spi-nand kernel module is missing (please add kernel config option MTD_SPI_NAND=m)
Go to solution Solved by Igor,
A lot of spi-nand flashes is supported linux kernel. It will be very helpful to add a possibility to read/write/erase such flashes using standard linux support. Unfortunately spi-nand support is not enabled in armbian linux kernel.
example: recovery bootloader on the router board
  • Orange Pi 4 configuration
    1. Recompile orange pi 4 linux kernel to enable spi-nand driver (linux-5.10 or above is required). Make sure spinand, mtd and nandcore are built as modules
    2. sudo armbian-config, go to “System → DTC” and replace spidev with spinand
    3. install the following packages: mtd-utils
    4. reboot board to apply changes
  • Connect spi-nand chip to orange pi4 board
    Testpoint Meaning Where to connect
    3.3V 3.3V power supply pin 17 of orange pi 4 connector
    DI SPI Data In pin 19 of orange pi 4 connector
    DO SPI Data Out pin 21 of orange pi 4 connector
    CLK SPI Clock pin 23 of orange pi 4 connector
    GND Ground pin 25 of orange pi 4connector
    CS# SPI Chip Select pin 24 of orange pi 4 connector
    WP# Write Protect short with HOLD# and 3.3V testpoints
    HOLD# Hold short with WP# and 3.3V testpoints
  • restart spinand and mtd modules
    rmmod ofpart spinand mtd nandcore
    modprobe spinand
    modprobe mtd
    make sure the flash was detected
    dmesg | tail -n 6
    [ 237.055291] spi-nand: probe of spi0.0 failed with error -524
    [ 383.913569] spi-id: 00, ef, aa, 21
    [ 383.913729] spi-id: ef, aa, 21, 00
    [ 383.913878] spi-id: ef, aa, 21, 00
    [ 383.913936] spi-nand spi0.0: Winbond SPI NAND was found.
    [ 383.913965] spi-nand spi0.0: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 64
  • Recovering bootloader
    Add partitions of your choice using
    mtdpart add /dev/mtd0 <PART_NAME>
    Erase & flash partition
    flash_erase /dev/mtd 0 0
    nandwrite /dev/mtd image_file
    Disconnect flash from orange pi board and test it
