stonetv Posted July 10, 2023 Posted July 10, 2023 The latest version Bookworm cannot start up when use udisk Perhaps the latest version of the kernel does not support USB drive startup。 The name of image is "Armbian_23.8.0-trunk.71_Aml-s9xx-box_bookworm_edge_6.4.2.img" The log is as follows: scanning bus 0 for devices... 2 USB Device(s) found scanning usb for storage devices... 1 Storage Device(s) found Found /extlinux/extlinux.conf Retrieving file: /extlinux/extlinux.conf reading /extlinux/extlinux.conf 522 bytes read in 28 ms (17.6 KiB/s) 1: Armbian Retrieving file: /uInitrd reading /uInitrd 22828930 bytes read in 679 ms (32.1 MiB/s) Retrieving file: /Image reading /Image 27617792 bytes read in 802 ms (32.8 MiB/s) append: root=UUID=deeabe18-1741-4611-8a5a-3581d9f4f77b rootflags=data=writeback console=ttyAML0,115200n8 console=tty0 rw no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 splash plymouth.ignore-serial-consoles Retrieving file: /dtb/amlogic/meson-g12a-u200.dtb reading /dtb/amlogic/meson-g12a-u200.dtb 72501 bytes read in 41 ms (1.7 MiB/s) [rsvmem] get fdtaddr NULL! rsvmem - reserve memory Usage: rsvmem check - check reserved memory rsvmem dump - dump reserved memory rsvmem check failed ## Loading init Ramdisk from Legacy Image at 03080000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 22828866 Bytes = 21.8 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK active_slot is <NULL> Unknown command 'store' - try 'help' No dtbo patitions found load dtb from 0x1000000 ...... ERROR: Did not find a cmdline Flattened Device Tree load dtb from 0x0 ...... ERROR: Did not find a cmdline Flattened Device Tree Could not find a valid device tree SCRIPT FAILED: continuing... ** Bad device usb 1 ** ** Bad device usb 2 ** ** Bad device usb 3 ** card out ** Bad device mmc 1 ** Failed to mount ext2 filesystem... ** Unrecognized filesystem type ** odroidn2#
billhu199 Posted January 11, 2024 Posted January 11, 2024 Same issue. Mine is also a similar g12a device. I tested from 23.8.1 - 23.11.1 and all have problems. But works fine on my gxl device. G12A:BL:0253b8:61aa2d;FEAT:E0F83180:2000;POC:F;RCY:0;EMMC:0;READ:0;0.0; bl2_stage_init 0x01 bl2_stage_init 0x81 hw id: 0x0000 - pwm id 0x01 bl2_stage_init 0xc1 bl2_stage_init 0x02 L0:00000000 L1:00000703 L2:00008267 L3:04000000 S1:00000000 B2:00002000 B1:e0f83180 TE: 96329 BL2 Built : 14:02:05, Nov 23 2020. g12a g966c864 - gongwei.chen@droid11-sz Board ID = 1 Set cpu clk to 24M Set clk81 to 24M CPU clk: 1200 MHz Set clk81 to 166.6M eMMC boot @ 0 sw8 s board id: 1 Load FIP HDR DDR from eMMC, src: 0x00010200, des: 0xfffd0000, size: 0x00004000, part: 0 fw parse done PIEI prepare done 00000000 emmc switch 1 ok ddr saved addr:00016000 Load ddr parameter from eMMC, src: 0x02c00000, des: 0xfffd0000, size: 0x00001000, part: 0 00000000 emmc switch 0 ok fastboot data verify result: 255 Cfg max: 12, cur: 1. Board id: 255. Force loop cfg LPDDR4 probe LPDDR4_PHY_V_0_1_22-Built : 15:59:30, May 25 2020. g12a gb6bfa83 - gongwei.chen@droid11-sz ddr clk to 1176MHz dmc_version 0000 Check phy result INFO : End of CA training INFO : End of initialization INFO : Training has run successfully! Check phy result INFO : End of initialization INFO : End of read enable training INFO : End of fine write leveling INFO : End of read dq deskew training INFO : End of MPR read delay center optimization INFO : End of Write leveling coarse delay INFO : End of read delay center optimization INFO : Training has run successfully! Check phy result INFO : End of initialization INFO : End of MPR read delay center optimization INFO : End of write delay center optimization INFO : End of read delay center optimization INFO : End of max read latency training INFO : Training has run successfully! 1D training succeed Check phy result INFO : End of initialization INFO : End of 2D read delay Voltage center optimization INFO : End of 2D read delay Voltage center optimization INFO : End of 2D write delay Voltage center optimization INFO : End of 2D write delay Voltage center optimization INFO : Training has run successfully! soc_vref_reg_value 0x 00000024 00000024 00000026 00000025 00000024 00000027 00000026 00000025 00000024 00000025 00000025 00000024 00000026 00000025 00000025 00000026 00000025 00000027 00000027 00000024 00000026 dram_vref_reg_value 0x 00000060 2D training succeed auto size-- 65535DDR cs0 size: 1024MB DDR cs1 size: 1024MB DMC_DDR_CTRL: 00e0001bDDR size: 2048MB cs0 DataBus test pass cs1 DataBus test pass cs0 AddrBus test pass cs1 AddrBus test pass non-sec scramble use zero key ddr scramble enabled 100bdlr_step_size ps== 447 result report boot times 1Enable ddr reg access 00000000 emmc switch 3 ok Authentication key not yet programmed get rpmb counter error 0x00000007 00000000 emmc switch 0 ok Load FIP HDR from eMMC, src: 0x00010200, des: 0x01700000, size: 0x00004000, part: 0 Load BL3X from eMMC, src: 0x00078200, des: 0x01768000, size: 0x000dac00, part: 0 BL33 CHK: 0x000000ff ADDR 017a7170 Load FIP HDR from eMMC, src: 0x00010200, des: 0x01700000, size: 0x00004000, part: 1 00000000 emmc switch 1 ok Load BL3X from eMMC, src: 0x00078200, des: 0x01768000, size: 0x000dac00, part: 1 0.0;M3 CHK:0;cm4_sp_mode 0 [Image: g12a_v1.1.3394-7d43064d5 2020-05-07 15:37:06 gongwei.chen@droid11-sz] OPS=0x70 ring efuse init 28 0c 70 00 01 15 11 00 00 09 35 38 39 41 48 50 [1.072094 Inits done] secure task start! high task start! low task start! boot bl31 NOTICE: BL31: v1.3(release):079690f10 NOTICE: BL31: Built : 16:11:33, Nov 8 2021 NOTICE: BL31: G12A normal boot! NOTICE: BL31: BL33 decompress pass ERROR: Error initializing runtime service opteed_fast U-Boot 2015.01 (Dec 30 2021 - 18:08:05) DRAM: 2 GiB Relocation Offset is: 76e3b000 mmu cfg end: 0x80000000 mmu cfg end: 0x80000000 spi_post_bind(spifc): req_seq = 0 register usb cfg[0][1] = 0000000077f387e8 NAND: get_sys_clk_rate_mtd() 292, clock setting 200! bus cycle0: 6,timing: 7 NAND device id: 0 ff ff ff ff ff No NAND device found!!! nand init failed: -6 get_sys_clk_rate_mtd() 292, clock setting 200! bus cycle0: 6,timing: 7 NAND device id: 0 ff ff ff ff ff No NAND device found!!! nand init failed: -6 MMC: aml_priv->desc_buf = 0x0000000073e2bd90 aml_priv->desc_buf = 0x0000000073e2e0d0 SDIO Port B: 0, SDIO Port 😄 1 co-phase 0x2, tx-dly 0, clock 400000 co-phase 0x2, tx-dly 0, clock 400000 co-phase 0x2, tx-dly 0, clock 400000 emmc/sd response timeout, cmd8, cmd->cmdarg=0x1aa, status=0x1ff2800 emmc/sd response timeout, cmd55, cmd->cmdarg=0x0, status=0x1ff2800 co-phase 0x2, tx-dly 0, clock 400000 co-phase 0x2, tx-dly 0, clock 40000000 [set_emmc_calc_fixed_adj][875]find fixed adj_delay=20 init_part() 297: PART_TYPE_AML [mmc_init] mmc init success Amlogic multi-dtb tool GZIP format, decompress... Multi dtb detected Multi dtb tool version: v2 . Support 3 dtbs. aml_dt soc: g12a platform: u212 variant: 2g dtb 0 soc: g12a plat: u212 vari: 1g dtb 1 soc: g12a plat: u212 vari: 2g dtb 2 soc: sm1 plat: ac213 vari: 2g Find match dtb: 1 start dts,buffer=0000000073e30920,dt_addr=0000000073e30920 get_partition_from_dts() 92: ret 0 Amlogic multi-dtb tool Single dtb detected parts: 18 00: logo 0000000000800000 1 01: recovery 0000000001800000 1 02: misc 0000000000800000 1 03: dtbo 0000000000800000 1 04: cri_data 0000000000800000 2 05: param 0000000001000000 2 06: boot 0000000001000000 1 set has_boot_slot = 0 07: rsv 0000000001000000 1 08: metadata 0000000001000000 1 09: vbmeta 0000000000200000 1 10: tee 0000000002000000 1 11: vendor 0000000014000000 1 12: odm 0000000008000000 1 13: system 0000000050000000 1 14: product 0000000008000000 1 15: cache 0000000040000000 2 16: backup 0000000040000000 2 17: data ffffffffffffffff 4 init_part() 297: PART_TYPE_AML eMMC/TSD partition table have been checked OK! crc32_s:0x1577dad == storage crc_pattern:0x1577dad!!! crc32_s:0xee152b83 == storage crc_pattern:0xee152b83!!! crc32_s:0x79f50f07 == storage crc_pattern:0x79f50f07!!! mmc env offset: 0x47400000 In: serial Out: serial Err: serial board_late_init: boardid = 0x1 reboot_mode=normal [store]To run cmd[emmc dtb_read 0x1000000 0x40000] _verify_dtb_checksum()-3476: calc eef30c2, store eef30c2 _verify_dtb_checksum()-3476: calc eef30c2, store eef30c2 dtb_read()-3691: total valid 2 update_old_dtb()-3672: do nothing Amlogic multi-dtb tool GZIP format, decompress... Multi dtb detected Multi dtb tool version: v2 . Support 3 dtbs. aml_dt soc: g12a platform: u212 variant: 2g dtb 0 soc: g12a plat: u212 vari: 1g dtb 1 soc: g12a plat: u212 vari: 2g dtb 2 soc: sm1 plat: ac213 vari: 2g Find match dtb: 1 amlkey_init() enter! [EFUSE_MSG]keynum is 4 vpu: driver version: v20190313 vpu: detect chip type: 8 vpu: clk_level default: 7(666667000Hz), max: 7(666667000Hz) vpu: clk_level in dts: 7 vpu: vpu_power_on vpu: set_vpu_clk vpu: set clk: 666667000Hz, readback: 666666667Hz(0x100) vpu: set_vpu_clk finish vpu: vpu_module_init_config vpp: vpp_init vpp: vpp osd2 matrix rgb2yuv.............. hdr_func 4, hdr_process_select 0x1 cvbs: cpuid:0x28 vdac_gsw_init: 0x0 cvbs: find clk_path: 0x0 cvbs: find performance_pal config cvbs: find performance_ntsc config hpd_state=0 do_hpd_detect: hdmimode=1080p60hz do_hpd_detect: colorattribute=rgb,8bit Saving Environment to aml-storage... mmc env offset: 0x47400000 Writing to MMC(1)... done aml_config_dtb 633 aml_config_dtb 663 co_phase = <0x00000003> caps2 = "??"_CAP2_HS200" status = "disabled" status = "okay" Net: dwmac.ff3f0000amlkey_init() enter! amlkey_init() 71: already init! [EFUSE_MSG]keynum is 4 wipe_data=successful wipe_cache=successful upgrade_step=2 reboot_mode:::: normal ext4logoLoadCmd=ext4load mmc 1:${logoPart} ${logoLoadAddr} ${ext4LogoPath} 6220854 bytes read in 180 ms (33 MiB/s) [imgread]load bmp from ext4 part okay bmp pixel: 24 [OSD]load fb addr from dts:/meson-fb [OSD]set initrd_high: 0x7f800000 [OSD]fb_addr for logo: 0x7f800000 [OSD]load fb addr from dts:/meson-fb [OSD]fb_addr for logo: 0x7f800000 [OSD]VPP_OFIFO_SIZE:0xfff01fff [CANVAS]canvas init [CANVAS]addr=0x7f800000 width=5760, height=2160 [OSD]osd_hw.free_dst_data: 0,719,0,575 [OSD]osd1_update_disp_freescale_enable vpp: vpp_matrix_update: 2 cvbs_performance_enhancement cvbs_config_hdmipll_g12a cvbs_set_vid2_clk vdac_enable: 1, module_sel:0x8 hdr_packet vpp: hdr_policy = 1 vpp: Rx hdr_info.hdr_sup_eotf_smpte_st_2084 = 0 amlkey_init() enter! amlkey_init() 71: already init! [EFUSE_MSG]keynum is 4 [KM]Error:f[key_manage_query_size]L515:key[oemkey] not programed yet Command: bcb uboot-command Start read misc partition datas! BCB hasn't any datas,exit! time_out = 7a120 key[0] = b8471420 key[1] = b847ff00 key[2] = 6699dd22 key[3] = 66994cb3 irkey - irkey <timeout> <key1> ...<keyN> - maximum value of N: 10 Usage: irkey - No additional help available. Hit Enter or space or Ctrl+C key to stop autoboot -- : 0 card out (Re)start USB... USB0: USB3.0 XHCI init start Register 3000140 NbrPorts 2 Starting the controller USB XHCI 1.10 scanning bus 0 for devices... 2 USB Device(s) found scanning usb for storage devices... init_part() 282: PART_TYPE_DOS 1 Storage Device(s) found reading s905_autoscript 537 bytes read in 23 ms (22.5 KiB/s) ## Executing script at 01020000 start amlogic old u-boot ## Error: "bootfromsd" not defined card out ** Bad device mmc 0 ** reading boot_android ** Unable to read file boot_android ** card out ** Bad device mmc 0 ** reading u-boot.ext 740080 bytes read in 68 ms (10.4 MiB/s) ## Starting application at 0x01000000 ... U-Boot 2015.01-dirty (Aug 14 2020 - 19:56:34) DRAM: 2 GiB Relocation Offset is: 76eec000 spi_post_bind(spifc): req_seq = 0 register usb cfg[0][1] = 0000000077f83f48 MMC: aml_priv->desc_buf = 0x0000000073edc7c0 aml_priv->desc_buf = 0x0000000073edeb00 SDIO Port 😄 0, SDIO Port B: 1 Using default environment In: serial Out: serial Err: serial vpu: error: vpu: check dts: FDT_ERR_BADMAGIC, load default parameters vpu: driver version: v20190313 vpu: detect chip type: 8 vpu: clk_level default: 7(666667000Hz), max: 7(666667000Hz) vpu: clk_level = 7 vpu: vpu_power_on vpu: set_vpu_clk vpu: set clk: 666667000Hz, readback: 666666667Hz(0x100) vpu: set_vpu_clk finish vpu: vpu_module_init_config vpp: vpp_init vpp: g12a/b osd1 matrix rgb2yuv .............. vpp: g12a/b osd2 matrix rgb2yuv.............. vpp: g12a/b osd3 matrix rgb2yuv.............. cvbs: cpuid:0x28 cvbs_config_hdmipll_g12a cvbs_set_vid2_clk co-phase 0x3, tx-dly 0, clock 400000 co-phase 0x3, tx-dly 0, clock 400000 co-phase 0x3, tx-dly 0, clock 400000 emmc/sd response timeout, cmd8, status=0x1ff2800 emmc/sd response timeout, cmd55, status=0x1ff2800 co-phase 0x3, tx-dly 0, clock 400000 co-phase 0x1, tx-dly 0, clock 40000000 aml_sd_retry_refix[983]:delay = 0x0,gadjust =0x2000 [mmc_startup] mmc refix success [mmc_init] mmc init success Failed to mount ext2 filesystem... ** Unrecognized filesystem type ** Failed to mount ext2 filesystem... ** Unrecognized filesystem type ** movi: not registered partition name, logo movi - Read/write command from/to SD/MMC for ODROID board Usage: movi <read|write> <partition|sector> <offset> <address> [<length>] - <read|write> the command to access the storage - <offset> the offset from the start of given partiton in lba - <address> the memory address to load/store from/to the storage device - [<length>] the size of the block to read/write in bytes - all parameters must be hexa-decimal only [OSD]check dts: FDT_ERR_BADMAGIC, load default fb_addr parameters [OSD]set initrd_high: 0x3d800000 [OSD]fb_addr for logo: 0x3d800000 [OSD]check dts: FDT_ERR_BADMAGIC, load default fb_addr parameters [OSD]fb_addr for logo: 0x3d800000 [OSD]VPP_OFIFO_SIZE:0xfff01fff [CANVAS]canvas init [CANVAS]addr=0x3d800000 width=5760, height=2160 cvbs: outputmode[1080p60hz] is invalid vpp: vpp_matrix_update: 2 set hdmitx VIC = 16 config HPLL = 5940000 frac_rate = 1 HPLL: 0x3b3a04f7 HPLL: 0x1b3a04f7 HPLLv1: 0xdb3a04f7 config HPLL done j = 6 vid_clk_div = 1 hdmitx phy setting done hdmitx: set enc for VIC: 16 enc_vpu_bridge_reset[1319] rx version is 1.4 or below div=10 Net: dwmac.ff3f0000MACADDR:02:00:00:11:15:01(from chipid) Hit Enter or space or Ctrl+C key to stop autoboot -- : 0 (Re)start USB... USB0: USB3.0 XHCI init start Register 3000140 NbrPorts 2 Starting the controller USB XHCI 1.10 scanning bus 0 for devices... 2 USB Device(s) found scanning usb for storage devices... 1 Storage Device(s) found Found /extlinux/extlinux.conf Retrieving file: /extlinux/extlinux.conf reading /extlinux/extlinux.conf 532 bytes read in 29 ms (17.6 KiB/s) 1: Armbian Retrieving file: /uInitrd reading /uInitrd 15122788 bytes read in 878 ms (16.4 MiB/s) Retrieving file: /Image reading /Image 27433472 bytes read in 1579 ms (16.6 MiB/s) append: root=UUID=b134c113-5cbe-4ccc-ab4a-6c24dde01dd3 rootflags=data=writeback console=ttyAML0,115200n8 console=tty0 rw no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 splash plymous Retrieving file: /dtb/amlogic/meson-g12a-u200.dtb reading /dtb/amlogic/meson-g12a-u200.dtb 72240 bytes read in 43 ms (1.6 MiB/s) [rsvmem] get fdtaddr NULL! rsvmem - reserve memory Usage: rsvmem check - check reserved memory rsvmem dump - dump reserved memory rsvmem check failed ## Loading init Ramdisk from Legacy Image at 03080000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 15122724 Bytes = 14.4 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK active_slot is <NULL> Unknown command 'store' - try 'help' No dtbo patitions found load dtb from 0x1000000 ...... ERROR: Did not find a cmdline Flattened Device Tree load dtb from 0x0 ...... ERROR: Did not find a cmdline Flattened Device Tree Could not find a valid device tree SCRIPT FAILED: continuing... ** Bad device usb 1 ** ** Bad device usb 2 ** ** Bad device usb 3 ** card out ** Bad device mmc 1 ** Failed to mount ext2 filesystem... ** Unrecognized filesystem type ** odroidn2#
SteeMan Posted January 11, 2024 Posted January 11, 2024 Known Issue: https://forum.armbian.com/topic/30245-cant-boot-with-2305-or-later-builds-on-s905x2-g12a-or-s905x3-sm1 1
