ytn Posted September 23, 2015 Posted September 23, 2015 I am trying to build an older image (i.e. not latest / next). I select wheezy and default (3.4 - 3.14 kernel). I did not modify compile.sh in any way. When building, I seem to constantly run into these errors: /root/armbian3/lib/boards.sh: line 217: cd: /root/armbian3/output/cache/sdcard/usr/src/linux-headers-: No such file or directory[ o.k. ] Compile kernel headers scripts/bin/bash: line 0: cd: /usr/src/linux-headers-: No such file or directorymake: *** No rule to make target `headers_install'. Stop.make: *** No rule to make target `scripts'. Stop.dpkg-deb: error: failed to read archive `/root/armbian3/output/debs/linux-headers-banana_4.4_armhf.deb': No such file or directorydpkg-deb: error: failed to read archive `/root/armbian3/output/debs/linux-headers-banana_4.4_armhf.deb': No such file or directorycp: cannot copy a directory, ‘.’, into itself, ‘/root/armbian3/output/cache/building/repack/usr/src/linux-headers-/.’dpkg-deb: error: failed to open package info file `/root/armbian3/output/cache/building/repack/DEBIAN/control' for reading: No such file or directorytar: ./building/linux-cache-banana_4.4_armhf.deb.tgz: file changed as we read ittar: ./sdcard/run/dbus/system_bus_socket: socket ignoredtar: ./sdcard/run/sdp: socket ignoredtar: ./sdcard/proc/sys/net/ipv4/route/flush: Cannot open: Permission deniedtar: ./sdcard/proc/sys/net/ipv6/route/flush: Cannot open: Permission deniedtar: ./sdcard/proc/sys/vm/compact_memory: Cannot open: Permission denied​ I don't have a problem building a 4.2 image.. the problem only seems to occur when trying to build an older image (based on 3.4 - 3.14). Any ideas as to what's going on and how I can fix it? Thanks.
Igor Posted September 23, 2015 Posted September 23, 2015 Yes, I broke it yesterday ... Fixed. Reboot and refresh build script.
