380 ffff1d36
[    9.887224] bb20  0036c400 ffff1d36 2a33cb00 ed5202de 0803bb70 ffff8000 697da744 ffffb65f
[    9.887965] bb40  04880a80 ffff1d36 0036c400 ffff1d36 0553e380 ffff1d36 0036c410 ffff1d36
[    9.888707] bb60  0553e380 ffff1d36 2a33cb00 ed5202de 0803bbb0 ffff8000 69388a14 ffffb65f
[    9.889450] bb80  00000000 00000000 0036c410 ffff1d36 6b26f690 ffffb65f 6b2e9ad8 ffffb65f
[    9.890192] bba0  00000000 00000000 693889fc ffffb65f 0803bbe0 ffff8000 69385b54 ffffb65f
[    9.890935] bbc0  0036c410 ffff1d36 00000000 00000000 6b26f690 ffffb65f 6b2e9ad8 ffffb65f
[    9.891679] bbe0  0803bc20 ffff8000 69385e54 ffffb65f 0036c410 ffff1d36 6b26f690 ffffb65f
[    9.892423] bc00  6b3f03a8 ffffb65f 0036c410 ffff1d36 00000000 00000000 69385dbc ffffb65f
[    9.893165] bc20  0803bc50 ffff8000 69385eb4 ffffb65f 6b3f0000 ffffb65f 6b26f690 ffffb65f
[    9.893906] bc40  6b3f03a8 ffffb65f 69386294 ffffb65f 0803bc90 ffff8000 69386554 ffffb65f
[    9.894648] bc60  0036c410 ffff1d36 6b26f690 ffffb65f 00000000 00000000 00000000 00000000
[    9.895390] bc80  6b2048d0 ffffb65f 6b26f690 ffffb65f 0803bcc0 ffff8000 69383410 ffffb65f
[    9.896133] bca0  00000000 00000000 6b26f690 ffffb65f 693863ec ffffb65f 00000000 00000000
[    9.896874] bcc0  0803bd10 ffff8000 6938501c ffffb65f 6b26f690 ffffb65f 0553e200 ffff1d36
[    9.897615] bce0  6b204bc8 ffffb65f 0553e278 ffff1d36 0803bd00 ffff8000 003448c8 ffff1d36
[    9.898361] Code: 910003fd a90153f3 aa0003f3 f90013f5 (b9425400)
[    9.898904] ---[ end trace 0000000000000000 ]---
[    9.900207] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[    9.900897] SMP: stopping secondary CPUs
[    9.901251] CPU1: stopping
[    9.901251] CPU0: stopping
[    9.901252] CPU2: stopping
[    9.901258] CPU: 1 PID: 0 Comm: swapper/1 Tainted: G      D            6.1.0-1027-rockchip #27
[    9.901265] Hardware name: h96 TVbox 3566 (DT)
[    9.901269] Call trace:
[    9.901272]  dump_backtrace+0xe4/0x108
[    9.901286]  show_stack+0x20/0x30
[    9.901292]  dump_stack_lvl+0x7c/0xa0
[    9.901301]  dump_stack+0x18/0x34
[    9.901306]  local_cpu_stop+0x4c/0x6c
[    9.901313]  do_handle_IPI+0x180/0x1c4
[    9.901318]  ipi_handler+0x24/0x34
[    9.901322]  handle_percpu_devid_irq+0x70/0x128
[    9.901328]  handle_irq_desc+0x28/0x40
[    9.901334]  generic_handle_domain_irq+0x20/0x2c
[    9.901339]  __gic_handle_irq_from_irqson.isra.0+0x174/0x1c8
[    9.901347]  gic_handle_irq+0x88/0x90
[    9.901352]  call_on_irq_stack+0x24/0x4c
[    9.901357]  do_interrupt_handler+0x88/0xa8
[    9.901364]  el1_interrupt+0x94/0xa4
[    9.901370]  el1h_64_irq_handler+0x18/0x24
[    9.901376]  el1h_64_irq+0x74/0x78
[    9.901381]  arch_cpu_idle+0x18/0x44
[    9.901388]  default_idle_call+0x58/0x78
[    9.901393]  cpuidle_idle_call+0x90/0x17c
[    9.901400]  do_idle+0xc4/0xc8
[    9.901404]  cpu_startup_entry+0x3c/0x40
[    9.901409]  __cpu_disable+0x0/0xc0
[    9.901414]  __secondary_switched+0xb0/0xb4
[    9.901421] CPU: 2 PID: 0 Comm: swapper/2 Tainted: G      D            6.1.0-1027-rockchip #27
[    9.901427] Hardware name: h96 TVbox 3566 (DT)
[    9.901430] Call trace:
[    9.901432]  dump_backtrace+0xe4/0x108
[    9.901440]  show_stack+0x20/0x30
[    9.901445]  dump_stack_lvl+0x7c/0xa0
[    9.901452]  dump_stack+0x18/0x34
[    9.901457]  local_cpu_stop+0x4c/0x6c
[    9.901462]  do_handle_IPI+0x180/0x1c4
[    9.901467]  ipi_handler+0x24/0x34
[    9.901472]  handle_percpu_devid_irq+0x70/0x128
[    9.901477]  handle_irq_desc+0x28/0x40
[    9.901483]  generic_handle_domain_irq+0x20/0x2c
[    9.901488]  __gic_handle_irq_from_irqson.isra.0+0x174/0x1c8
[    9.901494]  gic_handle_irq+0x88/0x90
[    9.901498]  call_on_irq_stack+0x24/0x4c
[    9.901504]  do_interrupt_handler+0x88/0xa8
[    9.901510]  el1_interrupt+0x94/0xa4
[    9.901516]  el1h_64_irq_handler+0x18/0x24
[    9.901523]  el1h_64_irq+0x74/0x78
[    9.901528]  arch_cpu_idle+0x18/0x44
[    9.901534]  default_idle_call+0x58/0x78
[    9.901540]  cpuidle_idle_call+0x90/0x17c
[    9.901545]  do_idle+0xc4/0xc8
[    9.901549]  cpu_startup_entry+0x3c/0x40
[    9.901554]  __cpu_disable+0x0/0xc0
[    9.901559]  __secondary_switched+0xb0/0xb4
[    9.901565] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G      D            6.1.0-1027-rockchip #27
[    9.901572] Hardware name: h96 TVbox 3566 (DT)
[    9.901574] Call trace:
[    9.901576]  dump_backtrace+0xe4/0x108
[    9.901584]  show_stack+0x20/0x30
[    9.901589]  dump_stack_lvl+0x7c/0xa0
[    9.901595]  dump_stack+0x18/0x34
[    9.901601]  local_cpu_stop+0x4c/0x6c
[    9.901605]  do_handle_IPI+0x180/0x1c4
[    9.901610]  ipi_handler+0x24/0x34
[    9.901615]  handle_percpu_devid_irq+0x70/0x128
[    9.901620]  handle_irq_desc+0x28/0x40
[    9.901626]  generic_handle_domain_irq+0x20/0x2c
[    9.901631]  __gic_handle_irq_from_irqson.isra.0+0x174/0x1c8
[    9.901637]  gic_handle_irq+0x88/0x90
[    9.901641]  call_on_irq_stack+0x24/0x4c
[    9.901646]  do_interrupt_handler+0x88/0xa8
[    9.901652]  el1_interrupt+0x94/0xa4
[    9.901659]  el1h_64_irq_handler+0x18/0x24
[    9.901665]  el1h_64_irq+0x74/0x78
[    9.901670]  arch_cpu_idle+0x18/0x44
[    9.901676]  default_idle_call+0x58/0x78
[    9.901681]  cpuidle_idle_call+0x90/0x17c
[    9.901686]  do_idle+0xc4/0xc8
[    9.901690]  cpu_startup_entry+0x3c/0x40
[    9.901697]  kernel_init+0x0/0x140
[    9.901703]  arch_post_acpi_subsys_init+0x0/0x28
[    9.901712]  start_kernel+0x5f0/0x630
[    9.901718]  __primary_switched+0xbc/0xc4
[    9.901729] PMU CRU:
[    9.931976] 00000000: 00006064 00001481 00000000 00000007 00007f00 00000000 00000000 00000000
[    9.932735] 00000020: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.933494] 00000040: 00002063 00001481 00000000 00000007 00007f00 00000000 00000000 00000000
[    9.934253] 00000060: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.935011] 00000080: 00000001 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.935770] 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.936529] 000000c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.937287] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.938046] 00000100: 00000080 0040b71b 00000001 00000001 00000800 00000000 00000001 00000009
[    9.938804] 00000120: 0000050f 0000888b 00000000 00000000 00000000 00000000 00000000 00000000
[    9.939562] 00000140: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.940321] 00000160: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.941079] 00000180: 00000000 00000003 00000000 00000000 00000000 00000000 00000000 00000000
[    9.941838] 000001a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.942596] 000001c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.943354] 000001e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.944112] 00000200: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.944871] 00000220: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.945625] 00000240: 00040020 00000000
[    9.945969] CRU:
[    9.946143] 00000000: 0000104b 00001441 00000000 00000007 00007f00 00000000 00000000 00000000
[    9.946901] 00000020: 00004082 00001441 00000000 00000007 00007f00 00000000 00000000 00000000
[    9.947661] 00000040: 00002064 00001441 00000000 00000007 00007f00 00000000 00000000 00000000
[    9.948419] 00000060: 0000107d 00001443 00000000 00000007 00007f00 00000000 00000000 00000000
[    9.949177] 00000080: 00001032 00001441 00000000 00000000 00000000 00000000 00000000 00000000
[    9.949935] 000000a0: 0000307d 00001442 00000000 00000000 00000000 00000000 00000000 00000000
[    9.950694] 000000c0: 00000455 00000000 00000000 00000000 00640064 00000000 00000000 00000103
[    9.951452] 000000e0: 00000001 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.952211] 00000100: 000080c0 00000000 00008100 00000505 00000505 00000111 00004191 00000011
[    9.952972] 00000120: 00000053 00000100 00000001 00008113 00000000 00008113 00000000 00008113
[    9.953730] 00000140: 00000000 00008113 00000000 00008113 00000000 00008113 00000000 00000013
[    9.954489] 00000160: 00000000 0000000b 00000000 00000010 00001031 00001c32 00002520 00000000
[    9.955247] 00000180: 00000020 00000000 00000310 0000c001 0000c0c0 00003100 00000001 00000000
[    9.956005] 000001a0: 00000001 00000003 00000103 00002100 00000203 00000003 00000000 00000102
[    9.956763] 000001c0: 00000003 00000301 00000021 00001715 0000200b 00000000 0000200b 00000000
[    9.957521] 000001e0: 0000200b 00000000 0000200b 00000000 0000200b 00000000 0000200b 00000000
[    9.958279] 00000200: 0000200b 00000000 0000200b 00000000 0000200b 00000000 00000303 00000203
[    9.959038] 00000220: 00001500 00002022 0000001f 00000302 00000705 00000f0b 0000013b 00000302
[    9.959796] 00000240: 00000f07 00002713 00001f09 00008113 00000000 00003b2f 00000101 00000302
[    9.960554] 00000260: 00000704 0000130f 00001f27 00000000 00000000 00000000 00000000 00000000
[    9.961312] 00000280: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.962070] 000002a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.962828] 000002c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.963585] 000002e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.964343] 00000300: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.965101] 00000320: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000003
[    9.965858] 00000340: 00000000 00000000 00000000 00000000 00000000 00000000 00001003 00000070
[    9.966616] 00000360: 00000000 00000000 00000000 00009000 00000000 00000000 00000000 00000000
[    9.967373] 00000380: 00000000 00000000 00000000 00008000 00000000 00000000 00000000 00000000
[    9.968131] 000003a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.968889] 000003c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.969647] 000003e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.970404] 00000400: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.971162] 00000420: 00000000 00000000 00000002 00000002 00000002 00000000 00000000 00000000
[    9.971920] 00000440: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.972677] 00000460: 00000000 00000000 00000400 00000000 00000000 00000000 00000000 00000000
[    9.973435] 00000480: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.974193] 000004a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.974951] 000004c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.975709] 000004e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.976467] 00000500: 00040020 00000000 00040020 00000000 00040020 00000000 00040020 00000000
[    9.977225] 00000520: 00040020 00000000 00040020 00000000 00040020 00000000 00040020 00000000
[    9.977984] 00000540: 00040020 00000000 00040020 00000000 00000000 00000000 00000000 00000000
[    9.978742] 00000560: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.979496] 00000580: 00000002 00000000
[    9.979840] PMU:
[    9.980010] pwr       0x00a0: 0000007f 00000000 00000003 00000000
[    9.980558] status    0x0098: 0000007f 00000000 0000007f 00000000
[    9.981105] req       0x0050: 00000060 00000000 00000000 00000000
[    9.981652] idle      0x0068: 000001ee 00000000 0000ffff 0000000f
[    9.982198] ack       0x0060: 000001ee 00000000 000001ee 00000000
[    9.982750] rockchip-thermal fe710000.tsadc: channal 0: temperature(44 C)
[    9.983354] rockchip-thermal fe710000.tsadc: channal 1: temperature(45 C)
[    9.983958] THERMAL REGS:
[    9.984201] 00000000: 00000fc0 00010033 00000033 00000000 00000000 00000000 00000000 00000000
[    9.984960] 00000020: 00000870 00000870 00000000 00000000 0000091c 0000091c 00000000 00000000
[    9.985719] 00000040: 000009c4 000009c4 00000000 00000000 00000000 00000000 00000000 00000000
[    9.986481] 00000060: 00000004 00000004 00000656 00000656 00000000 00000000 00000000 00000000
[    9.987235] 00000080: 00000000 00000000
[    9.987580] Kernel Offset: 0x365f60a00000 from 0xffff800008000000
[    9.988122] PHYS_OFFSET: 0xffffe2cb00000000
[    9.988495] CPU features: 0xc0000,001400a4,6200721b
[    9.988930] Memory Limit: none
[    9.989208] cpu cpu0: cur_freq: 1800000000 Hz, volt: 1050000 uV
[    9.989740] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b ]---
@Hqnicolas I build the kernel 6.1(noble) in the github action, and kernel panic, had you solve this problem before?
Edited by mvpwar
U-Boot 2025.01-dirty (Jun 06 2025 - 16:36:43 +0000)Model: h96 TVbox 3566DRAM:  8 GiB (effective 7.7 GiB)PMIC:  RK809 (on=0x40, off=0x00)Core:  323 devices, 31 uclasses, devicetree: separateMMC:   mmc@fe2b0000: 1, mmc@fe2c0000: 2, mmc@fe310000: 0Loading Environment from nowhere... OKIn:    serial@fe660000Out:   serial@fe660000Err:   serial@fe660000Model: h96 TVbox 3566ADC channel 2 value read: 1021setup_boot_mode: Boot mode 0x5242c300Net:   eth0: ethernet@fe010000Hit any key to stop autoboot:  0 Scanning for bootflows in all bootdevsSeq  Method       State   Uclass    Part  Name                      Filename---  -----------  ------  --------  ----  ------------------------  ----------------Scanning global bootmeth 'efi_mgr':Card did not respond to voltage select! : -110Card did not respond to voltage select! : -110** File not found ubootefi.var **Failed to load EFI variables** Unable to write file ubootefi.var **Failed to persist EFI variables** Unable to write file ubootefi.var **Failed to persist EFI variables** Unable to write file ubootefi.var **Failed to persist EFI variables 0  efi_mgr      ready   (none)       0                      ** Booting bootflow '' with efi_mgrLoading Boot0000 'mmc 0' failedEFI boot manager: Cannot load any imageBoot failed (err=-14)Scanning bootdev 'mmc@fe2b0000.bootdev':Card did not respond to voltage select! : -110Scanning bootdev 'mmc@fe310000.bootdev': 1  extlinux     ready   mmc          2  mmc@fe310000.bootdev.part /boot/extlinux/extlinux.conf** Booting bootflow 'mmc@fe310000.bootdev.part_2' with extlinuxU-Boot menu1:	Ubuntu 24.04.2 LTS 6.1.0-1027-rockchip2:	Ubuntu 24.04.2 LTS 6.1.0-1027-rockchip (rescue target)Enter choice: 1:	Ubuntu 24.04.2 LTS 6.1.0-1027-rockchipRetrieving file: /boot/vmlinuz-6.1.0-1027-rockchipRetrieving file: /boot/initrd.img-6.1.0-1027-rockchipappend: root=UUID=8bce15ff-99cf-482b-981d-3b732fcb0650 rootwait rw console=ttyS2,1500000 console=tty1 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memoryRetrieving file: /lib/firmware/6.1.0-1027-rockchip/device-tree/rockchip/rk3566-h96max-v56.dtbSkipping fdtdir /lib/firmware/6.1.0-1027-rockchip/device-tree/ for failure retrieving dts## Flattened Device Tree blob at edecb210  Booting using the fdt blob at 0xedecb210Working FDT set to edecb210  Loading Ramdisk to ebf24000, end ece9955c ... OK  Loading Device Tree to 00000000ebf0d000, end 00000000ebf23bc7 ... OKWorking FDT set to ebf0d000Starting kernel ...[    6.483775] Booting Linux on physical CPU 0x0000000000 [0x412fd050][    6.483821] Linux version 6.1.0-1027-rockchip (root@fv-az975-670) (aarch64-linux-gnu-gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #27 SMP Fri Jun  6 15:35:04 UTC 2025[    6.488694] Machine model: h96 TVbox 3566[    6.490148] efi: UEFI not found.[    6.684612] Zone ranges:[    6.684627]   DMA      [mem 0x0000000000200000-0x00000000ffffffff][    6.684648]   DMA32    empty[    6.684656]   Normal   [mem 0x0000000100000000-0x00000001ffffffff][    6.684667] Movable zone start for each node[    6.684671] Early memory node ranges[    6.684675]   node   0: [mem 0x0000000000200000-0x00000000efffffff][    6.684689]   node   0: [mem 0x0000000100000000-0x00000001ffffffff][    6.684700] Initmem setup node 0 [mem 0x0000000000200000-0x00000001ffffffff][    6.714813] On node 0, zone DMA: 512 pages in unavailable ranges[    6.746933] cma: Reserved 16 MiB at 0x00000000ef000000[    6.747041] psci: probing for conduit method from DT.[    6.747057] psci: PSCIv1.1 detected in firmware.[    6.747067] psci: Using standard PSCI v0.2 function IDs[    6.747075] psci: MIGRATE_INFO_TYPE not supported.[    6.747093] psci: SMC Calling Convention v1.2[    6.747578] percpu: Embedded 29 pages/cpu s80504 r8192 d30088 u118784[    6.747786] Detected VIPT I-cache on CPU0[    6.747881] CPU features: detected: GIC system register CPU interface[    6.747889] CPU features: detected: Virtualization Host Extensions[    6.747908] CPU features: kernel page table isolation forced ON by KASLR[    6.747917] CPU features: detected: Kernel page table isolation (KPTI)[    6.747927] CPU features: detected: Qualcomm erratum 1009, or ARM erratum 1286807, 2441009[    6.747933] CPU features: detected: ARM errata 1165522, 1319367, or 1530923[    6.747941] alternatives: applying boot alternatives[    6.748466] Built 1 zonelists, mobility grouping on.  Total pages: 1999368[    6.748486] Kernel command line: root=UUID=8bce15ff-99cf-482b-981d-3b732fcb0650 rootwait rw console=ttyS2,1500000 console=tty1 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory[    6.748977] Unknown kernel command line parameters "cgroup_enable=memory cgroup_memory=1", will be passed to user space.[    6.751628] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)[    6.752949] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)[    6.752965] mem auto-init: stack:off, heap alloc:off, heap free:off[    6.752975] software IO TLB: area num 4.[    6.795614] software IO TLB: mapped [mem 0x00000000e7f0d000-0x00000000ebf0d000] (64MB)[    6.957563] Memory: 7826628K/8124416K available (17984K kernel code, 3690K rwdata, 12860K rodata, 7616K init, 783K bss, 281404K reserved, 16384K cma-reserved)[    6.957848] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1[    6.957940] ftrace: allocating 73550 entries in 288 pages[    7.175507] ftrace: allocated 288 pages with 2 groups[    7.175725] trace event string verifier disabled[    7.176088] rcu: Hierarchical RCU implementation.[    7.176097] rcu: 	RCU event tracing is enabled.[    7.176102] rcu: 	RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.[    7.176112] 	Rude variant of Tasks RCU enabled.[    7.176116] 	Tracing variant of Tasks RCU enabled.[    7.176121] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.[    7.176128] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4[    7.187430] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0[    7.189226] GICv3: GIC: Using split EOI/Deactivate mode[    7.189238] GICv3: 320 SPIs implemented[    7.189247] GICv3: 0 Extended SPIs implemented[    7.189315] GICv3: MBI range [296:319][    7.189333] GICv3: Using MBI frame 0x00000000fd410000[    7.189389] Root IRQ handler: gic_handle_irq[    7.189413] GICv3: GICv3 features: 16 PPIs[    7.189460] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000[    7.190098] ITS: No ITS available, not enabling LPIs[    7.190183] rcu: srcu_init: Setting srcu_struct sizes based on contention.[    7.193391] rockchip_clk_register_muxgrf: regmap not available[    7.193405] rockchip_clk_register_branches: failed to register clock clk_32k_ioe: -524[    7.299472] arch_timer: cp15 timer(s) running at 24.00MHz (phys).[    7.299504] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns[    7.299521] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns[    7.300681] Console: colour dummy device 80x25[    7.301585] printk: console [tty1] enabled[    7.301658] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)[    7.301703] pid_max: default: 32768 minimum: 301[    7.301901] LSM: Security Framework initializing[    7.302098] AppArmor: AppArmor initialized[    7.302368] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)[    7.302517] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)[    7.306124] cblist_init_generic: Setting adjustable number of callback queues.[    7.306172] cblist_init_generic: Setting shift to 2 and lim to 1.[    7.306425] cblist_init_generic: Setting adjustable number of callback queues.[    7.306462] cblist_init_generic: Setting shift to 2 and lim to 1.[    7.306992] rcu: Hierarchical SRCU implementation.[    7.307022] rcu: 	Max phase no-delay instances is 1000.[    7.309992] EFI services will not be available.[    7.310799] smp: Bringing up secondary CPUs ...[    7.312169] Detected VIPT I-cache on CPU1[    7.312352] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000[    7.312425] CPU1: Booted secondary processor 0x0000000100 [0x412fd050][    7.313938] Detected VIPT I-cache on CPU2[    7.314109] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000[    7.314167] CPU2: Booted secondary processor 0x0000000200 [0x412fd050][    7.315644] Detected VIPT I-cache on CPU3[    7.315812] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000[    7.315867] CPU3: Booted secondary processor 0x0000000300 [0x412fd050][    7.316122] smp: Brought up 1 node, 4 CPUs[    7.316285] SMP: Total of 4 processors activated.[    7.316309] CPU features: detected: 32-bit EL0 Support[    7.316329] CPU features: detected: 32-bit EL1 Support[    7.316353] CPU features: detected: Data cache clean to the PoU not required for I/D coherence[    7.316381] CPU features: detected: Common not Private translations[    7.316402] CPU features: detected: CRC32 instructions[    7.316425] CPU features: detected: RCpc load-acquire (LDAPR)[    7.316446] CPU features: detected: Privileged Access Never[    7.316467] CPU features: detected: RAS Extension Support[    7.316491] CPU features: detected: Speculative Store Bypassing Safe (SSBS)[    7.316641] CPU: All CPU(s) started at EL2[    7.316668] alternatives: applying system-wide alternatives[    7.320933] devtmpfs: initialized[    7.343895] Registered cp15_barrier emulation handler[    7.343966] Registered setend emulation handler[    7.344315] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns[    7.344383] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)[    7.345291] pinctrl core: initialized pinctrl subsystem[    7.346546] DMI not present or invalid.[    7.347699] NET: Registered PF_NETLINK/PF_ROUTE protocol family[    7.349900] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations[    7.350579] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations[    7.351250] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations[    7.351369] audit: initializing netlink subsys (disabled)[    7.351731] audit: type=2000 audit(0.049:1): state=initialized audit_enabled=0 res=1[    7.352604] Registered FIQ tty driver[    7.353476] thermal_sys: Registered thermal governor 'fair_share'[    7.353489] thermal_sys: Registered thermal governor 'step_wise'[    7.353517] thermal_sys: Registered thermal governor 'user_space'[    7.353542] thermal_sys: Registered thermal governor 'power_allocator'[    7.353668] cpuidle: using governor menu[    7.354303] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.[    7.354612] ASID allocator initialised with 32768 entries[    7.375912] platform fe0a0000.hdmi: Fixed dependency cycle(s) with /vop@fe040000/ports/port@0/endpoint@2[    7.398644] rockchip-gpio fdd60000.gpio: probed /pinctrl/gpio@fdd60000[    7.399761] rockchip-gpio fe740000.gpio: probed /pinctrl/gpio@fe740000[    7.400862] rockchip-gpio fe750000.gpio: probed /pinctrl/gpio@fe750000[    7.402019] rockchip-gpio fe760000.gpio: probed /pinctrl/gpio@fe760000[    7.403043] rockchip-gpio fe770000.gpio: probed /pinctrl/gpio@fe770000[    7.403287] rockchip-pinctrl pinctrl: probed pinctrl[    7.405189] platform hdmi-con: Fixed dependency cycle(s) with /hdmi@fe0a0000/ports/port@1/endpoint[    7.414022] KASLR enabled[    7.439086] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages[    7.439136] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page[    7.439164] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages[    7.439187] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page[    7.439211] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages[    7.439234] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page[    7.439259] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages[    7.439280] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page[    7.497382] raid6: neonx8   gen()  1373 MB/s[    7.554282] raid6: neonx4   gen()  1412 MB/s[    7.611216] raid6: neonx2   gen()  1279 MB/s[    7.668140] raid6: neonx1   gen()  1041 MB/s[    7.725024] raid6: int64x8  gen()   352 MB/s[    7.781962] raid6: int64x4  gen()   439 MB/s[    7.838907] raid6: int64x2  gen()   354 MB/s[    7.895823] raid6: int64x1  gen()   308 MB/s[    7.895854] raid6: using algorithm neonx4 gen() 1412 MB/s[    7.952635] raid6: .... xor() 1068 MB/s, rmw enabled[    7.952666] raid6: using neon recovery algorithm[    7.961680] iommu: Default domain type: Translated [    7.961721] iommu: DMA domain TLB invalidation policy: strict mode [    7.962368] SCSI subsystem initialized[    7.962878] usbcore: registered new interface driver usbfs[    7.962985] usbcore: registered new interface driver hub[    7.963074] usbcore: registered new device driver usb[    7.963370] mc: Linux media interface: v0.10[    7.963474] videodev: Linux video capture interface: v2.00[    7.963665] pps_core: LinuxPPS API ver. 1 registered[    7.963693] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti @linux.it>[    7.963754] PTP clock support registered[    7.964693] arm-scmi firmware:scmi: Enabled polling mode TX channel - prot_id:16[    7.964983] arm-scmi firmware:scmi: SCMI Notifications - Core Enabled.[    7.965090] arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0[    7.967955] rockchip-otp fe38c000.nvmem: Failed to get clk 'usr': -2[    7.968000] rockchip-otp: probe of fe38c000.nvmem failed with error -2[    7.968240] Advanced Linux Sound Architecture Driver Initialized.[    7.969406] Bluetooth: Core ver 2.22[    7.969530] NET: Registered PF_BLUETOOTH protocol family[    7.969559] Bluetooth: HCI device and connection manager initialized[    7.969596] Bluetooth: HCI socket layer initialized[    7.969627] Bluetooth: L2CAP socket layer initialized[    7.969675] Bluetooth: SCO socket layer initialized[    7.969734] NetLabel: Initializing[    7.969757] NetLabel:  domain hash size = 128[    7.969777] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO[    7.969913] NetLabel:  unlabeled traffic allowed by default[    7.972752] clocksource: Switched to clocksource arch_sys_counter[    7.973564] VFS: Disk quotas dquot_6.6.0[    7.973674] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)[    7.974764] AppArmor: AppArmor Filesystem Enabled[    7.995841] NET: Registered PF_INET protocol family[    7.996490] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)[    8.006419] tcp_listen_portaddr_hash hash table entries: 4096 (order: 5, 131072 bytes, linear)[    8.006601] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)[    8.006770] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)[    8.007361] TCP bind hash table entries: 65536 (order: 10, 4194304 bytes, linear)[    8.011210] TCP: Hash tables configured (established 65536 bind 65536)[    8.011875] MPTCP token hash table entries: 8192 (order: 6, 393216 bytes, linear)[    8.012342] UDP hash table entries: 4096 (order: 6, 393216 bytes, linear)[    8.012820] UDP-Lite hash table entries: 4096 (order: 6, 393216 bytes, linear)[    8.013530] NET: Registered PF_UNIX/PF_LOCAL protocol family[    8.014503] RPC: Registered named UNIX socket transport module.[    8.014540] RPC: Registered udp transport module.[    8.014563] RPC: Registered tcp transport module.[    8.014583] RPC: Registered tcp NFSv4.1 backchannel transport module.[    8.014964] PCI: CLS 0 bytes, default 64[    8.015963] Trying to unpack rootfs image as initramfs...[    8.017002] rockchip-thermal fe710000.tsadc: Missing tshut mode property, using default (gpio)[    8.017052] rockchip-thermal fe710000.tsadc: Missing tshut-polarity property, using default (low)[    8.017383] rockchip-thermal fe710000.tsadc: failed to find thermal gpio state[    8.017422] rockchip-thermal fe710000.tsadc: failed to find thermal otpout state[    8.019189] rockchip-thermal fe710000.tsadc: tsadc is probed successfully![    8.030617] hw perfevents: enabled with armv8_cortex_a55 PMU driver, 7 counters available[    8.031845] kvm [1]: IPA Size Limit: 40 bits[    8.031917] kvm [1]: GICv3: no GICV resource entry[    8.031943] kvm [1]: disabling GICv2 emulation[    8.031963] kvm [1]: GIC system register CPU interface enabled[    8.039919] kvm [1]: vgic interrupt IRQ9[    8.049211] kvm [1]: VHE mode initialized successfully[    8.711850] Initialise system trusted keyrings[    8.712335] workingset: timestamp_bits=46 max_order=21 bucket_order=0[    8.727163] NFS: Registering the id_resolver key type[    8.727283] Key type id_resolver registered[    8.727311] Key type id_legacy registered[    8.727493] nfs4filelayout_init: NFSv4 File Layout Driver Registering...[    8.727531] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...[    8.782861] NET: Registered PF_ALG protocol family[    8.782942] xor: measuring software checksum speed[    8.789300]    8regs           :  1565 MB/sec[    8.794527]    32regs          :  1911 MB/sec[    8.800680]    arm64_neon      :  1621 MB/sec[    8.800722] xor: using function: 32regs (1911 MB/sec)[    8.800762] Key type asymmetric registered[    8.800787] Asymmetric key parser 'x509' registered[    8.800966] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)[    8.801442] io scheduler mq-deadline registered[    8.801480] io scheduler kyber registered[    8.816489] naneng-combphy fe830000.phy: Failed to get clk 'refclk': -2[    8.817418] naneng-combphy fe840000.phy: Failed to get clk 'refclk': -2[    8.822697] iep: Module initialized.[    8.833170] dma-pl330 fe530000.dma-controller: Loaded driver for PL330 DMAC-241330[    8.833232] dma-pl330 fe530000.dma-controller: 	DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16[    8.837769] dma-pl330 fe550000.dma-controller: Loaded driver for PL330 DMAC-241330[    8.837832] dma-pl330 fe550000.dma-controller: 	DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16[    8.840875] arm-scmi firmware:scmi: Failed. SCMI protocol 22 not active.[    8.841404] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled[    8.842902] fe650000.serial: ttyS1 at MMIO 0xfe650000 (irq = 30, base_baud = 1500000) is a 16550A[    8.844403] fe660000.serial: ttyS2 at MMIO 0xfe660000 (irq = 31, base_baud = 1500000) is a 16550A[    8.971461] printk: console [ttyS2] enabled[    8.976196] led_vk2c21_init[    8.976196] =============================================[    8.976565] random: crng init done[    8.998753] brd: module loaded[    9.010299] loop: module loaded[    9.011348] rbd: loaded (major 254)[    9.012246] lkdtm: No crash points registered, enable through debugfs[    9.019567] spi-nor spi4.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff[    9.025108] rk_gmac-dwmac fe010000.ethernet: IRQ eth_lpi not found[    9.026201] rk_gmac-dwmac fe010000.ethernet: supply phy not found, using dummy regulator[    9.027179] rk_gmac-dwmac fe010000.ethernet: clock input or output? (input).[    9.027839] rk_gmac-dwmac fe010000.ethernet: TX delay(0x30).[    9.028364] rk_gmac-dwmac fe010000.ethernet: RX delay(0x10).[    9.028908] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no).[    9.029657] rk_gmac-dwmac fe010000.ethernet: clock input from PHY[    9.030572] rk_gmac-dwmac fe010000.ethernet: init for RGMII[    9.031784] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51[    9.032512] rk_gmac-dwmac fe010000.ethernet: 	DWMAC4/5[    9.033088] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported[    9.033809] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported[    9.034513] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported[    9.035165] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported[    9.035993] rk_gmac-dwmac fe010000.ethernet: TSO supported[    9.036602] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer[    9.037375] rk_gmac-dwmac fe010000.ethernet: Enabled RFS Flow TC (entries=10)[    9.038060] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled[    9.038626] rk_gmac-dwmac fe010000.ethernet: Using 32/32 bits DMA host/device width[    9.038888] Freeing initrd memory: 15828K[    9.326991] usbcore: registered new interface driver asix[    9.327593] usbcore: registered new interface driver cdc_ether[    9.328219] usbcore: registered new interface driver rndis_host[    9.328855] usbcore: registered new interface driver cdc_ncm[    9.329829] VFIO - User Level meta-driver version: 0.3[    9.335165] naneng-combphy fe830000.phy: No refclk found[    9.335686] naneng-combphy fe830000.phy: failed to init phy for usb3[    9.342658] phy phy-fe8a0000.usb2phy.1: illegal mode[    9.343196] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller[    9.343737] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1[    9.344653] xhci-hcd xhci-hcd.0.auto: USB3 root hub has no ports[    9.345219] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010[    9.346198] xhci-hcd xhci-hcd.0.auto: irq 38, io mem 0xfcc00000[    9.347495] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01[    9.348264] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1[    9.348931] usb usb1: Product: xHCI Host Controller[    9.349384] usb usb1: Manufacturer: Linux 6.1.0-1027-rockchip xhci-hcd[    9.350016] usb usb1: SerialNumber: xhci-hcd.0.auto[    9.351382] hub 1-0:1.0: USB hub found[    9.351820] hub 1-0:1.0: 1 port detected[    9.353274] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller[    9.353819] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2[    9.354726] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010[    9.355675] xhci-hcd xhci-hcd.1.auto: irq 39, io mem 0xfd000000[    9.356582] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller[    9.357113] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 3[    9.357833] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed[    9.358857] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01[    9.359669] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1[    9.360339] usb usb2: Product: xHCI Host Controller[    9.360794] usb usb2: Manufacturer: Linux 6.1.0-1027-rockchip xhci-hcd[    9.361392] usb usb2: SerialNumber: xhci-hcd.1.auto[    9.362692] hub 2-0:1.0: USB hub found[    9.363168] hub 2-0:1.0: 1 port detected[    9.364413] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.[    9.365489] usb usb3: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01[    9.366298] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1[    9.366969] usb usb3: Product: xHCI Host Controller[    9.367425] usb usb3: Manufacturer: Linux 6.1.0-1027-rockchip xhci-hcd[    9.368024] usb usb3: SerialNumber: xhci-hcd.1.auto[    9.369322] hub 3-0:1.0: USB hub found[    9.369796] hub 3-0:1.0: 1 port detected[    9.371065] usbcore: registered new interface driver cdc_acm[    9.371596] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters[    9.372854] usbcore: registered new interface driver uas[    9.373501] usbcore: registered new interface driver usb-storage[    9.375030] mousedev: PS/2 mouse device common for all mice[    9.377185] i2c_dev: i2c /dev entries driver[    9.380375] fan53555-regulator 0-001c: FAN53555 Option[12] Rev[15] Detected![    9.388748] rk808 0-0020: chip id: 0x8090[    9.389209] rk808 0-0020: No cache defaults, reading back from HW[    9.413749] rk808 0-0020: source: on=0x40, off=0x00[    9.414223] rk808 0-0020: support dcdc3 fb mode:-22, 63[    9.415099] rk808 0-0020: support pmic reset mode:-22,0[    9.419325] rk808 0-0020: had get a pinctrl![    9.425456] rk808-regulator rk808-regulator: there is no dvs0 gpio[    9.426146] rk808-regulator rk808-regulator: there is no dvs1 gpio[    9.449620] rk817-battery: Failed to locate of_node [id: -1][    9.450385] rk817-battery rk817-battery: Failed to find matching dt id[    9.451160] rk817-charger: Failed to locate of_node [id: -1][    9.451869] rk817-charger rk817-charger: Failed to find matching dt id[    9.456870] input: rk805 pwrkey as /devices/platform/fdd40000.i2c/i2c-0/0-0020/rk805-pwrkey/input/input0[    9.465352] rk808-rtc rk808-rtc: registered as rtc0[    9.468292] rk808-rtc rk808-rtc: setting system clock to 2017-08-04T09:02:42 UTC (1501837362)[    9.469159] rk817-codec: Failed to locate of_node [id: -1][    9.478300] rockchip-rga fdeb0000.rga: HW Version: 0x03.02[    9.479441] rockchip-rga fdeb0000.rga: Registered rockchip-rga as /dev/video0[    9.481339] usbcore: registered new interface driver uvcvideo[    9.484804] cpu cpu0: bin=0[    9.485145] cpu cpu0: Failed to get leakage[    9.489015] cpu cpu0: avs=0[    9.489616] cpu cpu0: failed to register system monitor[    9.495187] sdhci: Secure Digital Host Controller Interface driver[    9.495756] sdhci: Copyright(c) Pierre Ossman[    9.496176] Synopsys Designware Multimedia Card Interface Driver[    9.497056] sdhci-pltfm: SDHCI platform and OF driver helper[    9.497686] dwmmc_rockchip fe2c0000.mmc: No normal pinctrl state[    9.497695] dwmmc_rockchip fe2b0000.mmc: No normal pinctrl state[    9.497707] dwmmc_rockchip fe2c0000.mmc: No idle pinctrl state[    9.497716] dwmmc_rockchip fe2b0000.mmc: No idle pinctrl state[    9.498107] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.[    9.498498] dwmmc_rockchip fe2b0000.mmc: IDMAC supports 32-bit address mode.[    9.498906] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.[    9.499355] dwmmc_rockchip fe2b0000.mmc: Using internal DMA controller.[    9.499868] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a[    9.500480] dwmmc_rockchip fe2b0000.mmc: Version ID is 270a[    9.501188] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 68,32 bit host data width,256 deep fifo[    9.501732] ledtrig-cpu: registered to indicate activity on CPUs[    9.501759] dwmmc_rockchip fe2b0000.mmc: DW MMC controller at irq 69,32 bit host data width,256 deep fifo[    9.502136] dwmmc_rockchip fe2b0000.mmc: Got CD GPIO[    9.502872] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.[    9.504215] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....[    9.506903] cryptodev: driver 1.12 loaded.[    9.507799] hid: raw HID events driver (C) Jiri Kosina[    9.508305] dwmmc_rockchip fe2c0000.mmc: allocated mmc-pwrseq[    9.508826] usbcore: registered new interface driver usbhid[    9.509096] mmc_host mmc2: card is non-removable.[    9.510039] usbhid: USB HID core driver[    9.511429] rockchip-dmc dmc: failed to get the count of devfreq-event in /dmc node[    9.512131] rockchip-dmc dmc: failed to init opp info[    9.512586] rockchip-dmc: probe of dmc failed with error -2[    9.513163] mmc_host mmc1: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)[    9.514910] Unable to handle kernel NULL pointer dereference at virtual address 0000000000000254[    9.515692] Mem abort info:[    9.515945]   ESR = 0x0000000096000004[    9.516300]   EC = 0x25: DABT (current EL), IL = 32 bits[    9.516776]   SET = 0, FnV = 0[    9.517051]   EA = 0, S1PTW = 0[    9.517335]   FSC = 0x04: level 0 translation fault[    9.517769] Data abort info:[    9.518029]   ISV = 0, ISS = 0x00000004[    9.518371]   CM = 0, WnR = 0[    9.518640] user pgtable: 4k pages, 48-bit VAs, pgdp=000000010546a000[    9.519211] [0000000000000254] pgd=0000000000000000, p4d=0000000000000000[    9.520476] Internal error: Oops: 0000000096000004 [#1] SMP[    9.520980] Modules linked in:[    9.521261] CPU: 3 PID: 1 Comm: swapper/0 Not tainted 6.1.0-1027-rockchip #27[    9.521897] Hardware name: h96 TVbox 3566 (DT)[    9.522295] pstate: 60400009 (nZCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--)[    9.522914] pc : regmap_read+0x20/0x80[    9.523260] lr : px30_dfi_init+0x90/0x110[    9.523626] sp : ffff80000803bb00[    9.523925] x29: ffff80000803bb00 x28: 0000000000000000 x27: ffffb65f6a840104[    9.524565] x26: ffffb65f6a8b6970 x25: ffff1d360553e278 x24: ffffb65f6a9b800c[    9.525204] x23: ffff1d36ff037830 x22: ffff1d36ff037830 x21: ffff1d360036c400[    9.525844] x20: ffff1d360553e380 x19: 0000000000000000 x18: 0000000000000000[    9.526483] x17: 0000000000000000 x16: 0000000000000000 x15: 000000000000000a[    9.527120] x14: 0000000000000000 x13: ffffffffffffffff x12: ffffffffffffffff[    9.527758] x11: 0000000000000001 x10: 00000000000487b1 x9 : ffffb65f6a886670[    9.528399] x8 : 0101010101010101 x7 : 203a732500667267 x6 : 0000000000000003[    9.529037] x5 : 0873131067000000 x4 : 0000000080000000 x3 : 0000000000000000[    9.529674] x2 : ffff80000803bb60 x1 : 0000000000000208 x0 : 0000000000000000[    9.530315] Call trace:[    9.530538]  regmap_read+0x20/0x80[    9.530853]  px30_dfi_init+0x90/0x110[    9.531189]  rockchip_dfi_probe+0xac/0x110[    9.531564]  platform_probe+0x70/0xc0[    9.531898]  really_probe+0x1cc/0x390[    9.532148] mmc0: SDHCI controller on fe310000.mmc [fe310000.mmc] using ADMA[    9.532230]  __driver_probe_device+0x13c/0x154[    9.533250]  driver_probe_device+0x48/0xd0[    9.533618]  __driver_attach+0x168/0x178[    9.533974]  bus_for_each_dev+0x78/0xc4[    9.534320]  driver_attach+0x2c/0x38[    9.534644]  bus_add_driver+0xf8/0x20c[    9.534982]  driver_register+0xbc/0xf8[    9.535326]  __platform_driver_register+0x30/0x3c[    9.535750]  rockchip_dfi_driver_init+0x24/0x30[    9.536797]  do_one_initcall+0x84/0x1c4[    9.537145]  kernel_init_freeable+0x298/0x2a0[    9.537544]  kernel_init+0x30/0x140[    9.537863]  ret_from_fork+0x10/0x20[    9.538190] [    9.538190] PC: 0xffffb65f693a8aa4:[    9.538633] 88a4  1a9f17e0 d5384101 f94017e3 f9429c22 eb020063 d2800002 54000080 941f5464[    9.539379] 88c4  52800000 17fffff8 a94153f3 a8c37bfd d50323bf d65f03c0 aa1e03e9 d503201f[    9.540122] 88e4  f9410802 b40002c2 b941a802 34000062 6b01005f 54000243 f9404802 b5000202[    9.540865] 8904  d503233f a9bf7bfd 910003fd f940dc02 b40000e2 f9402c00 d63f0040 12001c00[    9.541608] 8924  a8c17bfd d50323bf d65f03c0 f940f402 b40000a2 97fff661 17fffff9 52800000[    9.542351] 8944  d65f03c0 52800020 17fffff6 aa1e03e9 d503201f d503233f a9bc7bfd 910003fd[    9.543094] 8964  a90153f3 aa0003f3 a9025bf5 2a0103f5 aa0203f6 a90363f7 f9405c00 b5000140[    9.543836] 8984  f9411660 b5000100 f9406274 3949f660 340000e0 3949f260 34000240 128001f4[    9.544578] 89a4  14000009 aa1303f4 17fffff9 aa1603e2 2a1503e1 aa1303e0 94000a91 35fffec0[    9.545324] 89c4  52800014 2a1403e0 a94153f3 a9425bf5 a94363f7 a8c47bfd d50323bf d65f03c0[    9.546065] 89e4  2a1503e1 aa1303e0 97ffffbc 72001c1f 54000440 f9410a63 aa1403e0 aa1603e2[    9.546807] 8a04  2a1503e1 d63f0060 2a0003f4 35fffdc0 d000f920 91068000 91010000 b94002d8[    9.547550] 8a24  b9400800 7100001f 540001ad 97ffef2a b000b097 910022f7 b8606ae0 97ffef2a[    9.548291] 8a44  72001c1f 540000c0 d2800000 2a1803e3 2a1503e2 aa1303e1 97ffef53 3949f660[    9.549033] 8a64  35fffb00 b94002c2 2a1503e1 aa1303e0 94000a9b 17ffffd4 12800094 17ffffd2[    9.550417] 8a84  aa1e03e9 d503201f d503233f a9bd7bfd 910003fd a90153f3 aa0003f3 f90013f5[    9.551159] 8aa4* b9425400 51000400 6a01001f 54000261 2a0103f4 aa0203f5 f9401e61 f9402660[    9.551901] 8ac4  d63f0020 2a1403e1 aa1503e2 aa1303e0 97ffff9f 2a0003f4 a9440261 d63f0020[    9.552643] 8ae4  2a1403e0 a94153f3 f94013f5 a8c37bfd d50323bf d65f03c0 128002b4 17fffff9[    9.553383] 8b04  aa1e03e9 d503201f d503233f a9bd7bfd 910003fd a90153f3 aa0003f3 d5384100[    9.554126] 8b24  aa0103f4 f9429c01 f90017e1 d2800001 b9401261 910093e2 f9400260 97ffffd1[    9.554868] 8b44  350000e0 b9400a62 b94027e1 0a010042 b9400e61 1ac12442 b9000282 d5384101[    9.555610] 8b64  f94017e3 f9429c22 eb020063 d2800002 54000040 941f53b6 a94153f3 a8c37bfd[    9.556351] 8b84  d50323bf d65f03c0 aa1e03e9 d503201f d503233f a9bd7bfd 910003fd f9000bf3[    9.557093] 8ba4  2a0103f3 d5384101 f9429c22 f90017e2 d2800002 910093e1 97ffffd2 35000080[    9.557837] 8bc4  b94027e0 6a20027f 1a9f17e0 d5384101 f94017e3 f9429c22 eb020063 d2800002[    9.558579] 8be4  54000040 941f539a f9400bf3 a8c37bfd d50323bf d65f03c0 aa1e03e9 d503201f[    9.559320] 8c04  d503233f a9bd7bfd 910003fd a90153f3 aa0003f3 d5384100 aa0203f4 f9429c02[    9.560062] 8c24  f90017e2 d2800002 b9401660 6b01001f 540002a9 b9401260 910093e2 b9401a63[    9.560803] 8c44  1b030021 f9400260 97ffff8e 350000e0 b9400a61 b94027e2 0a020021 b9400e62[    9.561545] 8c64  1ac22421 b9000281 d5384101 f94017e3 f9429c22 eb020063 d2800002 54000080[    9.562286] 8c84  941f5373 128002a0 17fffff8 a94153f3 a8c37bfd d50323bf d65f03c0 aa1e03e9[    9.563028] [    9.563028] LR: 0xffffb65f6a886670:[    9.563472] 6470  a8c57bfd d50323bf d65f03c0 aa1e03e9 d503201f d503233f a9be7bfd 910003fd[    9.564216] 6490  f9000bf3 aa0103f3 97ffffa7 35000060 52a00021 b9008a61 f9400bf3 a8c27bfd[    9.564957] 64b0  d50323bf d65f03c0 aa1e03e9 d503201f d503233f a9bc7bfd 910003fd a90153f3[    9.565699] 64d0  aa0103f3 d5384101 a9025bf5 aa0203f5 91004016 f9429c22 f9001fe2 d2800002[    9.567085] 64f0  52800001 f9417814 97ac067e f9002e60 b140041f 540001a8 aa1603e0 f0ffee81[    9.567827] 6510  911dd821 97a3902d f9003e60 aa0003e1 b140041f 54000189 f0fff662 91283c42[    9.568569] 6530  aa1603e0 97abe3ff d5384101 f9401fe3 f9429c22 eb020063 d2800002 54000400[    9.569311] 6550  97cbdd40 aa1403e0 f0ffedc1 9129c821 97cbb727 aa0003f4 b50000a0 f0fff662[    9.570055] 6570  12800241 9128c042 17ffffee 97ad1acf f9003260 aa1403e0 97bcffe8 f9403260[    9.570797] 6590  b140041f 54fffd28 52806101 9100d3e2 97ac8939 b94037e0 d34d3c01 d35c7400[    9.571538] 65b0  b9008261 b900b260 d0ffc9c0 913ca000 f9000ea0 52800000 17ffffdc a94153f3[    9.572280] 65d0  a9425bf5 a8c47bfd d50323bf d65f03c0 aa1e03e9 d503201f d503233f a9bc7bfd[    9.573022] 65f0  910003fd a90153f3 aa0103f3 d5384101 a9025bf5 aa0203f4 aa0003f5 f9429c22[    9.573765] 6610  f9001fe2 d2800002 52804001 f9417816 97ac05bb aa0003e1 910042a0 979f4803[    9.574507] 6630  f9002e60 b140041f 54000448 90ffee81 aa1603e0 913e9021 97cbb6ed b40000a0[    9.575248] 6650  97ad1a9a f9003a60 b140041f 54000328 f9403a60 9100c3e2 52804101 97ac8906[    9.575991] 6670* 9100d3e2 f9403a60 52804181 97ac8902 f9003e7f 294603e1 531c7c02 530c7c00[    9.576733] 6690  d34d3c21 71000c5f 531d0400 2a000020 1a803021 52800020 b9008261 b900b260[    9.577476] 66b0  d0ffc9c0 913ca000 f9000e80 52800000 d5384101 f9401fe3 f9429c22 eb020063[    9.578219] 66d0  d2800002 54000040 97cbdcde a94153f3 a9425bf5 a8c47bfd d50323bf d65f03c0[    9.578961] 66f0  aa1e03e9 d503201f d503233f a9bc7bfd 910003fd a90153f3 aa0103f3 d5384101[    9.579703] 6710  a9025bf5 aa0203f5 aa0003f4 f9429c22 f9001fe2 d2800002 52804001 f9417816[    9.580445] 6730  97ac0577 aa0003e1 91004280 979f47bf f9002e60 b140041f 54000308 d0ffeda1[    9.581186] 6750  aa1603e0 912eb021 97cbb6a9 b40000a0 97ad1a56 f9003660 b140041f 540001e8[    9.581928] 6770  f9403660 9100d3e2 5280ba01 97ac88c2 b94037e0 f9003e7f d34d3c00 b9008260[    9.582670] 6790  52800020 b900b260 d0ffc9c0 913ca000 f9000ea0 52800000 d5384101 f9401fe3[    9.583411] 67b0  f9429c22 eb020063 d2800002 54000040 97cbdca4 a94153f3 a9425bf5 a8c47bfd[    9.584153] 67d0  d50323bf d65f03c0 aa1e03e9 d503201f d503233f a9bc7bfd 910003fd a90153f3[    9.584894] 67f0  aa0103f3 d5384101 a9025bf5 aa0203f4 aa0003f5 f9429c22 f9001fe2 d2800002[    9.585636] 6810  52804001 f9417816 97ac053d aa0003e1 910042a0 979f4785 f9002e60 b140041f[    9.586378] 6830  540004c8 d0ffeda1 aa1603e0 912eb021 97cbb66f b40000a0 97ad1a1c f9003660[    9.587120] 6850  b140041f 540003a8 f9403660 52804901 9100c3e2 72a000e1 97ac8887 9100d3e2[    9.587863] [    9.587863] SP: 0xffff80000803bb00:[    9.588305] b900  6a840104 ffffb65f 002d0000 ffff1d36 0803b940 ffff8000 68a32cc4 ffffb65f[    9.589048] b920  0803b9b0 ffff8000 96000004 00000000 00000254 00000000 69bab070 ffffb65f[    9.590433] b940  0803b970 ffff8000 69b7c288 ffffb65f 0803b9b0 ffff8000 96000004 00000000[    9.591176] b960  00000254 00000000 693a8aa4 ffffb65f 0803b9a0 ffff8000 69b7cfdc ffffb65f[    9.591918] b980  00000000 00000000 0553e380 ffff1d36 0803bb00 ffff8000 ff037830 ffff1d36[    9.592660] b9a0  0803bae0 ffff8000 68a112e0 ffffb65f 00000000 00000000 00000208 00000000[    9.593401] b9c0  0803bb60 ffff8000 00000000 00000000 80000000 00000000 67000000 08731310[    9.594144] b9e0  00000003 00000000 00667267 203a7325 01010101 01010101 6a886670 ffffb65f[    9.594885] ba00  000487b1 00000000 00000001 00000000 ffffffff ffffffff ffffffff ffffffff[    9.595628] ba20  00000000 00000000 0000000a 00000000 00000000 00000000 00000000 00000000[    9.596369] ba40  00000000 00000000 00000000 00000000 0553e380 ffff1d36 0036c400 ffff1d36[    9.597110] ba60  ff037830 ffff1d36 ff037830 ffff1d36 6a9b800c ffffb65f 0553e278 ffff1d36[    9.597852] ba80  6a8b6970 ffffb65f 6a840104 ffffb65f 00000000 00000000 0803bb00 ffff8000[    9.598556] mmc0: Host Software Queue enabled[    9.598593] baa0  6a886670 ffffb65f[    9.598614] mmc0: new HS200 MMC card at address 0001[    9.598985]  0803bb00 ffff8000 693a8aa4 ffffb65f 60400009 00000000[    9.600312] bac0  0803bb30 ffff8000 6a88664c ffffb65f 6afdcf88 ffffb65f 6a9b800c ffffb65f[    9.601091] bae0  0803bb00 ffff8000 693a8aa4 ffffb65f 04880a80 ffff1d36 00000000 00000000[    9.601790] mmcblk0: mmc0:0001 DD4064 58.2 GiB [    9.601853] bb00* 0803bb30 ffff8000 6a886670 ffffb65f 04880a80 ffff1d36 0553e380 ffff1d36[    9.603016] bb20  0036c400 ffff1d36 2a33cb00 ed5202de 0803bb70 ffff8000 697da744 ffffb65f[    9.603781] bb40  04880a80 ffff1d36 0036c400 ffff1d36 0553e380 ffff1d36 0036c410 ffff1d36[    9.604540] bb60  0553e380 ffff1d36 2a33cb00 ed5202de 0803bbb0 ffff8000 69388a14 ffffb65f[    9.605317] bb80  00000000 00000000 0036c410 ffff1d36 6b26f690 ffffb65f 6b2e9ad8 ffffb65f[    9.606092] bba0  00000000 00000000 693889fc ffffb65f 0803bbe0 ffff8000 69385b54 ffffb65f[    9.606846] bbc0  0036c410 ffff1d36 00000000 00000000 6b26f690 ffffb65f 6b2e9ad8 ffffb65f[    9.607592] bbe0  0803bc20 ffff8000 69385e54 ffffb65f 0036c410 ffff1d36 6b26f690 ffffb65f[    9.608335] bc00  6b3f03a8 ffffb65f 0036c410 ffff1d36 00000000 00000000 69385dbc ffffb65f[    9.609081] bc20  0803bc50 ffff8000 69385eb4 ffffb65f 6b3f0000 ffffb65f 6b26f690 ffffb65f[    9.610468] bc40  6b3f03a8 ffffb65f 69386294 ffffb65f 0803bc90 ffff8000 69386554 ffffb65f[    9.611212] bc60  0036c410 ffff1d36 6b26f690 ffffb65f 00000000 00000000 00000000 00000000[    9.611593] GPT:Primary header thinks Alt. header is not at the end of the disk.[    9.611953] bc80  6b2048d0 ffffb65f 6b26f690[    9.611972] GPT:9400319 != 122142719[    9.612614]  ffffb65f[    9.612621] GPT:Alternate GPT header not at the end of the disk.[    9.612626]  0803bcc0[    9.612631] GPT:9400319 != 122142719[    9.612639]  ffff8000[    9.612644] GPT: Use GNU Parted to correct GPT errors.[    9.612650]  69383410[    9.612678]  mmcblk0: p1 p2[    9.613035]  ffffb65f[    9.613039] bca0  00000000 00000000 6b26f690 ffffb65f 693863ec ffffb65f 00000000 00000000[    9.613055] bcc0  0803bd10 ffff8000[    9.615526] mmcblk0boot0: mmc0:0001 DD4064 4.00 MiB [    9.615724]  6938501c ffffb65f 6b26f690 ffffb65f 0553e200 ffff1d36[    9.617958] bce0  6b204bc8 ffffb65f 0553e278 ffff1d36 0803bd00 ffff8000 003448c8 ffff1d36[    9.618707] [    9.618707] X2: 0xffff80000803bb60:[    9.619155] b960  00000254 00000000 693a8aa4 ffffb65f 0803b9a0 ffff8000 69b7cfdc ffffb65f[    9.619907] b980  00000000 00000000 0553e380 ffff1d36 0803bb00 ffff8000 ff037830 ffff1d36[    9.620649] b9a0  0803bae0 ffff8000 68a112e0 ffffb65f 00000000 00000000 00000208 00000000[    9.621396] b9c0  0803bb60 ffff8000 00000000 00000000 80000000 00000000 67000000 08731310[    9.622141] b9e0  00000003 00000000 00667267 203a7325 01010101 01010101 6a886670 ffffb65f[    9.622267] mmcblk0boot1: mmc0:0001 DD4064 4.00 MiB [    9.622884] ba00  000487b1 00000000 00000001 00000000 ffffffff ffffffff ffffffff ffffffff[    9.622902] ba20  00000000 00000000 0000000a 00000000 00000000 00000000 00000000 00000000[    9.622918] ba40  00000000 00000000 00000000 00000000 0553e380 ffff1d36 0036c400 ffff1d36[    9.622935] ba60  ff037830 ffff1d36 ff037830 ffff1d36 6a9b800c ffffb65f 0553e278 ffff1d36[    9.626922] ba80  6a8b6970 ffffb65f 6a840104 ffffb65f 00000000 00000000 0803bb00 ffff8000[    9.627668] baa0  6a886670 ffffb65f 0803bb00 ffff8000 693a8aa4 ffffb65f 60400009 00000000[    9.628410] bac0  0803bb30 ffff8000 6a88664c ffffb65f 6afdcf88 ffffb65f 6a9b800c ffffb65f[    9.629025] mmcblk0rpmb: mmc0:0001 DD4064 16.0 MiB, chardev (236:0)[    9.629151] bae0  0803bb00 ffff8000 693a8aa4 ffffb65f 04880a80 ffff1d36 00000000 00000000[    9.630447] bb00  0803bb30 ffff8000 6a886670 ffffb65f 04880a80 ffff1d36 0553e380 ffff1d36[    9.631191] bb20  0036c400 ffff1d36 2a33cb00 ed5202de 0803bb70 ffff8000 697da744 ffffb65f[    9.631933] bb40  04880a80 ffff1d36 0036c400 ffff1d36 0553e380 ffff1d36 0036c410 ffff1d36[    9.632676] bb60* 0553e380 ffff1d36 2a33cb00 ed5202de 0803bbb0 ffff8000 69388a14 ffffb65f[    9.633419] bb80  00000000 00000000 0036c410 ffff1d36 6b26f690 ffffb65f 6b2e9ad8 ffffb65f[    9.634162] bba0  00000000 00000000 693889fc ffffb65f 0803bbe0 ffff8000 69385b54 ffffb65f[    9.634905] bbc0  0036c410 ffff1d36 00000000 00000000 6b26f690 ffffb65f 6b2e9ad8 ffffb65f[    9.635647] bbe0  0803bc20 ffff8000 69385e54 ffffb65f 0036c410 ffff1d36 6b26f690 ffffb65f[    9.636389] bc00  6b3f03a8 ffffb65f 0036c410 ffff1d36 00000000 00000000 69385dbc ffffb65f[    9.637130] bc20  0803bc50 ffff8000 69385eb4 ffffb65f 6b3f0000 ffffb65f 6b26f690 ffffb65f[    9.637873] bc40  6b3f03a8 ffffb65f 69386294 ffffb65f 0803bc90 ffff8000 69386554 ffffb65f[    9.638614] bc60  0036c410 ffff1d36 6b26f690 ffffb65f 00000000 00000000 00000000 00000000[    9.639357] bc80  6b2048d0 ffffb65f 6b26f690 ffffb65f 0803bcc0 ffff8000 69383410 ffffb65f[    9.640099] bca0  00000000 00000000 6b26f690 ffffb65f 693863ec ffffb65f 00000000 00000000[    9.640843] bcc0  0803bd10 ffff8000 6938501c ffffb65f 6b26f690 ffffb65f 0553e200 ffff1d36[    9.641584] bce0  6b204bc8 ffffb65f 0553e278 ffff1d36 0803bd00 ffff8000 003448c8 ffff1d36[    9.642326] bd00  00b71378 ffff1d36 2a33cb00 ed5202de 0803bd20 ffff8000 693848cc ffffb65f[    9.643068] bd20  0803bd70 ffff8000 69387100 ffffb65f 6b26f690 ffffb65f 6b2bca60 ffffb65f[    9.643810] bd40  6b351000 ffffb65f 00000000 00000000 008ff400 ffff1d36 6a9b800c ffffb65f[    9.644555] [    9.644555] X9: 0xffffb65f6a886670:[    9.644998] 6470  a8c57bfd d50323bf d65f03c0 aa1e03e9 d503201f d503233f a9be7bfd 910003fd[    9.645740] 6490  f9000bf3 aa0103f3 97ffffa7 35000060 52a00021 b9008a61 f9400bf3 a8c27bfd[    9.647125] 64b0  d50323bf d65f03c0 aa1e03e9 d503201f d503233f a9bc7bfd 910003fd a90153f3[    9.647867] 64d0  aa0103f3 d5384101 a9025bf5 aa0203f5 91004016 f9429c22 f9001fe2 d2800002[    9.648609] 64f0  52800001 f9417814 97ac067e f9002e60 b140041f 540001a8 aa1603e0 f0ffee81[    9.649351] 6510  911dd821 97a3902d f9003e60 aa0003e1 b140041f 54000189 f0fff662 91283c42[    9.650093] 6530  aa1603e0 97abe3ff d5384101 f9401fe3 f9429c22 eb020063 d2800002 54000400[    9.650834] 6550  97cbdd40 aa1403e0 f0ffedc1 9129c821 97cbb727 aa0003f4 b50000a0 f0fff662[    9.651577] 6570  12800241 9128c042 17ffffee 97ad1acf f9003260 aa1403e0 97bcffe8 f9403260[    9.652319] 6590  b140041f 54fffd28 52806101 9100d3e2 97ac8939 b94037e0 d34d3c01 d35c7400[    9.653062] 65b0  b9008261 b900b260 d0ffc9c0 913ca000 f9000ea0 52800000 17ffffdc a94153f3[    9.653804] 65d0  a9425bf5 a8c47bfd d50323bf d65f03c0 aa1e03e9 d503201f d503233f a9bc7bfd[    9.654546] 65f0  910003fd a90153f3 aa0103f3 d5384101 a9025bf5 aa0203f4 aa0003f5 f9429c22[    9.655288] 6610  f9001fe2 d2800002 52804001 f9417816 97ac05bb aa0003e1 910042a0 979f4803[    9.656029] 6630  f9002e60 b140041f 54000448 90ffee81 aa1603e0 913e9021 97cbb6ed b40000a0[    9.656772] 6650  97ad1a9a f9003a60 b140041f 54000328 f9403a60 9100c3e2 52804101 97ac8906[    9.657513] 6670* 9100d3e2 f9403a60 52804181 97ac8902 f9003e7f 294603e1 531c7c02 530c7c00[    9.658255] 6690  d34d3c21 71000c5f 531d0400 2a000020 1a803021 52800020 b9008261 b900b260[    9.658997] 66b0  d0ffc9c0 913ca000 f9000e80 52800000 d5384101 f9401fe3 f9429c22 eb020063[    9.659739] 66d0  d2800002 54000040 97cbdcde a94153f3 a9425bf5 a8c47bfd d50323bf d65f03c0[    9.660480] 66f0  aa1e03e9 d503201f d503233f a9bc7bfd 910003fd a90153f3 aa0103f3 d5384101[    9.661223] 6710  a9025bf5 aa0203f5 aa0003f4 f9429c22 f9001fe2 d2800002 52804001 f9417816[    9.661965] 6730  97ac0577 aa0003e1 91004280 979f47bf f9002e60 b140041f 54000308 d0ffeda1[    9.662707] 6750  aa1603e0 912eb021 97cbb6a9 b40000a0 97ad1a56 f9003660 b140041f 540001e8[    9.663449] 6770  f9403660 9100d3e2 5280ba01 97ac88c2 b94037e0 f9003e7f d34d3c00 b9008260[    9.664193] 6790  52800020 b900b260 d0ffc9c0 913ca000 f9000ea0 52800000 d5384101 f9401fe3[    9.664935] 67b0  f9429c22 eb020063 d2800002 54000040 97cbdca4 a94153f3 a9425bf5 a8c47bfd[    9.665678] 67d0  d50323bf d65f03c0 aa1e03e9 d503201f d503233f a9bc7bfd 910003fd a90153f3[    9.667061] 67f0  aa0103f3 d5384101 a9025bf5 aa0203f4 aa0003f5 f9429c22 f9001fe2 d2800002[    9.667802] 6810  52804001 f9417816 97ac053d aa0003e1 910042a0 979f4785 f9002e60 b140041f[    9.668544] 6830  540004c8 d0ffeda1 aa1603e0 912eb021 97cbb66f b40000a0 97ad1a1c f9003660[    9.669286] 6850  b140041f 540003a8 f9403660 52804901 9100c3e2 72a000e1 97ac8887 9100d3e2[    9.670033] [    9.670033] X20: 0xffff1d360553e380:[    9.670485] e180  0553e280 ffff1d36 0553e080 ffff1d36 00000001 00000000 00000000 00000000[    9.671228] e1a0  6b26f428 ffffb65f 00000000 00000000 00000000 00000000 00000000 00000000[    9.671969] e1c0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.672712] e1e0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.673453] e200  6a755a6c ffffb65f 00afec00 ffff1d36 0553e108 ffff1d36 00afec28 ffff1d36[    9.674196] e220  00afec00 ffff1d36 6b204960 ffffb65f 05539980 ffff1d36 00000001 00000003[    9.674937] e240  00000000 dead4ead ffffffff 00000000 ffffffff ffffffff 0553e258 ffff1d36[    9.675679] e260  0553e258 ffff1d36 00000000 00000000 00000000 00000000 00344900 ffff1d36[    9.676421] e280  00344918 ffff1d36 0553e180 ffff1d36 00000001 00000000 00000000 00000000[    9.677164] e2a0  6b26f690 ffffb65f 00000000 00000000 00000000 00000000 00000000 00000000[    9.677904] e2c0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.678647] e2e0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.679389] e300  0553e400 ffff1d36 04880a00 ffff1d36 6938b0d0 ffffb65f 6a6b4aa6 ffffb65f[    9.680130] e320  00000020 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.680871] e340  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.681612] e360  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.682353] e380* 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.683095] e3a0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.683836] e3c0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.684577] e3e0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.685319] e400  0553e500 ffff1d36 0553e300 ffff1d36 6938b0d0 ffffb65f 6a6b4aa6 ffffb65f[    9.686060] e420  0000001a 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.687453] e440  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.688194] e460  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.688935] e480  33326566 30303030 6966642e 69666420 32656640 30303033 00000030 00000000[    9.689678] e4a0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.690420] e4c0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.691162] e4e0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.691905] e500  0553e600 ffff1d36 0553e400 ffff1d36 68a8dbe8 ffffb65f 6a5deb68 ffffb65f[    9.692647] e520  00000018 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.693388] e540  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.694129] e560  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.694871] [    9.694871] X21: 0xffff1d360036c400:[    9.695322] c200  0036c1f8 ffff1d36 00000000 00000000 00000000 00000000 00000081 00000000[    9.696065] c220  00000000 00000002 ffffffff 00000000 00000000 00000000 00000000 00000000[    9.696807] c240  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.697549] c260  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.698290] c280  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.699034] c2a0  0036c368 ffff1d36 ffffffff 00000000 00000000 00000000 00000000 00000000[    9.699777] c2c0  0036c370 ffff1d36 0036c2c8 ffff1d36 0036c2c8 ffff1d36 00000000 00000000[    9.700519] c2e0  00000000 00000000 6b399408 ffffb65f ff0375a8 ffff1d36 ff0375c0 ffff1d36[    9.701264] c300  00000000 00000000 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff[    9.702005] c320  0036c320 ffff1d36 0036c320 ffff1d36 00000000 00000000 00000000 00000000[    9.702747] c340  693884cc ffffb65f 00000000 00000000 00000000 00000000 00000000 00000000[    9.703489] c360  00000000 00000000 ffffffff 00000000 00000000 00000000 00000000 00000000[    9.704230] c380  00000001 00000000 00b6e900 ffff1d36 00000000 00000000 00000000 00000000[    9.704972] c3a0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.705715] c3c0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.707097] c3e0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.707842] c400* 00b6eb80 ffff1d36 ffffffff 00000000 00b6eb80 ffff1d36 0036d418 ffff1d36[    9.708585] c420  0036c018 ffff1d36 6b204ca8 ffffb65f 008fa980 ffff1d36 6b2044b0 ffffb65f[    9.709326] c440  00b72b80 ffff1d36 00000003 00000007 6b204ca8 ffffb65f 00b71300 ffff1d36[    9.710068] c460  00000000 00000000 00000000 00000000 6b204bc8 ffffb65f 6b26f690 ffffb65f[    9.710809] c480  00000000 00000000 00000000 00000000 002d0000 ffff1d36 00000000 dead4ead[    9.711550] c4a0  ffffffff 00000000 ffffffff ffffffff 00000000 00000000 0036c4b8 ffff1d36[    9.712292] c4c0  0036c4b8 ffff1d36 0036c4c8 ffff1d36 0036c4c8 ffff1d36 0036c4d8 ffff1d36[    9.713034] c4e0  0036c4d8 ffff1d36 0036c4e8 ffff1d36 0036c4e8 ffff1d36 00000001 00000000[    9.713776] c500  00000000 00000104 00000000 00000000 00000000 dead4ead ffffffff 00000000[    9.714518] c520  ffffffff ffffffff 0036d528 ffff1d36 0036c128 ffff1d36 ffffffff 00000000[    9.715259] c540  00000000 dead4ead ffffffff 00000000 ffffffff ffffffff 0036c558 ffff1d36[    9.716001] c560  0036c558 ffff1d36 00000000 00000000 00000000 00000000 0036c578 ffff1d36[    9.716743] c580  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.717484] c5a0  69395fb8 ffffb65f fef8b480 ffff1d36 00000000 00000000 00000000 00000000[    9.718226] c5c0  ffffffe0 0000000f 0036c5c8 ffff1d36 0036c5c8 ffff1d36 693965f0 ffffb65f[    9.718968] c5e0  00000000 dead4ead ffffffff 00000000 ffffffff ffffffff 0036c5f8 ffff1d36[    9.719712] [    9.719712] X22: 0xffff1d36ff037830:[    9.720162] 7630  ff0378b8 ffff1d36 ff0373a8 ffff1d36 ff010e58 ffff1d36 008fa080 ffff1d36[    9.720905] 7650  6b26e708 ffffb65f 00a2d080 ffff1d36 00000003 00000003 00000008 00000000[    9.721648] 7670  00000000 00000000 40736f71 61316566 30303138 00000000 fdd1e7f0 fffffbff[    9.722391] 7690  0000001b 00000000 fdd12fcc fffffbff ff0376f0 ffff1d36 00000000 00000000[    9.723133] 76b0  00a2e080 ffff1d36 00000124 00000000 0000001b 00000000 00000000 00000000[    9.723875] 76d0  00000000 00000000 697c6038 ffffb65f 00000000 00000000 00000000 00000000[    9.724617] 76f0  fdd1e8cb fffffbff 00000010 00000000 fdd12ff4 fffffbff ff037758 ffff1d36[    9.725359] 7710  00000000 00000000 00a2e180 ffff1d36 00000124 00000000 00000010 00000000[    9.726744] 7730  00000000 00000000 00000000 00000000 697c6038 ffffb65f 00000000 00000000[    9.726781] mmc_host mmc2: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)[    9.727485] 7750  00000000 00000000 fdd1e97b fffffbff 00000004 00000000 fdd13010 fffffbff[    9.729035] 7770  ff0377c0 ffff1d36 00000000 00000000 00a2e280 ffff1d36 00000124 00000000[    9.729777] 7790  00000004 00000000 00000000 00000000 00000000 00000000 697c6038 ffffb65f[    9.730519] 77b0  00000000 00000000 00000000 00000000 6a60e7f3 ffffb65f 00000004 00000000[    9.731260] 77d0  ff037828 ffff1d36 00000000 00000000 00000000 00000000 00a2e380 ffff1d36[    9.732006] 77f0  00000124 00000000 00000004 00000000 00000000 00000000 00000000 00000000[    9.732748] 7810  697c6038 ffffb65f 00000000 00000000 00000000 00000000 00736f71 00000000[    9.733490] 7830* ff037b80 ffff1d36 000000fb 00000000 ff037900 ffff1d36 00000000 00000000[    9.734232] 7850  6a1bda80 ffffb65f 0036c410 ffff1d36 ff037860 ffff1d36 ff037860 ffff1d36[    9.734974] 7870  ff037870 ffff1d36 ff037870 ffff1d36 00000001 00000000 ff037910 ffff1d36[    9.735716] 7890  00000000 00000000 ff010dd8 ffff1d36 00000000 00000000 ff037b88 ffff1d36[    9.736457] 78b0  00a2e500 ffff1d36 ff037c10 ffff1d36 ff037630 ffff1d36 ff010e58 ffff1d36[    9.737199] 78d0  008fa080 ffff1d36 6b26e708 ffffb65f 00a2d300 ffff1d36 00000003 00000003[    9.737942] 78f0  00000008 00000000 00000000 00000000 40696664 33326566 30303030 00000000[    9.738684] 7910  fdd1e7f0 fffffbff 00000014 00000000 fdd13038 fffffbff ff037978 ffff1d36[    9.739426] 7930  00000000 00000000 00a2e480 ffff1d36 00000124 00000000 00000014 00000000[    9.740168] 7950  00000000 00000000 00000000 00000000 697c6038 ffffb65f 00000000 00000000[    9.740909] 7970  00000000 00000000 fdd1e8cb fffffbff 00000010 00000000 fdd13058 fffffbff[    9.741652] 7990  ff0379e0 ffff1d36 00000000 00000000 00a2e680 ffff1d36 00000124 00000000[    9.742393] 79b0  00000010 00000000 00000000 00000000 00000000 00000000 697c6038 ffffb65f[    9.743774] 79d0  00000000 00000000 00000000 00000000 fdd1ea59 fffffbff 0000000c 00000000[    9.744516] 79f0  fdd13074 fffffbff ff037a48 ffff1d36 00000000 00000000 00a2e780 ffff1d36[    9.745259] 7a10  00000124 00000000 0000000c 00000000 00000000 00000000 00000000 00000000[    9.746002] [    9.746002] X23: 0xffff1d36ff037830:[    9.746452] 7630  ff0378b8 ffff1d36 ff0373a8 ffff1d36 ff010e58 ffff1d36 008fa080 ffff1d36[    9.747194] 7650  6b26e708 ffffb65f 00a2d080 ffff1d36 00000003 00000003 00000008 00000000[    9.747936] 7670  00000000 00000000 40736f71 61316566 30303138 00000000 fdd1e7f0 fffffbff[    9.748677] 7690  0000001b 00000000 fdd12fcc fffffbff ff0376f0 ffff1d36 00000000 00000000[    9.749419] 76b0  00a2e080 ffff1d36 00000124 00000000 0000001b 00000000 00000000 00000000[    9.750161] 76d0  00000000 00000000 697c6038 ffffb65f 00000000 00000000 00000000 00000000[    9.750903] 76f0  fdd1e8cb fffffbff 00000010 00000000 fdd12ff4 fffffbff ff037758 ffff1d36[    9.751644] 7710  00000000 00000000 00a2e180 ffff1d36 00000124 00000000 00000010 00000000[    9.752386] 7730  00000000 00000000 00000000 00000000 697c6038 ffffb65f 00000000 00000000[    9.753127] 7750  00000000 00000000 fdd1e97b fffffbff 00000004 00000000 fdd13010 fffffbff[    9.753868] 7770  ff0377c0 ffff1d36 00000000 00000000 00a2e280 ffff1d36 00000124 00000000[    9.754610] 7790  00000004 00000000 00000000 00000000 00000000 00000000 697c6038 ffffb65f[    9.755351] 77b0  00000000 00000000 00000000 00000000 6a60e7f3 ffffb65f 00000004 00000000[    9.756738] 77d0  ff037828 ffff1d36 00000000 00000000 00000000 00000000 00a2e380 ffff1d36[    9.757479] 77f0  00000124 00000000 00000004 00000000 00000000 00000000 00000000 00000000[    9.758219] 7810  697c6038 ffffb65f 00000000 00000000 00000000 00000000 00736f71 00000000[    9.758961] 7830* ff037b80 ffff1d36 000000fb 00000000 ff037900 ffff1d36 00000000 00000000[    9.759703] 7850  6a1bda80 ffffb65f 0036c410 ffff1d36 ff037860 ffff1d36 ff037860 ffff1d36[    9.760446] 7870  ff037870 ffff1d36 ff037870 ffff1d36 00000001 00000000 ff037910 ffff1d36[    9.761188] 7890  00000000 00000000 ff010dd8 ffff1d36 00000000 00000000 ff037b88 ffff1d36[    9.761930] 78b0  00a2e500 ffff1d36 ff037c10 ffff1d36 ff037630 ffff1d36 ff010e58 ffff1d36[    9.762672] 78d0  008fa080 ffff1d36 6b26e708 ffffb65f 00a2d300 ffff1d36 00000003 00000003[    9.763413] 78f0  00000008 00000000 00000000 00000000 40696664 33326566 30303030 00000000[    9.764155] 7910  fdd1e7f0 fffffbff 00000014 00000000 fdd13038 fffffbff ff037978 ffff1d36[    9.764898] 7930  00000000 00000000 00a2e480 ffff1d36 00000124 00000000 00000014 00000000[    9.765640] 7950  00000000 00000000 00000000 00000000 697c6038 ffffb65f 00000000 00000000[    9.766381] 7970  00000000 00000000 fdd1e8cb fffffbff 00000010 00000000 fdd13058 fffffbff[    9.767123] 7990  ff0379e0 ffff1d36 00000000 00000000 00a2e680 ffff1d36 00000124 00000000[    9.767865] 79b0  00000010 00000000 00000000 00000000 00000000 00000000 697c6038 ffffb65f[    9.768610] 79d0  00000000 00000000 00000000 00000000 fdd1ea59 fffffbff 0000000c 00000000[    9.769351] 79f0  fdd13074 fffffbff ff037a48 ffff1d36 00000000 00000000 00a2e780 ffff1d36[    9.770093] 7a10  00000124 00000000 0000000c 00000000 00000000 00000000 00000000 00000000[    9.770835] [    9.770835] X24: 0xffffb65f6a9b800c:[    9.771284] 7e0c  ffec1214 ffec1248 ffec127c ffec12c4 ffec1418 ffec15a8 ffec15f8 ffec1620[    9.772026] 7e2c  ffec1ba0 ffec1c18 ffec1f00 ffec1f2c ffec1f60 ffec1f8c ffec1fb8 ffec1fe4[    9.773406] 7e4c  ffec2104 ffec2180 ffec21d0 ffec2274 ffec22c4 ffec2340 ffec23b8 ffec23f8[    9.774147] 7e6c  ffec2508 ffec2574 ffec25c4 ffec26c0 ffec26e8 ffec2848 ffec2870 ffec2898[    9.774891] 7e8c  ffec28c0 ffec28e8 ffec2910 ffec2938 ffec2960 ffec298c ffec29b8 ffec2a0c[    9.775632] 7eac  ffec2a38 ffec2a60 ffec2a8c ffec2ab4 ffec2adc ffec2b04 ffec2c44 ffec2c70[    9.776375] 7ecc  ffec2c9c ffec2cc8 ffec2e6c ffec2f28 ffec2f50 ffec2f9c ffec2fc8 fec2f278[    9.777117] 7eec  ffec2ff0 ffec3024 ffec3050 ffec3138 ffec3164 ffec3288 ffec3368 ffec33c4[    9.777859] 7f0c  ffec35d0 ffec365c ffec3688 ffec36b4 fece25d4 ffec3a80 ffec3b18 ffec3c84[    9.778600] 7f2c  ffec3cb0 ffec3ce0 ffec3edc ffec3f08 ffec3f34 ffec3fcc ffec3ff8 ffec4024[    9.779343] 7f4c  ffec4050 ffec407c ffec40a8 ffec4494 ffec4688 ffec46b8 ffec493c ffec4a80[    9.780085] 7f6c  ffec4aac ffec4ad8 ffec4bec ffec4c18 ffec4c50 ffec4c7c ffec4ca8 ffec4cd4[    9.780827] 7f8c  ffec4d00 ffec4d2c ffec4dc4 ffec4df0 ffec4e1c ffec4e44 ffec4e6c ffec4edc[    9.781569] 7fac  ffec4f2c ffec4f84 ffec4fac ffec4fd4 ffec50f8 ffec5150 ffec5178 ffec51a0[    9.782311] 7fcc  ffec51f0 ffec5248 ffec6988 ffec8698 ffec8b80 ffec9920 ffec9cf4 ffec9e54[    9.783052] 7fec  ffec9e80 ffecb4c8 ffecb660 ffecb688 ffecb6bc ffece2a4 ffece2d0 ffece2fc[    9.783793] 800c* ffece8ec ffece918 ffece94c ffecea2c ffecea58 ffecea84 ffeceab0 ffeceadc[    9.784535] 802c  ffeceb08 ffeceb34 ffecec50 ffecedec fee4e750 ffecf1e8 ffecf26c ffecf474[    9.785277] 804c  ffecf5a8 ffecf6c4 ffecf704 ffecfc8c ffecfd6c ffecfd98 ffecfdcc ffecff40[    9.786019] 806c  ffecffc0 ffed0014 ffed0040 ffed006c ffed0098 ffed00c4 ffed00f0 ffed011c[    9.787399] 808c  ffed0148 ffed0174 ffed01a0 ffed01cc ffed01f8 ffed0224 ffed0250 ffed027c[    9.788141] 80ac  ffed02a8 ffed02d4 ffed0300 ffed032c ffed03b0 ffed03dc ffed0408 ffed0434[    9.788882] 80cc  ffed0460 ffed048c ffed04b8 ffed04e4 ffed0510 ffed053c ffed0f80 ffed1488[    9.789624] 80ec  ffed19f0 ffed1b44 ffed3374 ffed34fc ffed3550 ffed5948 ffed5e1c ffed6178[    9.790366] 810c  ffed6844 ffed68cc ffed6ef0 ffed6f3c ffed7024 ffed7138 ffeb9900 ffeb9950[    9.791108] 812c  ffec3170 ffec31cc ffec31f8 ffec3224 ffec3250 ffec327c ffec32a8 ffec32d4[    9.791849] 814c  ffec3300 ffec332c ffec3358 ffec33b4 ffec33e0 ffec349c ffe8a954 ffe931dc[    9.792591] 816c  ffe93218 ffe937ac ffe937e8 ffe94ad0 ffe94efc ffe95738 ffe958ac ffe958ec[    9.793333] 818c  ffe9612c ffe95af0 ffe963fc ffe9647c ffe969f4 ffe977f8 ffe98a14 ffe99ffc[    9.794075] 81ac  ffe9a3bc ffe9a440 ffe9acf8 ffe9b78c ffe9bca0 ffe9bcdc ffe9bfd0 ffe9dd3c[    9.794817] 81cc  ffe9e034 ffe9e184 ffe9e238 ffe9e264 ffe9e2d0 ffe9e400 ffe9e444 ffe9e488[    9.795559] 81ec  ffe9e5fc ffe9ed04 ffea0cf4 ffea395c ffea5fbc ffea6cd8 ffea6e78 ffea8bc8[    9.796301] [    9.796301] X25: 0xffff1d360553e278:[    9.796752] e078  00344900 ffff1d36 0553e180 ffff1d36 0568b480 ffff1d36 00000001 00000000[    9.797495] e098  00000000 00000000 6b26f298 ffffb65f 00000000 00000000 00000000 00000000[    9.798237] e0b8  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.798979] e0d8  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.799720] e0f8  00000000 00000000 6a7543c1 ffffb65f 0553e208 ffff1d36 0553e008 ffff1d36[    9.800462] e118  00afec28 ffff1d36 00afec00 ffff1d36 6b204960 ffffb65f 05539780 ffff1d36[    9.801204] e138  00000001 00000007 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff[    9.801946] e158  0553e158 ffff1d36 0553e158 ffff1d36 00000000 00000000 00000000 00000000[    9.802688] e178  00344900 ffff1d36 0553e280 ffff1d36 0553e080 ffff1d36 00000001 00000000[    9.804074] e198  00000000 00000000 6b26f428 ffffb65f 00000000 00000000 00000000 00000000[    9.804816] e1b8  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.805558] e1d8  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.806299] e1f8  00000000 00000000 6a755a6c ffffb65f 00afec00 ffff1d36 0553e108 ffff1d36[    9.807041] e218  00afec28 ffff1d36 00afec00 ffff1d36 6b204960 ffffb65f 05539980 ffff1d36[    9.807784] e238  00000001 00000003 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff[    9.808526] e258  0553e258 ffff1d36 0553e258 ffff1d36 00000000 00000000 00000000 00000000[    9.809269] e278* 00344900 ffff1d36 00344918 ffff1d36 0553e180 ffff1d36 00000001 00000000[    9.810013] e298  00000000 00000000 6b26f690 ffffb65f 00000000 00000000 00000000 00000000[    9.810758] e2b8  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.811501] e2d8  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.812243] e2f8  00000000 00000000 0553e400 ffff1d36 04880a00 ffff1d36 6938b0d0 ffffb65f[    9.812985] e318  6a6b4aa6 ffffb65f 00000020 00000000 00000000 00000000 00000000 00000000[    9.813729] e338  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.814471] e358  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.815213] e378  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.815955] e398  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.817337] e3b8  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.818079] e3d8  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.818820] e3f8  00000000 00000000 0553e500 ffff1d36 0553e300 ffff1d36 6938b0d0 ffffb65f[    9.819561] e418  6a6b4aa6 ffffb65f 0000001a 00000000 00000000 00000000 00000000 00000000[    9.820302] e438  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.821044] e458  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.821786] [    9.821786] X26: 0xffffb65f6a8b6970:[    9.822234] 6770  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.822977] 6790  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.823718] 67b0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.824461] 67d0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.825202] 67f0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.825944] 6810  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.826689] 6830  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.827431] 6850  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.828174] 6870  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.828915] 6890  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.829657] 68b0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.830398] 68d0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.831139] 68f0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.831881] 6910  00000000 dead4ead ffffffff 00000000 ffffffff ffffffff 6a8b6928 ffffb65f[    9.832624] 6930  6a8b6928 ffffb65f 00000000 00000000 6a5d22c2 ffffb65f 6a5e6c2f ffffb65f[    9.834007] 6950  6a5d22c7 ffffb65f 6a74dfcb ffffb65f 6a5d22d0 ffffb65f 6a62ad45 ffffb65f[    9.834749] 6970* 6a6e853b ffffb65f 6a6b57ac ffffb65f 6a9b74dc ffffb65f 6a9b74f4 ffffb65f[    9.835491] 6990  6a9b75e0 ffffb65f 6a9b7678 ffffb65f 6a9b76bc ffffb65f 6a9b7924 ffffb65f[    9.836233] 69b0  6a9b7a24 ffffb65f 6a9b8164 ffffb65f 6a9b82d8 ffffb65f 00000000 00000000[    9.836975] 69d0  00000000 00000000 00000000 44495555 6362383d 66353165 39392d66 342d6663[    9.837716] 69f0  2d623238 64313839 3762332d 63663233 35363062 00000030 00000000 00000000[    9.838460] 6a10  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.839201] 6a30  00000001 00000000 ebf24000 00000000 00f7555c 00000000 00000000 00000000[    9.839944] 6a50  009d6e00 ffff1d36 00f7555c 00000000 00000000 00000000 009d6d12 ffff1d36[    9.840686] 6a70  00c30065 ffff1d36 00000000 00000000 00000007 00000007 0086a880 ffff1d36[    9.841427] 6a90  02e56d20 00000000 0000000b 00000000 00000000 00000000 00000000 00000000[    9.842168] 6ab0  00000000 00000000 6a842f70 ffffb65f 6a843790 ffffb65f 6a84363c ffffb65f[    9.842910] 6ad0  6a842fa8 ffffb65f 6a843bf4 ffffb65f 6a8433f0 ffffb65f 6a843110 ffffb65f[    9.843195] mmc_host mmc2: Bus speed (slot 0) = 150000000Hz (slot req 150000000Hz, actual 150000000HZ div = 0)[    9.843651] 6af0  6a84300c ffffb65f 00000000 00000000 00000000 00000000 00963e00 ffff1d36[    9.845271] 6b10  000000d1 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.846012] 6b30  00000001 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.847392] 6b50  00c30000 ffff1d36 009c8000 ffff1d36 00f5a15c 00000000 00000000 00000000[    9.848134] [    9.848134] X27: 0xffffb65f6a840104:[    9.848584] ff04  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.849327] ff24  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.850069] ff44  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.850812] ff64  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.851553] ff84  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.852295] ffa4  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.853037] ffc4  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.853778] ffe4  00000000 00000000 00000000 00000000 00000000 00000000 00000000 aa1e03e9[    9.854477] dwmmc_rockchip fe2c0000.mmc: Successfully tuned phase to 145[    9.854518] 0004  d503201f b0005881 52800020 d503233f d50323bf b9000020 d65f03c0 aa1e03e9[    9.855850] 0024  d503201f b0003d20 52800141 d503233f d50323bf b90c9c01 52800000 d65f03c0[    9.856593] 0044  aa1e03e9 d503201f b0003d20 52800081 d503233f d50323bf b90c9c01 52800000[    9.857335] 0064  d65f03c0 aa1e03e9 d503201f 52800000 d503233f d50323bf d65f03c0 aa1e03e9[    9.857796] mmc2: new ultra high speed SDR104 SDIO card at address 0001[    9.858077] 0084  d503201f d503233f a9bf7bfd b0005881 910003fd f9000420 f0003c40 91200000[    9.859401] 00a4  d2801f02 52800001 91002000 97cb2704 52800020 a8c17bfd d50323bf d65f03c0[    9.860144] 00c4  aa1e03e9 d503201f d503233f f0003c43 a9bf7bfd 91200063 d2801f02 910003fd[    9.860886] 00e4  52800001 f9008860 91002060 97cb26f4 52800020 a8c17bfd d50323bf d65f03c0[    9.861633] 0104* aa1e03e9 d503201f 52800000 d503233f d50323bf d65f03c0 aa1e03e9 d503201f[    9.862375] 0124  d503233f a9bf7bfd b0ffec81 910003fd 912da021 97cb274e 35000080 b0005880[    9.863119] 0144  52800021 39004001 a8c17bfd d50323bf 52800000 d65f03c0 aa1e03e9 d503201f[    9.863863] 0164  d503233f a9bc7bfd 910003fd a90153f3 d0000bb3 aa0003f4 91048273 a9025bf5[    9.864607] 0184  f0000bb5 aa0103f6 9111c2b5 a90363f7 b0ffec97 b0fff158 912dcef7 91126f18[    9.865349] 01a4  eb15027f 54000103 52800000 a94153f3 a9425bf5 a94363f7 a8c47bfd d50323bf[    9.866737] 01c4  d65f03c0 b9401260 350000e0 aa1803e1 aa1403e0 97cb2726 34000200 91006273[    9.867478] 01e4  17fffff0 f9400261 aa1403e0 97899f97 72001c1f 54fffec0 f9400661 aa1603e0[    9.868220] 0204  d63f0020 34fffec0 aa1403e1 aa1703e0 97cbadd6 17fffff2 f9400260 b0fff141[    9.868961] 0224  91336021 97cb2712 34fffe80 17ffffec aa1e03e9 d503201f d503233f a9be7bfd[    9.869704] 0244  910003fd f9000bf3 aa0003f3 b4000480 b0ffed61 9116c821 97cb2705 35000160[    9.870446] 0264  90fffaa1 52800020 390b6020 f0fffa81 39336020 52800000 f9400bf3 a8c27bfd[    9.871189] 0284  d50323bf d65f03c0 d0fff621 aa1303e0 913b7821 97cb26f6 350000c0 90fffaa0[    9.871931] 02a4  390b601f f0fffa80 3933601f 17fffff2 d0fff621 aa1303e0 913a2c21 97cb26ec[    9.872673] 02c4  350000e0 f0fffa80 52800021 39336001 90fffaa0 390b601f 17ffffe7 aa1303e1[    9.873414] 02e4  b0ffec80 912e4800 97cbada0 17ffffe2 aa1e03e9 d503201f b4000401 d503233f[    9.874157] [    9.874157] X29: 0xffff80000803bb00:[    9.874608] b900  6a840104 ffffb65f 002d0000 ffff1d36 0803b940 ffff8000 68a32cc4 ffffb65f[    9.875350] b920  0803b9b0 ffff8000 96000004 00000000 00000254 00000000 69bab070 ffffb65f[    9.876092] b940  0803b970 ffff8000 69b7c288 ffffb65f 0803b9b0 ffff8000 96000004 00000000[    9.876835] b960  00000254 00000000 693a8aa4 ffffb65f 0803b9a0 ffff8000 69b7cfdc ffffb65f[    9.877577] b980  00000000 00000000 0553e380 ffff1d36 0803bb00 ffff8000 ff037830 ffff1d36[    9.878321] b9a0  0803bae0 ffff8000 68a112e0 ffffb65f 00000000 00000000 00000208 00000000[    9.879063] b9c0  0803bb60 ffff8000 00000000 00000000 80000000 00000000 67000000 08731310[    9.879805] b9e0  00000003 00000000 00667267 203a7325 01010101 01010101 6a886670 ffffb65f[    9.880548] ba00  000487b1 00000000 00000001 00000000 ffffffff ffffffff ffffffff ffffffff[    9.881291] ba20  00000000 00000000 0000000a 00000000 00000000 00000000 00000000 00000000[    9.882032] ba40  00000000 00000000 00000000 00000000 0553e380 ffff1d36 0036c400 ffff1d36[    9.882773] ba60  ff037830 ffff1d36 ff037830 ffff1d36 6a9b800c ffffb65f 0553e278 ffff1d36[    9.883515] ba80  6a8b6970 ffffb65f 6a840104 ffffb65f 00000000 00000000 0803bb00 ffff8000[    9.884257] baa0  6a886670 ffffb65f 0803bb00 ffff8000 693a8aa4 ffffb65f 60400009 00000000[    9.884999] bac0  0803bb30 ffff8000 6a88664c ffffb65f 6afdcf88 ffffb65f 6a9b800c ffffb65f[    9.885741] bae0  0803bb00 ffff8000 693a8aa4 ffffb65f 04880a80 ffff1d36 00000000 00000000[    9.886482] bb00* 0803bb30 ffff8000 6a886670 ffffb65f 04880a80 ffff1d36 0553e380 ffff1d36[    9.887224] bb20  0036c400 ffff1d36 2a33cb00 ed5202de 0803bb70 ffff8000 697da744 ffffb65f[    9.887965] bb40  04880a80 ffff1d36 0036c400 ffff1d36 0553e380 ffff1d36 0036c410 ffff1d36[    9.888707] bb60  0553e380 ffff1d36 2a33cb00 ed5202de 0803bbb0 ffff8000 69388a14 ffffb65f[    9.889450] bb80  00000000 00000000 0036c410 ffff1d36 6b26f690 ffffb65f 6b2e9ad8 ffffb65f[    9.890192] bba0  00000000 00000000 693889fc ffffb65f 0803bbe0 ffff8000 69385b54 ffffb65f[    9.890935] bbc0  0036c410 ffff1d36 00000000 00000000 6b26f690 ffffb65f 6b2e9ad8 ffffb65f[    9.891679] bbe0  0803bc20 ffff8000 69385e54 ffffb65f 0036c410 ffff1d36 6b26f690 ffffb65f[    9.892423] bc00  6b3f03a8 ffffb65f 0036c410 ffff1d36 00000000 00000000 69385dbc ffffb65f[    9.893165] bc20  0803bc50 ffff8000 69385eb4 ffffb65f 6b3f0000 ffffb65f 6b26f690 ffffb65f[    9.893906] bc40  6b3f03a8 ffffb65f 69386294 ffffb65f 0803bc90 ffff8000 69386554 ffffb65f[    9.894648] bc60  0036c410 ffff1d36 6b26f690 ffffb65f 00000000 00000000 00000000 00000000[    9.895390] bc80  6b2048d0 ffffb65f 6b26f690 ffffb65f 0803bcc0 ffff8000 69383410 ffffb65f[    9.896133] bca0  00000000 00000000 6b26f690 ffffb65f 693863ec ffffb65f 00000000 00000000[    9.896874] bcc0  0803bd10 ffff8000 6938501c ffffb65f 6b26f690 ffffb65f 0553e200 ffff1d36[    9.897615] bce0  6b204bc8 ffffb65f 0553e278 ffff1d36 0803bd00 ffff8000 003448c8 ffff1d36[    9.898361] Code: 910003fd a90153f3 aa0003f3 f90013f5 (b9425400) [    9.898904] ---[ end trace 0000000000000000 ]---[    9.900207] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b[    9.900897] SMP: stopping secondary CPUs[    9.901251] CPU1: stopping[    9.901251] CPU0: stopping[    9.901252] CPU2: stopping[    9.901258] CPU: 1 PID: 0 Comm: swapper/1 Tainted: G      D            6.1.0-1027-rockchip #27[    9.901265] Hardware name: h96 TVbox 3566 (DT)[    9.901269] Call trace:[    9.901272]  dump_backtrace+0xe4/0x108[    9.901286]  show_stack+0x20/0x30[    9.901292]  dump_stack_lvl+0x7c/0xa0[    9.901301]  dump_stack+0x18/0x34[    9.901306]  local_cpu_stop+0x4c/0x6c[    9.901313]  do_handle_IPI+0x180/0x1c4[    9.901318]  ipi_handler+0x24/0x34[    9.901322]  handle_percpu_devid_irq+0x70/0x128[    9.901328]  handle_irq_desc+0x28/0x40[    9.901334]  generic_handle_domain_irq+0x20/0x2c[    9.901339]  __gic_handle_irq_from_irqson.isra.0+0x174/0x1c8[    9.901347]  gic_handle_irq+0x88/0x90[    9.901352]  call_on_irq_stack+0x24/0x4c[    9.901357]  do_interrupt_handler+0x88/0xa8[    9.901364]  el1_interrupt+0x94/0xa4[    9.901370]  el1h_64_irq_handler+0x18/0x24[    9.901376]  el1h_64_irq+0x74/0x78[    9.901381]  arch_cpu_idle+0x18/0x44[    9.901388]  default_idle_call+0x58/0x78[    9.901393]  cpuidle_idle_call+0x90/0x17c[    9.901400]  do_idle+0xc4/0xc8[    9.901404]  cpu_startup_entry+0x3c/0x40[    9.901409]  __cpu_disable+0x0/0xc0[    9.901414]  __secondary_switched+0xb0/0xb4[    9.901421] CPU: 2 PID: 0 Comm: swapper/2 Tainted: G      D            6.1.0-1027-rockchip #27[    9.901427] Hardware name: h96 TVbox 3566 (DT)[    9.901430] Call trace:[    9.901432]  dump_backtrace+0xe4/0x108[    9.901440]  show_stack+0x20/0x30[    9.901445]  dump_stack_lvl+0x7c/0xa0[    9.901452]  dump_stack+0x18/0x34[    9.901457]  local_cpu_stop+0x4c/0x6c[    9.901462]  do_handle_IPI+0x180/0x1c4[    9.901467]  ipi_handler+0x24/0x34[    9.901472]  handle_percpu_devid_irq+0x70/0x128[    9.901477]  handle_irq_desc+0x28/0x40[    9.901483]  generic_handle_domain_irq+0x20/0x2c[    9.901488]  __gic_handle_irq_from_irqson.isra.0+0x174/0x1c8[    9.901494]  gic_handle_irq+0x88/0x90[    9.901498]  call_on_irq_stack+0x24/0x4c[    9.901504]  do_interrupt_handler+0x88/0xa8[    9.901510]  el1_interrupt+0x94/0xa4[    9.901516]  el1h_64_irq_handler+0x18/0x24[    9.901523]  el1h_64_irq+0x74/0x78[    9.901528]  arch_cpu_idle+0x18/0x44[    9.901534]  default_idle_call+0x58/0x78[    9.901540]  cpuidle_idle_call+0x90/0x17c[    9.901545]  do_idle+0xc4/0xc8[    9.901549]  cpu_startup_entry+0x3c/0x40[    9.901554]  __cpu_disable+0x0/0xc0[    9.901559]  __secondary_switched+0xb0/0xb4[    9.901565] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G      D            6.1.0-1027-rockchip #27[    9.901572] Hardware name: h96 TVbox 3566 (DT)[    9.901574] Call trace:[    9.901576]  dump_backtrace+0xe4/0x108[    9.901584]  show_stack+0x20/0x30[    9.901589]  dump_stack_lvl+0x7c/0xa0[    9.901595]  dump_stack+0x18/0x34[    9.901601]  local_cpu_stop+0x4c/0x6c[    9.901605]  do_handle_IPI+0x180/0x1c4[    9.901610]  ipi_handler+0x24/0x34[    9.901615]  handle_percpu_devid_irq+0x70/0x128[    9.901620]  handle_irq_desc+0x28/0x40[    9.901626]  generic_handle_domain_irq+0x20/0x2c[    9.901631]  __gic_handle_irq_from_irqson.isra.0+0x174/0x1c8[    9.901637]  gic_handle_irq+0x88/0x90[    9.901641]  call_on_irq_stack+0x24/0x4c[    9.901646]  do_interrupt_handler+0x88/0xa8[    9.901652]  el1_interrupt+0x94/0xa4[    9.901659]  el1h_64_irq_handler+0x18/0x24[    9.901665]  el1h_64_irq+0x74/0x78[    9.901670]  arch_cpu_idle+0x18/0x44[    9.901676]  default_idle_call+0x58/0x78[    9.901681]  cpuidle_idle_call+0x90/0x17c[    9.901686]  do_idle+0xc4/0xc8[    9.901690]  cpu_startup_entry+0x3c/0x40[    9.901697]  kernel_init+0x0/0x140[    9.901703]  arch_post_acpi_subsys_init+0x0/0x28[    9.901712]  start_kernel+0x5f0/0x630[    9.901718]  __primary_switched+0xbc/0xc4[    9.901729] PMU CRU:[    9.931976] 00000000: 00006064 00001481 00000000 00000007 00007f00 00000000 00000000 00000000[    9.932735] 00000020: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.933494] 00000040: 00002063 00001481 00000000 00000007 00007f00 00000000 00000000 00000000[    9.934253] 00000060: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.935011] 00000080: 00000001 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.935770] 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.936529] 000000c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.937287] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.938046] 00000100: 00000080 0040b71b 00000001 00000001 00000800 00000000 00000001 00000009[    9.938804] 00000120: 0000050f 0000888b 00000000 00000000 00000000 00000000 00000000 00000000[    9.939562] 00000140: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.940321] 00000160: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.941079] 00000180: 00000000 00000003 00000000 00000000 00000000 00000000 00000000 00000000[    9.941838] 000001a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.942596] 000001c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.943354] 000001e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.944112] 00000200: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.944871] 00000220: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.945625] 00000240: 00040020 00000000[    9.945969] CRU:[    9.946143] 00000000: 0000104b 00001441 00000000 00000007 00007f00 00000000 00000000 00000000[    9.946901] 00000020: 00004082 00001441 00000000 00000007 00007f00 00000000 00000000 00000000[    9.947661] 00000040: 00002064 00001441 00000000 00000007 00007f00 00000000 00000000 00000000[    9.948419] 00000060: 0000107d 00001443 00000000 00000007 00007f00 00000000 00000000 00000000[    9.949177] 00000080: 00001032 00001441 00000000 00000000 00000000 00000000 00000000 00000000[    9.949935] 000000a0: 0000307d 00001442 00000000 00000000 00000000 00000000 00000000 00000000[    9.950694] 000000c0: 00000455 00000000 00000000 00000000 00640064 00000000 00000000 00000103[    9.951452] 000000e0: 00000001 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.952211] 00000100: 000080c0 00000000 00008100 00000505 00000505 00000111 00004191 00000011[    9.952972] 00000120: 00000053 00000100 00000001 00008113 00000000 00008113 00000000 00008113[    9.953730] 00000140: 00000000 00008113 00000000 00008113 00000000 00008113 00000000 00000013[    9.954489] 00000160: 00000000 0000000b 00000000 00000010 00001031 00001c32 00002520 00000000[    9.955247] 00000180: 00000020 00000000 00000310 0000c001 0000c0c0 00003100 00000001 00000000[    9.956005] 000001a0: 00000001 00000003 00000103 00002100 00000203 00000003 00000000 00000102[    9.956763] 000001c0: 00000003 00000301 00000021 00001715 0000200b 00000000 0000200b 00000000[    9.957521] 000001e0: 0000200b 00000000 0000200b 00000000 0000200b 00000000 0000200b 00000000[    9.958279] 00000200: 0000200b 00000000 0000200b 00000000 0000200b 00000000 00000303 00000203[    9.959038] 00000220: 00001500 00002022 0000001f 00000302 00000705 00000f0b 0000013b 00000302[    9.959796] 00000240: 00000f07 00002713 00001f09 00008113 00000000 00003b2f 00000101 00000302[    9.960554] 00000260: 00000704 0000130f 00001f27 00000000 00000000 00000000 00000000 00000000[    9.961312] 00000280: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.962070] 000002a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.962828] 000002c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.963585] 000002e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.964343] 00000300: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.965101] 00000320: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000003[    9.965858] 00000340: 00000000 00000000 00000000 00000000 00000000 00000000 00001003 00000070[    9.966616] 00000360: 00000000 00000000 00000000 00009000 00000000 00000000 00000000 00000000[    9.967373] 00000380: 00000000 00000000 00000000 00008000 00000000 00000000 00000000 00000000[    9.968131] 000003a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.968889] 000003c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.969647] 000003e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.970404] 00000400: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.971162] 00000420: 00000000 00000000 00000002 00000002 00000002 00000000 00000000 00000000[    9.971920] 00000440: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.972677] 00000460: 00000000 00000000 00000400 00000000 00000000 00000000 00000000 00000000[    9.973435] 00000480: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.974193] 000004a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.974951] 000004c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.975709] 000004e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.976467] 00000500: 00040020 00000000 00040020 00000000 00040020 00000000 00040020 00000000[    9.977225] 00000520: 00040020 00000000 00040020 00000000 00040020 00000000 00040020 00000000[    9.977984] 00000540: 00040020 00000000 00040020 00000000 00000000 00000000 00000000 00000000[    9.978742] 00000560: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000[    9.979496] 00000580: 00000002 00000000[    9.979840] PMU:[    9.980010] pwr       0x00a0: 0000007f 00000000 00000003 00000000[    9.980558] status    0x0098: 0000007f 00000000 0000007f 00000000[    9.981105] req       0x0050: 00000060 00000000 00000000 00000000[    9.981652] idle      0x0068: 000001ee 00000000 0000ffff 0000000f[    9.982198] ack       0x0060: 000001ee 00000000 000001ee 00000000[    9.982750] rockchip-thermal fe710000.tsadc: channal 0: temperature(44 C)[    9.983354] rockchip-thermal fe710000.tsadc: channal 1: temperature(45 C)[    9.983958] THERMAL REGS:[    9.984201] 00000000: 00000fc0 00010033 00000033 00000000 00000000 00000000 00000000 00000000[    9.984960] 00000020: 00000870 00000870 00000000 00000000 0000091c 0000091c 00000000 00000000[    9.985719] 00000040: 000009c4 000009c4 00000000 00000000 00000000 00000000 00000000 00000000[    9.986481] 00000060: 00000004 00000004 00000656 00000656 00000000 00000000 00000000 00000000[    9.987235] 00000080: 00000000 00000000[    9.987580] Kernel Offset: 0x365f60a00000 from 0xffff800008000000[    9.988122] PHYS_OFFSET: 0xffffe2cb00000000[    9.988495] CPU features: 0xc0000,001400a4,6200721b[    9.988930] Memory Limit: none[    9.989208] cpu cpu0: cur_freq: 1800000000 Hz, volt: 1050000 uV[    9.989740] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b ]---
[mention=204918]Hqnicolas[/mention] I build the kernel 6.1(noble) in the github action, and kernel panic, had you solve this problem before?
Never seen it, could be something that change this days
Posted (edited)
do you remember your commit id for your success github action build ?
@Hqnicolas by the way, I found the panther-x2 armbian image works, but the usb3.0 not works, do you know how to enable the USB3.0 port?
Edited by mvpwar
@maka
into this file:
https://github.com/hqnicolas/ubuntu-rockchip-joshua/blob/main/config/suites/noble.sh
it makes refference to the kernel repo:
https://github.com/hqnicolas/linux-rockchip
that contains the dts file:
https://github.com/hqnicolas/linux-rockchip/blob/arm64--dts--rockchip--add-rk3566-h96max-v56/arch/arm64/boot/dts/rockchip/rk3566-h96max-v56.dts
That have the USB setup:
&usb2phy0 {
	status = "okay";
&usb2phy1 {
	status = "disabled";
&usb_host0_ehci {
&usb_host0_ohci {
&usb_host1_ehci {
&usb_host1_ohci {
&usbdrd_dwc3 {
	dr_mode = "host";
	extcon = <&usb2phy0>;
	status = "okay";
&usbdrd30 {
	status = "okay";
&usbhost_dwc3 {
	status = "okay";
&usbhost30 {
	status = "okay";
&pinctrl {
	usb {
		vcc5v0_otg_en: vcc5v0-otg-en {
			rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>;
There Are 3 Branches:
Dear all, How can i auto login h96max armbian without input user name&password. Every time i turn on the box, i have to enter the user name&password. I don't want to do that the same to windows OS
Thank you,
Thank you,
Posted (edited)
For anyone looking for simple instructions to install the official Armbian image for "H96 Max V56" (as of August 30th, 2025) using a Linux PC (e.g. Ubuntu Desktop 24.04):
1. Install the "rkdeveloptool" tool first, as instructed inhttps://docs.radxa.com/en/zero/zero3/low-level-dev/rkdeveloptool?host-os=debian
sudo apt-get update
sudo apt-get install -y libudev-dev libusb-1.0-0-dev dh-autoreconf pkg-config libusb-1.0 build-essential git wget
git clone https://github.com/rockchip-linux/rkdeveloptool
cd rkdeveloptool
autoreconf -i
./configure
make -j $(nproc)
sudo cp rkdeveloptool /usr/local/sbin/
At the time of writing, this installed version 1.32. If you installed "rkdeveloptool" from Ubuntu's repos, it would install version 1.0 which may work, but let's be on the safe side here...
2. Connect and boot the device to loader/maskrom mode
2.1 While pressing the reset button (back/right) with a pin, connect the USB 2.0 port (back/left) and the power cable. Gotta be careful here not to miss the reset button pressing while connecting the cables.
2.2 Use the rkdeveloptool tool to identify the device and the mode it is on ("loader" or "maskrom").
    $ rkdeveloptool ld
    ...should show the connected device if point 2.1 was successful - e.g. on my 8GB RAM device it printed this: DevNo=1 Vid=0x2207,Pid=0x350a,LocationID=304 Loader
   Or after I had already flashed Armbian, it would show: DevNo=1 Vid=0x2207,Pid=0x350a,LocationID=304 Maskrom
    (If you installed "rkdeveloptool" from Ubuntu's repo, the command is "rkdeveloptool list" if I recall correctly - every other "rkdeveloptool" command following though is the same)
    Now grab the latest release of Armbian for this device. At the time of writing it was: https://github.com/armbian/community/releases/download/25.11.0-trunk.106/Armbian_community_25.11.0-trunk.106_H96-tvbox-3566_bookworm_current_6.12.44_minimal.img.xz (the name of the device is on the filename)
    Extract the included .img file with (sudo apt install xz-tools):
    $ unxz Armbian_community_25.11.0-trunk.106_H96-tvbox-3566_bookworm_current_6.12.44_minimal.img.xz
2.2.1 If in "loader" mode (see the last part of the command's output above), simply flash Armbian directly. E.g.
    $ sudo rkdeveloptool wl 0x0 Armbian_community_25.11.0-trunk.106_H96-tvbox-3566_bookworm_current_6.12.44_minimal.img
   (if you attempt to flash the attached bootloaders, you'll get a "device not supported" error - Armbian already contains a bootloader)
2.2.2 If in "maskrom" mode (e.g. if you are re-flashing Armbian), flash the bootloader first:
    # For the 8GB RAM device use the attached (in this post) H96-MAX-8gb-MiniLoaderAll.bin file
    $ sudo rkdeveloptool db H96-MAX-8gb-MiniLoaderAll.bin
    # For the 4GB RAM device use the attached (in this post) H96-MAX-4gb-MiniLoaderAll.bin file
    $ sudo rkdeveloptool db H96-MAX-4gb-MiniLoaderAll.bin
    ...and then re-flash Armbian as you did the first time:
2.3 Reboot the device with:
    $ sudo rkdeveloptool rd
Done!
If all goes well, once you reboot the device you will be asked to set a root password and optionally a sudo user. Rebooting afterwards you should now be greeted with:
    _             _    _                                         _ _
   /_\  _ _ _ __ | |__(_)__ _ _ _    __ ___ _ __  _ __ _  _ _ _ (_) |_ _  _
  / _ \| '_| '  \| '_ \ / _` | ' \  / _/ _ \ '  \| '  \ || | ' \| |  _| || |
 /_/ \_\_| |_|_|_|_.__/_\__,_|_||_|_\__\___/_|_|_|_|_|_\_,_|_||_|_|\__|\_, |
                                 |___|                                 |__/
 v25.11 rolling for h96-tvbox-3566 running Armbian Linux 6.12.44-current-rockchip64
 Packages:     Debian stable (bookworm), possible distro upgrade (trixie)
 Updates:      Kernel upgrade enabled and 2 packages available for upgrade
 Support:      for advanced users (rolling release)
 IPv4:         (LAN) 192.168.1.10 (WAN) 1.2.3.4
 Performance:
 Load:         3%           	 Uptime:       2 min
 Memory usage: 2% of 7.50G
 CPU temp:     40°C           	 Usage of /:   3% of 57G
 Commands:
 Configuration : armbian-config
 Upgrade       : armbian-upgrade
 Monitoring    : htop
Last login: Sat Aug 30 12:47:54 2025
Key points:
- If you do this the first time, it's obviously a matter of just flashing the latest Armbian image directly.
- You don't need to open the device or compile Armbian.
- It's simpler than 2 years ago when I bought the device thanks to people like @Hqnicolas (muito obrigado Nicolas!)
H96-MAX-4gb-MiniLoaderAll.bin H96-MAX-8gb-MiniLoaderAll.bin
Edited by fevangelou
@fevangelou
nice guide. THX!
but maybe it would be best to have the instruction in an separate topic! in best case it gets also pinned.
so new users can find it much easier than scrolling though 18 pages (in this thread. there is also the 4gb thread) to find it......
From @fevangelou
sudo apt-get update
cd rkdeveloptool
autoreconf -i
./configure
make -j $(nproc)
    $ rkdeveloptool ld
Done!
    _             _    _                                         _ _
                                 |___|                                 |__/
 Performance:
 Commands:
 Monitoring    : htop
Key points:
Please forgive my ignorance, I haven't been back here for some time.
Did anyone ever work-out how to control the blue enclosure illumination, and front panel display for this device?
I would be very grateful for code snippets, or and suggestions on how to approach investigating the above.
I spoke to HSTC. They didn't speak back, so beyond this plea, I'm not feeling optimistic.
Thanks,
M.
Posted (edited)
@GBEM
I'm running:
_             _    _                             __  __ _    _      _
  /_\  _ _ _ __ | |__(_)__ _ _ _ ___ _  _ _ _  ___ / _|/ _(_)__(_)__ _| |
 / _ \| '_| '  \| '_ \ / _` | ' \___| || | ' \/ _ \  _|  _| / _| / _` | |
/_/ \_\_| |_|_|_|_.__/_\__,_|_||_|   \_,_|_||_\___/_| |_| |_\__|_\__,_|_|
v25.8.1 for h96-tvbox-3566 running Armbian Linux 6.12.44-current-rockchip64
Support:      DIY (community maintained)
IPv4:         SNIPP
Performance:
Load:         2%                Uptime:       8 days 8:01
Memory usage: 3% of 7.50G
CPU temp:     38°C              Usage of /:   12% of 57G
Commands:
Monitoring    : htop
Last login: Mon Sep 15 15:59:34 2025 from 192.168.1.48
I can switch the blue leds with:
root@tvbox:/home/gt# echo 0 >/sys/class/leds/led-power/brightness
root@tvbox:/home/gt# echo 1 >/sys/class/leds/led-power/brightness
as root. sudo didn't work.
I used the project:
gt@tvbox:~/tm16xx-display$ git config --get remote.origin.url
https://github.com/jefflessard/tm16xx-display.git
I created a dtbo which is loaded during boot:
gt@tvbox:~/tm16xx-display$ cat /boot/armbianEnv.txt
user_overlays=tm16xx
The mentioned project provides a service which updates the front display with the time.
Edited by guenter
Awesome, @guenter.
I'm debugging a board support layer for the Home Assistant OS, which targets the H96 Max.
The fabulous work found in this thread, has been both inspiration and foundation for the port to Buildroot.
With your very welcome direction, guenter, I'll have a far more polished result, if I ever get my images to boot.
Thanks, so much, one and all,
M.
On 9/16/2025 at 2:33 AM, Vincenzoernst1 said:
would it be possible to have the driver @guenter pointed out in the base image?
Since it's an external driver,
@Vincenzoernst1 you will still need to do all the process:
Edit /boot/armbianEnv.txt to load the overlay
Kernel module and display service
Option 1: build and install in a single command
Builds then installs module and service
make install
Option 2: step by step commands
make module
make module-install
make service-install
Check your display configuration
display-service -c
3 phase display check
Check that all leds are ON
Check the order of digits and segment mapping (you should see "1234")
Check each led name (ex: LAN icon is ON while "LAN" text is shown on the digits)
I will include this section into a pull request:
/dts-v1/;
/plugin/;
#include <dt-bindings/gpio/gpio.h>
#include <dt-bindings/leds/common.h>
#include <dt-bindings/pinctrl/rockchip.h>
	i2c-display {
		compatible = "i2c-gpio";
		sda-gpios = <&gpio0 RK_PB4 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>;
		scl-gpios = <&gpio0 RK_PB3 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>;
		i2c-gpio,delay-us = <5>;
		#address-cells = <1>;
		#size-cells = <0>;
		display@24 {
			compatible = "fdhisi,fd6551";
			reg = <0x24>;
			digits {
				#size-cells = <0>;
				digit@0 {
					reg = <0>;
					segments = <1 3>,
						   <1 1>,
						   <1 2>,
						   <1 6>,
						   <1 4>,
						   <1 5>,
						   <1 0>;
				digit@1 {
					reg = <1>;
					segments = <2 3>,
						   <2 1>,
						   <2 2>,
						   <2 6>,
						   <2 4>,
						   <2 5>,
						   <2 0>;
				digit@2 {
					reg = <2>;
					segments = <3 3>,
						   <3 1>,
						   <3 2>,
						   <3 6>,
						   <3 4>,
						   <3 5>,
						   <3 0>;
				digit@3 {
					reg = <3>;
					segments = <4 3>,
						   <4 1>,
						   <4 2>,
						   <4 6>,
						   <4 4>,
						   <4 5>,
						   <4 0>;
			leds {
				#address-cells = <2>;
				#size-cells = <0>;
				led@0,0 {
					reg = <0 0>;
					function = LED_FUNCTION_ALARM;
				led@0,1 {
					reg = <0 1>;
					function = LED_FUNCTION_USB;
				led@0,3 {
					reg = <0 3>;
					function = "play";
				led@0,2 {
					reg = <0 2>;
					function = "pause";
				led@0,4 {
					reg = <0 4>;
					function = "colon";
				led@0,5 {
					reg = <0 5>;
					function = LED_FUNCTION_LAN;
				led@0,6 {
					reg = <0 6>;
					function = LED_FUNCTION_WLAN;
