Yuri Nakonechny Posted September 28, 2015 Share Posted September 28, 2015 Hello, I am using clean 2.9 jessie build on Cubox-i. I am planning to move from 1*bare sata HDD boot to 2*sata HDDs with lvm mirroring. Somebody had tried to boot from lvm on such devices? Is it works out-of-box or need some tweak? Thanks, Yuri. Link to comment Share on other sites More sharing options...
Yuri Nakonechny Posted October 29, 2015 Author Share Posted October 29, 2015 Tried to do that after newly upgrade to 4.5 and... it doesn`t boot. What I have done: hdd clearly seen by the system as /dev/sda device; create new partition on whole hdd (320Gb); create physical device /dev/sda1; create group "vg0" and volume "system" within it; format it with ext4, mount as /mnt; do rsync from / to /mnt (as found in nand-sata-install script); change "root=/dev/mapper/vg0-system" parameter in boot.cmd; remove "rd.dm=0 rd.luks=0 rd.lvm=0 raid=noautodetect" from boot.cmd, make boot.scr; change fstab from mmcblk to "/dev/mapper/vg0-system"; reboot. Anybody have suggestions what is going wrong? UPD: It stuck with kernel message on screen: rtc-pcf8523 2-0068: hctosys: unable to read the hardware clock Link to comment Share on other sites More sharing options...
Igor Posted November 1, 2015 Share Posted November 1, 2015 UPD: It stuck with kernel message on screen: rtc-pcf8523 2-0068: hctosys: unable to read the hardware clock This is a bit odd. I guess with SD boot you don't get that? Regarding LVM ... don't have experiences if it works. Link to comment Share on other sites More sharing options...
