Where is the en-us.utf variant Us intl with dead keys?
Go to solution Solved by Werner,
Hello,
I am attempting to set my armbian machine up to match my Arch install on my Intel box.
I like to use en-us. Utf8 with the 'US intl with dead keys' variant.  But I cannot find it.
Im currently using the intl variant but that requires the use of altgr. And doesn't work with my keyboard or me.
Is there something I need to install to get the 'with dead keys' variant which does not
Require the use of altgr?
  • Solution
dpkg-reconfigure locales to make sure en_US UTF8 is available and set default
dpkg-reconfigure keyboard-configuration should do the rest
I do seem to have some problems with my locale.
I've resorted to the manual method as I thought the configurator was broken.
This problem seems to be with locale-gen, not the configurator as the behavior is the same.
It generates locales for everything even though en_US.UTF-8 is the only line uncommented.
─(15:35:%)── grep -v "^#.*" /etc/locale.gen
en_US.UTF-8 UTF-8
It finally finished.  I'll continue with the next steps again and see how it goes.
My understanding is that the variant that should work is 'intl'.   I tried 'qwerty-us-deadkeys with no luck, but my locales were broken.
Thank you so much. I have no idea how it was so broken.
I installed months ago and dont remember too much about how that went.
My keyboard is happy now.
