Hi
On fresh installed Armbian_23.5.1_Odroidn2_jammy_current_6.1.30_xfce_desktop when starting chromium-browser I get
odroidn2:~$ chromium-browser
Gtk-Message: 20:49:33.686: Failed to load module "xapp-gtk3-module"
libva error: vaGetDriverNameByIndex() failed with unknown libva error, driver_name = (null)
[18372:18372:0625/204934.172288:ERROR:gpu_init.cc(537)] Passthrough is not supported, GL is egl, ANGLE is
[18372:18372:0625/204934.232251:ERROR:gl_display.cc(508)] EGL Driver message (Error) eglQueryDeviceAttribEXT: eglQueryDeviceAttribEXT
[18372:18372:0625/204934.232523:ERROR:gl_angle_util_vulkan.cc(189)] Failed to retrieve vkGetInstanceProcAddr
[18372:18372:0625/204934.232712:ERROR:vulkan_instance.cc(91)] Failed to get vkGetInstanceProcAddr pointer from ANGLE.
MESA-LOADER: failed to retrieve device information
MESA-LOADER: failed to open zink: /usr/lib/dri/zink_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/aarch64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri)
failed to load driver: zink
MESA-LOADER: failed to open kms_swrast: /usr/lib/dri/kms_swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/aarch64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri)
failed to load driver: kms_swrast
MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/aarch64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri)
failed to load swrast driver
After that browser starts and runs normally.
Are there any suggestions to fix this?
To use mainline kernel hardware video acceleration in applications it requires basic support for V4L2-M2M hardware-accelerated video decode in the first place. E.g. firefox has just landed initial support for the h.264 decoder. The next showstopper would be the lack of V4L2-M2M support in the ffmpeg framework. There are some hack patches in the wild, but no out-of-the-box solution. The next showstopper would be the lack of kernel support for the SOC video decoder IP.
The lack of support in the application is a general problem for all devices that provide their decoders via V4L2-M2M. The lack of support in the ffmpeg framework is a problem for all applications that base on it. Gstreamer-based applications, on the other hand, offer out-of-the-box solutions, as the necessary support is already integrated into the mainline gstreamer framework.
When it comes to choosing a desktop environment, Xwindow is a bad choice. It was developed for x86 architecture and therefore cannot deal efficiently with V4L2-M2M requirements due to its design. Their developers at that time also recognized this and therefore developed Wayland from scratch. So when it comes to efficiently using a video pipeline in combination with a display pipeline, a desktop environment with Wayland backend is the first choice.
@usual user Thanks for your response.
I don't even try to play video, just start and browser with empty url string.
To my regret now firefox gives the similar error and there is no wayland based desktop for Odroid N2+ SBC yet.
It's a good thing that my distribution doesn't know about this rumor, otherwise it would probably have to stop working immediately. There are several Wayland implementations, e.g. the plasma-desktop or Gnome with Wayland backend. User space is not really device-specific and therefore no specific solution for a specific device is necessary. As long as there is sufficient mainline kernel support for the components of a device, this even works out-of-the-box, provided you choose suitable software programs. The operating system I'm using works unchanged according to the kernel support for all my devices comparably. The only solution that is not yet satisfactory is hardware-accelerated video decoding, as development for mainline support is still in full swing. But with a suitable SOC selection, there are solutions that leave almost nothing to be desired for comprehensive desktop operation. E.g. my rk3399 based device is feature complete for generic desktop usage. My rk3568-based device only lacks support for the rkvdec2 video decoder IP, the hantro support is already available. The worst is for the S922X, because there is currently no working video hardware acceleration in mainline. But with its CPU processing power, a video playback with moderate resolutions is still usable.
7 часов назад, usual user сказал:
Sorry but I didn't get have you used KDE+Armbian on N2+ or any other SBC with S922X?
Do you suggest trying the Armbian Jammy Gnome desktop distribution or installing KDE on a Armbian minimal distribution for N2+?
I didn't claim to use Armbian. I'm using an OS that is compiled for an entire architecture (aarch64) and not for a specific single device. It works for any SOC, provided that a kernel can be built that uses mainline APIs. I can use the same storage device that contains the OS with all my devices (NanoPC-T4, ODROID-N2+, ODROID-M1, HoneyComb, ...). OK, I have some media copies, as flipping back and forth when using multiple devices at the same time is very annoying and impractical. The only requirement for this to be possible is the presence of a firmware that can boot the OS. And here's where my dilemma begins. The OS is 100% FREE & OPEN SOURCE, i.e. it does not provide firmware based on binary blobs. Firmware with mainline U-Boot as payload fulfills all the necessary requirements to boot my OS from any storage media and I have learned over time how to build it for my own. Armbian has always been a great help here, whether it's with knowledge from their forum or with legacy firmware builds as a workaround for my device bring-up until I was able to switch to mainline firmware. And since I've shared my firmware builds here and in other places, I also have confirmations that builds also work for devices I don't own (ODROID-C4, ODROID-HC4, ODROID-N2, Radxa ROCK Pi 4B, Radxa ROCK Pi 4C, ...).
I would suggest you choose the OS you are most familiar with, or the one that best suits your needs as long as it uses recent mainline software. IMHO debian based distributions are way to stable ... outdated. Or you can find someone to  backport all mainline improvements and deploy them in the appropriate distribution.
