maka Posted November 18, 2024 Posted November 18, 2024 (edited) What a rare thing I am. Maybe a trasgo, I don't know. Got chromium from apt and worked like a charm. Edited November 18, 2024 by maka 1 Quote
DreamDreams Posted November 19, 2024 Posted November 19, 2024 I installed u-boot to eMMC, but found that there is no saveenv command, does anybody know why? Tried to compile u-boot myself but when I run make command in u-boot source I got following error: Image 'simple-bin' is missing external blobs and is non-functional: rockchip-tpl atf-bl31 /binman/simple-bin/mkimage/rockchip-tpl (rockchip-tpl): An external TPL is required to initialize DRAM. Get the external TPL binary and build with ROCKCHIP_TPL=/path/to/ddr.bin. One possible source for the external TPL binary is https://github.com/rockchip-linux/rkbin. /binman/simple-bin/fit/images/@atf-SEQ/atf-bl31 (atf-bl31): See the documentation for your board. You may need to build ARM Trusted Firmware and build with BL31=/path/to/bl31.bin Image 'simple-bin' is missing optional external blobs but is still functional: tee-os /binman/simple-bin/fit/images/@tee-SEQ/tee-os (tee-os): See the documentation for your board. You may need to build Open Portable Trusted Execution Environment (OP-TEE) and build with TEE=/path/to/tee.bin Image 'simple-bin-spi' is missing external blobs and is non-functional: rockchip-tpl /binman/simple-bin-spi/mkimage/rockchip-tpl (rockchip-tpl): An external TPL is required to initialize DRAM. Get the external TPL binary and build with ROCKCHIP_TPL=/path/to/ddr.bin. One possible source for the external TPL binary is https://github.com/rockchip-linux/rkbin. Some images are invalid make: *** [Makefile:1126: .binman_stamp] Error 103 I got following binary files in the folder: u-boot-dtb.bin u-boot-nodtb.bin u-boot-rockchip-spi.bin u-boot-rockchip.bin u-boot.bin But none of them starts with bytes "RKNS" as in /usr/lib/linux-u-boot-edge-h96-tvbox-3566/u-boot-rockchip.bin . So I suspect that they are not the one I should burn to eMMC. 0 Quote
maka Posted November 19, 2024 Posted November 19, 2024 (edited) Where did you read the u-boot building? export BL31=../trusted-firmware-a/build/rk3568/release/bl31/bl31.elf [or]export BL31=../rkbin/bin/rk35/rk3568_bl31_v1.34.elf export ROCKCHIP_TPL=../rkbin/bin/rk35/rk3568_ddr_1560MHz_v1.13.bin make evb-rk3568_defconfig make CROSS_COMPILE=aarch64-linux-gnu- You have not done first and second step. This is an example for another board, an sbc better than your box, and the files you have to use is unknown. Don't use this ones or maybe you get a brick. You have been warned. Edited November 19, 2024 by maka 0 Quote
DreamDreams Posted November 19, 2024 Posted November 19, 2024 (edited) 46 minutes ago, maka said: Where did you read the u-boot building? export BL31=../trusted-firmware-a/build/rk3568/release/bl31/bl31.elf [or]export BL31=../rkbin/bin/rk35/rk3568_bl31_v1.34.elf export ROCKCHIP_TPL=../rkbin/bin/rk35/rk3568_ddr_1560MHz_v1.13.bin make evb-rk3568_defconfig make CROSS_COMPILE=aarch64-linux-gnu- You have not done first and second step. This is an example for another board, an sbc better than your box, and the files you have to use is unknown. Don't use this ones or maybe you get a brick. You have been warned. You are right, I didn't do the first two steps. I got the base config from running "./compile.sh BOARD=h96-tvbox-3566 BRANCH=edge uboot-config". Then 'make menuconfig' and make. It's hard to find documentation for compile u-boot only. Will try your steps. But where do I find file rk3568_bl31_v1.34.elf and rk3568_ddr_1560MHz_v1.13.bin? I could find it in the source folder. Edited November 19, 2024 by DreamDreams 0 Quote
DreamDreams Posted November 19, 2024 Posted November 19, 2024 I found the binary files. On my system they have different version. I successfully compiled and burn new u-boot to my board. But saveenv is still missing. # grep SAVEENV .config CONFIG_CMD_SAVEENV=y CONFIG_SAVEENV=y U-Boot 2024.07-armbian-2024.07-S3f77-P0000-H3f52-Vc494-Bda0a-R448a (Nov 19 2024 - 15:22:24 +0800) Model: Generic RK3566/RK3568 DRAM: 8 GiB (effective 7.7 GiB) Core: 251 devices, 25 uclasses, devicetree: separate MMC: mmc@fe2b0000: 1, mmc@fe310000: 0 Loading Environment from nowhere... OK In: serial@fe660000 Out: serial@fe660000 Err: serial@fe660000 Model: Generic RK3566/RK3568 Net: No ethernet found. Hit any key to stop autoboot: 0 Scanning for bootflows in all bootdevs Seq Method State Uclass Part Name Filename --- ----------- ------ -------- ---- ------------------------ ---------------- Scanning global bootmeth 'efi_mgr': Card did not respond to voltage select! : -110 No EFI system partition No EFI system partition Failed to persist EFI variables No EFI system partition Failed to persist EFI variables No EFI system partition Failed to persist EFI variables 0 efi_mgr ready (none) 0 <NULL> ** Booting bootflow '<NULL>' with efi_mgr Loading Boot0000 'mmc 0' failed EFI boot manager: Cannot load any image Boot failed (err=-14) Scanning bootdev 'mmc@fe2b0000.bootdev': Card did not respond to voltage select! : -110 Scanning bootdev 'mmc@fe310000.bootdev': Unknown uclass 'nvme' in label Unknown uclass 'scsi' in label No USB controllers found No ethernet found. No ethernet found. No more bootdevs --- ----------- ------ -------- ---- ------------------------ ---------------- (1 bootflow, 1 valid) => => => => => <INTERRUPT> => => saveenv Unknown command 'saveenv' - try 'help' 0 Quote
DreamDreams Posted November 19, 2024 Posted November 19, 2024 Got it working, the cause is that config CONFIG_ENV_IS_IN_MMC is not set. After setting this, saveenv appears. 0 Quote
DreamDreams Posted November 19, 2024 Posted November 19, 2024 Another question, how can I determine whter my memory is capable of 1560MHz or 1056MHz? Below is u-boot output when reset. => reset resetting ... DDR 2d653b3476 typ 24/01/20-15:04:19,fwver: v1.21 ln LP4/4x derate en, other dram:1x trefi SRX ddrconfig:7 LPDDR4X, 324MHz BW=32 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=8192MB tdqss: cs0 dqs0: 72ps, dqs1: -72ps, dqs2: -48ps, dqs3: -144ps, tdqss: cs1 dqs0: 72ps, dqs1: -72ps, dqs2: -24ps, dqs3: -144ps, 0 Quote
DreamDreams Posted November 21, 2024 Posted November 21, 2024 Now I'm very disapointed with this box. Comparing to my Firefly-rk3399, it has 2x memory, newer CPU/GPU, but performance is worse. glmark2-es2-wayland score: RK3399 1100, RK3566 500 ffmpeg -hwaccel drm -benchmark on same AVC/H264 video, RK3399 40X, RK3566 10X And GUI smothiness is much worse than RK3399. I can feel the difference, and it is very obvious. Kernel version are both 6.12 mainline. 0 Quote
maka Posted November 21, 2024 Posted November 21, 2024 Nothing rare in your review. You are comparing a high price rk3399 with a low one rk3566. The last makes a good job because is well supported and can move a Desktop for little money. With LXQT works wonderfull. 0 Quote
DreamDreams Posted November 21, 2024 Posted November 21, 2024 20 minutes ago, maka said: Nothing rare in your review. You are comparing a high price rk3399 with a low one rk3566. The last makes a good job because is well supported and can move a Desktop for little money. With LXQT works wonderfull. Is RK3399 more expansive? I was missled by my purchase price. And on paper, RK3399's Mali T860 is much weaker than RK3566's Mali G52. 0 Quote
DreamDreams Posted November 21, 2024 Posted November 21, 2024 I'd like to try Joshua Riek's image, but not sure how. @Hqnicolas, your link in previous post is 404 now. I tried to boot kernel linux-image-vendor-rk35xx with rk3566-h96-tvbox.dtb but got instant kernel panic. 0 Quote
maka Posted November 21, 2024 Posted November 21, 2024 (edited) Joshua ryek had to halt his project because of problems. I hope he is getting better know. His interest in rk3566 is almost zero. Only help could change this. RK3399's gpu Mali T860 MP4 is much more powerful than rk3566's Mali G52 2EE (MP1). Edited November 21, 2024 by maka 0 Quote
Hqnicolas Posted November 23, 2024 Author Posted November 23, 2024 (edited) On 11/21/2024 at 2:53 AM, DreamDreams said: 'd like to try Joshua Riek's image, but not sure how. @Hqnicolas, your link in previous post is 404 now. @DreamDreams I remove it because the joshua project changed, and my patches become deprecated..... you need to edit the patch file for orangepi3b to work with h96 max simple change the config for this: https://github.com/hqnicolas/ArmBoardBringUp Clone the Joshua riek project on github. remove patches from the .sh file that dont be compatible with h96max: https://github.com/Joshua-Riek/ubuntu-rockchip/blob/main/config/boards/orangepi-3b.sh take the dts file from armbian rk3566 h96 max and edit this patch below: https://github.com/Joshua-Riek/ubuntu-rockchip/blob/main/packages/u-boot-turing-rk3588/debian/patches/0005-board-rockchip-Add-Xunlong-Orange-Pi-3B.patch now when you compile for Orange pi 3B it will compile for H96 max.... the trick for this 0005-board-rockchip-Add-Xunlong-Orange-Pi-3B.patch is that you need to count the number of lines that you are insert in the path and edit the line. Quote arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3566-orangepi-3b-u-boot.dtsi | 24 + arch/arm/dts/rk3566-orangepi-3b.dts | 869 ++++++++++++++++++++ configs/orangepi-3b-rk3566_defconfig | 114 +++ doc/board/rockchip/rockchip.rst | 1 + 5 files changed, 1009 insertions(+) Quote diff --git a/configs/orangepi-3b-rk3566_defconfig b/configs/orangepi-3b-rk3566_defconfig new file mode 100644 index 00000000000..5557d983f31 --- /dev/null +++ b/configs/orangepi-3b-rk3566_defconfig @@ -0,0 +1,114 @@ you will need to enable / disable things on defconfig, use armbian defconfig as an exaple, (dont copy it) just compare and set it up @DreamDreams after doing it you can feel like a real linux hacker because you will be. Edited November 23, 2024 by Hqnicolas 0 Quote
DreamDreams Posted November 27, 2024 Posted November 27, 2024 (edited) On 11/24/2024 at 5:08 AM, Hqnicolas said: remove patches from the .sh file that dont be compatible with h96max: https://github.com/Joshua-Riek/ubuntu-rockchip/blob/main/config/boards/orangepi-3b.sh This shell script doesn't have any patch in it. On 11/24/2024 at 5:08 AM, Hqnicolas said: take the dts file from armbian rk3566 h96 max and edit this patch below: https://github.com/Joshua-Riek/ubuntu-rockchip/blob/main/packages/u-boot-turing-rk3588/debian/patches/0005-board-rockchip-Add-Xunlong-Orange-Pi-3B.patch Do you mean this dts patch file? @Hqnicolas Edited November 27, 2024 by DreamDreams 0 Quote
DreamDreams Posted November 27, 2024 Posted November 27, 2024 Another question, do we have to use Joshua Riek's u-boot? Should u-boot from Aribian just work? And the steps you mentioned above only affects u-boot right? What about kernel config and dts/dtb? 0 Quote
Hqnicolas Posted December 2, 2024 Author Posted December 2, 2024 On 11/27/2024 at 2:49 AM, DreamDreams said: This shell script doesn't have any patch in it. I think you just need to remove the # Enable bluetooth things On 11/27/2024 at 2:49 AM, DreamDreams said: Do you mean this dts patch file? Yes! Just Do it! On 11/27/2024 at 3:03 AM, DreamDreams said: Another question, do we have to use Joshua Riek's u-boot? Should u-boot from Aribian just work? I think this Joshua patch file have a section that apply to the uboot and other section that apply to kernel and dont forgot to change the kernelconfig based on armbian 0 Quote
paradigman Posted December 5, 2024 Posted December 5, 2024 I'm curious when rolling images are expected to be made with kernel 6.10 or 6.12? 0 Quote
Hqnicolas Posted December 7, 2024 Author Posted December 7, 2024 On 12/5/2024 at 10:43 AM, paradigman said: made with kernel 6.10 or 6.12? I'm going to take a break from college and my platform this month, maybe I should spend a week to update the google drive on this device I have some pending things to do on vacation, but I would like to include tools made by other technicians @pocosparc can you hear that? 0 Quote
Hqnicolas Posted December 7, 2024 Author Posted December 7, 2024 (edited) On 11/18/2024 at 2:39 PM, maka said: What a rare thing I am. Maybe a trasgo, I don't know. Got chromium from apt and worked like a charm. same here after I include the armbian REPO into my device.... Edited December 7, 2024 by Hqnicolas 0 Quote
Hqnicolas Posted December 7, 2024 Author Posted December 7, 2024 On 11/19/2024 at 5:01 AM, DreamDreams said: how can I determine whter my memory is capable of 1560MHz or 1056MHz? I did it by trial and error, but in the official versions you should always use the stable clock, overclocking here is nonsense 0 Quote
Hqnicolas Posted December 22, 2024 Author Posted December 22, 2024 (edited) On 12/7/2024 at 1:14 PM, Hqnicolas said: I should spend a week to update the google drive on this device Updated Links for this topic with Unofficial images Kernel 6.12.6 server noble https://drive.google.com/file/d/1ulAH8sqdGkkWeAEFSHqTZaWg1N1Yrqnh/view?usp=sharing desktop noble https://drive.google.com/file/d/1sVKe_HbmxcSpuls_AAGIOnyaxcYKTkKl/view?usp=sharing jammy server https://drive.google.com/file/d/1C_P2ojuMdtTgT9aMAjoblPDSVw1tD8Wr/view?usp=sharing jammy desktop https://drive.google.com/file/d/1pmOXNiedEWzHetJZ4CmASZKZsgAElQag/view?usp=sharing bookworm server https://drive.google.com/file/d/1NvUwikDr08RdY6oJj3PFtx-N16_QkMtR/view?usp=sharing bookworm desktop https://drive.google.com/file/d/1VtHnIidMDT8P-wzL_Wwv4v6TUzrgNC2z/view?usp=sharing How to flash: Same as V1.1 Quote Quote Edited December 23, 2024 by Hqnicolas 1 Quote
Hqnicolas Posted December 24, 2024 Author Posted December 24, 2024 (edited) On 11/27/2024 at 2:49 AM, DreamDreams said: Do you mean this dts patch file? @DreamDreams I will try to update this Joshua Riek Patch File Joshua Riek Kernel Files Kernel 6.1 Kernel 5.1 KernelConfig Old Test Report Edited January 1, 2025 by Hqnicolas 1 Quote
Andre B Posted December 27, 2024 Posted December 27, 2024 (edited) Thank you @Hqnicolas, i sucessfully installed armbian on h96 max rk3566 (not v56) 8/128, but ethernet isn't working yet, anyone facing the same issue ? i attached some pictures and dmesg output chip is JL2101 N040C DF dmesg.txt Edited December 27, 2024 by Andre B 0 Quote
Andre B Posted December 27, 2024 Posted December 27, 2024 (edited) On 11/28/2024 at 3:07 PM, maka said: I have made your work and mend the file that I think you are reporting to work well (I am not sure because your reports are not traceable) I hope you are lucky. rk3566-box-demo_x96x6_24.dtb Edited November 28 by maka Hi @maka, what's the magic ? i have the same problem but different device (h96max rk3566), i attached board picture and dmesg log and current dts dmesg.txt rk3566-h96-tvbox.dts Edited December 27, 2024 by Andre B 0 Quote
Vincenzoernst1 Posted December 28, 2024 Posted December 28, 2024 Zitat [ 15.548252] rk2-crypto fe380000.crypto: Fallback for ecb-aes-rk2 is ecb-aes-ce [ 17.219785] rk_gmac-dwmac fe010000.ethernet end0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 17.224400] rk_gmac-dwmac fe010000.ethernet end0: PHY [stmmac-0:00] driver [Generic PHY] (irq=POLL) [ 17.230833] dwmac4: Master AXI performs any burst length [ 17.230886] rk_gmac-dwmac fe010000.ethernet end0: No Safety Features support found [ 17.230929] rk_gmac-dwmac fe010000.ethernet end0: IEEE 1588-2008 Advanced Timestamp supported [ 17.231599] rk_gmac-dwmac fe010000.ethernet end0: registered PTP clock [ 17.269057] rk_gmac-dwmac fe010000.ethernet end0: configuring for phy/rgmii link mode [ 19.336647] rk_gmac-dwmac fe010000.ethernet end0: Link is Up - 100Mbps/Full - flow control rx/tx chip seems to be have driver support already. discussed here what says ip a? 1 Quote
Andre B Posted December 28, 2024 Posted December 28, 2024 (edited) since ethernet not working, i revert back to android, i also test different android firmware, with 8G-RK3566_userdebug_H96_Max_RK3566_11_20210421.2051.img ethernet is not working RK3566_userdebug_H96_Max_RK3566_11_20221126.1220.img ethernet is working here are dtb's that i extracted from working android's ethernet boot.img (there are 4 dtbs but the one is around 8mb so it doesn't upload) 01_dtbdump_rockchip,rk3566-evb3-DDR3-v10.dtb 03_dtbdump_rockchip,rk3566-evb3-DDR3-v10.dtb 04_dtbdump_rockchip,rk3566-evb3-DDR3-v10.dtb and here's the converted version of last dtb 04_dtbdump_rockchip,rk3566-evb3-DDR3-v10.dts in android dtb android_eth.txt, ethernet alias is ethernet1 while on armbian dtb armbian_eth.txt, ethernet alias is ethernet0, could it be the cause ? i'm about to test it android dtb ethernet Spoiler aliases { csi2dphy0 = "/csi2-dphy0"; csi2dphy1 = "/csi2-dphy1"; csi2dphy2 = "/csi2-dphy2"; dsi0 = "/dsi@fe060000"; dsi1 = "/dsi@fe070000"; ethernet1 = "/ethernet@fe010000"; gpio0 = "/pinctrl/gpio@fdd60000"; gpio1 = "/pinctrl/gpio@fe740000"; gpio2 = "/pinctrl/gpio@fe750000"; gpio3 = "/pinctrl/gpio@fe760000"; gpio4 = "/pinctrl/gpio@fe770000"; i2c0 = "/i2c@fdd40000"; i2c1 = "/i2c@fe5a0000"; i2c2 = "/i2c@fe5b0000"; i2c3 = "/i2c@fe5c0000"; i2c4 = "/i2c@fe5d0000"; i2c5 = "/i2c@fe5e0000"; mmc0 = "/dwmmc@fe2b0000"; mmc1 = "/dwmmc@fe2c0000"; mmc2 = "/sdhci@fe310000"; mmc3 = "/dwmmc@fe000000"; serial0 = "/serial@fdd50000"; serial1 = "/serial@fe650000"; serial2 = "/serial@fe660000"; serial3 = "/serial@fe670000"; serial4 = "/serial@fe680000"; serial5 = "/serial@fe690000"; serial6 = "/serial@fe6a0000"; serial7 = "/serial@fe6b0000"; serial8 = "/serial@fe6c0000"; serial9 = "/serial@fe6d0000"; spi0 = "/spi@fe610000"; spi1 = "/spi@fe620000"; spi2 = "/spi@fe630000"; spi3 = "/spi@fe640000"; }; ethernet@fe010000 { compatible = "rockchip,rk3568-gmac\0snps,dwmac-4.20a"; reg = <0x00 0xfe010000 0x00 0x10000>; interrupts = <0x00 0x20 0x04 0x00 0x1d 0x04>; interrupt-names = "macirq\0eth_wake_irq"; rockchip,grf = <0x32>; clocks = <0x1f 0x186 0x1f 0x189 0x1f 0x189 0x1f 0xc7 0x1f 0xc3 0x1f 0xc4 0x1f 0x189 0x1f 0xc8 0x1f 0xac>; clock-names = "stmmaceth\0mac_clk_rx\0mac_clk_tx\0clk_mac_refout\0aclk_mac\0pclk_mac\0clk_mac_speed\0ptp_ref\0pclk_xpcs"; resets = <0x1f 0xec>; reset-names = "stmmaceth"; snps,mixed-burst; snps,tso; snps,axi-config = <0x78>; snps,mtl-rx-config = <0x79>; snps,mtl-tx-config = <0x7a>; status = "okay"; phy-mode = "rgmii"; clock_in_out = "output"; snps,reset-gpio = <0x7b 0x01 0x01>; snps,reset-active-low; snps,reset-delays-us = <0x00 0x4e20 0x186a0>; assigned-clocks = <0x1f 0x189 0x1f 0x186>; assigned-clock-parents = <0x1f 0x187 0x1f 0xc5>; assigned-clock-rates = <0x00 0x7735940>; pinctrl-names = "default"; pinctrl-0 = <0x7c 0x7d 0x7e 0x7f 0x80>; tx_delay = <0x41>; rx_delay = <0x2e>; phy-handle = <0x81>; phandle = <0x182>; mdio { compatible = "snps,dwmac-mdio"; #address-cells = <0x01>; #size-cells = <0x00>; phandle = <0x183>; phy@0 { compatible = "ethernet-phy-ieee802.3-c22"; reg = <0x00>; phandle = <0x81>; }; }; stmmac-axi-config { snps,wr_osr_lmt = <0x04>; snps,rd_osr_lmt = <0x08>; snps,blen = <0x00 0x00 0x00 0x00 0x10 0x08 0x04>; phandle = <0x78>; }; rx-queues-config { snps,rx-queues-to-use = <0x01>; phandle = <0x79>; queue0 { }; }; tx-queues-config { snps,tx-queues-to-use = <0x01>; phandle = <0x7a>; queue0 { }; }; }; armbian dtb ethernet Spoiler aliases { gpio0 = "/pinctrl/gpio@fdd60000"; gpio1 = "/pinctrl/gpio@fe740000"; gpio2 = "/pinctrl/gpio@fe750000"; gpio3 = "/pinctrl/gpio@fe760000"; gpio4 = "/pinctrl/gpio@fe770000"; i2c0 = "/i2c@fdd40000"; i2c1 = "/i2c@fe5a0000"; i2c2 = "/i2c@fe5b0000"; i2c3 = "/i2c@fe5c0000"; i2c4 = "/i2c@fe5d0000"; i2c5 = "/i2c@fe5e0000"; serial0 = "/serial@fdd50000"; serial1 = "/serial@fe650000"; serial2 = "/serial@fe660000"; serial3 = "/serial@fe670000"; serial4 = "/serial@fe680000"; serial5 = "/serial@fe690000"; serial6 = "/serial@fe6a0000"; serial7 = "/serial@fe6b0000"; serial8 = "/serial@fe6c0000"; serial9 = "/serial@fe6d0000"; spi0 = "/spi@fe610000"; spi1 = "/spi@fe620000"; spi2 = "/spi@fe630000"; spi3 = "/spi@fe640000"; ethernet0 = "/ethernet@fe010000"; mmc0 = "/mmc@fe2b0000"; mmc1 = "/mmc@fe310000"; mmc2 = "/mmc@fe2c0000"; }; ethernet@fe010000 { compatible = "rockchip,rk3568-gmac\0snps,dwmac-4.20a"; reg = <0x00 0xfe010000 0x00 0x10000>; interrupts = <0x00 0x20 0x04 0x00 0x1d 0x04>; interrupt-names = "macirq\0eth_wake_irq"; clocks = <0x0e 0x186 0x0e 0x189 0x0e 0x189 0x0e 0xc7 0x0e 0xc3 0x0e 0xc4 0x0e 0x189 0x0e 0xc8>; clock-names = "stmmaceth\0mac_clk_rx\0mac_clk_tx\0clk_mac_refout\0aclk_mac\0pclk_mac\0clk_mac_speed\0ptp_ref"; resets = <0x0e 0xec>; reset-names = "stmmaceth"; rockchip,grf = <0x1e>; snps,axi-config = <0x45>; snps,mixed-burst; snps,mtl-rx-config = <0x46>; snps,mtl-tx-config = <0x47>; snps,tso; status = "okay"; assigned-clocks = <0x0e 0x189 0x0e 0x187 0x0e 0x186>; assigned-clock-parents = <0x0e 0x187 0x0e 0x186 0x48>; clock_in_out = "input"; phy-supply = <0x1b>; phy-mode = "rgmii"; pinctrl-names = "default"; pinctrl-0 = <0x49 0x4a 0x4b 0x4c 0x4d 0x4e>; snps,reset-gpio = <0x21 0x0f 0x01>; snps,reset-active-low; snps,reset-delays-us = <0x00 0x4e20 0x186a0>; tx_delay = <0x41>; rx_delay = <0x2e>; phy-handle = <0x4f>; phandle = <0xea>; mdio { compatible = "snps,dwmac-mdio"; #address-cells = <0x01>; #size-cells = <0x00>; phandle = <0xeb>; ethernet-phy@0 { compatible = "ethernet-phy-ieee802.3-c22"; reg = <0x00>; status = "okay"; phandle = <0x4f>; }; }; stmmac-axi-config { snps,blen = <0x00 0x00 0x00 0x00 0x10 0x08 0x04>; snps,rd_osr_lmt = <0x08>; snps,wr_osr_lmt = <0x04>; phandle = <0x45>; }; rx-queues-config { snps,rx-queues-to-use = <0x01>; phandle = <0x46>; queue0 { }; }; tx-queues-config { snps,tx-queues-to-use = <0x01>; phandle = <0x47>; queue0 { }; }; }; Edited December 28, 2024 by Andre B 0 Quote
Andre B Posted December 28, 2024 Posted December 28, 2024 full androiod dmesg : there's a line [ 0.833910] ********************************jl2101 test**************************************** Spoiler [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x412fd050] [ 0.000000] Linux version 4.19.172 (pc@ubuntu2) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05), GNU ld (Linaro_Binutils-2017.05) 2.27.0.20161019) #75 SMP PREEMPT Thu Nov 24 11:06:53 CST 2022 [ 0.000000] Machine model: Rockchip RK3566 EVB3 DDR3 V10 Board [ 0.000000] earlycon: uart8250 at MMIO32 0x00000000fe660000 (options '') [ 0.000000] bootconsole [uart8250] enabled [ 0.000000] Reserved memory: created CMA memory pool at 0x0000000010000000, size 8 MiB [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool [ 0.000000] On node 0 totalpages: 2027008 [ 0.000000] DMA32 zone: 15288 pages used for memmap [ 0.000000] DMA32 zone: 0 pages reserved [ 0.000000] DMA32 zone: 978432 pages, LIFO batch:63 [ 0.000000] Normal zone: 16384 pages used for memmap [ 0.000000] Normal zone: 1048576 pages, LIFO batch:63 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.2 [ 0.000000] percpu: Embedded 24 pages/cpu s58968 r8192 d31144 u98304 [ 0.000000] pcpu-alloc: s58968 r8192 d31144 u98304 alloc=24*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: Virtualization Host Extensions [ 0.000000] CPU features: detected: Hardware dirty bit management [ 0.000000] CPU features: detected: Speculative Store Bypassing Safe (SSBS) [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1995336 [ 0.000000] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal androidboot.dtb_idx=0 androidboot.dtbo_idx=0 androidboot.verifiedbootstate=orange androidboot.slot_suffix= androidboot.serialno=9KFNYA59G7 console=ttyFIQ0 androidboot.baseband=N/A androidboot.wificountrycode=XS androidboot.veritymode=enforcing androidboot.hardware=rk30board androidboot.console=ttyFIQ0 androidboot.verifiedbootstate=orange firmware_class.path=/vendor/etc/firmware init=/init rootwait ro loop.max_part=7 androidboot.selinux=permissive buildvariant=userdebug earlycon=uart8250,mmio32,0xfe660000 androidboot.boot_devices=fe310000.sdhci,fe330000.nandc [ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes) [ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] software IO TLB: mapped [mem 0xe9f00000-0xedf00000] (64MB) [ 0.000000] Memory: 7848364K/8108032K available (15486K kernel code, 2116K rwdata, 9292K rodata, 4160K init, 2230K bss, 251476K reserved, 8192K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4. [ 0.000000] Tasks RCU enabled. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: Distributor has no Range Selector support [ 0.000000] GICv3: no VLPI support, no direct LPI support [ 0.000000] ITS [mem 0xfd440000-0xfd45ffff] [ 0.000000] ITS@0x00000000fd440000: allocated 8192 Devices @210000 (indirect, esz 8, psz 64K, shr 0) [ 0.000000] ITS@0x00000000fd440000: allocated 32768 Interrupt Collections @220000 (flat, esz 2, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GIC: using LPI property table @0x0000000000230000 [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000 [ 0.000000] CPU0: using LPI pending table @0x0000000000240000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] random: random: get_random_bytes called from start_kernel+0x36c/0x4f0 with crng_init=0 [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.001580] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000) [ 0.002548] pid_max: default: 32768 minimum: 301 [ 0.003075] Security Framework initialized [ 0.003465] SELinux: Initializing. [ 0.003896] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes) [ 0.004568] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes) [ 0.006504] ASID allocator initialised with 32768 entries [ 0.007102] rcu: Hierarchical SRCU implementation. [ 0.007922] Platform MSI: interrupt-controller@fd440000 domain created [ 0.008907] PCI/MSI: /interrupt-controller@fd400000/interrupt-controller@fd440000 domain created [ 0.010334] smp: Bringing up secondary CPUs ... [ 0.011222] Detected VIPT I-cache on CPU1 [ 0.011249] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000 [ 0.011286] CPU1: using LPI pending table @0x0000000000250000 [ 0.011327] CPU1: Booted secondary processor 0x0000000100 [0x412fd050] [ 0.011873] Detected VIPT I-cache on CPU2 [ 0.011895] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000 [ 0.011933] CPU2: using LPI pending table @0x0000000000260000 [ 0.011962] CPU2: Booted secondary processor 0x0000000200 [0x412fd050] [ 0.012511] Detected VIPT I-cache on CPU3 [ 0.012528] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000 [ 0.012563] CPU3: using LPI pending table @0x0000000000270000 [ 0.012588] CPU3: Booted secondary processor 0x0000000300 [0x412fd050] [ 0.012666] smp: Brought up 1 node, 4 CPUs [ 0.019611] SMP: Total of 4 processors activated. [ 0.020053] CPU features: detected: GIC system register CPU interface [ 0.020655] CPU features: detected: Privileged Access Never [ 0.021175] CPU features: detected: LSE atomic instructions [ 0.021696] CPU features: detected: User Access Override [ 0.022192] CPU features: detected: 32-bit EL0 Support [ 0.022671] CPU features: detected: RAS Extension Support [ 0.029997] CPU: All CPU(s) started at EL2 [ 0.030406] alternatives: patching kernel code [ 0.035707] devtmpfs: initialized [ 0.049529] Trying to unpack rootfs image as initramfs... [ 0.050047] Registered cp15_barrier emulation handler [ 0.050543] Registered setend emulation handler [ 0.051323] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns [ 0.052247] futex hash table entries: 1024 (order: 4, 65536 bytes) [ 0.052973] pinctrl core: initialized pinctrl subsystem [ 0.054249] NET: Registered protocol family 16 [ 0.061498] schedtune: configured to support 6 boost groups [ 0.062165] audit: initializing netlink subsys (disabled) [ 0.062829] audit: type=2000 audit(0.059:1): state=initialized audit_enabled=0 res=1 [ 0.064606] cpuidle: using governor menu [ 0.065023] Registered FIQ tty driver [ 0.065937] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.066809] DMA: preallocated 256 KiB pool for atomic allocations [ 0.071177] console [pstore-1] enabled [ 0.071736] pstore: Registered ramoops as persistent store backend [ 0.072322] ramoops: attached 0xf0000@0x110000, ecc: 0/0 [ 0.073944] Freeing initrd memory: 880K [ 0.090477] rockchip-gpio fdd60000.gpio: probed gpio0 (fdd60000.gpio) [ 0.091461] rockchip-gpio fe740000.gpio: probed gpio1 (fe740000.gpio) [ 0.092427] rockchip-gpio fe750000.gpio: probed gpio2 (fe750000.gpio) [ 0.093367] rockchip-gpio fe760000.gpio: probed gpio3 (fe760000.gpio) [ 0.094298] rockchip-gpio fe770000.gpio: probed gpio4 (fe770000.gpio) [ 0.094964] rockchip-pinctrl pinctrl: probed pinctrl [ 0.103625] cryptd: max_cpu_qlen set to 1000 [ 0.105535] console [ttyFIQ0] enabled [ 0.106215] bootconsole [uart8250] disabled [ 0.106814] Registered fiq debugger ttyFIQ0 [ 0.107497] vcc3v3_sys: supplied by dc_12v [ 0.107724] vcc5v0_sys: supplied by dc_12v [ 0.108815] vcc3v3_vga: supplied by vcc3v3_sys [ 0.109623] rk_iommu fde4b000.iommu: version = 2 [ 0.110014] rk_iommu fdea0800.iommu: version = 2 [ 0.110332] rk_iommu fded0480.iommu: version = 2 [ 0.110513] rk_iommu fdee0800.iommu: version = 2 [ 0.110689] rk_iommu fdef0800.iommu: version = 2 [ 0.110861] rk_iommu fdf40f00.iommu: version = 2 [ 0.111065] rk_iommu fdf80800.iommu: version = 2 [ 0.111249] rk_iommu fdff1a00.iommu: version = 2 [ 0.111440] rk_iommu fe043e00.iommu: version = 2 [ 0.111976] SCSI subsystem initialized [ 0.112032] libata version 3.00 loaded. [ 0.112171] usbcore: registered new interface driver usbfs [ 0.112222] usbcore: registered new interface driver hub [ 0.112263] usbcore: registered new device driver usb [ 0.112590] media: Linux media interface: v0.10 [ 0.112628] videodev: Linux video capture interface: v2.00 [ 0.112708] pps_core: LinuxPPS API ver. 1 registered [ 0.112723] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.112744] PTP clock support registered [ 0.112962] arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0 [ 0.115072] Advanced Linux Sound Architecture Driver Initialized. [ 0.115420] Bluetooth: Core ver 2.22 [ 0.115464] NET: Registered protocol family 31 [ 0.115477] Bluetooth: HCI device and connection manager initialized [ 0.115495] Bluetooth: HCI socket layer initialized [ 0.115509] Bluetooth: L2CAP socket layer initialized [ 0.115594] Bluetooth: SCO socket layer initialized [ 0.115940] rockchip-cpuinfo cpuinfo: SoC : 35662000 [ 0.115958] rockchip-cpuinfo cpuinfo: Serial : 1df547fa866419ff [ 0.116880] clocksource: Switched to clocksource arch_sys_counter [ 0.165685] VFS: Disk quotas dquot_6.6.0 [ 0.165776] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.166854] thermal thermal_zone1: power_allocator: sustainable_power will be estimated [ 0.167166] NET: Registered protocol family 2 [ 0.167638] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes) [ 0.167703] TCP established hash table entries: 65536 (order: 7, 524288 bytes) [ 0.168028] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes) [ 0.168824] TCP: Hash tables configured (established 65536 bind 65536) [ 0.169000] UDP hash table entries: 4096 (order: 5, 131072 bytes) [ 0.169111] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes) [ 0.169340] NET: Registered protocol family 1 [ 0.169952] PCI: CLS 0 bytes, default 64 [ 0.171443] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available [ 0.172739] Initialise system trusted keyrings [ 0.172954] workingset: timestamp_bits=45 max_order=21 bucket_order=0 [ 0.176719] utf8_selftest: All 154 tests passed [ 0.176746] fuse init (API version 7.27) [ 0.177507] exFAT: Version 1.2.9 [ 0.177865] [ 0.177865] TEE Core Framework initialization (ver 1:0.1) [ 0.177893] TEE armv7 Driver initialization [ 0.178343] tz_tee_probe: name="armv7sec", id=0, pdev_name="armv7sec.0" [ 0.178362] TEE core: Alloc the misc device "opteearmtz00" (id=0) [ 0.178523] TEE Core: Register the misc device "opteearmtz00" (id=0,minor=62) [ 0.179652] Key type asymmetric registered [ 0.179670] Asymmetric key parser 'x509' registered [ 0.179707] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243) [ 0.179723] io scheduler noop registered [ 0.179845] io scheduler cfq registered (default) [ 0.179854] io scheduler mq-deadline registered [ 0.179860] io scheduler kyber registered [ 0.179938] io scheduler bfq registered [ 0.180699] rockchip-csi2-dphy csi2-dphy0: csi2 dphy0 probe successfully! [ 0.180823] rockchip-csi2-dphy-hw fe870000.csi2-dphy-hw: csi2 dphy hw probe successfully! [ 0.181948] phy phy-fe8a0000.usb2-phy.0: Linked as a consumer to regulator.4 [ 0.182133] phy phy-fe8a0000.usb2-phy.1: Linked as a consumer to regulator.5 [ 0.183225] extcon extcon1: failed to create extcon usb2-phy link [ 0.183324] phy phy-fe8b0000.usb2-phy.2: Linked as a consumer to regulator.4 [ 0.183439] phy phy-fe8b0000.usb2-phy.3: Linked as a consumer to regulator.4 [ 0.183507] phy phy-fe8b0000.usb2-phy.3: No vbus specified for otg port [ 0.188428] pwm-backlight backlight: backlight supply power not found, using dummy regulator [ 0.188524] pwm-backlight backlight: Linked as a consumer to regulator.0 [ 0.188667] pwm-backlight backlight1: backlight1 supply power not found, using dummy regulator [ 0.188719] pwm-backlight backlight1: Linked as a consumer to regulator.0 [ 0.188994] iep: Module initialized. [ 0.189050] mpp_service mpp-srv: 9cf57bf author: Ding Wei 2021-06-04 video: rockchip: mpp: rkvdec2: add rcb-min-width info for rcb usage [ 0.189067] mpp_service mpp-srv: probe start [ 0.189677] iommu: Adding device fdf40000.rkvenc to group 5 [ 0.189708] mpp_rkvenc fdf40000.rkvenc: Linked as a consumer to fdf40f00.iommu [ 0.189873] mpp_rkvenc fdf40000.rkvenc: probing start [ 0.190295] mpp_rkvenc fdf40000.rkvenc: venc regulator not ready, retry [ 0.190312] rkvenc_init:1195: failed to add venc devfreq [ 0.191431] iommu: Adding device fdea0400.vdpu to group 1 [ 0.191463] mpp_vdpu2 fdea0400.vdpu: Linked as a consumer to fdea0800.iommu [ 0.191593] mpp_vdpu2 fdea0400.vdpu: probe device [ 0.192054] mpp_vdpu2 fdea0400.vdpu: probing finish [ 0.192444] iommu: Adding device fdee0000.vepu to group 3 [ 0.192473] mpp_vepu2 fdee0000.vepu: Linked as a consumer to fdee0800.iommu [ 0.192618] mpp_vepu2 fdee0000.vepu: probe device [ 0.193041] mpp_vepu2 fdee0000.vepu: probing finish [ 0.193458] iommu: Adding device fdef0000.iep to group 4 [ 0.193489] mpp-iep2 fdef0000.iep: Linked as a consumer to fdef0800.iommu [ 0.193629] mpp-iep2 fdef0000.iep: probe device [ 0.194000] mpp-iep2 fdef0000.iep: allocate roi buffer failed [ 0.194126] mpp-iep2 fdef0000.iep: probing finish [ 0.194510] iommu: Adding device fded0000.jpegd to group 2 [ 0.194546] mpp_jpgdec fded0000.jpegd: Linked as a consumer to fded0480.iommu [ 0.194647] mpp_jpgdec fded0000.jpegd: probe device [ 0.195044] mpp_jpgdec fded0000.jpegd: probing finish [ 0.195427] iommu: Adding device fdf80200.rkvdec to group 6 [ 0.195447] mpp_rkvdec2 fdf80200.rkvdec: Linked as a consumer to fdf80800.iommu [ 0.195619] mpp_rkvdec2 fdf80200.rkvdec: probing start [ 0.195925] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_a is not found! [ 0.195942] rkvdec2_init:821: No niu aclk reset resource define [ 0.195957] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_h is not found! [ 0.195968] rkvdec2_init:824: No niu hclk reset resource define [ 0.196229] mpp_rkvdec2 fdf80200.rkvdec: sram_start 0x00000000fdcc0000 [ 0.196247] mpp_rkvdec2 fdf80200.rkvdec: rcb_iova 0x0000000010000000 [ 0.196260] mpp_rkvdec2 fdf80200.rkvdec: sram_size 45056 [ 0.196271] mpp_rkvdec2 fdf80200.rkvdec: rcb_size 65536 [ 0.196285] mpp_rkvdec2 fdf80200.rkvdec: min_width 512 [ 0.196305] mpp_rkvdec2 fdf80200.rkvdec: probing finish [ 0.196557] mpp_service mpp-srv: probe success [ 0.200417] dma-pl330 fe530000.dmac: Loaded driver for PL330 DMAC-241330 [ 0.200450] dma-pl330 fe530000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 0.201876] dma-pl330 fe550000.dmac: Loaded driver for PL330 DMAC-241330 [ 0.201898] dma-pl330 fe550000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 0.202915] rockchip-system-monitor rockchip-system-monitor: system monitor probe [ 0.203669] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled [ 0.204272] fe650000.serial: ttyS1 at MMIO 0xfe650000 (irq = 56, base_baud = 1500000) is a 16550A [ 0.204669] fe6d0000.serial: ttyS9 at MMIO 0xfe6d0000 (irq = 57, base_baud = 1500000) is a 16550A [ 0.206105] random: fast init done [ 0.206390] random: crng init done [ 0.206472] iommu: Adding device fe040000.vop to group 8 [ 0.206497] rockchip-vop2 fe040000.vop: Linked as a consumer to fe043e00.iommu [ 0.209495] rockchip-drm display-subsystem: Linked as a consumer to fe040000.vop [ 0.209862] rockchip-drm display-subsystem: Linked as a consumer to fe0c0000.edp [ 0.210176] rockchip-drm display-subsystem: Linked as a consumer to fe0a0000.hdmi [ 0.211281] rockchip-drm display-subsystem: dmc is disabled [ 0.211512] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x15, primary plane phy id: 4 [ 0.211537] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp1 assign plane mask: 0x0, primary plane phy id: -1 [ 0.211556] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x0, primary plane phy id: -1 [ 0.211721] [drm] unsupported AFBC format[3432564e] [ 0.212256] rockchip-drm display-subsystem: bound fe040000.vop (ops vop2_component_ops) [ 0.213027] rockchip-drm display-subsystem: bound fe0c0000.edp (ops rockchip_dp_component_ops) [ 0.213208] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY) [ 0.213617] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver [ 0.214027] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops dw_hdmi_rockchip_ops) [ 0.214050] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 0.214062] [drm] No driver support for vblank timestamp query. [ 0.667741] rockchip-drm display-subsystem: fb0: frame buffer device [ 0.668506] [drm] Initialized rockchip 2.0.0 20140818 for display-subsystem on minor 0 [ 0.674109] mali fde60000.gpu: Kernel DDK version g2p0-01eac0 [ 0.674205] mali fde60000.gpu: Power management initialization failed error = -517 [ 0.674230] mali fde60000.gpu: Device initialization Deferred [ 0.674545] cacheinfo: Unable to detect cache hierarchy for CPU 0 [ 0.679751] brd: module loaded [ 0.690501] loop: module loaded [ 0.690849] zram: Added device: zram0 [ 0.691164] SCSI Media Changer driver v0.25 [ 0.692135] ahci fc800000.sata: forcing port_map 0x0 -> 0x1 [ 0.692185] ahci fc800000.sata: AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl platform mode [ 0.692196] ahci fc800000.sata: flags: ncq sntf pm led clo only pmp fbs pio slum part ccc apst [ 0.692224] ahci fc800000.sata: port 0 is not capable of FBS [ 0.692765] scsi host0: ahci [ 0.693034] ata1: SATA max UDMA/133 mmio [mem 0xfc800000-0xfc800fff] port 0x100 irq 11 [ 0.694625] libphy: Fixed MDIO Bus: probed [ 0.694662] tun: Universal TUN/TAP device driver, 1.6 [ 0.696021] rk_gmac-dwmac fe010000.ethernet: no regulator found [ 0.696044] rk_gmac-dwmac fe010000.ethernet: clock input or output? (output). [ 0.696059] rk_gmac-dwmac fe010000.ethernet: TX delay(0x41). [ 0.696073] rk_gmac-dwmac fe010000.ethernet: RX delay(0x2e). [ 0.696089] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no). [ 0.701131] rk_gmac-dwmac fe010000.ethernet: init for RGMII [ 0.701350] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51 [ 0.701369] rk_gmac-dwmac fe010000.ethernet: DWMAC4/5 [ 0.701430] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported [ 0.701448] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported [ 0.701461] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported [ 0.701472] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported [ 0.701509] rk_gmac-dwmac fe010000.ethernet: TSO supported [ 0.701523] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 0.701536] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled [ 0.833561] libphy: stmmac: probed [ 0.833910] ********************************jl2101 test**************************************** [ 0.835092] PPP generic driver version 2.4.2 [ 0.835253] PPP BSD Compression module registered [ 0.835268] PPP Deflate Compression module registered [ 0.835303] PPP MPPE Compression module registered [ 0.835316] NET: Registered protocol family 24 [ 0.835342] PPTP driver version 0.8.5 [ 0.835585] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled). [ 0.835594] CSLIP: code copyright 1989 Regents of the University of California. [ 0.835685] usbcore: registered new interface driver catc [ 0.835730] usbcore: registered new interface driver kaweth [ 0.835744] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver [ 0.835781] usbcore: registered new interface driver pegasus [ 0.835820] usbcore: registered new interface driver rtl8150 [ 0.835862] usbcore: registered new interface driver r8152 [ 0.835870] hso: drivers/net/usb/hso.c: Option Wireless [ 0.835924] usbcore: registered new interface driver hso [ 0.835961] usbcore: registered new interface driver asix [ 0.836000] usbcore: registered new interface driver ax88179_178a [ 0.836041] usbcore: registered new interface driver cdc_ether [ 0.836080] usbcore: registered new interface driver cdc_eem [ 0.836113] usbcore: registered new interface driver dm9601 [ 0.836155] usbcore: registered new interface driver smsc75xx [ 0.836203] usbcore: registered new interface driver smsc95xx [ 0.836243] usbcore: registered new interface driver gl620a [ 0.836280] usbcore: registered new interface driver net1080 [ 0.836318] usbcore: registered new interface driver plusb [ 0.836356] usbcore: registered new interface driver rndis_host [ 0.836396] usbcore: registered new interface driver cdc_subset [ 0.836435] usbcore: registered new interface driver zaurus [ 0.836474] usbcore: registered new interface driver MOSCHIP usb-ethernet driver [ 0.836516] usbcore: registered new interface driver int51x1 [ 0.836554] usbcore: registered new interface driver kalmia [ 0.836597] usbcore: registered new interface driver ipheth [ 0.836635] usbcore: registered new interface driver sierra_net [ 0.836673] usbcore: registered new interface driver cx82310_eth [ 0.836714] usbcore: registered new interface driver cdc_ncm [ 0.836753] usbcore: registered new interface driver qmi_wwan [ 0.836796] usbcore: registered new interface driver cdc_mbim [ 0.837910] dwc3 fcc00000.dwc3: Failed to get clk 'ref': -2 [ 0.840781] dwc3 fd000000.dwc3: Failed to get clk 'ref': -2 [ 0.844424] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.844445] ehci-pci: EHCI PCI platform driver [ 0.844517] ehci-platform: EHCI generic platform driver [ 0.844731] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 0.844755] ohci-platform: OHCI generic platform driver [ 0.845419] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller [ 0.845593] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 1 [ 0.845747] xhci-hcd xhci-hcd.6.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000001002010010 [ 0.845802] xhci-hcd xhci-hcd.6.auto: irq 70, io mem 0xfcc00000 [ 0.846075] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19 [ 0.846093] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.846105] usb usb1: Product: xHCI Host Controller [ 0.846117] usb usb1: Manufacturer: Linux 4.19.172 xhci-hcd [ 0.846128] usb usb1: SerialNumber: xhci-hcd.6.auto [ 0.846493] hub 1-0:1.0: USB hub found [ 0.846539] hub 1-0:1.0: 1 port detected [ 0.846819] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller [ 0.846989] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 2 [ 0.847011] xhci-hcd xhci-hcd.6.auto: Host supports USB 3.0 SuperSpeed [ 0.847078] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 0.847188] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19 [ 0.847204] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.847217] usb usb2: Product: xHCI Host Controller [ 0.847229] usb usb2: Manufacturer: Linux 4.19.172 xhci-hcd [ 0.847240] usb usb2: SerialNumber: xhci-hcd.6.auto [ 0.847565] hub 2-0:1.0: USB hub found [ 0.847604] hub 2-0:1.0: 1 port detected [ 0.847987] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller [ 0.848127] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 3 [ 0.848272] xhci-hcd xhci-hcd.7.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000011002010010 [ 0.848329] xhci-hcd xhci-hcd.7.auto: irq 71, io mem 0xfd000000 [ 0.848584] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19 [ 0.848600] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.848608] usb usb3: Product: xHCI Host Controller [ 0.848614] usb usb3: Manufacturer: Linux 4.19.172 xhci-hcd [ 0.848621] usb usb3: SerialNumber: xhci-hcd.7.auto [ 0.848930] hub 3-0:1.0: USB hub found [ 0.848968] hub 3-0:1.0: 1 port detected [ 0.849210] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller [ 0.849339] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 4 [ 0.849361] xhci-hcd xhci-hcd.7.auto: Host supports USB 3.0 SuperSpeed [ 0.849427] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM. [ 0.849540] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19 [ 0.849556] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.849563] usb usb4: Product: xHCI Host Controller [ 0.849570] usb usb4: Manufacturer: Linux 4.19.172 xhci-hcd [ 0.849576] usb usb4: SerialNumber: xhci-hcd.7.auto [ 0.849880] hub 4-0:1.0: USB hub found [ 0.849918] hub 4-0:1.0: 1 port detected [ 0.850307] usbcore: registered new interface driver cdc_acm [ 0.850324] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 0.850381] usbcore: registered new interface driver usblp [ 0.850426] usbcore: registered new interface driver cdc_wdm [ 0.850642] usbcore: registered new interface driver uas [ 0.850717] usbcore: registered new interface driver usb-storage [ 0.850759] usbcore: registered new interface driver ums-alauda [ 0.850793] usbcore: registered new interface driver ums-cypress [ 0.850836] usbcore: registered new interface driver ums-datafab [ 0.850876] usbcore: registered new interface driver ums_eneub6250 [ 0.850919] usbcore: registered new interface driver ums-freecom [ 0.850962] usbcore: registered new interface driver ums-isd200 [ 0.851005] usbcore: registered new interface driver ums-jumpshot [ 0.851038] usbcore: registered new interface driver ums-karma [ 0.851079] usbcore: registered new interface driver ums-onetouch [ 0.851120] usbcore: registered new interface driver ums-sddr09 [ 0.851162] usbcore: registered new interface driver ums-sddr55 [ 0.851206] usbcore: registered new interface driver ums-usbat [ 0.851289] usbcore: registered new interface driver usbserial_generic [ 0.851319] usbserial: USB Serial support registered for generic [ 0.851367] usbcore: registered new interface driver option [ 0.851395] usbserial: USB Serial support registered for GSM modem (1-port) [ 0.851523] usbcore: registered new interface driver trancevibrator [ 0.852096] usbcore: registered new interface driver xpad [ 0.852147] usbcore: registered new interface driver usb_acecad [ 0.852193] usbcore: registered new interface driver aiptek [ 0.852229] usbcore: registered new interface driver gtco [ 0.852277] usbcore: registered new interface driver hanwang [ 0.852321] usbcore: registered new interface driver kbtab [ 0.852640] cyttsp5_loader_init: Parade TTSP FW Loader Driver (Built TTDA.03.08.874312) rc=0 [ 0.852659] cyttsp5_device_access_init: Parade TTSP Device Access Driver (Built TTDA.03.08.874312) rc=0 [ 0.852870] .. rk pwm remotectl v2.0 init [ 0.853105] input: fdd70030.pwm as /devices/platform/fdd70030.pwm/input/input0 [ 0.853409] remotectl-pwm fdd70030.pwm: pwm version is 0x2130000 [ 0.853426] remotectl-pwm fdd70030.pwm: cannot find PWR IRQ [ 0.853443] remotectl-pwm fdd70030.pwm: pwm sip wakeup config error!! [ 0.853456] remotectl-pwm fdd70030.pwm: Donot support ATF Wakeup [ 0.854745] i2c /dev entries driver [ 0.856641] rk808 0-0020: chip id: 0x8090 [ 0.856686] rk808 0-0020: No cache defaults, reading back from HW [ 0.880363] rk808 0-0020: source: on=0x40, off=0x00 [ 0.880384] rk808 0-0020: support dcdc3 fb mode:-22, 63 [ 0.880399] rk808 0-0020: support pmic reset mode:0,0 [ 0.885017] rk808-regulator rk808-regulator: there is no dvs0 gpio [ 0.885054] rk808-regulator rk808-regulator: there is no dvs1 gpio [ 0.885249] vdd_logic: supplied by vcc3v3_sys [ 0.885495] vdd_gpu: supplied by vcc3v3_sys [ 0.885701] vcc_ddr: supplied by vcc3v3_sys [ 0.885929] vdd_npu: supplied by vcc3v3_sys [ 0.886178] vcc_1v8: supplied by vcc3v3_sys [ 0.886393] vdda0v9_image: supplied by vcc3v3_sys [ 0.886612] vdda_0v9: supplied by vcc3v3_sys [ 0.886815] vdda0v9_pmu: supplied by vcc3v3_sys [ 0.887086] vccio_acodec: supplied by vcc3v3_sys [ 0.887308] vccio_sd: supplied by vcc3v3_sys [ 0.887534] vcc3v3_pmu: supplied by vcc3v3_sys [ 0.887744] vcca_1v8: supplied by vcc3v3_sys [ 0.887967] vcca1v8_pmu: supplied by vcc3v3_sys [ 0.888196] vcca1v8_image: supplied by vcc3v3_sys [ 0.888412] vcc_3v3: supplied by vcc3v3_sys [ 0.888618] vcc3v3_sd: supplied by vcc3v3_sys [ 0.888850] rk817-battery rk817-battery: Failed to find matching dt id [ 0.889049] rk817-charger rk817-charger: Failed to find matching dt id [ 0.892065] input: rk805 pwrkey as /devices/platform/fdd40000.i2c/i2c-0/0-0020/rk805-pwrkey/input/input1 [ 0.897986] rk808-rtc rk808-rtc: registered as rtc0 [ 0.899682] rk808-rtc rk808-rtc: setting system clock to 2022-11-26 04:28:42 UTC (1669436922) [ 0.901219] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected! [ 0.901698] vdd_cpu: Bringing 1000000uV into 1050000-1050000uV [ 0.907373] vdd_cpu: supplied by vcc5v0_sys [ 0.909083] rockchip-pinctrl pinctrl: pin gpio3-11 already requested by fe010000.ethernet; cannot claim for fe5e0000.i2c [ 0.909105] rockchip-pinctrl pinctrl: pin-107 (fe5e0000.i2c) status -22 [ 0.909119] rockchip-pinctrl pinctrl: could not request pin 107 (gpio3-11) from group i2c5m0-xfer on device rockchip-pinctrl [ 0.909132] rk3x-i2c fe5e0000.i2c: Error applying setting, reverse things back [ 0.909157] rk3x-i2c: probe of fe5e0000.i2c failed with error -22 [ 0.910893] rkcifhw fdfe0000.rkcif: iommu is disabled, using non-iommu buffers [ 0.910913] rkcifhw fdfe0000.rkcif: No reserved memory region assign to CIF [ 0.911077] rkcif rkcif_dvp: rkcif driver version: v00.01.0a [ 0.911120] rkcif rkcif_dvp: attach to cif hw node [ 0.913111] iommu: Adding device fdff0000.rkisp to group 7 [ 0.913145] rkisp_hw fdff0000.rkisp: Linked as a consumer to fdff1a00.iommu [ 0.913295] rkisp_hw fdff0000.rkisp: is_thunderboot: 0 [ 0.913313] rkisp_hw fdff0000.rkisp: max input:0x0@0fps [ 0.913341] rkisp_hw fdff0000.rkisp: can't request region for resource [mem 0xfdff0000-0xfdffffff] [ 0.913953] rkisp rkisp-vir0: rkisp driver version: v01.06.01 [ 0.914018] rkisp rkisp-vir0: No memory-region-thunderboot specified [ 0.914163] rkisp rkisp-vir0: Entity type for entity rkisp-isp-subdev was not initialized! [ 0.914185] rkisp rkisp-vir0: Entity type for entity rkisp-csi-subdev was not initialized! [ 0.915534] usbcore: registered new interface driver uvcvideo [ 0.915551] USB Video Class driver (1.1.1) [ 0.915784] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.20 [ 0.915817] rockchip-iodomain fdc20000.syscon:io-domains: pmuio1(3300000 uV) supplied by vcc3v3_pmu [ 0.915890] rockchip-iodomain fdc20000.syscon:io-domains: pmuio2(3300000 uV) supplied by vcc3v3_pmu [ 0.915974] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.18 [ 0.916003] rockchip-iodomain fdc20000.syscon:io-domains: vccio1(3300000 uV) supplied by vccio_acodec [ 0.916092] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.19 [ 0.916114] rockchip-iodomain fdc20000.syscon:io-domains: vccio3(3300000 uV) supplied by vccio_sd [ 0.916173] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.14 [ 0.916200] rockchip-iodomain fdc20000.syscon:io-domains: vccio4(1800000 uV) supplied by vcc_1v8 [ 0.916278] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.24 [ 0.916307] rockchip-iodomain fdc20000.syscon:io-domains: vccio5(3300000 uV) supplied by vcc_3v3 [ 0.916374] rockchip-iodomain fdc20000.syscon:io-domains: vccio6(1800000 uV) supplied by vcc_1v8 [ 0.916449] rockchip-iodomain fdc20000.syscon:io-domains: vccio7(3300000 uV) supplied by vcc_3v3 [ 0.917775] __power_supply_register: Expected proper parent device for 'test_ac' [ 0.917907] __power_supply_register: Expected proper parent device for 'test_battery' [ 0.918106] thermal thermal_zone2: power_allocator: sustainable_power will be estimated [ 0.918182] __power_supply_register: Expected proper parent device for 'test_usb' [ 0.919843] rockchip-thermal fe710000.tsadc: tsadc is probed successfully! [ 0.920768] device-mapper: uevent: version 1.0.3 [ 0.920988] device-mapper: ioctl: 4.39.0-ioctl (2018-04-03) initialised: dm-devel@redhat.com [ 0.921164] device-mapper: verity-avb: AVB error handler initialized with vbmeta device: [ 0.921183] Bluetooth: HCI UART driver ver 2.3 [ 0.921197] Bluetooth: HCI UART protocol H4 registered [ 0.921453] cpu cpu0: leakage=33 [ 0.921501] cpu cpu0: pvtm = 86980, from nvmem [ 0.921519] cpu cpu0: pvtm-volt-sel=1 [ 0.922284] cpu cpu0: Linked as a consumer to regulator.26 [ 0.922338] cpu cpu0: Dropping the link to regulator.26 [ 0.922932] cpu cpu0: Linked as a consumer to regulator.26 [ 0.923213] cpu cpu0: avs=0 [ 0.923320] energy_model: Created perf domain 0-3 [ 0.923349] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0 [ 0.926564] sdhci: Secure Digital Host Controller Interface driver [ 0.926583] sdhci: Copyright(c) Pierre Ossman [ 0.926594] Synopsys Designware Multimedia Card Interface Driver [ 0.927563] dwmmc_rockchip fe2b0000.dwmmc: IDMAC supports 32-bit address mode. [ 0.927613] dwmmc_rockchip fe2b0000.dwmmc: Using internal DMA controller. [ 0.927625] dwmmc_rockchip fe2b0000.dwmmc: Version ID is 270a [ 0.927673] dwmmc_rockchip fe2b0000.dwmmc: DW MMC controller at irq 41,32 bit host data width,256 deep fifo [ 0.927781] dwmmc_rockchip fe2b0000.dwmmc: Linked as a consumer to regulator.25 [ 0.927844] dwmmc_rockchip fe2b0000.dwmmc: Linked as a consumer to regulator.19 [ 0.940744] mmc_host mmc0: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0) [ 0.953922] dwmmc_rockchip fe2c0000.dwmmc: IDMAC supports 32-bit address mode. [ 0.953980] dwmmc_rockchip fe2c0000.dwmmc: Using internal DMA controller. [ 0.953993] dwmmc_rockchip fe2c0000.dwmmc: Version ID is 270a [ 0.954040] dwmmc_rockchip fe2c0000.dwmmc: DW MMC controller at irq 42,32 bit host data width,256 deep fifo [ 0.954149] dwmmc_rockchip fe2c0000.dwmmc: allocated mmc-pwrseq [ 0.954167] mmc_host mmc1: card is non-removable. [ 1.007003] ata1: SATA link down (SStatus 0 SControl 300) [ 1.170743] mmc_host mmc1: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0) [ 1.173602] usb 1-1: new full-speed USB device number 2 using xhci-hcd [ 1.183660] sdhci-pltfm: SDHCI platform and OF driver helper [ 1.184664] mmc2: Unknown controller version (5). You may experience problems. [ 1.216200] mmc2: SDHCI controller on fe310000.sdhci [fe310000.sdhci] using ADMA [ 1.219773] mmc1: queuing unknown CIS tuple 0x80 (2 bytes) [ 1.220024] hidraw: raw HID events driver (C) Jiri Kosina [ 1.222459] usbcore: registered new interface driver usbhid [ 1.222483] usbhid: USB HID core driver [ 1.222552] ion_device_add_heap: ion_system_contig_heap id=0 type=1 [ 1.222568] orders[0] = 6 [ 1.222579] orders[1] = 4 [ 1.222591] orders[2] = 0 [ 1.222833] ion_device_add_heap: ion_system_heap id=1 type=0 [ 1.222850] ion_device_add_heap: linux,cma id=2 type=4 [ 1.222946] mmc1: queuing unknown CIS tuple 0x80 (7 bytes) [ 1.223099] ashmem: initialized [ 1.223452] rockchip,bus bus-npu: Linked as a consumer to regulator.10 [ 1.223478] rockchip,bus bus-npu: Failed to get leakage [ 1.223529] rockchip,bus bus-npu: pvtm = 86980, from nvmem [ 1.223577] rockchip,bus bus-npu: pvtm-volt-sel=1 [ 1.223750] rockchip,bus bus-npu: avs=0 [ 1.224755] mmc1: queuing unknown CIS tuple 0x80 (3 bytes) [ 1.225653] rockchip-saradc fe720000.saradc: Linked as a consumer to regulator.21 [ 1.226160] optee: probing for conduit method from DT. [ 1.226192] optee: revision 3.6 (0b06ae94) [ 1.226509] optee: initialized driver [ 1.226548] rknandbase v1.2 2021-01-07 [ 1.227202] rknand fe330000.nandc: rknand_probe clk rate = 148500000 [ 1.247742] mmc2: new HS200 MMC card at address 0001 [ 1.248595] mmcblk2: mmc2:0001 hDEaP3 116 GiB [ 1.249219] mmcblk2boot0: mmc2:0001 hDEaP3 partition 1 4.00 MiB [ 1.249844] mmcblk2boot1: mmc2:0001 hDEaP3 partition 2 4.00 MiB [ 1.250077] mmcblk2rpmb: mmc2:0001 hDEaP3 partition 3 16.0 MiB, chardev (237:0) [ 1.253382] mmcblk2: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 [ 1.289419] mmc_host mmc1: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0) [ 1.298819] dwmmc_rockchip fe2c0000.dwmmc: Successfully tuned phase to 185 [ 1.301518] mmc1: new ultra high speed SDR104 SDIO card at address 0001 [ 1.316396] usb 1-1: New USB device found, idVendor=4037, idProduct=2804, bcdDevice= 1.10 [ 1.316412] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 1.316418] usb 1-1: Product: 2.4G Composite Devic [ 1.339046] input: 2.4G Composite Devic as /devices/platform/usbdrd/fcc00000.dwc3/xhci-hcd.6.auto/usb1/1-1/1-1:1.0/0003:4037:2804.0001/input/input2 [ 1.394088] hid-generic 0003:4037:2804.0001: input,hidraw0: USB HID v1.10 Keyboard [2.4G Composite Devic] on usb-xhci-hcd.6.auto-1/input0 [ 1.400154] input: 2.4G Composite Devic Mouse as /devices/platform/usbdrd/fcc00000.dwc3/xhci-hcd.6.auto/usb1/1-1/1-1:1.1/0003:4037:2804.0002/input/input3 [ 1.457022] input: 2.4G Composite Devic Consumer Control as /devices/platform/usbdrd/fcc00000.dwc3/xhci-hcd.6.auto/usb1/1-1/1-1:1.1/0003:4037:2804.0002/input/input4 [ 1.457246] input: 2.4G Composite Devic System Control as /devices/platform/usbdrd/fcc00000.dwc3/xhci-hcd.6.auto/usb1/1-1/1-1:1.1/0003:4037:2804.0002/input/input5 [ 1.457530] hid-generic 0003:4037:2804.0002: input,hidraw1: USB HID v1.10 Mouse [2.4G Composite Devic] on usb-xhci-hcd.6.auto-1/input1 [ 2.054148] ftl_init fffffffe [ 2.054160] rk_ftl_init fail [ 2.054470] usbcore: registered new interface driver snd-usb-audio [ 2.056471] rk817-codec rk817-codec: DMA mask not set [ 2.060356] netem: version 1.3 [ 2.060395] u32 classifier [ 2.060401] Actions configured [ 2.061065] xt_time: kernel timezone is -0000 [ 2.061142] gre: GRE over IPv4 demultiplexor driver [ 2.061153] IPv4 over IPsec tunneling driver [ 2.061759] Initializing XFRM netlink socket [ 2.061784] IPsec XFRM device driver [ 2.062042] NET: Registered protocol family 10 [ 2.062847] Segment Routing with IPv6 [ 2.062918] mip6: Mobile IPv6 [ 2.063572] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver [ 2.064122] NET: Registered protocol family 17 [ 2.064150] NET: Registered protocol family 15 [ 2.064201] Bridge firewalling registered [ 2.064456] Bluetooth: RFCOMM TTY layer initialized [ 2.064472] Bluetooth: RFCOMM socket layer initialized [ 2.064508] Bluetooth: RFCOMM ver 1.11 [ 2.064520] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 2.064526] Bluetooth: BNEP filters: protocol multicast [ 2.064538] Bluetooth: BNEP socket layer initialized [ 2.064548] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 2.064559] Bluetooth: HIDP socket layer initialized [ 2.064583] l2tp_core: L2TP core driver, V2.0 [ 2.064598] l2tp_ppp: PPPoL2TP kernel driver, V2.0 [ 2.064607] [BT_RFKILL]: Enter rfkill_rk_init [ 2.064616] [WLAN_RFKILL]: Enter rfkill_wlan_init [ 2.065075] [WLAN_RFKILL]: Enter rfkill_wlan_probe [ 2.065111] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6398s [ 2.065123] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control. [ 2.065132] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio. [ 2.065162] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,host_wake_irq = 74, flags = 0. [ 2.065176] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found ! [ 2.065185] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio [ 2.065195] [WLAN_RFKILL]: rfkill_set_wifi_bt_power: 1 [ 2.065205] [WLAN_RFKILL]: Exit rfkill_wlan_probe [ 2.065702] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 77. [ 2.065729] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 79. [ 2.065745] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 81. [ 2.065760] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 80. [ 2.065806] [BT_RFKILL]: Request irq for bt wakeup host [ 2.065877] [BT_RFKILL]: ** disable irq [ 2.065993] [BT_RFKILL]: bt_default device registered. [ 2.066481] ov5695 2-0036: driver version: 00.01.04 [ 2.066561] ov5695 2-0036: 2-0036 supply avdd not found, using dummy regulator [ 2.066636] ov5695 2-0036: Linked as a consumer to regulator.0 [ 2.066662] ov5695 2-0036: 2-0036 supply dovdd not found, using dummy regulator [ 2.066721] ov5695 2-0036: 2-0036 supply dvdd not found, using dummy regulator [ 2.067994] ov5695 2-0036: Unexpected sensor id(000000), ret(-5) [ 2.068563] rockchip-pinctrl pinctrl: pin gpio4-4 already requested by fe6d0000.serial; cannot claim for 2-003c [ 2.068579] rockchip-pinctrl pinctrl: pin-132 (2-003c) status -22 [ 2.068587] rockchip-pinctrl pinctrl: could not request pin 132 (gpio4-4) from group cif-dvp-bus16 on device rockchip-pinctrl [ 2.068594] gc2145 2-003c: Error applying setting, reverse things back [ 2.068618] gc2145: probe of 2-003c failed with error -22 [ 2.068853] gc8034 2-0037: driver version: 00.01.06 [ 2.068889] gc8034 2-0037: Failed to get power-gpios, maybe no use [ 2.068955] gc8034 2-0037: 2-0037 supply avdd not found, using dummy regulator [ 2.069012] gc8034 2-0037: Linked as a consumer to regulator.0 [ 2.069041] gc8034 2-0037: 2-0037 supply dovdd not found, using dummy regulator [ 2.069101] gc8034 2-0037: 2-0037 supply dvdd not found, using dummy regulator [ 2.069146] gc8034 2-0037: lane_num(4) pixel_rate(319887360) [ 2.069162] gc8034 2-0037: could not get default pinstate [ 2.069172] gc8034 2-0037: could not get sleep pinstate [ 2.074195] gc8034 2-0037: gc8034 read reg:0xf0 failed ! [ 2.074353] gc8034 2-0037: gc8034 read reg:0xf1 failed ! [ 2.074365] gc8034 2-0037: Unexpected sensor id(000000), ret(-6) [ 2.075489] registered taskstats version 1 [ 2.075502] Loading compiled-in X.509 certificates [ 2.075609] Key type ._fscrypt registered [ 2.075622] Key type .fscrypt registered [ 2.075627] Key type fscrypt-provisioning registered [ 2.075895] pstore: Using compression: deflate [ 2.076608] rga2: Driver loaded successfully ver:3.2.63318 [ 2.076951] rga2: Module initialized. [ 2.089216] vendor storage:20190527 ret = 0 [ 2.097070] mpp_rkvenc fdf40000.rkvenc: probing start [ 2.097626] mpp_rkvenc fdf40000.rkvenc: Linked as a consumer to regulator.10 [ 2.097656] mpp_rkvenc fdf40000.rkvenc: Failed to get leakage [ 2.097703] mpp_rkvenc fdf40000.rkvenc: pvtm = 86980, from nvmem [ 2.097720] mpp_rkvenc fdf40000.rkvenc: pvtm-volt-sel=1 [ 2.097876] mpp_rkvenc fdf40000.rkvenc: avs=0 [ 2.098174] mpp_rkvenc fdf40000.rkvenc: failed to find power_model node [ 2.098189] mpp_rkvenc fdf40000.rkvenc: failed to initialize power model [ 2.098200] mpp_rkvenc fdf40000.rkvenc: failed to get dynamic-coefficient [ 2.098527] mpp_rkvenc fdf40000.rkvenc: probing finish [ 2.098884] mali fde60000.gpu: Kernel DDK version g2p0-01eac0 [ 2.099044] mali fde60000.gpu: Linked as a consumer to regulator.11 [ 2.099129] mali fde60000.gpu: dev_pm_opp_set_regulators: no regulator (shadercores) found: -19 [ 2.099206] mali fde60000.gpu: leakage=9 [ 2.099244] mali fde60000.gpu: pvtm = 86980, from nvmem [ 2.099596] mali fde60000.gpu: avs=0 [ 2.099614] W : [File] : drivers/gpu/arm/bifrost/platform/rk/mali_kbase_config_rk.c; [Line] : 112; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available. [ 2.099817] mali fde60000.gpu: GPU identified as 0x2 arch 7.4.0 r1p0 status 0 [ 2.099890] mali fde60000.gpu: No memory group manager is configured [ 2.100372] mali fde60000.gpu: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0 [ 2.100996] mali fde60000.gpu: Probed as mali0 [ 2.101413] input: adc-keys as /devices/platform/adc-keys/input/input6 [ 2.102377] asoc-simple-card hdmi-sound: i2s-hifi <-> fe400000.i2s mapping ok [ 2.107996] asoc-simple-card rk809-sound: rk817-hifi <-> fe430000.i2s mapping ok [ 2.109221] asoc-simple-card spdif-sound: dit-hifi <-> fe460000.spdif mapping ok [ 2.110534] rkcif rkcif_dvp: clear unready subdev num: 1 [ 2.110551] rkcif_dvp: Async subdev notifier completed [ 2.111201] It doesn't contain Rogue gpu [ 2.111601] rockchip_headset rk-headset: Can not read property hook_gpio [ 2.111622] rockchip_headset rk-headset: have not set adc chan [ 2.111634] rockchip_headset rk-headset: headset have no hook mode [ 2.111799] input: rk-headset as /devices/platform/rk-headset/input/input7 [ 2.112333] iommu: Adding device fde40000.npu to group 0 [ 2.112360] RKNPU fde40000.npu: Linked as a consumer to fde4b000.iommu [ 2.112792] RKNPU fde40000.npu: RKNPU: rknpu iommu is enabled, using iommu mode [ 2.112903] RKNPU fde40000.npu: Linked as a consumer to regulator.13 [ 2.112920] RKNPU fde40000.npu: can't request region for resource [mem 0xfde40000-0xfde4ffff] [ 2.113371] [drm] Initialized rknpu 0.4.2 20210701 for fde40000.npu on minor 1 [ 2.113425] RKNPU fde40000.npu: leakage=5 [ 2.113465] RKNPU fde40000.npu: pvtm = 86980, from nvmem [ 2.113922] RKNPU fde40000.npu: avs=0 [ 2.114508] RKNPU fde40000.npu: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0 [ 2.115027] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 2.115934] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 2.116752] rockchip-pm rockchip-suspend: not set pwm-regulator-config [ 2.117329] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '12:07:37', on 'Nov 17 2022'. [ 2.117617] Mali: [ 2.117618] Mali device driver loaded [ 2.117639] rkisp rkisp-vir0: clear unready subdev num: 2 [ 2.117649] rockchip-csi2-dphy0: No link between dphy and sensor [ 2.117818] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2 [ 2.117833] cfg80211: failed to load regulatory.db [ 2.118064] rockchip-csi2-dphy0: No link between dphy and sensor [ 2.118078] rkisp-vir0: update sensor failed [ 2.118227] ALSA device list: [ 2.118236] #0: rockchip,hdmi [ 2.118246] #1: rockchip,rk809-codec [ 2.118254] #2: ROCKCHIP,SPDIF [ 2.120575] Freeing unused kernel memory: 4160K [ 2.120655] Run /init as init process [ 2.123094] init: init first stage started! [ 2.123256] init: Unable to open /lib/modules, skipping module loading. [ 2.123655] init: [libfs_mgr]ReadFstabFromDt(): failed to read fstab from dt [ 2.125381] init: Using Android DT directory /proc/device-tree/firmware/android/ [ 2.168610] init: [libfs_mgr]superblock s_max_mnt_count:65535,/dev/block/by-name/metadata [ 2.168866] init: [libfs_mgr]check_fs(): mount(/dev/block/by-name/metadata,/metadata,ext4)=-1: No such file or directory [ 2.169034] init: [libfs_mgr]Not running /system/bin/e2fsck on /dev/block/mmcblk2p11 (executable not in system image) [ 2.172265] EXT4-fs (mmcblk2p11): mounted filesystem with ordered data mode. Opts: discard [ 2.172434] init: [libfs_mgr]__mount(source=/dev/block/by-name/metadata,target=/metadata,type=ext4)=0: Success [ 2.172998] init: Failed to copy /avb into /metadata/gsi/dsu/avb/: No such file or directory [ 2.175433] init: [libfs_mgr]Created logical partition system on device /dev/block/dm-0 [ 2.183756] EXT4-fs (dm-0): mounted filesystem without journal. Opts: barrier=1 [ 2.191374] EXT4-fs (dm-2): mounted filesystem without journal. Opts: barrier=1 [ 2.194410] EXT4-fs (dm-4): mounted filesystem without journal. Opts: barrier=1 [ 2.197804] EXT4-fs (dm-3): mounted filesystem without journal. Opts: barrier=1 [ 2.201101] EXT4-fs (dm-1): mounted filesystem without journal. Opts: barrier=1 [ 2.204362] devfreq fde60000.gpu: Couldn't update frequency transition information. [ 2.222123] init: 17 output lines suppressed due to ratelimiting [ 2.340083] init: Loading SELinux policy [ 2.367969] SELinux: policy capability network_peer_controls=1 [ 2.368013] SELinux: policy capability open_perms=1 [ 2.368020] SELinux: policy capability extended_socket_class=1 [ 2.368025] SELinux: policy capability always_check_network=0 [ 2.368030] SELinux: policy capability cgroup_seclabel=0 [ 2.368035] SELinux: policy capability nnp_nosuid_transition=1 [ 2.505273] audit: type=1403 audit(1669436924.103:2): auid=4294967295 ses=4294967295 lsm=selinux res=1 [ 2.505411] selinux: SELinux: Loaded policy from /odm/etc/selinux/precompiled_sepolicy [ 2.505436] selinux: [ 2.511885] selinux: SELinux: Loaded file_contexts [ 2.511932] selinux: [ 2.543424] init: init second stage started! [ 2.599146] init: Using Android DT directory /proc/device-tree/firmware/android/ [ 2.600567] init: Init cannot set 'ro.boot.verifiedbootstate' to 'orange': Read-only property was already set [ 2.608759] init: Overriding previous 'ro.' property 'persist.sys.timezone':'' with new value 'America/New_York' [ 2.608851] init: Overriding previous 'ro.' property 'persist.sys.rotation.enable':'true' with new value 'false' [ 2.608914] init: Overriding previous 'ro.' property 'ro.boot.wificountrycode':'CN' with new value 'XS' [ 2.609396] init: Overriding previous 'ro.' property 'ro.opengles.version':'131072' with new value '196610' [ 2.609520] init: Overriding previous 'ro.' property 'sf.power.control':'8847360' with new value '2073600' [ 2.612428] init: Couldn't load property file '/factory/factory.prop': open() failed: No such file or directory: No such file or directory [ 2.613494] init: Could not set 'ro.boot.wificountrycode' to 'XS' while loading .prop filesRead-only property was already set [ 2.613587] ---headsetobserve_work--- [ 2.666060] audit: type=1107 audit(1669436924.263:3): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=u:r:init:s0 msg='avc: denied { read } for property=persist.sys.adb_enable pid=0 uid=0 gid=0 scontext=u:r:vendor_init:s0 tcontext=u:object_r:system_prop:s0 tclass=file permissive=1' [ 2.669326] audit: type=1107 audit(1669436924.266:4): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=u:r:init:s0 msg='avc: denied { read } for property=init.svc.adbd pid=0 uid=0 gid=0 scontext=u:r:vendor_init:s0 tcontext=u:object_r:default_prop:s0 tclass=file permissive=1' [ 2.720356] old_status == headset_info->headset_status [ 2.853948] ueventd: ueventd started! [ 2.857059] selinux: SELinux: Loaded file_contexts [ 2.857110] selinux: [ 2.857469] ueventd: Parsing file /system/etc/ueventd.rc... [ 2.858700] ueventd: Parsing file /vendor/ueventd.rc... [ 2.860383] ueventd: Parsing file /odm/ueventd.rc... [ 2.860497] ueventd: Unable to read config file '/odm/ueventd.rc': open() failed: No such file or directory [ 2.860576] ueventd: Parsing file /ueventd.rk30board.rc... [ 2.860640] ueventd: Unable to read config file '/ueventd.rk30board.rc': open() failed: No such file or directory [ 2.888446] apexd: This device does not support updatable APEX. Exiting [ 3.491614] bifrost_kbase: disagrees about version of symbol regulator_enable [ 3.491671] bifrost_kbase: Unknown symbol regulator_enable (err -22) [ 3.491700] bifrost_kbase: disagrees about version of symbol get_user_pages_fast [ 3.491706] bifrost_kbase: Unknown symbol get_user_pages_fast (err -22) [ 3.491724] bifrost_kbase: disagrees about version of symbol simple_attr_write [ 3.491729] bifrost_kbase: Unknown symbol simple_attr_write (err -22) [ 3.491751] bifrost_kbase: disagrees about version of symbol __put_page [ 3.491757] bifrost_kbase: Unknown symbol __put_page (err -22) [ 3.491781] bifrost_kbase: disagrees about version of symbol wakeup_source_remove [ 3.491786] bifrost_kbase: Unknown symbol wakeup_source_remove (err -22) [ 3.491799] bifrost_kbase: disagrees about version of symbol release_firmware [ 3.491837] bifrost_kbase: Unknown symbol release_firmware (err -22) [ 3.491859] bifrost_kbase: disagrees about version of symbol simple_attr_open [ 3.491868] bifrost_kbase: Unknown symbol simple_attr_open (err -22) [ 3.491925] bifrost_kbase: disagrees about version of symbol devfreq_register_opp_notifier [ 3.491935] bifrost_kbase: Unknown symbol devfreq_register_opp_notifier (err -22) [ 3.491953] bifrost_kbase: disagrees about version of symbol dev_pm_opp_put_regulators [ 3.491963] bifrost_kbase: Unknown symbol dev_pm_opp_put_regulators (err -22) [ 3.492080] bifrost_kbase: disagrees about version of symbol of_find_device_by_node [ 3.492091] bifrost_kbase: Unknown symbol of_find_device_by_node (err -22) [ 3.492141] bifrost_kbase: disagrees about version of symbol of_devfreq_cooling_register_power [ 3.492150] bifrost_kbase: Unknown symbol of_devfreq_cooling_register_power (err -22) [ 3.492214] bifrost_kbase: disagrees about version of symbol request_firmware [ 3.492223] bifrost_kbase: Unknown symbol request_firmware (err -22) [ 3.492261] bifrost_kbase: disagrees about version of symbol regulator_put [ 3.492267] bifrost_kbase: Unknown symbol regulator_put (err -22) [ 3.492293] bifrost_kbase: disagrees about version of symbol register_shrinker [ 3.492303] bifrost_kbase: Unknown symbol register_shrinker (err -22) [ 3.492349] bifrost_kbase: disagrees about version of symbol unmap_mapping_range [ 3.492359] bifrost_kbase: Unknown symbol unmap_mapping_range (err -22) [ 3.492372] bifrost_kbase: disagrees about version of symbol remap_pfn_range [ 3.492381] bifrost_kbase: Unknown symbol remap_pfn_range (err -22) [ 3.492518] bifrost_kbase: disagrees about version of symbol rockchip_init_opp_table [ 3.492528] bifrost_kbase: Unknown symbol rockchip_init_opp_table (err -22) [ 3.492575] bifrost_kbase: disagrees about version of symbol kmem_cache_alloc_trace [ 3.492584] bifrost_kbase: Unknown symbol kmem_cache_alloc_trace (err -22) [ 3.492619] bifrost_kbase: disagrees about version of symbol get_user_pages_remote [ 3.492629] bifrost_kbase: Unknown symbol get_user_pages_remote (err -22) [ 3.492650] bifrost_kbase: disagrees about version of symbol wake_up_process [ 3.492660] bifrost_kbase: Unknown symbol wake_up_process (err -22) [ 3.492674] bifrost_kbase: disagrees about version of symbol devfreq_add_device [ 3.492682] bifrost_kbase: Unknown symbol devfreq_add_device (err -22) [ 3.492697] bifrost_kbase: disagrees about version of symbol trace_event_buffer_commit [ 3.492705] bifrost_kbase: Unknown symbol trace_event_buffer_commit (err -22) [ 3.492744] bifrost_kbase: disagrees about version of symbol rockchip_monitor_dev_high_temp_adjust [ 3.492750] bifrost_kbase: Unknown symbol rockchip_monitor_dev_high_temp_adjust (err -22) [ 3.492800] bifrost_kbase: disagrees about version of symbol regulator_get_optional [ 3.492809] bifrost_kbase: Unknown symbol regulator_get_optional (err -22) [ 3.492850] bifrost_kbase: disagrees about version of symbol get_user_pages [ 3.492859] bifrost_kbase: Unknown symbol get_user_pages (err -22) [ 3.492934] bifrost_kbase: disagrees about version of symbol dev_pm_opp_put [ 3.492944] bifrost_kbase: Unknown symbol dev_pm_opp_put (err -22) [ 3.492974] bifrost_kbase: disagrees about version of symbol unregister_shrinker [ 3.492980] bifrost_kbase: Unknown symbol unregister_shrinker (err -22) [ 3.493001] bifrost_kbase: disagrees about version of symbol __free_pages [ 3.493010] bifrost_kbase: Unknown symbol __free_pages (err -22) [ 3.493039] bifrost_kbase: disagrees about version of symbol find_vma [ 3.493048] bifrost_kbase: Unknown symbol find_vma (err -22) [ 3.493114] bifrost_kbase: disagrees about version of symbol __pm_relax [ 3.493124] bifrost_kbase: Unknown symbol __pm_relax (err -22) [ 3.493168] bifrost_kbase: disagrees about version of symbol fput [ 3.493177] bifrost_kbase: Unknown symbol fput (err -22) [ 3.493198] bifrost_kbase: disagrees about version of symbol devfreq_remove_device [ 3.493204] bifrost_kbase: Unknown symbol devfreq_remove_device (err -22) [ 3.493229] bifrost_kbase: disagrees about version of symbol dev_pm_opp_set_regulators [ 3.493239] bifrost_kbase: Unknown symbol dev_pm_opp_set_regulators (err -22) [ 3.493257] bifrost_kbase: disagrees about version of symbol simple_open [ 3.493267] bifrost_kbase: Unknown symbol simple_open (err -22) [ 3.493306] bifrost_kbase: disagrees about version of symbol dev_pm_opp_find_freq_floor [ 3.493316] bifrost_kbase: Unknown symbol dev_pm_opp_find_freq_floor (err -22) [ 3.493330] bifrost_kbase: disagrees about version of symbol simple_attr_release [ 3.493339] bifrost_kbase: Unknown symbol simple_attr_release (err -22) [ 3.493352] bifrost_kbase: disagrees about version of symbol rockchip_monitor_dev_low_temp_adjust [ 3.493361] bifrost_kbase: Unknown symbol rockchip_monitor_dev_low_temp_adjust (err -22) [ 3.493416] bifrost_kbase: disagrees about version of symbol rockchip_system_monitor_register [ 3.493426] bifrost_kbase: Unknown symbol rockchip_system_monitor_register (err -22) [ 3.493517] bifrost_kbase: disagrees about version of symbol devfreq_unregister_opp_notifier [ 3.493526] bifrost_kbase: Unknown symbol devfreq_unregister_opp_notifier (err -22) [ 3.493605] bifrost_kbase: disagrees about version of symbol freezing_slow_path [ 3.493622] bifrost_kbase: Unknown symbol freezing_slow_path (err -22) [ 3.493676] bifrost_kbase: disagrees about version of symbol dev_pm_opp_get_opp_count [ 3.493681] bifrost_kbase: Unknown symbol dev_pm_opp_get_opp_count (err -22) [ 3.493706] bifrost_kbase: disagrees about version of symbol simple_attr_read [ 3.493718] bifrost_kbase: Unknown symbol simple_attr_read (err -22) [ 3.493738] bifrost_kbase: disagrees about version of symbol __mmdrop [ 3.493747] bifrost_kbase: Unknown symbol __mmdrop (err -22) [ 3.493765] bifrost_kbase: disagrees about version of symbol nonseekable_open [ 3.493774] bifrost_kbase: Unknown symbol nonseekable_open (err -22) [ 3.493796] bifrost_kbase: disagrees about version of symbol __alloc_pages_nodemask [ 3.493806] bifrost_kbase: Unknown symbol __alloc_pages_nodemask (err -22) [ 3.493863] bifrost_kbase: disagrees about version of symbol devfreq_suspend_device [ 3.493872] bifrost_kbase: Unknown symbol devfreq_suspend_device (err -22) [ 3.493932] bifrost_kbase: disagrees about version of symbol rockchip_system_monitor_unregister [ 3.493942] bifrost_kbase: Unknown symbol rockchip_system_monitor_unregister (err -22) [ 3.493955] bifrost_kbase: disagrees about version of symbol thermal_zone_get_zone_by_name [ 3.493964] bifrost_kbase: Unknown symbol thermal_zone_get_zone_by_name (err -22) [ 3.493984] bifrost_kbase: disagrees about version of symbol set_page_dirty_lock [ 3.493993] bifrost_kbase: Unknown symbol set_page_dirty_lock (err -22) [ 3.494025] bifrost_kbase: disagrees about version of symbol dev_pm_opp_find_freq_ceil [ 3.494035] bifrost_kbase: Unknown symbol dev_pm_opp_find_freq_ceil (err -22) [ 3.494051] bifrost_kbase: disagrees about version of symbol __pm_stay_awake [ 3.494060] bifrost_kbase: Unknown symbol __pm_stay_awake (err -22) [ 3.494080] bifrost_kbase: disagrees about version of symbol regulator_disable [ 3.494089] bifrost_kbase: Unknown symbol regulator_disable (err -22) [ 3.494112] bifrost_kbase: disagrees about version of symbol dev_pm_opp_get_voltage [ 3.494121] bifrost_kbase: Unknown symbol dev_pm_opp_get_voltage (err -22) [ 3.494140] bifrost_kbase: disagrees about version of symbol wakeup_source_add [ 3.494146] bifrost_kbase: Unknown symbol wakeup_source_add (err -22) [ 3.494171] bifrost_kbase: disagrees about version of symbol devfreq_resume_device [ 3.494180] bifrost_kbase: Unknown symbol devfreq_resume_device (err -22) [ 3.494206] bifrost_kbase: disagrees about version of symbol regulator_set_voltage [ 3.494215] bifrost_kbase: Unknown symbol regulator_set_voltage (err -22) [ 3.494236] bifrost_kbase: disagrees about version of symbol kmalloc_caches [ 3.494245] bifrost_kbase: Unknown symbol kmalloc_caches (err -22) [ 3.494265] bifrost_kbase: disagrees about version of symbol vm_insert_pfn_prot [ 3.494273] bifrost_kbase: Unknown symbol vm_insert_pfn_prot (err -22) [ 3.530827] aicbsp_init [ 3.530857] RELEASE_DATE:2022_0907_1948 [ 3.531356] aicbsp: aicbsp_set_subsys, subsys: AIC_WIFI, state to: 1 [ 3.531375] aicbsp: aicbsp_set_subsys, power state change to 1 dure to AIC_WIFI [ 3.531384] aicbsp: aicbsp_platform_power_on [ 3.535624] ueventd: Coldboot took 0.673 seconds [ 3.767150] Registered swp emulation handler [ 3.835056] logd.auditd: start [ 3.835178] logd.klogd: 3831626955 [ 3.843177] EXT4-fs (mmcblk2p10): Ignoring removed nomblk_io_submit option [ 3.847457] EXT4-fs (mmcblk2p10): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit [ 3.904466] e2fsck: e2fsck 1.45.4 (23-Sep-2019) [ 3.909245] e2fsck: /dev/block/by-name/cache: clean, 19/110592 files, 7604/110591 blocks [ 3.914751] EXT4-fs (mmcblk2p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard [ 4.108803] wait_for_keymaster: Waiting for Keymaster device [ 4.145378] wait_for_keymaster: List of Keymaster HALs found: [ 4.145837] wait_for_keymaster: Keymaster HAL #1: SoftwareKeymasterDevice from Google SecurityLevel: SOFTWARE HAL: android.hardware.keymaster@4.1::IKeymasterDevice/default [ 4.146297] wait_for_keymaster: Computing HMAC with params { (seed: , nonce: 41714fae71a7909df91457af6a47265c6986832819e4dffa28739353aca12f) } [ 4.146377] wait_for_keymaster: Computing HMAC for SoftwareKeymasterDevice from Google SecurityLevel: SOFTWARE HAL: android.hardware.keymaster@4.1::IKeymasterDevice/default [ 4.146969] wait_for_keymaster: Using SoftwareKeymasterDevice from Google for encryption. Security level: SOFTWARE, HAL: android.hardware.keymaster@4.1::IKeymasterDevice/default [ 4.147044] wait_for_keymaster: Keymaster device ready [ 4.176310] vdc: Waited 0ms for vold [ 4.204055] fsck.f2fs: Info: Fix the reported corruption. [ 4.205343] fsck.f2fs: Info: No support kernel version! [ 4.205382] fsck.f2fs: Info: Segments per section = 1 [ 4.205394] fsck.f2fs: Info: Sections per zone = 1 [ 4.205413] fsck.f2fs: Info: sector size = 512 [ 4.205434] fsck.f2fs: Info: total sectors = 235154369 (114821 MB) [ 4.206310] fsck.f2fs: Info: MKFS version [ 4.206347] fsck.f2fs: "4.19.172 #75 SMP PREEMPT Thu Nov 24 11:06:53 CST 2022" [ 4.220248] F2FS-fs (mmcblk2p16): Using encoding defined by superblock: utf8-12.1.0 with flags 0x0 [ 4.291321] F2FS-fs (mmcblk2p16): Found nat_bits in checkpoint [ 4.651483] F2FS-fs (mmcblk2p16): Mounted with checkpoint version = 33d05c13 [ 4.765887] vdc: Waited 0ms for vold [ 4.818631] fscrypt: AES-256-CTS-CBC using implementation "cts(cbc-aes-ce)" [ 4.830992] fscrypt: AES-256-XTS using implementation "xts-aes-ce" [ 4.858631] apexd: This device does not support updatable APEX. Exiting [ 4.858743] apexd: Marking APEXd as activated [ 4.888551] type=1400 audit(1669436926.486:5): avc: denied { read } for comm="android.hardwar" name="resolution_white.xml" dev="dm-0" ino=3932 scontext=u:r:hal_graphics_composer_default:s0 tcontext=u:object_r:system_file:s0 tclass=file permissive=1 [ 4.888892] type=1400 audit(1669436926.486:6): avc: denied { open } for comm="android.hardwar" path="/system/usr/share/resolution_white.xml" dev="dm-0" ino=3932 scontext=u:r:hal_graphics_composer_default:s0 tcontext=u:object_r:system_file:s0 tclass=file permissive=1 [ 4.889035] type=1400 audit(1669436926.486:7): avc: denied { getattr } for comm="android.hardwar" path="/system/usr/share/resolution_white.xml" dev="dm-0" ino=3932 scontext=u:r:hal_graphics_composer_default:s0 tcontext=u:object_r:system_file:s0 tclass=file permissive=1 [ 5.016416] vdc: Waited 0ms for vold [ 5.134595] apexd: This device does not support updatable APEX. Exiting [ 5.134687] apexd: Marking APEXd as ready [ 5.443235] type=1400 audit(1669436927.040:8): avc: denied { read } for comm="android.hardwar" name="u:object_r:default_prop:s0" dev="tmpfs" ino=2682 scontext=u:r:hal_graphics_composer_default:s0 tcontext=u:object_r:default_prop:s0 tclass=file permissive=1 [ 5.443587] type=1400 audit(1669436927.040:9): avc: denied { open } for comm="android.hardwar" path="/dev/__properties__/u:object_r:default_prop:s0" dev="tmpfs" ino=2682 scontext=u:r:hal_graphics_composer_default:s0 tcontext=u:object_r:default_prop:s0 tclass=file permissive=1 [ 5.443795] type=1400 audit(1669436927.040:10): avc: denied { getattr } for comm="android.hardwar" path="/dev/__properties__/u:object_r:default_prop:s0" dev="tmpfs" ino=2682 scontext=u:r:hal_graphics_composer_default:s0 tcontext=u:object_r:default_prop:s0 tclass=file permissive=1 [ 5.443952] type=1400 audit(1669436927.040:11): avc: denied { map } for comm="android.hardwar" path="/dev/__properties__/u:object_r:default_prop:s0" dev="tmpfs" ino=2682 scontext=u:r:hal_graphics_composer_default:s0 tcontext=u:object_r:default_prop:s0 tclass=file permissive=1 [ 5.463285] logd.daemon: reinit [ 5.556048] init: Verified that /data/nfc has the encryption policy d89af2388367d6a9fca1e593817bd9c4 v2 modes 1/4 flags 0xa [ 5.557507] init: Inferred action different from explicit one, expected 0 but got 2 [ 5.557918] init: Verified that /data/nfc/param has the encryption policy d89af2388367d6a9fca1e593817bd9c4 v2 modes 1/4 flags 0xa [ 5.615535] aicbsp: aicbsp_set_subsys, fail to set AIC_WIFI power state to 1 [ 5.982866] healthd: BatteryCurrentNowPath not found [ 5.982926] healthd: BatteryCycleCountPath not found [ 5.989855] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au [ 6.252813] file system registered [ 6.259565] using random self ethernet address [ 6.259765] using random host ethernet address [ 6.346979] dhd_module_init: in Dongle Host Driver, version 1.579.77.41.22 (r-20191105-2)(20191120-1) [ 6.347089] ======== dhd_wlan_init_plat_data ======== [ 6.347111] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter [ 6.347201] dhd_wlan_init_gpio: WL_HOST_WAKE=-1, oob_irq=99, oob_irq_flags=0x414 [ 6.347251] dhd_wlan_init_gpio: WL_REG_ON=-1 [ 6.347306] dhd_wifi_platform_load: Enter [ 6.347326] Power-up adapter 'DHD generic adapter' [ 6.351418] wifi_platform_set_power = 1 [ 6.351465] ======== PULL WL_REG_ON(-1) HIGH! ======== [ 6.351486] [WLAN_RFKILL]: rockchip_wifi_power: 1 [ 6.351504] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false [ 6.351521] [WLAN_RFKILL]: wifi turn on power [GPIO-1-0] [ 6.478975] rkcif_dvp: get_remote_sensor: remote pad is null [ 6.479091] rkcif_dvp: rkcif_update_sensor_info: stream[2] get remote sensor_sd failed! [ 6.479115] stream_cif_dvp_id2: update sensor info failed -19 [ 6.479275] rkcif_dvp: get_remote_sensor: remote pad is null [ 6.479661] rkcif_dvp: rkcif_update_sensor_info: stream[1] get remote sensor_sd failed! [ 6.480139] stream_cif_dvp_id1: update sensor info failed -19 [ 6.521652] rkcif_dvp: get_remote_sensor: remote pad is null [ 6.521689] rkcif_dvp: rkcif_update_sensor_info: stream[0] get remote sensor_sd failed! [ 6.521696] stream_cif_dvp_id0: update sensor info failed -19 [ 6.521788] rkcif_dvp: get_remote_sensor: remote pad is null [ 6.521803] rkcif_dvp: rkcif_update_sensor_info: stream[3] get remote sensor_sd failed! [ 6.521810] stream_cif_dvp_id3: update sensor info failed -19 [ 6.706986] wifi_platform_bus_enumerate device present 1 [ 6.707021] ======== Card detection to detect SDIO card! ======== [ 6.707029] mmc1:mmc host rescan start! [ 6.728186] bcmsdh_register: register client driver [ 6.728561] bcmsdh_sdmmc_probe: Enter num=1 [ 6.728797] bcmsdh_sdmmc_probe: Enter num=2 [ 6.728824] bus num (host idx)=1, slot num (rca)=1 [ 6.728833] found adapter info 'DHD generic adapter' [ 6.728862] sdioh_attach: set sd_f2_blocksize 256 [ 6.728882] sdioh_attach: sd clock rate = 0 [ 6.734944] dhdsdio_probe : no mutex held. set lock [ 6.735045] F1 signature read @0x18000000=0x16024335 [ 6.737112] F1 signature OK, socitype:0x1 chip:0x4339 rev:0x1 pkg:0x0 [ 6.737441] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000 [ 6.737545] [dhd] dhd_conf_set_chiprev : chip=0x4339, chiprev=1 [ 6.737701] [dhd] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211 [ 6.741847] [dhd] CFG80211-ERROR) wl_setup_wiphy : SAE support [ 6.743983] [dhd] CFG80211-ERROR) wl_init_prof : wl_init_prof: No profile [ 6.774504] dhd_attach(): thread:dhd_watchdog_thread:149 started [ 6.778490] dhd_attach(): thread:dhd_dpc:14a started [ 6.782322] dhd_attach(): thread:dhd_rxf:14b started [ 6.782360] dhd_deferred_work_init: work queue initialized [ 6.782369] dhd_tcpack_suppress_set: TCP ACK Suppress mode 0 -> mode 2 [ 6.782590] sdioh_cis_read: func_cis_ptr[0]=0x10ac [ 6.786598] Dongle Host Driver, version 1.579.77.41.22 (r-20191105-2)(20191120-1) [ 6.789803] Register interface [wlan0] MAC: f4:09:d8:80:37:2a [ 6.789803] [ 6.793627] dhd_tcpack_suppress_set: TCP ACK Suppress mode 2 -> mode 0 [ 6.793690] dhd_wl_ioctl: returning as busstate=0 [ 6.793699] dhd_dbg_detach_pkt_monitor, 2204 [ 6.793706] dhd_bus_devreset: == Power OFF == [ 6.793872] bcmsdh_oob_intr_unregister: Enter [ 6.793918] bcmsdh_oob_intr_unregister: irq is not registered [ 6.793991] dhd_txglom_enable: enable 0 [ 6.794027] dhd_bus_devreset: WLAN OFF DONE [ 6.794406] wifi_platform_set_power = 0 [ 6.794468] ======== PULL WL_REG_ON(-1) LOW! ======== [ 6.794489] [WLAN_RFKILL]: rockchip_wifi_power: 0 [ 6.794521] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false [ 6.794568] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1] [ 6.794590] dhdsdio_probe : the lock is released. [ 6.795210] dhd_module_init: Exit err=0 [ 7.006746] read descriptors [ 7.006858] read strings [ 7.769173] init: Control message: Processed ctl.interface_start for 'android.hardware.camera.provider@2.4::ICameraProvider/legacy/0' from pid: 144 (/system/bin/hwservicemanager) [ 8.170776] read descriptors [ 8.170819] read strings [ 8.171963] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 8.173324] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 8.173614] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 8.454568] init: Service 'vendor_flash_recovery' (pid 321) exited with status 0 oneshot service took 1.799000 seconds in background [ 8.454658] init: Sending signal 9 to service 'vendor_flash_recovery' (pid 321) process group... [ 8.455090] libprocessgroup: Successfully killed process cgroup uid 0 pid 321 in 0ms [ 9.208233] read descriptors [ 9.208276] read strings [ 9.209462] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 9.212278] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 1ms and failed: symlink() failed: File exists [ 9.212559] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 9.802193] type=1400 audit(1669436931.400:138): avc: denied { call } for comm="BootAnimation" scontext=u:r:bootanim:s0 tcontext=u:r:mediaserver:s0 tclass=binder permissive=1 [ 9.802398] type=1400 audit(1669436931.400:139): avc: denied { transfer } for comm="BootAnimation" scontext=u:r:bootanim:s0 tcontext=u:r:mediaserver:s0 tclass=binder permissive=1 [ 9.802538] type=1400 audit(1669436931.400:140): avc: denied { transfer } for comm="Binder:316_1" scontext=u:r:mediaserver:s0 tcontext=u:r:bootanim:s0 tclass=binder permissive=1 [ 9.948375] type=1400 audit(1669436931.546:141): avc: denied { read } for comm="hw@1.0-service" name="u:object_r:vendor_omx_prop:s0" dev="tmpfs" ino=2800 scontext=u:r:vendor-rockit-hal-1-0:s0 tcontext=u:object_r:vendor_omx_prop:s0 tclass=file permissive=1 [ 9.948676] type=1400 audit(1669436931.546:142): avc: denied { open } for comm="hw@1.0-service" path="/dev/__properties__/u:object_r:vendor_omx_prop:s0" dev="tmpfs" ino=2800 scontext=u:r:vendor-rockit-hal-1-0:s0 tcontext=u:object_r:vendor_omx_prop:s0 tclass=file permissive=1 [ 9.948873] type=1400 audit(1669436931.546:143): avc: denied { getattr } for comm="hw@1.0-service" path="/dev/__properties__/u:object_r:vendor_omx_prop:s0" dev="tmpfs" ino=2800 scontext=u:r:vendor-rockit-hal-1-0:s0 tcontext=u:object_r:vendor_omx_prop:s0 tclass=file permissive=1 [ 9.949049] type=1400 audit(1669436931.546:144): avc: denied { map } for comm="hw@1.0-service" path="/dev/__properties__/u:object_r:vendor_omx_prop:s0" dev="tmpfs" ino=2800 scontext=u:r:vendor-rockit-hal-1-0:s0 tcontext=u:object_r:vendor_omx_prop:s0 tclass=file permissive=1 [ 9.949172] type=1400 audit(1669436931.546:145): avc: denied { read } for comm="hw@1.0-service" name="version" dev="proc" ino=4026532060 scontext=u:r:vendor-rockit-hal-1-0:s0 tcontext=u:object_r:proc_version:s0 tclass=file permissive=1 [ 9.949268] type=1400 audit(1669436931.546:146): avc: denied { open } for comm="hw@1.0-service" path="/proc/version" dev="proc" ino=4026532060 scontext=u:r:vendor-rockit-hal-1-0:s0 tcontext=u:object_r:proc_version:s0 tclass=file permissive=1 [ 9.949382] type=1400 audit(1669436931.546:147): avc: denied { getattr } for comm="hw@1.0-service" path="/proc/version" dev="proc" ino=4026532060 scontext=u:r:vendor-rockit-hal-1-0:s0 tcontext=u:object_r:proc_version:s0 tclass=file permissive=1 [ 10.244078] read descriptors [ 10.244123] read strings [ 10.423368] Freeing drm_logo memory: 6072K [ 11.280644] read descriptors [ 11.280686] read strings [ 12.314183] read descriptors [ 12.314232] read strings [ 13.354168] read descriptors [ 13.354226] read strings [ 13.355335] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 13.356726] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 13.357119] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 14.383944] read descriptors [ 14.383989] read strings [ 14.384690] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 14.385734] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 14.385930] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 15.417306] read descriptors [ 15.417370] read strings [ 15.418352] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 15.419639] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 15.419826] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 16.454014] read descriptors [ 16.454053] read strings [ 16.454773] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 17.076772] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au [ 17.098848] type=1400 audit(1669436938.696:164): avc: denied { read } for comm="Binder:165_2" name="wakeup12" dev="sysfs" ino=23981 scontext=u:r:system_suspend:s0 tcontext=u:object_r:sysfs_power:s0 tclass=dir permissive=1 [ 17.100316] type=1400 audit(1669436938.696:165): avc: denied { open } for comm="Binder:165_2" path="/sys/devices/virtual/power_supply/test_usb/wakeup12" dev="sysfs" ino=23981 scontext=u:r:system_suspend:s0 tcontext=u:object_r:sysfs_power:s0 tclass=dir permissive=1 [ 17.117603] type=1400 audit(1669436938.716:166): avc: denied { read } for comm="android.bg" name="stat" dev="proc" ino=23367 scontext=u:r:system_server:s0 tcontext=u:r:datadis:s0 tclass=file permissive=1 [ 17.120042] type=1400 audit(1669436938.716:167): avc: denied { open } for comm="android.bg" path="/proc/307/stat" dev="proc" ino=23367 scontext=u:r:system_server:s0 tcontext=u:r:datadis:s0 tclass=file permissive=1 [ 17.487499] read descriptors [ 17.487553] read strings [ 18.524165] read descriptors [ 18.524211] read strings [ 18.529055] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 18.530551] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 18.530829] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 19.570686] read descriptors [ 19.570729] read strings [ 19.571494] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 19.573229] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 19.573453] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 20.604132] read descriptors [ 20.604193] read strings [ 20.607479] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 20.667375] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 58ms and failed: symlink() failed: File exists [ 20.667826] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 21.640858] read descriptors [ 21.640907] read strings [ 21.644340] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 22.674114] read descriptors [ 22.674164] read strings [ 23.714047] read descriptors [ 23.714092] read strings [ 23.714836] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 23.716080] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 23.716269] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 24.754024] read descriptors [ 24.754071] read strings [ 24.755247] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 24.760743] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 4ms and failed: symlink() failed: File exists [ 24.761441] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 25.800764] read descriptors [ 25.800822] read strings [ 25.801704] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 25.803042] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 25.803349] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 26.847389] read descriptors [ 26.847438] read strings [ 26.848522] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 27.890627] read descriptors [ 27.890672] read strings [ 28.937348] read descriptors [ 28.937389] read strings [ 28.938098] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 28.939711] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 28.939883] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 29.977421] read descriptors [ 29.977462] read strings [ 29.978384] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 29.979611] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 29.979907] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 31.014123] read descriptors [ 31.014170] read strings [ 31.015072] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 31.016320] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 31.016626] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 32.047284] read descriptors [ 32.047336] read strings [ 32.048082] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 32.509952] type=1400 audit(1669436954.106:168): avc: denied { call } for comm="BootAnimation" scontext=u:r:bootanim:s0 tcontext=u:r:mediaserver:s0 tclass=binder permissive=1 [ 33.083942] read descriptors [ 33.083979] read strings [ 33.568965] read descriptors [ 33.569077] read strings [ 33.569214] read descriptors [ 33.569239] read strings [ 33.760302] vcc3v3_lcd0_n: disabling [ 33.760340] vcc3v3_lcd1_n: disabling [ 33.809761] type=1400 audit(1669436955.406:169): avc: denied { call } for comm="MsgQueue" scontext=u:r:mediaserver:s0 tcontext=u:r:bootanim:s0 tclass=binder permissive=1 [ 33.954135] Generic PHY stmmac-1:00: attached PHY driver [Generic PHY] (mii_bus:phy_addr=stmmac-1:00, irq=POLL) [ 34.012716] type=1400 audit(1669436955.610:170): avc: denied { read } for comm="Binder:165_2" name="wakeup2" dev="sysfs" ino=15084 scontext=u:r:system_suspend:s0 tcontext=u:object_r:sysfs:s0 tclass=dir permissive=1 [ 34.014325] type=1400 audit(1669436955.610:171): avc: denied { open } for comm="Binder:165_2" path="/sys/devices/platform/fdef0000.iep/wakeup/wakeup2" dev="sysfs" ino=15084 scontext=u:r:system_suspend:s0 tcontext=u:object_r:sysfs:s0 tclass=dir permissive=1 [ 34.014573] type=1400 audit(1669436955.610:172): avc: denied { read } for comm="Binder:165_2" name="event_count" dev="sysfs" ino=15091 scontext=u:r:system_suspend:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1 [ 34.014792] type=1400 audit(1669436955.610:173): avc: denied { open } for comm="Binder:165_2" path="/sys/devices/platform/fdef0000.iep/wakeup/wakeup2/event_count" dev="sysfs" ino=15091 scontext=u:r:system_suspend:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1 [ 34.014972] type=1400 audit(1669436955.610:174): avc: denied { getattr } for comm="Binder:165_2" path="/sys/devices/platform/fdef0000.iep/wakeup/wakeup2/event_count" dev="sysfs" ino=15091 scontext=u:r:system_suspend:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1 [ 34.019976] type=1400 audit(1669436955.616:175): avc: denied { read } for comm="Binder:165_2" name="wakeup12" dev="sysfs" ino=23981 scontext=u:r:system_suspend:s0 tcontext=u:object_r:sysfs_power:s0 tclass=dir permissive=1 [ 34.020389] type=1400 audit(1669436955.616:176): avc: denied { open } for comm="Binder:165_2" path="/sys/devices/virtual/power_supply/test_usb/wakeup12" dev="sysfs" ino=23981 scontext=u:r:system_suspend:s0 tcontext=u:object_r:sysfs_power:s0 tclass=dir permissive=1 [ 34.117394] read descriptors [ 34.117438] read strings [ 34.118263] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 34.119375] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 34.119573] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 34.453252] type=1400 audit(1669436956.050:177): avc: denied { read } for comm="user_drmservice" lport=33334 scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=udp_socket permissive=1 [ 35.167649] read descriptors [ 35.167700] read strings [ 35.172040] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 35.173428] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 35.173703] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 36.117757] dwmac4: Master AXI performs any burst length [ 36.117811] rk_gmac-dwmac fe010000.ethernet eth0: No Safety Features support found [ 36.117835] rk_gmac-dwmac fe010000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported [ 36.122128] rk_gmac-dwmac fe010000.ethernet eth0: registered PTP clock [ 36.124267] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [ 36.139790] init: processing action (wlan.driver.status=ok) from (/vendor/etc/init/hw/init.connectivity.rc:46) [ 36.186382] dhd_open: Enter 00000000be517524 [ 36.186384] init: processing action (wlan.driver.status=ok) from (/vendor/etc/init/hw/init.connectivity.rc:46) [ 36.186426] dhd_open : no mutex held. set lock [ 36.186437] [ 36.186437] Dongle Host Driver, version 1.579.77.41.22 (r-20191105-2)(20191120-1) [ 36.186450] [dhd-wlan0] wl_android_wifi_on : in g_wifi_on=0 [ 36.186456] wifi_platform_set_power = 1 [ 36.186462] ======== PULL WL_REG_ON(-1) HIGH! ======== [ 36.186468] [WLAN_RFKILL]: rockchip_wifi_power: 1 [ 36.186474] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false [ 36.186480] [WLAN_RFKILL]: wifi turn on power [GPIO-1-0] [ 36.214277] read descriptors [ 36.214323] read strings [ 36.215169] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 36.216541] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 36.500278] sdio_reset_comm(): [ 36.705317] [BT_RFKILL]: bt shut off power [ 36.705556] [BT_RFKILL]: rfkill_rk_set_power: set bt wake_host high! [ 36.720331] mmc_host mmc1: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0) [ 36.738655] dwmmc_rockchip fe2c0000.dwmmc: failed to set rate 100000Hz [ 36.738707] mmc_host mmc1: Bus speed (slot 0) = 375000Hz (slot req 100000Hz, actual 93750HZ div = 2) [ 36.756978] [BT_RFKILL]: ENABLE UART_RTS [ 36.757208] dwmmc_rockchip fe2c0000.dwmmc: failed to set rate 100000Hz [ 36.798970] mmc1: queuing unknown CIS tuple 0x80 (2 bytes) [ 36.812685] mmc1: queuing unknown CIS tuple 0x80 (7 bytes) [ 36.821347] mmc1: queuing unknown CIS tuple 0x80 (3 bytes) [ 36.863590] [BT_RFKILL]: DISABLE UART_RTS [ 36.863662] [BT_RFKILL]: bt turn on power [ 36.863689] [BT_RFKILL]: Request irq for bt wakeup host [ 36.863724] [BT_RFKILL]: ** disable irq [ 36.864453] of_dma_request_slave_channel: dma-names property of node '/serial@fe650000' missing or empty [ 36.864475] ttyS1 - failed to request DMA, use interrupt mode [ 36.959674] audit: audit_lost=1 audit_rate_limit=5 audit_backlog_limit=64 [ 36.959712] audit: rate limit exceeded [ 37.087490] zram0: detected capacity change from 0 to 4024049664 [ 37.091135] dwmmc_rockchip fe2c0000.dwmmc: failed to set rate 100000Hz [ 37.095253] dwmmc_rockchip fe2c0000.dwmmc: failed to set rate 100000Hz [ 37.095338] mmc_host mmc1: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0) [ 37.146047] mkswap: Swapspace size: 3929732k, UUID=30ec3ed0-26ae-43d9-97ad-647df32e44d7 [ 37.148588] rk_gmac-dwmac fe010000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx [ 37.150375] Adding 3929732k swap on /dev/block/zram0. Priority:-2 extents:1 across:3929732k SS [ 37.360688] dwmmc_rockchip fe2c0000.dwmmc: Successfully tuned phase to 195 [ 37.360777] sdioh_start: set sd_f2_blocksize 256 [ 37.360983] [ 37.360983] [ 37.360983] dhd_bus_devreset: == WLAN ON == [ 37.361052] F1 signature read @0x18000000=0x16024335 [ 37.363187] F1 signature OK, socitype:0x1 chip:0x4339 rev:0x1 pkg:0x0 [ 37.363487] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000 [ 37.363870] [dhd] dhd_conf_read_config : Ignore config file /vendor/etc/firmware/config.txt [ 37.363895] [dhd] dhd_conf_set_path_params : Final fw_path=/vendor/etc/firmware/fw_bcm4339a0_ag.bin [ 37.363902] [dhd] dhd_conf_set_path_params : Final nv_path=/vendor/etc/firmware/nvram_AP6335.txt [ 37.363908] [dhd] dhd_conf_set_path_params : Final clm_path=/vendor/etc/firmware/clm_bcm4339a0_ag.blob [ 37.363913] [dhd] dhd_conf_set_path_params : Final conf_path=/vendor/etc/firmware/config.txt [ 37.364288] dhd_os_open_image: /vendor/etc/firmware/fw_bcm4339a0_ag.bin (569309 bytes) open success [ 37.453355] dhd_os_open_image: /vendor/etc/firmware/nvram_AP6335.txt (2180 bytes) open success [ 37.454221] NVRAM version: 2017-03-16 update by broadcom jennifer [ 37.454820] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded. [ 37.650371] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us) [ 37.650562] bcmsdh_oob_intr_register: HW_OOB irq=99 flags=0x4 [ 37.650995] dhd_get_memdump_info: File [/data/misc/wifi/.memdump.info] doesn't exist [ 37.651030] dhd_get_memdump_info: MEMDUMP ENABLED = 2 [ 37.651777] Disable tdls_auto_op failed. -1 [ 37.651800] dhd_tcpack_suppress_set: TCP ACK Suppress mode 0 -> mode 1 [ 37.652172] dhd_apply_default_clm: Ignore clm file /vendor/etc/firmware/clm_bcm4339a0_ag.blob [ 37.662009] Firmware up: op_mode=0x0005, MAC=f4:09:d8:80:37:2a [ 37.679322] Driver: 1.579.77.41.22 (r-20191105-2)(20191120-1) [ 37.679322] Firmware: wl0: Jun 20 2018 18:44:59 version 6.37.45.15 (9b93cd5@shgit) (r) [ 37.679322] CLM: 6.8.1 [ 37.679606] dhd_txglom_enable: enable 1 [ 37.679625] [dhd] dhd_conf_set_txglom_params : txglom_mode=copy [ 37.679631] [dhd] dhd_conf_set_txglom_params : txglomsize=36, deferred_tx_len=0 [ 37.679637] [dhd] dhd_conf_set_txglom_params : txinrx_thres=128, dhd_txminmax=-1 [ 37.679642] [dhd] dhd_conf_set_txglom_params : tx_max_offset=0, txctl_tmo_fix=300 [ 37.679666] [dhd] dhd_conf_get_disable_proptx : fw_proptx=1, disable_proptx=-1 [ 37.680576] dhd_wlfc_hostreorder_init(): successful bdcv2 tlv signaling, 64 [ 37.681854] dhd_pno_init: Support Android Location Service [ 37.723888] dhd_wlfc_enable: ret=0 [ 37.723940] [dhd] CFG80211-ERROR) wl_cfg80211_event : Event handler is not created [ 37.724029] [dhd] CFG80211-ERROR) wl_cfg80211_event : Event handler is not created [ 37.724102] [dhd] CFG80211-ERROR) wl_cfg80211_event : Event handler is not created [ 37.724256] rtt_do_get_ioctl: failed to send getbuf proxd iovar (CMD ID : 1), status=-23 [ 37.724269] dhd_rtt_init : FTM is not supported [ 37.724276] dhd_preinit_ioctls: SensorHub diabled 0 [ 37.724809] dhd_preinit_ioctls failed to set ShubHub disable [ 37.726821] dhd_wl_ioctl_get_intiovar: get int iovar wnm_bsstrans_resp failed, ERR -23 [ 37.726916] failed to get wnm_bsstrans_resp [ 37.730324] failed to set WNM capabilities [ 37.730666] dhd_wlfc_enable: ret=0 [ 37.730669] [dhd] dhd_conf_set_country : set country CN, revision 38 [ 37.730712] [dhd] CFG80211-ERROR) wl_cfg80211_event : Event handler is not created [ 37.730784] [dhd] CFG80211-ERROR) wl_cfg80211_event : Event handler is not created [ 37.730848] [dhd] CFG80211-ERROR) wl_cfg80211_event : Event handler is not created [ 37.733862] [dhd] dhd_conf_set_country : Country code: CN (CN/38) [ 37.737096] [dhd-wlan0] wl_android_wifi_on : Success [ 37.780500] dhd_wlfc_enable: ret=0 [ 37.798620] dhd_open : the lock is released. [ 37.798659] dhd_open: Exit ret=0 [ 37.798967] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ 37.930506] type=1400 audit(1669436959.526:400): avc: denied { read } for comm="main" name="u:object_r:radio_prop:s0" dev="tmpfs" ino=2764 scontext=u:r:preinstall:s0 tcontext=u:object_r:radio_prop:s0 tclass=file permissive=1 [ 37.931782] type=1400 audit(1669436959.530:401): avc: denied { open } for comm="main" path="/dev/__properties__/u:object_r:radio_prop:s0" dev="tmpfs" ino=2764 scontext=u:r:preinstall:s0 tcontext=u:object_r:radio_prop:s0 tclass=file permissive=1 [ 37.933373] type=1400 audit(1669436959.530:402): avc: denied { getattr } for comm="main" path="/dev/__properties__/u:object_r:radio_prop:s0" dev="tmpfs" ino=2764 scontext=u:r:preinstall:s0 tcontext=u:object_r:radio_prop:s0 tclass=file permissive=1 [ 37.938603] type=1400 audit(1669436959.530:403): avc: denied { map } for comm="main" path="/dev/__properties__/u:object_r:radio_prop:s0" dev="tmpfs" ino=2764 scontext=u:r:preinstall:s0 tcontext=u:object_r:radio_prop:s0 tclass=file permissive=1 [ 37.942715] type=1400 audit(1669436959.536:404): avc: denied { call } for comm="main" scontext=u:r:preinstall:s0 tcontext=u:r:servicemanager:s0 tclass=binder permissive=1 [ 38.032663] audit: audit_lost=53 audit_rate_limit=5 audit_backlog_limit=64 [ 38.032707] audit: rate limit exceeded [ 38.108415] capability: warning: `wpa_supplicant' uses 32-bit capabilities (legacy support in use) [ 38.334602] P2P interface registered [ 38.334647] wl_cfgp2p_add_p2p_disc_if: wdev: 000000003eb1ca48, wdev->net: (null) [ 38.417791] WLC_E_IF: NO_IF set, event Ignored [ 38.419962] P2P interface started [ 39.051073] WLDEV-INFO) wldev_set_country: Current country CN rev 38 [ 39.051110] [dhd] dhd_conf_set_country : set country XS, revision -1 [ 39.054586] type=1400 audit(1669436960.636:438): avc: denied { call } for comm="BootAnimation" scontext=u:r:bootanim:s0 tcontext=u:r:mediaserver:s0 tclass=binder permissive=1 [ 39.055509] [dhd] dhd_conf_set_country : Country code: XS (XS/0) [ 39.081892] wldev_set_country: set country for XS as XS rev 0 [ 39.087233] dhd_dbg_attach_pkt_monitor, 1606 [ 39.121182] dhd_wl_ioctl_get_intiovar: get int iovar rte_timesync failed, ERR -23 [ 39.121213] dhd_os_start_logging rte_timesync failed [ 39.140377] dhd_wl_ioctl_get_intiovar: get int iovar rte_timesync failed, ERR -23 [ 39.140407] dhd_os_start_logging rte_timesync failed [ 39.157028] dhd_wl_ioctl_get_intiovar: get int iovar rte_timesync failed, ERR -23 [ 39.157059] dhd_os_start_logging rte_timesync failed [ 39.164882] dhd_wl_ioctl_get_intiovar: get int iovar rte_timesync failed, ERR -23 [ 39.164973] dhd_os_start_logging rte_timesync failed [ 39.189087] type=1400 audit(1669436960.786:439): avc: denied { read } for comm="user_drmservice" lport=33334 scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=udp_socket permissive=1 [ 39.207705] net_os_enable_packet_filter: val = 0 [ 39.210491] net_os_rxfilter_add_remove: add_remove = 0, num = 2 [ 39.212048] net_os_enable_packet_filter: val = 1 [ 39.212812] net_os_enable_packet_filter: val = 0 [ 39.213604] net_os_rxfilter_add_remove: add_remove = 0, num = 3 [ 39.214896] net_os_enable_packet_filter: val = 1 [ 39.215992] dhd_set_suspend: Remove extra suspend setting [ 39.216028] dhd_enable_packet_filter: enter, value = 0 [ 39.387713] type=1400 audit(1669436960.986:440): avc: denied { read } for comm="user_drmservice" lport=33334 scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=udp_socket permissive=1 [ 39.655983] [dhd-wlan0] wl_run_escan : LEGACY_SCAN sync ID: 0, bssidx: 0 [ 39.664356] audit: audit_lost=82 audit_rate_limit=5 audit_backlog_limit=64 [ 39.664463] audit: rate limit exceeded [ 39.670433] type=1400 audit(1669436961.263:441): avc: denied { read } for comm="Binder:165_2" name="wakeup2" dev="sysfs" ino=15084 scontext=u:r:system_suspend:s0 tcontext=u:object_r:sysfs:s0 tclass=dir permissive=1 [ 39.670661] type=1400 audit(1669436961.263:442): avc: denied { open } for comm="Binder:165_2" path="/sys/devices/platform/fdef0000.iep/wakeup/wakeup2" dev="sysfs" ino=15084 scontext=u:r:system_suspend:s0 tcontext=u:object_r:sysfs:s0 tclass=dir permissive=1 [ 42.005410] init: processing action (sys.sysctl.tcp_def_init_rwnd=*) from (/system/etc/init/hw/init.rc:994) [ 42.158709] audit: audit_lost=87 audit_rate_limit=5 audit_backlog_limit=64 [ 42.158753] audit: rate limit exceeded [ 42.341353] init: Service 'bootanim' (pid 168) exited with status 0 oneshot service took 38.278999 seconds in background [ 42.341443] init: Sending signal 9 to service 'bootanim' (pid 168) process group... [ 42.341955] libprocessgroup: Successfully killed process cgroup uid 1003 pid 168 in 0ms [ 43.885910] type=1400 audit(1735396106.585:459): avc: denied { getattr } for comm="preinstall.sh" path="/system/bin/pm" dev="dm-0" ino=1621 scontext=u:r:preinstall:s0 tcontext=u:object_r:system_file:s0 tclass=file permissive=1 [ 43.886223] type=1400 audit(1735396106.585:460): avc: denied { execute } for comm="preinstall.sh" name="pm" dev="dm-0" ino=1621 scontext=u:r:preinstall:s0 tcontext=u:object_r:system_file:s0 tclass=file permissive=1 [ 43.887037] audit: audit_lost=88 audit_rate_limit=5 audit_backlog_limit=64 [ 43.887058] audit: rate limit exceeded [ 43.887172] type=1400 audit(1735396106.585:461): avc: denied { read open } for comm="preinstall.sh" path="/system/bin/pm" dev="dm-0" ino=1621 scontext=u:r:preinstall:s0 tcontext=u:object_r:system_file:s0 tclass=file permissive=1 [ 43.887471] type=1400 audit(1735396106.585:462): avc: denied { execute_no_trans } for comm="preinstall.sh" path="/system/bin/pm" dev="dm-0" ino=1621 scontext=u:r:preinstall:s0 tcontext=u:object_r:system_file:s0 tclass=file permissive=1 [ 43.887590] type=1400 audit(1735396106.589:463): avc: denied { execute } for comm="preinstall.sh" name="sh" dev="dm-0" ino=1674 scontext=u:r:preinstall:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1 [ 44.902749] type=1400 audit(1735396107.602:489): avc: denied { read } for comm="user_drmservice" lport=33334 scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=udp_socket permissive=1 [ 44.972765] type=1400 audit(1735396107.672:490): avc: denied { search } for comm="android.bg" name="307" dev="proc" ino=21818 scontext=u:r:system_server:s0 tcontext=u:r:datadis:s0 tclass=dir permissive=1 [ 44.981788] type=1400 audit(1735396107.672:491): avc: denied { read } for comm="android.bg" name="stat" dev="proc" ino=23367 scontext=u:r:system_server:s0 tcontext=u:r:datadis:s0 tclass=file permissive=1 [ 44.992717] type=1400 audit(1735396107.692:492): avc: denied { open } for comm="android.bg" path="/proc/307/stat" dev="proc" ino=23367 scontext=u:r:system_server:s0 tcontext=u:r:datadis:s0 tclass=file permissive=1 [ 45.256242] type=1400 audit(1735396107.955:493): avc: denied { getattr } for comm="android.bg" path="/proc/1093" dev="proc" ino=25093 scontext=u:r:system_server:s0 tcontext=u:r:datadis:s0 tclass=dir permissive=1 [ 45.259180] audit: audit_lost=113 audit_rate_limit=5 audit_backlog_limit=64 [ 45.259205] audit: rate limit exceeded [ 47.395389] init: processing action (persist.vendor.ethstate=4) from (/vendor/etc/init/hw/init.hcy.rc:96) [ 47.880847] [dhd-wlan0] wl_run_escan : LEGACY_SCAN sync ID: 1, bssidx: 0 [ 50.535418] type=1400 audit(1735396113.215:501): avc: denied { read } for comm="user_drmservice" lport=33334 scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=udp_socket permissive=1 [ 50.676608] type=1400 audit(1735396113.375:502): avc: denied { getattr } for comm="Binder:316_2" path="/data/system/rt_audio_config.xml" dev="mmcblk2p16" ino=992 scontext=u:r:mediaserver:s0 tcontext=u:object_r:system_data_file:s0 tclass=file permissive=1 [ 54.420972] type=1400 audit(1735396117.092:503): avc: denied { write } for comm="URATION_CHANGED" name="property_service" dev="tmpfs" ino=18099 scontext=u:r:gmscore_app:s0:c512,c768 tcontext=u:object_r:property_socket:s0 tclass=sock_file permissive=1 app=com.google.android.gms [ 54.474802] type=1400 audit(1735396117.092:504): avc: denied { connectto } for comm="URATION_CHANGED" path="/dev/socket/property_service" scontext=u:r:gmscore_app:s0:c512,c768 tcontext=u:r:init:s0 tclass=unix_stream_socket permissive=1 app=com.google.android.gms [ 54.491548] type=1107 audit(1735396117.095:505): uid=0 auid=4294967295 ses=4294967295 subj=u:r:init:s0 msg='avc: denied { set } for property=sys.gmali.version pid=1639 uid=10041 gid=10041 scontext=u:r:gmscore_app:s0:c512,c768 tcontext=u:object_r:system_prop:s0 tclass=property_service permissive=1' [ 54.494844] type=1400 audit(1735396117.125:506): avc: denied { read } for comm="user_drmservice" lport=33334 scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=udp_socket permissive=1 [ 55.205310] binder: undelivered TRANSACTION_COMPLETE [ 55.205352] binder: undelivered transaction 150841, process died. [ 55.205382] binder: release 1639:2075 transaction 150592 out, still active [ 55.205388] binder: undelivered TRANSACTION_COMPLETE [ 55.209320] binder_alloc: 1149: binder_alloc_buf, no vma [ 55.209360] binder: 439:621 transaction failed 29189/-3, size 244-8 line 3228 [ 55.217432] binder: undelivered transaction 151066, process died. [ 55.217618] binder: undelivered TRANSACTION_COMPLETE [ 55.217638] binder: undelivered transaction 151043, process died. [ 55.217665] binder: release 1149:2138 transaction 150592 in, still active [ 55.217677] binder: send failed reply for transaction 150592, target dead [ 57.333516] type=1400 audit(1735396120.032:507): avc: denied { read } for comm="user_drmservice" lport=33334 scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=udp_socket permissive=1 [ 59.582766] type=1400 audit(1735396122.282:508): avc: denied { read } for comm=".update.service" name="u:object_r:serialno_prop:s0" dev="tmpfs" ino=2768 scontext=u:r:system_app:s0 tcontext=u:object_r:serialno_prop:s0 tclass=file permissive=1 [ 59.608478] type=1400 audit(1735396122.282:509): avc: denied { open } for comm=".update.service" path="/dev/__properties__/u:object_r:serialno_prop:s0" dev="tmpfs" ino=2768 scontext=u:r:system_app:s0 tcontext=u:object_r:serialno_prop:s0 tclass=file permissive=1 [ 59.634300] type=1400 audit(1735396122.282:510): avc: denied { getattr } for comm=".update.service" path="/dev/__properties__/u:object_r:serialno_prop:s0" dev="tmpfs" ino=2768 scontext=u:r:system_app:s0 tcontext=u:object_r:serialno_prop:s0 tclass=file permissive=1 [ 59.641734] type=1400 audit(1735396122.285:511): avc: denied { map } for comm=".update.service" path="/dev/__properties__/u:object_r:serialno_prop:s0" dev="tmpfs" ino=2768 scontext=u:r:system_app:s0 tcontext=u:object_r:serialno_prop:s0 tclass=file permissive=1 [ 59.647846] type=1400 audit(1735396122.342:512): avc: denied { read } for comm="user_drmservice" lport=33334 scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=udp_socket permissive=1 [ 61.046390] type=1400 audit(1735396123.745:513): avc: denied { read } for comm="user_drmservice" lport=33334 scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=udp_socket permissive=1 [ 61.421943] logd: logdr: UID=10041 GID=10041 PID=2392 n tail=0 logMask=4 pid=0 start=0ns timeout=0ns [ 61.602882] [dhd-wlan0] wl_run_escan : LEGACY_SCAN sync ID: 2, bssidx: 0 [ 62.481123] type=1400 audit(1735396125.155:514): avc: denied { read } for comm="user_drmservice" lport=33334 scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=udp_socket permissive=1 [ 62.815427] type=1400 audit(1735396125.515:515): avc: denied { read write } for comm="com.gaoee.led" name="digital_dis" dev="tmpfs" ino=18227 scontext=u:r:system_app:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1 [ 62.815700] type=1400 audit(1735396125.515:516): avc: denied { open } for comm="com.gaoee.led" path="/dev/digital_dis" dev="tmpfs" ino=18227 scontext=u:r:system_app:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1 [ 62.884383] type=1400 audit(1735396125.582:517): avc: denied { ioctl } for comm="com.gaoee.led" path="/dev/digital_dis" dev="tmpfs" ino=18227 ioctlcmd=0x5409 scontext=u:r:system_app:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1 [ 63.604682] type=1400 audit(1735396126.299:518): avc: denied { write } for comm="BlockingExecuto" name="property_service" dev="tmpfs" ino=18099 scontext=u:r:priv_app:s0:c512,c768 tcontext=u:object_r:property_socket:s0 tclass=sock_file permissive=1 app=com.android.vending [ 63.635911] type=1400 audit(1735396126.299:519): avc: denied { connectto } for comm="BlockingExecuto" path="/dev/socket/property_service" scontext=u:r:priv_app:s0:c512,c768 tcontext=u:r:init:s0 tclass=unix_stream_socket permissive=1 app=com.android.vending [ 63.636432] type=1107 audit(1735396126.305:520): uid=0 auid=4294967295 ses=4294967295 subj=u:r:init:s0 msg='avc: denied { set } for property=sys.gmali.version pid=2089 uid=10038 gid=10038 scontext=u:r:priv_app:s0:c512,c768 tcontext=u:object_r:system_prop:s0 tclass=property_service permissive=1' [ 63.658793] type=1400 audit(1735396126.355:521): avc: denied { read } for comm="user_drmservice" lport=33334 scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=udp_socket permissive=1 [ 63.936639] audit: audit_lost=117 audit_rate_limit=5 audit_backlog_limit=64 [ 63.936676] audit: rate limit exceeded [ 63.940282] type=1400 audit(1735396126.635:522): avc: denied { search } for comm="oid.tv.settings" name="net" dev="sysfs" ino=11459 scontext=u:r:system_app:s0 tcontext=u:object_r:sysfs_net:s0 tclass=dir permissive=1 [ 65.989768] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au [ 66.795105] audit: audit_lost=120 audit_rate_limit=5 audit_backlog_limit=64 [ 66.795147] audit: rate limit exceeded [ 66.798453] type=1400 audit(1735396129.495:526): avc: denied { dac_read_search } for comm="xbmc_copy_folde" capability=2 scontext=u:r:xbmc_copy_folder:s0 tcontext=u:r:xbmc_copy_folder:s0 tclass=capability permissive=1 [ 68.040714] type=1401 audit(1735396130.739:712): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 68.042707] audit: audit_lost=301 audit_rate_limit=5 audit_backlog_limit=64 [ 68.042750] audit: rate limit exceeded [ 68.046322] type=1401 audit(1735396130.742:713): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 68.059249] type=1400 audit(1735396130.742:714): avc: denied { read } for comm="grep" name="properties_serial" dev="tmpfs" ino=2811 scontext=u:r:datadis:s0 tcontext=u:object_r:properties_serial:s0 tclass=file permissive=1 [ 68.066716] type=1400 audit(1735396130.742:715): avc: denied { open } for comm="grep" path="/dev/__properties__/properties_serial" dev="tmpfs" ino=2811 scontext=u:r:datadis:s0 tcontext=u:object_r:properties_serial:s0 tclass=file permissive=1 [ 68.080653] type=1400 audit(1735396130.742:716): avc: denied { getattr } for comm="grep" path="/dev/__properties__/properties_serial" dev="tmpfs" ino=2811 scontext=u:r:datadis:s0 tcontext=u:object_r:properties_serial:s0 tclass=file permissive=1 [ 69.207002] type=1400 audit(1735396131.879:768): avc: denied { read } for comm="user_drmservice" lport=33334 scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=udp_socket permissive=1 [ 69.207247] type=1400 audit(1735396131.889:769): avc: denied { fork } for comm="stress_wifi_tes" scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=process permissive=1 [ 69.207398] type=1400 audit(1735396131.892:770): avc: denied { read } for comm="stress_wifi_tes" path="pipe:[50654]" dev="pipefs" ino=50654 scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=fifo_file permissive=1 [ 69.210112] audit: audit_lost=352 audit_rate_limit=5 audit_backlog_limit=64 [ 69.210151] audit: rate limit exceeded [ 69.225327] type=1400 audit(1735396131.909:771): avc: denied { search } for comm="stress_wifi_tes" name="/" dev="dm-0" ino=2 scontext=u:r:datadis:s0 tcontext=u:object_r:rootfs:s0 tclass=dir permissive=1 [ 69.225865] type=1400 audit(1735396131.909:772): avc: denied { search } for comm="stress_wifi_tes" name="/" dev="dm-3" ino=2 scontext=u:r:datadis:s0 tcontext=u:object_r:system_file:s0 tclass=dir permissive=1 [ 70.507333] audit: audit_lost=477 audit_rate_limit=5 audit_backlog_limit=64 [ 70.507438] audit: rate limit exceeded [ 71.658284] audit: audit_lost=599 audit_rate_limit=5 audit_backlog_limit=64 [ 71.658399] audit: rate limit exceeded [ 72.807412] audit: audit_lost=706 audit_rate_limit=5 audit_backlog_limit=64 [ 72.807455] audit: rate limit exceeded [ 73.862661] [dhd-wlan0] wl_run_escan : LEGACY_SCAN sync ID: 3, bssidx: 0 [ 73.908662] type=1400 audit(1735396136.609:1233): avc: denied { read } for comm="stress_wifi_tes" path="pipe:[53531]" dev="pipefs" ino=53531 scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=fifo_file permissive=1 [ 73.913758] audit: audit_lost=797 audit_rate_limit=5 audit_backlog_limit=64 [ 73.913794] audit: rate limit exceeded [ 73.915519] type=1400 audit(1735396136.612:1234): avc: denied { search } for comm="stress_wifi_tes" name="/" dev="dm-0" ino=2 scontext=u:r:datadis:s0 tcontext=u:object_r:rootfs:s0 tclass=dir permissive=1 [ 73.916235] type=1400 audit(1735396136.612:1235): avc: denied { search } for comm="stress_wifi_tes" name="/" dev="dm-3" ino=2 scontext=u:r:datadis:s0 tcontext=u:object_r:system_file:s0 tclass=dir permissive=1 [ 73.925758] type=1400 audit(1735396136.615:1236): avc: denied { read } for comm="stress_wifi_tes" name="df" dev="dm-0" ino=1437 scontext=u:r:datadis:s0 tcontext=u:object_r:system_file:s0 tclass=lnk_file permissive=1 [ 73.926274] type=1400 audit(1735396136.615:1237): avc: denied { getattr } for comm="stress_wifi_tes" path="/system/bin/toybox" dev="dm-0" ino=1727 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1 [ 74.821305] init: Service 'xbmc_copy_folder' (pid 1090) exited with status 0 oneshot service took 38.165001 seconds in background [ 74.821399] init: Sending signal 9 to service 'xbmc_copy_folder' (pid 1090) process group... [ 74.821844] libprocessgroup: Successfully killed process cgroup uid 0 pid 1090 in 0ms [ 75.106120] type=1400 audit(1735396137.805:1373): avc: denied { fork } for comm="stress_wifi_tes" scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=process permissive=1 [ 75.106557] type=1400 audit(1735396137.805:1374): avc: denied { read } for comm="stress_wifi_tes" path="pipe:[56410]" dev="pipefs" ino=56410 scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=fifo_file permissive=1 [ 75.107530] audit: audit_lost=932 audit_rate_limit=5 audit_backlog_limit=64 [ 75.107557] audit: rate limit exceeded [ 75.108026] type=1400 audit(1735396137.809:1375): avc: denied { search } for comm="stress_wifi_tes" name="/" dev="dm-0" ino=2 scontext=u:r:datadis:s0 tcontext=u:object_r:rootfs:s0 tclass=dir permissive=1 [ 75.108373] type=1400 audit(1735396137.809:1376): avc: denied { search } for comm="stress_wifi_tes" name="/" dev="dm-3" ino=2 scontext=u:r:datadis:s0 tcontext=u:object_r:system_file:s0 tclass=dir permissive=1 [ 75.108548] type=1400 audit(1735396137.809:1377): avc: denied { read } for comm="stress_wifi_tes" name="df" dev="dm-0" ino=1437 scontext=u:r:datadis:s0 tcontext=u:object_r:system_file:s0 tclass=lnk_file permissive=1 [ 76.220069] audit: audit_lost=1067 audit_rate_limit=5 audit_backlog_limit=64 [ 76.220117] audit: rate limit exceeded [ 77.222673] audit: audit_lost=1127 audit_rate_limit=5 audit_backlog_limit=64 [ 77.222708] audit: rate limit exceeded [ 78.599871] audit: audit_lost=1476 audit_rate_limit=5 audit_backlog_limit=64 [ 78.599966] audit: rate limit exceeded [ 79.925289] audit: audit_lost=1542 audit_rate_limit=5 audit_backlog_limit=64 [ 79.925334] audit: rate limit exceeded [ 79.927831] type=1400 audit(1735396142.625:2003): avc: denied { search } for comm="stress_wifi_tes" name="/" dev="dm-3" ino=2 scontext=u:r:datadis:s0 tcontext=u:object_r:system_file:s0 tclass=dir permissive=1 [ 79.928268] type=1400 audit(1735396142.625:2004): avc: denied { read } for comm="stress_wifi_tes" name="df" dev="dm-0" ino=1437 scontext=u:r:datadis:s0 tcontext=u:object_r:system_file:s0 tclass=lnk_file permissive=1 [ 79.928446] type=1400 audit(1735396142.625:2005): avc: denied { getattr } for comm="stress_wifi_tes" path="/system/bin/toybox" dev="dm-0" ino=1727 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1 [ 79.928567] type=1400 audit(1735396142.625:2006): avc: denied { execute } for comm="stress_wifi_tes" name="toybox" dev="dm-0" ino=1727 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1 [ 79.928694] type=1400 audit(1735396142.625:2007): avc: denied { read open } for comm="stress_wifi_tes" path="/system/bin/toybox" dev="dm-0" ino=1727 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1 [ 80.400620] [dhd-wlan0] wl_run_escan : LEGACY_SCAN sync ID: 4, bssidx: 0 [ 81.137339] type=1400 audit(1735396143.835:2070): avc: denied { search } for comm="stress_wifi_tes" name="/" dev="tmpfs" ino=18090 scontext=u:r:datadis:s0 tcontext=u:object_r:apex_mnt_dir:s0 tclass=dir permissive=1 [ 81.169408] type=1401 audit(1735396143.869:2071): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 81.170163] type=1400 audit(1735396143.869:2072): avc: denied { read } for comm="df" name="urandom" dev="tmpfs" ino=2605 scontext=u:r:datadis:s0 tcontext=u:object_r:random_device:s0 tclass=chr_file permissive=1 [ 81.170450] type=1400 audit(1735396143.869:2073): avc: denied { getattr } for comm="df" path="/dev/__properties__" dev="tmpfs" ino=2639 scontext=u:r:datadis:s0 tcontext=u:object_r:properties_device:s0 tclass=dir permissive=1 [ 81.170475] audit: audit_lost=1604 audit_rate_limit=5 audit_backlog_limit=64 [ 81.170478] audit: rate limit exceeded [ 81.170670] type=1400 audit(1735396143.869:2074): avc: denied { search } for comm="df" name="__properties__" dev="tmpfs" ino=2639 scontext=u:r:datadis:s0 tcontext=u:object_r:properties_device:s0 tclass=dir permissive=1 [ 82.403398] audit: audit_lost=1632 audit_rate_limit=5 audit_backlog_limit=64 [ 82.403501] audit: rate limit exceeded [ 83.754023] audit: audit_lost=1660 audit_rate_limit=5 audit_backlog_limit=64 [ 83.754061] audit: rate limit exceeded [ 84.930545] audit: audit_lost=1680 audit_rate_limit=5 audit_backlog_limit=64 [ 84.930731] audit: rate limit exceeded [ 84.946308] type=1401 audit(1735396147.629:2163): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 84.947560] type=1400 audit(1735396147.629:2164): avc: denied { read } for comm="stress_wifi_tes" name="linker64" dev="dm-0" ino=1543 scontext=u:r:datadis:s0 tcontext=u:object_r:system_linker_exec:s0 tclass=lnk_file permissive=1 [ 84.948046] type=1400 audit(1735396147.629:2165): avc: denied { use } for comm="grep" path="/dev/null" dev="tmpfs" ino=2607 scontext=u:r:datadis:s0 tcontext=u:r:init:s0 tclass=fd permissive=1 [ 85.183409] binder: undelivered TRANSACTION_COMPLETE [ 85.183456] binder: undelivered transaction 249449, process died. [ 85.183765] binder: undelivered transaction 249591, process died. [ 85.183782] binder: undelivered transaction 249595, process died. [ 85.184263] binder: undelivered transaction 249569, process died. [ 86.064137] type=1400 audit(1735396148.762:2192): avc: denied { search } for comm="stress_wifi_tes" name="/" dev="tmpfs" ino=18090 scontext=u:r:datadis:s0 tcontext=u:object_r:apex_mnt_dir:s0 tclass=dir permissive=1 [ 86.071775] audit: audit_lost=1706 audit_rate_limit=5 audit_backlog_limit=64 [ 86.071817] audit: rate limit exceeded [ 86.072285] type=1401 audit(1735396148.772:2193): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 86.072713] type=1400 audit(1735396148.772:2194): avc: denied { execute } for comm="stress_wifi_tes" name="linker64" dev="dm-0" ino=500 scontext=u:r:datadis:s0 tcontext=u:object_r:system_linker_exec:s0 tclass=file permissive=1 [ 86.072873] type=1400 audit(1735396148.772:2195): avc: denied { read open } for comm="stress_wifi_tes" path="/apex/com.android.runtime/bin/linker64" dev="dm-0" ino=500 scontext=u:r:datadis:s0 tcontext=u:object_r:system_linker_exec:s0 tclass=file permissive=1 [ 86.073066] type=1400 audit(1735396148.772:2196): avc: denied { map } for comm="grep" path="/apex/com.android.runtime/bin/linker64" dev="dm-0" ino=500 scontext=u:r:datadis:s0 tcontext=u:object_r:system_linker_exec:s0 tclass=file permissive=1 [ 87.208610] audit: audit_lost=1781 audit_rate_limit=5 audit_backlog_limit=64 [ 87.208713] audit: rate limit exceeded [ 87.268791] type=1400 audit(1735396149.905:2272): avc: denied { fork } for comm="stress_wifi_tes" scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=process permissive=1 [ 87.269042] type=1400 audit(1735396149.909:2273): avc: denied { read } for comm="stress_wifi_tes" path="pipe:[62694]" dev="pipefs" ino=62694 scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=fifo_file permissive=1 [ 88.441938] audit: audit_lost=1859 audit_rate_limit=5 audit_backlog_limit=64 [ 88.441979] audit: rate limit exceeded [ 89.605604] audit: audit_lost=1884 audit_rate_limit=5 audit_backlog_limit=64 [ 89.605714] audit: rate limit exceeded [ 89.617662] [dhd-wlan0] wl_run_escan : LEGACY_SCAN sync ID: 5, bssidx: 0 [ 90.927076] type=1400 audit(1735396153.625:2426): avc: denied { fork } for comm="stress_wifi_tes" scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=process permissive=1 [ 90.927526] type=1400 audit(1735396153.625:2427): avc: denied { search } for comm="stress_wifi_tes" name="/" dev="dm-3" ino=2 scontext=u:r:datadis:s0 tcontext=u:object_r:system_file:s0 tclass=dir permissive=1 [ 90.927873] type=1400 audit(1735396153.625:2428): avc: denied { read } for comm="stress_wifi_tes" name="df" dev="dm-0" ino=1437 scontext=u:r:datadis:s0 tcontext=u:object_r:system_file:s0 tclass=lnk_file permissive=1 [ 90.947186] audit: audit_lost=1920 audit_rate_limit=5 audit_backlog_limit=64 [ 90.947225] audit: rate limit exceeded [ 90.953740] type=1401 audit(1735396153.645:2429): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 90.968572] type=1400 audit(1735396153.645:2430): avc: denied { read } for comm="stress_wifi_tes" name="linker64" dev="dm-0" ino=1543 scontext=u:r:datadis:s0 tcontext=u:object_r:system_linker_exec:s0 tclass=lnk_file permissive=1 [ 92.216801] type=1400 audit(1735396154.915:2500): avc: denied { read } for comm="stress_wifi_tes" path="pipe:[65977]" dev="pipefs" ino=65977 scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=fifo_file permissive=1 [ 92.223772] audit: audit_lost=1990 audit_rate_limit=5 audit_backlog_limit=64 [ 92.223864] audit: rate limit exceeded [ 92.224199] type=1400 audit(1735396154.922:2501): avc: denied { search } for comm="stress_wifi_tes" name="/" dev="dm-0" ino=2 scontext=u:r:datadis:s0 tcontext=u:object_r:rootfs:s0 tclass=dir permissive=1 [ 92.224757] type=1401 audit(1735396154.922:2502): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 92.225298] type=1400 audit(1735396154.925:2503): avc: denied { search } for comm="logd.auditd" name="3798" dev="proc" ino=64386 scontext=u:r:logd:s0 tcontext=u:r:datadis:s0 tclass=dir permissive=1 [ 92.225531] type=1400 audit(1735396154.925:2504): avc: denied { execute } for comm="stress_wifi_tes" name="linker64" dev="dm-0" ino=500 scontext=u:r:datadis:s0 tcontext=u:object_r:system_linker_exec:s0 tclass=file permissive=1 [ 93.697472] audit: audit_lost=2076 audit_rate_limit=5 audit_backlog_limit=64 [ 93.697562] audit: rate limit exceeded [ 94.908820] audit: audit_lost=2130 audit_rate_limit=5 audit_backlog_limit=64 [ 94.908914] audit: rate limit exceeded [ 96.216467] type=1400 audit(1735396158.915:2699): avc: denied { fork } for comm="stress_wifi_tes" scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=process permissive=1 [ 96.216714] type=1400 audit(1735396158.915:2700): avc: denied { read } for comm="stress_wifi_tes" path="pipe:[68733]" dev="pipefs" ino=68733 scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=fifo_file permissive=1 [ 96.217135] type=1400 audit(1735396158.915:2701): avc: denied { search } for comm="stress_wifi_tes" name="/" dev="dm-0" ino=2 scontext=u:r:datadis:s0 tcontext=u:object_r:rootfs:s0 tclass=dir permissive=1 [ 96.218026] audit: audit_lost=2173 audit_rate_limit=5 audit_backlog_limit=64 [ 96.218048] audit: rate limit exceeded [ 96.227712] type=1401 audit(1735396158.915:2702): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 96.228504] type=1400 audit(1735396158.915:2703): avc: denied { read } for comm="stress_wifi_tes" name="linker64" dev="dm-0" ino=1543 scontext=u:r:datadis:s0 tcontext=u:object_r:system_linker_exec:s0 tclass=lnk_file permissive=1 [ 97.344877] type=1400 audit(1735396160.045:2747): avc: denied { read } for comm="stress_wifi_tes" name="df" dev="dm-0" ino=1437 scontext=u:r:datadis:s0 tcontext=u:object_r:system_file:s0 tclass=lnk_file permissive=1 [ 97.349983] audit: audit_lost=2216 audit_rate_limit=5 audit_backlog_limit=64 [ 97.350019] audit: rate limit exceeded [ 97.355529] type=1400 audit(1735396160.049:2748): avc: denied { getattr } for comm="stress_wifi_tes" path="/system/bin/toybox" dev="dm-0" ino=1727 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1 [ 97.359738] type=1400 audit(1735396160.049:2749): avc: denied { execute } for comm="stress_wifi_tes" name="toybox" dev="dm-0" ino=1727 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1 [ 97.375083] type=1400 audit(1735396160.049:2750): avc: denied { read open } for comm="stress_wifi_tes" path="/system/bin/toybox" dev="dm-0" ino=1727 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1 [ 97.375346] type=1401 audit(1735396160.049:2751): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 98.180100] binder: 2253:2353 transaction failed 29189/-22, size 176-0 line 3059 [ 98.582655] audit: audit_lost=2248 audit_rate_limit=5 audit_backlog_limit=64 [ 98.582750] audit: rate limit exceeded [ 99.832656] audit: audit_lost=2262 audit_rate_limit=5 audit_backlog_limit=64 [ 99.832760] audit: rate limit exceeded [ 100.969417] audit: audit_lost=2271 audit_rate_limit=5 audit_backlog_limit=64 [ 100.969455] audit: rate limit exceeded [ 102.227117] [dhd-wlan0] wl_run_escan : LEGACY_SCAN sync ID: 6, bssidx: 0 [ 102.321269] type=1400 audit(1735396165.022:2855): avc: denied { search } for comm="stress_wifi_tes" name="/" dev="dm-0" ino=2 scontext=u:r:datadis:s0 tcontext=u:object_r:rootfs:s0 tclass=dir permissive=1 [ 102.351825] audit: audit_lost=2304 audit_rate_limit=5 audit_backlog_limit=64 [ 102.351861] audit: rate limit exceeded [ 102.381542] type=1400 audit(1735396165.022:2856): avc: denied { read } for comm="stress_wifi_tes" path="pipe:[71100]" dev="pipefs" ino=71100 scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=fifo_file permissive=1 [ 102.398281] type=1401 audit(1735396165.029:2857): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 102.419798] type=1400 audit(1735396165.032:2858): avc: denied { search } for comm="df" name="/" dev="tmpfs" ino=2599 scontext=u:r:datadis:s0 tcontext=u:object_r:device:s0 tclass=dir permissive=1 [ 102.420084] type=1400 audit(1735396165.032:2859): avc: denied { read } for comm="df" name="self" dev="proc" ino=4026531841 scontext=u:r:datadis:s0 tcontext=u:object_r:proc:s0 tclass=lnk_file permissive=1 [ 103.545665] audit: audit_lost=2334 audit_rate_limit=5 audit_backlog_limit=64 [ 103.545760] audit: rate limit exceeded [ 103.564059] type=1400 audit(1735396166.245:2889): avc: denied { search } for comm="stress_wifi_tes" name="/" dev="dm-3" ino=2 scontext=u:r:datadis:s0 tcontext=u:object_r:system_file:s0 tclass=dir permissive=1 [ 103.634757] type=1400 audit(1735396166.245:2890): avc: denied { read } for comm="stress_wifi_tes" name="grep" dev="dm-0" ino=1482 scontext=u:r:datadis:s0 tcontext=u:object_r:system_file:s0 tclass=lnk_file permissive=1 [ 103.635181] type=1400 audit(1735396166.245:2891): avc: denied { getattr } for comm="stress_wifi_tes" path="/system/bin/toybox" dev="dm-0" ino=1727 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1 [ 103.635491] type=1400 audit(1735396166.245:2892): avc: denied { execute } for comm="stress_wifi_tes" name="toybox" dev="dm-0" ino=1727 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1 [ 103.635751] type=1400 audit(1735396166.245:2893): avc: denied { read } for comm="logd.auditd" name="status" dev="proc" ino=72161 scontext=u:r:logd:s0 tcontext=u:r:datadis:s0 tclass=file permissive=1 [ 104.891370] audit: audit_lost=2379 audit_rate_limit=5 audit_backlog_limit=64 [ 104.891423] audit: rate limit exceeded [ 106.021963] audit: audit_lost=2393 audit_rate_limit=5 audit_backlog_limit=64 [ 106.022190] audit: rate limit exceeded [ 107.211679] audit: audit_lost=2440 audit_rate_limit=5 audit_backlog_limit=64 [ 107.211718] audit: rate limit exceeded [ 108.507063] type=1401 audit(1735396171.199:3101): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 108.530394] audit: audit_lost=2525 audit_rate_limit=5 audit_backlog_limit=64 [ 108.530485] audit: rate limit exceeded [ 108.540984] type=1401 audit(1735396171.199:3102): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 108.542244] type=1400 audit(1735396171.229:3103): avc: denied { read } for comm="grep" name="u:object_r:vendor_socket_hook_prop:s0" dev="tmpfs" ino=2802 scontext=u:r:datadis:s0 tcontext=u:object_r:vendor_socket_hook_prop:s0 tclass=file permissive=1 [ 108.597206] type=1400 audit(1735396171.232:3104): avc: denied { open } for comm="grep" path="/dev/__properties__/u:object_r:vendor_socket_hook_prop:s0" dev="tmpfs" ino=2802 scontext=u:r:datadis:s0 tcontext=u:object_r:vendor_socket_hook_prop:s0 tclass=file permissive=1 [ 108.597646] type=1400 audit(1735396171.232:3105): avc: denied { getattr } for comm="grep" path="/dev/__properties__/u:object_r:vendor_socket_hook_prop:s0" dev="tmpfs" ino=2802 scontext=u:r:datadis:s0 tcontext=u:object_r:vendor_socket_hook_prop:s0 tclass=file permissive=1 [ 109.703803] type=1400 audit(1735396172.402:3117): avc: denied { search } for comm="stress_wifi_tes" name="/" dev="tmpfs" ino=18090 scontext=u:r:datadis:s0 tcontext=u:object_r:apex_mnt_dir:s0 tclass=dir permissive=1 [ 109.704365] type=1401 audit(1735396172.402:3118): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 109.732174] type=1401 audit(1735396172.405:3119): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 109.766674] audit: audit_lost=2536 audit_rate_limit=5 audit_backlog_limit=64 [ 109.766770] audit: rate limit exceeded [ 109.772612] type=1400 audit(1735396172.465:3120): avc: denied { getattr } for comm="df" path="/apex" dev="tmpfs" ino=18090 scontext=u:r:datadis:s0 tcontext=u:object_r:apex_mnt_dir:s0 tclass=dir permissive=1 [ 109.773306] type=1400 audit(1735396172.465:3121): avc: denied { getattr } for comm="df" name="/" dev="binder" ino=1 scontext=u:r:datadis:s0 tcontext=u:object_r:binderfs:s0 tclass=filesystem permissive=1 [ 110.957411] audit: audit_lost=2541 audit_rate_limit=5 audit_backlog_limit=64 [ 110.957516] audit: rate limit exceeded [ 112.154119] audit: audit_lost=2555 audit_rate_limit=5 audit_backlog_limit=64 [ 112.154253] audit: rate limit exceeded [ 113.365456] audit: audit_lost=2583 audit_rate_limit=5 audit_backlog_limit=64 [ 113.365495] audit: rate limit exceeded [ 114.510384] type=1400 audit(1735396177.209:3201): avc: denied { fork } for comm="stress_wifi_tes" scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=process permissive=1 [ 114.512757] type=1401 audit(1735396177.212:3202): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 114.513880] type=1401 audit(1735396177.212:3203): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 114.521040] type=1400 audit(1735396177.215:3204): avc: denied { getsched } for comm="df" scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=process permissive=1 [ 114.532961] type=1400 audit(1735396177.232:3205): avc: denied { search } for comm="df" name="/" dev="sysfs" ino=1 scontext=u:r:datadis:s0 tcontext=u:object_r:sysfs:s0 tclass=dir permissive=1 [ 114.533765] audit: audit_lost=2600 audit_rate_limit=5 audit_backlog_limit=64 [ 114.533785] audit: rate limit exceeded [ 115.616440] type=1400 audit(1735396178.315:3216): avc: denied { search } for comm="stress_wifi_tes" name="/" dev="dm-3" ino=2 scontext=u:r:datadis:s0 tcontext=u:object_r:system_file:s0 tclass=dir permissive=1 [ 115.617278] type=1400 audit(1735396178.315:3217): avc: denied { read } for comm="stress_wifi_tes" name="df" dev="dm-0" ino=1437 scontext=u:r:datadis:s0 tcontext=u:object_r:system_file:s0 tclass=lnk_file permissive=1 [ 115.618231] audit: audit_lost=2610 audit_rate_limit=5 audit_backlog_limit=64 [ 115.618254] audit: rate limit exceeded [ 115.623397] type=1401 audit(1735396178.315:3218): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 115.645428] type=1401 audit(1735396178.319:3219): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 115.645927] type=1400 audit(1735396178.319:3220): avc: denied { use } for comm="df" path="/dev/null" dev="tmpfs" ino=2607 scontext=u:r:datadis:s0 tcontext=u:r:init:s0 tclass=fd permissive=1 [ 116.807475] audit: audit_lost=2641 audit_rate_limit=5 audit_backlog_limit=64 [ 116.807516] audit: rate limit exceeded [ 118.002095] audit: audit_lost=2665 audit_rate_limit=5 audit_backlog_limit=64 [ 118.002135] audit: rate limit exceeded [ 119.166403] audit: audit_lost=2677 audit_rate_limit=5 audit_backlog_limit=64 [ 119.166458] audit: rate limit exceeded [ 120.340839] type=1400 audit(1735396183.042:3337): avc: denied { read } for comm="stress_wifi_tes" path="pipe:[84205]" dev="pipefs" ino=84205 scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=fifo_file permissive=1 [ 120.342665] type=1400 audit(1735396183.042:3338): avc: denied { search } for comm="stress_wifi_tes" name="/" dev="dm-0" ino=2 scontext=u:r:datadis:s0 tcontext=u:object_r:rootfs:s0 tclass=dir permissive=1 [ 120.343063] type=1401 audit(1735396183.042:3339): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 120.343855] audit: audit_lost=2711 audit_rate_limit=5 audit_backlog_limit=64 [ 120.343939] audit: rate limit exceeded [ 120.355781] type=1401 audit(1735396183.042:3340): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 120.362122] type=1400 audit(1735396183.042:3341): avc: denied { search } for comm="df" name="/" dev="tmpfs" ino=2599 scontext=u:r:datadis:s0 tcontext=u:object_r:device:s0 tclass=dir permissive=1 [ 121.444297] audit: audit_lost=2743 audit_rate_limit=5 audit_backlog_limit=64 [ 121.444331] audit: rate limit exceeded [ 121.444817] type=1400 audit(1735396184.132:3374): avc: denied { search } for comm="stress_wifi_tes" name="/" dev="dm-3" ino=2 scontext=u:r:datadis:s0 tcontext=u:object_r:system_file:s0 tclass=dir permissive=1 [ 121.523100] type=1400 audit(1735396184.132:3375): avc: denied { read } for comm="stress_wifi_tes" name="df" dev="dm-0" ino=1437 scontext=u:r:datadis:s0 tcontext=u:object_r:system_file:s0 tclass=lnk_file permissive=1 [ 121.577659] type=1400 audit(1735396184.132:3376): avc: denied { getattr } for comm="stress_wifi_tes" path="/system/bin/toybox" dev="dm-0" ino=1727 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1 [ 121.587599] type=1400 audit(1735396184.132:3377): avc: denied { execute } for comm="stress_wifi_tes" name="toybox" dev="dm-0" ino=1727 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1 [ 121.591280] type=1400 audit(1735396184.145:3378): avc: denied { read } for comm="logd.auditd" name="status" dev="proc" ino=80574 scontext=u:r:logd:s0 tcontext=u:r:datadis:s0 tclass=file permissive=1 [ 122.642596] audit: audit_lost=2796 audit_rate_limit=5 audit_backlog_limit=64 [ 122.642652] audit: rate limit exceeded [ 123.744251] audit: audit_lost=2805 audit_rate_limit=5 audit_backlog_limit=64 [ 123.744352] audit: rate limit exceeded [ 125.047938] audit: audit_lost=2891 audit_rate_limit=5 audit_backlog_limit=64 [ 125.048052] audit: rate limit exceeded [ 125.989782] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au [ 126.269099] audit: audit_lost=2992 audit_rate_limit=5 audit_backlog_limit=64 [ 126.269207] audit: rate limit exceeded [ 126.284148] type=1400 audit(1735396188.942:3643): avc: denied { search } for comm="stress_wifi_tes" name="/" dev="dm-0" ino=2 scontext=u:r:datadis:s0 tcontext=u:object_r:rootfs:s0 tclass=dir permissive=1 [ 126.287372] type=1401 audit(1735396188.942:3644): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 126.287929] type=1400 audit(1735396188.942:3645): avc: denied { read } for comm="stress_wifi_tes" path="pipe:[85393]" dev="pipefs" ino=85393 scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=fifo_file permissive=1 [ 126.288108] type=1400 audit(1735396188.945:3646): avc: denied { search } for comm="df" name="/" dev="tmpfs" ino=2599 scontext=u:r:datadis:s0 tcontext=u:object_r:device:s0 tclass=dir permissive=1 [ 126.288248] type=1401 audit(1735396188.952:3647): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 127.432332] type=1400 audit(1735396190.132:3678): avc: denied { search } for comm="stress_wifi_tes" name="/" dev="dm-3" ino=2 scontext=u:r:datadis:s0 tcontext=u:object_r:system_file:s0 tclass=dir permissive=1 [ 127.435267] audit: audit_lost=3022 audit_rate_limit=5 audit_backlog_limit=64 [ 127.435375] audit: rate limit exceeded [ 127.446409] type=1400 audit(1735396190.132:3679): avc: denied { read } for comm="stress_wifi_tes" name="grep" dev="dm-0" ino=1482 scontext=u:r:datadis:s0 tcontext=u:object_r:system_file:s0 tclass=lnk_file permissive=1 [ 127.446781] type=1401 audit(1735396190.132:3680): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 127.455803] type=1400 audit(1735396190.135:3681): avc: denied { read } for comm="stress_wifi_tes" name="linker64" dev="dm-0" ino=1543 scontext=u:r:datadis:s0 tcontext=u:object_r:system_linker_exec:s0 tclass=lnk_file permissive=1 [ 127.464475] type=1401 audit(1735396190.135:3682): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 128.648162] audit: audit_lost=3056 audit_rate_limit=5 audit_backlog_limit=64 [ 128.648225] audit: rate limit exceeded [ 129.820706] audit: audit_lost=3070 audit_rate_limit=5 audit_backlog_limit=64 [ 129.820802] audit: rate limit exceeded [ 130.906423] audit: audit_lost=3078 audit_rate_limit=5 audit_backlog_limit=64 [ 130.906531] audit: rate limit exceeded [ 131.974887] type=1401 audit(1735396194.675:3757): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 131.977204] type=1401 audit(1735396194.679:3758): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 132.000706] type=1400 audit(1735396194.695:3759): avc: denied { getattr } for comm="df" path="/sys/fs/bpf" dev="bpf" ino=1 scontext=u:r:datadis:s0 tcontext=u:object_r:fs_bpf:s0 tclass=dir permissive=1 [ 132.002896] type=1400 audit(1735396194.695:3760): avc: denied { getattr } for comm="df" path="/dev/block/mmcblk2p11" dev="tmpfs" ino=10875 scontext=u:r:datadis:s0 tcontext=u:object_r:metadata_block_device:s0 tclass=blk_file permissive=1 [ 132.009146] type=1401 audit(1735396194.709:3761): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 132.032085] audit: audit_lost=3081 audit_rate_limit=5 audit_backlog_limit=64 [ 132.032131] audit: rate limit exceeded [ 133.055338] type=1401 audit(1735396195.755:3763): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 133.055795] type=1401 audit(1735396195.755:3764): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 133.084181] type=1400 audit(1735396195.782:3765): avc: denied { getattr } for comm="df" path="/sys/fs/pstore" dev="pstore" ino=18377 scontext=u:r:datadis:s0 tcontext=u:object_r:pstorefs:s0 tclass=dir permissive=1 [ 133.102494] type=1401 audit(1735396195.802:3766): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 133.126296] type=1401 audit(1735396195.825:3767): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 134.185773] audit: audit_lost=3082 audit_rate_limit=5 audit_backlog_limit=64 [ 134.186319] audit: rate limit exceeded [ 135.328300] audit: audit_lost=3089 audit_rate_limit=5 audit_backlog_limit=64 [ 135.331128] audit: rate limit exceeded [ 136.339211] audit: audit_lost=3111 audit_rate_limit=5 audit_backlog_limit=64 [ 136.339250] audit: rate limit exceeded [ 137.733725] type=1400 audit(1735396200.425:3978): avc: denied { fork } for comm="stress_wifi_tes" scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=process permissive=1 [ 137.734067] audit: audit_lost=3277 audit_rate_limit=5 audit_backlog_limit=64 [ 137.734093] audit: rate limit exceeded [ 137.734508] type=1400 audit(1735396200.425:3979): avc: denied { search } for comm="stress_wifi_tes" name="/" dev="dm-0" ino=2 scontext=u:r:datadis:s0 tcontext=u:object_r:rootfs:s0 tclass=dir permissive=1 [ 137.734861] type=1400 audit(1735396200.429:3980): avc: denied { search } for comm="stress_wifi_tes" name="/" dev="dm-3" ino=2 scontext=u:r:datadis:s0 tcontext=u:object_r:system_file:s0 tclass=dir permissive=1 [ 137.735026] type=1400 audit(1735396200.429:3981): avc: denied { read } for comm="stress_wifi_tes" name="df" dev="dm-0" ino=1437 scontext=u:r:datadis:s0 tcontext=u:object_r:system_file:s0 tclass=lnk_file permissive=1 [ 137.735147] type=1400 audit(1735396200.429:3982): avc: denied { read } for comm="stress_wifi_tes" path="pipe:[98373]" dev="pipefs" ino=98373 scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=fifo_file permissive=1 [ 139.010431] type=1400 audit(1735396201.709:4122): avc: denied { read } for comm="stress_wifi_tes" path="pipe:[98801]" dev="pipefs" ino=98801 scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=fifo_file permissive=1 [ 139.013068] audit: audit_lost=3416 audit_rate_limit=5 audit_backlog_limit=64 [ 139.013110] audit: rate limit exceeded [ 139.013685] type=1400 audit(1735396201.709:4123): avc: denied { search } for comm="stress_wifi_tes" name="/" dev="dm-0" ino=2 scontext=u:r:datadis:s0 tcontext=u:object_r:rootfs:s0 tclass=dir permissive=1 [ 139.014227] type=1400 audit(1735396201.712:4124): avc: denied { search } for comm="logd.auditd" name="4576" dev="proc" ino=95041 scontext=u:r:logd:s0 tcontext=u:r:datadis:s0 tclass=dir permissive=1 [ 139.014603] type=1400 audit(1735396201.712:4125): avc: denied { read } for comm="logd.auditd" name="status" dev="proc" ino=95042 scontext=u:r:logd:s0 tcontext=u:r:datadis:s0 tclass=file permissive=1 [ 139.014765] type=1400 audit(1735396201.712:4126): avc: denied { open } for comm="logd.auditd" path="/proc/4576/status" dev="proc" ino=95042 scontext=u:r:logd:s0 tcontext=u:r:datadis:s0 tclass=file permissive=1 [ 140.193144] audit: audit_lost=3465 audit_rate_limit=5 audit_backlog_limit=64 [ 140.198539] audit: rate limit exceeded [ 141.411465] audit: audit_lost=3496 audit_rate_limit=5 audit_backlog_limit=64 [ 141.411583] audit: rate limit exceeded [ 142.502739] audit: audit_lost=3502 audit_rate_limit=5 audit_backlog_limit=64 [ 142.502787] audit: rate limit exceeded [ 143.670905] type=1401 audit(1735396206.372:4237): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 143.677055] type=1401 audit(1735396206.372:4238): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 143.694941] audit: audit_lost=3511 audit_rate_limit=5 audit_backlog_limit=64 [ 143.694973] audit: rate limit exceeded [ 143.695374] type=1400 audit(1735396206.395:4239): avc: denied { read } for comm="df" name="u:object_r:vendor_socket_hook_prop:s0" dev="tmpfs" ino=2802 scontext=u:r:datadis:s0 tcontext=u:object_r:vendor_socket_hook_prop:s0 tclass=file permissive=1 [ 143.695926] type=1400 audit(1735396206.395:4240): avc: denied { open } for comm="df" path="/dev/__properties__/u:object_r:vendor_socket_hook_prop:s0" dev="tmpfs" ino=2802 scontext=u:r:datadis:s0 tcontext=u:object_r:vendor_socket_hook_prop:s0 tclass=file permissive=1 [ 143.696690] type=1400 audit(1735396206.395:4241): avc: denied { getattr } for comm="df" path="/dev/__properties__/u:object_r:vendor_socket_hook_prop:s0" dev="tmpfs" ino=2802 scontext=u:r:datadis:s0 tcontext=u:object_r:vendor_socket_hook_prop:s0 tclass=file permissive=1 [ 144.752667] type=1401 audit(1735396207.452:4249): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 144.770290] type=1401 audit(1735396207.459:4250): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 144.821867] type=1400 audit(1735396207.522:4251): avc: denied { getattr } for comm="df" name="/" dev="fusectl" ino=1 scontext=u:r:datadis:s0 tcontext=u:object_r:fusectlfs:s0 tclass=filesystem permissive=1 [ 144.823182] type=1400 audit(1735396207.522:4252): avc: denied { getattr } for comm="df" path="/data_mirror/cur_profiles" dev="mmcblk2p16" ino=66 scontext=u:r:datadis:s0 tcontext=u:object_r:user_profile_data_file:s0 tclass=dir permissive=1 [ 144.855186] audit: audit_lost=3518 audit_rate_limit=5 audit_backlog_limit=64 [ 144.855286] audit: rate limit exceeded [ 144.855376] type=1400 audit(1735396207.555:4253): avc: denied { getattr } for comm="df" path="/dev/block/mmcblk2p11" dev="tmpfs" ino=10875 scontext=u:r:datadis:s0 tcontext=u:object_r:metadata_block_device:s0 tclass=blk_file permissive=1 [ 146.192252] audit: audit_lost=3521 audit_rate_limit=5 audit_backlog_limit=64 [ 146.192285] audit: rate limit exceeded [ 147.232902] audit: audit_lost=3522 audit_rate_limit=5 audit_backlog_limit=64 [ 147.232954] audit: rate limit exceeded [ 147.250619] [dhd-wlan0] wl_run_escan : LEGACY_SCAN sync ID: 7, bssidx: 0 [ 148.449775] audit: audit_lost=3566 audit_rate_limit=5 audit_backlog_limit=64 [ 148.449909] audit: rate limit exceeded [ 149.600639] type=1400 audit(1735396212.299:4358): avc: denied { read } for comm="stress_wifi_tes" name="df" dev="dm-0" ino=1437 scontext=u:r:datadis:s0 tcontext=u:object_r:system_file:s0 tclass=lnk_file permissive=1 [ 149.610167] audit: audit_lost=3607 audit_rate_limit=5 audit_backlog_limit=64 [ 149.610647] audit: rate limit exceeded [ 149.639089] type=1400 audit(1735396212.299:4359): avc: denied { getattr } for comm="stress_wifi_tes" path="/system/bin/toybox" dev="dm-0" ino=1727 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1 [ 149.639378] type=1400 audit(1735396212.299:4360): avc: denied { execute } for comm="stress_wifi_tes" name="toybox" dev="dm-0" ino=1727 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1 [ 149.639542] type=1400 audit(1735396212.302:4361): avc: denied { read open } for comm="stress_wifi_tes" path="/system/bin/toybox" dev="dm-0" ino=1727 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1 [ 149.679216] type=1401 audit(1735396212.309:4362): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 150.818091] type=1401 audit(1735396213.519:4391): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 150.819533] audit: audit_lost=3635 audit_rate_limit=5 audit_backlog_limit=64 [ 150.819566] audit: rate limit exceeded [ 150.827118] type=1400 audit(1735396213.519:4392): avc: denied { read } for comm="df" name="properties_serial" dev="tmpfs" ino=2811 scontext=u:r:datadis:s0 tcontext=u:object_r:properties_serial:s0 tclass=file permissive=1 [ 150.836064] type=1400 audit(1735396213.519:4393): avc: denied { open } for comm="df" path="/dev/__properties__/properties_serial" dev="tmpfs" ino=2811 scontext=u:r:datadis:s0 tcontext=u:object_r:properties_serial:s0 tclass=file permissive=1 [ 150.836229] type=1401 audit(1735396213.519:4395): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 150.845428] type=1400 audit(1735396213.519:4394): avc: denied { getattr } for comm="df" path="/dev/__properties__/properties_serial" dev="tmpfs" ino=2811 scontext=u:r:datadis:s0 tcontext=u:object_r:properties_serial:s0 tclass=file permissive=1 [ 151.933452] audit: audit_lost=3642 audit_rate_limit=5 audit_backlog_limit=64 [ 151.933561] audit: rate limit exceeded [ 152.401304] WLC_E_IF: NO_IF set, event Ignored [ 152.401313] Exit. P2P interface stopped [ 152.468945] dhd_stop: Enter 00000000be517524 [ 152.479238] CFGP2P-ERROR) wl_cfgp2p_disable_discovery : [ 152.479242] do nothing, not initialized [ 152.479285] [dhd] CFG80211-ERROR) wl_cfgp2p_down : Clean up the p2p discovery IF [ 152.479296] wl_cfgp2p_del_p2p_disc_if: wdev: 000000003eb1ca48, wdev->net: (null) [ 152.523739] P2P interface unregistered [ 152.523785] CFGP2P-ERROR) wl_cfgp2p_deinit_priv : [ 152.523786] In [ 152.524152] dhd_tcpack_suppress_set: TCP ACK Suppress mode 1 -> mode 0 [ 152.524192] [dhd-wlan0] wl_android_wifi_off : in g_wifi_on=1, on_failure=1 [ 152.525614] dhd_dbg_detach_pkt_monitor, 2204 [ 152.525650] __dhd_dbg_free_tx_pkts, 1518 [ 152.525660] __dhd_dbg_free_rx_pkts, 1536 [ 152.525668] dhd_bus_devreset: == Power OFF == [ 152.525812] bcmsdh_oob_intr_unregister: Enter [ 152.525851] dhd_txglom_enable: enable 0 [ 152.525858] dhd_bus_devreset: WLAN OFF DONE [ 152.525886] wifi_platform_set_power = 0 [ 152.525894] ======== PULL WL_REG_ON(-1) LOW! ======== [ 152.525901] [WLAN_RFKILL]: rockchip_wifi_power: 0 [ 152.525921] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false [ 152.525928] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1] [ 152.525934] [dhd-wlan0] wl_android_wifi_off : out [ 152.540633] dhd_stop: Exit [ 152.569331] init: Service 'wpa_supplicant' (pid 1195) exited with status 0 oneshot service took 114.632004 seconds in background [ 152.569433] init: Sending signal 9 to service 'wpa_supplicant' (pid 1195) process group... [ 152.569921] libprocessgroup: Successfully killed process cgroup uid 0 pid 1195 in 0ms [ 152.599613] dhd_wl_ioctl: returning as busstate=0 [ 152.599678] dhd_wl_ioctl: returning as busstate=0 [ 152.599686] dhd_wl_ioctl: returning as busstate=0 [ 152.599693] dhd_wl_ioctl: returning as busstate=0 [ 152.599699] dhd_wl_ioctl: returning as busstate=0 [ 152.599705] dhd_wl_ioctl: returning as busstate=0 [ 152.599711] dhd_wl_ioctl: returning as busstate=0 [ 152.599717] dhd_wl_ioctl: returning as busstate=0 [ 152.599723] dhd_wl_ioctl: returning as busstate=0 [ 152.599729] dhd_wl_ioctl: returning as busstate=0 [ 152.599735] dhd_wl_ioctl: returning as busstate=0 [ 152.599742] dhd_wl_ioctl: returning as busstate=0 [ 152.599748] dhd_wl_ioctl: returning as busstate=0 [ 152.599757] dhd_wl_ioctl: returning as busstate=0 [ 152.599762] dhd_wl_ioctl: returning as busstate=0 [ 152.599768] dhd_wl_ioctl: returning as busstate=0 [ 152.599777] dhd_wl_ioctl: returning as busstate=0 [ 152.599783] dhd_wl_ioctl: returning as busstate=0 [ 152.599789] dhd_wl_ioctl: returning as busstate=0 [ 153.017261] audit: audit_lost=3685 audit_rate_limit=5 audit_backlog_limit=64 [ 153.017303] audit: rate limit exceeded [ 154.134841] audit: audit_lost=3781 audit_rate_limit=5 audit_backlog_limit=64 [ 154.134886] audit: rate limit exceeded [ 155.218667] type=1400 audit(1735396217.919:4586): avc: denied { search } for comm="stress_wifi_tes" name="/" dev="tmpfs" ino=18090 scontext=u:r:datadis:s0 tcontext=u:object_r:apex_mnt_dir:s0 tclass=dir permissive=1 [ 155.222006] type=1401 audit(1735396217.919:4587): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 155.224165] type=1401 audit(1735396217.919:4588): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 155.241306] type=1400 audit(1735396217.942:4589): avc: denied { getattr } for comm="df" path="/apex" dev="tmpfs" ino=18090 scontext=u:r:datadis:s0 tcontext=u:object_r:apex_mnt_dir:s0 tclass=dir permissive=1 [ 155.242084] audit: audit_lost=3810 audit_rate_limit=5 audit_backlog_limit=64 [ 155.242114] audit: rate limit exceeded [ 155.242310] type=1400 audit(1735396217.942:4590): avc: denied { getattr } for comm="df" name="/" dev="fusectl" ino=1 scontext=u:r:datadis:s0 tcontext=u:object_r:fusectlfs:s0 tclass=filesystem permissive=1 [ 156.296142] type=1401 audit(1735396218.995:4595): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 156.299612] type=1400 audit(1735396218.999:4596): avc: denied { getattr } for comm="df" path="/dev/__properties__" dev="tmpfs" ino=2639 scontext=u:r:datadis:s0 tcontext=u:object_r:properties_device:s0 tclass=dir permissive=1 [ 156.309554] type=1400 audit(1735396218.999:4597): avc: denied { search } for comm="df" name="__properties__" dev="tmpfs" ino=2639 scontext=u:r:datadis:s0 tcontext=u:object_r:properties_device:s0 tclass=dir permissive=1 [ 156.314752] type=1401 audit(1735396219.012:4598): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 156.322144] type=1400 audit(1735396219.022:4599): avc: denied { getattr } for comm="df" name="/" dev="binder" ino=1 scontext=u:r:datadis:s0 tcontext=u:object_r:binderfs:s0 tclass=filesystem permissive=1 [ 156.322739] audit: audit_lost=3814 audit_rate_limit=5 audit_backlog_limit=64 [ 156.322763] audit: rate limit exceeded [ 157.459625] audit: audit_lost=3819 audit_rate_limit=5 audit_backlog_limit=64 [ 157.459726] audit: rate limit exceeded [ 158.606339] audit: audit_lost=3831 audit_rate_limit=5 audit_backlog_limit=64 [ 158.606449] audit: rate limit exceeded [ 159.763791] audit: audit_lost=3843 audit_rate_limit=5 audit_backlog_limit=64 [ 159.763888] audit: rate limit exceeded [ 160.829589] type=1401 audit(1735396223.529:4655): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 160.830482] type=1401 audit(1735396223.532:4656): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 160.851731] type=1400 audit(1735396223.552:4657): avc: denied { getattr } for comm="df" name="/" dev="tracefs" ino=1 scontext=u:r:datadis:s0 tcontext=u:object_r:debugfs_tracing_debug:s0 tclass=filesystem permissive=1 [ 160.852220] type=1400 audit(1735396223.552:4658): avc: denied { getattr } for comm="df" name="/" dev="debugfs" ino=1 scontext=u:r:datadis:s0 tcontext=u:object_r:debugfs:s0 tclass=filesystem permissive=1 [ 160.871076] type=1401 audit(1735396223.572:4659): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 160.893326] audit: audit_lost=3854 audit_rate_limit=5 audit_backlog_limit=64 [ 160.893365] audit: rate limit exceeded [ 161.922369] type=1400 audit(1735396224.619:4685): avc: denied { fork } for comm="stress_wifi_tes" scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=process permissive=1 [ 161.922755] type=1400 audit(1735396224.622:4686): avc: denied { read } for comm="stress_wifi_tes" path="pipe:[115764]" dev="pipefs" ino=115764 scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=fifo_file permissive=1 [ 161.924559] audit: audit_lost=3879 audit_rate_limit=5 audit_backlog_limit=64 [ 161.924588] audit: rate limit exceeded [ 161.945667] type=1400 audit(1735396224.625:4687): avc: denied { search } for comm="stress_wifi_tes" name="/" dev="dm-0" ino=2 scontext=u:r:datadis:s0 tcontext=u:object_r:rootfs:s0 tclass=dir permissive=1 [ 161.946538] type=1400 audit(1735396224.625:4688): avc: denied { search } for comm="stress_wifi_tes" name="/" dev="dm-3" ino=2 scontext=u:r:datadis:s0 tcontext=u:object_r:system_file:s0 tclass=dir permissive=1 [ 161.946809] type=1400 audit(1735396224.625:4689): avc: denied { read } for comm="stress_wifi_tes" name="grep" dev="dm-0" ino=1482 scontext=u:r:datadis:s0 tcontext=u:object_r:system_file:s0 tclass=lnk_file permissive=1 [ 163.069458] audit: audit_lost=3939 audit_rate_limit=5 audit_backlog_limit=64 [ 163.069556] audit: rate limit exceeded [ 164.258915] audit: audit_lost=3959 audit_rate_limit=5 audit_backlog_limit=64 [ 164.258951] audit: rate limit exceeded [ 165.384064] audit: audit_lost=3962 audit_rate_limit=5 audit_backlog_limit=64 [ 165.384095] audit: rate limit exceeded [ 166.405037] type=1401 audit(1735396229.105:4789): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 166.413348] type=1401 audit(1735396229.105:4790): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 166.426093] type=1400 audit(1735396229.125:4791): avc: denied { getattr } for comm="df" path="/sys/fs/bpf" dev="bpf" ino=1 scontext=u:r:datadis:s0 tcontext=u:object_r:fs_bpf:s0 tclass=dir permissive=1 [ 166.426518] type=1400 audit(1735396229.125:4792): avc: denied { getattr } for comm="df" path="/sys/fs/pstore" dev="pstore" ino=18377 scontext=u:r:datadis:s0 tcontext=u:object_r:pstorefs:s0 tclass=dir permissive=1 [ 166.428975] type=1400 audit(1735396229.129:4793): avc: denied { getattr } for comm="df" path="/dev/block/mmcblk2p11" dev="tmpfs" ino=10875 scontext=u:r:datadis:s0 tcontext=u:object_r:metadata_block_device:s0 tclass=blk_file permissive=1 [ 166.439680] audit: audit_lost=3963 audit_rate_limit=5 audit_backlog_limit=64 [ 166.439714] audit: rate limit exceeded [ 167.490579] type=1401 audit(1735396230.192:4797): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 167.494407] type=1400 audit(1735396230.195:4798): avc: denied { getattr } for comm="grep" path="/dev/__properties__" dev="tmpfs" ino=2639 scontext=u:r:datadis:s0 tcontext=u:object_r:properties_device:s0 tclass=dir permissive=1 [ 167.510725] type=1400 audit(1735396230.195:4799): avc: denied { search } for comm="grep" name="__properties__" dev="tmpfs" ino=2639 scontext=u:r:datadis:s0 tcontext=u:object_r:properties_device:s0 tclass=dir permissive=1 [ 167.522745] type=1401 audit(1735396230.222:4800): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 167.546308] type=1400 audit(1735396230.245:4801): avc: denied { read } for comm="df" name="urandom" dev="tmpfs" ino=2605 scontext=u:r:datadis:s0 tcontext=u:object_r:random_device:s0 tclass=chr_file permissive=1 [ 167.567243] audit: audit_lost=3966 audit_rate_limit=5 audit_backlog_limit=64 [ 167.567296] audit: rate limit exceeded [ 168.910079] audit: audit_lost=3979 audit_rate_limit=5 audit_backlog_limit=64 [ 168.910138] audit: rate limit exceeded [ 169.947640] audit: audit_lost=3981 audit_rate_limit=5 audit_backlog_limit=64 [ 169.947797] audit: rate limit exceeded [ 171.015149] audit: audit_lost=3987 audit_rate_limit=5 audit_backlog_limit=64 [ 171.015268] audit: rate limit exceeded [ 172.073322] type=1401 audit(1735396234.772:4849): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 172.074949] type=1401 audit(1735396234.775:4850): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 172.075244] audit: audit_lost=3998 audit_rate_limit=5 audit_backlog_limit=64 [ 172.075266] audit: rate limit exceeded [ 172.075613] type=1400 audit(1735396234.775:4851): avc: denied { read write } for comm="df" name="null" dev="tmpfs" ino=2607 scontext=u:r:datadis:s0 tcontext=u:object_r:null_device:s0 tclass=chr_file permissive=1 [ 172.076223] type=1400 audit(1735396234.775:4852): avc: denied { open } for comm="df" path="/dev/null" dev="tmpfs" ino=2607 scontext=u:r:datadis:s0 tcontext=u:object_r:null_device:s0 tclass=chr_file permissive=1 [ 172.076380] type=1400 audit(1735396234.775:4853): avc: denied { search } for comm="df" name="/" dev="proc" ino=1 scontext=u:r:datadis:s0 tcontext=u:object_r:proc:s0 tclass=dir permissive=1 [ 173.150477] type=1401 audit(1735396235.849:4866): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 173.151592] type=1401 audit(1735396235.852:4867): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 173.169745] type=1400 audit(1735396235.869:4868): avc: denied { getattr } for comm="df" path="/" dev="dm-0" ino=2 scontext=u:r:datadis:s0 tcontext=u:object_r:rootfs:s0 tclass=dir permissive=1 [ 173.171359] type=1400 audit(1735396235.869:4869): avc: denied { search } for comm="df" name="/" dev="tmpfs" ino=2608 scontext=u:r:datadis:s0 tcontext=u:object_r:tmpfs:s0 tclass=dir permissive=1 [ 173.171545] type=1400 audit(1735396235.869:4870): avc: denied { search } for comm="df" name="/" dev="tmpfs" ino=2599 scontext=u:r:datadis:s0 tcontext=u:object_r:device:s0 tclass=dir permissive=1 [ 173.181613] audit: audit_lost=4010 audit_rate_limit=5 audit_backlog_limit=64 [ 173.181668] audit: rate limit exceeded [ 174.237534] audit: audit_lost=4012 audit_rate_limit=5 audit_backlog_limit=64 [ 174.237566] audit: rate limit exceeded [ 177.412854] type=1401 audit(1735396240.112:4897): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 177.413372] type=1401 audit(1735396240.112:4898): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 177.427799] type=1400 audit(1735396240.129:4899): avc: denied { getattr } for comm="df" name="/" dev="proc" ino=1 scontext=u:r:datadis:s0 tcontext=u:object_r:proc:s0 tclass=filesystem permissive=1 [ 177.428126] type=1400 audit(1735396240.129:4900): avc: denied { getattr } for comm="df" path="/sys" dev="sysfs" ino=1 scontext=u:r:datadis:s0 tcontext=u:object_r:sysfs:s0 tclass=dir permissive=1 [ 177.428305] type=1400 audit(1735396240.129:4901): avc: denied { search } for comm="df" name="/" dev="sysfs" ino=1 scontext=u:r:datadis:s0 tcontext=u:object_r:sysfs:s0 tclass=dir permissive=1 [ 177.428449] type=1400 audit(1735396240.129:4902): avc: denied { getattr } for comm="df" path="/sys/fs/selinux" dev="selinuxfs" ino=1 scontext=u:r:datadis:s0 tcontext=u:object_r:selinuxfs:s0 tclass=dir permissive=1 [ 177.428457] audit: audit_lost=4022 audit_rate_limit=5 audit_backlog_limit=64 [ 177.428483] audit: rate limit exceeded [ 178.476460] audit: audit_lost=4058 audit_rate_limit=5 audit_backlog_limit=64 [ 178.476551] audit: rate limit exceeded [ 178.477511] type=1400 audit(1735396241.175:4939): avc: denied { read } for comm="stress_wifi_tes" name="df" dev="dm-0" ino=1437 scontext=u:r:datadis:s0 tcontext=u:object_r:system_file:s0 tclass=lnk_file permissive=1 [ 178.477885] type=1400 audit(1735396241.175:4940): avc: denied { getattr } for comm="stress_wifi_tes" path="/system/bin/toybox" dev="dm-0" ino=1727 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1 [ 178.478082] type=1400 audit(1735396241.175:4941): avc: denied { execute } for comm="stress_wifi_tes" name="toybox" dev="dm-0" ino=1727 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1 [ 178.478217] type=1400 audit(1735396241.175:4942): avc: denied { read open } for comm="stress_wifi_tes" path="/system/bin/toybox" dev="dm-0" ino=1727 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1 [ 179.596104] audit: audit_lost=4121 audit_rate_limit=5 audit_backlog_limit=64 [ 179.596143] audit: rate limit exceeded [ 180.640057] audit: audit_lost=4124 audit_rate_limit=5 audit_backlog_limit=64 [ 180.640091] audit: rate limit exceeded [ 181.701880] audit: audit_lost=4133 audit_rate_limit=5 audit_backlog_limit=64 [ 181.701930] audit: rate limit exceeded [ 182.766872] type=1401 audit(1735396245.465:5076): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 182.767717] type=1401 audit(1735396245.469:5077): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 182.778355] audit: audit_lost=4175 audit_rate_limit=5 audit_backlog_limit=64 [ 182.778386] audit: rate limit exceeded [ 182.778839] type=1400 audit(1735396245.479:5078): avc: denied { read } for comm="df" name="u:object_r:heapprofd_prop:s0" dev="tmpfs" ino=2733 scontext=u:r:datadis:s0 tcontext=u:object_r:heapprofd_prop:s0 tclass=file permissive=1 [ 182.779552] type=1400 audit(1735396245.479:5079): avc: denied { read } for comm="grep" name="u:object_r:heapprofd_prop:s0" dev="tmpfs" ino=2733 scontext=u:r:datadis:s0 tcontext=u:object_r:heapprofd_prop:s0 tclass=file permissive=1 [ 182.779815] type=1400 audit(1735396245.479:5081): avc: denied { open } for comm="grep" path="/dev/__properties__/u:object_r:heapprofd_prop:s0" dev="tmpfs" ino=2733 scontext=u:r:datadis:s0 tcontext=u:object_r:heapprofd_prop:s0 tclass=file permissive=1 [ 183.829680] type=1400 audit(1735396246.525:5091): avc: denied { fork } for comm="stress_wifi_tes" scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=process permissive=1 [ 183.831918] type=1401 audit(1735396246.529:5092): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 183.839260] type=1400 audit(1735396246.532:5093): avc: denied { getsched } for comm="grep" scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=process permissive=1 [ 183.852370] audit: audit_lost=4185 audit_rate_limit=5 audit_backlog_limit=64 [ 183.852508] audit: rate limit exceeded [ 183.855458] type=1401 audit(1735396246.532:5094): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 183.870523] type=1400 audit(1735396246.549:5095): avc: denied { search } for comm="df" name="/" dev="sysfs" ino=1 scontext=u:r:datadis:s0 tcontext=u:object_r:sysfs:s0 tclass=dir permissive=1 [ 184.931897] audit: audit_lost=4193 audit_rate_limit=5 audit_backlog_limit=64 [ 184.932011] audit: rate limit exceeded [ 185.992431] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au [ 186.004459] audit: audit_lost=4229 audit_rate_limit=5 audit_backlog_limit=64 [ 186.004505] audit: rate limit exceeded [ 187.136413] audit: audit_lost=4246 audit_rate_limit=5 audit_backlog_limit=64 [ 187.136464] audit: rate limit exceeded [ 188.205585] type=1401 audit(1735396250.905:5176): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 188.214895] type=1401 audit(1735396250.912:5177): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 188.240561] type=1400 audit(1735396250.935:5178): avc: denied { getattr } for comm="df" path="/dev/block/dm-0" dev="tmpfs" ino=10885 scontext=u:r:datadis:s0 tcontext=u:object_r:dm_device:s0 tclass=blk_file permissive=1 [ 188.250398] type=1401 audit(1735396250.949:5179): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 188.274045] type=1401 audit(1735396250.972:5180): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 189.303719] type=1401 audit(1735396252.002:5181): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 189.306943] type=1401 audit(1735396252.005:5182): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 189.349257] type=1400 audit(1735396252.049:5183): avc: denied { getattr } for comm="df" path="/sys/fs/bpf" dev="bpf" ino=1 scontext=u:r:datadis:s0 tcontext=u:object_r:fs_bpf:s0 tclass=dir permissive=1 [ 189.350717] type=1400 audit(1735396252.049:5184): avc: denied { getattr } for comm="df" path="/sys/fs/pstore" dev="pstore" ino=18377 scontext=u:r:datadis:s0 tcontext=u:object_r:pstorefs:s0 tclass=dir permissive=1 [ 189.355987] type=1400 audit(1735396252.052:5185): avc: denied { getattr } for comm="df" path="/dev/block/mmcblk2p11" dev="tmpfs" ino=10875 scontext=u:r:datadis:s0 tcontext=u:object_r:metadata_block_device:s0 tclass=blk_file permissive=1 [ 189.365377] audit: audit_lost=4250 audit_rate_limit=5 audit_backlog_limit=64 [ 189.365512] audit: rate limit exceeded [ 191.990876] audit: audit_lost=4252 audit_rate_limit=5 audit_backlog_limit=64 [ 191.990912] audit: rate limit exceeded [ 193.046756] audit: audit_lost=4324 audit_rate_limit=5 audit_backlog_limit=64 [ 193.048336] audit: rate limit exceeded [ 193.870761] type=1400 audit(1735396256.572:5276): avc: denied { fork } for comm="stress_wifi_tes" scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=process permissive=1 [ 193.872131] type=1400 audit(1735396256.572:5277): avc: denied { search } for comm="stress_wifi_tes" name="/" dev="dm-3" ino=2 scontext=u:r:datadis:s0 tcontext=u:object_r:system_file:s0 tclass=dir permissive=1 [ 193.872692] type=1401 audit(1735396256.572:5278): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 193.873912] type=1400 audit(1735396256.572:5279): avc: denied { read } for comm="stress_wifi_tes" name="linker64" dev="dm-0" ino=1543 scontext=u:r:datadis:s0 tcontext=u:object_r:system_linker_exec:s0 tclass=lnk_file permissive=1 [ 193.874192] type=1400 audit(1735396256.572:5280): avc: denied { search } for comm="df" name="/" dev="tmpfs" ino=2599 scontext=u:r:datadis:s0 tcontext=u:object_r:device:s0 tclass=dir permissive=1 [ 194.959770] type=1400 audit(1735396257.659:5325): avc: denied { getattr } for comm="stress_wifi_tes" path="/system/bin/toybox" dev="dm-0" ino=1727 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1 [ 194.960570] audit: audit_lost=4369 audit_rate_limit=5 audit_backlog_limit=64 [ 194.960612] audit: rate limit exceeded [ 194.962107] type=1400 audit(1735396257.659:5326): avc: denied { read } for comm="logd.auditd" name="status" dev="proc" ino=124036 scontext=u:r:logd:s0 tcontext=u:r:datadis:s0 tclass=file permissive=1 [ 194.962942] type=1400 audit(1735396257.659:5327): avc: denied { open } for comm="logd.auditd" path="/proc/5083/status" dev="proc" ino=124036 scontext=u:r:logd:s0 tcontext=u:r:datadis:s0 tclass=file permissive=1 [ 194.965253] type=1400 audit(1735396257.659:5328): avc: denied { getattr } for comm="logd.auditd" path="/proc/5083/status" dev="proc" ino=124036 scontext=u:r:logd:s0 tcontext=u:r:datadis:s0 tclass=file permissive=1 [ 194.967298] type=1400 audit(1735396257.662:5329): avc: denied { execute } for comm="stress_wifi_tes" name="toybox" dev="dm-0" ino=1727 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1 [ 196.147274] audit: audit_lost=4393 audit_rate_limit=5 audit_backlog_limit=64 [ 196.147314] audit: rate limit exceeded [ 197.249321] audit: audit_lost=4405 audit_rate_limit=5 audit_backlog_limit=64 [ 197.249352] audit: rate limit exceeded [ 198.225161] init: processing action (logd.logpersistd=clear && logd.logpersistd.enable=true) from (/system/etc/init/logcatd.rc:38) [ 198.244990] init: starting service 'exec 16 (/system/bin/logcat -c -f /data/misc/logd/logcat -n 256)'... [ 198.261735] init: SVC_EXEC service 'exec 16 (/system/bin/logcat -c -f /data/misc/logd/logcat -n 256)' pid 5111 (uid 1036 gid 1007+0 context default) started; waiting... [ 198.298868] audit: audit_lost=4407 audit_rate_limit=5 audit_backlog_limit=64 [ 198.298964] audit: rate limit exceeded [ 198.372225] init: Service 'exec 16 (/system/bin/logcat -c -f /data/misc/logd/logcat -n 256)' (pid 5111) exited with status 0 waiting took 0.111000 seconds [ 198.372312] init: Sending signal 9 to service 'exec 16 (/system/bin/logcat -c -f /data/misc/logd/logcat -n 256)' (pid 5111) process group... [ 198.372651] libprocessgroup: Successfully killed process cgroup uid 1036 pid 5111 in 0ms [ 199.475075] audit: audit_lost=4713 audit_rate_limit=5 audit_backlog_limit=64 [ 199.475113] audit: rate limit exceeded [ 199.475705] type=1400 audit(1735396262.175:5688): avc: denied { search } for comm="stress_wifi_tes" name="/" dev="dm-0" ino=2 scontext=u:r:datadis:s0 tcontext=u:object_r:rootfs:s0 tclass=dir permissive=1 [ 199.476352] type=1400 audit(1735396262.175:5689): avc: denied { search } for comm="stress_wifi_tes" name="/" dev="tmpfs" ino=18090 scontext=u:r:datadis:s0 tcontext=u:object_r:apex_mnt_dir:s0 tclass=dir permissive=1 [ 199.476600] type=1400 audit(1735396262.175:5690): avc: denied { read } for comm="stress_wifi_tes" path="pipe:[124204]" dev="pipefs" ino=124204 scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=fifo_file permissive=1 [ 199.476783] type=1401 audit(1735396262.175:5691): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 199.477908] type=1400 audit(1735396262.175:5692): avc: denied { search } for comm="logd.auditd" name="5119" dev="proc" ino=125314 scontext=u:r:logd:s0 tcontext=u:r:datadis:s0 tclass=dir permissive=1 [ 200.539376] type=1400 audit(1735396263.239:5799): avc: denied { fork } for comm="stress_wifi_tes" scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=process permissive=1 [ 200.539629] type=1401 audit(1735396263.239:5800): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 200.543489] audit: audit_lost=4818 audit_rate_limit=5 audit_backlog_limit=64 [ 200.543583] audit: rate limit exceeded [ 200.545997] type=1400 audit(1735396263.239:5801): avc: denied { read } for comm="stress_wifi_tes" name="linker64" dev="dm-0" ino=1543 scontext=u:r:datadis:s0 tcontext=u:object_r:system_linker_exec:s0 tclass=lnk_file permissive=1 [ 200.550734] type=1401 audit(1735396263.242:5802): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 200.551179] type=1400 audit(1735396263.242:5803): avc: denied { getsched } for comm="df" scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=process permissive=1 [ 201.662105] audit: audit_lost=4832 audit_rate_limit=5 audit_backlog_limit=64 [ 201.662151] audit: rate limit exceeded [ 202.754295] audit: audit_lost=4836 audit_rate_limit=5 audit_backlog_limit=64 [ 202.754344] audit: rate limit exceeded [ 203.841662] audit: audit_lost=4838 audit_rate_limit=5 audit_backlog_limit=64 [ 203.841701] audit: rate limit exceeded [ 204.861291] type=1401 audit(1735396267.562:5840): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 204.861800] type=1401 audit(1735396267.562:5841): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 204.886193] type=1401 audit(1735396267.585:5842): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 204.902895] type=1401 audit(1735396267.602:5843): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 205.922038] audit: audit_lost=4839 audit_rate_limit=5 audit_backlog_limit=64 [ 205.922252] audit: rate limit exceeded [ 205.922798] type=1400 audit(1735396268.622:5845): avc: denied { getattr } for comm="stress_wifi_tes" path="/system/bin/toybox" dev="dm-0" ino=1727 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1 [ 205.927880] type=1400 audit(1735396268.622:5844): avc: denied { getattr } for comm="stress_wifi_tes" path="/system/bin/toybox" dev="dm-0" ino=1727 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1 [ 205.929767] type=1400 audit(1735396268.622:5846): avc: denied { execute } for comm="stress_wifi_tes" name="toybox" dev="dm-0" ino=1727 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1 [ 205.930100] type=1400 audit(1735396268.622:5847): avc: denied { read open } for comm="stress_wifi_tes" path="/system/bin/toybox" dev="dm-0" ino=1727 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1 [ 205.930553] type=1401 audit(1735396268.622:5848): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 205.931108] type=1400 audit(1735396268.622:5849): avc: denied { execute_no_trans } for comm="stress_wifi_tes" path="/system/bin/toybox" dev="dm-0" ino=1727 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1 [ 207.049728] audit: audit_lost=4891 audit_rate_limit=5 audit_backlog_limit=64 [ 207.049769] audit: rate limit exceeded [ 208.165409] audit: audit_lost=4916 audit_rate_limit=5 audit_backlog_limit=64 [ 208.165454] audit: rate limit exceeded [ 210.281019] type=1400 audit(1735396272.982:5977): avc: denied { fork } for comm="stress_wifi_tes" scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=process permissive=1 [ 210.282952] type=1400 audit(1735396272.982:5978): avc: denied { search } for comm="stress_wifi_tes" name="/" dev="dm-0" ino=2 scontext=u:r:datadis:s0 tcontext=u:object_r:rootfs:s0 tclass=dir permissive=1 [ 210.284478] audit: audit_lost=4952 audit_rate_limit=5 audit_backlog_limit=64 [ 210.284517] audit: rate limit exceeded [ 210.291467] type=1400 audit(1735396272.982:5979): avc: denied { read } for comm="stress_wifi_tes" path="pipe:[126248]" dev="pipefs" ino=126248 scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=fifo_file permissive=1 [ 210.291686] type=1401 audit(1735396272.982:5980): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 210.292396] type=1400 audit(1735396272.982:5981): avc: denied { read } for comm="stress_wifi_tes" name="linker64" dev="dm-0" ino=1543 scontext=u:r:datadis:s0 tcontext=u:object_r:system_linker_exec:s0 tclass=lnk_file permissive=1 [ 210.300617] type=1401 audit(1735396272.982:5982): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 211.358337] audit: audit_lost=4992 audit_rate_limit=5 audit_backlog_limit=64 [ 211.358381] audit: rate limit exceeded [ 211.358968] type=1400 audit(1735396274.055:6024): avc: denied { read } for comm="stress_wifi_tes" name="grep" dev="dm-0" ino=1482 scontext=u:r:datadis:s0 tcontext=u:object_r:system_file:s0 tclass=lnk_file permissive=1 [ 211.359779] type=1400 audit(1735396274.055:6023): avc: denied { read } for comm="stress_wifi_tes" name="df" dev="dm-0" ino=1437 scontext=u:r:datadis:s0 tcontext=u:object_r:system_file:s0 tclass=lnk_file permissive=1 [ 211.360046] type=1401 audit(1735396274.059:6025): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 211.361093] type=1401 audit(1735396274.059:6026): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 212.429579] audit: audit_lost=5009 audit_rate_limit=5 audit_backlog_limit=64 [ 212.429956] audit: rate limit exceeded [ 213.496957] audit: audit_lost=5041 audit_rate_limit=5 audit_backlog_limit=64 [ 213.496990] audit: rate limit exceeded [ 214.003306] init: Service 'preinstall' (pid 1080) exited with status 0 oneshot service took 177.358002 seconds in background [ 214.003459] init: Sending signal 9 to service 'preinstall' (pid 1080) process group... [ 214.003952] libprocessgroup: Successfully killed process cgroup uid 0 pid 1080 in 0ms [ 214.579118] audit: audit_lost=5080 audit_rate_limit=5 audit_backlog_limit=64 [ 214.579158] audit: rate limit exceeded [ 215.624117] type=1401 audit(1735396278.325:6142): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 215.624605] type=1401 audit(1735396278.325:6143): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 215.641884] type=1400 audit(1735396278.342:6144): avc: denied { getattr } for comm="df" path="/dev/blkio" dev="cgroup" ino=1 scontext=u:r:datadis:s0 tcontext=u:object_r:cgroup:s0 tclass=dir permissive=1 [ 215.642221] type=1400 audit(1735396278.342:6145): avc: denied { getattr } for comm="df" path="/sys/fs/cgroup" dev="cgroup2" ino=1 scontext=u:r:datadis:s0 tcontext=u:object_r:cgroup_bpf:s0 tclass=dir permissive=1 [ 215.642343] type=1400 audit(1735396278.342:6146): avc: denied { search } for comm="logd.auditd" name="5329" dev="proc" ino=128085 scontext=u:r:logd:s0 tcontext=u:r:datadis:s0 tclass=dir permissive=1 [ 215.648846] audit: audit_lost=5091 audit_rate_limit=5 audit_backlog_limit=64 [ 215.648883] audit: rate limit exceeded [ 216.680831] type=1401 audit(1735396279.382:6149): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 216.681478] type=1400 audit(1735396279.382:6150): avc: denied { execute } for comm="stress_wifi_tes" name="linker64" dev="dm-0" ino=500 scontext=u:r:datadis:s0 tcontext=u:object_r:system_linker_exec:s0 tclass=file permissive=1 [ 216.681775] type=1400 audit(1735396279.382:6151): avc: denied { read open } for comm="stress_wifi_tes" path="/apex/com.android.runtime/bin/linker64" dev="dm-0" ino=500 scontext=u:r:datadis:s0 tcontext=u:object_r:system_linker_exec:s0 tclass=file permissive=1 [ 216.681901] type=1401 audit(1735396279.382:6152): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 216.682145] type=1400 audit(1735396279.382:6153): avc: denied { map } for comm="df" path="/apex/com.android.runtime/bin/linker64" dev="dm-0" ino=500 scontext=u:r:datadis:s0 tcontext=u:object_r:system_linker_exec:s0 tclass=file permissive=1 [ 216.682230] audit: audit_lost=5093 audit_rate_limit=5 audit_backlog_limit=64 [ 216.682240] audit: rate limit exceeded [ 217.755221] audit: audit_lost=5113 audit_rate_limit=5 audit_backlog_limit=64 [ 217.755262] audit: rate limit exceeded [ 218.827059] audit: audit_lost=5124 audit_rate_limit=5 audit_backlog_limit=64 [ 218.827092] audit: rate limit exceeded [ 220.924539] type=1401 audit(1735396283.625:6208): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 220.925033] type=1401 audit(1735396283.625:6209): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 220.949387] type=1401 audit(1735396283.649:6210): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 220.964535] type=1401 audit(1735396283.665:6211): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 221.981090] type=1401 audit(1735396284.682:6212): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 221.982548] type=1401 audit(1735396284.682:6213): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 221.995029] type=1400 audit(1735396284.695:6214): avc: denied { read } for comm="df" name="u:object_r:heapprofd_prop:s0" dev="tmpfs" ino=2733 scontext=u:r:datadis:s0 tcontext=u:object_r:heapprofd_prop:s0 tclass=file permissive=1 [ 221.995436] type=1400 audit(1735396284.695:6215): avc: denied { open } for comm="df" path="/dev/__properties__/u:object_r:heapprofd_prop:s0" dev="tmpfs" ino=2733 scontext=u:r:datadis:s0 tcontext=u:object_r:heapprofd_prop:s0 tclass=file permissive=1 [ 221.995615] type=1400 audit(1735396284.695:6216): avc: denied { getattr } for comm="df" path="/dev/__properties__/u:object_r:heapprofd_prop:s0" dev="tmpfs" ino=2733 scontext=u:r:datadis:s0 tcontext=u:object_r:heapprofd_prop:s0 tclass=file permissive=1 [ 221.995768] type=1400 audit(1735396284.695:6217): avc: denied { map } for comm="df" path="/dev/__properties__/u:object_r:heapprofd_prop:s0" dev="tmpfs" ino=2733 scontext=u:r:datadis:s0 tcontext=u:object_r:heapprofd_prop:s0 tclass=file permissive=1 [ 221.999045] audit: audit_lost=5133 audit_rate_limit=5 audit_backlog_limit=64 [ 221.999071] audit: rate limit exceeded [ 224.135148] audit: audit_lost=5137 audit_rate_limit=5 audit_backlog_limit=64 [ 224.135181] audit: rate limit exceeded [ 226.212206] type=1401 audit(1735396288.912:6238): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 226.212737] type=1401 audit(1735396288.912:6239): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 226.238779] type=1401 audit(1735396288.939:6240): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 226.254419] type=1401 audit(1735396288.955:6241): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 227.270802] type=1401 audit(1735396289.972:6242): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 227.271271] type=1401 audit(1735396289.972:6243): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 227.295682] type=1401 audit(1735396289.995:6244): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 227.311204] type=1401 audit(1735396290.012:6245): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 228.326373] type=1400 audit(1735396291.025:6246): avc: denied { fork } for comm="stress_wifi_tes" scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=process permissive=1 [ 228.327467] type=1401 audit(1735396291.029:6247): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 228.343769] audit: audit_lost=5138 audit_rate_limit=5 audit_backlog_limit=64 [ 228.343803] audit: rate limit exceeded [ 231.507963] type=1401 audit(1735396294.209:6269): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 231.508474] type=1401 audit(1735396294.209:6270): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 231.530836] type=1401 audit(1735396294.232:6271): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 231.545906] type=1401 audit(1735396294.245:6272): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 232.561910] type=1401 audit(1735396295.262:6273): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 232.562371] type=1401 audit(1735396295.262:6274): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 232.586644] type=1401 audit(1735396295.285:6275): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 232.601825] type=1401 audit(1735396295.302:6276): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 233.618090] type=1401 audit(1735396296.319:6277): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 233.618650] type=1401 audit(1735396296.319:6278): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 236.791506] type=1401 audit(1735396299.492:6289): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 236.792240] type=1401 audit(1735396299.492:6290): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 236.816206] type=1401 audit(1735396299.515:6291): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 236.832551] type=1401 audit(1735396299.532:6292): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 237.850388] type=1401 audit(1735396300.549:6293): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 237.850808] type=1401 audit(1735396300.552:6294): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 237.872878] type=1401 audit(1735396300.572:6295): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 237.887948] type=1401 audit(1735396300.589:6296): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 238.904820] type=1401 audit(1735396301.605:6297): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 238.906057] type=1401 audit(1735396301.605:6298): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 242.076794] type=1401 audit(1735396304.775:6309): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 242.077276] type=1401 audit(1735396304.775:6310): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 242.101651] type=1401 audit(1735396304.802:6311): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 242.117131] type=1401 audit(1735396304.819:6312): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 243.133922] type=1401 audit(1735396305.832:6313): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 243.134753] type=1401 audit(1735396305.835:6314): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 243.159419] type=1401 audit(1735396305.859:6315): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 243.174791] type=1401 audit(1735396305.875:6316): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 244.191517] type=1401 audit(1735396306.892:6317): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 244.192058] type=1401 audit(1735396306.892:6318): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 245.251613] audit: audit_lost=5143 audit_rate_limit=5 audit_backlog_limit=64 [ 245.251657] audit: rate limit exceeded [ 245.989818] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au [ 246.308860] audit: audit_lost=5151 audit_rate_limit=5 audit_backlog_limit=64 [ 246.308903] audit: rate limit exceeded [ 247.362237] type=1401 audit(1735396310.062:6350): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 247.362720] type=1401 audit(1735396310.062:6351): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 247.387347] type=1401 audit(1735396310.089:6352): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 247.403427] type=1401 audit(1735396310.102:6353): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 248.419251] type=1401 audit(1735396311.119:6354): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 248.419918] type=1401 audit(1735396311.119:6355): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 248.445406] type=1401 audit(1735396311.145:6356): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 248.461291] type=1401 audit(1735396311.162:6357): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 249.478174] type=1401 audit(1735396312.179:6358): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 249.479384] type=1401 audit(1735396312.179:6359): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 252.654497] type=1401 audit(1735396315.355:6370): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 252.655348] type=1401 audit(1735396315.355:6371): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 252.655990] audit: audit_lost=5159 audit_rate_limit=5 audit_backlog_limit=64 [ 252.656020] audit: rate limit exceeded [ 252.656516] type=1400 audit(1735396315.355:6372): avc: denied { read } for comm="df" name="u:object_r:exported2_default_prop:s0" dev="tmpfs" ino=2701 scontext=u:r:datadis:s0 tcontext=u:object_r:exported2_default_prop:s0 tclass=file permissive=1 [ 252.657027] type=1400 audit(1735396315.355:6373): avc: denied { open } for comm="df" path="/dev/__properties__/u:object_r:exported2_default_prop:s0" dev="tmpfs" ino=2701 scontext=u:r:datadis:s0 tcontext=u:object_r:exported2_default_prop:s0 tclass=file permissive=1 [ 252.657204] type=1400 audit(1735396315.355:6374): avc: denied { getattr } for comm="df" path="/dev/__properties__/u:object_r:exported2_default_prop:s0" dev="tmpfs" ino=2701 scontext=u:r:datadis:s0 tcontext=u:object_r:exported2_default_prop:s0 tclass=file permissive=1 [ 253.716435] type=1401 audit(1735396316.415:6389): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 253.716981] type=1401 audit(1735396316.415:6390): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 253.741480] type=1401 audit(1735396316.442:6391): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 253.757375] type=1401 audit(1735396316.459:6392): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 254.774453] type=1401 audit(1735396317.475:6393): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 257.949827] type=1401 audit(1735396320.649:6405): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 257.950471] type=1401 audit(1735396320.649:6406): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 257.952105] type=1400 audit(1735396320.652:6407): avc: denied { read } for comm="df" name="properties_serial" dev="tmpfs" ino=2811 scontext=u:r:datadis:s0 tcontext=u:object_r:properties_serial:s0 tclass=file permissive=1 [ 257.952754] type=1400 audit(1735396320.652:6408): avc: denied { open } for comm="df" path="/dev/__properties__/properties_serial" dev="tmpfs" ino=2811 scontext=u:r:datadis:s0 tcontext=u:object_r:properties_serial:s0 tclass=file permissive=1 [ 257.952922] type=1400 audit(1735396320.652:6409): avc: denied { getattr } for comm="df" path="/dev/__properties__/properties_serial" dev="tmpfs" ino=2811 scontext=u:r:datadis:s0 tcontext=u:object_r:properties_serial:s0 tclass=file permissive=1 [ 257.953041] type=1400 audit(1735396320.652:6410): avc: denied { map } for comm="df" path="/dev/__properties__/properties_serial" dev="tmpfs" ino=2811 scontext=u:r:datadis:s0 tcontext=u:object_r:properties_serial:s0 tclass=file permissive=1 [ 257.967146] type=1400 audit(1735396320.669:6411): avc: denied { getattr } for comm="df" name="/" dev="functionfs" ino=19125 scontext=u:r:datadis:s0 tcontext=u:object_r:functionfs:s0 tclass=filesystem permissive=1 [ 257.975393] type=1401 audit(1735396320.675:6412): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 257.991554] type=1401 audit(1735396320.692:6413): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 259.007986] type=1401 audit(1735396321.709:6414): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 261.138486] audit: audit_lost=5173 audit_rate_limit=5 audit_backlog_limit=64 [ 261.138524] audit: rate limit exceeded [ 262.253307] audit: audit_lost=5185 audit_rate_limit=5 audit_backlog_limit=64 [ 262.253339] audit: rate limit exceeded [ 263.279154] type=1401 audit(1735396325.975:6448): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 263.280079] type=1401 audit(1735396325.979:6449): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 263.299754] type=1400 audit(1735396325.999:6450): avc: denied { getattr } for comm="df" name="/" dev="fusectl" ino=1 scontext=u:r:datadis:s0 tcontext=u:object_r:fusectlfs:s0 tclass=filesystem permissive=1 [ 263.301283] type=1400 audit(1735396326.002:6451): avc: denied { getattr } for comm="df" path="/data_mirror/cur_profiles" dev="mmcblk2p16" ino=66 scontext=u:r:datadis:s0 tcontext=u:object_r:user_profile_data_file:s0 tclass=dir permissive=1 [ 263.305491] type=1400 audit(1735396326.002:6452): avc: denied { getattr } for comm="df" path="/dev/block/dm-0" dev="tmpfs" ino=10885 scontext=u:r:datadis:s0 tcontext=u:object_r:dm_device:s0 tclass=blk_file permissive=1 [ 263.317506] audit: audit_lost=5187 audit_rate_limit=5 audit_backlog_limit=64 [ 263.317546] audit: rate limit exceeded [ 264.361477] type=1400 audit(1735396327.062:6455): avc: denied { search } for comm="stress_wifi_tes" name="/" dev="tmpfs" ino=18090 scontext=u:r:datadis:s0 tcontext=u:object_r:apex_mnt_dir:s0 tclass=dir permissive=1 [ 264.363603] type=1401 audit(1735396327.062:6456): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 264.364241] type=1401 audit(1735396327.062:6457): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 264.383697] type=1400 audit(1735396327.082:6458): avc: denied { getattr } for comm="df" path="/apex" dev="tmpfs" ino=18090 scontext=u:r:datadis:s0 tcontext=u:object_r:apex_mnt_dir:s0 tclass=dir permissive=1 [ 264.384407] audit: audit_lost=5189 audit_rate_limit=5 audit_backlog_limit=64 [ 264.384417] type=1400 audit(1735396327.085:6459): avc: denied { getattr } for comm="df" name="/" dev="binder" ino=1 scontext=u:r:datadis:s0 tcontext=u:object_r:binderfs:s0 tclass=filesystem permissive=1 [ 264.384426] audit: rate limit exceeded [ 265.438033] audit: audit_lost=5195 audit_rate_limit=5 audit_backlog_limit=64 [ 265.438082] audit: rate limit exceeded [ 266.532374] audit: audit_lost=5248 audit_rate_limit=5 audit_backlog_limit=64 [ 266.532470] audit: rate limit exceeded [ 267.629549] audit: audit_lost=5262 audit_rate_limit=5 audit_backlog_limit=64 [ 267.629680] audit: rate limit exceeded [ 268.679794] type=1401 audit(1735396331.379:6555): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 268.680552] type=1401 audit(1735396331.382:6556): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 268.695323] type=1400 audit(1735396331.395:6557): avc: denied { getattr } for comm="df" path="/dev/pts" dev="devpts" ino=1 scontext=u:r:datadis:s0 tcontext=u:object_r:devpts:s0 tclass=dir permissive=1 [ 268.704471] type=1401 audit(1735396331.405:6558): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 268.722551] type=1401 audit(1735396331.422:6559): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 269.743821] type=1401 audit(1735396332.445:6561): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 269.744398] type=1401 audit(1735396332.445:6560): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 269.757598] type=1400 audit(1735396332.445:6562): avc: denied { read } for comm="stress_wifi_tes" name="linker64" dev="dm-0" ino=1543 scontext=u:r:datadis:s0 tcontext=u:object_r:system_linker_exec:s0 tclass=lnk_file permissive=1 [ 269.763008] type=1400 audit(1735396332.462:6563): avc: denied { dac_read_search } for comm="df" capability=2 scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=capability permissive=1 [ 269.770826] type=1401 audit(1735396332.472:6564): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 269.790722] audit: audit_lost=5269 audit_rate_limit=5 audit_backlog_limit=64 [ 269.790754] audit: rate limit exceeded [ 274.046548] type=1400 audit(1735396336.745:6578): avc: denied { search } for comm="stress_wifi_tes" name="/" dev="dm-3" ino=2 scontext=u:r:datadis:s0 tcontext=u:object_r:system_file:s0 tclass=dir permissive=1 [ 274.048404] type=1401 audit(1735396336.745:6579): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 274.051243] type=1401 audit(1735396336.752:6580): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 274.051861] type=1400 audit(1735396336.752:6581): avc: denied { read } for comm="df" name="bin" dev="dm-0" ino=1362 scontext=u:r:datadis:s0 tcontext=u:object_r:system_file:s0 tclass=dir permissive=1 [ 274.052260] type=1400 audit(1735396336.752:6582): avc: denied { getattr } for comm="df" path="/system/bin" dev="dm-0" ino=1362 scontext=u:r:datadis:s0 tcontext=u:object_r:system_file:s0 tclass=dir permissive=1 [ 274.053183] type=1400 audit(1735396336.752:6583): avc: denied { search } for comm="df" name="lib64" dev="dm-3" ino=99 scontext=u:r:datadis:s0 tcontext=u:object_r:system_lib_file:s0 tclass=dir permissive=1 [ 274.054132] type=1400 audit(1735396336.755:6584): avc: denied { getattr } for comm="df" path="/apex/com.android.runtime/lib64" dev="dm-0" ino=517 scontext=u:r:datadis:s0 tcontext=u:object_r:system_lib_file:s0 tclass=dir permissive=1 [ 274.068725] type=1400 audit(1735396336.769:6585): avc: denied { getattr } for comm="df" path="/dev/block/mmcblk2p16" dev="tmpfs" ino=2909 scontext=u:r:datadis:s0 tcontext=u:object_r:userdata_block_device:s0 tclass=blk_file permissive=1 [ 274.080278] audit: audit_lost=5270 audit_rate_limit=5 audit_backlog_limit=64 [ 274.080311] audit: rate limit exceeded [ 275.116162] type=1401 audit(1735396337.815:6588): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 275.116656] type=1401 audit(1735396337.815:6589): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 277.243723] audit: audit_lost=5272 audit_rate_limit=5 audit_backlog_limit=64 [ 277.243766] audit: rate limit exceeded [ 278.373115] audit: audit_lost=5428 audit_rate_limit=5 audit_backlog_limit=64 [ 278.373222] audit: rate limit exceeded [ 279.446526] type=1400 audit(1735396342.145:6832): avc: denied { read } for comm="stress_wifi_tes" path="pipe:[132077]" dev="pipefs" ino=132077 scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=fifo_file permissive=1 [ 279.447266] audit: audit_lost=5496 audit_rate_limit=5 audit_backlog_limit=64 [ 279.447310] audit: rate limit exceeded [ 279.447336] type=1400 audit(1735396342.145:6833): avc: denied { search } for comm="stress_wifi_tes" name="/" dev="dm-0" ino=2 scontext=u:r:datadis:s0 tcontext=u:object_r:rootfs:s0 tclass=dir permissive=1 [ 279.448070] type=1400 audit(1735396342.145:6834): avc: denied { search } for comm="stress_wifi_tes" name="/" dev="dm-3" ino=2 scontext=u:r:datadis:s0 tcontext=u:object_r:system_file:s0 tclass=dir permissive=1 [ 279.448965] type=1400 audit(1735396342.145:6835): avc: denied { read } for comm="stress_wifi_tes" name="grep" dev="dm-0" ino=1482 scontext=u:r:datadis:s0 tcontext=u:object_r:system_file:s0 tclass=lnk_file permissive=1 [ 279.449240] type=1401 audit(1735396342.149:6836): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 280.523870] type=1401 audit(1735396343.225:6918): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 280.524799] type=1401 audit(1735396343.225:6919): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 280.527227] audit: audit_lost=5577 audit_rate_limit=5 audit_backlog_limit=64 [ 280.527259] audit: rate limit exceeded [ 280.527878] type=1400 audit(1735396343.229:6920): avc: denied { read } for comm="grep" name="u:object_r:vndk_prop:s0" dev="tmpfs" ino=2807 scontext=u:r:datadis:s0 tcontext=u:object_r:vndk_prop:s0 tclass=file permissive=1 [ 280.530736] type=1400 audit(1735396343.229:6921): avc: denied { open } for comm="grep" path="/dev/__properties__/u:object_r:vndk_prop:s0" dev="tmpfs" ino=2807 scontext=u:r:datadis:s0 tcontext=u:object_r:vndk_prop:s0 tclass=file permissive=1 [ 280.530932] type=1400 audit(1735396343.229:6922): avc: denied { getattr } for comm="grep" path="/dev/__properties__/u:object_r:vndk_prop:s0" dev="tmpfs" ino=2807 scontext=u:r:datadis:s0 tcontext=u:object_r:vndk_prop:s0 tclass=file permissive=1 [ 281.613988] audit: audit_lost=5599 audit_rate_limit=5 audit_backlog_limit=64 [ 281.614023] audit: rate limit exceeded [ 282.679958] audit: audit_lost=5607 audit_rate_limit=5 audit_backlog_limit=64 [ 282.680015] audit: rate limit exceeded [ 283.743995] audit: audit_lost=5615 audit_rate_limit=5 audit_backlog_limit=64 [ 283.744056] audit: rate limit exceeded [ 284.835902] type=1401 audit(1735396347.535:6988): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 284.836485] type=1401 audit(1735396347.535:6989): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 284.864245] type=1401 audit(1735396347.565:6990): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 284.880779] type=1401 audit(1735396347.582:6991): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 285.898706] type=1401 audit(1735396348.599:6992): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 285.900645] audit: audit_lost=5627 audit_rate_limit=5 audit_backlog_limit=64 [ 285.900666] audit: rate limit exceeded [ 285.902171] type=1400 audit(1735396348.602:6993): avc: denied { search } for comm="df" name="/" dev="proc" ino=1 scontext=u:r:datadis:s0 tcontext=u:object_r:proc:s0 tclass=dir permissive=1 [ 285.902685] type=1401 audit(1735396348.602:6994): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 285.903120] type=1400 audit(1735396348.602:6995): avc: denied { read } for comm="df" name="exe" dev="proc" ino=138510 scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=lnk_file permissive=1 [ 285.903345] type=1400 audit(1735396348.602:6996): avc: denied { getattr } for comm="df" path="/linkerconfig/ld.config.txt" dev="tmpfs" ino=18122 scontext=u:r:datadis:s0 tcontext=u:object_r:linkerconfig_file:s0 tclass=file permissive=1 [ 285.903779] type=1400 audit(1735396348.602:6997): avc: denied { read } for comm="df" name="ld.config.txt" dev="tmpfs" ino=18122 scontext=u:r:datadis:s0 tcontext=u:object_r:linkerconfig_file:s0 tclass=file permissive=1 [ 286.979661] audit: audit_lost=5653 audit_rate_limit=5 audit_backlog_limit=64 [ 286.979709] audit: rate limit exceeded [ 288.050455] audit: audit_lost=5700 audit_rate_limit=5 audit_backlog_limit=64 [ 288.052826] audit: rate limit exceeded [ 289.175930] audit: audit_lost=5721 audit_rate_limit=5 audit_backlog_limit=64 [ 289.175972] audit: rate limit exceeded [ 290.219449] type=1401 audit(1735396352.919:7115): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 290.220310] type=1401 audit(1735396352.919:7116): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 290.237120] type=1400 audit(1735396352.935:7117): avc: denied { getattr } for comm="df" name="/" dev="binder" ino=1 scontext=u:r:datadis:s0 tcontext=u:object_r:binderfs:s0 tclass=filesystem permissive=1 [ 290.237843] type=1400 audit(1735396352.939:7118): avc: denied { getattr } for comm="df" path="/dev/usb-ffs/adb" dev="functionfs" ino=19125 scontext=u:r:datadis:s0 tcontext=u:object_r:functionfs:s0 tclass=dir permissive=1 [ 290.240482] type=1400 audit(1735396352.942:7119): avc: denied { read } for comm="df" name="metadata" dev="tmpfs" ino=10877 scontext=u:r:datadis:s0 tcontext=u:object_r:metadata_block_device:s0 tclass=lnk_file permissive=1 [ 290.250823] audit: audit_lost=5729 audit_rate_limit=5 audit_backlog_limit=64 [ 290.250854] audit: rate limit exceeded [ 290.906373] init: processing action (logd.logpersistd=clear && logd.logpersistd.enable=true) from (/system/etc/init/logcatd.rc:38) [ 290.926545] init: starting service 'exec 17 (/system/bin/logcat -c -f /data/misc/logd/logcat -n 256)'... [ 290.930137] init: SVC_EXEC service 'exec 17 (/system/bin/logcat -c -f /data/misc/logd/logcat -n 256)' pid 6109 (uid 1036 gid 1007+0 context default) started; waiting... [ 290.986263] init: Service 'exec 17 (/system/bin/logcat -c -f /data/misc/logd/logcat -n 256)' (pid 6109) exited with status 0 waiting took 0.056000 seconds [ 290.986362] init: Sending signal 9 to service 'exec 17 (/system/bin/logcat -c -f /data/misc/logd/logcat -n 256)' (pid 6109) process group... [ 290.987144] libprocessgroup: Successfully killed process cgroup uid 1036 pid 6109 in 0ms [ 291.225660] type=1400 audit(1735396353.925:7292): avc: denied { getattr } for comm="Thread-3" path="/data/misc_de/0/storaged" dev="mmcblk2p16" ino=171 scontext=u:r:system_app:s0 tcontext=u:object_r:storaged_data_file:s0 tclass=dir permissive=1 [ 291.225906] type=1400 audit(1735396353.925:7293): avc: denied { getattr } for comm="Thread-3" path="/data/misc_de/0/rollback" dev="mmcblk2p16" ino=172 scontext=u:r:system_app:s0 tcontext=u:object_r:rollback_data_file:s0 tclass=dir permissive=1 [ 291.231003] type=1400 audit(1735396353.929:7294): avc: denied { getattr } for comm="Thread-3" path="/data/misc_ce/0/storaged" dev="mmcblk2p16" ino=1097 scontext=u:r:system_app:s0 tcontext=u:object_r:storaged_data_file:s0 tclass=dir permissive=1 [ 291.235309] type=1400 audit(1735396353.935:7295): avc: denied { getattr } for comm="Thread-3" path="/data/user/0/com.android.companiondevicemanager" dev="mmcblk2p16" ino=1192 scontext=u:r:system_app:s0 tcontext=u:object_r:app_data_file:s0:c16,c256,c512,c768 tclass=dir permissive=1 [ 291.236135] type=1400 audit(1735396353.935:7296): avc: denied { getattr } for comm="Thread-3" path="/data/user/0/com.android.networkstack" dev="mmcblk2p16" ino=1218 scontext=u:r:system_app:s0 tcontext=u:object_r:radio_data_file:s0:c49,c260,c512,c768 tclass=dir permissive=1 [ 291.288139] audit: audit_lost=5902 audit_rate_limit=5 audit_backlog_limit=64 [ 291.288171] audit: rate limit exceeded [ 292.401374] audit: audit_lost=6058 audit_rate_limit=5 audit_backlog_limit=64 [ 292.401413] audit: rate limit exceeded [ 293.475450] audit: audit_lost=6089 audit_rate_limit=5 audit_backlog_limit=64 [ 293.475486] audit: rate limit exceeded [ 294.536265] audit: audit_lost=6095 audit_rate_limit=5 audit_backlog_limit=64 [ 294.536311] audit: rate limit exceeded [ 294.962541] init: processing action (persist.internet_adb_enable=1) from (/vendor/etc/init/hw/init.rk30board.rc:244) [ 294.964069] init: starting service 'adbd'... [ 294.965314] init: Created socket '/dev/socket/adbd', mode 660, user 1000, group 1000 [ 294.994979] read descriptors [ 294.995035] read strings [ 295.002979] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 295.595361] type=1400 audit(1735396358.295:7526): avc: denied { search } for comm="stress_wifi_tes" name="/" dev="dm-0" ino=2 scontext=u:r:datadis:s0 tcontext=u:object_r:rootfs:s0 tclass=dir permissive=1 [ 295.595858] type=1401 audit(1735396358.295:7528): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 295.596374] type=1400 audit(1735396358.295:7527): avc: denied { read } for comm="stress_wifi_tes" path="pipe:[140405]" dev="pipefs" ino=140405 scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=fifo_file permissive=1 [ 295.596583] type=1401 audit(1735396358.295:7529): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 295.596803] audit: audit_lost=6115 audit_rate_limit=5 audit_backlog_limit=64 [ 295.596884] audit: rate limit exceeded [ 295.597233] type=1400 audit(1735396358.295:7530): avc: denied { search } for comm="df" name="/" dev="tmpfs" ino=2599 scontext=u:r:datadis:s0 tcontext=u:object_r:device:s0 tclass=dir permissive=1 [ 296.040528] read descriptors [ 296.040569] read strings [ 296.041357] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 296.042638] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 296.042833] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 296.659003] type=1400 audit(1735396359.359:7566): avc: denied { fork } for comm="stress_wifi_tes" scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=process permissive=1 [ 296.659782] type=1401 audit(1735396359.359:7567): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 296.661641] type=1401 audit(1735396359.359:7568): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 296.662582] type=1400 audit(1735396359.362:7569): avc: denied { getsched } for comm="df" scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=process permissive=1 [ 296.673298] audit: audit_lost=6150 audit_rate_limit=5 audit_backlog_limit=64 [ 296.673332] audit: rate limit exceeded [ 296.673584] type=1400 audit(1735396359.372:7571): avc: denied { search } for comm="df" name="/" dev="sysfs" ino=1 scontext=u:r:datadis:s0 tcontext=u:object_r:sysfs:s0 tclass=dir permissive=1 [ 297.090611] read descriptors [ 297.090654] read strings [ 297.091537] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 297.092700] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 297.093064] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 297.746204] audit: audit_lost=6156 audit_rate_limit=5 audit_backlog_limit=64 [ 297.746240] audit: rate limit exceeded [ 298.127321] read descriptors [ 298.127368] read strings [ 298.128247] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 298.129438] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 298.129635] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 298.783795] audit: audit_lost=6159 audit_rate_limit=5 audit_backlog_limit=64 [ 298.783838] audit: rate limit exceeded [ 299.177268] read descriptors [ 299.177316] read strings [ 299.178166] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 300.213933] read descriptors [ 300.213976] read strings [ 300.895642] type=1400 audit(1735396363.595:7602): avc: denied { read } for comm="stress_wifi_tes" name="df" dev="dm-0" ino=1437 scontext=u:r:datadis:s0 tcontext=u:object_r:system_file:s0 tclass=lnk_file permissive=1 [ 300.897809] type=1401 audit(1735396363.595:7603): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 300.898167] type=1401 audit(1735396363.595:7604): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 300.898619] type=1400 audit(1735396363.599:7606): avc: denied { use } for comm="grep" path="/dev/null" dev="tmpfs" ino=2607 scontext=u:r:datadis:s0 tcontext=u:r:init:s0 tclass=fd permissive=1 [ 300.898811] type=1400 audit(1735396363.599:7605): avc: denied { use } for comm="df" path="/dev/null" dev="tmpfs" ino=2607 scontext=u:r:datadis:s0 tcontext=u:r:init:s0 tclass=fd permissive=1 [ 300.899566] audit: audit_lost=6167 audit_rate_limit=5 audit_backlog_limit=64 [ 300.899601] audit: rate limit exceeded [ 300.900005] type=1400 audit(1735396363.599:7607): avc: denied { search } for comm="grep" name="/" dev="dm-4" ino=2 scontext=u:r:datadis:s0 tcontext=u:object_r:vendor_file:s0 tclass=dir permissive=1 [ 301.260712] read descriptors [ 301.260760] read strings [ 301.261640] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 301.262888] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 301.263142] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 301.952722] type=1401 audit(1735396364.652:7629): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 301.953193] type=1401 audit(1735396364.652:7630): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 301.970444] audit: audit_lost=6188 audit_rate_limit=5 audit_backlog_limit=64 [ 301.970487] audit: rate limit exceeded [ 301.970771] type=1400 audit(1735396364.669:7631): avc: denied { search } for comm="df" name="user" dev="mmcblk2p16" ino=112 scontext=u:r:datadis:s0 tcontext=u:object_r:system_data_file:s0 tclass=dir permissive=1 [ 301.971076] type=1400 audit(1735396364.672:7632): avc: denied { read } for comm="logd.auditd" name="status" dev="proc" ino=140499 scontext=u:r:logd:s0 tcontext=u:r:datadis:s0 tclass=file permissive=1 [ 302.300638] read descriptors [ 302.300681] read strings [ 302.301459] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 302.302615] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 302.302808] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 303.340599] read descriptors [ 303.340647] read strings [ 303.341427] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 303.342607] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 303.342806] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 304.373931] read descriptors [ 304.373984] read strings [ 304.374914] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 305.410586] read descriptors [ 305.410631] read strings [ 305.989799] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au [ 306.189498] type=1401 audit(1735396368.889:7649): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 306.190019] type=1401 audit(1735396368.889:7650): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 306.205415] type=1400 audit(1735396368.905:7651): avc: denied { getattr } for comm="df" name="/" dev="cgroup" ino=1 scontext=u:r:datadis:s0 tcontext=u:object_r:cgroup:s0 tclass=filesystem permissive=1 [ 306.205673] type=1400 audit(1735396368.905:7652): avc: denied { getattr } for comm="df" name="/" dev="functionfs" ino=19125 scontext=u:r:datadis:s0 tcontext=u:object_r:functionfs:s0 tclass=filesystem permissive=1 [ 306.212819] type=1401 audit(1735396368.912:7653): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 306.228310] type=1401 audit(1735396368.929:7654): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 306.457327] read descriptors [ 306.457370] read strings [ 306.458165] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 306.459217] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 306.459378] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 307.244828] type=1401 audit(1735396369.945:7655): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 307.245948] type=1401 audit(1735396369.945:7656): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 307.270473] type=1401 audit(1735396369.972:7657): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 307.288386] type=1401 audit(1735396369.989:7658): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 307.503899] read descriptors [ 307.503946] read strings [ 307.504730] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 307.505916] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 307.506112] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 308.534144] read descriptors [ 308.534189] read strings [ 308.534918] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 308.536022] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 308.536205] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 309.367674] audit: audit_lost=6192 audit_rate_limit=5 audit_backlog_limit=64 [ 309.367718] audit: rate limit exceeded [ 309.577310] read descriptors [ 309.577360] read strings [ 309.578341] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 310.439049] audit: audit_lost=6202 audit_rate_limit=5 audit_backlog_limit=64 [ 310.439154] audit: rate limit exceeded [ 310.607299] read descriptors [ 310.607338] read strings [ 311.487544] type=1401 audit(1735396374.189:7695): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 311.488199] type=1401 audit(1735396374.189:7696): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 311.505102] type=1400 audit(1735396374.205:7697): avc: denied { getattr } for comm="df" name="/" dev="fusectl" ino=1 scontext=u:r:datadis:s0 tcontext=u:object_r:fusectlfs:s0 tclass=filesystem permissive=1 [ 311.506682] type=1400 audit(1735396374.205:7698): avc: denied { getattr } for comm="df" path="/dev/block/dm-0" dev="tmpfs" ino=10885 scontext=u:r:datadis:s0 tcontext=u:object_r:dm_device:s0 tclass=blk_file permissive=1 [ 311.513425] type=1401 audit(1735396374.212:7699): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 311.529326] audit: audit_lost=6209 audit_rate_limit=5 audit_backlog_limit=64 [ 311.529370] audit: rate limit exceeded [ 311.653936] read descriptors [ 311.653980] read strings [ 311.654710] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 311.655908] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 311.656089] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 312.546152] type=1401 audit(1735396375.245:7701): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 312.551008] type=1401 audit(1735396375.252:7702): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 312.576173] type=1401 audit(1735396375.275:7703): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 312.592908] type=1401 audit(1735396375.292:7704): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 312.683920] read descriptors [ 312.683981] read strings [ 312.684787] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 312.685870] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 312.686040] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 313.610327] type=1401 audit(1735396376.309:7705): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 313.730562] read descriptors [ 313.730603] read strings [ 313.731373] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 313.732488] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 313.732680] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 314.777252] read descriptors [ 314.777294] read strings [ 314.778014] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 315.817386] read descriptors [ 315.817427] read strings [ 316.796982] type=1401 audit(1735396379.492:7718): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 316.797412] type=1401 audit(1735396379.492:7719): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 316.820369] type=1401 audit(1735396379.519:7720): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 316.834754] type=1401 audit(1735396379.535:7721): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 316.860576] read descriptors [ 316.860619] read strings [ 316.861409] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 316.863369] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 316.863701] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 317.852691] type=1401 audit(1735396380.552:7722): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 317.853329] type=1401 audit(1735396380.552:7723): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 317.869571] type=1400 audit(1735396380.569:7724): avc: denied { getattr } for comm="df" path="/sys/fs/pstore" dev="pstore" ino=18377 scontext=u:r:datadis:s0 tcontext=u:object_r:pstorefs:s0 tclass=dir permissive=1 [ 317.877346] type=1400 audit(1735396380.575:7725): avc: denied { search } for comm="stress_wifi_tes" name="/" dev="tmpfs" ino=18090 scontext=u:r:datadis:s0 tcontext=u:object_r:apex_mnt_dir:s0 tclass=dir permissive=1 [ 317.877963] type=1401 audit(1735396380.579:7726): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 317.892606] type=1401 audit(1735396380.592:7727): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 317.897251] read descriptors [ 317.897295] read strings [ 317.898076] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 317.899249] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 317.899469] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 318.940688] read descriptors [ 318.940735] read strings [ 318.941576] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 318.942658] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 318.942836] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 319.970605] read descriptors [ 319.970654] read strings [ 319.971623] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 321.007326] read descriptors [ 321.007369] read strings [ 322.047262] read descriptors [ 322.047301] read strings [ 322.048014] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 322.049163] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 322.049359] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 322.082245] type=1401 audit(1735396384.782:7743): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 322.082653] type=1401 audit(1735396384.782:7744): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 322.105475] type=1401 audit(1735396384.805:7745): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 322.121268] type=1401 audit(1735396384.822:7746): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 323.083950] read descriptors [ 323.083992] read strings [ 323.084704] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 323.085834] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 323.086049] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 323.137735] type=1401 audit(1735396385.839:7747): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 323.138260] type=1401 audit(1735396385.839:7748): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 323.161031] type=1401 audit(1735396385.862:7749): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 323.176886] type=1401 audit(1735396385.875:7750): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 324.123971] read descriptors [ 324.124012] read strings [ 324.124783] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 324.125920] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 324.126124] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 324.193135] type=1401 audit(1735396386.892:7751): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 324.193958] type=1401 audit(1735396386.895:7752): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 325.183900] read descriptors [ 325.183946] read strings [ 325.184703] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 326.223973] read descriptors [ 326.224024] read strings [ 326.328685] audit: audit_lost=6210 audit_rate_limit=5 audit_backlog_limit=64 [ 326.328716] audit: rate limit exceeded [ 327.267284] read descriptors [ 327.267345] read strings [ 327.268257] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 327.269546] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 327.269830] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 327.370633] type=1401 audit(1735396390.069:7771): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 327.371351] type=1401 audit(1735396390.072:7772): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 327.394644] type=1401 audit(1735396390.095:7773): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 327.411773] type=1401 audit(1735396390.112:7774): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 328.303893] read descriptors [ 328.303937] read strings [ 328.304692] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 328.305811] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 328.305988] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 328.428108] type=1401 audit(1735396391.129:7775): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 328.428575] type=1401 audit(1735396391.129:7776): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 328.452078] type=1401 audit(1735396391.152:7777): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 328.469247] type=1401 audit(1735396391.169:7778): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 329.347290] read descriptors [ 329.347334] read strings [ 329.348092] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 329.349270] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 329.349474] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 329.487477] type=1401 audit(1735396392.189:7779): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 329.487868] type=1401 audit(1735396392.189:7780): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 330.380606] read descriptors [ 330.380656] read strings [ 330.381436] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 331.417281] read descriptors [ 331.417330] read strings [ 332.460613] read descriptors [ 332.460662] read strings [ 332.461630] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 332.462852] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 332.463124] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 332.662419] type=1401 audit(1735396395.362:7791): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 332.662831] type=1401 audit(1735396395.362:7792): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 332.685605] type=1401 audit(1735396395.385:7793): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 332.700794] type=1401 audit(1735396395.402:7794): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 333.493974] read descriptors [ 333.494019] read strings [ 333.494801] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 333.496165] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 333.496452] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 333.717797] type=1401 audit(1735396396.419:7795): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 333.718245] type=1401 audit(1735396396.419:7796): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 333.743333] type=1401 audit(1735396396.442:7797): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 333.760516] type=1401 audit(1735396396.462:7798): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 334.533897] read descriptors [ 334.533941] read strings [ 334.534707] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 334.535900] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 334.536105] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 334.777515] type=1401 audit(1735396397.479:7799): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 334.778414] type=1401 audit(1735396397.479:7800): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 335.563927] read descriptors [ 335.563972] read strings [ 335.564726] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 336.559396] audit: audit_lost=6215 audit_rate_limit=5 audit_backlog_limit=64 [ 336.559425] audit: rate limit exceeded [ 336.600535] read descriptors [ 336.600577] read strings [ 337.640661] read descriptors [ 337.640705] read strings [ 337.641520] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 337.642723] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 337.642923] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 337.957080] type=1401 audit(1735396400.655:7869): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 337.957730] type=1401 audit(1735396400.659:7870): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 337.971137] audit: audit_lost=6268 audit_rate_limit=5 audit_backlog_limit=64 [ 337.971172] audit: rate limit exceeded [ 337.971609] type=1400 audit(1735396400.672:7872): avc: denied { read } for comm="grep" name="u:object_r:heapprofd_prop:s0" dev="tmpfs" ino=2733 scontext=u:r:datadis:s0 tcontext=u:object_r:heapprofd_prop:s0 tclass=file permissive=1 [ 337.972520] type=1400 audit(1735396400.672:7871): avc: denied { read } for comm="df" name="u:object_r:heapprofd_prop:s0" dev="tmpfs" ino=2733 scontext=u:r:datadis:s0 tcontext=u:object_r:heapprofd_prop:s0 tclass=file permissive=1 [ 337.973305] type=1400 audit(1735396400.672:7874): avc: denied { open } for comm="df" path="/dev/__properties__/u:object_r:heapprofd_prop:s0" dev="tmpfs" ino=2733 scontext=u:r:datadis:s0 tcontext=u:object_r:heapprofd_prop:s0 tclass=file permissive=1 [ 338.687227] read descriptors [ 338.687270] read strings [ 338.687946] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 338.689016] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 338.689184] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 339.018573] type=1401 audit(1735396401.719:7881): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 339.027984] type=1401 audit(1735396401.722:7882): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 339.045163] type=1400 audit(1735396401.745:7883): avc: denied { getattr } for comm="df" name="/" dev="proc" ino=1 scontext=u:r:datadis:s0 tcontext=u:object_r:proc:s0 tclass=filesystem permissive=1 [ 339.045610] type=1400 audit(1735396401.745:7884): avc: denied { getattr } for comm="df" path="/sys/fs/selinux" dev="selinuxfs" ino=1 scontext=u:r:datadis:s0 tcontext=u:object_r:selinuxfs:s0 tclass=dir permissive=1 [ 339.046215] type=1400 audit(1735396401.745:7885): avc: denied { getattr } for comm="df" path="/config" dev="configfs" ino=3229 scontext=u:r:datadis:s0 tcontext=u:object_r:configfs:s0 tclass=dir permissive=1 [ 339.054857] audit: audit_lost=6275 audit_rate_limit=5 audit_backlog_limit=64 [ 339.054888] audit: rate limit exceeded [ 339.777259] read descriptors [ 339.777306] read strings [ 339.778169] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 339.779615] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 339.779891] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 340.762516] binder: undelivered death notification, b400007674b242e0 [ 340.807589] binder: undelivered transaction 506424, process died. [ 340.820569] read descriptors [ 340.820609] read strings [ 340.821367] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 341.148750] audit: audit_lost=6277 audit_rate_limit=5 audit_backlog_limit=64 [ 341.148793] audit: rate limit exceeded [ 341.860576] read descriptors [ 341.860618] read strings [ 342.890551] read descriptors [ 342.890592] read strings [ 342.891391] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 342.892432] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 342.892588] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 343.271174] type=1401 audit(1735396405.972:7946): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 343.271604] type=1401 audit(1735396405.972:7947): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 343.303658] type=1401 audit(1735396405.999:7948): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 343.316716] type=1401 audit(1735396406.015:7949): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 343.923893] read descriptors [ 343.923940] read strings [ 343.924822] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 343.925977] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 343.926215] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 344.340327] type=1401 audit(1735396407.039:7950): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 344.347158] type=1401 audit(1735396407.049:7951): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 344.375143] type=1401 audit(1735396407.075:7952): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 344.394219] type=1401 audit(1735396407.095:7953): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 344.970639] read descriptors [ 344.970686] read strings [ 344.971508] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 344.972604] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 344.972806] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 345.414339] type=1401 audit(1735396408.115:7954): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 345.417178] type=1401 audit(1735396408.119:7955): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 346.017346] read descriptors [ 346.017397] read strings [ 346.018229] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 347.060620] read descriptors [ 347.060663] read strings [ 348.103949] read descriptors [ 348.103996] read strings [ 348.104856] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 348.106076] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 348.106279] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 348.667593] type=1401 audit(1735396411.369:7966): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 348.672403] type=1401 audit(1735396411.369:7967): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 348.691303] type=1401 audit(1735396411.392:7968): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 348.707593] type=1401 audit(1735396411.409:7969): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 349.140585] read descriptors [ 349.140634] read strings [ 349.141484] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 349.142624] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 349.142870] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 349.728368] type=1401 audit(1735396412.429:7970): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 349.729461] type=1401 audit(1735396412.429:7971): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 349.765114] type=1401 audit(1735396412.465:7972): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 349.783456] type=1401 audit(1735396412.482:7973): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 350.173983] read descriptors [ 350.174028] read strings [ 350.174808] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 350.175880] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 350.176116] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 350.802424] type=1401 audit(1735396413.502:7974): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 350.802946] type=1401 audit(1735396413.502:7975): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 351.213976] read descriptors [ 351.214033] read strings [ 351.214931] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 352.247237] read descriptors [ 352.247286] read strings [ 353.296845] read descriptors [ 353.296885] read strings [ 353.297882] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 353.299035] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 353.299284] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 353.982346] audit: audit_lost=6320 audit_rate_limit=5 audit_backlog_limit=64 [ 353.982445] audit: rate limit exceeded [ 353.984077] type=1400 audit(1735396416.682:7988): avc: denied { search } for comm="stress_wifi_tes" name="/" dev="dm-0" ino=2 scontext=u:r:datadis:s0 tcontext=u:object_r:rootfs:s0 tclass=dir permissive=1 [ 353.984412] type=1400 audit(1735396416.682:7989): avc: denied { search } for comm="stress_wifi_tes" name="/" dev="tmpfs" ino=18090 scontext=u:r:datadis:s0 tcontext=u:object_r:apex_mnt_dir:s0 tclass=dir permissive=1 [ 353.984561] type=1401 audit(1735396416.682:7990): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 353.984935] type=1400 audit(1735396416.682:7991): avc: denied { execute } for comm="stress_wifi_tes" name="linker64" dev="dm-0" ino=500 scontext=u:r:datadis:s0 tcontext=u:object_r:system_linker_exec:s0 tclass=file permissive=1 [ 353.985109] type=1400 audit(1735396416.682:7992): avc: denied { read open } for comm="stress_wifi_tes" path="/apex/com.android.runtime/bin/linker64" dev="dm-0" ino=500 scontext=u:r:datadis:s0 tcontext=u:object_r:system_linker_exec:s0 tclass=file permissive=1 [ 353.985234] type=1400 audit(1735396416.682:7993): avc: denied { read } for comm="stress_wifi_tes" path="pipe:[144273]" dev="pipefs" ino=144273 scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=fifo_file permissive=1 [ 353.985336] type=1400 audit(1735396416.682:7994): avc: denied { map } for comm="df" path="/apex/com.android.runtime/bin/linker64" dev="dm-0" ino=500 scontext=u:r:datadis:s0 tcontext=u:object_r:system_linker_exec:s0 tclass=file permissive=1 [ 353.985435] type=1400 audit(1735396416.682:7995): avc: denied { search } for comm="df" name="/" dev="tmpfs" ino=2599 scontext=u:r:datadis:s0 tcontext=u:object_r:device:s0 tclass=dir permissive=1 [ 354.330760] read descriptors [ 354.330809] read strings [ 354.331919] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 354.333244] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 354.333638] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 355.000382] type=1400 audit(1735396417.699:8085): avc: denied { read } for comm="user_drmservice" lport=33334 scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=udp_socket permissive=1 [ 355.063550] audit: audit_lost=6409 audit_rate_limit=5 audit_backlog_limit=64 [ 355.063639] audit: rate limit exceeded [ 355.067681] type=1400 audit(1735396417.762:8086): avc: denied { search } for comm="stress_wifi_tes" name="/" dev="dm-3" ino=2 scontext=u:r:datadis:s0 tcontext=u:object_r:system_file:s0 tclass=dir permissive=1 [ 355.377369] read descriptors [ 355.377420] read strings [ 355.378596] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 355.379813] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 355.380101] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 356.143011] audit: audit_lost=6471 audit_rate_limit=5 audit_backlog_limit=64 [ 356.143056] audit: rate limit exceeded [ 356.420571] read descriptors [ 356.420617] read strings [ 356.421400] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 357.228836] audit: audit_lost=6532 audit_rate_limit=5 audit_backlog_limit=64 [ 357.228876] audit: rate limit exceeded [ 357.457179] read descriptors [ 357.457217] read strings [ 358.500534] read descriptors [ 358.500572] read strings [ 358.501276] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 358.502344] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 358.502510] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 359.344435] type=1401 audit(1735396422.045:8233): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 359.345244] type=1401 audit(1735396422.045:8234): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 359.359176] type=1400 audit(1735396422.059:8235): avc: denied { getattr } for comm="df" name="/" dev="proc" ino=1 scontext=u:r:datadis:s0 tcontext=u:object_r:proc:s0 tclass=filesystem permissive=1 [ 359.359738] type=1400 audit(1735396422.059:8236): avc: denied { getattr } for comm="df" path="/sys/fs/selinux" dev="selinuxfs" ino=1 scontext=u:r:datadis:s0 tcontext=u:object_r:selinuxfs:s0 tclass=dir permissive=1 [ 359.360127] type=1400 audit(1735396422.059:8237): avc: denied { getattr } for comm="df" path="/config" dev="configfs" ino=3229 scontext=u:r:datadis:s0 tcontext=u:object_r:configfs:s0 tclass=dir permissive=1 [ 359.369232] type=1401 audit(1735396422.069:8238): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 359.384577] audit: audit_lost=6538 audit_rate_limit=5 audit_backlog_limit=64 [ 359.384610] audit: rate limit exceeded [ 359.540659] read descriptors [ 359.540707] read strings [ 359.541589] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 359.542718] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 359.542938] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 360.400384] type=1400 audit(1735396423.099:8240): avc: denied { fork } for comm="stress_wifi_tes" scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=process permissive=1 [ 360.401130] audit: audit_lost=6539 audit_rate_limit=5 audit_backlog_limit=64 [ 360.401216] audit: rate limit exceeded [ 360.401930] type=1400 audit(1735396423.102:8241): avc: denied { search } for comm="stress_wifi_tes" name="/" dev="dm-3" ino=2 scontext=u:r:datadis:s0 tcontext=u:object_r:system_file:s0 tclass=dir permissive=1 [ 360.403915] type=1400 audit(1735396423.102:8242): avc: denied { read } for comm="stress_wifi_tes" name="df" dev="dm-0" ino=1437 scontext=u:r:datadis:s0 tcontext=u:object_r:system_file:s0 tclass=lnk_file permissive=1 [ 360.404177] type=1400 audit(1735396423.102:8243): avc: denied { getattr } for comm="stress_wifi_tes" path="/system/bin/toybox" dev="dm-0" ino=1727 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1 [ 360.577447] read descriptors [ 360.577502] read strings [ 360.578689] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 360.580012] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 360.581550] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 361.495406] audit: audit_lost=6585 audit_rate_limit=5 audit_backlog_limit=64 [ 361.495445] audit: rate limit exceeded [ 361.627455] read descriptors [ 361.627508] read strings [ 361.628717] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 362.649674] audit: audit_lost=6601 audit_rate_limit=5 audit_backlog_limit=64 [ 362.649737] audit: rate limit exceeded [ 362.690622] read descriptors [ 362.690666] read strings [ 363.691005] audit: audit_lost=6602 audit_rate_limit=5 audit_backlog_limit=64 [ 363.691090] audit: rate limit exceeded [ 363.730692] read descriptors [ 363.730742] read strings [ 363.731779] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 363.733044] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 363.733309] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 364.767425] read descriptors [ 364.767474] read strings [ 364.768432] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 364.769715] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 364.770017] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 364.784552] type=1400 audit(1735396427.482:8384): avc: denied { fork } for comm="stress_wifi_tes" scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=process permissive=1 [ 364.790374] type=1401 audit(1735396427.485:8385): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 364.800287] type=1400 audit(1735396427.489:8386): avc: denied { getsched } for comm="df" scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=process permissive=1 [ 364.802091] type=1401 audit(1735396427.489:8387): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 364.805691] audit: audit_lost=6663 audit_rate_limit=5 audit_backlog_limit=64 [ 364.805782] audit: rate limit exceeded [ 364.817684] type=1400 audit(1735396427.505:8388): avc: denied { read } for comm="grep" name="u:object_r:heapprofd_prop:s0" dev="tmpfs" ino=2733 scontext=u:r:datadis:s0 tcontext=u:object_r:heapprofd_prop:s0 tclass=file permissive=1 [ 365.823969] read descriptors [ 365.824017] read strings [ 365.825038] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 365.826207] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 365.826452] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 365.881563] audit: audit_lost=6963 audit_rate_limit=5 audit_backlog_limit=64 [ 365.881593] audit: rate limit exceeded [ 365.887195] type=1400 audit(1735396428.582:8689): avc: denied { search } for comm="stress_wifi_tes" name="/" dev="dm-3" ino=2 scontext=u:r:datadis:s0 tcontext=u:object_r:system_file:s0 tclass=dir permissive=1 [ 365.887720] type=1400 audit(1735396428.582:8690): avc: denied { read } for comm="stress_wifi_tes" name="df" dev="dm-0" ino=1437 scontext=u:r:datadis:s0 tcontext=u:object_r:system_file:s0 tclass=lnk_file permissive=1 [ 365.887981] type=1400 audit(1735396428.582:8691): avc: denied { getattr } for comm="stress_wifi_tes" path="/system/bin/toybox" dev="dm-0" ino=1727 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1 [ 365.888182] type=1400 audit(1735396428.582:8692): avc: denied { execute } for comm="stress_wifi_tes" name="toybox" dev="dm-0" ino=1727 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1 [ 365.888353] type=1400 audit(1735396428.582:8693): avc: denied { read open } for comm="stress_wifi_tes" path="/system/bin/toybox" dev="dm-0" ino=1727 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1 [ 365.989578] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au [ 366.870918] read descriptors [ 366.870965] read strings [ 366.871988] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 366.977879] audit: audit_lost=7000 audit_rate_limit=5 audit_backlog_limit=64 [ 366.977918] audit: rate limit exceeded [ 367.913969] read descriptors [ 367.914016] read strings [ 368.136573] audit: audit_lost=7082 audit_rate_limit=5 audit_backlog_limit=64 [ 368.136613] audit: rate limit exceeded [ 368.957288] read descriptors [ 368.957331] read strings [ 368.958308] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 368.959486] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 368.959748] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 369.243825] audit: audit_lost=7109 audit_rate_limit=5 audit_backlog_limit=64 [ 369.243872] audit: rate limit exceeded [ 369.990657] read descriptors [ 369.990702] read strings [ 369.991725] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 369.992972] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 369.993250] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 370.344829] type=1401 audit(1735396433.042:8873): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 370.345365] audit: audit_lost=7127 audit_rate_limit=5 audit_backlog_limit=64 [ 370.345429] audit: rate limit exceeded [ 370.348789] type=1400 audit(1735396433.042:8874): avc: denied { read } for comm="df" name="properties_serial" dev="tmpfs" ino=2811 scontext=u:r:datadis:s0 tcontext=u:object_r:properties_serial:s0 tclass=file permissive=1 [ 370.349315] type=1400 audit(1735396433.042:8875): avc: denied { open } for comm="df" path="/dev/__properties__/properties_serial" dev="tmpfs" ino=2811 scontext=u:r:datadis:s0 tcontext=u:object_r:properties_serial:s0 tclass=file permissive=1 [ 370.349562] type=1400 audit(1735396433.042:8876): avc: denied { getattr } for comm="df" path="/dev/__properties__/properties_serial" dev="tmpfs" ino=2811 scontext=u:r:datadis:s0 tcontext=u:object_r:properties_serial:s0 tclass=file permissive=1 [ 370.349805] type=1400 audit(1735396433.042:8877): avc: denied { map } for comm="df" path="/dev/__properties__/properties_serial" dev="tmpfs" ino=2811 scontext=u:r:datadis:s0 tcontext=u:object_r:properties_serial:s0 tclass=file permissive=1 [ 371.030541] read descriptors [ 371.030592] read strings [ 371.031365] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 371.032509] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 371.032732] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 371.430463] type=1401 audit(1735396434.129:8895): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 371.430917] type=1401 audit(1735396434.132:8896): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 371.448364] type=1400 audit(1735396434.149:8897): avc: denied { getattr } for comm="df" path="/data_mirror/cur_profiles" dev="mmcblk2p16" ino=66 scontext=u:r:datadis:s0 tcontext=u:object_r:user_profile_data_file:s0 tclass=dir permissive=1 [ 371.458049] type=1401 audit(1735396434.159:8898): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 371.483644] type=1401 audit(1735396434.179:8899): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 372.064012] read descriptors [ 372.064061] read strings [ 372.065150] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 372.527505] audit: audit_lost=7144 audit_rate_limit=5 audit_backlog_limit=64 [ 372.527543] audit: rate limit exceeded [ 373.107333] read descriptors [ 373.107378] read strings [ 373.589754] audit: audit_lost=7147 audit_rate_limit=5 audit_backlog_limit=64 [ 373.589853] audit: rate limit exceeded [ 374.140608] read descriptors [ 374.140656] read strings [ 374.141591] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 374.142820] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 374.143086] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 375.174293] read descriptors [ 375.174438] read strings [ 375.175600] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 375.176748] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 375.177134] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 375.732081] type=1401 audit(1735396438.432:8922): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 375.732593] type=1401 audit(1735396438.432:8923): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 375.747504] type=1400 audit(1735396438.449:8924): avc: denied { getattr } for comm="df" name="/" dev="binder" ino=1 scontext=u:r:datadis:s0 tcontext=u:object_r:binderfs:s0 tclass=filesystem permissive=1 [ 375.755125] type=1401 audit(1735396438.455:8925): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 375.770667] type=1401 audit(1735396438.472:8926): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 376.210864] read descriptors [ 376.210915] read strings [ 376.211920] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 376.213153] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 376.213411] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 376.787901] audit: audit_lost=7151 audit_rate_limit=5 audit_backlog_limit=64 [ 376.789066] type=1400 audit(1735396439.485:8927): avc: denied { search } for comm="stress_wifi_tes" name="/" dev="dm-0" ino=2 scontext=u:r:datadis:s0 tcontext=u:object_r:rootfs:s0 tclass=dir permissive=1 [ 376.790462] audit: rate limit exceeded [ 376.807271] type=1401 audit(1735396439.485:8928): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 376.807955] type=1400 audit(1735396439.485:8929): avc: denied { execute } for comm="stress_wifi_tes" name="linker64" dev="dm-0" ino=500 scontext=u:r:datadis:s0 tcontext=u:object_r:system_linker_exec:s0 tclass=file permissive=1 [ 376.809506] type=1400 audit(1735396439.485:8930): avc: denied { read } for comm="stress_wifi_tes" path="pipe:[153433]" dev="pipefs" ino=153433 scontext=u:r:datadis:s0 tcontext=u:r:datadis:s0 tclass=fifo_file permissive=1 [ 376.811337] type=1400 audit(1735396439.485:8931): avc: denied { read open } for comm="stress_wifi_tes" path="/apex/com.android.runtime/bin/linker64" dev="dm-0" ino=500 scontext=u:r:datadis:s0 tcontext=u:object_r:system_linker_exec:s0 tclass=file permissive=1 [ 377.264030] read descriptors [ 377.264077] read strings [ 377.264936] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 377.877175] audit: audit_lost=7221 audit_rate_limit=5 audit_backlog_limit=64 [ 377.877216] audit: rate limit exceeded [ 378.307402] read descriptors [ 378.307455] read strings [ 378.947778] audit: audit_lost=7237 audit_rate_limit=5 audit_backlog_limit=64 [ 378.947913] audit: rate limit exceeded [ 379.363964] read descriptors [ 379.364010] read strings [ 379.364828] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 379.366094] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 379.366345] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 380.027874] audit: audit_lost=7242 audit_rate_limit=5 audit_backlog_limit=64 [ 380.027910] audit: rate limit exceeded [ 380.417219] read descriptors [ 380.417265] read strings [ 380.418038] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 380.419232] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 380.419489] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 381.070395] audit: audit_lost=7245 audit_rate_limit=5 audit_backlog_limit=64 [ 381.070437] audit: rate limit exceeded [ 381.073697] type=1401 audit(1735396443.769:9041): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 381.074097] type=1401 audit(1735396443.769:9042): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 381.074504] type=1400 audit(1735396443.772:9044): avc: denied { open } for comm="grep" path="/dev/__properties__/u:object_r:exported2_default_prop:s0" dev="tmpfs" ino=2701 scontext=u:r:datadis:s0 tcontext=u:object_r:exported2_default_prop:s0 tclass=file permissive=1 [ 381.074919] type=1400 audit(1735396443.772:9043): avc: denied { read } for comm="df" name="u:object_r:exported2_default_prop:s0" dev="tmpfs" ino=2701 scontext=u:r:datadis:s0 tcontext=u:object_r:exported2_default_prop:s0 tclass=file permissive=1 [ 381.075177] type=1400 audit(1735396443.772:9045): avc: denied { getattr } for comm="df" path="/dev/__properties__/u:object_r:exported2_default_prop:s0" dev="tmpfs" ino=2701 scontext=u:r:datadis:s0 tcontext=u:object_r:exported2_default_prop:s0 tclass=file permissive=1 [ 381.453975] read descriptors [ 381.454022] read strings [ 381.455070] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 381.456288] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 381.456560] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 382.149579] type=1401 audit(1735396444.849:9055): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 382.150311] type=1401 audit(1735396444.849:9056): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 382.177291] type=1401 audit(1735396444.875:9057): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 382.197496] type=1401 audit(1735396444.899:9058): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 382.497320] read descriptors [ 382.497371] read strings [ 382.498363] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 383.223631] type=1401 audit(1735396445.919:9059): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 383.264818] audit: audit_lost=7254 audit_rate_limit=5 audit_backlog_limit=64 [ 383.264851] audit: rate limit exceeded [ 383.537293] read descriptors [ 383.537337] read strings [ 384.580564] read descriptors [ 384.580611] read strings [ 384.581366] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 384.582537] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 384.582734] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 385.620631] read descriptors [ 385.620680] read strings [ 385.621510] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 385.622582] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 385.622748] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 386.427641] type=1401 audit(1735396449.125:9075): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 386.428046] type=1401 audit(1735396449.125:9076): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 386.446891] type=1400 audit(1735396449.145:9077): avc: denied { getattr } for comm="df" name="/" dev="cgroup" ino=1 scontext=u:r:datadis:s0 tcontext=u:object_r:cgroup:s0 tclass=filesystem permissive=1 [ 386.447516] type=1400 audit(1735396449.149:9078): avc: denied { getattr } for comm="df" name="/" dev="cgroup2" ino=1 scontext=u:r:datadis:s0 tcontext=u:object_r:cgroup_bpf:s0 tclass=filesystem permissive=1 [ 386.466996] type=1401 audit(1735396449.162:9079): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 386.486972] type=1401 audit(1735396449.182:9080): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 386.657356] read descriptors [ 386.657408] read strings [ 386.658302] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 386.659657] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 386.659920] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 387.499906] type=1401 audit(1735396450.199:9081): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 387.500514] type=1401 audit(1735396450.202:9082): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 387.522451] type=1401 audit(1735396450.222:9083): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 387.537602] type=1401 audit(1735396450.239:9084): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 387.707210] read descriptors [ 387.707256] read strings [ 387.708051] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 388.737585] read descriptors [ 388.737763] read strings [ 389.777320] read descriptors [ 389.777369] read strings [ 389.778241] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 389.779566] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 389.779849] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 390.833879] read descriptors [ 390.833929] read strings [ 390.834720] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 390.835880] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 390.836075] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 391.726586] type=1401 audit(1735396454.425:9097): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 391.727830] type=1401 audit(1735396454.429:9098): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 391.753932] type=1401 audit(1735396454.455:9099): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 391.769674] type=1401 audit(1735396454.469:9100): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 391.867242] read descriptors [ 391.867281] read strings [ 391.867958] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) [ 391.869257] init: Command 'symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists [ 391.869492] init: Command 'write /config/usb_gadget/g1/UDC ${sys.usb.controller}' action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:23) took 0ms and failed: property 'sys.usb.controller' doesn't exist while expanding '${sys.usb.controller}' [ 392.786032] type=1401 audit(1735396455.485:9101): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 392.787507] type=1401 audit(1735396455.489:9102): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 392.811107] type=1401 audit(1735396455.512:9103): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 392.827728] type=1401 audit(1735396455.529:9104): op=security_compute_sid invalid_context=u:r:datadis:s0 scontext=u:r:datadis:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=process [ 392.907247] read descriptors [ 392.907300] read strings [ 392.908138] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20) 0 Quote
Andre B Posted December 29, 2024 Posted December 29, 2024 (edited) Hi @Vincenzoernst1, here's the ip a output 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet 127.0.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host noprefixroute valid_lft forever preferred_lft forever 2: end1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000 link/ether d2:c2:c4:17:88:2f brd ff:ff:ff:ff:ff:ff 3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000 link/ether f4:09:d8:80:37:2a brd ff:ff:ff:ff:ff:ff inet 192.168.96.107/24 brd 192.168.96.255 scope global dynamic noprefixroute wlan0 valid_lft 41386sec preferred_lft 41386sec inet6 fd00::3dc0:70e2:e833:ff64/64 scope global temporary dynamic valid_lft 602988sec preferred_lft 84035sec inet6 fd00::9a9c:ab02:8d24:7ee1/64 scope global mngtmpaddr noprefixroute valid_lft forever preferred_lft forever inet6 fe80::cde1:e0da:9797:f10b/64 scope link noprefixroute valid_lft forever preferred_lft forever sometimes ethernet says connected but don't gets an ip and here's hwinfo output hwinfo.txt Edited December 29, 2024 by Andre B 0 Quote
Andre B Posted December 29, 2024 Posted December 29, 2024 i revert ethernet1 to ethernet0 in dtb and added extra arg net.ifnames=0 in armbianEnv.txt and here's the new ip a output : 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet 127.0.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host noprefixroute valid_lft forever preferred_lft forever 2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000 link/ether d2:c2:c4:17:88:2e brd ff:ff:ff:ff:ff:ff altname end0 inet6 fe80::d0c2:c4ff:fe17:882e/64 scope link noprefixroute valid_lft forever preferred_lft forever 3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000 link/ether f4:09:d8:80:37:2a brd ff:ff:ff:ff:ff:ff inet 192.168.96.107/24 brd 192.168.96.255 scope global dynamic noprefixroute wlan0 valid_lft 43192sec preferred_lft 43192sec inet6 fd00::772d:8941:d231:6a49/64 scope global temporary dynamic valid_lft 604794sec preferred_lft 86143sec inet6 fd00::9aed:b2b3:c4e4:4c18/64 scope global mngtmpaddr noprefixroute valid_lft forever preferred_lft forever inet6 fe80::f410:d986:f27:4400/64 scope link noprefixroute valid_lft forever preferred_lft forever i dont know what i'm doing, i dont have enough knowledge on this, im just experimenting. 0 Quote
Andre B Posted December 29, 2024 Posted December 29, 2024 (edited) dmesg says Link is up but those "Connection failed" notification keep appearing, and armbian never gets an ip from the router Edited December 29, 2024 by Andre B 0 Quote
